[mapguide-commits] r9663 - sandbox/jng/catch2/Server/src/UnitTesting
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Jul 13 08:06:55 PDT 2020
Author: jng
Date: 2020-07-13 08:06:55 -0700 (Mon, 13 Jul 2020)
New Revision: 9663
Removed:
   sandbox/jng/catch2/Server/src/UnitTesting/CppUnitExtensions.h
   sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.cpp
   sandbox/jng/catch2/Server/src/UnitTesting/TestServiceFactory.cpp
   sandbox/jng/catch2/Server/src/UnitTesting/TestServiceFactory.h
   sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.cpp
   sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj
Remove references to cppunit and make test data setup/teardown conditional on whether the suite in question is to be run
Deleted: sandbox/jng/catch2/Server/src/UnitTesting/CppUnitExtensions.h
--- sandbox/jng/catch2/Server/src/UnitTesting/CppUnitExtensions.h	2020-07-13 14:35:45 UTC (rev 9662)
+++ sandbox/jng/catch2/Server/src/UnitTesting/CppUnitExtensions.h	2020-07-13 15:06:55 UTC (rev 9663)
@@ -1,78 +0,0 @@
-//  Copyright (C) 2004-2011 by Autodesk, Inc.
-//  This library is free software; you can redistribute it and/or
-//  modify it under the terms of version 2.1 of the GNU Lesser
-//  General Public License as published by the Free Software Foundation.
-//  This library is distributed in the hope that it will be useful,
-//  but WITHOUT ANY WARRANTY; without even the implied warranty of
-//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-//  Lesser General Public License for more details.
-//  You should have received a copy of the GNU Lesser General Public
-//  License along with this library; if not, write to the Free Software
-//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-#ifndef _CPPUNIT_EXTENSIONS_H
-#define _CPPUNIT_EXTENSIONS_H
-/** Asserts that the given expression throws an exception of the specified type.
- * \ingroup Assertions
- * Example of usage:
- * \code
- *   std::out_of_range exception;
- *   std::vector<int> v;
- *  CPPUNIT_ASSERT_THROW_EX( v.at( 50 ), std::out_of_range, exception );
- * \endcode
-# define CPPUNIT_ASSERT_THROW_EX( expression, ExceptionType, exception )    \
-   do {        \
-      bool cpputExceptionThrown_ = false;                                   \
-      try {        \
-         expression;                                                        \
-      } catch ( ExceptionType & ex_) {                                      \
-         cpputExceptionThrown_ = true;                                      \
-         exception = ex_;                                                   \
-      if ( cpputExceptionThrown_ )                                          \
-         break;                                                             \
-      CPPUNIT_NS::Asserter::fail(                                           \
-                     "Expected exception: " #ExceptionType                  \
-                     " not thrown.",                                        \
-                     CPPUNIT_SOURCELINE() );                                \
-   } while ( false )
-/** Asserts that the given expression throws an MgException of the specified type.
- * \code
- *   MgLogManager* pMgLogManager = MgLogManager::GetInstance();
- *   CPPUNIT_ASSERT_THROW_MG(mgr->DeleteLog(L""), MgNullArgumentException*);
- * \endcode
-# define CPPUNIT_ASSERT_THROW_MG( expression, MgExceptionType )             \
-   do {        \
-      Ptr<MgException> exception;                                           \
-      try {        \
-         expression;                                                        \
-      } catch ( MgExceptionType & ex_) {                                    \
-         break;                                                             \
-                     "Expected exception: " #MgExceptionType                \
-                     " not thrown.",                                        \
-   } while ( false )
-#endif // _CPPUNIT_EXTENSIONS_H
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.cpp	2020-07-13 14:35:45 UTC (rev 9662)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestPerformance.cpp	2020-07-13 15:06:55 UTC (rev 9663)
@@ -16,7 +16,6 @@
 #include "MapGuideCommon.h"
-#include "CppUnitExtensions.h"
 #include "ServiceManager.h"
 #include "FdoConnectionManager.h"
 #include "Services/FeatureService.h"
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestServiceFactory.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/TestServiceFactory.cpp	2020-07-13 14:35:45 UTC (rev 9662)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestServiceFactory.cpp	2020-07-13 15:06:55 UTC (rev 9663)
@@ -21,9 +21,37 @@
 #define CATCH_CONFIG_EXTERNAL_INTERFACES
 #include "catch.hpp"
 const STRING TestServiceFactory::TEST_LOCALE = L"en";
+std::set<std::string> TestServiceFactory::sm_suitesToRun;
+bool TestServiceFactory::IsRunningSuite(const std::string& suite)
+    return sm_suitesToRun.find(suite) != sm_suitesToRun.end();
+void TestServiceFactory::GetCatch2Tags(std::string& testOrTags)
+    bool bFirst = true;
+    for (auto const& item : sm_suitesToRun)
+        if (bFirst)
+            bFirst = false;
+        else
+            testOrTags += ",";
+        testOrTags += item;
+void TestServiceFactory::AddSuiteToRun(const std::string& suite)
+    sm_suitesToRun.insert(suite);
 MgSiteConnection* TestServiceFactory::CreateSiteConnection(MgServerSiteService* svcSite)
     STRING session;
@@ -187,12 +215,14 @@
 #endif
-        printf("************************************\n");
-        printf("******* Setting up test data *******\n");
+        printf("*******************************************\n");
+        printf("******* Setting up test environment *******\n");
         // TestMisc setup
+        if (TestServiceFactory::IsRunningSuite("[Misc]"))
+            printf("Setting up data for suite: Misc\n");
             //Reusing Mapping Service test data
             try
@@ -290,7 +320,9 @@
         // TestMdfModel setup
+        if (TestServiceFactory::IsRunningSuite("[MdfModel]"))
+            printf("Setting up data for suite: MdfModel\n");
             try
                 // set user info
@@ -347,7 +379,9 @@
         // TestGeometry setup
+        if (TestServiceFactory::IsRunningSuite("[Geometry]"))
+            printf("Setting up data for suite: Geometry\n");
             try
                 MgResourceIdentifier resourceIdentifier1(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
@@ -378,7 +412,9 @@
         // TestDrawingService setup
+        if (TestServiceFactory::IsRunningSuite("[DrawingService]"))
+            printf("Setting up data for suite: DrawingService\n");
             try
                 MgResourceIdentifier resourceIdentifier1(L"Library://UnitTests/Drawings/SpaceShip.DrawingSource");
@@ -400,7 +436,9 @@
         // TestKmlService setup
+        if (TestServiceFactory::IsRunningSuite("[KmlService]"))
+            printf("Setting up data for suite: KmlService\n");
             try
                 //publish the map definition
@@ -467,7 +505,9 @@
         // TestMappingService setup
+        if (TestServiceFactory::IsRunningSuite("[MappingService]"))
+            printf("Setting up data for suite: MappingService\n");
             try
@@ -603,7 +643,9 @@
         // TestRenderingService setup
+        if (TestServiceFactory::IsRunningSuite("[RenderingService]"))
+            printf("Setting up data for suite: RenderingService\n");
             try
                 // publish the map definition
@@ -944,7 +986,9 @@
         // TestTileService setup
+        if (TestServiceFactory::IsRunningSuite("[TileService]"))
+            printf("Setting up data for suite: TileService\n");
             try
@@ -1049,7 +1093,9 @@
         // TestProfilingService setup
+        if (TestServiceFactory::IsRunningSuite("[ProfilingService]"))
+            printf("Setting up data for suite: ProfilingService\n");
             try
@@ -1290,7 +1336,9 @@
         // TestFeatureService setup
+        if (TestServiceFactory::IsRunningSuite("[FeatureService]"))
+            printf("Setting up data for suite: FeatureService\n");
             try
@@ -1435,7 +1483,9 @@
         // TestPerformance setup
+        if (TestServiceFactory::IsRunningSuite("[Performance]"))
+            printf("Setting up data for suite: Performance\n");
             try
@@ -1474,12 +1524,14 @@
         printf("Tearing down test data\n");
-        printf("**************************************\n");
-        printf("******* Tearing down test data *******\n");
+        printf("***************************************\n");
+        printf("**** Tearing down test environment ****\n");
         // TestMisc teardown
+            printf("Tearing down data for suite: Misc\n");
             try
                 //set user info
@@ -1546,7 +1598,9 @@
         // TestMdfModel teardown
+            printf("Tearing down data for suite: MdfModel\n");
             try
                 // set user info
@@ -1588,7 +1642,9 @@
         // TestGeometry teardown
+            printf("Tearing down data for suite: Geometry\n");
             try
                 Ptr<MgResourceIdentifier> fsres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
@@ -1607,7 +1663,9 @@
         // TestDrawingService teardown
+            printf("Tearing down data for suite: DrawingService\n");
             try
@@ -1623,7 +1681,9 @@
         // TestKmlService teardown
+            printf("Tearing down data for suite: KmlService\n");
             try
                 //delete the map definition
@@ -1663,7 +1723,9 @@
         // TestMappingService teardown
+            printf("Tearing down data for suite: MappingService\n");
             try
@@ -1744,7 +1806,9 @@
         // TestProfilingService teardown
+            printf("Tearing down data for suite: ProfilingService\n");
             try
                 // delete the map definition
@@ -1858,7 +1922,10 @@
         // TestRenderingService teardown
+            printf("Tearing down data for suite: RenderingService\n");
             Ptr<MgResourceIdentifier> mapres1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
             svcResource->DeleteResource(mapres1);
@@ -1993,7 +2060,9 @@
         // TestTileService teardown
+            printf("Tearing down data for suite: TileService\n");
             try
@@ -2058,7 +2127,9 @@
         // TestResourceService teardown
+        if (TestServiceFactory::IsRunningSuite("[ResourceService]"))
+            printf("Tearing down data for suite: ResourceService\n");
             try
                 // delete the drawing source definition
@@ -2078,7 +2149,10 @@
         // TestFeatureService teardown
+            printf("Tearing down data for suite: FeatureService\n");
             // delete the feature sources definition
             svcResource->DeleteResource(fsres1);
@@ -2113,7 +2187,10 @@
         // TestPerformance teardown
+            printf("Tearing down data for suite: Performance\n");
             Ptr<MgResourceIdentifier> mapres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
Modified: sandbox/jng/catch2/Server/src/UnitTesting/TestServiceFactory.h
--- sandbox/jng/catch2/Server/src/UnitTesting/TestServiceFactory.h	2020-07-13 14:35:45 UTC (rev 9662)
+++ sandbox/jng/catch2/Server/src/UnitTesting/TestServiceFactory.h	2020-07-13 15:06:55 UTC (rev 9663)
@@ -24,6 +24,9 @@
 #include "ServerSiteService.h"
 #include "FoundationDefs.h"
+#include <string>
+#include <set>
 class TestServiceFactory
 public:
@@ -50,6 +53,15 @@
     static MgMappingService* CreateMappingService();
     static MgProfilingService* CreateProfilingService();
+    static void AddSuiteToRun(const std::string& suite);
+    static void GetCatch2Tags(std::string& testOrTags);
+    static bool IsRunningSuite(const std::string& suite);
+private:
+    static std::set<std::string> sm_suitesToRun;
 #endif
Modified: sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.cpp
--- sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.cpp	2020-07-13 14:35:45 UTC (rev 9662)
+++ sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.cpp	2020-07-13 15:06:55 UTC (rev 9663)
@@ -18,6 +18,7 @@
 #include "UnitTesting.h"
+#include "TestServiceFactory.h"
 #define CATCH_CONFIG_RUNNER
@@ -35,26 +36,26 @@
         if (test == L"all")
-            session.configData().testsOrTags.push_back("[CoordinateSystem]");
-            session.configData().testsOrTags.push_back("[DrawingService]");
-            session.configData().testsOrTags.push_back("[FeatureService]");
-            session.configData().testsOrTags.push_back("[Geometry]");
-            session.configData().testsOrTags.push_back("[KmlService]");
-            session.configData().testsOrTags.push_back("[LogManager]");
-            session.configData().testsOrTags.push_back("[MappingService]");
-            session.configData().testsOrTags.push_back("[MdfModel]");
-            session.configData().testsOrTags.push_back("[Misc]");
-            session.configData().testsOrTags.push_back("[Performance]");
-            session.configData().testsOrTags.push_back("[RenderingService]");
-            session.configData().testsOrTags.push_back("[ResourceService]");
-            session.configData().testsOrTags.push_back("[ServerAdminService]");
-            session.configData().testsOrTags.push_back("[ServerManager]");
-            session.configData().testsOrTags.push_back("[ServiceManager]");
-            session.configData().testsOrTags.push_back("[SiteManager]");
-            session.configData().testsOrTags.push_back("[SiteService]");
-            session.configData().testsOrTags.push_back("[TileService]");
-            session.configData().testsOrTags.push_back("[ProfilingService]");
-            session.configData().testsOrTags.push_back("[TransformMesh]");
+            TestServiceFactory::AddSuiteToRun("[CoordinateSystem]");
+            TestServiceFactory::AddSuiteToRun("[DrawingService]");
+            TestServiceFactory::AddSuiteToRun("[FeatureService]");
+            TestServiceFactory::AddSuiteToRun("[Geometry]");
+            TestServiceFactory::AddSuiteToRun("[KmlService]");
+            TestServiceFactory::AddSuiteToRun("[LogManager]");
+            TestServiceFactory::AddSuiteToRun("[MappingService]");
+            TestServiceFactory::AddSuiteToRun("[MdfModel]");
+            TestServiceFactory::AddSuiteToRun("[Misc]");
+            TestServiceFactory::AddSuiteToRun("[Performance]");
+            TestServiceFactory::AddSuiteToRun("[RenderingService]");
+            TestServiceFactory::AddSuiteToRun("[ResourceService]");
+            TestServiceFactory::AddSuiteToRun("[ServerAdminService]");
+            TestServiceFactory::AddSuiteToRun("[ServerManager]");
+            TestServiceFactory::AddSuiteToRun("[ServiceManager]");
+            TestServiceFactory::AddSuiteToRun("[SiteManager]");
+            TestServiceFactory::AddSuiteToRun("[SiteService]");
+            TestServiceFactory::AddSuiteToRun("[TileService]");
+            TestServiceFactory::AddSuiteToRun("[ProfilingService]");
+            TestServiceFactory::AddSuiteToRun("[TransformMesh]");
         else if (test == L"list")
@@ -92,7 +93,7 @@
             std::string testToRun = "[";
             testToRun += MgUtil::WideCharToMultiByte(test);
             testToRun += "]";
-            session.configData().testsOrTags.push_back(testToRun);
+            TestServiceFactory::AddSuiteToRun(testToRun);
@@ -99,6 +100,9 @@
     int nResult = 0;
     if (bRunTests)
+        std::string testsOrTags;
+        TestServiceFactory::GetCatch2Tags(testsOrTags);
+        session.configData().testsOrTags.push_back(testsOrTags);
         nResult = session.run();
     return nResult;
Modified: sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj
--- sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj	2020-07-13 14:35:45 UTC (rev 9662)
+++ sandbox/jng/catch2/Server/src/UnitTesting/UnitTesting.vcxproj	2020-07-13 15:06:55 UTC (rev 9663)
@@ -94,7 +94,7 @@
   <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
     <ClCompile>
       <Optimization>Disabled</Optimization>
-      <AdditionalIncludeDirectories>..\Common;..\Common\Cache;..\Common\Manager;..\Services\Feature;..\Services\Kml;..\Services\Mapping;..\Services\Rendering;..\Services\Resource;..\Services\ServerAdmin;..\Services\Site;..\Services\Tile;..\..\..\Common\Foundation;..\..\..\Common\Geometry;..\..\..\Common\PlatformBase;..\..\..\Common\MapGuideCommon;..\..\..\Common\MdfModel;..\..\..\Common\MdfParser;..\..\..\Common\Renderers;..\..\..\Common\Stylization;..\..\..\Oem\ACE\ACE_wrappers;..\..\..\Oem\CppUnit-1.9.14\include;..\..\..\Oem\catch2;..\..\..\Oem\dbxml\xerces-c-src\src;..\..\..\Oem\FDO\inc;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+      <AdditionalIncludeDirectories>..\Common;..\Common\Cache;..\Common\Manager;..\Services\Feature;..\Services\Kml;..\Services\Mapping;..\Services\Rendering;..\Services\Resource;..\Services\ServerAdmin;..\Services\Site;..\Services\Tile;..\..\..\Common\Foundation;..\..\..\Common\Geometry;..\..\..\Common\PlatformBase;..\..\..\Common\MapGuideCommon;..\..\..\Common\MdfModel;..\..\..\Common\MdfParser;..\..\..\Common\Renderers;..\..\..\Common\Stylization;..\..\..\Oem\ACE\ACE_wrappers;..\..\..\Oem\catch2;..\..\..\Oem\dbxml\xerces-c-src\src;..\..\..\Oem\FDO\inc;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
       <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;%(PreprocessorDefinitions)</PreprocessorDefinitions>
       <ExceptionHandling>Async</ExceptionHandling>
       <BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
@@ -104,9 +104,9 @@
       <MultiProcessorCompilation>true</MultiProcessorCompilation>
     </ClCompile>
     <Link>
-      <AdditionalDependencies>ACEd.lib;cppunitd.lib;%(AdditionalDependencies)</AdditionalDependencies>
+      <AdditionalDependencies>ACEd.lib;%(AdditionalDependencies)</AdditionalDependencies>
       <OutputFile>$(OutDir)MgUnitTestingd.dll</OutputFile>
-      <AdditionalLibraryDirectories>..\..\..\Oem\ACE\ACE_wrappers\lib\$(Configuration);..\..\..\Oem\CppUnit-1.9.14\lib\$(Configuration);..\..\..\Oem\FDO\lib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+      <AdditionalLibraryDirectories>..\..\..\Oem\ACE\ACE_wrappers\lib\$(Configuration);..\..\..\Oem\FDO\lib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
       <GenerateDebugInformation>true</GenerateDebugInformation>
       <ProgramDatabaseFile>$(OutDir)MgUnitTestingd.pdb</ProgramDatabaseFile>
       <SubSystem>Windows</SubSystem>
@@ -120,7 +120,7 @@
   <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
     <ClCompile>
@@ -130,9 +130,9 @@
     </ClCompile>
     <Link>
-      <AdditionalLibraryDirectories>..\..\..\Oem\ACE\ACE_wrappers\lib64\$(Configuration);..\..\..\Oem\CppUnit-1.9.14\lib64\$(Configuration);..\..\..\Oem\FDO\lib64;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+      <AdditionalLibraryDirectories>..\..\..\Oem\ACE\ACE_wrappers\lib64\$(Configuration);..\..\..\Oem\FDO\lib64;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
@@ -146,7 +146,7 @@
   <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
     <ClCompile>
       <Optimization>MaxSpeed</Optimization>
       <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;%(PreprocessorDefinitions)</PreprocessorDefinitions>
       <RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
@@ -155,9 +155,9 @@
     </ClCompile>
     <Link>
-      <AdditionalDependencies>ACE.lib;cppunit.lib;%(AdditionalDependencies)</AdditionalDependencies>
+      <AdditionalDependencies>ACE.lib;%(AdditionalDependencies)</AdditionalDependencies>
       <OutputFile>$(OutDir)MgUnitTesting.dll</OutputFile>
       <ProgramDatabaseFile>$(OutDir)MgUnitTesting.pdb</ProgramDatabaseFile>
@@ -173,7 +173,7 @@
   <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
     <ClCompile>
@@ -182,9 +182,9 @@
     </ClCompile>
     <Link>
@@ -199,7 +199,6 @@
   </ItemDefinitionGroup>
   <ItemGroup>
     <ClInclude Include="CatchHelperMacros.h" />
-    <ClInclude Include="CppUnitExtensions.h" />
     <ClInclude Include="TestServiceFactory.h" />
     <ClInclude Include="TestLogManagerThread.h" />
     <ClInclude Include="UnitTesting.h" />
More information about the mapguide-commits mailing list
