[mapguide-commits] r9794 - in sandbox/jng/vanilla_swig/Bindings: . src/Bindings/DotNet/PlatformBase src/Bindings/Java src/IMake
svn_mapguide at osgeo.org
Thu Nov 19 04:46:33 PST 2020
Author: jng
Date: 2020-11-19 04:46:33 -0800 (Thu, 19 Nov 2020)
New Revision: 9794
sandbox/jng/vanilla_swig/Bindings/TODO.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj
sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/JavaApi.vcxproj
sandbox/jng/vanilla_swig/Bindings/src/IMake/IMake.cpp
Update IMake to re-map exception documentation to output MgException with every possible exception code.
Also fix bad pre-build in PlatformBaseApi that caused MgMdfParser.dll to not be copied over, resulting in a nuget package with un-met native dependencies.
Modified: sandbox/jng/vanilla_swig/Bindings/TODO.txt
--- sandbox/jng/vanilla_swig/Bindings/TODO.txt 2020-11-19 11:28:37 UTC (rev 9793)
+++ sandbox/jng/vanilla_swig/Bindings/TODO.txt 2020-11-19 12:46:33 UTC (rev 9794)
@@ -24,11 +24,12 @@
- [ ] Add SWIG preprocessor that controls whether the class id header should be included
- [ ] Run SWIG in XML mode to produce an XML of the MapGuide API surface
- [ ] Update ClassMapGen tool to generate class id files for .net/Java/PHP based on this XML file
- - [ ] Because we've flattened the exception hierarchy, IMake needs to rewrite \exception directives to say in [Java/C#] that it throws MgException with any of the following exception codes
+ - [x] Because we've flattened the exception hierarchy, IMake needs to rewrite \exception directives to say in [Java/C#] that it throws MgException with any of the following exception codes
- Test Suite
- [x] Sync up current test data under /UnitTest to match what is in GitHub repo
- [x] Add test data setup script for .net/Java test suites to copy the synced up test data under /UnitTest to the location the test suite is expecting
- - Java binding are generated)
+ - Java binding
+ - [ ] Running javadoc against the generated sources produces many errors. See if we can fix them
- [x] Verify test suite still passes (Windows)
- [ ] Verify test suite still passes (Linux)
- Migrate to SWIG 4.0.0 (https://github.com/jumpinjackie/mapguide-api-bindings/issues/36)
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj 2020-11-19 11:28:37 UTC (rev 9793)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj 2020-11-19 12:46:33 UTC (rev 9794)
@@ -63,7 +63,7 @@
"..\..\..\Tools\swig\install\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module PlatformBaseUnmanagedApi -o "$(ProjectDir)PlatformBaseUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.PlatformBase" PlatformBaseApi.i
del /Q ..\..\..\Managed\DotNet\OSGeo.MapGuide.PlatformBase\PlatformBaseUnmanagedApi.cs
copy /Y "$(ProjectDir)..\..\..\..\..\Common\bin\$(Configuration)64\MgMdfModel*.*" "$(TargetDir)\native\"
-copy /Y "$(ProjectDir)..\..\..\..\..\Common\bin\$(Configuration)64\MgMdfModel*.*" "$(TargetDir)\native\"
+copy /Y "$(ProjectDir)..\..\..\..\..\Common\bin\$(Configuration)64\MgMdfParser*.*" "$(TargetDir)\native\"
copy /Y "$(ProjectDir)..\..\..\..\..\Common\bin\$(Configuration)64\MgPlatformBase*.*" "$(TargetDir)\native\"
</Command>
</PreBuildEvent>
@@ -103,7 +103,7 @@
</Command>
</PreBuildEvent>
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/JavaApi.vcxproj
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/JavaApi.vcxproj 2020-11-19 11:28:37 UTC (rev 9793)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/JavaApi.vcxproj 2020-11-19 12:46:33 UTC (rev 9794)
@@ -95,6 +95,8 @@
"$(JAVA_HOME)\bin\jar" cf $(SolutionDir)..\..\packages\Java\Release\x64\MapGuideApi.jar org\osgeo\mapguide\*.class
echo Building -sources JAR file
"$(JAVA_HOME)\bin\jar" cf $(SolutionDir)..\..\packages\Java\Release\x64\MapGuideApi-sources.jar org\osgeo\mapguide\*.java
+rem echo Building javadoc
+rem "$(JAVA_HOME)\bin\javadoc" -d $(SolutionDir)..\..\packages\Java\Release\x64\html org\osgeo\mapguide\*.java
popd</Command>
</PostBuildEvent>
</ItemDefinitionGroup>
@@ -141,6 +143,8 @@
popd</Command>
</PostBuildEvent>
Modified: sandbox/jng/vanilla_swig/Bindings/src/IMake/IMake.cpp
--- sandbox/jng/vanilla_swig/Bindings/src/IMake/IMake.cpp 2020-11-19 11:28:37 UTC (rev 9793)
+++ sandbox/jng/vanilla_swig/Bindings/src/IMake/IMake.cpp 2020-11-19 12:46:33 UTC (rev 9794)
@@ -13,7 +13,7 @@
java
-static char version[] = "1.5.2";
+static char version[] = "1.5.3";
static char EXTERNAL_API_DOCUMENTATION[] = "(NOTE: This API is not officially supported and may be subject to removal in a future release without warning. Use with caution.)";
static string module;
@@ -915,8 +915,8 @@
if (exceptionParts.size() > 0) {
for (size_t i = 0; i < exceptionParts.size(); i++) {
- javaDoc.append(" * @exception ");
- javaDoc.append(exceptionParts[i]);
+ javaDoc.append(" * @exception org.osgeo.mapguide.MgException with code ");
+ javaDoc.append(Trim(exceptionParts[i]));
javaDoc.append("\n");
@@ -1119,10 +1119,13 @@
csharpDoc.append("///<exception cref=\"");
csharpDoc.append(nspace);
- csharpDoc.append(".");
+ csharpDoc.append(".MgException\">");
if (eelems.size() > 1) {
+ csharpDoc.append("with code (<see cref=\"");
+ csharpDoc.append(nspace);
+ csharpDoc.append(".MgExceptionCodes.");
csharpDoc.append(eelems[0]);
- csharpDoc.append("\">");
+ csharpDoc.append("\" />) ");
for (size_t j = 1; j < eelems.size(); j++) {
csharpDoc.append(" ");
csharpDoc.append(eelems[j]);
More information about the mapguide-commits
