[mapguide-commits] r9713 - trunk/MgDev/Oem/cpp-httplib
svn_mapguide at osgeo.org
Fri Aug 14 03:41:33 PDT 2020
Author: jng
Date: 2020-08-14 03:41:32 -0700 (Fri, 14 Aug 2020)
New Revision: 9713
trunk/MgDev/Oem/cpp-httplib/CHANGES.txt
Note initial version of cpp-httplib added for reference
Modified: trunk/MgDev/Oem/cpp-httplib/CHANGES.txt
--- trunk/MgDev/Oem/cpp-httplib/CHANGES.txt 2020-08-14 10:38:57 UTC (rev 9712)
+++ trunk/MgDev/Oem/cpp-httplib/CHANGES.txt 2020-08-14 10:41:32 UTC (rev 9713)
@@ -1,4 +1,9 @@
14 Aug 2020
-Added ability to register request paths (add_static_file_ignore) to not treat as static file requests. Needed so that requests for mapagent.fcgi do not try to get the physical file.
\ No newline at end of file
+Added ability to register request paths (add_static_file_ignore) to not treat as static file requests. Needed so that requests for mapagent.fcgi do not try to get the physical file.
+23 Jul 2020
+Added initial v0.7.1 release
More information about the mapguide-commits
