[mapguide-commits] r9642 - in sandbox/jng/mapstatecache2: . Common/MapGuideCommon/MapLayer Common/MapGuideCommon/Services Server/src/Services/Mapping Server/src/UnitTesting
svn_mapguide at osgeo.org
Thu Jan 30 02:36:25 PST 2020
Author: jng
Date: 2020-01-30 02:36:25 -0800 (Thu, 30 Jan 2020)
New Revision: 9642
sandbox/jng/mapstatecache2/
sandbox/jng/mapstatecache2/Common/MapGuideCommon/MapLayer/Map.h
sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/MappingDefs.h
sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/MappingService.h
sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/ProxyMappingService.cpp
sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/ProxyMappingService.h
sandbox/jng/mapstatecache2/Server/src/Services/Mapping/MappingOperationFactory.cpp
sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.cpp
sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.h
sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.vcxproj
sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.vcxproj.filters
sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingServiceBuild.cpp
sandbox/jng/mapstatecache2/Server/src/UnitTesting/TestMappingService.cpp
sandbox/jng/mapstatecache2/Server/src/UnitTesting/TestMappingService.h
Merged revision(s) 9558 from sandbox/jng/mapstatecache:
Add new CreateMap method to MgMappingService. This method behaves identically to MgMap.Create(), except this method is ultimately executed in the server tier, meaning we have a hook by which we can insert a caching strategy in subsequent commits.
Add a unit test that compares MgMap.Create() vs MgMappingService.CreateMap(). As caching is not layered in yet, the perf numbers should mostly be the same.
Index: sandbox/jng/mapstatecache2
--- sandbox/jng/mapstatecache2 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2 2020-01-30 10:36:25 UTC (rev 9642)
Property changes on: sandbox/jng/mapstatecache2
___________________________________________________________________
Modified: svn:mergeinfo
## -19,6 +19,7 ##
/sandbox/jng/fusion_entrypoint_refactor:9400-9406
/sandbox/jng/geoprocessing:9205-9229
/sandbox/jng/geos34x:8256-8259
+/sandbox/jng/mapstatecache:9558
/sandbox/jng/mvt:9527-9528,9535,9537,9546-9547
/sandbox/jng/mvt_alt:9604-9629
/sandbox/jng/ogc:9240-9255
Modified: sandbox/jng/mapstatecache2/Common/MapGuideCommon/MapLayer/Map.h
--- sandbox/jng/mapstatecache2/Common/MapGuideCommon/MapLayer/Map.h 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Common/MapGuideCommon/MapLayer/Map.h 2020-01-30 10:36:25 UTC (rev 9642)
@@ -788,6 +788,8 @@
int dpi, int tileWidth, int tileHeight,
double &tileMinX, double &tileMaxX, double &tileMinY, double & tileMaxY);
+ void InitializeResourceService(MgResourceService* resourceService);
protected:
@@ -822,10 +824,6 @@
virtual void Dispose();
-private:
- void InitializeResourceService(MgResourceService* resourceService);
CLASS_ID:
static const INT32 m_cls_id = MapGuide_MapLayer_Map;
Modified: sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/MappingDefs.h
--- sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/MappingDefs.h 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/MappingDefs.h 2020-01-30 10:36:25 UTC (rev 9642)
@@ -109,6 +109,7 @@
static const int DescribeRuntimeMap2 = 0x1111EE11;
static const int CreateRuntimeMap3 = 0x1111EE12;
static const int DescribeRuntimeMap3 = 0x1111EE13;
+ static const int CreateMap = 0x1111EE14;
/// \endcond
Modified: sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/MappingService.h
--- sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/MappingService.h 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/MappingService.h 2020-01-30 10:36:25 UTC (rev 9642)
@@ -454,6 +454,106 @@
INT32 requestedFeatures,
INT32 iconsPerScaleRange) = 0;
+ /// \brief
+ /// Initializes a new MgMap object given a map definition or tile set
+ /// definition and a name for the map. This method is used for
+ /// MapGuide Viewers or for offline map production.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// void CreateMap(MgResourceIdentifier mapDefinition, string mapName);
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// void CreateMap(MgResourceIdentifier mapDefinition, String mapName);
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \param resource
+ /// An MgResourceIdentifier that specifies the
+ /// location of the map definition in a resource
+ /// repository.
+ /// \param mapName
+ /// A string that specifies the name of the map.
+ /// \return
+ /// Returns nothing.
+ /// <!-- Example (PHP) -->
+ /// \htmlinclude PHPExampleTop.html
+ /// \code
+ /// // Assuming the site connection has already been intialized as $site
+ /// $resourceID = new MgResourceIdentifier('Library://Calgary/Maps/Calgary.MapDefinition');
+ /// $mappingService = $site->CreateService(MgServiceType::MappingService);
+ /// $map = $mappingService->CreateMap($resourceID, 'Calgary');
+ /// \endcode
+ /// \htmlinclude ExampleBottom.html
+ virtual MgMap* CreateMap(MgResourceIdentifier* mapDefinition,
+ CREFSTRING mapName) = 0;
+ /// \brief
+ /// definition and a name for the map with initial display parameters set.
+ /// This method is used for MapGuide Viewers or for offline map production.
+ /// void CreateMap(MgResourceIdentifier mapDefinition, string mapName, int displayWidth, int displayHeight, double x, double y, double scale, int dpi);
+ /// void CreateMap(MgResourceIdentifier mapDefinition, String mapName, int displayWidth, int displayHeight, double x, double y, double scale, int dpi);
+ /// repository.
+ /// \param displayWidth
+ /// The display width to initially set for the map
+ /// \param displayHeight
+ /// The display height to initially set for the map
+ /// \param x
+ /// The view center X coordinate to initially set for the map
+ /// \param y
+ /// The view center Y coordinate to initially set for the map
+ /// \param scale
+ /// The view scale to initially set for the map
+ /// \param dpi
+ /// The display DPI to initially set for the map
+ /// \since 4.0
+ /// \return
+ /// \code
+ /// // Initializes the map to be centered on the Calgary CBD at 1:5000 scale with a DPI of 96
+ /// $map = $site->CreateMap($resourceID, 'Calgary', 640, 480, -114.054565, 51.068369, 5000.0, 96);
+ /// \endcode
+ CREFSTRING mapName,
+ INT32 displayWidth,
+ INT32 displayHeight,
+ double x,
+ double y,
+ double scale,
+ INT32 dpi) = 0;
EXTERNAL_API:
Modified: sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/ProxyMappingService.cpp
--- sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/ProxyMappingService.cpp 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/ProxyMappingService.cpp 2020-01-30 10:36:25 UTC (rev 9642)
@@ -611,6 +611,58 @@
return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
+MgMap* MgProxyMappingService::CreateMap(MgResourceIdentifier* mapDefinition,
+ MgCommand cmd;
+ cmd.ExecuteCommand(m_connProp,
+ MgCommand::knObject,
+ MgMappingServiceOpId::CreateMap,
+ 2,
+ Mapping_Service,
+ BUILD_VERSION(4, 0, 0),
+ MgCommand::knObject, mapDefinition,
+ MgCommand::knString, &mapName,
+ MgCommand::knNone);
+ SetWarning(cmd.GetWarningObject());
+ return (MgMap*)cmd.GetReturnValue().val.m_obj;
+ double x,
+ double y,
+ double scale,
+ INT32 dpi)
+ MgCommand cmd;
+ 8,
+ Mapping_Service,
+ MgCommand::knInt32, displayWidth,
+ MgCommand::knInt32, displayHeight,
+ MgCommand::knDouble, x,
+ MgCommand::knDouble, y,
+ MgCommand::knDouble, scale,
+ MgCommand::knInt32, dpi,
/// \brief
/// Sets the connection properties for the Proxy Service. This
Modified: sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/ProxyMappingService.h
--- sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/ProxyMappingService.h 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Common/MapGuideCommon/Services/ProxyMappingService.h 2020-01-30 10:36:25 UTC (rev 9642)
@@ -422,6 +422,106 @@
INT32 iconsPerScaleRange);
+ /// \brief
+ /// repository.
+ /// \return
+ /// \code
+ /// \endcode
+ CREFSTRING mapName);
+ /// \brief
+ /// repository.
+ /// \param x
+ /// \param y
+ /// \param scale
+ /// \param dpi
+ /// \since 4.0
+ /// \return
+ /// \code
+ /// \endcode
+ double x,
+ double y,
+ double scale,
+ INT32 dpi);
INTERNAL_API:
/// \brief
Modified: sandbox/jng/mapstatecache2/Server/src/Services/Mapping/MappingOperationFactory.cpp
--- sandbox/jng/mapstatecache2/Server/src/Services/Mapping/MappingOperationFactory.cpp 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Server/src/Services/Mapping/MappingOperationFactory.cpp 2020-01-30 10:36:25 UTC (rev 9642)
@@ -18,6 +18,7 @@
#include "ServerMappingServiceDefs.h"
#include "MappingOperationFactory.h"
+#include "OpCreateMap.h"
#include "OpCreateRuntimeMap.h"
#include "OpDescribeRuntimeMap.h"
#include "OpGeneratePlot.h"
@@ -243,6 +244,18 @@
break;
+ case MgMappingServiceOpId::CreateMap:
+ switch (VERSION_NO_PHASE(operationVersion))
+ case VERSION_SUPPORTED(4, 0):
+ handler.reset(new MgOpCreateMap());
+ break;
+ default:
+ throw new MgInvalidOperationVersionException(
+ L"MgDrawingOperationFactory.GetOperation", __LINE__, __WFILE__, NULL, L"", NULL);
+ break;
default:
throw new MgInvalidOperationException(
L"MgMappingOperationFactory.GetOperation", __LINE__, __WFILE__, NULL, L"", NULL);
Modified: sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.cpp
--- sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.cpp 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.cpp 2020-01-30 10:36:25 UTC (rev 9642)
@@ -1823,4 +1823,47 @@
xml.append("</Layer>");
MG_SERVER_MAPPING_SERVICE_CATCH_AND_THROW(L"MgServerMappingService.CreateLayerItem")
+MgMap* MgServerMappingService::CreateMap(MgResourceIdentifier* mapDefinition,
+ Ptr<MgMap> map;
+ MG_SERVER_MAPPING_SERVICE_TRY()
+ if (m_svcResource == NULL)
+ InitializeResourceService();
+ Ptr<MgSiteConnection> siteConn = new MgSiteConnection();
+ siteConn->Open(MgUserInformation::GetCurrentUserInfo());
+ map = new MgMap(siteConn);
+ map->InitializeResourceService(m_svcResource);
+ map->Create(mapDefinition, mapName);
+ MG_SERVER_MAPPING_SERVICE_CATCH_AND_THROW(L"MgServerMappingService.CreateMap")
+ return map.Detach();
+ double x,
+ double y,
+ double scale,
+ INT32 dpi)
+ Ptr<MgMap> map;
+ map->Create(mapDefinition, mapName, displayWidth, displayHeight, x, y, scale, dpi);
\ No newline at end of file
Modified: sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.h
--- sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.h 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.h 2020-01-30 10:36:25 UTC (rev 9642)
@@ -156,6 +156,18 @@
void SetConnectionProperties(MgConnectionProperties* connProp);
+ double x,
+ double y,
+ double scale,
+ INT32 dpi);
// Data Members
private:
Modified: sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.vcxproj
--- sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.vcxproj 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.vcxproj 2020-01-30 10:36:25 UTC (rev 9642)
@@ -214,6 +214,12 @@
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
</ClCompile>
+ <ClCompile Include="OpCreateMap.cpp">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </ClCompile>
<ClCompile Include="OpCreateRuntimeMap.cpp">
@@ -321,6 +327,7 @@
<ItemGroup>
<ClInclude Include="MappingOperation.h" />
<ClInclude Include="MappingOperationFactory.h" />
+ <ClInclude Include="OpCreateMap.h" />
<ClInclude Include="OpCreateRuntimeMap.h" />
<ClInclude Include="OpDescribeRuntimeMap.h" />
<ClInclude Include="OpGenerateLegendImage.h" />
Modified: sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.vcxproj.filters
--- sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.vcxproj.filters 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingService.vcxproj.filters 2020-01-30 10:36:25 UTC (rev 9642)
@@ -46,6 +46,9 @@
<ClCompile Include="OpDescribeRuntimeMap.cpp">
<Filter>Ops</Filter>
</ClCompile>
+ <Filter>Ops</Filter>
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="MappingOperation.h">
@@ -90,6 +93,9 @@
<ClInclude Include="OpDescribeRuntimeMap.h">
</ClInclude>
+ <ClInclude Include="OpCreateMap.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="ServerMappingService.rc" />
Modified: sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingServiceBuild.cpp
--- sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingServiceBuild.cpp 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Server/src/Services/Mapping/ServerMappingServiceBuild.cpp 2020-01-30 10:36:25 UTC (rev 9642)
@@ -21,6 +21,7 @@
#include "MappingOperation.cpp"
#include "MappingOperationFactory.cpp"
#include "MappingServiceHandler.cpp"
+#include "OpCreateMap.cpp"
#include "OpCreateRuntimeMap.cpp"
#include "OpDescribeRuntimeMap.cpp"
#include "OpGeneratePlot.cpp"
Modified: sandbox/jng/mapstatecache2/Server/src/UnitTesting/TestMappingService.cpp
--- sandbox/jng/mapstatecache2/Server/src/UnitTesting/TestMappingService.cpp 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Server/src/UnitTesting/TestMappingService.cpp 2020-01-30 10:36:25 UTC (rev 9642)
@@ -24,6 +24,9 @@
#include "../Common/Manager/FdoConnectionManager.h"
#include "CppUnitExtensions.h"
#include "FoundationDefs.h"
+#include "CacheManager.h"
+#include <chrono>
const STRING TEST_LOCALE = L"en";
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION(TestMappingService, "TestMappingService");
@@ -330,6 +333,66 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nMapping Service tests completed.\n\n")));
+void TestMappingService::TestCase_CreateMap()
+ try
+ //make a runtime map
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ STRING format = MgImageFormats::Png;
+ //Clear all cached data
+ MgCacheManager* cache = MgCacheManager::GetInstance();
+ cache->ClearCaches();
+ auto begin = std::chrono::steady_clock::now();
+ Ptr<MgMap> map1 = new MgMap(m_siteConnection);
+ map1->Create(mdfres, L"UnitTestSheboygan1Orig");
+ auto end = std::chrono::steady_clock::now();
+ printf("MgMap::Create() cold start - %dms\n", std::chrono::duration_cast<std::chrono::milliseconds>(end - begin).count());
+ begin = std::chrono::steady_clock::now();
+ map1 = new MgMap(m_siteConnection);
+ end = std::chrono::steady_clock::now();
+ printf("MgMap::Create() warm start - %dms\n", std::chrono::duration_cast<std::chrono::milliseconds>(end - begin).count());
+ Ptr<MgMap> map2 = new MgMap(m_siteConnection);
+ map1->Create(mdfres, L"UnitTestSheboygan2Orig", 800, 600, -87, 43, 12000, 96);
+ //Clear caches again
+ Ptr<MgMap> rtMap1 = m_svcMapping->CreateMap(mdfres, L"UnitTestSheboygan1");
+ printf("MgMappingService::CreateMap() cold start - %dms\n", std::chrono::duration_cast<std::chrono::milliseconds>(end - begin).count());
+ rtMap1 = m_svcMapping->CreateMap(mdfres, L"UnitTestSheboygan1");
+ printf("MgMappingService::CreateMap() warm start - %dms\n", std::chrono::duration_cast<std::chrono::milliseconds>(end - begin).count());
+ Ptr<MgMap> rtMap2 = m_svcMapping->CreateMap(mdfres, L"UnitTestSheboygan2", 800, 600, -87, 43, 12000, 96);
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
void TestMappingService::TestCase_CreateRuntimeMap(INT32 major, INT32 minor, INT32 rev)
try
Modified: sandbox/jng/mapstatecache2/Server/src/UnitTesting/TestMappingService.h
--- sandbox/jng/mapstatecache2/Server/src/UnitTesting/TestMappingService.h 2020-01-30 10:20:10 UTC (rev 9641)
+++ sandbox/jng/mapstatecache2/Server/src/UnitTesting/TestMappingService.h 2020-01-30 10:36:25 UTC (rev 9642)
@@ -25,6 +25,7 @@
CPPUNIT_TEST_SUITE(TestMappingService);
CPPUNIT_TEST(TestStart); // This must be the very first unit test
+ CPPUNIT_TEST(TestCase_CreateMap);
CPPUNIT_TEST(TestCase_SaveMap);
CPPUNIT_TEST(TestCase_GetMultiPlot);
CPPUNIT_TEST(TestCase_GetPlotUsingCurrentCenterAndScale);
@@ -59,6 +60,7 @@
void TestStart();
void TestEnd();
+ void TestCase_CreateMap();
void TestCase_CreateRuntimeMap(INT32 major, INT32 minor, INT32 rev);
void TestCase_CreateRuntimeMap260() { TestCase_CreateRuntimeMap(2, 6, 0); }
void TestCase_CreateRuntimeMap300() { TestCase_CreateRuntimeMap(3, 0, 0); }
@@ -65,7 +67,6 @@
void TestCase_CreateRuntimeMap400() { TestCase_CreateRuntimeMap(4, 0, 0); }
void TestCase_DescribeRuntimeMap();
void TestCase_SaveMap();
- void TestCase_GetPlot();
void TestCase_GetMultiPlot();
void TestCase_CreateAndDescribeLinkedRuntimeMap();
void TestCase_GetPlotUsingCurrentCenterAndScale();
More information about the mapguide-commits
