[mapguide-commits] r9735 - trunk/MgDev/Oem/CsMapLibrary
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Sep 17 05:02:35 PDT 2020
Author: jng
Date: 2020-09-17 05:02:35 -0700 (Thu, 17 Sep 2020)
New Revision: 9735
   trunk/MgDev/Oem/CsMapLibrary/CMakeLists.txt
#2819: Fix CS-Map build. We still need to copy data files to staging area for post-build to work properly
Modified: trunk/MgDev/Oem/CsMapLibrary/CMakeLists.txt
--- trunk/MgDev/Oem/CsMapLibrary/CMakeLists.txt	2020-09-17 11:54:54 UTC (rev 9734)
+++ trunk/MgDev/Oem/CsMapLibrary/CMakeLists.txt	2020-09-17 12:02:35 UTC (rev 9735)
@@ -170,40 +170,41 @@
     COMMENT "Compile dictionaries"
+file(COPY ${CSMAP_DICT_SRC_DIR} DESTINATION ${CSMAP_DICT_STAGING_DIR})
+# Remove junk we know to not be related to dictionary data
+if (CSMAP_NO_GRID)
+    file(GLOB_RECURSE CSMAP_JUNK_FILES
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.c"
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.cnt"
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.HLP"
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.mak"
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.nmk"
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/WW15MGH.GRD"
+        # FIXME: Though this removes the files it still leaves the empty directories
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Australia/Gda94/*.*"
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Usa/Geoid03/*.*"
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Usa/Geoid96/*.*"
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Usa/Geoid99/*.*"
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Usa/NSRS2007/*.*"
+        "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Usa/NSRS2011/*.*"
+else (CSMAP_NO_GRID)
+endif (CSMAP_NO_GRID)
+#message(STATUS "Removing CS-Map junk: ${CSMAP_JUNK_FILES}")
+file(REMOVE ${CSMAP_JUNK_FILES})
+file(GLOB CS_MAP_ROOT_FILES "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.*")
 # Only install data files if not building for the common subset profile
 if (NOT MG_COMMON_SUBSET_ONLY)
-    file(COPY ${CSMAP_DICT_SRC_DIR} DESTINATION ${CSMAP_DICT_STAGING_DIR})
-    # Remove junk we know to not be related to dictionary data
-    if (CSMAP_NO_GRID)
-        file(GLOB_RECURSE CSMAP_JUNK_FILES
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.c"
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.cnt"
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.HLP"
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.mak"
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.nmk"
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/WW15MGH.GRD"
-            # FIXME: Though this removes the files it still leaves the empty directories
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Australia/Gda94/*.*"
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Usa/Geoid03/*.*"
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Usa/Geoid96/*.*"
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Usa/Geoid99/*.*"
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Usa/NSRS2007/*.*"
-            "${CSMAP_DICT_STAGING_DIR}/Dictionaries/Usa/NSRS2011/*.*"
-    else (CSMAP_NO_GRID)
-    endif (CSMAP_NO_GRID)
-    #message(STATUS "Removing CS-Map junk: ${CSMAP_JUNK_FILES}")
-    file(REMOVE ${CSMAP_JUNK_FILES})
-    file(GLOB CS_MAP_ROOT_FILES "${CSMAP_DICT_STAGING_DIR}/Dictionaries/*.*")
     #message(STATUS "CS-Map root files: ${CS_MAP_ROOT_FILES}")
     install(FILES ${CS_MAP_ROOT_FILES} DESTINATION ${MG_INSTALL_COORDSYS_PREFIX} COMPONENT ${MG_COMPONENT_COMMON})
     # NOTE: These .csd files below are generated as a post-build so they aren't caught by the initial GLOB above
More information about the mapguide-commits mailing list
