[mapguide-commits] r9651 - sandbox/jng/catch2/Server/src/UnitTesting
svn_mapguide at osgeo.org
Tue Jul 7 06:24:43 PDT 2020
Author: jng
Date: 2020-07-07 06:24:42 -0700 (Tue, 07 Jul 2020)
New Revision: 9651
sandbox/jng/catch2/Server/src/UnitTesting/TestMisc.cpp
sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.cpp
sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj
Fully port over TestMisc over to catch2. The catch2 listener is the closest analogy to our existing TestStart/TestEnd pair and our custom listener is what is used to setup/teardown any required data
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestMisc.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestMisc.cpp 2020-07-07 12:06:40 UTC (rev 9650)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestMisc.cpp 2020-07-07 13:24:42 UTC (rev 9651)
@@ -16,15 +16,15 @@
#include "MapGuideCommon.h"
-#include "TestMisc.h"
#include "ServiceManager.h"
#include "ServerResourceService.h"
#include "ServerSiteService.h"
-#include "../UnitTesting/CppUnitExtensions.h"
#include "FoundationDefs.h"
#include "FdoConnectionManager.h"
#include "LineBuffer.h"
#include "RS_BufferOutputStream.h"
+#define CATCH_CONFIG_EXTERNAL_INTERFACES
#include "catch.hpp"
const STRING TEST_LOCALE = L"en";
@@ -34,415 +34,246 @@
#define THREAD_GROUP 65520
#define TESTREQUESTS 5000
-TEST_CASE("Common Exception Messages", "[TestMisc]")
+struct TestMiscSetup : Catch::TestEventListenerBase
- try
- MgObject* ptr = NULL;
- CHECKNULL(ptr, L"TestMisc::TestCase_CommonExceptionMessages");
- catch(MgException* ex)
- STRING msg = ex->GetExceptionMessage(TEST_LOCALE);
- REQUIRE(msg.find(L"ptr") != STRING::npos);
- ex->Release();
+ using TestEventListenerBase::TestEventListenerBase; // inherit constructor
- try
- MgObject* ptr2 = NULL;
- CHECKNULL((void*)ptr2, L"TestMisc::TestCase_CommonExceptionMessages");
- REQUIRE(msg.find(L"ptr2") != STRING::npos);
- ex->Release();
+ // Get rid of Wweak-tables
+ ~TestMiscSetup();
- try
- MgObject* ptr3 = NULL;
- CHECKARGUMENTNULL(ptr3, L"TestMisc::TestCase_CommonExceptionMessages");
- REQUIRE(msg.find(L"ptr3") != STRING::npos);
- ex->Release();
+ // The whole test run starting
+ void testRunStarting(Catch::TestRunInfo const& testRunInfo) override {
+ Ptr<MgResourceService> m_svcResource = CreateResourceService();
- try
- MgObject* ptr4 = NULL;
- CHECKARGUMENTNULL((void*)ptr4, L"TestMisc::TestCase_CommonExceptionMessages");
- REQUIRE(msg.find(L"ptr4") != STRING::npos);
- ex->Release();
+ // Initialize a site connection.
+ Ptr<MgServerSiteService> svcSite = CreateSiteService();
- try
- STRING arg5;
- CHECKARGUMENTEMPTYSTRING(arg5, L"TestMisc::TestCase_CommonExceptionMessages");
- catch (MgException* ex)
- REQUIRE(msg.find(L"arg5") != STRING::npos);
- ex->Release();
+ printf("Setting up test data for TestMisc\n");
- try
- INT32 val = 1;
- MG_CHECK_RANGE(val, 2, 3, L"TestMisc::TestCase_CommonExceptionMessages");
- REQUIRE(msg.find(L"val") != STRING::npos);
- ex->Release();
+ //Reusing Mapping Service test data
+ try
+#ifdef _DEBUG
+ MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
+ if (pFdoConnectionManager)
+ pFdoConnectionManager->ShowCache();
+#endif
- try
- INT32 val = 1;
- INT32 min = 2;
- INT32 max = 3;
- MG_CHECK_RANGE(val, min, max, L"TestMisc::TestCase_CommonExceptionMessages");
- ex->Release();
+ //set user info
+ Ptr<MgUserInformation> userInfo = new MgUserInformation(L"Administrator", L"admin");
+ userInfo->SetLocale(TEST_LOCALE);
+ MgUserInformation::SetCurrentUserInfo(userInfo);
- try
- INT64 val = 1L;
- MG_CHECK_RANGE(val, 2L, 3L, L"TestMisc::TestCase_CommonExceptionMessages");
- ex->Release();
+ //publish the map definition
+ Ptr<MgResourceIdentifier> mapres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ Ptr<MgByteSource> mdfsrc = new MgByteSource(L"../UnitTestFiles/UT_Sheboygan.mdf", false);
+ Ptr<MgByteReader> mdfrdr = mdfsrc->GetReader();
+ m_svcResource->SetResource(mapres, mdfrdr, NULL);
- try
- INT64 val = 1L;
- INT64 min = 2L;
- INT64 max = 3L;
- ex->Release();
+ Ptr<MgResourceIdentifier> mapres2 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan_833.MapDefinition");
+ Ptr<MgByteSource> mdfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_Sheboygan_833.mdf", false);
+ Ptr<MgByteReader> mdfrdr2 = mdfsrc2->GetReader();
+ m_svcResource->SetResource(mapres2, mdfrdr2, NULL);
- try
- float val = 1.0f;
- MG_CHECK_RANGE(val, 2.0f, 3.0f, L"TestMisc::TestCase_CommonExceptionMessages");
- ex->Release();
+ //publish the layer definitions
+ Ptr<MgResourceIdentifier> ldfres1 = new MgResourceIdentifier(L"Library://UnitTests/Layers/HydrographicPolygons.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.ldf", false);
+ Ptr<MgByteReader> ldfrdr1 = ldfsrc1->GetReader();
+ m_svcResource->SetResource(ldfres1, ldfrdr1, NULL);
- try
- float val = 1.0f;
- float min = 2.0f;
- float max = 3.0f;
- ex->Release();
+ Ptr<MgResourceIdentifier> ldfres2 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.ldf", false);
+ Ptr<MgByteReader> ldfrdr2 = ldfsrc2->GetReader();
+ m_svcResource->SetResource(ldfres2, ldfrdr2, NULL);
- try
- double val = 1.0;
- MG_CHECK_RANGE(val, 2.0, 3.0, L"TestMisc::TestCase_CommonExceptionMessages");
- ex->Release();
+ Ptr<MgResourceIdentifier> ldfres3 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Rail.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc3 = new MgByteSource(L"../UnitTestFiles/UT_Rail.ldf", false);
+ Ptr<MgByteReader> ldfrdr3 = ldfsrc3->GetReader();
+ m_svcResource->SetResource(ldfres3, ldfrdr3, NULL);
- try
- double val = 1.0;
- double min = 2.0;
- double max = 3.0;
- ex->Release();
+ //publish the feature sources
+ Ptr<MgResourceIdentifier> fsres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/HydrographicPolygons.FeatureSource");
+ Ptr<MgByteSource> fssrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.fs", false);
+ Ptr<MgByteReader> fsrdr1 = fssrc1->GetReader();
+ m_svcResource->SetResource(fsres1, fsrdr1, NULL);
- try
- Ptr<MgNamedCollection> coll = new MgNamedCollection(false);
- coll->GetItem(L"Foo");
- REQUIRE(msg.find(L"Foo") != STRING::npos);
- ex->Release();
+ Ptr<MgResourceIdentifier> fsres2 = new MgResourceIdentifier(L"Library://UnitTests/Data/Parcels.FeatureSource");
+ Ptr<MgByteSource> fssrc2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.fs", false);
+ Ptr<MgByteReader> fsrdr2 = fssrc2->GetReader();
+ m_svcResource->SetResource(fsres2, fsrdr2, NULL);
-CPPUNIT_TEST_SUITE_NAMED_REGISTRATION(TestMisc, "TestMisc");
+ Ptr<MgResourceIdentifier> fsres3 = new MgResourceIdentifier(L"Library://UnitTests/Data/Rail.FeatureSource");
+ Ptr<MgByteSource> fssrc3 = new MgByteSource(L"../UnitTestFiles/UT_Rail.fs", false);
+ Ptr<MgByteReader> fsrdr3 = fssrc3->GetReader();
+ m_svcResource->SetResource(fsres3, fsrdr3, NULL);
-TestMisc::TestMisc()
- // Initialize service objects.
- MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ // publish the resource data
+ Ptr<MgByteSource> dataSource1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.sdf", false);
+ Ptr<MgByteReader> dataReader1 = dataSource1->GetReader();
+ m_svcResource->SetResourceData(fsres1, L"UT_HydrographicPolygons.sdf", L"File", dataReader1);
- m_svcResource = dynamic_cast<MgResourceService*>(
- serviceManager->RequestService(MgServiceType::ResourceService));
- assert(m_svcResource != NULL);
+ Ptr<MgByteSource> dataSource2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.sdf", false);
+ Ptr<MgByteReader> dataReader2 = dataSource2->GetReader();
+ m_svcResource->SetResourceData(fsres2, L"UT_Parcels.sdf", L"File", dataReader2);
- // Initialize a site connection.
- Ptr<MgServerSiteService> svcSite = dynamic_cast<MgServerSiteService*>(
- serviceManager->RequestService(MgServiceType::SiteService));
- assert(svcSite != NULL);
+ Ptr<MgByteSource> dataSource3 = new MgByteSource(L"../UnitTestFiles/UT_Rail.sdf", false);
+ Ptr<MgByteReader> dataReader3 = dataSource3->GetReader();
+ m_svcResource->SetResourceData(fsres3, L"UT_Rail.sdf", L"File", dataReader3);
- Ptr<MgUserInformation> userInfo = new MgUserInformation(
- L"Administrator", L"admin");
- userInfo->SetLocale(TEST_LOCALE);
+ // publish the print layouts
+ Ptr<MgResourceIdentifier> plres1 = new MgResourceIdentifier(L"Library://UnitTests/PrintLayouts/AllElements.PrintLayout");
+ Ptr<MgByteSource> plsrc1 = new MgByteSource(L"../UnitTestFiles/UT_AllElements.pl", false);
+ Ptr<MgByteReader> plrdr1 = plsrc1->GetReader();
+ m_svcResource->SetResource(plres1, plrdr1, NULL);
- // Set the current MgUserInformation
- // This must be done before calling CreateSession()
- MgUserInformation::SetCurrentUserInfo(userInfo);
+ Ptr<MgResourceIdentifier> plres2 = new MgResourceIdentifier(L"Library://UnitTests/PrintLayouts/NoLegend.PrintLayout");
+ Ptr<MgByteSource> plsrc2 = new MgByteSource(L"../UnitTestFiles/UT_NoLegend.pl", false);
+ Ptr<MgByteReader> plrdr2 = plsrc2->GetReader();
+ m_svcResource->SetResource(plres2, plrdr2, NULL);
- STRING session = svcSite->CreateSession();
- assert(!session.empty());
- userInfo->SetMgSessionId(session);
- m_siteConnection = new MgSiteConnection();
- m_siteConnection->Open(userInfo);
-TestMisc::~TestMisc()
-void TestMisc::setUp()
-void TestMisc::tearDown()
-void TestMisc::TestStart()
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nRunning Miscellaneous tests.\n")));
- //Reusing Mapping Service test data
- try
- #ifdef _DEBUG
- MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
- if(pFdoConnectionManager)
+ // publish the symbol library
+ Ptr<MgResourceIdentifier> slres1 = new MgResourceIdentifier(L"Library://UnitTests/Symbols/SymbolMart.SymbolLibrary");
+ Ptr<MgByteSource> slsrc1 = new MgByteSource(L"../UnitTestFiles/UT_SymbolMart.sl", false);
+ Ptr<MgByteReader> slrdr1 = slsrc1->GetReader();
+ m_svcResource->SetResource(slres1, slrdr1, NULL);
+ Ptr<MgByteSource> datasrc = new MgByteSource(L"../UnitTestFiles/UT_Symbols.dwf", false);
+ Ptr<MgByteReader> datardr = datasrc->GetReader();
+ m_svcResource->SetResourceData(slres1, L"symbols.dwf", L"File", datardr);
+ catch (MgException* e)
- pFdoConnectionManager->ShowCache();
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
- #endif
+ catch (...)
+ throw;
- //set user info
- Ptr<MgUserInformation> userInfo = new MgUserInformation(L"Administrator", L"admin");
+ static MgSiteConnection* CreateSiteConnection(MgServerSiteService* svcSite)
+ L"Administrator", L"admin");
+ // Set the current MgUserInformation
+ // This must be done before calling CreateSession()
- //publish the map definition
- Ptr<MgResourceIdentifier> mapres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
- Ptr<MgByteSource> mdfsrc = new MgByteSource(L"../UnitTestFiles/UT_Sheboygan.mdf", false);
- Ptr<MgByteReader> mdfrdr = mdfsrc->GetReader();
- m_svcResource->SetResource(mapres, mdfrdr, NULL);
+ STRING session = svcSite->CreateSession();
+ assert(!session.empty());
+ userInfo->SetMgSessionId(session);
- Ptr<MgResourceIdentifier> mapres2 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan_833.MapDefinition");
- Ptr<MgByteSource> mdfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_Sheboygan_833.mdf", false);
- Ptr<MgByteReader> mdfrdr2 = mdfsrc2->GetReader();
- m_svcResource->SetResource(mapres2, mdfrdr2, NULL);
- //publish the layer definitions
- Ptr<MgResourceIdentifier> ldfres1 = new MgResourceIdentifier(L"Library://UnitTests/Layers/HydrographicPolygons.LayerDefinition");
- Ptr<MgByteSource> ldfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.ldf", false);
- Ptr<MgByteReader> ldfrdr1 = ldfsrc1->GetReader();
- m_svcResource->SetResource(ldfres1, ldfrdr1, NULL);
+ Ptr<MgSiteConnection> m_siteConnection = new MgSiteConnection();
+ m_siteConnection->Open(userInfo);
+ return m_siteConnection.Detach();
- Ptr<MgResourceIdentifier> ldfres2 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
- Ptr<MgByteSource> ldfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.ldf", false);
- Ptr<MgByteReader> ldfrdr2 = ldfsrc2->GetReader();
- m_svcResource->SetResource(ldfres2, ldfrdr2, NULL);
+ static MgServerSiteService* CreateSiteService()
+ // Initialize service objects.
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
- Ptr<MgResourceIdentifier> ldfres3 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Rail.LayerDefinition");
- Ptr<MgByteSource> ldfsrc3 = new MgByteSource(L"../UnitTestFiles/UT_Rail.ldf", false);
- Ptr<MgByteReader> ldfrdr3 = ldfsrc3->GetReader();
- m_svcResource->SetResource(ldfres3, ldfrdr3, NULL);
+ return dynamic_cast<MgServerSiteService*>(
+ serviceManager->RequestService(MgServiceType::SiteService));
- //publish the feature sources
- Ptr<MgResourceIdentifier> fsres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/HydrographicPolygons.FeatureSource");
- Ptr<MgByteSource> fssrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.fs", false);
- Ptr<MgByteReader> fsrdr1 = fssrc1->GetReader();
- m_svcResource->SetResource(fsres1, fsrdr1, NULL);
+ static MgResourceService* CreateResourceService()
- Ptr<MgResourceIdentifier> fsres2 = new MgResourceIdentifier(L"Library://UnitTests/Data/Parcels.FeatureSource");
- Ptr<MgByteSource> fssrc2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.fs", false);
- Ptr<MgByteReader> fsrdr2 = fssrc2->GetReader();
- m_svcResource->SetResource(fsres2, fsrdr2, NULL);
- Ptr<MgResourceIdentifier> fsres3 = new MgResourceIdentifier(L"Library://UnitTests/Data/Rail.FeatureSource");
- Ptr<MgByteSource> fssrc3 = new MgByteSource(L"../UnitTestFiles/UT_Rail.fs", false);
- Ptr<MgByteReader> fsrdr3 = fssrc3->GetReader();
- m_svcResource->SetResource(fsres3, fsrdr3, NULL);
- // publish the resource data
- Ptr<MgByteSource> dataSource1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.sdf", false);
- Ptr<MgByteReader> dataReader1 = dataSource1->GetReader();
- m_svcResource->SetResourceData(fsres1, L"UT_HydrographicPolygons.sdf", L"File", dataReader1);
- Ptr<MgByteSource> dataSource2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.sdf", false);
- Ptr<MgByteReader> dataReader2 = dataSource2->GetReader();
- m_svcResource->SetResourceData(fsres2, L"UT_Parcels.sdf", L"File", dataReader2);
- Ptr<MgByteSource> dataSource3 = new MgByteSource(L"../UnitTestFiles/UT_Rail.sdf", false);
- Ptr<MgByteReader> dataReader3 = dataSource3->GetReader();
- m_svcResource->SetResourceData(fsres3, L"UT_Rail.sdf", L"File", dataReader3);
- // publish the print layouts
- Ptr<MgResourceIdentifier> plres1 = new MgResourceIdentifier(L"Library://UnitTests/PrintLayouts/AllElements.PrintLayout");
- Ptr<MgByteSource> plsrc1 = new MgByteSource(L"../UnitTestFiles/UT_AllElements.pl", false);
- Ptr<MgByteReader> plrdr1 = plsrc1->GetReader();
- m_svcResource->SetResource(plres1, plrdr1, NULL);
- Ptr<MgResourceIdentifier> plres2 = new MgResourceIdentifier(L"Library://UnitTests/PrintLayouts/NoLegend.PrintLayout");
- Ptr<MgByteSource> plsrc2 = new MgByteSource(L"../UnitTestFiles/UT_NoLegend.pl", false);
- Ptr<MgByteReader> plrdr2 = plsrc2->GetReader();
- m_svcResource->SetResource(plres2, plrdr2, NULL);
- // publish the symbol library
- Ptr<MgResourceIdentifier> slres1 = new MgResourceIdentifier(L"Library://UnitTests/Symbols/SymbolMart.SymbolLibrary");
- Ptr<MgByteSource> slsrc1 = new MgByteSource(L"../UnitTestFiles/UT_SymbolMart.sl", false);
- Ptr<MgByteReader> slrdr1 = slsrc1->GetReader();
- m_svcResource->SetResource(slres1, slrdr1, NULL);
- Ptr<MgByteSource> datasrc = new MgByteSource(L"../UnitTestFiles/UT_Symbols.dwf", false);
- Ptr<MgByteReader> datardr = datasrc->GetReader();
- m_svcResource->SetResourceData(slres1, L"symbols.dwf", L"File", datardr);
+ return dynamic_cast<MgResourceService*>(
+ serviceManager->RequestService(MgServiceType::ResourceService));
- catch (MgException* e)
- STRING message = e->GetDetails(TEST_LOCALE);
- SAFE_RELEASE(e);
- CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
- catch (...)
- throw;
+ // The whole test run ending
+ void testRunEnded(Catch::TestRunStats const& testRunStats) override {
-void TestMisc::TestEnd()
- try
- //set user info
+ printf("Tearing down test data for TestMisc\n");
+ try
+ //set user info
- //delete the map definition
- m_svcResource->DeleteResource(mapres);
+ //delete the map definition
+ m_svcResource->DeleteResource(mapres);
- m_svcResource->DeleteResource(mapres2);
+ m_svcResource->DeleteResource(mapres2);
- //delete the layer definitions
- m_svcResource->DeleteResource(ldfres1);
+ //delete the layer definitions
+ m_svcResource->DeleteResource(ldfres1);
- m_svcResource->DeleteResource(ldfres2);
+ m_svcResource->DeleteResource(ldfres2);
- m_svcResource->DeleteResource(ldfres3);
+ m_svcResource->DeleteResource(ldfres3);
- //delete the feature sources
- m_svcResource->DeleteResource(fsres1);
+ //delete the feature sources
+ m_svcResource->DeleteResource(fsres1);
- m_svcResource->DeleteResource(fsres2);
+ m_svcResource->DeleteResource(fsres2);
- m_svcResource->DeleteResource(fsres3);
+ m_svcResource->DeleteResource(fsres3);
- // delete the print layouts
- m_svcResource->DeleteResource(plres1);
+ // delete the print layouts
+ m_svcResource->DeleteResource(plres1);
- m_svcResource->DeleteResource(plres2);
+ m_svcResource->DeleteResource(plres2);
- // delete the symbol library
- m_svcResource->DeleteResource(slres1);
+ // delete the symbol library
+ m_svcResource->DeleteResource(slres1);
- #ifdef _DEBUG
+#ifdef _DEBUG
+#endif
+ SAFE_RELEASE(e);
- #endif
+ catch (...)
+ throw;
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\nMiscellaneous tests completed.\n\n")));
- SAFE_RELEASE(e);
- catch (...)
- throw;
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nMiscellaneous tests completed.\n\n")));
+CATCH_REGISTER_LISTENER(TestMiscSetup)
-void TestMisc::TestCase_CommonExceptionMessages()
+// Get rid of Wweak-tables
+TestMiscSetup::~TestMiscSetup() {}
+TEST_CASE("Common Exception Messages", "[TestMisc]")
try
@@ -452,10 +283,7 @@
- //ACE_DEBUG((LM_INFO, ACE_TEXT("Exception: %W\n"), msg.c_str()));
- std::string assertMsg = "Expected identifier 'ptr' in exception message: ";
- assertMsg += MgUtil::WideCharToMultiByte(msg);
- CPPUNIT_ASSERT_MESSAGE(assertMsg, msg.find(L"ptr") != STRING::npos);
+ REQUIRE(msg.find(L"ptr") != STRING::npos);
ex->Release();
@@ -467,10 +295,7 @@
- std::string assertMsg = "Expected identifier 'ptr2' in exception message: ";
- CPPUNIT_ASSERT_MESSAGE(assertMsg, msg.find(L"ptr2") != STRING::npos);
+ REQUIRE(msg.find(L"ptr2") != STRING::npos);
ex->Release();
@@ -482,10 +307,7 @@
- std::string assertMsg = "Expected identifier 'ptr3' in exception message: ";
- CPPUNIT_ASSERT_MESSAGE(assertMsg, msg.find(L"ptr3") != STRING::npos);
+ REQUIRE(msg.find(L"ptr3") != STRING::npos);
ex->Release();
@@ -497,10 +319,7 @@
- std::string assertMsg = "Expected identifier 'ptr4' in exception message: ";
- CPPUNIT_ASSERT_MESSAGE(assertMsg, msg.find(L"ptr4") != STRING::npos);
+ REQUIRE(msg.find(L"ptr4") != STRING::npos);
ex->Release();
@@ -512,10 +331,7 @@
- std::string assertMsg = "Expected identifier 'arg5' in exception message: ";
- CPPUNIT_ASSERT_MESSAGE(assertMsg, msg.find(L"arg5") != STRING::npos);
+ REQUIRE(msg.find(L"arg5") != STRING::npos);
ex->Release();
@@ -527,10 +343,7 @@
- std::string assertMsg = "Expected identifier 'val' in exception message: ";
- CPPUNIT_ASSERT_MESSAGE(assertMsg, msg.find(L"val") != STRING::npos);
+ REQUIRE(msg.find(L"val") != STRING::npos);
ex->Release();
@@ -544,10 +357,7 @@
- std::string assertMsg = "Expected identifier '' in exception message: ";
- CPPUNIT_ASSERT_MESSAGE(assertMsg, msg.find(L"") != STRING::npos);
ex->Release();
@@ -559,10 +369,7 @@
ex->Release();
@@ -576,10 +383,7 @@
ex->Release();
@@ -591,10 +395,7 @@
ex->Release();
@@ -608,10 +409,7 @@
ex->Release();
@@ -623,10 +421,7 @@
ex->Release();
@@ -640,10 +435,7 @@
ex->Release();
@@ -655,449 +447,13 @@
- std::string assertMsg = "Expected string 'Foo' in exception message: ";
- CPPUNIT_ASSERT_MESSAGE(assertMsg, msg.find(L"Foo") != STRING::npos);
+ REQUIRE(msg.find(L"Foo") != STRING::npos);
ex->Release();
-void TestMisc::TestCase_611()
+TEST_CASE("LineBuffer Conversion", "[TestMisc]")
- try
- Ptr<MgResourceIdentifier> mapRes1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
- Ptr<MgMap> map1 = new MgMap(m_siteConnection);
- map1->Create(mapRes1, L"UnitTestSheboygan1");
- Ptr<MgLayerGroup> detachedGroup = new MgLayerGroup(L"Detached");
- Ptr<MgResourceIdentifier> ldf = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
- Ptr<MgLayer> layer = new MgLayer(ldf, m_svcResource);
- layer->SetName(L"BelongsToDetachedGroup");
- layer->SetLegendLabel(L"BelongsToDetachedGroup");
- layer->SetGroup(detachedGroup);
- Ptr<MgLayerCollection> mapLayers = map1->GetLayers();
- mapLayers->Insert(0, layer);
- CPPUNIT_ASSERT_THROW_MG(map1->Save(), MgGroupNotFoundException*);
- SAFE_RELEASE(e);
- catch (...)
- throw;
-void TestMisc::TestCase_833()
- try
- Ptr<MgResourceIdentifier> mapRes1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan_833.MapDefinition");
- Ptr<MgLayerGroupCollection> groups = map1->GetLayerGroups();
- Ptr<MgLayerCollection> layers = map1->GetLayers();
- //These are the ones initially hidden from the legend
- Ptr<MgLayerGroup> group = groups->GetItem(L"Municipal");
- Ptr<MgLayerBase> layer = layers->GetItem(L"HydrographicPolygons");
- CPPUNIT_ASSERT(!group->GetLegendLabel().empty());
- CPPUNIT_ASSERT(!layer->GetLegendLabel().empty());
- SAFE_RELEASE(e);
- catch (...)
- throw;
-void TestMisc::TestCase_1304()
- try
- Ptr<MgSelection> sel = new MgSelection(map1, L"");
- Ptr<MgReadOnlyLayerCollection> selLayers = sel->GetLayers();
- CPPUNIT_ASSERT_MESSAGE("Expected null MgReadOnlyLayerCollection", NULL == selLayers.p);
- sel->FromXml(L""); //Should be same result
- selLayers = sel->GetLayers();
- SAFE_RELEASE(e);
- catch (...)
- throw;
-void TestMisc::TestCase_CreateMapWithInitialDisplayParams()
- try
- Ptr<MgMap> map = new MgMap(m_siteConnection);
- map->Create(mapRes1, L"TestCase_CreateMapWithInitialDisplayParams", 800, 600, -87.45, 43.32, 8000.0, 256);
- CPPUNIT_ASSERT_MESSAGE("Expected width of 800", map->GetDisplayWidth() == 800);
- CPPUNIT_ASSERT_MESSAGE("Expected height of 600", map->GetDisplayHeight() == 600);
- Ptr<MgPoint> pt = map->GetViewCenter();
- Ptr<MgCoordinate> coord = pt->GetCoordinate();
- CPPUNIT_ASSERT_DOUBLES_EQUAL(coord->GetX(), -87.45, 0.001);
- CPPUNIT_ASSERT_DOUBLES_EQUAL(coord->GetY(), 43.32, 0.001);
- CPPUNIT_ASSERT_DOUBLES_EQUAL(map->GetViewScale(), 8000.0, 0.0001);
- CPPUNIT_ASSERT_MESSAGE("Expected DPI of 256", map->GetDisplayDpi() == 256);
- SAFE_RELEASE(e);
- catch (...)
- throw;
-void TestMisc::TestCase_ApiVersionCheck()
- try
- //Just making sure this macro behaves as we expect
- CPPUNIT_ASSERT_MESSAGE("Expected 4.1.0 >= 4.0.0", MG_API_VERSION(4, 1, 0) >= MG_API_VERSION(4, 0, 0));
- CPPUNIT_ASSERT_MESSAGE("Expected 4.0.0 >= 4.0.0", MG_API_VERSION(4, 0, 0) >= MG_API_VERSION(4, 0, 0));
- SAFE_RELEASE(e);
- catch (...)
- throw;
-void TestMisc::TestCase_MapLayerCollections()
- try
- Ptr<MgLayerGroup> detachedGroup = new MgLayerGroup(L"DetachedGroup");
- Ptr<MgLayer> detachedLayer = new MgLayer(ldf, m_svcResource);
- detachedLayer->SetName(L"DetachedLayer");
- Ptr<MgLayerGroupCollection> mapGroups = map1->GetLayerGroups();
- //Remove() should be returning false when passing in layers/groups that don't belong
- CPPUNIT_ASSERT(!mapLayers->Remove(detachedLayer));
- CPPUNIT_ASSERT(!mapGroups->Remove(detachedGroup));
- SAFE_RELEASE(e);
- catch (...)
- throw;
-void TestMisc::TestCase_DoubleToStringWithDecimals()
- try
- double d = 1.23456789032748754;
- std::string s;
- STRING ws;
- MgUtil::DoubleToString(d, ws, 4);
- MgUtil::DoubleToString(d, s, 4);
- CPPUNIT_ASSERT(L"1.2346" == ws);
- CPPUNIT_ASSERT("1.2346" == s);
- ws.clear();
- s.clear();
- MgUtil::DoubleToString(d, ws, 8);
- MgUtil::DoubleToString(d, s, 8);
- CPPUNIT_ASSERT(L"1.23456789" == ws);
- CPPUNIT_ASSERT("1.23456789" == s);
- ws.clear();
- s.clear();
- std::string s1;
- STRING ws1;
- //This should be the equivalent to not even passing in precision at all
- MgUtil::DoubleToString(d, ws, -1);
- MgUtil::DoubleToString(d, s, -1);
- MgUtil::DoubleToString(d, ws1);
- MgUtil::DoubleToString(d, s1);
- CPPUNIT_ASSERT(ws1 == ws);
- CPPUNIT_ASSERT(s1 == s);
- double d1 = 1.1;
- ws.clear();
- s.clear();
- MgUtil::DoubleToString(d1, ws, 4);
- MgUtil::DoubleToString(d1, s, 4);
- CPPUNIT_ASSERT(L"1.1" == ws);
- CPPUNIT_ASSERT("1.1" == s);
- double d2 = 123.3457483434945;
- ws.clear();
- s.clear();
- MgUtil::DoubleToString(d2, ws, 8);
- MgUtil::DoubleToString(d2, s, 8);
- CPPUNIT_ASSERT(L"123.34574834" == ws);
- CPPUNIT_ASSERT("123.34574834" == s);
- SAFE_RELEASE(e);
- catch (...)
- throw;
-void TestMisc::TestCase_TryParseDouble()
- try
- double dBad = 0.0;
- CPPUNIT_ASSERT(!MgUtil::TryParseDouble(L"", dBad));
- CPPUNIT_ASSERT(!MgUtil::TryParseDouble(L"abc", dBad));
- CPPUNIT_ASSERT(!MgUtil::TryParseDouble(L"abc123", dBad));
- CPPUNIT_ASSERT(!MgUtil::TryParseDouble(L"123.asd", dBad));
- double d1 = 0.0;
- CPPUNIT_ASSERT(MgUtil::TryParseDouble(L"123", d1));
- CPPUNIT_ASSERT(123 == d1);
- double d2 = 0.0;
- CPPUNIT_ASSERT(MgUtil::TryParseDouble(L"123.23", d2));
- CPPUNIT_ASSERT_DOUBLES_EQUAL(123.23, d2, 0.001);
- double d3 = 0.0;
- CPPUNIT_ASSERT(MgUtil::TryParseDouble(L"0.1237483", d3));
- CPPUNIT_ASSERT_DOUBLES_EQUAL(0.1237483, d3, 0.00000001);
- double d4 = 0.0;
- CPPUNIT_ASSERT(MgUtil::TryParseDouble(L"123.", d4));
- CPPUNIT_ASSERT(123 == d4);
- double d5 = 0.0;
- CPPUNIT_ASSERT(MgUtil::TryParseDouble(L".1235", d5));
- CPPUNIT_ASSERT_DOUBLES_EQUAL(0.1235, d5, 0.00001);
- SAFE_RELEASE(e);
- catch (...)
- throw;
-void TestMisc::TestCase_BadResourceIdentifier()
- try
- Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(L"I'm a baaaaad id");
- CPPUNIT_FAIL("This should've thrown");
- SAFE_RELEASE(e);
- CPPUNIT_ASSERT(message.find(L"I'm a baaaaad id") != STRING::npos);
- catch (...)
- throw;
-// data structure which is passed to each thread
-struct GetConfigValueThreadData
- INT32 threadId;
- bool success;
- bool done;
- STRING section;
- STRING key;
-ACE_THR_FUNC_RETURN GetConfigValueWorker(void* param)
- // get the data for this thread
- GetConfigValueThreadData* threadData = (GetConfigValueThreadData*)param;
- INT32 threadId = threadData->threadId;
-#ifdef _DEBUG
- printf("> thread %d started\n", threadId);
-#endif
- try
- MgConfiguration* conf = MgConfiguration::GetInstance();
- bool b = false;
- conf->GetBoolValue(threadData->section, threadData->key, b, false);
- threadData->success = true;
- threadData->success = false;
- SAFE_RELEASE(e);
- catch (...)
- throw;
-#ifdef _DEBUG
- // printf("> thread %d done\n", threadId);
-#endif
- threadData->done = true;
- return 0;
-void TestMisc::TestCase_ThreadSafeConfiguration()
- try
- // specify the number of threads to use
- const INT32 numThreads = MG_TEST_THREADS;
- GetConfigValueThreadData threadData[numThreads];
- // need a thread manager
- ACE_Thread_Manager* manager = ACE_Thread_Manager::instance();
- // initialize the thread data
- for (INT32 i = 0; i < numThreads; i++)
- threadData[i].threadId = i;
- threadData[i].done = true;
- threadData[i].success = true;
- threadData[i].section = MgConfigProperties::GeneralPropertiesSection;
- threadData[i].key = MgConfigProperties::GeneralPropertyMaxLogFileSizeEnabled;
- INT32 nRequest = 0;
- INT32 nSuccessful = 0;
- INT32 nFailed = 0;
- bool bExceptionOcurred = false;
- for (;;)
- INT32 dc = 0;
- // check if the thread is available
- if (threadData[i].done)
- if (threadData[i].success)
- nSuccessful++;
- else
- nFailed++;
- // Reset for next run
- threadData[i].done = false;
- // spawn a new thread using a specific group id
- int thid = manager->spawn(ACE_THR_FUNC(GetConfigValueWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
- nRequest++;
- // move on if all threads are done
- if ((nRequest > TESTREQUESTS) || (bExceptionOcurred))
- break;
- // under Linux we get a deadlock if we don't call this every once in a while
- if (nRequest % 25 == 0)
- manager->wait_grp(THREAD_GROUP);
- else
- // pause briefly (10ms) before checking again
- ACE_Time_Value t(0, 10000);
- ACE_OS::sleep(t);
- // make sure all threads in the group have completed
- nSuccessful++;
- else
- nFailed++;
- CPPUNIT_ASSERT(nFailed == 0);
- SAFE_RELEASE(e);
- catch (...)
- throw;
-void TestMisc::TestCase_LineBuffer_Conversion()
//This isn't really a test, it's more verification and internal documentation
//of how LineBuffers are meant to be represented for various geometry types
try
@@ -1123,10 +479,10 @@
Ptr<MgByte> bytes = agfSink->ToBuffer();
lb.LoadFromAgf(bytes->Bytes(), bytes->GetLength(), nullptr);
- CPPUNIT_ASSERT(1 == lb.geom_count());
- CPPUNIT_ASSERT(1 == lb.point_count());
- CPPUNIT_ASSERT(30 == lb.x_coord(0));
- CPPUNIT_ASSERT(10 == lb.y_coord(0));
+ REQUIRE(1 == lb.geom_count());
+ REQUIRE(1 == lb.point_count());
+ REQUIRE(30 == lb.x_coord(0));
+ REQUIRE(10 == lb.y_coord(0));
//MultiPoint
@@ -1137,16 +493,16 @@
- CPPUNIT_ASSERT(4 == lb.geom_count());
- CPPUNIT_ASSERT(4 == lb.point_count());
- CPPUNIT_ASSERT(10 == lb.x_coord(0));
- CPPUNIT_ASSERT(40 == lb.y_coord(0));
- CPPUNIT_ASSERT(40 == lb.x_coord(1));
- CPPUNIT_ASSERT(30 == lb.y_coord(1));
- CPPUNIT_ASSERT(20 == lb.x_coord(2));
- CPPUNIT_ASSERT(20 == lb.y_coord(2));
- CPPUNIT_ASSERT(30 == lb.x_coord(3));
- CPPUNIT_ASSERT(10 == lb.y_coord(3));
+ REQUIRE(4 == lb.geom_count());
+ REQUIRE(4 == lb.point_count());
+ REQUIRE(10 == lb.x_coord(0));
+ REQUIRE(40 == lb.y_coord(0));
+ REQUIRE(40 == lb.x_coord(1));
+ REQUIRE(30 == lb.y_coord(1));
+ REQUIRE(20 == lb.x_coord(2));
+ REQUIRE(20 == lb.y_coord(2));
+ REQUIRE(30 == lb.x_coord(3));
+ REQUIRE(10 == lb.y_coord(3));
//LineString
@@ -1158,9 +514,9 @@
int lineIdx = 0;
- CPPUNIT_ASSERT(1 == lb.cntr_count());
- CPPUNIT_ASSERT(3 == lb.cntr_size(lineIdx));
+ REQUIRE(1 == lb.cntr_count());
+ REQUIRE(3 == lb.cntr_size(lineIdx));
auto ptOffset = lb.contour_start_point(lineIdx);
for (int i = 0; i < lb.cntr_size(lineIdx); i++)
@@ -1170,16 +526,16 @@
switch (i)
case 0:
- CPPUNIT_ASSERT(30 == x);
- CPPUNIT_ASSERT(10 == y);
+ REQUIRE(30 == x);
+ REQUIRE(10 == y);
break;
case 1:
- CPPUNIT_ASSERT(10 == x);
- CPPUNIT_ASSERT(30 == y);
+ REQUIRE(10 == x);
+ REQUIRE(30 == y);
break;
case 2:
- CPPUNIT_ASSERT(40 == x);
- CPPUNIT_ASSERT(40 == y);
+ REQUIRE(40 == x);
+ REQUIRE(40 == y);
break;
@@ -1193,12 +549,12 @@
- CPPUNIT_ASSERT(2 == lb.geom_count());
- CPPUNIT_ASSERT(1 == lb.geom_size(0));
- CPPUNIT_ASSERT(1 == lb.geom_size(1));
- CPPUNIT_ASSERT(2 == lb.cntr_count());
- CPPUNIT_ASSERT(3 == lb.cntr_size(0));
- CPPUNIT_ASSERT(4 == lb.cntr_size(1));
+ REQUIRE(2 == lb.geom_count());
+ REQUIRE(1 == lb.geom_size(0));
+ REQUIRE(1 == lb.geom_size(1));
+ REQUIRE(2 == lb.cntr_count());
+ REQUIRE(3 == lb.cntr_size(0));
+ REQUIRE(4 == lb.cntr_size(1));
//LineString 1
@@ -1210,16 +566,16 @@
switch (i)
case 0:
+ REQUIRE(10 == x);
+ REQUIRE(10 == y);
break;
case 1:
- CPPUNIT_ASSERT(20 == x);
- CPPUNIT_ASSERT(20 == y);
+ REQUIRE(20 == x);
+ REQUIRE(20 == y);
break;
case 2:
+ REQUIRE(10 == x);
+ REQUIRE(40 == y);
break;
@@ -1235,20 +591,20 @@
switch (i)
case 0:
+ REQUIRE(40 == x);
+ REQUIRE(40 == y);
break;
case 1:
+ REQUIRE(30 == x);
+ REQUIRE(30 == y);
break;
case 2:
+ REQUIRE(40 == x);
+ REQUIRE(20 == y);
break;
case 3:
+ REQUIRE(30 == x);
+ REQUIRE(10 == y);
break;
@@ -1263,13 +619,13 @@
auto cc = lb.cntr_count();
- CPPUNIT_ASSERT(1 == cc);
+ REQUIRE(1 == cc);
int lineIdx = 0;
- CPPUNIT_ASSERT(5 == lb.cntr_size(lineIdx));
+ REQUIRE(5 == lb.cntr_size(lineIdx));
@@ -1279,24 +635,24 @@
switch (i)
case 0:
+ REQUIRE(30 == x);
+ REQUIRE(10 == y);
break;
case 1:
+ REQUIRE(40 == x);
+ REQUIRE(40 == y);
break;
case 2:
+ REQUIRE(20 == x);
+ REQUIRE(40 == y);
break;
case 3:
+ REQUIRE(10 == x);
+ REQUIRE(20 == y);
break;
case 4:
+ REQUIRE(30 == x);
+ REQUIRE(10 == y);
break;
@@ -1310,14 +666,14 @@
- CPPUNIT_ASSERT(2 == lb.geom_size(0));
+ REQUIRE(2 == lb.geom_size(0));
- CPPUNIT_ASSERT(2 == cc);
+ REQUIRE(2 == cc);
//Outer Ring
- CPPUNIT_ASSERT(5 == lb.cntr_size(0));
+ REQUIRE(5 == lb.cntr_size(0));
auto ptOffset = lb.contour_start_point(0);
for (int i = 0; i < lb.cntr_size(0); i++)
@@ -1326,24 +682,24 @@
switch (i)
case 0:
- CPPUNIT_ASSERT(35 == x);
+ REQUIRE(35 == x);
+ REQUIRE(10 == y);
break;
case 1:
- CPPUNIT_ASSERT(45 == x);
- CPPUNIT_ASSERT(45 == y);
+ REQUIRE(45 == x);
+ REQUIRE(45 == y);
break;
case 2:
- CPPUNIT_ASSERT(15 == x);
+ REQUIRE(15 == x);
+ REQUIRE(40 == y);
break;
case 3:
+ REQUIRE(10 == x);
+ REQUIRE(20 == y);
break;
case 4:
+ REQUIRE(35 == x);
+ REQUIRE(10 == y);
break;
@@ -1351,7 +707,7 @@
//Inner Ring
auto ptOffset = lb.contour_start_point(1);
for (int i = 0; i < lb.cntr_size(1); i++)
@@ -1360,20 +716,20 @@
switch (i)
case 0:
+ REQUIRE(20 == x);
+ REQUIRE(30 == y);
break;
case 1:
- CPPUNIT_ASSERT(35 == y);
+ REQUIRE(35 == x);
+ REQUIRE(35 == y);
break;
case 2:
+ REQUIRE(30 == x);
+ REQUIRE(20 == y);
break;
case 3:
+ REQUIRE(20 == x);
+ REQUIRE(30 == y);
break;
@@ -1388,17 +744,17 @@
+ REQUIRE(2 == cc);
auto closed1 = lb.contour_closed(0);
auto closed2 = lb.contour_closed(1);
//Polygon 1
- CPPUNIT_ASSERT(4 == lb.cntr_size(0));
+ REQUIRE(4 == lb.cntr_size(0));
@@ -1407,20 +763,20 @@
switch (i)
case 0:
+ REQUIRE(30 == x);
+ REQUIRE(20 == y);
break;
case 1:
+ REQUIRE(45 == x);
+ REQUIRE(40 == y);
break;
case 2:
+ REQUIRE(10 == x);
+ REQUIRE(40 == y);
break;
case 3:
+ REQUIRE(30 == x);
+ REQUIRE(20 == y);
break;
@@ -1428,7 +784,7 @@
//Polygon 2
- CPPUNIT_ASSERT(5 == lb.cntr_size(1));
+ REQUIRE(5 == lb.cntr_size(1));
@@ -1437,24 +793,24 @@
switch (i)
case 0:
- CPPUNIT_ASSERT(5 == y);
+ REQUIRE(15 == x);
+ REQUIRE(5 == y);
break;
case 1:
+ REQUIRE(40 == x);
+ REQUIRE(10 == y);
break;
case 2:
+ REQUIRE(10 == x);
+ REQUIRE(20 == y);
break;
case 3:
- CPPUNIT_ASSERT(5 == x);
+ REQUIRE(5 == x);
+ REQUIRE(10 == y);
break;
case 4:
+ REQUIRE(15 == x);
+ REQUIRE(5 == y);
break;
@@ -1469,7 +825,7 @@
Ptr<MgGeometry> g2 = agfRw.Read(oagf);
STRING owkt = wktRw.Write(g2);
- CPPUNIT_ASSERT(owkt == mpWkt1);
+ REQUIRE(owkt == mpWkt1);
//MultiPolygon 2
@@ -1480,11 +836,11 @@
- CPPUNIT_ASSERT(2 == lb.geom_size(1));
+ REQUIRE(2 == lb.geom_size(1));
- CPPUNIT_ASSERT(3 == cc);
+ REQUIRE(3 == cc);
auto closed3 = lb.contour_closed(2);
@@ -1491,7 +847,7 @@
//Polygon 1
@@ -1500,20 +856,20 @@
switch (i)
case 0:
+ REQUIRE(40 == x);
+ REQUIRE(40 == y);
break;
case 1:
+ REQUIRE(20 == x);
+ REQUIRE(45 == y);
break;
case 2:
+ REQUIRE(45 == x);
+ REQUIRE(30 == y);
break;
case 3:
+ REQUIRE(40 == x);
+ REQUIRE(40 == y);
break;
@@ -1521,7 +877,7 @@
//Polygon 2 (inner ring)
- CPPUNIT_ASSERT(6 == lb.cntr_size(1));
+ REQUIRE(6 == lb.cntr_size(1));
@@ -1530,28 +886,28 @@
switch (i)
case 0:
+ REQUIRE(20 == x);
+ REQUIRE(35 == y);
break;
case 1:
+ REQUIRE(10 == x);
+ REQUIRE(30 == y);
break;
case 2:
+ REQUIRE(10 == x);
+ REQUIRE(10 == y);
break;
case 3:
+ REQUIRE(30 == x);
+ REQUIRE(5 == y);
break;
case 4:
+ REQUIRE(45 == x);
+ REQUIRE(20 == y);
break;
case 5:
+ REQUIRE(20 == x);
+ REQUIRE(35 == y);
break;
@@ -1559,7 +915,7 @@
//Polygon 2 (outer ring)
- CPPUNIT_ASSERT(4 == lb.cntr_size(2));
+ REQUIRE(4 == lb.cntr_size(2));
auto ptOffset = lb.contour_start_point(2);
for (int i = 0; i < lb.cntr_size(2); i++)
@@ -1568,20 +924,20 @@
switch (i)
case 0:
+ REQUIRE(30 == x);
+ REQUIRE(20 == y);
break;
case 1:
- CPPUNIT_ASSERT(15 == y);
+ REQUIRE(20 == x);
+ REQUIRE(15 == y);
break;
case 2:
- CPPUNIT_ASSERT(25 == y);
+ REQUIRE(20 == x);
+ REQUIRE(25 == y);
break;
case 3:
+ REQUIRE(30 == x);
+ REQUIRE(20 == y);
break;
@@ -1596,7 +952,7 @@
- CPPUNIT_ASSERT(owkt == mpWkt2);
+ REQUIRE(owkt == mpWkt2);
@@ -1603,10 +959,483 @@
SAFE_RELEASE(e);
catch (...)
throw;
+TEST_CASE("MgUtil::TryParseDouble", "[TestMisc]")
+ try
+ double dBad = 0.0;
+ REQUIRE(!MgUtil::TryParseDouble(L"", dBad));
+ REQUIRE(!MgUtil::TryParseDouble(L"abc", dBad));
+ REQUIRE(!MgUtil::TryParseDouble(L"abc123", dBad));
+ REQUIRE(!MgUtil::TryParseDouble(L"123.asd", dBad));
+ double d1 = 0.0;
+ REQUIRE(MgUtil::TryParseDouble(L"123", d1));
+ REQUIRE(123 == d1);
+ double d2 = 0.0;
+ REQUIRE(MgUtil::TryParseDouble(L"123.23", d2));
+ REQUIRE(d2 == Approx(123.23));
+ double d3 = 0.0;
+ REQUIRE(MgUtil::TryParseDouble(L"0.1237483", d3));
+ REQUIRE(d3 == Approx(0.1237483));
+ double d4 = 0.0;
+ REQUIRE(MgUtil::TryParseDouble(L"123.", d4));
+ REQUIRE(123 == d4);
+ double d5 = 0.0;
+ REQUIRE(MgUtil::TryParseDouble(L".1235", d5));
+ REQUIRE(d5 == Approx(0.1235));
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+TEST_CASE("Bad resource identifier", "[TestMisc]")
+ try
+ Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(L"I'm a baaaaad id");
+ FAIL("This should've thrown");
+ SAFE_RELEASE(e);
+ REQUIRE(message.find(L"I'm a baaaaad id") != STRING::npos);
+ catch (...)
+ throw;
+TEST_CASE("Double to String with decimals", "[TestMisc]")
+ try
+ double d = 1.23456789032748754;
+ std::string s;
+ STRING ws;
+ MgUtil::DoubleToString(d, ws, 4);
+ MgUtil::DoubleToString(d, s, 4);
+ REQUIRE(L"1.2346" == ws);
+ REQUIRE("1.2346" == s);
+ ws.clear();
+ s.clear();
+ MgUtil::DoubleToString(d, ws, 8);
+ MgUtil::DoubleToString(d, s, 8);
+ REQUIRE(L"1.23456789" == ws);
+ REQUIRE("1.23456789" == s);
+ ws.clear();
+ s.clear();
+ std::string s1;
+ STRING ws1;
+ //This should be the equivalent to not even passing in precision at all
+ MgUtil::DoubleToString(d, ws, -1);
+ MgUtil::DoubleToString(d, s, -1);
+ MgUtil::DoubleToString(d, ws1);
+ MgUtil::DoubleToString(d, s1);
+ REQUIRE(ws1 == ws);
+ REQUIRE(s1 == s);
+ double d1 = 1.1;
+ ws.clear();
+ s.clear();
+ MgUtil::DoubleToString(d1, ws, 4);
+ MgUtil::DoubleToString(d1, s, 4);
+ REQUIRE(L"1.1" == ws);
+ REQUIRE("1.1" == s);
+ double d2 = 123.3457483434945;
+ ws.clear();
+ s.clear();
+ MgUtil::DoubleToString(d2, ws, 8);
+ MgUtil::DoubleToString(d2, s, 8);
+ REQUIRE(L"123.34574834" == ws);
+ REQUIRE("123.34574834" == s);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+TEST_CASE("API Version Check", "[TestMisc]")
+ try
+ //Just making sure this macro behaves as we expect
+ REQUIRE(MG_API_VERSION(4, 1, 0) >= MG_API_VERSION(4, 0, 0));
+ REQUIRE(MG_API_VERSION(4, 0, 0) >= MG_API_VERSION(4, 0, 0));
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+TEST_CASE("Trac #611", "[TestMisc]")
+ try
+ Ptr<MgResourceService> m_svcResource = TestMiscSetup::CreateResourceService();
+ Ptr<MgServerSiteService> svcSite = TestMiscSetup::CreateSiteService();
+ Ptr<MgSiteConnection> m_siteConnection = TestMiscSetup::CreateSiteConnection(svcSite);
+ // ========================== Begin Test ======================== //
+ Ptr<MgResourceIdentifier> mapRes1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ Ptr<MgMap> map1 = new MgMap(m_siteConnection);
+ map1->Create(mapRes1, L"UnitTestSheboygan1");
+ Ptr<MgLayerGroup> detachedGroup = new MgLayerGroup(L"Detached");
+ Ptr<MgResourceIdentifier> ldf = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
+ Ptr<MgLayer> layer = new MgLayer(ldf, m_svcResource);
+ layer->SetName(L"BelongsToDetachedGroup");
+ layer->SetLegendLabel(L"BelongsToDetachedGroup");
+ layer->SetGroup(detachedGroup);
+ Ptr<MgLayerCollection> mapLayers = map1->GetLayers();
+ mapLayers->Insert(0, layer);
+ try
+ map1->Save();
+ FAIL("Expected MgGroupNotFoundException to be thrown");
+ catch (MgGroupNotFoundException* gnex)
+ SAFE_RELEASE(gnex);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+TEST_CASE("Trac #833", "[TestMisc]")
+ try
+ Ptr<MgResourceIdentifier> mapRes1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan_833.MapDefinition");
+ Ptr<MgLayerGroupCollection> groups = map1->GetLayerGroups();
+ Ptr<MgLayerCollection> layers = map1->GetLayers();
+ //These are the ones initially hidden from the legend
+ Ptr<MgLayerGroup> group = groups->GetItem(L"Municipal");
+ Ptr<MgLayerBase> layer = layers->GetItem(L"HydrographicPolygons");
+ REQUIRE(!group->GetLegendLabel().empty());
+ REQUIRE(!layer->GetLegendLabel().empty());
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+TEST_CASE("Trac #1304", "[TestMisc]")
+ try
+ Ptr<MgSelection> sel = new MgSelection(map1, L"");
+ Ptr<MgReadOnlyLayerCollection> selLayers = sel->GetLayers();
+ REQUIRE(nullptr == selLayers.p);
+ sel->FromXml(L""); //Should be same result
+ selLayers = sel->GetLayers();
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+TEST_CASE("Create Map w/ initial display params", "[TestMisc]")
+ try
+ Ptr<MgMap> map = new MgMap(m_siteConnection);
+ map->Create(mapRes1, L"TestCase_CreateMapWithInitialDisplayParams", 800, 600, -87.45, 43.32, 8000.0, 256);
+ REQUIRE(map->GetDisplayWidth() == 800);
+ REQUIRE(map->GetDisplayHeight() == 600);
+ Ptr<MgPoint> pt = map->GetViewCenter();
+ Ptr<MgCoordinate> coord = pt->GetCoordinate();
+ REQUIRE(coord->GetX() == Approx(-87.45));
+ REQUIRE(coord->GetY() == Approx(43.32));
+ REQUIRE(map->GetViewScale() == Approx(8000.0));
+ REQUIRE(map->GetDisplayDpi() == 256);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+TEST_CASE("Map Layer Collection", "[TestMisc]")
+ try
+ Ptr<MgLayerGroup> detachedGroup = new MgLayerGroup(L"DetachedGroup");
+ Ptr<MgLayer> detachedLayer = new MgLayer(ldf, m_svcResource);
+ detachedLayer->SetName(L"DetachedLayer");
+ Ptr<MgLayerGroupCollection> mapGroups = map1->GetLayerGroups();
+ //Remove() should be returning false when passing in layers/groups that don't belong
+ REQUIRE(!mapLayers->Remove(detachedLayer));
+ REQUIRE(!mapGroups->Remove(detachedGroup));
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+// data structure which is passed to each thread
+struct GetConfigValueThreadData
+ INT32 threadId;
+ bool success;
+ bool done;
+ STRING section;
+ STRING key;
+ACE_THR_FUNC_RETURN GetConfigValueWorker(void* param)
+ // get the data for this thread
+ GetConfigValueThreadData* threadData = (GetConfigValueThreadData*)param;
+ INT32 threadId = threadData->threadId;
+#ifdef _DEBUG
+ printf("> thread %d started\n", threadId);
+#endif
+ try
+ MgConfiguration* conf = MgConfiguration::GetInstance();
+ bool b = false;
+ conf->GetBoolValue(threadData->section, threadData->key, b, false);
+ threadData->success = true;
+ threadData->success = false;
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+#ifdef _DEBUG
+ // printf("> thread %d done\n", threadId);
+#endif
+ threadData->done = true;
+ return 0;
+TEST_CASE("Thread-safe configuration", "[TestMisc]")
+ try
+ // specify the number of threads to use
+ const INT32 numThreads = MG_TEST_THREADS;
+ GetConfigValueThreadData threadData[numThreads];
+ // need a thread manager
+ ACE_Thread_Manager* manager = ACE_Thread_Manager::instance();
+ // initialize the thread data
+ for (INT32 i = 0; i < numThreads; i++)
+ threadData[i].threadId = i;
+ threadData[i].done = true;
+ threadData[i].success = true;
+ threadData[i].section = MgConfigProperties::GeneralPropertiesSection;
+ threadData[i].key = MgConfigProperties::GeneralPropertyMaxLogFileSizeEnabled;
+ INT32 nRequest = 0;
+ INT32 nSuccessful = 0;
+ INT32 nFailed = 0;
+ bool bExceptionOcurred = false;
+ for (;;)
+ INT32 dc = 0;
+ // check if the thread is available
+ if (threadData[i].done)
+ if (threadData[i].success)
+ nSuccessful++;
+ else
+ nFailed++;
+ // Reset for next run
+ threadData[i].done = false;
+ // spawn a new thread using a specific group id
+ int thid = manager->spawn(ACE_THR_FUNC(GetConfigValueWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
+ nRequest++;
+ // move on if all threads are done
+ if ((nRequest > TESTREQUESTS) || (bExceptionOcurred))
+ break;
+ // under Linux we get a deadlock if we don't call this every once in a while
+ if (nRequest % 25 == 0)
+ manager->wait_grp(THREAD_GROUP);
+ else
+ // pause briefly (10ms) before checking again
+ ACE_Time_Value t(0, 10000);
+ ACE_OS::sleep(t);
+ // make sure all threads in the group have completed
+ nSuccessful++;
+ else
+ nFailed++;
+ REQUIRE(nFailed == 0);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
\ No newline at end of file
Modified: sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.cpp 2020-07-07 12:06:40 UTC (rev 9650)
+++ sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.cpp 2020-07-07 13:24:42 UTC (rev 9651)
@@ -29,6 +29,11 @@
int Execute(CREFSTRING fileName, CREFSTRING test)
+ // Set the default user information for this test run.
+ // Any specific test case may overwrite these information.
+ Ptr<MgUserInformation> userInfo = new MgUserInformation(MgUser::Administrator, L"");
Catch::Session session;
int nResult = session.run();
Modified: sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj
--- sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj 2020-07-07 12:06:40 UTC (rev 9650)
+++ sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj 2020-07-07 13:24:42 UTC (rev 9651)
@@ -208,7 +208,6 @@
<ClInclude Include="TestLogManagerThread.h" />
<ClInclude Include="TestMappingService.h" />
<ClInclude Include="TestMdfModel.h" />
- <ClInclude Include="TestMisc.h" />
<ClInclude Include="TestPerformance.h" />
<ClInclude Include="TestProfilingService.h" />
<ClInclude Include="TestRenderingService.h" />
More information about the mapguide-commits
