[mapguide-commits] r9790 - in sandbox/jng/vanilla_swig/Bindings: . src/Test/DotNet src/Test/DotNet/src src/Test/DotNet/src/TestRunnerFull
svn_mapguide at osgeo.org
Thu Nov 19 01:55:54 PST 2020
Author: jng
Date: 2020-11-19 01:55:54 -0800 (Thu, 19 Nov 2020)
New Revision: 9790
Removed:
sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestCommonFull/
sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApiFull/
sandbox/jng/vanilla_swig/Bindings/TODO.txt
sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/FullFramework.sln
sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunnerFull/TestRunnerFull.csproj
Remove full versions of TestCommon and TestMapGuideApi as their netstandard2.0 counterparts are already consumable by the full framework test runner
Modified: sandbox/jng/vanilla_swig/Bindings/TODO.txt
--- sandbox/jng/vanilla_swig/Bindings/TODO.txt 2020-11-19 09:51:19 UTC (rev 9789)
+++ sandbox/jng/vanilla_swig/Bindings/TODO.txt 2020-11-19 09:55:54 UTC (rev 9790)
@@ -9,7 +9,7 @@
- [ ] Relocate/remove existing test code
- Split .net binding into the Foundation/Geometry/PlatformBase/MapGuideCommon/Web layout (https://github.com/jumpinjackie/mapguide-api-bindings/issues/18)
- [x] Add .targets files to each C# project so that native dlls are copied properly when consumed by legacy .net framework applications/libraries
- - [ ] Consolidate TestCommon and TestMapGuideApi .net projects to unified netstandard2.0 libraries
+ - [x] Consolidate TestCommon and TestMapGuideApi .net projects to unified netstandard2.0 libraries
- [ ] Tidy mg_exception_callback to no longer take an exception class name argument (it is no longer used or necessary)
- [ ] Add CentOS 6 Dockerfile that
- Install SWIG and common libs tarball (from docker build system)
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/FullFramework.sln
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/FullFramework.sln 2020-11-19 09:51:19 UTC (rev 9789)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/FullFramework.sln 2020-11-19 09:55:54 UTC (rev 9790)
@@ -1,56 +1,70 @@
Microsoft Visual Studio Solution File, Format Version 12.00
-# Visual Studio 15
-VisualStudioVersion = 15.0.26124.0
+# Visual Studio Version 16
+VisualStudioVersion = 16.0.30709.132
MinimumVisualStudioVersion = 15.0.26124.0
Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "TestMiscFull", "src\TestMiscFull\TestMiscFull.csproj", "{27285BB5-37B4-42DD-AB2C-CCD91824D044}"
EndProject
-Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "TestCommonFull", "src\TestCommonFull\TestCommonFull.csproj", "{EB8713C5-0284-47C5-950A-90E4EB326669}"
+Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "TestRunnerFull", "src\TestRunnerFull\TestRunnerFull.csproj", "{757BA8EB-065F-47A7-834D-025C1559E2A5}"
EndProject
-Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "TestMapGuideApiFull", "src\TestMapGuideApiFull\TestMapGuideApiFull.csproj", "{6584C02F-080F-425D-BE53-9F72F7BE2897}"
+Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "TestCommon", "src\TestCommon\TestCommon.csproj", "{905BB3C2-4969-4AF3-8F4D-659DB683038C}"
EndProject
-Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "TestRunnerFull", "src\TestRunnerFull\TestRunnerFull.csproj", "{757BA8EB-065F-47A7-834D-025C1559E2A5}"
+Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "TestMapGuideApi", "src\TestMapGuideApi\TestMapGuideApi.csproj", "{F3AEE349-3493-47C9-A1EF-607775FBCC3A}"
EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
+ Debug|Any CPU = Debug|Any CPU
Debug|x64 = Debug|x64
Debug|x86 = Debug|x86
+ Release|Any CPU = Release|Any CPU
Release|x64 = Release|x64
Release|x86 = Release|x86
EndGlobalSection
GlobalSection(ProjectConfigurationPlatforms) = postSolution
+ {27285BB5-37B4-42DD-AB2C-CCD91824D044}.Debug|Any CPU.ActiveCfg = Debug|x86
{27285BB5-37B4-42DD-AB2C-CCD91824D044}.Debug|x64.ActiveCfg = Debug|x64
{27285BB5-37B4-42DD-AB2C-CCD91824D044}.Debug|x64.Build.0 = Debug|x64
{27285BB5-37B4-42DD-AB2C-CCD91824D044}.Debug|x86.ActiveCfg = Debug|x86
{27285BB5-37B4-42DD-AB2C-CCD91824D044}.Debug|x86.Build.0 = Debug|x86
+ {27285BB5-37B4-42DD-AB2C-CCD91824D044}.Release|Any CPU.ActiveCfg = Release|x86
{27285BB5-37B4-42DD-AB2C-CCD91824D044}.Release|x64.ActiveCfg = Release|x64
{27285BB5-37B4-42DD-AB2C-CCD91824D044}.Release|x64.Build.0 = Release|x64
{27285BB5-37B4-42DD-AB2C-CCD91824D044}.Release|x86.ActiveCfg = Release|x86
{27285BB5-37B4-42DD-AB2C-CCD91824D044}.Release|x86.Build.0 = Release|x86
- {EB8713C5-0284-47C5-950A-90E4EB326669}.Debug|x64.ActiveCfg = Debug|Any CPU
- {EB8713C5-0284-47C5-950A-90E4EB326669}.Debug|x64.Build.0 = Debug|Any CPU
- {EB8713C5-0284-47C5-950A-90E4EB326669}.Debug|x86.ActiveCfg = Debug|Any CPU
- {EB8713C5-0284-47C5-950A-90E4EB326669}.Debug|x86.Build.0 = Debug|Any CPU
- {EB8713C5-0284-47C5-950A-90E4EB326669}.Release|x64.ActiveCfg = Release|Any CPU
- {EB8713C5-0284-47C5-950A-90E4EB326669}.Release|x64.Build.0 = Release|Any CPU
- {EB8713C5-0284-47C5-950A-90E4EB326669}.Release|x86.ActiveCfg = Release|Any CPU
- {EB8713C5-0284-47C5-950A-90E4EB326669}.Release|x86.Build.0 = Release|Any CPU
- {6584C02F-080F-425D-BE53-9F72F7BE2897}.Debug|x64.ActiveCfg = Debug|Any CPU
- {6584C02F-080F-425D-BE53-9F72F7BE2897}.Debug|x64.Build.0 = Debug|Any CPU
- {6584C02F-080F-425D-BE53-9F72F7BE2897}.Debug|x86.ActiveCfg = Debug|Any CPU
- {6584C02F-080F-425D-BE53-9F72F7BE2897}.Debug|x86.Build.0 = Debug|Any CPU
- {6584C02F-080F-425D-BE53-9F72F7BE2897}.Release|x64.ActiveCfg = Release|Any CPU
- {6584C02F-080F-425D-BE53-9F72F7BE2897}.Release|x64.Build.0 = Release|Any CPU
- {6584C02F-080F-425D-BE53-9F72F7BE2897}.Release|x86.ActiveCfg = Release|Any CPU
- {6584C02F-080F-425D-BE53-9F72F7BE2897}.Release|x86.Build.0 = Release|Any CPU
+ {757BA8EB-065F-47A7-834D-025C1559E2A5}.Debug|Any CPU.ActiveCfg = Debug|x86
{757BA8EB-065F-47A7-834D-025C1559E2A5}.Debug|x64.ActiveCfg = Debug|x64
{757BA8EB-065F-47A7-834D-025C1559E2A5}.Debug|x64.Build.0 = Debug|x64
{757BA8EB-065F-47A7-834D-025C1559E2A5}.Debug|x86.ActiveCfg = Debug|x86
{757BA8EB-065F-47A7-834D-025C1559E2A5}.Debug|x86.Build.0 = Debug|x86
+ {757BA8EB-065F-47A7-834D-025C1559E2A5}.Release|Any CPU.ActiveCfg = Release|x86
{757BA8EB-065F-47A7-834D-025C1559E2A5}.Release|x64.ActiveCfg = Release|x64
{757BA8EB-065F-47A7-834D-025C1559E2A5}.Release|x64.Build.0 = Release|x64
{757BA8EB-065F-47A7-834D-025C1559E2A5}.Release|x86.ActiveCfg = Release|x86
{757BA8EB-065F-47A7-834D-025C1559E2A5}.Release|x86.Build.0 = Release|x86
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Debug|x64.ActiveCfg = Debug|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Debug|x64.Build.0 = Debug|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Debug|x86.Build.0 = Debug|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Release|Any CPU.Build.0 = Release|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Release|x64.ActiveCfg = Release|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Release|x64.Build.0 = Release|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Release|x86.ActiveCfg = Release|Any CPU
+ {905BB3C2-4969-4AF3-8F4D-659DB683038C}.Release|x86.Build.0 = Release|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Debug|x64.ActiveCfg = Debug|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Debug|x64.Build.0 = Debug|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Debug|x86.Build.0 = Debug|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Release|Any CPU.Build.0 = Release|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Release|x64.ActiveCfg = Release|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Release|x64.Build.0 = Release|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Release|x86.ActiveCfg = Release|Any CPU
+ {F3AEE349-3493-47C9-A1EF-607775FBCC3A}.Release|x86.Build.0 = Release|Any CPU
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunnerFull/TestRunnerFull.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunnerFull/TestRunnerFull.csproj 2020-11-19 09:51:19 UTC (rev 9789)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestRunnerFull/TestRunnerFull.csproj 2020-11-19 09:55:54 UTC (rev 9790)
@@ -13,10 +13,6 @@
<Compile Include="..\TestRunner\Program.cs" Link="Program.cs" />
</ItemGroup>
<ItemGroup>
- <ProjectReference Include="..\TestCommonFull\TestCommonFull.csproj" />
- <ProjectReference Include="..\TestMapGuideApiFull\TestMapGuideApiFull.csproj" />
- </ItemGroup>
- <ItemGroup>
<PackageReference Include="CommandLineParser" Version="2.2.1" />
<PackageReference Include="OSGeo.MapGuide.Foundation" Version="4.0.0" />
<PackageReference Include="OSGeo.MapGuide.Geometry" Version="4.0.0" />
@@ -30,4 +26,8 @@
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
</ItemGroup>
+ <ItemGroup>
+ <ProjectReference Include="..\TestCommon\TestCommon.csproj" />
+ <ProjectReference Include="..\TestMapGuideApi\TestMapGuideApi.csproj" />
+ </ItemGroup>
</Project>
\ No newline at end of file
More information about the mapguide-commits
