[mapguide-commits] r9632 - in sandbox/jng/312_hardening/Common/MapGuideCommon: Controller System
svn_mapguide at osgeo.org
Wed Nov 13 01:34:06 PST 2019
Author: jng
Date: 2019-11-13 01:34:05 -0800 (Wed, 13 Nov 2019)
New Revision: 9632
sandbox/jng/312_hardening/Common/MapGuideCommon/Controller/HtmlController.cpp
sandbox/jng/312_hardening/Common/MapGuideCommon/System/ConfigProperties.cpp
sandbox/jng/312_hardening/Common/MapGuideCommon/System/ConfigProperties.h
Add new configuration property to (globally) control whether QUERYMAPFEATURES is permitted to include bounds for any feature data returned.
Modified: sandbox/jng/312_hardening/Common/MapGuideCommon/Controller/HtmlController.cpp
--- sandbox/jng/312_hardening/Common/MapGuideCommon/Controller/HtmlController.cpp 2019-11-12 11:09:22 UTC (rev 9631)
+++ sandbox/jng/312_hardening/Common/MapGuideCommon/Controller/HtmlController.cpp 2019-11-13 09:34:05 UTC (rev 9632)
@@ -449,6 +449,16 @@
MgWktReaderWriter wktRw;
MgCoordinateSystemFactory csFactory;
+ // If specified, enable or suppress feature bounds inclusion
+ // TODO: Down the road, this could perhaps be configurable on a per-feature-source basis via
+ // its resource header metadata
+ MgConfiguration* conf = MgConfiguration::GetInstance();
+ bool includeFeatureBounds = true;
+ conf->GetBoolValue(MgConfigProperties::AgentPropertiesSection,
+ MgConfigProperties::AgentGlobalIncludeFeatureBoundsForQueryMapFeatures,
+ includeFeatureBounds,
+ MgConfigProperties::DefaultAgentGlobalIncludeFeatureBoundsForQueryMapFeatures);
Ptr<MgReadOnlyLayerCollection> selLayers = selectionSet->GetLayers();
if (NULL != selLayers.p)
@@ -541,7 +551,7 @@
xmlOut.append(L"<Feature>\n");
STRING geomPropName = selLayer->GetFeatureGeometryName();
- if (!reader->IsNull(geomPropName))
+ if (includeFeatureBounds && !reader->IsNull(geomPropName))
try
Modified: sandbox/jng/312_hardening/Common/MapGuideCommon/System/ConfigProperties.cpp
--- sandbox/jng/312_hardening/Common/MapGuideCommon/System/ConfigProperties.cpp 2019-11-12 11:09:22 UTC (rev 9631)
+++ sandbox/jng/312_hardening/Common/MapGuideCommon/System/ConfigProperties.cpp 2019-11-13 09:34:05 UTC (rev 9632)
@@ -553,6 +553,8 @@
const INT32 MgConfigProperties::DefaultAgentGlobalGetWfsFeaturesLimit = 0;
const STRING MgConfigProperties::AgentGlobalGetWmsFeatureInfoLimit = L"GlobalGetWmsFeatureInfoLimit";
const INT32 MgConfigProperties::DefaultAgentGlobalGetWmsFeatureInfoLimit = 0;
+const STRING MgConfigProperties::AgentGlobalIncludeFeatureBoundsForQueryMapFeatures = L"GlobalIncludeFeatureBoundsForQueryMapFeatures";
+const bool MgConfigProperties::DefaultAgentGlobalIncludeFeatureBoundsForQueryMapFeatures = true;
// OGC Properties
Modified: sandbox/jng/312_hardening/Common/MapGuideCommon/System/ConfigProperties.h
--- sandbox/jng/312_hardening/Common/MapGuideCommon/System/ConfigProperties.h 2019-11-12 11:09:22 UTC (rev 9631)
+++ sandbox/jng/312_hardening/Common/MapGuideCommon/System/ConfigProperties.h 2019-11-13 09:34:05 UTC (rev 9632)
@@ -961,8 +961,11 @@
/// Global limit for QUERYMAPFEATURES
static const STRING AgentGlobalMaxMapFeatureQueryLimit; /// value("GlobalMaxMapFeatureQueryLimit")
static const INT32 DefaultAgentGlobalMaxMapFeatureQueryLimit; /// value(0)
+ /// Global flag to toggle feature bounds inclusion in QUERYMAPFEATURES response
+ static const STRING AgentGlobalIncludeFeatureBoundsForQueryMapFeatures; /// value("GlobalIncludeFeatureBoundsForQueryMapFeatures")
+ static const bool DefaultAgentGlobalIncludeFeatureBoundsForQueryMapFeatures; /// value(true)
/// OGC PROPERTIES SECTION -------------------------------------------------------------------------------------------
/// Ogc properties
More information about the mapguide-commits
