[mapguide-commits] r9715 - in trunk/Installer: . Libraries/MapGuide Web Extensions Libraries/MapGuide Web Extensions/Lang
svn_mapguide at osgeo.org
Fri Aug 14 05:55:52 PDT 2020
Author: jng
Date: 2020-08-14 05:55:52 -0700 (Fri, 14 Aug 2020)
New Revision: 9715
trunk/Installer/Features.xml
trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_en-US.wxl
trunk/Installer/Libraries/MapGuide Web Extensions/MapGuide Web Extensions.wixproj
trunk/Installer/Libraries/MapGuide Web Extensions/MapGuideWebExtensions.wxs
trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs
trunk/Installer/build.bat
#2811: Include MgDevHttpServer binaries in Windows installer
Modified: trunk/Installer/Features.xml
--- trunk/Installer/Features.xml 2020-08-14 12:07:34 UTC (rev 9714)
+++ trunk/Installer/Features.xml 2020-08-14 12:55:52 UTC (rev 9715)
@@ -8,4 +8,6 @@
<IdentifierOverride Pattern="Apache24\bin\httpd.exe" Identifier="HTTPD_EXE" />
<IdentifierOverride Pattern="Tomcat\bin\service.bat" Identifier="TOMCAT_SERVICE_BAT" />
<IdentifierOverride Pattern="Tomcat\bin\tomcat7.exe" Identifier="TOMCAT_EXE" />
+ <IdentifierOverride Pattern="DevHttpServer\MgDevHttpServer.exe" Identifier="DEV_HTTP_SERVER_EXE" />
+ <IdentifierOverride Pattern="www\webconfig.ini" Identifier="WEB_CONFIG_INI" />
</FeatureMap>
\ No newline at end of file
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_en-US.wxl
--- trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_en-US.wxl 2020-08-14 12:07:34 UTC (rev 9714)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_en-US.wxl 2020-08-14 12:55:52 UTC (rev 9715)
@@ -8,6 +8,8 @@
<String Id="WebExtPhpFeature_Description">A bundled version of PHP with MapGuide enabled.</String>
<String Id="WebExtTomcatFeature">Tomcat</String>
<String Id="WebExtTomcatFeature_Description">A bundled version of Tomcat with MapGuide enabled.</String>
+ <String Id="WebDevHttpServerFeature">Development HTTP Server</String>
+ <String Id="WebDevHttpServerFeature_Description">A simple development HTTP server to easily spin up a mapagent or static HTML/JS content for development/testing without IIS or Apache</String>
<String Id="WebExtHelpFeature">API Help</String>
<String Id="WebExtHelpFeature_Description">Web Extension API documentation</String>
<String Id="WebExtMapViewerFeature">Map Viewer files</String>
@@ -62,4 +64,5 @@
<String Id="Shortcut_GetMaestro">Get MapGuide Maestro</String>
<String Id="Shortcut_MapGuide">MapGuide Project Home</String>
<String Id="Shortcut_Trac">MapGuide Trac</String>
+ <String Id="Shortcut_DevHttpServer">Start MapGuide Development HTTP Server</String>
</WixLocalization>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/MapGuide Web Extensions.wixproj
--- trunk/Installer/Libraries/MapGuide Web Extensions/MapGuide Web Extensions.wixproj 2020-08-14 12:07:34 UTC (rev 9714)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/MapGuide Web Extensions.wixproj 2020-08-14 12:55:52 UTC (rev 9715)
@@ -55,6 +55,7 @@
<Compile Include="FileIncludes\incPhpFiles.wxs" />
<Compile Include="FileIncludes\incPhpViewerSampleFiles.wxs" />
<Compile Include="FileIncludes\incTomcatFiles.wxs" />
+ <Compile Include="FileIncludes\incDevHttpServerFiles.wxs" />
<Compile Include="FileIncludes\incWebInfFiles.wxs" />
<Compile Include="FileIncludes\incWebRootFiles.wxs" />
<Compile Include="IIS7.wxs" />
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/MapGuideWebExtensions.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/MapGuideWebExtensions.wxs 2020-08-14 12:07:34 UTC (rev 9714)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/MapGuideWebExtensions.wxs 2020-08-14 12:55:52 UTC (rev 9715)
@@ -156,6 +156,7 @@
</Component>
</Directory>
<Directory Id="TOMCATLOCATION" Name="Tomcat" />
+ <Directory Id="DEVHTTPSERVERLOCATION" Name="DevHttpServer" />
</Directory>
</DirectoryRef>
<Feature Id="WebExtensionsFeature" Title="!(loc.WebExtensionsFeature)" Level="1" Description="!(loc.WebExtensionsFeature_Description)" AllowAdvertise="no" TypicalDefault="install" InstallDefault="local">
@@ -178,6 +179,10 @@
<Feature Id="WebExtTomcatFeature" Title="!(loc.WebExtTomcatFeature)" Level="1" Description="!(loc.WebExtTomcatFeature_Description)" AllowAdvertise="no" TypicalDefault="install" InstallDefault="local" >
<ComponentGroupRef Id="group_TOMCATFILES"/>
</Feature>
+ <Feature Id="WebDevHttpServerFeature" Title="!(loc.WebDevHttpServerFeature)" Level="1" Description="!(loc.WebDevHttpServerFeature_Description)" AllowAdvertise="no" TypicalDefault="install" InstallDefault="local" >
+ <ComponentGroupRef Id="group_DEVHTTPSERVER"/>
+ <ComponentRef Id="DevHttpServerShortcutComponent"/>
+ </Feature>
<Feature Id="WebExtHelpFeature" Title="!(loc.WebExtHelpFeature)" Level="1" Description="!(loc.WebExtHelpFeature_Description)" AllowAdvertise="no" TypicalDefault="install" InstallDefault="local">
<ComponentGroupRef Id="group_HELPFILES" />
<ComponentRef Id="ApacheWebApiShortcutComponent"/>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs 2020-08-14 12:07:34 UTC (rev 9714)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs 2020-08-14 12:55:52 UTC (rev 9715)
@@ -220,6 +220,18 @@
KeyPath="yes" />
</RegistryKey>
</Component>
+ <Component Id="DevHttpServerShortcutComponent" Win64="$(var.Win64)" Guid="3517d6df-a723-4fb0-ac21-5b5de3a5cff3">
+ HACK: I'd prefer not to use relative paths below, but the variables for the paths in question
+ area "owned" by a different component, preventing their use here
+ <Shortcut Id="DevHttpServerShortcut"
+ Name="!(loc.Shortcut_DevHttpServer)"
+ Target="[#DEV_HTTP_SERVER_EXE]"
+ Arguments="-p 8028 -r ..\www -w ..\www\webconfig.ini"
+ WorkingDirectory="DEVHTTPSERVERLOCATION"/>
+ <RegistryValue Root="HKCU" Key="$(var.MgRegKey)\DevHttpServerShortcut" Name="installed" Type="integer" Value="1" KeyPath="yes"/>
+ </Component>
<Directory Id="WebResourcesLocation" Name="Web Resources">
<Component Id="WebShortcutsComponent" Win64="$(var.Win64)" Guid="7D2E24E9-533B-4119-A6D1-E48A33BF34C3">
<CreateFolder />
Modified: trunk/Installer/build.bat
--- trunk/Installer/build.bat 2020-08-14 12:07:34 UTC (rev 9714)
+++ trunk/Installer/build.bat 2020-08-14 12:55:52 UTC (rev 9715)
@@ -261,6 +261,9 @@
echo [generate]: Web - Tomcat
%PARAFFIN% -dir %MG_SOURCE%\Web\Tomcat -alias $(var.MgSource)\Web\Tomcat -custom TOMCATFILES -dirref WEBEXTENSIONSLOCATION %WIX_INC_WEB%\incTomcatFiles.wxs
+echo [generate]: Web - DevHttpServer
+%PARAFFIN% -dir %MG_SOURCE%\Web\DevHttpServer -alias $(var.MgSource)\Web\DevHttpServer -custom DEVHTTPSERVER -dirref WEBEXTENSIONSLOCATION %WIX_INC_WEB%\incDevHttpServerFiles.wxs
echo [generate]: Web - Help
%PARAFFIN% -dir %MG_SOURCE%\Web\www\help -alias $(var.MgSource)\Web\www\help -custom HELPFILES -dirref WEBROOTLOCATION %WIX_INC_WEB%\incHelpFiles.wxs
More information about the mapguide-commits
