[mapguide-commits] r9644 - in trunk/MgDev: . Common/MapGuideCommon/Controller Common/MapGuideCommon/MapLayer Common/MdfModel Common/MdfParser Common/PlatformBase/MapLayer Common/Schema Server/src/PostBuild Server/src/UnitTesting UnitTest/TestData/MdfModel Web/src/viewerfiles
svn_mapguide at osgeo.org
Wed Feb 5 01:12:21 PST 2020
Author: jng
Date: 2020-02-05 01:12:21 -0800 (Wed, 05 Feb 2020)
New Revision: 9644
Added:
trunk/MgDev/Common/Schema/LayerDefinition-4.0.0.xsd
trunk/MgDev/UnitTest/TestData/MdfModel/MdfTestDisabledBounds.ldf
trunk/MgDev/
trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
trunk/MgDev/Common/MdfModel/VectorLayerDefinition.cpp
trunk/MgDev/Common/MdfModel/VectorLayerDefinition.h
trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h
trunk/MgDev/Server/src/PostBuild/PostBuild.mak
trunk/MgDev/Server/src/UnitTesting/TestMdfModel.cpp
trunk/MgDev/Server/src/UnitTesting/TestMdfModel.h
trunk/MgDev/Web/src/viewerfiles/
trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ
Merged revision(s) 9635-9643 from sandbox/jng/layer_bbox_toggle:
Implement MapGuide RFC 178
Index: trunk/MgDev
--- trunk/MgDev 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev 2020-02-05 09:12:21 UTC (rev 9644)
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
## -19,6 +19,7 ##
/sandbox/jng/fusion_entrypoint_refactor:9400-9406
/sandbox/jng/geoprocessing:9205-9229
/sandbox/jng/geos34x:8256-8259
+/sandbox/jng/layer_bbox_toggle:9635-9643
/sandbox/jng/mvt:9527-9528,9535,9537,9546-9547
/sandbox/jng/mvt_alt:9604-9629
/sandbox/jng/ogc:9240-9255
Modified: trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
--- trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2020-02-05 09:12:21 UTC (rev 9644)
@@ -568,7 +568,7 @@
STRING geomPropName = selLayer->GetFeatureGeometryName();
- if (!reader->IsNull(geomPropName))
+ if (selLayer->GetIncludeBoundsForSelectedFeatures() && !reader->IsNull(geomPropName))
try
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2020-02-05 09:12:21 UTC (rev 9644)
@@ -166,6 +166,7 @@
if (m_expandInLegend) flags += 8;
if (m_needRefresh) flags += 16;
if (m_hasTooltips) flags += 32;
+ if (m_includeBoundsForSelectedFeatures) flags += 64;
helper->WriteUINT8(flags);
helper->WriteString(m_legendLabel);
helper->WriteBytes((const unsigned char*)&m_displayOrder, sizeof(double));
@@ -214,6 +215,7 @@
m_expandInLegend = (flags & 8) > 0;
m_needRefresh = (flags & 16) > 0;
m_hasTooltips = (flags & 32) > 0;
+ m_includeBoundsForSelectedFeatures = (flags & 64) > 0;
helper->GetString(m_legendLabel);
helper->GetData((void*)&m_displayOrder, sizeof(double));
Modified: trunk/MgDev/Common/MdfModel/VectorLayerDefinition.cpp
--- trunk/MgDev/Common/MdfModel/VectorLayerDefinition.cpp 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Common/MdfModel/VectorLayerDefinition.cpp 2020-02-05 09:12:21 UTC (rev 9644)
@@ -33,7 +33,7 @@
VectorLayerDefinition::VectorLayerDefinition(const MdfString& strDataResourceID, const MdfString &strFeatureName)
: LayerDefinition(strDataResourceID)
-, m_strFeatureName(strFeatureName)
+, m_strFeatureName(strFeatureName), m_includeBoundsForSelectedFeatures(true)
// default values
this->m_featureNameType = FeatureClass;
@@ -92,6 +92,17 @@
this->m_featureNameType = featureNameType;
+// Property : IncludeBoundsForSelectedFeatures
+bool VectorLayerDefinition::GetIncludeBoundsForSelectedFeatures() const
+ return m_includeBoundsForSelectedFeatures;
+void VectorLayerDefinition::SetIncludeBoundsForSelectedFeatures(bool flag)
+ m_includeBoundsForSelectedFeatures = flag;
// PURPOSE: Accessor method for the PropertyMappings property. The PropertyMappings
// is a collection of objects, each of which defines a pair of
Modified: trunk/MgDev/Common/MdfModel/VectorLayerDefinition.h
--- trunk/MgDev/Common/MdfModel/VectorLayerDefinition.h 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Common/MdfModel/VectorLayerDefinition.h 2020-02-05 09:12:21 UTC (rev 9644)
@@ -58,6 +58,10 @@
const MdfString& GetFilter() const;
void SetFilter(const MdfString& strFilter);
+ // Property : IncludeBoundsForSelectedFeatures
+ bool GetIncludeBoundsForSelectedFeatures() const;
+ void SetIncludeBoundsForSelectedFeatures(bool flag);
// Property : Properties
NameStringPairCollection* GetPropertyMappings();
@@ -87,6 +91,9 @@
// The meaning of the string in the FeatureName property.
FeatureNameType m_featureNameType;
+ // Controls whether to include bounding box data for features selected from this layer
+ bool m_includeBoundsForSelectedFeatures;
// Collection of attributes that are to be associated with each feature
// returned to the client by this data setup.
NameStringPairCollection m_collPropertyMappings;
Modified: trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp
--- trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp 2020-02-05 09:12:21 UTC (rev 9644)
@@ -43,6 +43,7 @@
ELEM_MAP_ENTRY(13, Watermarks);
ELEM_MAP_ENTRY(14, Watermark);
ELEM_MAP_ENTRY(15, UrlData);
+ELEM_MAP_ENTRY(16, IncludeBoundsForSelectedFeatures);
IOVectorLayerDefinition::IOVectorLayerDefinition(Version& version) : SAX2ElementHandler(version)
@@ -153,6 +154,13 @@
this->m_layer->SetGeometry(ch);
break;
+ case eIncludeBoundsForSelectedFeatures:
+ bool flag = (::wcscmp(ch, L"true") == 0);
+ this->m_layer->SetIncludeBoundsForSelectedFeatures(flag);
+ break;
case eUrl:
// Handle layer definition <= 2.3.0
if (m_version <= Version(2, 3, 0))
@@ -218,7 +226,7 @@
// LDF in MapGuide 2006
strVersion = L"1.0.0";
- else if ((*version >= Version(1, 0, 0)) && (*version <= Version(2, 4, 0)))
+ else if ((*version >= Version(1, 0, 0)) && (*version <= Version(4, 0, 0)))
// LDF in MapGuide 2007 - current
strVersion = version->ToString();
@@ -234,7 +242,7 @@
else
// use the current highest version
- strVersion = L"2.4.0";
+ strVersion = L"4.0.0";
fd << tab.tab() << "<LayerDefinition xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"LayerDefinition-" << EncodeString(strVersion) << ".xsd\" version=\"" << EncodeString(strVersion) << "\">" << std::endl; // NOXLATE
@@ -309,6 +317,14 @@
fd << endStr(sFilter) << std::endl;
+ if (!version || (*version >= Version(4, 0, 0)))
+ // Property: IncludeBoundsForSelectedFeatures
+ fd << tab.tab() << startStr(sIncludeBoundsForSelectedFeatures);
+ fd << EncodeString(vectorLayer->GetIncludeBoundsForSelectedFeatures() ? L"true" : L"false");
+ fd << endStr(sIncludeBoundsForSelectedFeatures) << std::endl;
// Property: PropertyMappings
for (int i=0; i<vectorLayer->GetPropertyMappings()->GetCount(); ++i)
IONameStringPair::Write(fd, sPropertyMapping, vectorLayer->GetPropertyMappings()->GetAt(i), version, tab);
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp 2020-02-05 09:12:21 UTC (rev 9644)
@@ -42,7 +42,8 @@
m_layers(NULL),
m_displayOrder(0.0),
m_resourceContent(L""),
- m_forceReadFromServer(false)
+ m_forceReadFromServer(false),
+ m_includeBoundsForSelectedFeatures(true)
@@ -62,7 +63,8 @@
m_layers(NULL),
m_definition = layerDefinition;
if(SAFE_ADDREF((MgResourceIdentifier*)m_definition) != NULL)
@@ -89,7 +91,8 @@
m_layers(NULL),
@@ -195,7 +198,6 @@
return m_visible;
// Alters the layers potential visibility.
// Note that setting this property to true will not necessarily guarantee the layer will be visible.
@@ -693,6 +695,9 @@
//get the geometry property
m_geometry = vl->GetGeometry();
+ //get flag for including feature bounds
+ m_includeBoundsForSelectedFeatures = vl->GetIncludeBoundsForSelectedFeatures();
// Drawing Layer
else if(dl != NULL)
@@ -848,4 +853,9 @@
throw new MgNotImplementedException(L"MgLayerBase.GetSpatialContexts",
__LINE__, __WFILE__, NULL, L"", NULL);
+bool MgLayerBase::GetIncludeBoundsForSelectedFeatures()
\ No newline at end of file
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h
--- trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h 2020-02-05 09:12:21 UTC (rev 9644)
@@ -1311,6 +1311,8 @@
virtual void SetLayerResourceContent(CREFSTRING resourceContent);
+ virtual bool GetIncludeBoundsForSelectedFeatures();
protected:
/// \brief
/// Destruct a MgLayerBase object
@@ -1369,6 +1371,7 @@
IdPropertyList m_idProps;
bool m_forceReadFromServer;
STRING m_filter;
Copied: trunk/MgDev/Common/Schema/LayerDefinition-4.0.0.xsd (from rev 9643, sandbox/jng/layer_bbox_toggle/Common/Schema/LayerDefinition-4.0.0.xsd)
--- trunk/MgDev/Common/Schema/LayerDefinition-4.0.0.xsd (rev 0)
+++ trunk/MgDev/Common/Schema/LayerDefinition-4.0.0.xsd 2020-02-05 09:12:21 UTC (rev 9644)
@@ -0,0 +1,1275 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="2.4.0">
+ <xs:include schemaLocation="SymbolDefinition-2.4.0.xsd"/>
+ <xs:include schemaLocation="PlatformCommon-1.0.0.xsd"/>
+ <xs:include schemaLocation="WatermarkDefinition-2.4.0.xsd"/>
+ <xs:element name="LayerDefinition">
+ <xs:annotation>
+ <xs:documentation>The specification of the data source and stylization for a layer.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:complexContent>
+ <xs:extension base="LayerDefinitionType">
+ <xs:attribute name="version" type="xs:string" use="required" fixed="4.0.0"/>
+ </xs:extension>
+ </xs:complexContent>
+ </xs:complexType>
+ </xs:element>
+ <xs:complexType name="LayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>Encapsulates the definition of a map layer.</xs:documentation>
+ </xs:annotation>
+ <xs:choice>
+ <xs:element name="DrawingLayerDefinition" type="DrawingLayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>A layer with a drawing (i.e., DWF) data source.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VectorLayerDefinition" type="VectorLayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>A layer with a vector data source; and stylization specification for the datum's geometry types.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GridLayerDefinition" type="GridLayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>A layer with a raster or grid data source.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ </xs:complexType>
+ <xs:annotation>
+ <xs:documentation>******************** Common types for all layer types ********************</xs:documentation>
+ </xs:annotation>
+ <xs:complexType name="BaseLayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>Specifies common properties for all layer types.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="ResourceId" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Link to the drawing data source.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Opacity" default="1.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Opacity at which to display the rendered data.</xs:documentation>
+ </xs:annotation>
+ <xs:simpleType>
+ <xs:restriction base="xs:double">
+ <xs:minInclusive value="0.0"/>
+ <xs:maxInclusive value="1.0"/>
+ </xs:restriction>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="Watermarks" type="WatermarkInstanceCollectionType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The collection of watermarks used in the layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:annotation>
+ <xs:documentation>******************** Drawing layer ********************</xs:documentation>
+ </xs:annotation>
+ <xs:complexType name="DrawingLayerDefinitionType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:extension base="BaseLayerDefinitionType">
+ <xs:sequence>
+ <xs:element name="Sheet" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The sheet of the DWF to use.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayerFilter" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The layers to show from the specified sheet. Show all layers if this is not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MinScale" type="xs:double" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The zoomed in part of the scale range. Defaults to 0 if not specified. Inclusive.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MaxScale" type="xs:double" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The zoomed out part of the scale range. Defaults to the application's maximum value if not specified. Exclusive.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:annotation>
+ <xs:documentation>******************** Vector layer ********************</xs:documentation>
+ </xs:annotation>
+ <xs:complexType name="VectorLayerDefinitionType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="FeatureName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Either a feature class or named extension.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="FeatureNameType" type="FeatureNameType"/>
+ <xs:element name="Filter" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A boolean FDO expression that specifies which features to return. No filter means pass all features through.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="IncludeBoundsForSelectedFeatures" type="xs:boolean" default="true">
+ <xs:annotation>
+ <xs:documentation>Controls whether bounding box data is included with selected features when selecting from this layer</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PropertyMapping" type="NameStringPairType" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>Specifies which properties to expose to the user and its corresponding friendly name.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Geometry" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Specifies the geometry property that should be used to get the geometries.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="UrlData" type="URLDataType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The optional URL information associated with each feature.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ToolTip" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The text to put into the tooltip for displayed features. This is a string FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VectorScaleRange" type="VectorScaleRangeType" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>The stylization to be applied to the features for a given scale range.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:simpleType name="FeatureNameType">
+ <xs:annotation>
+ <xs:documentation>Enumeration describing whether the features are coming from a feature class or named extension</xs:documentation>
+ </xs:annotation>
+ <xs:restriction base="xs:string">
+ <xs:enumeration value="FeatureClass"/>
+ <xs:enumeration value="NamedExtension"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="URLDataType">
+ <xs:annotation>
+ <xs:documentation>URL information for features.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Content" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The real address of the URL. This can be a string FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Description" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The description of the URL. This can be a string FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ContentOverride" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specify the the override of URL content for a specific feature which can be a string FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DescriptionOverride" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specify the override of URL description for a specific feature which can be a string FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="VectorScaleRangeType">
+ <xs:annotation>
+ <xs:documentation>The stylization to be applied to the vector features for a given scale range.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:choice minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>Note that where there is no style specified for a particular geometry type a default styling should be used.</xs:documentation>
+ </xs:annotation>
+ <xs:element name="AreaTypeStyle" type="AreaTypeStyleType">
+ <xs:annotation>
+ <xs:documentation>Style specification of a polygon geometry type.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineTypeStyle" type="LineTypeStyleType">
+ <xs:annotation>
+ <xs:documentation>Style specification of a line geometry type.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PointTypeStyle" type="PointTypeStyleType">
+ <xs:annotation>
+ <xs:documentation>Style specification of a point geometry type.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CompositeTypeStyle" type="CompositeTypeStyle">
+ <xs:annotation>
+ <xs:documentation>A composite style definition.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ <xs:element name="ElevationSettings" type="ElevationSettingsType" minOccurs="0"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ElevationSettingsType">
+ <xs:sequence>
+ <xs:element name="ZOffset" type="xs:string" minOccurs="0"/>
+ <xs:element name="ZExtrusion" type="xs:string" minOccurs="0"/>
+ <xs:element name="ZOffsetType" type="ElevationTypeType" default="RelativeToGround" minOccurs="0"/>
+ <xs:element name="Unit" type="LengthUnitType" default="Centimeters" minOccurs="0"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="ElevationTypeType">
+ <xs:annotation>
+ <xs:documentation>The possible interpretations of a z offset value.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="RelativeToGround"/>
+ <xs:enumeration value="Absolute"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="PointTypeStyleType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="DisplayAsText" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Create a text layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="AllowOverpost" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Allows labels from any map layer (including the current layer) to obscure features on the current layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PointRule" type="PointRuleType" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>One or more PointRules defining the PointTypeStyle.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ShowInLegend" type="xs:boolean" default="true" minOccurs="0"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="PointRuleType">
+ <xs:annotation>
+ <xs:documentation>Style rule for a point geometry type.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="LegendLabel" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The label for the Rule to be displayed in the legend.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>A filter for the Rule. This is a boolean FDO expression. Any features that pass this filter are styled using this rule's stylization.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Label" type="TextSymbolType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A label for the Rule.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:choice minOccurs="0">
+ <xs:element name="PointSymbolization2D" type="PointSymbolization2DType"/>
+ </xs:choice>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="PointSymbolizationType">
+ <xs:annotation>
+ <xs:documentation>Base point symbolization type.</xs:documentation>
+ </xs:annotation>
+ </xs:complexType>
+ <xs:complexType name="PointSymbolization2DType">
+ <xs:annotation>
+ <xs:documentation>The different types of point geometries.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:choice>
+ <xs:element name="Mark" type="MarkSymbolType">
+ <xs:annotation>
+ <xs:documentation>A predefined shape such as a square or circle.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Image" type="ImageSymbolType">
+ <xs:annotation>
+ <xs:documentation>A raster or image symbol. Note that these do not scale well, but sometimes this is all that you have. Supported formats are application specific.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Font" type="FontSymbolType">
+ <xs:annotation>
+ <xs:documentation>A symbol specified using a font character.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="W2D" type="W2DSymbolType">
+ <xs:annotation>
+ <xs:documentation>A vector symbol defined using a W2D stream.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Block" type="BlockSymbolType">
+ <xs:annotation>
+ <xs:documentation>A vector symbol specifed from a block.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="LineTypeStyleType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="LineRule" type="LineRuleType" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>Rules to define a theme.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="LineRuleType">
+ <xs:annotation>
+ <xs:documentation>Style rule for a line geometry type.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineSymbolization2D" type="StrokeType"/>
+ </xs:choice>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="AreaSymbolizationType">
+ <xs:annotation>
+ <xs:documentation>Symbolization characteristics for areas.</xs:documentation>
+ </xs:annotation>
+ </xs:complexType>
+ <xs:complexType name="AreaSymbolizationFillType">
+ <xs:annotation>
+ <xs:documentation>Describes the style of a polygon.</xs:documentation>
+ </xs:annotation>
+ <xs:extension base="AreaSymbolizationType">
+ <xs:sequence>
+ <xs:element name="Fill" type="FillType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The style of the polygon fill.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Stroke" type="StrokeType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The style of the polygon edge.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="AreaTypeStyleType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="AreaRule" type="AreaRuleType" maxOccurs="unbounded">
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="AreaRuleType">
+ <xs:annotation>
+ <xs:documentation>Style rule for an area geometry type.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:choice>
+ <xs:element name="AreaSymbolization2D" type="AreaSymbolizationFillType">
+ <xs:annotation>
+ <xs:documentation>The stylization of the polygon geometry.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="StrokeType">
+ <xs:annotation>
+ <xs:documentation>Encapsulates the stylization of a line.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="LineStyle" type="xs:string"/>
+ <xs:element name="Thickness" type="xs:string"/>
+ <xs:element name="Color" type="xs:string"/>
+ <xs:element name="Unit" type="LengthUnitType">
+ <xs:annotation>
+ <xs:documentation>Unit of measurement that the thickness is specified in</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SizeContext" type="SizeContextType">
+ <xs:annotation>
+ <xs:documentation>Whether the sizes are with respect to the earth or the user's display device.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="FillType">
+ <xs:annotation>
+ <xs:documentation>Encapsulates the stylization of a polygon's fill.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="FillPattern" type="xs:string"/>
+ <xs:element name="ForegroundColor" type="xs:string"/>
+ <xs:element name="BackgroundColor" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The background color. Not applicable to solid fills.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="BackgroundStyleType">
+ <xs:annotation>
+ <xs:documentation>The possible background styles of a TextSymbol.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Transparent"/>
+ <xs:enumeration value="Opaque"/>
+ <xs:enumeration value="Ghosted"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="SizeContextType">
+ <xs:annotation>
+ <xs:documentation>Whether the sizes are specified as sizes on the earth or on the user's display device.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="MappingUnits"/>
+ <xs:enumeration value="DeviceUnits"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="LengthUnitType">
+ <xs:annotation>
+ <xs:documentation>The measurement units that linear sizes are specified in.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Millimeters"/>
+ <xs:enumeration value="Centimeters"/>
+ <xs:enumeration value="Meters"/>
+ <xs:enumeration value="Kilometers"/>
+ <xs:enumeration value="Inches"/>
+ <xs:enumeration value="Feet"/>
+ <xs:enumeration value="Yards"/>
+ <xs:enumeration value="Miles"/>
+ <xs:enumeration value="Points"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="TextSymbolType">
+ <xs:annotation>
+ <xs:documentation>Encapsulates the text label stylization used to label features, and for FontSymbols.</xs:documentation>
+ </xs:annotation>
+ <xs:extension base="SymbolType">
+ <xs:sequence>
+ <xs:element name="Text" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The text of the TextSymbol. This is a string FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="FontName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The font to use.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ForegroundColor" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The color of the text.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The text background color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="BackgroundStyle" type="BackgroundStyleType">
+ <xs:annotation>
+ <xs:documentation>The background style</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="HorizontalAlignment" type="xs:string" default="'Center'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A string FDO expression for the horizontal alignment. Must evaluate to one of the HorizontalAlignmentType enums. Only applicable to text styles.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VerticalAlignment" type="xs:string" default="'Baseline'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A string FDO expression for the vertical alignment. Must evaluate to one of the VerticalAlignmentType enums. Only applicable to text and line styles.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Bold" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies if the label should be in a bold font.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Italic" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies if the font should be italicized.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Underlined" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies if the text should be underlined.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="AdvancedPlacement" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Optional element which specifies that a more advanced labeling algorithm should be used with the AJAX viewer.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="ScaleLimit" type="xs:double" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The maximum amount any label is allowed to shrink in order to fit into the feature. For example, 0.8 means that the label can shrink until it is 80% of the original size. 1.0 means that the label cannot shrink. If not specified, the application should assume 1.0. If set to 0.0 or less then the advanced placement option is disabled.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="SymbolType">
+ <xs:annotation>
+ <xs:documentation>Defines common properties for all symbols.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The units that the sizes are specified in.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SizeX" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Width of the symbol. This is a double FDO expression. Does not apply to font symbols.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SizeY" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Height of the symbol. This is a double FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Rotation" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Amount to rotate the symbol in degrees. This is a double FDO expression. Does not apply to line labels.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MaintainAspect" type="xs:boolean" default="true" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Hint for the UI only. When the user enters a constant size for the width or height, the other dimension should be adjusted accordingly. Does not apply to font symbols or labels.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="InsertionPointX" type="xs:string" default="0.5" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>X offset for the symbol specified in symbol space. Does not apply to labels.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="InsertionPointY" type="xs:string" default="0.5" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Y offset for the symbol specified in symbol space. Does not apply to labels.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="MarkSymbolType">
+ <xs:annotation>
+ <xs:documentation>Stylization of a predefined shape (ShapeType).</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Shape" type="ShapeType"/>
+ <xs:annotation>
+ <xs:documentation>No fill is drawn if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Edge" type="StrokeType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>No edge is drawn if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="NameStringPairType">
+ <xs:annotation>
+ <xs:documentation>Used by vector layer definition to hold properties that can be displayed to the end user, and the friendly name to display it as.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Name" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the property to expose.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Value" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name to show the end user.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="ShapeType">
+ <xs:annotation>
+ <xs:documentation>SLD supports square, circle, triangle, star, cross, and X.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Square"/>
+ <xs:enumeration value="Circle"/>
+ <xs:enumeration value="Triangle"/>
+ <xs:enumeration value="Star"/>
+ <xs:enumeration value="Cross"/>
+ <xs:enumeration value="X"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="ImageSymbolType">
+ <xs:annotation>
+ <xs:documentation>Symbols that are comprised of a raster.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:choice>
+ <xs:element name="Image">
+ <xs:annotation>
+ <xs:documentation>Reference to the image.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="ResourceId">
+ <xs:annotation>
+ <xs:documentation>The reference to the resource.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LibraryItemName" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If ResourceId specifies a library, this identifies the name of a library item.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ <xs:element name="Content" type="xs:hexBinary">
+ <xs:annotation>
+ <xs:documentation>BinHex data for image.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="FontSymbolType">
+ <xs:annotation>
+ <xs:documentation>Symbols that are specified by a font and character.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>If the font is not installed, the actual font used is application dependent.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Character" type="xs:string"/>
+ <xs:element name="Bold" type="xs:boolean" minOccurs="0"/>
+ <xs:element name="Italic" type="xs:boolean" minOccurs="0"/>
+ <xs:element name="Underlined" type="xs:boolean" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="W2DSymbolType">
+ <xs:annotation>
+ <xs:documentation>A symbol using a W2D stream.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="W2DSymbol">
+ <xs:complexType>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The reference to the symbol library.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LibraryItemName">
+ <xs:annotation>
+ <xs:documentation>The W2D stream in the symbol library.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ <xs:element name="FillColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If specified all polygon fills in the symbol are drawn in this color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If specified all lines in the symbol are drawn in this color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TextColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If specified all text in the symbol is drawn in this color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="BlockSymbolType">
+ <xs:annotation>
+ <xs:documentation>A block symbol.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="DrawingName" type="xs:string"/>
+ <xs:element name="BlockName" type="xs:string"/>
+ <xs:element name="BlockColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Static color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayerColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="CompositeTypeStyle">
+ <xs:annotation>
+ <xs:documentation>A style specification consisting of composite rules.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="CompositeRule" type="CompositeRule" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>One or more CompositeRules defining the CompositeTypeStyle.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="CompositeRule">
+ <xs:annotation>
+ <xs:documentation>A style rule containing a composite symbolization.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CompositeSymbolization" type="CompositeSymbolization">
+ <xs:annotation>
+ <xs:documentation>The symbolization for the Rule.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="CompositeSymbolization">
+ <xs:annotation>
+ <xs:documentation>Stylization attributes of a point, line, or area feature.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="SymbolInstance" type="SymbolInstance" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>The symbol instances used for stylization.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ThemeLabel">
+ <xs:annotation>
+ <xs:documentation>Provides legend labeling information for a theme.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Description" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The legend description for the theme.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CategoryFormat" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The default legend format to use for each category in the theme.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="Override">
+ <xs:annotation>
+ <xs:documentation>A parameter override.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="SymbolName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the symbol definition containing the parameter being overridden.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ParameterIdentifier" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The identifier of the parameter being overridden.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ParameterValue" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The override value for the parameter.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ThemeLabel" type="ThemeLabel" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>An optional theme label for this override.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ParameterOverrides">
+ <xs:annotation>
+ <xs:documentation>A collection of parameter overrides.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Override" type="Override" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="UsageContextType">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed UsageContext values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Unspecified"/>
+ <xs:enumeration value="Point"/>
+ <xs:enumeration value="Line"/>
+ <xs:enumeration value="Area"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="GeometryContextType">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed GeometryContext values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="LineString"/>
+ <xs:enumeration value="Polygon"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="SymbolInstance">
+ <xs:annotation>
+ <xs:documentation>An instance of a symbol.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:choice>
+ <xs:annotation>
+ <xs:documentation>A library reference to an existing SymbolDefinition, either simple or compound.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SimpleSymbolDefinition" type="SimpleSymbolDefinition">
+ <xs:annotation>
+ <xs:documentation>An inlined SimpleSymbolDefinition.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CompoundSymbolDefinition" type="CompoundSymbolDefinition">
+ <xs:annotation>
+ <xs:documentation>An inlined CompoundSymbolDefinition.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ <xs:element name="ParameterOverrides" type="ParameterOverrides">
+ <xs:annotation>
+ <xs:documentation>Specifies all parameter overrides for this symbol instance.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ScaleX" type="xs:string" default="1.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The additional amount to scale the symbol horizontally in symbol space. Defaults to 1 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ScaleY" type="xs:string" default="1.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The additional amount to scale the symbol vertically in symbol space. Defaults to 1 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="InsertionOffsetX" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the additional amount to offset the symbol horizontally, in mm in device units, after scaling and rotation have been applied. Applies only to point symbols. Defaults to 0 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="InsertionOffsetY" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the additional amount to offset the symbol vertically, in mm in device units, after scaling and rotation have been applied. Applies only to point symbols. Defaults to 0 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SizeContext" type="SizeContextType" default="DeviceUnits" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies whether the symbol sizes are with respect to the map or the user's display device. Defaults to device units.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DrawLast" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Boolean value which specifies whether the symbol is drawn as part of a final rendering pass (e.g. for labeling). This must evaluate to True or False (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CheckExclusionRegion" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Boolean value which specifies whether to render this symbol only if its graphical extent does not overlap the exclusion region. If the positioning algorithm generates multiple candidate symbol positions and this setting is True, then only the first non-overlapping candidate is rendered. This must evaluate to True or False (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="AddToExclusionRegion" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Boolean value which specifies whether the graphical extent for this symbol instance is added to the exclusion region (if it is rendered). Symbols which check the exclusion region will not draw on top of this symbol. This must evaluate to True or False (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PositioningAlgorithm" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the algorithm used to generate candidate positions for the symbol. If specified this must evaluate to one of: Default, EightSurrounding, or PathLabels. Default means generate one position using the feature geometry (used for normal rendering). EightSurrounding means generate eight candidate labels surrounding the feature geometry (used when labeling point features). PathLabels means generate periodic labels which follow the feature geometry (used when labeling linestring features).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="RenderingPass" type="xs:string" default="0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The optional rendering pass in which this symbol instance draws. If specified this must be greater than or equal to zero. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="UsageContext" type="UsageContextType" default="Unspecified" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies which usage in the symbol should be the active one. Defaults to Unspecified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GeometryContext" type="GeometryContextType" default="Unspecified" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies which geometry type this symbol instance applies to. Defaults to Unspecified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:annotation>
+ <xs:documentation>******************** Grid layer ********************</xs:documentation>
+ </xs:annotation>
+ <xs:complexType name="GridLayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>A layer for raster or grid data.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="FeatureName" type="xs:string"/>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GridScaleRange" type="GridScaleRangeType" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="ChannelBandType">
+ <xs:annotation>
+ <xs:documentation>Defines how to scale numbers into a color channel.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Band" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Name of the band.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LowBand" type="xs:double" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Default is low value found in band. Band values less than this are snapped to this number.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="HighBand" type="xs:double" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Default is high value found in band. Band values greater than this are snapped to this number.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LowChannel" type="xs:unsignedByte" default="0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Default is 0. Range is 0:255. LowBand is mapped to this number. LowChannel can be greater than HighChannel.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="HighChannel" type="xs:unsignedByte" default="255" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Default is 255. Range is 0:255.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridColorBandsType">
+ <xs:annotation>
+ <xs:documentation>Specifies a color using distinct RGB values.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="RedBand" type="ChannelBandType"/>
+ <xs:element name="GreenBand" type="ChannelBandType"/>
+ <xs:element name="BlueBand" type="ChannelBandType"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridColorType">
+ <xs:annotation>
+ <xs:documentation>The color to use for a grid rule.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="ExplicitColor" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Explicit ARGB color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Band" type="xs:string"/>
+ <xs:element name="Bands" type="GridColorBandsType"/>
+ </xs:choice>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridColorRuleType">
+ <xs:annotation>
+ <xs:documentation>Encapsulate a style for a grid source.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>A label for the Rule. Does not apply to GridColorRule.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Color" type="GridColorType"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="HillShadeType">
+ <xs:annotation>
+ <xs:documentation>Specifies how to shade given a band and a light source.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>Name of the band used for the computation.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Azimuth" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>Azimuth of the sun in degrees.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Altitude" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>Altitude of the sun in degrees.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ScaleFactor" type="xs:double" default="1.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The scale factor applied to the band prior to computing hillshade. Defaults to 1 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridColorStyleType">
+ <xs:annotation>
+ <xs:documentation>Specifies how to style each pixel.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="HillShade" type="HillShadeType" minOccurs="0"/>
+ <xs:element name="TransparencyColor" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If a pixel color prior to factoring in HillShade is this value then the pixel is transparent.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="BrightnessFactor" type="xs:double" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Default is 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ContrastFactor" type="xs:double" default="0.0" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ColorRule" type="GridColorRuleType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridSurfaceStyleType">
+ <xs:annotation>
+ <xs:documentation>Specifies how to calculate pixel elevations.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>Band to use for 3D data.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ZeroValue" type="xs:double" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Determines which input value is mapped to zero elevation. Defaults to 0 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>Determines how to scale the inputs into a consistent elevation. Defaults to 1 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DefaultColor" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The default color to use if no ColorStyle is defined at a pixel.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridScaleRangeType">
+ <xs:annotation>
+ <xs:documentation>The stylization for a specified scale range.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SurfaceStyle" type="GridSurfaceStyleType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Defines the height field of the grid.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ColorStyle" type="GridColorStyleType" minOccurs="0"/>
+ <xs:element name="RebuildFactor" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>When the user has zoomed in by this amount, a request for more detailed raster data is made.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
Modified: trunk/MgDev/Server/src/PostBuild/PostBuild.mak
--- trunk/MgDev/Server/src/PostBuild/PostBuild.mak 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Server/src/PostBuild/PostBuild.mak 2020-02-05 09:12:21 UTC (rev 9644)
@@ -234,6 +234,7 @@
..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource \
..\..\bin\UnitTestFiles\MdfTestMap.mdf \
..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf \
+ ..\..\bin\UnitTestFiles\MdfTestDisabledBounds.ldf \
..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd \
..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd \
..\..\bin\UnitTestFiles\areasymbol.sd \
@@ -515,6 +516,7 @@
@@ -796,6 +798,7 @@
@@ -1077,6 +1080,7 @@
@@ -1231,6 +1235,7 @@
if EXIST ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource del /F ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource
if EXIST ..\..\bin\UnitTestFiles\MdfTestMap.mdf del /F ..\..\bin\UnitTestFiles\MdfTestMap.mdf
if EXIST ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf del /F ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf
+ if EXIST ..\..\bin\UnitTestFiles\MdfTestDisabledBounds.ldf del /F ..\..\bin\UnitTestFiles\MdfTestDisabledBounds.ldf
if EXIST ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd del /F ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd
if EXIST ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd del /F ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd
if EXIST ..\..\bin\UnitTestFiles\areasymbol.sd del /F ..\..\bin\UnitTestFiles\areasymbol.sd
@@ -1380,6 +1385,7 @@
@@ -1529,6 +1535,7 @@
@@ -1676,6 +1683,7 @@
@@ -1943,6 +1951,7 @@
@@ -2217,6 +2226,7 @@
@@ -2491,6 +2501,7 @@
@@ -2765,6 +2776,7 @@
@@ -2912,6 +2924,7 @@
@@ -3054,6 +3067,7 @@
@@ -3196,6 +3210,7 @@
@@ -3336,6 +3351,7 @@
@@ -3451,6 +3467,7 @@
"..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt" :
"..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf" :
"..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" :
+"..\..\..\UnitTest\TestData\MdfModel\MdfTestDisabledBounds.ldf" :
"..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" :
"..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd" :
"..\..\..\UnitTest\TestData\Symbology\areasymbol.sd" :
@@ -3795,6 +3812,10 @@
if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" ..\..\bin\UnitTestFiles\
+..\..\bin\UnitTestFiles\MdfTestDisabledBounds.ldf : "..\..\..\UnitTest\TestData\MdfModel\MdfTestDisabledBounds.ldf"
+ if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
+ if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestDisabledBounds.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestDisabledBounds.ldf" ..\..\bin\UnitTestFiles\
..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd : "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd"
if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" ..\..\bin\UnitTestFiles\
Modified: trunk/MgDev/Server/src/UnitTesting/TestMdfModel.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestMdfModel.cpp 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Server/src/UnitTesting/TestMdfModel.cpp 2020-02-05 09:12:21 UTC (rev 9644)
@@ -78,6 +78,11 @@
Ptr<MgByteReader> ldfrdr3 = ldfsrc3->GetReader();
m_svcResource->SetResource(ldfres3, ldfrdr3, NULL);
+ Ptr<MgResourceIdentifier> ldfres4 = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestDisabledBounds.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc4 = new MgByteSource(L"../UnitTestFiles/MdfTestDisabledBounds.ldf", false);
+ Ptr<MgByteReader> ldfrdr4 = ldfsrc4->GetReader();
+ m_svcResource->SetResource(ldfres4, ldfrdr4, NULL);
Ptr<MgResourceIdentifier> mdfres4 = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestMap.MapDefinition");
Ptr<MgByteSource> mdfsrc4 = new MgByteSource(L"../UnitTestFiles/MdfTestMap.mdf", false);
Ptr<MgByteReader> mdfrdr4 = mdfsrc4->GetReader();
@@ -122,6 +127,8 @@
m_svcResource->DeleteResource(sdres2);
Ptr<MgResourceIdentifier> ldfres3 = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestTypeStyles.LayerDefinition");
m_svcResource->DeleteResource(ldfres3);
+ m_svcResource->DeleteResource(ldfres4);
m_svcResource->DeleteResource(mdfres4);
Ptr<MgResourceIdentifier> mdfres5 = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestTileSet.TileSetDefinition");
@@ -186,7 +193,7 @@
CPPUNIT_ASSERT(parser.GetSucceeded());
// write the file - this exercises MdfParser serialization
- auto_ptr<SymbolDefinition> symbolDef1(parser.DetachSymbolDefinition());
+ unique_ptr<SymbolDefinition> symbolDef1(parser.DetachSymbolDefinition());
CPPUNIT_ASSERT(symbolDef1.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestSimpleSymbol_Copy1.sd", symbolDef1.get(), &symbolDefVersion);
@@ -198,7 +205,7 @@
Ptr<MgByteSink> sink1 = new MgByteSink(rdr1);
Ptr<MgByte> bytes1 = sink1->ToBuffer();
parser.ParseString((const char*)bytes1->Bytes(), bytes1->GetLength());
- auto_ptr<SymbolDefinition> symbolDef2(parser.DetachSymbolDefinition());
+ unique_ptr<SymbolDefinition> symbolDef2(parser.DetachSymbolDefinition());
CPPUNIT_ASSERT(symbolDef2.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestSimpleSymbol_Copy2.sd", symbolDef2.get(), &symbolDefVersion);
@@ -242,7 +249,7 @@
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_Copy1.sd", symbolDef1.get(), &symbolDefVersion);
@@ -254,7 +261,7 @@
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_Copy2.sd", symbolDef2.get(), &symbolDefVersion);
@@ -307,7 +314,7 @@
- auto_ptr<VectorLayerDefinition> layerDef1(parser.DetachVectorLayerDefinition());
+ unique_ptr<VectorLayerDefinition> layerDef1(parser.DetachVectorLayerDefinition());
CPPUNIT_ASSERT(layerDef1.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_Copy1.ldf", NULL, layerDef1.get(), NULL, NULL, NULL, NULL, &layerDefVersion);
@@ -319,7 +326,7 @@
- auto_ptr<VectorLayerDefinition> layerDef2(parser.DetachVectorLayerDefinition());
+ unique_ptr<VectorLayerDefinition> layerDef2(parser.DetachVectorLayerDefinition());
CPPUNIT_ASSERT(layerDef2.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_Copy2.ldf", NULL, layerDef2.get(), NULL, NULL, NULL, NULL, &layerDefVersion);
@@ -370,7 +377,7 @@
- auto_ptr<MapDefinition> mapDef1(parser.DetachMapDefinition());
+ unique_ptr<MapDefinition> mapDef1(parser.DetachMapDefinition());
CPPUNIT_ASSERT(mapDef1.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestMap_Copy1.mdf", mapDef1.get(), NULL, NULL, NULL, NULL, NULL, &mapDefVersion);
@@ -382,7 +389,7 @@
- auto_ptr<MapDefinition> mapDef2(parser.DetachMapDefinition());
+ unique_ptr<MapDefinition> mapDef2(parser.DetachMapDefinition());
CPPUNIT_ASSERT(mapDef2.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestMap_Copy2.mdf", mapDef2.get(), NULL, NULL, NULL, NULL, NULL, &mapDefVersion);
@@ -452,7 +459,7 @@
// write the file using each version - this exercises MdfParser serialization
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_v10_Copy1.sd", symbolDef1.get(), &symbolDefVersion10);
@@ -470,7 +477,7 @@
Ptr<MgByteSink> sink1_10 = new MgByteSink(rdr1_10);
Ptr<MgByte> bytes1_10 = sink1_10->ToBuffer();
parser.ParseString((const char*)bytes1_10->Bytes(), bytes1_10->GetLength());
- auto_ptr<SymbolDefinition> symbolDef2_10(parser.DetachSymbolDefinition());
+ unique_ptr<SymbolDefinition> symbolDef2_10(parser.DetachSymbolDefinition());
CPPUNIT_ASSERT(symbolDef2_10.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_v10_Copy2.sd", symbolDef2_10.get(), &symbolDefVersion10);
@@ -481,7 +488,7 @@
Ptr<MgByteSink> sink1_11 = new MgByteSink(rdr1_11);
Ptr<MgByte> bytes1_11 = sink1_11->ToBuffer();
parser.ParseString((const char*)bytes1_11->Bytes(), bytes1_11->GetLength());
- auto_ptr<SymbolDefinition> symbolDef2_11(parser.DetachSymbolDefinition());
+ unique_ptr<SymbolDefinition> symbolDef2_11(parser.DetachSymbolDefinition());
CPPUNIT_ASSERT(symbolDef2_11.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_v11_Copy2.sd", symbolDef2_11.get(), &symbolDefVersion11);
@@ -492,7 +499,7 @@
Ptr<MgByteSink> sink1_24 = new MgByteSink(rdr1_24);
Ptr<MgByte> bytes1_24 = sink1_24->ToBuffer();
parser.ParseString((const char*)bytes1_24->Bytes(), bytes1_24->GetLength());
- auto_ptr<SymbolDefinition> symbolDef2_24(parser.DetachSymbolDefinition());
+ unique_ptr<SymbolDefinition> symbolDef2_24(parser.DetachSymbolDefinition());
CPPUNIT_ASSERT(symbolDef2_24.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_v24_Copy2.sd", symbolDef2_24.get(), &symbolDefVersion24);
@@ -596,7 +603,7 @@
parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v09_Copy1.ldf", NULL, layerDef1.get(), NULL, NULL, NULL, NULL, &layerDefVersion09);
@@ -626,7 +633,7 @@
Ptr<MgByteSink> sink1_09 = new MgByteSink(rdr1_09);
Ptr<MgByte> bytes1_09 = sink1_09->ToBuffer();
parser.ParseString((const char*)bytes1_09->Bytes(), bytes1_09->GetLength());
- auto_ptr<VectorLayerDefinition> layerDef2_09(parser.DetachVectorLayerDefinition());
+ unique_ptr<VectorLayerDefinition> layerDef2_09(parser.DetachVectorLayerDefinition());
CPPUNIT_ASSERT(layerDef2_09.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v09_Copy2.ldf", NULL, layerDef2_09.get(), NULL, NULL, NULL, NULL, &layerDefVersion09);
@@ -637,7 +644,7 @@
- auto_ptr<VectorLayerDefinition> layerDef2_10(parser.DetachVectorLayerDefinition());
+ unique_ptr<VectorLayerDefinition> layerDef2_10(parser.DetachVectorLayerDefinition());
CPPUNIT_ASSERT(layerDef2_10.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v10_Copy2.ldf", NULL, layerDef2_10.get(), NULL, NULL, NULL, NULL, &layerDefVersion10);
@@ -648,7 +655,7 @@
- auto_ptr<VectorLayerDefinition> layerDef2_11(parser.DetachVectorLayerDefinition());
+ unique_ptr<VectorLayerDefinition> layerDef2_11(parser.DetachVectorLayerDefinition());
CPPUNIT_ASSERT(layerDef2_11.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v11_Copy2.ldf", NULL, layerDef2_11.get(), NULL, NULL, NULL, NULL, &layerDefVersion11);
@@ -659,7 +666,7 @@
Ptr<MgByteSink> sink1_12 = new MgByteSink(rdr1_12);
Ptr<MgByte> bytes1_12 = sink1_12->ToBuffer();
parser.ParseString((const char*)bytes1_12->Bytes(), bytes1_12->GetLength());
- auto_ptr<VectorLayerDefinition> layerDef2_12(parser.DetachVectorLayerDefinition());
+ unique_ptr<VectorLayerDefinition> layerDef2_12(parser.DetachVectorLayerDefinition());
CPPUNIT_ASSERT(layerDef2_12.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v12_Copy2.ldf", NULL, layerDef2_12.get(), NULL, NULL, NULL, NULL, &layerDefVersion12);
@@ -670,7 +677,7 @@
Ptr<MgByteSink> sink1_13 = new MgByteSink(rdr1_13);
Ptr<MgByte> bytes1_13 = sink1_13->ToBuffer();
parser.ParseString((const char*)bytes1_13->Bytes(), bytes1_13->GetLength());
- auto_ptr<VectorLayerDefinition> layerDef2_13(parser.DetachVectorLayerDefinition());
+ unique_ptr<VectorLayerDefinition> layerDef2_13(parser.DetachVectorLayerDefinition());
CPPUNIT_ASSERT(layerDef2_13.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v13_Copy2.ldf", NULL, layerDef2_13.get(), NULL, NULL, NULL, NULL, &layerDefVersion13);
@@ -681,7 +688,7 @@
Ptr<MgByteSink> sink1_23 = new MgByteSink(rdr1_23);
Ptr<MgByte> bytes1_23 = sink1_23->ToBuffer();
parser.ParseString((const char*)bytes1_23->Bytes(), bytes1_23->GetLength());
- auto_ptr<VectorLayerDefinition> layerDef2_23(parser.DetachVectorLayerDefinition());
+ unique_ptr<VectorLayerDefinition> layerDef2_23(parser.DetachVectorLayerDefinition());
CPPUNIT_ASSERT(layerDef2_23.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v23_Copy2.ldf", NULL, layerDef2_23.get(), NULL, NULL, NULL, NULL, &layerDefVersion23);
@@ -692,7 +699,7 @@
- auto_ptr<VectorLayerDefinition> layerDef2_24(parser.DetachVectorLayerDefinition());
+ unique_ptr<VectorLayerDefinition> layerDef2_24(parser.DetachVectorLayerDefinition());
CPPUNIT_ASSERT(layerDef2_24.get() != NULL);
parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy2.ldf", NULL, layerDef2_24.get(), NULL, NULL, NULL, NULL, &layerDefVersion24);
@@ -1062,4 +1069,47 @@
SAFE_RELEASE(e);
CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+void TestMdfModel::TestCase_LayerDef_DisabledBounds()
+ try
+ Ptr<MgResourceIdentifier> ldfId = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestDisabledBounds.LayerDefinition");
+ Ptr<MgByteReader> rdr = m_svcResource->GetResourceContent(ldfId);
+ MdfParser::SAX2Parser parser;
+ Ptr<MgByteSink> sink = new MgByteSink(rdr);
+ Ptr<MgByte> bytes = sink->ToBuffer();
+ CPPUNIT_ASSERT(bytes->GetLength() > 0);
+ parser.ParseString((const char*)bytes->Bytes(), bytes->GetLength());
+ CPPUNIT_ASSERT(parser.GetSucceeded());
+ unique_ptr<LayerDefinition> ldf(parser.DetachLayerDefinition());
+ CPPUNIT_ASSERT(ldf.get() != NULL);
+ VectorLayerDefinition* vl = dynamic_cast<VectorLayerDefinition*>(ldf.get());
+ CPPUNIT_ASSERT(vl != NULL);
+ CPPUNIT_ASSERT(!vl->GetIncludeBoundsForSelectedFeatures());
+ Ptr<MgLayer> layer = new MgLayer(ldfId, m_svcResource);
+ CPPUNIT_ASSERT(!layer->GetIncludeBoundsForSelectedFeatures());
+ Ptr<MgMemoryStreamHelper> helper = new MgMemoryStreamHelper();
+ Ptr<MgStream> stream = new MgStream(helper);
+ layer->Serialize(stream);
+ Ptr<MgLayer> layer2 = new MgLayer();
+ layer2->Deserialize(stream);
+ CPPUNIT_ASSERT(!layer2->GetIncludeBoundsForSelectedFeatures());
+ catch (MgException * e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
Modified: trunk/MgDev/Server/src/UnitTesting/TestMdfModel.h
--- trunk/MgDev/Server/src/UnitTesting/TestMdfModel.h 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Server/src/UnitTesting/TestMdfModel.h 2020-02-05 09:12:21 UTC (rev 9644)
@@ -31,6 +31,8 @@
CPPUNIT_TEST(TestCase_TileSetDefinitionDefault);
CPPUNIT_TEST(TestCase_TileSetDefinitionXYZ);
+ CPPUNIT_TEST(TestCase_LayerDef_DisabledBounds);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -48,6 +50,8 @@
void TestCase_TileSetDefinitionDefault();
void TestCase_TileSetDefinitionXYZ();
+ void TestCase_LayerDef_DisabledBounds();
private:
Ptr<MgResourceService> m_svcResource;
Copied: trunk/MgDev/UnitTest/TestData/MdfModel/MdfTestDisabledBounds.ldf (from rev 9643, sandbox/jng/layer_bbox_toggle/UnitTest/TestData/MdfModel/MdfTestDisabledBounds.ldf)
--- trunk/MgDev/UnitTest/TestData/MdfModel/MdfTestDisabledBounds.ldf (rev 0)
+++ trunk/MgDev/UnitTest/TestData/MdfModel/MdfTestDisabledBounds.ldf 2020-02-05 09:12:21 UTC (rev 9644)
@@ -0,0 +1,690 @@
+<?xml version="1.0" encoding="utf-8"?>
+<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="4.0.0" xsi:noNamespaceSchemaLocation="LayerDefinition-4.0.0.xsd">
+ <VectorLayerDefinition>
+ <ResourceId>Library://UnitTests/Data/Capitals.FeatureSource</ResourceId>
+ <Opacity>0.5</Opacity>
+ <Watermarks />
+ <FeatureName>SDF_2_Schema:CN_Capitals</FeatureName>
+ <FeatureNameType>FeatureClass</FeatureNameType>
+ <Filter>FilterString</Filter>
+ <IncludeBoundsForSelectedFeatures>false</IncludeBoundsForSelectedFeatures>
+ <PropertyMapping>
+ <Name>Name</Name>
+ <Value>Name</Value>
+ <ExtendedData1>
+ <NewElementA>
+ <SubElement>DataA</SubElement>
+ </NewElementA>
+ <NewElementB>DataB</NewElementB>
+ </ExtendedData1>
+ </PropertyMapping>
+ <PropertyMapping>
+ <Name>Url</Name>
+ <Value>Url</Value>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ <PropertyMapping>
+ <Name>Key</Name>
+ <Value>Key</Value>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ <Geometry>Data</Geometry>
+ <UrlData>
+ <Content>MyUrl</Content>
+ </UrlData>
+ <ToolTip>MyToolTip</ToolTip>
+ <VectorScaleRange>
+ <MinScale>10</MinScale>
+ <MaxScale>100000</MaxScale>
+ <PointTypeStyle>
+ <DisplayAsText>false</DisplayAsText>
+ <AllowOverpost>false</AllowOverpost>
+ <PointRule>
+ <LegendLabel>Composite</LegendLabel>
+ <Filter>Filter</Filter>
+ <Label>
+ <Unit>Points</Unit>
+ <SizeContext>DeviceUnits</SizeContext>
+ <SizeX>0</SizeX>
+ <SizeY>10</SizeY>
+ <Rotation>0</Rotation>
+ <MaintainAspect>false</MaintainAspect>
+ <InsertionPointX>0</InsertionPointX>
+ <InsertionPointY>0</InsertionPointY>
+ <Text>concat('District ', Autogenerated_SDF_ID)</Text>
+ <FontName>Verdana</FontName>
+ <ForegroundColor>FF625231</ForegroundColor>
+ <BackgroundColor>FFFFFFFF</BackgroundColor>
+ <BackgroundStyle>Transparent</BackgroundStyle>
+ <AdvancedPlacement>
+ <ScaleLimit>0.8</ScaleLimit>
+ </AdvancedPlacement>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Label>
+ <PointSymbolization2D>
+ <Mark>
+ <Unit>Inches</Unit>
+ <SizeX>0.6</SizeX>
+ <SizeY>0.06</SizeY>
+ <Rotation>15</Rotation>
+ <Shape>Triangle</Shape>
+ <Fill>
+ <FillPattern>Solid</FillPattern>
+ <ForegroundColor>FFFFFF00</ForegroundColor>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Fill>
+ <Edge>
+ <LineStyle>Solid</LineStyle>
+ <Thickness>0.0</Thickness>
+ <Color>FF000000</Color>
+ <Unit>Centimeters</Unit>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Edge>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Mark>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </PointSymbolization2D>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </PointRule>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </PointTypeStyle>
+ <LineTypeStyle>
+ <LineRule>
+ <Label>
+ <SizeX>0</SizeX>
+ <SizeY>10</SizeY>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Label>
+ <LineSymbolization2D>
+ <LineStyle>Rail</LineStyle>
+ <Thickness>0</Thickness>
+ <Color>FF646464</Color>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </LineSymbolization2D>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </LineRule>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </LineTypeStyle>
+ <AreaTypeStyle>
+ <AreaRule>
+ <Label>
+ <SizeX>0</SizeX>
+ <SizeY>10</SizeY>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Label>
+ <AreaSymbolization2D>
+ <Fill>
+ <ForegroundColor>FFC19E6A</ForegroundColor>
+ <BackgroundColor>FF000000</BackgroundColor>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Fill>
+ <Stroke>
+ <Color>FF808080</Color>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Stroke>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </AreaSymbolization2D>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </AreaRule>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </AreaTypeStyle>
+ <CompositeTypeStyle>
+ <CompositeRule>
+ <CompositeSymbolization>
+ <SymbolInstance>
+ <ResourceId>Library://UnitTests/Symbols/PointSymbolParam.SymbolDefinition</ResourceId>
+ <ParameterOverrides>
+ <Override>
+ <SymbolName>X_on_Box</SymbolName>
+ <ParameterIdentifier>COLOR</ParameterIdentifier>
+ <ParameterValue>ff00ff00</ParameterValue>
+ <ThemeLabel>
+ <Description>Theme description</Description>
+ <CategoryFormat>Theme category format</CategoryFormat>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </ThemeLabel>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Override>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </ParameterOverrides>
+ <SizeContext>MappingUnits</SizeContext>
+ <DrawLast>False</DrawLast>
+ <CheckExclusionRegion>False</CheckExclusionRegion>
+ <AddToExclusionRegion>False</AddToExclusionRegion>
+ <PositioningAlgorithm>'Default'</PositioningAlgorithm>
+ <UsageContext>Point</UsageContext>
+ <GeometryContext>Point</GeometryContext>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </SymbolInstance>
+ <SymbolInstance>
+ <CompoundSymbolDefinition>
+ <Name>MdfTestCompoundSymbol</Name>
+ <Description>A dummy symbol used to test the MdfModel/MdfParser code.</Description>
+ <SimpleSymbol>
+ <SimpleSymbolDefinition>
+ <Name>MdfTestSimpleSymbol</Name>
+ <Graphics>
+ <Path>
+ <ResizeControl>'AddToResizeBox'</ResizeControl>
+ <Geometry>M 0,0 L 5,0 L 5,5 L 0,5 L 0,0</Geometry>
+ <FillColor>ffff0000</FillColor>
+ <LineColor>%OUTLINE%</LineColor>
+ <LineWeight>2.0*(%THICKNESS% + 1.0)</LineWeight>
+ <LineWeightScalable>True</LineWeightScalable>
+ <LineCap>'None'</LineCap>
+ <LineJoin>'None'</LineJoin>
+ <LineMiterLimit>10.0</LineMiterLimit>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Path>
+ <Image>
+ <Content>R0lGODlhcgGSALMAAAQCAEMmCZtuMFQxDS8b</Content>
+ <SizeX>100.0</SizeX>
+ <SizeY>100.0</SizeY>
+ <SizeScalable>True</SizeScalable>
+ <Angle>0.0</Angle>
+ <PositionX>0.0</PositionX>
+ <PositionY>0.0</PositionY>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Image>
+ <Image>
+ <Reference>
+ <ResourceId>Library://ImageLibrary.SymbolDefinition</ResourceId>
+ <LibraryItemName>MyImage</LibraryItemName>
+ </Reference>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Image>
+ <Text>
+ <Content>'Some text'</Content>
+ <FontName>'Arial'</FontName>
+ <Bold>False</Bold>
+ <Italic>False</Italic>
+ <Underlined>False</Underlined>
+ <Overlined>True</Overlined>
+ <ObliqueAngle>%OBLIQUEANGLE%</ObliqueAngle>
+ <TrackSpacing>2.0</TrackSpacing>
+ <Height>10.0</Height>
+ <HeightScalable>True</HeightScalable>
+ <HorizontalAlignment>'Center'</HorizontalAlignment>
+ <VerticalAlignment>'Baseline'</VerticalAlignment>
+ <Justification>'Center'</Justification>
+ <LineSpacing>15.0</LineSpacing>
+ <TextColor>%TEXTCOLOR%</TextColor>
+ <GhostColor>ffffffff</GhostColor>
+ <Frame>
+ <LineColor>ff000000</LineColor>
+ <OffsetX>5.0</OffsetX>
+ <OffsetY>5.0</OffsetY>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Frame>
+ <Markup>'Rtf'</Markup>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Text>
+ </Graphics>
+ <ResizeBox>
+ <SizeX>50.0</SizeX>
+ <SizeY>10.0</SizeY>
+ <GrowControl>'GrowInXYMaintainAspect'</GrowControl>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </ResizeBox>
+ <PointUsage>
+ <AngleControl>'FromGeometry'</AngleControl>
+ <OriginOffsetX>0.0</OriginOffsetX>
+ <OriginOffsetY>0.0</OriginOffsetY>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </PointUsage>
+ <LineUsage>
+ <UnitsControl>'Absolute'</UnitsControl>
+ <VertexControl>'OverlapNone'</VertexControl>
+ <StartOffset>0.0</StartOffset>
+ <EndOffset>0.0</EndOffset>
+ <Repeat>10.0</Repeat>
+ <VertexAngleLimit>5.0</VertexAngleLimit>
+ <VertexJoin>'None'</VertexJoin>
+ <VertexMiterLimit>10.0</VertexMiterLimit>
+ <DefaultPath>
+ <LineColor>ff00ff00</LineColor>
+ <LineWeight>1.0</LineWeight>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </DefaultPath>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </LineUsage>
+ <AreaUsage>
+ <OriginControl>'Global'</OriginControl>
+ <ClippingControl>'Clip'</ClippingControl>
+ <OriginX>0.0</OriginX>
+ <OriginY>0.0</OriginY>
+ <RepeatX>10.0</RepeatX>
+ <RepeatY>5.0</RepeatY>
+ <BufferWidth>0.0</BufferWidth>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </AreaUsage>
+ <ParameterDefinition>
+ <Parameter>
+ <Identifier>OUTLINE</Identifier>
+ <DefaultValue>ffff0000</DefaultValue>
+ <DisplayName>Outline Color</DisplayName>
+ <Description>The color of the outline of the box.</Description>
+ <DataType>Color</DataType>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Parameter>
+ <Parameter>
+ <Identifier>THICKNESS</Identifier>
+ <DefaultValue>-0.5</DefaultValue>
+ <DisplayName>Line Thickness</DisplayName>
+ <Description>The thickness of the line in mm... minus 2 and halved.</Description>
+ <DataType>Real</DataType>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Parameter>
+ <Parameter>
+ <Identifier>TEXTCOLOR</Identifier>
+ <DefaultValue>ffffff00</DefaultValue>
+ <DisplayName>Text Color</DisplayName>
+ <Description>The color of the text.</Description>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Parameter>
+ <Parameter>
+ <Identifier>OBLIQUEANGLE</Identifier>
+ <DefaultValue>0.0</DefaultValue>
+ <DisplayName>Oblique Angle</DisplayName>
+ <Description>The oblique angle of the text.</Description>
+ <DataType>ObliqueAngle</DataType>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Parameter>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </ParameterDefinition>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </SimpleSymbolDefinition>
+ <RenderingPass>10</RenderingPass>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </SimpleSymbol>
+ <SimpleSymbol>
+ <ResourceId>Library://UnitTests/Symbols/MdfTestSimpleSymbol.SymbolDefinition</ResourceId>
+ <RenderingPass>20</RenderingPass>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </SimpleSymbol>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </CompoundSymbolDefinition>
+ <Override>
+ <ThemeLabel>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </ThemeLabel>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </Override>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ <ScaleX>2.0</ScaleX>
+ <ScaleY>2.0</ScaleY>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </SymbolInstance>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </CompositeSymbolization>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </CompositeRule>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </CompositeTypeStyle>
+ <ElevationSettings>
+ <ZOffset>0.0</ZOffset>
+ <ZExtrusion>0.0</ZExtrusion>
+ <Unit>Meters</Unit>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </ElevationSettings>
+ <ExtendedData1>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </VectorScaleRange>
+ <ExtendedData1>
+ <Watermarks>
+ <Watermark>
+ <Name>New Watermark Definition</Name>
+ <ResourceId>Library://UnitTests/Watermark/Text.WatermarkDefinition</ResourceId>
+ </Watermark>
+ </Watermarks>
+ <NewElementA>
+ </NewElementA>
+ </ExtendedData1>
+ </VectorLayerDefinition>
+</LayerDefinition>
\ No newline at end of file
Index: trunk/MgDev/Web/src/viewerfiles
--- trunk/MgDev/Web/src/viewerfiles 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Web/src/viewerfiles 2020-02-05 09:12:21 UTC (rev 9644)
Property changes on: trunk/MgDev/Web/src/viewerfiles
___________________________________________________________________
Modified: svn:mergeinfo
## -6,4 +6,5 ##
/sandbox/adsk/3.2o.AIMS/Web/src/viewerfiles:9136-9139
/sandbox/jng/clean_json/Web/src/viewerfiles:8818-9180
/sandbox/jng/createruntimemap/Web/src/viewerfiles:7486-7555
+/sandbox/jng/layer_bbox_toggle/Web/src/viewerfiles:9635-9643
/sandbox/jng/v30/Web/src/viewerfiles:8226-8227
\ No newline at end of property
Modified: trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ
--- trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ 2020-01-30 11:21:13 UTC (rev 9643)
+++ trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ 2020-02-05 09:12:21 UTC (rev 9644)
@@ -4243,9 +4243,11 @@
var feat = { /* INTERNAL_API */ selKey: ((msie && !msie10plus) ? selFeatEls[j].text : selFeatEls[j].textContent), values: [] };
var featEl = featEls[j];
var bounds = featEl.getElementsByTagName("Bounds")[0];
- var bbox = ((msie && !msie10plus) ? bounds.text : bounds.textContent).split(" ");
- feat.zoom = { minx: parseFloat(bbox[0]), miny: parseFloat(bbox[1]), maxx: parseFloat(bbox[2]), maxy: parseFloat(bbox[3]) };
+ if (bounds)
+ var bbox = ((msie && !msie10plus) ? bounds.text : bounds.textContent).split(" ");
+ feat.zoom = { minx: parseFloat(bbox[0]), miny: parseFloat(bbox[1]), maxx: parseFloat(bbox[2]), maxy: parseFloat(bbox[3]) };
var featVals = [];
var propEls = featEl.getElementsByTagName("Property");
for (var k = 0; k < propEls.length; k++)
More information about the mapguide-commits
