[mapguide-commits] r9785 - in sandbox/jng/vanilla_swig/Bindings/src/Test: . Java Java/extlib Java/src/org/osgeo/mapguide/test/platform/operations/resource
svn_mapguide at osgeo.org
Sat Nov 14 06:54:14 PST 2020
Author: jng
Date: 2020-11-14 06:54:14 -0800 (Sat, 14 Nov 2020)
New Revision: 9785
Added:
sandbox/jng/vanilla_swig/Bindings/src/Test/Java/extlib/ant-contrib.jar
sandbox/jng/vanilla_swig/Bindings/src/Test/Java/build.xml
sandbox/jng/vanilla_swig/Bindings/src/Test/Java/src/org/osgeo/mapguide/test/platform/operations/resource/SetResourceData.java
Fix up Java test runner to build and run properly (it is not passing, we'll deal with that later)
Index: sandbox/jng/vanilla_swig/Bindings/src/Test
--- sandbox/jng/vanilla_swig/Bindings/src/Test 2020-11-14 14:13:44 UTC (rev 9784)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test 2020-11-14 14:54:14 UTC (rev 9785)
Property changes on: sandbox/jng/vanilla_swig/Bindings/src/Test
___________________________________________________________________
Added: svn:ignore
## -0,0 +1 ##
+java_dist
Index: sandbox/jng/vanilla_swig/Bindings/src/Test/Java
--- sandbox/jng/vanilla_swig/Bindings/src/Test/Java 2020-11-14 14:13:44 UTC (rev 9784)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/Java 2020-11-14 14:54:14 UTC (rev 9785)
Property changes on: sandbox/jng/vanilla_swig/Bindings/src/Test/Java
Added: svn:ignore
## -0,0 +1 ##
+build
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/Java/build.xml
--- sandbox/jng/vanilla_swig/Bindings/src/Test/Java/build.xml 2020-11-14 14:13:44 UTC (rev 9784)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/Java/build.xml 2020-11-14 14:54:14 UTC (rev 9785)
@@ -1,8 +1,12 @@
<?xml version="1.0" encoding="utf-8" ?>
<project name="MgUnitTest" default="dist" basedir=".">
<description>MgUnitTest project file</description>
- <!-- Must install ant-contrib 1.0b2 or higher -->
- <taskdef resource="net/sf/antcontrib/antcontrib.properties"/>
+ <!-- Must install ant-contrib 1.0b2 or higher as we need this to write a custom webconfig.ini -->
+ <taskdef resource="net/sf/antcontrib/antcontrib.properties">
+ <classpath>
+ <pathelement location="extlib/ant-contrib.jar"/>
+ </classpath>
+ </taskdef>
<condition property="unix">
<os family="unix" />
</condition>
@@ -16,16 +20,17 @@
<property name="classpath" location="lib" />
<property name="extlib" location="extlib" />
<property name="build.target" location="64" />
- <property name="binsrc.web" location="../../../Web/bin/release64" />
- <property name="jarsrc.web" location="../../../Web/src/WEB-INF/lib" />
- <property name="mapguide.res.src" location="../../../Common/MapGuideCommon/Resources/mapguide_en.res" />
- <property name="mapguide.config.src" location="../../../Web/src/webconfig.ini" />
+ <property name="binsrc.common" location="../../../../Common/bin/Release64" />
+ <property name="binsrc.web" location="../../../../Web/bin/Release64" />
+ <property name="jarsrc.web" location="../../../packages/Java/Release/x64" />
+ <property name="mapguide.res.src" location="../../../../Common/MapGuideCommon/Resources/mapguide_en.res" />
+ <property name="mapguide.config.src" location="../../../../Web/src/webconfig.ini" />
<property name="mapguide.res" location="${dist}/Resources/mapguide_en.res" />
<property name="mapguide.config" location="${dist}/webconfig.ini" />
- <property name="mapguide.dictpath" location="../../../Oem/CsMap/Dictionaries" />
+ <property name="mapguide.dictpath" location="../../../../Oem/CsMap/CsMapDev/Dictionaries" />
<property name="unittest.logpath" location="${dist}/unittest.log" />
<!-- Linux-specific -->
- <property name="mapguide.ldpath" location="/usr/local/mapguideopensource-3.0.0/lib:/usr/local/mapguideopensource-3.0.0/webserverextensions/lib" />
+ <property name="mapguide.ldpath" location="/usr/local/mapguideopensource-4.0.0/lib64:/usr/local/mapguideopensource-4.0.0/webserverextensions/lib64" />
<path id="master-classpath">
<fileset dir="${classpath}">
<include name="*.jar" />
@@ -33,38 +38,53 @@
</path>
<target name="initwin" if="windows">
<echo message="Init build environment for Windows" />
+ <echo message=" dist = ${dist}" />
+ <echo message=" binsrc.web = ${binsrc.web}" />
+ <echo message=" jarsrc.web = ${jarsrc.web}" />
+ <echo message=" mapguide.res.src = ${mapguide.res.src}" />
+ <echo message=" mapguide.config.src = ${mapguide.config.src}" />
+ <echo message=" mapguide.dictpath = ${mapguide.dictpath}" />
<!-- Create the time stamp -->
<tstamp/>
<!-- Create the build directory structure used by compile -->
<mkdir dir="${build}"/>
<!-- Copy required jars and dlls -->
+ <echo message="Copying files from ${jarsrc.web}" />
<copy todir="${classpath}">
<fileset dir="${jarsrc.web}">
- <include name="**/MapGuideApi.jar" />
+ <include name="**/*.jar" />
+ <include name="**/*.dll" />
+ <include name="**/*.pdb" />
</fileset>
</copy>
+ <echo message="Copying support files from ${extlib}" />
<fileset dir="${extlib}">
<include name="**/sqlite4java.jar" />
</fileset>
</copy>
- <condition property="binsrc.web" value="../../../Web/bin/release">
- <equals arg1="${build.target}" arg2="32" />
- </condition>
- <condition property="binsrc.web" value="../../../Web/bin/release64">
- <equals arg1="${build.target}" arg2="64" />
- </condition>
<echo message="Copying dlls from ${binsrc.web}" />
<fileset dir="${binsrc.web}">
- <include name="**/Mg*.dll" />
- <include name="**/ACE.dll" />
- <include name="**/GEOS.dll" />
- <include name="**/lib_json.dll" />
- <include name="**/MapGuideJavaApi.dll" />
- <include name="**/xerces-c_3_1mg.dll" />
+ <include name="**/MgFoundation.*" />
+ <include name="**/MgGeometry.*" />
+ <include name="**/MgPlatformBase.*" />
+ <include name="**/MgMapGuideCommon.*" />
+ <include name="**/MgMdfModel.*" />
+ <include name="**/MgMdfParser.*" />
</fileset>
</copy>
+ <echo message="Copying dlls from ${binsrc.web}" />
+ <copy todir="${classpath}">
+ <fileset dir="${binsrc.web}">
+ <include name="**/MgHttpHandler*.*" />
+ <include name="**/MgWeb*.*" />
+ <include name="**/ACE.*" />
+ <include name="**/GEOS.*" />
+ <include name="**/lib_json.*" />
+ <include name="**/xerces-c_3_1mg.*" />
+ </fileset>
+ </copy>
</target>
<target name="initunix" if="unix">
<echo message="Init build environment for Unix" />
Added: sandbox/jng/vanilla_swig/Bindings/src/Test/Java/extlib/ant-contrib.jar
(Binary files differ)
Index: sandbox/jng/vanilla_swig/Bindings/src/Test/Java/extlib/ant-contrib.jar
--- sandbox/jng/vanilla_swig/Bindings/src/Test/Java/extlib/ant-contrib.jar 2020-11-14 14:13:44 UTC (rev 9784)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/Java/extlib/ant-contrib.jar 2020-11-14 14:54:14 UTC (rev 9785)
Property changes on: sandbox/jng/vanilla_swig/Bindings/src/Test/Java/extlib/ant-contrib.jar
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/Java/src/org/osgeo/mapguide/test/platform/operations/resource/SetResourceData.java
--- sandbox/jng/vanilla_swig/Bindings/src/Test/Java/src/org/osgeo/mapguide/test/platform/operations/resource/SetResourceData.java 2020-11-14 14:13:44 UTC (rev 9784)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/Java/src/org/osgeo/mapguide/test/platform/operations/resource/SetResourceData.java 2020-11-14 14:54:14 UTC (rev 9785)
@@ -41,15 +41,15 @@
return TestResult.FromByteReader(null);
catch (MgException ex)
- //HACK/FIXME: The test suite is passing paths with incorrect case to this operation (presumably to exercise
- //this operation in a Linux environment where case-sensitive paths matter), but there's no way in my knowledge
- //to perform platform-specific verification of test results. So what we have is an intentionally failing test
- //for a platform that has no means to verify that.
- //As a workaround, when such bad paths are encountered (that should present themselves as thrown
+ //HACK/FIXME: The test suite is passing paths with incorrect case to this operation (presumably to exercise
+ //this operation in a Linux environment where case-sensitive paths matter), but there's no way in my knowledge
+ //to perform platform-specific verification of test results. So what we have is an intentionally failing test
+ //for a platform that has no means to verify that.
+ //As a workaround, when such bad paths are encountered (that should present themselves as thrown
//MgFileNotFoundException objects), return the result that is expected on Windows: An empty result.
- if (!CommonUtility.IsWindows() && (ex instanceof MgFileNotFoundException)) {
+ if (!CommonUtility.IsWindows() && (ex.getExceptionCode() == MgExceptionCodes.MgFileNotFoundException)) {
} else {
return TestResult.FromMgException(ex);
More information about the mapguide-commits
