[mapguide-commits] r9836 - in trunk/MgDev: Common/MapGuideCommon/System Server/src/Core Server/src/Services/Mapping cmake/configs
svn_mapguide at osgeo.org
Mon Apr 12 06:04:00 PDT 2021
Author: jng
Date: 2021-04-12 06:04:00 -0700 (Mon, 12 Apr 2021)
New Revision: 9836
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
trunk/MgDev/Server/src/Core/serverconfig.ini
trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
trunk/MgDev/cmake/configs/serverconfig.ini.in
Make the global raster stylization lock toggle-able through a serverconfig.ini setting (GlobalRasterStylizationLockEnabled). The default value for this setting is still true, so the global lock is still in effect.
Fixes #2830
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2021-04-12 12:20:00 UTC (rev 9835)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2021-04-12 13:04:00 UTC (rev 9836)
@@ -322,6 +322,8 @@
const INT32 MgConfigProperties::DefaultRenderingServicePropertyMaxRenderImageWidth = 16384;
const STRING MgConfigProperties::RenderingServicePropertyMaxRenderImageHeight = L"MaxRenderImageHeight";
const INT32 MgConfigProperties::DefaultRenderingServicePropertyMaxRenderImageHeight = 16384;
+const STRING MgConfigProperties::RenderingServicePropertiesGlobalRasterStylizationLockEnabled = L"GlobalRasterStylizationLockEnabled";
+const bool MgConfigProperties::DefaultRenderingServicePropertiesGlobalRasterStylizationLockEnabled = true;
// Font Alias Mappings section
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2021-04-12 12:20:00 UTC (rev 9835)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2021-04-12 13:04:00 UTC (rev 9836)
@@ -425,6 +425,10 @@
static const STRING RenderingServicePropertyMaxRenderImageHeight; /// value("MaxRenderImageHeight")
static const INT32 DefaultRenderingServicePropertyMaxRenderImageHeight; /// value(16384)
+ /// Sets the global raster stylization lock option
+ static const STRING RenderingServicePropertiesGlobalRasterStylizationLockEnabled; /// value("GlobalRasterStylizationLockEnabled")
+ static const bool DefaultRenderingServicePropertiesGlobalRasterStylizationLockEnabled; /// value(true)
/// FONT ALIASES SECTION -----------------------------------------------------------------------------
/// font alias mappings
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2021-04-12 12:20:00 UTC (rev 9835)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2021-04-12 13:04:00 UTC (rev 9836)
@@ -361,6 +361,8 @@
# 0 < Value <= 2147483647
# MaxRenderImageHeight The minimum allowed width for a map image rendering operation
+# GlobalRasterStylizationLockEnabled Enable/disable the use of a global lock for raster stylization
+# 0 = false and 1 = true
TileExtentOffset = 0.35
RasterGridSize = 100
@@ -376,6 +378,7 @@
MaxRasterImageHeight = 2048
+GlobalRasterStylizationLockEnabled = 1
[ResourceServiceProperties]
Modified: trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2021-04-12 12:20:00 UTC (rev 9835)
+++ trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2021-04-12 13:04:00 UTC (rev 9836)
@@ -377,6 +377,14 @@
ACE_DEBUG((LM_INFO, L"(%t)StylizeLayers() **MAPSTART** Layers:%d Scale:%f\n", layers->GetCount(), scale));
#endif
+ // Check if we want to use global raster stylization lock from config
+ MgConfiguration* pConf = MgConfiguration::GetInstance();
+ bool bUseGlobalLock = true;
+ pConf->GetBoolValue(MgConfigProperties::RenderingServicePropertiesSection,
+ MgConfigProperties::RenderingServicePropertiesGlobalRasterStylizationLockEnabled,
+ bUseGlobalLock,
+ MgConfigProperties::DefaultRenderingServicePropertiesGlobalRasterStylizationLockEnabled);
// Cache coordinate system transforms for the life of the
// stylization operation.
TransformCacheMap transformCache;
@@ -641,10 +649,15 @@
//get a transform from layer coord sys to map coord sys
TransformCache* item = NULL;
+ if (bUseGlobalLock)
ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, sg_fdoRfpMutex));
item = TransformCache::GetLayerToMapTransform(transformCache, gl->GetFeatureName(), featResId, dstCs, csFactory, svcFeature, true);
+ else
+ item = TransformCache::GetLayerToMapTransform(transformCache, gl->GetFeatureName(), featResId, dstCs, csFactory, svcFeature, true);
TCForProfile = item;
Ptr<MgCoordinateSystem> layerCs = item? item->GetCoordSys() : NULL;
@@ -739,11 +752,17 @@
//perform the raster query
FdoPtr<FdoIFeatureReader> fdoReader;
rsReader = ExecuteRasterQuery(svcFeature, extent, gl, overrideFilter.c_str(), dstCs, layerCs, width, height);
fdoReader = (NULL == rsReader) ? NULL : rsReader->GetInternalReader();
+ else
+ rsReader = ExecuteRasterQuery(svcFeature, extent, gl, overrideFilter.c_str(), dstCs, layerCs, width, height);
+ fdoReader = (NULL == rsReader) ? NULL : rsReader->GetInternalReader();
if (NULL != fdoReader.p)
@@ -1226,7 +1245,7 @@
// draw the preview
StylizationUtil::DrawStylePreview(imgWidth, imgHeight, themeCategory, fts, &er, &se_sman);
- auto_ptr<RS_ByteData> data;
+ unique_ptr<RS_ByteData> data;
data.reset(er.Save(format, imgWidth, imgHeight));
if (NULL != data.get())
Modified: trunk/MgDev/cmake/configs/serverconfig.ini.in
--- trunk/MgDev/cmake/configs/serverconfig.ini.in 2021-04-12 12:20:00 UTC (rev 9835)
+++ trunk/MgDev/cmake/configs/serverconfig.ini.in 2021-04-12 13:04:00 UTC (rev 9836)
@@ -363,6 +363,8 @@
@@ -378,6 +380,7 @@
More information about the mapguide-commits
