[mapguide-commits] r9659 - sandbox/jng/catch2/Server/src/UnitTesting
svn_mapguide at osgeo.org
Mon Jul 13 06:05:00 PDT 2020
Author: jng
Date: 2020-07-13 06:04:59 -0700 (Mon, 13 Jul 2020)
New Revision: 9659
Removed:
sandbox/jng/catch2/Server/src/UnitTesting/TestFeatureService.h
sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.h
sandbox/jng/catch2/Server/src/UnitTesting/TestRenderingService.h
sandbox/jng/catch2/Server/src/UnitTesting/TestServiceManager.h
sandbox/jng/catch2/Server/src/UnitTesting/TestTileService.h
sandbox/jng/catch2/Server/src/UnitTesting/TestDrawingService.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestFeatureService.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestGeometry.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestKmlService.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestLogManager.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestLogManagerThread.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestMappingService.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestMdfModel.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestMisc.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestProfilingService.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestRenderingService.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestResourceService.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestServerAdminService.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestServerManager.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestServiceManager.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestSiteManager.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestSiteService.cpp
sandbox/jng/catch2/Server/src/UnitTesting/TestTileService.cpp
sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj
Port feature, performance, rendering and tile service tests to catch2
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestDrawingService.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestDrawingService.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestDrawingService.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -137,7 +137,7 @@
Ptr<MgDrawingService> m_svcDrawing = TestServiceFactory::CreateDrawingService();
Ptr<MgResourceIdentifier> resId1 = new MgResourceIdentifier(L"Library://UnitTests/Drawings/SpaceShip.DrawingSource");
Ptr<MgByteReader> rdr1 = m_svcDrawing->GetDrawing(resId1);
- REQUIRE(NULL != rdr1.p);
+ REQUIRE(nullptr != rdr1.p);
catch (MgException* e)
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestFeatureService.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestFeatureService.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestFeatureService.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -16,8 +16,6 @@
#include "MapGuideCommon.h"
-#include "TestFeatureService.h"
-#include "CppUnitExtensions.h"
#include "ServiceManager.h"
#include "FdoConnectionManager.h"
#include "Services/FeatureService.h"
@@ -25,308 +23,78 @@
#include "Fdo.h"
#include "FoundationDefs.h"
-const STRING TEST_LOCALE = L"en";
+#include "CatchHelperMacros.h"
+#include "TestServiceFactory.h"
+#include "catch.hpp"
-CPPUNIT_TEST_SUITE_NAMED_REGISTRATION(TestFeatureService, "TestFeatureService");
-void TestFeatureService::setUp()
+static STRING CreateTestDataStore(MgFeatureService* svcFeature, CREFSTRING provider, MgResourceIdentifier* fsId)
+ Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
+ STRING scName = L"Default";
+ STRING csWkt = csFactory->ConvertCoordinateSystemCodeToWkt(L"LL84");
+ Ptr<MgFeatureSchema> schema = new MgFeatureSchema(L"Default", L"Default Feature Schema");
+ Ptr<MgClassDefinition> klass = new MgClassDefinition();
+ klass->SetName(L"Test");
-void TestFeatureService::tearDown()
+ Ptr<MgPropertyDefinitionCollection> clsProps = klass->GetProperties();
+ Ptr<MgPropertyDefinitionCollection> clsIdProps = klass->GetIdentityProperties();
+ Ptr<MgDataPropertyDefinition> id = new MgDataPropertyDefinition(L"ID");
+ id->SetDataType(MgPropertyType::Int32);
+ id->SetAutoGeneration(true);
-void TestFeatureService::TestStart()
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nRunning Feature Service tests.\n")));
+ Ptr<MgDataPropertyDefinition> name = new MgDataPropertyDefinition(L"Name");
+ name->SetDataType(MgPropertyType::String);
+ name->SetLength(255);
+ name->SetNullable(true);
-#ifdef _WIN32
- //If the FDO we're using has a full providers.xml and we haven't met the dependencies
- //of some providers (eg. OCI.dll for King.Oracle), then it's going to show a message box
- //in our face about this that has to be manually dismissed. Not something you want to have
- //happen when trying to run tests in an automated fashion. This test suite only covers the
- //SDF, SHP and SQLite providers so having such message boxes show up is intrusive.
- //This call will suppress such message boxes when loading dlls with unmet depdendencies. It's
- //okay to do this here because mgserver.exe would not be running as a service or long-running process
- //when running its test suite, so this will only take effect for the duration of the test run
- SetErrorMode(SEM_FAILCRITICALERRORS);
-#endif
+ Ptr<MgGeometricPropertyDefinition> geom = new MgGeometricPropertyDefinition(L"Geometry");
+ geom->SetGeometryTypes(MgFeatureGeometricType::Point);
+ geom->SetSpatialContextAssociation(scName);
- try
- #ifdef _DEBUG
- ACE_DEBUG((LM_INFO, ACE_TEXT("TestFeatureService::TestStart()\n")));
- MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
- if(pFdoConnectionManager)
- pFdoConnectionManager->ShowCache();
- #endif
+ clsProps->Add(id);
+ clsProps->Add(name);
+ clsProps->Add(geom);
- MgServiceManager* serviceManager = MgServiceManager::GetInstance();
- if(serviceManager == 0)
- throw new MgNullReferenceException(L"TestResourceService.setUp", __LINE__, __WFILE__, NULL, L"", NULL);
+ clsIdProps->Add(id);
- Ptr<MgResourceService> pService = dynamic_cast<MgResourceService*>(serviceManager->RequestService(MgServiceType::ResourceService));
- if (pService == 0)
- throw new MgServiceNotAvailableException(L"TestResourceService.setUp", __LINE__, __WFILE__, NULL, L"", NULL);
+ klass->SetDefaultGeometryPropertyName(L"Geometry");
- //Set the user information for the current thread to be administrator
- MgUserInformation::SetCurrentUserInfo(NULL);
- Ptr<MgUserInformation> userInfo = new MgUserInformation(L"Administrator", L"admin");
- if (userInfo != NULL)
- userInfo->SetLocale(TEST_LOCALE);
- MgUserInformation::SetCurrentUserInfo(userInfo);
+ Ptr<MgClassDefinitionCollection> classes = schema->GetClasses();
+ classes->Add(klass);
- MgResourceIdentifier resourceIdentifier1(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
- MgResourceIdentifier resourceIdentifier2(L"Library://UnitTests/Data/Redding_Parcels.FeatureSource");
- MgResourceIdentifier resourceIdentifier3(L"Library://UnitTests/Data/Sheboygan_BuildingOutlines.FeatureSource");
- MgResourceIdentifier resourceIdentifier4(L"Library://UnitTests/Data/Sheboygan_VotingDistricts.FeatureSource");
- MgResourceIdentifier resourceIdentifier5(L"Library://UnitTests/Data/TestChainedInner1ToManyJoin.FeatureSource");
- MgResourceIdentifier resourceIdentifier6(L"Library://UnitTests/Data/Empty.FeatureSource");
- MgResourceIdentifier resourceIdentifier7(L"Library://UnitTests/Data/SavePointTest.FeatureSource");
- MgResourceIdentifier resourceIdentifier8(L"Library://UnitTests/Data/ParcelsJoinTestSQLite.FeatureSource");
- MgResourceIdentifier resourceIdentifier9(L"Library://UnitTests/Data/FdoJoin.FeatureSource");
-#ifdef _WIN32
- STRING resourceContentFileName1 = L"..\\UnitTestFiles\\Sheboygan_Parcels.FeatureSource";
- STRING resourceContentFileName2 = L"..\\UnitTestFiles\\Redding_Parcels.FeatureSource";
- STRING resourceContentFileName3 = L"..\\UnitTestFiles\\Sheboygan_BuildingOutlines.FeatureSource";
- STRING resourceContentFileName4 = L"..\\UnitTestFiles\\Sheboygan_VotingDistricts.FeatureSource";
- STRING resourceContentFileName5 = L"..\\UnitTestFiles\\TESTChainedInner1ToManyJoin.FeatureSource";
- STRING resourceContentFileName6 = L"..\\UnitTestFiles\\Empty.FeatureSource";
- STRING resourceContentFileName7 = L"..\\UnitTestFiles\\SavePointTest.FeatureSource";
- STRING resourceContentFileName8 = L"..\\UnitTestFiles\\UT_Parcels_SQLite_Join.FeatureSource";
- STRING resourceContentFileName9 = L"..\\UnitTestFiles\\UT_FdoJoin.FeatureSource";
- STRING dataFileName1 = L"..\\UnitTestFiles\\Sheboygan_Parcels.sdf";
- STRING dataFileName2 = L"..\\UnitTestFiles\\Redding_Parcels.shp";
- STRING dataFileName3 = L"..\\UnitTestFiles\\Redding_Parcels.dbf";
- STRING dataFileName4 = L"..\\UnitTestFiles\\Redding_Parcels.shx";
- STRING dataFileName5 = L"..\\UnitTestFiles\\Sheboygan_BuildingOutlines.sdf";
- STRING dataFileName6 = L"..\\UnitTestFiles\\Sheboygan_VotingDistricts.sdf";
- STRING dataFileName7 = L"..\\UnitTestFiles\\Empty.sdf";
- STRING dataFileName8 = L"..\\UnitTestFiles\\SavePointTest.sqlite";
- STRING dataFileName9 = L"..\\UnitTestFiles\\JoinTest.sqlite";
- STRING dataFileName10 = L"..\\UnitTestFiles\\ParcelsJoinTest.sqlite";
-#else
- STRING resourceContentFileName1 = L"../UnitTestFiles/Sheboygan_Parcels.FeatureSource";
- STRING resourceContentFileName2 = L"../UnitTestFiles/Redding_Parcels.FeatureSource";
- STRING resourceContentFileName3 = L"../UnitTestFiles/Sheboygan_BuildingOutlines.FeatureSource";
- STRING resourceContentFileName4 = L"../UnitTestFiles/Sheboygan_VotingDistricts.FeatureSource";
- STRING resourceContentFileName5 = L"../UnitTestFiles/TESTChainedInner1ToManyJoin.FeatureSource";
- STRING resourceContentFileName6 = L"../UnitTestFiles/Empty.FeatureSource";
- STRING resourceContentFileName7 = L"../UnitTestFiles/SavePointTest.FeatureSource";
- STRING resourceContentFileName8 = L"../UnitTestFiles/UT_Parcels_SQLite_Join.FeatureSource";
- STRING resourceContentFileName9 = L"../UnitTestFiles/UT_FdoJoin.FeatureSource";
- STRING dataFileName1 = L"../UnitTestFiles/Sheboygan_Parcels.sdf";
- STRING dataFileName2 = L"../UnitTestFiles/Redding_Parcels.shp";
- STRING dataFileName3 = L"../UnitTestFiles/Redding_Parcels.dbf";
- STRING dataFileName4 = L"../UnitTestFiles/Redding_Parcels.shx";
- STRING dataFileName5 = L"../UnitTestFiles/Sheboygan_BuildingOutlines.sdf";
- STRING dataFileName6 = L"../UnitTestFiles/Sheboygan_VotingDistricts.sdf";
- STRING dataFileName7 = L"../UnitTestFiles/Empty.sdf";
- STRING dataFileName8 = L"../UnitTestFiles/SavePointTest.sqlite";
- STRING dataFileName9 = L"../UnitTestFiles/JoinTest.sqlite";
- STRING dataFileName10 = L"../UnitTestFiles/ParcelsJoinTest.sqlite";
-#endif
+ Ptr<MgFileFeatureSourceParams> fsParams = new MgFileFeatureSourceParams(provider, scName, csWkt, schema);
+ svcFeature->CreateFeatureSource(fsId, fsParams);
- //Add a new resource
- Ptr<MgByteSource> contentSource1 = new MgByteSource(resourceContentFileName1);
- Ptr<MgByteReader> contentReader1 = contentSource1->GetReader();
- pService->SetResource(&resourceIdentifier1, contentReader1, NULL);
+ Ptr<MgFeatureSchemaCollection> schemas = svcFeature->DescribeSchema(fsId, L"");
+ Ptr<MgFeatureSchema> theSchema = schemas->GetItem(0);
+ Ptr<MgClassDefinitionCollection> theClasses = theSchema->GetClasses();
+ Ptr<MgClassDefinition> theClass = theClasses->GetItem(0);
- Ptr<MgByteSource> contentSource2 = new MgByteSource(resourceContentFileName2);
- Ptr<MgByteReader> contentReader2 = contentSource2->GetReader();
- pService->SetResource(&resourceIdentifier2, contentReader2, NULL);
- Ptr<MgByteSource> contentSource3 = new MgByteSource(resourceContentFileName3);
- Ptr<MgByteReader> contentReader3 = contentSource3->GetReader();
- pService->SetResource(&resourceIdentifier3, contentReader3, NULL);
- Ptr<MgByteSource> contentSource4 = new MgByteSource(resourceContentFileName4);
- Ptr<MgByteReader> contentReader4 = contentSource4->GetReader();
- pService->SetResource(&resourceIdentifier4, contentReader4, NULL);
- Ptr<MgByteSource> contentSource5 = new MgByteSource(resourceContentFileName5);
- Ptr<MgByteReader> contentReader5 = contentSource5->GetReader();
- pService->SetResource(&resourceIdentifier5, contentReader5, NULL);
- Ptr<MgByteSource> contentSource6 = new MgByteSource(resourceContentFileName6);
- Ptr<MgByteReader> contentReader6 = contentSource6->GetReader();
- pService->SetResource(&resourceIdentifier6, contentReader6, NULL);
- Ptr<MgByteSource> contentSource7 = new MgByteSource(resourceContentFileName7);
- Ptr<MgByteReader> contentReader7 = contentSource7->GetReader();
- pService->SetResource(&resourceIdentifier7, contentReader7, NULL);
- Ptr<MgByteSource> contentSource8 = new MgByteSource(resourceContentFileName8);
- Ptr<MgByteReader> contentReader8 = contentSource8->GetReader();
- pService->SetResource(&resourceIdentifier8, contentReader8, NULL);
- Ptr<MgByteSource> contentSource9 = new MgByteSource(resourceContentFileName9);
- Ptr<MgByteReader> contentReader9 = contentSource9->GetReader();
- pService->SetResource(&resourceIdentifier9, contentReader9, NULL);
- //Set the resource data
- Ptr<MgByteSource> dataSource1 = new MgByteSource(dataFileName1);
- Ptr<MgByteReader> dataReader1 = dataSource1->GetReader();
- pService->SetResourceData(&resourceIdentifier1, L"Sheboygan_Parcels.sdf", L"File", dataReader1);
- Ptr<MgByteSource> dataSource2 = new MgByteSource(dataFileName2);
- Ptr<MgByteReader> dataReader2 = dataSource2->GetReader();
- pService->SetResourceData(&resourceIdentifier2, L"Redding_Parcels.shp", L"File", dataReader2);
- Ptr<MgByteSource> dataSource3 = new MgByteSource(dataFileName3);
- Ptr<MgByteReader> dataReader3 = dataSource3->GetReader();
- pService->SetResourceData(&resourceIdentifier2, L"Redding_Parcels.dbf", L"File", dataReader3);
- Ptr<MgByteSource> dataSource4 = new MgByteSource(dataFileName4);
- Ptr<MgByteReader> dataReader4 = dataSource4->GetReader();
- pService->SetResourceData(&resourceIdentifier2, L"Redding_Parcels.shx", L"File", dataReader4);
- Ptr<MgByteSource> dataSource5 = new MgByteSource(dataFileName5);
- Ptr<MgByteReader> dataReader5 = dataSource5->GetReader();
- pService->SetResourceData(&resourceIdentifier3, L"Sheboygan_BuildingOutlines.sdf", L"File", dataReader5);
- Ptr<MgByteSource> dataSource6 = new MgByteSource(dataFileName6);
- Ptr<MgByteReader> dataReader6 = dataSource6->GetReader();
- pService->SetResourceData(&resourceIdentifier4, L"Sheboygan_VotingDistricts.sdf", L"File", dataReader6);
- Ptr<MgByteSource> dataSource7 = new MgByteSource(dataFileName1);
- Ptr<MgByteReader> dataReader7 = dataSource7->GetReader();
- pService->SetResourceData(&resourceIdentifier5, L"Sheboygan_Parcels.sdf", L"File", dataReader7);
- Ptr<MgByteSource> dataSource8 = new MgByteSource(dataFileName7);
- Ptr<MgByteReader> dataReader8 = dataSource8->GetReader();
- pService->SetResourceData(&resourceIdentifier6, L"Empty.sdf", L"File", dataReader8);
- Ptr<MgByteSource> dataSource9 = new MgByteSource(dataFileName8);
- Ptr<MgByteReader> dataReader9 = dataSource9->GetReader();
- pService->SetResourceData(&resourceIdentifier7, L"SavePointTest.sqlite", L"File", dataReader9);
- Ptr<MgByteSource> dataSource10 = new MgByteSource(dataFileName9);
- Ptr<MgByteReader> dataReader10 = dataSource10->GetReader();
- pService->SetResourceData(&resourceIdentifier9, L"JoinTest.sqlite", L"File", dataReader10);
- Ptr<MgByteSource> dataSource11 = new MgByteSource(dataFileName10);
- Ptr<MgByteReader> dataReader11 = dataSource11->GetReader();
- pService->SetResourceData(&resourceIdentifier8, L"ParcelsJoinTest.sqlite", L"File", dataReader11);
- catch(MgException* e)
- STRING message = e->GetDetails(TEST_LOCALE);
- SAFE_RELEASE(e);
- CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ STRING qClassName = theSchema->GetName();
+ qClassName += L":";
+ qClassName += theClass->GetName();
+ return qClassName;
-void TestFeatureService::TestEnd()
- try
- throw new MgNullReferenceException(L"TestFeatureService.TestEnd",
- __LINE__, __WFILE__, NULL, L"", NULL);
- throw new MgServiceNotAvailableException(L"TestFeatureService.TestEnd",
- // set user info
- // delete the feature sources definition
- Ptr<MgResourceIdentifier> fsres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
- pService->DeleteResource(fsres1);
- Ptr<MgResourceIdentifier> fsres2 = new MgResourceIdentifier(L"Library://UnitTests/Data/Redding_Parcels.FeatureSource");
- pService->DeleteResource(fsres2);
- Ptr<MgResourceIdentifier> fsres3 = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_BuildingOutlines.FeatureSource");
- pService->DeleteResource(fsres3);
- Ptr<MgResourceIdentifier> fsres4 = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_VotingDistricts.FeatureSource");
- pService->DeleteResource(fsres4);
- Ptr<MgResourceIdentifier> fsres5 = new MgResourceIdentifier(L"Library://UnitTests/Data/TestChainedInner1ToManyJoin.FeatureSource");
- pService->DeleteResource(fsres5);
- Ptr<MgResourceIdentifier> fsres6 = new MgResourceIdentifier(L"Library://UnitTests/Data/Empty.FeatureSource");
- pService->DeleteResource(fsres6);
- Ptr<MgResourceIdentifier> fsres7 = new MgResourceIdentifier(L"Library://UnitTests/Data/FdoJoin.FeatureSource");
- pService->DeleteResource(fsres7);
- Ptr<MgResourceIdentifier> fsres8 = new MgResourceIdentifier(L"Library://UnitTests/Data/ParcelsJoinTestSQLite.FeatureSource");
- pService->DeleteResource(fsres8);
- //May or may not have been created during the test
- Ptr<MgResourceIdentifier> fsres9 = new MgResourceIdentifier(L"Library://UnitTests/Data/GetIdentityPropertiesTest.FeatureSource");
- if (pService->ResourceExists(fsres9)) pService->DeleteResource(fsres9);
- Ptr<MgResourceIdentifier> fsres10 = new MgResourceIdentifier(L"Library://UnitTests/Data/TestInsert.FeatureSource");
- if (pService->ResourceExists(fsres10)) pService->DeleteResource(fsres10);
- #ifdef _DEBUG
- ACE_DEBUG((LM_INFO, ACE_TEXT("TestFeatureService::TestEnd()\n")));
- #endif
- catch (MgException* e)
- SAFE_RELEASE(e);
- catch (...)
- throw;
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nFeature Service tests completed.\n\n")));
/// Test Case Description:
/// This test case gets the feature providers.
-void TestFeatureService::TestCase_GetFeatureProviders()
+TEST_CASE("GetFeatureProviders", "[FeatureService]")
try
+ if (serviceManager == NULL)
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetFeatureProviders", __LINE__, __WFILE__, NULL, L"", NULL);
Ptr<MgFeatureService> pService = dynamic_cast<MgFeatureService*>(serviceManager->RequestService(MgServiceType::FeatureService));
+ if (pService == NULL)
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetFeatureProviders", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -333,18 +101,18 @@
Ptr<MgByteReader> byteReader = pService->GetFeatureProviders();
STRING mimeType = byteReader->GetMimeType();
- CPPUNIT_ASSERT(wcscmp(mimeType.c_str(), MgMimeType::Xml.c_str()) == 0);
+ REQUIRE(wcscmp(mimeType.c_str(), MgMimeType::Xml.c_str()) == 0);
+ STRING message = e->GetDetails(TestServiceFactory::TEST_LOCALE);
SAFE_RELEASE(e);
+ FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
catch(FdoException* e)
FDO_SAFE_RELEASE(e);
- CPPUNIT_FAIL("FdoException occurred");
+ FAIL("FdoException occurred");
catch(...)
@@ -358,18 +126,18 @@
/// This test case tests connections to the SDF provider.
-void TestFeatureService::TestCase_TestConnectionSDFProvider()
+TEST_CASE("TestConnectionSDFProvider", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_TestConnectionSDFProvider", __LINE__, __WFILE__, NULL, L"", NULL);
+ if (pService.p == NULL)
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_TestConnectionSDFProvider", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -385,18 +153,18 @@
const STRING connectionString = L"File=../UnitTestFiles/Sheboygan_Parcels.sdf";
#endif
bool bSuccess = pService->TestConnection(provider, connectionString);
- CPPUNIT_ASSERT(bSuccess);
+ REQUIRE(bSuccess);
SAFE_RELEASE(e);
catch(...)
@@ -410,12 +178,12 @@
/// This test case tests the FDO connection manager.
-void TestFeatureService::TestCase_TestFdoConnectionManager()
+TEST_CASE("TestFdoConnectionManager", "[FeatureService]")
try
MgFdoConnectionManager* pManager = MgFdoConnectionManager::GetInstance();
- if(pManager == 0)
+ if (pManager == NULL)
throw new MgNullReferenceException(L"TestFeatureService.TestCase_TestFdoConnectionManager", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -430,20 +198,20 @@
#endif
FdoIConnection* pFdoConnection1 = pManager->Open(provider, connectionString);
- CPPUNIT_ASSERT(pFdoConnection1);
+ REQUIRE(pFdoConnection1);
FdoIConnection* pFdoConnectionAlt = pManager->Open(provider, connectionStringAlt);
- CPPUNIT_ASSERT(pFdoConnectionAlt);
+ REQUIRE(pFdoConnectionAlt);
FdoIConnection* pFdoConnection2 = pManager->Open(provider, connectionString);
- CPPUNIT_ASSERT(pFdoConnection2);
+ REQUIRE(pFdoConnection2);
FdoIConnection* pFdoConnection3 = pManager->Open(provider, connectionString);
- CPPUNIT_ASSERT(pFdoConnection3);
+ REQUIRE(pFdoConnection3);
// These connections should be different
- CPPUNIT_ASSERT(pFdoConnection1 != pFdoConnection2);
- CPPUNIT_ASSERT(pFdoConnection1 != pFdoConnection3);
+ REQUIRE(pFdoConnection1 != pFdoConnection2);
+ REQUIRE(pFdoConnection1 != pFdoConnection3);
pManager->Close(pFdoConnection1);
pManager->Close(pFdoConnection2);
@@ -459,14 +227,14 @@
SAFE_RELEASE(e);
catch(...)
@@ -480,18 +248,18 @@
/// This test case gets the connection property values.
-void TestFeatureService::TestCase_GetConnectionPropertyValues()
+TEST_CASE("GetConnectionPropertyValues", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetConnectionPropertyValues", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetConnectionPropertyValues", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -499,23 +267,23 @@
STRING provider = L"";
STRING property = L"";
STRING connectionString = L"";
- CPPUNIT_ASSERT_THROW_MG(pService->GetConnectionPropertyValues(provider, property, connectionString), MgInvalidArgumentException*);
+ REQUIRE_THROWS_MG(pService->GetConnectionPropertyValues(provider, property, connectionString), MgInvalidArgumentException*);
provider = L"OSGeo.SDF";
property = L"ReadOnly";
Ptr<MgStringCollection> properties = pService->GetConnectionPropertyValues(provider, property, connectionString);
- CPPUNIT_ASSERT(properties->GetCount() > 0);
+ REQUIRE(properties->GetCount() > 0);
SAFE_RELEASE(e);
catch(...)
@@ -529,18 +297,18 @@
/// This test case gets the provider capabilities.
-void TestFeatureService::TestCase_GetCapabilities()
+TEST_CASE("GetCapabilities", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetCapabilities", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetCapabilities", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -548,7 +316,7 @@
STRING provider = L"OSGeo.SDF";
MgFdoConnectionManager* fdoConnectionManager = MgFdoConnectionManager::GetInstance();
- if(fdoConnectionManager == 0)
+ if (fdoConnectionManager == NULL)
@@ -556,22 +324,22 @@
Ptr<MgByteReader> reader = pService->GetCapabilities(providerNoVersion);
STRING mimetype = reader->GetMimeType();
- CPPUNIT_ASSERT(wcscmp(mimetype.c_str(), MgMimeType::Xml.c_str()) == 0);
+ REQUIRE(wcscmp(mimetype.c_str(), MgMimeType::Xml.c_str()) == 0);
provider = L"";
- CPPUNIT_ASSERT_THROW_MG(pService->GetCapabilities(provider), MgInvalidArgumentException*);
+ REQUIRE_THROWS_MG(pService->GetCapabilities(provider), MgInvalidArgumentException*);
SAFE_RELEASE(e);
catch(...)
@@ -585,42 +353,42 @@
/// This test case tests a connection to a resource.
-void TestFeatureService::TestCase_TestConnectionResourceIdentifier()
+TEST_CASE("TestConnectionResourceIdentifier", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_TestConnectionResourceIdentifier", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_TestConnectionResourceIdentifier", __LINE__, __WFILE__, NULL, L"", NULL);
Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier();
- CPPUNIT_ASSERT_THROW_MG(pService->TestConnection(resource), MgInvalidRepositoryTypeException*);
+ REQUIRE_THROWS_MG(pService->TestConnection(resource), MgInvalidRepositoryTypeException*);
resource = new MgResourceIdentifier(L"Library://UnitTests/Geography/World.MapDefinition");
- CPPUNIT_ASSERT_THROW_MG(pService->TestConnection(resource), MgInvalidResourceTypeException*);
+ REQUIRE_THROWS_MG(pService->TestConnection(resource), MgInvalidResourceTypeException*);
resource = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
bool bResult = pService->TestConnection(resource);
- CPPUNIT_ASSERT(bResult);
+ REQUIRE(bResult);
SAFE_RELEASE(e);
catch(...)
@@ -634,18 +402,18 @@
/// This test case exercises getting schemas.
-void TestFeatureService::TestCase_GetSchemas()
+TEST_CASE("GetSchemas", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetSchemas", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetSchemas", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -655,25 +423,25 @@
MgUserInformation::SetCurrentUserInfo(adminUserInfo);
- CPPUNIT_ASSERT_THROW_MG(pService->GetSchemas(resource), MgInvalidRepositoryTypeException*);
+ REQUIRE_THROWS_MG(pService->GetSchemas(resource), MgInvalidRepositoryTypeException*);
- CPPUNIT_ASSERT_THROW_MG(pService->GetSchemas(resource), MgInvalidResourceTypeException*);
+ REQUIRE_THROWS_MG(pService->GetSchemas(resource), MgInvalidResourceTypeException*);
Ptr<MgStringCollection> schemas = pService->GetSchemas(resource);
- CPPUNIT_ASSERT(schemas->GetCount() > 0);
+ REQUIRE(schemas->GetCount() > 0);
SAFE_RELEASE(e);
catch(...)
@@ -687,18 +455,18 @@
/// This test case exercises getting classes.
-void TestFeatureService::TestCase_GetClasses()
+TEST_CASE("GetClasses", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetClasses", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetClasses", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -709,26 +477,26 @@
STRING schemaName = L"";
- CPPUNIT_ASSERT_THROW_MG(pService->GetClasses(resource, schemaName), MgInvalidRepositoryTypeException*);
+ REQUIRE_THROWS_MG(pService->GetClasses(resource, schemaName), MgInvalidRepositoryTypeException*);
- CPPUNIT_ASSERT_THROW_MG(pService->GetClasses(resource, schemaName), MgInvalidResourceTypeException*);
+ REQUIRE_THROWS_MG(pService->GetClasses(resource, schemaName), MgInvalidResourceTypeException*);
schemaName = L"SHP_Schema";
Ptr<MgStringCollection> classes = pService->GetClasses(resource, schemaName);
- CPPUNIT_ASSERT(classes->GetCount() > 0);
+ REQUIRE(classes->GetCount() > 0);
SAFE_RELEASE(e);
catch(...)
@@ -742,18 +510,18 @@
/// This test case exercises getting class definitions.
-void TestFeatureService::TestCase_GetClassDefinition()
+TEST_CASE("GetClassDefinition", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetClassDefinition", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetClassDefinition", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -761,7 +529,7 @@
STRING className = L"";
- CPPUNIT_ASSERT_THROW_MG(pService->GetClassDefinition(resource, schemaName, className), MgClassNotFoundException*);
+ REQUIRE_THROWS_MG(pService->GetClassDefinition(resource, schemaName, className), MgClassNotFoundException*);
@@ -768,18 +536,18 @@
className = L"Parcels";
Ptr<MgClassDefinition> classDef = pService->GetClassDefinition(resource, schemaName, className);
STRING name = classDef->GetName();
- CPPUNIT_ASSERT(name == L"Parcels");
+ REQUIRE(name == L"Parcels");
SAFE_RELEASE(e);
catch(...)
@@ -792,18 +560,18 @@
/// This test case exercises the GetIdentityProperties() internal API
-void TestFeatureService::TestCase_GetIdentityProperties()
+TEST_CASE("GetIdentityProperties", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetIdentityProperties", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetIdentityProperties", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -829,28 +597,30 @@
Ptr<MgStringCollection> classNames = new MgStringCollection();
classNames->Add(L"NoProps");
Ptr<MgClassDefinitionCollection> matchingClasses = pService->GetIdentityProperties(fsId, L"UnitTest", classNames);
- CPPUNIT_ASSERT_MESSAGE("Expected class (NoProps) to be in result for GetIdentityProperties", 1 == matchingClasses->GetCount());
+ // Expected class (NoProps) to be in result for GetIdentityProperties
+ REQUIRE(1 == matchingClasses->GetCount());
// Here's the kicker - We expect 0 identity properties instead of exception (#1403)
Ptr<MgClassDefinition> klass = matchingClasses->GetItem(0);
Ptr<MgPropertyDefinitionCollection> idProps = klass->GetIdentityProperties();
- CPPUNIT_ASSERT_MESSAGE("Expected 0 identity properties in class (NoProps)", 0 == idProps->GetCount());
+ // Expected 0 identity properties in class (NoProps)
+ REQUIRE(0 == idProps->GetCount());
// Here is where exception should be thrown
classNames->Clear();
classNames->Add(L"IDontExist");
- CPPUNIT_ASSERT_THROW_MG(pService->GetIdentityProperties(fsId, L"UnitTest", classNames), MgFdoException*);
+ REQUIRE_THROWS_MG(pService->GetIdentityProperties(fsId, L"UnitTest", classNames), MgFdoException*);
SAFE_RELEASE(e);
catch(...)
@@ -864,18 +634,18 @@
/// This test case exercises describing schemas.
-void TestFeatureService::TestCase_DescribeSchema()
+TEST_CASE("DescribeSchema", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_DescribeSchema", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_DescribeSchema", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -886,27 +656,27 @@
- CPPUNIT_ASSERT_THROW_MG(pService->DescribeSchema(resource, schemaName, NULL), MgInvalidRepositoryTypeException*);
+ REQUIRE_THROWS_MG(pService->DescribeSchema(resource, schemaName, NULL), MgInvalidRepositoryTypeException*);
schemaName = L"";
- CPPUNIT_ASSERT_THROW_MG(pService->DescribeSchema(resource, schemaName, NULL), MgInvalidResourceTypeException*);
+ REQUIRE_THROWS_MG(pService->DescribeSchema(resource, schemaName, NULL), MgInvalidResourceTypeException*);
schemaName = L"";
Ptr<MgFeatureSchemaCollection> schemaCollection = pService->DescribeSchema(resource, schemaName, NULL);
- CPPUNIT_ASSERT(schemaCollection->GetCount() > 0);
+ REQUIRE(schemaCollection->GetCount() > 0);
SAFE_RELEASE(e);
catch(...)
@@ -936,18 +706,18 @@
/// This test case exercises applying schemas.
-void TestFeatureService::TestCase_ApplySchema()
+TEST_CASE("ApplySchema", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_ApplySchema", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_ApplySchema", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -976,7 +746,7 @@
Ptr<MgClassDefinitionCollection> newSchemaClasses = newSchema->GetClasses();
Ptr<MgClassDefinition> newClassDef = FindClassByName(newSchemaClasses, L"Parcel");
Ptr<MgPropertyDefinitionCollection> newProperties = newClassDef->GetProperties();
- CPPUNIT_ASSERT(newProperties->Contains(L"Name") == false);
+ REQUIRE(newProperties->Contains(L"Name") == false);
/// The second test case: ///
@@ -1049,7 +819,7 @@
STRING temp;
newSchema = newSchemas->GetItem(0);
temp = newSchema->GetName();
- CPPUNIT_ASSERT(temp == L"Schema");
+ REQUIRE(temp == L"Schema");
schemaClasses = newSchema->GetClasses();
@@ -1056,62 +826,62 @@
// Verify the first feature class
classDef1 = FindClassByName(schemaClasses, L"FeatureClass1");
temp = classDef1->GetName();
- CPPUNIT_ASSERT(temp == L"FeatureClass1");
+ REQUIRE(temp == L"FeatureClass1");
temp = classDef1->GetDescription();
- CPPUNIT_ASSERT(temp == L"Feature class 1");
+ REQUIRE(temp == L"Feature class 1");
temp = classDef1->GetDefaultGeometryPropertyName();
- CPPUNIT_ASSERT(temp == L"GEOM");
+ REQUIRE(temp == L"GEOM");
identityProperties1 = classDef1->GetIdentityProperties();
- CPPUNIT_ASSERT(identityProperties1->GetCount() == 1);
+ REQUIRE(identityProperties1->GetCount() == 1);
prop = static_cast<MgDataPropertyDefinition*>(identityProperties1->GetItem(L"KEY1"));
- CPPUNIT_ASSERT(prop != NULL);
+ REQUIRE(prop.p != NULL);
properties1 = classDef1->GetProperties();
- CPPUNIT_ASSERT(properties1->GetCount() == 3);
+ REQUIRE(properties1->GetCount() == 3);
prop = static_cast<MgDataPropertyDefinition*>(properties1->GetItem(L"KEY1"));
- CPPUNIT_ASSERT(prop->GetDataType() == MgPropertyType::Int32);
- CPPUNIT_ASSERT(prop->IsAutoGenerated() == true);
- CPPUNIT_ASSERT(prop->GetReadOnly() == true);
+ REQUIRE(prop->GetDataType() == MgPropertyType::Int32);
+ REQUIRE(prop->IsAutoGenerated() == true);
+ REQUIRE(prop->GetReadOnly() == true);
prop = static_cast<MgDataPropertyDefinition*>(properties1->GetItem(L"NAME1"));
- CPPUNIT_ASSERT(prop->GetDataType() == MgPropertyType::String);
+ REQUIRE(prop->GetDataType() == MgPropertyType::String);
propGeom = static_cast<MgGeometricPropertyDefinition*>(properties1->GetItem(L"GEOM"));
- CPPUNIT_ASSERT(propGeom->GetGeometryTypes() == MgFeatureGeometricType::Surface);
+ REQUIRE(propGeom->GetGeometryTypes() == MgFeatureGeometricType::Surface);
// Verify the second feature class
classDef2 = FindClassByName(schemaClasses, L"FeatureClass2");
temp = classDef2->GetDescription();
- CPPUNIT_ASSERT(temp == L"Feature class 2");
+ REQUIRE(temp == L"Feature class 2");
temp = classDef2->GetDefaultGeometryPropertyName();
identityProperties2 = classDef2->GetIdentityProperties();
- CPPUNIT_ASSERT(identityProperties2->GetCount() == 1);
+ REQUIRE(identityProperties2->GetCount() == 1);
prop = static_cast<MgDataPropertyDefinition*>(identityProperties2->GetItem(L"KEY2"));
properties2 = classDef2->GetProperties();
- CPPUNIT_ASSERT(properties2->GetCount() == 3);
+ REQUIRE(properties2->GetCount() == 3);
prop = static_cast<MgDataPropertyDefinition*>(properties2->GetItem(L"KEY2"));
prop = static_cast<MgDataPropertyDefinition*>(properties2->GetItem(L"NAME2"));
propGeom = static_cast<MgGeometricPropertyDefinition*>(properties2->GetItem(L"GEOM"));
- CPPUNIT_ASSERT(propGeom->GetGeometryTypes() == MgFeatureGeometricType::Curve);
+ REQUIRE(propGeom->GetGeometryTypes() == MgFeatureGeometricType::Curve);
/// The third test case: ///
@@ -1141,53 +911,53 @@
newSchemas = pService->DescribeSchema(resource, L"Schema", NULL);
- CPPUNIT_ASSERT(classDef1 == NULL);
+ REQUIRE(classDef1.p == NULL);
- CPPUNIT_ASSERT(temp == L"Modified Feature Class");
+ REQUIRE(temp == L"Modified Feature Class");
- CPPUNIT_ASSERT(properties2->GetCount() == 5);
+ REQUIRE(properties2->GetCount() == 5);
prop = static_cast<MgDataPropertyDefinition*>(properties2->GetItem(L"ID"));
prop = static_cast<MgDataPropertyDefinition*>(properties2->GetItem(L"LENGTH"));
- CPPUNIT_ASSERT(prop->GetDataType() == MgPropertyType::Single);
+ REQUIRE(prop->GetDataType() == MgPropertyType::Single);
SAFE_RELEASE(e);
catch(...)
@@ -1201,18 +971,18 @@
/// This test case exercises selecting features.
-void TestFeatureService::TestCase_SelectFeatures()
+TEST_CASE("SelectFeatures", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_SelectFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_SelectFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1220,7 +990,7 @@
Ptr<MgFeatureQueryOptions> options = new MgFeatureQueryOptions();
- CPPUNIT_ASSERT_THROW_MG(pService->SelectFeatures(resource, className, options), MgInvalidArgumentException*);
+ REQUIRE_THROWS_MG(pService->SelectFeatures(resource, className, options), MgInvalidArgumentException*);
@@ -1227,18 +997,18 @@
Ptr<MgFeatureReader> reader = pService->SelectFeatures(resource, className, options);
bool bResult = reader->ReadNext();
reader->Close();
+ REQUIRE(bResult);
SAFE_RELEASE(e);
catch(...)
@@ -1251,18 +1021,18 @@
/// This test case exercises selecting features transformed to a specific coordinate system.
-void TestFeatureService::TestCase_SelectFeaturesWithXform()
+TEST_CASE("SelectFeaturesWithXform", "[FeatureService]")
try
@@ -1329,44 +1099,44 @@
Ptr<MgFeatureQueryOptions> query = new MgFeatureQueryOptions();
Ptr<MgReader> reader = pService->SelectFeatures(fsId, L"Default:Test", query, dstWkt);
- CPPUNIT_ASSERT(reader->ReadNext());
- CPPUNIT_ASSERT(!reader->IsNull(L"Geometry"));
+ REQUIRE(reader->ReadNext());
+ REQUIRE(!reader->IsNull(L"Geometry"));
Ptr<MgByteReader> txAgf1 = reader->GetGeometry(L"Geometry");
Ptr<MgGeometry> txGeom1 = agfRw->Read(txAgf1);
MgPoint* txPt1 = dynamic_cast<MgPoint*>(txGeom1.p);
- CPPUNIT_ASSERT(txPt1 != NULL);
+ REQUIRE(txPt1 != NULL);
Ptr<MgCoordinate> txCoord1 = txPt1->GetCoordinate();
//TODO: Maybe we should really check that it matches the expected transformed result
- CPPUNIT_ASSERT(txCoord1->GetX() != -37.1020);
- CPPUNIT_ASSERT(txCoord1->GetY() != 144.0020);
+ REQUIRE(txCoord1->GetX() != -37.1020);
+ REQUIRE(txCoord1->GetY() != 144.0020);
Ptr<MgByteReader> txAgf2 = reader->GetGeometry(L"Geometry");
Ptr<MgGeometry> txGeom2 = agfRw->Read(txAgf2);
MgPoint* txPt2 = dynamic_cast<MgPoint*>(txGeom2.p);
- CPPUNIT_ASSERT(txPt2 != NULL);
+ REQUIRE(txPt2 != NULL);
Ptr<MgCoordinate> txCoord2 = txPt2->GetCoordinate();
- CPPUNIT_ASSERT(txCoord2->GetX() != -37.2020);
- CPPUNIT_ASSERT(txCoord2->GetY() != 144.2020);
+ REQUIRE(txCoord2->GetX() != -37.2020);
+ REQUIRE(txCoord2->GetY() != 144.2020);
reader->Close();
SAFE_RELEASE(e);
catch(...)
@@ -1381,7 +1151,7 @@
/// with ordering (not supported in capabilities, but allowed through extended
/// select but only on a single property)
-void TestFeatureService::TestCase_SelectFeaturesSdfWithOrdering()
+TEST_CASE("SelectFeaturesSdfWithOrdering", "[FeatureService]")
try
@@ -1392,7 +1162,7 @@
@@ -1407,7 +1177,7 @@
options->SetOrderingFilter(orderProps, MgOrderingOption::Descending);
//Invalid conditions for ordered select
- CPPUNIT_ASSERT_THROW_MG(pService->SelectFeatures(resource, className, options), MgFeatureServiceException*);
+ REQUIRE_THROWS_MG(pService->SelectFeatures(resource, className, options), MgFeatureServiceException*);
orderProps->Clear();
orderProps->Add(L"ID");
@@ -1421,7 +1191,7 @@
str += reader->GetString(L"ID");
reader->Close();
- CPPUNIT_ASSERT(str == L"12334456678");
+ REQUIRE(str == L"12334456678");
@@ -1435,18 +1205,18 @@
reader->Close();
- CPPUNIT_ASSERT(str == L"87665443321");
+ REQUIRE(str == L"87665443321");
SAFE_RELEASE(e);
catch (FdoException* e)
catch (...)
@@ -1459,18 +1229,18 @@
/// This test case exercises selecting aggregate features.
-void TestFeatureService::TestCase_SelectAggregate()
+TEST_CASE("SelectAggregates", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_SelectAggregate", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_SelectAggregate", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1478,7 +1248,7 @@
Ptr<MgFeatureAggregateOptions> options = new MgFeatureAggregateOptions();
- CPPUNIT_ASSERT_THROW_MG(pService->SelectAggregate(resource, className, options), MgInvalidArgumentException*);
+ REQUIRE_THROWS_MG(pService->SelectAggregate(resource, className, options), MgInvalidArgumentException*);
@@ -1486,18 +1256,18 @@
Ptr<MgDataReader> reader = pService->SelectAggregate(resource, className, options);
reader->Close();
+ REQUIRE(bResult);
SAFE_RELEASE(e);
catch(...)
@@ -1512,18 +1282,18 @@
/// This test case exercises executing SQL queries containing SELECT
/// statements.
-void TestFeatureService::TestCase_ExecuteSqlQuery()
+TEST_CASE("ExecuteSqlQuery", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_ExecuteSqlQuery", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_ExecuteSqlQuery", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1530,20 +1300,20 @@
const STRING sqlQuery = L"";
- CPPUNIT_ASSERT_THROW_MG(pService->ExecuteSqlQuery(resource, sqlQuery), MgInvalidArgumentException*);
+ REQUIRE_THROWS_MG(pService->ExecuteSqlQuery(resource, sqlQuery), MgInvalidArgumentException*);
//TODO test with correct input
SAFE_RELEASE(e);
catch(...)
@@ -1558,18 +1328,18 @@
/// This test case exercises executing SQL queries not containing
/// SELECT statements.
-void TestFeatureService::TestCase_ExecuteSqlNonQuery()
+TEST_CASE("ExecuteSqlNonQuery", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_ExecuteSqlNonQuery", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_ExecuteSqlNonQuery", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1576,20 +1346,20 @@
const STRING sqlNonQuery = L"";
- CPPUNIT_ASSERT_THROW_MG(pService->ExecuteSqlNonQuery(resource, sqlNonQuery), MgInvalidArgumentException*);
+ REQUIRE_THROWS_MG(pService->ExecuteSqlNonQuery(resource, sqlNonQuery), MgInvalidArgumentException*);
SAFE_RELEASE(e);
catch(...)
@@ -1603,18 +1373,18 @@
/// This test case exercises getting spatial contexts.
-void TestFeatureService::TestCase_GetSpatialContexts()
+TEST_CASE("GetSpatialContexts", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetSpatialContexts", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetSpatialContexts", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1625,10 +1395,10 @@
bool activeOnly = false;
- CPPUNIT_ASSERT_THROW_MG(pService->GetSpatialContexts(resource, activeOnly), MgInvalidRepositoryTypeException*);
+ REQUIRE_THROWS_MG(pService->GetSpatialContexts(resource, activeOnly), MgInvalidRepositoryTypeException*);
- CPPUNIT_ASSERT_THROW_MG(pService->GetSpatialContexts(resource, activeOnly), MgInvalidResourceTypeException*);
+ REQUIRE_THROWS_MG(pService->GetSpatialContexts(resource, activeOnly), MgInvalidResourceTypeException*);
@@ -1637,7 +1407,7 @@
// Advance to the 1st spatial context
+ REQUIRE(bResult);
// Get the CS name and CS WKT
STRING csName = reader->GetName();
@@ -1644,8 +1414,8 @@
STRING csWkt = reader->GetCoordinateSystemWkt();
ACE_DEBUG((LM_DEBUG, ACE_TEXT("TestFeatureService::TestCase_GetSpatialContexts()\nName: %W\nWKT: %W\n"), csName.c_str(), csWkt.c_str()));
- CPPUNIT_ASSERT(wcscmp(csName.c_str(), L"WGS84 Lat/Long's, Degre") == 0);
- CPPUNIT_ASSERT(wcscmp(csWkt.c_str(), L"GEOGCS[\"WGS84 Lat/Long's, Degrees, -180 ==> +180\",DATUM[\"D_WGS_1984\",SPHEROID[\"World_Geodetic_System_of_1984\",6378137,298.257222932867]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.017453292519943295]]") == 0);
+ REQUIRE(wcscmp(csName.c_str(), L"WGS84 Lat/Long's, Degre") == 0);
+ REQUIRE(wcscmp(csWkt.c_str(), L"GEOGCS[\"WGS84 Lat/Long's, Degrees, -180 ==> +180\",DATUM[\"D_WGS_1984\",SPHEROID[\"World_Geodetic_System_of_1984\",6378137,298.257222932867]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.017453292519943295]]") == 0);
// Close the reader
reader->Close();
@@ -1658,13 +1428,13 @@
+ REQUIRE(bResult);
// Close the reader
reader->Close();
@@ -1671,14 +1441,14 @@
SAFE_RELEASE(e);
catch(...)
@@ -1692,18 +1462,18 @@
/// This test case exercises getting long transactions.
-void TestFeatureService::TestCase_GetLongTransactions()
+TEST_CASE("GetLongTransaction", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetLongTransactions", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetLongTransactions", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1714,23 +1484,23 @@
- CPPUNIT_ASSERT_THROW_MG(pService->GetLongTransactions(resource, activeOnly), MgInvalidRepositoryTypeException*);
+ REQUIRE_THROWS_MG(pService->GetLongTransactions(resource, activeOnly), MgInvalidRepositoryTypeException*);
- CPPUNIT_ASSERT_THROW_MG(pService->GetLongTransactions(resource, activeOnly), MgInvalidResourceTypeException*);
+ REQUIRE_THROWS_MG(pService->GetLongTransactions(resource, activeOnly), MgInvalidResourceTypeException*);
SAFE_RELEASE(e);
catch(...)
@@ -1744,18 +1514,18 @@
/// This test case exercises setting long transaction names.
-void TestFeatureService::TestCase_SetLongTransaction()
+TEST_CASE("SetLongTransaction", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_SetLongTransaction", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_SetLongTransaction", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1763,46 +1533,46 @@
STRING longTransactionName = L"Live";
// verify exception when passing in a NULL resource
- CPPUNIT_ASSERT_THROW_MG(pService->SetLongTransaction(NULL, longTransactionName), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->SetLongTransaction(NULL, longTransactionName), MgNullArgumentException*);
// verify exception when passing in an invalid resource type
- CPPUNIT_ASSERT_THROW_MG(pService->SetLongTransaction(resource, longTransactionName), MgInvalidResourceTypeException*);
+ REQUIRE_THROWS_MG(pService->SetLongTransaction(resource, longTransactionName), MgInvalidResourceTypeException*);
// verify exception when session is not set
- CPPUNIT_ASSERT_THROW_MG(pService->SetLongTransaction(resource, longTransactionName), MgSessionNotFoundException*);
+ REQUIRE_THROWS_MG(pService->SetLongTransaction(resource, longTransactionName), MgSessionNotFoundException*);
// set the user information for the current thread to be administrator - this
// alone doesn't create a session
Ptr<MgUserInformation> userInfo = new MgUserInformation(MgUser::Administrator, L"");
// now set a session
userInfo->SetMgSessionId(userInfo->CreateMgSessionId());
- CPPUNIT_ASSERT(pService->SetLongTransaction(resource, longTransactionName));
+ REQUIRE(pService->SetLongTransaction(resource, longTransactionName));
// setting the same LT name twice shouldn't matter
// should be able to clear the LT name
- CPPUNIT_ASSERT(pService->SetLongTransaction(resource, L""));
+ REQUIRE(pService->SetLongTransaction(resource, L""));
SAFE_RELEASE(e);
catch(...)
@@ -1816,37 +1586,37 @@
/// This test case exercises getting features.
-void TestFeatureService::TestCase_GetFeatures()
+TEST_CASE("GetFeatures", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
STRING readerId = L"0";
- CPPUNIT_ASSERT_THROW_MG(pService->GetFeatures(readerId), MgInvalidArgumentException*);
+ REQUIRE_THROWS_MG(pService->GetFeatures(readerId), MgInvalidArgumentException*);
SAFE_RELEASE(e);
catch(...)
@@ -1860,18 +1630,18 @@
/// This test case exercises closing a feature reader.
-void TestFeatureService::TestCase_CloseFeatureReader()
+TEST_CASE("CloseFeatureReader", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_CloseFeatureReader", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_CloseFeatureReader", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1878,20 +1648,20 @@
bool closed = pService->CloseFeatureReader(readerId);
- CPPUNIT_ASSERT(!closed);
+ REQUIRE(!closed);
// TODO test with correct input
SAFE_RELEASE(e);
catch(...)
@@ -1905,37 +1675,37 @@
/// This test case exercises getting SQL rows.
-void TestFeatureService::TestCase_GetSqlRows()
+TEST_CASE("GetSqlRows", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetSqlRows", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetSqlRows", __LINE__, __WFILE__, NULL, L"", NULL);
STRING sqlReader = L"0";
- CPPUNIT_ASSERT_THROW_MG(pService->GetSqlRows(sqlReader), MgInvalidArgumentException*);
+ REQUIRE_THROWS_MG(pService->GetSqlRows(sqlReader), MgInvalidArgumentException*);
SAFE_RELEASE(e);
catch(...)
@@ -1949,18 +1719,18 @@
/// This test case exercises closing a SQL reader.
-void TestFeatureService::TestCase_CloseSqlReader()
+TEST_CASE("CloseSqlReader", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_CloseSqlReader", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_CloseSqlReader", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1967,20 +1737,20 @@
bool closed = pService->CloseSqlReader(sqlReader);
+ REQUIRE(!closed);
SAFE_RELEASE(e);
catch(...)
@@ -1994,18 +1764,18 @@
/// This test case exercises getting a raster.
-void TestFeatureService::TestCase_GetRaster()
+TEST_CASE("GetRaster", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetRaster", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetRaster", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -2013,20 +1783,20 @@
STRING featureReader = L"0";
INT32 xSize = 0;
INT32 ySize = 0;
- CPPUNIT_ASSERT_THROW_MG(pService->GetRaster(featureReader, xSize, ySize, L""), MgInvalidArgumentException*);
+ REQUIRE_THROWS_MG(pService->GetRaster(featureReader, xSize, ySize, L""), MgInvalidArgumentException*);
SAFE_RELEASE(e);
catch(...)
@@ -2040,37 +1810,37 @@
/// This test case exercises getting data rows.
-void TestFeatureService::TestCase_GetDataRows()
+TEST_CASE("GetDataRows", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_GetDataRows", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_GetDataRows", __LINE__, __WFILE__, NULL, L"", NULL);
STRING dataReader = L"0";
- CPPUNIT_ASSERT_THROW_MG(pService->GetDataRows(dataReader), MgInvalidArgumentException*);
+ REQUIRE_THROWS_MG(pService->GetDataRows(dataReader), MgInvalidArgumentException*);
SAFE_RELEASE(e);
catch(...)
@@ -2084,18 +1854,18 @@
/// This test case exercises closing a data reader.
-void TestFeatureService::TestCase_CloseDataReader()
+TEST_CASE("CloseDataReader", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_CloseDataReader", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_CloseDataReader", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -2102,20 +1872,20 @@
bool closed = pService->CloseDataReader(dataReader);
+ REQUIRE(!closed);
SAFE_RELEASE(e);
catch(...)
@@ -2129,12 +1899,12 @@
/// This test case exercises joining features.
-void TestFeatureService::TestCase_JoinFeatures()
+TEST_CASE("JoinFeatures", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_JoinFeatures",
@@ -2141,7 +1911,7 @@
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_JoinFeatures",
@@ -2162,22 +1932,22 @@
// Close the reader
reader->Close();
- CPPUNIT_ASSERT(bReadNextResult);
- CPPUNIT_ASSERT(bIsNullResult == false);
- CPPUNIT_ASSERT(s1 == L"NIEMUTH, ROGER L.");
- CPPUNIT_ASSERT(s2 == L"Wells Fargo");
- CPPUNIT_ASSERT(s3 == L"10573");
+ REQUIRE(bReadNextResult);
+ REQUIRE(bIsNullResult == false);
+ REQUIRE(s1 == L"NIEMUTH, ROGER L.");
+ REQUIRE(s2 == L"Wells Fargo");
+ REQUIRE(s3 == L"10573");
SAFE_RELEASE(e);
catch(...)
@@ -2191,7 +1961,7 @@
/// This test case exercises joining features defined as chained, inner, 1-to-many.
-void TestFeatureService::TestCase_JoinFeaturesChainedInner1ToMany()
+TEST_CASE("JoinFeaturesChainedInner1ToMany", "[FeatureService]")
try
@@ -2205,7 +1975,7 @@
#endif
throw new MgNullReferenceException(L"TestFeatureService.TestCase_JoinFeaturesChainedInner1ToMany",
@@ -2212,7 +1982,7 @@
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_JoinFeaturesChainedInner1ToMany",
@@ -2242,25 +2012,25 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("TestFeatureService::TestCase_JoinFeaturesChainedInner1ToMany() - End\n")));
#endif
- CPPUNIT_ASSERT(bIsNullResult2 == false);
- CPPUNIT_ASSERT(s1 == L"CITY OF SHEBOYGAN");
- CPPUNIT_ASSERT(s2 == L"Johnson Bank");
- CPPUNIT_ASSERT(s3 == L"30320");
- CPPUNIT_ASSERT(s4 == L"Voting District Seven");
- CPPUNIT_ASSERT(s5 == L"7");
+ REQUIRE(bIsNullResult2 == false);
+ REQUIRE(s1 == L"CITY OF SHEBOYGAN");
+ REQUIRE(s2 == L"Johnson Bank");
+ REQUIRE(s3 == L"30320");
+ REQUIRE(s4 == L"Voting District Seven");
+ REQUIRE(s5 == L"7");
SAFE_RELEASE(e);
catch(...)
@@ -2275,12 +2045,12 @@
/// This test case exercises creating a feature source.
-void TestFeatureService::TestCase_CreateFeatureSource()
+TEST_CASE("CreateFeatureSource", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_CreateFeatureSource",
@@ -2287,7 +2057,7 @@
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_CreateFeatureSource",
@@ -2294,7 +2064,7 @@
Ptr<MgResourceService> pResourceService = dynamic_cast<MgResourceService*>(serviceManager->RequestService(MgServiceType::ResourceService));
@@ -2363,14 +2133,14 @@
SAFE_RELEASE(e);
catch(...)
@@ -2381,92 +2151,9 @@
-/// This test case benchmarks selecting features.
-void TestFeatureService::TestCase_BenchmarkSelectFeatures()
- try
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSelectFeatures() - Start\n")));
- #ifdef _DEBUG
- #endif
- throw new MgNullReferenceException(L"TestFeatureService.TestCase_BenchmarkSelectFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
- Ptr<MgFeatureService> pService = dynamic_cast<MgFeatureService*>(serviceManager->RequestService(MgServiceType::FeatureService));
- throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_BenchmarkSelectFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
- Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier();
- STRING className = L"Parcels";
- resource = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
- Ptr<MgFeatureQueryOptions> options = new MgFeatureQueryOptions();
-#ifdef _DEBUG
- const int iterations = 1;
-#else
- const int iterations = 1000;
-#endif
- long lStart = GetTickCount();
- for(int i=0;i<iterations;i++)
- int nFeatures = 0;
- Ptr<MgFeatureReader> reader = pService->SelectFeatures(resource, className, options);
- while(reader->ReadNext())
- nFeatures++;
- // Close the reader
- reader->Close();
- CPPUNIT_ASSERT(nFeatures == 17565);
- #ifdef _DEBUG
- #endif
- ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (Average of %d runs): = %6.4f (s)\n"), iterations, ((GetTickCount()-lStart)/1000.0)/(double)iterations ));
- ACE_DEBUG((LM_INFO, ACE_TEXT("TestCase_BenchmarkSelectFeatures - END\n")));
- SAFE_RELEASE(e);
- catch(FdoException* e)
- FDO_SAFE_RELEASE(e);
- catch(...)
- throw;
-/// Test Case Description:
/// This test case tests concurrent access to a provider.
-void TestFeatureService::TestCase_ConcurrentAccess()
+TEST_CASE("ConcurrentAccess", "[FeatureService]")
vector<MgFeatureReader*> featureReaders;
@@ -2482,13 +2169,13 @@
#endif
throw new MgNullReferenceException(L"TestFeatureService.TestCase_ConcurrentAccess", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_ConcurrentAccess", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -2518,7 +2205,7 @@
// Create another reader - this one should timeout and throw exception
Ptr<MgFeatureReader> readerFail;
- CPPUNIT_ASSERT_THROW_MG(readerFail = pService->SelectFeatures(resource, className, options), MgAllProviderConnectionsUsedException*);
+ REQUIRE_THROWS_MG(readerFail = pService->SelectFeatures(resource, className, options), MgAllProviderConnectionsUsedException*);
if (!featureReaders.empty())
@@ -2534,7 +2221,7 @@
// Create another reader - this one should succeed
Ptr<MgFeatureReader> readerSuccess = pService->SelectFeatures(resource, className, options);
bool bResult = readerSuccess->ReadNext();
+ REQUIRE(bResult);
featureReaders.push_back(readerSuccess.Detach());
@@ -2549,14 +2236,14 @@
SAFE_RELEASE(e);
catch(...)
@@ -2580,18 +2267,18 @@
featureReaders.clear();
-void TestFeatureService::TestCase_SavePoint()
+TEST_CASE("SavePoint", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_SavePoint", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_SavePoint", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -2631,7 +2318,7 @@
STRING sp = pTransaction->AddSavePoint(L"test");
STRING sp1 = pTransaction->AddSavePoint(L"test");
- CPPUNIT_ASSERT(sp != sp1);
+ REQUIRE(sp != sp1);
commands->Clear();
Ptr<MgPropertyCollection> properties3 = new MgPropertyCollection();
@@ -2658,19 +2345,19 @@
count++;
- CPPUNIT_ASSERT(count == 2);
+ REQUIRE(count == 2);
SAFE_RELEASE(e);
catch(...)
@@ -2683,18 +2370,18 @@
/// This test case exercises the UpdateFeatures API for insertion
-void TestFeatureService::TestCase_UpdateFeaturesInsert()
+TEST_CASE("UpdateFeaturesInsert", "[FeatureService]")
try
@@ -2761,10 +2448,10 @@
//Execute insert. Should be fine
Ptr<MgPropertyCollection> result = pService->UpdateFeatures(featureSource, commands, true);
- CPPUNIT_ASSERT(result->GetCount() == 1);
+ REQUIRE(result->GetCount() == 1);
INT32 i = 0;
Ptr<MgProperty> resItem1 = result->GetItem(i);
- CPPUNIT_ASSERT(resItem1->GetPropertyType() == MgPropertyType::Feature);
+ REQUIRE(resItem1->GetPropertyType() == MgPropertyType::Feature);
Ptr<MgFeatureReader> rdr = ((MgFeatureProperty*)resItem1.p)->GetValue();
rdr->Close();
@@ -2772,7 +2459,7 @@
nameVal->SetValue(L"Bar");
//Execute again, expect MgFdoException due to constraint violation
- CPPUNIT_ASSERT_THROW_MG(result = pService->UpdateFeatures(featureSource, commands, true), MgFdoException*);
+ REQUIRE_THROWS_MG(result = pService->UpdateFeatures(featureSource, commands, true), MgFdoException*);
//Expect one inserted result
@@ -2780,14 +2467,14 @@
INT32 count = 0;
while (qryReader->ReadNext()) { count++; }
qryReader->Close();
- CPPUNIT_ASSERT(1 == count);
+ REQUIRE(1 == count);
//Execute again, useTransaction = false. Should not throw exception, but log
//the error as a MgStringProperty
result = pService->UpdateFeatures(featureSource, commands, false);
- CPPUNIT_ASSERT(resItem1->GetPropertyType() == MgPropertyType::String); //Errors are of type String
+ REQUIRE(resItem1->GetPropertyType() == MgPropertyType::String); //Errors are of type String
//Use new id
idVal->SetValue(2);
@@ -2794,22 +2481,22 @@
//Should be fine now
rdr->Close();
SAFE_RELEASE(e);
catch(...)
@@ -2822,19 +2509,19 @@
/// This test case exercises the FDO join optimization
-void TestFeatureService::TestCase_JoinFdoFeatures()
+TEST_CASE("JoinFdoFeatures", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_JoinFdoFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_JoinFdoFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -2846,17 +2533,17 @@
INT32 count1 = 0;
- CPPUNIT_ASSERT(reader->IsNull(L"ID") == false);
- CPPUNIT_ASSERT(reader->IsNull(L"CountryCode") == false);
- CPPUNIT_ASSERT(reader->IsNull(L"StateCode") == false);
- CPPUNIT_ASSERT(reader->IsNull(L"Name") == false);
- CPPUNIT_ASSERT(reader->IsNull(L"Population") == false);
- CPPUNIT_ASSERT(reader->IsNull(L"CNT_CountryCode") == false);
- CPPUNIT_ASSERT(reader->IsNull(L"CNT_Name") == false);
+ REQUIRE(reader->IsNull(L"ID") == false);
+ REQUIRE(reader->IsNull(L"CountryCode") == false);
+ REQUIRE(reader->IsNull(L"StateCode") == false);
+ REQUIRE(reader->IsNull(L"Name") == false);
+ REQUIRE(reader->IsNull(L"Population") == false);
+ REQUIRE(reader->IsNull(L"CNT_CountryCode") == false);
+ REQUIRE(reader->IsNull(L"CNT_Name") == false);
count1++;
reader->Close();
- CPPUNIT_ASSERT(10 == count1);
+ REQUIRE(10 == count1);
Ptr<MgFeatureReader> reader2 = pService->SelectFeatures(lFeatureSource, L"CitiesStates", NULL);
@@ -2863,19 +2550,19 @@
INT32 count2 = 0;
while(reader2->ReadNext())
- CPPUNIT_ASSERT(reader2->IsNull(L"ID") == false);
- CPPUNIT_ASSERT(reader2->IsNull(L"CountryCode") == false);
- CPPUNIT_ASSERT(reader2->IsNull(L"StateCode") == false);
- CPPUNIT_ASSERT(reader2->IsNull(L"Name") == false);
- CPPUNIT_ASSERT(reader2->IsNull(L"Population") == false);
- CPPUNIT_ASSERT(reader2->IsNull(L"ST_ID") == false);
- CPPUNIT_ASSERT(reader2->IsNull(L"ST_CountryCode") == false);
- CPPUNIT_ASSERT(reader2->IsNull(L"ST_StateCode") == false);
- CPPUNIT_ASSERT(reader2->IsNull(L"ST_Name") == false);
+ REQUIRE(reader2->IsNull(L"ID") == false);
+ REQUIRE(reader2->IsNull(L"CountryCode") == false);
+ REQUIRE(reader2->IsNull(L"StateCode") == false);
+ REQUIRE(reader2->IsNull(L"Name") == false);
+ REQUIRE(reader2->IsNull(L"Population") == false);
+ REQUIRE(reader2->IsNull(L"ST_ID") == false);
+ REQUIRE(reader2->IsNull(L"ST_CountryCode") == false);
+ REQUIRE(reader2->IsNull(L"ST_StateCode") == false);
+ REQUIRE(reader2->IsNull(L"ST_Name") == false);
count2++;
reader2->Close();
- CPPUNIT_ASSERT(10 == count2);
+ REQUIRE(10 == count2);
Ptr<MgFeatureReader> reader3 = pService->SelectFeatures(lFeatureSource, L"CitiesStatesOneToOne", NULL);
INT32 count3 = 0;
@@ -2884,13 +2571,13 @@
count3++;
reader3->Close();
- CPPUNIT_ASSERT(10 == count3);
+ REQUIRE(10 == count3);
SAFE_RELEASE(e);
@@ -2897,7 +2584,7 @@
STRING message = L"FdoException occurred: ";
message += e->GetExceptionMessage();
catch(...)
@@ -2905,24 +2592,24 @@
-void TestFeatureService::TestCase_BenchmarkSqliteJoin()
+TEST_CASE("BenchmarkSqliteJoin", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_BenchmarkSqliteJoin", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_BenchmarkSqliteJoin", __LINE__, __WFILE__, NULL, L"", NULL);
Ptr<MgFeatureService> featSvc = dynamic_cast<MgFeatureService*>(serviceManager->RequestService(MgServiceType::FeatureService));
- if (featSvc == 0)
+ if (featSvc == NULL)
@@ -2929,7 +2616,7 @@
Ptr<MgResourceIdentifier> fsId = new MgResourceIdentifier(L"Library://UnitTests/Data/ParcelsJoinTestSQLite.FeatureSource");
- CPPUNIT_ASSERT(featSvc->TestConnection(fsId));
+ REQUIRE(featSvc->TestConnection(fsId));
Ptr<MgFeatureReader> reader;
// ----- Start the tests ------- //
@@ -2984,9 +2671,9 @@
SAFE_RELEASE(e);
@@ -2993,7 +2680,7 @@
catch(...)
@@ -3001,24 +2688,24 @@
-void TestFeatureService::TestCase_BenchmarkSqliteAggregateJoin()
+TEST_CASE("BenchmarkSqliteAggregateJoin", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_BenchmarkSqliteAggregateJoin", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_BenchmarkSqliteAggregateJoin", __LINE__, __WFILE__, NULL, L"", NULL);
- if (featSvc == 0)
@@ -3025,7 +2712,7 @@
Ptr<MgDataReader> reader;
@@ -3035,7 +2722,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Inner Join \n")));
- long total = 0L;
+ INT64 total = 0L;
int iterations = 0;
reader = featSvc->SelectAggregate(fsId, L"ParcelsInner", aggOpts);
@@ -3046,7 +2733,7 @@
iterations++;
reader->Close();
- CPPUNIT_ASSERT(iterations == 1);
+ REQUIRE(iterations == 1);
ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (%d results): = %6.4f (s)\n"), total, ((GetTickCount()-lStart)/1000.0) ));
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Left Outer Join \n")));
@@ -3061,7 +2748,7 @@
iterations++;
reader->Close();
- CPPUNIT_ASSERT(iterations == 1L);
+ REQUIRE(iterations == 1L);
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Inner Join (Forced 1:1) \n")));
@@ -3076,7 +2763,7 @@
iterations++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Left Outer Join (Forced 1:1) \n")));
@@ -3091,15 +2778,15 @@
iterations++;
reader->Close();
SAFE_RELEASE(e);
@@ -3106,7 +2793,7 @@
catch(...)
@@ -3120,18 +2807,18 @@
/// This test case tests the correct response for a non-transactional failure
/// in UpdateFeatures
-void TestFeatureService::TestCase_UpdateFeaturesPartialFailure()
+TEST_CASE("UpdateFeaturesPartialFailure", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_UpdateFeaturesPartialFailure", __LINE__, __WFILE__, NULL, L"", NULL);
- if (featSvc == 0)
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_UpdateFeaturesPartialFailure",
@@ -3146,7 +2833,7 @@
cmds->Add(insert);
Ptr<MgPropertyCollection> result = featSvc->UpdateFeatures(fsId, cmds, false);
- CPPUNIT_ASSERT(result->GetCount() > 0);
+ REQUIRE(result->GetCount() > 0);
bool bPartialFailure = false;
for (INT32 i = 0; i < result->GetCount(); i++)
@@ -3159,13 +2846,13 @@
- CPPUNIT_ASSERT(bPartialFailure);
+ REQUIRE(bPartialFailure);
SAFE_RELEASE(e);
@@ -3172,7 +2859,7 @@
catch(...)
@@ -3180,18 +2867,18 @@
-void TestFeatureService::TestCase_InsertFeatures()
+TEST_CASE("InsertFeatures", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_InsertFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
- if (featSvc == 0)
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_InsertFeatures",
@@ -3221,7 +2908,7 @@
count++;
fr->Close();
fr = featSvc->SelectFeatures(fsId, className, query);
@@ -3228,20 +2915,20 @@
count = 0;
while(fr->ReadNext())
- CPPUNIT_ASSERT(fr->GetString(L"Name") == L"Test");
+ REQUIRE(fr->GetString(L"Name") == L"Test");
agf = fr->GetGeometry(L"Geometry");
geom = agfRw.Read(agf);
- CPPUNIT_ASSERT(wktRw.Write(geom) == L"POINT (1 1)");
+ REQUIRE(wktRw.Write(geom) == L"POINT (1 1)");
count++;
fr->Close();
SAFE_RELEASE(e);
@@ -3248,7 +2935,7 @@
catch(...)
@@ -3256,18 +2943,18 @@
-void TestFeatureService::TestCase_InsertFeaturesBatch()
+TEST_CASE("InsertFeaturesBatch", "[FeatureService]")
try
MgServiceManager* serviceManager = MgServiceManager::GetInstance();
- if(serviceManager == 0)
- if (featSvc == 0)
@@ -3308,7 +2995,7 @@
count++;
fr->Close();
- CPPUNIT_ASSERT(5 == count);
+ REQUIRE(5 == count);
@@ -3318,13 +3005,13 @@
count++;
fr->Close();
SAFE_RELEASE(e);
@@ -3331,7 +3018,7 @@
catch(...)
@@ -3339,18 +3026,18 @@
-void TestFeatureService::TestCase_UpdateMatchingFeatures()
+TEST_CASE("UpdateMatchingFeatures", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_UpdateMatchingFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
- if (featSvc == 0)
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_UpdateMatchingFeatures",
@@ -3386,7 +3073,7 @@
count++;
fr->Close();
@@ -3397,7 +3084,7 @@
count++;
fr->Close();
Ptr<MgPropertyCollection> updateProps = new MgPropertyCollection();
Ptr<MgStringProperty> newNameProp = new MgStringProperty(L"Name", L"Test3Updated");
@@ -3408,7 +3095,7 @@
updateProps->Add(newGeomProp);
INT32 updated = featSvc->UpdateMatchingFeatures(fsId, className, updateProps, L"Name = 'Test3'");
- CPPUNIT_ASSERT(1 == updated);
+ REQUIRE(1 == updated);
query->SetFilter(L"Name = 'Test3'");
@@ -3418,7 +3105,7 @@
count++;
fr->Close();
- CPPUNIT_ASSERT(0 == count);
+ REQUIRE(0 == count);
query->SetFilter(L"Name = 'Test3Updated'");
@@ -3428,13 +3115,13 @@
count++;
fr->Close();
SAFE_RELEASE(e);
@@ -3441,7 +3128,7 @@
catch(...)
@@ -3449,18 +3136,18 @@
-void TestFeatureService::TestCase_DeleteFeatures()
+TEST_CASE("DeleteFeatures", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_DeleteFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
- if (featSvc == 0)
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_DeleteFeatures",
@@ -3496,7 +3183,7 @@
count++;
fr->Close();
@@ -3507,10 +3194,10 @@
count++;
fr->Close();
INT32 deleted = featSvc->DeleteFeatures(fsId, className, L"Name = 'Test3'");
- CPPUNIT_ASSERT(1 == deleted);
+ REQUIRE(1 == deleted);
@@ -3520,7 +3207,7 @@
count++;
fr->Close();
@@ -3530,13 +3217,13 @@
count++;
fr->Close();
- CPPUNIT_ASSERT(4 == count);
+ REQUIRE(4 == count);
SAFE_RELEASE(e);
@@ -3543,7 +3230,7 @@
catch(...)
@@ -3551,18 +3238,18 @@
-void TestFeatureService::TestCase_TransactedCrud()
+TEST_CASE("TransactedCrud", "[FeatureService]")
try
throw new MgNullReferenceException(L"TestFeatureService.TestCase_TransactedCrud", __LINE__, __WFILE__, NULL, L"", NULL);
- if (featSvc == 0)
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_TransactedCrud",
@@ -3598,7 +3285,7 @@
count++;
fr->Close();
@@ -3609,7 +3296,7 @@
count++;
fr->Close();
//Do a transacted update
Ptr<MgTransaction> trans = featSvc->BeginTransaction(fsId);
@@ -3623,7 +3310,7 @@
INT32 updated = featSvc->UpdateMatchingFeatures(fsId, className, updateProps, L"Name = 'Test3'", trans);
//This hasn't been commited yet. So roll it back and verify our update never made it
trans->Rollback();
@@ -3635,7 +3322,7 @@
count++;
fr->Close();
//Do a transacted update. This time, commit it.
@@ -3649,7 +3336,7 @@
trans->Commit();
//Verify the update came through
@@ -3661,13 +3348,13 @@
count++;
fr->Close();
SAFE_RELEASE(e);
@@ -3674,7 +3361,7 @@
catch(...)
@@ -3682,57 +3369,6 @@
-STRING TestFeatureService::CreateTestDataStore(MgFeatureService* svcFeature, CREFSTRING provider, MgResourceIdentifier* fsId)
- Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
- STRING scName = L"Default";
- STRING csWkt = csFactory->ConvertCoordinateSystemCodeToWkt(L"LL84");
- Ptr<MgFeatureSchema> schema = new MgFeatureSchema(L"Default", L"Default Feature Schema");
- Ptr<MgClassDefinition> klass = new MgClassDefinition();
- klass->SetName(L"Test");
- Ptr<MgPropertyDefinitionCollection> clsProps = klass->GetProperties();
- Ptr<MgPropertyDefinitionCollection> clsIdProps = klass->GetIdentityProperties();
- Ptr<MgDataPropertyDefinition> id = new MgDataPropertyDefinition(L"ID");
- id->SetDataType(MgPropertyType::Int32);
- id->SetAutoGeneration(true);
- Ptr<MgDataPropertyDefinition> name = new MgDataPropertyDefinition(L"Name");
- name->SetDataType(MgPropertyType::String);
- name->SetLength(255);
- name->SetNullable(true);
- Ptr<MgGeometricPropertyDefinition> geom = new MgGeometricPropertyDefinition(L"Geometry");
- geom->SetGeometryTypes(MgFeatureGeometricType::Point);
- geom->SetSpatialContextAssociation(scName);
- clsProps->Add(id);
- clsProps->Add(name);
- clsProps->Add(geom);
- clsIdProps->Add(id);
- klass->SetDefaultGeometryPropertyName(L"Geometry");
- Ptr<MgClassDefinitionCollection> classes = schema->GetClasses();
- classes->Add(klass);
- Ptr<MgFileFeatureSourceParams> fsParams = new MgFileFeatureSourceParams(provider, scName, csWkt, schema);
- svcFeature->CreateFeatureSource(fsId, fsParams);
- Ptr<MgFeatureSchemaCollection> schemas = svcFeature->DescribeSchema(fsId, L"");
- Ptr<MgFeatureSchema> theSchema = schemas->GetItem(0);
- Ptr<MgClassDefinitionCollection> theClasses = theSchema->GetClasses();
- Ptr<MgClassDefinition> theClass = theClasses->GetItem(0);
- STRING qClassName = theSchema->GetName();
- qClassName += L":";
- qClassName += theClass->GetName();
- return qClassName;
@@ -3739,18 +3375,18 @@
/// This test case exercises getting indices of invalid property names from
/// the feature reader
-void TestFeatureService::TestCase_FeatureReader_GetPropertyIndex_BadProp()
+TEST_CASE("FeatureReader_GetPropertyIndex_BadProp", "[FeatureService]")
try
- if (serviceManager == 0)
throw new MgNullReferenceException(L"TestFeatureService.TestCase_FeatureReader_GetPropertyIndex_BadProp", __LINE__, __WFILE__, NULL, L"", NULL);
- if (pService == 0)
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_FeatureReader_GetPropertyIndex_BadProp", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -3758,24 +3394,24 @@
- CPPUNIT_ASSERT(reader->GetPropertyIndex(L"IDontExist") < 0);
+ REQUIRE(reader->GetPropertyIndex(L"IDontExist") < 0);
reader->Close();
SAFE_RELEASE(e);
catch (...)
Deleted: sandbox/jng/catch2/Server/src/UnitTesting/TestFeatureService.h
--- sandbox/jng/catch2/Server/src/UnitTesting/TestFeatureService.h 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestFeatureService.h 2020-07-13 13:04:59 UTC (rev 9659)
@@ -1,134 +0,0 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#ifndef _TESTFEATURESERVICE_H
-#define _TESTFEATURESERVICE_H
-#include <cppunit/extensions/HelperMacros.h>
-class TestFeatureService : public CppUnit::TestFixture
- CPPUNIT_TEST_SUITE(TestFeatureService);
- CPPUNIT_TEST(TestStart); // This must be the very first unit test
- CPPUNIT_TEST(TestCase_GetFeatureProviders);
- CPPUNIT_TEST(TestCase_TestConnectionSDFProvider);
- CPPUNIT_TEST(TestCase_TestFdoConnectionManager);
- CPPUNIT_TEST(TestCase_GetConnectionPropertyValues);
- CPPUNIT_TEST(TestCase_GetCapabilities);
- CPPUNIT_TEST(TestCase_TestConnectionResourceIdentifier);
- CPPUNIT_TEST(TestCase_GetSchemas);
- CPPUNIT_TEST(TestCase_GetClasses);
- CPPUNIT_TEST(TestCase_GetClassDefinition);
- CPPUNIT_TEST(TestCase_GetIdentityProperties);
- CPPUNIT_TEST(TestCase_DescribeSchema);
- CPPUNIT_TEST(TestCase_ApplySchema);
- CPPUNIT_TEST(TestCase_SelectFeatures);
- CPPUNIT_TEST(TestCase_SelectFeaturesWithXform);
- CPPUNIT_TEST(TestCase_SelectFeaturesSdfWithOrdering);
- CPPUNIT_TEST(TestCase_SelectAggregate);
- CPPUNIT_TEST(TestCase_UpdateFeaturesInsert);
- CPPUNIT_TEST(TestCase_UpdateFeaturesPartialFailure);
- CPPUNIT_TEST(TestCase_InsertFeatures);
- CPPUNIT_TEST(TestCase_InsertFeaturesBatch);
- CPPUNIT_TEST(TestCase_UpdateMatchingFeatures);
- CPPUNIT_TEST(TestCase_DeleteFeatures);
- CPPUNIT_TEST(TestCase_TransactedCrud);
- CPPUNIT_TEST(TestCase_ExecuteSqlQuery);
- CPPUNIT_TEST(TestCase_ExecuteSqlNonQuery);
- CPPUNIT_TEST(TestCase_GetSpatialContexts);
- CPPUNIT_TEST(TestCase_GetLongTransactions);
- CPPUNIT_TEST(TestCase_SetLongTransaction);
- CPPUNIT_TEST(TestCase_GetFeatures);
- CPPUNIT_TEST(TestCase_CloseFeatureReader);
- CPPUNIT_TEST(TestCase_GetSqlRows);
- CPPUNIT_TEST(TestCase_CloseSqlReader);
- CPPUNIT_TEST(TestCase_GetRaster);
- CPPUNIT_TEST(TestCase_GetDataRows);
- CPPUNIT_TEST(TestCase_CloseDataReader);
- CPPUNIT_TEST(TestCase_JoinFeatures);
- CPPUNIT_TEST(TestCase_JoinFeaturesChainedInner1ToMany);
- CPPUNIT_TEST(TestCase_CreateFeatureSource);
- CPPUNIT_TEST(TestCase_BenchmarkSelectFeatures);
- CPPUNIT_TEST(TestCase_ConcurrentAccess);
- CPPUNIT_TEST(TestCase_SavePoint);
- CPPUNIT_TEST(TestCase_JoinFdoFeatures);
- CPPUNIT_TEST(TestCase_BenchmarkSqliteJoin);
- CPPUNIT_TEST(TestCase_BenchmarkSqliteAggregateJoin);
- CPPUNIT_TEST(TestCase_FeatureReader_GetPropertyIndex_BadProp);
- CPPUNIT_TEST(TestEnd); // This must be the very last unit test
- CPPUNIT_TEST_SUITE_END();
-public:
- void setUp();
- void tearDown();
- void TestStart();
- void TestEnd();
- void TestCase_GetFeatureProviders();
- void TestCase_TestConnectionSDFProvider();
- void TestCase_TestFdoConnectionManager();
- void TestCase_GetConnectionPropertyValues();
- void TestCase_GetCapabilities();
- void TestCase_TestConnectionProviderConnectionString();
- void TestCase_TestConnectionResourceIdentifier();
- void TestCase_GetSchemas();
- void TestCase_GetClasses();
- void TestCase_GetClassDefinition();
- void TestCase_GetIdentityProperties();
- void TestCase_DescribeSchema();
- void TestCase_ApplySchema();
- void TestCase_SelectFeatures();
- void TestCase_SelectFeaturesWithXform();
- void TestCase_SelectFeaturesSdfWithOrdering();
- void TestCase_SelectAggregate();
- void TestCase_UpdateFeaturesInsert();
- void TestCase_UpdateFeaturesPartialFailure();
- void TestCase_InsertFeatures();
- void TestCase_InsertFeaturesBatch();
- void TestCase_UpdateMatchingFeatures();
- void TestCase_DeleteFeatures();
- void TestCase_TransactedCrud();
- void TestCase_ExecuteSqlQuery();
- void TestCase_ExecuteSqlNonQuery();
- void TestCase_GetSpatialContexts();
- void TestCase_GetLongTransactions();
- void TestCase_SetLongTransaction();
- void TestCase_GetFeatures();
- void TestCase_CloseFeatureReader();
- void TestCase_GetSqlRows();
- void TestCase_CloseSqlReader();
- void TestCase_GetRaster();
- void TestCase_GetDataRows();
- void TestCase_CloseDataReader();
- void TestCase_JoinFeatures();
- void TestCase_JoinFeaturesChainedInner1ToMany();
- void TestCase_CreateFeatureSource();
- void TestCase_BenchmarkSelectFeatures();
- void TestCase_ConcurrentAccess();
- void TestCase_SavePoint();
- void TestCase_JoinFdoFeatures();
- void TestCase_BenchmarkSqliteJoin();
- void TestCase_BenchmarkSqliteAggregateJoin();
- void TestCase_FeatureReader_GetPropertyIndex_BadProp();
-private:
- STRING CreateTestDataStore(MgFeatureService* svcFeature, CREFSTRING provider, MgResourceIdentifier* fsId);
-#endif // _TESTFEATURESERVICE_H
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestGeometry.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestGeometry.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestGeometry.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -951,12 +951,12 @@
MgWktReaderWriter readerWriter;
Ptr<MgPoint> point = CreatePoint();
- Ptr<MgGeometry> geom = point->Buffer(5.0, NULL);
+ Ptr<MgGeometry> geom = point->Buffer(5.0, nullptr);
STRING found = geom->ToAwkt(false);
REQUIRE(CheckGeometry(geom, found));
Ptr<MgMultiGeometry> multiGeometry = CreateMultiGeometry();
- geom = multiGeometry->Buffer(5.0, NULL);
+ geom = multiGeometry->Buffer(5.0, nullptr);
@@ -1101,7 +1101,7 @@
outerCoords->Add(coord4);
outerCoords->Add(coord5);
Ptr<MgLinearRing> outerRing = factory.CreateLinearRing(outerCoords);
- Ptr<MgLinearRingCollection> innerRings = NULL;
+ Ptr<MgLinearRingCollection> innerRings = nullptr;
polygon = factory.CreatePolygon(outerRing, innerRings);
geom = point->Intersection(polygon);
REQUIRE(geom.p == nullptr);
@@ -2150,7 +2150,7 @@
Ptr<MgLinearRing> linearRing = factory.CreateLinearRing(coords);
- polygon = factory.CreatePolygon(linearRing, NULL);
+ polygon = factory.CreatePolygon(linearRing, nullptr);
area = polygon->GetArea();
REQUIRE(area == 8100.0);
@@ -2268,7 +2268,7 @@
base = L"POINT (0 0)";
centroid = polygon->GetCentroid();
found = readerWriter.Write(centroid);
REQUIRE(CheckGeometry(found, base));
@@ -2377,7 +2377,7 @@
Ptr<MgWktReaderWriter> wktRw = new MgWktReaderWriter();
Ptr<MgGeometry> geom = wktRw->Read(L"POINT (1 1)");
- REQUIRE_THROWS_MG(simp->Simplify(NULL, 1.0, MgGeometrySimplificationAlgorithmType::DouglasPeucker), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(simp->Simplify(nullptr, 1.0, MgGeometrySimplificationAlgorithmType::DouglasPeucker), MgNullArgumentException*);
REQUIRE_THROWS_MG(simp->Simplify(geom, 1.0, -1), MgInvalidArgumentException*);
REQUIRE_THROWS_MG(simp->Simplify(geom, 1.0, 2), MgInvalidArgumentException*);
@@ -2409,7 +2409,7 @@
Ptr<MgGeometry> gInput = wktRw->Read(wkt);
Ptr<MgGeometry> gOutput = simp->Simplify(gInput, 10.0, algo);
- REQUIRE(NULL != gOutput.p);
+ REQUIRE(nullptr != gOutput.p);
REQUIRE(gOutput->IsValid());
REQUIRE(gTest->Equals(gOutput));
@@ -2419,7 +2419,7 @@
gInput = wktRw->Read(L"POLYGON ((40 240, 160 241, 280 240, 280 160, \
160 240, 40 140, 40 240))");
@@ -2428,7 +2428,7 @@
gInput = wktRw->Read(L"POLYGON ((120 120, 121 121, 122 122, 220 120, \
180 199, 160 200, 140 199, 120 120))");
@@ -2438,7 +2438,7 @@
gInput = wktRw->Read(L"POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200), \
(120 120, 220 120, 180 199, 160 200, 140 199, 120 120))");
@@ -2445,20 +2445,20 @@
// 5 - FlattishPolygon
gInput = wktRw->Read(L"POLYGON ((0 0, 50 0, 53 0, 55 0, 100 0, 70 1, 60 1, 50 1, 40 1, 0 0))");
- //Unlike GEOS, we don't support "POLYGON EMPTY", so we should be expecting NULL instead
- REQUIRE(NULL == gOutput.p);
+ //Unlike GEOS, we don't support "POLYGON EMPTY", so we should be expecting nullptr instead
+ REQUIRE(nullptr == gOutput.p);
// 6 - TinySquare
gInput = wktRw->Read(L"POLYGON ((0 5, 5 5, 5 0, 0 0, 0 1, 0 5))");
// 7 - TinyLineString
gTest = wktRw->Read(L"LINESTRING (0 5, 5 5)");
gInput = wktRw->Read(L"LINESTRING (0 5, 1 5, 2 5, 5 5)");
@@ -2466,7 +2466,7 @@
gTest = wktRw->Read(L"MULTIPOINT(80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120)");
gInput = wktRw->Read(L"MULTIPOINT(80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120)");
@@ -2475,7 +2475,7 @@
gInput = wktRw->Read(L"MULTILINESTRING( (0 0, 50 0, 70 0, 80 0, 100 0), \
(0 0, 50 1, 60 1, 100 0) )");
@@ -2486,7 +2486,7 @@
POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200)), \
LINESTRING (80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120) )");
//STRING sTest = gTest->ToAwkt(true);
//STRING sOutput = gOutput->ToAwkt(true);
@@ -2516,7 +2516,7 @@
Ptr<MgGeometry> gTest = wktRw->Read(L"POINT (10 10)");
Ptr<MgGeometry> gInput = wktRw->Read(L"POINT (10 10)");
@@ -2539,7 +2539,7 @@
3312468.253 6646874.01, 3312463.52 6646875.779, \
3312459.605 6646878.353))");
gOutput = simp->Simplify(gInput, 2.0, algo);
// PolygonNoReduction
@@ -2550,7 +2550,7 @@
100 220, 120 220, 140 220, 140 180, 100 180, \
60 180, 20 180, 20 220))");
@@ -2560,7 +2560,7 @@
@@ -2570,7 +2570,7 @@
@@ -2580,7 +2580,7 @@
gInput = wktRw->Read(L"POLYGON ((0 0, 50 0, 53 0, 55 0, 100 0, \
@@ -2592,7 +2592,7 @@
gInput = wktRw->Read(L"POLYGON ((0 0, 0 200, 200 200, 200 0, 0 0), \
(140 40, 90 95, 40 160, 95 100, 140 40))");
@@ -2600,7 +2600,7 @@
gTest = wktRw->Read(L"POLYGON ((0 5, 5 5, 5 0, 0 0, 0 1, 0 5))");
@@ -2608,7 +2608,7 @@
gTest = wktRw->Read(L"LINESTRING (0 0, 5 0, 5 5, 0 0)");
gInput = wktRw->Read(L"LINESTRING (0 0, 5 0, 5 5, 0 0)");
@@ -2618,7 +2618,7 @@
gInput = wktRw->Read(L"MULTIPOINT(80 200, 240 200, 240 60, \
@@ -2628,7 +2628,7 @@
gInput = wktRw->Read(L"MULTILINESTRING((0 0, 50 0, 70 0, 80 0, 100 0), \
(0 0, 50 1, 60 1, 100 0))");
@@ -2644,7 +2644,7 @@
LINESTRING (80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120))");
@@ -2669,15 +2669,15 @@
try
+ if (serviceManager == nullptr)
- throw new MgNullReferenceException(L"TestGeometry::TestCase_PreparedGeometry", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestGeometry::TestCase_PreparedGeometry", __LINE__, __WFILE__, nullptr, L"", nullptr);
+ if (pService == nullptr)
- throw new MgServiceNotAvailableException(L"TestGeometry::TestCase_PreparedGeometry", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestGeometry::TestCase_PreparedGeometry", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgAgfReaderWriter> agfRw = new MgAgfReaderWriter();
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestKmlService.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestKmlService.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestKmlService.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -29,7 +29,7 @@
STRING sessionId;
Ptr<MgUserInformation> userInfo = MgUserInformation::GetCurrentUserInfo();
- if (userInfo != NULL)
+ if (userInfo != nullptr)
sessionId = userInfo->GetMgSessionId();
@@ -54,7 +54,7 @@
static void SaveToFile(CREFSTRING content, CREFSTRING filename)
FILE* file = ACE_OS::fopen(MG_WCHAR_TO_TCHAR(filename), ACE_TEXT("wt"));
- if (file != NULL)
+ if (file != nullptr)
fwprintf(file, content.c_str());
fclose(file);
@@ -66,10 +66,10 @@
STRING content;
FILE* file = ACE_OS::fopen(MG_WCHAR_TO_TCHAR(filename), ACE_TEXT("rt"));
- if (file != NULL)
wchar_t buffer[1024];
- while (fgetws(buffer, 1024, file) != NULL)
+ while (fgetws(buffer, 1024, file) != nullptr)
content.append(buffer);
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestLogManager.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestLogManager.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestLogManager.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -53,7 +53,7 @@
static bool CreateFile(STRING filename, STRING contents)
- FILE* file = NULL;
+ FILE* file = nullptr;
file = ::fopen(MG_WCHAR_TO_CHAR(filename), "wb");
if (file)
@@ -440,7 +440,7 @@
REQUIRE(logContents.length() == 0);
// Use a null value for the date
- REQUIRE_THROWS_MG(pMgLogManager->GetAccessLog(NULL, toDate), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pMgLogManager->GetAccessLog(nullptr, toDate), MgNullArgumentException*);
// Use dates more than 24 hours apart
fromDate = new MgDateTime(2005, 2, 18, 14, 0, 0, 0);
@@ -659,7 +659,7 @@
- REQUIRE_THROWS_MG(pMgLogManager->GetAdminLog(NULL, toDate), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pMgLogManager->GetAdminLog(nullptr, toDate), MgNullArgumentException*);
@@ -871,7 +871,7 @@
- REQUIRE_THROWS_MG(pMgLogManager->GetAuthenticationLog(NULL, toDate), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pMgLogManager->GetAuthenticationLog(nullptr, toDate), MgNullArgumentException*);
@@ -1083,7 +1083,7 @@
- REQUIRE_THROWS_MG(pMgLogManager->GetErrorLog(NULL, toDate), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pMgLogManager->GetErrorLog(nullptr, toDate), MgNullArgumentException*);
@@ -1295,7 +1295,7 @@
- REQUIRE_THROWS_MG(pMgLogManager->GetSessionLog(NULL, toDate), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pMgLogManager->GetSessionLog(nullptr, toDate), MgNullArgumentException*);
@@ -1507,7 +1507,7 @@
- REQUIRE_THROWS_MG(pMgLogManager->GetTraceLog(NULL, toDate), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pMgLogManager->GetTraceLog(nullptr, toDate), MgNullArgumentException*);
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestLogManagerThread.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestLogManagerThread.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestLogManagerThread.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -30,9 +30,9 @@
int TestLogManagerThread::svc()
MgLogManager* pMan = MgLogManager::GetInstance();
- if (NULL == pMan)
+ if (nullptr == pMan)
- throw new MgNullReferenceException(L"TestLogManagerThread.svc", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestLogManagerThread.svc", __LINE__, __WFILE__, nullptr, L"", nullptr);
INT32 nResult = 0;
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestMappingService.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestMappingService.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestMappingService.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -453,7 +453,7 @@
Ptr<MgLayout> layout = new MgLayout(allElementsLayout, L"TestTitle", MgUnitType::USEnglish);
// call the API
- Ptr<MgByteReader> eplot = m_svcMapping->GeneratePlot(map1, plotSpec, NULL, version);
+ Ptr<MgByteReader> eplot = m_svcMapping->GeneratePlot(map1, plotSpec, nullptr, version);
//Ptr<MgByteReader> eplot = m_svcMapping->GeneratePlot(map1, plotSpec, layout, version);
INT64 len = eplot->GetLength();
@@ -604,7 +604,7 @@
// call the API
- Ptr<MgByteReader> eplot = m_svcMapping->GeneratePlot(map1, extents, true, plotSpec, NULL, version);
+ Ptr<MgByteReader> eplot = m_svcMapping->GeneratePlot(map1, extents, true, plotSpec, nullptr, version);
@@ -889,7 +889,7 @@
REQUIRE(-1 == layer->GetThemeCategoryCount(10000.0, 4));
types = layer->GetGeometryTypeStyles(14000.0);
- REQUIRE(NULL == types.p);
+ REQUIRE(nullptr == types.p);
REQUIRE(-1 == layer->GetThemeCategoryCount(14000.0, 3));
REQUIRE(-1 == layer->GetThemeCategoryCount(14000.0, 1));
REQUIRE(-1 == layer->GetThemeCategoryCount(14000.0, 2));
@@ -1362,7 +1362,7 @@
// call the API
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestMdfModel.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestMdfModel.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestMdfModel.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -61,7 +61,7 @@
// write the file - this exercises MdfParser serialization
unique_ptr<SymbolDefinition> symbolDef1(parser.DetachSymbolDefinition());
- REQUIRE(symbolDef1.get() != NULL);
+ REQUIRE(symbolDef1.get() != nullptr);
parser.WriteToFile("../UnitTestFiles/MdfTestSimpleSymbol_Copy1.sd", symbolDef1.get(), &symbolDefVersion);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestSimpleSymbol_Copy1.sd"));
@@ -73,7 +73,7 @@
Ptr<MgByte> bytes1 = sink1->ToBuffer();
parser.ParseString((const char*)bytes1->Bytes(), bytes1->GetLength());
unique_ptr<SymbolDefinition> symbolDef2(parser.DetachSymbolDefinition());
- REQUIRE(symbolDef2.get() != NULL);
+ REQUIRE(symbolDef2.get() != nullptr);
parser.WriteToFile("../UnitTestFiles/MdfTestSimpleSymbol_Copy2.sd", symbolDef2.get(), &symbolDefVersion);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestSimpleSymbol_Copy2.sd"));
@@ -87,7 +87,7 @@
REQUIRE(memcmp(bytes1->Bytes(), bytes2->Bytes(), bytes1->GetLength()) == 0);
// save the new resource to the repository to validate the XML
- m_svcResource->SetResource(sdresV, rdr1, NULL);
+ m_svcResource->SetResource(sdresV, rdr1, nullptr);
m_svcResource->DeleteResource(sdresV);
@@ -117,7 +117,7 @@
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_Copy1.sd", symbolDef1.get(), &symbolDefVersion);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestCompoundSymbol_Copy1.sd"));
@@ -129,7 +129,7 @@
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_Copy2.sd", symbolDef2.get(), &symbolDefVersion);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestCompoundSymbol_Copy2.sd"));
@@ -143,7 +143,7 @@
@@ -182,9 +182,9 @@
unique_ptr<VectorLayerDefinition> layerDef1(parser.DetachVectorLayerDefinition());
- REQUIRE(layerDef1.get() != NULL);
+ REQUIRE(layerDef1.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_Copy1.ldf", NULL, layerDef1.get(), NULL, NULL, NULL, NULL, &layerDefVersion);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_Copy1.ldf", nullptr, layerDef1.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_Copy1.ldf"));
// parse and resave the newly written file
@@ -194,9 +194,9 @@
unique_ptr<VectorLayerDefinition> layerDef2(parser.DetachVectorLayerDefinition());
- REQUIRE(layerDef2.get() != NULL);
+ REQUIRE(layerDef2.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_Copy2.ldf", NULL, layerDef2.get(), NULL, NULL, NULL, NULL, &layerDefVersion);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_Copy2.ldf", nullptr, layerDef2.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_Copy2.ldf"));
// compare the two files
@@ -209,7 +209,7 @@
- m_svcResource->SetResource(ldfresV, rdr1, NULL);
+ m_svcResource->SetResource(ldfresV, rdr1, nullptr);
m_svcResource->DeleteResource(ldfresV);
@@ -245,9 +245,9 @@
unique_ptr<MapDefinition> mapDef1(parser.DetachMapDefinition());
- REQUIRE(mapDef1.get() != NULL);
+ REQUIRE(mapDef1.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestMap_Copy1.mdf", mapDef1.get(), NULL, NULL, NULL, NULL, NULL, &mapDefVersion);
+ parser.WriteToFile("../UnitTestFiles/MdfTestMap_Copy1.mdf", mapDef1.get(), nullptr, nullptr, nullptr, nullptr, nullptr, &mapDefVersion);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestMap_Copy1.mdf"));
@@ -257,9 +257,9 @@
unique_ptr<MapDefinition> mapDef2(parser.DetachMapDefinition());
- REQUIRE(mapDef2.get() != NULL);
+ REQUIRE(mapDef2.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestMap_Copy2.mdf", mapDef2.get(), NULL, NULL, NULL, NULL, NULL, &mapDefVersion);
+ parser.WriteToFile("../UnitTestFiles/MdfTestMap_Copy2.mdf", mapDef2.get(), nullptr, nullptr, nullptr, nullptr, nullptr, &mapDefVersion);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestMap_Copy2.mdf"));
@@ -272,7 +272,7 @@
- m_svcResource->SetResource(mdfresV, rdr1, NULL);
+ m_svcResource->SetResource(mdfresV, rdr1, nullptr);
m_svcResource->DeleteResource(mdfresV);
@@ -328,7 +328,7 @@
// write the file using each version - this exercises MdfParser serialization
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_v10_Copy1.sd", symbolDef1.get(), &symbolDefVersion10);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestCompoundSymbol_v10_Copy1.sd"));
@@ -346,7 +346,7 @@
Ptr<MgByte> bytes1_10 = sink1_10->ToBuffer();
parser.ParseString((const char*)bytes1_10->Bytes(), bytes1_10->GetLength());
unique_ptr<SymbolDefinition> symbolDef2_10(parser.DetachSymbolDefinition());
- REQUIRE(symbolDef2_10.get() != NULL);
+ REQUIRE(symbolDef2_10.get() != nullptr);
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_v10_Copy2.sd", symbolDef2_10.get(), &symbolDefVersion10);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestCompoundSymbol_v10_Copy2.sd"));
@@ -357,7 +357,7 @@
Ptr<MgByte> bytes1_11 = sink1_11->ToBuffer();
parser.ParseString((const char*)bytes1_11->Bytes(), bytes1_11->GetLength());
unique_ptr<SymbolDefinition> symbolDef2_11(parser.DetachSymbolDefinition());
- REQUIRE(symbolDef2_11.get() != NULL);
+ REQUIRE(symbolDef2_11.get() != nullptr);
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_v11_Copy2.sd", symbolDef2_11.get(), &symbolDefVersion11);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestCompoundSymbol_v11_Copy2.sd"));
@@ -368,7 +368,7 @@
Ptr<MgByte> bytes1_24 = sink1_24->ToBuffer();
parser.ParseString((const char*)bytes1_24->Bytes(), bytes1_24->GetLength());
unique_ptr<SymbolDefinition> symbolDef2_24(parser.DetachSymbolDefinition());
- REQUIRE(symbolDef2_24.get() != NULL);
+ REQUIRE(symbolDef2_24.get() != nullptr);
parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_v24_Copy2.sd", symbolDef2_24.get(), &symbolDefVersion24);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestCompoundSymbol_v24_Copy2.sd"));
@@ -432,13 +432,13 @@
REQUIRE(memcmp(bytes3a_24->Bytes(), bytes3c_24->Bytes(), bytes3a_24->GetLength()) == 0);
// save the new resources to the repository to validate the XML
- m_svcResource->SetResource(sdresV, rdr1_10, NULL);
+ m_svcResource->SetResource(sdresV, rdr1_10, nullptr);
- m_svcResource->SetResource(sdresV, rdr1_11, NULL);
+ m_svcResource->SetResource(sdresV, rdr1_11, nullptr);
- m_svcResource->SetResource(sdresV, rdr1_24, NULL);
+ m_svcResource->SetResource(sdresV, rdr1_24, nullptr);
- m_svcResource->SetResource(sdresV, rdr3a_24, NULL);
+ m_svcResource->SetResource(sdresV, rdr3a_24, nullptr);
@@ -472,27 +472,27 @@
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v09_Copy1.ldf", NULL, layerDef1.get(), NULL, NULL, NULL, NULL, &layerDefVersion09);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v09_Copy1.ldf", nullptr, layerDef1.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion09);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v09_Copy1.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v10_Copy1.ldf", NULL, layerDef1.get(), NULL, NULL, NULL, NULL, &layerDefVersion10);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v10_Copy1.ldf", nullptr, layerDef1.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion10);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v10_Copy1.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v11_Copy1.ldf", NULL, layerDef1.get(), NULL, NULL, NULL, NULL, &layerDefVersion11);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v11_Copy1.ldf", nullptr, layerDef1.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion11);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v11_Copy1.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v12_Copy1.ldf", NULL, layerDef1.get(), NULL, NULL, NULL, NULL, &layerDefVersion12);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v12_Copy1.ldf", nullptr, layerDef1.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion12);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v12_Copy1.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v13_Copy1.ldf", NULL, layerDef1.get(), NULL, NULL, NULL, NULL, &layerDefVersion13);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v13_Copy1.ldf", nullptr, layerDef1.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion13);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v13_Copy1.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v23_Copy1.ldf", NULL, layerDef1.get(), NULL, NULL, NULL, NULL, &layerDefVersion23);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v23_Copy1.ldf", nullptr, layerDef1.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion23);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v23_Copy1.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy1.ldf", NULL, layerDef1.get(), NULL, NULL, NULL, NULL, &layerDefVersion24);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy1.ldf", nullptr, layerDef1.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion24);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy1.ldf"));
// parse and resave the newly written files
@@ -502,9 +502,9 @@
Ptr<MgByte> bytes1_09 = sink1_09->ToBuffer();
parser.ParseString((const char*)bytes1_09->Bytes(), bytes1_09->GetLength());
unique_ptr<VectorLayerDefinition> layerDef2_09(parser.DetachVectorLayerDefinition());
- REQUIRE(layerDef2_09.get() != NULL);
+ REQUIRE(layerDef2_09.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v09_Copy2.ldf", NULL, layerDef2_09.get(), NULL, NULL, NULL, NULL, &layerDefVersion09);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v09_Copy2.ldf", nullptr, layerDef2_09.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion09);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v09_Copy2.ldf"));
Ptr<MgByteSource> src1_10 = new MgByteSource(L"../UnitTestFiles/MdfTestTypeStyles_v10_Copy1.ldf");
@@ -513,9 +513,9 @@
unique_ptr<VectorLayerDefinition> layerDef2_10(parser.DetachVectorLayerDefinition());
- REQUIRE(layerDef2_10.get() != NULL);
+ REQUIRE(layerDef2_10.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v10_Copy2.ldf", NULL, layerDef2_10.get(), NULL, NULL, NULL, NULL, &layerDefVersion10);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v10_Copy2.ldf", nullptr, layerDef2_10.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion10);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v10_Copy2.ldf"));
Ptr<MgByteSource> src1_11 = new MgByteSource(L"../UnitTestFiles/MdfTestTypeStyles_v11_Copy1.ldf");
@@ -524,9 +524,9 @@
unique_ptr<VectorLayerDefinition> layerDef2_11(parser.DetachVectorLayerDefinition());
- REQUIRE(layerDef2_11.get() != NULL);
+ REQUIRE(layerDef2_11.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v11_Copy2.ldf", NULL, layerDef2_11.get(), NULL, NULL, NULL, NULL, &layerDefVersion11);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v11_Copy2.ldf", nullptr, layerDef2_11.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion11);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v11_Copy2.ldf"));
Ptr<MgByteSource> src1_12 = new MgByteSource(L"../UnitTestFiles/MdfTestTypeStyles_v12_Copy1.ldf");
@@ -535,9 +535,9 @@
Ptr<MgByte> bytes1_12 = sink1_12->ToBuffer();
parser.ParseString((const char*)bytes1_12->Bytes(), bytes1_12->GetLength());
unique_ptr<VectorLayerDefinition> layerDef2_12(parser.DetachVectorLayerDefinition());
- REQUIRE(layerDef2_12.get() != NULL);
+ REQUIRE(layerDef2_12.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v12_Copy2.ldf", NULL, layerDef2_12.get(), NULL, NULL, NULL, NULL, &layerDefVersion12);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v12_Copy2.ldf", nullptr, layerDef2_12.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion12);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v12_Copy2.ldf"));
Ptr<MgByteSource> src1_13 = new MgByteSource(L"../UnitTestFiles/MdfTestTypeStyles_v13_Copy1.ldf");
@@ -546,9 +546,9 @@
Ptr<MgByte> bytes1_13 = sink1_13->ToBuffer();
parser.ParseString((const char*)bytes1_13->Bytes(), bytes1_13->GetLength());
unique_ptr<VectorLayerDefinition> layerDef2_13(parser.DetachVectorLayerDefinition());
- REQUIRE(layerDef2_13.get() != NULL);
+ REQUIRE(layerDef2_13.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v13_Copy2.ldf", NULL, layerDef2_13.get(), NULL, NULL, NULL, NULL, &layerDefVersion13);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v13_Copy2.ldf", nullptr, layerDef2_13.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion13);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v13_Copy2.ldf"));
Ptr<MgByteSource> src1_23 = new MgByteSource(L"../UnitTestFiles/MdfTestTypeStyles_v23_Copy1.ldf");
@@ -557,9 +557,9 @@
Ptr<MgByte> bytes1_23 = sink1_23->ToBuffer();
parser.ParseString((const char*)bytes1_23->Bytes(), bytes1_23->GetLength());
unique_ptr<VectorLayerDefinition> layerDef2_23(parser.DetachVectorLayerDefinition());
- REQUIRE(layerDef2_23.get() != NULL);
+ REQUIRE(layerDef2_23.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v23_Copy2.ldf", NULL, layerDef2_23.get(), NULL, NULL, NULL, NULL, &layerDefVersion23);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v23_Copy2.ldf", nullptr, layerDef2_23.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion23);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v23_Copy2.ldf"));
Ptr<MgByteSource> src1_24 = new MgByteSource(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy1.ldf");
@@ -568,9 +568,9 @@
unique_ptr<VectorLayerDefinition> layerDef2_24(parser.DetachVectorLayerDefinition());
- REQUIRE(layerDef2_24.get() != NULL);
+ REQUIRE(layerDef2_24.get() != nullptr);
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy2.ldf", NULL, layerDef2_24.get(), NULL, NULL, NULL, NULL, &layerDefVersion24);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy2.ldf", nullptr, layerDef2_24.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion24);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy2.ldf"));
// compare the files
@@ -632,22 +632,22 @@
// layerDef2_24 was loaded from XML containing no extended data
// the data in these object models should be the same
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3a.ldf", NULL, layerDef2_10.get(), NULL, NULL, NULL, NULL, &layerDefVersion24);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3a.ldf", nullptr, layerDef2_10.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion24);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy3a.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3b.ldf", NULL, layerDef2_11.get(), NULL, NULL, NULL, NULL, &layerDefVersion24);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3b.ldf", nullptr, layerDef2_11.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion24);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy3b.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3c.ldf", NULL, layerDef2_12.get(), NULL, NULL, NULL, NULL, &layerDefVersion24);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3c.ldf", nullptr, layerDef2_12.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion24);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy3c.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3d.ldf", NULL, layerDef2_13.get(), NULL, NULL, NULL, NULL, &layerDefVersion24);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3d.ldf", nullptr, layerDef2_13.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion24);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy3d.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3e.ldf", NULL, layerDef2_23.get(), NULL, NULL, NULL, NULL, &layerDefVersion24);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3e.ldf", nullptr, layerDef2_23.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion24);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy3e.ldf"));
- parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3f.ldf", NULL, layerDef2_24.get(), NULL, NULL, NULL, NULL, &layerDefVersion24);
+ parser.WriteToFile("../UnitTestFiles/MdfTestTypeStyles_v24_Copy3f.ldf", nullptr, layerDef2_24.get(), nullptr, nullptr, nullptr, nullptr, &layerDefVersion24);
REQUIRE(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy3f.ldf"));
Ptr<MgByteSource> src3a_24 = new MgByteSource(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy3a.ldf");
@@ -691,21 +691,21 @@
REQUIRE(memcmp(bytes3d_24->Bytes(), bytes3e_24->Bytes(), bytes3d_24->GetLength()) == 0);
REQUIRE(memcmp(bytes3e_24->Bytes(), bytes3f_24->Bytes(), bytes3e_24->GetLength()) == 0);
- m_svcResource->SetResource(ldfresV, rdr1_09, NULL);
+ m_svcResource->SetResource(ldfresV, rdr1_09, nullptr);
- m_svcResource->SetResource(ldfresV, rdr1_10, NULL);
+ m_svcResource->SetResource(ldfresV, rdr1_10, nullptr);
- m_svcResource->SetResource(ldfresV, rdr1_11, NULL);
+ m_svcResource->SetResource(ldfresV, rdr1_11, nullptr);
- m_svcResource->SetResource(ldfresV, rdr1_12, NULL);
+ m_svcResource->SetResource(ldfresV, rdr1_12, nullptr);
- m_svcResource->SetResource(ldfresV, rdr1_13, NULL);
+ m_svcResource->SetResource(ldfresV, rdr1_13, nullptr);
- m_svcResource->SetResource(ldfresV, rdr1_23, NULL);
+ m_svcResource->SetResource(ldfresV, rdr1_23, nullptr);
- m_svcResource->SetResource(ldfresV, rdr1_24, NULL);
+ m_svcResource->SetResource(ldfresV, rdr1_24, nullptr);
- m_svcResource->SetResource(ldfresV, rdr3a_24, NULL);
+ m_svcResource->SetResource(ldfresV, rdr3a_24, nullptr);
@@ -765,10 +765,10 @@
REQUIRE(parser.GetSucceeded());
MdfModel::TileSetDefinition* tileset = parser.DetachTileSetDefinition();
- REQUIRE(NULL != tileset);
+ REQUIRE(nullptr != tileset);
MdfModel::TileStoreParameters* tilesetParams = tileset->GetTileStoreParameters();
- REQUIRE(NULL != tilesetParams);
+ REQUIRE(nullptr != tilesetParams);
REQUIRE(MG_TILE_PROVIDER_DEFAULT == tilesetParams->GetTileProvider());
STRING path;
@@ -879,10 +879,10 @@
REQUIRE(MG_TILE_PROVIDER_XYZ == tilesetParams->GetTileProvider());
STRING path;
@@ -962,10 +962,10 @@
unique_ptr<LayerDefinition> ldf(parser.DetachLayerDefinition());
- REQUIRE(ldf.get() != NULL);
+ REQUIRE(ldf.get() != nullptr);
VectorLayerDefinition* vl = dynamic_cast<VectorLayerDefinition*>(ldf.get());
- REQUIRE(vl != NULL);
+ REQUIRE(vl != nullptr);
REQUIRE(!vl->GetIncludeBoundsForSelectedFeatures());
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestMisc.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestMisc.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestMisc.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -36,7 +36,7 @@
try
- MgObject* ptr = NULL;
+ MgObject* ptr = nullptr;
CHECKNULL(ptr, L"TestMisc::TestCase_CommonExceptionMessages");
catch(MgException* ex)
@@ -48,7 +48,7 @@
try
- MgObject* ptr2 = NULL;
+ MgObject* ptr2 = nullptr;
CHECKNULL((void*)ptr2, L"TestMisc::TestCase_CommonExceptionMessages");
@@ -60,7 +60,7 @@
try
- MgObject* ptr3 = NULL;
+ MgObject* ptr3 = nullptr;
CHECKARGUMENTNULL(ptr3, L"TestMisc::TestCase_CommonExceptionMessages");
@@ -72,7 +72,7 @@
try
- MgObject* ptr4 = NULL;
+ MgObject* ptr4 = nullptr;
CHECKARGUMENTNULL((void*)ptr4, L"TestMisc::TestCase_CommonExceptionMessages");
@@ -1154,7 +1154,7 @@
threadData[i].done = false;
// spawn a new thread using a specific group id
- int thid = manager->spawn(ACE_THR_FUNC(GetConfigValueWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
+ int thid = manager->spawn(ACE_THR_FUNC(GetConfigValueWorker), &threadData[i], 0, nullptr, nullptr, 0, THREAD_GROUP);
nRequest++;
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -16,7 +16,6 @@
#include "MapGuideCommon.h"
-#include "TestPerformance.h"
#include "CppUnitExtensions.h"
#include "ServiceManager.h"
#include "FdoConnectionManager.h"
@@ -24,161 +23,36 @@
#include "ServerFeatureService.h"
#include "Fdo.h"
#include "FoundationDefs.h"
+#include "TestServiceFactory.h"
+#include "catch.hpp"
// **************************************** PLEASE READ ****************************************
// Note: The resources used here require that the following packages are installed:
// 1) PerformanceTest.mgp
// 2) JoinTest.mgp
-const STRING TEST_LOCALE = L"en";
-CPPUNIT_TEST_SUITE_NAMED_REGISTRATION(TestPerformance, "TestPerformance");
-void TestPerformance::setUp()
-void TestPerformance::tearDown()
-void TestPerformance::TestStart()
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nRunning Performance tests.\n")));
- try
- #ifdef _DEBUG
- MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
- if(pFdoConnectionManager)
- pFdoConnectionManager->ShowCache();
- #endif
- MgServiceManager* serviceManager = MgServiceManager::GetInstance();
- throw new MgNullReferenceException(L"TestPerformance.TestStart", __LINE__, __WFILE__, NULL, L"", NULL);
- Ptr<MgResourceService> pService = dynamic_cast<MgResourceService*>(serviceManager->RequestService(MgServiceType::ResourceService));
- throw new MgServiceNotAvailableException(L"TestPerformance.TestStart", __LINE__, __WFILE__, NULL, L"", NULL);
- //Set the user information for the current thread to be administrator
- MgUserInformation::SetCurrentUserInfo(NULL);
- Ptr<MgUserInformation> userInfo = new MgUserInformation(L"Administrator", L"admin");
- userInfo->SetLocale(TEST_LOCALE);
- MgUserInformation::SetCurrentUserInfo(userInfo);
- MgResourceIdentifier resourceIdentifier1(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
-#ifdef _WIN32
- STRING resourceContentFileName1 = L"..\\UnitTestFiles\\Sheboygan_Parcels.FeatureSource";
- STRING dataFileName1 = L"..\\UnitTestFiles\\Sheboygan_Parcels.sdf";
-#else
- STRING resourceContentFileName1 = L"../UnitTestFiles/Sheboygan_Parcels.FeatureSource";
- STRING dataFileName1 = L"../UnitTestFiles/Sheboygan_Parcels.sdf";
-#endif
- //Add a new resource
- Ptr<MgByteSource> contentSource1 = new MgByteSource(resourceContentFileName1);
- Ptr<MgByteReader> contentReader1 = contentSource1->GetReader();
- pService->SetResource(&resourceIdentifier1, contentReader1, NULL);
- //Set the resource data
- Ptr<MgByteSource> dataSource1 = new MgByteSource(dataFileName1);
- Ptr<MgByteReader> dataReader1 = dataSource1->GetReader();
- pService->SetResourceData(&resourceIdentifier1, L"Sheboygan_Parcels.sdf", L"File", dataReader1);
- catch(MgException* e)
- STRING message = e->GetDetails(TEST_LOCALE);
- SAFE_RELEASE(e);
- CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
-void TestPerformance::TestEnd()
- try
- throw new MgNullReferenceException(L"TestPerformance.TestEnd",
- __LINE__, __WFILE__, NULL, L"", NULL);
- throw new MgServiceNotAvailableException(L"TestPerformance.TestEnd",
- // set user info
- // delete the feature sources definition
- Ptr<MgResourceIdentifier> mapres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
- pService->DeleteResource(mapres1);
- #ifdef _DEBUG
- #endif
- catch (MgException* e)
- SAFE_RELEASE(e);
- catch (...)
- throw;
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nFeature Service tests completed.\n\n")));
-void TestPerformance::TestCase_BenchmarkSelectFeatures()
+TEST_CASE("BenchmarkSelectFeatures", "[Performance]")
try
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestCase_BenchmarkSelectFeatures - START\n")));
+ if(serviceManager == nullptr)
- throw new MgNullReferenceException(L"TestPerformance.TestCase_BenchmarkSelectFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestPerformance.TestCase_BenchmarkSelectFeatures", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestPerformance.TestCase_BenchmarkSelectFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestPerformance.TestCase_BenchmarkSelectFeatures", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -198,7 +72,7 @@
reader->Close();
+ REQUIRE(nFeatures == 17565);
@@ -206,20 +80,20 @@
catch(MgResourceNotFoundException* e)
+ STRING message = e->GetDetails(TestServiceFactory::TEST_LOCALE);
SAFE_RELEASE(e);
ACE_DEBUG((LM_INFO, ACE_TEXT("\n%W\nAre the performance test resources installed?\n\n"), message.c_str()));
SAFE_RELEASE(e);
+ FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
- CPPUNIT_FAIL("FdoException occurred");
+ FAIL("FdoException occurred");
catch(...)
@@ -232,23 +106,23 @@
/// This test case benchmarks joining features.
-void TestPerformance::TestCase_BenchmarkJoinFeatures()
+TEST_CASE("BenchmarkJoinFeatures", "[Performance]")
try
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestCase_BenchmarkJoinFeatures - START\n\n")));
throw new MgNullReferenceException(L"TestPerformance.TestCase_BenchmarkJoinFeatures",
+ __LINE__, __WFILE__, nullptr, L"", nullptr);
throw new MgServiceNotAvailableException(L"TestPerformance.TestCase_BenchmarkJoinFeatures",
Ptr<MgResourceIdentifier> lFeatureSource = new MgResourceIdentifier(L"Library://JoinTest/Data/World_Countries_Join.FeatureSource");
@@ -265,7 +139,7 @@
nFeatures = 0;
- Ptr<MgFeatureReader> reader = pService->SelectFeatures(lFeatureSource, L"World_Countries", NULL);
+ Ptr<MgFeatureReader> reader = pService->SelectFeatures(lFeatureSource, L"World_Countries", nullptr);
STRING s1 = L"<null>";
@@ -300,7 +174,7 @@
nFeatures = 0;
- Ptr<MgFeatureReader> reader = pService->SelectFeatures(lFeatureSource, L"Join", NULL);
+ Ptr<MgFeatureReader> reader = pService->SelectFeatures(lFeatureSource, L"Join", nullptr);
@@ -350,7 +224,7 @@
for(int i=0;i<iterations;i++)
nFeatures = 0;
INT32 n1 = 0;
@@ -385,7 +259,7 @@
nFeatures = 0;
INT32 n1 = 0;
@@ -435,7 +309,7 @@
nFeatures = 0;
- Ptr<MgFeatureReader> reader = pService->SelectFeatures(lFeatureSource, L"geonames_n83", NULL);
+ Ptr<MgFeatureReader> reader = pService->SelectFeatures(lFeatureSource, L"geonames_n83", nullptr);
while(reader->ReadNext())
INT32 fid = 0;
@@ -473,7 +347,7 @@
nFeatures = 0;
- Ptr<MgFeatureReader> reader = pService->SelectFeatures(lFeatureSource, L"GEONAMES_N83", NULL);
+ Ptr<MgFeatureReader> reader = pService->SelectFeatures(lFeatureSource, L"GEONAMES_N83", nullptr);
INT32 fid = 0;
@@ -511,7 +385,7 @@
nFeatures = 0;
INT32 fid = 0;
@@ -556,20 +430,20 @@
SAFE_RELEASE(e);
SAFE_RELEASE(e);
catch(FdoException* e)
FDO_SAFE_RELEASE(e);
catch(...)
Deleted: sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.h
--- sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.h 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.h 2020-07-13 13:04:59 UTC (rev 9659)
@@ -1,44 +0,0 @@
-#ifndef _TESTPERFORMANCE_H
-#define _TESTPERFORMANCE_H
-class TestPerformance : public CppUnit::TestFixture
- CPPUNIT_TEST_SUITE(TestPerformance);
- CPPUNIT_TEST(TestCase_BenchmarkJoinFeatures);
-public:
- void setUp();
- void tearDown();
- void TestStart();
- void TestEnd();
- void TestCase_BenchmarkJoinFeatures();
-#endif // _TESTPERFORMANCE_H
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestProfilingService.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestProfilingService.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestProfilingService.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -96,10 +96,10 @@
Ptr<MgSelection> selectionOnMapWithWatermark = CreateSelection(mapWithWatermark);
// make a rendering option
- Ptr<MgRenderingOptions> options = new MgRenderingOptions(L"PNG",MgRenderingOptions::RenderSelection| MgRenderingOptions::RenderLayers| MgRenderingOptions::KeepSelection,NULL);
+ Ptr<MgRenderingOptions> options = new MgRenderingOptions(L"PNG",MgRenderingOptions::RenderSelection| MgRenderingOptions::RenderLayers| MgRenderingOptions::KeepSelection,nullptr);
// profile rendering normal map
- Ptr<MgByteReader> rdr1 = svcProfiling->ProfileRenderDynamicOverlay(map, NULL, options);
+ Ptr<MgByteReader> rdr1 = svcProfiling->ProfileRenderDynamicOverlay(map, nullptr, options);
rdr1->ToFile(L"../UnitTestFiles/ProfileRenderDynamicOverlay_Normal.xml");
// profile rendering normal map with selection
@@ -107,7 +107,7 @@
rdr2->ToFile(L"../UnitTestFiles/ProfileRenderDynamicOverlay_Selection.xml");
// profile rendering map with watermark
- Ptr<MgByteReader> rdr3 = svcProfiling->ProfileRenderDynamicOverlay(mapWithWatermark, NULL, options);
+ Ptr<MgByteReader> rdr3 = svcProfiling->ProfileRenderDynamicOverlay(mapWithWatermark, nullptr, options);
rdr3->ToFile(L"../UnitTestFiles/ProfileRenderDynamicOverlay_Watermark.xml");
// profile rendering map with both watermark and selection
@@ -143,13 +143,13 @@
Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.733253, 43.746199);
Ptr<MgColor> bgc = new MgColor(255, 255, 255, 255);
- Ptr<MgByteReader> rdr1 = svcProfiling->ProfileRenderMap(map, NULL, coordNewCenter, 75000, 1024, 1024, bgc, L"PNG", false);
+ Ptr<MgByteReader> rdr1 = svcProfiling->ProfileRenderMap(map, nullptr, coordNewCenter, 75000, 1024, 1024, bgc, L"PNG", false);
rdr1->ToFile(L"../UnitTestFiles/ProfileRenderMap_Normal.xml");
@@ -157,7 +157,7 @@
rdr2->ToFile(L"../UnitTestFiles/ProfileRenderMap_Selection.xml");
// profile rendering normal map with watermark
- Ptr<MgByteReader> rdr3 = svcProfiling->ProfileRenderMap(mapWithWatermark, NULL, coordNewCenter, 75000, 1024, 1024, bgc, L"PNG", false);
+ Ptr<MgByteReader> rdr3 = svcProfiling->ProfileRenderMap(mapWithWatermark, nullptr, coordNewCenter, 75000, 1024, 1024, bgc, L"PNG", false);
rdr3->ToFile(L"../UnitTestFiles/ProfileRenderMap_Watermark.xml");
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestRenderingService.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestRenderingService.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestRenderingService.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -16,605 +16,167 @@
-#include "TestRenderingService.h"
#include "ServerSiteService.h"
+#include "Fdo.h"
#include "StylizationDefs.h"
-#include "../Common/Manager/FdoConnectionManager.h"
#include "MVTRenderer.h"
+//#include "AGGRenderer.h"
#include "SE_Renderer.h"
-CPPUNIT_TEST_SUITE_NAMED_REGISTRATION(TestRenderingService, "TestRenderingService");
-TestRenderingService::TestRenderingService()
+static MgMap* CreateTestMapWithWatermark()
- // Initialize service objects.
+ Ptr<MgServerSiteService> svcSite = TestServiceFactory::CreateSiteService();
+ Ptr<MgSiteConnection> m_siteConnection = TestServiceFactory::CreateSiteConnection(svcSite);
- m_svcResource = dynamic_cast<MgResourceService*>(
- serviceManager->RequestService(MgServiceType::ResourceService));
- assert(m_svcResource != NULL);
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/SheboyganWithWatermark.MapDefinition");
+ MgMap* map = new MgMap(m_siteConnection);
+ map->Create(mdfres, L"UnitTestSheboyganWithWatermark");
- m_svcRendering = dynamic_cast<MgRenderingService*>(
- serviceManager->RequestService(MgServiceType::RenderingService));
- assert(m_svcRendering != NULL);
+ Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.733253, 43.746199);
+ Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
+ map->SetViewCenter(ptNewCenter);
+ map->SetViewScale(75000.0);
+ map->SetDisplayDpi(96);
+ map->SetDisplayWidth(1024);
+ map->SetDisplayHeight(1024);
- // Initialize a site connection.
- Ptr<MgServerSiteService> svcSite = dynamic_cast<MgServerSiteService*>(
- serviceManager->RequestService(MgServiceType::SiteService));
- assert(svcSite != NULL);
+ return map;
- L"Administrator", L"admin");
+static MgMap* CreateTestMap()
- // Set the current MgUserInformation
- // This must be done before calling CreateSession()
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ map->Create(mdfres, L"UnitTestSheboygan");
- STRING session = svcSite->CreateSession();
- assert(!session.empty());
- userInfo->SetMgSessionId(session);
- m_siteConnection = new MgSiteConnection();
- m_siteConnection->Open(userInfo);
+ return map;
-TestRenderingService::~TestRenderingService()
+static MgMap* CreateTestStylizationFunctionMap()
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/StylizationFuncs.MapDefinition");
+ map->Create(mdfres, L"StylizationFuncs");
-void TestRenderingService::setUp()
+ map->SetViewScale(60000.0);
-void TestRenderingService::tearDown()
+ return map;
-void TestRenderingService::TestStart()
+static MgMap* CreateTestXYZMap()
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nRunning Rendering Service tests.\n")));
- try
- #ifdef _DEBUG
- #endif
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/BaseMap.MapDefinition");
+ map->Create(mdfres, L"UnitTestSheboyganXYZ");
- // set user info
+ Ptr<MgLayerCollection> layers = map->GetLayers();
+ Ptr<MgLayerGroupCollection> groups = map->GetLayerGroups();
+ Ptr<MgLayerBase> roads = layers->GetItem(L"RoadCenterLines");
+ Ptr<MgLayerGroup> baseGroup = groups->GetItem(L"BaseLayers");
+ roads->SetGroup(baseGroup);
- // publish the map definition
- Ptr<MgResourceIdentifier> mapres1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
- Ptr<MgByteSource> mdfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_Sheboygan.mdf", false);
- Ptr<MgByteReader> mdfrdr1 = mdfsrc1->GetReader();
- m_svcResource->SetResource(mapres1, mdfrdr1, NULL);
- // publish tile set
- Ptr<MgResourceIdentifier> tilesetres1 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ.TileSetDefinition");
- Ptr<MgByteSource> tsdsrc1 = new MgByteSource(L"../UnitTestFiles/UT_XYZ.tsd", false);
- Ptr<MgByteReader> tsdrdr1 = tsdsrc1->GetReader();
- m_svcResource->SetResource(tilesetres1, tsdrdr1, NULL);
+ return map;
- // publish the layer definitions
- Ptr<MgResourceIdentifier> ldfres1 = new MgResourceIdentifier(L"Library://UnitTests/Layers/HydrographicPolygons.LayerDefinition");
- Ptr<MgByteSource> ldfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.ldf", false);
- Ptr<MgByteReader> ldfrdr1 = ldfsrc1->GetReader();
- m_svcResource->SetResource(ldfres1, ldfrdr1, NULL);
+static MgMap* CreateTestTiledMap()
- Ptr<MgResourceIdentifier> ldfres2 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Rail.LayerDefinition");
- Ptr<MgByteSource> ldfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_Rail.ldf", false);
- Ptr<MgByteReader> ldfrdr2 = ldfsrc2->GetReader();
- m_svcResource->SetResource(ldfres2, ldfrdr2, NULL);
+ map->Create(mdfres, L"UnitTestSheboyganTiled");
- Ptr<MgResourceIdentifier> ldfres3 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
- Ptr<MgByteSource> ldfsrc3 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.ldf", false);
- Ptr<MgByteReader> ldfrdr3 = ldfsrc3->GetReader();
- m_svcResource->SetResource(ldfres3, ldfrdr3, NULL);
- // publish the feature sources
- Ptr<MgResourceIdentifier> fsres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/HydrographicPolygons.FeatureSource");
- Ptr<MgByteSource> fssrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.fs", false);
- Ptr<MgByteReader> fsrdr1 = fssrc1->GetReader();
- m_svcResource->SetResource(fsres1, fsrdr1, NULL);
+ return map;
- Ptr<MgResourceIdentifier> fsres2 = new MgResourceIdentifier(L"Library://UnitTests/Data/Rail.FeatureSource");
- Ptr<MgByteSource> fssrc2 = new MgByteSource(L"../UnitTestFiles/UT_Rail.fs", false);
- Ptr<MgByteReader> fsrdr2 = fssrc2->GetReader();
- m_svcResource->SetResource(fsres2, fsrdr2, NULL);
+// creates a selection bounds in mapping space
+static MgPolygon* CreateSelectionPolygon(MgMap* map, double width, double height)
+ Ptr<MgPoint> centerPt = map->GetViewCenter();
+ Ptr<MgCoordinate> center = centerPt->GetCoordinate();
+ double xMin = center->GetX() - 0.5 * width;
+ double yMin = center->GetY() - 0.5 * height;
+ double xMax = center->GetX() + 0.5 * width;
+ double yMax = center->GetY() + 0.5 * height;
+ Ptr<MgCoordinateXY> c1 = new MgCoordinateXY(xMin, yMin);
+ Ptr<MgCoordinateXY> c2 = new MgCoordinateXY(xMax, yMin);
+ Ptr<MgCoordinateXY> c3 = new MgCoordinateXY(xMax, yMax);
+ Ptr<MgCoordinateXY> c4 = new MgCoordinateXY(xMin, yMax);
+ Ptr<MgCoordinateXY> c5 = new MgCoordinateXY(xMin, yMin);
- Ptr<MgResourceIdentifier> fsres3 = new MgResourceIdentifier(L"Library://UnitTests/Data/Parcels.FeatureSource");
- Ptr<MgByteSource> fssrc3 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.fs", false);
- Ptr<MgByteReader> fsrdr3 = fssrc3->GetReader();
- m_svcResource->SetResource(fsres3, fsrdr3, NULL);
+ Ptr<MgCoordinateCollection> cc = new MgCoordinateCollection();
+ cc->Add(c1);
+ cc->Add(c2);
+ cc->Add(c3);
+ cc->Add(c4);
+ cc->Add(c5);
- // publish the resource data
- Ptr<MgByteSource> dataSource1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.sdf", false);
- m_svcResource->SetResourceData(fsres1, L"UT_HydrographicPolygons.sdf", L"File", dataReader1);
- Ptr<MgByteSource> dataSource2 = new MgByteSource(L"../UnitTestFiles/UT_Rail.sdf", false);
- Ptr<MgByteReader> dataReader2 = dataSource2->GetReader();
- m_svcResource->SetResourceData(fsres2, L"UT_Rail.sdf", L"File", dataReader2);
- Ptr<MgByteSource> dataSource3 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.sdf", false);
- Ptr<MgByteReader> dataReader3 = dataSource3->GetReader();
- m_svcResource->SetResourceData(fsres3, L"UT_Parcels.sdf", L"File", dataReader3);
- // publish the print layouts
- Ptr<MgResourceIdentifier> plres1 = new MgResourceIdentifier(L"Library://UnitTests/PrintLayouts/AllElements.PrintLayout");
- Ptr<MgByteSource> plsrc1 = new MgByteSource(L"../UnitTestFiles/UT_AllElements.pl", false);
- Ptr<MgByteReader> plrdr1 = plsrc1->GetReader();
- m_svcResource->SetResource(plres1, plrdr1, NULL);
- Ptr<MgResourceIdentifier> plres2 = new MgResourceIdentifier(L"Library://UnitTests/PrintLayouts/NoLegend.PrintLayout");
- Ptr<MgByteSource> plsrc2 = new MgByteSource(L"../UnitTestFiles/UT_NoLegend.pl", false);
- Ptr<MgByteReader> plrdr2 = plsrc2->GetReader();
- m_svcResource->SetResource(plres2, plrdr2, NULL);
- // publish the symbol library
- Ptr<MgResourceIdentifier> slres1 = new MgResourceIdentifier(L"Library://UnitTests/Symbols/SymbolMart.SymbolLibrary");
- Ptr<MgByteSource> slsrc1 = new MgByteSource(L"../UnitTestFiles/UT_SymbolMart.sl", false);
- Ptr<MgByteReader> slrdr1 = slsrc1->GetReader();
- m_svcResource->SetResource(slres1, slrdr1, NULL);
- Ptr<MgByteSource> datasrc = new MgByteSource(L"../UnitTestFiles/UT_Symbols.dwf", false);
- Ptr<MgByteReader> datardr = datasrc->GetReader();
- m_svcResource->SetResourceData(slres1, L"symbols.dwf", L"File", datardr);
- // publish symbology stuff
- // the point feature source
- Ptr<MgResourceIdentifier> fsres4 = new MgResourceIdentifier(L"Library://UnitTests/Data/Capitals.FeatureSource");
- Ptr<MgByteSource> fssrc4 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyPoints.fs", false);
- Ptr<MgByteReader> fsrdr4 = fssrc4->GetReader();
- m_svcResource->SetResource(fsres4, fsrdr4, NULL);
- // point sdf file
- Ptr<MgByteSource> dataSource4 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyPoints.sdf", false);
- Ptr<MgByteReader> dataReader4 = dataSource4->GetReader();
- m_svcResource->SetResourceData(fsres4, L"UT_SymbologyPoints.sdf", L"File", dataReader4);
- // point symbols
- Ptr<MgResourceIdentifier> sdres1 = new MgResourceIdentifier(L"Library://UnitTests/Symbols/PointSymbol.SymbolDefinition");
- Ptr<MgByteSource> sdsrc1 = new MgByteSource(L"../UnitTestFiles/symbol.sd", false);
- Ptr<MgByteReader> sdrdr1 = sdsrc1->GetReader();
- m_svcResource->SetResource(sdres1, sdrdr1, NULL);
- Ptr<MgResourceIdentifier> sdres2 = new MgResourceIdentifier(L"Library://UnitTests/Symbols/PointSymbolParam.SymbolDefinition");
- Ptr<MgByteSource> sdsrc2 = new MgByteSource(L"../UnitTestFiles/symbolp.sd", false);
- Ptr<MgByteReader> sdrdr2 = sdsrc2->GetReader();
- m_svcResource->SetResource(sdres2, sdrdr2, NULL);
- // point ldf
- Ptr<MgResourceIdentifier> ldfres4 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Capitals.LayerDefinition");
- Ptr<MgByteSource> ldfsrc4 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyPoints.ldf", false);
- Ptr<MgByteReader> ldfrdr4 = ldfsrc4->GetReader();
- m_svcResource->SetResource(ldfres4, ldfrdr4, NULL);
- Ptr<MgResourceIdentifier> ldfres5 = new MgResourceIdentifier(L"Library://UnitTests/Layers/CapitalsParam.LayerDefinition");
- Ptr<MgByteSource> ldfsrc5 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyPointsParam.ldf", false);
- Ptr<MgByteReader> ldfrdr5 = ldfsrc5->GetReader();
- m_svcResource->SetResource(ldfres5, ldfrdr5, NULL);
- // point mdf
- Ptr<MgResourceIdentifier> mapres2 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Capitals.MapDefinition");
- Ptr<MgByteSource> mdfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyPoints.mdf", false);
- Ptr<MgByteReader> mdfrdr2 = mdfsrc2->GetReader();
- m_svcResource->SetResource(mapres2, mdfrdr2, NULL);
- Ptr<MgResourceIdentifier> mapres3 = new MgResourceIdentifier(L"Library://UnitTests/Maps/CapitalsParam.MapDefinition");
- Ptr<MgByteSource> mdfsrc3 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyPointsParam.mdf", false);
- Ptr<MgByteReader> mdfrdr3 = mdfsrc3->GetReader();
- m_svcResource->SetResource(mapres3, mdfrdr3, NULL);
- // the line feature source
- Ptr<MgResourceIdentifier> fsres5 = new MgResourceIdentifier(L"Library://UnitTests/Data/Lines.FeatureSource");
- Ptr<MgByteSource> fssrc5 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyLines.fs", false);
- Ptr<MgByteReader> fsrdr5 = fssrc5->GetReader();
- m_svcResource->SetResource(fsres5, fsrdr5, NULL);
- // line sdf file
- Ptr<MgByteSource> dataSource5 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyLines.sdf", false);
- Ptr<MgByteReader> dataReader5 = dataSource5->GetReader();
- m_svcResource->SetResourceData(fsres5, L"UT_SymbologyLines.sdf", L"File", dataReader5);
- // line symbols
- Ptr<MgResourceIdentifier> sdres3 = new MgResourceIdentifier(L"Library://UnitTests/Symbols/LineSymbol.SymbolDefinition");
- Ptr<MgByteSource> sdsrc3 = new MgByteSource(L"../UnitTestFiles/linesymbol.sd", false);
- Ptr<MgByteReader> sdrdr3 = sdsrc3->GetReader();
- m_svcResource->SetResource(sdres3, sdrdr3, NULL);
- Ptr<MgResourceIdentifier> sdres4 = new MgResourceIdentifier(L"Library://UnitTests/Symbols/MTYP1500a.SymbolDefinition");
- Ptr<MgByteSource> sdsrc4 = new MgByteSource(L"../UnitTestFiles/MTYP1500a.sd", false);
- Ptr<MgByteReader> sdrdr4 = sdsrc4->GetReader();
- m_svcResource->SetResource(sdres4, sdrdr4, NULL);
- // line ldf
- Ptr<MgResourceIdentifier> ldfres6 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Lines.LayerDefinition");
- Ptr<MgByteSource> ldfsrc6 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyLines.ldf", false);
- Ptr<MgByteReader> ldfrdr6 = ldfsrc6->GetReader();
- m_svcResource->SetResource(ldfres6, ldfrdr6, NULL);
- Ptr<MgResourceIdentifier> ldfres7 = new MgResourceIdentifier(L"Library://UnitTests/Layers/LinesCrossTick.LayerDefinition");
- Ptr<MgByteSource> ldfsrc7 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyLinesCrossTick.ldf", false);
- Ptr<MgByteReader> ldfrdr7 = ldfsrc7->GetReader();
- m_svcResource->SetResource(ldfres7, ldfrdr7, NULL);
- // line mdf
- Ptr<MgResourceIdentifier> mapres4 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Lines.MapDefinition");
- Ptr<MgByteSource> mdfsrc4 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyLines.mdf", false);
- Ptr<MgByteReader> mdfrdr4 = mdfsrc4->GetReader();
- m_svcResource->SetResource(mapres4, mdfrdr4, NULL);
- Ptr<MgResourceIdentifier> mapres5 = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinesCrossTick.MapDefinition");
- Ptr<MgByteSource> mdfsrc5 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyLinesCrossTick.mdf", false);
- Ptr<MgByteReader> mdfrdr5 = mdfsrc5->GetReader();
- m_svcResource->SetResource(mapres5, mdfrdr5, NULL);
- // annotation ldf - this shares the point sdf
- Ptr<MgResourceIdentifier> ldfres8 = new MgResourceIdentifier(L"Library://UnitTests/Layers/UT_Annotation1.LayerDefinition");
- Ptr<MgByteSource> ldfsrc8 = new MgByteSource(L"../UnitTestFiles/UT_Annotation1.ldf", false);
- Ptr<MgByteReader> ldfrdr8 = ldfsrc8->GetReader();
- m_svcResource->SetResource(ldfres8, ldfrdr8, NULL);
- Ptr<MgResourceIdentifier> ldfres9 = new MgResourceIdentifier(L"Library://UnitTests/Layers/UT_Annotation2.LayerDefinition");
- Ptr<MgByteSource> ldfsrc9 = new MgByteSource(L"../UnitTestFiles/UT_Annotation2.ldf", false);
- Ptr<MgByteReader> ldfrdr9 = ldfsrc9->GetReader();
- m_svcResource->SetResource(ldfres9, ldfrdr9, NULL);
- Ptr<MgResourceIdentifier> ldfres10 = new MgResourceIdentifier(L"Library://UnitTests/Layers/UT_Annotation3.LayerDefinition");
- Ptr<MgByteSource> ldfsrc10 = new MgByteSource(L"../UnitTestFiles/UT_Annotation3.ldf", false);
- Ptr<MgByteReader> ldfrdr10 = ldfsrc10->GetReader();
- m_svcResource->SetResource(ldfres10, ldfrdr10, NULL);
- // annotation mdf
- Ptr<MgResourceIdentifier> mapres8 = new MgResourceIdentifier(L"Library://UnitTests/Maps/UT_Annotation1.MapDefinition");
- Ptr<MgByteSource> mdfsrc8 = new MgByteSource(L"../UnitTestFiles/UT_Annotation1.mdf", false);
- Ptr<MgByteReader> mdfrdr8 = mdfsrc8->GetReader();
- m_svcResource->SetResource(mapres8, mdfrdr8, NULL);
- Ptr<MgResourceIdentifier> mapres9 = new MgResourceIdentifier(L"Library://UnitTests/Maps/UT_Annotation2.MapDefinition");
- Ptr<MgByteSource> mdfsrc9 = new MgByteSource(L"../UnitTestFiles/UT_Annotation2.mdf", false);
- Ptr<MgByteReader> mdfrdr9 = mdfsrc9->GetReader();
- m_svcResource->SetResource(mapres9, mdfrdr9, NULL);
- Ptr<MgResourceIdentifier> mapres10 = new MgResourceIdentifier(L"Library://UnitTests/Maps/UT_Annotation3.MapDefinition");
- Ptr<MgByteSource> mdfsrc10 = new MgByteSource(L"../UnitTestFiles/UT_Annotation3.mdf", false);
- Ptr<MgByteReader> mdfrdr10 = mdfsrc10->GetReader();
- m_svcResource->SetResource(mapres10, mdfrdr10, NULL);
- //symbology - polygons
- Ptr<MgResourceIdentifier> mapres11 = new MgResourceIdentifier(L"Library://UnitTests/Maps/UT_SymbologyPolygons.MapDefinition");
- Ptr<MgByteSource> mdfsrc11 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyPolygons.mdf", false);
- Ptr<MgByteReader> mdfrdr11 = mdfsrc11->GetReader();
- m_svcResource->SetResource(mapres11, mdfrdr11, NULL);
- Ptr<MgResourceIdentifier> ldfres11 = new MgResourceIdentifier(L"Library://UnitTests/Layers/SymbologyParcels.LayerDefinition");
- Ptr<MgByteSource> ldfsrc11 = new MgByteSource(L"../UnitTestFiles/UT_SymbologyParcels.ldf", false);
- Ptr<MgByteReader> ldfrdr11 = ldfsrc11->GetReader();
- m_svcResource->SetResource(ldfres11, ldfrdr11, NULL);
- Ptr<MgResourceIdentifier> sdres5 = new MgResourceIdentifier(L"Library://UnitTests/Symbols/AreaSymbol.SymbolDefinition");
- Ptr<MgByteSource> sdsrc5 = new MgByteSource(L"../UnitTestFiles/areasymbol.sd", false);
- Ptr<MgByteReader> sdrdr5 = sdsrc5->GetReader();
- m_svcResource->SetResource(sdres5, sdrdr5, NULL);
- // For watermark test
- Ptr<MgResourceIdentifier> mapres12 = new MgResourceIdentifier(L"Library://UnitTests/Maps/SheboyganWithWatermark.MapDefinition");
- Ptr<MgByteSource> mdfsrc12 = new MgByteSource(L"../UnitTestFiles/UT_SheboyganWithWatermark.mdf", false);
- Ptr<MgByteReader> mdfrdr12 = mdfsrc12->GetReader();
- m_svcResource->SetResource(mapres12, mdfrdr12, NULL);
- // publish the watermark definition
- Ptr<MgResourceIdentifier> wdfres1 = new MgResourceIdentifier(L"Library://UnitTests/Watermarks/PoweredByMapGuide.WatermarkDefinition");
- Ptr<MgByteSource> wdfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_PoweredByMapGuide.wdf", false);
- Ptr<MgByteReader> wdfrdr1 = wdfsrc1->GetReader();
- m_svcResource->SetResource(wdfres1, wdfrdr1, NULL);
- // base map source data
- Ptr<MgResourceIdentifier> mapres13 = new MgResourceIdentifier(L"Library://UnitTests/Maps/BaseMap.MapDefinition");
- Ptr<MgByteSource> mdfsrc13 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap.mdf", false);
- Ptr<MgByteReader> mdfrdr13 = mdfsrc13->GetReader();
- m_svcResource->SetResource(mapres13, mdfrdr13, NULL);
- Ptr<MgResourceIdentifier> ldfres12 = new MgResourceIdentifier(L"Library://UnitTests/Layers/RoadCenterLines.LayerDefinition");
- Ptr<MgByteSource> ldfsrc12 = new MgByteSource(L"../UnitTestFiles/UT_RoadCenterLines.ldf", false);
- Ptr<MgByteReader> ldfrdr12 = ldfsrc12->GetReader();
- m_svcResource->SetResource(ldfres12, ldfrdr12, NULL);
- Ptr<MgResourceIdentifier> ldfres13 = new MgResourceIdentifier(L"Library://UnitTests/Layers/VotingDistricts.LayerDefinition");
- Ptr<MgByteSource> ldfsrc13 = new MgByteSource(L"../UnitTestFiles/UT_VotingDistricts.ldf", false);
- Ptr<MgByteReader> ldfrdr13 = ldfsrc13->GetReader();
- m_svcResource->SetResource(ldfres13, ldfrdr13, NULL);
- Ptr<MgResourceIdentifier> fsres6 = new MgResourceIdentifier(L"Library://UnitTests/Data/RoadCenterLines.FeatureSource");
- Ptr<MgByteSource> fssrc6 = new MgByteSource(L"../UnitTestFiles/UT_RoadCenterLines.fs", false);
- Ptr<MgByteReader> fsrdr6 = fssrc6->GetReader();
- m_svcResource->SetResource(fsres6, fsrdr6, NULL);
- Ptr<MgResourceIdentifier> fsres7 = new MgResourceIdentifier(L"Library://UnitTests/Data/VotingDistricts.FeatureSource");
- Ptr<MgByteSource> fssrc7 = new MgByteSource(L"../UnitTestFiles/UT_VotingDistricts.fs", false);
- Ptr<MgByteReader> fsrdr7 = fssrc7->GetReader();
- m_svcResource->SetResource(fsres7, fsrdr7, NULL);
- Ptr<MgByteSource> dataSource6 = new MgByteSource(L"../UnitTestFiles/UT_RoadCenterLines.sdf", false);
- Ptr<MgByteReader> dataReader6 = dataSource6->GetReader();
- m_svcResource->SetResourceData(fsres6, L"UT_RoadCenterLines.sdf", L"File", dataReader6);
- Ptr<MgByteSource> dataSource7 = new MgByteSource(L"../UnitTestFiles/UT_VotingDistricts.sdf", false);
- Ptr<MgByteReader> dataReader7 = dataSource7->GetReader();
- m_svcResource->SetResourceData(fsres7, L"UT_VotingDistricts.sdf", L"File", dataReader7);
- // Data for exercising legend rendering
- Ptr<MgResourceIdentifier> ldfres14 = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiFTS.LayerDefinition");
- Ptr<MgByteSource> ldfsrc14 = new MgByteSource(L"../UnitTestFiles/UT_MultiFTS.ldf", false);
- Ptr<MgByteReader> ldfrdr14 = ldfsrc14->GetReader();
- m_svcResource->SetResource(ldfres14, ldfrdr14, NULL);
- Ptr<MgResourceIdentifier> ldfres15 = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiCTS.LayerDefinition");
- Ptr<MgByteSource> ldfsrc15 = new MgByteSource(L"../UnitTestFiles/UT_MultiCTS.ldf", false);
- Ptr<MgByteReader> ldfrdr15 = ldfsrc15->GetReader();
- m_svcResource->SetResource(ldfres15, ldfrdr15, NULL);
- Ptr<MgResourceIdentifier> ldfres16 = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiFTSWithTheme.LayerDefinition");
- Ptr<MgByteSource> ldfsrc16 = new MgByteSource(L"../UnitTestFiles/UT_MultiFTSWithTheme.ldf", false);
- Ptr<MgByteReader> ldfrdr16 = ldfsrc16->GetReader();
- m_svcResource->SetResource(ldfres16, ldfrdr16, NULL);
- Ptr<MgResourceIdentifier> ldfres17 = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiCTSWithTheme.LayerDefinition");
- Ptr<MgByteSource> ldfsrc17 = new MgByteSource(L"../UnitTestFiles/UT_MultiCTSWithTheme.ldf", false);
- Ptr<MgByteReader> ldfrdr17 = ldfsrc17->GetReader();
- m_svcResource->SetResource(ldfres17, ldfrdr17, NULL);
- Ptr<MgResourceIdentifier> ldfres18 = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiFTSSingleCTS.LayerDefinition");
- Ptr<MgByteSource> ldfsrc18 = new MgByteSource(L"../UnitTestFiles/UT_MultiFTSSingleCTS.ldf", false);
- Ptr<MgByteReader> ldfrdr18 = ldfsrc18->GetReader();
- m_svcResource->SetResource(ldfres18, ldfrdr18, NULL);
- Ptr<MgResourceIdentifier> ldfres19 = new MgResourceIdentifier(L"Library://UnitTests/Layers/SingleFTSMultiCTS.LayerDefinition");
- Ptr<MgByteSource> ldfsrc19 = new MgByteSource(L"../UnitTestFiles/UT_SingleFTSMultiCTS.ldf", false);
- Ptr<MgByteReader> ldfrdr19 = ldfsrc19->GetReader();
- m_svcResource->SetResource(ldfres19, ldfrdr19, NULL);
- // Data related to stylization function tests
- Ptr<MgResourceIdentifier> ldfres20 = new MgResourceIdentifier(L"Library://UnitTests/Layers/StylizationFuncs.LayerDefinition");
- Ptr<MgByteSource> ldfsrc20 = new MgByteSource(L"../UnitTestFiles/UT_VotingDistrictsFunctions.ldf", false);
- Ptr<MgByteReader> ldfrdr20 = ldfsrc20->GetReader();
- m_svcResource->SetResource(ldfres20, ldfrdr20, NULL);
- Ptr<MgResourceIdentifier> mapres15 = new MgResourceIdentifier(L"Library://UnitTests/Maps/StylizationFuncs.MapDefinition");
- Ptr<MgByteSource> mdfsrc15 = new MgByteSource(L"../UnitTestFiles/UT_StylizationFuncs.mdf", false);
- Ptr<MgByteReader> mdfrdr15 = mdfsrc15->GetReader();
- m_svcResource->SetResource(mapres15, mdfrdr15, NULL);
- // For layer watermark test
- Ptr<MgResourceIdentifier> wdfres2 = new MgResourceIdentifier(L"Library://UnitTests/Watermarks/Rail.WatermarkDefinition");
- Ptr<MgByteSource> wdfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_Rail.wdf", false);
- Ptr<MgByteReader> wdfrdr2 = wdfsrc2->GetReader();
- m_svcResource->SetResource(wdfres2, wdfrdr2, NULL);
- Ptr<MgResourceIdentifier> ldfres21 = new MgResourceIdentifier(L"Library://UnitTests/Layers/RailWatermark.LayerDefinition");
- Ptr<MgByteSource> ldfsrc21 = new MgByteSource(L"../UnitTestFiles/UT_Rail_Watermark.ldf", false);
- Ptr<MgByteReader> ldfrdr21 = ldfsrc21->GetReader();
- m_svcResource->SetResource(ldfres21, ldfrdr21, NULL);
- SAFE_RELEASE(e);
- catch (...)
- throw;
+ Ptr<MgLinearRing> outer = new MgLinearRing(cc);
+ return new MgPolygon(outer, nullptr);
-void TestRenderingService::TestEnd()
+static STRING GetPath(CREFSTRING basePath, CREFSTRING imageFormat, CREFSTRING extension)
- try
- // set user info
- // delete the map definition
- m_svcResource->DeleteResource(mapres1);
- // delete tile set
- m_svcResource->DeleteResource(tilesetres1);
- // delete the layer definitions
- m_svcResource->DeleteResource(ldfres1);
- m_svcResource->DeleteResource(ldfres2);
- m_svcResource->DeleteResource(ldfres3);
- m_svcResource->DeleteResource(fsres1);
- m_svcResource->DeleteResource(fsres2);
- m_svcResource->DeleteResource(fsres3);
- // delete the print layouts
- m_svcResource->DeleteResource(plres1);
- m_svcResource->DeleteResource(plres2);
- // delete the symbol library
- m_svcResource->DeleteResource(slres1);
- // delete symbology stuff
- m_svcResource->DeleteResource(fsres4);
- m_svcResource->DeleteResource(sdres1);
- m_svcResource->DeleteResource(sdres2);
- m_svcResource->DeleteResource(ldfres4);
- m_svcResource->DeleteResource(ldfres5);
- m_svcResource->DeleteResource(mapres2);
- m_svcResource->DeleteResource(mapres3);
- m_svcResource->DeleteResource(fsres5);
- m_svcResource->DeleteResource(sdres3);
- m_svcResource->DeleteResource(sdres4);
- m_svcResource->DeleteResource(ldfres6);
- m_svcResource->DeleteResource(ldfres7);
- m_svcResource->DeleteResource(mapres4);
- m_svcResource->DeleteResource(mapres5);
- m_svcResource->DeleteResource(ldfres8);
- m_svcResource->DeleteResource(ldfres9);
- m_svcResource->DeleteResource(ldfres10);
- m_svcResource->DeleteResource(mapres8);
- m_svcResource->DeleteResource(mapres9);
- m_svcResource->DeleteResource(mapres10);
- m_svcResource->DeleteResource(mapres11);
- m_svcResource->DeleteResource(ldfres11);
- m_svcResource->DeleteResource(sdres5);
- m_svcResource->DeleteResource(mapres12);
- m_svcResource->DeleteResource(wdfres1);
- m_svcResource->DeleteResource(mapres13);
- m_svcResource->DeleteResource(ldfres12);
- m_svcResource->DeleteResource(ldfres13);
- m_svcResource->DeleteResource(fsres6);
- m_svcResource->DeleteResource(fsres7);
- m_svcResource->DeleteResource(ldfres14);
- m_svcResource->DeleteResource(ldfres15);
- m_svcResource->DeleteResource(ldfres16);
- m_svcResource->DeleteResource(ldfres17);
- m_svcResource->DeleteResource(ldfres18);
- m_svcResource->DeleteResource(ldfres19);
- m_svcResource->DeleteResource(ldfres20);
- m_svcResource->DeleteResource(mapres15);
- // Layer watermark test
- m_svcResource->DeleteResource(wdfres2);
- m_svcResource->DeleteResource(ldfres21);
- #ifdef _DEBUG
- #endif
- catch(MgFileIoException* e)
- SAFE_RELEASE(e);
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nMgFileIoException - Possible file permission error.\nError: %W\n"), message.c_str()));
- message += e->GetStackTrace(TEST_LOCALE);
- SAFE_RELEASE(e);
- catch (...)
- throw;
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nRendering Service tests completed.\n\n")));
+ STRING ret;
+ ret += basePath;
+ ret += L"_";
+ ret += imageFormat;
+ ret += L".";
+ ret += extension;
+ return ret;
-void TestRenderingService::TestCase_RenderDynamicOverlay(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderDynamicOverlay(CREFSTRING imageFormat, CREFSTRING extension)
try
+ Ptr<MgRenderingService> m_svcRendering = TestServiceFactory::CreateRenderingService();
// make a runtime map
Ptr<MgMap> map = CreateTestMap();
@@ -625,7 +187,7 @@
// for (int i=0; i<10; i++)
- Ptr<MgByteReader> rdr1 = m_svcRendering->RenderDynamicOverlay(map, NULL, imageFormat);
+ Ptr<MgByteReader> rdr1 = m_svcRendering->RenderDynamicOverlay(map, nullptr, imageFormat);
rdr1->ToFile(GetPath(L"../UnitTestFiles/RenderDynamicOverlay75k", imageFormat, extension));
@@ -633,7 +195,7 @@
// for (int i=0; i<100; i++)
- Ptr<MgByteReader> rdr2 = m_svcRendering->RenderDynamicOverlay(map, NULL, imageFormat);
+ Ptr<MgByteReader> rdr2 = m_svcRendering->RenderDynamicOverlay(map, nullptr, imageFormat);
rdr2->ToFile(GetPath(L"../UnitTestFiles/RenderDynamicOverlay12k", imageFormat, extension));
@@ -642,9 +204,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -653,31 +215,33 @@
-void TestRenderingService::TestCase_RenderDynamicOverlayTiledMap(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderDynamicOverlayTiledMap(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgMap> map = CreateTestTiledMap();
// clock_t t0 = clock();
- Ptr<MgRenderingOptions> renderOpts = new MgRenderingOptions(imageFormat, MgRenderingOptions::RenderLayers | MgRenderingOptions::RenderBaseLayers, NULL);
+ Ptr<MgRenderingOptions> renderOpts = new MgRenderingOptions(imageFormat, MgRenderingOptions::RenderLayers | MgRenderingOptions::RenderBaseLayers, nullptr);
map->SetViewScale(12000.0);
//EXPECT: Tiled layers rendered with transparent background for applicable formats
- Ptr<MgByteReader> rdr1 = m_svcRendering->RenderDynamicOverlay(map, NULL, renderOpts);
+ Ptr<MgByteReader> rdr1 = m_svcRendering->RenderDynamicOverlay(map, nullptr, renderOpts);
rdr1->ToFile(GetPath(L"../UnitTestFiles/RenderDynamicOverlayTiled_WithBase12k", imageFormat, extension));
- Ptr<MgRenderingOptions> renderOpts2 = new MgRenderingOptions(imageFormat, MgRenderingOptions::RenderLayers, NULL);
+ Ptr<MgRenderingOptions> renderOpts2 = new MgRenderingOptions(imageFormat, MgRenderingOptions::RenderLayers, nullptr);
//EXPECT: Nothing, with transparent background for applicable formats
- Ptr<MgByteReader> rdr2 = m_svcRendering->RenderDynamicOverlay(map, NULL, renderOpts2);
+ Ptr<MgByteReader> rdr2 = m_svcRendering->RenderDynamicOverlay(map, nullptr, renderOpts2);
rdr2->ToFile(GetPath(L"../UnitTestFiles/RenderDynamicOverlayTiled_NoBase12k", imageFormat, extension));
@@ -686,9 +250,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -697,27 +261,29 @@
-void TestRenderingService::TestCase_RenderMap(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderMap(CREFSTRING imageFormat, CREFSTRING extension)
try
// call the API using scales of 75000 and 12000
- Ptr<MgByteReader> rdr1 = m_svcRendering->RenderMap(map, NULL, imageFormat);
+ Ptr<MgByteReader> rdr1 = m_svcRendering->RenderMap(map, nullptr, imageFormat);
rdr1->ToFile(GetPath(L"../UnitTestFiles/RenderMap75k", imageFormat, extension));
- Ptr<MgByteReader> rdr2 = m_svcRendering->RenderMap(map, NULL, imageFormat);
+ Ptr<MgByteReader> rdr2 = m_svcRendering->RenderMap(map, nullptr, imageFormat);
rdr2->ToFile(GetPath(L"../UnitTestFiles/RenderMap12k", imageFormat, extension));
SAFE_RELEASE(e);
catch (...)
@@ -725,10 +291,12 @@
-void TestRenderingService::TestCase_RenderMapWithSelection(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderMapWithSelection(CREFSTRING imageFormat, CREFSTRING extension)
try
@@ -738,7 +306,7 @@
Ptr<MgFeatureService> featSvc = dynamic_cast<MgFeatureService*>(serviceManager->RequestService(MgServiceType::FeatureService));
- assert(featSvc != NULL);
+ assert(featSvc != nullptr);
Ptr<MgFeatureQueryOptions> query = new MgFeatureQueryOptions();
query->SetFilter(L"Autogenerated_SDF_ID = 1");
@@ -798,9 +366,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -808,27 +376,29 @@
-void TestRenderingService::TestCase_RenderMapWithWatermark(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderMapWithWatermark(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgMap> map = CreateTestMapWithWatermark();
rdr1->ToFile(GetPath(L"../UnitTestFiles/RenderMapWithWatermark75k", imageFormat, extension));
rdr2->ToFile(GetPath(L"../UnitTestFiles/RenderMapWithWatermark12k", imageFormat, extension));
SAFE_RELEASE(e);
catch (...)
@@ -837,10 +407,13 @@
-void TestRenderingService::TestCase_RenderLegend(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderLegend(CREFSTRING imageFormat, CREFSTRING extension)
try
+ Ptr<MgResourceService> m_svcResource = TestServiceFactory::CreateResourceService();
@@ -915,9 +488,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -925,10 +498,12 @@
-void TestRenderingService::TestCase_RenderLegendEmptyGroups(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderLegendEmptyGroups(CREFSTRING imageFormat, CREFSTRING extension)
try
@@ -967,9 +542,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -977,21 +552,23 @@
-void TestRenderingService::TestCase_StylizationFunctions(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_StylizationFunctions(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgMap> map = CreateTestStylizationFunctionMap();
// call the API using a scale of 75000
rdr1->ToFile(GetPath(L"../UnitTestFiles/StylizationFunc_75k", imageFormat, extension));
// call the API using a scale of 12000
map->SetViewScale(12000);
rdr2->ToFile(GetPath(L"../UnitTestFiles/StylizationFunc_12k", imageFormat, extension));
// Move around
@@ -998,14 +575,14 @@
Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.733753, 43.746899);
- Ptr<MgByteReader> rdr3 = m_svcRendering->RenderDynamicOverlay(map, NULL, imageFormat);
+ Ptr<MgByteReader> rdr3 = m_svcRendering->RenderDynamicOverlay(map, nullptr, imageFormat);
rdr3->ToFile(GetPath(L"../UnitTestFiles/StylizationFunc_12k_Moved", imageFormat, extension));
SAFE_RELEASE(e);
catch (...)
@@ -1013,10 +590,13 @@
-void TestRenderingService::TestCase_RenderLegendMultiFTS(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderLegendMultiFTS(CREFSTRING imageFormat, CREFSTRING extension)
try
@@ -1037,9 +617,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1047,10 +627,13 @@
-void TestRenderingService::TestCase_RenderLegendMultiCTS(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderLegendMultiCTS(CREFSTRING imageFormat, CREFSTRING extension)
try
@@ -1071,9 +654,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1081,10 +664,13 @@
-void TestRenderingService::TestCase_RenderLegendMultiFTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderLegendMultiFTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension)
try
@@ -1105,9 +691,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1115,10 +701,13 @@
-void TestRenderingService::TestCase_RenderLegendMultiCTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderLegendMultiCTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension)
try
@@ -1139,9 +728,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1149,10 +738,13 @@
-void TestRenderingService::TestCase_RenderLegendMultiFTSSingleCTS(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderLegendMultiFTSSingleCTS(CREFSTRING imageFormat, CREFSTRING extension)
try
@@ -1173,9 +765,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1184,10 +776,13 @@
-void TestRenderingService::TestCase_RenderLegendSingleFTSMultiCTS(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderLegendSingleFTSMultiCTS(CREFSTRING imageFormat, CREFSTRING extension)
try
@@ -1208,9 +803,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1218,10 +813,13 @@
-void TestRenderingService::TestCase_LayerWatermark(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_LayerWatermark(CREFSTRING imageFormat, CREFSTRING extension)
try
@@ -1244,19 +842,19 @@
Ptr<MgColor> selColor = new MgColor(0, 0, 255);
Ptr<MgRenderingOptions> renderOpts = new MgRenderingOptions(imageFormat, MgRenderingOptions::RenderLayers | MgRenderingOptions::RenderBaseLayers, selColor);
- Ptr<MgByteReader> img = m_svcRendering->RenderDynamicOverlay(map, NULL, renderOpts);
+ Ptr<MgByteReader> img = m_svcRendering->RenderDynamicOverlay(map, nullptr, renderOpts);
img->ToFile(GetPath(L"../UnitTestFiles/LayerWatermarkOn", imageFormat, extension));
layer->SetVisible(false);
map->Save();
- img = m_svcRendering->RenderDynamicOverlay(map, NULL, renderOpts);
+ img = m_svcRendering->RenderDynamicOverlay(map, nullptr, renderOpts);
img->ToFile(GetPath(L"../UnitTestFiles/LayerWatermarkOff", imageFormat, extension));
SAFE_RELEASE(e);
catch (...)
@@ -1264,10 +862,12 @@
-void TestRenderingService::TestCase_QueryFeatures()
+TEST_CASE("QueryFeatures", "[RenderingService]")
try
@@ -1299,9 +899,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1309,128 +909,15 @@
-MgMap* TestRenderingService::CreateTestMapWithWatermark()
- Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/SheboyganWithWatermark.MapDefinition");
- MgMap* map = new MgMap(m_siteConnection);
- map->Create(mdfres, L"UnitTestSheboyganWithWatermark");
- Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.733253, 43.746199);
- Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
- map->SetViewCenter(ptNewCenter);
- map->SetViewScale(75000.0);
- map->SetDisplayDpi(96);
- map->SetDisplayWidth(1024);
- map->SetDisplayHeight(1024);
- return map;
-MgMap* TestRenderingService::CreateTestMap()
+static void TestCase_SymbologyPoints(CREFSTRING imageFormat, CREFSTRING extension)
- Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
- map->Create(mdfres, L"UnitTestSheboygan");
- return map;
-MgMap* TestRenderingService::CreateTestStylizationFunctionMap()
- Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/StylizationFuncs.MapDefinition");
- map->Create(mdfres, L"StylizationFuncs");
- map->SetViewScale(60000.0);
- return map;
-MgMap* TestRenderingService::CreateTestXYZMap()
- Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/BaseMap.MapDefinition");
- map->Create(mdfres, L"UnitTestSheboyganXYZ");
- Ptr<MgLayerCollection> layers = map->GetLayers();
- Ptr<MgLayerGroupCollection> groups = map->GetLayerGroups();
- Ptr<MgLayerBase> roads = layers->GetItem(L"RoadCenterLines");
- Ptr<MgLayerGroup> baseGroup = groups->GetItem(L"BaseLayers");
- roads->SetGroup(baseGroup);
- return map;
-MgMap* TestRenderingService::CreateTestTiledMap()
- map->Create(mdfres, L"UnitTestSheboyganTiled");
- return map;
-// creates a selection bounds in mapping space
-MgPolygon* TestRenderingService::CreateSelectionPolygon(MgMap* map, double width, double height)
- Ptr<MgPoint> centerPt = map->GetViewCenter();
- Ptr<MgCoordinate> center = centerPt->GetCoordinate();
- double xMin = center->GetX() - 0.5*width;
- double yMin = center->GetY() - 0.5*height;
- double xMax = center->GetX() + 0.5*width;
- double yMax = center->GetY() + 0.5*height;
- Ptr<MgCoordinateXY> c1 = new MgCoordinateXY(xMin, yMin);
- Ptr<MgCoordinateXY> c2 = new MgCoordinateXY(xMax, yMin);
- Ptr<MgCoordinateXY> c3 = new MgCoordinateXY(xMax, yMax);
- Ptr<MgCoordinateXY> c4 = new MgCoordinateXY(xMin, yMax);
- Ptr<MgCoordinateXY> c5 = new MgCoordinateXY(xMin, yMin);
- Ptr<MgCoordinateCollection> cc = new MgCoordinateCollection();
- cc->Add(c1);
- cc->Add(c2);
- cc->Add(c3);
- cc->Add(c4);
- cc->Add(c5);
- Ptr<MgLinearRing> outer = new MgLinearRing(cc);
- return new MgPolygon(outer, NULL);
-void TestRenderingService::TestCase_SymbologyPoints(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Capitals.MapDefinition");
Ptr<MgMap> map = new MgMap(m_siteConnection);
@@ -1452,22 +939,26 @@
map->SetViewScale(scale);
// call the API
- Ptr<MgByteReader> rdr = m_svcRendering->RenderMap(map, NULL, imageFormat);
+ Ptr<MgByteReader> rdr = m_svcRendering->RenderMap(map, nullptr, imageFormat);
rdr->ToFile(GetPath(L"../UnitTestFiles/SymbologyPoints", imageFormat, extension));
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_SymbologyPointsParam(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_SymbologyPointsParam(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/CapitalsParam.MapDefinition");
@@ -1489,22 +980,26 @@
// call the API
rdr->ToFile(GetPath(L"../UnitTestFiles/SymbologyPointsParam", imageFormat, extension));
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_SymbologyLines(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_SymbologyLines(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Lines.MapDefinition");
@@ -1526,22 +1021,26 @@
// call the API
rdr->ToFile(GetPath(L"../UnitTestFiles/SymbologyLines", imageFormat, extension));
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_SymbologyLinesCrossTick(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_SymbologyLinesCrossTick(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinesCrossTick.MapDefinition");
@@ -1563,22 +1062,26 @@
// call the API
rdr->ToFile(GetPath(L"../UnitTestFiles/SymbologyLinesCrossTick", imageFormat, extension));
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_Annotation1(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_Annotation1(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/UT_Annotation1.MapDefinition");
@@ -1600,22 +1103,26 @@
// call the API
rdr->ToFile(GetPath(L"../UnitTestFiles/Annotation1", imageFormat, extension));
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_Annotation2(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_Annotation2(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/UT_Annotation2.MapDefinition");
@@ -1637,22 +1144,26 @@
// call the API
rdr->ToFile(GetPath(L"../UnitTestFiles/Annotation2", imageFormat, extension));
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_Annotation3(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_Annotation3(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/UT_Annotation3.MapDefinition");
@@ -1674,22 +1185,26 @@
// call the API
rdr->ToFile(GetPath(L"../UnitTestFiles/Annotation3", imageFormat, extension));
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_SymbologyPolygons(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_SymbologyPolygons(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/UT_SymbologyPolygons.MapDefinition");
@@ -1703,21 +1218,23 @@
rdr2->ToFile(GetPath(L"../UnitTestFiles/SymbologyPolygons", imageFormat, extension));
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_RenderMetatile(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderMetatile(CREFSTRING imageFormat, CREFSTRING extension)
try
map->SetViewScale(12500.0);
Ptr<MgByteReader> tile4_6_baseline = m_svcRendering->RenderTile(map, L"BaseLayers", 4, 6, MgTileParameters::tileWidth, MgTileParameters::tileHeight, MgTileParameters::tileDPI, imageFormat);
@@ -1731,13 +1248,13 @@
tile5_7_baseline->ToFile(GetPath(L"../UnitTestFiles/RenderTile_5_7_Baseline", imageFormat, extension));
MgRenderingService* renderSvc = dynamic_cast<MgRenderingService*>(m_svcRendering.p);
- CPPUNIT_ASSERT(NULL != renderSvc);
+ REQUIRE(nullptr != renderSvc);
// Render a 2x2 metatile which should cover the same tiles as the baseline test.
INT32 metaTileFactor = 2;
Ptr<MgMetatile> metaTile = renderSvc->RenderMetatile(map, L"BaseLayers", 4, 6, MgTileParameters::tileWidth, MgTileParameters::tileHeight, MgTileParameters::tileDPI, imageFormat, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, metaTileFactor);
//metaTile->ToFile(L"../UnitTestFiles/RenderTile_Metatile at 4_6.png");
- //CPPUNIT_ASSERT(metaTile->IsRewindable());
+ //REQUIRE(metaTile->IsRewindable());
//metaTile->Rewind();
Ptr<MgByteReader> tile4_6 = renderSvc->RenderTileFromMetaTile(map, metaTile, 0, 0);
Ptr<MgByteReader> tile4_7 = renderSvc->RenderTileFromMetaTile(map, metaTile, 0, 1);
@@ -1752,16 +1269,18 @@
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_RenderXYZMetatile(CREFSTRING imageFormat, CREFSTRING extension, INT32 retinaScale)
+static void TestCase_RenderXYZMetatile(CREFSTRING imageFormat, CREFSTRING extension, INT32 retinaScale)
try
STRING retinaSuffix = L"";
if (retinaScale > 1)
@@ -1784,13 +1303,13 @@
tile_16799_23892_baseline->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16799_23892_16_Baseline" + retinaSuffix, imageFormat, extension));
Ptr<MgMetatile> metaTile = renderSvc->RenderMetatileXYZ(map, L"BaseLayers", 16798, 23891, 16, MgTileParameters::tileDPI, imageFormat, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, metaTileFactor, retinaScale);
//metaTile->ToFile(L"../UnitTestFiles/RenderTileXYZ_Metatile at 16798_23891_16.png");
Ptr<MgByteReader> tile_16798_23891 = renderSvc->RenderTileFromMetaTile(map, metaTile, 0, 0);
Ptr<MgByteReader> tile_16799_23891 = renderSvc->RenderTileFromMetaTile(map, metaTile, 1, 0);
@@ -1804,16 +1323,18 @@
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_RenderTile(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderTile(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgByteReader> tile4_6 = m_svcRendering->RenderTile(map, L"BaseLayers", 4, 6, 300, 300, 96, imageFormat);
@@ -1838,16 +1359,18 @@
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_RenderTileXYZ(CREFSTRING imageFormat, CREFSTRING extension)
+static void TestCase_RenderTileXYZ(CREFSTRING imageFormat, CREFSTRING extension)
try
Ptr<MgByteReader> tileTL = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 2099, 2985, 13, 96, imageFormat);
Ptr<MgByteReader> tileTR = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 2100, 2985, 13, 96, imageFormat);
@@ -1861,16 +1384,18 @@
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_RenderTileUTFGrid()
+TEST_CASE("RenderTileUTFGrid", "[RenderingService]")
try
Ptr<MgMap> map = CreateTestXYZMap();
//For ease of visual verfication, render the XYZ image tiles as baseline
@@ -1897,16 +1422,18 @@
SAFE_RELEASE(e);
-void TestRenderingService::TestCase_RenderTileMVT()
+TEST_CASE("RenderTileMVT", "[RenderingService]")
try
@@ -1926,15 +1453,15 @@
Ptr<MgByteReader> mvtBL = m_svcRendering->RenderTileMVT(map, L"BaseLayers", 16797, 23894, 16, 96);
Ptr<MgByteReader> mvtBR = m_svcRendering->RenderTileMVT(map, L"BaseLayers", 16798, 23894, 16, 96);
- CPPUNIT_ASSERT(MgMimeType::Mvt == mvtTL->GetMimeType());
- CPPUNIT_ASSERT(MgMimeType::Mvt == mvtTR->GetMimeType());
- CPPUNIT_ASSERT(MgMimeType::Mvt == mvtBL->GetMimeType());
- CPPUNIT_ASSERT(MgMimeType::Mvt == mvtBR->GetMimeType());
+ REQUIRE(MgMimeType::Mvt == mvtTL->GetMimeType());
+ REQUIRE(MgMimeType::Mvt == mvtTR->GetMimeType());
+ REQUIRE(MgMimeType::Mvt == mvtBL->GetMimeType());
+ REQUIRE(MgMimeType::Mvt == mvtBR->GetMimeType());
- CPPUNIT_ASSERT(mvtTL->GetLength() > 0);
- CPPUNIT_ASSERT(mvtTR->GetLength() > 0);
- CPPUNIT_ASSERT(mvtBL->GetLength() > 0);
- CPPUNIT_ASSERT(mvtBR->GetLength() > 0);
+ REQUIRE(mvtTL->GetLength() > 0);
+ REQUIRE(mvtTR->GetLength() > 0);
+ REQUIRE(mvtBL->GetLength() > 0);
+ REQUIRE(mvtBR->GetLength() > 0);
mvtTL->ToFile(L"../UnitTestFiles/RenderTileMVT_TL.mvt");
mvtTR->ToFile(L"../UnitTestFiles/RenderTileMVT_TR.mvt");
@@ -1956,31 +1483,20 @@
Ptr<MgByte> bytesBL = sinkBL->ToBuffer();
Ptr<MgByte> bytesBR = sinkBR->ToBuffer();
- CPPUNIT_ASSERT(MVTRenderer::IsValidTile(bytesTL->Bytes(), bytesTL->GetLength()));
- CPPUNIT_ASSERT(MVTRenderer::IsValidTile(bytesTR->Bytes(), bytesTR->GetLength()));
- CPPUNIT_ASSERT(MVTRenderer::IsValidTile(bytesBL->Bytes(), bytesBL->GetLength()));
- CPPUNIT_ASSERT(MVTRenderer::IsValidTile(bytesBR->Bytes(), bytesBR->GetLength()));
+ REQUIRE(MVTRenderer::IsValidTile(bytesTL->Bytes(), bytesTL->GetLength()));
+ REQUIRE(MVTRenderer::IsValidTile(bytesTR->Bytes(), bytesTR->GetLength()));
+ REQUIRE(MVTRenderer::IsValidTile(bytesBL->Bytes(), bytesBL->GetLength()));
+ REQUIRE(MVTRenderer::IsValidTile(bytesBR->Bytes(), bytesBR->GetLength()));
SAFE_RELEASE(e);
-STRING TestRenderingService::GetPath(CREFSTRING basePath, CREFSTRING imageFormat, CREFSTRING extension)
- STRING ret;
- ret += basePath;
- ret += L"_";
- ret += imageFormat;
- ret += L".";
- ret += extension;
- return ret;
-//void TestRenderingService::TestCase_RendererPerformance()
+//TEST_CASE("RendererPerformance", "[Performance]")
// LineBuffer lb(8);
@@ -1989,8 +1505,8 @@
// lb.LineTo(50, 201.2);
// lb.LineTo(207, 203);
// lb.Close();
// lb.MoveTo(1,1);
// lb.LineTo(1023, 1);
@@ -1997,45 +1513,154 @@
// lb.LineTo(1023, 1023);
// lb.LineTo(1, 1023);
// lb.Close();
// RS_LineStroke stroke(RS_Color(0), 0, L"Solid", RS_Units_Device);
// RS_FillStyle fillstyle(stroke, RS_Color(255,0,0,255), RS_Color(0), L"Solid");
// AGGRenderer* agg = new AGGRenderer(1024, 1024, RS_Color(0xffffffff), false, false, 0.0);
-// agg->StartMap(NULL, RS_Bounds(0,0,0,1024,1024,0), 1.0, 1.0, 1.0, NULL);
+// agg->StartMap(nullptr, RS_Bounds(0,0,0,1024,1024,0), 1.0, 1.0, 1.0, nullptr);
// for (int i=0; i<10000; i++)
// agg->ProcessPolygon(&lb, fillstyle);
// clock_t t1 = clock();
// printf ("diff %d\n", t1 - t0);
// agg->EndMap();
// agg->Save(L"c:\\agg.png", L"PNG");
-// GDRenderer* gd = new GDRenderer(1024, 1024, RS_Color(0xffffffff), false);
-// gd->StartMap(NULL, RS_Bounds(0,0,0,1024,1024,0), 1.0, 1.0, 1.0, NULL);
-// t0 = clock();
-// for (int i=0; i<10000; i++)
-// gd->ProcessPolygon(&lb, fillstyle);
-// t1 = clock();
-// printf ("diff %d\n", t1 - t0);
-// gd->EndMap();
-// gd->Save(L"c:\\gd.png", L"PNG");
+//PNG output tests
+TEST_CASE("RenderDynamicOverlayPNG", "[RenderingService]") { TestCase_RenderDynamicOverlay(L"PNG", L"png"); }
+TEST_CASE("RenderDynamicOverlayTiledMapPNG", "[RenderingService]") { TestCase_RenderDynamicOverlayTiledMap(L"PNG", L"png"); }
+TEST_CASE("RenderMapPNG", "[RenderingService]") { TestCase_RenderMap(L"PNG", L"png"); }
+TEST_CASE("RenderMapWithSelectionPNG", "[RenderingService]") { TestCase_RenderMapWithSelection(L"PNG", L"png"); }
+TEST_CASE("RenderMapWithWatermarkPNG", "[RenderingService]") { TestCase_RenderMapWithWatermark(L"PNG", L"png"); }
+TEST_CASE("RenderLegendPNG", "[RenderingService]") { TestCase_RenderLegend(L"PNG", L"png"); }
+TEST_CASE("RenderLegendEmptyGroupsPNG", "[RenderingService]") { TestCase_RenderLegendEmptyGroups(L"PNG", L"png"); }
+TEST_CASE("SymbologyPointsPNG", "[RenderingService]") { TestCase_SymbologyPoints(L"PNG", L"png"); }
+TEST_CASE("SymbologyPointsParamPNG", "[RenderingService]") { TestCase_SymbologyPointsParam(L"PNG", L"png"); }
+TEST_CASE("SymbologyLinesPNG", "[RenderingService]") { TestCase_SymbologyLines(L"PNG", L"png"); }
+TEST_CASE("SymbologyLinesCrossTickPNG", "[RenderingService]") { TestCase_SymbologyLinesCrossTick(L"PNG", L"png"); }
+TEST_CASE("SymbologyPolygonsPNG", "[RenderingService]") { TestCase_SymbologyPolygons(L"PNG", L"png"); }
+TEST_CASE("Annotation1PNG", "[RenderingService]") { TestCase_Annotation1(L"PNG", L"png"); }
+TEST_CASE("Annotation2PNG", "[RenderingService]") { TestCase_Annotation2(L"PNG", L"png"); }
+TEST_CASE("Annotation3PNG", "[RenderingService]") { TestCase_Annotation3(L"PNG", L"png"); }
+TEST_CASE("RenderLegendMultiFTSPNG", "[RenderingService]") { TestCase_RenderLegendMultiFTS(L"PNG", L"png"); }
+TEST_CASE("RenderLegendMultiCTSPNG", "[RenderingService]") { TestCase_RenderLegendMultiCTS(L"PNG", L"png"); }
+TEST_CASE("RenderLegendMultiFTSWithThemePNG", "[RenderingService]") { TestCase_RenderLegendMultiFTSWithTheme(L"PNG", L"png"); }
+TEST_CASE("RenderLegendMultiCTSWithThemePNG", "[RenderingService]") { TestCase_RenderLegendMultiCTSWithTheme(L"PNG", L"png"); }
+TEST_CASE("RenderLegendMultiFTSSingleCTSPNG", "[RenderingService]") { TestCase_RenderLegendMultiFTSSingleCTS(L"PNG", L"png"); }
+TEST_CASE("RenderLegendSingleFTSMultiCTSPNG", "[RenderingService]") { TestCase_RenderLegendSingleFTSMultiCTS(L"PNG", L"png"); }
+TEST_CASE("StylizationFunctionsPNG", "[RenderingService]") { TestCase_StylizationFunctions(L"PNG", L"png"); }
+TEST_CASE("LayerWatermarkPNG", "[RenderingService]") { TestCase_LayerWatermark(L"PNG", L"png"); }
+TEST_CASE("RenderTilePNG", "[RenderingService]") { TestCase_RenderTile(L"PNG", L"png"); }
+TEST_CASE("RenderTileXYZ_PNG", "[RenderingService]") { TestCase_RenderTileXYZ(L"PNG", L"png"); }
+//PNG8 output tests
+TEST_CASE("RenderDynamicOverlayPNG8", "[RenderingService]") { TestCase_RenderDynamicOverlay(L"PNG8", L"png"); }
+TEST_CASE("RenderDynamicOverlayTiledMapPNG8", "[RenderingService]") { TestCase_RenderDynamicOverlayTiledMap(L"PNG8", L"png"); }
+TEST_CASE("RenderMapPNG8", "[RenderingService]") { TestCase_RenderMap(L"PNG8", L"png"); }
+TEST_CASE("RenderMapWithSelectionPNG8", "[RenderingService]") { TestCase_RenderMapWithSelection(L"PNG8", L"png"); }
+TEST_CASE("RenderMapWithWatermarkPNG8", "[RenderingService]") { TestCase_RenderMapWithWatermark(L"PNG8", L"png"); }
+TEST_CASE("RenderLegendPNG8", "[RenderingService]") { TestCase_RenderLegend(L"PNG8", L"png"); }
+TEST_CASE("RenderLegendEmptyGroupsPNG8", "[RenderingService]") { TestCase_RenderLegendEmptyGroups(L"PNG8", L"png"); }
+TEST_CASE("SymbologyPointsPNG8", "[RenderingService]") { TestCase_SymbologyPoints(L"PNG8", L"png"); }
+TEST_CASE("SymbologyPointsParamPNG8", "[RenderingService]") { TestCase_SymbologyPointsParam(L"PNG8", L"png"); }
+TEST_CASE("SymbologyLinesPNG8", "[RenderingService]") { TestCase_SymbologyLines(L"PNG8", L"png"); }
+TEST_CASE("SymbologyLinesCrossTickPNG8", "[RenderingService]") { TestCase_SymbologyLinesCrossTick(L"PNG8", L"png"); }
+TEST_CASE("SymbologyPolygonsPNG8", "[RenderingService]") { TestCase_SymbologyPolygons(L"PNG8", L"png"); }
+TEST_CASE("Annotation1PNG8", "[RenderingService]") { TestCase_Annotation1(L"PNG8", L"png"); }
+TEST_CASE("Annotation2PNG8", "[RenderingService]") { TestCase_Annotation2(L"PNG8", L"png"); }
+TEST_CASE("Annotation3PNG8", "[RenderingService]") { TestCase_Annotation3(L"PNG8", L"png"); }
+TEST_CASE("RenderLegendMultiFTSPNG8", "[RenderingService]") { TestCase_RenderLegendMultiFTS(L"PNG8", L"png"); }
+TEST_CASE("RenderLegendMultiCTSPNG8", "[RenderingService]") { TestCase_RenderLegendMultiCTS(L"PNG8", L"png"); }
+TEST_CASE("RenderLegendMultiFTSWithThemePNG8", "[RenderingService]") { TestCase_RenderLegendMultiFTSWithTheme(L"PNG8", L"png"); }
+TEST_CASE("RenderLegendMultiCTSWithThemePNG8", "[RenderingService]") { TestCase_RenderLegendMultiCTSWithTheme(L"PNG8", L"png"); }
+TEST_CASE("RenderLegendMultiFTSSingleCTSPNG8", "[RenderingService]") { TestCase_RenderLegendMultiFTSSingleCTS(L"PNG8", L"png"); }
+TEST_CASE("RenderLegendSingleFTSMultiCTSPNG8", "[RenderingService]") { TestCase_RenderLegendSingleFTSMultiCTS(L"PNG8", L"png"); }
+TEST_CASE("StylizationFunctionsPNG8", "[RenderingService]") { TestCase_StylizationFunctions(L"PNG8", L"png"); }
+TEST_CASE("LayerWatermarkPNG8", "[RenderingService]") { TestCase_LayerWatermark(L"PNG8", L"png"); }
+TEST_CASE("RenderTilePNG8", "[RenderingService]") { TestCase_RenderTile(L"PNG8", L"png"); }
+TEST_CASE("RenderTileXYZ_PNG8", "[RenderingService]") { TestCase_RenderTileXYZ(L"PNG8", L"png"); }
+//GIF output tests
+TEST_CASE("RenderDynamicOverlayGIF", "[RenderingService]") { TestCase_RenderDynamicOverlay(L"GIF", L"gif"); }
+TEST_CASE("RenderDynamicOverlayTiledMapGIF", "[RenderingService]") { TestCase_RenderDynamicOverlayTiledMap(L"GIF", L"gif"); }
+TEST_CASE("RenderMapGIF", "[RenderingService]") { TestCase_RenderMap(L"GIF", L"gif"); }
+TEST_CASE("RenderMapWithSelectionGIF", "[RenderingService]") { TestCase_RenderMapWithSelection(L"GIF", L"gif"); }
+TEST_CASE("RenderMapWithWatermarkGIF", "[RenderingService]") { TestCase_RenderMapWithWatermark(L"GIF", L"gif"); }
+TEST_CASE("RenderLegendGIF", "[RenderingService]") { TestCase_RenderLegend(L"GIF", L"gif"); }
+TEST_CASE("RenderLegendEmptyGroupsGIF", "[RenderingService]") { TestCase_RenderLegendEmptyGroups(L"GIF", L"gif"); }
+TEST_CASE("SymbologyPointsGIF", "[RenderingService]") { TestCase_SymbologyPoints(L"GIF", L"gif"); }
+TEST_CASE("SymbologyPointsParamGIF", "[RenderingService]") { TestCase_SymbologyPointsParam(L"GIF", L"gif"); }
+TEST_CASE("SymbologyLinesGIF", "[RenderingService]") { TestCase_SymbologyLines(L"GIF", L"gif"); }
+TEST_CASE("SymbologyLinesCrossTickGIF", "[RenderingService]") { TestCase_SymbologyLinesCrossTick(L"GIF", L"gif"); }
+TEST_CASE("SymbologyPolygonsGIF", "[RenderingService]") { TestCase_SymbologyPolygons(L"GIF", L"gif"); }
+TEST_CASE("Annotation1GIF", "[RenderingService]") { TestCase_Annotation1(L"GIF", L"gif"); }
+TEST_CASE("Annotation2GIF", "[RenderingService]") { TestCase_Annotation2(L"GIF", L"gif"); }
+TEST_CASE("Annotation3GIF", "[RenderingService]") { TestCase_Annotation3(L"GIF", L"gif"); }
+TEST_CASE("RenderLegendMultiFTSGIF", "[RenderingService]") { TestCase_RenderLegendMultiFTS(L"GIF", L"gif"); }
+TEST_CASE("RenderLegendMultiCTSGIF", "[RenderingService]") { TestCase_RenderLegendMultiCTS(L"GIF", L"gif"); }
+TEST_CASE("RenderLegendMultiFTSWithThemeGIF", "[RenderingService]") { TestCase_RenderLegendMultiFTSWithTheme(L"GIF", L"gif"); }
+TEST_CASE("RenderLegendMultiCTSWithThemeGIF", "[RenderingService]") { TestCase_RenderLegendMultiCTSWithTheme(L"GIF", L"gif"); }
+TEST_CASE("RenderLegendMultiFTSSingleCTSGIF", "[RenderingService]") { TestCase_RenderLegendMultiFTSSingleCTS(L"GIF", L"gif"); }
+TEST_CASE("RenderLegendSingleFTSMultiCTSGIF", "[RenderingService]") { TestCase_RenderLegendSingleFTSMultiCTS(L"GIF", L"gif"); }
+TEST_CASE("StylizationFunctionsGIF", "[RenderingService]") { TestCase_StylizationFunctions(L"GIF", L"gif"); }
+TEST_CASE("LayerWatermarkGIF", "[RenderingService]") { TestCase_LayerWatermark(L"GIF", L"gif"); }
+TEST_CASE("RenderTileGIF", "[RenderingService]") { TestCase_RenderTile(L"GIF", L"gif"); }
+TEST_CASE("RenderTileXYZ_GIF", "[RenderingService]") { TestCase_RenderTileXYZ(L"GIF", L"gif"); }
+//JPG output tests
+TEST_CASE("RenderDynamicOverlayJPG", "[RenderingService]") { TestCase_RenderDynamicOverlay(L"JPG", L"jpg"); }
+TEST_CASE("RenderDynamicOverlayTiledMapJPG", "[RenderingService]") { TestCase_RenderDynamicOverlayTiledMap(L"JPG", L"jpg"); }
+TEST_CASE("RenderMapJPG", "[RenderingService]") { TestCase_RenderMap(L"JPG", L"jpg"); }
+TEST_CASE("RenderMapWithSelectionJPG", "[RenderingService]") { TestCase_RenderMapWithSelection(L"JPG", L"jpg"); }
+TEST_CASE("RenderMapWithWatermarkJPG", "[RenderingService]") { TestCase_RenderMapWithWatermark(L"JPG", L"jpg"); }
+TEST_CASE("RenderLegendJPG", "[RenderingService]") { TestCase_RenderLegend(L"JPG", L"jpg"); }
+TEST_CASE("RenderLegendEmptyGroupsJPG", "[RenderingService]") { TestCase_RenderLegendEmptyGroups(L"JPG", L"jpg"); }
+TEST_CASE("SymbologyPointsJPG", "[RenderingService]") { TestCase_SymbologyPoints(L"JPG", L"jpg"); }
+TEST_CASE("SymbologyPointsParamJPG", "[RenderingService]") { TestCase_SymbologyPointsParam(L"JPG", L"jpg"); }
+TEST_CASE("SymbologyLinesJPG", "[RenderingService]") { TestCase_SymbologyLines(L"JPG", L"jpg"); }
+TEST_CASE("SymbologyLinesCrossTickJPG", "[RenderingService]") { TestCase_SymbologyLinesCrossTick(L"JPG", L"jpg"); }
+TEST_CASE("SymbologyPolygonsJPG", "[RenderingService]") { TestCase_SymbologyPolygons(L"JPG", L"jpg"); }
+TEST_CASE("Annotation1JPG", "[RenderingService]") { TestCase_Annotation1(L"JPG", L"jpg"); }
+TEST_CASE("Annotation2JPG", "[RenderingService]") { TestCase_Annotation2(L"JPG", L"jpg"); }
+TEST_CASE("Annotation3JPG", "[RenderingService]") { TestCase_Annotation3(L"JPG", L"jpg"); }
+TEST_CASE("RenderLegendMultiFTSJPG", "[RenderingService]") { TestCase_RenderLegendMultiFTS(L"JPG", L"jpg"); }
+TEST_CASE("RenderLegendMultiCTSJPG", "[RenderingService]") { TestCase_RenderLegendMultiCTS(L"JPG", L"jpg"); }
+TEST_CASE("RenderLegendMultiFTSWithThemeJPG", "[RenderingService]") { TestCase_RenderLegendMultiFTSWithTheme(L"JPG", L"jpg"); }
+TEST_CASE("RenderLegendMultiCTSWithThemeJPG", "[RenderingService]") { TestCase_RenderLegendMultiCTSWithTheme(L"JPG", L"jpg"); }
+TEST_CASE("RenderLegendMultiFTSSingleCTSJPG", "[RenderingService]") { TestCase_RenderLegendMultiFTSSingleCTS(L"JPG", L"jpg"); }
+TEST_CASE("RenderLegendSingleFTSMultiCTSJPG", "[RenderingService]") { TestCase_RenderLegendSingleFTSMultiCTS(L"JPG", L"jpg"); }
+TEST_CASE("StylizationFunctionsJPG", "[RenderingService]") { TestCase_StylizationFunctions(L"JPG", L"jpg"); }
+TEST_CASE("LayerWatermarkJPG", "[RenderingService]") { TestCase_LayerWatermark(L"JPG", L"jpg"); }
+TEST_CASE("RenderTileJPG", "[RenderingService]") { TestCase_RenderTile(L"JPG", L"jpg"); }
+TEST_CASE("RenderTileXYZ_JPG", "[RenderingService]") { TestCase_RenderTileXYZ(L"JPG", L"jpg"); }
+//TEST_CASE("RendererPerformance();
+TEST_CASE("RenderMetatilePNG", "[RenderingService]") { TestCase_RenderMetatile(L"PNG", L"png"); }
+TEST_CASE("RenderMetatilePNG8", "[RenderingService]") { TestCase_RenderMetatile(L"PNG8", L"png"); }
+TEST_CASE("RenderMetatileJPG", "[RenderingService]") { TestCase_RenderMetatile(L"JPG", L"jpg"); }
+TEST_CASE("RenderMetatileGIF", "[RenderingService]") { TestCase_RenderMetatile(L"GIF", L"gif"); }
+TEST_CASE("RenderXYZMetatilePNG", "[RenderingService]") { TestCase_RenderXYZMetatile(L"PNG", L"png", 1); }
+TEST_CASE("RenderXYZMetatilePNG8", "[RenderingService]") { TestCase_RenderXYZMetatile(L"PNG8", L"png", 1); }
+TEST_CASE("RenderXYZMetatileJPG", "[RenderingService]") { TestCase_RenderXYZMetatile(L"JPG", L"jpg", 1); }
+TEST_CASE("RenderXYZMetatileGIF", "[RenderingService]") { TestCase_RenderXYZMetatile(L"GIF", L"gif", 1); }
+TEST_CASE("RenderXYZMetatilePNG_2x", "[RenderingService]") { TestCase_RenderXYZMetatile(L"PNG", L"png", 2); }
+TEST_CASE("RenderXYZMetatilePNG8_2x", "[RenderingService]") { TestCase_RenderXYZMetatile(L"PNG8", L"png", 2); }
+TEST_CASE("RenderXYZMetatileJPG_2x", "[RenderingService]") { TestCase_RenderXYZMetatile(L"JPG", L"jpg", 2); }
+TEST_CASE("RenderXYZMetatileGIF_2x", "[RenderingService]") { TestCase_RenderXYZMetatile(L"GIF", L"gif", 2); }
+TEST_CASE("RenderXYZMetatilePNG_4x", "[RenderingService]") { TestCase_RenderXYZMetatile(L"PNG", L"png", 4); }
+TEST_CASE("RenderXYZMetatilePNG8_4x", "[RenderingService]") { TestCase_RenderXYZMetatile(L"PNG8", L"png", 4); }
+TEST_CASE("RenderXYZMetatileJPG_4x", "[RenderingService]") { TestCase_RenderXYZMetatile(L"JPG", L"jpg", 4); }
+TEST_CASE("RenderXYZMetatileGIF_4x", "[RenderingService]") { TestCase_RenderXYZMetatile(L"GIF", L"gif", 4); }
\ No newline at end of file
Deleted: sandbox/jng/catch2/Server/src/UnitTesting/TestRenderingService.h
--- sandbox/jng/catch2/Server/src/UnitTesting/TestRenderingService.h 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestRenderingService.h 2020-07-13 13:04:59 UTC (rev 9659)
@@ -1,364 +0,0 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#ifndef _TESTRENDERINGSERVICE_H
-#define _TESTRENDERINGSERVICE_H
-#include <cppunit/extensions/HelperMacros.h>
-class TestRenderingService : public CppUnit::TestFixture
- CPPUNIT_TEST_SUITE(TestRenderingService);
- CPPUNIT_TEST(TestStart); // This must be the very first unit test
- CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG);
- CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG8);
- CPPUNIT_TEST(TestCase_RenderXYZMetatileJPG);
- CPPUNIT_TEST(TestCase_RenderXYZMetatileGIF);
- CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG_2x);
- CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG8_2x);
- CPPUNIT_TEST(TestCase_RenderXYZMetatileJPG_2x);
- CPPUNIT_TEST(TestCase_RenderXYZMetatileGIF_2x);
- CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG_4x);
- CPPUNIT_TEST(TestCase_RenderXYZMetatilePNG8_4x);
- CPPUNIT_TEST(TestCase_RenderXYZMetatileJPG_4x);
- CPPUNIT_TEST(TestCase_RenderXYZMetatileGIF_4x);
- CPPUNIT_TEST(TestCase_RenderMetatilePNG);
- CPPUNIT_TEST(TestCase_RenderMetatilePNG8);
- CPPUNIT_TEST(TestCase_RenderMetatileJPG);
- CPPUNIT_TEST(TestCase_RenderMetatileGIF);
- CPPUNIT_TEST(TestCase_StylizationFunctionsPNG);
- CPPUNIT_TEST(TestCase_SymbologyPointsPNG);
- CPPUNIT_TEST(TestCase_SymbologyPointsParamPNG);
- CPPUNIT_TEST(TestCase_SymbologyLinesPNG);
- CPPUNIT_TEST(TestCase_SymbologyLinesCrossTickPNG);
- CPPUNIT_TEST(TestCase_SymbologyPolygonsPNG);
- CPPUNIT_TEST(TestCase_Annotation1PNG);
- CPPUNIT_TEST(TestCase_Annotation2PNG);
- CPPUNIT_TEST(TestCase_Annotation3PNG);
- CPPUNIT_TEST(TestCase_RenderDynamicOverlayPNG);
- CPPUNIT_TEST(TestCase_RenderDynamicOverlayTiledMapPNG);
- CPPUNIT_TEST(TestCase_RenderMapPNG);
- CPPUNIT_TEST(TestCase_RenderMapWithSelectionPNG);
- CPPUNIT_TEST(TestCase_RenderMapWithWatermarkPNG);
- CPPUNIT_TEST(TestCase_RenderLegendPNG);
- CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsPNG);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSPNG);
- CPPUNIT_TEST(TestCase_RenderLegendMultiCTSPNG);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemePNG);
- CPPUNIT_TEST(TestCase_RenderLegendMultiCTSWithThemePNG);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSPNG);
- CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSPNG);
- CPPUNIT_TEST(TestCase_LayerWatermarkPNG);
- CPPUNIT_TEST(TestCase_RenderTilePNG);
- CPPUNIT_TEST(TestCase_RenderTileXYZ_PNG);
- CPPUNIT_TEST(TestCase_RenderTileUTFGrid);
- CPPUNIT_TEST(TestCase_RenderTileMVT);
- CPPUNIT_TEST(TestCase_StylizationFunctionsPNG8);
- CPPUNIT_TEST(TestCase_SymbologyPointsPNG8);
- CPPUNIT_TEST(TestCase_SymbologyPointsParamPNG8);
- CPPUNIT_TEST(TestCase_SymbologyLinesPNG8);
- CPPUNIT_TEST(TestCase_SymbologyLinesCrossTickPNG8);
- CPPUNIT_TEST(TestCase_SymbologyPolygonsPNG8);
- CPPUNIT_TEST(TestCase_Annotation1PNG8);
- CPPUNIT_TEST(TestCase_Annotation2PNG8);
- CPPUNIT_TEST(TestCase_Annotation3PNG8);
- CPPUNIT_TEST(TestCase_RenderDynamicOverlayPNG8);
- CPPUNIT_TEST(TestCase_RenderDynamicOverlayTiledMapPNG8);
- CPPUNIT_TEST(TestCase_RenderMapPNG8);
- CPPUNIT_TEST(TestCase_RenderMapWithSelectionPNG8);
- CPPUNIT_TEST(TestCase_RenderMapWithWatermarkPNG8);
- CPPUNIT_TEST(TestCase_RenderLegendPNG8);
- CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsPNG8);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSPNG8);
- CPPUNIT_TEST(TestCase_RenderLegendMultiCTSPNG8);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemePNG8);
- CPPUNIT_TEST(TestCase_RenderLegendMultiCTSWithThemePNG8);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSPNG8);
- CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSPNG8);
- CPPUNIT_TEST(TestCase_LayerWatermarkPNG8);
- CPPUNIT_TEST(TestCase_RenderTilePNG8);
- CPPUNIT_TEST(TestCase_RenderTileXYZ_PNG8);
- CPPUNIT_TEST(TestCase_StylizationFunctionsGIF);
- CPPUNIT_TEST(TestCase_SymbologyPointsGIF);
- CPPUNIT_TEST(TestCase_SymbologyPointsParamGIF);
- CPPUNIT_TEST(TestCase_SymbologyLinesGIF);
- CPPUNIT_TEST(TestCase_SymbologyLinesCrossTickGIF);
- CPPUNIT_TEST(TestCase_SymbologyPolygonsGIF);
- CPPUNIT_TEST(TestCase_Annotation1GIF);
- CPPUNIT_TEST(TestCase_Annotation2GIF);
- CPPUNIT_TEST(TestCase_Annotation3GIF);
- CPPUNIT_TEST(TestCase_RenderDynamicOverlayGIF);
- CPPUNIT_TEST(TestCase_RenderDynamicOverlayTiledMapGIF);
- CPPUNIT_TEST(TestCase_RenderMapGIF);
- CPPUNIT_TEST(TestCase_RenderMapWithSelectionGIF);
- CPPUNIT_TEST(TestCase_RenderMapWithWatermarkGIF);
- CPPUNIT_TEST(TestCase_RenderLegendGIF);
- CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsGIF);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSGIF);
- CPPUNIT_TEST(TestCase_RenderLegendMultiCTSGIF);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemeGIF);
- CPPUNIT_TEST(TestCase_RenderLegendMultiCTSWithThemeGIF);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSGIF);
- CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSGIF);
- CPPUNIT_TEST(TestCase_LayerWatermarkGIF);
- CPPUNIT_TEST(TestCase_RenderTileGIF);
- CPPUNIT_TEST(TestCase_RenderTileXYZ_GIF);
- CPPUNIT_TEST(TestCase_StylizationFunctionsJPG);
- CPPUNIT_TEST(TestCase_SymbologyPointsJPG);
- CPPUNIT_TEST(TestCase_SymbologyPointsParamJPG);
- CPPUNIT_TEST(TestCase_SymbologyLinesJPG);
- CPPUNIT_TEST(TestCase_SymbologyLinesCrossTickJPG);
- CPPUNIT_TEST(TestCase_SymbologyPolygonsJPG);
- CPPUNIT_TEST(TestCase_Annotation1JPG);
- CPPUNIT_TEST(TestCase_Annotation2JPG);
- CPPUNIT_TEST(TestCase_Annotation3JPG);
- CPPUNIT_TEST(TestCase_RenderDynamicOverlayJPG);
- CPPUNIT_TEST(TestCase_RenderDynamicOverlayTiledMapJPG);
- CPPUNIT_TEST(TestCase_RenderMapJPG);
- CPPUNIT_TEST(TestCase_RenderMapWithSelectionJPG);
- CPPUNIT_TEST(TestCase_RenderMapWithWatermarkJPG);
- CPPUNIT_TEST(TestCase_RenderLegendJPG);
- CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsJPG);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSJPG);
- CPPUNIT_TEST(TestCase_RenderLegendMultiCTSJPG);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemeJPG);
- CPPUNIT_TEST(TestCase_RenderLegendMultiCTSWithThemeJPG);
- CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSJPG);
- CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSJPG);
- CPPUNIT_TEST(TestCase_LayerWatermarkJPG);
- CPPUNIT_TEST(TestCase_RenderTileJPG);
- CPPUNIT_TEST(TestCase_RenderTileXYZ_JPG);
- CPPUNIT_TEST(TestCase_QueryFeatures);
- //CPPUNIT_TEST(TestCase_RendererPerformance);
- CPPUNIT_TEST(TestEnd); // This must be the very last unit test
- CPPUNIT_TEST_SUITE_END();
-public:
- TestRenderingService();
- ~TestRenderingService();
- void setUp();
- void tearDown();
- void TestStart();
- void TestEnd();
- void TestCase_QueryFeatures();
- void TestCase_RenderTileUTFGrid();
- void TestCase_RenderTileMVT();
- void TestCase_RenderMetatile(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderXYZMetatile(CREFSTRING imageFormat, CREFSTRING extension, INT32 retinaScale);
- void TestCase_RenderTile(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderTileXYZ(CREFSTRING imageFormat, CREFSTRING extension);
- //Parameterized versions that all format-specific tests call into
- void TestCase_RenderDynamicOverlay(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderDynamicOverlayTiledMap(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderMap(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderMapWithSelection(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderMapWithWatermark(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderLegend(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderLegendEmptyGroups(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderLegendMultiFTS(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderLegendMultiCTS(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderLegendMultiFTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderLegendMultiCTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderLegendMultiFTSSingleCTS(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_RenderLegendSingleFTSMultiCTS(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_LayerWatermark(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_SymbologyPoints(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_SymbologyPointsParam(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_SymbologyLines(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_SymbologyLinesCrossTick(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_SymbologyPolygons(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_Annotation1(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_Annotation2(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_Annotation3(CREFSTRING imageFormat, CREFSTRING extension);
- void TestCase_StylizationFunctions(CREFSTRING imageFormat, CREFSTRING extension);
- //PNG output tests
- void TestCase_RenderDynamicOverlayPNG() { TestCase_RenderDynamicOverlay(L"PNG", L"png"); }
- void TestCase_RenderDynamicOverlayTiledMapPNG() { TestCase_RenderDynamicOverlayTiledMap(L"PNG", L"png"); }
- void TestCase_RenderMapPNG() { TestCase_RenderMap(L"PNG", L"png"); }
- void TestCase_RenderMapWithSelectionPNG() { TestCase_RenderMapWithSelection(L"PNG", L"png"); }
- void TestCase_RenderMapWithWatermarkPNG() { TestCase_RenderMapWithWatermark(L"PNG", L"png"); }
- void TestCase_RenderLegendPNG() { TestCase_RenderLegend(L"PNG", L"png"); }
- void TestCase_RenderLegendEmptyGroupsPNG() { TestCase_RenderLegendEmptyGroups(L"PNG", L"png"); }
- void TestCase_SymbologyPointsPNG() { TestCase_SymbologyPoints(L"PNG", L"png"); }
- void TestCase_SymbologyPointsParamPNG() { TestCase_SymbologyPointsParam(L"PNG", L"png"); }
- void TestCase_SymbologyLinesPNG() { TestCase_SymbologyLines(L"PNG", L"png"); }
- void TestCase_SymbologyLinesCrossTickPNG() { TestCase_SymbologyLinesCrossTick(L"PNG", L"png"); }
- void TestCase_SymbologyPolygonsPNG() { TestCase_SymbologyPolygons(L"PNG", L"png"); }
- void TestCase_Annotation1PNG() { TestCase_Annotation1(L"PNG", L"png"); }
- void TestCase_Annotation2PNG() { TestCase_Annotation2(L"PNG", L"png"); }
- void TestCase_Annotation3PNG() { TestCase_Annotation3(L"PNG", L"png"); }
- void TestCase_RenderLegendMultiFTSPNG() { TestCase_RenderLegendMultiFTS(L"PNG", L"png"); }
- void TestCase_RenderLegendMultiCTSPNG() { TestCase_RenderLegendMultiCTS(L"PNG", L"png"); }
- void TestCase_RenderLegendMultiFTSWithThemePNG() { TestCase_RenderLegendMultiFTSWithTheme(L"PNG", L"png"); }
- void TestCase_RenderLegendMultiCTSWithThemePNG() { TestCase_RenderLegendMultiCTSWithTheme(L"PNG", L"png"); }
- void TestCase_RenderLegendMultiFTSSingleCTSPNG() { TestCase_RenderLegendMultiFTSSingleCTS(L"PNG", L"png"); }
- void TestCase_RenderLegendSingleFTSMultiCTSPNG() { TestCase_RenderLegendSingleFTSMultiCTS(L"PNG", L"png"); }
- void TestCase_StylizationFunctionsPNG() { TestCase_StylizationFunctions(L"PNG", L"png"); }
- void TestCase_LayerWatermarkPNG() { TestCase_LayerWatermark(L"PNG", L"png"); }
- void TestCase_RenderTilePNG() { TestCase_RenderTile(L"PNG", L"png"); }
- void TestCase_RenderTileXYZ_PNG() { TestCase_RenderTileXYZ(L"PNG", L"png"); }
- //PNG8 output tests
- void TestCase_RenderDynamicOverlayPNG8() { TestCase_RenderDynamicOverlay(L"PNG8", L"png"); }
- void TestCase_RenderDynamicOverlayTiledMapPNG8() { TestCase_RenderDynamicOverlayTiledMap(L"PNG8", L"png"); }
- void TestCase_RenderMapPNG8() { TestCase_RenderMap(L"PNG8", L"png"); }
- void TestCase_RenderMapWithSelectionPNG8() { TestCase_RenderMapWithSelection(L"PNG8", L"png"); }
- void TestCase_RenderMapWithWatermarkPNG8() { TestCase_RenderMapWithWatermark(L"PNG8", L"png"); }
- void TestCase_RenderLegendPNG8() { TestCase_RenderLegend(L"PNG8", L"png"); }
- void TestCase_RenderLegendEmptyGroupsPNG8() { TestCase_RenderLegendEmptyGroups(L"PNG8", L"png"); }
- void TestCase_SymbologyPointsPNG8() { TestCase_SymbologyPoints(L"PNG8", L"png"); }
- void TestCase_SymbologyPointsParamPNG8() { TestCase_SymbologyPointsParam(L"PNG8", L"png"); }
- void TestCase_SymbologyLinesPNG8() { TestCase_SymbologyLines(L"PNG8", L"png"); }
- void TestCase_SymbologyLinesCrossTickPNG8() { TestCase_SymbologyLinesCrossTick(L"PNG8", L"png"); }
- void TestCase_SymbologyPolygonsPNG8() { TestCase_SymbologyPolygons(L"PNG8", L"png"); }
- void TestCase_Annotation1PNG8() { TestCase_Annotation1(L"PNG8", L"png"); }
- void TestCase_Annotation2PNG8() { TestCase_Annotation2(L"PNG8", L"png"); }
- void TestCase_Annotation3PNG8() { TestCase_Annotation3(L"PNG8", L"png"); }
- void TestCase_RenderLegendMultiFTSPNG8() { TestCase_RenderLegendMultiFTS(L"PNG8", L"png"); }
- void TestCase_RenderLegendMultiCTSPNG8() { TestCase_RenderLegendMultiCTS(L"PNG8", L"png"); }
- void TestCase_RenderLegendMultiFTSWithThemePNG8() { TestCase_RenderLegendMultiFTSWithTheme(L"PNG8", L"png"); }
- void TestCase_RenderLegendMultiCTSWithThemePNG8() { TestCase_RenderLegendMultiCTSWithTheme(L"PNG8", L"png"); }
- void TestCase_RenderLegendMultiFTSSingleCTSPNG8() { TestCase_RenderLegendMultiFTSSingleCTS(L"PNG8", L"png"); }
- void TestCase_RenderLegendSingleFTSMultiCTSPNG8() { TestCase_RenderLegendSingleFTSMultiCTS(L"PNG8", L"png"); }
- void TestCase_StylizationFunctionsPNG8() { TestCase_StylizationFunctions(L"PNG8", L"png"); }
- void TestCase_LayerWatermarkPNG8() { TestCase_LayerWatermark(L"PNG8", L"png"); }
- void TestCase_RenderTilePNG8() { TestCase_RenderTile(L"PNG8", L"png"); }
- void TestCase_RenderTileXYZ_PNG8() { TestCase_RenderTileXYZ(L"PNG8", L"png"); }
- //GIF output tests
- void TestCase_RenderDynamicOverlayGIF() { TestCase_RenderDynamicOverlay(L"GIF", L"gif"); }
- void TestCase_RenderDynamicOverlayTiledMapGIF() { TestCase_RenderDynamicOverlayTiledMap(L"GIF", L"gif"); }
- void TestCase_RenderMapGIF() { TestCase_RenderMap(L"GIF", L"gif"); }
- void TestCase_RenderMapWithSelectionGIF() { TestCase_RenderMapWithSelection(L"GIF", L"gif"); }
- void TestCase_RenderMapWithWatermarkGIF() { TestCase_RenderMapWithWatermark(L"GIF", L"gif"); }
- void TestCase_RenderLegendGIF() { TestCase_RenderLegend(L"GIF", L"gif"); }
- void TestCase_RenderLegendEmptyGroupsGIF() { TestCase_RenderLegendEmptyGroups(L"GIF", L"gif"); }
- void TestCase_SymbologyPointsGIF() { TestCase_SymbologyPoints(L"GIF", L"gif"); }
- void TestCase_SymbologyPointsParamGIF() { TestCase_SymbologyPointsParam(L"GIF", L"gif"); }
- void TestCase_SymbologyLinesGIF() { TestCase_SymbologyLines(L"GIF", L"gif"); }
- void TestCase_SymbologyLinesCrossTickGIF() { TestCase_SymbologyLinesCrossTick(L"GIF", L"gif"); }
- void TestCase_SymbologyPolygonsGIF() { TestCase_SymbologyPolygons(L"GIF", L"gif"); }
- void TestCase_Annotation1GIF() { TestCase_Annotation1(L"GIF", L"gif"); }
- void TestCase_Annotation2GIF() { TestCase_Annotation2(L"GIF", L"gif"); }
- void TestCase_Annotation3GIF() { TestCase_Annotation3(L"GIF", L"gif"); }
- void TestCase_RenderLegendMultiFTSGIF() { TestCase_RenderLegendMultiFTS(L"GIF", L"gif"); }
- void TestCase_RenderLegendMultiCTSGIF() { TestCase_RenderLegendMultiCTS(L"GIF", L"gif"); }
- void TestCase_RenderLegendMultiFTSWithThemeGIF() { TestCase_RenderLegendMultiFTSWithTheme(L"GIF", L"gif"); }
- void TestCase_RenderLegendMultiCTSWithThemeGIF() { TestCase_RenderLegendMultiCTSWithTheme(L"GIF", L"gif"); }
- void TestCase_RenderLegendMultiFTSSingleCTSGIF() { TestCase_RenderLegendMultiFTSSingleCTS(L"GIF", L"gif"); }
- void TestCase_RenderLegendSingleFTSMultiCTSGIF() { TestCase_RenderLegendSingleFTSMultiCTS(L"GIF", L"gif"); }
- void TestCase_StylizationFunctionsGIF() { TestCase_StylizationFunctions(L"GIF", L"gif"); }
- void TestCase_LayerWatermarkGIF() { TestCase_LayerWatermark(L"GIF", L"gif"); }
- void TestCase_RenderTileGIF() { TestCase_RenderTile(L"GIF", L"gif"); }
- void TestCase_RenderTileXYZ_GIF() { TestCase_RenderTileXYZ(L"GIF", L"gif"); }
- //JPG output tests
- void TestCase_RenderDynamicOverlayJPG() { TestCase_RenderDynamicOverlay(L"JPG", L"jpg"); }
- void TestCase_RenderDynamicOverlayTiledMapJPG() { TestCase_RenderDynamicOverlayTiledMap(L"JPG", L"jpg"); }
- void TestCase_RenderMapJPG() { TestCase_RenderMap(L"JPG", L"jpg"); }
- void TestCase_RenderMapWithSelectionJPG() { TestCase_RenderMapWithSelection(L"JPG", L"jpg"); }
- void TestCase_RenderMapWithWatermarkJPG() { TestCase_RenderMapWithWatermark(L"JPG", L"jpg"); }
- void TestCase_RenderLegendJPG() { TestCase_RenderLegend(L"JPG", L"jpg"); }
- void TestCase_RenderLegendEmptyGroupsJPG() { TestCase_RenderLegendEmptyGroups(L"JPG", L"jpg"); }
- void TestCase_SymbologyPointsJPG() { TestCase_SymbologyPoints(L"JPG", L"jpg"); }
- void TestCase_SymbologyPointsParamJPG() { TestCase_SymbologyPointsParam(L"JPG", L"jpg"); }
- void TestCase_SymbologyLinesJPG() { TestCase_SymbologyLines(L"JPG", L"jpg"); }
- void TestCase_SymbologyLinesCrossTickJPG() { TestCase_SymbologyLinesCrossTick(L"JPG", L"jpg"); }
- void TestCase_SymbologyPolygonsJPG() { TestCase_SymbologyPolygons(L"JPG", L"jpg"); }
- void TestCase_Annotation1JPG() { TestCase_Annotation1(L"JPG", L"jpg"); }
- void TestCase_Annotation2JPG() { TestCase_Annotation2(L"JPG", L"jpg"); }
- void TestCase_Annotation3JPG() { TestCase_Annotation3(L"JPG", L"jpg"); }
- void TestCase_RenderLegendMultiFTSJPG() { TestCase_RenderLegendMultiFTS(L"JPG", L"jpg"); }
- void TestCase_RenderLegendMultiCTSJPG() { TestCase_RenderLegendMultiCTS(L"JPG", L"jpg"); }
- void TestCase_RenderLegendMultiFTSWithThemeJPG() { TestCase_RenderLegendMultiFTSWithTheme(L"JPG", L"jpg"); }
- void TestCase_RenderLegendMultiCTSWithThemeJPG() { TestCase_RenderLegendMultiCTSWithTheme(L"JPG", L"jpg"); }
- void TestCase_RenderLegendMultiFTSSingleCTSJPG() { TestCase_RenderLegendMultiFTSSingleCTS(L"JPG", L"jpg"); }
- void TestCase_RenderLegendSingleFTSMultiCTSJPG() { TestCase_RenderLegendSingleFTSMultiCTS(L"JPG", L"jpg"); }
- void TestCase_StylizationFunctionsJPG() { TestCase_StylizationFunctions(L"JPG", L"jpg"); }
- void TestCase_LayerWatermarkJPG() { TestCase_LayerWatermark(L"JPG", L"jpg"); }
- void TestCase_RenderTileJPG() { TestCase_RenderTile(L"JPG", L"jpg"); }
- void TestCase_RenderTileXYZ_JPG() { TestCase_RenderTileXYZ(L"JPG", L"jpg"); }
- //void TestCase_RendererPerformance();
- void TestCase_RenderMetatilePNG() { TestCase_RenderMetatile(L"PNG", L"png"); }
- void TestCase_RenderMetatilePNG8() { TestCase_RenderMetatile(L"PNG8", L"png"); }
- void TestCase_RenderMetatileJPG() { TestCase_RenderMetatile(L"JPG", L"jpg"); }
- void TestCase_RenderMetatileGIF() { TestCase_RenderMetatile(L"GIF", L"gif"); }
- void TestCase_RenderXYZMetatilePNG() { TestCase_RenderXYZMetatile(L"PNG", L"png", 1); }
- void TestCase_RenderXYZMetatilePNG8() { TestCase_RenderXYZMetatile(L"PNG8", L"png", 1); }
- void TestCase_RenderXYZMetatileJPG() { TestCase_RenderXYZMetatile(L"JPG", L"jpg", 1); }
- void TestCase_RenderXYZMetatileGIF() { TestCase_RenderXYZMetatile(L"GIF", L"gif", 1); }
- void TestCase_RenderXYZMetatilePNG_2x() { TestCase_RenderXYZMetatile(L"PNG", L"png", 2); }
- void TestCase_RenderXYZMetatilePNG8_2x() { TestCase_RenderXYZMetatile(L"PNG8", L"png", 2); }
- void TestCase_RenderXYZMetatileJPG_2x() { TestCase_RenderXYZMetatile(L"JPG", L"jpg", 2); }
- void TestCase_RenderXYZMetatileGIF_2x() { TestCase_RenderXYZMetatile(L"GIF", L"gif", 2); }
- void TestCase_RenderXYZMetatilePNG_4x() { TestCase_RenderXYZMetatile(L"PNG", L"png", 4); }
- void TestCase_RenderXYZMetatilePNG8_4x() { TestCase_RenderXYZMetatile(L"PNG8", L"png", 4); }
- void TestCase_RenderXYZMetatileJPG_4x() { TestCase_RenderXYZMetatile(L"JPG", L"jpg", 4); }
- void TestCase_RenderXYZMetatileGIF_4x() { TestCase_RenderXYZMetatile(L"GIF", L"gif", 4); }
-private:
- MgMap* CreateTestMap();
- MgMap* CreateTestTiledMap();
- MgMap* CreateTestXYZMap();
- MgMap* CreateTestStylizationFunctionMap();
- MgMap* CreateTestMapWithWatermark();
- MgPolygon* CreateSelectionPolygon(MgMap* map, double width, double height);
- static STRING GetPath(CREFSTRING basePath, CREFSTRING imageFormat, CREFSTRING extension);
-private:
- Ptr<MgSiteConnection> m_siteConnection;
- Ptr<MgResourceService> m_svcResource;
- Ptr<MgRenderingService> m_svcRendering;
-#endif // _TESTRENDERINGSERVICE_H
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestResourceService.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestResourceService.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestResourceService.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -101,7 +101,7 @@
MgServiceManager* serviceManager = MgServiceManager::GetInstance();
Ptr<MgResourceService> svcResource = dynamic_cast<MgResourceService*>(
serviceManager->RequestService(MgServiceType::ResourceService));
- assert(svcResource != NULL);
+ assert(svcResource != nullptr);
STRING resource = L"Session:";
resource += session;
@@ -115,7 +115,7 @@
//Set the resource
Ptr<MgByteSource> contentSource = new MgByteSource(resourceContentFileName);
Ptr<MgByteReader> contentReader = contentSource->GetReader();
- svcResource->SetResource(resId, contentReader, NULL);
+ svcResource->SetResource(resId, contentReader, nullptr);
case 1:
@@ -127,7 +127,7 @@
// Need to add a case that updates the session with runtime map
- MgUserInformation::SetCurrentUserInfo(NULL);
+ MgUserInformation::SetCurrentUserInfo(nullptr);
threadData->success = true;
catch (MgException* e)
@@ -144,7 +144,7 @@
// clear the user info to prevent leaks - if an exception happens and this is not called it leaks about 500 bytes!
ACE_DEBUG((LM_INFO, ACE_TEXT("> thread %d done\n"), threadId));
@@ -162,23 +162,23 @@
try
- if(serviceManager == 0)
+ if (serviceManager == nullptr)
- throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateRepositories", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateRepositories", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgResourceService> pService = dynamic_cast<MgResourceService*>(serviceManager->RequestService(MgServiceType::ResourceService));
- if (pService == 0)
+ if (pService == nullptr)
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateRepositories", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateRepositories", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgUserInformation> userInfo;
//Sets the user information for the current thread to be administrator
userInfo = new MgUserInformation(adminName, adminPass);
- if (userInfo != NULL)
+ if (userInfo != nullptr)
userInfo->SetLocale(userLocale);
MgUserInformation::SetCurrentUserInfo(userInfo);
@@ -193,9 +193,9 @@
//Try to enumerate repositories while not an admin
userInfo = new MgUserInformation(L"", L"");
@@ -220,48 +220,48 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_CreateRepository", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_CreateRepository", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_CreateRepository", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_CreateRepository", __LINE__, __WFILE__, nullptr, L"", nullptr);
- //Try to create a repository using a NULL identifier
- REQUIRE_THROWS_MG(pService->CreateRepository(NULL, NULL, NULL), MgNullArgumentException*);
+ //Try to create a repository using a nullptr identifier
+ REQUIRE_THROWS_MG(pService->CreateRepository(nullptr, nullptr, nullptr), MgNullArgumentException*);
//Try to create a repository using an invalid repository identifier
- REQUIRE_THROWS_MG(pService->CreateRepository(&resourceIdentifier, NULL, NULL), MgInvalidRepositoryTypeException*);
+ REQUIRE_THROWS_MG(pService->CreateRepository(&resourceIdentifier, nullptr, nullptr), MgInvalidRepositoryTypeException*);
//Create a new repository
- pService->CreateRepository(&sessionRepositoryIdentifier, NULL, NULL);
+ pService->CreateRepository(&sessionRepositoryIdentifier, nullptr, nullptr);
//Try to create the same repository again
- REQUIRE_THROWS_MG(pService->CreateRepository(&sessionRepositoryIdentifier, NULL, NULL), MgDuplicateRepositoryException*);
+ REQUIRE_THROWS_MG(pService->CreateRepository(&sessionRepositoryIdentifier, nullptr, nullptr), MgDuplicateRepositoryException*);
//Try to create a repository while not an admin
- REQUIRE_THROWS_MG(pService->CreateRepository(&sessionRepositoryIdentifier, NULL, NULL), MgUnauthorizedAccessException*);
+ REQUIRE_THROWS_MG(pService->CreateRepository(&sessionRepositoryIdentifier, nullptr, nullptr), MgUnauthorizedAccessException*);
catch(MgException* e)
@@ -282,15 +282,15 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_UpdateRepository", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_UpdateRepository", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_UpdateRepository", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_UpdateRepository", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -299,42 +299,42 @@
Ptr<MgByteSource> contentSource;
- //Try to use a NULL argument
- REQUIRE_THROWS_MG(pService->UpdateRepository(NULL, NULL, NULL), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->UpdateRepository(&sessionRepositoryIdentifier, NULL, NULL), MgNullArgumentException*);
+ //Try to use a nullptr argument
+ REQUIRE_THROWS_MG(pService->UpdateRepository(nullptr, nullptr, nullptr), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->UpdateRepository(&sessionRepositoryIdentifier, nullptr, nullptr), MgNullArgumentException*);
//Try to update a repository that doesn't exist
contentSource = new MgByteSource(repositoryContentFileName);
- REQUIRE_THROWS_MG(pService->UpdateRepository(&sessionRepositoryNotExist, contentReader, NULL), MgRepositoryNotFoundException*);
+ REQUIRE_THROWS_MG(pService->UpdateRepository(&sessionRepositoryNotExist, contentReader, nullptr), MgRepositoryNotFoundException*);
//Try to update the repository using invalid content
string str = "asdf";
Ptr<MgByteReader> byteReader = MgUtil::GetByteReader(str);
- REQUIRE_THROWS_MG(pService->UpdateRepository(&sessionRepositoryIdentifier, byteReader, NULL), MgDbXmlException*);
+ REQUIRE_THROWS_MG(pService->UpdateRepository(&sessionRepositoryIdentifier, byteReader, nullptr), MgDbXmlException*);
//Try to update the repository using valid header
headerSource = new MgByteSource(repositoryHeaderFileName);
Ptr<MgByteReader> headerReader = headerSource->GetReader();
- pService->UpdateRepository(&libraryRepositoryIdentifier, NULL, headerReader);
+ pService->UpdateRepository(&libraryRepositoryIdentifier, nullptr, headerReader);
//Try to update repository while not an admin
- REQUIRE_THROWS_MG(pService->UpdateRepository(&sessionRepositoryIdentifier, contentReader, NULL), MgUnauthorizedAccessException*);
+ REQUIRE_THROWS_MG(pService->UpdateRepository(&sessionRepositoryIdentifier, contentReader, nullptr), MgUnauthorizedAccessException*);
@@ -355,29 +355,29 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_GetRepositoryContent", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_GetRepositoryContent", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetRepositoryContent", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetRepositoryContent", __LINE__, __WFILE__, nullptr, L"", nullptr);
- //Try to get repository content using a NULL argument
- REQUIRE_THROWS_MG(pService->GetRepositoryContent(NULL), MgNullArgumentException*);
+ //Try to get repository content using a nullptr argument
+ REQUIRE_THROWS_MG(pService->GetRepositoryContent(nullptr), MgNullArgumentException*);
//Try to get the repository contents of a repository that doesn't exist
REQUIRE_THROWS_MG(pService->GetRepositoryContent(&sessionRepositoryNotExist), MgRepositoryNotFoundException*);
@@ -389,9 +389,9 @@
//Try to get repository content while not an admin
@@ -416,19 +416,19 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_GetRepositoryHeader", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_GetRepositoryHeader", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetRepositoryHeader", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetRepositoryHeader", __LINE__, __WFILE__, nullptr, L"", nullptr);
- //Try to get repository header using a NULL argument
- REQUIRE_THROWS_MG(pService->GetRepositoryHeader(NULL), MgNullArgumentException*);
+ //Try to get repository header using a nullptr argument
+ REQUIRE_THROWS_MG(pService->GetRepositoryHeader(nullptr), MgNullArgumentException*);
//Try to get repository header of a repository other than Library://
REQUIRE_THROWS_MG(pService->GetRepositoryHeader(&sessionRepositoryIdentifier), MgInvalidRepositoryTypeException*);
@@ -460,29 +460,29 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_ApplyResourcePackage", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_ApplyResourcePackage", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_ApplyResourcePackage", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_ApplyResourcePackage", __LINE__, __WFILE__, nullptr, L"", nullptr);
- //Try using NULL argument
- REQUIRE_THROWS_MG(pService->ApplyResourcePackage(NULL), MgNullArgumentException*);
+ //Try using nullptr argument
+ REQUIRE_THROWS_MG(pService->ApplyResourcePackage(nullptr), MgNullArgumentException*);
Ptr<MgByteSource> byteSource = new MgByteSource(packageName);
byteSource->SetMimeType(MgMimeType::Binary);
@@ -492,9 +492,9 @@
//Try to apply a package while not an admin
userInfo = new MgUserInformation(anonymousName, L"");
@@ -524,23 +524,23 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_DeleteRepository", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_DeleteRepository", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_DeleteRepository", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_DeleteRepository", __LINE__, __WFILE__, nullptr, L"", nullptr);
//Try to delete repository while not an admin
@@ -548,15 +548,15 @@
- REQUIRE_THROWS_MG(pService->DeleteRepository(NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->DeleteRepository(nullptr), MgNullArgumentException*);
//Try to delete a repository that does not exist
REQUIRE_THROWS_MG(pService->DeleteRepository(&sessionRepositoryNotExist), MgRepositoryNotFoundException*);
@@ -584,21 +584,21 @@
- if (NULL == serviceManager)
+ if (nullptr == serviceManager)
L"TestResourceService.TestCase_ResourceExists",
- __LINE__, __WFILE__, NULL, L"", NULL);
+ __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgResourceService> service = dynamic_cast<MgResourceService*>(
- if (NULL == service)
+ if (nullptr == service)
// Set the user information for the current thread to be administrator.
@@ -605,9 +605,9 @@
Ptr<MgUserInformation> adminUserInfo = new MgUserInformation(adminName, adminPass);
MgUserInformation::SetCurrentUserInfo(adminUserInfo);
- // Try to check a NULL resource.
+ // Try to check a nullptr resource.
bool existed = false;
- REQUIRE_THROWS_MG(service->ResourceExists(NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(service->ResourceExists(nullptr), MgNullArgumentException*);
// Try to check a resource that exists
existed = service->ResourceExists(&libraryRepositoryIdentifier);
@@ -635,19 +635,19 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateResources", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateResources", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateResources", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateResources", __LINE__, __WFILE__, nullptr, L"", nullptr);
- //Try to enumerate resources using a NULL argument
- REQUIRE_THROWS_MG(pService->EnumerateResources(NULL, -1, L"", true), MgNullArgumentException*);
+ //Try to enumerate resources using a nullptr argument
+ REQUIRE_THROWS_MG(pService->EnumerateResources(nullptr, -1, L"", true), MgNullArgumentException*);
// Enumerate the Library resource.
Ptr<MgByteReader> byteReader = pService->EnumerateResources(&libraryRepositoryIdentifier, -1, L"", true);
@@ -673,59 +673,59 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_SetResource", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_SetResource", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_SetResource", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_SetResource", __LINE__, __WFILE__, nullptr, L"", nullptr);
- contentSource = NULL;
+ contentSource = nullptr;
- //Try to use NULL arguments
- REQUIRE_THROWS_MG(pService->SetResource(NULL, NULL, NULL), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->SetResource(&resourceIdentifier, NULL, NULL), MgNullArgumentException*);
+ //Try to use nullptr arguments
+ REQUIRE_THROWS_MG(pService->SetResource(nullptr, nullptr, nullptr), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->SetResource(&resourceIdentifier, nullptr, nullptr), MgNullArgumentException*);
//Add a new resource
- pService->SetResource(&resourceIdentifier, contentReader, NULL);
+ pService->SetResource(&resourceIdentifier, contentReader, nullptr);
//Try to add the same resource again (should be fine and just update it)
//Add another resource layer definition, which references to the feature source. This is for cascade MoveResource test.
contentSource = new MgByteSource(resourceContentFileName2);
- pService->SetResource(&resourceIdentifier4, contentReader, NULL);
+ pService->SetResource(&resourceIdentifier4, contentReader, nullptr);
//Try to add resource while not an admin
- REQUIRE_THROWS_MG(pService->SetResource(&resourceIdentifier2, contentReader, NULL), MgUnauthorizedAccessException*);
+ REQUIRE_THROWS_MG(pService->SetResource(&resourceIdentifier2, contentReader, nullptr), MgUnauthorizedAccessException*);
@@ -747,32 +747,32 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_MoveResource", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_MoveResource", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_MoveResource", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_MoveResource", __LINE__, __WFILE__, nullptr, L"", nullptr);
- REQUIRE_THROWS_MG(pService->MoveResource(NULL, NULL, true, false), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->MoveResource(&resourceIdentifier, NULL, true, true), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->MoveResource(NULL, &resourceIdentifier, true, false), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->MoveResource(nullptr, nullptr, true, false), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->MoveResource(&resourceIdentifier, nullptr, true, true), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->MoveResource(nullptr, &resourceIdentifier, true, false), MgNullArgumentException*);
//Try to move a resource that doesn't exist
REQUIRE_THROWS_MG(pService->MoveResource(&resourceNotExist, &resourceIdentifier2, false, true), MgResourceNotFoundException*);
@@ -797,9 +797,9 @@
//Try to move resource while not an admin
@@ -825,31 +825,31 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_CopyResource", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_CopyResource", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_CopyResource", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_CopyResource", __LINE__, __WFILE__, nullptr, L"", nullptr);
- REQUIRE_THROWS_MG(pService->CopyResource(NULL, NULL, true), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->CopyResource(&resourceIdentifier, NULL, true), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->CopyResource(NULL, &resourceIdentifier2, true), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->CopyResource(nullptr, nullptr, true), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->CopyResource(&resourceIdentifier, nullptr, true), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->CopyResource(nullptr, &resourceIdentifier2, true), MgNullArgumentException*);
//Try to use source & destination as the same thing
REQUIRE_THROWS_MG(pService->CopyResource(&resourceIdentifier2, &resourceIdentifier2, false), MgInvalidArgumentException*);
@@ -862,9 +862,9 @@
//Try to copy resource while not an admin
@@ -888,15 +888,15 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_GetResourceContent", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_GetResourceContent", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetResourceContent", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetResourceContent", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -904,10 +904,10 @@
Ptr<MgByteReader> byteReader;
- byteReader = NULL;
+ byteReader = nullptr;
- //Try to get the content using NULL arguments
- REQUIRE_THROWS_MG(pService->GetResourceContent(NULL, L""), MgNullArgumentException*);
+ //Try to get the content using nullptr arguments
+ REQUIRE_THROWS_MG(pService->GetResourceContent(nullptr, L""), MgNullArgumentException*);
//Try to get the content of a resource that doesn't exist
REQUIRE_THROWS_MG(pService->GetResourceContent(&resourceNotExist, L""), MgResourceNotFoundException*);
@@ -935,15 +935,15 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_GetResourceContents", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_GetResourceContents", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetResourceContents", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetResourceContents", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -950,20 +950,20 @@
- //Try to get the contents using NULL arguments
- REQUIRE_THROWS_MG(pService->GetResourceContents(NULL, NULL), MgNullArgumentException*);
+ //Try to get the contents using nullptr arguments
+ REQUIRE_THROWS_MG(pService->GetResourceContents(nullptr, nullptr), MgNullArgumentException*);
Ptr<MgStringCollection> resourceNotExistCol = new MgStringCollection();
resourceNotExistCol->Add(resourceNotExist.ToString());
resourceNotExistCol->Add(resourceIdentifier.ToString());
- REQUIRE_THROWS_MG(pService->GetResourceContents(resourceNotExistCol, NULL), MgResourceNotFoundException*);
+ REQUIRE_THROWS_MG(pService->GetResourceContents(resourceNotExistCol, nullptr), MgResourceNotFoundException*);
//Get the content of the resource that was added in TestCase_SetResource
Ptr<MgStringCollection> resourceIds = new MgStringCollection();
resourceIds->Add(resourceIdentifier.ToString());
resourceIds->Add(resourceIdentifier4.ToString());
- Ptr<MgStringCollection> ret = pService->GetResourceContents(resourceIds, NULL);
+ Ptr<MgStringCollection> ret = pService->GetResourceContents(resourceIds, nullptr);
REQUIRE(ret->GetCount() == 2);
for(int i = 0; i < ret->GetCount(); i ++)
@@ -988,15 +988,15 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_GetResourceHeader", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_GetResourceHeader", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetResourceHeader", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetResourceHeader", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -1004,10 +1004,10 @@
- REQUIRE_THROWS_MG(pService->GetResourceHeader(NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->GetResourceHeader(nullptr), MgNullArgumentException*);
REQUIRE_THROWS_MG(pService->GetResourceHeader(&resourceNotExist), MgResourceNotFoundException*);
@@ -1035,15 +1035,15 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateReferences", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateReferences", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateReferences", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateReferences", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -1051,10 +1051,10 @@
- REQUIRE_THROWS_MG(pService->EnumerateReferences(NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->EnumerateReferences(nullptr), MgNullArgumentException*);
byteReader = pService->EnumerateReferences(&resourceIdentifier);
@@ -1079,29 +1079,29 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_ChangeResourceOwner", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_ChangeResourceOwner", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_ChangeResourceOwner", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_ChangeResourceOwner", __LINE__, __WFILE__, nullptr, L"", nullptr);
- //Try to change the user using NULL arguments
- REQUIRE_THROWS_MG(pService->ChangeResourceOwner(NULL, L"", false), MgNullArgumentException*);
+ //Try to change the user using nullptr arguments
+ REQUIRE_THROWS_MG(pService->ChangeResourceOwner(nullptr, L"", false), MgNullArgumentException*);
//Try to change the owner of a resource that doesn't exist
//TODO: this does not throw exception, should it?
@@ -1115,9 +1115,9 @@
@@ -1142,29 +1142,29 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_InheritPermissionsFrom", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_InheritPermissionsFrom", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_InheritPermissionsFrom", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_InheritPermissionsFrom", __LINE__, __WFILE__, nullptr, L"", nullptr);
- REQUIRE_THROWS_MG(pService->InheritPermissionsFrom(NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->InheritPermissionsFrom(nullptr), MgNullArgumentException*);
//Set resources to inherit permissions
pService->InheritPermissionsFrom(&libraryRepositoryIdentifier);
@@ -1171,9 +1171,9 @@
//Try to perform this operation while not an administrator
@@ -1199,15 +1199,15 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateResourceData", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateResourceData", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -1215,10 +1215,10 @@
- //Try enumerating using a NULL argument
- REQUIRE_THROWS_MG(pService->EnumerateResourceData(NULL), MgNullArgumentException*);
+ //Try enumerating using a nullptr argument
+ REQUIRE_THROWS_MG(pService->EnumerateResourceData(nullptr), MgNullArgumentException*);
//Try enumerating using a resource that doesn't exist
REQUIRE_THROWS_MG(pService->EnumerateResourceData(&resourceNotExist), MgResourceNotFoundException*);
@@ -1246,32 +1246,32 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_SetResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_SetResourceData", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_SetResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_SetResourceData", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgByteSource> dataSource;
- dataSource = NULL;
+ dataSource = nullptr;
- //Try using a NULL identifier
- REQUIRE_THROWS_MG(pService->SetResourceData(NULL, L"", L"", NULL), MgNullArgumentException*);
+ //Try using a nullptr identifier
+ REQUIRE_THROWS_MG(pService->SetResourceData(nullptr, L"", L"", nullptr), MgNullArgumentException*);
//Try to name the resource data with a 0 character string
dataSource = new MgByteSource(dataFileName);
@@ -1286,9 +1286,9 @@
//Try to set resource data while not an admin
@@ -1314,29 +1314,29 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_RenameResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_RenameResourceData", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_RenameResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_RenameResourceData", __LINE__, __WFILE__, nullptr, L"", nullptr);
//Try using a null argument for the idenfier
- REQUIRE_THROWS_MG(pService->RenameResourceData(NULL, resourceDataName, resourceDataName2, true), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->RenameResourceData(nullptr, resourceDataName, resourceDataName2, true), MgNullArgumentException*);
//Try using a resource identifier that doesn't exist
REQUIRE_THROWS_MG(pService->RenameResourceData(&resourceNotExist, resourceDataName, resourceDataName2, true), MgResourceNotFoundException*);
@@ -1353,9 +1353,9 @@
//Try to rename resource data while not an admin
@@ -1380,15 +1380,15 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_GetResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_GetResourceData", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_GetResourceData", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -1396,10 +1396,10 @@
- //Try to get resource data using a NULL identifier
- REQUIRE_THROWS_MG(pService->GetResourceData(NULL, resourceDataName, L""), MgNullArgumentException*);
+ //Try to get resource data using a nullptr identifier
+ REQUIRE_THROWS_MG(pService->GetResourceData(nullptr, resourceDataName, L""), MgNullArgumentException*);
//Try to get resource data using an empty data name string
REQUIRE_THROWS_MG(pService->GetResourceData(&resourceIdentifier, L"", L""), MgInvalidArgumentException*);
@@ -1431,29 +1431,29 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_DeleteResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_DeleteResourceData", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_DeleteResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_DeleteResourceData", __LINE__, __WFILE__, nullptr, L"", nullptr);
- //Try using a NULL resource identifier
- REQUIRE_THROWS_MG(pService->DeleteResourceData(NULL, resourceDataName), MgNullArgumentException*);
+ //Try using a nullptr resource identifier
+ REQUIRE_THROWS_MG(pService->DeleteResourceData(nullptr, resourceDataName), MgNullArgumentException*);
//Try using an empty string for the resource data name
REQUIRE_THROWS_MG(pService->DeleteResourceData(&resourceIdentifier, L""), MgInvalidArgumentException*);
@@ -1466,9 +1466,9 @@
@@ -1494,35 +1494,35 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_DeleteResource", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_DeleteResource", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_DeleteResource", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_DeleteResource", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgFeatureService> pFeatureService = dynamic_cast<MgFeatureService*>(serviceManager->RequestService(MgServiceType::FeatureService));
- if (pFeatureService == 0)
+ if (pFeatureService == nullptr)
- REQUIRE_THROWS_MG(pService->DeleteResource(NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->DeleteResource(nullptr), MgNullArgumentException*);
//Try to delete a resource that doesn't exist. We allow doing this for performance reason.
pService->DeleteResource(&resourceNotExist);
@@ -1534,9 +1534,9 @@
//Try to delete resource while not an admin
@@ -1544,9 +1544,9 @@
// Try to delete resource after FDO exception
Ptr<MgResourceIdentifier> resource;
resource = new MgResourceIdentifier(L"Library://UnitTests/Data/TEST.FeatureSource");
@@ -1565,7 +1565,7 @@
contentSource = new MgByteSource(rcName);
- pService->SetResource(resource, contentReader, NULL);
+ pService->SetResource(resource, contentReader, nullptr);
dataSource = new MgByteSource(dfName);
@@ -1573,7 +1573,7 @@
Ptr<MgByteReader> dataReader;
dataReader = dataSource->GetReader();
pService->SetResourceData(resource, L"TEST.sdf", L"File", dataReader);
- dataReader = NULL; // Holds on to the file, so must release resources!
+ dataReader = nullptr; // Holds on to the file, so must release resources!
// Force an FDO exception
Ptr<MgFeatureAggregateOptions> options = new MgFeatureAggregateOptions();
@@ -1585,7 +1585,7 @@
REQUIRE(bResult);
reader->Close();
- reader = NULL; // Holds on to the file, so must release resources!
+ reader = nullptr; // Holds on to the file, so must release resources!
// Attempt to delete the resource
pService->DeleteResource(resource);
@@ -1618,15 +1618,15 @@
try
- throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateUnmanagedData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateUnmanagedData", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateUnmanagedData", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateUnmanagedData", __LINE__, __WFILE__, nullptr, L"", nullptr);
// Try to enumerate mappings
@@ -1661,7 +1661,7 @@
// set user info
Ptr<MgUserInformation> userInfo = new MgUserInformation(L"Administrator", L"admin");
@@ -1686,7 +1686,7 @@
// Create session resource
Ptr<MgResourceIdentifier> resIdSession = new MgResourceIdentifier(resource);
- svcResource->CreateRepository(resIdSession, NULL, NULL);
+ svcResource->CreateRepository(resIdSession, nullptr, nullptr);
// Create feature source resource
resource += L"UnitTests/Data/test-1.FeatureSource";
@@ -1693,7 +1693,7 @@
Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resource);
// Set the thread specific data
threadData[i].threadId = i;
@@ -1723,7 +1723,7 @@
threadData[i].command = i%2;
// spawn a new thread using a specific group id
- int thid = manager->spawn(ACE_THR_FUNC(RepositoryWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
+ int thid = manager->spawn(ACE_THR_FUNC(RepositoryWorker), &threadData[i], 0, nullptr, nullptr, 0, THREAD_GROUP);
nRequest++;
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestServerAdminService.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestServerAdminService.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestServerAdminService.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -45,15 +45,15 @@
try
MgServiceManager* serviceMan = MgServiceManager::GetInstance();
- if(serviceMan == 0)
+ if (serviceMan == nullptr)
- throw new MgNullReferenceException(L"TestServerAdminService.TestCase_TakeOffline", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService.TestCase_TakeOffline", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgServerAdminService> pService = dynamic_cast<MgServerAdminService*>(serviceMan->RequestService(MgServiceType::ServerAdminService));
- throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_TakeOffline", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_TakeOffline", __LINE__, __WFILE__, nullptr, L"", nullptr);
pService->TakeOffline();
@@ -83,15 +83,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService.TestCase_BringOnline", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService.TestCase_BringOnline", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_BringOnline", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_BringOnline", __LINE__, __WFILE__, nullptr, L"", nullptr);
pService->BringOnline();
@@ -121,15 +121,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService::TestCase_GetConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_GetConfigurationProperties", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_GetConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_GetConfigurationProperties", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgPropertyCollection> pPropertyCollection1 = MgServerManager::GetInstance()->GetConfigurationProperties(L"GeneralProperties");
@@ -164,15 +164,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService::TestCase_SetConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_SetConfigurationProperties", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_SetConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_SetConfigurationProperties", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgPropertyCollection> pPropertyCollection1 = pService->GetConfigurationProperties(L"GeneralProperties");
@@ -213,15 +213,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService::TestCase_RemoveConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_RemoveConfigurationProperties", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_RemoveConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_RemoveConfigurationProperties", __LINE__, __WFILE__, nullptr, L"", nullptr);
// add a property to unmanaged data mappings
@@ -271,15 +271,15 @@
try
- if (serviceMan == 0)
- throw new MgNullReferenceException(L"TestServerAdminService.TestCase_ClearLog", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService.TestCase_ClearLog", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_ClearLog", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_ClearLog", __LINE__, __WFILE__, nullptr, L"", nullptr);
REQUIRE(pService->ClearLog(MgLogFileType::Access));
@@ -314,15 +314,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService.TestCase_GetLog", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService.TestCase_GetLog", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_GetLog", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_GetLog", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -371,15 +371,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService.TestCase_GetLogEntries", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService.TestCase_GetLogEntries", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_GetLogEntries", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_GetLogEntries", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -428,15 +428,15 @@
try
@@ -463,7 +463,7 @@
byteReader = pService->GetLog(MgLogFileType::Trace, dateTime1, dateTime2);
REQUIRE(byteReader.p != nullptr);
- REQUIRE_THROWS_MG(pService->GetLog(MgLogFileType::Access, dateTime1, NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->GetLog(MgLogFileType::Access, dateTime1, nullptr), MgNullArgumentException*);
REQUIRE_THROWS_MG(pService->GetLog(MgLogFileType::Access, dateTime2, dateTime1), MgInvalidArgumentException*);
REQUIRE_THROWS_MG(pService->GetLog(MgLogFileType::Access, dateTime1, dateTime3), MgInvalidArgumentException*);
REQUIRE_THROWS_MG(pService->GetLog(MgLogFileType::Access, invalidDateTime, dateTime2), MgInvalidArgumentException*);
@@ -491,15 +491,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService::TestCase_GetInformationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_GetInformationProperties", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_GetInformationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_GetInformationProperties", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgPropertyCollection> pPropertyCollection = MgServerManager::GetInstance()->GetInformationProperties();
@@ -528,15 +528,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService::TestCase_EnumeratePackages", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_EnumeratePackages", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_EnumeratePackages", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_EnumeratePackages", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgPropertyCollection> pPropertyCollection1 = pService->GetConfigurationProperties(L"ResourceServiceProperties");
@@ -581,15 +581,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService::TestCase_LoadPackage", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_LoadPackage", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_LoadPackage", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_LoadPackage", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -605,9 +605,9 @@
@@ -643,15 +643,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService::TestCase_MakePackage", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_MakePackage", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_MakePackage", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_MakePackage", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -667,9 +667,9 @@
@@ -716,15 +716,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService::TestCase_GetPackageLog", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_GetPackageLog", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_GetPackageLog", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_GetPackageLog", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -770,15 +770,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService::TestCase_GetPackageStatus", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_GetPackageStatus", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_GetPackageStatus", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_GetPackageStatus", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -824,15 +824,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService::TestCase_DeletePackage", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_DeletePackage", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_DeletePackage", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_DeletePackage", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -881,15 +881,15 @@
// try
// MgServiceManager* serviceMan = MgServiceManager::GetInstance();
-// if(serviceMan == 0)
+// if (serviceMan == nullptr)
-// throw new MgNullReferenceException(L"TestServerAdminService::TestCase_GetInformationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+// throw new MgNullReferenceException(L"TestServerAdminService::TestCase_GetInformationProperties", __LINE__, __WFILE__, nullptr, L"", nullptr);
// Ptr<MgServerAdminService> pService = dynamic_cast<MgServerAdminService*>(serviceMan->RequestService(MgServiceType::ServerAdminService));
-// if (pService == 0)
+// if (pService == nullptr)
-// throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_GetInformationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+// throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_GetInformationProperties", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -916,15 +916,15 @@
// try
// catch(MgException* e)
@@ -951,15 +951,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService.TestCase_GetDocument", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService.TestCase_GetDocument", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_GetDocument", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_GetDocument", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -1013,15 +1013,15 @@
try
- throw new MgNullReferenceException(L"TestServerAdminService.TestCase_SetDocument", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestServerAdminService.TestCase_SetDocument", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_SetDocument", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestServerAdminService.TestCase_SetDocument", __LINE__, __WFILE__, nullptr, L"", nullptr);
// Check to see if the path exists before trying to set document
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestServerManager.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestServerManager.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestServerManager.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -41,7 +41,7 @@
TEST_CASE("ValidServerManager", "[ServerManager]")
MgServerManager* pMgServerManager = MgServerManager::GetInstance();
- REQUIRE(pMgServerManager != NULL);
+ REQUIRE(pMgServerManager != nullptr);
MgServerManager* pMgServerManager2 = MgServerManager::GetInstance();
REQUIRE(pMgServerManager == pMgServerManager2);
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestServiceManager.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestServiceManager.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestServiceManager.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -17,29 +17,10 @@
#include "MapGuideCommon.h"
#include "ServiceManager.h"
-#include "TestServiceManager.h"
#include "FoundationDefs.h"
-CPPUNIT_TEST_SUITE_NAMED_REGISTRATION(TestServiceManager, "TestServiceManager");
-void TestServiceManager::setUp()
+#include "catch.hpp"
-void TestServiceManager::tearDown()
-void TestServiceManager::TestStart()
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nRunning Service Manager tests.\n")));
-void TestServiceManager::TestEnd()
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nService Manager tests completed.\n\n")));
/// Test Case Description:
@@ -46,13 +27,13 @@
/// This test case checks to see if there is a valid MgServiceManager and that
/// there is only 1 MgServiceManager.
-void TestServiceManager::TestCase_ValidServiceManager()
+TEST_CASE("ValidServiceManager", "[ServiceManager]")
MgServiceManager* pMgServiceManager = MgServiceManager::GetInstance();
- CPPUNIT_ASSERT(pMgServiceManager != NULL);
+ REQUIRE(pMgServiceManager != nullptr);
MgServiceManager* pMgServiceManager2 = MgServiceManager::GetInstance();
- CPPUNIT_ASSERT(pMgServiceManager == pMgServiceManager2);
+ REQUIRE(pMgServiceManager == pMgServiceManager2);
@@ -61,7 +42,7 @@
/// This test case tries to enable/disable services.
-void TestServiceManager::TestCase_EnableServices()
+TEST_CASE("EnableServices", "[ServiceManager]")
Ptr<MgPropertyCollection> pProperties = new MgPropertyCollection();
@@ -76,10 +57,10 @@
try
Ptr<MgService> pService = pMgServiceManager->RequestService(MgServiceType::DrawingService);
- CPPUNIT_ASSERT(pService != NULL);
+ REQUIRE(pService != nullptr);
catch(...)
- CPPUNIT_ASSERT(false);
+ REQUIRE(false);
Deleted: sandbox/jng/catch2/Server/src/UnitTesting/TestServiceManager.h
--- sandbox/jng/catch2/Server/src/UnitTesting/TestServiceManager.h 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestServiceManager.h 2020-07-13 13:04:59 UTC (rev 9659)
@@ -1,44 +0,0 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#ifndef _TESTSERVICEMANAGER_H
-#define _TESTSERVICEMANAGER_H
-#include <cppunit/extensions/HelperMacros.h>
-class TestServiceManager : public CppUnit::TestFixture
- CPPUNIT_TEST_SUITE(TestServiceManager);
- CPPUNIT_TEST(TestStart); // This must be the very first unit test
- CPPUNIT_TEST(TestCase_ValidServiceManager);
- CPPUNIT_TEST(TestCase_EnableServices);
- CPPUNIT_TEST(TestEnd); // This must be the very last unit test
- CPPUNIT_TEST_SUITE_END();
-public:
- void setUp();
- void tearDown();
- void TestStart();
- void TestEnd();
- void TestCase_ValidServiceManager();
- void TestCase_EnableServices();
-#endif // _TESTSERVICEMANAGER_H
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestSiteManager.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestSiteManager.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestSiteManager.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -37,7 +37,7 @@
TEST_CASE("ValidSiteManager", "[SiteManager]")
MgSiteManager* pMgSiteManager = MgSiteManager::GetInstance();
- REQUIRE(pMgSiteManager != NULL);
+ REQUIRE(pMgSiteManager != nullptr);
MgSiteManager* pMgSiteManager2 = MgSiteManager::GetInstance();
REQUIRE(pMgSiteManager == pMgSiteManager2);
@@ -100,7 +100,7 @@
Ptr<MgConnectionProperties> connPropsAdmin = pSiteManager->GetConnectionProperties(userInfo, MgSiteInfo::Admin, true);
// Verify that the connection properties match those in the session ID
- REQUIRE((connPropsSite != NULL && connPropsClient != NULL && connPropsAdmin != NULL));
+ REQUIRE((connPropsSite != nullptr && connPropsClient != nullptr && connPropsAdmin != nullptr));
REQUIRE(connPropsSite->GetTarget() == TEST_TARGET);
REQUIRE(connPropsSite->GetPort() == TEST_SITE_PORT);
REQUIRE(connPropsClient->GetPort() == TEST_CLIENT_PORT);
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestSiteService.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestSiteService.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestSiteService.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -54,15 +54,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_AddUser", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_AddUser", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgServerSiteService> pService = dynamic_cast<MgServerSiteService*>(serviceManager->RequestService(MgServiceType::SiteService));
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_AddUser", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_AddUser", __LINE__, __WFILE__, nullptr, L"", nullptr);
//Try to add a user with empty strings
@@ -100,15 +100,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_EnumerateUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_EnumerateUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_EnumerateUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_EnumerateUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -146,15 +146,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_UpdateUser", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_UpdateUser", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_UpdateUser", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_UpdateUser", __LINE__, __WFILE__, nullptr, L"", nullptr);
//Try to update user with empty strings
@@ -192,15 +192,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_AddGroup", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_AddGroup", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_AddGroup", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_AddGroup", __LINE__, __WFILE__, nullptr, L"", nullptr);
//Try to add an empty group name
@@ -237,23 +237,23 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_GrantGroupMembershipsToUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_GrantGroupMembershipsToUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_GrantGroupMembershipsToUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_GrantGroupMembershipsToUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgStringCollection> groupCollection = new MgStringCollection();
Ptr<MgStringCollection> userCollection = new MgStringCollection();
- REQUIRE_THROWS_MG(pService->GrantGroupMembershipsToUsers(NULL, userCollection), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->GrantGroupMembershipsToUsers(groupCollection, NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->GrantGroupMembershipsToUsers(nullptr, userCollection), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->GrantGroupMembershipsToUsers(groupCollection, nullptr), MgNullArgumentException*);
//Make both new users members of first group
groupCollection->Add(groupName1);
@@ -303,25 +303,25 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_GrantRoleMembershipsToUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_GrantRoleMembershipsToUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_GrantRoleMembershipsToUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_GrantRoleMembershipsToUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgStringCollection> roleCollection;
Ptr<MgStringCollection> userCollection;
- //Try using NULL arguments
+ //Try using nullptr arguments
roleCollection = new MgStringCollection();
- REQUIRE_THROWS_MG(pService->GrantRoleMembershipsToUsers(NULL, userCollection), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->GrantRoleMembershipsToUsers(roleCollection, NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->GrantRoleMembershipsToUsers(nullptr, userCollection), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->GrantRoleMembershipsToUsers(roleCollection, nullptr), MgNullArgumentException*);
//Try using with a user that does not exist
@@ -366,25 +366,25 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_GrantRoleMembershipsToGroups", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_GrantRoleMembershipsToGroups", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_GrantRoleMembershipsToGroups", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_GrantRoleMembershipsToGroups", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgStringCollection> groupCollection;
- REQUIRE_THROWS_MG(pService->GrantRoleMembershipsToGroups(NULL, groupCollection), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->GrantRoleMembershipsToGroups(roleCollection, NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->GrantRoleMembershipsToGroups(nullptr, groupCollection), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->GrantRoleMembershipsToGroups(roleCollection, nullptr), MgNullArgumentException*);
//Try using with a group that does not exist
@@ -429,15 +429,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_UpdateGroup", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_UpdateGroup", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_UpdateGroup", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_UpdateGroup", __LINE__, __WFILE__, nullptr, L"", nullptr);
//Try to update using an empty string for group name
@@ -478,15 +478,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_EnumerateGroups", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_EnumerateGroups", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_EnumerateGroups", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_EnumerateGroups", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -530,15 +530,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_EnumerateRoles", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_EnumerateRoles", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_EnumerateRoles", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_EnumerateRoles", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -590,23 +590,23 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_RevokeGroupMembershipsFromUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_RevokeGroupMembershipsFromUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_RevokeGroupMembershipsFromUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_RevokeGroupMembershipsFromUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
- REQUIRE_THROWS_MG(pService->RevokeGroupMembershipsFromUsers(NULL, userCollection), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->RevokeGroupMembershipsFromUsers(groupCollection, NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->RevokeGroupMembershipsFromUsers(nullptr, userCollection), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->RevokeGroupMembershipsFromUsers(groupCollection, nullptr), MgNullArgumentException*);
//Remove both new users from first group
@@ -649,25 +649,25 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_RevokeRoleMembershipsFromUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_RevokeRoleMembershipsFromUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_RevokeRoleMembershipsFromUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_RevokeRoleMembershipsFromUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
- REQUIRE_THROWS_MG(pService->RevokeRoleMembershipsFromUsers(NULL, userCollection), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->RevokeRoleMembershipsFromUsers(roleCollection, NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->RevokeRoleMembershipsFromUsers(nullptr, userCollection), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->RevokeRoleMembershipsFromUsers(roleCollection, nullptr), MgNullArgumentException*);
@@ -712,25 +712,25 @@
try
MgServiceManager* serviceManager = MgServiceManager::GetInstance();
- throw new MgNullReferenceException(L"TestSiteService.TestCase_RevokeRoleMembershipsFromGroups", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_RevokeRoleMembershipsFromGroups", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_RevokeRoleMembershipsFromGroups", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_RevokeRoleMembershipsFromGroups", __LINE__, __WFILE__, nullptr, L"", nullptr);
- REQUIRE_THROWS_MG(pService->RevokeRoleMembershipsFromGroups(NULL, groupCollection), MgNullArgumentException*);
- REQUIRE_THROWS_MG(pService->RevokeRoleMembershipsFromGroups(roleCollection, NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->RevokeRoleMembershipsFromGroups(nullptr, groupCollection), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->RevokeRoleMembershipsFromGroups(roleCollection, nullptr), MgNullArgumentException*);
@@ -775,19 +775,19 @@
try
- if(serviceManager == 0)
+ if (serviceManager == nullptr)
- throw new MgNullReferenceException(L"TestSiteService.TestCase_DeleteUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_DeleteUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
- if (pService == 0)
+ if (pService == nullptr)
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_DeleteUsers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_DeleteUsers", __LINE__, __WFILE__, nullptr, L"", nullptr);
- //Try using a NULL argument
- REQUIRE_THROWS_MG(pService->DeleteUsers(NULL), MgNullArgumentException*);
+ //Try using a nullptr argument
+ REQUIRE_THROWS_MG(pService->DeleteUsers(nullptr), MgNullArgumentException*);
//Delete the two users added earlier
MgStringCollection userCollection;
@@ -821,19 +821,19 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_DeleteGroups", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_DeleteGroups", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_DeleteGroups", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_DeleteGroups", __LINE__, __WFILE__, nullptr, L"", nullptr);
- REQUIRE_THROWS_MG(pService->DeleteGroups(NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(pService->DeleteGroups(nullptr), MgNullArgumentException*);
MgStringCollection groupCollection;
groupCollection.Add(groupName1);
@@ -869,15 +869,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_AddServer", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_AddServer", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_AddServer", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_AddServer", __LINE__, __WFILE__, nullptr, L"", nullptr);
//Try using empty string arguments
@@ -928,15 +928,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_EnumerateServers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_EnumerateServers", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_EnumerateServers", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_EnumerateServers", __LINE__, __WFILE__, nullptr, L"", nullptr);
@@ -970,15 +970,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_UpdateServer", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_UpdateServer", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_UpdateServer", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_UpdateServer", __LINE__, __WFILE__, nullptr, L"", nullptr);
// Disable ACE's ERROR message for the server name
@@ -1032,15 +1032,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_RemoveServer", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_RemoveServer", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_RemoveServer", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_RemoveServer", __LINE__, __WFILE__, nullptr, L"", nullptr);
//Delete the servers that were added earlier
@@ -1073,22 +1073,22 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_Authenticate", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_Authenticate", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_Authenticate", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_Authenticate", __LINE__, __WFILE__, nullptr, L"", nullptr);
Ptr<MgUserInformation> userInfo;
- //Try to use a NULL argument
- REQUIRE_THROWS_MG(pService->Authenticate(NULL, NULL, false), MgAuthenticationFailedException*);
+ //Try to use a nullptr argument
+ REQUIRE_THROWS_MG(pService->Authenticate(nullptr, nullptr, false), MgAuthenticationFailedException*);
//Try to authenticate an anonymous user when admin role is needed
@@ -1098,11 +1098,11 @@
//Try to authenticate when an incorrect password is given
userInfo = new MgUserInformation(adminName, L"");
- REQUIRE_THROWS_MG(pService->Authenticate(userInfo, NULL, false), MgAuthenticationFailedException*);
+ REQUIRE_THROWS_MG(pService->Authenticate(userInfo, nullptr, false), MgAuthenticationFailedException*);
//Authenticate an anonymous user that has appropriate access
- pService->Authenticate(userInfo, NULL, false);
+ pService->Authenticate(userInfo, nullptr, false);
@@ -1139,23 +1139,23 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_CreateSession", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_CreateSession", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_CreateSession", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_CreateSession", __LINE__, __WFILE__, nullptr, L"", nullptr);
//Sets the user information for the current thread to be anonymous
- MgUserInformation::SetCurrentUserInfo(NULL);
+ MgUserInformation::SetCurrentUserInfo(nullptr);
- if (userInfo != NULL)
+ if (userInfo != nullptr)
userInfo->SetLocale(userLocale);
MgUserInformation::SetCurrentUserInfo(userInfo);
@@ -1187,23 +1187,23 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_DestroySession", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_DestroySession", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_DestroySession", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_DestroySession", __LINE__, __WFILE__, nullptr, L"", nullptr);
//Sets the user information for the current thread to be administrator
userInfo = new MgUserInformation(adminName, adminPass);
@@ -1214,9 +1214,9 @@
REQUIRE_THROWS_MG(pService->DestroySession(session), MgRepositoryNotFoundException*);
userInfo = new MgUserInformation(L"", L"");
@@ -1246,15 +1246,15 @@
try
- throw new MgNullReferenceException(L"TestSiteService.TestCase_GetSessionTimeout", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullReferenceException(L"TestSiteService.TestCase_GetSessionTimeout", __LINE__, __WFILE__, nullptr, L"", nullptr);
- throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_GetSessionTimeout", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestSiteService.TestCase_GetSessionTimeout", __LINE__, __WFILE__, nullptr, L"", nullptr);
INT32 timeoutValue = pService->GetSessionTimeout();
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestTileService.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestTileService.cpp 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestTileService.cpp 2020-07-13 13:04:59 UTC (rev 9659)
@@ -17,13 +17,15 @@
#include "SAX2Parser.h"
-#include "TestTileService.h"
-#include "../UnitTesting/CppUnitExtensions.h"
#include "ServerSiteService.h"
-#include "../Common/Manager/FdoConnectionManager.h"
#include "ServerRenderingService.h"
+#include "CatchHelperMacros.h"
+#include "TestServiceFactory.h"
#define PATH_LEN 512
// determines the number of requests to make, as a factor of the number of tiles
@@ -38,255 +40,322 @@
static const INT32 MG_TEST_THREADS = 4;
-const STRING TEST_LOCALE = L"en";
-CPPUNIT_TEST_SUITE_NAMED_REGISTRATION(TestTileService, "TestTileService");
-TestTileService::TestTileService()
+/// Helpers
+static MgMap* CreateMap(MgSiteConnection* m_siteConnection, CREFSTRING mapName = L"")
- // store references to the various services we use
- MgServiceManager* serviceMan = MgServiceManager::GetInstance();
- assert(NULL != serviceMan);
+ // set a default name if not supplied
+ STRING name = (mapName.empty()) ? L"UnitTestBaseMap" : mapName;
- m_svcResource = dynamic_cast<MgResourceService*>(serviceMan->RequestService(MgServiceType::ResourceService));
- assert(m_svcResource != NULL);
+ // make a runtime map
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/BaseMap.MapDefinition");
+ MgMap* map = new MgMap(m_siteConnection);
+ map->Create(mdfres, name);
- m_svcTile = dynamic_cast<MgTileService*>(serviceMan->RequestService(MgServiceType::TileService));
- assert(m_svcTile != NULL);
+ // set the view
+ Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.723636, 43.715015);
+ Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
+ map->SetViewCenter(ptNewCenter);
+ map->SetDisplayDpi(96);
+ map->SetDisplayWidth(1024);
+ map->SetDisplayHeight(1024);
- // Initialize a site connection.
- Ptr<MgServerSiteService> svcSite = dynamic_cast<MgServerSiteService*>(
- serviceMan->RequestService(MgServiceType::SiteService));
- assert(svcSite != NULL);
+ // render at a scale of 1:12500
+ map->SetViewScale(12500.0);
- Ptr<MgUserInformation> userInfo = new MgUserInformation(
- L"Administrator", L"admin");
- userInfo->SetLocale(TEST_LOCALE);
+ return map;
- // Set the current MgUserInformation
- // This must be done before calling CreateSession()
- MgUserInformation::SetCurrentUserInfo(userInfo);
+static MgMap* CreateMapLinked(MgSiteConnection* m_siteConnection, CREFSTRING mapName = L"")
+ STRING name = (mapName.empty()) ? L"UnitTestBaseMapLinked" : mapName;
- STRING session = svcSite->CreateSession();
- assert(!session.empty());
- userInfo->SetMgSessionId(session);
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
+ // set the view
- m_siteConnection = new MgSiteConnection();
- m_siteConnection->Open(userInfo);
-TestTileService::~TestTileService()
+ return map;
-void TestTileService::setUp()
+static MgMap* CreateMapLinked2(MgSiteConnection* m_siteConnection, CREFSTRING mapName = L"", CREFSTRING ovCsWkt = L"")
+ // Parse the Map Definition and modify it so it matches its linked tile set
+ Ptr<MgResourceService> resSvc = dynamic_cast<MgResourceService*>(m_siteConnection->CreateService(MgServiceType::ResourceService));
-void TestTileService::tearDown()
+ MdfModel::MapDefinition* mdf = MgMapBase::GetMapDefinition(resSvc, mdfres);
+ MdfModel::TileSetSource* tsRef = mdf->GetTileSetSource();
+ Ptr<MgResourceIdentifier> tileSetId = new MgResourceIdentifier(tsRef->GetResourceId());
+ Ptr<MgByteReader> reader = resSvc->GetResourceContent(tileSetId);
+ Ptr<MgByteSink> sink = new MgByteSink(reader);
+ Ptr<MgByte> bytes = sink->ToBuffer();
-void TestTileService::TestStart()
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nRunning Tile Service tests.\n")));
+ MdfParser::SAX2Parser parser;
+ parser.ParseString((const char*)bytes->Bytes(), bytes->GetLength());
- try
+ REQUIRE(parser.GetSucceeded());
+ MdfModel::TileSetDefinition* tsd = parser.DetachTileSetDefinition();
+ // Update coordinate systems to match
+ STRING csWkt;
+ MdfModel::NameStringPairCollection* params = tsd->GetTileStoreParameters()->GetParameters();
+ for (INT32 i = 0; i < params->GetCount(); i++)
- #ifdef _DEBUG
- MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
- if(pFdoConnectionManager)
+ MdfModel::NameStringPair* pair = params->GetAt(i);
+ if (pair->GetName() == L"CoordinateSystem")
- pFdoConnectionManager->ShowCache();
+ csWkt = pair->GetValue();
+ mdf->SetCoordinateSystem(csWkt);
+ break;
- #endif
- // set user info
- Ptr<MgUserInformation> userInfo = new MgUserInformation(L"Administrator", L"admin");
+ if (!ovCsWkt.empty())
+ mdf->SetCoordinateSystem(ovCsWkt);
- // base map source data
+ // Fix up extents too
+ mdf->SetExtents(tsd->GetExtents());
- // publish the map definition
- Ptr<MgResourceIdentifier> mapres1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/BaseMap.MapDefinition");
- Ptr<MgByteSource> mdfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap.mdf", false);
- Ptr<MgByteReader> mdfrdr1 = mdfsrc1->GetReader();
- m_svcResource->SetResource(mapres1, mdfrdr1, NULL);
+ // Save back out to XML
+ MdfModel::Version ver(3, 0, 0);
+ std::string mbXml = parser.SerializeToXML(mdf, &ver);
+ Ptr<MgByteSource> source = new MgByteSource((BYTE_ARRAY_IN)mbXml.c_str(), (INT32)mbXml.length());
+ Ptr<MgByteReader> content = source->GetReader();
+ mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet2.MapDefinition");
+ resSvc->SetResource(mdfres, content, nullptr);
- Ptr<MgResourceIdentifier> mapres2 = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
- Ptr<MgByteSource> mdfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_LinkedTileSet.mdf", false);
- Ptr<MgByteReader> mdfrdr2 = mdfsrc2->GetReader();
- m_svcResource->SetResource(mapres2, mdfrdr2, NULL);
+ // make a runtime map from our changed map definition
- Ptr<MgResourceIdentifier> tilesetres1 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition");
- Ptr<MgByteSource> tsdsrc1 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap.tsd", false);
- Ptr<MgByteReader> tsdrdr1 = tsdsrc1->GetReader();
- m_svcResource->SetResource(tilesetres1, tsdrdr1, NULL);
+ // set the view
- Ptr<MgResourceIdentifier> tilesetres2 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ.TileSetDefinition");
- Ptr<MgByteSource> tsdsrc2 = new MgByteSource(L"../UnitTestFiles/UT_XYZ.tsd", false);
- Ptr<MgByteReader> tsdrdr2 = tsdsrc2->GetReader();
- m_svcResource->SetResource(tilesetres2, tsdrdr2, NULL);
- Ptr<MgResourceIdentifier> tilesetres3 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan_Metatiled.TileSetDefinition");
- Ptr<MgByteSource> tsdsrc3 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap_Metatiled.tsd", false);
- Ptr<MgByteReader> tsdrdr3 = tsdsrc3->GetReader();
- m_svcResource->SetResource(tilesetres3, tsdrdr3, NULL);
+ return map;
- Ptr<MgResourceIdentifier> tilesetres4 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ_Metatiled.TileSetDefinition");
- Ptr<MgByteSource> tsdsrc4 = new MgByteSource(L"../UnitTestFiles/UT_XYZ_Metatiled.tsd", false);
- Ptr<MgByteReader> tsdrdr4 = tsdsrc4->GetReader();
- m_svcResource->SetResource(tilesetres4, tsdrdr4, NULL);
+// returns a random integer in the range 0 to n-1
+static INT32 Rand(INT32 n)
+ double numer = (double)rand() + 0.5;
+ double denom = (double)RAND_MAX + 1.0;
+ return (INT32)(numer / denom * n);
- Ptr<MgResourceIdentifier> tilesetres5 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan_OrigSize.TileSetDefinition");
- Ptr<MgByteSource> tsdsrc5 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap_OrigSize.tsd", false);
- Ptr<MgByteReader> tsdrdr5 = tsdsrc5->GetReader();
- m_svcResource->SetResource(tilesetres5, tsdrdr5, NULL);
+// data structure which is passed to each thread
+struct TileThreadData
+ INT32 threadId;
+ bool done;
+ bool saveTile;
+ Ptr<MgMap> map;
+ INT32 tileRow;
+ INT32 tileCol;
+ INT32 tileScale;
+ STRING tileSetId;
- // publish the layer definitions
- Ptr<MgResourceIdentifier> ldfres1 = new MgResourceIdentifier(L"Library://UnitTests/Layers/RoadCenterLines.LayerDefinition");
- Ptr<MgByteSource> ldfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_RoadCenterLines.ldf", false);
- Ptr<MgByteReader> ldfrdr1 = ldfsrc1->GetReader();
- m_svcResource->SetResource(ldfres1, ldfrdr1, NULL);
+// the method which gets executed by the ACE worker thread
+static ACE_THR_FUNC_RETURN GetTileWorker(void* param)
+ // get the data for this thread
+ TileThreadData* threadData = (TileThreadData*)param;
+ INT32 threadId = threadData->threadId;
+ INT32 tileRow = threadData->tileRow;
+ INT32 tileCol = threadData->tileCol;
+ bool saveTile = threadData->saveTile;
+ Ptr<MgMap> map = threadData->map;
+ #ifdef _DEBUG
+ printf("> thread %d started, tile %d,%d\n", threadId, tileRow, tileCol);
+ #endif
- Ptr<MgResourceIdentifier> ldfres2 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
- Ptr<MgByteSource> ldfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.ldf", false);
- Ptr<MgByteReader> ldfrdr2 = ldfsrc2->GetReader();
- m_svcResource->SetResource(ldfres2, ldfrdr2, NULL);
+ try
+ // set user info
+ Ptr<MgUserInformation> userInfo = new MgUserInformation(L"Administrator", L"admin");
+ userInfo->SetLocale(TestServiceFactory::TEST_LOCALE);
+ MgUserInformation::SetCurrentUserInfo(userInfo);
- Ptr<MgResourceIdentifier> ldfres3 = new MgResourceIdentifier(L"Library://UnitTests/Layers/VotingDistricts.LayerDefinition");
- Ptr<MgByteSource> ldfsrc3 = new MgByteSource(L"../UnitTestFiles/UT_VotingDistricts.ldf", false);
- Ptr<MgByteReader> ldfrdr3 = ldfsrc3->GetReader();
- m_svcResource->SetResource(ldfres3, ldfrdr3, NULL);
+ // get the tile service instance
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ Ptr<MgTileService> svcTile = dynamic_cast<MgTileService*>(
+ serviceManager->RequestService(MgServiceType::TileService));
+ assert(svcTile != nullptr);
- // publish the feature sources
- Ptr<MgResourceIdentifier> fsres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/RoadCenterLines.FeatureSource");
- Ptr<MgByteSource> fssrc1 = new MgByteSource(L"../UnitTestFiles/UT_RoadCenterLines.fs", false);
- Ptr<MgByteReader> fsrdr1 = fssrc1->GetReader();
- m_svcResource->SetResource(fsres1, fsrdr1, NULL);
+ // get the tile
+ Ptr<MgByteReader> img = svcTile->GetTile(map, L"BaseLayers", tileCol, tileRow);
- Ptr<MgResourceIdentifier> fsres2 = new MgResourceIdentifier(L"Library://UnitTests/Data/Parcels.FeatureSource");
- Ptr<MgByteSource> fssrc2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.fs", false);
- Ptr<MgByteReader> fsrdr2 = fssrc2->GetReader();
- m_svcResource->SetResource(fsres2, fsrdr2, NULL);
+ // save the image to a file if necessary
+ if (saveTile)
+ wchar_t imgName[PATH_LEN] = { 0 };
+ swprintf(imgName, PATH_LEN, L"./temp_tiles/tile%d_%d.png", tileRow, tileCol);
+ (MgByteSink(img)).ToFile(imgName);
- Ptr<MgResourceIdentifier> fsres3 = new MgResourceIdentifier(L"Library://UnitTests/Data/VotingDistricts.FeatureSource");
- Ptr<MgByteSource> fssrc3 = new MgByteSource(L"../UnitTestFiles/UT_VotingDistricts.fs", false);
- Ptr<MgByteReader> fsrdr3 = fssrc3->GetReader();
- m_svcResource->SetResource(fsres3, fsrdr3, NULL);
- // publish the resource data
- Ptr<MgByteSource> dataSource1 = new MgByteSource(L"../UnitTestFiles/UT_RoadCenterLines.sdf", false);
- Ptr<MgByteReader> dataReader1 = dataSource1->GetReader();
- m_svcResource->SetResourceData(fsres1, L"UT_RoadCenterLines.sdf", L"File", dataReader1);
- Ptr<MgByteSource> dataSource2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.sdf", false);
- Ptr<MgByteReader> dataReader2 = dataSource2->GetReader();
- m_svcResource->SetResourceData(fsres2, L"UT_Parcels.sdf", L"File", dataReader2);
- Ptr<MgByteSource> dataSource3 = new MgByteSource(L"../UnitTestFiles/UT_VotingDistricts.sdf", false);
- Ptr<MgByteReader> dataReader3 = dataSource3->GetReader();
- m_svcResource->SetResourceData(fsres3, L"UT_VotingDistricts.sdf", L"File", dataReader3);
- // set up temporary directory for tile images
- MgFileUtil::CreateDirectory(L"./temp_tiles", false);
- MgFileUtil::CreateDirectory(L"../UnitTestFiles/TileCaches", false);
+ // clear the user info to prevent leaks
catch (MgException* e)
- STRING message = e->GetDetails(TEST_LOCALE);
+ STRING message = e->GetDetails(TestServiceFactory::TEST_LOCALE);
SAFE_RELEASE(e);
- CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
catch (...)
throw;
+ #ifdef _DEBUG
+// printf("> thread %d done\n", threadId);
+ #endif
+ threadData->done = true;
+ return 0;
+static ACE_THR_FUNC_RETURN GetTileLinkedWorker(void* param)
+ INT32 tileScale = threadData->tileScale;
+ Ptr<MgResourceIdentifier> tsId = new MgResourceIdentifier(threadData->tileSetId);
+#ifdef _DEBUG
+#endif
-void TestTileService::TestEnd()
try
// set user info
- // delete the map definition
- m_svcResource->DeleteResource(mapres1);
+ // get the tile
+ Ptr<MgByteReader> img = svcTile->GetTile(tsId, L"BaseLayers", tileCol, tileRow, tileScale);
+ CHECKNULL((MgByteReader*)img, L"GetTileLinkedWorker");
- m_svcResource->DeleteResource(mapres2);
+ if (saveTile)
- m_svcResource->DeleteResource(tilesetres1);
+ catch (MgException* e)
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
- m_svcResource->DeleteResource(tilesetres2);
+#ifdef _DEBUG
+ // printf("> thread %d done\n", threadId);
+#endif
- m_svcResource->DeleteResource(tilesetres3);
+ return 0;
- m_svcResource->DeleteResource(tilesetres4);
+static ACE_THR_FUNC_RETURN SetTileWorker(void* param)
+#ifdef _DEBUG
+#endif
- m_svcResource->DeleteResource(tilesetres5);
+ try
+ // set user info
- // delete the layer definitions
- m_svcResource->DeleteResource(ldfres1);
- m_svcResource->DeleteResource(ldfres2);
+ // find the finite display scale closest to the requested map scale
+ double scale = map->GetViewScale();
+ INT32 scaleIndex = map->FindNearestFiniteDisplayScaleIndex(scale);
- m_svcResource->DeleteResource(ldfres3);
+ // read the image which we saved earlier
+ Ptr<MgByteSource> bs = new MgByteSource(imgName);
+ Ptr<MgByteReader> img = bs->GetReader();
- // delete the feature sources
- m_svcResource->DeleteResource(fsres1);
+ // set the tile in the cache
+ svcTile->SetTile(img, map, scaleIndex, L"BaseLayers", tileCol, tileRow);
- m_svcResource->DeleteResource(fsres2);
- m_svcResource->DeleteResource(fsres3);
- // remove temporary directory for tile images
- MgFileUtil::DeleteDirectory(L"./temp_tiles", true, false);
- #ifdef _DEBUG
- #endif
+ catch (MgFileIoException* e)
+ // we sometimes get this due to a sharing error
+ SAFE_RELEASE(e);
SAFE_RELEASE(e);
catch (...)
@@ -293,48 +362,34 @@
throw;
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nTile Service tests completed.\n\n")));
+#ifdef _DEBUG
+#endif
+ return 0;
-// data structure which is passed to each thread
-struct TileThreadData
- INT32 threadId;
- bool done;
- bool saveTile;
- Ptr<MgMap> map;
- INT32 tileRow;
- INT32 tileCol;
- INT32 tileScale;
- STRING tileSetId;
-/// GetTile methods
-ACE_THR_FUNC_RETURN GetTileWorker(void* param)
+static ACE_THR_FUNC_RETURN GetTileXYZWorker(void* param)
- INT32 tileRow = threadData->tileRow;
- INT32 tileCol = threadData->tileCol;
- bool saveTile = threadData->saveTile;
- Ptr<MgMap> map = threadData->map;
- #ifdef _DEBUG
+#ifdef _DEBUG
- #endif
+#endif
try
// set user info
@@ -341,10 +396,11 @@
- assert(svcTile != NULL);
// get the tile
- Ptr<MgByteReader> img = svcTile->GetTile(map, L"BaseLayers", tileCol, tileRow);
+ CHECKNULL((MgByteReader*)img, L"GetTileXYZWorker");
if (saveTile)
@@ -355,13 +411,13 @@
SAFE_RELEASE(e);
catch (...)
@@ -368,17 +424,22 @@
throw;
- #ifdef _DEBUG
-// printf("> thread %d done\n", threadId);
- #endif
+#ifdef _DEBUG
+#endif
return 0;
+/// GetTile methods
+TEST_CASE("GetTile", "[TileService]")
+ Ptr<MgServerSiteService> svcSite = TestServiceFactory::CreateSiteService();
+ Ptr<MgSiteConnection> m_siteConnection = TestServiceFactory::CreateSiteConnection(svcSite);
-void TestTileService::TestCase_GetTile()
// specify the number of threads to use
const INT32 numThreads = MG_TEST_THREADS;
TileThreadData threadData[numThreads];
@@ -395,7 +456,7 @@
ACE_Thread_Manager* manager = ACE_Thread_Manager::instance();
// make the runtime map
- Ptr<MgMap> map = CreateMap();
+ Ptr<MgMap> map = CreateMap(m_siteConnection);
// set up the tile indices
INT32 numTileRows = tileRowMax - tileRowMin + 1;
@@ -464,7 +525,7 @@
threadData[i].tileCol = tileCols[nTile];
- int thid = manager->spawn(ACE_THR_FUNC(GetTileWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
+ int thid = manager->spawn(ACE_THR_FUNC(GetTileWorker), &threadData[i], 0, nullptr, nullptr, 0, THREAD_GROUP);
nRequest++;
@@ -498,9 +559,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -508,70 +569,11 @@
-// the method which gets executed by the ACE worker thread
-ACE_THR_FUNC_RETURN GetTileLinkedWorker(void* param)
+TEST_CASE("GetTileLinked", "[TileService]")
- // get the data for this thread
- TileThreadData* threadData = (TileThreadData*)param;
- INT32 threadId = threadData->threadId;
- INT32 tileScale = threadData->tileScale;
- Ptr<MgResourceIdentifier> tsId = new MgResourceIdentifier(threadData->tileSetId);
- #ifdef _DEBUG
- printf("> thread %d started, tile %d,%d\n", threadId, tileRow, tileCol);
- #endif
- try
- // set user info
- // get the tile service instance
- MgServiceManager* serviceManager = MgServiceManager::GetInstance();
- Ptr<MgTileService> svcTile = dynamic_cast<MgTileService*>(
- serviceManager->RequestService(MgServiceType::TileService));
- // get the tile
- Ptr<MgByteReader> img = svcTile->GetTile(tsId, L"BaseLayers", tileCol, tileRow, tileScale);
- CHECKNULL((MgByteReader*)img, L"GetTileLinkedWorker");
- // save the image to a file if necessary
- if (saveTile)
- wchar_t imgName[PATH_LEN] = { 0 };
- swprintf(imgName, PATH_LEN, L"./temp_tiles/tile%d_%d.png", tileRow, tileCol);
- (MgByteSink(img)).ToFile(imgName);
- // clear the user info to prevent leaks
- catch (MgException* e)
- SAFE_RELEASE(e);
- catch (...)
- throw;
- #ifdef _DEBUG
- #endif
- threadData->done = true;
- return 0;
-void TestTileService::TestCase_GetTileLinked()
@@ -588,7 +590,7 @@
- Ptr<MgMap> map = CreateMapLinked();
+ Ptr<MgMap> map = CreateMapLinked(m_siteConnection);
Ptr<MgResourceIdentifier> tsId;
Ptr<MgLayerGroupCollection> groups = map->GetLayerGroups();
Ptr<MgLayerGroup> group = groups->GetItem(L"BaseLayers");
@@ -656,7 +658,7 @@
- int thid = manager->spawn(ACE_THR_FUNC(GetTileLinkedWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
+ int thid = manager->spawn(ACE_THR_FUNC(GetTileLinkedWorker), &threadData[i], 0, nullptr, nullptr, 0, THREAD_GROUP);
nRequest++;
@@ -690,9 +692,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -703,77 +705,11 @@
/// SetTile methods
-ACE_THR_FUNC_RETURN SetTileWorker(void* param)
+TEST_CASE("SetTile", "[TileService]")
- #ifdef _DEBUG
- #endif
- try
- // set user info
- // find the finite display scale closest to the requested map scale
- double scale = map->GetViewScale();
- INT32 scaleIndex = map->FindNearestFiniteDisplayScaleIndex(scale);
- // read the image which we saved earlier
- Ptr<MgByteSource> bs = new MgByteSource(imgName);
- Ptr<MgByteReader> img = bs->GetReader();
- // set the tile in the cache
- svcTile->SetTile(img, map, scaleIndex, L"BaseLayers", tileCol, tileRow);
- catch (MgFileIoException* e)
- // we sometimes get this due to a sharing error
- SAFE_RELEASE(e);
- SAFE_RELEASE(e);
- catch (...)
- throw;
- #ifdef _DEBUG
- #endif
- return 0;
-void TestTileService::TestCase_SetTile()
@@ -790,7 +726,7 @@
@@ -850,7 +786,7 @@
threadData[i].tileCol = tileCols[nRequest];
- int thid = manager->spawn(ACE_THR_FUNC(SetTileWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
+ int thid = manager->spawn(ACE_THR_FUNC(SetTileWorker), &threadData[i], 0, nullptr, nullptr, 0, THREAD_GROUP);
nRequest++;
@@ -913,7 +849,7 @@
nRequest++;
@@ -947,9 +883,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -961,10 +897,11 @@
/// GetSetTile methods
+TEST_CASE("GetSetTile", "[TileService]")
-void TestTileService::TestCase_GetSetTile()
@@ -981,7 +918,7 @@
@@ -1046,9 +983,9 @@
// spawn a new thread - 75% of the calls are gets, 25% are sets
int thid;
if ((double)rand() < 0.75 * (double)RAND_MAX)
- thid = manager->spawn(ACE_THR_FUNC(GetTileWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
+ thid = manager->spawn(ACE_THR_FUNC(GetTileWorker), &threadData[i], 0, nullptr, nullptr, 0, THREAD_GROUP);
else
- thid = manager->spawn(ACE_THR_FUNC(SetTileWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
+ thid = manager->spawn(ACE_THR_FUNC(SetTileWorker), &threadData[i], 0, nullptr, nullptr, 0, THREAD_GROUP);
nRequest++;
@@ -1082,9 +1019,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1095,21 +1032,23 @@
/// ClearCache methods
-void TestTileService::TestCase_ClearCache()
+TEST_CASE("ClearCache", "[TileService]")
try
- // call the API with a NULL argument
- CPPUNIT_ASSERT_THROW_MG(m_svcTile->ClearCache((MgMap*)NULL), MgNullArgumentException*);
+ Ptr<MgTileService> m_svcTile = TestServiceFactory::CreateTileService();
+ // call the API with a nullptr argument
+ REQUIRE_THROWS_MG(m_svcTile->ClearCache((MgMap*)nullptr), MgNullArgumentException*);
// call the API with a map having a different name
- Ptr<MgMap> map = CreateMap(L"blah");
+ Ptr<MgMap> map = CreateMap(m_siteConnection, L"blah");
m_svcTile->ClearCache(map);
// call the API with the run time map
- map = CreateMap();
+ map = CreateMap(m_siteConnection);
// call the API again on the same map
@@ -1117,9 +1056,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1127,71 +1066,11 @@
-ACE_THR_FUNC_RETURN GetTileXYZWorker(void* param)
+TEST_CASE("GetTileXYZ", "[TileService]")
- #ifdef _DEBUG
- #endif
- try
- // set user info
- // get the tile
- CHECKNULL((MgByteReader*)img, L"GetTileXYZWorker");
- if (saveTile)
- SAFE_RELEASE(e);
- catch (...)
- throw;
- #ifdef _DEBUG
- #endif
- return 0;
-void TestTileService::TestCase_GetTileXYZ()
@@ -1208,7 +1087,7 @@
@@ -1271,7 +1150,7 @@
- int thid = manager->spawn(ACE_THR_FUNC(GetTileXYZWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
+ int thid = manager->spawn(ACE_THR_FUNC(GetTileXYZWorker), &threadData[i], 0, nullptr, nullptr, 0, THREAD_GROUP);
nRequest++;
@@ -1305,9 +1184,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1315,22 +1194,23 @@
-void TestTileService::TestCase_ClearCacheLinked()
+TEST_CASE("ClearCacheLinked", "[TileService]")
try
- CPPUNIT_ASSERT_THROW_MG(m_svcTile->ClearCache((MgResourceIdentifier*)NULL), MgNullArgumentException*);
+ REQUIRE_THROWS_MG(m_svcTile->ClearCache((MgResourceIdentifier*)nullptr), MgNullArgumentException*);
Ptr<MgResourceIdentifier> tsId = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition");
m_svcTile->ClearCache(tsId);
SAFE_RELEASE(e);
catch (...)
@@ -1338,42 +1218,43 @@
-void TestTileService::TestCase_MgMap_Inline()
+TEST_CASE("MgMap_Inline", "[TileService]")
try
STRING mapName = L"TestCase_MgMap_Inline";
- Ptr<MgMap> map = CreateMap(mapName);
+ Ptr<MgMap> map = CreateMap(m_siteConnection, mapName);
Ptr<MgEnvelope> extents = map->GetMapExtent();
Ptr<MgCoordinate> ll = extents->GetLowerLeftCoordinate();
Ptr<MgCoordinate> ur = extents->GetUpperRightCoordinate();
- CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.79786601383196, ll->GetX(), 0.00000000000001);
- CPPUNIT_ASSERT_DOUBLES_EQUAL( 43.686857862181, ll->GetY(), 0.000000000001);
- CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.66452777186925, ur->GetX(), 0.00000000000001);
- CPPUNIT_ASSERT_DOUBLES_EQUAL( 43.8037962206133, ur->GetY(), 0.0000000000001);
+ REQUIRE(Approx(-87.79786601383196) == ll->GetX());
+ REQUIRE(Approx(43.686857862181) == ll->GetY());
+ REQUIRE(Approx(-87.66452777186925) == ur->GetX());
+ REQUIRE(Approx(43.8037962206133) == ur->GetY());
Ptr<MgResourceIdentifier> tsId = map->GetTileSetDefinition();
- CPPUNIT_ASSERT(NULL == (MgResourceIdentifier*)tsId);
+ REQUIRE(nullptr == (MgResourceIdentifier*)tsId);
for (INT32 i = 0; i < groups->GetCount(); i++)
Ptr<MgLayerGroup> group = groups->GetItem(i);
- CPPUNIT_ASSERT(MgLayerGroupType::BaseMap == group->GetLayerGroupType());
+ REQUIRE(MgLayerGroupType::BaseMap == group->GetLayerGroupType());
// Initialize service objects.
- Ptr<MgServerSiteService> svcSite = dynamic_cast<MgServerSiteService*>(serviceManager->RequestService(MgServiceType::SiteService));
Ptr<MgResourceService> svcRes = dynamic_cast<MgResourceService*>(serviceManager->RequestService(MgServiceType::ResourceService));
- assert(svcRes != NULL);
+ assert(svcSite.p != nullptr);
+ assert(svcRes.p != nullptr);
@@ -1380,7 +1261,7 @@
Ptr<MgResourceIdentifier> mapStateId = new MgResourceIdentifier(MgRepositoryType::Session, session, L"", map->GetName(), MgResourceType::Map);
map->Save(svcRes, mapStateId);
- map = NULL;
+ map = nullptr;
Ptr<MgSiteConnection> siteConn = new MgSiteConnection();
userInfo = new MgUserInformation(session);
@@ -1392,18 +1273,18 @@
svcSite->DestroySession(session);
@@ -1410,9 +1291,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1420,43 +1301,45 @@
-void TestTileService::TestCase_MgMap_Linked()
+TEST_CASE("MgMap_Linked", "[TileService]")
try
STRING mapName = L"TestCase_MgMap_Linked";
- Ptr<MgMap> map = CreateMapLinked(mapName);
+ Ptr<MgMap> map = CreateMapLinked(m_siteConnection, mapName);
//Bounds should be that of the tile set
- CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.797866013831, ll->GetX(), 0.000000000001);
- CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.664527771869, ur->GetX(), 0.000000000001);
- CPPUNIT_ASSERT_DOUBLES_EQUAL( 43.803796220613, ur->GetY(), 0.000000000001);
+ REQUIRE(Approx(-87.797866013831) == ll->GetX());
+ REQUIRE(Approx(-87.664527771869) == ur->GetX());
+ REQUIRE(Approx(43.803796220613) == ur->GetY());
- CPPUNIT_ASSERT(NULL != (MgResourceIdentifier*)tsId);
- CPPUNIT_ASSERT(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition" == tsId->ToString());
+ REQUIRE(nullptr != (MgResourceIdentifier*)tsId);
+ REQUIRE(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition" == tsId->ToString());
- CPPUNIT_ASSERT(MgLayerGroupType::BaseMapFromTileSet == group->GetLayerGroupType());
+ REQUIRE(MgLayerGroupType::BaseMapFromTileSet == group->GetLayerGroupType());
@@ -1463,7 +1346,7 @@
- map = NULL;
+ map = nullptr;
@@ -1475,19 +1358,19 @@
@@ -1494,9 +1377,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1504,46 +1387,48 @@
-void TestTileService::TestCase_MgMap_LinkedSameCS()
+TEST_CASE("MgMap_LinkedSameCS", "[TileService]")
try
- Ptr<MgMap> map = CreateMapLinked2(mapName);
+ Ptr<MgMap> map = CreateMapLinked2(m_siteConnection, mapName);
- CPPUNIT_ASSERT(NULL != extents.p);
+ REQUIRE(nullptr != extents.p);
Ptr<MgEnvelope> dataExtents = map->GetDataExtent();
- CPPUNIT_ASSERT(NULL != dataExtents.p);
+ REQUIRE(nullptr != dataExtents.p);
- CPPUNIT_ASSERT_DOUBLES_EQUAL(43.686857862181, ll->GetY(), 0.000000000001);
- CPPUNIT_ASSERT_DOUBLES_EQUAL(43.803796220613, ur->GetY(), 0.000000000001);
@@ -1550,7 +1435,7 @@
- map = NULL;
+ map = nullptr;
@@ -1562,19 +1447,19 @@
@@ -1581,9 +1466,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1591,22 +1476,26 @@
-void TestTileService::TestCase_MgMapFromXYZTileSetLoose()
+TEST_CASE("MgMapFromXYZTileSetLoose", "[TileService]")
try
+ Ptr<MgResourceService> m_svcResource = TestServiceFactory::CreateResourceService();
Ptr<MgResourceIdentifier> tsdres = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ.TileSetDefinition");
map->Create(m_svcResource, tsdres, L"XYZTileSet");
- CPPUNIT_ASSERT(0 == map->GetFiniteDisplayScaleCount());
+ REQUIRE(0 == map->GetFiniteDisplayScaleCount());
SAFE_RELEASE(e);
catch (...)
@@ -1614,10 +1503,13 @@
-void TestTileService::TestCase_MgMapFromTileSet()
+TEST_CASE("MgMapFromTileSet", "[TileService]")
try
STRING mapName = L"TestCase_MgMapFromTileSet";
@@ -1626,38 +1518,37 @@
map->Create(tsdres, mapName);
Ptr<MgResourceIdentifier> mdfId = map->GetMapDefinition();
- CPPUNIT_ASSERT(NULL == (MgResourceIdentifier*)mdfId);
+ REQUIRE(nullptr == (MgResourceIdentifier*)mdfId);
@@ -1664,7 +1555,7 @@
- map = NULL;
+ map = nullptr;
@@ -1676,19 +1567,19 @@
@@ -1695,9 +1586,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1705,10 +1596,12 @@
-void TestTileService::TestCase_GetTileProviders()
+TEST_CASE("GetTileProviders", "[TileService]")
try
Ptr<MgByteReader> content = m_svcTile->GetTileProviders();
Ptr<MgByteSink> sink = new MgByteSink(content);
sink->ToFile(L"../UnitTestFiles/GetTileProviders_Result.xml");
@@ -1715,9 +1608,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1725,10 +1618,14 @@
-void TestTileService::TestCase_GetMetatileSingle()
+TEST_CASE("GetMetatileSingle", "[TileService]")
try
INT32 col = 28;
INT32 row = 29;
INT32 scale = 3;
@@ -1751,10 +1648,10 @@
- Ptr<MgMap> map = CreateMapLinked(L"MetaTileBaseline");
+ Ptr<MgMap> map = CreateMapLinked(m_siteConnection, L"MetaTileBaseline");
map->SetViewScale(3125);
Ptr<MgRenderingService> renderSvc = dynamic_cast<MgRenderingService*>(m_siteConnection->CreateService(MgServiceType::RenderingService));
- CPPUNIT_ASSERT(NULL != renderSvc);
+ REQUIRE(nullptr != renderSvc);
MgFileUtil::CreateDirectory(L"../UnitTestFiles/GetMetatileSingle_Baseline");
@@ -1786,9 +1683,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1796,10 +1693,14 @@
-void TestTileService::TestCase_GetMetatileXYZSingle()
+TEST_CASE("GetMetatileXYZSingle", "[TileService]")
try
INT32 x = 23892;
INT32 y = 16798;
INT32 z = 16;
@@ -1825,10 +1726,10 @@
Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
STRING ovCsvWkt = csFactory->ConvertCoordinateSystemCodeToWkt(L"LL84");
- Ptr<MgMap> map = CreateMapLinked2(L"MetaTileBaseline", ovCsvWkt);
+ Ptr<MgMap> map = CreateMapLinked2(m_siteConnection, L"MetaTileBaseline", ovCsvWkt);
MgFileUtil::CreateDirectory(L"../UnitTestFiles/GetMetatileSingleXYZ_Baseline");
@@ -1866,9 +1767,9 @@
SAFE_RELEASE(e);
catch (...)
@@ -1875,135 +1776,3 @@
throw;
-/// Helpers
-MgMap* TestTileService::CreateMap(CREFSTRING mapName)
- // set a default name if not supplied
- STRING name = (mapName.empty())? L"UnitTestBaseMap" : mapName;
- // make a runtime map
- Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/BaseMap.MapDefinition");
- MgMap* map = new MgMap(m_siteConnection);
- map->Create(mdfres, name);
- // set the view
- Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.723636, 43.715015);
- Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
- map->SetViewCenter(ptNewCenter);
- map->SetDisplayDpi(96);
- map->SetDisplayWidth(1024);
- map->SetDisplayHeight(1024);
- // render at a scale of 1:12500
- map->SetViewScale(12500.0);
- return map;
-MgMap* TestTileService::CreateMapLinked(CREFSTRING mapName)
- STRING name = (mapName.empty())? L"UnitTestBaseMapLinked" : mapName;
- Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
- // set the view
- return map;
-MgMap* TestTileService::CreateMapLinked2(CREFSTRING mapName, CREFSTRING ovCsWkt)
- STRING name = (mapName.empty()) ? L"UnitTestBaseMapLinked" : mapName;
- // Parse the Map Definition and modify it so it matches its linked tile set
- Ptr<MgResourceService> resSvc = dynamic_cast<MgResourceService*>(m_siteConnection->CreateService(MgServiceType::ResourceService));
- MdfModel::MapDefinition* mdf = MgMapBase::GetMapDefinition(resSvc, mdfres);
- MdfModel::TileSetSource* tsRef = mdf->GetTileSetSource();
- Ptr<MgResourceIdentifier> tileSetId = new MgResourceIdentifier(tsRef->GetResourceId());
- Ptr<MgByteReader> reader = resSvc->GetResourceContent(tileSetId);
- Ptr<MgByteSink> sink = new MgByteSink(reader);
- Ptr<MgByte> bytes = sink->ToBuffer();
- MdfParser::SAX2Parser parser;
- parser.ParseString((const char*)bytes->Bytes(), bytes->GetLength());
- CPPUNIT_ASSERT(parser.GetSucceeded());
- MdfModel::TileSetDefinition* tsd = parser.DetachTileSetDefinition();
- // Update coordinate systems to match
- STRING csWkt;
- MdfModel::NameStringPairCollection* params = tsd->GetTileStoreParameters()->GetParameters();
- for (INT32 i = 0; i < params->GetCount(); i++)
- MdfModel::NameStringPair* pair = params->GetAt(i);
- if (pair->GetName() == L"CoordinateSystem")
- csWkt = pair->GetValue();
- mdf->SetCoordinateSystem(csWkt);
- break;
- if (!ovCsWkt.empty())
- mdf->SetCoordinateSystem(ovCsWkt);
- // Fix up extents too
- mdf->SetExtents(tsd->GetExtents());
- // Save back out to XML
- MdfModel::Version ver(3, 0, 0);
- std::string mbXml = parser.SerializeToXML(mdf, &ver);
- Ptr<MgByteSource> source = new MgByteSource((BYTE_ARRAY_IN)mbXml.c_str(), (INT32)mbXml.length());
- Ptr<MgByteReader> content = source->GetReader();
- mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet2.MapDefinition");
- resSvc->SetResource(mdfres, content, NULL);
- // make a runtime map from our changed map definition
- // set the view
- return map;
-// returns a random integer in the range 0 to n-1
-INT32 TestTileService::Rand(INT32 n)
- double numer = (double)rand() + 0.5;
- double denom = (double)RAND_MAX + 1.0;
- return (INT32)(numer / denom * n);
Deleted: sandbox/jng/catch2/Server/src/UnitTesting/TestTileService.h
--- sandbox/jng/catch2/Server/src/UnitTesting/TestTileService.h 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestTileService.h 2020-07-13 13:04:59 UTC (rev 9659)
@@ -1,88 +0,0 @@
-#ifndef _TESTTILESERVICE_H
-#define _TESTTILESERVICE_H
-class TestTileService : public CppUnit::TestFixture
- CPPUNIT_TEST_SUITE(TestTileService);
- CPPUNIT_TEST(TestCase_GetMetatileSingle);
- CPPUNIT_TEST(TestCase_GetMetatileXYZSingle);
- CPPUNIT_TEST(TestCase_GetTileProviders);
- CPPUNIT_TEST(TestCase_MgMap_Inline);
- CPPUNIT_TEST(TestCase_MgMap_Linked);
- CPPUNIT_TEST(TestCase_MgMap_LinkedSameCS);
- CPPUNIT_TEST(TestCase_MgMapFromXYZTileSetLoose);
- CPPUNIT_TEST(TestCase_MgMapFromTileSet);
- CPPUNIT_TEST(TestCase_GetTile);
- CPPUNIT_TEST(TestCase_SetTile);
- CPPUNIT_TEST(TestCase_GetSetTile);
- CPPUNIT_TEST(TestCase_ClearCache);
- CPPUNIT_TEST(TestCase_GetTileLinked);
- CPPUNIT_TEST(TestCase_GetTileXYZ);
- CPPUNIT_TEST(TestCase_ClearCacheLinked);
-public:
- TestTileService();
- ~TestTileService();
- void setUp();
- void tearDown();
- void TestStart();
- void TestEnd();
- void TestCase_GetTileProviders();
- void TestCase_MgMap_Inline();
- void TestCase_MgMap_Linked();
- void TestCase_MgMap_LinkedSameCS();
- void TestCase_MgMapFromXYZTileSetLoose();
- void TestCase_MgMapFromTileSet();
- void TestCase_GetTile();
- void TestCase_SetTile();
- void TestCase_GetSetTile();
- void TestCase_GetTileXYZ();
- void TestCase_ClearCache();
- void TestCase_GetTileLinked();
- void TestCase_ClearCacheLinked();
- void TestCase_GetMetatileSingle();
- void TestCase_GetMetatileXYZSingle();
-private:
- MgMap* CreateMap(CREFSTRING mapName = L"");
- MgMap* CreateMapLinked(CREFSTRING mapName = L"");
- MgMap* CreateMapLinked2(CREFSTRING mapName = L"", CREFSTRING ovCsWkt = L"");
- INT32 Rand(INT32 n);
-private:
- Ptr<MgSiteConnection> m_siteConnection;
- Ptr<MgResourceService> m_svcResource;
- Ptr<MgTileService> m_svcTile;
-#endif
Modified: sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj
--- sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj 2020-07-09 15:16:00 UTC (rev 9658)
+++ sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj 2020-07-13 13:04:59 UTC (rev 9659)
@@ -202,12 +202,7 @@
<ClInclude Include="CppUnitExtensions.h" />
<ClInclude Include="TestServiceFactory.h" />
<ClInclude Include="TestCoordinateSystem.h" />
- <ClInclude Include="TestFeatureService.h" />
<ClInclude Include="TestLogManagerThread.h" />
- <ClInclude Include="TestPerformance.h" />
- <ClInclude Include="TestRenderingService.h" />
- <ClInclude Include="TestServiceManager.h" />
- <ClInclude Include="TestTileService.h" />
<ClInclude Include="UnitTesting.h" />
</ItemGroup>
<ItemGroup>
More information about the mapguide-commits
