[mapguide-commits] r9772 - in sandbox/jng/vanilla_swig/Bindings: . src src/Bindings/Common/DotNet src/Test/DotNet src/Test/DotNet/src/TestCommon src/Test/DotNet/src/TestMapGuideApi src/Test/DotNet/src/TestMisc src/Test/DotNet/src/TestMisc/Properties src/Test/DotNet/src/TestRunner src/Test/DotNet/src/TestRunner/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Nov 12 06:21:52 PST 2020
Author: jng
Date: 2020-11-12 06:21:51 -0800 (Thu, 12 Nov 2020)
New Revision: 9772
Added:
   sandbox/jng/vanilla_swig/Bindings/setup_test_data.cmd
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Properties/
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Properties/launchSettings.json
   sandbox/jng/vanilla_swig/Bindings/TODO.txt
   sandbox/jng/vanilla_swig/Bindings/src/Bindings/Common/DotNet/coreclr_compat.i
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestCommon/
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestCommon/TestCommon.csproj
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/TestMapGuideApi.csproj
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/TestMisc.csproj
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner/
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner/Properties/launchSettings.json
   sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner/TestRunner.csproj
- Add batch file to setup test data
- Update test runners to target netcoreapp3.1
- Add missing nuget packages for test projects
- Fix up MgObjectFactory to scan assemblies in the current AppDomain for the requested .net type instead of just the current assembly
Modified: sandbox/jng/vanilla_swig/Bindings/TODO.txt
--- sandbox/jng/vanilla_swig/Bindings/TODO.txt	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/TODO.txt	2020-11-12 14:21:51 UTC (rev 9772)
@@ -1,4 +1,4 @@
- - Check that .net error messages are being read (https://github.com/jumpinjackie/mapguide-api-bindings/issues/35)
+ - [ ] Check that .net error messages are being read (https://github.com/jumpinjackie/mapguide-api-bindings/issues/35)
  - Split .net binding into the Foundation/Geometry/PlatformBase/MapGuideCommon/Web layout (https://github.com/jumpinjackie/mapguide-api-bindings/issues/18)
    - [ ] Add CentOS 6 Dockerfile that
       - Install SWIG and common libs tarball (from docker build system)
@@ -5,7 +5,7 @@
       - Install same compilers/tools as the same docker image used to produce the common libs tarball
       - Generate and build the .net/Java SWIG glue libraries
       - Copy the compiled libs out of the docker container and into the same native library staging area for Java/.net
-   - [ ] Refactor current .net test suite to reference these nuget packages
+   - [x] Refactor current .net test suite to reference these nuget packages
       - [ ] Verify test suite still passes (Windows)
       - [ ] Verify test suite still passes (Linux)
  - Automatic class id generation (https://github.com/jumpinjackie/mapguide-api-bindings/issues/34)
@@ -13,8 +13,8 @@
    - [ ] Run SWIG in XML mode to produce an XML of the MapGuide API surface
    - [ ] Update ClassMapGen tool to generate class id files for .net/Java/PHP based on this XML file
  - Test Suite
-   - [ ] Sync up current test data under /UnitTest to match what is in GitHub repo
-   - [ ] Add test data setup script for .net/Java test suites to copy the synced up test data under /UnitTest to the location the test suite is expecting
+   - [x] Sync up current test data under /UnitTest to match what is in GitHub repox
+   - [x] Add test data setup script for .net/Java test suites to copy the synced up test data under /UnitTest to the location the test suite is expecting
  - Java binding
    - [ ] Re-shuffle MgBase64 and AppThrowable to a .internal package (so we can bulk svn ignore *.java/*.class in the current dir where sources are generated)
Added: sandbox/jng/vanilla_swig/Bindings/setup_test_data.cmd
--- sandbox/jng/vanilla_swig/Bindings/setup_test_data.cmd	                        (rev 0)
+++ sandbox/jng/vanilla_swig/Bindings/setup_test_data.cmd	2020-11-12 14:21:51 UTC (rev 9772)
@@ -0,0 +1 @@
+xcopy /S /Y /I ..\UnitTest\TestData src\TestData
\ No newline at end of file
Index: sandbox/jng/vanilla_swig/Bindings/src
--- sandbox/jng/vanilla_swig/Bindings/src	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src	2020-11-12 14:21:51 UTC (rev 9772)
Property changes on: sandbox/jng/vanilla_swig/Bindings/src
___________________________________________________________________
Modified: svn:ignore
## -1,2 +1,3 ##
+TestData
 lib
 obj
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/Common/DotNet/coreclr_compat.i
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/Common/DotNet/coreclr_compat.i	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/Common/DotNet/coreclr_compat.i	2020-11-12 14:21:51 UTC (rev 9772)
@@ -183,6 +183,19 @@
     internal static class MgObjectFactory
+        static global::System.Collections.Generic.Dictionary<string, string> assemblyNameMap;
+        static MgObjectFactory()
+            assemblyNameMap = new global::System.Collections.Generic.Dictionary<string, string>();
+            assemblyNameMap["OSGeo.MapGuide.Foundation"] = "OSGeo.MapGuide.Foundation";
+            assemblyNameMap["OSGeo.MapGuide.Geometry"] = "OSGeo.MapGuide.Geometry";
+            assemblyNameMap["OSGeo.MapGuide.PlatformBase"] = "OSGeo.MapGuide.PlatformBase";
+            assemblyNameMap["OSGeo.MapGuide.MapGuideCommon"] = "OSGeo.MapGuide.MapGuideCommon";
+            assemblyNameMap["OSGeo.MapGuide.Web"] = "OSGeo.MapGuide.Web";
         static string GetClassName(global::System.IntPtr objPtr)
             var cPtr = $imclassname.GetClassName(objPtr);
@@ -200,8 +213,32 @@
                 throw new global::System.Exception("Could not resolve .net type for this unmanaged pointer. The unmanaged pointer reported a class ID of: " + clsId);
+            var type = global::System.Type.GetType(typeName);
+            if (type == null)
+                // Find the specified class in the pre-defined assemblies
+                var assemblies = global::System.AppDomain.CurrentDomain.GetAssemblies();
+                foreach (var assem in assemblies)
+                    var assemblyName = new global::System.Reflection.AssemblyName(assem.FullName);
+                    if (assemblyNameMap.ContainsKey(assemblyName.Name))
+                        type = assem.GetType(typeName, false);
+                        if (type != null)
+                            break;
-            var type = global::System.Type.GetType(typeName);
+                // Fall back to finding the type in every assembly in the current appdomain
+                foreach (var assem in global::System.AppDomain.CurrentDomain.GetAssemblies())
+                    if (type != null)
+                        break;
             if (type == null) //Shouldn't happen. But if it did, this would mean we didn't expose this class to SWIG
                 throw new global::System.Exception("The type " + typeName + " does not exist. The unmanaged pointer reported a class ID of: " + clsId);
Index: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet	2020-11-12 14:21:51 UTC (rev 9772)
Property changes on: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet
Added: svn:ignore
## -0,0 +1 ##
+.vs
Index: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestCommon
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestCommon	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestCommon	2020-11-12 14:21:51 UTC (rev 9772)
Property changes on: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestCommon
Added: svn:ignore
## -0,0 +1,2 ##
+bin
+obj
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestCommon/TestCommon.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestCommon/TestCommon.csproj	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestCommon/TestCommon.csproj	2020-11-12 14:21:51 UTC (rev 9772)
@@ -14,6 +14,8 @@
   </PropertyGroup>
   <ItemGroup>
     <PackageReference Include="Microsoft.Data.SQLite" Version="2.0.1" />
+    <PackageReference Include="OSGeo.MapGuide.Foundation" Version="4.0.0" />
+    <PackageReference Include="OSGeo.MapGuide.Geometry" Version="4.0.0" />
     <PackageReference Include="OSGeo.MapGuide.PlatformBase" Version="4.0.0" />
   </ItemGroup>
 </Project>
Index: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi	2020-11-12 14:21:51 UTC (rev 9772)
Property changes on: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi
Added: svn:ignore
## -0,0 +1,2 ##
+bin
+obj
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/TestMapGuideApi.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/TestMapGuideApi.csproj	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/TestMapGuideApi.csproj	2020-11-12 14:21:51 UTC (rev 9772)
@@ -17,6 +17,8 @@
   </ItemGroup>
   <ItemGroup>
     <PackageReference Include="OSGeo.MapGuide.MapGuideCommon" Version="4.0.0" />
     <PackageReference Include="OSGeo.MapGuide.Web" Version="4.0.0" />
   </ItemGroup>
Index: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc	2020-11-12 14:21:51 UTC (rev 9772)
Property changes on: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc
Added: svn:ignore
## -0,0 +1,2 ##
+obj
+bin
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs	2020-11-12 14:21:51 UTC (rev 9772)
@@ -8,11 +8,29 @@
         static void TestBody(string webConfigPath)
-            MapGuideApi.MgInitializeWebTier(webConfigPath);
+            try
+                MapGuideApi.MgInitializeWebTier(webConfigPath);
+            catch (MgException ex)
+                OnException(ex);
+                return;
             Console.WriteLine("[dotnet]: Initialized");
-            var user = new MgUserInformation("Anonymous", "");
-            var conn = new MgSiteConnection();
-            conn.Open(user);
+            MgUserInformation user;
+            MgSiteConnection conn;
+            try
+                user = new MgUserInformation("Anonymous", "");
+                conn = new MgSiteConnection();
+                conn.Open(user);
+                OnException(ex);
+                return;
             // Create a session repository
             var site = conn.GetSite();
             var sessionID = site.CreateSession();
@@ -86,10 +104,7 @@
-                Console.WriteLine("[dotnet]: MgException caught");
-                Console.WriteLine($"[dotnet]: MgException - Message: {ex.GetExceptionMessage()}");
-                Console.WriteLine($"[dotnet]: MgException - Details: {ex.GetDetails()}");
-                Console.WriteLine($"[dotnet]: MgException - Stack: {ex.GetStackTrace()}");
+                OnException(ex);
             Console.WriteLine("[dotnet]: Trigger another exception");
             try
@@ -98,13 +113,18 @@
+                OnException(ex);
+        static void OnException(MgException ex)
+            Console.WriteLine("[dotnet]: MgException caught");
+            Console.WriteLine($"[dotnet]: MgException - Message: {ex.GetExceptionMessage()}");
+            Console.WriteLine($"[dotnet]: MgException - Details: {ex.GetDetails()}");
+            Console.WriteLine($"[dotnet]: MgException - Stack: {ex.GetStackTrace()}");
         static void Main(string[] args)
             string path = args[0];
Added: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Properties/launchSettings.json
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Properties/launchSettings.json	                        (rev 0)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Properties/launchSettings.json	2020-11-12 14:21:51 UTC (rev 9772)
@@ -0,0 +1,9 @@
+  "profiles": {
+    "TestMisc": {
+      "commandName": "Project",
+      "commandLineArgs": "..\\..\\..\\..\\..\\..\\..\\..\\..\\Web\\src\\webconfig.ini",
+      "nativeDebugging": true
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/TestMisc.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/TestMisc.csproj	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/TestMisc.csproj	2020-11-12 14:21:51 UTC (rev 9772)
@@ -2,11 +2,13 @@
   <PropertyGroup>
     <OutputType>Exe</OutputType>
-    <TargetFramework>netcoreapp2.1</TargetFramework>
+    <TargetFramework>netcoreapp3.1</TargetFramework>
   </PropertyGroup>
   <ItemGroup>
     <PackageReference Include="CommandLineParser" Version="2.2.1" />
   </ItemGroup>
Index: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner	2020-11-12 14:21:51 UTC (rev 9772)
Property changes on: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner
Added: svn:ignore
## -0,0 +1,2 ##
+bin
+obj
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner/Properties/launchSettings.json
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner/Properties/launchSettings.json	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner/Properties/launchSettings.json	2020-11-12 14:21:51 UTC (rev 9772)
@@ -2,8 +2,8 @@
   "profiles": {
     "TestRunner": {
-      "commandLineArgs": "--web-config-path \"C:\\Program Files\\OSGeo\\MapGuide\\Web\\www\\webconfig.ini\" --dictionary-path \"C:\\Program Files\\OSGeo\\MapGuide\\CS-Map\\Dictionaries\" --test-data-root \"D:\\workspace\\mapguide-api-bindings\\src\\TestData\"",
-      "workingDirectory": "D:\\Workspace\\mapguide-api-bindings\\src\\Test\\DotNet\\src\\TestRunner"
+      "commandLineArgs": "--web-config-path \"..\\..\\..\\..\\..\\..\\..\\..\\..\\Web\\src\\webconfig.ini\" --dictionary-path \"..\\..\\..\\..\\..\\..\\..\\..\\..\\Oem\\CsMap\\CsMapDev\\Dictionaries\" --test-data-root \"..\\..\\..\\..\\..\\..\\..\\TestData\"",
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner/TestRunner.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner/TestRunner.csproj	2020-11-12 13:09:50 UTC (rev 9771)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunner/TestRunner.csproj	2020-11-12 14:21:51 UTC (rev 9772)
@@ -2,7 +2,7 @@
   <PropertyGroup>
     <Description>TestRunner Console Application</Description>
     <Authors>OSGeo</Authors>
-    <TargetFrameworks>netcoreapp2.1</TargetFrameworks>
+    <TargetFrameworks>netcoreapp3.1</TargetFrameworks>
     <AssemblyName>TestRunner</AssemblyName>
     <PackageId>TestRunner</PackageId>
@@ -19,6 +19,8 @@
   </ItemGroup>
   <ItemGroup>
   </ItemGroup>
 </Project>
More information about the mapguide-commits mailing list
