[mapguide-commits] r9810 - in sandbox/jng/vanilla_swig: . Bindings Bindings/src/Bindings/Java Bindings/src/Managed/DotNet/MapGuideDotNetApi Bindings/src/Managed/DotNet/OSGeo.MapGuide.Foundation Bindings/src/Managed/DotNet/OSGeo.MapGuide.Geometry Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon Bindings/src/Managed/DotNet/OSGeo.MapGuide.PlatformBase Bindings/src/Managed/DotNet/OSGeo.MapGuide.Web
svn_mapguide at osgeo.org
Sat Nov 28 04:10:12 PST 2020
Author: jng
Date: 2020-11-28 04:10:11 -0800 (Sat, 28 Nov 2020)
New Revision: 9810
Added:
sandbox/jng/vanilla_swig/nuget.config
Removed:
sandbox/jng/vanilla_swig/Bindings/nuget.config
sandbox/jng/vanilla_swig/Bindings/TODO.txt
sandbox/jng/vanilla_swig/Bindings/setup_linux_native_libs.cmd
sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/JavaApi.vcxproj
sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/MapGuideDotNetApi.csproj
sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Foundation/OSGeo.MapGuide.Foundation.csproj
sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Geometry/OSGeo.MapGuide.Geometry.csproj
sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/OSGeo.MapGuide.MapGuideCommon.csproj
sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.PlatformBase/OSGeo.MapGuide.PlatformBase.csproj
sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Web/OSGeo.MapGuide.Web.csproj
Move packages dir up one level
Index: sandbox/jng/vanilla_swig
--- sandbox/jng/vanilla_swig 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig 2020-11-28 12:10:11 UTC (rev 9810)
Property changes on: sandbox/jng/vanilla_swig
___________________________________________________________________
Added: svn:ignore
## -0,0 +1 ##
+packages
Index: sandbox/jng/vanilla_swig/Bindings
--- sandbox/jng/vanilla_swig/Bindings 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings 2020-11-28 12:10:11 UTC (rev 9810)
Property changes on: sandbox/jng/vanilla_swig/Bindings
Modified: svn:ignore
## -1,2 +1 ##
linux-x64
-packages
Modified: sandbox/jng/vanilla_swig/Bindings/TODO.txt
--- sandbox/jng/vanilla_swig/Bindings/TODO.txt 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings/TODO.txt 2020-11-28 12:10:11 UTC (rev 9810)
@@ -7,7 +7,7 @@
- [x] Check in test case admin tool
- [x] Consolidate Tools.sln into Bindings.sln
- [ ] Relocate/remove existing test code
- - [ ] Move packages dir up to to top-level MgDev subdirectory and make sure nuget.config sources from this dir
+ - [x] Move packages dir up to to top-level MgDev subdirectory and make sure nuget.config sources from this dir
- Split .net binding into the Foundation/Geometry/PlatformBase/MapGuideCommon/Web layout (https://github.com/jumpinjackie/mapguide-api-bindings/issues/18)
- [x] Add .targets files to each C# project so that native dlls are copied properly when consumed by legacy .net framework applications/libraries
- [x] Consolidate TestCommon and TestMapGuideApi .net projects to unified netstandard2.0 libraries
Deleted: sandbox/jng/vanilla_swig/Bindings/nuget.config
--- sandbox/jng/vanilla_swig/Bindings/nuget.config 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings/nuget.config 2020-11-28 12:10:11 UTC (rev 9810)
@@ -1,10 +0,0 @@
-<?xml version="1.0" encoding="utf-8" ?>
-<configuration>
- <packageSources>
- <add key="nuget.org" value="https://api.nuget.org/v3/index.json" protocolVersion="3" />
- <add key="local" value="packages/DotNet/Release" />
- </packageSources>
- <config>
- <add key="globalPackagesFolder" value="packages/Installed" />
- </config>
-</configuration>
\ No newline at end of file
Modified: sandbox/jng/vanilla_swig/Bindings/setup_linux_native_libs.cmd
--- sandbox/jng/vanilla_swig/Bindings/setup_linux_native_libs.cmd 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings/setup_linux_native_libs.cmd 2020-11-28 12:10:11 UTC (rev 9810)
@@ -1,23 +1,23 @@
SET TARBALL=%1
7z x %TARBALL% -so | 7z x -aoa -si -ttar -o"linux-x64"
rem Foundation setup
-copy /Y linux-x64\lib64\libFoundation* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\libMgFoundation* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\libMgMdfModel* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\libACE* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\libxerces* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libFoundation* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libMgFoundation* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libMgMdfModel* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libACE* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libxerces* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
rem Geometry setup
-copy /Y linux-x64\lib64\libGeometry* src\Managed\DotNet\OSGeo.MapGuide.Geometry\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\libMgGeometry* src\Managed\DotNet\OSGeo.MapGuide.Geometry\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libGeometry* src\Managed\DotNet\OSGeo.MapGuide.Geometry\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libMgGeometry* src\Managed\DotNet\OSGeo.MapGuide.Geometry\runtimes\linux-x64\native
rem PlatformBase setup
-copy /Y linux-x64\lib64\libPlatformBase* src\Managed\DotNet\OSGeo.MapGuide.PlatformBase\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\libMgPlatformBase* src\Managed\DotNet\OSGeo.MapGuide.PlatformBase\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\libMgMdfParser* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libPlatformBase* src\Managed\DotNet\OSGeo.MapGuide.PlatformBase\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libMgPlatformBase* src\Managed\DotNet\OSGeo.MapGuide.PlatformBase\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libMgMdfParser* src\Managed\DotNet\OSGeo.MapGuide.Foundation\runtimes\linux-x64\native
rem MapGuideCommon setup
-copy /Y linux-x64\lib64\libMapGuideCommon* src\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\libMgMapGuideCommon* src\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libMapGuideCommon* src\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libMgMapGuideCommon* src\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon\runtimes\linux-x64\native
rem Web setup
-copy /Y linux-x64\lib64\libWeb* src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\libMgWeb* src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\libMgHttpHandler* src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native
-copy /Y linux-x64\lib64\liblib_json* src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libWeb* src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libMgWeb* src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\libMgHttpHandler* src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native
+copy /Y /L linux-x64\lib64\liblib_json* src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/JavaApi.vcxproj
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/JavaApi.vcxproj 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/Java/JavaApi.vcxproj 2020-11-28 12:10:11 UTC (rev 9810)
@@ -38,10 +38,10 @@
<PropertyGroup Label="UserMacros" />
<PropertyGroup>
<_ProjectFileVersion>10.0.40219.1</_ProjectFileVersion>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\..\packages\Java\$(Configuration)\x64\</OutDir>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\..\..\packages\Java\$(Configuration)\x64\</OutDir>
<IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\obj\$(Configuration)64\JavaApi\</IntDir>
<LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</LinkIncremental>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\..\packages\Java\$(Configuration)\x64\</OutDir>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\..\..\packages\Java\$(Configuration)\x64\</OutDir>
<IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\obj\$(Configuration)64\JavaApi\</IntDir>
<LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|x64'">false</LinkIncremental>
<CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
@@ -92,11 +92,11 @@
echo Building java classes...
"$(JAVA_HOME)\bin\javac" -classpath . org\osgeo\mapguide\*.java
echo Building JAR file
-"$(JAVA_HOME)\bin\jar" cf $(SolutionDir)..\..\packages\Java\Release\x64\MapGuideApi.jar org\osgeo\mapguide\*.class
+"$(JAVA_HOME)\bin\jar" cf $(SolutionDir)..\..\..\packages\Java\Release\x64\MapGuideApi.jar org\osgeo\mapguide\*.class
echo Building -sources JAR file
-"$(JAVA_HOME)\bin\jar" cf $(SolutionDir)..\..\packages\Java\Release\x64\MapGuideApi-sources.jar org\osgeo\mapguide\*.java
+"$(JAVA_HOME)\bin\jar" cf $(SolutionDir)..\..\..\packages\Java\Release\x64\MapGuideApi-sources.jar org\osgeo\mapguide\*.java
rem echo Building javadoc
-rem "$(JAVA_HOME)\bin\javadoc" -d $(SolutionDir)..\..\packages\Java\Release\x64\html org\osgeo\mapguide\*.java
+rem "$(JAVA_HOME)\bin\javadoc" -d $(SolutionDir)..\..\..\packages\Java\Release\x64\html org\osgeo\mapguide\*.java
popd</Command>
</PostBuildEvent>
</ItemDefinitionGroup>
@@ -140,11 +140,11 @@
popd</Command>
</PostBuildEvent>
Modified: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/MapGuideDotNetApi.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/MapGuideDotNetApi.csproj 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/MapGuideDotNetApi/MapGuideDotNetApi.csproj 2020-11-28 12:10:11 UTC (rev 9810)
@@ -18,13 +18,13 @@
</PropertyGroup>
<PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|AnyCPU'">
- <OutputPath>..\..\..\..\packages\DotNet\Release</OutputPath>
- <DocumentationFile>..\..\..\..\packages\DotNet\Release\MapGuideDotNetApi.xml</DocumentationFile>
+ <OutputPath>..\..\..\..\..\packages\DotNet\Release</OutputPath>
+ <DocumentationFile>..\..\..\..\..\packages\DotNet\Release\MapGuideDotNetApi.xml</DocumentationFile>
<DefineConstants>TRACE;MONOLITHIC_ASSEMBLY</DefineConstants>
</PropertyGroup>
<PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|AnyCPU'">
- <OutputPath>..\..\..\..\packages\DotNet\Debug</OutputPath>
+ <OutputPath>..\..\..\..\..\packages\DotNet\Debug</OutputPath>
<DefineConstants>MONOLITHIC_ASSEMBLY</DefineConstants>
</PropertyGroup>
Modified: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Foundation/OSGeo.MapGuide.Foundation.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Foundation/OSGeo.MapGuide.Foundation.csproj 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Foundation/OSGeo.MapGuide.Foundation.csproj 2020-11-28 12:10:11 UTC (rev 9810)
@@ -18,12 +18,12 @@
</PropertyGroup>
- <DocumentationFile>..\..\..\..\packages\DotNet\Release\OSGeo.MapGuide.Foundation.xml</DocumentationFile>
+ <DocumentationFile>..\..\..\..\..\packages\DotNet\Release\OSGeo.MapGuide.Foundation.xml</DocumentationFile>
</PropertyGroup>
</PropertyGroup>
<ItemGroup>
Modified: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Geometry/OSGeo.MapGuide.Geometry.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Geometry/OSGeo.MapGuide.Geometry.csproj 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Geometry/OSGeo.MapGuide.Geometry.csproj 2020-11-28 12:10:11 UTC (rev 9810)
@@ -18,12 +18,12 @@
</PropertyGroup>
- <DocumentationFile>..\..\..\..\packages\DotNet\Release\OSGeo.MapGuide.Geometry.xml</DocumentationFile>
+ <DocumentationFile>..\..\..\..\..\packages\DotNet\Release\OSGeo.MapGuide.Geometry.xml</DocumentationFile>
</PropertyGroup>
</PropertyGroup>
<ItemGroup>
Modified: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/OSGeo.MapGuide.MapGuideCommon.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/OSGeo.MapGuide.MapGuideCommon.csproj 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/OSGeo.MapGuide.MapGuideCommon.csproj 2020-11-28 12:10:11 UTC (rev 9810)
@@ -18,12 +18,12 @@
</PropertyGroup>
- <DocumentationFile>..\..\..\..\packages\DotNet\Release\OSGeo.MapGuide.MapGuideCommon.xml</DocumentationFile>
+ <DocumentationFile>..\..\..\..\..\packages\DotNet\Release\OSGeo.MapGuide.MapGuideCommon.xml</DocumentationFile>
</PropertyGroup>
</PropertyGroup>
<ItemGroup>
Modified: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.PlatformBase/OSGeo.MapGuide.PlatformBase.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.PlatformBase/OSGeo.MapGuide.PlatformBase.csproj 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.PlatformBase/OSGeo.MapGuide.PlatformBase.csproj 2020-11-28 12:10:11 UTC (rev 9810)
@@ -18,12 +18,12 @@
</PropertyGroup>
- <DocumentationFile>..\..\..\..\packages\DotNet\Release\OSGeo.MapGuide.PlatformBase.xml</DocumentationFile>
+ <DocumentationFile>..\..\..\..\..\packages\DotNet\Release\OSGeo.MapGuide.PlatformBase.xml</DocumentationFile>
</PropertyGroup>
</PropertyGroup>
<ItemGroup>
Modified: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Web/OSGeo.MapGuide.Web.csproj
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Web/OSGeo.MapGuide.Web.csproj 2020-11-27 17:59:44 UTC (rev 9809)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Web/OSGeo.MapGuide.Web.csproj 2020-11-28 12:10:11 UTC (rev 9810)
@@ -18,9 +18,9 @@
</PropertyGroup>
<GenerateSerializationAssemblies>Off</GenerateSerializationAssemblies>
- <DocumentationFile>..\..\..\..\packages\DotNet\Release\OSGeo.MapGuide.Web.xml</DocumentationFile>
+ <DocumentationFile>..\..\..\..\..\packages\DotNet\Release\OSGeo.MapGuide.Web.xml</DocumentationFile>
</PropertyGroup>
Copied: sandbox/jng/vanilla_swig/nuget.config (from rev 9809, sandbox/jng/vanilla_swig/Bindings/nuget.config)
--- sandbox/jng/vanilla_swig/nuget.config (rev 0)
+++ sandbox/jng/vanilla_swig/nuget.config 2020-11-28 12:10:11 UTC (rev 9810)
@@ -0,0 +1,10 @@
+<?xml version="1.0" encoding="utf-8" ?>
+<configuration>
+ <packageSources>
+ <add key="nuget.org" value="https://api.nuget.org/v3/index.json" protocolVersion="3" />
+ <add key="local" value="packages/DotNet/Release" />
+ </packageSources>
+ <config>
+ <add key="globalPackagesFolder" value="packages/Installed" />
+ </config>
+</configuration>
More information about the mapguide-commits
