[mapguide-commits] r9637 - in sandbox/jng/layer_bbox_toggle/Common: MapGuideCommon/Controller MapGuideCommon/MapLayer MdfModel MdfParser PlatformBase/MapLayer
svn_mapguide at osgeo.org
Tue Jan 14 04:06:13 PST 2020
Author: jng
Date: 2020-01-14 04:06:13 -0800 (Tue, 14 Jan 2020)
New Revision: 9637
sandbox/jng/layer_bbox_toggle/Common/MapGuideCommon/Controller/HtmlController.cpp
sandbox/jng/layer_bbox_toggle/Common/MapGuideCommon/MapLayer/Layer.cpp
sandbox/jng/layer_bbox_toggle/Common/MdfModel/VectorLayerDefinition.cpp
sandbox/jng/layer_bbox_toggle/Common/MdfModel/VectorLayerDefinition.h
sandbox/jng/layer_bbox_toggle/Common/MdfParser/IOVectorLayerDefinition.cpp
sandbox/jng/layer_bbox_toggle/Common/PlatformBase/MapLayer/LayerBase.cpp
sandbox/jng/layer_bbox_toggle/Common/PlatformBase/MapLayer/LayerBase.h
MdfModel and runtime layer updates to support the new bounds inclusion flag. Use this flag to determine whether feature bounds are included for the QUERYMAPFEATURES response.
Modified: sandbox/jng/layer_bbox_toggle/Common/MapGuideCommon/Controller/HtmlController.cpp
--- sandbox/jng/layer_bbox_toggle/Common/MapGuideCommon/Controller/HtmlController.cpp 2020-01-14 11:22:47 UTC (rev 9636)
+++ sandbox/jng/layer_bbox_toggle/Common/MapGuideCommon/Controller/HtmlController.cpp 2020-01-14 12:06:13 UTC (rev 9637)
@@ -568,7 +568,7 @@
STRING geomPropName = selLayer->GetFeatureGeometryName();
- if (!reader->IsNull(geomPropName))
+ if (selLayer->GetIncludeBoundsForSelectedFeatures() && !reader->IsNull(geomPropName))
try
Modified: sandbox/jng/layer_bbox_toggle/Common/MapGuideCommon/MapLayer/Layer.cpp
--- sandbox/jng/layer_bbox_toggle/Common/MapGuideCommon/MapLayer/Layer.cpp 2020-01-14 11:22:47 UTC (rev 9636)
+++ sandbox/jng/layer_bbox_toggle/Common/MapGuideCommon/MapLayer/Layer.cpp 2020-01-14 12:06:13 UTC (rev 9637)
@@ -166,6 +166,7 @@
if (m_expandInLegend) flags += 8;
if (m_needRefresh) flags += 16;
if (m_hasTooltips) flags += 32;
+ if (m_includeBoundsForSelectedFeatures) flags += 64;
helper->WriteUINT8(flags);
helper->WriteString(m_legendLabel);
helper->WriteBytes((const unsigned char*)&m_displayOrder, sizeof(double));
@@ -214,6 +215,7 @@
m_expandInLegend = (flags & 8) > 0;
m_needRefresh = (flags & 16) > 0;
m_hasTooltips = (flags & 32) > 0;
+ m_includeBoundsForSelectedFeatures = (flags & 64) > 0;
helper->GetString(m_legendLabel);
helper->GetData((void*)&m_displayOrder, sizeof(double));
Modified: sandbox/jng/layer_bbox_toggle/Common/MdfModel/VectorLayerDefinition.cpp
--- sandbox/jng/layer_bbox_toggle/Common/MdfModel/VectorLayerDefinition.cpp 2020-01-14 11:22:47 UTC (rev 9636)
+++ sandbox/jng/layer_bbox_toggle/Common/MdfModel/VectorLayerDefinition.cpp 2020-01-14 12:06:13 UTC (rev 9637)
@@ -33,7 +33,7 @@
VectorLayerDefinition::VectorLayerDefinition(const MdfString& strDataResourceID, const MdfString &strFeatureName)
: LayerDefinition(strDataResourceID)
-, m_strFeatureName(strFeatureName)
+, m_strFeatureName(strFeatureName), m_includeBoundsForSelectedFeatures(true)
// default values
this->m_featureNameType = FeatureClass;
@@ -92,6 +92,17 @@
this->m_featureNameType = featureNameType;
+// Property : IncludeBoundsForSelectedFeatures
+bool VectorLayerDefinition::GetIncludeBoundsForSelectedFeatures() const
+ return m_includeBoundsForSelectedFeatures;
+void VectorLayerDefinition::SetIncludeBoundsForSelectedFeatures(bool flag)
+ m_includeBoundsForSelectedFeatures = flag;
// PURPOSE: Accessor method for the PropertyMappings property. The PropertyMappings
// is a collection of objects, each of which defines a pair of
Modified: sandbox/jng/layer_bbox_toggle/Common/MdfModel/VectorLayerDefinition.h
--- sandbox/jng/layer_bbox_toggle/Common/MdfModel/VectorLayerDefinition.h 2020-01-14 11:22:47 UTC (rev 9636)
+++ sandbox/jng/layer_bbox_toggle/Common/MdfModel/VectorLayerDefinition.h 2020-01-14 12:06:13 UTC (rev 9637)
@@ -58,6 +58,10 @@
const MdfString& GetFilter() const;
void SetFilter(const MdfString& strFilter);
+ // Property : IncludeBoundsForSelectedFeatures
+ bool GetIncludeBoundsForSelectedFeatures() const;
+ void SetIncludeBoundsForSelectedFeatures(bool flag);
// Property : Properties
NameStringPairCollection* GetPropertyMappings();
@@ -87,6 +91,9 @@
// The meaning of the string in the FeatureName property.
FeatureNameType m_featureNameType;
+ // Controls whether to include bounding box data for features selected from this layer
+ bool m_includeBoundsForSelectedFeatures;
// Collection of attributes that are to be associated with each feature
// returned to the client by this data setup.
NameStringPairCollection m_collPropertyMappings;
Modified: sandbox/jng/layer_bbox_toggle/Common/MdfParser/IOVectorLayerDefinition.cpp
--- sandbox/jng/layer_bbox_toggle/Common/MdfParser/IOVectorLayerDefinition.cpp 2020-01-14 11:22:47 UTC (rev 9636)
+++ sandbox/jng/layer_bbox_toggle/Common/MdfParser/IOVectorLayerDefinition.cpp 2020-01-14 12:06:13 UTC (rev 9637)
@@ -43,6 +43,7 @@
ELEM_MAP_ENTRY(13, Watermarks);
ELEM_MAP_ENTRY(14, Watermark);
ELEM_MAP_ENTRY(15, UrlData);
+ELEM_MAP_ENTRY(16, IncludeBoundsForSelectedFeatures);
IOVectorLayerDefinition::IOVectorLayerDefinition(Version& version) : SAX2ElementHandler(version)
@@ -153,6 +154,13 @@
this->m_layer->SetGeometry(ch);
break;
+ case eIncludeBoundsForSelectedFeatures:
+ bool flag = (::wcscmp(ch, L"true") == 0);
+ this->m_layer->SetIncludeBoundsForSelectedFeatures(flag);
+ break;
case eUrl:
// Handle layer definition <= 2.3.0
if (m_version <= Version(2, 3, 0))
@@ -218,7 +226,7 @@
// LDF in MapGuide 2006
strVersion = L"1.0.0";
- else if ((*version >= Version(1, 0, 0)) && (*version <= Version(2, 4, 0)))
+ else if ((*version >= Version(1, 0, 0)) && (*version <= Version(4, 0, 0)))
// LDF in MapGuide 2007 - current
strVersion = version->ToString();
@@ -234,7 +242,7 @@
else
// use the current highest version
- strVersion = L"2.4.0";
+ strVersion = L"4.0.0";
fd << tab.tab() << "<LayerDefinition xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"LayerDefinition-" << EncodeString(strVersion) << ".xsd\" version=\"" << EncodeString(strVersion) << "\">" << std::endl; // NOXLATE
@@ -309,6 +317,14 @@
fd << endStr(sFilter) << std::endl;
+ if (!version || (*version >= Version(4, 0, 0)))
+ // Property: IncludeBoundsForSelectedFeatures
+ fd << tab.tab() << startStr(sIncludeBoundsForSelectedFeatures);
+ fd << EncodeString(vectorLayer->GetIncludeBoundsForSelectedFeatures() ? L"true" : L"false");
+ fd << endStr(sIncludeBoundsForSelectedFeatures) << std::endl;
// Property: PropertyMappings
for (int i=0; i<vectorLayer->GetPropertyMappings()->GetCount(); ++i)
IONameStringPair::Write(fd, sPropertyMapping, vectorLayer->GetPropertyMappings()->GetAt(i), version, tab);
Modified: sandbox/jng/layer_bbox_toggle/Common/PlatformBase/MapLayer/LayerBase.cpp
--- sandbox/jng/layer_bbox_toggle/Common/PlatformBase/MapLayer/LayerBase.cpp 2020-01-14 11:22:47 UTC (rev 9636)
+++ sandbox/jng/layer_bbox_toggle/Common/PlatformBase/MapLayer/LayerBase.cpp 2020-01-14 12:06:13 UTC (rev 9637)
@@ -42,7 +42,8 @@
m_layers(NULL),
m_displayOrder(0.0),
m_resourceContent(L""),
- m_forceReadFromServer(false)
+ m_forceReadFromServer(false),
+ m_includeBoundsForSelectedFeatures(true)
@@ -62,7 +63,8 @@
m_layers(NULL),
m_definition = layerDefinition;
if(SAFE_ADDREF((MgResourceIdentifier*)m_definition) != NULL)
@@ -89,7 +91,8 @@
m_layers(NULL),
@@ -195,7 +198,6 @@
return m_visible;
// Alters the layers potential visibility.
// Note that setting this property to true will not necessarily guarantee the layer will be visible.
@@ -693,6 +695,9 @@
//get the geometry property
m_geometry = vl->GetGeometry();
+ //get flag for including feature bounds
+ m_includeBoundsForSelectedFeatures = vl->GetIncludeBoundsForSelectedFeatures();
// Drawing Layer
else if(dl != NULL)
@@ -848,4 +853,9 @@
throw new MgNotImplementedException(L"MgLayerBase.GetSpatialContexts",
__LINE__, __WFILE__, NULL, L"", NULL);
+bool MgLayerBase::GetIncludeBoundsForSelectedFeatures()
\ No newline at end of file
Modified: sandbox/jng/layer_bbox_toggle/Common/PlatformBase/MapLayer/LayerBase.h
--- sandbox/jng/layer_bbox_toggle/Common/PlatformBase/MapLayer/LayerBase.h 2020-01-14 11:22:47 UTC (rev 9636)
+++ sandbox/jng/layer_bbox_toggle/Common/PlatformBase/MapLayer/LayerBase.h 2020-01-14 12:06:13 UTC (rev 9637)
@@ -1311,6 +1311,8 @@
virtual void SetLayerResourceContent(CREFSTRING resourceContent);
+ virtual bool GetIncludeBoundsForSelectedFeatures();
protected:
/// \brief
/// Destruct a MgLayerBase object
@@ -1369,6 +1371,7 @@
IdPropertyList m_idProps;
bool m_forceReadFromServer;
STRING m_filter;
More information about the mapguide-commits
