[mapguide-commits] r9797 - in sandbox/jng/vanilla_swig/Bindings: . src/Bindings src/Bindings/MapGuideApi src/Bindings/Php src/Managed/DotNet/Common src/Managed/Java/org/osgeo/mapguide src/Test/DotNet/src/TestMapGuideApi src/Test/DotNet/src/TestMapGuideApi/ExternalTests src/Test/DotNet/src/TestMisc src/Tools/ClassMapGen src/Tools/ClassMapGen/Data src/Tools/ClassMapGen/Data/Templates
svn_mapguide at osgeo.org
Fri Nov 20 06:21:55 PST 2020
Author: jng
Date: 2020-11-20 06:21:54 -0800 (Fri, 20 Nov 2020)
New Revision: 9797
Added:
sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/ExternalTests/ClassIdSanityTest.cs
Removed:
sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/classmap_master.json
sandbox/jng/vanilla_swig/Bindings/TODO.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/Bindings.sln
sandbox/jng/vanilla_swig/Bindings/src/Bindings/MapGuideApi/MapGuideApiGen.xml
sandbox/jng/vanilla_swig/Bindings/src/Bindings/Php/PhpClassMap.cpp
sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/Common/MgClassMap.cs
sandbox/jng/vanilla_swig/Bindings/src/Managed/Java/org/osgeo/mapguide/ObjectFactory.java
sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/MapGuideTestExecutorCollection.cs
sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/TestMapGuideApi.csproj
sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs
sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/TestMisc.csproj
sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/dotnet.txt
sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/java.txt
sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Program.cs
- Update .net test suite with a sanity check that all the class ids extracted by ClassMapGen map to types that actually exist in our 5 .net assemblies
- Update MgClassMap template to do a name -> id reverse test to make sure that we haven't accidentally double-registered the same type name under different class ids
- Update ObjectFactory.java template to throw a better error if we cannot resolve a java proxy class from the C++ pointer
- Add upstream dependent projects to Bindings.sln so we don't have to build said projects in Server.sln or WebTier.sln first
- Check in regenerated class maps
- Delete classmap_master.json as that is no longer necessary
Modified: sandbox/jng/vanilla_swig/Bindings/TODO.txt
--- sandbox/jng/vanilla_swig/Bindings/TODO.txt 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/TODO.txt 2020-11-20 14:21:54 UTC (rev 9797)
@@ -26,8 +26,8 @@
- [ ] Remove monolithic binding upon verification of test suite across all supported platforms
- Automatic class id generation (https://github.com/jumpinjackie/mapguide-api-bindings/issues/34)
- [x] Add SWIG preprocessor that controls whether the class id header should be included
- - [ ] Run SWIG in XML mode to produce an XML of the MapGuide API surface
- - [ ] Update ClassMapGen tool to generate class id files for .net/Java/PHP based on this XML file
+ - [x] Run SWIG in XML mode to produce an XML of the MapGuide API surface
+ - [x] Update ClassMapGen tool to generate class id files for .net/Java/PHP based on this XML file
- [x] Because we've flattened the exception hierarchy, IMake needs to rewrite \exception directives to say in [Java/C#] that it throws MgException with any of the following exception codes
- Test Suite
- [x] Sync up current test data under /UnitTest to match what is in GitHub repo
@@ -85,5 +85,6 @@
- [ ] Port over Java binding
- Old code cleanup/consolidation
- [ ] Remove old IMake
+ - [ ] Remove old binding projects from WebTier
- [ ] Fold FoundationTest into mgserver test suite
- [ ] Remove SQLite and its related projects from Oem
\ No newline at end of file
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/Bindings.sln
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/Bindings.sln 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/Bindings.sln 2020-11-20 14:21:54 UTC (rev 9797)
@@ -5,7 +5,14 @@
MinimumVisualStudioVersion = 10.0.40219.1
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DotNetUnmanagedApi", "DotNet\DotNetUnmanagedApi.vcxproj", "{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}"
ProjectSection(ProjectDependencies) = postProject
+ {795B1B0E-4EC8-469D-B641-E26324266FBF} = {795B1B0E-4EC8-469D-B641-E26324266FBF}
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44} = {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4} = {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}
{B601F04C-0D42-4AFC-A092-B31185E2EA8C} = {B601F04C-0D42-4AFC-A092-B31185E2EA8C}
+ {B797917B-6842-467C-8B14-E00B76A91247} = {B797917B-6842-467C-8B14-E00B76A91247}
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425} = {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}
+ {5287A594-4D4F-43FE-A281-E279AB708CF1} = {5287A594-4D4F-43FE-A281-E279AB708CF1}
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0} = {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}
EndProjectSection
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IMake", "..\IMake\IMake.vcxproj", "{B601F04C-0D42-4AFC-A092-B31185E2EA8C}"
@@ -40,6 +47,7 @@
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FoundationApi", "DotNet\Foundation\FoundationApi.vcxproj", "{73C62FF2-C188-4A61-929E-2F112D7E17AA}"
EndProjectSection
EndProject
Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "OSGeo.MapGuide.Foundation", "..\Managed\DotNet\OSGeo.MapGuide.Foundation\OSGeo.MapGuide.Foundation.csproj", "{120AC2A9-5EBE-4512-9FF7-54EA04192196}"
@@ -50,6 +58,7 @@
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "GeometryApi", "DotNet\Geometry\GeometryApi.vcxproj", "{B994F673-EB8E-4C65-8884-B56AB8783115}"
{73C62FF2-C188-4A61-929E-2F112D7E17AA} = {73C62FF2-C188-4A61-929E-2F112D7E17AA}
EndProjectSection
EndProject
@@ -73,6 +82,7 @@
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B} = {3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}
{B994F673-EB8E-4C65-8884-B56AB8783115} = {B994F673-EB8E-4C65-8884-B56AB8783115}
EndProjectSection
EndProject
@@ -88,9 +98,12 @@
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WebApi", "DotNet\Web\WebApi.vcxproj", "{C83BF842-ABB1-4870-8003-11EF860E6741}"
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4} = {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}
{42FC41FD-742B-4AED-816E-C211F1B07F3F} = {42FC41FD-742B-4AED-816E-C211F1B07F3F}
@@ -108,156 +121,345 @@
EndProject
Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "MgTestAdmin", "..\Tools\MgTestAdmin\MgTestAdmin.csproj", "{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}"
EndProject
+Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = "Wrap Dependencies", "Wrap Dependencies", "{8CF61B8E-3BE0-4F25-B663-DFB082A67F00}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Geometry", "..\..\..\Common\Geometry\Geometry.vcxproj", "{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Foundation", "..\..\..\Common\Foundation\Foundation.vcxproj", "{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MapGuideCommon", "..\..\..\Common\MapGuideCommon\MapGuideCommon.vcxproj", "{5287A594-4D4F-43FE-A281-E279AB708CF1}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MdfModel", "..\..\..\Common\MdfModel\MdfModel.vcxproj", "{C50254F2-654A-48DE-AF5B-20605AEF8D10}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MdfParser", "..\..\..\Common\MdfParser\MdfParser.vcxproj", "{85882748-DD71-4D2B-9E5A-03AF8C8D91B7}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PlatformBase", "..\..\..\Common\PlatformBase\PlatformBase.vcxproj", "{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}"
+ ProjectSection(ProjectDependencies) = postProject
+ {3BAE3F0E-8F3F-404B-B29B-5881C16BD33B} = {3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HttpHandler", "..\..\..\Web\src\HttpHandler\HttpHandler.vcxproj", "{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WebApp", "..\..\..\Web\src\WebApp\WebApp.vcxproj", "{B797917B-6842-467C-8B14-E00B76A91247}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WebSupport", "..\..\..\Web\src\WebSupport\WebSupport.vcxproj", "{795B1B0E-4EC8-469D-B641-E26324266FBF}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Security", "..\..\..\Common\Security\Security.vcxproj", "{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}"
+EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|Any CPU = Debug|Any CPU
Debug|x64 = Debug|x64
+ Debug|x86 = Debug|x86
Release|Any CPU = Release|Any CPU
Release|x64 = Release|x64
+ Release|x86 = Release|x86
EndGlobalSection
GlobalSection(ProjectConfigurationPlatforms) = postSolution
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|Any CPU.ActiveCfg = Debug|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|x64.ActiveCfg = Debug|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|x64.Build.0 = Debug|x64
+ {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|x86.ActiveCfg = Debug|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|Any CPU.ActiveCfg = Release|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|x64.ActiveCfg = Release|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|x64.Build.0 = Release|x64
+ {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|x86.ActiveCfg = Release|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|Any CPU.ActiveCfg = Debug|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|x64.ActiveCfg = Debug|x64
+ {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|x86.ActiveCfg = Debug|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|Any CPU.ActiveCfg = Release|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x64.ActiveCfg = Release|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x64.Build.0 = Release|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x64.Deploy.0 = Release|x64
+ {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x86.ActiveCfg = Release|x64
{696D2664-D17F-4357-8A19-2B5DC4B29962}.Debug|Any CPU.ActiveCfg = Debug|x64
{696D2664-D17F-4357-8A19-2B5DC4B29962}.Debug|x64.ActiveCfg = Debug|x64
{696D2664-D17F-4357-8A19-2B5DC4B29962}.Debug|x64.Build.0 = Debug|x64
+ {696D2664-D17F-4357-8A19-2B5DC4B29962}.Debug|x86.ActiveCfg = Debug|x64
{696D2664-D17F-4357-8A19-2B5DC4B29962}.Release|Any CPU.ActiveCfg = Release|x64
{696D2664-D17F-4357-8A19-2B5DC4B29962}.Release|x64.ActiveCfg = Release|x64
{696D2664-D17F-4357-8A19-2B5DC4B29962}.Release|x64.Build.0 = Release|x64
+ {696D2664-D17F-4357-8A19-2B5DC4B29962}.Release|x86.ActiveCfg = Release|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|Any CPU.ActiveCfg = Debug|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|x64.ActiveCfg = Debug|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|x64.Build.0 = Debug|x64
+ {C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|x86.ActiveCfg = Debug|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|Any CPU.ActiveCfg = Release|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x64.ActiveCfg = Release|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x64.Build.0 = Release|x64
+ {C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x86.ActiveCfg = Release|x64
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|Any CPU.Build.0 = Debug|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x64.ActiveCfg = Debug|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x64.Build.0 = Debug|Any CPU
+ {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x86.Build.0 = Debug|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|Any CPU.ActiveCfg = Release|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|Any CPU.Build.0 = Release|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x64.ActiveCfg = Release|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x64.Build.0 = Release|Any CPU
+ {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x86.ActiveCfg = Release|Any CPU
+ {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x86.Build.0 = Release|Any CPU
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|Any CPU.ActiveCfg = Debug|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|x64.ActiveCfg = Debug|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|x64.Build.0 = Debug|x64
+ {73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|x86.ActiveCfg = Debug|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Release|Any CPU.ActiveCfg = Release|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Release|x64.ActiveCfg = Release|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Release|x64.Build.0 = Release|x64
+ {73C62FF2-C188-4A61-929E-2F112D7E17AA}.Release|x86.ActiveCfg = Release|x64
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|Any CPU.Build.0 = Debug|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|x64.ActiveCfg = Debug|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|x64.Build.0 = Debug|Any CPU
+ {120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|x86.Build.0 = Debug|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|Any CPU.ActiveCfg = Release|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|Any CPU.Build.0 = Release|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|x64.ActiveCfg = Release|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|x64.Build.0 = Release|Any CPU
+ {120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|x86.ActiveCfg = Release|Any CPU
+ {120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|x86.Build.0 = Release|Any CPU
{B994F673-EB8E-4C65-8884-B56AB8783115}.Debug|Any CPU.ActiveCfg = Debug|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Debug|x64.ActiveCfg = Debug|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Debug|x64.Build.0 = Debug|x64
+ {B994F673-EB8E-4C65-8884-B56AB8783115}.Debug|x86.ActiveCfg = Debug|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Release|Any CPU.ActiveCfg = Release|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Release|x64.ActiveCfg = Release|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Release|x64.Build.0 = Release|x64
+ {B994F673-EB8E-4C65-8884-B56AB8783115}.Release|x86.ActiveCfg = Release|x64
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|Any CPU.Build.0 = Debug|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|x64.ActiveCfg = Debug|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|x64.Build.0 = Debug|Any CPU
+ {15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|x86.Build.0 = Debug|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|Any CPU.ActiveCfg = Release|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|Any CPU.Build.0 = Release|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|x64.ActiveCfg = Release|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|x64.Build.0 = Release|Any CPU
+ {15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|x86.ActiveCfg = Release|Any CPU
+ {15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|x86.Build.0 = Release|Any CPU
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Debug|Any CPU.ActiveCfg = Debug|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Debug|x64.ActiveCfg = Debug|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Debug|x64.Build.0 = Debug|x64
+ {3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Debug|x86.ActiveCfg = Debug|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Release|Any CPU.ActiveCfg = Release|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Release|x64.ActiveCfg = Release|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Release|x64.Build.0 = Release|x64
+ {3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Release|x86.ActiveCfg = Release|x64
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|Any CPU.Build.0 = Debug|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|x64.ActiveCfg = Debug|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|x64.Build.0 = Debug|Any CPU
+ {80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|x86.Build.0 = Debug|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|Any CPU.ActiveCfg = Release|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|Any CPU.Build.0 = Release|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|x64.ActiveCfg = Release|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|x64.Build.0 = Release|Any CPU
+ {80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|x86.ActiveCfg = Release|Any CPU
+ {80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|x86.Build.0 = Release|Any CPU
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Debug|Any CPU.ActiveCfg = Debug|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Debug|x64.ActiveCfg = Debug|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Debug|x64.Build.0 = Debug|x64
+ {42FC41FD-742B-4AED-816E-C211F1B07F3F}.Debug|x86.ActiveCfg = Debug|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Release|Any CPU.ActiveCfg = Release|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Release|x64.ActiveCfg = Release|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Release|x64.Build.0 = Release|x64
+ {42FC41FD-742B-4AED-816E-C211F1B07F3F}.Release|x86.ActiveCfg = Release|x64
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|Any CPU.Build.0 = Debug|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|x64.ActiveCfg = Debug|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|x64.Build.0 = Debug|Any CPU
+ {B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|x86.Build.0 = Debug|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|Any CPU.ActiveCfg = Release|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|Any CPU.Build.0 = Release|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|x64.ActiveCfg = Release|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|x64.Build.0 = Release|Any CPU
+ {B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|x86.ActiveCfg = Release|Any CPU
+ {B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|x86.Build.0 = Release|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|Any CPU.Build.0 = Debug|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|x64.ActiveCfg = Debug|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|x64.Build.0 = Debug|Any CPU
+ {0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|x86.Build.0 = Debug|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|Any CPU.ActiveCfg = Release|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|Any CPU.Build.0 = Release|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|x64.ActiveCfg = Release|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|x64.Build.0 = Release|Any CPU
+ {0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|x86.ActiveCfg = Release|Any CPU
+ {0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|x86.Build.0 = Release|Any CPU
{C83BF842-ABB1-4870-8003-11EF860E6741}.Debug|Any CPU.ActiveCfg = Debug|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Debug|x64.ActiveCfg = Debug|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Debug|x64.Build.0 = Debug|x64
+ {C83BF842-ABB1-4870-8003-11EF860E6741}.Debug|x86.ActiveCfg = Debug|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Release|Any CPU.ActiveCfg = Release|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Release|x64.ActiveCfg = Release|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Release|x64.Build.0 = Release|x64
+ {C83BF842-ABB1-4870-8003-11EF860E6741}.Release|x86.ActiveCfg = Release|x64
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|Any CPU.Build.0 = Debug|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|x64.ActiveCfg = Debug|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|x64.Build.0 = Debug|Any CPU
+ {C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|x86.Build.0 = Debug|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|Any CPU.ActiveCfg = Release|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|Any CPU.Build.0 = Release|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|x64.ActiveCfg = Release|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|x64.Build.0 = Release|Any CPU
+ {C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|x86.ActiveCfg = Release|Any CPU
+ {C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|x86.Build.0 = Release|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Debug|Any CPU.Build.0 = Debug|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Debug|x64.ActiveCfg = Debug|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Debug|x64.Build.0 = Debug|Any CPU
+ {42199427-9825-4A45-A3D1-5C3090C57035}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {42199427-9825-4A45-A3D1-5C3090C57035}.Debug|x86.Build.0 = Debug|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Release|Any CPU.ActiveCfg = Release|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Release|Any CPU.Build.0 = Release|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Release|x64.ActiveCfg = Release|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Release|x64.Build.0 = Release|Any CPU
+ {42199427-9825-4A45-A3D1-5C3090C57035}.Release|x86.ActiveCfg = Release|Any CPU
+ {42199427-9825-4A45-A3D1-5C3090C57035}.Release|x86.Build.0 = Release|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|Any CPU.Build.0 = Debug|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|x64.ActiveCfg = Debug|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|x64.Build.0 = Debug|Any CPU
+ {7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|x86.Build.0 = Debug|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|Any CPU.ActiveCfg = Release|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|Any CPU.Build.0 = Release|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|x64.ActiveCfg = Release|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|x64.Build.0 = Release|Any CPU
+ {7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|x86.ActiveCfg = Release|Any CPU
+ {7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|x86.Build.0 = Release|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|Any CPU.Build.0 = Debug|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|x64.ActiveCfg = Debug|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|x64.Build.0 = Debug|Any CPU
+ {27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|x86.Build.0 = Debug|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|Any CPU.ActiveCfg = Release|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|Any CPU.Build.0 = Release|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|x64.ActiveCfg = Release|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|x64.Build.0 = Release|Any CPU
+ {27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|x86.ActiveCfg = Release|Any CPU
+ {27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|x86.Build.0 = Release|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|Any CPU.Build.0 = Debug|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|x64.ActiveCfg = Debug|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|x64.Build.0 = Debug|Any CPU
+ {096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|x86.ActiveCfg = Debug|Any CPU
+ {096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|x86.Build.0 = Debug|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|Any CPU.ActiveCfg = Release|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|Any CPU.Build.0 = Release|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|x64.ActiveCfg = Release|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|x64.Build.0 = Release|Any CPU
+ {096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|x86.ActiveCfg = Release|Any CPU
+ {096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|x86.Build.0 = Release|Any CPU
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Debug|Any CPU.ActiveCfg = Debug|Win32
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Debug|x64.ActiveCfg = Debug|x64
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Debug|x64.Build.0 = Debug|x64
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Debug|x86.ActiveCfg = Debug|Win32
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Debug|x86.Build.0 = Debug|Win32
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Release|Any CPU.ActiveCfg = Release|Win32
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Release|x64.ActiveCfg = Release|x64
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Release|x64.Build.0 = Release|x64
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Release|x86.ActiveCfg = Release|Win32
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Release|x86.Build.0 = Release|Win32
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Debug|Any CPU.ActiveCfg = Debug|Win32
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Debug|x64.ActiveCfg = Debug|x64
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Debug|x64.Build.0 = Debug|x64
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Debug|x86.ActiveCfg = Debug|Win32
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Debug|x86.Build.0 = Debug|Win32
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Release|Any CPU.ActiveCfg = Release|Win32
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Release|x64.ActiveCfg = Release|x64
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Release|x64.Build.0 = Release|x64
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Release|x86.ActiveCfg = Release|Win32
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Release|x86.Build.0 = Release|Win32
+ {5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|Any CPU.ActiveCfg = Debug|Win32
+ {5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|x64.ActiveCfg = Debug|x64
+ {5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|x64.Build.0 = Debug|x64
+ {5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|x86.ActiveCfg = Debug|Win32
+ {5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|x86.Build.0 = Debug|Win32
+ {5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|Any CPU.ActiveCfg = Release|Win32
+ {5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|x64.ActiveCfg = Release|x64
+ {5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|x64.Build.0 = Release|x64
+ {5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|x86.ActiveCfg = Release|Win32
+ {5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|x86.Build.0 = Release|Win32
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Debug|Any CPU.ActiveCfg = Debug|Win32
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Debug|x64.ActiveCfg = Debug|x64
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Debug|x64.Build.0 = Debug|x64
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Debug|x86.ActiveCfg = Debug|Win32
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Debug|x86.Build.0 = Debug|Win32
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Release|Any CPU.ActiveCfg = Release|Win32
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Release|x64.ActiveCfg = Release|x64
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Release|x64.Build.0 = Release|x64
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Release|x86.ActiveCfg = Release|Win32
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Release|x86.Build.0 = Release|Win32
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Debug|Any CPU.ActiveCfg = Debug|Win32
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Debug|x64.ActiveCfg = Debug|x64
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Debug|x64.Build.0 = Debug|x64
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Debug|x86.ActiveCfg = Debug|Win32
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Debug|x86.Build.0 = Debug|Win32
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Release|Any CPU.ActiveCfg = Release|Win32
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Release|x64.ActiveCfg = Release|x64
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Release|x64.Build.0 = Release|x64
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Release|x86.ActiveCfg = Release|Win32
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Release|x86.Build.0 = Release|Win32
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Debug|Any CPU.ActiveCfg = Debug|Win32
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Debug|x64.ActiveCfg = Debug|x64
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Debug|x64.Build.0 = Debug|x64
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Debug|x86.ActiveCfg = Debug|Win32
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Debug|x86.Build.0 = Debug|Win32
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Release|Any CPU.ActiveCfg = Release|Win32
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Release|x64.ActiveCfg = Release|x64
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Release|x64.Build.0 = Release|x64
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Release|x86.ActiveCfg = Release|Win32
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Release|x86.Build.0 = Release|Win32
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Debug|Any CPU.ActiveCfg = Debug|Win32
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Debug|x64.ActiveCfg = Debug|x64
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Debug|x64.Build.0 = Debug|x64
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Debug|x86.ActiveCfg = Debug|Win32
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Debug|x86.Build.0 = Debug|Win32
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Release|Any CPU.ActiveCfg = Release|Win32
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Release|x64.ActiveCfg = Release|x64
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Release|x64.Build.0 = Release|x64
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Release|x86.ActiveCfg = Release|Win32
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Release|x86.Build.0 = Release|Win32
+ {B797917B-6842-467C-8B14-E00B76A91247}.Debug|Any CPU.ActiveCfg = Debug|Win32
+ {B797917B-6842-467C-8B14-E00B76A91247}.Debug|x64.ActiveCfg = Debug|x64
+ {B797917B-6842-467C-8B14-E00B76A91247}.Debug|x64.Build.0 = Debug|x64
+ {B797917B-6842-467C-8B14-E00B76A91247}.Debug|x86.ActiveCfg = Debug|Win32
+ {B797917B-6842-467C-8B14-E00B76A91247}.Debug|x86.Build.0 = Debug|Win32
+ {B797917B-6842-467C-8B14-E00B76A91247}.Release|Any CPU.ActiveCfg = Release|Win32
+ {B797917B-6842-467C-8B14-E00B76A91247}.Release|x64.ActiveCfg = Release|x64
+ {B797917B-6842-467C-8B14-E00B76A91247}.Release|x64.Build.0 = Release|x64
+ {B797917B-6842-467C-8B14-E00B76A91247}.Release|x86.ActiveCfg = Release|Win32
+ {B797917B-6842-467C-8B14-E00B76A91247}.Release|x86.Build.0 = Release|Win32
+ {795B1B0E-4EC8-469D-B641-E26324266FBF}.Debug|Any CPU.ActiveCfg = Debug|Win32
+ {795B1B0E-4EC8-469D-B641-E26324266FBF}.Debug|x64.ActiveCfg = Debug|x64
+ {795B1B0E-4EC8-469D-B641-E26324266FBF}.Debug|x64.Build.0 = Debug|x64
+ {795B1B0E-4EC8-469D-B641-E26324266FBF}.Debug|x86.ActiveCfg = Debug|Win32
+ {795B1B0E-4EC8-469D-B641-E26324266FBF}.Debug|x86.Build.0 = Debug|Win32
+ {795B1B0E-4EC8-469D-B641-E26324266FBF}.Release|Any CPU.ActiveCfg = Release|Win32
+ {795B1B0E-4EC8-469D-B641-E26324266FBF}.Release|x64.ActiveCfg = Release|x64
+ {795B1B0E-4EC8-469D-B641-E26324266FBF}.Release|x64.Build.0 = Release|x64
+ {795B1B0E-4EC8-469D-B641-E26324266FBF}.Release|x86.ActiveCfg = Release|Win32
+ {795B1B0E-4EC8-469D-B641-E26324266FBF}.Release|x86.Build.0 = Release|Win32
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Debug|Any CPU.ActiveCfg = Debug|Win32
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Debug|x64.ActiveCfg = Debug|x64
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Debug|x64.Build.0 = Debug|x64
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Debug|x86.ActiveCfg = Debug|Win32
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Debug|x86.Build.0 = Debug|Win32
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Release|Any CPU.ActiveCfg = Release|Win32
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Release|x64.ActiveCfg = Release|x64
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Release|x64.Build.0 = Release|x64
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Release|x86.ActiveCfg = Release|Win32
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Release|x86.Build.0 = Release|Win32
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
@@ -285,6 +487,16 @@
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59} = {99132700-5CAD-4540-9939-7502C1A448EA}
{27210DB6-811B-4D4E-A7E0-6488E5AFA733} = {99132700-5CAD-4540-9939-7502C1A448EA}
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF} = {99132700-5CAD-4540-9939-7502C1A448EA}
+ {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
+ {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
+ {5287A594-4D4F-43FE-A281-E279AB708CF1} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
+ {C50254F2-654A-48DE-AF5B-20605AEF8D10} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
+ {85882748-DD71-4D2B-9E5A-03AF8C8D91B7} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
+ {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
+ {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
+ {B797917B-6842-467C-8B14-E00B76A91247} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
+ {795B1B0E-4EC8-469D-B641-E26324266FBF} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
+ {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
EndGlobalSection
GlobalSection(ExtensibilityGlobals) = postSolution
SolutionGuid = {733BCCC2-0431-4AB7-ABB6-AAE81AB54C48}
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/MapGuideApi/MapGuideApiGen.xml
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/MapGuideApi/MapGuideApiGen.xml 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/MapGuideApi/MapGuideApiGen.xml 2020-11-20 14:21:54 UTC (rev 9797)
@@ -197,6 +197,7 @@
<Header path="../../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h" />
<Header path="../../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h" />
<Header path="../../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h" />
+ <Header path="../../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformDefParams.h" />
<Header path="../../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h" />
<Header path="../../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionary.h" />
<Header path="../../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryUtility.h" />
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/Php/PhpClassMap.cpp
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/Php/PhpClassMap.cpp 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/Php/PhpClassMap.cpp 2020-11-20 14:21:54 UTC (rev 9797)
@@ -6,11 +6,7 @@
classNameMap[20004] = "_p_MgAgfReaderWriter";
classNameMap[20005] = "_p_MgAggregateGeometry";
- classNameMap[1500] = "_p_MgApplicationException";
classNameMap[20006] = "_p_MgArcSegment";
- classNameMap[1501] = "_p_MgArgumentOutOfRangeException";
- classNameMap[10500] = "_p_MgArrayTypeMismatchException";
- classNameMap[30000] = "_p_MgAuthenticationFailedException";
classNameMap[1005] = "_p_MgBatchPropertyCollection";
classNameMap[10252] = "_p_MgBlobProperty";
classNameMap[10253] = "_p_MgBooleanProperty";
@@ -20,22 +16,15 @@
classNameMap[1251] = "_p_MgByteSource";
classNameMap[11750] = "_p_MgClassDefinition";
classNameMap[11780] = "_p_MgClassDefinitionCollection";
- classNameMap[1502] = "_p_MgClassNotFoundException";
classNameMap[10255] = "_p_MgClobProperty";
classNameMap[10250] = "_p_MgColor";
- classNameMap[1503] = "_p_MgConfigurationException";
- classNameMap[1504] = "_p_MgConfigurationLoadFailedException";
- classNameMap[1505] = "_p_MgConfigurationSaveFailedException";
- classNameMap[30001] = "_p_MgConnectionFailedException";
- classNameMap[30002] = "_p_MgConnectionNotOpenException";
classNameMap[20003] = "_p_MgCoordinate";
+ classNameMap[20008] = "_p_MgCoordinateCollection";
classNameMap[20009] = "_p_MgCoordinateIterator";
classNameMap[20500] = "_p_MgCoordinateSystem";
classNameMap[20504] = "_p_MgCoordinateSystemCatalog";
classNameMap[20506] = "_p_MgCoordinateSystemCategory";
classNameMap[20510] = "_p_MgCoordinateSystemCategoryDictionary";
- classNameMap[21000] = "_p_MgCoordinateSystemComputationFailedException";
- classNameMap[21001] = "_p_MgCoordinateSystemConversionFailedException";
classNameMap[20507] = "_p_MgCoordinateSystemDatum";
classNameMap[20512] = "_p_MgCoordinateSystemDatumDictionary";
classNameMap[20511] = "_p_MgCoordinateSystemDictionary";
@@ -54,9 +43,11 @@
classNameMap[20533] = "_p_MgCoordinateSystemGeodeticPath";
classNameMap[20535] = "_p_MgCoordinateSystemGeodeticPathDictionary";
classNameMap[20534] = "_p_MgCoordinateSystemGeodeticPathElement";
+ classNameMap[20546] = "_p_MgCoordinateSystemGeodeticStandaloneTransformDefParams";
classNameMap[20508] = "_p_MgCoordinateSystemGeodeticTransformation";
classNameMap[20536] = "_p_MgCoordinateSystemGeodeticTransformDef";
classNameMap[20540] = "_p_MgCoordinateSystemGeodeticTransformDefDictionary";
+ classNameMap[20541] = "_p_MgCoordinateSystemGeodeticTransformDefParams";
classNameMap[20545] = "_p_MgCoordinateSystemGeodeticTransformGridFile";
classNameMap[20532] = "_p_MgCoordinateSystemGridBase";
classNameMap[20524] = "_p_MgCoordinateSystemGridBoundary";
@@ -67,15 +58,11 @@
classNameMap[20525] = "_p_MgCoordinateSystemGridSpecification";
classNameMap[20531] = "_p_MgCoordinateSystemGridTick";
classNameMap[20528] = "_p_MgCoordinateSystemGridTickCollection";
- classNameMap[21002] = "_p_MgCoordinateSystemInitializationFailedException";
- classNameMap[21003] = "_p_MgCoordinateSystemLoadFailedException";
classNameMap[20518] = "_p_MgCoordinateSystemMathComparator";
classNameMap[20502] = "_p_MgCoordinateSystemMeasure";
- classNameMap[21004] = "_p_MgCoordinateSystemMeasureFailedException";
classNameMap[20522] = "_p_MgCoordinateSystemMgrs";
classNameMap[20520] = "_p_MgCoordinateSystemProjectionInformation";
classNameMap[20503] = "_p_MgCoordinateSystemTransform";
- classNameMap[21005] = "_p_MgCoordinateSystemTransformFailedException";
classNameMap[20519] = "_p_MgCoordinateSystemUnitInformation";
classNameMap[20048] = "_p_MgCoordinateXY";
classNameMap[20051] = "_p_MgCoordinateXYM";
@@ -93,41 +80,15 @@
classNameMap[11751] = "_p_MgDataPropertyDefinition";
classNameMap[11773] = "_p_MgDataReader";
classNameMap[1256] = "_p_MgDateTime";
- classNameMap[1506] = "_p_MgDateTimeException";
classNameMap[10256] = "_p_MgDateTimeProperty";
- classNameMap[30003] = "_p_MgDbException";
- classNameMap[30004] = "_p_MgDbXmlException";
- classNameMap[1507] = "_p_MgDecryptionException";
classNameMap[11775] = "_p_MgDeleteFeatures";
- classNameMap[1508] = "_p_MgDirectoryNotFoundException";
+ classNameMap[2251] = "_p_MgDisposable";
classNameMap[1000] = "_p_MgDisposableCollection";
- classNameMap[1509] = "_p_MgDivideByZeroException";
- classNameMap[1510] = "_p_MgDomainException";
classNameMap[10257] = "_p_MgDoubleProperty";
classNameMap[30700] = "_p_MgDrawingService";
- classNameMap[1511] = "_p_MgDuplicateDirectoryException";
- classNameMap[1512] = "_p_MgDuplicateFileException";
- classNameMap[30005] = "_p_MgDuplicateGroupException";
- classNameMap[30006] = "_p_MgDuplicateNameException";
- classNameMap[1513] = "_p_MgDuplicateObjectException";
- classNameMap[30007] = "_p_MgDuplicateParameterException";
- classNameMap[30008] = "_p_MgDuplicateRepositoryException";
- classNameMap[10501] = "_p_MgDuplicateResourceDataException";
- classNameMap[10502] = "_p_MgDuplicateResourceException";
- classNameMap[30009] = "_p_MgDuplicateRoleException";
- classNameMap[30010] = "_p_MgDuplicateServerException";
- classNameMap[30011] = "_p_MgDuplicateSessionException";
- classNameMap[30012] = "_p_MgDuplicateUserException";
- classNameMap[30013] = "_p_MgDwfException";
- classNameMap[30014] = "_p_MgDwfSectionNotFoundException";
- classNameMap[30015] = "_p_MgDwfSectionResourceNotFoundException";
classNameMap[30901] = "_p_MgDwfVersion";
- classNameMap[10503] = "_p_MgEmptyFeatureSetException";
- classNameMap[1514] = "_p_MgEncryptionException";
- classNameMap[30016] = "_p_MgEndOfStreamException";
classNameMap[20001] = "_p_MgEnvelope";
classNameMap[1515] = "_p_MgException";
- classNameMap[10504] = "_p_MgFdoException";
classNameMap[11772] = "_p_MgFeatureAggregateOptions";
classNameMap[11774] = "_p_MgFeatureCommandCollection";
classNameMap[31001] = "_p_MgFeatureInformation";
@@ -137,20 +98,16 @@
classNameMap[11778] = "_p_MgFeatureSchema";
classNameMap[11779] = "_p_MgFeatureSchemaCollection";
classNameMap[11754] = "_p_MgFeatureService";
- classNameMap[10505] = "_p_MgFeatureServiceException";
classNameMap[11786] = "_p_MgFileFeatureSourceParams";
- classNameMap[1516] = "_p_MgFileIoException";
- classNameMap[1517] = "_p_MgFileNotFoundException";
classNameMap[20016] = "_p_MgGeometricEntity";
classNameMap[11756] = "_p_MgGeometricPropertyDefinition";
- classNameMap[20019] = "_p_MgGeometry";
+ classNameMap[11757] = "_p_MgGeometry";
classNameMap[20020] = "_p_MgGeometryCollection";
classNameMap[20021] = "_p_MgGeometryComponent";
- classNameMap[21006] = "_p_MgGeometryException";
classNameMap[20002] = "_p_MgGeometryFactory";
classNameMap[11758] = "_p_MgGeometryProperty";
+ classNameMap[20054] = "_p_MgGeometrySimplifier";
classNameMap[11785] = "_p_MgGeometryTypeInfo";
- classNameMap[30018] = "_p_MgGroupNotFoundException";
classNameMap[11782] = "_p_MgGwsFeatureReader";
classNameMap[40000] = "_p_MgHttpHeader";
classNameMap[40006] = "_p_MgHttpPrimitiveValue";
@@ -159,41 +116,11 @@
classNameMap[40001] = "_p_MgHttpRequestParam";
classNameMap[40005] = "_p_MgHttpResponse";
classNameMap[40003] = "_p_MgHttpResult";
- classNameMap[1518] = "_p_MgIndexOutOfRangeException";
classNameMap[11776] = "_p_MgInsertFeatures";
classNameMap[10258] = "_p_MgInt16Property";
classNameMap[10259] = "_p_MgInt32Property";
classNameMap[10260] = "_p_MgInt64Property";
classNameMap[10000] = "_p_MgIntCollection";
- classNameMap[1519] = "_p_MgInvalidArgumentException";
- classNameMap[1520] = "_p_MgInvalidCastException";
- classNameMap[21007] = "_p_MgInvalidCoordinateSystemException";
- classNameMap[21008] = "_p_MgInvalidCoordinateSystemTypeException";
- classNameMap[21009] = "_p_MgInvalidCoordinateSystemUnitsException";
- classNameMap[30019] = "_p_MgInvalidDwfPackageException";
- classNameMap[30020] = "_p_MgInvalidDwfSectionException";
- classNameMap[30021] = "_p_MgInvalidFeatureSourceException";
- classNameMap[30022] = "_p_MgInvalidIpAddressException";
- classNameMap[30023] = "_p_MgInvalidLicenseException";
- classNameMap[30024] = "_p_MgInvalidLogEntryException";
- classNameMap[10507] = "_p_MgInvalidMapDefinitionException";
- classNameMap[1522] = "_p_MgInvalidOperationException";
- classNameMap[30026] = "_p_MgInvalidPasswordException";
- classNameMap[30027] = "_p_MgInvalidPrintLayoutFontSizeUnitsException";
- classNameMap[30028] = "_p_MgInvalidPrintLayoutPositionUnitsException";
- classNameMap[30029] = "_p_MgInvalidPrintLayoutSizeUnitsException";
- classNameMap[1523] = "_p_MgInvalidPropertyTypeException";
- classNameMap[10508] = "_p_MgInvalidRepositoryNameException";
- classNameMap[10509] = "_p_MgInvalidRepositoryTypeException";
- classNameMap[10510] = "_p_MgInvalidResourceDataNameException";
- classNameMap[10511] = "_p_MgInvalidResourceDataTypeException";
- classNameMap[10512] = "_p_MgInvalidResourceNameException";
- classNameMap[10513] = "_p_MgInvalidResourcePathException";
- classNameMap[10514] = "_p_MgInvalidResourcePreProcessingTypeException";
- classNameMap[10515] = "_p_MgInvalidResourceTypeException";
- classNameMap[30031] = "_p_MgInvalidServerNameException";
- classNameMap[1524] = "_p_MgInvalidStreamHeaderException";
- classNameMap[1525] = "_p_MgIoException";
classNameMap[31300] = "_p_MgKmlService";
classNameMap[30501] = "_p_MgLayer";
classNameMap[12003] = "_p_MgLayerBase";
@@ -200,17 +127,12 @@
classNameMap[12002] = "_p_MgLayerCollection";
classNameMap[12001] = "_p_MgLayerGroup";
classNameMap[12004] = "_p_MgLayerGroupCollection";
- classNameMap[10517] = "_p_MgLayerNotFoundException";
classNameMap[30904] = "_p_MgLayout";
- classNameMap[1526] = "_p_MgLengthException";
- classNameMap[30032] = "_p_MgLicenseException";
- classNameMap[30033] = "_p_MgLicenseExpiredException";
classNameMap[20023] = "_p_MgLinearRing";
classNameMap[20053] = "_p_MgLinearRingCollection";
classNameMap[20024] = "_p_MgLinearSegment";
classNameMap[20042] = "_p_MgLineString";
classNameMap[20044] = "_p_MgLineStringCollection";
- classNameMap[1527] = "_p_MgLogicException";
classNameMap[11766] = "_p_MgLongTransactionReader";
classNameMap[30500] = "_p_MgMap";
classNameMap[12000] = "_p_MgMapBase";
@@ -218,6 +140,8 @@
classNameMap[30900] = "_p_MgMappingService";
classNameMap[30905] = "_p_MgMapPlot";
classNameMap[30906] = "_p_MgMapPlotCollection";
+ classNameMap[20027] = "_p_MgMeasure";
+ classNameMap[31003] = "_p_MgMetatile";
classNameMap[20029] = "_p_MgMultiCurvePolygon";
classNameMap[20030] = "_p_MgMultiCurveString";
classNameMap[20031] = "_p_MgMultiGeometry";
@@ -224,34 +148,21 @@
classNameMap[20032] = "_p_MgMultiLineString";
classNameMap[20033] = "_p_MgMultiPoint";
classNameMap[20034] = "_p_MgMultiPolygon";
- classNameMap[1528] = "_p_MgNotFiniteNumberException";
- classNameMap[1529] = "_p_MgNotImplementedException";
- classNameMap[1530] = "_p_MgNullArgumentException";
- classNameMap[1531] = "_p_MgNullPropertyValueException";
- classNameMap[1532] = "_p_MgNullReferenceException";
- classNameMap[1533] = "_p_MgObjectNotFoundException";
+ classNameMap[2252] = "_p_MgObject";
classNameMap[11759] = "_p_MgObjectPropertyDefinition";
- classNameMap[30035] = "_p_MgOperationProcessingException";
- classNameMap[1534] = "_p_MgOutOfMemoryException";
- classNameMap[1535] = "_p_MgOutOfRangeException";
- classNameMap[1536] = "_p_MgOverflowException";
classNameMap[30604] = "_p_MgPackageStatusInformation";
classNameMap[11788] = "_p_MgParameter";
classNameMap[10004] = "_p_MgParameterCollection";
- classNameMap[30036] = "_p_MgParameterNotFoundException";
- classNameMap[30037] = "_p_MgPathTooLongException";
- classNameMap[1537] = "_p_MgPlatformNotSupportedException";
classNameMap[30902] = "_p_MgPlotSpecification";
classNameMap[20000] = "_p_MgPoint";
classNameMap[20045] = "_p_MgPointCollection";
classNameMap[20035] = "_p_MgPolygon";
classNameMap[20046] = "_p_MgPolygonCollection";
- classNameMap[30039] = "_p_MgPortNotAvailableException";
- classNameMap[30040] = "_p_MgPrintToScaleModeNotSelectedException";
+ classNameMap[20055] = "_p_MgPreparedGeometry";
classNameMap[31400] = "_p_MgProfilingService";
classNameMap[2000] = "_p_MgProperty";
classNameMap[1002] = "_p_MgPropertyCollection";
- classNameMap[2002] = "_p_MgPropertyDefinition";
+ classNameMap[10251] = "_p_MgPropertyDefinition";
classNameMap[10001] = "_p_MgPropertyDefinitionCollection";
classNameMap[11769] = "_p_MgRaster";
classNameMap[11770] = "_p_MgRasterProperty";
@@ -260,32 +171,14 @@
classNameMap[20037] = "_p_MgRegion";
classNameMap[31002] = "_p_MgRenderingOptions";
classNameMap[31000] = "_p_MgRenderingService";
- classNameMap[30041] = "_p_MgRepositoryCreationFailedException";
- classNameMap[30042] = "_p_MgRepositoryNotFoundException";
- classNameMap[30043] = "_p_MgRepositoryNotOpenException";
- classNameMap[30044] = "_p_MgRepositoryOpenFailedException";
classNameMap[11526] = "_p_MgResource";
- classNameMap[10518] = "_p_MgResourceBusyException";
- classNameMap[10519] = "_p_MgResourceDataNotFoundException";
classNameMap[11500] = "_p_MgResourceIdentifier";
- classNameMap[10520] = "_p_MgResourceNotFoundException";
classNameMap[11501] = "_p_MgResourceService";
- classNameMap[1538] = "_p_MgResourcesException";
- classNameMap[1539] = "_p_MgResourcesLoadFailedException";
- classNameMap[1540] = "_p_MgResourceTagNotFoundException";
classNameMap[20038] = "_p_MgRing";
- classNameMap[30045] = "_p_MgRoleNotFoundException";
- classNameMap[1541] = "_p_MgRuntimeException";
classNameMap[30502] = "_p_MgSelection";
classNameMap[12007] = "_p_MgSelectionBase";
classNameMap[30607] = "_p_MgServerAdmin";
- classNameMap[30046] = "_p_MgServerNotFoundException";
- classNameMap[30047] = "_p_MgServerNotOnlineException";
classNameMap[11251] = "_p_MgService";
- classNameMap[10521] = "_p_MgServiceNotAvailableException";
- classNameMap[10522] = "_p_MgServiceNotSupportedException";
- classNameMap[30048] = "_p_MgSessionExpiredException";
- classNameMap[30052] = "_p_MgSessionNotFoundException";
classNameMap[10261] = "_p_MgSingleProperty";
classNameMap[30605] = "_p_MgSite";
classNameMap[30601] = "_p_MgSiteConnection";
@@ -292,24 +185,14 @@
classNameMap[30608] = "_p_MgSiteInfo";
classNameMap[11761] = "_p_MgSpatialContextReader";
classNameMap[11762] = "_p_MgSqlDataReader";
- classNameMap[1542] = "_p_MgStreamIoException";
classNameMap[1003] = "_p_MgStringCollection";
classNameMap[2001] = "_p_MgStringProperty";
classNameMap[10003] = "_p_MgStringPropertyCollection";
- classNameMap[1543] = "_p_MgSystemException";
- classNameMap[1544] = "_p_MgTemporaryFileNotAvailableException";
- classNameMap[1545] = "_p_MgThirdPartyException";
classNameMap[31200] = "_p_MgTileService";
classNameMap[11787] = "_p_MgTransaction";
- classNameMap[30049] = "_p_MgUnauthorizedAccessException";
- classNameMap[1547] = "_p_MgUnclassifiedException";
- classNameMap[1548] = "_p_MgUnderflowException";
- classNameMap[30056] = "_p_MgUnknownTileProviderException";
- classNameMap[30057] = "_p_MgUnsupportedTileProviderException";
+ classNameMap[20039] = "_p_MgTransform";
classNameMap[11777] = "_p_MgUpdateFeatures";
- classNameMap[30050] = "_p_MgUriFormatException";
classNameMap[30606] = "_p_MgUserInformation";
- classNameMap[10523] = "_p_MgUserNotFoundException";
classNameMap[11257] = "_p_MgWarnings";
classNameMap[50005] = "_p_MgWebBufferCommand";
classNameMap[50000] = "_p_MgWebCommand";
@@ -339,8 +222,6 @@
classNameMap[50013] = "_p_MgWebWidget";
classNameMap[50018] = "_p_MgWebWidgetCollection";
classNameMap[20040] = "_p_MgWktReaderWriter";
- classNameMap[1549] = "_p_MgXmlException";
- classNameMap[1550] = "_p_MgXmlParserException";
return classNameMap;
Modified: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/Common/MgClassMap.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/Common/MgClassMap.cs 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/Common/MgClassMap.cs 2020-11-20 14:21:54 UTC (rev 9797)
@@ -7,19 +7,22 @@
internal static class MgClassMap
+ //TODO: We should take a page out of the java binding and convert this to a
+ //Dictionary<int, ConstructorInfo>. This would save us having to do repeated lookups
+ //for this information. Also it would serve as a fail-early sanity check that we are
+ //not registering class ids of classes that are not actual classes (eg. Classes with
+ //constants should not be here)
static Dictionary<int, string> classNameMap;
+ static Dictionary<string, int> nameClassMap;
static MgClassMap()
classNameMap = new Dictionary<int, string>();
+ nameClassMap = new Dictionary<string, int>();
classNameMap[20004] = "OSGeo.MapGuide.MgAgfReaderWriter";
classNameMap[20005] = "OSGeo.MapGuide.MgAggregateGeometry";
- classNameMap[1500] = "OSGeo.MapGuide.MgApplicationException";
classNameMap[20006] = "OSGeo.MapGuide.MgArcSegment";
- classNameMap[1501] = "OSGeo.MapGuide.MgArgumentOutOfRangeException";
- classNameMap[10500] = "OSGeo.MapGuide.MgArrayTypeMismatchException";
- classNameMap[30000] = "OSGeo.MapGuide.MgAuthenticationFailedException";
classNameMap[1005] = "OSGeo.MapGuide.MgBatchPropertyCollection";
classNameMap[10252] = "OSGeo.MapGuide.MgBlobProperty";
classNameMap[10253] = "OSGeo.MapGuide.MgBooleanProperty";
@@ -29,22 +32,15 @@
classNameMap[1251] = "OSGeo.MapGuide.MgByteSource";
classNameMap[11750] = "OSGeo.MapGuide.MgClassDefinition";
classNameMap[11780] = "OSGeo.MapGuide.MgClassDefinitionCollection";
- classNameMap[1502] = "OSGeo.MapGuide.MgClassNotFoundException";
classNameMap[10255] = "OSGeo.MapGuide.MgClobProperty";
classNameMap[10250] = "OSGeo.MapGuide.MgColor";
- classNameMap[1503] = "OSGeo.MapGuide.MgConfigurationException";
- classNameMap[1504] = "OSGeo.MapGuide.MgConfigurationLoadFailedException";
- classNameMap[1505] = "OSGeo.MapGuide.MgConfigurationSaveFailedException";
- classNameMap[30001] = "OSGeo.MapGuide.MgConnectionFailedException";
- classNameMap[30002] = "OSGeo.MapGuide.MgConnectionNotOpenException";
classNameMap[20003] = "OSGeo.MapGuide.MgCoordinate";
+ classNameMap[20008] = "OSGeo.MapGuide.MgCoordinateCollection";
classNameMap[20009] = "OSGeo.MapGuide.MgCoordinateIterator";
classNameMap[20500] = "OSGeo.MapGuide.MgCoordinateSystem";
classNameMap[20504] = "OSGeo.MapGuide.MgCoordinateSystemCatalog";
classNameMap[20506] = "OSGeo.MapGuide.MgCoordinateSystemCategory";
classNameMap[20510] = "OSGeo.MapGuide.MgCoordinateSystemCategoryDictionary";
- classNameMap[21000] = "OSGeo.MapGuide.MgCoordinateSystemComputationFailedException";
- classNameMap[21001] = "OSGeo.MapGuide.MgCoordinateSystemConversionFailedException";
classNameMap[20507] = "OSGeo.MapGuide.MgCoordinateSystemDatum";
classNameMap[20512] = "OSGeo.MapGuide.MgCoordinateSystemDatumDictionary";
classNameMap[20511] = "OSGeo.MapGuide.MgCoordinateSystemDictionary";
@@ -63,9 +59,11 @@
classNameMap[20533] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticPath";
classNameMap[20535] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticPathDictionary";
classNameMap[20534] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticPathElement";
+ classNameMap[20546] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticStandaloneTransformDefParams";
classNameMap[20508] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformation";
classNameMap[20536] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDef";
classNameMap[20540] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefDictionary";
+ classNameMap[20541] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefParams";
classNameMap[20545] = "OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformGridFile";
classNameMap[20532] = "OSGeo.MapGuide.MgCoordinateSystemGridBase";
classNameMap[20524] = "OSGeo.MapGuide.MgCoordinateSystemGridBoundary";
@@ -76,15 +74,11 @@
classNameMap[20525] = "OSGeo.MapGuide.MgCoordinateSystemGridSpecification";
classNameMap[20531] = "OSGeo.MapGuide.MgCoordinateSystemGridTick";
classNameMap[20528] = "OSGeo.MapGuide.MgCoordinateSystemGridTickCollection";
- classNameMap[21002] = "OSGeo.MapGuide.MgCoordinateSystemInitializationFailedException";
- classNameMap[21003] = "OSGeo.MapGuide.MgCoordinateSystemLoadFailedException";
classNameMap[20518] = "OSGeo.MapGuide.MgCoordinateSystemMathComparator";
classNameMap[20502] = "OSGeo.MapGuide.MgCoordinateSystemMeasure";
- classNameMap[21004] = "OSGeo.MapGuide.MgCoordinateSystemMeasureFailedException";
classNameMap[20522] = "OSGeo.MapGuide.MgCoordinateSystemMgrs";
classNameMap[20520] = "OSGeo.MapGuide.MgCoordinateSystemProjectionInformation";
classNameMap[20503] = "OSGeo.MapGuide.MgCoordinateSystemTransform";
- classNameMap[21005] = "OSGeo.MapGuide.MgCoordinateSystemTransformFailedException";
classNameMap[20519] = "OSGeo.MapGuide.MgCoordinateSystemUnitInformation";
classNameMap[20048] = "OSGeo.MapGuide.MgCoordinateXY";
classNameMap[20051] = "OSGeo.MapGuide.MgCoordinateXYM";
@@ -102,41 +96,15 @@
classNameMap[11751] = "OSGeo.MapGuide.MgDataPropertyDefinition";
classNameMap[11773] = "OSGeo.MapGuide.MgDataReader";
classNameMap[1256] = "OSGeo.MapGuide.MgDateTime";
- classNameMap[1506] = "OSGeo.MapGuide.MgDateTimeException";
classNameMap[10256] = "OSGeo.MapGuide.MgDateTimeProperty";
- classNameMap[30003] = "OSGeo.MapGuide.MgDbException";
- classNameMap[30004] = "OSGeo.MapGuide.MgDbXmlException";
- classNameMap[1507] = "OSGeo.MapGuide.MgDecryptionException";
classNameMap[11775] = "OSGeo.MapGuide.MgDeleteFeatures";
- classNameMap[1508] = "OSGeo.MapGuide.MgDirectoryNotFoundException";
+ classNameMap[2251] = "OSGeo.MapGuide.MgDisposable";
classNameMap[1000] = "OSGeo.MapGuide.MgDisposableCollection";
- classNameMap[1509] = "OSGeo.MapGuide.MgDivideByZeroException";
- classNameMap[1510] = "OSGeo.MapGuide.MgDomainException";
classNameMap[10257] = "OSGeo.MapGuide.MgDoubleProperty";
classNameMap[30700] = "OSGeo.MapGuide.MgDrawingService";
- classNameMap[1511] = "OSGeo.MapGuide.MgDuplicateDirectoryException";
- classNameMap[1512] = "OSGeo.MapGuide.MgDuplicateFileException";
- classNameMap[30005] = "OSGeo.MapGuide.MgDuplicateGroupException";
- classNameMap[30006] = "OSGeo.MapGuide.MgDuplicateNameException";
- classNameMap[1513] = "OSGeo.MapGuide.MgDuplicateObjectException";
- classNameMap[30007] = "OSGeo.MapGuide.MgDuplicateParameterException";
- classNameMap[30008] = "OSGeo.MapGuide.MgDuplicateRepositoryException";
- classNameMap[10501] = "OSGeo.MapGuide.MgDuplicateResourceDataException";
- classNameMap[10502] = "OSGeo.MapGuide.MgDuplicateResourceException";
- classNameMap[30009] = "OSGeo.MapGuide.MgDuplicateRoleException";
- classNameMap[30010] = "OSGeo.MapGuide.MgDuplicateServerException";
- classNameMap[30011] = "OSGeo.MapGuide.MgDuplicateSessionException";
- classNameMap[30012] = "OSGeo.MapGuide.MgDuplicateUserException";
- classNameMap[30013] = "OSGeo.MapGuide.MgDwfException";
- classNameMap[30014] = "OSGeo.MapGuide.MgDwfSectionNotFoundException";
- classNameMap[30015] = "OSGeo.MapGuide.MgDwfSectionResourceNotFoundException";
classNameMap[30901] = "OSGeo.MapGuide.MgDwfVersion";
- classNameMap[10503] = "OSGeo.MapGuide.MgEmptyFeatureSetException";
- classNameMap[1514] = "OSGeo.MapGuide.MgEncryptionException";
- classNameMap[30016] = "OSGeo.MapGuide.MgEndOfStreamException";
classNameMap[20001] = "OSGeo.MapGuide.MgEnvelope";
classNameMap[1515] = "OSGeo.MapGuide.MgException";
- classNameMap[10504] = "OSGeo.MapGuide.MgFdoException";
classNameMap[11772] = "OSGeo.MapGuide.MgFeatureAggregateOptions";
classNameMap[11774] = "OSGeo.MapGuide.MgFeatureCommandCollection";
classNameMap[31001] = "OSGeo.MapGuide.MgFeatureInformation";
@@ -146,20 +114,16 @@
classNameMap[11778] = "OSGeo.MapGuide.MgFeatureSchema";
classNameMap[11779] = "OSGeo.MapGuide.MgFeatureSchemaCollection";
classNameMap[11754] = "OSGeo.MapGuide.MgFeatureService";
- classNameMap[10505] = "OSGeo.MapGuide.MgFeatureServiceException";
classNameMap[11786] = "OSGeo.MapGuide.MgFileFeatureSourceParams";
- classNameMap[1516] = "OSGeo.MapGuide.MgFileIoException";
- classNameMap[1517] = "OSGeo.MapGuide.MgFileNotFoundException";
classNameMap[20016] = "OSGeo.MapGuide.MgGeometricEntity";
classNameMap[11756] = "OSGeo.MapGuide.MgGeometricPropertyDefinition";
- classNameMap[20019] = "OSGeo.MapGuide.MgGeometry";
+ classNameMap[11757] = "OSGeo.MapGuide.MgGeometry";
classNameMap[20020] = "OSGeo.MapGuide.MgGeometryCollection";
classNameMap[20021] = "OSGeo.MapGuide.MgGeometryComponent";
- classNameMap[21006] = "OSGeo.MapGuide.MgGeometryException";
classNameMap[20002] = "OSGeo.MapGuide.MgGeometryFactory";
classNameMap[11758] = "OSGeo.MapGuide.MgGeometryProperty";
+ classNameMap[20054] = "OSGeo.MapGuide.MgGeometrySimplifier";
classNameMap[11785] = "OSGeo.MapGuide.MgGeometryTypeInfo";
- classNameMap[30018] = "OSGeo.MapGuide.MgGroupNotFoundException";
classNameMap[11782] = "OSGeo.MapGuide.MgGwsFeatureReader";
classNameMap[40000] = "OSGeo.MapGuide.MgHttpHeader";
classNameMap[40006] = "OSGeo.MapGuide.MgHttpPrimitiveValue";
@@ -168,41 +132,11 @@
classNameMap[40001] = "OSGeo.MapGuide.MgHttpRequestParam";
classNameMap[40005] = "OSGeo.MapGuide.MgHttpResponse";
classNameMap[40003] = "OSGeo.MapGuide.MgHttpResult";
- classNameMap[1518] = "OSGeo.MapGuide.MgIndexOutOfRangeException";
classNameMap[11776] = "OSGeo.MapGuide.MgInsertFeatures";
classNameMap[10258] = "OSGeo.MapGuide.MgInt16Property";
classNameMap[10259] = "OSGeo.MapGuide.MgInt32Property";
classNameMap[10260] = "OSGeo.MapGuide.MgInt64Property";
classNameMap[10000] = "OSGeo.MapGuide.MgIntCollection";
- classNameMap[1519] = "OSGeo.MapGuide.MgInvalidArgumentException";
- classNameMap[1520] = "OSGeo.MapGuide.MgInvalidCastException";
- classNameMap[21007] = "OSGeo.MapGuide.MgInvalidCoordinateSystemException";
- classNameMap[21008] = "OSGeo.MapGuide.MgInvalidCoordinateSystemTypeException";
- classNameMap[21009] = "OSGeo.MapGuide.MgInvalidCoordinateSystemUnitsException";
- classNameMap[30019] = "OSGeo.MapGuide.MgInvalidDwfPackageException";
- classNameMap[30020] = "OSGeo.MapGuide.MgInvalidDwfSectionException";
- classNameMap[30021] = "OSGeo.MapGuide.MgInvalidFeatureSourceException";
- classNameMap[30022] = "OSGeo.MapGuide.MgInvalidIpAddressException";
- classNameMap[30023] = "OSGeo.MapGuide.MgInvalidLicenseException";
- classNameMap[30024] = "OSGeo.MapGuide.MgInvalidLogEntryException";
- classNameMap[10507] = "OSGeo.MapGuide.MgInvalidMapDefinitionException";
- classNameMap[1522] = "OSGeo.MapGuide.MgInvalidOperationException";
- classNameMap[30026] = "OSGeo.MapGuide.MgInvalidPasswordException";
- classNameMap[30027] = "OSGeo.MapGuide.MgInvalidPrintLayoutFontSizeUnitsException";
- classNameMap[30028] = "OSGeo.MapGuide.MgInvalidPrintLayoutPositionUnitsException";
- classNameMap[30029] = "OSGeo.MapGuide.MgInvalidPrintLayoutSizeUnitsException";
- classNameMap[1523] = "OSGeo.MapGuide.MgInvalidPropertyTypeException";
- classNameMap[10508] = "OSGeo.MapGuide.MgInvalidRepositoryNameException";
- classNameMap[10509] = "OSGeo.MapGuide.MgInvalidRepositoryTypeException";
- classNameMap[10510] = "OSGeo.MapGuide.MgInvalidResourceDataNameException";
- classNameMap[10511] = "OSGeo.MapGuide.MgInvalidResourceDataTypeException";
- classNameMap[10512] = "OSGeo.MapGuide.MgInvalidResourceNameException";
- classNameMap[10513] = "OSGeo.MapGuide.MgInvalidResourcePathException";
- classNameMap[10514] = "OSGeo.MapGuide.MgInvalidResourcePreProcessingTypeException";
- classNameMap[10515] = "OSGeo.MapGuide.MgInvalidResourceTypeException";
- classNameMap[30031] = "OSGeo.MapGuide.MgInvalidServerNameException";
- classNameMap[1524] = "OSGeo.MapGuide.MgInvalidStreamHeaderException";
- classNameMap[1525] = "OSGeo.MapGuide.MgIoException";
classNameMap[31300] = "OSGeo.MapGuide.MgKmlService";
classNameMap[30501] = "OSGeo.MapGuide.MgLayer";
classNameMap[12003] = "OSGeo.MapGuide.MgLayerBase";
@@ -209,17 +143,12 @@
classNameMap[12002] = "OSGeo.MapGuide.MgLayerCollection";
classNameMap[12001] = "OSGeo.MapGuide.MgLayerGroup";
classNameMap[12004] = "OSGeo.MapGuide.MgLayerGroupCollection";
- classNameMap[10517] = "OSGeo.MapGuide.MgLayerNotFoundException";
classNameMap[30904] = "OSGeo.MapGuide.MgLayout";
- classNameMap[1526] = "OSGeo.MapGuide.MgLengthException";
- classNameMap[30032] = "OSGeo.MapGuide.MgLicenseException";
- classNameMap[30033] = "OSGeo.MapGuide.MgLicenseExpiredException";
classNameMap[20023] = "OSGeo.MapGuide.MgLinearRing";
classNameMap[20053] = "OSGeo.MapGuide.MgLinearRingCollection";
classNameMap[20024] = "OSGeo.MapGuide.MgLinearSegment";
classNameMap[20042] = "OSGeo.MapGuide.MgLineString";
classNameMap[20044] = "OSGeo.MapGuide.MgLineStringCollection";
- classNameMap[1527] = "OSGeo.MapGuide.MgLogicException";
classNameMap[11766] = "OSGeo.MapGuide.MgLongTransactionReader";
classNameMap[30500] = "OSGeo.MapGuide.MgMap";
classNameMap[12000] = "OSGeo.MapGuide.MgMapBase";
@@ -227,6 +156,8 @@
classNameMap[30900] = "OSGeo.MapGuide.MgMappingService";
classNameMap[30905] = "OSGeo.MapGuide.MgMapPlot";
classNameMap[30906] = "OSGeo.MapGuide.MgMapPlotCollection";
+ classNameMap[20027] = "OSGeo.MapGuide.MgMeasure";
+ classNameMap[31003] = "OSGeo.MapGuide.MgMetatile";
classNameMap[20029] = "OSGeo.MapGuide.MgMultiCurvePolygon";
classNameMap[20030] = "OSGeo.MapGuide.MgMultiCurveString";
classNameMap[20031] = "OSGeo.MapGuide.MgMultiGeometry";
@@ -233,34 +164,21 @@
classNameMap[20032] = "OSGeo.MapGuide.MgMultiLineString";
classNameMap[20033] = "OSGeo.MapGuide.MgMultiPoint";
classNameMap[20034] = "OSGeo.MapGuide.MgMultiPolygon";
- classNameMap[1528] = "OSGeo.MapGuide.MgNotFiniteNumberException";
- classNameMap[1529] = "OSGeo.MapGuide.MgNotImplementedException";
- classNameMap[1530] = "OSGeo.MapGuide.MgNullArgumentException";
- classNameMap[1531] = "OSGeo.MapGuide.MgNullPropertyValueException";
- classNameMap[1532] = "OSGeo.MapGuide.MgNullReferenceException";
- classNameMap[1533] = "OSGeo.MapGuide.MgObjectNotFoundException";
+ classNameMap[2252] = "OSGeo.MapGuide.MgObject";
classNameMap[11759] = "OSGeo.MapGuide.MgObjectPropertyDefinition";
- classNameMap[30035] = "OSGeo.MapGuide.MgOperationProcessingException";
- classNameMap[1534] = "OSGeo.MapGuide.MgOutOfMemoryException";
- classNameMap[1535] = "OSGeo.MapGuide.MgOutOfRangeException";
- classNameMap[1536] = "OSGeo.MapGuide.MgOverflowException";
classNameMap[30604] = "OSGeo.MapGuide.MgPackageStatusInformation";
classNameMap[11788] = "OSGeo.MapGuide.MgParameter";
classNameMap[10004] = "OSGeo.MapGuide.MgParameterCollection";
- classNameMap[30036] = "OSGeo.MapGuide.MgParameterNotFoundException";
- classNameMap[30037] = "OSGeo.MapGuide.MgPathTooLongException";
- classNameMap[1537] = "OSGeo.MapGuide.MgPlatformNotSupportedException";
classNameMap[30902] = "OSGeo.MapGuide.MgPlotSpecification";
classNameMap[20000] = "OSGeo.MapGuide.MgPoint";
classNameMap[20045] = "OSGeo.MapGuide.MgPointCollection";
classNameMap[20035] = "OSGeo.MapGuide.MgPolygon";
classNameMap[20046] = "OSGeo.MapGuide.MgPolygonCollection";
- classNameMap[30039] = "OSGeo.MapGuide.MgPortNotAvailableException";
- classNameMap[30040] = "OSGeo.MapGuide.MgPrintToScaleModeNotSelectedException";
+ classNameMap[20055] = "OSGeo.MapGuide.MgPreparedGeometry";
classNameMap[31400] = "OSGeo.MapGuide.MgProfilingService";
classNameMap[2000] = "OSGeo.MapGuide.MgProperty";
classNameMap[1002] = "OSGeo.MapGuide.MgPropertyCollection";
- classNameMap[2002] = "OSGeo.MapGuide.MgPropertyDefinition";
+ classNameMap[10251] = "OSGeo.MapGuide.MgPropertyDefinition";
classNameMap[10001] = "OSGeo.MapGuide.MgPropertyDefinitionCollection";
classNameMap[11769] = "OSGeo.MapGuide.MgRaster";
classNameMap[11770] = "OSGeo.MapGuide.MgRasterProperty";
@@ -269,32 +187,14 @@
classNameMap[20037] = "OSGeo.MapGuide.MgRegion";
classNameMap[31002] = "OSGeo.MapGuide.MgRenderingOptions";
classNameMap[31000] = "OSGeo.MapGuide.MgRenderingService";
- classNameMap[30041] = "OSGeo.MapGuide.MgRepositoryCreationFailedException";
- classNameMap[30042] = "OSGeo.MapGuide.MgRepositoryNotFoundException";
- classNameMap[30043] = "OSGeo.MapGuide.MgRepositoryNotOpenException";
- classNameMap[30044] = "OSGeo.MapGuide.MgRepositoryOpenFailedException";
classNameMap[11526] = "OSGeo.MapGuide.MgResource";
- classNameMap[10518] = "OSGeo.MapGuide.MgResourceBusyException";
- classNameMap[10519] = "OSGeo.MapGuide.MgResourceDataNotFoundException";
classNameMap[11500] = "OSGeo.MapGuide.MgResourceIdentifier";
- classNameMap[10520] = "OSGeo.MapGuide.MgResourceNotFoundException";
classNameMap[11501] = "OSGeo.MapGuide.MgResourceService";
- classNameMap[1538] = "OSGeo.MapGuide.MgResourcesException";
- classNameMap[1539] = "OSGeo.MapGuide.MgResourcesLoadFailedException";
- classNameMap[1540] = "OSGeo.MapGuide.MgResourceTagNotFoundException";
classNameMap[20038] = "OSGeo.MapGuide.MgRing";
- classNameMap[30045] = "OSGeo.MapGuide.MgRoleNotFoundException";
- classNameMap[1541] = "OSGeo.MapGuide.MgRuntimeException";
classNameMap[30502] = "OSGeo.MapGuide.MgSelection";
classNameMap[12007] = "OSGeo.MapGuide.MgSelectionBase";
classNameMap[30607] = "OSGeo.MapGuide.MgServerAdmin";
- classNameMap[30046] = "OSGeo.MapGuide.MgServerNotFoundException";
- classNameMap[30047] = "OSGeo.MapGuide.MgServerNotOnlineException";
classNameMap[11251] = "OSGeo.MapGuide.MgService";
- classNameMap[10521] = "OSGeo.MapGuide.MgServiceNotAvailableException";
- classNameMap[10522] = "OSGeo.MapGuide.MgServiceNotSupportedException";
- classNameMap[30048] = "OSGeo.MapGuide.MgSessionExpiredException";
- classNameMap[30052] = "OSGeo.MapGuide.MgSessionNotFoundException";
classNameMap[10261] = "OSGeo.MapGuide.MgSingleProperty";
classNameMap[30605] = "OSGeo.MapGuide.MgSite";
classNameMap[30601] = "OSGeo.MapGuide.MgSiteConnection";
@@ -301,24 +201,14 @@
classNameMap[30608] = "OSGeo.MapGuide.MgSiteInfo";
classNameMap[11761] = "OSGeo.MapGuide.MgSpatialContextReader";
classNameMap[11762] = "OSGeo.MapGuide.MgSqlDataReader";
- classNameMap[1542] = "OSGeo.MapGuide.MgStreamIoException";
classNameMap[1003] = "OSGeo.MapGuide.MgStringCollection";
classNameMap[2001] = "OSGeo.MapGuide.MgStringProperty";
classNameMap[10003] = "OSGeo.MapGuide.MgStringPropertyCollection";
- classNameMap[1543] = "OSGeo.MapGuide.MgSystemException";
- classNameMap[1544] = "OSGeo.MapGuide.MgTemporaryFileNotAvailableException";
- classNameMap[1545] = "OSGeo.MapGuide.MgThirdPartyException";
classNameMap[31200] = "OSGeo.MapGuide.MgTileService";
classNameMap[11787] = "OSGeo.MapGuide.MgTransaction";
- classNameMap[30049] = "OSGeo.MapGuide.MgUnauthorizedAccessException";
- classNameMap[1547] = "OSGeo.MapGuide.MgUnclassifiedException";
- classNameMap[1548] = "OSGeo.MapGuide.MgUnderflowException";
- classNameMap[30056] = "OSGeo.MapGuide.MgUnknownTileProviderException";
- classNameMap[30057] = "OSGeo.MapGuide.MgUnsupportedTileProviderException";
+ classNameMap[20039] = "OSGeo.MapGuide.MgTransform";
classNameMap[11777] = "OSGeo.MapGuide.MgUpdateFeatures";
- classNameMap[30050] = "OSGeo.MapGuide.MgUriFormatException";
classNameMap[30606] = "OSGeo.MapGuide.MgUserInformation";
- classNameMap[10523] = "OSGeo.MapGuide.MgUserNotFoundException";
classNameMap[11257] = "OSGeo.MapGuide.MgWarnings";
classNameMap[50005] = "OSGeo.MapGuide.MgWebBufferCommand";
classNameMap[50000] = "OSGeo.MapGuide.MgWebCommand";
@@ -348,14 +238,32 @@
classNameMap[50013] = "OSGeo.MapGuide.MgWebWidget";
classNameMap[50018] = "OSGeo.MapGuide.MgWebWidgetCollection";
classNameMap[20040] = "OSGeo.MapGuide.MgWktReaderWriter";
- classNameMap[1549] = "OSGeo.MapGuide.MgXmlException";
- classNameMap[1550] = "OSGeo.MapGuide.MgXmlParserException";
+ //Sanity check that we haven't double registered the same type name under different
+ //class ids (Only possible when class id is being accidentally reused in a base or
+ //derived C++ class)
+ foreach (var kvp in classNameMap)
+ if (nameClassMap.ContainsKey(kvp.Value))
+ throw new Exception($"Failed sanity check. Type ({kvp.Value}) already registered with class id of ({kvp.Key})");
+ nameClassMap[kvp.Value] = kvp.Key;
+ internal static IEnumerable<int> ClassIds => classNameMap.Keys;
internal static string GetTypeName(int id)
return classNameMap.ContainsKey(id) ? classNameMap[id] : null;
+ internal static int? GetClassId(string typeName)
+ return nameClassMap.ContainsKey(typeName) ? nameClassMap[typeName] : (int?)null;
\ No newline at end of file
Modified: sandbox/jng/vanilla_swig/Bindings/src/Managed/Java/org/osgeo/mapguide/ObjectFactory.java
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/Java/org/osgeo/mapguide/ObjectFactory.java 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/Java/org/osgeo/mapguide/ObjectFactory.java 2020-11-20 14:21:54 UTC (rev 9797)
@@ -44,6 +44,7 @@
classMap.put(new Integer(10255), getSWIGCtor("MgClobProperty"));
classMap.put(new Integer(10250), getSWIGCtor("MgColor"));
classMap.put(new Integer(20003), getSWIGCtor("MgCoordinate"));
+ classMap.put(new Integer(20008), getSWIGCtor("MgCoordinateCollection"));
classMap.put(new Integer(20009), getSWIGCtor("MgCoordinateIterator"));
classMap.put(new Integer(20500), getSWIGCtor("MgCoordinateSystem"));
classMap.put(new Integer(20504), getSWIGCtor("MgCoordinateSystemCatalog"));
@@ -67,9 +68,11 @@
classMap.put(new Integer(20533), getSWIGCtor("MgCoordinateSystemGeodeticPath"));
classMap.put(new Integer(20535), getSWIGCtor("MgCoordinateSystemGeodeticPathDictionary"));
classMap.put(new Integer(20534), getSWIGCtor("MgCoordinateSystemGeodeticPathElement"));
+ classMap.put(new Integer(20546), getSWIGCtor("MgCoordinateSystemGeodeticStandaloneTransformDefParams"));
classMap.put(new Integer(20508), getSWIGCtor("MgCoordinateSystemGeodeticTransformation"));
classMap.put(new Integer(20536), getSWIGCtor("MgCoordinateSystemGeodeticTransformDef"));
classMap.put(new Integer(20540), getSWIGCtor("MgCoordinateSystemGeodeticTransformDefDictionary"));
+ classMap.put(new Integer(20541), getSWIGCtor("MgCoordinateSystemGeodeticTransformDefParams"));
classMap.put(new Integer(20545), getSWIGCtor("MgCoordinateSystemGeodeticTransformGridFile"));
classMap.put(new Integer(20532), getSWIGCtor("MgCoordinateSystemGridBase"));
classMap.put(new Integer(20524), getSWIGCtor("MgCoordinateSystemGridBoundary"));
@@ -104,11 +107,13 @@
classMap.put(new Integer(1256), getSWIGCtor("MgDateTime"));
classMap.put(new Integer(10256), getSWIGCtor("MgDateTimeProperty"));
classMap.put(new Integer(11775), getSWIGCtor("MgDeleteFeatures"));
+ classMap.put(new Integer(2251), getSWIGCtor("MgDisposable"));
classMap.put(new Integer(1000), getSWIGCtor("MgDisposableCollection"));
classMap.put(new Integer(10257), getSWIGCtor("MgDoubleProperty"));
classMap.put(new Integer(30700), getSWIGCtor("MgDrawingService"));
classMap.put(new Integer(30901), getSWIGCtor("MgDwfVersion"));
classMap.put(new Integer(20001), getSWIGCtor("MgEnvelope"));
+ classMap.put(new Integer(1515), getSWIGCtor("MgException"));
classMap.put(new Integer(11772), getSWIGCtor("MgFeatureAggregateOptions"));
classMap.put(new Integer(11774), getSWIGCtor("MgFeatureCommandCollection"));
classMap.put(new Integer(31001), getSWIGCtor("MgFeatureInformation"));
@@ -121,11 +126,12 @@
classMap.put(new Integer(11786), getSWIGCtor("MgFileFeatureSourceParams"));
classMap.put(new Integer(20016), getSWIGCtor("MgGeometricEntity"));
classMap.put(new Integer(11756), getSWIGCtor("MgGeometricPropertyDefinition"));
- classMap.put(new Integer(20019), getSWIGCtor("MgGeometry"));
+ classMap.put(new Integer(11757), getSWIGCtor("MgGeometry"));
classMap.put(new Integer(20020), getSWIGCtor("MgGeometryCollection"));
classMap.put(new Integer(20021), getSWIGCtor("MgGeometryComponent"));
classMap.put(new Integer(20002), getSWIGCtor("MgGeometryFactory"));
classMap.put(new Integer(11758), getSWIGCtor("MgGeometryProperty"));
+ classMap.put(new Integer(20054), getSWIGCtor("MgGeometrySimplifier"));
classMap.put(new Integer(11785), getSWIGCtor("MgGeometryTypeInfo"));
classMap.put(new Integer(11782), getSWIGCtor("MgGwsFeatureReader"));
classMap.put(new Integer(40000), getSWIGCtor("MgHttpHeader"));
@@ -159,6 +165,8 @@
classMap.put(new Integer(30900), getSWIGCtor("MgMappingService"));
classMap.put(new Integer(30905), getSWIGCtor("MgMapPlot"));
classMap.put(new Integer(30906), getSWIGCtor("MgMapPlotCollection"));
+ classMap.put(new Integer(20027), getSWIGCtor("MgMeasure"));
+ classMap.put(new Integer(31003), getSWIGCtor("MgMetatile"));
classMap.put(new Integer(20029), getSWIGCtor("MgMultiCurvePolygon"));
classMap.put(new Integer(20030), getSWIGCtor("MgMultiCurveString"));
classMap.put(new Integer(20031), getSWIGCtor("MgMultiGeometry"));
@@ -165,6 +173,7 @@
classMap.put(new Integer(20032), getSWIGCtor("MgMultiLineString"));
classMap.put(new Integer(20033), getSWIGCtor("MgMultiPoint"));
classMap.put(new Integer(20034), getSWIGCtor("MgMultiPolygon"));
+ classMap.put(new Integer(2252), getSWIGCtor("MgObject"));
classMap.put(new Integer(11759), getSWIGCtor("MgObjectPropertyDefinition"));
classMap.put(new Integer(30604), getSWIGCtor("MgPackageStatusInformation"));
classMap.put(new Integer(11788), getSWIGCtor("MgParameter"));
@@ -174,10 +183,11 @@
classMap.put(new Integer(20045), getSWIGCtor("MgPointCollection"));
classMap.put(new Integer(20035), getSWIGCtor("MgPolygon"));
classMap.put(new Integer(20046), getSWIGCtor("MgPolygonCollection"));
+ classMap.put(new Integer(20055), getSWIGCtor("MgPreparedGeometry"));
classMap.put(new Integer(31400), getSWIGCtor("MgProfilingService"));
classMap.put(new Integer(2000), getSWIGCtor("MgProperty"));
classMap.put(new Integer(1002), getSWIGCtor("MgPropertyCollection"));
- classMap.put(new Integer(2002), getSWIGCtor("MgPropertyDefinition"));
+ classMap.put(new Integer(10251), getSWIGCtor("MgPropertyDefinition"));
classMap.put(new Integer(10001), getSWIGCtor("MgPropertyDefinitionCollection"));
classMap.put(new Integer(11769), getSWIGCtor("MgRaster"));
classMap.put(new Integer(11770), getSWIGCtor("MgRasterProperty"));
@@ -205,6 +215,7 @@
classMap.put(new Integer(10003), getSWIGCtor("MgStringPropertyCollection"));
classMap.put(new Integer(31200), getSWIGCtor("MgTileService"));
classMap.put(new Integer(11787), getSWIGCtor("MgTransaction"));
+ classMap.put(new Integer(20039), getSWIGCtor("MgTransform"));
classMap.put(new Integer(11777), getSWIGCtor("MgUpdateFeatures"));
classMap.put(new Integer(30606), getSWIGCtor("MgUserInformation"));
classMap.put(new Integer(11257), getSWIGCtor("MgWarnings"));
@@ -236,6 +247,7 @@
classMap.put(new Integer(50013), getSWIGCtor("MgWebWidget"));
classMap.put(new Integer(50018), getSWIGCtor("MgWebWidgetCollection"));
classMap.put(new Integer(20040), getSWIGCtor("MgWktReaderWriter"));
catch(Exception e)
Added: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/ExternalTests/ClassIdSanityTest.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/ExternalTests/ClassIdSanityTest.cs (rev 0)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/ExternalTests/ClassIdSanityTest.cs 2020-11-20 14:21:54 UTC (rev 9797)
@@ -0,0 +1,26 @@
+using OSGeo.MapGuide.Test.Common;
+using System;
+using System.Linq;
+namespace TestMapGuideApi.ExternalTests
+ public class ClassIdSanityTest : IExternalTest
+ public void Execute(IPlatformFactory factory, ITestLogger logger)
+ var missing = 0;
+ var mgAssemblies = AppDomain.CurrentDomain.GetAssemblies().Where(asm => asm.FullName.Contains("OSGeo.MapGuide"));
+ foreach (var clsId in OSGeo.MapGuide.MgClassMap.ClassIds)
+ var typeName = OSGeo.MapGuide.MgClassMap.GetTypeName(clsId);
+ var types = mgAssemblies.Select(asm => asm.GetType(typeName, false));
+ if (!types.Any())
+ logger.WriteLine($"ERROR: .net proxy class ({typeName}, id: {clsId} does not exist");
+ missing++;
+ Assert.AreEqual(0, missing);
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/MapGuideTestExecutorCollection.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/MapGuideTestExecutorCollection.cs 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/MapGuideTestExecutorCollection.cs 2020-11-20 14:21:54 UTC (rev 9797)
@@ -1,11 +1,8 @@
-using OSGeo.MapGuide;
-using OSGeo.MapGuide.Test.Common;
using System;
using System.Collections.Generic;
using System.IO;
-using System.Linq;
using System.Text;
-using System.Threading.Tasks;
namespace OSGeo.MapGuide.Test
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/TestMapGuideApi.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/TestMapGuideApi.csproj 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMapGuideApi/TestMapGuideApi.csproj 2020-11-20 14:21:54 UTC (rev 9797)
@@ -13,6 +13,9 @@
<GenerateAssemblyCopyrightAttribute>false</GenerateAssemblyCopyrightAttribute>
</PropertyGroup>
<ItemGroup>
+ <Compile Include="..\..\..\..\Managed\DotNet\Common\MgClassMap.cs" Link="MgClassMap.cs" />
+ </ItemGroup>
+ <ItemGroup>
<ProjectReference Include="..\TestCommon\TestCommon.csproj" />
</ItemGroup>
<ItemGroup>
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/Program.cs 2020-11-20 14:21:54 UTC (rev 9797)
@@ -1,5 +1,6 @@
using System;
using System.IO;
+using System.Linq;
using System.Runtime.InteropServices;
@@ -13,6 +14,8 @@
mentorDictionaryPath = Path.GetFullPath(Path.Combine(Environment.CurrentDirectory, mentorDictionaryPath));
Environment.SetEnvironmentVariable("MENTOR_DICTIONARY_PATH", mentorDictionaryPath, EnvironmentVariableTarget.Process);
+ ClassIdSanityTest();
var csFactory = new MgCoordinateSystemFactory();
var csCat = csFactory.GetCatalog();
csCat.SetDictionaryDir(mentorDictionaryPath);
@@ -137,6 +140,64 @@
Console.WriteLine("*********** ALL OK ****************");
+ private static void ClassIdSanityTest()
+ var missing = 0;
+ .Where(t => t != null)
+ .ToList();
+ if (types.Count == 0)
+ Console.WriteLine($"ERROR: .net proxy class ({typeName}, id: {clsId}) does not exist");
+ missing++;
+ if (missing > 0)
+ throw new Exception($"{missing} .net proxy class(es) could not be found");
+ missing = 0;
+ //Now check in reverse
+ foreach (var type in mgAssemblies.SelectMany(asm => asm.ExportedTypes.Where(t => t.Name.StartsWith("Mg"))))
+ if (type.IsClass && !IsConstantClass(type))
+ var id = MgClassMap.GetClassId(type.FullName);
+ if (!id.HasValue)
+ Console.WriteLine($".net proxy class ({type.FullName}) does not have a known corresponding class id");
+ missing++;
+ if (missing > 0)
+ throw new Exception($"{missing} .net proxy class(es) are missing class ids");
+ private static bool IsConstantClass(Type type)
+ if (type.IsClass)
+ var fields = type.GetFields(System.Reflection.BindingFlags.Public | System.Reflection.BindingFlags.Static | System.Reflection.BindingFlags.FlattenHierarchy);
+ // IsLiteral determines if its value is written at
+ // compile time and not changeable
+ // IsInitOnly determines if the field can be set
+ // in the body of the constructor
+ // for C# a field which is readonly keyword would have both true
+ // but a const field would have only IsLiteral equal to true
+ var constants = fields.Where(fi => fi.IsLiteral && !fi.IsInitOnly);
+ return constants.Any();
+ return false;
static void OnException(MgException ex)
Console.WriteLine("[dotnet]: MgException caught");
Modified: sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/TestMisc.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/TestMisc.csproj 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Test/DotNet/src/TestMisc/TestMisc.csproj 2020-11-20 14:21:54 UTC (rev 9797)
@@ -6,6 +6,10 @@
</PropertyGroup>
<ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
<PackageReference Include="CommandLineParser" Version="2.2.1" />
<PackageReference Include="OSGeo.MapGuide.Foundation" Version="4.0.0" />
<PackageReference Include="OSGeo.MapGuide.Geometry" Version="4.0.0" />
Modified: sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/dotnet.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/dotnet.txt 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/dotnet.txt 2020-11-20 14:21:54 UTC (rev 9797)
@@ -7,18 +7,45 @@
static MgClassMap()
$CLASS_NAME_MAP_BODY$
Modified: sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/java.txt
--- sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/java.txt 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/Templates/java.txt 2020-11-20 14:21:54 UTC (rev 9797)
@@ -40,7 +40,13 @@
private static Constructor getSWIGCtor(String className) throws ClassNotFoundException, Exception
Constructor swigCtor = null;
- Constructor[] cons = Class.forName("org.osgeo.mapguide." + className).getDeclaredConstructors();
+ String typeName = "org.osgeo.mapguide." + className;
+ Class type = Class.forName(typeName);
+ if (type == null)
+ throw new Exception("Could not find proxy class: " + typeName);
+ Constructor[] cons = type.getDeclaredConstructors();
for (int i = 0; i < cons.length; i++)
Class[] parameterTypes = cons[i].getParameterTypes();
Deleted: sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/classmap_master.json
--- sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/classmap_master.json 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Data/classmap_master.json 2020-11-20 14:21:54 UTC (rev 9797)
@@ -1,1114 +0,0 @@
- "Modules": [
- "Name": "Foundation",
- "Classes": {
- "1500": "MgApplicationException",
- "1501": "MgArgumentOutOfRangeException",
- "1005": "MgBatchPropertyCollection",
- "1250": "MgByteReader",
- "1257": "MgByteSink",
- "1251": "MgByteSource",
- "1502": "MgClassNotFoundException",
- "1503": "MgConfigurationException",
- "1504": "MgConfigurationLoadFailedException",
- "1505": "MgConfigurationSaveFailedException",
- "1256": "MgDateTime",
- "1506": "MgDateTimeException",
- "1507": "MgDecryptionException",
- "1508": "MgDirectoryNotFoundException",
- "1000": "MgDisposableCollection",
- "1509": "MgDivideByZeroException",
- "1510": "MgDomainException",
- "1511": "MgDuplicateDirectoryException",
- "1512": "MgDuplicateFileException",
- "1513": "MgDuplicateObjectException",
- "1514": "MgEncryptionException",
- "1515": "MgException",
- "1516": "MgFileIoException",
- "1517": "MgFileNotFoundException",
- "1518": "MgIndexOutOfRangeException",
- "1519": "MgInvalidArgumentException",
- "1520": "MgInvalidCastException",
- "1522": "MgInvalidOperationException",
- "1523": "MgInvalidPropertyTypeException",
- "1524": "MgInvalidStreamHeaderException",
- "1525": "MgIoException",
- "1526": "MgLengthException",
- "1527": "MgLogicException",
- "1528": "MgNotFiniteNumberException",
- "1529": "MgNotImplementedException",
- "1530": "MgNullArgumentException",
- "1531": "MgNullPropertyValueException",
- "1532": "MgNullReferenceException",
- "1533": "MgObjectNotFoundException",
- "1534": "MgOutOfMemoryException",
- "1535": "MgOutOfRangeException",
- "1536": "MgOverflowException",
- "1537": "MgPlatformNotSupportedException",
- "2000": "MgProperty",
- "1002": "MgPropertyCollection",
- "2002": "MgPropertyDefinition",
- "1540": "MgResourceTagNotFoundException",
- "1538": "MgResourcesException",
- "1539": "MgResourcesLoadFailedException",
- "1541": "MgRuntimeException",
- "1542": "MgStreamIoException",
- "1003": "MgStringCollection",
- "2001": "MgStringProperty",
- "1543": "MgSystemException",
- "1544": "MgTemporaryFileNotAvailableException",
- "1545": "MgThirdPartyException",
- "1547": "MgUnclassifiedException",
- "1548": "MgUnderflowException",
- "1549": "MgXmlException",
- "1550": "MgXmlParserException"
- "Name": "Geometry",
- "Classes": {
- "20004": "MgAgfReaderWriter",
- "20005": "MgAggregateGeometry",
- "20006": "MgArcSegment",
- "20003": "MgCoordinate",
- "20009": "MgCoordinateIterator",
- "20500": "MgCoordinateSystem",
- "20504": "MgCoordinateSystemCatalog",
- "20506": "MgCoordinateSystemCategory",
- "20510": "MgCoordinateSystemCategoryDictionary",
- "21000": "MgCoordinateSystemComputationFailedException",
- "21001": "MgCoordinateSystemConversionFailedException",
- "20507": "MgCoordinateSystemDatum",
- "20512": "MgCoordinateSystemDatumDictionary",
- "20511": "MgCoordinateSystemDictionary",
- "20521": "MgCoordinateSystemDictionaryUtility",
- "20509": "MgCoordinateSystemEllipsoid",
- "20513": "MgCoordinateSystemEllipsoidDictionary",
- "20514": "MgCoordinateSystemEnum",
- "20515": "MgCoordinateSystemEnumInteger32",
- "20501": "MgCoordinateSystemFactory",
- "20516": "MgCoordinateSystemFilter",
- "20517": "MgCoordinateSystemFilterInteger32",
- "20505": "MgCoordinateSystemFormatConverter",
- "20542": "MgCoordinateSystemGeodeticAnalyticalTransformDefParams",
- "20543": "MgCoordinateSystemGeodeticInterpolationTransformDefParams",
- "20544": "MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams",
- "20533": "MgCoordinateSystemGeodeticPath",
- "20535": "MgCoordinateSystemGeodeticPathDictionary",
- "20534": "MgCoordinateSystemGeodeticPathElement",
- "20536": "MgCoordinateSystemGeodeticTransformDef",
- "20540": "MgCoordinateSystemGeodeticTransformDefDictionary",
- "20545": "MgCoordinateSystemGeodeticTransformGridFile",
- "20508": "MgCoordinateSystemGeodeticTransformation",
- "20532": "MgCoordinateSystemGridBase",
- "20524": "MgCoordinateSystemGridBoundary",
- "20529": "MgCoordinateSystemGridLine",
- "20526": "MgCoordinateSystemGridLineCollection",
- "20530": "MgCoordinateSystemGridRegion",
- "20527": "MgCoordinateSystemGridRegionCollection",
- "20525": "MgCoordinateSystemGridSpecification",
- "20531": "MgCoordinateSystemGridTick",
- "20528": "MgCoordinateSystemGridTickCollection",
- "21002": "MgCoordinateSystemInitializationFailedException",
- "21003": "MgCoordinateSystemLoadFailedException",
- "20518": "MgCoordinateSystemMathComparator",
- "20502": "MgCoordinateSystemMeasure",
- "21004": "MgCoordinateSystemMeasureFailedException",
- "20522": "MgCoordinateSystemMgrs",
- "20520": "MgCoordinateSystemProjectionInformation",
- "20503": "MgCoordinateSystemTransform",
- "21005": "MgCoordinateSystemTransformFailedException",
- "20519": "MgCoordinateSystemUnitInformation",
- "20048": "MgCoordinateXY",
- "20051": "MgCoordinateXYM",
- "20049": "MgCoordinateXYZ",
- "20050": "MgCoordinateXYZM",
- "20010": "MgCurve",
- "20011": "MgCurvePolygon",
- "20047": "MgCurvePolygonCollection",
- "20012": "MgCurveRing",
- "20052": "MgCurveRingCollection",
- "20013": "MgCurveSegment",
- "20041": "MgCurveSegmentCollection",
- "20014": "MgCurveString",
- "20043": "MgCurveStringCollection",
- "20001": "MgEnvelope",
- "20016": "MgGeometricEntity",
- "20019": "MgGeometry",
- "20020": "MgGeometryCollection",
- "20021": "MgGeometryComponent",
- "21006": "MgGeometryException",
- "20002": "MgGeometryFactory",
- "21007": "MgInvalidCoordinateSystemException",
- "21008": "MgInvalidCoordinateSystemTypeException",
- "21009": "MgInvalidCoordinateSystemUnitsException",
- "20042": "MgLineString",
- "20044": "MgLineStringCollection",
- "20023": "MgLinearRing",
- "20053": "MgLinearRingCollection",
- "20024": "MgLinearSegment",
- "20029": "MgMultiCurvePolygon",
- "20030": "MgMultiCurveString",
- "20031": "MgMultiGeometry",
- "20032": "MgMultiLineString",
- "20033": "MgMultiPoint",
- "20034": "MgMultiPolygon",
- "20000": "MgPoint",
- "20045": "MgPointCollection",
- "20035": "MgPolygon",
- "20046": "MgPolygonCollection",
- "20037": "MgRegion",
- "20038": "MgRing",
- "20040": "MgWktReaderWriter",
- "Name": "PlatformBase",
- "Classes": {
- "10500": "MgArrayTypeMismatchException",
- "10252": "MgBlobProperty",
- "10253": "MgBooleanProperty",
- "10254": "MgByteProperty",
- "11750": "MgClassDefinition",
- "11780": "MgClassDefinitionCollection",
- "10255": "MgClobProperty",
- "10250": "MgColor",
- "11751": "MgDataPropertyDefinition",
- "11773": "MgDataReader",
- "10256": "MgDateTimeProperty",
- "11775": "MgDeleteFeatures",
- "10257": "MgDoubleProperty",
- "10501": "MgDuplicateResourceDataException",
- "10502": "MgDuplicateResourceException",
- "10503": "MgEmptyFeatureSetException",
- "10504": "MgFdoException",
- "11772": "MgFeatureAggregateOptions",
- "11774": "MgFeatureCommandCollection",
- "11764": "MgFeatureProperty",
- "11771": "MgFeatureQueryOptions",
- "11753": "MgFeatureReader",
- "11778": "MgFeatureSchema",
- "11779": "MgFeatureSchemaCollection",
- "11754": "MgFeatureService",
- "10505": "MgFeatureServiceException",
- "11786": "MgFileFeatureSourceParams",
- "11756": "MgGeometricPropertyDefinition",
- "11758": "MgGeometryProperty",
- "11785": "MgGeometryTypeInfo",
- "11782": "MgGwsFeatureReader",
- "11776": "MgInsertFeatures",
- "10258": "MgInt16Property",
- "10259": "MgInt32Property",
- "10260": "MgInt64Property",
- "10000": "MgIntCollection",
- "10507": "MgInvalidMapDefinitionException",
- "10508": "MgInvalidRepositoryNameException",
- "10509": "MgInvalidRepositoryTypeException",
- "10510": "MgInvalidResourceDataNameException",
- "10511": "MgInvalidResourceDataTypeException",
- "10512": "MgInvalidResourceNameException",
- "10513": "MgInvalidResourcePathException",
- "10514": "MgInvalidResourcePreProcessingTypeException",
- "10515": "MgInvalidResourceTypeException",
- "12003": "MgLayerBase",
- "12002": "MgLayerCollection",
- "12001": "MgLayerGroup",
- "12004": "MgLayerGroupCollection",
- "10517": "MgLayerNotFoundException",
- "11766": "MgLongTransactionReader",
- "12000": "MgMapBase",
- "12005": "MgMapCollection",
- "11759": "MgObjectPropertyDefinition",
- "11788": "MgParameter",
- "10004": "MgParameterCollection",
- "10001": "MgPropertyDefinitionCollection",
- "11769": "MgRaster",
- "11770": "MgRasterProperty",
- "11768": "MgRasterPropertyDefinition",
- "12006": "MgReadOnlyLayerCollection",
- "11526": "MgResource",
- "10518": "MgResourceBusyException",
- "10519": "MgResourceDataNotFoundException",
- "11500": "MgResourceIdentifier",
- "10520": "MgResourceNotFoundException",
- "11501": "MgResourceService",
- "12007": "MgSelectionBase",
- "11251": "MgService",
- "10521": "MgServiceNotAvailableException",
- "10522": "MgServiceNotSupportedException",
- "10261": "MgSingleProperty",
- "11761": "MgSpatialContextReader",
- "11762": "MgSqlDataReader",
- "10003": "MgStringPropertyCollection",
- "11787": "MgTransaction",
- "11777": "MgUpdateFeatures",
- "10523": "MgUserNotFoundException",
- "11257": "MgWarnings",
- "Name": "MapGuideCommon",
- "Classes": {
- "30000": "MgAuthenticationFailedException",
- "30001": "MgConnectionFailedException",
- "30002": "MgConnectionNotOpenException",
- "30003": "MgDbException",
- "30004": "MgDbXmlException",
- "30700": "MgDrawingService",
- "30005": "MgDuplicateGroupException",
- "30006": "MgDuplicateNameException",
- "30007": "MgDuplicateParameterException",
- "30008": "MgDuplicateRepositoryException",
- "30009": "MgDuplicateRoleException",
- "30010": "MgDuplicateServerException",
- "30011": "MgDuplicateSessionException",
- "30012": "MgDuplicateUserException",
- "30013": "MgDwfException",
- "30014": "MgDwfSectionNotFoundException",
- "30015": "MgDwfSectionResourceNotFoundException",
- "30901": "MgDwfVersion",
- "30016": "MgEndOfStreamException",
- "31001": "MgFeatureInformation",
- "30018": "MgGroupNotFoundException",
- "30019": "MgInvalidDwfPackageException",
- "30020": "MgInvalidDwfSectionException",
- "30021": "MgInvalidFeatureSourceException",
- "30022": "MgInvalidIpAddressException",
- "30023": "MgInvalidLicenseException",
- "30024": "MgInvalidLogEntryException",
- "30026": "MgInvalidPasswordException",
- "30027": "MgInvalidPrintLayoutFontSizeUnitsException",
- "30028": "MgInvalidPrintLayoutPositionUnitsException",
- "30029": "MgInvalidPrintLayoutSizeUnitsException",
- "30031": "MgInvalidServerNameException",
- "31300": "MgKmlService",
- "30501": "MgLayer",
- "30904": "MgLayout",
- "30032": "MgLicenseException",
- "30033": "MgLicenseExpiredException",
- "30500": "MgMap",
- "30905": "MgMapPlot",
- "30906": "MgMapPlotCollection",
- "30900": "MgMappingService",
- "30035": "MgOperationProcessingException",
- "30604": "MgPackageStatusInformation",
- "30036": "MgParameterNotFoundException",
- "30037": "MgPathTooLongException",
- "30902": "MgPlotSpecification",
- "30039": "MgPortNotAvailableException",
- "30040": "MgPrintToScaleModeNotSelectedException",
- "31400": "MgProfilingService",
- "31002": "MgRenderingOptions",
- "31000": "MgRenderingService",
- "30041": "MgRepositoryCreationFailedException",
- "30042": "MgRepositoryNotFoundException",
- "30043": "MgRepositoryNotOpenException",
- "30044": "MgRepositoryOpenFailedException",
- "30045": "MgRoleNotFoundException",
- "30502": "MgSelection",
- "30607": "MgServerAdmin",
- "30046": "MgServerNotFoundException",
- "30047": "MgServerNotOnlineException",
- "30048": "MgSessionExpiredException",
- "30052": "MgSessionNotFoundException",
- "30605": "MgSite",
- "30601": "MgSiteConnection",
- "30608": "MgSiteInfo",
- "31200": "MgTileService",
- "30049": "MgUnauthorizedAccessException",
- "30056": "MgUnknownTileProviderException",
- "30057": "MgUnsupportedTileProviderException",
- "30050": "MgUriFormatException",
- "30606": "MgUserInformation",
- "Name": "Web",
- "Classes": {
- "40000": "MgHttpHeader",
- "40006": "MgHttpPrimitiveValue",
- "40004": "MgHttpRequest",
- "40002": "MgHttpRequestMetadata",
- "40001": "MgHttpRequestParam",
- "40005": "MgHttpResponse",
- "40003": "MgHttpResult",
- "30500": "MgMap",
- "50005": "MgWebBufferCommand",
- "50000": "MgWebCommand",
- "50012": "MgWebCommandCollection",
- "50015": "MgWebCommandWidget",
- "50025": "MgWebContextMenu",
- "50016": "MgWebFlyoutWidget",
- "50009": "MgWebGetPrintablePageCommand",
- "50011": "MgWebHelpCommand",
- "50022": "MgWebInformationPane",
- "50003": "MgWebInvokeScriptCommand",
- "50004": "MgWebInvokeUrlCommand",
- "50026": "MgWebLayout",
- "50008": "MgWebMeasureCommand",
- "50007": "MgWebPrintCommand",
- "50002": "MgWebSearchCommand",
- "50006": "MgWebSelectWithinCommand",
- "50014": "MgWebSeparatorWidget",
- "50023": "MgWebTaskBar",
- "50017": "MgWebTaskBarWidget",
- "50024": "MgWebTaskPane",
- "50021": "MgWebToolBar",
- "50019": "MgWebUiPane",
- "50020": "MgWebUiSizablePane",
- "50001": "MgWebUiTargetCommand",
- "50010": "MgWebViewOptionsCommand",
- "50013": "MgWebWidget",
- "50018": "MgWebWidgetCollection",
Modified: sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Program.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Program.cs 2020-11-20 10:04:15 UTC (rev 9796)
+++ sandbox/jng/vanilla_swig/Bindings/src/Tools/ClassMapGen/Program.cs 2020-11-20 14:21:54 UTC (rev 9797)
@@ -246,8 +246,12 @@
var classId = f.Invoke();
var mod = modsByName[modName];
- var className = "Mg" + uqClassName;
+ var className = uqClassName;
+ //Prefix "Mg" if not done already
+ if (!className.StartsWith("Mg"))
+ className = "Mg" + uqClassName;
// Skip class ids for removed exception classes. The ids are remaining in the
// original headers so we don't try to reuse them for any new classes we add to the
// MapGuide API in the future
More information about the mapguide-commits
