[mapguide-commits] r9647 - in sandbox/adsk/trunk: Doc/devguide/source/_static Doc/devguide/source/_templates Oem/dbxml/xerces-c-src/Build Oem/dbxml/xerces-c-src/tests/src/xinclude/tests/xinclude/written UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/mapping UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/rendering nuget/x64/api-base/lib/net40 nuget/x64/api-desktop/lib/net40 nuget/x64/api-desktop-viewer/lib/net40 nuget/x64/api-desktop-viewer/tools/net40 nuget/x64/api-web/lib/net40 nuget/x86/api-base/lib/net40 nuget/x86/api-desktop/lib/net40 nuget/x86/api-desktop-viewer/lib/net40 nuget/x86/api-web/lib/net40
svn_mapguide at osgeo.org
Mon Mar 9 23:48:32 PDT 2020
Author: simonliu
Date: 2020-03-09 23:48:31 -0700 (Mon, 09 Mar 2020)
New Revision: 9647
Added:
sandbox/adsk/trunk/Doc/devguide/source/_static/PlaceHolder.txt
sandbox/adsk/trunk/Doc/devguide/source/_templates/PlaceHolder.txt
sandbox/adsk/trunk/Oem/dbxml/xerces-c-src/Build/PlaceHolder.txt
sandbox/adsk/trunk/Oem/dbxml/xerces-c-src/tests/src/xinclude/tests/xinclude/written/PlaceHolder.txt
sandbox/adsk/trunk/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/mapping/PlaceHolder.txt
sandbox/adsk/trunk/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/rendering/PlaceHolder.txt
sandbox/adsk/trunk/nuget/x64/api-base/lib/net40/PlaceHolder.txt
sandbox/adsk/trunk/nuget/x64/api-desktop-viewer/lib/net40/PlaceHolder.txt
sandbox/adsk/trunk/nuget/x64/api-desktop-viewer/tools/net40/PlaceHolder.txt
sandbox/adsk/trunk/nuget/x64/api-desktop/lib/net40/PlaceHolder.txt
sandbox/adsk/trunk/nuget/x64/api-web/lib/net40/PlaceHolder.txt
sandbox/adsk/trunk/nuget/x86/api-base/lib/net40/PlaceHolder.txt
sandbox/adsk/trunk/nuget/x86/api-desktop-viewer/lib/net40/PlaceHolder.txt
sandbox/adsk/trunk/nuget/x86/api-desktop/lib/net40/PlaceHolder.txt
sandbox/adsk/trunk/nuget/x86/api-web/lib/net40/PlaceHolder.txt
The place holders are added since git cannot accept the empty folder.
Added: sandbox/adsk/trunk/Doc/devguide/source/_static/PlaceHolder.txt
--- sandbox/adsk/trunk/Doc/devguide/source/_static/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/Doc/devguide/source/_static/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
+It is a place holder for git.
\ No newline at end of file
Added: sandbox/adsk/trunk/Doc/devguide/source/_templates/PlaceHolder.txt
--- sandbox/adsk/trunk/Doc/devguide/source/_templates/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/Doc/devguide/source/_templates/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/Oem/dbxml/xerces-c-src/Build/PlaceHolder.txt
--- sandbox/adsk/trunk/Oem/dbxml/xerces-c-src/Build/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/Oem/dbxml/xerces-c-src/Build/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/Oem/dbxml/xerces-c-src/tests/src/xinclude/tests/xinclude/written/PlaceHolder.txt
--- sandbox/adsk/trunk/Oem/dbxml/xerces-c-src/tests/src/xinclude/tests/xinclude/written/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/Oem/dbxml/xerces-c-src/tests/src/xinclude/tests/xinclude/written/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/mapping/PlaceHolder.txt
--- sandbox/adsk/trunk/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/mapping/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/mapping/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/rendering/PlaceHolder.txt
--- sandbox/adsk/trunk/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/rendering/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/rendering/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/nuget/x64/api-base/lib/net40/PlaceHolder.txt
--- sandbox/adsk/trunk/nuget/x64/api-base/lib/net40/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/nuget/x64/api-base/lib/net40/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/nuget/x64/api-desktop/lib/net40/PlaceHolder.txt
--- sandbox/adsk/trunk/nuget/x64/api-desktop/lib/net40/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/nuget/x64/api-desktop/lib/net40/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/nuget/x64/api-desktop-viewer/lib/net40/PlaceHolder.txt
--- sandbox/adsk/trunk/nuget/x64/api-desktop-viewer/lib/net40/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/nuget/x64/api-desktop-viewer/lib/net40/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/nuget/x64/api-desktop-viewer/tools/net40/PlaceHolder.txt
--- sandbox/adsk/trunk/nuget/x64/api-desktop-viewer/tools/net40/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/nuget/x64/api-desktop-viewer/tools/net40/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/nuget/x64/api-web/lib/net40/PlaceHolder.txt
--- sandbox/adsk/trunk/nuget/x64/api-web/lib/net40/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/nuget/x64/api-web/lib/net40/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/nuget/x86/api-base/lib/net40/PlaceHolder.txt
--- sandbox/adsk/trunk/nuget/x86/api-base/lib/net40/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/nuget/x86/api-base/lib/net40/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/nuget/x86/api-desktop/lib/net40/PlaceHolder.txt
--- sandbox/adsk/trunk/nuget/x86/api-desktop/lib/net40/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/nuget/x86/api-desktop/lib/net40/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/nuget/x86/api-desktop-viewer/lib/net40/PlaceHolder.txt
--- sandbox/adsk/trunk/nuget/x86/api-desktop-viewer/lib/net40/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/nuget/x86/api-desktop-viewer/lib/net40/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
Added: sandbox/adsk/trunk/nuget/x86/api-web/lib/net40/PlaceHolder.txt
--- sandbox/adsk/trunk/nuget/x86/api-web/lib/net40/PlaceHolder.txt (rev 0)
+++ sandbox/adsk/trunk/nuget/x86/api-web/lib/net40/PlaceHolder.txt 2020-03-10 06:48:31 UTC (rev 9647)
@@ -0,0 +1 @@
More information about the mapguide-commits
