[mapguide-commits] r9626 - sandbox/jng/mvt_alt/Common/Renderers/mvt
svn_mapguide at osgeo.org
Tue Sep 24 00:11:57 PDT 2019
Author: jng
Date: 2019-09-24 00:11:56 -0700 (Tue, 24 Sep 2019)
New Revision: 9626
Removed:
sandbox/jng/mvt_alt/Common/Renderers/mvt/mvt_tile_test.cpp
Remove unused test code
Deleted: sandbox/jng/mvt_alt/Common/Renderers/mvt/mvt_tile_test.cpp
--- sandbox/jng/mvt_alt/Common/Renderers/mvt/mvt_tile_test.cpp 2019-09-24 07:08:18 UTC (rev 9625)
+++ sandbox/jng/mvt_alt/Common/Renderers/mvt/mvt_tile_test.cpp 2019-09-24 07:11:56 UTC (rev 9626)
@@ -1,203 +0,0 @@
- * Project: MVT Translator
- * Purpose: Test Mapbox Vector Tile encoder
- * Author: Even Rouault, Even Rouault <even dot rouault at spatialys dot com>
- * Copyright (c) 2018, Even Rouault <even dot rouault at spatialys dot com>
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
- * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
-#define ADD_MVT_TILE_READ
-#include "mvt_tile.h"
-#include "mvt_tile.cpp"
-#include "cpl_conv.h"
-#include "cpl_error.h"
-#include "cpl_vsi.h"
-#include <limits>
-#include <memory>
-int main()
- MVTTile oEmptyTile;
- CPLAssert( oEmptyTile.getSize() == 0 );
- MVTTile oTile;
- MVTTileLayer* poLayer = new MVTTileLayer();
- oTile.addLayer( std::shared_ptr<MVTTileLayer>(poLayer) );
- CPLAssert( oTile.getSize() ==
- 1 /* layer key */ +
- 1 /* layer size*/ +
- 1 /* name key */ +
- 1 /* version size */ +
- 1 /* version key */ +
- 1 /* version */
- MVTTile oTile;
- MVTTileLayerFeature* poFeature = new MVTTileLayerFeature();
- poLayer->setVersion(2);
- poLayer->setName(std::string("my_layer"));
- poLayer->setExtent(4096);
- poLayer->addFeature( std::shared_ptr<MVTTileLayerFeature>(poFeature) );
- poLayer->addKey(std::string("key0"));
- MVTTileLayerValue oValue;
- oValue.setStringValue(std::string(""));
- poLayer->addValue(oValue);
- oValue.setStringValue(std::string("x"));
- oValue.setStringValue(std::string("1234567"));
- oValue.setStringValue(std::string("12345678"));
- oValue.setStringValue(std::string("123456789"));
- oValue.setIntValue(-1);
- oValue.setUIntValue(1);
- oValue.setSIntValue(-1);
- oValue.setFloatValue(1.25f);
- oValue.setDoubleValue(1.25);
- oValue.setBoolValue(true);
- oValue.setValue(123456);
- oValue.setValue(-123456);
- oValue.setValue(123456.0);
- oValue.setValue(-123456.0);
- oValue.setValue(1.25);
- oValue.setValue(1.256789);
- oValue.setValue(std::numeric_limits<double>::infinity());
- poFeature->setId(1);
- poFeature->addTag(0);
- poFeature->setType(MVTTileLayerFeature::GeomType::POINT);
- poFeature->addGeometry(9);
- poFeature->addGeometry(0);
- std::shared_ptr<MVTTileLayerFeature>(new MVTTileLayerFeature()) );
- oTile.addLayer( std::shared_ptr<MVTTileLayer>(new MVTTileLayer()) );
- poLayer = new MVTTileLayer();
- poLayer->addValue(MVTTileLayerValue());
- size_t nSize = oTile.getSize();
- GByte* pabyBuffer = static_cast<GByte*>(CPLMalloc(nSize));
- oTile.write(pabyBuffer);
- VSILFILE* fp = VSIFOpenL("out.gpb", "wb");
- if( fp )
- VSIFWriteL(pabyBuffer, 1, nSize, fp);
- VSIFCloseL(fp);
- MVTTile oTileDeserialized;
- bool bRet = oTileDeserialized.read(pabyBuffer, pabyBuffer + nSize);
- CPLAssert(bRet);
- size_t nSize2 = oTileDeserialized.getSize();
- CPLAssert(nSize == nSize2);
- GByte* pabyBuffer2 = static_cast<GByte*>(CPLMalloc(nSize2));
- oTileDeserialized.write(pabyBuffer2);
- CPLAssert(memcmp(pabyBuffer, pabyBuffer2, nSize) == 0);
- CPLFree(pabyBuffer);
- CPLFree(pabyBuffer2);
- return 0;
More information about the mapguide-commits
