[mapguide-commits] r9692 - sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler
svn_mapguide at osgeo.org
Tue Jul 28 07:13:51 PDT 2020
Author: jng
Date: 2020-07-28 07:13:51 -0700 (Tue, 28 Jul 2020)
New Revision: 9692
sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/HttpWmsGetMap.cpp
sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/OgcServer.cpp
sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/OgcServer.h
Implement the OpenLayers viewer representation for WMS GetMap
Modified: sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/HttpWmsGetMap.cpp
--- sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/HttpWmsGetMap.cpp 2020-07-28 14:12:57 UTC (rev 9691)
+++ sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/HttpWmsGetMap.cpp 2020-07-28 14:13:51 UTC (rev 9692)
@@ -178,28 +178,17 @@
// Construct a self url
auto selfUrl = m_hRequest->GetAgentUri();
- for (INT32 i = 0; i < requestParams.Count(); i++)
- if (i == 0)
- selfUrl += L"?";
- else
- selfUrl += L"&";
+ STRING sLayers = GetRequestParameter(wms, MgHttpResourceStrings::reqWmsLayers);
+ wms.GenerateViewerResponse(selfUrl, sLayers, m_crs, m_bbox);
- auto name = requestParams.Name(i);
- selfUrl += name;
- selfUrl += L"=";
- if (name == MgHttpResourceStrings::reqWmsFormat)
- selfUrl += L"image/png"; //TODO: Surely default image format is defined somewhere
- else
- auto value = (CPSZ)requestParams.Value(i);
- selfUrl += value;
+ // Slurp the results.
+ // NOTE: The application/openlayers mime type is just a means to get to the code path
+ // the actual mime type to serve back is HTML
+ responseStream.Stream().SetMimeType(MgMimeType::Html);
+ Ptr<MgByteReader> content = responseStream.Stream().GetReader();
- wms.OutputViewerResponse(selfUrl, hResult);
+ // Set the result
+ hResult->SetResultObject(content, content->GetMimeType());
else
Modified: sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/OgcServer.cpp
--- sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/OgcServer.cpp 2020-07-28 14:12:57 UTC (rev 9691)
+++ sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/OgcServer.cpp 2020-07-28 14:13:51 UTC (rev 9692)
@@ -135,6 +135,11 @@
CPSZ kpszNewline = _("\n");
CPSZ kpszXmlSlash = _("/");
+CPSZ kpszViewerSelfUrl = _("Viewer.SelfUrl");
+CPSZ kpszViewerLayersParam = _("Viewer.LayersParam");
+CPSZ kpszViewerSrs = _("Viewer.SRS");
+CPSZ kpszViewerBounds = _("Viewer.BBOX");
// BEGIN LOCALIZATION --
CPSZ kpszDefaultExceptionTemplate = _("<html><head><title>Server Exception</title></head><body><h1>Server Exception:</h1><p>Type: &Exception.Type;</p><p>Message: &Exception.Message;</p><pre><?EnumDictionary?></pre></body></html>");
CPSZ kpszInternalErrorNoSupportedVersions = _("Service Config file does not contain any SupportedVersions definition; unable to perform version negotiation.");
@@ -1890,18 +1895,16 @@
ProcessExpandableText(pszTextWithExpansion,(int)szlen(pszTextWithExpansion));
-void MgOgcServer::OutputViewerResponse(CREFSTRING selfUrl, MgHttpResult* hResult)
+void MgOgcServer::GenerateViewerResponse(CREFSTRING selfUrl, CREFSTRING layers, CREFSTRING srs, CREFSTRING bbox)
- STRING content = L"<html><head></head><body>";
- content += L"<p>TODO: Display OpenLayers view with the following URL</p>";
- content += selfUrl;
- content += L"</body></html>";
+ CDictionaryStackFrame forThis(this);
- std::string mbContent = MgUtil::WideCharToMultiByte(content);
- Ptr<MgByteSource> bs = new MgByteSource((BYTE_ARRAY_IN)mbContent.c_str(), (INT32)mbContent.length());
- bs->SetMimeType(MgMimeType::Html);
- Ptr<MgByteReader> br = bs->GetReader();
- hResult->SetResultObject(br, br->GetMimeType());
+ AddDefinition(kpszViewerSelfUrl, selfUrl);
+ AddDefinition(kpszViewerLayersParam, layers);
+ AddDefinition(kpszViewerSrs, srs);
+ AddDefinition(kpszViewerBounds, bbox);
+ GenerateResponse(kpszQueryValueGetMap, kpszOpenLayersMimeType);
MgOgcServer::CDictionaryStackFrame::CDictionaryStackFrame(MgOgcServer* pServer)
Modified: sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/OgcServer.h
--- sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/OgcServer.h 2020-07-28 14:12:57 UTC (rev 9691)
+++ sandbox/jng/ogc_viewer_representation/Web/src/HttpHandler/OgcServer.h 2020-07-28 14:13:51 UTC (rev 9692)
@@ -553,7 +553,7 @@
// to actually do the loading. See signature, above.
static void SetLoader(DocLoaderFunc fnDocLoad);
- void OutputViewerResponse(CREFSTRING selfUrl, MgHttpResult* hResult);
+ void GenerateViewerResponse(CREFSTRING selfUrl, CREFSTRING layers, CREFSTRING srs, CREFSTRING bbox);
private:
// Pointer to the document loader function; modified by SetLoader().
More information about the mapguide-commits
