[mapguide-commits] r9600 - trunk/MgDev/Web/src/ApacheAgent
svn_mapguide at osgeo.org
Wed Sep 11 04:07:08 PDT 2019
Author: jng
Date: 2019-09-11 04:07:08 -0700 (Wed, 11 Sep 2019)
New Revision: 9600
trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp
I was debugging a mysterious crash in httpd and encountered a case which is suspiciously similar to #2224.
This commit does not fix that problem. It merely moves the call to ApacheAgent.Initialize() into the main try/catch block of mgmapagent_handler() so that any exceptions thrown does not take down httpd.exe
Modified: trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp
--- trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp 2019-09-11 07:21:40 UTC (rev 9599)
+++ trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp 2019-09-11 11:07:08 UTC (rev 9600)
@@ -105,17 +105,17 @@
static int mgmapagent_handler (request_rec *r)
if (strcmp(r->handler, "mgmapagent_handler") != 0) // NOXLATE
return DECLINED;
- Initialize(r);
ApacheResponseHandler responseHandler(r);
MG_TRY()
+ Initialize(r);
// Construct self Url. It is embedded into the output stream
// of some requests (like GetMap). Use a fully qualified URL.
string serverName = GetServerVariable(r, MapAgentStrings::ServerName);
More information about the mapguide-commits
