[mapguide-commits] r9598 - in trunk/MgDev/UnitTest/TestData/Samples/Sheboygan: . Library/Samples Library/Samples/Sheboygan/Data Library/Samples/Sheboygan/FlexibleLayouts Library/Samples/Sheboygan/Layers Library/Samples/Sheboygan/Layers_Advanced Library/Samples/Sheboygan/Layouts Library/Samples/Sheboygan/Maps Library/Samples/Sheboygan/MapsTiled Library/Samples/Sheboygan/Symbols Library/Samples/Sheboygan/TileSets Library/Samples/Sheboygan/Watermarks
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Sep 2 04:51:01 PDT 2019
Author: jng
Date: 2019-09-02 04:51:01 -0700 (Mon, 02 Sep 2019)
New Revision: 9598
Added:
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml
   trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
Fix inconsistent Sheboygan package manifest. The fix was done by loading the package with Maestro in non-transactional mode, and re-creating the package using the Site Administrator, and then extracting the package contents back out to MgDev/UnitTest/TestData/Samples/Sheboygan.
The regenerated manifest is XML formatted to make future diffs easier to comprehend.
Fixes #2807
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,32 +3,32 @@
   <General>
     <IconName>FeatureSourceSdf</IconName>
   </General>
-  <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
+  <Security>
     <Inherited>true</Inherited>
   </Security>
   <Metadata>
     <Simple>
-      <Property xsi:noNamespaceSchemaLocation="Property-1.0.0.xsd">
+      <Property>
         <Name>_PrimarySRS</Name>
         <Value>EPSG:4326</Value>
       </Property>
+      <Property>
         <Name>_Bounds</Name>
         <Value><Bounds SRS="EPSG:4326" west="-87.74" south="43.68" east="-87.69" north="43.815"/></Value>
       </Property>
+      <Property>
         <Name>_Abstract</Name>
         <Value>Building Outlines.</Value>
       </Property>
+      <Property>
         <Name>_Keywords</Name>
         <Value>Buildings, Outlines</Value>
       </Property>
+      <Property>
         <Name>_Title</Name>
         <Value>Building Outlines</Value>
       </Property>
+      <Property>
         <Name>_IsPublished</Name>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,32 +3,32 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
       </Property>
+      <Property>
       </Property>
+      <Property>
         <Value>City Limits</Value>
       </Property>
+      <Property>
         <Value>City, Limits</Value>
       </Property>
+      <Property>
         <Name>_Title</Name>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,28 +3,28 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
       </Property>
+      <Property>
         <Value>Hydrographic Lines</Value>
       </Property>
+      <Property>
         <Value>Hydrography</Value>
       </Property>
+      <Property>
         <Name>_Title</Name>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,28 +3,28 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
       </Property>
+      <Property>
         <Value>Hydrographic Polygons</Value>
       </Property>
+      <Property>
         <Value>Hydrography, Hydrogaphic</Value>
       </Property>
+      <Property>
         <Name>_Title</Name>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,24 +3,24 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
       </Property>
+      <Property>
         <Value>Islands</Value>
       </Property>
+      <Property>
         <Name>_Title</Name>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,7 +3,7 @@
   <General>
   </General>
+  <Security>
   </Security>
 </ResourceDocumentHeader>
\ No newline at end of file
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,24 +3,24 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
       </Property>
+      <Property>
         <Value>Parcels</Value>
       </Property>
+      <Property>
         <Name>_Title</Name>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,7 +3,7 @@
   <General>
   </General>
+  <Security>
   </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,7 +3,7 @@
   <General>
   </General>
+  <Security>
   </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,7 +3,7 @@
   <General>
   </General>
+  <Security>
   </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,16 +3,16 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,20 +3,20 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
       </Property>
+      <Property>
         <Name>_Title</Name>
         <Value>Voting Districts</Value>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-<ResourceDocumentHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
-		<Inherited>true</Inherited>
-	</Security>
+<ResourceDocumentHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
+  <Security>
+    <Inherited>true</Inherited>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,32 +3,32 @@
   <General>
     <IconName>LayerDefinitionVector</IconName>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
         <Name>_Queryable</Name>
         <Value>1</Value>
       </Property>
+      <Property>
         <Value>Buildings in the city</Value>
       </Property>
+      <Property>
       </Property>
+      <Property>
         <Name>_Title</Name>
         <Value>Buildings</Value>
       </Property>
+      <Property>
         <Name>_Opaque</Name>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,28 +3,28 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
       </Property>
+      <Property>
         <Name>_Title</Name>
       </Property>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,28 +3,28 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
       </Property>
+      <Property>
         <Name>_Title</Name>
         <Value>Districts</Value>
       </Property>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,32 +3,32 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>Water features</Value>
       </Property>
+      <Property>
       </Property>
+      <Property>
         <Name>_Title</Name>
       </Property>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,32 +3,32 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
       </Property>
+      <Property>
       </Property>
+      <Property>
         <Name>_Title</Name>
       </Property>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,28 +3,28 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
       </Property>
+      <Property>
         <Name>_Title</Name>
       </Property>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,28 +3,28 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
       </Property>
+      <Property>
         <Name>_Title</Name>
         <Value>Roads</Value>
       </Property>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -3,32 +3,32 @@
   <General>
   </General>
+  <Security>
   </Security>
   <Metadata>
     <Simple>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>Railroad right of way</Value>
       </Property>
+      <Property>
       </Property>
+      <Property>
         <Name>_Title</Name>
         <Value>Tracks</Value>
       </Property>
+      <Property>
         <Value>0</Value>
       </Property>
+      <Property>
         <Value>1</Value>
       </Property>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1,6 +1,6 @@
-	</Security>
+  <Security>
+  </Security>
Added: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/_HEADER.xml	                        (rev 0)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/_HEADER.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -0,0 +1,6 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ResourceFolderHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourceFolderHeader-1.0.0.xsd">
+	<Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
+	</Security>
+</ResourceFolderHeader>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml	2019-09-02 11:42:24 UTC (rev 9597)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml	2019-09-02 11:51:01 UTC (rev 9598)
@@ -1 +1,2453 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no" ?><ResourcePackageManifest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourcePackageManifest-1.0.0.xsd"><Operations><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/_HEADER.xml</Value><Content
 Type>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/_HEADER.xml</Value><ContentType>
 text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/_HEADER.xml</Value><ContentType>text/xml
 </ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/_HEADER.xml</Value><Content
 Type>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Paramet
 ers><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><N
 ame>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerD
 efinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERE
 SOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0<
 /Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>
 Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.We
 bLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter
 ></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentTyp
 e></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboy
 gan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/Bas
 icSymbols.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>5594</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml</Valu
 e><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>22760</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Ope
 ration><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>8038400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>BuildingOutlines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Val
 ue>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Paramete
 rs><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_DATA_CityLimits.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>CityLimits.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Para
 meter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_DATA_HydrographicLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>768000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Ver
 sion><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf</Value><ContentType>application/octet-stream</ContentType><
 /Parameter><Parameter><Name>DATALENGTH</Name><Value>512000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicPolygons.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOUR
 CEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_DATA_Islands.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Islands.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Para
 meter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_DATA_LandUse.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>1996800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>LandUse.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Va
 lue></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_DATA_Parcels.sdf</Value><ContentType>application/octet-s
 tream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>11929600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Parcels.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><V
 alue>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_DATA_Rail.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>870400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Rail.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT<
 /Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>665600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>RoadCenterLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Dat
 a/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_DATA_Soils.sdf</Value><ContentT
 ype>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>4556800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Soils.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Nam
 e>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_DATA_Trees.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>6656000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Trees.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameter
 s><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>VotingDistricts.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Libr
 ary://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/
 Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.Water
 markDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition
 _HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value><
 /Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Pa
 rameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheb
 oygan/FlexibleLayouts/Slate.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/She
 boygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/
 Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Paramete
 r><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Vers
 ion><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Soils.L
 ayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURC
 E</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><
 Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentT
 ype>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Para
 meter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Ver
 sion><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0
 .0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>
 Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value></Parameter></Par
 ameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value
 ></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advance
 d/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml</Value><
 ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Op
 eration><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value></Parameter></P
 arameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml</Value><Con
 tentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESO
 URCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Par
 ameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Versi
 on>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition</Value></Parameter></Parameters></Operation></Operations></ResourcePackageManifest>
\ No newline at end of file
+<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
+<ResourcePackageManifest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourcePackageManifest-1.0.0.xsd">
+    <Operations>
+        <Operation>
+            <Name>SETRESOURCE</Name>
+            <Version>1.0.0</Version>
+            <Parameters>
+                <Parameter>
+                    <Name>HEADER</Name>
+                    <Value>Library/Samples/_HEADER.xml</Value>
+                    <ContentType>text/xml</ContentType>
+                </Parameter>
+                <Parameter>
+                    <Name>RESOURCEID</Name>
+                    <Value>Library://Samples/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layouts/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Symbols/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Symbols/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Watermarks/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Watermarks/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/FlexibleLayouts/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Maps/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Maps/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/TileSets/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/TileSets/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/MapsTiled/_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/MapsTiled/</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Name>DELETERESOURCE</Name>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>CONTENT</Name>
+                    <Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Name>SETRESOURCEDATA</Name>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_DATA_symbols.dwf</Value>
+                    <ContentType>application/octet-stream</ContentType>
+                </Parameter>
+                <Parameter>
+                    <Name>DATALENGTH</Name>
+                    <Value>5594</Value>
+                </Parameter>
+                <Parameter>
+                    <Name>DATANAME</Name>
+                    <Value>symbols.dwf</Value>
+                </Parameter>
+                <Parameter>
+                    <Name>DATATYPE</Name>
+                    <Value>File</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_DATA_symbols.dwf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>22760</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>8038400</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>BuildingOutlines.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_DATA_CityLimits.sdf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>307200</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>CityLimits.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_DATA_HydrographicLines.sdf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>768000</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>HydrographicLines.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>512000</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>HydrographicPolygons.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_DATA_Islands.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                    <Value>Islands.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_DATA_LandUse.sdf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>1996800</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>LandUse.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_DATA_Parcels.sdf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>11929600</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Parcels.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_DATA_Rail.sdf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>870400</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Rail.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>665600</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>RoadCenterLines.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_DATA_Soils.sdf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>4556800</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Soils.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_DATA_Trees.sdf</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>6656000</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Trees.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Name>DATA</Name>
+                    <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                    <Value>VotingDistricts.sdf</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition</Value>
+                </Parameter>
+            </Parameters>
+        </Operation>
+        <Operation>
+            <Parameters>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml</Value>
+                </Parameter>
+                <Parameter>
+                    <Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml</Value>
+                </Parameter>
+                <Parameter>
+                </Parameter>
+            </Parameters>
+        </Operation>
+    </Operations>
+</ResourcePackageManifest>
More information about the mapguide-commits mailing list
