[mapguide-commits] r9865 - in sandbox/adsk/trunk/Oem/ACE/ACE_wrappers: . ASNMP ASNMP/agent ASNMP/asnmp ASNMP/examples ASNMP/examples/get ASNMP/examples/next ASNMP/examples/set ASNMP/examples/trap ASNMP/examples/walk ASNMP/tests ace ace/Compression ace/Compression/rle ace/ETCL ace/FlReactor ace/FoxReactor ace/Monitor_Control ace/QoS ace/QtReactor ace/SSL ace/TkReactor ace/XML_Utils ace/XML_Utils/XMLSchema ace/XML_Utils/XSCRT ace/XtReactor ace/os_include ace/os_include/sys bin bin/DependencyGenerator bin/MakeProjectCreator/config bin/MakeProjectCreator/templates bin/PerlACE etc include/makeinclude
svn_mapguide at osgeo.org
Sun Aug 15 23:26:32 PDT 2021
Author: christinebao
Date: 2021-08-15 23:26:30 -0700 (Sun, 15 Aug 2021)
New Revision: 9865
Added:
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/asnmp_example_set_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/asnmp_example_set_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/set_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/asnmp_example_trap_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/asnmp_example_trap_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/trap_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/asnmp_example_walk_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/asnmp_example_walk_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/walk_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Address_Test_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Address_Test_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter64_Test_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter64_Test_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter_Test_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter_Test_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Gauge_Test_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Gauge_Test_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Integer_Test_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Integer_Test_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Octet_Test_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Octet_Test_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Oid_Test_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Oid_Test_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Target_Test_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Target_Test_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Varbind_Test_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Varbind_Test_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/tests_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ACE_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ACE_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/ACE_Compression_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/ACE_Compression_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/Compression_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/ACE_RLECompression_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/ACE_RLECompression_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/rle_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_Parser_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_Parser_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ETCL_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/Monitor_Control_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/Monitor_Control_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/Monitor_Control_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ace_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-macosx-yosemite.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-win32-msvc-11.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-win32-msvc-12.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-win32-msvc-14.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/vc14nmake.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/PerlACE_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/PerlACE_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/PerlACE_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/bin_vc12.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/bin_vc12.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/bin_vc12.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_macosx_yosemite.GNU
Removed:
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/asnmp_example_set_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/asnmp_example_set_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/set_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/asnmp_example_trap_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/asnmp_example_trap_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/trap_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/asnmp_example_walk_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/asnmp_example_walk_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/walk_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Address_Test_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Address_Test_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter64_Test_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter64_Test_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter_Test_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter_Test_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Gauge_Test_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Gauge_Test_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Integer_Test_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Integer_Test_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Octet_Test_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Octet_Test_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Oid_Test_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Oid_Test_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Target_Test_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Target_Test_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Varbind_Test_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Varbind_Test_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/tests_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ACE_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ACE_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/ACE_Compression_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/ACE_Compression_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/Compression_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/ACE_RLECompression_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/ACE_RLECompression_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/rle_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_Parser_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_Parser_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ETCL_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/Monitor_Control_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/Monitor_Control_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/Monitor_Control_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/QoS/QoS_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/QoS/QoS_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/QoS/QoS_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ace_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/PerlACE_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/PerlACE_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/PerlACE_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/bin_vc10.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/bin_vc10.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/bin_vc10.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE-INSTALL.html
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE.mwc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/GNUmakefile.asnmp_agent
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/GNUmakefile.asnmp_lib
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asn1.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile.asnmp_example_get
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile.asnmp_example_get_async
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/GNUmakefile.asnmp_example_next
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/GNUmakefile.asnmp_example_set
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/asnmp_example_set_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/asnmp_example_set_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/set_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/GNUmakefile.asnmp_example_trap
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/asnmp_example_trap_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/asnmp_example_trap_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/trap/trap_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/GNUmakefile.asnmp_example_walk
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/asnmp_example_walk_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/asnmp_example_walk_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/walk/walk_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/GNUmakefile.asnmp_tests_Address_Test
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/GNUmakefile.asnmp_tests_Counter64_Test
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/GNUmakefile.asnmp_tests_Counter_Test
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/GNUmakefile.asnmp_tests_Gauge_Test
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/GNUmakefile.asnmp_tests_Integer_Test
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/GNUmakefile.asnmp_tests_Octet_Test
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/GNUmakefile.asnmp_tests_Oid_Test
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/GNUmakefile.asnmp_tests_Target_Test
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/GNUmakefile.asnmp_tests_Varbind_Test
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Address_Test_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Address_Test_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter64_Test_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter64_Test_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter_Test_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Counter_Test_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Gauge_Test_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Gauge_Test_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Integer_Test_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Integer_Test_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Octet_Test_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Octet_Test_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Oid_Test_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Oid_Test_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Target_Test_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Target_Test_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Varbind_Test_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/asnmp_tests_Varbind_Test_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/tests/tests_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ChangeLog
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/NEWS
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/PROBLEM-REPORT-FORM
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/THANKS
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/VERSION
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ACE_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ACE_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Abstract_Timer_Queue.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Abstract_Timer_Queue.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Auto_IncDec_T.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/CDR_Base.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/CDR_Base.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/CDR_Base.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Caching_Strategies_T.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/ACE_Compression.mpc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/ACE_Compression_export.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/ACE_Compression_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/ACE_Compression_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/Compression_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/Compressor.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/Compressor.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/Compressor.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/GNUmakefile.ACE_Compression
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/ACE_RLECompression.mpc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/ACE_RLECompression_export.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/ACE_RLECompression_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/ACE_RLECompression_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/GNUmakefile.ACE_RLECompression
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/RLECompressor.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/RLECompressor.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Compression/rle/rle_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Condition_Attributes.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Condition_Attributes.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Condition_Attributes.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Configuration.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Connector.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Countdown_Time_T.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Countdown_Time_T.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Countdown_Time_T.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/DLL.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/DLL.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/DLL_Manager.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/DLL_Manager.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Dev_Poll_Reactor.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_Parser_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_Parser_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ACE_ETCL_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ETCL_l.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ETCL_l.cpp.diff
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ETCL_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ETCL_y.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/ETCL_y.cpp.diff
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/GNUmakefile.ACE_ETCL
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ETCL/GNUmakefile.ACE_ETCL_Parser
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Event_Base.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Event_Base.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Event_Base.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Event_Handler.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Event_Handler.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Event_Handler_Handle_Timeout_Upcall.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Event_Handler_Handle_Timeout_Upcall.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Event_Handler_Handle_Timeout_Upcall.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/FlReactor/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/FlReactor/GNUmakefile.ACE_FlReactor
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/FlReactor/ace_flreactor.mpc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/FoxReactor/ace_foxreactor.mpc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/GNUmakefile.ACE
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Get_Opt.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Global_Macros.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Guard_T.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Handle_Set.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Log_Category.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Log_Category.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Log_Category.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/MMAP_Memory_Pool.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/GNUmakefile.Monitor_Control
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/Monitor_Control_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/Monitor_Control_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monitor_Control/Monitor_Control_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monotonic_Time_Policy.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monotonic_Time_Policy.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Monotonic_Time_Policy.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/OS_Log_Msg_Attributes.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/OS_NS_stdio.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/OS_NS_stdlib.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/OS_NS_string.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/OS_NS_time.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Obstack.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Process.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/QoS/QoS_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/QoS/QoS_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/QoS/QoS_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/QtReactor/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/QtReactor/GNUmakefile.ACE_Qt4Reactor
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/QtReactor/GNUmakefile.ACE_Qt4Reactor_moc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/QtReactor/ace_qt4reactor.mpc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Reactor.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/SOCK_Dgram_Bcast.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/SSL/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/SSL/GNUmakefile.SSL
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/SSL/SSL_Initializer.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/SSL/SSL_Initializer.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Select_Reactor_Base.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Select_Reactor_T.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Service_Gestalt.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Sock_Connect.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Thread_Manager.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Time_Policy.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Time_Policy.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Time_Policy.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Time_Policy_T.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Time_Policy_T.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Time_Policy_T.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Time_Value.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Time_Value_T.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Time_Value_T.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Time_Value_T.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Timer_Queue_Iterator.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Timer_Queue_Iterator.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Timer_Queue_Iterator.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Timer_Wheel_T.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/TkReactor/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/TkReactor/GNUmakefile.ACE_TkReactor
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/TkReactor/ace_tkreactor.mpc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/Version.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/WFMO_Reactor.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/WFMO_Reactor.inl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/ACE_XML_Utils.pc.in
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML.mpc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XMLSchema/Traversal.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XMLSchema/Traversal.ipp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XMLSchema/TypeInfo.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XMLSchema/TypeInfo.ipp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XMLSchema/TypeInfo.tpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XMLSchema/Types.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XMLSchema/Types.ipp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XMLSchema/Writer.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XMLSchema/Writer.ipp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XMLSchema/id_map.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML_Error_Handler.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML_Error_Handler.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML_Helper.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML_Helper.tpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML_Schema_Resolver.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML_Schema_Resolver.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML_Schema_Resolver.tpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML_Typedefs.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML_Typedefs.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XML_Utils_Export.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XSCRT/Elements.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XSCRT/ExtendedTypeInfo.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XSCRT/ExtendedTypeInfo.ipp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XSCRT/Parser.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XSCRT/Traversal.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XSCRT/Traversal.tpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XSCRT/Writer.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XSCRT/XML.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XSCRT/XMLSchema.hpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XercesString.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XML_Utils/XercesString.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XtReactor/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XtReactor/GNUmakefile.ACE_XtReactor
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/XtReactor/ace_xtreactor.mpc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ace.mpc
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/ace_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-aix-7.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-android.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-g++-common.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-kfreebsd.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-macosx-iOS-hardware.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-macosx-iOS-simulator.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-macosx-leopard.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-macosx-lion.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-macosx-mavericks.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-macosx-mountainlion.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-qnx.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-vxworks6.9.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-win32-mingw64.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-win32-msvc.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/config-windows.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_assert.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_byteswap.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_complex.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_cpio.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_fenv.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_float.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_fmtmsg.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_fnmatch.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_ftw.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_glob.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_grp.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_iconv.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_ifaddrs.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_inttypes.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_iso646.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_kstat.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_langinfo.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_libgen.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_local.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_math.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_monetary.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_mqueue.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_ndbm.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_nl_types.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_pdh.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_pdhmsg.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_poll.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_pwd.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_regex.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_search.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_setjmp.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_spawn.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_stdarg.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_stdbool.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_string.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_stropts.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_syslog.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_tar.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_termios.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_tgmath.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_trace.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_typeinfo.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_ulimit.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_utime.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_utmpx.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_wchar.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_wctype.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/os_wordexp.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/sys/os_loadavg.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/sys/os_pstat.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/sys/os_statvfs.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/sys/os_sysctl.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/sys/os_sysinfo.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/sys/os_timeb.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/sys/os_times.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ace/os_include/sys/os_utsname.h
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/ACE+TAO+CIAO+DAnCE.json
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/DependencyGenerator/GNUIDLDependencyWriter.pm
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/DependencyGenerator/GNUIDLObjectGenerator.pm
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/GNUmakefile.bin
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/ace_compressionlib.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/ace_idl_dependencies.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/ace_rlecompressionlib.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/ace_xml_utils.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/acelib.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/acemfcexe.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/inetssl.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/vc10nmake.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/vc11.features
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/vc11nmake.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/config/vc12nmake.mpb
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/MakeProjectCreator/templates/gnu.mpd
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/GNUmakefile
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/GNUmakefile.PerlACE
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/PerlACE_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/PerlACE_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/PerlACE_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/ProcessAndroid.pm
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/Process_Unix.pm
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/TestTarget.pm
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/PerlACE/TestTarget_Android.pm
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/ace_install_pkgconfig.pl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/bin_vc11.sln
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/bin_vc11.vcxproj
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/bin_vc11.vcxproj.filters
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/cleanbuilds.sh
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/coverity_model.cpp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/diff-builds-and-group-fixed-tests-only.sh
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/fuzz.pl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/generate_doxygen.pl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/generate_export_file.pl
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/inspxe-cl.sup
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/make_release.py
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/bin/valgrind.supp
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/etc/ace_inet.doxygen
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/etc/index.html
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_aix_ibm.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_android.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_clang_common.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_g++_common.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux_clang.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux_common.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_macosx_iOS.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_macosx_lion.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_macosx_mavericks.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_macosx_mountainlion.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_qnx_gcc.GNU
sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/include/makeinclude/platform_vxworks6.9.GNU
Update ACE to 6.2.8.
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE-INSTALL.html
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE-INSTALL.html 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE-INSTALL.html 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,5 +1,5 @@
-http://www.dre.vanderbilt.edu/~schmidt/PDF/Svc-Conf.pdf<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html><head><!-- $Id: ACE-INSTALL.html 97719 2014-04-15 08:58:11Z johnnyw $ -->
+<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html><head><!-- $Id: ACE-INSTALL.html 97736 2014-04-29 15:07:10Z johnnyw $ -->
<meta content="text/html; charset=ISO-8859-1" http-equiv="content-type"><title>Building and Installing ACE and Its Auxiliary Libraries and Services</title>
<link rev="made" href="mailto:d.schmidt at vanderbilt.edu"></head>
@@ -2989,7 +2989,7 @@
<EM><br> -->
<!-- hhmts start -->
-Last modified: Wed Jul 5 17:26:22 EST 2006
+$Id: ACE-INSTALL.html 97736 2014-04-29 15:07:10Z johnnyw $
<!-- hhmts end -->
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE.mwc
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE.mwc 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE.mwc 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,32 +1,32 @@
-// $Id: ACE.mwc 86476 2009-08-13 03:27:23Z elliott_c $
-workspace {
- exclude(automake) {
- build
- exclude {
- TAO
- // The associate scope does not add directories to the workspace;
- // it only associates a name with one or more directories.
- associate(examples) {
- examples
- associate(tests) {
- performance-tests
- tests
- associate(gperf) {
- gperf
- // The '--' is a special key that indicates that the associated
- // projects should be of the form @NAME@ in the generated Makefile.am.
- associate(--) {
- ACEXML
- ASNMP
- protocols
- KOKYU
- TAO
+// $Id: ACE.mwc 86476 2009-08-13 03:27:23Z elliott_c $
+workspace {
+ exclude(automake) {
+ build
+ exclude {
+ TAO
+ // The associate scope does not add directories to the workspace;
+ // it only associates a name with one or more directories.
+ associate(examples) {
+ examples
+ associate(tests) {
+ performance-tests
+ tests
+ associate(gperf) {
+ gperf
+ // The '--' is a special key that indicates that the associated
+ // projects should be of the form @NAME@ in the generated Makefile.am.
+ associate(--) {
+ ACEXML
+ ASNMP
+ protocols
+ KOKYU
+ TAO
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc10.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc10.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc10.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,9664 +0,0 @@
-Microsoft Visual Studio Solution File, Format Version 11.00
-# Visual Studio 2010
-# $Id: VC10WorkspaceCreator.pm 2035 2011-10-06 15:05:21Z johnnyw $
-# This file was generated by MPC. Any changes made directly to
-# this file will be lost the next time it is generated.
-# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type vc10 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE -workers 16 -name_modifier "*_vc10"
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML_XML_Svc_Conf_Parser", "ACEXML\apps\svcconf\ACEXML_XML_Svc_Conf_Parser_vc10.vcxproj", "{97A5797D-FECA-1BAD-5984-FE664DEC7B87}"
- ProjectSection(ProjectDependencies) = postProject
- {47BC56ED-FECA-1BAD-6757-8A6300006755} = {47BC56ED-FECA-1BAD-6757-8A6300006755}
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C} = {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57} = {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML", "ACEXML\common\ACEXML_vc10.vcxproj", "{D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SAXPrint", "ACEXML\examples\SAXPrint\SAXPrint_vc10.vcxproj", "{E9FB1B9D-FECA-1BAD-4F93-FEB4C47D7318}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML_Parser", "ACEXML\parser\parser\ACEXML_Parser_vc10.vcxproj", "{4E55F4DB-FECA-1BAD-5520-8D0596E4677C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ContentHandler_Test", "ACEXML\tests\ContentHandler_Test_vc10.vcxproj", "{15144841-FECA-1BAD-2431-8A119E86733F}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HttpCharStream_Test", "ACEXML\tests\HttpCharStream_Test_vc10.vcxproj", "{84DB7028-FECA-1BAD-2431-8A119E86733F}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "NamespaceSupport_Test", "ACEXML\tests\NamespaceSupport_Test_vc10.vcxproj", "{A18276C8-FECA-1BAD-2431-8A119E86733F}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Transcoder_Test", "ACEXML\tests\Transcoder_Test_vc10.vcxproj", "{613B4532-FECA-1BAD-2431-8A119E86733F}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "util", "ACEXML\tests\util\util_vc10.vcxproj", "{3F2C569B-FECA-1BAD-22FE-8A6433D1CA9B}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_agent", "ASNMP\agent\asnmp_agent_vc10.vcxproj", "{4C260F9E-FECA-1BAD-1396-8A04829757EE}"
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA} = {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_lib", "ASNMP\asnmp\asnmp_lib_vc10.vcxproj", "{B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get_async", "ASNMP\examples\get\asnmp_example_get_async_vc10.vcxproj", "{B8E6506D-FECA-1BAD-6126-8A63C208BB19}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get", "ASNMP\examples\get\asnmp_example_get_vc10.vcxproj", "{2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_next", "ASNMP\examples\next\asnmp_example_next_vc10.vcxproj", "{BE5253E3-FECA-1BAD-82F6-8A65208B2128}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_set", "ASNMP\examples\set\asnmp_example_set_vc10.vcxproj", "{6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_trap", "ASNMP\examples\trap\asnmp_example_trap_vc10.vcxproj", "{D71253F8-FECA-1BAD-3462-8A64208A97BC}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_walk", "ASNMP\examples\walk\asnmp_example_walk_vc10.vcxproj", "{EBA253FA-FECA-1BAD-17A9-8A64208AB477}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Address_Test", "ASNMP\tests\asnmp_tests_Address_Test_vc10.vcxproj", "{95AC7E59-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Counter64_Test", "ASNMP\tests\asnmp_tests_Counter64_Test_vc10.vcxproj", "{E4E3174A-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Counter_Test", "ASNMP\tests\asnmp_tests_Counter_Test_vc10.vcxproj", "{357C1F5B-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Gauge_Test", "ASNMP\tests\asnmp_tests_Gauge_Test_vc10.vcxproj", "{204D0425-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Integer_Test", "ASNMP\tests\asnmp_tests_Integer_Test_vc10.vcxproj", "{24DF1F51-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Octet_Test", "ASNMP\tests\asnmp_tests_Octet_Test_vc10.vcxproj", "{286C3525-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Oid_Test", "ASNMP\tests\asnmp_tests_Oid_Test_vc10.vcxproj", "{5AB02509-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Target_Test", "ASNMP\tests\asnmp_tests_Target_Test_vc10.vcxproj", "{4AC951AB-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Varbind_Test", "ASNMP\tests\asnmp_tests_Varbind_Test_vc10.vcxproj", "{D2A1B94E-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Kokyu", "Kokyu\Kokyu_vc10.vcxproj", "{DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DSRT_MIF", "Kokyu\tests\DSRT_MIF\DSRT_MIF_vc10.vcxproj", "{8DCD31F2-FECA-1BAD-B9D0-9C126E572303}"
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5} = {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "EDF", "Kokyu\tests\EDF\EDF_vc10.vcxproj", "{008C56ED-FECA-1BAD-4104-8A6369AD5684}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FIFO", "Kokyu\tests\FIFO\FIFO_vc10.vcxproj", "{C21C56AB-FECA-1BAD-2D2D-8A679AD55509}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE", "ace\ACE_vc10.vcxproj", "{47BC56ED-FECA-1BAD-6757-8A6300006755}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_Compression", "ace\Compression\ACE_Compression_vc10.vcxproj", "{B0AF43A7-FECA-1BAD-EA06-BB371373EA04}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_RLECompression", "ace\Compression\rle\ACE_RLECompression_vc10.vcxproj", "{F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}"
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04} = {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_ETCL_Parser", "ace\ETCL\ACE_ETCL_Parser_vc10.vcxproj", "{42B1A787-FECA-1BAD-007E-8A67757B007A}"
- {17692659-FECA-1BAD-007E-8A67757B007A} = {17692659-FECA-1BAD-007E-8A67757B007A}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_ETCL", "ace\ETCL\ACE_ETCL_vc10.vcxproj", "{17692659-FECA-1BAD-007E-8A67757B007A}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Monitor_Control", "ace\Monitor_Control\Monitor_Control_vc10.vcxproj", "{7153B6F4-FECA-1BAD-D619-74620E01B14C}"
- {42B1A787-FECA-1BAD-007E-8A67757B007A} = {42B1A787-FECA-1BAD-007E-8A67757B007A}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "QoS", "ace\QoS\QoS_vc10.vcxproj", "{6ADC56EC-FECA-1BAD-7781-8A636757A7A3}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Gateway", "apps\Gateway\Gateway\Gateway_vc10.vcxproj", "{067840CB-FECA-1BAD-216B-EB0100066773}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "gatewayd", "apps\Gateway\Gateway\gatewayd_vc10.vcxproj", "{7FCD34C8-FECA-1BAD-216B-EB0100066773}"
- {067840CB-FECA-1BAD-216B-EB0100066773} = {067840CB-FECA-1BAD-216B-EB0100066773}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Gateway_Peer", "apps\Gateway\Peer\Gateway_Peer_vc10.vcxproj", "{40ED3A0E-FECA-1BAD-6320-8A6461A17566}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "gateway_peerd", "apps\Gateway\Peer\gateway_peerd_vc10.vcxproj", "{16BA989C-FECA-1BAD-6320-8A6461A17566}"
- {40ED3A0E-FECA-1BAD-6320-8A6461A17566} = {40ED3A0E-FECA-1BAD-6320-8A6461A17566}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "blobby", "apps\JAWS\clients\Blobby\blobby_vc10.vcxproj", "{557C3240-FECA-1BAD-945B-8C296561D98E}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "http_client", "apps\JAWS\clients\Caching\http_client_vc10.vcxproj", "{DA99C340-FECA-1BAD-EF85-EF1657C132F1}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JAWS_server", "apps\JAWS\server\JAWS_server_vc10.vcxproj", "{F6EAD3C8-FECA-1BAD-5020-8D317F23EE66}"
- {52DC56A7-FECA-1BAD-5020-8D317F23EE66} = {52DC56A7-FECA-1BAD-5020-8D317F23EE66}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JAWS", "apps\JAWS\server\JAWS_vc10.vcxproj", "{52DC56A7-FECA-1BAD-5020-8D317F23EE66}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HTTPU", "apps\JAWS2\HTTPU\HTTPU_vc10.vcxproj", "{05BC5238-FECA-1BAD-3377-8A0C67CCAF11}"
- {30CC520D-FECA-1BAD-6000-8A0F467CFFC7} = {30CC520D-FECA-1BAD-6000-8A0F467CFFC7}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JAWS2", "apps\JAWS2\JAWS\JAWS2_vc10.vcxproj", "{30CC520D-FECA-1BAD-6000-8A0F467CFFC7}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JAWS3_server", "apps\JAWS3\jaws3\JAWS3_server_vc10.vcxproj", "{50CAD382-FECA-1BAD-6001-8A0F66EDDE47}"
- {30DC520D-FECA-1BAD-6001-8A0F66EDDE47} = {30DC520D-FECA-1BAD-6001-8A0F66EDDE47}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JAWS3", "apps\JAWS3\jaws3\JAWS3_vc10.vcxproj", "{30DC520D-FECA-1BAD-6001-8A0F66EDDE47}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "gperf_docs", "apps\gperf\gperf_docs_vc10.vcxproj", "{E4BE157B-FECA-1BAD-6223-DAF371906421}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "gperf", "apps\gperf\src\gperf_vc10.vcxproj", "{348C50EF-FECA-1BAD-6244-8A036423F5D3}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "adainset", "apps\gperf\tests\adainset_vc10.vcxproj", "{42CB7110-FECA-1BAD-2431-8A1123F3B457}"
- {348C50EF-FECA-1BAD-6244-8A036423F5D3} = {348C50EF-FECA-1BAD-6244-8A036423F5D3}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "cinset", "apps\gperf\tests\cinset_vc10.vcxproj", "{42AC3310-FECA-1BAD-2431-8A1123F3B457}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "cppinset", "apps\gperf\tests\cppinset_vc10.vcxproj", "{42C82010-FECA-1BAD-2431-8A1123F3B457}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "iinset2", "apps\gperf\tests\iinset2_vc10.vcxproj", "{37CAA97C-FECA-1BAD-2431-8A1123F3B457}"
- {42AC3910-FECA-1BAD-2431-8A1123F3B457} = {42AC3910-FECA-1BAD-2431-8A1123F3B457}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "iinset", "apps\gperf\tests\iinset_vc10.vcxproj", "{42AC3910-FECA-1BAD-2431-8A1123F3B457}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "m3inset", "apps\gperf\tests\m3inset_vc10.vcxproj", "{42AAB310-FECA-1BAD-2431-8A1123F3B457}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "pinset", "apps\gperf\tests\pinset_vc10.vcxproj", "{42AC2010-FECA-1BAD-2431-8A1123F3B457}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "preinset", "apps\gperf\tests\preinset_vc10.vcxproj", "{42DB1510-FECA-1BAD-2431-8A1123F3B457}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "taoinset", "apps\gperf\tests\taoinset_vc10.vcxproj", "{42DE2F10-FECA-1BAD-2431-8A1123F3B457}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "tinset", "apps\gperf\tests\tinset_vc10.vcxproj", "{42AC2410-FECA-1BAD-2431-8A1123F3B457}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "mkcsregdb", "apps\mkcsregdb\mkcsregdb_vc10.vcxproj", "{047112AA-FECA-1BAD-314B-5E27D22340B9}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "soreduce", "apps\soreduce\soreduce_vc10.vcxproj", "{25C9D2DA-FECA-1BAD-3350-D2205825444D}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PerlACE", "bin\PerlACE\PerlACE_vc10.vcxproj", "{47B934A1-FECA-1BAD-A757-FC47A624E189}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "bin", "bin\bin_vc10.vcxproj", "{5F0C56EF-FECA-1BAD-64FC-8A63000064FE}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "AO2", "examples\APG\Active_Objects\AO2_vc10.vcxproj", "{4CCC56ED-FECA-1BAD-1A31-155B449A6390}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "AO", "examples\APG\Active_Objects\AO_vc10.vcxproj", "{551C56E9-FECA-1BAD-1A31-155B449A6390}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ARGV_Example", "examples\APG\Config\ARGV_Example_vc10.vcxproj", "{188778D7-FECA-1BAD-80F5-8C3AFDFBF954}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Config_HA_Status", "examples\APG\Config\Config_HA_Status_vc10.vcxproj", "{095D6AC0-FECA-1BAD-80F5-8C3AFDFBF954}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Get_Opt_Long", "examples\APG\Config\Get_Opt_Long_vc10.vcxproj", "{A9242712-FECA-1BAD-80F5-8C3AFDFBF954}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Get_Opt", "examples\APG\Config\Get_Opt_vc10.vcxproj", "{97A844F2-FECA-1BAD-80F5-8C3AFDFBF954}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Allocator", "examples\APG\Containers\Allocator_vc10.vcxproj", "{3CB6FFBF-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Array", "examples\APG\Containers\Array_vc10.vcxproj", "{567C528C-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Containers_Hash_Map", "examples\APG\Containers\Containers_Hash_Map_vc10.vcxproj", "{A9C04CB4-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Containers_Map_Manager", "examples\APG\Containers\Containers_Map_Manager_vc10.vcxproj", "{936F819C-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLList", "examples\APG\Containers\DLList_vc10.vcxproj", "{F4AC1663-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Hash_Map_Hash", "examples\APG\Containers\Hash_Map_Hash_vc10.vcxproj", "{28D737B1-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Map_Manager_Specialization", "examples\APG\Containers\Map_Manager_Specialization_vc10.vcxproj", "{8C34A590-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Queues", "examples\APG\Containers\Queues_vc10.vcxproj", "{22DC00DB-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RB_Tree_Functors", "examples\APG\Containers\RB_Tree_Functors_vc10.vcxproj", "{A53B149F-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RB_Tree", "examples\APG\Containers\RB_Tree_vc10.vcxproj", "{53B9314A-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sets", "examples\APG\Containers\Sets_vc10.vcxproj", "{33DC56BC-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Stacks", "examples\APG\Containers\Stacks_vc10.vcxproj", "{4CDC02CE-FECA-1BAD-8408-181CEBDC7FA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Change_Instance_Default", "examples\APG\Logging\Change_Instance_Default_vc10.vcxproj", "{BE1CBFB0-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Change_Mask", "examples\APG\Logging\Change_Mask_vc10.vcxproj", "{2B244656-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Howto_Syslog", "examples\APG\Logging\Howto_Syslog_vc10.vcxproj", "{39B6F242-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Simple1", "examples\APG\Logging\Simple1_vc10.vcxproj", "{B6F9094F-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Simple2", "examples\APG\Logging\Simple2_vc10.vcxproj", "{B6C9094F-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Trace_Return", "examples\APG\Logging\Trace_Return_vc10.vcxproj", "{735CF299-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Callback2", "examples\APG\Logging\Use_Callback2_vc10.vcxproj", "{439BF98B-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Callback", "examples\APG\Logging\Use_Callback_vc10.vcxproj", "{35E92C1F-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_LogManager", "examples\APG\Logging\Use_LogManager_vc10.vcxproj", "{B85FB33E-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Logger", "examples\APG\Logging\Use_Logger_vc10.vcxproj", "{509CEC78-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Logging_Server", "examples\APG\Logging\Use_Logging_Server_vc10.vcxproj", "{5F1E495D-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Logging_Strategy", "examples\APG\Logging\Use_Logging_Strategy_vc10.vcxproj", "{F262F3C6-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Multiple_Sinks", "examples\APG\Logging\Use_Multiple_Sinks_vc10.vcxproj", "{E0E6E68D-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Ostream", "examples\APG\Logging\Use_Ostream_vc10.vcxproj", "{0237D2D8-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Stderr", "examples\APG\Logging\Use_Stderr_vc10.vcxproj", "{679CF2CB-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Syslog", "examples\APG\Logging\Use_Syslog_vc10.vcxproj", "{EBCCF20C-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Wrap_Macros_Alt", "examples\APG\Logging\Wrap_Macros_Alt_vc10.vcxproj", "{D0DD1AE7-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Wrap_Macros", "examples\APG\Logging\Wrap_Macros_vc10.vcxproj", "{5CB9ED98-FECA-1BAD-1F85-E0F2D0B685B8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UDP_Broadcast", "examples\APG\Misc_IPC\UDP_Broadcast_vc10.vcxproj", "{2FF8C4DD-FECA-1BAD-9E67-34351C2F1FBE}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UDP_Multicast", "examples\APG\Misc_IPC\UDP_Multicast_vc10.vcxproj", "{2F0FE10D-FECA-1BAD-9E67-34351C2F1FBE}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UDP_Unicast", "examples\APG\Misc_IPC\UDP_Unicast_vc10.vcxproj", "{65F66E19-FECA-1BAD-9E67-34351C2F1FBE}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Netlocal_Reader", "examples\APG\Naming\Netlocal_Reader_vc10.vcxproj", "{A7B170F4-FECA-1BAD-BF85-8CE4FD25C624}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Netlocal", "examples\APG\Naming\Netlocal_vc10.vcxproj", "{47647440-FECA-1BAD-BF85-8CE4FD25C624}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Nodelocal_Shared_Reader", "examples\APG\Naming\Nodelocal_Shared_Reader_vc10.vcxproj", "{FFAEE1A3-FECA-1BAD-BF85-8CE4FD25C624}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Nodelocal_Shared", "examples\APG\Naming\Nodelocal_Shared_vc10.vcxproj", "{C69D6135-FECA-1BAD-BF85-8CE4FD25C624}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Nodelocal", "examples\APG\Naming\Nodelocal_vc10.vcxproj", "{43A57540-FECA-1BAD-BF85-8CE4FD25C624}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HA_Proactive_Status", "examples\APG\Proactor\HA_Proactive_Status_vc10.vcxproj", "{C87BBBBF-FECA-1BAD-4287-FEF4D6EEE17E}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Manager_Death", "examples\APG\Processes\Process_Manager_Death_vc10.vcxproj", "{605A4309-FECA-1BAD-4556-C3316EC87AEE}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Manager_Spawn", "examples\APG\Processes\Process_Manager_Spawn_vc10.vcxproj", "{633A426C-FECA-1BAD-4556-C3316EC87AEE}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Mutex", "examples\APG\Processes\Process_Mutex_vc10.vcxproj", "{A748383F-FECA-1BAD-4556-C3316EC87AEE}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Spawn", "examples\APG\Processes\Spawn_vc10.vcxproj", "{710C53AF-FECA-1BAD-4556-C3316EC87AEE}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Client", "examples\APG\Reactor\Client_vc10.vcxproj", "{29AC1346-FECA-1BAD-4280-FE54CE10D8BD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HAStatus_AC", "examples\APG\Reactor\HAStatus_AC_vc10.vcxproj", "{619E35CB-FECA-1BAD-4280-FE54CE10D8BD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HAStatus", "examples\APG\Reactor\HAStatus_vc10.vcxproj", "{229012CF-FECA-1BAD-4280-FE54CE10D8BD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Timers", "examples\APG\Reactor\Reactor_Timers_vc10.vcxproj", "{775BA025-FECA-1BAD-4280-FE54CE10D8BD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reschedule", "examples\APG\Reactor\Reschedule_vc10.vcxproj", "{7E9908DA-FECA-1BAD-4280-FE54CE10D8BD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Schedule_Timers", "examples\APG\Reactor\Schedule_Timers_vc10.vcxproj", "{0679A1F1-FECA-1BAD-4280-FE54CE10D8BD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Cancel", "examples\APG\Reactor\Timer_Cancel_vc10.vcxproj", "{B80BE3C3-FECA-1BAD-4280-FE54CE10D8BD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_State_Data", "examples\APG\Reactor\Timer_State_Data_vc10.vcxproj", "{D6888D7C-FECA-1BAD-4280-FE54CE10D8BD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Malloc", "examples\APG\Shared_Memory\Malloc_vc10.vcxproj", "{B9DC1D93-FECA-1BAD-5E18-93A5247C7980}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mem_Map", "examples\APG\Shared_Memory\Mem_Map_vc10.vcxproj", "{A6E8E562-FECA-1BAD-5E18-93A5247C7980}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PI_Malloc", "examples\APG\Shared_Memory\PI_Malloc_vc10.vcxproj", "{BC90ED93-FECA-1BAD-5E18-93A5247C7980}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Pool_Growth", "examples\APG\Shared_Memory\Pool_Growth_vc10.vcxproj", "{7BF5E6A4-FECA-1BAD-5E18-93A5247C7980}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Memory_Hash_Map", "examples\APG\Shared_Memory\Shared_Memory_Hash_Map_vc10.vcxproj", "{B949D56C-FECA-1BAD-5E18-93A5247C7980}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SigAction", "examples\APG\Signals\SigAction_vc10.vcxproj", "{EC5361AB-FECA-1BAD-87B1-FF92CFD61D8C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SigGuard", "examples\APG\Signals\SigGuard_vc10.vcxproj", "{74F9A5EA-FECA-1BAD-87B1-FF92CFD61D8C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SigHandler", "examples\APG\Signals\SigHandler_vc10.vcxproj", "{E73FB16B-FECA-1BAD-87B1-FF92CFD61D8C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SigHandlers", "examples\APG\Signals\SigHandlers_vc10.vcxproj", "{6AE22EC6-FECA-1BAD-87B1-FF92CFD61D8C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SigInfo", "examples\APG\Signals\SigInfo_vc10.vcxproj", "{901909D6-FECA-1BAD-87B1-FF92CFD61D8C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sockets_Basic_Robust", "examples\APG\Sockets\Sockets_Basic_Robust_vc10.vcxproj", "{C488C49D-FECA-1BAD-D231-FFF6CFB2480C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sockets_Basic", "examples\APG\Sockets\Sockets_Basic_vc10.vcxproj", "{12FF38F6-FECA-1BAD-D231-FFF6CFB2480C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sockets_Iovec", "examples\APG\Sockets\Sockets_Iovec_vc10.vcxproj", "{4EFF3848-FECA-1BAD-D231-FFF6CFB2480C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sockets_Server", "examples\APG\Sockets\Sockets_Server_vc10.vcxproj", "{C0FAA659-FECA-1BAD-D231-FFF6CFB2480C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Answerer", "examples\APG\Streams\Answerer_vc10.vcxproj", "{528BC2FB-FECA-1BAD-37A1-FE57CE13AD9C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HA_Configurable_Server_Dynamic", "examples\APG\Svc_Config\HA_Configurable_Server_Dynamic_vc10.vcxproj", "{80877024-FECA-1BAD-87B5-E33A12FA7C15}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HA_Configurable_Server_Static", "examples\APG\Svc_Config\HA_Configurable_Server_Static_vc10.vcxproj", "{9D29F35B-FECA-1BAD-87B5-E33A12FA7C15}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Config_HA_Status", "examples\APG\Svc_Config\Svc_Config_HA_Status_vc10.vcxproj", "{0FAD6A94-FECA-1BAD-87B5-E33A12FA7C15}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Async_Cancel", "examples\APG\ThreadManagement\Async_Cancel_vc10.vcxproj", "{0CAAE3D7-FECA-1BAD-B689-C9110A2960DF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Coop_Cancel", "examples\APG\ThreadManagement\Coop_Cancel_vc10.vcxproj", "{1AA9E395-FECA-1BAD-B689-C9110A2960DF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ExitHandler", "examples\APG\ThreadManagement\ExitHandler_vc10.vcxproj", "{9C2CB16F-FECA-1BAD-B689-C9110A2960DF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Pool", "examples\APG\ThreadManagement\Pool_vc10.vcxproj", "{892C56BF-FECA-1BAD-B689-C9110A2960DF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Priorities", "examples\APG\ThreadManagement\Priorities_vc10.vcxproj", "{B593D20B-FECA-1BAD-B689-C9110A2960DF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Signals2", "examples\APG\ThreadManagement\Signals2_vc10.vcxproj", "{A099A76E-FECA-1BAD-B689-C9110A2960DF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Signals", "examples\APG\ThreadManagement\Signals_vc10.vcxproj", "{6BD909F1-FECA-1BAD-B689-C9110A2960DF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Start_Hook", "examples\APG\ThreadManagement\Start_Hook_vc10.vcxproj", "{DD7A0757-FECA-1BAD-B689-C9110A2960DF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "State", "examples\APG\ThreadManagement\State_vc10.vcxproj", "{72BC53AB-FECA-1BAD-B689-C9110A2960DF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Futures", "examples\APG\ThreadPools\Futures_vc10.vcxproj", "{52D844DB-FECA-1BAD-EB45-BD55AD295160}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "LF_ThreadPool", "examples\APG\ThreadPools\LF_ThreadPool_vc10.vcxproj", "{2BD8657C-FECA-1BAD-EB45-BD55AD295160}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TP_Reactor", "examples\APG\ThreadPools\TP_Reactor_vc10.vcxproj", "{6996159D-FECA-1BAD-EB45-BD55AD295160}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Task_ThreadPool", "examples\APG\ThreadPools\Task_ThreadPool_vc10.vcxproj", "{2BDD47A1-FECA-1BAD-EB45-BD55AD295160}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ThreadPool", "examples\APG\ThreadPools\ThreadPool_vc10.vcxproj", "{DBD861FF-FECA-1BAD-EB45-BD55AD295160}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Atomic_Op", "examples\APG\ThreadSafety\Atomic_Op_vc10.vcxproj", "{AC8ECD1F-FECA-1BAD-2D78-F933D2AB8F03}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Barrier", "examples\APG\ThreadSafety\Barrier_vc10.vcxproj", "{E2C810BD-FECA-1BAD-2D78-F933D2AB8F03}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mutex", "examples\APG\ThreadSafety\Mutex_vc10.vcxproj", "{326C524B-FECA-1BAD-2D78-F933D2AB8F03}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RW_Lock", "examples\APG\ThreadSafety\RW_Lock_vc10.vcxproj", "{85592453-FECA-1BAD-2D78-F933D2AB8F03}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Semaphore", "examples\APG\ThreadSafety\Semaphore_vc10.vcxproj", "{91EFE087-FECA-1BAD-2D78-F933D2AB8F03}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TSS", "examples\APG\ThreadSafety\TSS_vc10.vcxproj", "{06DC56EC-FECA-1BAD-2D78-F933D2AB8F03}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Tokens_Deadlock", "examples\APG\ThreadSafety\Tokens_Deadlock_vc10.vcxproj", "{13EB4810-FECA-1BAD-2D78-F933D2AB8F03}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Tokens", "examples\APG\ThreadSafety\Tokens_vc10.vcxproj", "{29DC0474-FECA-1BAD-2D78-F933D2AB8F03}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Activate", "examples\APG\Threads\Activate_vc10.vcxproj", "{72FB1409-FECA-1BAD-3731-F897C8D3AD0C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Condition_Variables", "examples\APG\Threads\Condition_Variables_vc10.vcxproj", "{5158FB60-FECA-1BAD-3731-F897C8D3AD0C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Guards", "examples\APG\Threads\Guards_vc10.vcxproj", "{53DC16DF-FECA-1BAD-3731-F897C8D3AD0C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Blocks", "examples\APG\Threads\Message_Blocks_vc10.vcxproj", "{1BCCA964-FECA-1BAD-3731-F897C8D3AD0C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Queue", "examples\APG\Threads\Message_Queue_vc10.vcxproj", "{76CD5838-FECA-1BAD-3731-F897C8D3AD0C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mutexes", "examples\APG\Threads\Mutexes_vc10.vcxproj", "{F2D8F4CB-FECA-1BAD-3731-F897C8D3AD0C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Alarm", "examples\APG\Timers\Alarm_vc10.vcxproj", "{743C5293-FECA-1BAD-B251-8D4CFC8DCBF0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Task", "examples\APG\Timers\Task_vc10.vcxproj", "{755C56BB-FECA-1BAD-B251-8D4CFC8DCBF0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timers", "examples\APG\Timers\Timers_vc10.vcxproj", "{35DC0412-FECA-1BAD-B251-8D4CFC8DCBF0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Upcall", "examples\APG\Timers\Upcall_vc10.vcxproj", "{6A2C048C-FECA-1BAD-B251-8D4CFC8DCBF0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_CCM_App_Client", "examples\ASX\CCM_App\ASX_CCM_App_Client_vc10.vcxproj", "{DBB4543E-FECA-1BAD-F21F-3D1BDD5F2C60}"
- {E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60} = {E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_CCM_App_Lib", "examples\ASX\CCM_App\ASX_CCM_App_Lib_vc10.vcxproj", "{C8437769-FECA-1BAD-F21F-3D1BDD5F2C60}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_CCM_App_Server", "examples\ASX\CCM_App\ASX_CCM_App_Server_vc10.vcxproj", "{E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60}"
- {C8437769-FECA-1BAD-F21F-3D1BDD5F2C60} = {C8437769-FECA-1BAD-F21F-3D1BDD5F2C60}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Event_Server", "examples\ASX\Event_Server\Event_Server\Event_Server_vc10.vcxproj", "{115DF38E-FECA-1BAD-0396-8A213C52C5E6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Transceiver", "examples\ASX\Event_Server\Transceiver\Transceiver_vc10.vcxproj", "{26B503D2-FECA-1BAD-B367-1F304733F83A}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_Message_Queue_Bounded_Buffer", "examples\ASX\Message_Queue\ASX_Message_Queue_Bounded_Buffer_vc10.vcxproj", "{86DE2A47-FECA-1BAD-1624-F77E007731F8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_Message_Queue_Buffer_Stream", "examples\ASX\Message_Queue\ASX_Message_Queue_Buffer_Stream_vc10.vcxproj", "{F679CE5F-FECA-1BAD-1624-F77E007731F8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_Message_Queue_Priority_Buffer", "examples\ASX\Message_Queue\ASX_Message_Queue_Priority_Buffer_vc10.vcxproj", "{3ECD46F0-FECA-1BAD-1624-F77E007731F8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UPIPE_Event_Server", "examples\ASX\UPIPE_Event_Server\UPIPE_Event_Server_vc10.vcxproj", "{4111B37E-FECA-1BAD-53DA-CAD1A7F87CBD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bounded_Packet_Relay", "examples\Bounded_Packet_Relay\Bounded_Packet_Relay_vc10.vcxproj", "{402C7D48-FECA-1BAD-150E-88D9A0C7F2AA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_Iterative_Logging_Server", "examples\C++NPv1\C++NPv1_Iterative_Logging_Server_vc10.vcxproj", "{77B1F4AC-FECA-1BAD-B753-CBFC9FE5DD76}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_Logging_Client", "examples\C++NPv1\C++NPv1_Logging_Client_vc10.vcxproj", "{817A1848-FECA-1BAD-B753-CBFC9FE5DD76}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_PPC_Logging_Server", "examples\C++NPv1\C++NPv1_PPC_Logging_Server_vc10.vcxproj", "{E997FE09-FECA-1BAD-B753-CBFC9FE5DD76}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_RTTPC_Logging_Server", "examples\C++NPv1\C++NPv1_RTTPC_Logging_Server_vc10.vcxproj", "{83BF1DBB-FECA-1BAD-B753-CBFC9FE5DD76}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_Reactive_Logging_Server_Ex", "examples\C++NPv1\C++NPv1_Reactive_Logging_Server_Ex_vc10.vcxproj", "{663FE282-FECA-1BAD-B753-CBFC9FE5DD76}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_Reactive_Logging_Server", "examples\C++NPv1\C++NPv1_Reactive_Logging_Server_vc10.vcxproj", "{560013D2-FECA-1BAD-B753-CBFC9FE5DD76}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_TPC_Logging_Server", "examples\C++NPv1\C++NPv1_TPC_Logging_Server_vc10.vcxproj", "{ED97FE09-FECA-1BAD-B753-CBFC9FE5DD76}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_CLD", "examples\C++NPv2\C++NPv2_CLD_vc10.vcxproj", "{71572396-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_Configurable_Log_Server", "examples\C++NPv2\C++NPv2_Configurable_Log_Server_vc10.vcxproj", "{2D05C717-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_Display_Logfile", "examples\C++NPv2\C++NPv2_Display_Logfile_vc10.vcxproj", "{3908C844-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_Reactor_Log_Server", "examples\C++NPv2\C++NPv2_Reactor_Log_Server_vc10.vcxproj", "{4DF6061C-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_SLD", "examples\C++NPv2\C++NPv2_SLD_vc10.vcxproj", "{71572397-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_SLDex", "examples\C++NPv2\C++NPv2_SLDex_vc10.vcxproj", "{C9192888-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_SR_Configurable_Log_Server", "examples\C++NPv2\C++NPv2_SR_Configurable_Log_Server_vc10.vcxproj", "{BF9E69BB-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_Select_Reactor_Log_Server", "examples\C++NPv2\C++NPv2_Select_Reactor_Log_Server_vc10.vcxproj", "{7223E97F-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_TPLS", "examples\C++NPv2\C++NPv2_TPLS_vc10.vcxproj", "{C66B0109-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_TP_Reactor_Log_Server", "examples\C++NPv2\C++NPv2_TP_Reactor_Log_Server_vc10.vcxproj", "{F71CCF47-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_WFMO_Reactor_Log_Server", "examples\C++NPv2\C++NPv2_WFMO_Reactor_Log_Server_vc10.vcxproj", "{79179A2A-FECA-1BAD-B750-CBFC9FE5DD75}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Blocking_Acceptor", "examples\Connection\blocking\Connection_Blocking_Acceptor_vc10.vcxproj", "{99B2D4AD-FECA-1BAD-63A6-43B4A3F0BDAC}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Blocking_Connector", "examples\Connection\blocking\Connection_Blocking_Connector_vc10.vcxproj", "{2F08A8E7-FECA-1BAD-63A6-43B4A3F0BDAC}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Misc_Handler", "examples\Connection\misc\Connection_Misc_Handler_vc10.vcxproj", "{638C7358-FECA-1BAD-3D13-3640622B5736}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Misc_Test_Upipe", "examples\Connection\misc\Connection_Misc_Test_Upipe_vc10.vcxproj", "{E8BB71DB-FECA-1BAD-3D13-3640622B5736}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_LSockClient", "examples\Connection\non_blocking\Connection_Non_Blocking_LSockClient_vc10.vcxproj", "{D754F4F2-FECA-1BAD-D57C-7CD528BEBF5B}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_LSockServer", "examples\Connection\non_blocking\Connection_Non_Blocking_LSockServer_vc10.vcxproj", "{EC34E478-FECA-1BAD-D57C-7CD528BEBF5B}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_SPipeClient", "examples\Connection\non_blocking\Connection_Non_Blocking_SPipeClient_vc10.vcxproj", "{242714F3-FECA-1BAD-D57C-7CD528BEBF5B}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_SPipeServer", "examples\Connection\non_blocking\Connection_Non_Blocking_SPipeServer_vc10.vcxproj", "{1F470479-FECA-1BAD-D57C-7CD528BEBF5B}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_SockClient", "examples\Connection\non_blocking\Connection_Non_Blocking_SockClient_vc10.vcxproj", "{7A8F763D-FECA-1BAD-D57C-7CD528BEBF5B}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_SockServer", "examples\Connection\non_blocking\Connection_Non_Blocking_SockServer_vc10.vcxproj", "{41EF66B7-FECA-1BAD-D57C-7CD528BEBF5B}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_TLIClient", "examples\Connection\non_blocking\Connection_Non_Blocking_TLIClient_vc10.vcxproj", "{9CCFEE11-FECA-1BAD-D57C-7CD528BEBF5B}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_TLIServer", "examples\Connection\non_blocking\Connection_Non_Blocking_TLIServer_vc10.vcxproj", "{A7AFFE9B-FECA-1BAD-D57C-7CD528BEBF5B}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Main", "examples\DLL\DLL_Main_vc10.vcxproj", "{6F4CDF52-FECA-1BAD-408E-8A636A279EF6}"
- {AAE476E8-FECA-1BAD-408E-8A636A279EF6} = {AAE476E8-FECA-1BAD-408E-8A636A279EF6}
- {3274CCC0-FECA-1BAD-408E-8A636A279EF6} = {3274CCC0-FECA-1BAD-408E-8A636A279EF6}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Newsweek", "examples\DLL\DLL_Newsweek_vc10.vcxproj", "{AAE476E8-FECA-1BAD-408E-8A636A279EF6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Today", "examples\DLL\DLL_Today_vc10.vcxproj", "{3274CCC0-FECA-1BAD-408E-8A636A279EF6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Export_Lib", "examples\Export\Export_Lib_vc10.vcxproj", "{FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Export_Test", "examples\Export\Export_Test_vc10.vcxproj", "{1BC4074F-FECA-1BAD-6856-8E4C79C8CEF6}"
- {FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6} = {FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IOStream_Client", "examples\IOStream\client\IOStream_Client_vc10.vcxproj", "{6AD03905-FECA-1BAD-C7A1-4C9D6A84AD84}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IOStream_Server", "examples\IOStream\server\IOStream_Server_vc10.vcxproj", "{51B0298F-FECA-1BAD-6417-4D956B8C0E32}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "atm_sap_client", "examples\IPC_SAP\ATM_SAP\atm_sap_client_vc10.vcxproj", "{ACC9A56E-FECA-1BAD-8562-EC4B26346A25}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "atm_sap_server", "examples\IPC_SAP\ATM_SAP\atm_sap_server_vc10.vcxproj", "{97A9B5E4-FECA-1BAD-8562-EC4B26346A25}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "dev_sap_reader", "examples\IPC_SAP\DEV_SAP\reader\dev_sap_reader_vc10.vcxproj", "{B7A9B0FD-FECA-1BAD-4A76-D4027A608480}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "dev_sap_writer", "examples\IPC_SAP\DEV_SAP\writer\dev_sap_writer_vc10.vcxproj", "{B7A9B484-FECA-1BAD-DA76-D4457A271480}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Fifo_Sap_Msg_Client", "examples\IPC_SAP\FIFO_SAP\Fifo_Sap_Msg_Client_vc10.vcxproj", "{9CF44627-FECA-1BAD-8564-85690EE67112}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Fifo_Sap_Msg_Server", "examples\IPC_SAP\FIFO_SAP\Fifo_Sap_Msg_Server_vc10.vcxproj", "{A79456AD-FECA-1BAD-8564-85690EE67112}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "fifo_sap_client", "examples\IPC_SAP\FIFO_SAP\fifo_sap_client_vc10.vcxproj", "{ACCFCC4C-FECA-1BAD-8564-85690EE67112}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "fifo_sap_server", "examples\IPC_SAP\FIFO_SAP\fifo_sap_server_vc10.vcxproj", "{97AFDCC6-FECA-1BAD-8564-85690EE67112}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "fifo_sap_test", "examples\IPC_SAP\FIFO_SAP\fifo_sap_test_vc10.vcxproj", "{3E293564-FECA-1BAD-8564-85690EE67112}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "file_sap_client", "examples\IPC_SAP\FILE_SAP\file_sap_client_vc10.vcxproj", "{ACCFCCE6-FECA-1BAD-FBC0-B3C30E4C7112}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Inclient", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Inclient_vc10.vcxproj", "{22B6B3A9-FECA-1BAD-8565-D33D58B27113}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Inserver", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Inserver_vc10.vcxproj", "{19D6A323-FECA-1BAD-8565-D33D58B27113}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Memclient", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Memclient_vc10.vcxproj", "{9849EDB6-FECA-1BAD-8565-D33D58B27113}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Memserver", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Memserver_vc10.vcxproj", "{A329FD3C-FECA-1BAD-8565-D33D58B27113}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Unclient", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Unclient_vc10.vcxproj", "{22AAB3A9-FECA-1BAD-8565-D33D58B27113}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Unserver", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Unserver_vc10.vcxproj", "{19CAA323-FECA-1BAD-8565-D33D58B27113}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_C_Inclient", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_C_Inclient_vc10.vcxproj", "{C64D7626-FECA-1BAD-8565-D33D58B27113}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_C_Inserver", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_C_Inserver_vc10.vcxproj", "{FD2D66AC-FECA-1BAD-8565-D33D58B27113}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_FD_Unclient", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_FD_Unclient_vc10.vcxproj", "{9DE58548-FECA-1BAD-8565-D33D58B27113}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Client", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Client_vc10.vcxproj", "{8EBFAF06-FECA-1BAD-A714-C623708DC274}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Consumer_Msg", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Consumer_Msg_vc10.vcxproj", "{6C78F76B-FECA-1BAD-A714-C623708DC274}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Consumer_Read", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Consumer_Read_vc10.vcxproj", "{B9E64ED0-FECA-1BAD-A714-C623708DC274}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_NPClient", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_NPClient_vc10.vcxproj", "{3A5B53E1-FECA-1BAD-A714-C623708DC274}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_NPServer", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_NPServer_vc10.vcxproj", "{013B436B-FECA-1BAD-A714-C623708DC274}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Producer_Msg", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Producer_Msg_vc10.vcxproj", "{BC081779-FECA-1BAD-A714-C623708DC274}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Producer_Read", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Producer_Read_vc10.vcxproj", "{BEE84FFD-FECA-1BAD-A714-C623708DC274}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Server", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Server_vc10.vcxproj", "{B5DFBF8C-FECA-1BAD-A714-C623708DC274}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_ATM_Client", "examples\IPC_SAP\TLI_SAP\TLI_SAP_ATM_Client_vc10.vcxproj", "{CD284403-FECA-1BAD-A742-DAEF32B06A25}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_ATM_Server", "examples\IPC_SAP\TLI_SAP\TLI_SAP_ATM_Server_vc10.vcxproj", "{F6485489-FECA-1BAD-A742-DAEF32B06A25}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_CPP_Client", "examples\IPC_SAP\TLI_SAP\TLI_SAP_CPP_Client_vc10.vcxproj", "{CF754403-FECA-1BAD-A742-DAEF32B06A25}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_CPP_Server", "examples\IPC_SAP\TLI_SAP\TLI_SAP_CPP_Server_vc10.vcxproj", "{F4155489-FECA-1BAD-A742-DAEF32B06A25}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_Db_Client", "examples\IPC_SAP\TLI_SAP\TLI_SAP_Db_Client_vc10.vcxproj", "{77832932-FECA-1BAD-A742-DAEF32B06A25}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_Db_Server", "examples\IPC_SAP\TLI_SAP\TLI_SAP_Db_Server_vc10.vcxproj", "{4CE339B8-FECA-1BAD-A742-DAEF32B06A25}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_Ftp_Client", "examples\IPC_SAP\TLI_SAP\TLI_SAP_Ftp_Client_vc10.vcxproj", "{C8154403-FECA-1BAD-A742-DAEF32B06A25}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_Ftp_Server", "examples\IPC_SAP\TLI_SAP\TLI_SAP_Ftp_Server_vc10.vcxproj", "{F3755489-FECA-1BAD-A742-DAEF32B06A25}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UPIPE_SAP_Ex1", "examples\IPC_SAP\UPIPE_SAP\UPIPE_SAP_Ex1_vc10.vcxproj", "{FFF627B6-FECA-1BAD-A712-C623708DC272}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UPIPE_SAP_Ex2", "examples\IPC_SAP\UPIPE_SAP\UPIPE_SAP_Ex2_vc10.vcxproj", "{FFC627B6-FECA-1BAD-A712-C623708DC272}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UPIPE_SAP_Ex3", "examples\IPC_SAP\UPIPE_SAP\UPIPE_SAP_Ex3_vc10.vcxproj", "{FFD627B6-FECA-1BAD-A712-C623708DC272}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Msg_Test_Callback", "examples\Log_Msg\Log_Msg_Test_Callback_vc10.vcxproj", "{0F4C02C6-FECA-1BAD-BA55-C0F194E8D070}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Msg_Test_Log_Msg", "examples\Log_Msg\Log_Msg_Test_Log_Msg_vc10.vcxproj", "{033DAD2A-FECA-1BAD-BA55-C0F194E8D070}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Msg_Test_Ostream", "examples\Log_Msg\Log_Msg_Test_Ostream_vc10.vcxproj", "{919D8035-FECA-1BAD-BA55-C0F194E8D070}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Logger_Acceptor_Server", "examples\Logger\Acceptor-server\Logger_Acceptor_Server_vc10.vcxproj", "{7230CC0F-FECA-1BAD-662F-43CDC449C088}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Logger_client", "examples\Logger\client\Logger_client_vc10.vcxproj", "{388BC7EF-FECA-1BAD-6284-F3732ECE18EC}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Logger_Simple_Server", "examples\Logger\simple-server\Logger_Simple_Server_vc10.vcxproj", "{257E89D9-FECA-1BAD-035B-A790F8AEE4FF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Map_Manager", "examples\Map_Manager\Map_Manager_vc10.vcxproj", "{B497E16A-FECA-1BAD-3A45-311BD15FE43D}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mem_Map_IO_Tests", "examples\Mem_Map\IO-tests\Mem_Map_IO_Tests_vc10.vcxproj", "{362AC470-FECA-1BAD-926E-E34A898F3061}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mem_Map_File_Reverse", "examples\Mem_Map\file-reverse\Mem_Map_File_Reverse_vc10.vcxproj", "{870D7110-FECA-1BAD-997C-981CB0707EDF}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Dump", "examples\Misc\Misc_Test_Dump_vc10.vcxproj", "{40CE5CBF-FECA-1BAD-BE51-8A67A27959F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Get_Opt", "examples\Misc\Misc_Test_Get_Opt_vc10.vcxproj", "{B7091250-FECA-1BAD-BE51-8A67A27959F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Profile_Timer", "examples\Misc\Misc_Test_Profile_Timer_vc10.vcxproj", "{9016F8E4-FECA-1BAD-BE51-8A67A27959F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Read_Buffer", "examples\Misc\Misc_Test_Read_Buffer_vc10.vcxproj", "{071FC37D-FECA-1BAD-BE51-8A67A27959F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Set", "examples\Misc\Misc_Test_Set_vc10.vcxproj", "{140E764D-FECA-1BAD-BE51-8A67A27959F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Sstring", "examples\Misc\Misc_Test_Sstring_vc10.vcxproj", "{C838447F-FECA-1BAD-BE51-8A67A27959F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Timestamp", "examples\Misc\Misc_Test_Timestamp_vc10.vcxproj", "{CE95468B-FECA-1BAD-BE51-8A67A27959F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Trace", "examples\Misc\Misc_Test_Trace_vc10.vcxproj", "{C79CF28B-FECA-1BAD-BE51-8A67A27959F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bytes_Sent", "examples\Monitor\Bytes_Sent\Bytes_Sent_vc10.vcxproj", "{6C4E704C-FECA-1BAD-57C8-A8090AE02194}"
- {7153B6F4-FECA-1BAD-D619-74620E01B14C} = {7153B6F4-FECA-1BAD-D619-74620E01B14C}
- {FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5} = {FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "CPU_Load", "examples\Monitor\CPU_Load\CPU_Load_vc10.vcxproj", "{87EA0653-FECA-1BAD-A972-EF683B232306}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Constraint", "examples\Monitor\Constraint\Constraint_vc10.vcxproj", "{AC3515AE-FECA-1BAD-7BCF-1E57BCBE0D93}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Group", "examples\Monitor\Group\Group_vc10.vcxproj", "{92EC52ED-FECA-1BAD-4822-8A23A725AAA8}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MC_Test_Utilities", "examples\Monitor\MC_Test_Utilities_vc10.vcxproj", "{FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Memory_Usage", "examples\Monitor\Memory_Usage\Memory_Usage_vc10.vcxproj", "{5A399C87-FECA-1BAD-E4AF-D6C5D6D0BA85}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Queue_Size", "examples\Monitor\Message_Queue_Size\Message_Queue_Size_vc10.vcxproj", "{11AA315C-FECA-1BAD-5016-EC184EF1264A}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Num_Threads", "examples\Monitor\Num_Threads\Num_Threads_vc10.vcxproj", "{F05679AE-FECA-1BAD-7E09-28972A531BE9}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "NT_Service", "examples\NT_Service\NT_Service_vc10.vcxproj", "{AEA604B9-FECA-1BAD-0BE6-2F4603877603}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Naming_Multiple_Contexts", "examples\Naming\Naming_Multiple_Contexts_vc10.vcxproj", "{688206D5-FECA-1BAD-BF85-8EE479601925}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Naming_Non_Existent", "examples\Naming\Naming_Non_Existent_vc10.vcxproj", "{35A13A17-FECA-1BAD-BF85-8EE479601925}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Naming_Open", "examples\Naming\Naming_Open_vc10.vcxproj", "{F4B3D455-FECA-1BAD-BF85-8EE479601925}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Naming_Writers", "examples\Naming\Naming_Writers_vc10.vcxproj", "{CDF61A70-FECA-1BAD-BF85-8EE479601925}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "OS_Process_Imore", "examples\OS\Process\OS_Process_Imore_vc10.vcxproj", "{01D25766-FECA-1BAD-56E7-2D2A01EB2B05}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "OS_Process_Process", "examples\OS\Process\OS_Process_Process_vc10.vcxproj", "{5ADC56E9-FECA-1BAD-56E7-2D2A01EB2B05}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "QOS_Change_Receiver_FlowSpec_Receiver", "examples\QOS\Change_Receiver_FlowSpec\QOS_Change_Receiver_FlowSpec_Receiver_vc10.vcxproj", "{9009A2D9-FECA-1BAD-0E85-EBA2C3BCE951}"
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3} = {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "QOS_Change_Receiver_FlowSpec_Sender", "examples\QOS\Change_Receiver_FlowSpec\QOS_Change_Receiver_FlowSpec_Sender_vc10.vcxproj", "{3C4E9210-FECA-1BAD-0E85-EBA2C3BCE951}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "QOS_Change_Sender_TSpec_Receiver", "examples\QOS\Change_Sender_TSpec\QOS_Change_Sender_TSpec_Receiver_vc10.vcxproj", "{419B6E77-FECA-1BAD-A054-796E2D70CA71}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "QOS_Change_Sender_TSpec_Sender", "examples\QOS\Change_Sender_TSpec\QOS_Change_Sender_TSpec_Sender_vc10.vcxproj", "{929F00DC-FECA-1BAD-A054-796E2D70CA71}"
- ProjectSection(ProjectDependencies) = postProject
- {47BC56ED-FECA-1BAD-6757-8A6300006755} = {47BC56ED-FECA-1BAD-6757-8A6300006755}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "QOS_Diffserv_Client", "examples\QOS\Diffserv\QOS_Diffserv_Client_vc10.vcxproj", "{2194CC42-FECA-1BAD-083F-A5678D79EFEB}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "QOS_Diffserv_Server", "examples\QOS\Diffserv\QOS_Diffserv_Server_vc10.vcxproj", "{1AF4DCC8-FECA-1BAD-083F-A5678D79EFEB}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "QOS_Simple_Receiver", "examples\QOS\Simple\QOS_Simple_Receiver_vc10.vcxproj", "{E8023C74-FECA-1BAD-A3FD-E03CBCFDDE18}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "QOS_Simple_Sender", "examples\QOS\Simple\QOS_Simple_Sender_vc10.vcxproj", "{9136998E-FECA-1BAD-A3FD-E03CBCFDDE18}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Dgram_CO", "examples\Reactor\Dgram\Reactor_Dgram_CO_vc10.vcxproj", "{20FA65D3-FECA-1BAD-333D-0D85A7384955}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Dgram", "examples\Reactor\Dgram\Reactor_Dgram_vc10.vcxproj", "{2314288A-FECA-1BAD-333D-0D85A7384955}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_FIFO_Client", "examples\Reactor\FIFO\Reactor_FIFO_Client_vc10.vcxproj", "{47F2CB38-FECA-1BAD-6E59-A21D8A7389FD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_FIFO_Server", "examples\Reactor\FIFO\Reactor_FIFO_Server_vc10.vcxproj", "{7C92DBB2-FECA-1BAD-6E59-A21D8A7389FD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Demuxing", "examples\Reactor\Misc\Reactor_Misc_Demuxing_vc10.vcxproj", "{CA06123A-FECA-1BAD-FD25-A21D8A731A81}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Early_Timeouts", "examples\Reactor\Misc\Reactor_Misc_Early_Timeouts_vc10.vcxproj", "{725C36CB-FECA-1BAD-FD25-A21D8A731A81}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Event_Handler_t", "examples\Reactor\Misc\Reactor_Misc_Event_Handler_t_vc10.vcxproj", "{A162739D-FECA-1BAD-FD25-A21D8A731A81}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Notification", "examples\Reactor\Misc\Reactor_Misc_Notification_vc10.vcxproj", "{1501811B-FECA-1BAD-FD25-A21D8A731A81}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Pingpong", "examples\Reactor\Misc\Reactor_Misc_Pingpong_vc10.vcxproj", "{AA12D012-FECA-1BAD-FD25-A21D8A731A81}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Reactors", "examples\Reactor\Misc\Reactor_Misc_Reactors_vc10.vcxproj", "{B7501F56-FECA-1BAD-FD25-A21D8A731A81}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Signals_1", "examples\Reactor\Misc\Reactor_Misc_Signals_1_vc10.vcxproj", "{5424A140-FECA-1BAD-FD25-A21D8A731A81}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Signals_2", "examples\Reactor\Misc\Reactor_Misc_Signals_2_vc10.vcxproj", "{5414A140-FECA-1BAD-FD25-A21D8A731A81}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Timer_Queue", "examples\Reactor\Misc\Reactor_Misc_Timer_Queue_vc10.vcxproj", "{9BE1FEA2-FECA-1BAD-FD25-A21D8A731A81}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Multicast_Client", "examples\Reactor\Multicast\Reactor_Multicast_Client_vc10.vcxproj", "{F803EF2B-FECA-1BAD-D1A8-860E7607F174}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Multicast_Server", "examples\Reactor\Multicast\Reactor_Multicast_Server_vc10.vcxproj", "{C363FFA1-FECA-1BAD-D1A8-860E7607F174}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Ntalker", "examples\Reactor\Ntalker\Reactor_Ntalker_vc10.vcxproj", "{EAB287E7-FECA-1BAD-EFA7-6773336A8585}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Cancel", "examples\Reactor\Proactor\Proactor_Cancel_vc10.vcxproj", "{01AE9706-FECA-1BAD-4285-FEF4D045C8F0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_End_Event_Loops", "examples\Reactor\Proactor\Proactor_End_Event_Loops_vc10.vcxproj", "{9FC93C2F-FECA-1BAD-4285-FEF4D045C8F0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Multiple_Loops", "examples\Reactor\Proactor\Proactor_Multiple_Loops_vc10.vcxproj", "{FB3493EC-FECA-1BAD-4285-FEF4D045C8F0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Post_Completions", "examples\Reactor\Proactor\Proactor_Post_Completions_vc10.vcxproj", "{52A8E79F-FECA-1BAD-4285-FEF4D045C8F0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Proactor", "examples\Reactor\Proactor\Proactor_Proactor_vc10.vcxproj", "{BA1F88DF-FECA-1BAD-4285-FEF4D045C8F0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Timeout", "examples\Reactor\Proactor\Proactor_Timeout_vc10.vcxproj", "{BA81302E-FECA-1BAD-4285-FEF4D045C8F0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Udp_Proactor", "examples\Reactor\Proactor\Proactor_Udp_Proactor_vc10.vcxproj", "{9A299D4A-FECA-1BAD-4285-FEF4D045C8F0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TP_Reactor_Client", "examples\Reactor\TP_Reactor\TP_Reactor_Client_vc10.vcxproj", "{6E3E4771-FECA-1BAD-4795-2E5476BD3033}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TP_Reactor_Server", "examples\Reactor\TP_Reactor\TP_Reactor_Server_vc10.vcxproj", "{555E57FB-FECA-1BAD-4795-2E5476BD3033}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_APC", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_APC_vc10.vcxproj", "{17FB5738-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Abandoned", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Abandoned_vc10.vcxproj", "{429B09C1-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Console_Input", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Console_Input_vc10.vcxproj", "{D0378C0A-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Directory_Changes", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Directory_Changes_vc10.vcxproj", "{567A6CD2-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Exceptions", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Exceptions_vc10.vcxproj", "{9F0B01DB-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Handle_Close", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Handle_Close_vc10.vcxproj", "{DFE640A9-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Multithreading", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Multithreading_vc10.vcxproj", "{B6AE0B92-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Network_Events", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Network_Events_vc10.vcxproj", "{EB8FF8FB-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Prerun_State_Changes", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Prerun_State_Changes_vc10.vcxproj", "{10F4AFD0-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Registration", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Registration_vc10.vcxproj", "{EA987F8B-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Registry_Changes", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Registry_Changes_vc10.vcxproj", "{2A170B05-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Removals", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Removals_vc10.vcxproj", "{76DC5F19-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Suspended_Removals", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Suspended_Removals_vc10.vcxproj", "{5A6E7EF6-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Talker", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Talker_vc10.vcxproj", "{B2D150A1-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Timeouts", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Timeouts_vc10.vcxproj", "{2EDA9FA1-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Window_Messages", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Window_Messages_vc10.vcxproj", "{81B72E1B-FECA-1BAD-701A-2E512E45D4CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Registry_Iterator", "examples\Registry\Registry_Iterator_vc10.vcxproj", "{61316AEC-FECA-1BAD-435E-C97DA4B8E121}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Registry_Update", "examples\Registry\Registry_Update_vc10.vcxproj", "{31E5B795-FECA-1BAD-435E-C97DA4B8E121}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Semaphores_Starter", "examples\Semaphores\Semaphores_Starter_vc10.vcxproj", "{259D7264-FECA-1BAD-8172-3C0D10CCFC97}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Semaphores_Worker", "examples\Semaphores\Semaphores_Worker_vc10.vcxproj", "{43B94103-FECA-1BAD-8172-3C0D10CCFC97}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Bcast", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Bcast_vc10.vcxproj", "{D97D0DAC-FECA-1BAD-DD12-8A69A8383EB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Loc_Dgram", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Loc_Dgram_vc10.vcxproj", "{0C959018-FECA-1BAD-DD12-8A69A8383EB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Loc_Fifo", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Loc_Fifo_vc10.vcxproj", "{F5A6CA84-FECA-1BAD-DD12-8A69A8383EB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Loc_Pipe", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Loc_Pipe_vc10.vcxproj", "{E306CA92-FECA-1BAD-DD12-8A69A8383EB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Loc_Spipe", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Loc_Spipe_vc10.vcxproj", "{AD15917E-FECA-1BAD-DD12-8A69A8383EB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Loc_Stream", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Loc_Stream_vc10.vcxproj", "{9DA02FC8-FECA-1BAD-DD12-8A69A8383EB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Rem_Dgram", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Rem_Dgram_vc10.vcxproj", "{0D7F7018-FECA-1BAD-DD12-8A69A8383EB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Rem_Stream", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Rem_Stream_vc10.vcxproj", "{830E2FC8-FECA-1BAD-DD12-8A69A8383EB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Rem_Svc_Dir", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Rem_Svc_Dir_vc10.vcxproj", "{7DEBC7D8-FECA-1BAD-DD12-8A69A8383EB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Rem_Thr_Stream", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Rem_Thr_Stream_vc10.vcxproj", "{58DE56EF-FECA-1BAD-DD12-8A69A8383EB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Server_Lib", "examples\Service_Configurator\IPC-tests\server\Svc_Cfg_IPC_Server_Lib_vc10.vcxproj", "{AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Server_Test", "examples\Service_Configurator\IPC-tests\server\Svc_Cfg_IPC_Server_Test_vc10.vcxproj", "{36D2F54A-FECA-1BAD-7EA4-8B61A9309D00}"
- {AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00} = {AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Configurator_Misc_Main", "examples\Service_Configurator\Misc\Service_Configurator_Misc_Main_vc10.vcxproj", "{14E0A6C7-FECA-1BAD-ECF7-1F18EF61CB2B}"
- {1C035591-FECA-1BAD-ECF7-1F18EF61CB2B} = {1C035591-FECA-1BAD-ECF7-1F18EF61CB2B}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Configurator_Misc_Timer", "examples\Service_Configurator\Misc\Service_Configurator_Misc_Timer_vc10.vcxproj", "{1C035591-FECA-1BAD-ECF7-1F18EF61CB2B}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Malloc_Multiple", "examples\Shared_Malloc\Shared_Malloc_Multiple_vc10.vcxproj", "{AF1D8F8B-FECA-1BAD-4CD2-91813C3C36BA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Malloc_Persistence", "examples\Shared_Malloc\Shared_Malloc_Persistence_vc10.vcxproj", "{49CD7F91-FECA-1BAD-4CD2-91813C3C36BA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Malloc_Posind", "examples\Shared_Malloc\Shared_Malloc_Posind_vc10.vcxproj", "{A479EB8E-FECA-1BAD-4CD2-91813C3C36BA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Malloc", "examples\Shared_Malloc\Shared_Malloc_vc10.vcxproj", "{DDEDE8CD-FECA-1BAD-4CD2-91813C3C36BA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Memory_MM", "examples\Shared_Memory\Shared_Memory_MM_vc10.vcxproj", "{B2DA08F6-FECA-1BAD-5E18-91853C382470}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Memory_SV", "examples\Shared_Memory\Shared_Memory_SV_vc10.vcxproj", "{AD6A08F6-FECA-1BAD-5E18-91853C382470}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Smart_Pointers_Gadget", "examples\Smart_Pointers\Smart_Pointers_Gadget_vc10.vcxproj", "{45E08B39-FECA-1BAD-474B-E6C11145E1EB}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Smart_Pointers_Widget", "examples\Smart_Pointers\Smart_Pointers_Widget_vc10.vcxproj", "{45E09BB9-FECA-1BAD-474B-E6C11145E1EB}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Synch", "examples\Synch\Synch_vc10.vcxproj", "{956C53A6-FECA-1BAD-F85A-8A37278A8232}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Message_Queues_MQ_Client", "examples\System_V_IPC\SV_Message_Queues\SV_Message_Queues_MQ_Client_vc10.vcxproj", "{3135F526-FECA-1BAD-6606-BBB2EAC4C36E}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Message_Queues_MQ_Server", "examples\System_V_IPC\SV_Message_Queues\SV_Message_Queues_MQ_Server_vc10.vcxproj", "{0A55E5AC-FECA-1BAD-6606-BBB2EAC4C36E}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Message_Queues_TMQ_Client", "examples\System_V_IPC\SV_Message_Queues\SV_Message_Queues_TMQ_Client_vc10.vcxproj", "{B8F98547-FECA-1BAD-6606-BBB2EAC4C36E}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Message_Queues_TMQ_Server", "examples\System_V_IPC\SV_Message_Queues\SV_Message_Queues_TMQ_Server_vc10.vcxproj", "{839995CD-FECA-1BAD-6606-BBB2EAC4C36E}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Semaphores_1", "examples\System_V_IPC\SV_Semaphores\SV_Semaphores_1_vc10.vcxproj", "{479FDD0E-FECA-1BAD-BE72-3C5B13526565}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Semaphores_2", "examples\System_V_IPC\SV_Semaphores\SV_Semaphores_2_vc10.vcxproj", "{47AFDD0E-FECA-1BAD-BE72-3C5B13526565}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Auto_Event", "examples\Threads\Threads_Auto_Event_vc10.vcxproj", "{CD7ACAFF-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Barrier1", "examples\Threads\Threads_Barrier1_vc10.vcxproj", "{071AC791-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Barrier2", "examples\Threads\Threads_Barrier2_vc10.vcxproj", "{072AC791-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Cancel", "examples\Threads\Threads_Cancel_vc10.vcxproj", "{741AB165-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Future1", "examples\Threads\Threads_Future1_vc10.vcxproj", "{25926B98-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Future2", "examples\Threads\Threads_Future2_vc10.vcxproj", "{25A26B98-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Manual_Event", "examples\Threads\Threads_Manual_Event_vc10.vcxproj", "{A4ACFB20-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Process_Mutex", "examples\Threads\Threads_Process_Mutex_vc10.vcxproj", "{E43B5210-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Process_Semaphore", "examples\Threads\Threads_Process_Semaphore_vc10.vcxproj", "{91B436D0-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Reader_Writer", "examples\Threads\Threads_Reader_Writer_vc10.vcxproj", "{039899CB-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Recursive_Mutex", "examples\Threads\Threads_Recursive_Mutex_vc10.vcxproj", "{14E3314A-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Task_Five", "examples\Threads\Threads_Task_Five_vc10.vcxproj", "{9FB54B2A-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Task_Four", "examples\Threads\Threads_Task_Four_vc10.vcxproj", "{FDC54B2A-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Task_One", "examples\Threads\Threads_Task_One_vc10.vcxproj", "{BE4CC735-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Task_Three", "examples\Threads\Threads_Task_Three_vc10.vcxproj", "{A32D8BF0-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Task_Two", "examples\Threads\Threads_Task_Two_vc10.vcxproj", "{17ECC734-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Thread_Manager", "examples\Threads\Threads_Thread_Manager_vc10.vcxproj", "{02E1116E-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Thread_Pool", "examples\Threads\Threads_Thread_Pool_vc10.vcxproj", "{892C5420-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Thread_Specific", "examples\Threads\Threads_Thread_Specific_vc10.vcxproj", "{1D1735B6-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Token", "examples\Threads\Threads_Token_vc10.vcxproj", "{807F39EF-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Tss1", "examples\Threads\Threads_Tss1_vc10.vcxproj", "{A4CB6018-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Tss2", "examples\Threads\Threads_Tss2_vc10.vcxproj", "{A4FB6018-FECA-1BAD-3731-D8978C8E5D14}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Async", "examples\Timer_Queue\Timer_Queue_Async_vc10.vcxproj", "{8ED0EFF7-FECA-1BAD-60CC-ADC54D81BEB4}"
- {79C583DB-FECA-1BAD-60CC-ADC54D81BEB4} = {79C583DB-FECA-1BAD-60CC-ADC54D81BEB4}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Library", "examples\Timer_Queue\Timer_Queue_Library_vc10.vcxproj", "{79C583DB-FECA-1BAD-60CC-ADC54D81BEB4}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Reactor", "examples\Timer_Queue\Timer_Queue_Reactor_vc10.vcxproj", "{34746FFB-FECA-1BAD-60CC-ADC54D81BEB4}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Thread_Custom_Handlers", "examples\Timer_Queue\Timer_Queue_Thread_Custom_Handlers_vc10.vcxproj", "{FAB2E9D3-FECA-1BAD-60CC-ADC54D81BEB4}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Thread", "examples\Timer_Queue\Timer_Queue_Thread_vc10.vcxproj", "{4767D3BB-FECA-1BAD-60CC-ADC54D81BEB4}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Web_Crawler", "examples\Web_Crawler\Web_Crawler_vc10.vcxproj", "{A1B7128D-FECA-1BAD-4B17-3E25DE61956F}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "direct_logging", "netsvcs\clients\Logger\direct_logging_vc10.vcxproj", "{DC859D1C-FECA-1BAD-1120-8ECA0471D6B5}"
- {14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1} = {14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "indirect_logging", "netsvcs\clients\Logger\indirect_logging_vc10.vcxproj", "{DCEA7D1C-FECA-1BAD-1120-8ECA0471D6B5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Netsvcs_Client_Test", "netsvcs\clients\Naming\Client\Netsvcs_Client_Test_vc10.vcxproj", "{EC6BC324-FECA-1BAD-F396-8E392B1F0415}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Netsvcs_Dump_Restore", "netsvcs\clients\Naming\Dump_Restore\Netsvcs_Dump_Restore_vc10.vcxproj", "{8DA65250-FECA-1BAD-1BE2-2E43250F5E17}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "netsvcs", "netsvcs\lib\netsvcs_vc10.vcxproj", "{14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Netsvcs_server", "netsvcs\servers\Netsvcs_server_vc10.vcxproj", "{528A9BEF-FECA-1BAD-0251-FF46ED064212}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Basic_Perf", "performance-tests\Misc\Misc_Basic_Perf_vc10.vcxproj", "{80ED1E19-FECA-1BAD-BE51-8A67F3FC84F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Childbirth_Time", "performance-tests\Misc\Misc_Childbirth_Time_vc10.vcxproj", "{2A3225FA-FECA-1BAD-BE51-8A67F3FC84F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Context_Switch_Time", "performance-tests\Misc\Misc_Context_Switch_Time_vc10.vcxproj", "{F387C13A-FECA-1BAD-BE51-8A67F3FC84F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Preempt", "performance-tests\Misc\Misc_Preempt_vc10.vcxproj", "{52C62291-FECA-1BAD-BE51-8A67F3FC84F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Guard", "performance-tests\Misc\Misc_Test_Guard_vc10.vcxproj", "{D68CF3BC-FECA-1BAD-BE51-8A67F3FC84F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Mutex", "performance-tests\Misc\Misc_Test_Mutex_vc10.vcxproj", "{904CF31D-FECA-1BAD-BE51-8A67F3FC84F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Naming", "performance-tests\Misc\Misc_Test_Naming_vc10.vcxproj", "{CA960BF8-FECA-1BAD-BE51-8A67F3FC84F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Singleton", "performance-tests\Misc\Misc_Test_Singleton_vc10.vcxproj", "{9D05756B-FECA-1BAD-BE51-8A67F3FC84F5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SCTP_SOCK_SEQPACK_Association_Test", "performance-tests\SCTP\SCTP_SOCK_SEQPACK_Association_Test_vc10.vcxproj", "{95F3D6E0-FECA-1BAD-7612-8A66F3FD4CB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SCTP_SOCK_SEQPACK_Clt", "performance-tests\SCTP\SCTP_SOCK_SEQPACK_Clt_vc10.vcxproj", "{2E4FB39E-FECA-1BAD-7612-8A66F3FD4CB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SCTP_SOCK_SEQPACK_Srv", "performance-tests\SCTP\SCTP_SOCK_SEQPACK_Srv_vc10.vcxproj", "{306FB39F-FECA-1BAD-7612-8A66F3FD4CB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SCTP_SOCK_STREAM_Clt", "performance-tests\SCTP\SCTP_SOCK_STREAM_Clt_vc10.vcxproj", "{8CE0384B-FECA-1BAD-7612-8A66F3FD4CB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SCTP_SOCK_STREAM_Srv", "performance-tests\SCTP\SCTP_SOCK_STREAM_Srv_vc10.vcxproj", "{92C0384A-FECA-1BAD-7612-8A66F3FD4CB6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svr_Conc_Leader_Follower_RT_CORBA", "performance-tests\Server_Concurrency\Leader_Follower\Svr_Conc_Leader_Follower_RT_CORBA_vc10.vcxproj", "{A9A9AB69-FECA-1BAD-FAD8-7885071DD3E2}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svr_Conc_Leader_Follower", "performance-tests\Server_Concurrency\Leader_Follower\Svr_Conc_Leader_Follower_vc10.vcxproj", "{BD437886-FECA-1BAD-FAD8-7885071DD3E2}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svr_Conc_Queue_Based_Workers_RTCorba", "performance-tests\Server_Concurrency\Queue_Based_Workers\Svr_Conc_Queue_Based_Workers_RTCorba_vc10.vcxproj", "{561AAD84-FECA-1BAD-5029-42D0E18BA5D0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svr_Conc_Queue_Based_Workers", "performance-tests\Server_Concurrency\Queue_Based_Workers\Svr_Conc_Queue_Based_Workers_vc10.vcxproj", "{1250DDDC-FECA-1BAD-5029-42D0E18BA5D0}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Synch_Benchmarks_Base_Test", "performance-tests\Synch-Benchmarks\Base_Test\Synch_Benchmarks_Base_Test_vc10.vcxproj", "{334CEDB3-FECA-1BAD-A238-81D6AD345D00}"
- {BA83D332-FECA-1BAD-3A9E-1C813063C5A6} = {BA83D332-FECA-1BAD-3A9E-1C813063C5A6}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Synch_Benchmarks_Perf_Test", "performance-tests\Synch-Benchmarks\Perf_Test\Synch_Benchmarks_Perf_Test_vc10.vcxproj", "{3268FEB3-FECA-1BAD-A22A-C0E6EC045D12}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Synch_Benchmarks", "performance-tests\Synch-Benchmarks\Synch_Benchmarks_vc10.vcxproj", "{E8B0F002-FECA-1BAD-BF87-400DF0C83E7D}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Synch_Lib", "performance-tests\Synch-Benchmarks\Synch_Lib\Synch_Lib_vc10.vcxproj", "{BA83D332-FECA-1BAD-3A9E-1C813063C5A6}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TCP", "performance-tests\TCP\TCP_vc10.vcxproj", "{16EC56EC-FECA-1BAD-5062-8A636F3FD3CA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UDP", "performance-tests\UDP\UDP_vc10.vcxproj", "{01EC56EC-FECA-1BAD-5112-8A636F3FD2BA}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HTBP", "protocols\ace\HTBP\HTBP_vc10.vcxproj", "{17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "INet", "protocols\ace\INet\INet_vc10.vcxproj", "{92AC56A4-FECA-1BAD-F826-8A65F7EE4449}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RMCast", "protocols\ace\RMCast\RMCast_vc10.vcxproj", "{74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TMCast", "protocols\ace\TMCast\TMCast_vc10.vcxproj", "{74AC067C-FECA-1BAD-5646-8F6AEF953BB3}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FTP_Simple_exec", "protocols\examples\INet\FTP_Simple_exec_vc10.vcxproj", "{AC7EC721-FECA-1BAD-F826-8A6564C116DB}"
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449} = {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HTTP_Simple_exec", "protocols\examples\INet\HTTP_Simple_exec_vc10.vcxproj", "{AC37E721-FECA-1BAD-F826-8A6564C116DB}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Send_Msg_Receiver", "protocols\examples\RMCast\Send_Msg\Send_Msg_Receiver_vc10.vcxproj", "{453BE26D-FECA-1BAD-BA50-D9E259FB2871}"
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3} = {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Send_Msg_Sender", "protocols\examples\RMCast\Send_Msg\Send_Msg_Sender_vc10.vcxproj", "{889BA050-FECA-1BAD-BA50-D9E259FB2871}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Member", "protocols\examples\TMCast\Member\Member_vc10.vcxproj", "{52CC1DD2-FECA-1BAD-B420-8ED027BFCEB0}"
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3} = {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Tests_Client", "protocols\tests\HTBP\Reactor_Tests\Reactor_Tests_Client_vc10.vcxproj", "{3AD864B0-FECA-1BAD-1373-0D9555D094CD}"
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D} = {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Tests_Server", "protocols\tests\HTBP\Reactor_Tests\Reactor_Tests_Server_vc10.vcxproj", "{01B8743A-FECA-1BAD-1373-0D9555D094CD}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Send_Large_Msg_Client", "protocols\tests\HTBP\Send_Large_Msg\Send_Large_Msg_Client_vc10.vcxproj", "{12448205-FECA-1BAD-3BEF-EB20432B4020}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Send_Large_Msg_Server", "protocols\tests\HTBP\Send_Large_Msg\Send_Large_Msg_Server_vc10.vcxproj", "{2924928F-FECA-1BAD-3BEF-EB20432B4020}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SendRecv_Test_Client", "protocols\tests\HTBP\Send_Recv_Tests\SendRecv_Test_Client_vc10.vcxproj", "{33F9D729-FECA-1BAD-1A52-BE0C301D82A2}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SendRecv_Test_Server", "protocols\tests\HTBP\Send_Recv_Tests\SendRecv_Test_Server_vc10.vcxproj", "{0899C7A3-FECA-1BAD-1A52-BE0C301D82A2}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Ping_Client", "protocols\tests\HTBP\ping\Ping_Client_vc10.vcxproj", "{462EE343-FECA-1BAD-6F85-8A64CD2507FC}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Ping_Server", "protocols\tests\HTBP\ping\Ping_Server_vc10.vcxproj", "{7D4EF3C9-FECA-1BAD-6F85-8A64CD2507FC}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_Get", "protocols\tests\INet\MT_Get\MT_Get_vc10.vcxproj", "{02AC1EF2-FECA-1BAD-2246-8A6466E9CA6C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RMCast_Receiver", "protocols\tests\RMCast\RMCast_Receiver_vc10.vcxproj", "{536D0A81-FECA-1BAD-5646-8F0A8605F692}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RMCast_Sender", "protocols\tests\RMCast\RMCast_Sender_vc10.vcxproj", "{648DF6B8-FECA-1BAD-5646-8F0A8605F692}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_Test", "tests\ACE_Test_vc10.vcxproj", "{34E9264B-FECA-1BAD-2431-8A1100722433}"
- {40EDEECF-FECA-1BAD-2431-8A1100722433} = {40EDEECF-FECA-1BAD-2431-8A1100722433}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ARGV_Test", "tests\ARGV_Test_vc10.vcxproj", "{30EA754B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Aio_Platform_Test", "tests\Aio_Platform_Test_vc10.vcxproj", "{52DBB421-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Arg_Shifter_Test", "tests\Arg_Shifter_Test_vc10.vcxproj", "{DBF833EE-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Array_Map_Test", "tests\Array_Map_Test_vc10.vcxproj", "{5817751F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Atomic_Op_Test", "tests\Atomic_Op_Test_vc10.vcxproj", "{8BC79562-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Auto_Event_Test", "tests\Auto_Event_Test_vc10.vcxproj", "{86ABA561-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Auto_IncDec_Test", "tests\Auto_IncDec_Test_vc10.vcxproj", "{CC9842E0-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Barrier_Test", "tests\Barrier_Test_vc10.vcxproj", "{51E3710F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Based_Pointer_Test_Lib", "tests\Based_Pointer_Test_Lib_vc10.vcxproj", "{A9C8A905-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Based_Pointer_Test", "tests\Based_Pointer_Test_vc10.vcxproj", "{EF5B40ED-FECA-1BAD-2431-8A1100722433}"
- {A9C8A905-FECA-1BAD-2431-8A1100722433} = {A9C8A905-FECA-1BAD-2431-8A1100722433}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Basic_Types_Test", "tests\Basic_Types_Test_vc10.vcxproj", "{970E15BD-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bound_Ptr_Test", "tests\Bound_Ptr_Test_vc10.vcxproj", "{B50B25C8-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Buffer_Stream_Test", "tests\Buffer_Stream_Test_vc10.vcxproj", "{32DF2C31-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_1576_Regression_Test", "tests\Bug_1576_Regression_Test_vc10.vcxproj", "{748CBC8D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_1890_Regression_Test", "tests\Bug_1890_Regression_Test_vc10.vcxproj", "{AAECBC8D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2368_Regression_Test", "tests\Bug_2368_Regression_Test_vc10.vcxproj", "{156CBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2434_Regression_Test", "tests\Bug_2434_Regression_Test_vc10.vcxproj", "{60ACBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2497_Regression_Test", "tests\Bug_2497_Regression_Test_vc10.vcxproj", "{6A9CBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2540_Regression_Test", "tests\Bug_2540_Regression_Test_vc10.vcxproj", "{77ECBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2609_Regression_Test", "tests\Bug_2609_Regression_Test_vc10.vcxproj", "{437CBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2610_Regression_Test", "tests\Bug_2610_Regression_Test_vc10.vcxproj", "{42ECBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2653_Regression_Test", "tests\Bug_2653_Regression_Test_vc10.vcxproj", "{46DCBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2659_Regression_Test", "tests\Bug_2659_Regression_Test_vc10.vcxproj", "{467CBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2740_Regression_Test", "tests\Bug_2740_Regression_Test_vc10.vcxproj", "{57ECBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2772_Regression_Test", "tests\Bug_2772_Regression_Test_vc10.vcxproj", "{54CCBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2815_Regression_Test", "tests\Bug_2815_Regression_Test_vc10.vcxproj", "{A2BCBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2820_Regression_Test", "tests\Bug_2820_Regression_Test_vc10.vcxproj", "{A1ECBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2975_Regression_Test", "tests\Bug_2975_Regression_Test_vc10.vcxproj", "{B4BCBC8E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2980_Regression_Dll", "tests\Bug_2980_Regression_Dll_vc10.vcxproj", "{62D8584E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2980_Regression_Test", "tests\Bug_2980_Regression_Test_vc10.vcxproj", "{BBECBC8E-FECA-1BAD-2431-8A1100722433}"
- {62D8584E-FECA-1BAD-2431-8A1100722433} = {62D8584E-FECA-1BAD-2431-8A1100722433}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3102_Regression_Test", "tests\Bug_3102_Regression_Test_vc10.vcxproj", "{33CCBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3319_Regression_Test", "tests\Bug_3319_Regression_Test_vc10.vcxproj", "{127CBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3332_Regression_Test", "tests\Bug_3332_Regression_Test_vc10.vcxproj", "{10CCBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3334_Regression_Test", "tests\Bug_3334_Regression_Test_vc10.vcxproj", "{10ACBC8F-FECA-1BAD-2431-8A1100722433}"
- {B213B165-FECA-1BAD-2431-8A1100722433} = {B213B165-FECA-1BAD-2431-8A1100722433}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3432_Regression_Test", "tests\Bug_3432_Regression_Test_vc10.vcxproj", "{60CCBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3500_Regression_Test", "tests\Bug_3500_Regression_Test_vc10.vcxproj", "{73ECBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3505_Regression_Test", "tests\Bug_3505_Regression_Test_vc10.vcxproj", "{73BCBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3532_Regression_Test", "tests\Bug_3532_Regression_Test_vc10.vcxproj", "{70CCBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3539_Regression_Test", "tests\Bug_3539_Regression_Test_vc10.vcxproj", "{707CBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3541_Regression_Test", "tests\Bug_3541_Regression_Test_vc10.vcxproj", "{77FCBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3673_Regression_Test", "tests\Bug_3673_Regression_Test_vc10.vcxproj", "{44DCBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3709_Regression_Test", "tests\Bug_3709_Regression_Test_vc10.vcxproj", "{537CBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3710_Regression_Test", "tests\Bug_3710_Regression_Test_vc10.vcxproj", "{52ECBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3729_Regression_Test", "tests\Bug_3729_Regression_Test_vc10.vcxproj", "{517CBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3744_Regression_Test", "tests\Bug_3744_Regression_Test_vc10.vcxproj", "{57ACBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3758_Regression_Test", "tests\Bug_3758_Regression_Test_vc10.vcxproj", "{566CBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3878_Regression_Test", "tests\Bug_3878_Regression_Test_vc10.vcxproj", "{A46CBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3911_Regression_Test", "tests\Bug_3911_Regression_Test_vc10.vcxproj", "{B2FCBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3912_Regression_Test", "tests\Bug_3912_Regression_Test_vc10.vcxproj", "{B2CCBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3943_Regression_Test", "tests\Bug_3943_Regression_Test_vc10.vcxproj", "{B7DCBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3974_Regression_Test", "tests\Bug_3974_Regression_Test_vc10.vcxproj", "{B4ACBC8F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_4055_Regression_Test", "tests\Bug_4055_Regression_Test_vc10.vcxproj", "{26BCBC88-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "CDR_Array_Test", "tests\CDR_Array_Test_vc10.vcxproj", "{82F87D5C-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "CDR_File_Test", "tests\CDR_File_Test_vc10.vcxproj", "{4FA3F23A-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "CDR_Test", "tests\CDR_Test_vc10.vcxproj", "{34EB414B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Cache_Map_Manager_Test", "tests\Cache_Map_Manager_Test_vc10.vcxproj", "{AC665185-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Cached_Accept_Conn_Test", "tests\Cached_Accept_Conn_Test_vc10.vcxproj", "{1E46DF32-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Cached_Allocator_Test", "tests\Cached_Allocator_Test_vc10.vcxproj", "{FFFF62B6-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Cached_Conn_Test", "tests\Cached_Conn_Test_vc10.vcxproj", "{2FB0A8A8-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Capabilities_Test", "tests\Capabilities_Test_vc10.vcxproj", "{9ED51704-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Codecs_Test", "tests\Codecs_Test_vc10.vcxproj", "{6D8F104F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Collection_Test", "tests\Collection_Test_vc10.vcxproj", "{008794E1-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_01_Test", "tests\Compiler_Features_01_Test_vc10.vcxproj", "{5529F283-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_02_Test", "tests\Compiler_Features_02_Test_vc10.vcxproj", "{5529F183-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_03_Test", "tests\Compiler_Features_03_Test_vc10.vcxproj", "{5529F083-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_04_Test", "tests\Compiler_Features_04_Test_vc10.vcxproj", "{5529F783-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_05_Test", "tests\Compiler_Features_05_Test_vc10.vcxproj", "{5529F683-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_06_Test", "tests\Compiler_Features_06_Test_vc10.vcxproj", "{5529F583-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_07_Test", "tests\Compiler_Features_07_Test_vc10.vcxproj", "{5529F483-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_09_Test", "tests\Compiler_Features_09_Test_vc10.vcxproj", "{5529FA83-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_10_Test", "tests\Compiler_Features_10_Test_vc10.vcxproj", "{5529E383-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_11_Test", "tests\Compiler_Features_11_Test_vc10.vcxproj", "{5529E283-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_12_Test", "tests\Compiler_Features_12_Test_vc10.vcxproj", "{5529E183-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_13_Test", "tests\Compiler_Features_13_Test_vc10.vcxproj", "{5529E083-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_14_Test", "tests\Compiler_Features_14_Test_vc10.vcxproj", "{5529E783-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_15_Test", "tests\Compiler_Features_15_Test_vc10.vcxproj", "{5529E683-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_16_Test", "tests\Compiler_Features_16_Test_vc10.vcxproj", "{5529E583-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_17_Test", "tests\Compiler_Features_17_Test_vc10.vcxproj", "{5529E483-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_18_Test", "tests\Compiler_Features_18_Test_vc10.vcxproj", "{5529EB83-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_19_Test", "tests\Compiler_Features_19_Test_vc10.vcxproj", "{5529EA83-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_20_Test", "tests\Compiler_Features_20_Test_vc10.vcxproj", "{5529D383-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_21_Test", "tests\Compiler_Features_21_Test_vc10.vcxproj", "{5529D283-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_22_Test", "tests\Compiler_Features_22_Test_vc10.vcxproj", "{5529D183-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_23_Test", "tests\Compiler_Features_23_Test_vc10.vcxproj", "{5529D083-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_24_Test", "tests\Compiler_Features_24_Test_vc10.vcxproj", "{5529D783-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_25_Test", "tests\Compiler_Features_25_Test_vc10.vcxproj", "{5529D683-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_26_Test", "tests\Compiler_Features_26_Test_vc10.vcxproj", "{5529D583-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_27_Test", "tests\Compiler_Features_27_Test_vc10.vcxproj", "{5529D483-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_28_Test", "tests\Compiler_Features_28_Test_vc10.vcxproj", "{5529DB83-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_29_Test", "tests\Compiler_Features_29_Test_vc10.vcxproj", "{5529DA83-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_31_Test", "tests\Compiler_Features_31_Test_vc10.vcxproj", "{5529C283-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_32_Test", "tests\Compiler_Features_32_Test_vc10.vcxproj", "{5529C183-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_33_Test", "tests\Compiler_Features_33_Test_vc10.vcxproj", "{5529C083-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_34_Test", "tests\Compiler_Features_34_Test_vc10.vcxproj", "{5529C783-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Config_Test", "tests\Config_Test_vc10.vcxproj", "{6D2CA44F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Conn_Test", "tests\Conn_Test_vc10.vcxproj", "{30F5DD4B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Test_Lib", "tests\DLL_Test_Lib_vc10.vcxproj", "{366E72B2-FECA-1BAD-2431-8A1100722433}"
- {11324DB7-FECA-1BAD-2431-8A1100722433} = {11324DB7-FECA-1BAD-2431-8A1100722433}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Test_Parent_Lib", "tests\DLL_Test_Parent_Lib_vc10.vcxproj", "{11324DB7-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Test", "tests\DLL_Test_vc10.vcxproj", "{34ECDF4B-FECA-1BAD-2431-8A1100722433}"
- {366E72B2-FECA-1BAD-2431-8A1100722433} = {366E72B2-FECA-1BAD-2431-8A1100722433}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLList_Test", "tests\DLList_Test_vc10.vcxproj", "{3C02174F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Date_Time_Test", "tests\Date_Time_Test_vc10.vcxproj", "{3E83A429-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Dev_Poll_Reactor_Test", "tests\Dev_Poll_Reactor_Test_vc10.vcxproj", "{39877CCD-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Dirent_Test", "tests\Dirent_Test_vc10.vcxproj", "{1AEFC74F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Dynamic_Priority_Test", "tests\Dynamic_Priority_Test_vc10.vcxproj", "{4B5D0400-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Dynamic_Test", "tests\Dynamic_Test_vc10.vcxproj", "{CCD7A008-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Enum_Interfaces_Test", "tests\Enum_Interfaces_Test_vc10.vcxproj", "{E752892A-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Env_Value_Test", "tests\Env_Value_Test_vc10.vcxproj", "{94D725D8-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FIFO_Test", "tests\FIFO_Test_vc10.vcxproj", "{30817C4B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Framework_Component_DLL", "tests\Framework_Component_DLL_vc10.vcxproj", "{9F3490D0-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Framework_Component_Test", "tests\Framework_Component_Test_vc10.vcxproj", "{45203563-FECA-1BAD-2431-8A1100722433}"
- {9F3490D0-FECA-1BAD-2431-8A1100722433} = {9F3490D0-FECA-1BAD-2431-8A1100722433}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Future_Set_Test", "tests\Future_Set_Test_vc10.vcxproj", "{740D6579-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Future_Test", "tests\Future_Test_vc10.vcxproj", "{269E164F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Get_Opt_Test", "tests\Get_Opt_Test_vc10.vcxproj", "{1514270A-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Handle_Set_Test", "tests\Handle_Set_Test_vc10.vcxproj", "{940D90C9-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Hash_Map_Bucket_Iterator_Test", "tests\Hash_Map_Bucket_Iterator_Test_vc10.vcxproj", "{78A7ABFA-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Hash_Map_Manager_Test", "tests\Hash_Map_Manager_Test_vc10.vcxproj", "{11661016-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Hash_Multi_Map_Manager_Test", "tests\Hash_Multi_Map_Manager_Test_vc10.vcxproj", "{863BAECF-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "High_Res_Timer_Test", "tests\High_Res_Timer_Test_vc10.vcxproj", "{794AD569-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "INET_Addr_Test_IPV6", "tests\INET_Addr_Test_IPV6_vc10.vcxproj", "{E5AFA072-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "INET_Addr_Test", "tests\INET_Addr_Test_vc10.vcxproj", "{2FDE2CEB-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IOStream_Test", "tests\IOStream_Test_vc10.vcxproj", "{77EF2A91-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Integer_Truncate_Test", "tests\Integer_Truncate_Test_vc10.vcxproj", "{2FE80887-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Intrusive_Auto_Ptr_Test", "tests\Intrusive_Auto_Ptr_Test_vc10.vcxproj", "{3BEF931C-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Lazy_Map_Manager_Test", "tests\Lazy_Map_Manager_Test_vc10.vcxproj", "{90661056-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Library_Unload", "tests\Library_Unload_vc10.vcxproj", "{C1F0BF96-FECA-1BAD-2431-8A1100722433}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Msg_Backend_Test", "tests\Log_Msg_Backend_Test_vc10.vcxproj", "{D3C585B5-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Msg_Test", "tests\Log_Msg_Test_vc10.vcxproj", "{A6160401-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Thread_Inheritance_Test", "tests\Log_Thread_Inheritance_Test_vc10.vcxproj", "{0E41A728-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Logging_Strategy_Test", "tests\Logging_Strategy_Test_vc10.vcxproj", "{637774A1-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MEM_Stream_Test", "tests\MEM_Stream_Test_vc10.vcxproj", "{77EBBFC1-FECA-1BAD-2431-8A1100722433}"
- ProjectSection(ProjectDependencies) = postProject
- {47BC56ED-FECA-1BAD-6757-8A6300006755} = {47BC56ED-FECA-1BAD-6757-8A6300006755}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MM_Shared_Memory_Test", "tests\MM_Shared_Memory_Test_vc10.vcxproj", "{22F24DC8-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_NonBlocking_Connect_Test", "tests\MT_NonBlocking_Connect_Test_vc10.vcxproj", "{B8480FB0-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_Reactor_Timer_Test", "tests\MT_Reactor_Timer_Test_vc10.vcxproj", "{3260374D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_Reactor_Upcall_Test", "tests\MT_Reactor_Upcall_Test_vc10.vcxproj", "{518F9F2B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_Ref_Counted_Event_Handler_Test", "tests\MT_Ref_Counted_Event_Handler_Test_vc10.vcxproj", "{4F87D6F7-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_Reference_Counted_Notify_Test", "tests\MT_Reference_Counted_Notify_Test_vc10.vcxproj", "{E6B1F618-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_SOCK_Test", "tests\MT_SOCK_Test_vc10.vcxproj", "{2ED72803-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Malloc_Test", "tests\Malloc_Test_vc10.vcxproj", "{8306C04F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Manual_Event_Test", "tests\Manual_Event_Test_vc10.vcxproj", "{82185432-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Map_Manager_Test", "tests\Map_Manager_Test_vc10.vcxproj", "{4C9614F0-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Map_Test", "tests\Map_Test_vc10.vcxproj", "{34E7334B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Max_Default_Port_Test_IPV6", "tests\Max_Default_Port_Test_IPV6_vc10.vcxproj", "{777203E0-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Max_Default_Port_Test", "tests\Max_Default_Port_Test_vc10.vcxproj", "{F5E705C6-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mem_Map_Test", "tests\Mem_Map_Test_vc10.vcxproj", "{0C173300-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Memcpy_Test", "tests\Memcpy_Test_vc10.vcxproj", "{87182A4F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Block_Large_Copy_Test", "tests\Message_Block_Large_Copy_Test_vc10.vcxproj", "{EF6E83F2-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Block_Test", "tests\Message_Block_Test_vc10.vcxproj", "{CB215F5B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Queue_Notifications_Test", "tests\Message_Queue_Notifications_Test_vc10.vcxproj", "{FE3A26D9-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Queue_Test_Ex", "tests\Message_Queue_Test_Ex_vc10.vcxproj", "{C4177A79-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Queue_Test", "tests\Message_Queue_Test_vc10.vcxproj", "{D9BA315B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Missing_Svc_Conf_Test", "tests\Missing_Svc_Conf_Test_vc10.vcxproj", "{1A0DFBB5-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Monotonic_Manual_Event_Test", "tests\Monotonic_Manual_Event_Test_vc10.vcxproj", "{54907DB9-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Monotonic_Message_Queue_Test", "tests\Monotonic_Message_Queue_Test_vc10.vcxproj", "{B138A9E6-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Monotonic_Task_Test", "tests\Monotonic_Task_Test_vc10.vcxproj", "{E70221C0-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Multicast_Test_IPV6", "tests\Multicast_Test_IPV6_vc10.vcxproj", "{FC1CE235-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Multicast_Test", "tests\Multicast_Test_vc10.vcxproj", "{1BFA5D70-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Multihomed_INET_Addr_Test_IPV6", "tests\Multihomed_INET_Addr_Test_IPV6_vc10.vcxproj", "{CA465956-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Multihomed_INET_Addr_Test", "tests\Multihomed_INET_Addr_Test_vc10.vcxproj", "{B04C6E15-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Naming_Test", "tests\Naming_Test_vc10.vcxproj", "{B313D44F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Network_Adapters_Test", "tests\Network_Adapters_Test_vc10.vcxproj", "{620AEFBB-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "New_Fail_Test", "tests\New_Fail_Test_vc10.vcxproj", "{1FABABC9-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "NonBlocking_Conn_Test", "tests\NonBlocking_Conn_Test_vc10.vcxproj", "{BB5C843A-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Notification_Queue_Unit_Test", "tests\Notification_Queue_Unit_Test_vc10.vcxproj", "{45DE2142-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Notify_Performance_Test", "tests\Notify_Performance_Test_vc10.vcxproj", "{6376AA6C-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "OS_Test", "tests\OS_Test_vc10.vcxproj", "{34A8F04B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Object_Manager_Flipping_Test", "tests\Object_Manager_Flipping_Test_vc10.vcxproj", "{18E5B4BF-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Object_Manager_Test", "tests\Object_Manager_Test_vc10.vcxproj", "{D81E30F4-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Obstack_Test", "tests\Obstack_Test_vc10.vcxproj", "{608B0802-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "OrdMultiSet_Test", "tests\OrdMultiSet_Test_vc10.vcxproj", "{862137E8-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Pipe_Test", "tests\Pipe_Test_vc10.vcxproj", "{31C2364B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Priority_Buffer_Test", "tests\Priority_Buffer_Test_vc10.vcxproj", "{282892D7-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Priority_Reactor_Test", "tests\Priority_Reactor_Test_vc10.vcxproj", "{FBA0E89B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Priority_Task_Test", "tests\Priority_Task_Test_vc10.vcxproj", "{A9C58CA8-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Scatter_Gather_Test", "tests\Proactor_Scatter_Gather_Test_vc10.vcxproj", "{3E957B1D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Test_IPV6", "tests\Proactor_Test_IPV6_vc10.vcxproj", "{68E7637D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Test", "tests\Proactor_Test_vc10.vcxproj", "{A3EED43F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Timer_Test", "tests\Proactor_Timer_Test_vc10.vcxproj", "{E2C033C9-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_UDP_Test", "tests\Proactor_UDP_Test_vc10.vcxproj", "{B679D409-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Env_Test", "tests\Process_Env_Test_vc10.vcxproj", "{72488C19-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Manager_Test", "tests\Process_Manager_Test_vc10.vcxproj", "{058F37A7-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Manual_Event_Test", "tests\Process_Manual_Event_Test_vc10.vcxproj", "{E86CC116-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Mutex_Test", "tests\Process_Mutex_Test_vc10.vcxproj", "{D9C7290D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Semaphore_Test", "tests\Process_Semaphore_Test_vc10.vcxproj", "{0002E439-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Strategy_Test", "tests\Process_Strategy_Test_vc10.vcxproj", "{E7AB357C-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Test", "tests\Process_Test_vc10.vcxproj", "{7DFE101C-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RB_Tree_Test", "tests\RB_Tree_Test_vc10.vcxproj", "{4E98661D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RW_Process_Mutex_Test", "tests\RW_Process_Mutex_Test_vc10.vcxproj", "{29C72C7F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Dispatch_Order_Test_Dev_Poll", "tests\Reactor_Dispatch_Order_Test_Dev_Poll_vc10.vcxproj", "{9C98AD50-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Dispatch_Order_Test", "tests\Reactor_Dispatch_Order_Test_vc10.vcxproj", "{E1DC3B68-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Exceptions_Test", "tests\Reactor_Exceptions_Test_vc10.vcxproj", "{6E2BAD6D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Fairness_Test", "tests\Reactor_Fairness_Test_vc10.vcxproj", "{A4066E0F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Notification_Queue_Test", "tests\Reactor_Notification_Queue_Test_vc10.vcxproj", "{B5B6828B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Notify_Test", "tests\Reactor_Notify_Test_vc10.vcxproj", "{FFF76235-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Performance_Test", "tests\Reactor_Performance_Test_vc10.vcxproj", "{F8261501-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Registration_Test", "tests\Reactor_Registration_Test_vc10.vcxproj", "{0D83A720-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Remove_Resume_Test_Dev_Poll", "tests\Reactor_Remove_Resume_Test_Dev_Poll_vc10.vcxproj", "{EF6957B6-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Remove_Resume_Test", "tests\Reactor_Remove_Resume_Test_vc10.vcxproj", "{86E324C6-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Timer_Test", "tests\Reactor_Timer_Test_vc10.vcxproj", "{C26033CC-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactors_Test", "tests\Reactors_Test_vc10.vcxproj", "{40840508-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reader_Writer_Test", "tests\Reader_Writer_Test_vc10.vcxproj", "{64795331-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Recursive_Condition_Bug_Test", "tests\Recursive_Condition_Bug_Test_vc10.vcxproj", "{2EA41430-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Recursive_Condition_Test", "tests\Recursive_Condition_Test_vc10.vcxproj", "{44D74CF6-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Recursive_Mutex_Test", "tests\Recursive_Mutex_Test_vc10.vcxproj", "{BAAB251F-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Refcounted_Auto_Ptr_Test", "tests\Refcounted_Auto_Ptr_Test_vc10.vcxproj", "{277C4A71-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Refcounted_Event_Handler_Test_DevPoll", "tests\Refcounted_Event_Handler_Test_DevPoll_vc10.vcxproj", "{619D55B1-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reference_Counted_Event_Handler_Test", "tests\Reference_Counted_Event_Handler_Test_vc10.vcxproj", "{7B224AC0-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reverse_Lock_Test", "tests\Reverse_Lock_Test_vc10.vcxproj", "{3A470A1E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Connector_Test", "tests\SOCK_Connector_Test_vc10.vcxproj", "{CC9064D6-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Dgram_Bcast_Test", "tests\SOCK_Dgram_Bcast_Test_vc10.vcxproj", "{FE481648-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Dgram_Test", "tests\SOCK_Dgram_Test_vc10.vcxproj", "{86AD5535-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Netlink_Test", "tests\SOCK_Netlink_Test_vc10.vcxproj", "{1378A6F3-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_SEQPACK_SCTP_Test", "tests\SOCK_SEQPACK_SCTP_Test_vc10.vcxproj", "{34AA50AB-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Send_Recv_Test_IPV6", "tests\SOCK_Send_Recv_Test_IPV6_vc10.vcxproj", "{2C78048B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Send_Recv_Test", "tests\SOCK_Send_Recv_Test_vc10.vcxproj", "{5591B076-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Test_IPv6", "tests\SOCK_Test_IPv6_vc10.vcxproj", "{8FAE40E2-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Test", "tests\SOCK_Test_vc10.vcxproj", "{31D7284B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_Test", "tests\SPIPE_Test_vc10.vcxproj", "{62E0164B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SString_Test", "tests\SString_Test_vc10.vcxproj", "{77E3D41D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Shared_Memory_Test", "tests\SV_Shared_Memory_Test_vc10.vcxproj", "{22F24C33-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Semaphore_Test", "tests\Semaphore_Test_vc10.vcxproj", "{52444370-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sendfile_Test", "tests\Sendfile_Test_vc10.vcxproj", "{B6A3F318-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Config_DLL", "tests\Service_Config_DLL_vc10.vcxproj", "{F8915692-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Config_Stream_DLL", "tests\Service_Config_Stream_DLL_vc10.vcxproj", "{B213B165-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Config_Stream_Test", "tests\Service_Config_Stream_Test_vc10.vcxproj", "{97522E31-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Config_Test", "tests\Service_Config_Test_vc10.vcxproj", "{3F7C5145-FECA-1BAD-2431-8A1100722433}"
- {F8915692-FECA-1BAD-2431-8A1100722433} = {F8915692-FECA-1BAD-2431-8A1100722433}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sig_Handlers_Test", "tests\Sig_Handlers_Test_vc10.vcxproj", "{B3512BAC-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Signal_Test", "tests\Signal_Test_vc10.vcxproj", "{6BB42F4E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sigset_Ops_Test", "tests\Sigset_Ops_Test_vc10.vcxproj", "{15117F4E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Simple_Message_Block_Test", "tests\Simple_Message_Block_Test_vc10.vcxproj", "{3E7EF9FB-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Singleton_Test", "tests\Singleton_Test_vc10.vcxproj", "{2E8E98B3-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Stack_Trace_Test", "tests\Stack_Trace_Test_vc10.vcxproj", "{97BF2115-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Handler_Test", "tests\Svc_Handler_Test_vc10.vcxproj", "{4CD277F5-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TP_Reactor_Test", "tests\TP_Reactor_Test_vc10.vcxproj", "{03EBC4EF-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TSS_Static_Test", "tests\TSS_Static_Test_vc10.vcxproj", "{76CBB621-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TSS_Test", "tests\TSS_Test_vc10.vcxproj", "{34FD304B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Task_Ex_Test", "tests\Task_Ex_Test_vc10.vcxproj", "{51477B19-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Task_Test", "tests\Task_Test_vc10.vcxproj", "{318A084B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Task_Wait_Test", "tests\Task_Wait_Test_vc10.vcxproj", "{DEBBE52E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Test_Output", "tests\Test_Output_vc10.vcxproj", "{40EDEECF-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Attrs_Test", "tests\Thread_Attrs_Test_vc10.vcxproj", "{87B0433A-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Creation_Threshold_Test", "tests\Thread_Creation_Threshold_Test_vc10.vcxproj", "{09C5437D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Manager_Test", "tests\Thread_Manager_Test_vc10.vcxproj", "{639E00F5-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Mutex_Test", "tests\Thread_Mutex_Test_vc10.vcxproj", "{8BA1383A-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Pool_Reactor_Resume_Test", "tests\Thread_Pool_Reactor_Resume_Test_vc10.vcxproj", "{443878E8-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Pool_Reactor_Test", "tests\Thread_Pool_Reactor_Test_vc10.vcxproj", "{19D5BCD8-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Pool_Test", "tests\Thread_Pool_Test_vc10.vcxproj", "{2E973B7C-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Timer_Queue_Adapter_Test", "tests\Thread_Timer_Queue_Adapter_Test_vc10.vcxproj", "{C54B9598-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Time_Service_Test", "tests\Time_Service_Test_vc10.vcxproj", "{148CB6EE-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Time_Value_Test", "tests\Time_Value_Test_vc10.vcxproj", "{94D249FB-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timeprobe_Test", "tests\Timeprobe_Test_vc10.vcxproj", "{13E544B0-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Cancellation_Test", "tests\Timer_Cancellation_Test_vc10.vcxproj", "{E9D167C3-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Reference_Counting_Test", "tests\Timer_Queue_Reference_Counting_Test_vc10.vcxproj", "{42BEE677-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Test", "tests\Timer_Queue_Test_vc10.vcxproj", "{92CC9D6C-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Token_Strategy_Test", "tests\Token_Strategy_Test_vc10.vcxproj", "{5B5CE00D-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Tokens_Test", "tests\Tokens_Test_vc10.vcxproj", "{1D7FC04E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UPIPE_SAP_Test", "tests\UPIPE_SAP_Test_vc10.vcxproj", "{740B4307-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UUID_Test", "tests\UUID_Test_vc10.vcxproj", "{31AD874B-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Unbounded_Set_Test", "tests\Unbounded_Set_Test_vc10.vcxproj", "{568DF4C9-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Upgradable_RW_Test", "tests\Upgradable_RW_Test_vc10.vcxproj", "{2CC6636C-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Vector_Test", "tests\Vector_Test_vc10.vcxproj", "{37EED14E-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Test", "tests\WFMO_Reactor_Test_vc10.vcxproj", "{06DC4BEF-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Wild_Match_Test", "tests\Wild_Match_Test_vc10.vcxproj", "{8FCB14EA-FECA-1BAD-2431-8A1100722433}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "websvcs", "websvcs\lib\websvcs_vc10.vcxproj", "{14DB45BD-FECA-1BAD-6AF0-8A634041EBC7}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Websvcs_Test", "websvcs\tests\Websvcs_Test_vc10.vcxproj", "{01EC101A-FECA-1BAD-2431-8A1141F31173}"
- {14DB45BD-FECA-1BAD-6AF0-8A634041EBC7} = {14DB45BD-FECA-1BAD-6AF0-8A634041EBC7}
- EndProjectSection
-EndProject
-Global
- GlobalSection(SolutionConfigurationPlatforms) = preSolution
- Debug|Win32 = Debug|Win32
- Debug|x64 = Debug|x64
- Release|Win32 = Release|Win32
- Release|x64 = Release|x64
- EndGlobalSection
- GlobalSection(ProjectConfigurationPlatforms) = postSolution
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Debug|Win32.ActiveCfg = Debug|Win32
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Debug|Win32.Build.0 = Debug|Win32
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Debug|x64.ActiveCfg = Debug|x64
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Debug|x64.Build.0 = Debug|x64
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Release|Win32.ActiveCfg = Release|Win32
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Release|Win32.Build.0 = Release|Win32
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Release|x64.ActiveCfg = Release|x64
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Release|x64.Build.0 = Release|x64
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|Win32.ActiveCfg = Debug|Win32
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|Win32.Build.0 = Debug|Win32
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|x64.ActiveCfg = Debug|x64
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|x64.Build.0 = Debug|x64
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|Win32.ActiveCfg = Release|Win32
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|Win32.Build.0 = Release|Win32
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|x64.ActiveCfg = Release|x64
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|x64.Build.0 = Release|x64
- {E9FB1B9D-FECA-1BAD-4F93-FEB4C47D7318}.Debug|Win32.ActiveCfg = Debug|Win32
- {E9FB1B9D-FECA-1BAD-4F93-FEB4C47D7318}.Debug|Win32.Build.0 = Debug|Win32
- {E9FB1B9D-FECA-1BAD-4F93-FEB4C47D7318}.Debug|x64.ActiveCfg = Debug|x64
- {E9FB1B9D-FECA-1BAD-4F93-FEB4C47D7318}.Debug|x64.Build.0 = Debug|x64
- {E9FB1B9D-FECA-1BAD-4F93-FEB4C47D7318}.Release|Win32.ActiveCfg = Release|Win32
- {E9FB1B9D-FECA-1BAD-4F93-FEB4C47D7318}.Release|Win32.Build.0 = Release|Win32
- {E9FB1B9D-FECA-1BAD-4F93-FEB4C47D7318}.Release|x64.ActiveCfg = Release|x64
- {E9FB1B9D-FECA-1BAD-4F93-FEB4C47D7318}.Release|x64.Build.0 = Release|x64
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Debug|Win32.ActiveCfg = Debug|Win32
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Debug|Win32.Build.0 = Debug|Win32
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Debug|x64.ActiveCfg = Debug|x64
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Debug|x64.Build.0 = Debug|x64
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Release|Win32.ActiveCfg = Release|Win32
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Release|Win32.Build.0 = Release|Win32
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Release|x64.ActiveCfg = Release|x64
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Release|x64.Build.0 = Release|x64
- {15144841-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.ActiveCfg = Debug|Win32
- {15144841-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.Build.0 = Debug|Win32
- {15144841-FECA-1BAD-2431-8A119E86733F}.Debug|x64.ActiveCfg = Debug|x64
- {15144841-FECA-1BAD-2431-8A119E86733F}.Debug|x64.Build.0 = Debug|x64
- {15144841-FECA-1BAD-2431-8A119E86733F}.Release|Win32.ActiveCfg = Release|Win32
- {15144841-FECA-1BAD-2431-8A119E86733F}.Release|Win32.Build.0 = Release|Win32
- {15144841-FECA-1BAD-2431-8A119E86733F}.Release|x64.ActiveCfg = Release|x64
- {15144841-FECA-1BAD-2431-8A119E86733F}.Release|x64.Build.0 = Release|x64
- {84DB7028-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.ActiveCfg = Debug|Win32
- {84DB7028-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.Build.0 = Debug|Win32
- {84DB7028-FECA-1BAD-2431-8A119E86733F}.Debug|x64.ActiveCfg = Debug|x64
- {84DB7028-FECA-1BAD-2431-8A119E86733F}.Debug|x64.Build.0 = Debug|x64
- {84DB7028-FECA-1BAD-2431-8A119E86733F}.Release|Win32.ActiveCfg = Release|Win32
- {84DB7028-FECA-1BAD-2431-8A119E86733F}.Release|Win32.Build.0 = Release|Win32
- {84DB7028-FECA-1BAD-2431-8A119E86733F}.Release|x64.ActiveCfg = Release|x64
- {84DB7028-FECA-1BAD-2431-8A119E86733F}.Release|x64.Build.0 = Release|x64
- {A18276C8-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.ActiveCfg = Debug|Win32
- {A18276C8-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.Build.0 = Debug|Win32
- {A18276C8-FECA-1BAD-2431-8A119E86733F}.Debug|x64.ActiveCfg = Debug|x64
- {A18276C8-FECA-1BAD-2431-8A119E86733F}.Debug|x64.Build.0 = Debug|x64
- {A18276C8-FECA-1BAD-2431-8A119E86733F}.Release|Win32.ActiveCfg = Release|Win32
- {A18276C8-FECA-1BAD-2431-8A119E86733F}.Release|Win32.Build.0 = Release|Win32
- {A18276C8-FECA-1BAD-2431-8A119E86733F}.Release|x64.ActiveCfg = Release|x64
- {A18276C8-FECA-1BAD-2431-8A119E86733F}.Release|x64.Build.0 = Release|x64
- {613B4532-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.ActiveCfg = Debug|Win32
- {613B4532-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.Build.0 = Debug|Win32
- {613B4532-FECA-1BAD-2431-8A119E86733F}.Debug|x64.ActiveCfg = Debug|x64
- {613B4532-FECA-1BAD-2431-8A119E86733F}.Debug|x64.Build.0 = Debug|x64
- {613B4532-FECA-1BAD-2431-8A119E86733F}.Release|Win32.ActiveCfg = Release|Win32
- {613B4532-FECA-1BAD-2431-8A119E86733F}.Release|Win32.Build.0 = Release|Win32
- {613B4532-FECA-1BAD-2431-8A119E86733F}.Release|x64.ActiveCfg = Release|x64
- {613B4532-FECA-1BAD-2431-8A119E86733F}.Release|x64.Build.0 = Release|x64
- {3F2C569B-FECA-1BAD-22FE-8A6433D1CA9B}.Debug|Win32.ActiveCfg = Debug|Win32
- {3F2C569B-FECA-1BAD-22FE-8A6433D1CA9B}.Debug|Win32.Build.0 = Debug|Win32
- {3F2C569B-FECA-1BAD-22FE-8A6433D1CA9B}.Debug|x64.ActiveCfg = Debug|x64
- {3F2C569B-FECA-1BAD-22FE-8A6433D1CA9B}.Debug|x64.Build.0 = Debug|x64
- {3F2C569B-FECA-1BAD-22FE-8A6433D1CA9B}.Release|Win32.ActiveCfg = Release|Win32
- {3F2C569B-FECA-1BAD-22FE-8A6433D1CA9B}.Release|Win32.Build.0 = Release|Win32
- {3F2C569B-FECA-1BAD-22FE-8A6433D1CA9B}.Release|x64.ActiveCfg = Release|x64
- {3F2C569B-FECA-1BAD-22FE-8A6433D1CA9B}.Release|x64.Build.0 = Release|x64
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Debug|Win32.ActiveCfg = Debug|Win32
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Debug|Win32.Build.0 = Debug|Win32
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Debug|x64.ActiveCfg = Debug|x64
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Debug|x64.Build.0 = Debug|x64
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Release|Win32.ActiveCfg = Release|Win32
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Release|Win32.Build.0 = Release|Win32
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Release|x64.ActiveCfg = Release|x64
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Release|x64.Build.0 = Release|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.ActiveCfg = Debug|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.Build.0 = Debug|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.ActiveCfg = Debug|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.Build.0 = Debug|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.ActiveCfg = Release|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.Build.0 = Release|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.ActiveCfg = Release|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.Build.0 = Release|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.ActiveCfg = Debug|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.Build.0 = Debug|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.ActiveCfg = Debug|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.Build.0 = Debug|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.ActiveCfg = Release|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.Build.0 = Release|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|x64.ActiveCfg = Release|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|x64.Build.0 = Release|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.ActiveCfg = Debug|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.Build.0 = Debug|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.ActiveCfg = Debug|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.Build.0 = Debug|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.ActiveCfg = Release|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.Build.0 = Release|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|x64.ActiveCfg = Release|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|x64.Build.0 = Release|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.ActiveCfg = Debug|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.Build.0 = Debug|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.ActiveCfg = Debug|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.Build.0 = Debug|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.ActiveCfg = Release|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.Build.0 = Release|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|x64.ActiveCfg = Release|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|x64.Build.0 = Release|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.ActiveCfg = Debug|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.Build.0 = Debug|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.ActiveCfg = Debug|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.Build.0 = Debug|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.ActiveCfg = Release|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.Build.0 = Release|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|x64.ActiveCfg = Release|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|x64.Build.0 = Release|x64
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {204D0425-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {204D0425-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {204D0425-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {204D0425-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {204D0425-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {204D0425-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {204D0425-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {204D0425-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {286C3525-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {286C3525-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {286C3525-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {286C3525-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {286C3525-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {286C3525-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {286C3525-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {286C3525-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|Win32.ActiveCfg = Debug|Win32
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|Win32.Build.0 = Debug|Win32
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|x64.ActiveCfg = Debug|x64
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|x64.Build.0 = Debug|x64
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|Win32.ActiveCfg = Release|Win32
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|Win32.Build.0 = Release|Win32
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|x64.ActiveCfg = Release|x64
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|x64.Build.0 = Release|x64
- {8DCD31F2-FECA-1BAD-B9D0-9C126E572303}.Debug|Win32.ActiveCfg = Debug|Win32
- {8DCD31F2-FECA-1BAD-B9D0-9C126E572303}.Debug|Win32.Build.0 = Debug|Win32
- {8DCD31F2-FECA-1BAD-B9D0-9C126E572303}.Debug|x64.ActiveCfg = Debug|x64
- {8DCD31F2-FECA-1BAD-B9D0-9C126E572303}.Debug|x64.Build.0 = Debug|x64
- {8DCD31F2-FECA-1BAD-B9D0-9C126E572303}.Release|Win32.ActiveCfg = Release|Win32
- {8DCD31F2-FECA-1BAD-B9D0-9C126E572303}.Release|Win32.Build.0 = Release|Win32
- {8DCD31F2-FECA-1BAD-B9D0-9C126E572303}.Release|x64.ActiveCfg = Release|x64
- {8DCD31F2-FECA-1BAD-B9D0-9C126E572303}.Release|x64.Build.0 = Release|x64
- {008C56ED-FECA-1BAD-4104-8A6369AD5684}.Debug|Win32.ActiveCfg = Debug|Win32
- {008C56ED-FECA-1BAD-4104-8A6369AD5684}.Debug|Win32.Build.0 = Debug|Win32
- {008C56ED-FECA-1BAD-4104-8A6369AD5684}.Debug|x64.ActiveCfg = Debug|x64
- {008C56ED-FECA-1BAD-4104-8A6369AD5684}.Debug|x64.Build.0 = Debug|x64
- {008C56ED-FECA-1BAD-4104-8A6369AD5684}.Release|Win32.ActiveCfg = Release|Win32
- {008C56ED-FECA-1BAD-4104-8A6369AD5684}.Release|Win32.Build.0 = Release|Win32
- {008C56ED-FECA-1BAD-4104-8A6369AD5684}.Release|x64.ActiveCfg = Release|x64
- {008C56ED-FECA-1BAD-4104-8A6369AD5684}.Release|x64.Build.0 = Release|x64
- {C21C56AB-FECA-1BAD-2D2D-8A679AD55509}.Debug|Win32.ActiveCfg = Debug|Win32
- {C21C56AB-FECA-1BAD-2D2D-8A679AD55509}.Debug|Win32.Build.0 = Debug|Win32
- {C21C56AB-FECA-1BAD-2D2D-8A679AD55509}.Debug|x64.ActiveCfg = Debug|x64
- {C21C56AB-FECA-1BAD-2D2D-8A679AD55509}.Debug|x64.Build.0 = Debug|x64
- {C21C56AB-FECA-1BAD-2D2D-8A679AD55509}.Release|Win32.ActiveCfg = Release|Win32
- {C21C56AB-FECA-1BAD-2D2D-8A679AD55509}.Release|Win32.Build.0 = Release|Win32
- {C21C56AB-FECA-1BAD-2D2D-8A679AD55509}.Release|x64.ActiveCfg = Release|x64
- {C21C56AB-FECA-1BAD-2D2D-8A679AD55509}.Release|x64.Build.0 = Release|x64
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Debug|Win32.ActiveCfg = Debug|Win32
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Debug|Win32.Build.0 = Debug|Win32
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Debug|x64.ActiveCfg = Debug|x64
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Debug|x64.Build.0 = Debug|x64
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Release|Win32.ActiveCfg = Release|Win32
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Release|Win32.Build.0 = Release|Win32
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Release|x64.ActiveCfg = Release|x64
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Release|x64.Build.0 = Release|x64
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Debug|Win32.ActiveCfg = Debug|Win32
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Debug|Win32.Build.0 = Debug|Win32
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Debug|x64.ActiveCfg = Debug|x64
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Debug|x64.Build.0 = Debug|x64
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Release|Win32.ActiveCfg = Release|Win32
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Release|Win32.Build.0 = Release|Win32
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Release|x64.ActiveCfg = Release|x64
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Release|x64.Build.0 = Release|x64
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Debug|Win32.ActiveCfg = Debug|Win32
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Debug|Win32.Build.0 = Debug|Win32
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Debug|x64.ActiveCfg = Debug|x64
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Debug|x64.Build.0 = Debug|x64
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Release|Win32.ActiveCfg = Release|Win32
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Release|Win32.Build.0 = Release|Win32
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Release|x64.ActiveCfg = Release|x64
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Release|x64.Build.0 = Release|x64
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.ActiveCfg = Debug|Win32
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.Build.0 = Debug|Win32
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Debug|x64.ActiveCfg = Debug|x64
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Debug|x64.Build.0 = Debug|x64
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Release|Win32.ActiveCfg = Release|Win32
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Release|Win32.Build.0 = Release|Win32
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Release|x64.ActiveCfg = Release|x64
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Release|x64.Build.0 = Release|x64
- {17692659-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.ActiveCfg = Debug|Win32
- {17692659-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.Build.0 = Debug|Win32
- {17692659-FECA-1BAD-007E-8A67757B007A}.Debug|x64.ActiveCfg = Debug|x64
- {17692659-FECA-1BAD-007E-8A67757B007A}.Debug|x64.Build.0 = Debug|x64
- {17692659-FECA-1BAD-007E-8A67757B007A}.Release|Win32.ActiveCfg = Release|Win32
- {17692659-FECA-1BAD-007E-8A67757B007A}.Release|Win32.Build.0 = Release|Win32
- {17692659-FECA-1BAD-007E-8A67757B007A}.Release|x64.ActiveCfg = Release|x64
- {17692659-FECA-1BAD-007E-8A67757B007A}.Release|x64.Build.0 = Release|x64
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Debug|Win32.ActiveCfg = Debug|Win32
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Debug|Win32.Build.0 = Debug|Win32
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Debug|x64.ActiveCfg = Debug|x64
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Debug|x64.Build.0 = Debug|x64
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Release|Win32.ActiveCfg = Release|Win32
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Release|Win32.Build.0 = Release|Win32
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Release|x64.ActiveCfg = Release|x64
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Release|x64.Build.0 = Release|x64
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Debug|Win32.ActiveCfg = Debug|Win32
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Debug|Win32.Build.0 = Debug|Win32
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Debug|x64.ActiveCfg = Debug|x64
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Debug|x64.Build.0 = Debug|x64
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Release|Win32.ActiveCfg = Release|Win32
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Release|Win32.Build.0 = Release|Win32
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Release|x64.ActiveCfg = Release|x64
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Release|x64.Build.0 = Release|x64
- {067840CB-FECA-1BAD-216B-EB0100066773}.Debug|Win32.ActiveCfg = Debug|Win32
- {067840CB-FECA-1BAD-216B-EB0100066773}.Debug|Win32.Build.0 = Debug|Win32
- {067840CB-FECA-1BAD-216B-EB0100066773}.Debug|x64.ActiveCfg = Debug|x64
- {067840CB-FECA-1BAD-216B-EB0100066773}.Debug|x64.Build.0 = Debug|x64
- {067840CB-FECA-1BAD-216B-EB0100066773}.Release|Win32.ActiveCfg = Release|Win32
- {067840CB-FECA-1BAD-216B-EB0100066773}.Release|Win32.Build.0 = Release|Win32
- {067840CB-FECA-1BAD-216B-EB0100066773}.Release|x64.ActiveCfg = Release|x64
- {067840CB-FECA-1BAD-216B-EB0100066773}.Release|x64.Build.0 = Release|x64
- {7FCD34C8-FECA-1BAD-216B-EB0100066773}.Debug|Win32.ActiveCfg = Debug|Win32
- {7FCD34C8-FECA-1BAD-216B-EB0100066773}.Debug|Win32.Build.0 = Debug|Win32
- {7FCD34C8-FECA-1BAD-216B-EB0100066773}.Debug|x64.ActiveCfg = Debug|x64
- {7FCD34C8-FECA-1BAD-216B-EB0100066773}.Debug|x64.Build.0 = Debug|x64
- {7FCD34C8-FECA-1BAD-216B-EB0100066773}.Release|Win32.ActiveCfg = Release|Win32
- {7FCD34C8-FECA-1BAD-216B-EB0100066773}.Release|Win32.Build.0 = Release|Win32
- {7FCD34C8-FECA-1BAD-216B-EB0100066773}.Release|x64.ActiveCfg = Release|x64
- {7FCD34C8-FECA-1BAD-216B-EB0100066773}.Release|x64.Build.0 = Release|x64
- {40ED3A0E-FECA-1BAD-6320-8A6461A17566}.Debug|Win32.ActiveCfg = Debug|Win32
- {40ED3A0E-FECA-1BAD-6320-8A6461A17566}.Debug|Win32.Build.0 = Debug|Win32
- {40ED3A0E-FECA-1BAD-6320-8A6461A17566}.Debug|x64.ActiveCfg = Debug|x64
- {40ED3A0E-FECA-1BAD-6320-8A6461A17566}.Debug|x64.Build.0 = Debug|x64
- {40ED3A0E-FECA-1BAD-6320-8A6461A17566}.Release|Win32.ActiveCfg = Release|Win32
- {40ED3A0E-FECA-1BAD-6320-8A6461A17566}.Release|Win32.Build.0 = Release|Win32
- {40ED3A0E-FECA-1BAD-6320-8A6461A17566}.Release|x64.ActiveCfg = Release|x64
- {40ED3A0E-FECA-1BAD-6320-8A6461A17566}.Release|x64.Build.0 = Release|x64
- {16BA989C-FECA-1BAD-6320-8A6461A17566}.Debug|Win32.ActiveCfg = Debug|Win32
- {16BA989C-FECA-1BAD-6320-8A6461A17566}.Debug|Win32.Build.0 = Debug|Win32
- {16BA989C-FECA-1BAD-6320-8A6461A17566}.Debug|x64.ActiveCfg = Debug|x64
- {16BA989C-FECA-1BAD-6320-8A6461A17566}.Debug|x64.Build.0 = Debug|x64
- {16BA989C-FECA-1BAD-6320-8A6461A17566}.Release|Win32.ActiveCfg = Release|Win32
- {16BA989C-FECA-1BAD-6320-8A6461A17566}.Release|Win32.Build.0 = Release|Win32
- {16BA989C-FECA-1BAD-6320-8A6461A17566}.Release|x64.ActiveCfg = Release|x64
- {16BA989C-FECA-1BAD-6320-8A6461A17566}.Release|x64.Build.0 = Release|x64
- {557C3240-FECA-1BAD-945B-8C296561D98E}.Debug|Win32.ActiveCfg = Debug|Win32
- {557C3240-FECA-1BAD-945B-8C296561D98E}.Debug|Win32.Build.0 = Debug|Win32
- {557C3240-FECA-1BAD-945B-8C296561D98E}.Debug|x64.ActiveCfg = Debug|x64
- {557C3240-FECA-1BAD-945B-8C296561D98E}.Debug|x64.Build.0 = Debug|x64
- {557C3240-FECA-1BAD-945B-8C296561D98E}.Release|Win32.ActiveCfg = Release|Win32
- {557C3240-FECA-1BAD-945B-8C296561D98E}.Release|Win32.Build.0 = Release|Win32
- {557C3240-FECA-1BAD-945B-8C296561D98E}.Release|x64.ActiveCfg = Release|x64
- {557C3240-FECA-1BAD-945B-8C296561D98E}.Release|x64.Build.0 = Release|x64
- {DA99C340-FECA-1BAD-EF85-EF1657C132F1}.Debug|Win32.ActiveCfg = Debug|Win32
- {DA99C340-FECA-1BAD-EF85-EF1657C132F1}.Debug|Win32.Build.0 = Debug|Win32
- {DA99C340-FECA-1BAD-EF85-EF1657C132F1}.Debug|x64.ActiveCfg = Debug|x64
- {DA99C340-FECA-1BAD-EF85-EF1657C132F1}.Debug|x64.Build.0 = Debug|x64
- {DA99C340-FECA-1BAD-EF85-EF1657C132F1}.Release|Win32.ActiveCfg = Release|Win32
- {DA99C340-FECA-1BAD-EF85-EF1657C132F1}.Release|Win32.Build.0 = Release|Win32
- {DA99C340-FECA-1BAD-EF85-EF1657C132F1}.Release|x64.ActiveCfg = Release|x64
- {DA99C340-FECA-1BAD-EF85-EF1657C132F1}.Release|x64.Build.0 = Release|x64
- {F6EAD3C8-FECA-1BAD-5020-8D317F23EE66}.Debug|Win32.ActiveCfg = Debug|Win32
- {F6EAD3C8-FECA-1BAD-5020-8D317F23EE66}.Debug|Win32.Build.0 = Debug|Win32
- {F6EAD3C8-FECA-1BAD-5020-8D317F23EE66}.Debug|x64.ActiveCfg = Debug|x64
- {F6EAD3C8-FECA-1BAD-5020-8D317F23EE66}.Debug|x64.Build.0 = Debug|x64
- {F6EAD3C8-FECA-1BAD-5020-8D317F23EE66}.Release|Win32.ActiveCfg = Release|Win32
- {F6EAD3C8-FECA-1BAD-5020-8D317F23EE66}.Release|Win32.Build.0 = Release|Win32
- {F6EAD3C8-FECA-1BAD-5020-8D317F23EE66}.Release|x64.ActiveCfg = Release|x64
- {F6EAD3C8-FECA-1BAD-5020-8D317F23EE66}.Release|x64.Build.0 = Release|x64
- {52DC56A7-FECA-1BAD-5020-8D317F23EE66}.Debug|Win32.ActiveCfg = Debug|Win32
- {52DC56A7-FECA-1BAD-5020-8D317F23EE66}.Debug|Win32.Build.0 = Debug|Win32
- {52DC56A7-FECA-1BAD-5020-8D317F23EE66}.Debug|x64.ActiveCfg = Debug|x64
- {52DC56A7-FECA-1BAD-5020-8D317F23EE66}.Debug|x64.Build.0 = Debug|x64
- {52DC56A7-FECA-1BAD-5020-8D317F23EE66}.Release|Win32.ActiveCfg = Release|Win32
- {52DC56A7-FECA-1BAD-5020-8D317F23EE66}.Release|Win32.Build.0 = Release|Win32
- {52DC56A7-FECA-1BAD-5020-8D317F23EE66}.Release|x64.ActiveCfg = Release|x64
- {52DC56A7-FECA-1BAD-5020-8D317F23EE66}.Release|x64.Build.0 = Release|x64
- {05BC5238-FECA-1BAD-3377-8A0C67CCAF11}.Debug|Win32.ActiveCfg = Debug|Win32
- {05BC5238-FECA-1BAD-3377-8A0C67CCAF11}.Debug|Win32.Build.0 = Debug|Win32
- {05BC5238-FECA-1BAD-3377-8A0C67CCAF11}.Debug|x64.ActiveCfg = Debug|x64
- {05BC5238-FECA-1BAD-3377-8A0C67CCAF11}.Debug|x64.Build.0 = Debug|x64
- {05BC5238-FECA-1BAD-3377-8A0C67CCAF11}.Release|Win32.ActiveCfg = Release|Win32
- {05BC5238-FECA-1BAD-3377-8A0C67CCAF11}.Release|Win32.Build.0 = Release|Win32
- {05BC5238-FECA-1BAD-3377-8A0C67CCAF11}.Release|x64.ActiveCfg = Release|x64
- {05BC5238-FECA-1BAD-3377-8A0C67CCAF11}.Release|x64.Build.0 = Release|x64
- {30CC520D-FECA-1BAD-6000-8A0F467CFFC7}.Debug|Win32.ActiveCfg = Debug|Win32
- {30CC520D-FECA-1BAD-6000-8A0F467CFFC7}.Debug|Win32.Build.0 = Debug|Win32
- {30CC520D-FECA-1BAD-6000-8A0F467CFFC7}.Debug|x64.ActiveCfg = Debug|x64
- {30CC520D-FECA-1BAD-6000-8A0F467CFFC7}.Debug|x64.Build.0 = Debug|x64
- {30CC520D-FECA-1BAD-6000-8A0F467CFFC7}.Release|Win32.ActiveCfg = Release|Win32
- {30CC520D-FECA-1BAD-6000-8A0F467CFFC7}.Release|Win32.Build.0 = Release|Win32
- {30CC520D-FECA-1BAD-6000-8A0F467CFFC7}.Release|x64.ActiveCfg = Release|x64
- {30CC520D-FECA-1BAD-6000-8A0F467CFFC7}.Release|x64.Build.0 = Release|x64
- {50CAD382-FECA-1BAD-6001-8A0F66EDDE47}.Debug|Win32.ActiveCfg = Debug|Win32
- {50CAD382-FECA-1BAD-6001-8A0F66EDDE47}.Debug|Win32.Build.0 = Debug|Win32
- {50CAD382-FECA-1BAD-6001-8A0F66EDDE47}.Debug|x64.ActiveCfg = Debug|x64
- {50CAD382-FECA-1BAD-6001-8A0F66EDDE47}.Debug|x64.Build.0 = Debug|x64
- {50CAD382-FECA-1BAD-6001-8A0F66EDDE47}.Release|Win32.ActiveCfg = Release|Win32
- {50CAD382-FECA-1BAD-6001-8A0F66EDDE47}.Release|Win32.Build.0 = Release|Win32
- {50CAD382-FECA-1BAD-6001-8A0F66EDDE47}.Release|x64.ActiveCfg = Release|x64
- {50CAD382-FECA-1BAD-6001-8A0F66EDDE47}.Release|x64.Build.0 = Release|x64
- {30DC520D-FECA-1BAD-6001-8A0F66EDDE47}.Debug|Win32.ActiveCfg = Debug|Win32
- {30DC520D-FECA-1BAD-6001-8A0F66EDDE47}.Debug|Win32.Build.0 = Debug|Win32
- {30DC520D-FECA-1BAD-6001-8A0F66EDDE47}.Debug|x64.ActiveCfg = Debug|x64
- {30DC520D-FECA-1BAD-6001-8A0F66EDDE47}.Debug|x64.Build.0 = Debug|x64
- {30DC520D-FECA-1BAD-6001-8A0F66EDDE47}.Release|Win32.ActiveCfg = Release|Win32
- {30DC520D-FECA-1BAD-6001-8A0F66EDDE47}.Release|Win32.Build.0 = Release|Win32
- {30DC520D-FECA-1BAD-6001-8A0F66EDDE47}.Release|x64.ActiveCfg = Release|x64
- {30DC520D-FECA-1BAD-6001-8A0F66EDDE47}.Release|x64.Build.0 = Release|x64
- {E4BE157B-FECA-1BAD-6223-DAF371906421}.Debug|Win32.ActiveCfg = Debug|Win32
- {E4BE157B-FECA-1BAD-6223-DAF371906421}.Debug|Win32.Build.0 = Debug|Win32
- {E4BE157B-FECA-1BAD-6223-DAF371906421}.Debug|x64.ActiveCfg = Debug|x64
- {E4BE157B-FECA-1BAD-6223-DAF371906421}.Debug|x64.Build.0 = Debug|x64
- {E4BE157B-FECA-1BAD-6223-DAF371906421}.Release|Win32.ActiveCfg = Release|Win32
- {E4BE157B-FECA-1BAD-6223-DAF371906421}.Release|Win32.Build.0 = Release|Win32
- {E4BE157B-FECA-1BAD-6223-DAF371906421}.Release|x64.ActiveCfg = Release|x64
- {E4BE157B-FECA-1BAD-6223-DAF371906421}.Release|x64.Build.0 = Release|x64
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Debug|Win32.ActiveCfg = Debug|Win32
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Debug|Win32.Build.0 = Debug|Win32
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Debug|x64.ActiveCfg = Debug|x64
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Debug|x64.Build.0 = Debug|x64
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Release|Win32.ActiveCfg = Release|Win32
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Release|Win32.Build.0 = Release|Win32
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Release|x64.ActiveCfg = Release|x64
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Release|x64.Build.0 = Release|x64
- {42CB7110-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
- {42CB7110-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
- {42CB7110-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
- {42CB7110-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
- {42CB7110-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
- {42CB7110-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
- {42CB7110-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
- {42CB7110-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
- {42AC3310-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
- {42AC3310-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
- {42AC3310-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
- {42AC3310-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
- {42AC3310-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
- {42AC3310-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
- {42AC3310-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
- {42AC3310-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
- {42C82010-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
- {42C82010-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
- {42C82010-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
- {42C82010-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
- {42C82010-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
- {42C82010-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
- {42C82010-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
- {42C82010-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
- {37CAA97C-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
- {37CAA97C-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
- {37CAA97C-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
- {37CAA97C-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
- {37CAA97C-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
- {37CAA97C-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
- {37CAA97C-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
- {37CAA97C-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
- {42AC3910-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
- {42AC3910-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
- {42AC3910-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
- {42AC3910-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
- {42AC3910-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
- {42AC3910-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
- {42AC3910-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
- {42AC3910-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
- {42AAB310-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
- {42AAB310-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
- {42AAB310-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
- {42AAB310-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
- {42AAB310-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
- {42AAB310-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
- {42AAB310-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
- {42AAB310-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
- {42AC2010-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
- {42AC2010-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
- {42AC2010-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
- {42AC2010-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
- {42AC2010-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
- {42AC2010-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
- {42AC2010-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
- {42AC2010-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
- {42DB1510-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
- {42DB1510-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
- {42DB1510-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
- {42DB1510-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
- {42DB1510-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
- {42DB1510-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
- {42DB1510-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
- {42DB1510-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
- {42DE2F10-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
- {42DE2F10-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
- {42DE2F10-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
- {42DE2F10-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
- {42DE2F10-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
- {42DE2F10-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
- {42DE2F10-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
- {42DE2F10-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
- {42AC2410-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
- {42AC2410-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
- {42AC2410-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
- {42AC2410-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
- {42AC2410-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
- {42AC2410-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
- {42AC2410-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
- {42AC2410-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
- {047112AA-FECA-1BAD-314B-5E27D22340B9}.Debug|Win32.ActiveCfg = Debug|Win32
- {047112AA-FECA-1BAD-314B-5E27D22340B9}.Debug|Win32.Build.0 = Debug|Win32
- {047112AA-FECA-1BAD-314B-5E27D22340B9}.Debug|x64.ActiveCfg = Debug|x64
- {047112AA-FECA-1BAD-314B-5E27D22340B9}.Debug|x64.Build.0 = Debug|x64
- {047112AA-FECA-1BAD-314B-5E27D22340B9}.Release|Win32.ActiveCfg = Release|Win32
- {047112AA-FECA-1BAD-314B-5E27D22340B9}.Release|Win32.Build.0 = Release|Win32
- {047112AA-FECA-1BAD-314B-5E27D22340B9}.Release|x64.ActiveCfg = Release|x64
- {047112AA-FECA-1BAD-314B-5E27D22340B9}.Release|x64.Build.0 = Release|x64
- {25C9D2DA-FECA-1BAD-3350-D2205825444D}.Debug|Win32.ActiveCfg = Debug|Win32
- {25C9D2DA-FECA-1BAD-3350-D2205825444D}.Debug|Win32.Build.0 = Debug|Win32
- {25C9D2DA-FECA-1BAD-3350-D2205825444D}.Debug|x64.ActiveCfg = Debug|x64
- {25C9D2DA-FECA-1BAD-3350-D2205825444D}.Debug|x64.Build.0 = Debug|x64
- {25C9D2DA-FECA-1BAD-3350-D2205825444D}.Release|Win32.ActiveCfg = Release|Win32
- {25C9D2DA-FECA-1BAD-3350-D2205825444D}.Release|Win32.Build.0 = Release|Win32
- {25C9D2DA-FECA-1BAD-3350-D2205825444D}.Release|x64.ActiveCfg = Release|x64
- {25C9D2DA-FECA-1BAD-3350-D2205825444D}.Release|x64.Build.0 = Release|x64
- {47B934A1-FECA-1BAD-A757-FC47A624E189}.Debug|Win32.ActiveCfg = Debug|Win32
- {47B934A1-FECA-1BAD-A757-FC47A624E189}.Debug|Win32.Build.0 = Debug|Win32
- {47B934A1-FECA-1BAD-A757-FC47A624E189}.Debug|x64.ActiveCfg = Debug|x64
- {47B934A1-FECA-1BAD-A757-FC47A624E189}.Debug|x64.Build.0 = Debug|x64
- {47B934A1-FECA-1BAD-A757-FC47A624E189}.Release|Win32.ActiveCfg = Release|Win32
- {47B934A1-FECA-1BAD-A757-FC47A624E189}.Release|Win32.Build.0 = Release|Win32
- {47B934A1-FECA-1BAD-A757-FC47A624E189}.Release|x64.ActiveCfg = Release|x64
- {47B934A1-FECA-1BAD-A757-FC47A624E189}.Release|x64.Build.0 = Release|x64
- {5F0C56EF-FECA-1BAD-64FC-8A63000064FE}.Debug|Win32.ActiveCfg = Debug|Win32
- {5F0C56EF-FECA-1BAD-64FC-8A63000064FE}.Debug|Win32.Build.0 = Debug|Win32
- {5F0C56EF-FECA-1BAD-64FC-8A63000064FE}.Debug|x64.ActiveCfg = Debug|x64
- {5F0C56EF-FECA-1BAD-64FC-8A63000064FE}.Debug|x64.Build.0 = Debug|x64
- {5F0C56EF-FECA-1BAD-64FC-8A63000064FE}.Release|Win32.ActiveCfg = Release|Win32
- {5F0C56EF-FECA-1BAD-64FC-8A63000064FE}.Release|Win32.Build.0 = Release|Win32
- {5F0C56EF-FECA-1BAD-64FC-8A63000064FE}.Release|x64.ActiveCfg = Release|x64
- {5F0C56EF-FECA-1BAD-64FC-8A63000064FE}.Release|x64.Build.0 = Release|x64
- {4CCC56ED-FECA-1BAD-1A31-155B449A6390}.Debug|Win32.ActiveCfg = Debug|Win32
- {4CCC56ED-FECA-1BAD-1A31-155B449A6390}.Debug|Win32.Build.0 = Debug|Win32
- {4CCC56ED-FECA-1BAD-1A31-155B449A6390}.Debug|x64.ActiveCfg = Debug|x64
- {4CCC56ED-FECA-1BAD-1A31-155B449A6390}.Debug|x64.Build.0 = Debug|x64
- {4CCC56ED-FECA-1BAD-1A31-155B449A6390}.Release|Win32.ActiveCfg = Release|Win32
- {4CCC56ED-FECA-1BAD-1A31-155B449A6390}.Release|Win32.Build.0 = Release|Win32
- {4CCC56ED-FECA-1BAD-1A31-155B449A6390}.Release|x64.ActiveCfg = Release|x64
- {4CCC56ED-FECA-1BAD-1A31-155B449A6390}.Release|x64.Build.0 = Release|x64
- {551C56E9-FECA-1BAD-1A31-155B449A6390}.Debug|Win32.ActiveCfg = Debug|Win32
- {551C56E9-FECA-1BAD-1A31-155B449A6390}.Debug|Win32.Build.0 = Debug|Win32
- {551C56E9-FECA-1BAD-1A31-155B449A6390}.Debug|x64.ActiveCfg = Debug|x64
- {551C56E9-FECA-1BAD-1A31-155B449A6390}.Debug|x64.Build.0 = Debug|x64
- {551C56E9-FECA-1BAD-1A31-155B449A6390}.Release|Win32.ActiveCfg = Release|Win32
- {551C56E9-FECA-1BAD-1A31-155B449A6390}.Release|Win32.Build.0 = Release|Win32
- {551C56E9-FECA-1BAD-1A31-155B449A6390}.Release|x64.ActiveCfg = Release|x64
- {551C56E9-FECA-1BAD-1A31-155B449A6390}.Release|x64.Build.0 = Release|x64
- {188778D7-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.ActiveCfg = Debug|Win32
- {188778D7-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.Build.0 = Debug|Win32
- {188778D7-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.ActiveCfg = Debug|x64
- {188778D7-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.Build.0 = Debug|x64
- {188778D7-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.ActiveCfg = Release|Win32
- {188778D7-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.Build.0 = Release|Win32
- {188778D7-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.ActiveCfg = Release|x64
- {188778D7-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.Build.0 = Release|x64
- {095D6AC0-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.ActiveCfg = Debug|Win32
- {095D6AC0-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.Build.0 = Debug|Win32
- {095D6AC0-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.ActiveCfg = Debug|x64
- {095D6AC0-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.Build.0 = Debug|x64
- {095D6AC0-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.ActiveCfg = Release|Win32
- {095D6AC0-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.Build.0 = Release|Win32
- {095D6AC0-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.ActiveCfg = Release|x64
- {095D6AC0-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.Build.0 = Release|x64
- {A9242712-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.ActiveCfg = Debug|Win32
- {A9242712-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.Build.0 = Debug|Win32
- {A9242712-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.ActiveCfg = Debug|x64
- {A9242712-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.Build.0 = Debug|x64
- {A9242712-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.ActiveCfg = Release|Win32
- {A9242712-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.Build.0 = Release|Win32
- {A9242712-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.ActiveCfg = Release|x64
- {A9242712-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.Build.0 = Release|x64
- {97A844F2-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.ActiveCfg = Debug|Win32
- {97A844F2-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.Build.0 = Debug|Win32
- {97A844F2-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.ActiveCfg = Debug|x64
- {97A844F2-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.Build.0 = Debug|x64
- {97A844F2-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.ActiveCfg = Release|Win32
- {97A844F2-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.Build.0 = Release|Win32
- {97A844F2-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.ActiveCfg = Release|x64
- {97A844F2-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.Build.0 = Release|x64
- {3CB6FFBF-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {3CB6FFBF-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {3CB6FFBF-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {3CB6FFBF-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {3CB6FFBF-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {3CB6FFBF-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {3CB6FFBF-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {3CB6FFBF-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {567C528C-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {567C528C-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {567C528C-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {567C528C-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {567C528C-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {567C528C-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {567C528C-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {567C528C-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {A9C04CB4-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {A9C04CB4-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {A9C04CB4-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {A9C04CB4-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {A9C04CB4-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {A9C04CB4-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {A9C04CB4-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {A9C04CB4-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {936F819C-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {936F819C-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {936F819C-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {936F819C-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {936F819C-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {936F819C-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {936F819C-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {936F819C-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {F4AC1663-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {F4AC1663-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {F4AC1663-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {F4AC1663-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {F4AC1663-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {F4AC1663-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {F4AC1663-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {F4AC1663-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {28D737B1-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {28D737B1-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {28D737B1-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {28D737B1-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {28D737B1-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {28D737B1-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {28D737B1-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {28D737B1-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {8C34A590-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {8C34A590-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {8C34A590-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {8C34A590-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {8C34A590-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {8C34A590-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {8C34A590-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {8C34A590-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {22DC00DB-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {22DC00DB-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {22DC00DB-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {22DC00DB-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {22DC00DB-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {22DC00DB-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {22DC00DB-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {22DC00DB-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {A53B149F-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {A53B149F-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {A53B149F-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {A53B149F-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {A53B149F-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {A53B149F-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {A53B149F-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {A53B149F-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {53B9314A-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {53B9314A-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {53B9314A-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {53B9314A-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {53B9314A-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {53B9314A-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {53B9314A-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {53B9314A-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {33DC56BC-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {33DC56BC-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {33DC56BC-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {33DC56BC-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {33DC56BC-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {33DC56BC-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {33DC56BC-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {33DC56BC-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {4CDC02CE-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {4CDC02CE-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
- {4CDC02CE-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
- {4CDC02CE-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
- {4CDC02CE-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
- {4CDC02CE-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
- {4CDC02CE-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
- {4CDC02CE-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
- {BE1CBFB0-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {BE1CBFB0-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {BE1CBFB0-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {BE1CBFB0-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {BE1CBFB0-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {BE1CBFB0-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {BE1CBFB0-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {BE1CBFB0-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {2B244656-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {2B244656-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {2B244656-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {2B244656-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {2B244656-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {2B244656-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {2B244656-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {2B244656-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {39B6F242-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {39B6F242-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {39B6F242-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {39B6F242-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {39B6F242-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {39B6F242-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {39B6F242-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {39B6F242-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {B6F9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {B6F9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {B6F9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {B6F9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {B6F9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {B6F9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {B6F9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {B6F9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {B6C9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {B6C9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {B6C9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {B6C9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {B6C9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {B6C9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {B6C9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {B6C9094F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {735CF299-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {735CF299-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {735CF299-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {735CF299-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {735CF299-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {735CF299-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {735CF299-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {735CF299-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {439BF98B-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {439BF98B-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {439BF98B-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {439BF98B-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {439BF98B-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {439BF98B-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {439BF98B-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {439BF98B-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {35E92C1F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {35E92C1F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {35E92C1F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {35E92C1F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {35E92C1F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {35E92C1F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {35E92C1F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {35E92C1F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {B85FB33E-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {B85FB33E-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {B85FB33E-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {B85FB33E-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {B85FB33E-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {B85FB33E-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {B85FB33E-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {B85FB33E-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {509CEC78-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {509CEC78-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {509CEC78-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {509CEC78-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {509CEC78-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {509CEC78-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {509CEC78-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {509CEC78-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {5F1E495D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {5F1E495D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {5F1E495D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {5F1E495D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {5F1E495D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {5F1E495D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {5F1E495D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {5F1E495D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {F262F3C6-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {F262F3C6-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {F262F3C6-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {F262F3C6-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {F262F3C6-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {F262F3C6-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {F262F3C6-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {F262F3C6-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {E0E6E68D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {E0E6E68D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {E0E6E68D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {E0E6E68D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {E0E6E68D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {E0E6E68D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {E0E6E68D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {E0E6E68D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {0237D2D8-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {0237D2D8-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {0237D2D8-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {0237D2D8-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {0237D2D8-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {0237D2D8-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {0237D2D8-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {0237D2D8-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {679CF2CB-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {679CF2CB-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {679CF2CB-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {679CF2CB-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {679CF2CB-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {679CF2CB-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {679CF2CB-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {679CF2CB-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {EBCCF20C-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {EBCCF20C-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {EBCCF20C-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {EBCCF20C-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {EBCCF20C-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {EBCCF20C-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {EBCCF20C-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {EBCCF20C-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {D0DD1AE7-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {D0DD1AE7-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {D0DD1AE7-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {D0DD1AE7-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {D0DD1AE7-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {D0DD1AE7-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {D0DD1AE7-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {D0DD1AE7-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {5CB9ED98-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
- {5CB9ED98-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
- {5CB9ED98-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
- {5CB9ED98-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
- {5CB9ED98-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
- {5CB9ED98-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
- {5CB9ED98-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
- {5CB9ED98-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
- {2FF8C4DD-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.ActiveCfg = Debug|Win32
- {2FF8C4DD-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.Build.0 = Debug|Win32
- {2FF8C4DD-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.ActiveCfg = Debug|x64
- {2FF8C4DD-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.Build.0 = Debug|x64
- {2FF8C4DD-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.ActiveCfg = Release|Win32
- {2FF8C4DD-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.Build.0 = Release|Win32
- {2FF8C4DD-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.ActiveCfg = Release|x64
- {2FF8C4DD-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.Build.0 = Release|x64
- {2F0FE10D-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.ActiveCfg = Debug|Win32
- {2F0FE10D-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.Build.0 = Debug|Win32
- {2F0FE10D-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.ActiveCfg = Debug|x64
- {2F0FE10D-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.Build.0 = Debug|x64
- {2F0FE10D-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.ActiveCfg = Release|Win32
- {2F0FE10D-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.Build.0 = Release|Win32
- {2F0FE10D-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.ActiveCfg = Release|x64
- {2F0FE10D-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.Build.0 = Release|x64
- {65F66E19-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.ActiveCfg = Debug|Win32
- {65F66E19-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.Build.0 = Debug|Win32
- {65F66E19-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.ActiveCfg = Debug|x64
- {65F66E19-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.Build.0 = Debug|x64
- {65F66E19-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.ActiveCfg = Release|Win32
- {65F66E19-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.Build.0 = Release|Win32
- {65F66E19-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.ActiveCfg = Release|x64
- {65F66E19-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.Build.0 = Release|x64
- {A7B170F4-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.ActiveCfg = Debug|Win32
- {A7B170F4-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.Build.0 = Debug|Win32
- {A7B170F4-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.ActiveCfg = Debug|x64
- {A7B170F4-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.Build.0 = Debug|x64
- {A7B170F4-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.ActiveCfg = Release|Win32
- {A7B170F4-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.Build.0 = Release|Win32
- {A7B170F4-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.ActiveCfg = Release|x64
- {A7B170F4-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.Build.0 = Release|x64
- {47647440-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.ActiveCfg = Debug|Win32
- {47647440-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.Build.0 = Debug|Win32
- {47647440-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.ActiveCfg = Debug|x64
- {47647440-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.Build.0 = Debug|x64
- {47647440-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.ActiveCfg = Release|Win32
- {47647440-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.Build.0 = Release|Win32
- {47647440-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.ActiveCfg = Release|x64
- {47647440-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.Build.0 = Release|x64
- {FFAEE1A3-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.ActiveCfg = Debug|Win32
- {FFAEE1A3-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.Build.0 = Debug|Win32
- {FFAEE1A3-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.ActiveCfg = Debug|x64
- {FFAEE1A3-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.Build.0 = Debug|x64
- {FFAEE1A3-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.ActiveCfg = Release|Win32
- {FFAEE1A3-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.Build.0 = Release|Win32
- {FFAEE1A3-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.ActiveCfg = Release|x64
- {FFAEE1A3-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.Build.0 = Release|x64
- {C69D6135-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.ActiveCfg = Debug|Win32
- {C69D6135-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.Build.0 = Debug|Win32
- {C69D6135-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.ActiveCfg = Debug|x64
- {C69D6135-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.Build.0 = Debug|x64
- {C69D6135-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.ActiveCfg = Release|Win32
- {C69D6135-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.Build.0 = Release|Win32
- {C69D6135-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.ActiveCfg = Release|x64
- {C69D6135-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.Build.0 = Release|x64
- {43A57540-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.ActiveCfg = Debug|Win32
- {43A57540-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.Build.0 = Debug|Win32
- {43A57540-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.ActiveCfg = Debug|x64
- {43A57540-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.Build.0 = Debug|x64
- {43A57540-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.ActiveCfg = Release|Win32
- {43A57540-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.Build.0 = Release|Win32
- {43A57540-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.ActiveCfg = Release|x64
- {43A57540-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.Build.0 = Release|x64
- {C87BBBBF-FECA-1BAD-4287-FEF4D6EEE17E}.Debug|Win32.ActiveCfg = Debug|Win32
- {C87BBBBF-FECA-1BAD-4287-FEF4D6EEE17E}.Debug|Win32.Build.0 = Debug|Win32
- {C87BBBBF-FECA-1BAD-4287-FEF4D6EEE17E}.Debug|x64.ActiveCfg = Debug|x64
- {C87BBBBF-FECA-1BAD-4287-FEF4D6EEE17E}.Debug|x64.Build.0 = Debug|x64
- {C87BBBBF-FECA-1BAD-4287-FEF4D6EEE17E}.Release|Win32.ActiveCfg = Release|Win32
- {C87BBBBF-FECA-1BAD-4287-FEF4D6EEE17E}.Release|Win32.Build.0 = Release|Win32
- {C87BBBBF-FECA-1BAD-4287-FEF4D6EEE17E}.Release|x64.ActiveCfg = Release|x64
- {C87BBBBF-FECA-1BAD-4287-FEF4D6EEE17E}.Release|x64.Build.0 = Release|x64
- {605A4309-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.ActiveCfg = Debug|Win32
- {605A4309-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.Build.0 = Debug|Win32
- {605A4309-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.ActiveCfg = Debug|x64
- {605A4309-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.Build.0 = Debug|x64
- {605A4309-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.ActiveCfg = Release|Win32
- {605A4309-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.Build.0 = Release|Win32
- {605A4309-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.ActiveCfg = Release|x64
- {605A4309-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.Build.0 = Release|x64
- {633A426C-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.ActiveCfg = Debug|Win32
- {633A426C-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.Build.0 = Debug|Win32
- {633A426C-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.ActiveCfg = Debug|x64
- {633A426C-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.Build.0 = Debug|x64
- {633A426C-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.ActiveCfg = Release|Win32
- {633A426C-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.Build.0 = Release|Win32
- {633A426C-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.ActiveCfg = Release|x64
- {633A426C-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.Build.0 = Release|x64
- {A748383F-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.ActiveCfg = Debug|Win32
- {A748383F-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.Build.0 = Debug|Win32
- {A748383F-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.ActiveCfg = Debug|x64
- {A748383F-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.Build.0 = Debug|x64
- {A748383F-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.ActiveCfg = Release|Win32
- {A748383F-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.Build.0 = Release|Win32
- {A748383F-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.ActiveCfg = Release|x64
- {A748383F-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.Build.0 = Release|x64
- {710C53AF-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.ActiveCfg = Debug|Win32
- {710C53AF-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.Build.0 = Debug|Win32
- {710C53AF-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.ActiveCfg = Debug|x64
- {710C53AF-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.Build.0 = Debug|x64
- {710C53AF-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.ActiveCfg = Release|Win32
- {710C53AF-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.Build.0 = Release|Win32
- {710C53AF-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.ActiveCfg = Release|x64
- {710C53AF-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.Build.0 = Release|x64
- {29AC1346-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
- {29AC1346-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
- {29AC1346-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
- {29AC1346-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
- {29AC1346-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
- {29AC1346-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
- {29AC1346-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
- {29AC1346-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
- {619E35CB-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
- {619E35CB-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
- {619E35CB-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
- {619E35CB-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
- {619E35CB-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
- {619E35CB-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
- {619E35CB-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
- {619E35CB-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
- {229012CF-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
- {229012CF-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
- {229012CF-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
- {229012CF-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
- {229012CF-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
- {229012CF-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
- {229012CF-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
- {229012CF-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
- {775BA025-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
- {775BA025-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
- {775BA025-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
- {775BA025-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
- {775BA025-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
- {775BA025-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
- {775BA025-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
- {775BA025-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
- {7E9908DA-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
- {7E9908DA-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
- {7E9908DA-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
- {7E9908DA-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
- {7E9908DA-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
- {7E9908DA-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
- {7E9908DA-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
- {7E9908DA-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
- {0679A1F1-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
- {0679A1F1-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
- {0679A1F1-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
- {0679A1F1-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
- {0679A1F1-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
- {0679A1F1-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
- {0679A1F1-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
- {0679A1F1-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
- {B80BE3C3-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
- {B80BE3C3-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
- {B80BE3C3-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
- {B80BE3C3-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
- {B80BE3C3-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
- {B80BE3C3-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
- {B80BE3C3-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
- {B80BE3C3-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
- {D6888D7C-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
- {D6888D7C-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
- {D6888D7C-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
- {D6888D7C-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
- {D6888D7C-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
- {D6888D7C-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
- {D6888D7C-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
- {D6888D7C-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
- {B9DC1D93-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.ActiveCfg = Debug|Win32
- {B9DC1D93-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.Build.0 = Debug|Win32
- {B9DC1D93-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.ActiveCfg = Debug|x64
- {B9DC1D93-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.Build.0 = Debug|x64
- {B9DC1D93-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.ActiveCfg = Release|Win32
- {B9DC1D93-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.Build.0 = Release|Win32
- {B9DC1D93-FECA-1BAD-5E18-93A5247C7980}.Release|x64.ActiveCfg = Release|x64
- {B9DC1D93-FECA-1BAD-5E18-93A5247C7980}.Release|x64.Build.0 = Release|x64
- {A6E8E562-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.ActiveCfg = Debug|Win32
- {A6E8E562-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.Build.0 = Debug|Win32
- {A6E8E562-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.ActiveCfg = Debug|x64
- {A6E8E562-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.Build.0 = Debug|x64
- {A6E8E562-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.ActiveCfg = Release|Win32
- {A6E8E562-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.Build.0 = Release|Win32
- {A6E8E562-FECA-1BAD-5E18-93A5247C7980}.Release|x64.ActiveCfg = Release|x64
- {A6E8E562-FECA-1BAD-5E18-93A5247C7980}.Release|x64.Build.0 = Release|x64
- {BC90ED93-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.ActiveCfg = Debug|Win32
- {BC90ED93-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.Build.0 = Debug|Win32
- {BC90ED93-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.ActiveCfg = Debug|x64
- {BC90ED93-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.Build.0 = Debug|x64
- {BC90ED93-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.ActiveCfg = Release|Win32
- {BC90ED93-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.Build.0 = Release|Win32
- {BC90ED93-FECA-1BAD-5E18-93A5247C7980}.Release|x64.ActiveCfg = Release|x64
- {BC90ED93-FECA-1BAD-5E18-93A5247C7980}.Release|x64.Build.0 = Release|x64
- {7BF5E6A4-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.ActiveCfg = Debug|Win32
- {7BF5E6A4-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.Build.0 = Debug|Win32
- {7BF5E6A4-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.ActiveCfg = Debug|x64
- {7BF5E6A4-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.Build.0 = Debug|x64
- {7BF5E6A4-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.ActiveCfg = Release|Win32
- {7BF5E6A4-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.Build.0 = Release|Win32
- {7BF5E6A4-FECA-1BAD-5E18-93A5247C7980}.Release|x64.ActiveCfg = Release|x64
- {7BF5E6A4-FECA-1BAD-5E18-93A5247C7980}.Release|x64.Build.0 = Release|x64
- {B949D56C-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.ActiveCfg = Debug|Win32
- {B949D56C-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.Build.0 = Debug|Win32
- {B949D56C-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.ActiveCfg = Debug|x64
- {B949D56C-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.Build.0 = Debug|x64
- {B949D56C-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.ActiveCfg = Release|Win32
- {B949D56C-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.Build.0 = Release|Win32
- {B949D56C-FECA-1BAD-5E18-93A5247C7980}.Release|x64.ActiveCfg = Release|x64
- {B949D56C-FECA-1BAD-5E18-93A5247C7980}.Release|x64.Build.0 = Release|x64
- {EC5361AB-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.ActiveCfg = Debug|Win32
- {EC5361AB-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.Build.0 = Debug|Win32
- {EC5361AB-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.ActiveCfg = Debug|x64
- {EC5361AB-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.Build.0 = Debug|x64
- {EC5361AB-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.ActiveCfg = Release|Win32
- {EC5361AB-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.Build.0 = Release|Win32
- {EC5361AB-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.ActiveCfg = Release|x64
- {EC5361AB-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.Build.0 = Release|x64
- {74F9A5EA-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.ActiveCfg = Debug|Win32
- {74F9A5EA-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.Build.0 = Debug|Win32
- {74F9A5EA-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.ActiveCfg = Debug|x64
- {74F9A5EA-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.Build.0 = Debug|x64
- {74F9A5EA-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.ActiveCfg = Release|Win32
- {74F9A5EA-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.Build.0 = Release|Win32
- {74F9A5EA-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.ActiveCfg = Release|x64
- {74F9A5EA-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.Build.0 = Release|x64
- {E73FB16B-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.ActiveCfg = Debug|Win32
- {E73FB16B-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.Build.0 = Debug|Win32
- {E73FB16B-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.ActiveCfg = Debug|x64
- {E73FB16B-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.Build.0 = Debug|x64
- {E73FB16B-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.ActiveCfg = Release|Win32
- {E73FB16B-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.Build.0 = Release|Win32
- {E73FB16B-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.ActiveCfg = Release|x64
- {E73FB16B-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.Build.0 = Release|x64
- {6AE22EC6-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.ActiveCfg = Debug|Win32
- {6AE22EC6-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.Build.0 = Debug|Win32
- {6AE22EC6-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.ActiveCfg = Debug|x64
- {6AE22EC6-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.Build.0 = Debug|x64
- {6AE22EC6-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.ActiveCfg = Release|Win32
- {6AE22EC6-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.Build.0 = Release|Win32
- {6AE22EC6-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.ActiveCfg = Release|x64
- {6AE22EC6-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.Build.0 = Release|x64
- {901909D6-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.ActiveCfg = Debug|Win32
- {901909D6-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.Build.0 = Debug|Win32
- {901909D6-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.ActiveCfg = Debug|x64
- {901909D6-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.Build.0 = Debug|x64
- {901909D6-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.ActiveCfg = Release|Win32
- {901909D6-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.Build.0 = Release|Win32
- {901909D6-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.ActiveCfg = Release|x64
- {901909D6-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.Build.0 = Release|x64
- {C488C49D-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.ActiveCfg = Debug|Win32
- {C488C49D-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.Build.0 = Debug|Win32
- {C488C49D-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.ActiveCfg = Debug|x64
- {C488C49D-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.Build.0 = Debug|x64
- {C488C49D-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.ActiveCfg = Release|Win32
- {C488C49D-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.Build.0 = Release|Win32
- {C488C49D-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.ActiveCfg = Release|x64
- {C488C49D-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.Build.0 = Release|x64
- {12FF38F6-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.ActiveCfg = Debug|Win32
- {12FF38F6-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.Build.0 = Debug|Win32
- {12FF38F6-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.ActiveCfg = Debug|x64
- {12FF38F6-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.Build.0 = Debug|x64
- {12FF38F6-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.ActiveCfg = Release|Win32
- {12FF38F6-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.Build.0 = Release|Win32
- {12FF38F6-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.ActiveCfg = Release|x64
- {12FF38F6-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.Build.0 = Release|x64
- {4EFF3848-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.ActiveCfg = Debug|Win32
- {4EFF3848-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.Build.0 = Debug|Win32
- {4EFF3848-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.ActiveCfg = Debug|x64
- {4EFF3848-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.Build.0 = Debug|x64
- {4EFF3848-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.ActiveCfg = Release|Win32
- {4EFF3848-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.Build.0 = Release|Win32
- {4EFF3848-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.ActiveCfg = Release|x64
- {4EFF3848-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.Build.0 = Release|x64
- {C0FAA659-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.ActiveCfg = Debug|Win32
- {C0FAA659-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.Build.0 = Debug|Win32
- {C0FAA659-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.ActiveCfg = Debug|x64
- {C0FAA659-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.Build.0 = Debug|x64
- {C0FAA659-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.ActiveCfg = Release|Win32
- {C0FAA659-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.Build.0 = Release|Win32
- {C0FAA659-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.ActiveCfg = Release|x64
- {C0FAA659-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.Build.0 = Release|x64
- {528BC2FB-FECA-1BAD-37A1-FE57CE13AD9C}.Debug|Win32.ActiveCfg = Debug|Win32
- {528BC2FB-FECA-1BAD-37A1-FE57CE13AD9C}.Debug|Win32.Build.0 = Debug|Win32
- {528BC2FB-FECA-1BAD-37A1-FE57CE13AD9C}.Debug|x64.ActiveCfg = Debug|x64
- {528BC2FB-FECA-1BAD-37A1-FE57CE13AD9C}.Debug|x64.Build.0 = Debug|x64
- {528BC2FB-FECA-1BAD-37A1-FE57CE13AD9C}.Release|Win32.ActiveCfg = Release|Win32
- {528BC2FB-FECA-1BAD-37A1-FE57CE13AD9C}.Release|Win32.Build.0 = Release|Win32
- {528BC2FB-FECA-1BAD-37A1-FE57CE13AD9C}.Release|x64.ActiveCfg = Release|x64
- {528BC2FB-FECA-1BAD-37A1-FE57CE13AD9C}.Release|x64.Build.0 = Release|x64
- {80877024-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.ActiveCfg = Debug|Win32
- {80877024-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.Build.0 = Debug|Win32
- {80877024-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.ActiveCfg = Debug|x64
- {80877024-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.Build.0 = Debug|x64
- {80877024-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.ActiveCfg = Release|Win32
- {80877024-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.Build.0 = Release|Win32
- {80877024-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.ActiveCfg = Release|x64
- {80877024-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.Build.0 = Release|x64
- {9D29F35B-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.ActiveCfg = Debug|Win32
- {9D29F35B-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.Build.0 = Debug|Win32
- {9D29F35B-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.ActiveCfg = Debug|x64
- {9D29F35B-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.Build.0 = Debug|x64
- {9D29F35B-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.ActiveCfg = Release|Win32
- {9D29F35B-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.Build.0 = Release|Win32
- {9D29F35B-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.ActiveCfg = Release|x64
- {9D29F35B-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.Build.0 = Release|x64
- {0FAD6A94-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.ActiveCfg = Debug|Win32
- {0FAD6A94-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.Build.0 = Debug|Win32
- {0FAD6A94-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.ActiveCfg = Debug|x64
- {0FAD6A94-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.Build.0 = Debug|x64
- {0FAD6A94-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.ActiveCfg = Release|Win32
- {0FAD6A94-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.Build.0 = Release|Win32
- {0FAD6A94-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.ActiveCfg = Release|x64
- {0FAD6A94-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.Build.0 = Release|x64
- {0CAAE3D7-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
- {0CAAE3D7-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
- {0CAAE3D7-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
- {0CAAE3D7-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
- {0CAAE3D7-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
- {0CAAE3D7-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
- {0CAAE3D7-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
- {0CAAE3D7-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
- {1AA9E395-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
- {1AA9E395-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
- {1AA9E395-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
- {1AA9E395-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
- {1AA9E395-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
- {1AA9E395-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
- {1AA9E395-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
- {1AA9E395-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
- {9C2CB16F-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
- {9C2CB16F-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
- {9C2CB16F-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
- {9C2CB16F-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
- {9C2CB16F-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
- {9C2CB16F-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
- {9C2CB16F-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
- {9C2CB16F-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
- {892C56BF-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
- {892C56BF-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
- {892C56BF-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
- {892C56BF-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
- {892C56BF-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
- {892C56BF-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
- {892C56BF-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
- {892C56BF-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
- {B593D20B-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
- {B593D20B-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
- {B593D20B-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
- {B593D20B-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
- {B593D20B-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
- {B593D20B-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
- {B593D20B-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
- {B593D20B-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
- {A099A76E-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
- {A099A76E-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
- {A099A76E-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
- {A099A76E-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
- {A099A76E-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
- {A099A76E-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
- {A099A76E-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
- {A099A76E-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
- {6BD909F1-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
- {6BD909F1-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
- {6BD909F1-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
- {6BD909F1-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
- {6BD909F1-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
- {6BD909F1-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
- {6BD909F1-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
- {6BD909F1-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
- {DD7A0757-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
- {DD7A0757-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
- {DD7A0757-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
- {DD7A0757-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
- {DD7A0757-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
- {DD7A0757-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
- {DD7A0757-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
- {DD7A0757-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
- {72BC53AB-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
- {72BC53AB-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
- {72BC53AB-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
- {72BC53AB-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
- {72BC53AB-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
- {72BC53AB-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
- {72BC53AB-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
- {72BC53AB-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
- {52D844DB-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.ActiveCfg = Debug|Win32
- {52D844DB-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.Build.0 = Debug|Win32
- {52D844DB-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.ActiveCfg = Debug|x64
- {52D844DB-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.Build.0 = Debug|x64
- {52D844DB-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.ActiveCfg = Release|Win32
- {52D844DB-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.Build.0 = Release|Win32
- {52D844DB-FECA-1BAD-EB45-BD55AD295160}.Release|x64.ActiveCfg = Release|x64
- {52D844DB-FECA-1BAD-EB45-BD55AD295160}.Release|x64.Build.0 = Release|x64
- {2BD8657C-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.ActiveCfg = Debug|Win32
- {2BD8657C-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.Build.0 = Debug|Win32
- {2BD8657C-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.ActiveCfg = Debug|x64
- {2BD8657C-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.Build.0 = Debug|x64
- {2BD8657C-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.ActiveCfg = Release|Win32
- {2BD8657C-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.Build.0 = Release|Win32
- {2BD8657C-FECA-1BAD-EB45-BD55AD295160}.Release|x64.ActiveCfg = Release|x64
- {2BD8657C-FECA-1BAD-EB45-BD55AD295160}.Release|x64.Build.0 = Release|x64
- {6996159D-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.ActiveCfg = Debug|Win32
- {6996159D-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.Build.0 = Debug|Win32
- {6996159D-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.ActiveCfg = Debug|x64
- {6996159D-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.Build.0 = Debug|x64
- {6996159D-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.ActiveCfg = Release|Win32
- {6996159D-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.Build.0 = Release|Win32
- {6996159D-FECA-1BAD-EB45-BD55AD295160}.Release|x64.ActiveCfg = Release|x64
- {6996159D-FECA-1BAD-EB45-BD55AD295160}.Release|x64.Build.0 = Release|x64
- {2BDD47A1-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.ActiveCfg = Debug|Win32
- {2BDD47A1-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.Build.0 = Debug|Win32
- {2BDD47A1-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.ActiveCfg = Debug|x64
- {2BDD47A1-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.Build.0 = Debug|x64
- {2BDD47A1-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.ActiveCfg = Release|Win32
- {2BDD47A1-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.Build.0 = Release|Win32
- {2BDD47A1-FECA-1BAD-EB45-BD55AD295160}.Release|x64.ActiveCfg = Release|x64
- {2BDD47A1-FECA-1BAD-EB45-BD55AD295160}.Release|x64.Build.0 = Release|x64
- {DBD861FF-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.ActiveCfg = Debug|Win32
- {DBD861FF-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.Build.0 = Debug|Win32
- {DBD861FF-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.ActiveCfg = Debug|x64
- {DBD861FF-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.Build.0 = Debug|x64
- {DBD861FF-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.ActiveCfg = Release|Win32
- {DBD861FF-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.Build.0 = Release|Win32
- {DBD861FF-FECA-1BAD-EB45-BD55AD295160}.Release|x64.ActiveCfg = Release|x64
- {DBD861FF-FECA-1BAD-EB45-BD55AD295160}.Release|x64.Build.0 = Release|x64
- {AC8ECD1F-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
- {AC8ECD1F-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
- {AC8ECD1F-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
- {AC8ECD1F-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
- {AC8ECD1F-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
- {AC8ECD1F-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
- {AC8ECD1F-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
- {AC8ECD1F-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
- {E2C810BD-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
- {E2C810BD-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
- {E2C810BD-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
- {E2C810BD-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
- {E2C810BD-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
- {E2C810BD-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
- {E2C810BD-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
- {E2C810BD-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
- {326C524B-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
- {326C524B-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
- {326C524B-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
- {326C524B-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
- {326C524B-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
- {326C524B-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
- {326C524B-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
- {326C524B-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
- {85592453-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
- {85592453-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
- {85592453-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
- {85592453-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
- {85592453-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
- {85592453-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
- {85592453-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
- {85592453-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
- {91EFE087-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
- {91EFE087-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
- {91EFE087-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
- {91EFE087-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
- {91EFE087-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
- {91EFE087-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
- {91EFE087-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
- {91EFE087-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
- {06DC56EC-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
- {06DC56EC-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
- {06DC56EC-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
- {06DC56EC-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
- {06DC56EC-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
- {06DC56EC-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
- {06DC56EC-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
- {06DC56EC-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
- {13EB4810-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
- {13EB4810-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
- {13EB4810-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
- {13EB4810-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
- {13EB4810-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
- {13EB4810-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
- {13EB4810-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
- {13EB4810-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
- {29DC0474-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
- {29DC0474-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
- {29DC0474-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
- {29DC0474-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
- {29DC0474-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
- {29DC0474-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
- {29DC0474-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
- {29DC0474-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
- {72FB1409-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
- {72FB1409-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
- {72FB1409-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
- {72FB1409-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
- {72FB1409-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
- {72FB1409-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
- {72FB1409-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
- {72FB1409-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
- {5158FB60-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
- {5158FB60-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
- {5158FB60-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
- {5158FB60-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
- {5158FB60-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
- {5158FB60-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
- {5158FB60-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
- {5158FB60-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
- {53DC16DF-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
- {53DC16DF-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
- {53DC16DF-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
- {53DC16DF-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
- {53DC16DF-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
- {53DC16DF-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
- {53DC16DF-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
- {53DC16DF-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
- {1BCCA964-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
- {1BCCA964-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
- {1BCCA964-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
- {1BCCA964-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
- {1BCCA964-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
- {1BCCA964-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
- {1BCCA964-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
- {1BCCA964-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
- {76CD5838-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
- {76CD5838-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
- {76CD5838-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
- {76CD5838-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
- {76CD5838-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
- {76CD5838-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
- {76CD5838-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
- {76CD5838-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
- {F2D8F4CB-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
- {F2D8F4CB-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
- {F2D8F4CB-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
- {F2D8F4CB-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
- {F2D8F4CB-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
- {F2D8F4CB-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
- {F2D8F4CB-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
- {F2D8F4CB-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
- {743C5293-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.ActiveCfg = Debug|Win32
- {743C5293-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.Build.0 = Debug|Win32
- {743C5293-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.ActiveCfg = Debug|x64
- {743C5293-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.Build.0 = Debug|x64
- {743C5293-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.ActiveCfg = Release|Win32
- {743C5293-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.Build.0 = Release|Win32
- {743C5293-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.ActiveCfg = Release|x64
- {743C5293-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.Build.0 = Release|x64
- {755C56BB-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.ActiveCfg = Debug|Win32
- {755C56BB-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.Build.0 = Debug|Win32
- {755C56BB-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.ActiveCfg = Debug|x64
- {755C56BB-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.Build.0 = Debug|x64
- {755C56BB-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.ActiveCfg = Release|Win32
- {755C56BB-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.Build.0 = Release|Win32
- {755C56BB-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.ActiveCfg = Release|x64
- {755C56BB-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.Build.0 = Release|x64
- {35DC0412-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.ActiveCfg = Debug|Win32
- {35DC0412-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.Build.0 = Debug|Win32
- {35DC0412-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.ActiveCfg = Debug|x64
- {35DC0412-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.Build.0 = Debug|x64
- {35DC0412-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.ActiveCfg = Release|Win32
- {35DC0412-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.Build.0 = Release|Win32
- {35DC0412-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.ActiveCfg = Release|x64
- {35DC0412-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.Build.0 = Release|x64
- {6A2C048C-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.ActiveCfg = Debug|Win32
- {6A2C048C-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.Build.0 = Debug|Win32
- {6A2C048C-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.ActiveCfg = Debug|x64
- {6A2C048C-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.Build.0 = Debug|x64
- {6A2C048C-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.ActiveCfg = Release|Win32
- {6A2C048C-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.Build.0 = Release|Win32
- {6A2C048C-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.ActiveCfg = Release|x64
- {6A2C048C-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.Build.0 = Release|x64
- {DBB4543E-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.ActiveCfg = Debug|Win32
- {DBB4543E-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.Build.0 = Debug|Win32
- {DBB4543E-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.ActiveCfg = Debug|x64
- {DBB4543E-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.Build.0 = Debug|x64
- {DBB4543E-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.ActiveCfg = Release|Win32
- {DBB4543E-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.Build.0 = Release|Win32
- {DBB4543E-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.ActiveCfg = Release|x64
- {DBB4543E-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.Build.0 = Release|x64
- {C8437769-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.ActiveCfg = Debug|Win32
- {C8437769-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.Build.0 = Debug|Win32
- {C8437769-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.ActiveCfg = Debug|x64
- {C8437769-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.Build.0 = Debug|x64
- {C8437769-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.ActiveCfg = Release|Win32
- {C8437769-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.Build.0 = Release|Win32
- {C8437769-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.ActiveCfg = Release|x64
- {C8437769-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.Build.0 = Release|x64
- {E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.ActiveCfg = Debug|Win32
- {E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.Build.0 = Debug|Win32
- {E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.ActiveCfg = Debug|x64
- {E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.Build.0 = Debug|x64
- {E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.ActiveCfg = Release|Win32
- {E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.Build.0 = Release|Win32
- {E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.ActiveCfg = Release|x64
- {E0D444B4-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.Build.0 = Release|x64
- {115DF38E-FECA-1BAD-0396-8A213C52C5E6}.Debug|Win32.ActiveCfg = Debug|Win32
- {115DF38E-FECA-1BAD-0396-8A213C52C5E6}.Debug|Win32.Build.0 = Debug|Win32
- {115DF38E-FECA-1BAD-0396-8A213C52C5E6}.Debug|x64.ActiveCfg = Debug|x64
- {115DF38E-FECA-1BAD-0396-8A213C52C5E6}.Debug|x64.Build.0 = Debug|x64
- {115DF38E-FECA-1BAD-0396-8A213C52C5E6}.Release|Win32.ActiveCfg = Release|Win32
- {115DF38E-FECA-1BAD-0396-8A213C52C5E6}.Release|Win32.Build.0 = Release|Win32
- {115DF38E-FECA-1BAD-0396-8A213C52C5E6}.Release|x64.ActiveCfg = Release|x64
- {115DF38E-FECA-1BAD-0396-8A213C52C5E6}.Release|x64.Build.0 = Release|x64
- {26B503D2-FECA-1BAD-B367-1F304733F83A}.Debug|Win32.ActiveCfg = Debug|Win32
- {26B503D2-FECA-1BAD-B367-1F304733F83A}.Debug|Win32.Build.0 = Debug|Win32
- {26B503D2-FECA-1BAD-B367-1F304733F83A}.Debug|x64.ActiveCfg = Debug|x64
- {26B503D2-FECA-1BAD-B367-1F304733F83A}.Debug|x64.Build.0 = Debug|x64
- {26B503D2-FECA-1BAD-B367-1F304733F83A}.Release|Win32.ActiveCfg = Release|Win32
- {26B503D2-FECA-1BAD-B367-1F304733F83A}.Release|Win32.Build.0 = Release|Win32
- {26B503D2-FECA-1BAD-B367-1F304733F83A}.Release|x64.ActiveCfg = Release|x64
- {26B503D2-FECA-1BAD-B367-1F304733F83A}.Release|x64.Build.0 = Release|x64
- {86DE2A47-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.ActiveCfg = Debug|Win32
- {86DE2A47-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.Build.0 = Debug|Win32
- {86DE2A47-FECA-1BAD-1624-F77E007731F8}.Debug|x64.ActiveCfg = Debug|x64
- {86DE2A47-FECA-1BAD-1624-F77E007731F8}.Debug|x64.Build.0 = Debug|x64
- {86DE2A47-FECA-1BAD-1624-F77E007731F8}.Release|Win32.ActiveCfg = Release|Win32
- {86DE2A47-FECA-1BAD-1624-F77E007731F8}.Release|Win32.Build.0 = Release|Win32
- {86DE2A47-FECA-1BAD-1624-F77E007731F8}.Release|x64.ActiveCfg = Release|x64
- {86DE2A47-FECA-1BAD-1624-F77E007731F8}.Release|x64.Build.0 = Release|x64
- {F679CE5F-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.ActiveCfg = Debug|Win32
- {F679CE5F-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.Build.0 = Debug|Win32
- {F679CE5F-FECA-1BAD-1624-F77E007731F8}.Debug|x64.ActiveCfg = Debug|x64
- {F679CE5F-FECA-1BAD-1624-F77E007731F8}.Debug|x64.Build.0 = Debug|x64
- {F679CE5F-FECA-1BAD-1624-F77E007731F8}.Release|Win32.ActiveCfg = Release|Win32
- {F679CE5F-FECA-1BAD-1624-F77E007731F8}.Release|Win32.Build.0 = Release|Win32
- {F679CE5F-FECA-1BAD-1624-F77E007731F8}.Release|x64.ActiveCfg = Release|x64
- {F679CE5F-FECA-1BAD-1624-F77E007731F8}.Release|x64.Build.0 = Release|x64
- {3ECD46F0-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.ActiveCfg = Debug|Win32
- {3ECD46F0-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.Build.0 = Debug|Win32
- {3ECD46F0-FECA-1BAD-1624-F77E007731F8}.Debug|x64.ActiveCfg = Debug|x64
- {3ECD46F0-FECA-1BAD-1624-F77E007731F8}.Debug|x64.Build.0 = Debug|x64
- {3ECD46F0-FECA-1BAD-1624-F77E007731F8}.Release|Win32.ActiveCfg = Release|Win32
- {3ECD46F0-FECA-1BAD-1624-F77E007731F8}.Release|Win32.Build.0 = Release|Win32
- {3ECD46F0-FECA-1BAD-1624-F77E007731F8}.Release|x64.ActiveCfg = Release|x64
- {3ECD46F0-FECA-1BAD-1624-F77E007731F8}.Release|x64.Build.0 = Release|x64
- {4111B37E-FECA-1BAD-53DA-CAD1A7F87CBD}.Debug|Win32.ActiveCfg = Debug|Win32
- {4111B37E-FECA-1BAD-53DA-CAD1A7F87CBD}.Debug|Win32.Build.0 = Debug|Win32
- {4111B37E-FECA-1BAD-53DA-CAD1A7F87CBD}.Debug|x64.ActiveCfg = Debug|x64
- {4111B37E-FECA-1BAD-53DA-CAD1A7F87CBD}.Debug|x64.Build.0 = Debug|x64
- {4111B37E-FECA-1BAD-53DA-CAD1A7F87CBD}.Release|Win32.ActiveCfg = Release|Win32
- {4111B37E-FECA-1BAD-53DA-CAD1A7F87CBD}.Release|Win32.Build.0 = Release|Win32
- {4111B37E-FECA-1BAD-53DA-CAD1A7F87CBD}.Release|x64.ActiveCfg = Release|x64
- {4111B37E-FECA-1BAD-53DA-CAD1A7F87CBD}.Release|x64.Build.0 = Release|x64
- {402C7D48-FECA-1BAD-150E-88D9A0C7F2AA}.Debug|Win32.ActiveCfg = Debug|Win32
- {402C7D48-FECA-1BAD-150E-88D9A0C7F2AA}.Debug|Win32.Build.0 = Debug|Win32
- {402C7D48-FECA-1BAD-150E-88D9A0C7F2AA}.Debug|x64.ActiveCfg = Debug|x64
- {402C7D48-FECA-1BAD-150E-88D9A0C7F2AA}.Debug|x64.Build.0 = Debug|x64
- {402C7D48-FECA-1BAD-150E-88D9A0C7F2AA}.Release|Win32.ActiveCfg = Release|Win32
- {402C7D48-FECA-1BAD-150E-88D9A0C7F2AA}.Release|Win32.Build.0 = Release|Win32
- {402C7D48-FECA-1BAD-150E-88D9A0C7F2AA}.Release|x64.ActiveCfg = Release|x64
- {402C7D48-FECA-1BAD-150E-88D9A0C7F2AA}.Release|x64.Build.0 = Release|x64
- {77B1F4AC-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
- {77B1F4AC-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
- {77B1F4AC-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
- {77B1F4AC-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
- {77B1F4AC-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
- {77B1F4AC-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
- {77B1F4AC-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
- {77B1F4AC-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
- {817A1848-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
- {817A1848-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
- {817A1848-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
- {817A1848-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
- {817A1848-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
- {817A1848-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
- {817A1848-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
- {817A1848-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
- {E997FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
- {E997FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
- {E997FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
- {E997FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
- {E997FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
- {E997FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
- {E997FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
- {E997FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
- {83BF1DBB-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
- {83BF1DBB-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
- {83BF1DBB-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
- {83BF1DBB-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
- {83BF1DBB-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
- {83BF1DBB-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
- {83BF1DBB-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
- {83BF1DBB-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
- {663FE282-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
- {663FE282-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
- {663FE282-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
- {663FE282-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
- {663FE282-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
- {663FE282-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
- {663FE282-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
- {663FE282-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
- {560013D2-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
- {560013D2-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
- {560013D2-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
- {560013D2-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
- {560013D2-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
- {560013D2-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
- {560013D2-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
- {560013D2-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
- {ED97FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
- {ED97FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
- {ED97FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
- {ED97FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
- {ED97FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
- {ED97FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
- {ED97FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
- {ED97FE09-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
- {71572396-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {71572396-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {71572396-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {71572396-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {71572396-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {71572396-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {71572396-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {71572396-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {2D05C717-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {2D05C717-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {2D05C717-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {2D05C717-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {2D05C717-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {2D05C717-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {2D05C717-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {2D05C717-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {3908C844-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {3908C844-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {3908C844-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {3908C844-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {3908C844-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {3908C844-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {3908C844-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {3908C844-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {4DF6061C-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {4DF6061C-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {4DF6061C-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {4DF6061C-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {4DF6061C-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {4DF6061C-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {4DF6061C-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {4DF6061C-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {71572397-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {71572397-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {71572397-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {71572397-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {71572397-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {71572397-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {71572397-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {71572397-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {C9192888-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {C9192888-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {C9192888-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {C9192888-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {C9192888-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {C9192888-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {C9192888-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {C9192888-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {BF9E69BB-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {BF9E69BB-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {BF9E69BB-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {BF9E69BB-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {BF9E69BB-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {BF9E69BB-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {BF9E69BB-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {BF9E69BB-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {7223E97F-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {7223E97F-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {7223E97F-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {7223E97F-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {7223E97F-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {7223E97F-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {7223E97F-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {7223E97F-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {C66B0109-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {C66B0109-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {C66B0109-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {C66B0109-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {C66B0109-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {C66B0109-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {C66B0109-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {C66B0109-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {F71CCF47-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {F71CCF47-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {F71CCF47-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {F71CCF47-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {F71CCF47-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {F71CCF47-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {F71CCF47-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {F71CCF47-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {79179A2A-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
- {79179A2A-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
- {79179A2A-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
- {79179A2A-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
- {79179A2A-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
- {79179A2A-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
- {79179A2A-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
- {79179A2A-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
- {99B2D4AD-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|Win32.ActiveCfg = Debug|Win32
- {99B2D4AD-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|Win32.Build.0 = Debug|Win32
- {99B2D4AD-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|x64.ActiveCfg = Debug|x64
- {99B2D4AD-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|x64.Build.0 = Debug|x64
- {99B2D4AD-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|Win32.ActiveCfg = Release|Win32
- {99B2D4AD-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|Win32.Build.0 = Release|Win32
- {99B2D4AD-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|x64.ActiveCfg = Release|x64
- {99B2D4AD-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|x64.Build.0 = Release|x64
- {2F08A8E7-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|Win32.ActiveCfg = Debug|Win32
- {2F08A8E7-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|Win32.Build.0 = Debug|Win32
- {2F08A8E7-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|x64.ActiveCfg = Debug|x64
- {2F08A8E7-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|x64.Build.0 = Debug|x64
- {2F08A8E7-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|Win32.ActiveCfg = Release|Win32
- {2F08A8E7-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|Win32.Build.0 = Release|Win32
- {2F08A8E7-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|x64.ActiveCfg = Release|x64
- {2F08A8E7-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|x64.Build.0 = Release|x64
- {638C7358-FECA-1BAD-3D13-3640622B5736}.Debug|Win32.ActiveCfg = Debug|Win32
- {638C7358-FECA-1BAD-3D13-3640622B5736}.Debug|Win32.Build.0 = Debug|Win32
- {638C7358-FECA-1BAD-3D13-3640622B5736}.Debug|x64.ActiveCfg = Debug|x64
- {638C7358-FECA-1BAD-3D13-3640622B5736}.Debug|x64.Build.0 = Debug|x64
- {638C7358-FECA-1BAD-3D13-3640622B5736}.Release|Win32.ActiveCfg = Release|Win32
- {638C7358-FECA-1BAD-3D13-3640622B5736}.Release|Win32.Build.0 = Release|Win32
- {638C7358-FECA-1BAD-3D13-3640622B5736}.Release|x64.ActiveCfg = Release|x64
- {638C7358-FECA-1BAD-3D13-3640622B5736}.Release|x64.Build.0 = Release|x64
- {E8BB71DB-FECA-1BAD-3D13-3640622B5736}.Debug|Win32.ActiveCfg = Debug|Win32
- {E8BB71DB-FECA-1BAD-3D13-3640622B5736}.Debug|Win32.Build.0 = Debug|Win32
- {E8BB71DB-FECA-1BAD-3D13-3640622B5736}.Debug|x64.ActiveCfg = Debug|x64
- {E8BB71DB-FECA-1BAD-3D13-3640622B5736}.Debug|x64.Build.0 = Debug|x64
- {E8BB71DB-FECA-1BAD-3D13-3640622B5736}.Release|Win32.ActiveCfg = Release|Win32
- {E8BB71DB-FECA-1BAD-3D13-3640622B5736}.Release|Win32.Build.0 = Release|Win32
- {E8BB71DB-FECA-1BAD-3D13-3640622B5736}.Release|x64.ActiveCfg = Release|x64
- {E8BB71DB-FECA-1BAD-3D13-3640622B5736}.Release|x64.Build.0 = Release|x64
- {D754F4F2-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
- {D754F4F2-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
- {D754F4F2-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
- {D754F4F2-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
- {D754F4F2-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
- {D754F4F2-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
- {D754F4F2-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
- {D754F4F2-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
- {EC34E478-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
- {EC34E478-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
- {EC34E478-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
- {EC34E478-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
- {EC34E478-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
- {EC34E478-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
- {EC34E478-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
- {EC34E478-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
- {242714F3-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
- {242714F3-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
- {242714F3-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
- {242714F3-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
- {242714F3-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
- {242714F3-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
- {242714F3-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
- {242714F3-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
- {1F470479-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
- {1F470479-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
- {1F470479-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
- {1F470479-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
- {1F470479-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
- {1F470479-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
- {1F470479-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
- {1F470479-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
- {7A8F763D-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
- {7A8F763D-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
- {7A8F763D-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
- {7A8F763D-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
- {7A8F763D-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
- {7A8F763D-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
- {7A8F763D-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
- {7A8F763D-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
- {41EF66B7-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
- {41EF66B7-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
- {41EF66B7-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
- {41EF66B7-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
- {41EF66B7-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
- {41EF66B7-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
- {41EF66B7-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
- {41EF66B7-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
- {9CCFEE11-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
- {9CCFEE11-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
- {9CCFEE11-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
- {9CCFEE11-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
- {9CCFEE11-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
- {9CCFEE11-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
- {9CCFEE11-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
- {9CCFEE11-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
- {A7AFFE9B-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
- {A7AFFE9B-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
- {A7AFFE9B-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
- {A7AFFE9B-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
- {A7AFFE9B-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
- {A7AFFE9B-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
- {A7AFFE9B-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
- {A7AFFE9B-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
- {6F4CDF52-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.ActiveCfg = Debug|Win32
- {6F4CDF52-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.Build.0 = Debug|Win32
- {6F4CDF52-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.ActiveCfg = Debug|x64
- {6F4CDF52-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.Build.0 = Debug|x64
- {6F4CDF52-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.ActiveCfg = Release|Win32
- {6F4CDF52-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.Build.0 = Release|Win32
- {6F4CDF52-FECA-1BAD-408E-8A636A279EF6}.Release|x64.ActiveCfg = Release|x64
- {6F4CDF52-FECA-1BAD-408E-8A636A279EF6}.Release|x64.Build.0 = Release|x64
- {AAE476E8-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.ActiveCfg = Debug|Win32
- {AAE476E8-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.Build.0 = Debug|Win32
- {AAE476E8-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.ActiveCfg = Debug|x64
- {AAE476E8-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.Build.0 = Debug|x64
- {AAE476E8-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.ActiveCfg = Release|Win32
- {AAE476E8-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.Build.0 = Release|Win32
- {AAE476E8-FECA-1BAD-408E-8A636A279EF6}.Release|x64.ActiveCfg = Release|x64
- {AAE476E8-FECA-1BAD-408E-8A636A279EF6}.Release|x64.Build.0 = Release|x64
- {3274CCC0-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.ActiveCfg = Debug|Win32
- {3274CCC0-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.Build.0 = Debug|Win32
- {3274CCC0-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.ActiveCfg = Debug|x64
- {3274CCC0-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.Build.0 = Debug|x64
- {3274CCC0-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.ActiveCfg = Release|Win32
- {3274CCC0-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.Build.0 = Release|Win32
- {3274CCC0-FECA-1BAD-408E-8A636A279EF6}.Release|x64.ActiveCfg = Release|x64
- {3274CCC0-FECA-1BAD-408E-8A636A279EF6}.Release|x64.Build.0 = Release|x64
- {FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|Win32.ActiveCfg = Debug|Win32
- {FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|Win32.Build.0 = Debug|Win32
- {FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|x64.ActiveCfg = Debug|x64
- {FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|x64.Build.0 = Debug|x64
- {FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6}.Release|Win32.ActiveCfg = Release|Win32
- {FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6}.Release|Win32.Build.0 = Release|Win32
- {FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6}.Release|x64.ActiveCfg = Release|x64
- {FD3AD3F2-FECA-1BAD-6856-8E4C79C8CEF6}.Release|x64.Build.0 = Release|x64
- {1BC4074F-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|Win32.ActiveCfg = Debug|Win32
- {1BC4074F-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|Win32.Build.0 = Debug|Win32
- {1BC4074F-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|x64.ActiveCfg = Debug|x64
- {1BC4074F-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|x64.Build.0 = Debug|x64
- {1BC4074F-FECA-1BAD-6856-8E4C79C8CEF6}.Release|Win32.ActiveCfg = Release|Win32
- {1BC4074F-FECA-1BAD-6856-8E4C79C8CEF6}.Release|Win32.Build.0 = Release|Win32
- {1BC4074F-FECA-1BAD-6856-8E4C79C8CEF6}.Release|x64.ActiveCfg = Release|x64
- {1BC4074F-FECA-1BAD-6856-8E4C79C8CEF6}.Release|x64.Build.0 = Release|x64
- {6AD03905-FECA-1BAD-C7A1-4C9D6A84AD84}.Debug|Win32.ActiveCfg = Debug|Win32
- {6AD03905-FECA-1BAD-C7A1-4C9D6A84AD84}.Debug|Win32.Build.0 = Debug|Win32
- {6AD03905-FECA-1BAD-C7A1-4C9D6A84AD84}.Debug|x64.ActiveCfg = Debug|x64
- {6AD03905-FECA-1BAD-C7A1-4C9D6A84AD84}.Debug|x64.Build.0 = Debug|x64
- {6AD03905-FECA-1BAD-C7A1-4C9D6A84AD84}.Release|Win32.ActiveCfg = Release|Win32
- {6AD03905-FECA-1BAD-C7A1-4C9D6A84AD84}.Release|Win32.Build.0 = Release|Win32
- {6AD03905-FECA-1BAD-C7A1-4C9D6A84AD84}.Release|x64.ActiveCfg = Release|x64
- {6AD03905-FECA-1BAD-C7A1-4C9D6A84AD84}.Release|x64.Build.0 = Release|x64
- {51B0298F-FECA-1BAD-6417-4D956B8C0E32}.Debug|Win32.ActiveCfg = Debug|Win32
- {51B0298F-FECA-1BAD-6417-4D956B8C0E32}.Debug|Win32.Build.0 = Debug|Win32
- {51B0298F-FECA-1BAD-6417-4D956B8C0E32}.Debug|x64.ActiveCfg = Debug|x64
- {51B0298F-FECA-1BAD-6417-4D956B8C0E32}.Debug|x64.Build.0 = Debug|x64
- {51B0298F-FECA-1BAD-6417-4D956B8C0E32}.Release|Win32.ActiveCfg = Release|Win32
- {51B0298F-FECA-1BAD-6417-4D956B8C0E32}.Release|Win32.Build.0 = Release|Win32
- {51B0298F-FECA-1BAD-6417-4D956B8C0E32}.Release|x64.ActiveCfg = Release|x64
- {51B0298F-FECA-1BAD-6417-4D956B8C0E32}.Release|x64.Build.0 = Release|x64
- {ACC9A56E-FECA-1BAD-8562-EC4B26346A25}.Debug|Win32.ActiveCfg = Debug|Win32
- {ACC9A56E-FECA-1BAD-8562-EC4B26346A25}.Debug|Win32.Build.0 = Debug|Win32
- {ACC9A56E-FECA-1BAD-8562-EC4B26346A25}.Debug|x64.ActiveCfg = Debug|x64
- {ACC9A56E-FECA-1BAD-8562-EC4B26346A25}.Debug|x64.Build.0 = Debug|x64
- {ACC9A56E-FECA-1BAD-8562-EC4B26346A25}.Release|Win32.ActiveCfg = Release|Win32
- {ACC9A56E-FECA-1BAD-8562-EC4B26346A25}.Release|Win32.Build.0 = Release|Win32
- {ACC9A56E-FECA-1BAD-8562-EC4B26346A25}.Release|x64.ActiveCfg = Release|x64
- {ACC9A56E-FECA-1BAD-8562-EC4B26346A25}.Release|x64.Build.0 = Release|x64
- {97A9B5E4-FECA-1BAD-8562-EC4B26346A25}.Debug|Win32.ActiveCfg = Debug|Win32
- {97A9B5E4-FECA-1BAD-8562-EC4B26346A25}.Debug|Win32.Build.0 = Debug|Win32
- {97A9B5E4-FECA-1BAD-8562-EC4B26346A25}.Debug|x64.ActiveCfg = Debug|x64
- {97A9B5E4-FECA-1BAD-8562-EC4B26346A25}.Debug|x64.Build.0 = Debug|x64
- {97A9B5E4-FECA-1BAD-8562-EC4B26346A25}.Release|Win32.ActiveCfg = Release|Win32
- {97A9B5E4-FECA-1BAD-8562-EC4B26346A25}.Release|Win32.Build.0 = Release|Win32
- {97A9B5E4-FECA-1BAD-8562-EC4B26346A25}.Release|x64.ActiveCfg = Release|x64
- {97A9B5E4-FECA-1BAD-8562-EC4B26346A25}.Release|x64.Build.0 = Release|x64
- {B7A9B0FD-FECA-1BAD-4A76-D4027A608480}.Debug|Win32.ActiveCfg = Debug|Win32
- {B7A9B0FD-FECA-1BAD-4A76-D4027A608480}.Debug|Win32.Build.0 = Debug|Win32
- {B7A9B0FD-FECA-1BAD-4A76-D4027A608480}.Debug|x64.ActiveCfg = Debug|x64
- {B7A9B0FD-FECA-1BAD-4A76-D4027A608480}.Debug|x64.Build.0 = Debug|x64
- {B7A9B0FD-FECA-1BAD-4A76-D4027A608480}.Release|Win32.ActiveCfg = Release|Win32
- {B7A9B0FD-FECA-1BAD-4A76-D4027A608480}.Release|Win32.Build.0 = Release|Win32
- {B7A9B0FD-FECA-1BAD-4A76-D4027A608480}.Release|x64.ActiveCfg = Release|x64
- {B7A9B0FD-FECA-1BAD-4A76-D4027A608480}.Release|x64.Build.0 = Release|x64
- {B7A9B484-FECA-1BAD-DA76-D4457A271480}.Debug|Win32.ActiveCfg = Debug|Win32
- {B7A9B484-FECA-1BAD-DA76-D4457A271480}.Debug|Win32.Build.0 = Debug|Win32
- {B7A9B484-FECA-1BAD-DA76-D4457A271480}.Debug|x64.ActiveCfg = Debug|x64
- {B7A9B484-FECA-1BAD-DA76-D4457A271480}.Debug|x64.Build.0 = Debug|x64
- {B7A9B484-FECA-1BAD-DA76-D4457A271480}.Release|Win32.ActiveCfg = Release|Win32
- {B7A9B484-FECA-1BAD-DA76-D4457A271480}.Release|Win32.Build.0 = Release|Win32
- {B7A9B484-FECA-1BAD-DA76-D4457A271480}.Release|x64.ActiveCfg = Release|x64
- {B7A9B484-FECA-1BAD-DA76-D4457A271480}.Release|x64.Build.0 = Release|x64
- {9CF44627-FECA-1BAD-8564-85690EE67112}.Debug|Win32.ActiveCfg = Debug|Win32
- {9CF44627-FECA-1BAD-8564-85690EE67112}.Debug|Win32.Build.0 = Debug|Win32
- {9CF44627-FECA-1BAD-8564-85690EE67112}.Debug|x64.ActiveCfg = Debug|x64
- {9CF44627-FECA-1BAD-8564-85690EE67112}.Debug|x64.Build.0 = Debug|x64
- {9CF44627-FECA-1BAD-8564-85690EE67112}.Release|Win32.ActiveCfg = Release|Win32
- {9CF44627-FECA-1BAD-8564-85690EE67112}.Release|Win32.Build.0 = Release|Win32
- {9CF44627-FECA-1BAD-8564-85690EE67112}.Release|x64.ActiveCfg = Release|x64
- {9CF44627-FECA-1BAD-8564-85690EE67112}.Release|x64.Build.0 = Release|x64
- {A79456AD-FECA-1BAD-8564-85690EE67112}.Debug|Win32.ActiveCfg = Debug|Win32
- {A79456AD-FECA-1BAD-8564-85690EE67112}.Debug|Win32.Build.0 = Debug|Win32
- {A79456AD-FECA-1BAD-8564-85690EE67112}.Debug|x64.ActiveCfg = Debug|x64
- {A79456AD-FECA-1BAD-8564-85690EE67112}.Debug|x64.Build.0 = Debug|x64
- {A79456AD-FECA-1BAD-8564-85690EE67112}.Release|Win32.ActiveCfg = Release|Win32
- {A79456AD-FECA-1BAD-8564-85690EE67112}.Release|Win32.Build.0 = Release|Win32
- {A79456AD-FECA-1BAD-8564-85690EE67112}.Release|x64.ActiveCfg = Release|x64
- {A79456AD-FECA-1BAD-8564-85690EE67112}.Release|x64.Build.0 = Release|x64
- {ACCFCC4C-FECA-1BAD-8564-85690EE67112}.Debug|Win32.ActiveCfg = Debug|Win32
- {ACCFCC4C-FECA-1BAD-8564-85690EE67112}.Debug|Win32.Build.0 = Debug|Win32
- {ACCFCC4C-FECA-1BAD-8564-85690EE67112}.Debug|x64.ActiveCfg = Debug|x64
- {ACCFCC4C-FECA-1BAD-8564-85690EE67112}.Debug|x64.Build.0 = Debug|x64
- {ACCFCC4C-FECA-1BAD-8564-85690EE67112}.Release|Win32.ActiveCfg = Release|Win32
- {ACCFCC4C-FECA-1BAD-8564-85690EE67112}.Release|Win32.Build.0 = Release|Win32
- {ACCFCC4C-FECA-1BAD-8564-85690EE67112}.Release|x64.ActiveCfg = Release|x64
- {ACCFCC4C-FECA-1BAD-8564-85690EE67112}.Release|x64.Build.0 = Release|x64
- {97AFDCC6-FECA-1BAD-8564-85690EE67112}.Debug|Win32.ActiveCfg = Debug|Win32
- {97AFDCC6-FECA-1BAD-8564-85690EE67112}.Debug|Win32.Build.0 = Debug|Win32
- {97AFDCC6-FECA-1BAD-8564-85690EE67112}.Debug|x64.ActiveCfg = Debug|x64
- {97AFDCC6-FECA-1BAD-8564-85690EE67112}.Debug|x64.Build.0 = Debug|x64
- {97AFDCC6-FECA-1BAD-8564-85690EE67112}.Release|Win32.ActiveCfg = Release|Win32
- {97AFDCC6-FECA-1BAD-8564-85690EE67112}.Release|Win32.Build.0 = Release|Win32
- {97AFDCC6-FECA-1BAD-8564-85690EE67112}.Release|x64.ActiveCfg = Release|x64
- {97AFDCC6-FECA-1BAD-8564-85690EE67112}.Release|x64.Build.0 = Release|x64
- {3E293564-FECA-1BAD-8564-85690EE67112}.Debug|Win32.ActiveCfg = Debug|Win32
- {3E293564-FECA-1BAD-8564-85690EE67112}.Debug|Win32.Build.0 = Debug|Win32
- {3E293564-FECA-1BAD-8564-85690EE67112}.Debug|x64.ActiveCfg = Debug|x64
- {3E293564-FECA-1BAD-8564-85690EE67112}.Debug|x64.Build.0 = Debug|x64
- {3E293564-FECA-1BAD-8564-85690EE67112}.Release|Win32.ActiveCfg = Release|Win32
- {3E293564-FECA-1BAD-8564-85690EE67112}.Release|Win32.Build.0 = Release|Win32
- {3E293564-FECA-1BAD-8564-85690EE67112}.Release|x64.ActiveCfg = Release|x64
- {3E293564-FECA-1BAD-8564-85690EE67112}.Release|x64.Build.0 = Release|x64
- {ACCFCCE6-FECA-1BAD-FBC0-B3C30E4C7112}.Debug|Win32.ActiveCfg = Debug|Win32
- {ACCFCCE6-FECA-1BAD-FBC0-B3C30E4C7112}.Debug|Win32.Build.0 = Debug|Win32
- {ACCFCCE6-FECA-1BAD-FBC0-B3C30E4C7112}.Debug|x64.ActiveCfg = Debug|x64
- {ACCFCCE6-FECA-1BAD-FBC0-B3C30E4C7112}.Debug|x64.Build.0 = Debug|x64
- {ACCFCCE6-FECA-1BAD-FBC0-B3C30E4C7112}.Release|Win32.ActiveCfg = Release|Win32
- {ACCFCCE6-FECA-1BAD-FBC0-B3C30E4C7112}.Release|Win32.Build.0 = Release|Win32
- {ACCFCCE6-FECA-1BAD-FBC0-B3C30E4C7112}.Release|x64.ActiveCfg = Release|x64
- {ACCFCCE6-FECA-1BAD-FBC0-B3C30E4C7112}.Release|x64.Build.0 = Release|x64
- {22B6B3A9-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
- {22B6B3A9-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
- {22B6B3A9-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
- {22B6B3A9-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
- {22B6B3A9-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
- {22B6B3A9-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
- {22B6B3A9-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
- {22B6B3A9-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
- {19D6A323-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
- {19D6A323-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
- {19D6A323-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
- {19D6A323-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
- {19D6A323-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
- {19D6A323-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
- {19D6A323-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
- {19D6A323-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
- {9849EDB6-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
- {9849EDB6-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
- {9849EDB6-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
- {9849EDB6-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
- {9849EDB6-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
- {9849EDB6-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
- {9849EDB6-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
- {9849EDB6-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
- {A329FD3C-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
- {A329FD3C-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
- {A329FD3C-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
- {A329FD3C-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
- {A329FD3C-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
- {A329FD3C-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
- {A329FD3C-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
- {A329FD3C-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
- {22AAB3A9-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
- {22AAB3A9-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
- {22AAB3A9-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
- {22AAB3A9-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
- {22AAB3A9-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
- {22AAB3A9-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
- {22AAB3A9-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
- {22AAB3A9-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
- {19CAA323-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
- {19CAA323-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
- {19CAA323-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
- {19CAA323-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
- {19CAA323-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
- {19CAA323-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
- {19CAA323-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
- {19CAA323-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
- {C64D7626-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
- {C64D7626-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
- {C64D7626-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
- {C64D7626-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
- {C64D7626-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
- {C64D7626-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
- {C64D7626-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
- {C64D7626-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
- {FD2D66AC-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
- {FD2D66AC-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
- {FD2D66AC-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
- {FD2D66AC-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
- {FD2D66AC-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
- {FD2D66AC-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
- {FD2D66AC-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
- {FD2D66AC-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
- {9DE58548-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
- {9DE58548-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
- {9DE58548-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
- {9DE58548-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
- {9DE58548-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
- {9DE58548-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
- {9DE58548-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
- {9DE58548-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
- {8EBFAF06-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
- {8EBFAF06-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
- {8EBFAF06-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
- {8EBFAF06-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
- {8EBFAF06-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
- {8EBFAF06-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
- {8EBFAF06-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
- {8EBFAF06-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
- {6C78F76B-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
- {6C78F76B-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
- {6C78F76B-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
- {6C78F76B-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
- {6C78F76B-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
- {6C78F76B-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
- {6C78F76B-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
- {6C78F76B-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
- {B9E64ED0-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
- {B9E64ED0-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
- {B9E64ED0-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
- {B9E64ED0-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
- {B9E64ED0-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
- {B9E64ED0-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
- {B9E64ED0-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
- {B9E64ED0-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
- {3A5B53E1-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
- {3A5B53E1-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
- {3A5B53E1-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
- {3A5B53E1-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
- {3A5B53E1-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
- {3A5B53E1-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
- {3A5B53E1-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
- {3A5B53E1-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
- {013B436B-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
- {013B436B-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
- {013B436B-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
- {013B436B-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
- {013B436B-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
- {013B436B-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
- {013B436B-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
- {013B436B-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
- {BC081779-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
- {BC081779-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
- {BC081779-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
- {BC081779-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
- {BC081779-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
- {BC081779-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
- {BC081779-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
- {BC081779-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
- {BEE84FFD-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
- {BEE84FFD-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
- {BEE84FFD-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
- {BEE84FFD-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
- {BEE84FFD-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
- {BEE84FFD-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
- {BEE84FFD-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
- {BEE84FFD-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
- {B5DFBF8C-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
- {B5DFBF8C-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
- {B5DFBF8C-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
- {B5DFBF8C-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
- {B5DFBF8C-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
- {B5DFBF8C-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
- {B5DFBF8C-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
- {B5DFBF8C-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
- {CD284403-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
- {CD284403-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
- {CD284403-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
- {CD284403-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
- {CD284403-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
- {CD284403-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
- {CD284403-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
- {CD284403-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
- {F6485489-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
- {F6485489-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
- {F6485489-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
- {F6485489-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
- {F6485489-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
- {F6485489-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
- {F6485489-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
- {F6485489-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
- {CF754403-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
- {CF754403-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
- {CF754403-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
- {CF754403-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
- {CF754403-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
- {CF754403-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
- {CF754403-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
- {CF754403-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
- {F4155489-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
- {F4155489-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
- {F4155489-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
- {F4155489-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
- {F4155489-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
- {F4155489-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
- {F4155489-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
- {F4155489-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
- {77832932-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
- {77832932-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
- {77832932-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
- {77832932-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
- {77832932-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
- {77832932-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
- {77832932-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
- {77832932-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
- {4CE339B8-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
- {4CE339B8-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
- {4CE339B8-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
- {4CE339B8-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
- {4CE339B8-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
- {4CE339B8-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
- {4CE339B8-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
- {4CE339B8-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
- {C8154403-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
- {C8154403-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
- {C8154403-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
- {C8154403-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
- {C8154403-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
- {C8154403-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
- {C8154403-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
- {C8154403-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
- {F3755489-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
- {F3755489-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
- {F3755489-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
- {F3755489-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
- {F3755489-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
- {F3755489-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
- {F3755489-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
- {F3755489-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
- {FFF627B6-FECA-1BAD-A712-C623708DC272}.Debug|Win32.ActiveCfg = Debug|Win32
- {FFF627B6-FECA-1BAD-A712-C623708DC272}.Debug|Win32.Build.0 = Debug|Win32
- {FFF627B6-FECA-1BAD-A712-C623708DC272}.Debug|x64.ActiveCfg = Debug|x64
- {FFF627B6-FECA-1BAD-A712-C623708DC272}.Debug|x64.Build.0 = Debug|x64
- {FFF627B6-FECA-1BAD-A712-C623708DC272}.Release|Win32.ActiveCfg = Release|Win32
- {FFF627B6-FECA-1BAD-A712-C623708DC272}.Release|Win32.Build.0 = Release|Win32
- {FFF627B6-FECA-1BAD-A712-C623708DC272}.Release|x64.ActiveCfg = Release|x64
- {FFF627B6-FECA-1BAD-A712-C623708DC272}.Release|x64.Build.0 = Release|x64
- {FFC627B6-FECA-1BAD-A712-C623708DC272}.Debug|Win32.ActiveCfg = Debug|Win32
- {FFC627B6-FECA-1BAD-A712-C623708DC272}.Debug|Win32.Build.0 = Debug|Win32
- {FFC627B6-FECA-1BAD-A712-C623708DC272}.Debug|x64.ActiveCfg = Debug|x64
- {FFC627B6-FECA-1BAD-A712-C623708DC272}.Debug|x64.Build.0 = Debug|x64
- {FFC627B6-FECA-1BAD-A712-C623708DC272}.Release|Win32.ActiveCfg = Release|Win32
- {FFC627B6-FECA-1BAD-A712-C623708DC272}.Release|Win32.Build.0 = Release|Win32
- {FFC627B6-FECA-1BAD-A712-C623708DC272}.Release|x64.ActiveCfg = Release|x64
- {FFC627B6-FECA-1BAD-A712-C623708DC272}.Release|x64.Build.0 = Release|x64
- {FFD627B6-FECA-1BAD-A712-C623708DC272}.Debug|Win32.ActiveCfg = Debug|Win32
- {FFD627B6-FECA-1BAD-A712-C623708DC272}.Debug|Win32.Build.0 = Debug|Win32
- {FFD627B6-FECA-1BAD-A712-C623708DC272}.Debug|x64.ActiveCfg = Debug|x64
- {FFD627B6-FECA-1BAD-A712-C623708DC272}.Debug|x64.Build.0 = Debug|x64
- {FFD627B6-FECA-1BAD-A712-C623708DC272}.Release|Win32.ActiveCfg = Release|Win32
- {FFD627B6-FECA-1BAD-A712-C623708DC272}.Release|Win32.Build.0 = Release|Win32
- {FFD627B6-FECA-1BAD-A712-C623708DC272}.Release|x64.ActiveCfg = Release|x64
- {FFD627B6-FECA-1BAD-A712-C623708DC272}.Release|x64.Build.0 = Release|x64
- {0F4C02C6-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.ActiveCfg = Debug|Win32
- {0F4C02C6-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.Build.0 = Debug|Win32
- {0F4C02C6-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.ActiveCfg = Debug|x64
- {0F4C02C6-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.Build.0 = Debug|x64
- {0F4C02C6-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.ActiveCfg = Release|Win32
- {0F4C02C6-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.Build.0 = Release|Win32
- {0F4C02C6-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.ActiveCfg = Release|x64
- {0F4C02C6-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.Build.0 = Release|x64
- {033DAD2A-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.ActiveCfg = Debug|Win32
- {033DAD2A-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.Build.0 = Debug|Win32
- {033DAD2A-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.ActiveCfg = Debug|x64
- {033DAD2A-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.Build.0 = Debug|x64
- {033DAD2A-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.ActiveCfg = Release|Win32
- {033DAD2A-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.Build.0 = Release|Win32
- {033DAD2A-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.ActiveCfg = Release|x64
- {033DAD2A-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.Build.0 = Release|x64
- {919D8035-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.ActiveCfg = Debug|Win32
- {919D8035-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.Build.0 = Debug|Win32
- {919D8035-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.ActiveCfg = Debug|x64
- {919D8035-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.Build.0 = Debug|x64
- {919D8035-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.ActiveCfg = Release|Win32
- {919D8035-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.Build.0 = Release|Win32
- {919D8035-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.ActiveCfg = Release|x64
- {919D8035-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.Build.0 = Release|x64
- {7230CC0F-FECA-1BAD-662F-43CDC449C088}.Debug|Win32.ActiveCfg = Debug|Win32
- {7230CC0F-FECA-1BAD-662F-43CDC449C088}.Debug|Win32.Build.0 = Debug|Win32
- {7230CC0F-FECA-1BAD-662F-43CDC449C088}.Debug|x64.ActiveCfg = Debug|x64
- {7230CC0F-FECA-1BAD-662F-43CDC449C088}.Debug|x64.Build.0 = Debug|x64
- {7230CC0F-FECA-1BAD-662F-43CDC449C088}.Release|Win32.ActiveCfg = Release|Win32
- {7230CC0F-FECA-1BAD-662F-43CDC449C088}.Release|Win32.Build.0 = Release|Win32
- {7230CC0F-FECA-1BAD-662F-43CDC449C088}.Release|x64.ActiveCfg = Release|x64
- {7230CC0F-FECA-1BAD-662F-43CDC449C088}.Release|x64.Build.0 = Release|x64
- {388BC7EF-FECA-1BAD-6284-F3732ECE18EC}.Debug|Win32.ActiveCfg = Debug|Win32
- {388BC7EF-FECA-1BAD-6284-F3732ECE18EC}.Debug|Win32.Build.0 = Debug|Win32
- {388BC7EF-FECA-1BAD-6284-F3732ECE18EC}.Debug|x64.ActiveCfg = Debug|x64
- {388BC7EF-FECA-1BAD-6284-F3732ECE18EC}.Debug|x64.Build.0 = Debug|x64
- {388BC7EF-FECA-1BAD-6284-F3732ECE18EC}.Release|Win32.ActiveCfg = Release|Win32
- {388BC7EF-FECA-1BAD-6284-F3732ECE18EC}.Release|Win32.Build.0 = Release|Win32
- {388BC7EF-FECA-1BAD-6284-F3732ECE18EC}.Release|x64.ActiveCfg = Release|x64
- {388BC7EF-FECA-1BAD-6284-F3732ECE18EC}.Release|x64.Build.0 = Release|x64
- {257E89D9-FECA-1BAD-035B-A790F8AEE4FF}.Debug|Win32.ActiveCfg = Debug|Win32
- {257E89D9-FECA-1BAD-035B-A790F8AEE4FF}.Debug|Win32.Build.0 = Debug|Win32
- {257E89D9-FECA-1BAD-035B-A790F8AEE4FF}.Debug|x64.ActiveCfg = Debug|x64
- {257E89D9-FECA-1BAD-035B-A790F8AEE4FF}.Debug|x64.Build.0 = Debug|x64
- {257E89D9-FECA-1BAD-035B-A790F8AEE4FF}.Release|Win32.ActiveCfg = Release|Win32
- {257E89D9-FECA-1BAD-035B-A790F8AEE4FF}.Release|Win32.Build.0 = Release|Win32
- {257E89D9-FECA-1BAD-035B-A790F8AEE4FF}.Release|x64.ActiveCfg = Release|x64
- {257E89D9-FECA-1BAD-035B-A790F8AEE4FF}.Release|x64.Build.0 = Release|x64
- {B497E16A-FECA-1BAD-3A45-311BD15FE43D}.Debug|Win32.ActiveCfg = Debug|Win32
- {B497E16A-FECA-1BAD-3A45-311BD15FE43D}.Debug|Win32.Build.0 = Debug|Win32
- {B497E16A-FECA-1BAD-3A45-311BD15FE43D}.Debug|x64.ActiveCfg = Debug|x64
- {B497E16A-FECA-1BAD-3A45-311BD15FE43D}.Debug|x64.Build.0 = Debug|x64
- {B497E16A-FECA-1BAD-3A45-311BD15FE43D}.Release|Win32.ActiveCfg = Release|Win32
- {B497E16A-FECA-1BAD-3A45-311BD15FE43D}.Release|Win32.Build.0 = Release|Win32
- {B497E16A-FECA-1BAD-3A45-311BD15FE43D}.Release|x64.ActiveCfg = Release|x64
- {B497E16A-FECA-1BAD-3A45-311BD15FE43D}.Release|x64.Build.0 = Release|x64
- {362AC470-FECA-1BAD-926E-E34A898F3061}.Debug|Win32.ActiveCfg = Debug|Win32
- {362AC470-FECA-1BAD-926E-E34A898F3061}.Debug|Win32.Build.0 = Debug|Win32
- {362AC470-FECA-1BAD-926E-E34A898F3061}.Debug|x64.ActiveCfg = Debug|x64
- {362AC470-FECA-1BAD-926E-E34A898F3061}.Debug|x64.Build.0 = Debug|x64
- {362AC470-FECA-1BAD-926E-E34A898F3061}.Release|Win32.ActiveCfg = Release|Win32
- {362AC470-FECA-1BAD-926E-E34A898F3061}.Release|Win32.Build.0 = Release|Win32
- {362AC470-FECA-1BAD-926E-E34A898F3061}.Release|x64.ActiveCfg = Release|x64
- {362AC470-FECA-1BAD-926E-E34A898F3061}.Release|x64.Build.0 = Release|x64
- {870D7110-FECA-1BAD-997C-981CB0707EDF}.Debug|Win32.ActiveCfg = Debug|Win32
- {870D7110-FECA-1BAD-997C-981CB0707EDF}.Debug|Win32.Build.0 = Debug|Win32
- {870D7110-FECA-1BAD-997C-981CB0707EDF}.Debug|x64.ActiveCfg = Debug|x64
- {870D7110-FECA-1BAD-997C-981CB0707EDF}.Debug|x64.Build.0 = Debug|x64
- {870D7110-FECA-1BAD-997C-981CB0707EDF}.Release|Win32.ActiveCfg = Release|Win32
- {870D7110-FECA-1BAD-997C-981CB0707EDF}.Release|Win32.Build.0 = Release|Win32
- {870D7110-FECA-1BAD-997C-981CB0707EDF}.Release|x64.ActiveCfg = Release|x64
- {870D7110-FECA-1BAD-997C-981CB0707EDF}.Release|x64.Build.0 = Release|x64
- {40CE5CBF-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {40CE5CBF-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
- {40CE5CBF-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
- {40CE5CBF-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
- {40CE5CBF-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
- {40CE5CBF-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
- {40CE5CBF-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
- {40CE5CBF-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
- {B7091250-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {B7091250-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
- {B7091250-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
- {B7091250-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
- {B7091250-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
- {B7091250-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
- {B7091250-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
- {B7091250-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
- {9016F8E4-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {9016F8E4-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
- {9016F8E4-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
- {9016F8E4-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
- {9016F8E4-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
- {9016F8E4-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
- {9016F8E4-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
- {9016F8E4-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
- {071FC37D-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {071FC37D-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
- {071FC37D-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
- {071FC37D-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
- {071FC37D-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
- {071FC37D-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
- {071FC37D-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
- {071FC37D-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
- {140E764D-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {140E764D-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
- {140E764D-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
- {140E764D-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
- {140E764D-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
- {140E764D-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
- {140E764D-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
- {140E764D-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
- {C838447F-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {C838447F-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
- {C838447F-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
- {C838447F-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
- {C838447F-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
- {C838447F-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
- {C838447F-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
- {C838447F-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
- {CE95468B-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {CE95468B-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
- {CE95468B-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
- {CE95468B-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
- {CE95468B-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
- {CE95468B-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
- {CE95468B-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
- {CE95468B-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
- {C79CF28B-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {C79CF28B-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
- {C79CF28B-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
- {C79CF28B-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
- {C79CF28B-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
- {C79CF28B-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
- {C79CF28B-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
- {C79CF28B-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
- {6C4E704C-FECA-1BAD-57C8-A8090AE02194}.Debug|Win32.ActiveCfg = Debug|Win32
- {6C4E704C-FECA-1BAD-57C8-A8090AE02194}.Debug|Win32.Build.0 = Debug|Win32
- {6C4E704C-FECA-1BAD-57C8-A8090AE02194}.Debug|x64.ActiveCfg = Debug|x64
- {6C4E704C-FECA-1BAD-57C8-A8090AE02194}.Debug|x64.Build.0 = Debug|x64
- {6C4E704C-FECA-1BAD-57C8-A8090AE02194}.Release|Win32.ActiveCfg = Release|Win32
- {6C4E704C-FECA-1BAD-57C8-A8090AE02194}.Release|Win32.Build.0 = Release|Win32
- {6C4E704C-FECA-1BAD-57C8-A8090AE02194}.Release|x64.ActiveCfg = Release|x64
- {6C4E704C-FECA-1BAD-57C8-A8090AE02194}.Release|x64.Build.0 = Release|x64
- {87EA0653-FECA-1BAD-A972-EF683B232306}.Debug|Win32.ActiveCfg = Debug|Win32
- {87EA0653-FECA-1BAD-A972-EF683B232306}.Debug|Win32.Build.0 = Debug|Win32
- {87EA0653-FECA-1BAD-A972-EF683B232306}.Debug|x64.ActiveCfg = Debug|x64
- {87EA0653-FECA-1BAD-A972-EF683B232306}.Debug|x64.Build.0 = Debug|x64
- {87EA0653-FECA-1BAD-A972-EF683B232306}.Release|Win32.ActiveCfg = Release|Win32
- {87EA0653-FECA-1BAD-A972-EF683B232306}.Release|Win32.Build.0 = Release|Win32
- {87EA0653-FECA-1BAD-A972-EF683B232306}.Release|x64.ActiveCfg = Release|x64
- {87EA0653-FECA-1BAD-A972-EF683B232306}.Release|x64.Build.0 = Release|x64
- {AC3515AE-FECA-1BAD-7BCF-1E57BCBE0D93}.Debug|Win32.ActiveCfg = Debug|Win32
- {AC3515AE-FECA-1BAD-7BCF-1E57BCBE0D93}.Debug|Win32.Build.0 = Debug|Win32
- {AC3515AE-FECA-1BAD-7BCF-1E57BCBE0D93}.Debug|x64.ActiveCfg = Debug|x64
- {AC3515AE-FECA-1BAD-7BCF-1E57BCBE0D93}.Debug|x64.Build.0 = Debug|x64
- {AC3515AE-FECA-1BAD-7BCF-1E57BCBE0D93}.Release|Win32.ActiveCfg = Release|Win32
- {AC3515AE-FECA-1BAD-7BCF-1E57BCBE0D93}.Release|Win32.Build.0 = Release|Win32
- {AC3515AE-FECA-1BAD-7BCF-1E57BCBE0D93}.Release|x64.ActiveCfg = Release|x64
- {AC3515AE-FECA-1BAD-7BCF-1E57BCBE0D93}.Release|x64.Build.0 = Release|x64
- {92EC52ED-FECA-1BAD-4822-8A23A725AAA8}.Debug|Win32.ActiveCfg = Debug|Win32
- {92EC52ED-FECA-1BAD-4822-8A23A725AAA8}.Debug|Win32.Build.0 = Debug|Win32
- {92EC52ED-FECA-1BAD-4822-8A23A725AAA8}.Debug|x64.ActiveCfg = Debug|x64
- {92EC52ED-FECA-1BAD-4822-8A23A725AAA8}.Debug|x64.Build.0 = Debug|x64
- {92EC52ED-FECA-1BAD-4822-8A23A725AAA8}.Release|Win32.ActiveCfg = Release|Win32
- {92EC52ED-FECA-1BAD-4822-8A23A725AAA8}.Release|Win32.Build.0 = Release|Win32
- {92EC52ED-FECA-1BAD-4822-8A23A725AAA8}.Release|x64.ActiveCfg = Release|x64
- {92EC52ED-FECA-1BAD-4822-8A23A725AAA8}.Release|x64.Build.0 = Release|x64
- {FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5}.Debug|Win32.ActiveCfg = Debug|Win32
- {FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5}.Debug|Win32.Build.0 = Debug|Win32
- {FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5}.Debug|x64.ActiveCfg = Debug|x64
- {FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5}.Debug|x64.Build.0 = Debug|x64
- {FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5}.Release|Win32.ActiveCfg = Release|Win32
- {FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5}.Release|Win32.Build.0 = Release|Win32
- {FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5}.Release|x64.ActiveCfg = Release|x64
- {FC680E2F-FECA-1BAD-6ECA-CFEF95E288A5}.Release|x64.Build.0 = Release|x64
- {5A399C87-FECA-1BAD-E4AF-D6C5D6D0BA85}.Debug|Win32.ActiveCfg = Debug|Win32
- {5A399C87-FECA-1BAD-E4AF-D6C5D6D0BA85}.Debug|Win32.Build.0 = Debug|Win32
- {5A399C87-FECA-1BAD-E4AF-D6C5D6D0BA85}.Debug|x64.ActiveCfg = Debug|x64
- {5A399C87-FECA-1BAD-E4AF-D6C5D6D0BA85}.Debug|x64.Build.0 = Debug|x64
- {5A399C87-FECA-1BAD-E4AF-D6C5D6D0BA85}.Release|Win32.ActiveCfg = Release|Win32
- {5A399C87-FECA-1BAD-E4AF-D6C5D6D0BA85}.Release|Win32.Build.0 = Release|Win32
- {5A399C87-FECA-1BAD-E4AF-D6C5D6D0BA85}.Release|x64.ActiveCfg = Release|x64
- {5A399C87-FECA-1BAD-E4AF-D6C5D6D0BA85}.Release|x64.Build.0 = Release|x64
- {11AA315C-FECA-1BAD-5016-EC184EF1264A}.Debug|Win32.ActiveCfg = Debug|Win32
- {11AA315C-FECA-1BAD-5016-EC184EF1264A}.Debug|Win32.Build.0 = Debug|Win32
- {11AA315C-FECA-1BAD-5016-EC184EF1264A}.Debug|x64.ActiveCfg = Debug|x64
- {11AA315C-FECA-1BAD-5016-EC184EF1264A}.Debug|x64.Build.0 = Debug|x64
- {11AA315C-FECA-1BAD-5016-EC184EF1264A}.Release|Win32.ActiveCfg = Release|Win32
- {11AA315C-FECA-1BAD-5016-EC184EF1264A}.Release|Win32.Build.0 = Release|Win32
- {11AA315C-FECA-1BAD-5016-EC184EF1264A}.Release|x64.ActiveCfg = Release|x64
- {11AA315C-FECA-1BAD-5016-EC184EF1264A}.Release|x64.Build.0 = Release|x64
- {F05679AE-FECA-1BAD-7E09-28972A531BE9}.Debug|Win32.ActiveCfg = Debug|Win32
- {F05679AE-FECA-1BAD-7E09-28972A531BE9}.Debug|Win32.Build.0 = Debug|Win32
- {F05679AE-FECA-1BAD-7E09-28972A531BE9}.Debug|x64.ActiveCfg = Debug|x64
- {F05679AE-FECA-1BAD-7E09-28972A531BE9}.Debug|x64.Build.0 = Debug|x64
- {F05679AE-FECA-1BAD-7E09-28972A531BE9}.Release|Win32.ActiveCfg = Release|Win32
- {F05679AE-FECA-1BAD-7E09-28972A531BE9}.Release|Win32.Build.0 = Release|Win32
- {F05679AE-FECA-1BAD-7E09-28972A531BE9}.Release|x64.ActiveCfg = Release|x64
- {F05679AE-FECA-1BAD-7E09-28972A531BE9}.Release|x64.Build.0 = Release|x64
- {AEA604B9-FECA-1BAD-0BE6-2F4603877603}.Debug|Win32.ActiveCfg = Debug|Win32
- {AEA604B9-FECA-1BAD-0BE6-2F4603877603}.Debug|Win32.Build.0 = Debug|Win32
- {AEA604B9-FECA-1BAD-0BE6-2F4603877603}.Debug|x64.ActiveCfg = Debug|x64
- {AEA604B9-FECA-1BAD-0BE6-2F4603877603}.Debug|x64.Build.0 = Debug|x64
- {AEA604B9-FECA-1BAD-0BE6-2F4603877603}.Release|Win32.ActiveCfg = Release|Win32
- {AEA604B9-FECA-1BAD-0BE6-2F4603877603}.Release|Win32.Build.0 = Release|Win32
- {AEA604B9-FECA-1BAD-0BE6-2F4603877603}.Release|x64.ActiveCfg = Release|x64
- {AEA604B9-FECA-1BAD-0BE6-2F4603877603}.Release|x64.Build.0 = Release|x64
- {688206D5-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.ActiveCfg = Debug|Win32
- {688206D5-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.Build.0 = Debug|Win32
- {688206D5-FECA-1BAD-BF85-8EE479601925}.Debug|x64.ActiveCfg = Debug|x64
- {688206D5-FECA-1BAD-BF85-8EE479601925}.Debug|x64.Build.0 = Debug|x64
- {688206D5-FECA-1BAD-BF85-8EE479601925}.Release|Win32.ActiveCfg = Release|Win32
- {688206D5-FECA-1BAD-BF85-8EE479601925}.Release|Win32.Build.0 = Release|Win32
- {688206D5-FECA-1BAD-BF85-8EE479601925}.Release|x64.ActiveCfg = Release|x64
- {688206D5-FECA-1BAD-BF85-8EE479601925}.Release|x64.Build.0 = Release|x64
- {35A13A17-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.ActiveCfg = Debug|Win32
- {35A13A17-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.Build.0 = Debug|Win32
- {35A13A17-FECA-1BAD-BF85-8EE479601925}.Debug|x64.ActiveCfg = Debug|x64
- {35A13A17-FECA-1BAD-BF85-8EE479601925}.Debug|x64.Build.0 = Debug|x64
- {35A13A17-FECA-1BAD-BF85-8EE479601925}.Release|Win32.ActiveCfg = Release|Win32
- {35A13A17-FECA-1BAD-BF85-8EE479601925}.Release|Win32.Build.0 = Release|Win32
- {35A13A17-FECA-1BAD-BF85-8EE479601925}.Release|x64.ActiveCfg = Release|x64
- {35A13A17-FECA-1BAD-BF85-8EE479601925}.Release|x64.Build.0 = Release|x64
- {F4B3D455-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.ActiveCfg = Debug|Win32
- {F4B3D455-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.Build.0 = Debug|Win32
- {F4B3D455-FECA-1BAD-BF85-8EE479601925}.Debug|x64.ActiveCfg = Debug|x64
- {F4B3D455-FECA-1BAD-BF85-8EE479601925}.Debug|x64.Build.0 = Debug|x64
- {F4B3D455-FECA-1BAD-BF85-8EE479601925}.Release|Win32.ActiveCfg = Release|Win32
- {F4B3D455-FECA-1BAD-BF85-8EE479601925}.Release|Win32.Build.0 = Release|Win32
- {F4B3D455-FECA-1BAD-BF85-8EE479601925}.Release|x64.ActiveCfg = Release|x64
- {F4B3D455-FECA-1BAD-BF85-8EE479601925}.Release|x64.Build.0 = Release|x64
- {CDF61A70-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.ActiveCfg = Debug|Win32
- {CDF61A70-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.Build.0 = Debug|Win32
- {CDF61A70-FECA-1BAD-BF85-8EE479601925}.Debug|x64.ActiveCfg = Debug|x64
- {CDF61A70-FECA-1BAD-BF85-8EE479601925}.Debug|x64.Build.0 = Debug|x64
- {CDF61A70-FECA-1BAD-BF85-8EE479601925}.Release|Win32.ActiveCfg = Release|Win32
- {CDF61A70-FECA-1BAD-BF85-8EE479601925}.Release|Win32.Build.0 = Release|Win32
- {CDF61A70-FECA-1BAD-BF85-8EE479601925}.Release|x64.ActiveCfg = Release|x64
- {CDF61A70-FECA-1BAD-BF85-8EE479601925}.Release|x64.Build.0 = Release|x64
- {01D25766-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|Win32.ActiveCfg = Debug|Win32
- {01D25766-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|Win32.Build.0 = Debug|Win32
- {01D25766-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|x64.ActiveCfg = Debug|x64
- {01D25766-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|x64.Build.0 = Debug|x64
- {01D25766-FECA-1BAD-56E7-2D2A01EB2B05}.Release|Win32.ActiveCfg = Release|Win32
- {01D25766-FECA-1BAD-56E7-2D2A01EB2B05}.Release|Win32.Build.0 = Release|Win32
- {01D25766-FECA-1BAD-56E7-2D2A01EB2B05}.Release|x64.ActiveCfg = Release|x64
- {01D25766-FECA-1BAD-56E7-2D2A01EB2B05}.Release|x64.Build.0 = Release|x64
- {5ADC56E9-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|Win32.ActiveCfg = Debug|Win32
- {5ADC56E9-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|Win32.Build.0 = Debug|Win32
- {5ADC56E9-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|x64.ActiveCfg = Debug|x64
- {5ADC56E9-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|x64.Build.0 = Debug|x64
- {5ADC56E9-FECA-1BAD-56E7-2D2A01EB2B05}.Release|Win32.ActiveCfg = Release|Win32
- {5ADC56E9-FECA-1BAD-56E7-2D2A01EB2B05}.Release|Win32.Build.0 = Release|Win32
- {5ADC56E9-FECA-1BAD-56E7-2D2A01EB2B05}.Release|x64.ActiveCfg = Release|x64
- {5ADC56E9-FECA-1BAD-56E7-2D2A01EB2B05}.Release|x64.Build.0 = Release|x64
- {9009A2D9-FECA-1BAD-0E85-EBA2C3BCE951}.Debug|Win32.ActiveCfg = Debug|Win32
- {9009A2D9-FECA-1BAD-0E85-EBA2C3BCE951}.Debug|Win32.Build.0 = Debug|Win32
- {9009A2D9-FECA-1BAD-0E85-EBA2C3BCE951}.Debug|x64.ActiveCfg = Debug|x64
- {9009A2D9-FECA-1BAD-0E85-EBA2C3BCE951}.Debug|x64.Build.0 = Debug|x64
- {9009A2D9-FECA-1BAD-0E85-EBA2C3BCE951}.Release|Win32.ActiveCfg = Release|Win32
- {9009A2D9-FECA-1BAD-0E85-EBA2C3BCE951}.Release|Win32.Build.0 = Release|Win32
- {9009A2D9-FECA-1BAD-0E85-EBA2C3BCE951}.Release|x64.ActiveCfg = Release|x64
- {9009A2D9-FECA-1BAD-0E85-EBA2C3BCE951}.Release|x64.Build.0 = Release|x64
- {3C4E9210-FECA-1BAD-0E85-EBA2C3BCE951}.Debug|Win32.ActiveCfg = Debug|Win32
- {3C4E9210-FECA-1BAD-0E85-EBA2C3BCE951}.Debug|Win32.Build.0 = Debug|Win32
- {3C4E9210-FECA-1BAD-0E85-EBA2C3BCE951}.Debug|x64.ActiveCfg = Debug|x64
- {3C4E9210-FECA-1BAD-0E85-EBA2C3BCE951}.Debug|x64.Build.0 = Debug|x64
- {3C4E9210-FECA-1BAD-0E85-EBA2C3BCE951}.Release|Win32.ActiveCfg = Release|Win32
- {3C4E9210-FECA-1BAD-0E85-EBA2C3BCE951}.Release|Win32.Build.0 = Release|Win32
- {3C4E9210-FECA-1BAD-0E85-EBA2C3BCE951}.Release|x64.ActiveCfg = Release|x64
- {3C4E9210-FECA-1BAD-0E85-EBA2C3BCE951}.Release|x64.Build.0 = Release|x64
- {419B6E77-FECA-1BAD-A054-796E2D70CA71}.Debug|Win32.ActiveCfg = Debug|Win32
- {419B6E77-FECA-1BAD-A054-796E2D70CA71}.Debug|Win32.Build.0 = Debug|Win32
- {419B6E77-FECA-1BAD-A054-796E2D70CA71}.Debug|x64.ActiveCfg = Debug|x64
- {419B6E77-FECA-1BAD-A054-796E2D70CA71}.Debug|x64.Build.0 = Debug|x64
- {419B6E77-FECA-1BAD-A054-796E2D70CA71}.Release|Win32.ActiveCfg = Release|Win32
- {419B6E77-FECA-1BAD-A054-796E2D70CA71}.Release|Win32.Build.0 = Release|Win32
- {419B6E77-FECA-1BAD-A054-796E2D70CA71}.Release|x64.ActiveCfg = Release|x64
- {419B6E77-FECA-1BAD-A054-796E2D70CA71}.Release|x64.Build.0 = Release|x64
- {929F00DC-FECA-1BAD-A054-796E2D70CA71}.Debug|Win32.ActiveCfg = Debug|Win32
- {929F00DC-FECA-1BAD-A054-796E2D70CA71}.Debug|Win32.Build.0 = Debug|Win32
- {929F00DC-FECA-1BAD-A054-796E2D70CA71}.Debug|x64.ActiveCfg = Debug|x64
- {929F00DC-FECA-1BAD-A054-796E2D70CA71}.Debug|x64.Build.0 = Debug|x64
- {929F00DC-FECA-1BAD-A054-796E2D70CA71}.Release|Win32.ActiveCfg = Release|Win32
- {929F00DC-FECA-1BAD-A054-796E2D70CA71}.Release|Win32.Build.0 = Release|Win32
- {929F00DC-FECA-1BAD-A054-796E2D70CA71}.Release|x64.ActiveCfg = Release|x64
- {929F00DC-FECA-1BAD-A054-796E2D70CA71}.Release|x64.Build.0 = Release|x64
- {2194CC42-FECA-1BAD-083F-A5678D79EFEB}.Debug|Win32.ActiveCfg = Debug|Win32
- {2194CC42-FECA-1BAD-083F-A5678D79EFEB}.Debug|Win32.Build.0 = Debug|Win32
- {2194CC42-FECA-1BAD-083F-A5678D79EFEB}.Debug|x64.ActiveCfg = Debug|x64
- {2194CC42-FECA-1BAD-083F-A5678D79EFEB}.Debug|x64.Build.0 = Debug|x64
- {2194CC42-FECA-1BAD-083F-A5678D79EFEB}.Release|Win32.ActiveCfg = Release|Win32
- {2194CC42-FECA-1BAD-083F-A5678D79EFEB}.Release|Win32.Build.0 = Release|Win32
- {2194CC42-FECA-1BAD-083F-A5678D79EFEB}.Release|x64.ActiveCfg = Release|x64
- {2194CC42-FECA-1BAD-083F-A5678D79EFEB}.Release|x64.Build.0 = Release|x64
- {1AF4DCC8-FECA-1BAD-083F-A5678D79EFEB}.Debug|Win32.ActiveCfg = Debug|Win32
- {1AF4DCC8-FECA-1BAD-083F-A5678D79EFEB}.Debug|Win32.Build.0 = Debug|Win32
- {1AF4DCC8-FECA-1BAD-083F-A5678D79EFEB}.Debug|x64.ActiveCfg = Debug|x64
- {1AF4DCC8-FECA-1BAD-083F-A5678D79EFEB}.Debug|x64.Build.0 = Debug|x64
- {1AF4DCC8-FECA-1BAD-083F-A5678D79EFEB}.Release|Win32.ActiveCfg = Release|Win32
- {1AF4DCC8-FECA-1BAD-083F-A5678D79EFEB}.Release|Win32.Build.0 = Release|Win32
- {1AF4DCC8-FECA-1BAD-083F-A5678D79EFEB}.Release|x64.ActiveCfg = Release|x64
- {1AF4DCC8-FECA-1BAD-083F-A5678D79EFEB}.Release|x64.Build.0 = Release|x64
- {E8023C74-FECA-1BAD-A3FD-E03CBCFDDE18}.Debug|Win32.ActiveCfg = Debug|Win32
- {E8023C74-FECA-1BAD-A3FD-E03CBCFDDE18}.Debug|Win32.Build.0 = Debug|Win32
- {E8023C74-FECA-1BAD-A3FD-E03CBCFDDE18}.Debug|x64.ActiveCfg = Debug|x64
- {E8023C74-FECA-1BAD-A3FD-E03CBCFDDE18}.Debug|x64.Build.0 = Debug|x64
- {E8023C74-FECA-1BAD-A3FD-E03CBCFDDE18}.Release|Win32.ActiveCfg = Release|Win32
- {E8023C74-FECA-1BAD-A3FD-E03CBCFDDE18}.Release|Win32.Build.0 = Release|Win32
- {E8023C74-FECA-1BAD-A3FD-E03CBCFDDE18}.Release|x64.ActiveCfg = Release|x64
- {E8023C74-FECA-1BAD-A3FD-E03CBCFDDE18}.Release|x64.Build.0 = Release|x64
- {9136998E-FECA-1BAD-A3FD-E03CBCFDDE18}.Debug|Win32.ActiveCfg = Debug|Win32
- {9136998E-FECA-1BAD-A3FD-E03CBCFDDE18}.Debug|Win32.Build.0 = Debug|Win32
- {9136998E-FECA-1BAD-A3FD-E03CBCFDDE18}.Debug|x64.ActiveCfg = Debug|x64
- {9136998E-FECA-1BAD-A3FD-E03CBCFDDE18}.Debug|x64.Build.0 = Debug|x64
- {9136998E-FECA-1BAD-A3FD-E03CBCFDDE18}.Release|Win32.ActiveCfg = Release|Win32
- {9136998E-FECA-1BAD-A3FD-E03CBCFDDE18}.Release|Win32.Build.0 = Release|Win32
- {9136998E-FECA-1BAD-A3FD-E03CBCFDDE18}.Release|x64.ActiveCfg = Release|x64
- {9136998E-FECA-1BAD-A3FD-E03CBCFDDE18}.Release|x64.Build.0 = Release|x64
- {20FA65D3-FECA-1BAD-333D-0D85A7384955}.Debug|Win32.ActiveCfg = Debug|Win32
- {20FA65D3-FECA-1BAD-333D-0D85A7384955}.Debug|Win32.Build.0 = Debug|Win32
- {20FA65D3-FECA-1BAD-333D-0D85A7384955}.Debug|x64.ActiveCfg = Debug|x64
- {20FA65D3-FECA-1BAD-333D-0D85A7384955}.Debug|x64.Build.0 = Debug|x64
- {20FA65D3-FECA-1BAD-333D-0D85A7384955}.Release|Win32.ActiveCfg = Release|Win32
- {20FA65D3-FECA-1BAD-333D-0D85A7384955}.Release|Win32.Build.0 = Release|Win32
- {20FA65D3-FECA-1BAD-333D-0D85A7384955}.Release|x64.ActiveCfg = Release|x64
- {20FA65D3-FECA-1BAD-333D-0D85A7384955}.Release|x64.Build.0 = Release|x64
- {2314288A-FECA-1BAD-333D-0D85A7384955}.Debug|Win32.ActiveCfg = Debug|Win32
- {2314288A-FECA-1BAD-333D-0D85A7384955}.Debug|Win32.Build.0 = Debug|Win32
- {2314288A-FECA-1BAD-333D-0D85A7384955}.Debug|x64.ActiveCfg = Debug|x64
- {2314288A-FECA-1BAD-333D-0D85A7384955}.Debug|x64.Build.0 = Debug|x64
- {2314288A-FECA-1BAD-333D-0D85A7384955}.Release|Win32.ActiveCfg = Release|Win32
- {2314288A-FECA-1BAD-333D-0D85A7384955}.Release|Win32.Build.0 = Release|Win32
- {2314288A-FECA-1BAD-333D-0D85A7384955}.Release|x64.ActiveCfg = Release|x64
- {2314288A-FECA-1BAD-333D-0D85A7384955}.Release|x64.Build.0 = Release|x64
- {47F2CB38-FECA-1BAD-6E59-A21D8A7389FD}.Debug|Win32.ActiveCfg = Debug|Win32
- {47F2CB38-FECA-1BAD-6E59-A21D8A7389FD}.Debug|Win32.Build.0 = Debug|Win32
- {47F2CB38-FECA-1BAD-6E59-A21D8A7389FD}.Debug|x64.ActiveCfg = Debug|x64
- {47F2CB38-FECA-1BAD-6E59-A21D8A7389FD}.Debug|x64.Build.0 = Debug|x64
- {47F2CB38-FECA-1BAD-6E59-A21D8A7389FD}.Release|Win32.ActiveCfg = Release|Win32
- {47F2CB38-FECA-1BAD-6E59-A21D8A7389FD}.Release|Win32.Build.0 = Release|Win32
- {47F2CB38-FECA-1BAD-6E59-A21D8A7389FD}.Release|x64.ActiveCfg = Release|x64
- {47F2CB38-FECA-1BAD-6E59-A21D8A7389FD}.Release|x64.Build.0 = Release|x64
- {7C92DBB2-FECA-1BAD-6E59-A21D8A7389FD}.Debug|Win32.ActiveCfg = Debug|Win32
- {7C92DBB2-FECA-1BAD-6E59-A21D8A7389FD}.Debug|Win32.Build.0 = Debug|Win32
- {7C92DBB2-FECA-1BAD-6E59-A21D8A7389FD}.Debug|x64.ActiveCfg = Debug|x64
- {7C92DBB2-FECA-1BAD-6E59-A21D8A7389FD}.Debug|x64.Build.0 = Debug|x64
- {7C92DBB2-FECA-1BAD-6E59-A21D8A7389FD}.Release|Win32.ActiveCfg = Release|Win32
- {7C92DBB2-FECA-1BAD-6E59-A21D8A7389FD}.Release|Win32.Build.0 = Release|Win32
- {7C92DBB2-FECA-1BAD-6E59-A21D8A7389FD}.Release|x64.ActiveCfg = Release|x64
- {7C92DBB2-FECA-1BAD-6E59-A21D8A7389FD}.Release|x64.Build.0 = Release|x64
- {CA06123A-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
- {CA06123A-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
- {CA06123A-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
- {CA06123A-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
- {CA06123A-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
- {CA06123A-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
- {CA06123A-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
- {CA06123A-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
- {725C36CB-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
- {725C36CB-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
- {725C36CB-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
- {725C36CB-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
- {725C36CB-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
- {725C36CB-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
- {725C36CB-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
- {725C36CB-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
- {A162739D-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
- {A162739D-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
- {A162739D-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
- {A162739D-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
- {A162739D-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
- {A162739D-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
- {A162739D-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
- {A162739D-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
- {1501811B-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
- {1501811B-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
- {1501811B-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
- {1501811B-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
- {1501811B-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
- {1501811B-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
- {1501811B-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
- {1501811B-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
- {AA12D012-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
- {AA12D012-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
- {AA12D012-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
- {AA12D012-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
- {AA12D012-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
- {AA12D012-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
- {AA12D012-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
- {AA12D012-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
- {B7501F56-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
- {B7501F56-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
- {B7501F56-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
- {B7501F56-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
- {B7501F56-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
- {B7501F56-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
- {B7501F56-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
- {B7501F56-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
- {5424A140-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
- {5424A140-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
- {5424A140-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
- {5424A140-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
- {5424A140-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
- {5424A140-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
- {5424A140-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
- {5424A140-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
- {5414A140-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
- {5414A140-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
- {5414A140-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
- {5414A140-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
- {5414A140-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
- {5414A140-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
- {5414A140-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
- {5414A140-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
- {9BE1FEA2-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
- {9BE1FEA2-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
- {9BE1FEA2-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
- {9BE1FEA2-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
- {9BE1FEA2-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
- {9BE1FEA2-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
- {9BE1FEA2-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
- {9BE1FEA2-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
- {F803EF2B-FECA-1BAD-D1A8-860E7607F174}.Debug|Win32.ActiveCfg = Debug|Win32
- {F803EF2B-FECA-1BAD-D1A8-860E7607F174}.Debug|Win32.Build.0 = Debug|Win32
- {F803EF2B-FECA-1BAD-D1A8-860E7607F174}.Debug|x64.ActiveCfg = Debug|x64
- {F803EF2B-FECA-1BAD-D1A8-860E7607F174}.Debug|x64.Build.0 = Debug|x64
- {F803EF2B-FECA-1BAD-D1A8-860E7607F174}.Release|Win32.ActiveCfg = Release|Win32
- {F803EF2B-FECA-1BAD-D1A8-860E7607F174}.Release|Win32.Build.0 = Release|Win32
- {F803EF2B-FECA-1BAD-D1A8-860E7607F174}.Release|x64.ActiveCfg = Release|x64
- {F803EF2B-FECA-1BAD-D1A8-860E7607F174}.Release|x64.Build.0 = Release|x64
- {C363FFA1-FECA-1BAD-D1A8-860E7607F174}.Debug|Win32.ActiveCfg = Debug|Win32
- {C363FFA1-FECA-1BAD-D1A8-860E7607F174}.Debug|Win32.Build.0 = Debug|Win32
- {C363FFA1-FECA-1BAD-D1A8-860E7607F174}.Debug|x64.ActiveCfg = Debug|x64
- {C363FFA1-FECA-1BAD-D1A8-860E7607F174}.Debug|x64.Build.0 = Debug|x64
- {C363FFA1-FECA-1BAD-D1A8-860E7607F174}.Release|Win32.ActiveCfg = Release|Win32
- {C363FFA1-FECA-1BAD-D1A8-860E7607F174}.Release|Win32.Build.0 = Release|Win32
- {C363FFA1-FECA-1BAD-D1A8-860E7607F174}.Release|x64.ActiveCfg = Release|x64
- {C363FFA1-FECA-1BAD-D1A8-860E7607F174}.Release|x64.Build.0 = Release|x64
- {EAB287E7-FECA-1BAD-EFA7-6773336A8585}.Debug|Win32.ActiveCfg = Debug|Win32
- {EAB287E7-FECA-1BAD-EFA7-6773336A8585}.Debug|Win32.Build.0 = Debug|Win32
- {EAB287E7-FECA-1BAD-EFA7-6773336A8585}.Debug|x64.ActiveCfg = Debug|x64
- {EAB287E7-FECA-1BAD-EFA7-6773336A8585}.Debug|x64.Build.0 = Debug|x64
- {EAB287E7-FECA-1BAD-EFA7-6773336A8585}.Release|Win32.ActiveCfg = Release|Win32
- {EAB287E7-FECA-1BAD-EFA7-6773336A8585}.Release|Win32.Build.0 = Release|Win32
- {EAB287E7-FECA-1BAD-EFA7-6773336A8585}.Release|x64.ActiveCfg = Release|x64
- {EAB287E7-FECA-1BAD-EFA7-6773336A8585}.Release|x64.Build.0 = Release|x64
- {01AE9706-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
- {01AE9706-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
- {01AE9706-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
- {01AE9706-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
- {01AE9706-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
- {01AE9706-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
- {01AE9706-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
- {01AE9706-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
- {9FC93C2F-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
- {9FC93C2F-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
- {9FC93C2F-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
- {9FC93C2F-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
- {9FC93C2F-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
- {9FC93C2F-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
- {9FC93C2F-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
- {9FC93C2F-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
- {FB3493EC-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
- {FB3493EC-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
- {FB3493EC-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
- {FB3493EC-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
- {FB3493EC-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
- {FB3493EC-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
- {FB3493EC-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
- {FB3493EC-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
- {52A8E79F-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
- {52A8E79F-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
- {52A8E79F-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
- {52A8E79F-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
- {52A8E79F-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
- {52A8E79F-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
- {52A8E79F-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
- {52A8E79F-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
- {BA1F88DF-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
- {BA1F88DF-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
- {BA1F88DF-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
- {BA1F88DF-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
- {BA1F88DF-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
- {BA1F88DF-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
- {BA1F88DF-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
- {BA1F88DF-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
- {BA81302E-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
- {BA81302E-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
- {BA81302E-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
- {BA81302E-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
- {BA81302E-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
- {BA81302E-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
- {BA81302E-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
- {BA81302E-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
- {9A299D4A-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
- {9A299D4A-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
- {9A299D4A-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
- {9A299D4A-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
- {9A299D4A-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
- {9A299D4A-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
- {9A299D4A-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
- {9A299D4A-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
- {6E3E4771-FECA-1BAD-4795-2E5476BD3033}.Debug|Win32.ActiveCfg = Debug|Win32
- {6E3E4771-FECA-1BAD-4795-2E5476BD3033}.Debug|Win32.Build.0 = Debug|Win32
- {6E3E4771-FECA-1BAD-4795-2E5476BD3033}.Debug|x64.ActiveCfg = Debug|x64
- {6E3E4771-FECA-1BAD-4795-2E5476BD3033}.Debug|x64.Build.0 = Debug|x64
- {6E3E4771-FECA-1BAD-4795-2E5476BD3033}.Release|Win32.ActiveCfg = Release|Win32
- {6E3E4771-FECA-1BAD-4795-2E5476BD3033}.Release|Win32.Build.0 = Release|Win32
- {6E3E4771-FECA-1BAD-4795-2E5476BD3033}.Release|x64.ActiveCfg = Release|x64
- {6E3E4771-FECA-1BAD-4795-2E5476BD3033}.Release|x64.Build.0 = Release|x64
- {555E57FB-FECA-1BAD-4795-2E5476BD3033}.Debug|Win32.ActiveCfg = Debug|Win32
- {555E57FB-FECA-1BAD-4795-2E5476BD3033}.Debug|Win32.Build.0 = Debug|Win32
- {555E57FB-FECA-1BAD-4795-2E5476BD3033}.Debug|x64.ActiveCfg = Debug|x64
- {555E57FB-FECA-1BAD-4795-2E5476BD3033}.Debug|x64.Build.0 = Debug|x64
- {555E57FB-FECA-1BAD-4795-2E5476BD3033}.Release|Win32.ActiveCfg = Release|Win32
- {555E57FB-FECA-1BAD-4795-2E5476BD3033}.Release|Win32.Build.0 = Release|Win32
- {555E57FB-FECA-1BAD-4795-2E5476BD3033}.Release|x64.ActiveCfg = Release|x64
- {555E57FB-FECA-1BAD-4795-2E5476BD3033}.Release|x64.Build.0 = Release|x64
- {17FB5738-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {17FB5738-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {17FB5738-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {17FB5738-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {17FB5738-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {17FB5738-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {17FB5738-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {17FB5738-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {429B09C1-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {429B09C1-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {429B09C1-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {429B09C1-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {429B09C1-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {429B09C1-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {429B09C1-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {429B09C1-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {D0378C0A-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {D0378C0A-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {D0378C0A-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {D0378C0A-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {D0378C0A-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {D0378C0A-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {D0378C0A-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {D0378C0A-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {567A6CD2-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {567A6CD2-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {567A6CD2-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {567A6CD2-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {567A6CD2-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {567A6CD2-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {567A6CD2-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {567A6CD2-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {9F0B01DB-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {9F0B01DB-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {9F0B01DB-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {9F0B01DB-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {9F0B01DB-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {9F0B01DB-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {9F0B01DB-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {9F0B01DB-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {DFE640A9-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {DFE640A9-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {DFE640A9-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {DFE640A9-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {DFE640A9-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {DFE640A9-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {DFE640A9-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {DFE640A9-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {B6AE0B92-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {B6AE0B92-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {B6AE0B92-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {B6AE0B92-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {B6AE0B92-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {B6AE0B92-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {B6AE0B92-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {B6AE0B92-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {EB8FF8FB-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {EB8FF8FB-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {EB8FF8FB-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {EB8FF8FB-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {EB8FF8FB-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {EB8FF8FB-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {EB8FF8FB-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {EB8FF8FB-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {10F4AFD0-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {10F4AFD0-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {10F4AFD0-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {10F4AFD0-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {10F4AFD0-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {10F4AFD0-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {10F4AFD0-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {10F4AFD0-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {EA987F8B-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {EA987F8B-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {EA987F8B-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {EA987F8B-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {EA987F8B-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {EA987F8B-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {EA987F8B-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {EA987F8B-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {2A170B05-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {2A170B05-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {2A170B05-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {2A170B05-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {2A170B05-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {2A170B05-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {2A170B05-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {2A170B05-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {76DC5F19-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {76DC5F19-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {76DC5F19-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {76DC5F19-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {76DC5F19-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {76DC5F19-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {76DC5F19-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {76DC5F19-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {5A6E7EF6-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {5A6E7EF6-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {5A6E7EF6-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {5A6E7EF6-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {5A6E7EF6-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {5A6E7EF6-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {5A6E7EF6-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {5A6E7EF6-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {B2D150A1-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {B2D150A1-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {B2D150A1-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {B2D150A1-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {B2D150A1-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {B2D150A1-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {B2D150A1-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {B2D150A1-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {2EDA9FA1-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {2EDA9FA1-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {2EDA9FA1-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {2EDA9FA1-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {2EDA9FA1-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {2EDA9FA1-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {2EDA9FA1-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {2EDA9FA1-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {81B72E1B-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {81B72E1B-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
- {81B72E1B-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
- {81B72E1B-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
- {81B72E1B-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
- {81B72E1B-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
- {81B72E1B-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
- {81B72E1B-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
- {61316AEC-FECA-1BAD-435E-C97DA4B8E121}.Debug|Win32.ActiveCfg = Debug|Win32
- {61316AEC-FECA-1BAD-435E-C97DA4B8E121}.Debug|Win32.Build.0 = Debug|Win32
- {61316AEC-FECA-1BAD-435E-C97DA4B8E121}.Debug|x64.ActiveCfg = Debug|x64
- {61316AEC-FECA-1BAD-435E-C97DA4B8E121}.Debug|x64.Build.0 = Debug|x64
- {61316AEC-FECA-1BAD-435E-C97DA4B8E121}.Release|Win32.ActiveCfg = Release|Win32
- {61316AEC-FECA-1BAD-435E-C97DA4B8E121}.Release|Win32.Build.0 = Release|Win32
- {61316AEC-FECA-1BAD-435E-C97DA4B8E121}.Release|x64.ActiveCfg = Release|x64
- {61316AEC-FECA-1BAD-435E-C97DA4B8E121}.Release|x64.Build.0 = Release|x64
- {31E5B795-FECA-1BAD-435E-C97DA4B8E121}.Debug|Win32.ActiveCfg = Debug|Win32
- {31E5B795-FECA-1BAD-435E-C97DA4B8E121}.Debug|Win32.Build.0 = Debug|Win32
- {31E5B795-FECA-1BAD-435E-C97DA4B8E121}.Debug|x64.ActiveCfg = Debug|x64
- {31E5B795-FECA-1BAD-435E-C97DA4B8E121}.Debug|x64.Build.0 = Debug|x64
- {31E5B795-FECA-1BAD-435E-C97DA4B8E121}.Release|Win32.ActiveCfg = Release|Win32
- {31E5B795-FECA-1BAD-435E-C97DA4B8E121}.Release|Win32.Build.0 = Release|Win32
- {31E5B795-FECA-1BAD-435E-C97DA4B8E121}.Release|x64.ActiveCfg = Release|x64
- {31E5B795-FECA-1BAD-435E-C97DA4B8E121}.Release|x64.Build.0 = Release|x64
- {259D7264-FECA-1BAD-8172-3C0D10CCFC97}.Debug|Win32.ActiveCfg = Debug|Win32
- {259D7264-FECA-1BAD-8172-3C0D10CCFC97}.Debug|Win32.Build.0 = Debug|Win32
- {259D7264-FECA-1BAD-8172-3C0D10CCFC97}.Debug|x64.ActiveCfg = Debug|x64
- {259D7264-FECA-1BAD-8172-3C0D10CCFC97}.Debug|x64.Build.0 = Debug|x64
- {259D7264-FECA-1BAD-8172-3C0D10CCFC97}.Release|Win32.ActiveCfg = Release|Win32
- {259D7264-FECA-1BAD-8172-3C0D10CCFC97}.Release|Win32.Build.0 = Release|Win32
- {259D7264-FECA-1BAD-8172-3C0D10CCFC97}.Release|x64.ActiveCfg = Release|x64
- {259D7264-FECA-1BAD-8172-3C0D10CCFC97}.Release|x64.Build.0 = Release|x64
- {43B94103-FECA-1BAD-8172-3C0D10CCFC97}.Debug|Win32.ActiveCfg = Debug|Win32
- {43B94103-FECA-1BAD-8172-3C0D10CCFC97}.Debug|Win32.Build.0 = Debug|Win32
- {43B94103-FECA-1BAD-8172-3C0D10CCFC97}.Debug|x64.ActiveCfg = Debug|x64
- {43B94103-FECA-1BAD-8172-3C0D10CCFC97}.Debug|x64.Build.0 = Debug|x64
- {43B94103-FECA-1BAD-8172-3C0D10CCFC97}.Release|Win32.ActiveCfg = Release|Win32
- {43B94103-FECA-1BAD-8172-3C0D10CCFC97}.Release|Win32.Build.0 = Release|Win32
- {43B94103-FECA-1BAD-8172-3C0D10CCFC97}.Release|x64.ActiveCfg = Release|x64
- {43B94103-FECA-1BAD-8172-3C0D10CCFC97}.Release|x64.Build.0 = Release|x64
- {D97D0DAC-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {D97D0DAC-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
- {D97D0DAC-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
- {D97D0DAC-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
- {D97D0DAC-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
- {D97D0DAC-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
- {D97D0DAC-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
- {D97D0DAC-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
- {0C959018-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {0C959018-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
- {0C959018-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
- {0C959018-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
- {0C959018-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
- {0C959018-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
- {0C959018-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
- {0C959018-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
- {F5A6CA84-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {F5A6CA84-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
- {F5A6CA84-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
- {F5A6CA84-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
- {F5A6CA84-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
- {F5A6CA84-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
- {F5A6CA84-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
- {F5A6CA84-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
- {E306CA92-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {E306CA92-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
- {E306CA92-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
- {E306CA92-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
- {E306CA92-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
- {E306CA92-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
- {E306CA92-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
- {E306CA92-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
- {AD15917E-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {AD15917E-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
- {AD15917E-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
- {AD15917E-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
- {AD15917E-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
- {AD15917E-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
- {AD15917E-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
- {AD15917E-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
- {9DA02FC8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {9DA02FC8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
- {9DA02FC8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
- {9DA02FC8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
- {9DA02FC8-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
- {9DA02FC8-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
- {9DA02FC8-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
- {9DA02FC8-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
- {0D7F7018-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {0D7F7018-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
- {0D7F7018-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
- {0D7F7018-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
- {0D7F7018-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
- {0D7F7018-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
- {0D7F7018-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
- {0D7F7018-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
- {830E2FC8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {830E2FC8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
- {830E2FC8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
- {830E2FC8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
- {830E2FC8-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
- {830E2FC8-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
- {830E2FC8-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
- {830E2FC8-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
- {7DEBC7D8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {7DEBC7D8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
- {7DEBC7D8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
- {7DEBC7D8-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
- {7DEBC7D8-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
- {7DEBC7D8-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
- {7DEBC7D8-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
- {7DEBC7D8-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
- {58DE56EF-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {58DE56EF-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
- {58DE56EF-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
- {58DE56EF-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
- {58DE56EF-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
- {58DE56EF-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
- {58DE56EF-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
- {58DE56EF-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
- {AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00}.Debug|Win32.ActiveCfg = Debug|Win32
- {AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00}.Debug|Win32.Build.0 = Debug|Win32
- {AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00}.Debug|x64.ActiveCfg = Debug|x64
- {AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00}.Debug|x64.Build.0 = Debug|x64
- {AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00}.Release|Win32.ActiveCfg = Release|Win32
- {AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00}.Release|Win32.Build.0 = Release|Win32
- {AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00}.Release|x64.ActiveCfg = Release|x64
- {AFEBBCD2-FECA-1BAD-7EA4-8B61A9309D00}.Release|x64.Build.0 = Release|x64
- {36D2F54A-FECA-1BAD-7EA4-8B61A9309D00}.Debug|Win32.ActiveCfg = Debug|Win32
- {36D2F54A-FECA-1BAD-7EA4-8B61A9309D00}.Debug|Win32.Build.0 = Debug|Win32
- {36D2F54A-FECA-1BAD-7EA4-8B61A9309D00}.Debug|x64.ActiveCfg = Debug|x64
- {36D2F54A-FECA-1BAD-7EA4-8B61A9309D00}.Debug|x64.Build.0 = Debug|x64
- {36D2F54A-FECA-1BAD-7EA4-8B61A9309D00}.Release|Win32.ActiveCfg = Release|Win32
- {36D2F54A-FECA-1BAD-7EA4-8B61A9309D00}.Release|Win32.Build.0 = Release|Win32
- {36D2F54A-FECA-1BAD-7EA4-8B61A9309D00}.Release|x64.ActiveCfg = Release|x64
- {36D2F54A-FECA-1BAD-7EA4-8B61A9309D00}.Release|x64.Build.0 = Release|x64
- {14E0A6C7-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|Win32.ActiveCfg = Debug|Win32
- {14E0A6C7-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|Win32.Build.0 = Debug|Win32
- {14E0A6C7-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|x64.ActiveCfg = Debug|x64
- {14E0A6C7-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|x64.Build.0 = Debug|x64
- {14E0A6C7-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|Win32.ActiveCfg = Release|Win32
- {14E0A6C7-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|Win32.Build.0 = Release|Win32
- {14E0A6C7-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|x64.ActiveCfg = Release|x64
- {14E0A6C7-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|x64.Build.0 = Release|x64
- {1C035591-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|Win32.ActiveCfg = Debug|Win32
- {1C035591-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|Win32.Build.0 = Debug|Win32
- {1C035591-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|x64.ActiveCfg = Debug|x64
- {1C035591-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|x64.Build.0 = Debug|x64
- {1C035591-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|Win32.ActiveCfg = Release|Win32
- {1C035591-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|Win32.Build.0 = Release|Win32
- {1C035591-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|x64.ActiveCfg = Release|x64
- {1C035591-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|x64.Build.0 = Release|x64
- {AF1D8F8B-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.ActiveCfg = Debug|Win32
- {AF1D8F8B-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.Build.0 = Debug|Win32
- {AF1D8F8B-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.ActiveCfg = Debug|x64
- {AF1D8F8B-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.Build.0 = Debug|x64
- {AF1D8F8B-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.ActiveCfg = Release|Win32
- {AF1D8F8B-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.Build.0 = Release|Win32
- {AF1D8F8B-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.ActiveCfg = Release|x64
- {AF1D8F8B-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.Build.0 = Release|x64
- {49CD7F91-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.ActiveCfg = Debug|Win32
- {49CD7F91-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.Build.0 = Debug|Win32
- {49CD7F91-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.ActiveCfg = Debug|x64
- {49CD7F91-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.Build.0 = Debug|x64
- {49CD7F91-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.ActiveCfg = Release|Win32
- {49CD7F91-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.Build.0 = Release|Win32
- {49CD7F91-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.ActiveCfg = Release|x64
- {49CD7F91-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.Build.0 = Release|x64
- {A479EB8E-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.ActiveCfg = Debug|Win32
- {A479EB8E-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.Build.0 = Debug|Win32
- {A479EB8E-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.ActiveCfg = Debug|x64
- {A479EB8E-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.Build.0 = Debug|x64
- {A479EB8E-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.ActiveCfg = Release|Win32
- {A479EB8E-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.Build.0 = Release|Win32
- {A479EB8E-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.ActiveCfg = Release|x64
- {A479EB8E-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.Build.0 = Release|x64
- {DDEDE8CD-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.ActiveCfg = Debug|Win32
- {DDEDE8CD-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.Build.0 = Debug|Win32
- {DDEDE8CD-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.ActiveCfg = Debug|x64
- {DDEDE8CD-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.Build.0 = Debug|x64
- {DDEDE8CD-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.ActiveCfg = Release|Win32
- {DDEDE8CD-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.Build.0 = Release|Win32
- {DDEDE8CD-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.ActiveCfg = Release|x64
- {DDEDE8CD-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.Build.0 = Release|x64
- {B2DA08F6-FECA-1BAD-5E18-91853C382470}.Debug|Win32.ActiveCfg = Debug|Win32
- {B2DA08F6-FECA-1BAD-5E18-91853C382470}.Debug|Win32.Build.0 = Debug|Win32
- {B2DA08F6-FECA-1BAD-5E18-91853C382470}.Debug|x64.ActiveCfg = Debug|x64
- {B2DA08F6-FECA-1BAD-5E18-91853C382470}.Debug|x64.Build.0 = Debug|x64
- {B2DA08F6-FECA-1BAD-5E18-91853C382470}.Release|Win32.ActiveCfg = Release|Win32
- {B2DA08F6-FECA-1BAD-5E18-91853C382470}.Release|Win32.Build.0 = Release|Win32
- {B2DA08F6-FECA-1BAD-5E18-91853C382470}.Release|x64.ActiveCfg = Release|x64
- {B2DA08F6-FECA-1BAD-5E18-91853C382470}.Release|x64.Build.0 = Release|x64
- {AD6A08F6-FECA-1BAD-5E18-91853C382470}.Debug|Win32.ActiveCfg = Debug|Win32
- {AD6A08F6-FECA-1BAD-5E18-91853C382470}.Debug|Win32.Build.0 = Debug|Win32
- {AD6A08F6-FECA-1BAD-5E18-91853C382470}.Debug|x64.ActiveCfg = Debug|x64
- {AD6A08F6-FECA-1BAD-5E18-91853C382470}.Debug|x64.Build.0 = Debug|x64
- {AD6A08F6-FECA-1BAD-5E18-91853C382470}.Release|Win32.ActiveCfg = Release|Win32
- {AD6A08F6-FECA-1BAD-5E18-91853C382470}.Release|Win32.Build.0 = Release|Win32
- {AD6A08F6-FECA-1BAD-5E18-91853C382470}.Release|x64.ActiveCfg = Release|x64
- {AD6A08F6-FECA-1BAD-5E18-91853C382470}.Release|x64.Build.0 = Release|x64
- {45E08B39-FECA-1BAD-474B-E6C11145E1EB}.Debug|Win32.ActiveCfg = Debug|Win32
- {45E08B39-FECA-1BAD-474B-E6C11145E1EB}.Debug|Win32.Build.0 = Debug|Win32
- {45E08B39-FECA-1BAD-474B-E6C11145E1EB}.Debug|x64.ActiveCfg = Debug|x64
- {45E08B39-FECA-1BAD-474B-E6C11145E1EB}.Debug|x64.Build.0 = Debug|x64
- {45E08B39-FECA-1BAD-474B-E6C11145E1EB}.Release|Win32.ActiveCfg = Release|Win32
- {45E08B39-FECA-1BAD-474B-E6C11145E1EB}.Release|Win32.Build.0 = Release|Win32
- {45E08B39-FECA-1BAD-474B-E6C11145E1EB}.Release|x64.ActiveCfg = Release|x64
- {45E08B39-FECA-1BAD-474B-E6C11145E1EB}.Release|x64.Build.0 = Release|x64
- {45E09BB9-FECA-1BAD-474B-E6C11145E1EB}.Debug|Win32.ActiveCfg = Debug|Win32
- {45E09BB9-FECA-1BAD-474B-E6C11145E1EB}.Debug|Win32.Build.0 = Debug|Win32
- {45E09BB9-FECA-1BAD-474B-E6C11145E1EB}.Debug|x64.ActiveCfg = Debug|x64
- {45E09BB9-FECA-1BAD-474B-E6C11145E1EB}.Debug|x64.Build.0 = Debug|x64
- {45E09BB9-FECA-1BAD-474B-E6C11145E1EB}.Release|Win32.ActiveCfg = Release|Win32
- {45E09BB9-FECA-1BAD-474B-E6C11145E1EB}.Release|Win32.Build.0 = Release|Win32
- {45E09BB9-FECA-1BAD-474B-E6C11145E1EB}.Release|x64.ActiveCfg = Release|x64
- {45E09BB9-FECA-1BAD-474B-E6C11145E1EB}.Release|x64.Build.0 = Release|x64
- {956C53A6-FECA-1BAD-F85A-8A37278A8232}.Debug|Win32.ActiveCfg = Debug|Win32
- {956C53A6-FECA-1BAD-F85A-8A37278A8232}.Debug|Win32.Build.0 = Debug|Win32
- {956C53A6-FECA-1BAD-F85A-8A37278A8232}.Debug|x64.ActiveCfg = Debug|x64
- {956C53A6-FECA-1BAD-F85A-8A37278A8232}.Debug|x64.Build.0 = Debug|x64
- {956C53A6-FECA-1BAD-F85A-8A37278A8232}.Release|Win32.ActiveCfg = Release|Win32
- {956C53A6-FECA-1BAD-F85A-8A37278A8232}.Release|Win32.Build.0 = Release|Win32
- {956C53A6-FECA-1BAD-F85A-8A37278A8232}.Release|x64.ActiveCfg = Release|x64
- {956C53A6-FECA-1BAD-F85A-8A37278A8232}.Release|x64.Build.0 = Release|x64
- {3135F526-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.ActiveCfg = Debug|Win32
- {3135F526-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.Build.0 = Debug|Win32
- {3135F526-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.ActiveCfg = Debug|x64
- {3135F526-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.Build.0 = Debug|x64
- {3135F526-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.ActiveCfg = Release|Win32
- {3135F526-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.Build.0 = Release|Win32
- {3135F526-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.ActiveCfg = Release|x64
- {3135F526-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.Build.0 = Release|x64
- {0A55E5AC-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.ActiveCfg = Debug|Win32
- {0A55E5AC-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.Build.0 = Debug|Win32
- {0A55E5AC-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.ActiveCfg = Debug|x64
- {0A55E5AC-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.Build.0 = Debug|x64
- {0A55E5AC-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.ActiveCfg = Release|Win32
- {0A55E5AC-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.Build.0 = Release|Win32
- {0A55E5AC-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.ActiveCfg = Release|x64
- {0A55E5AC-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.Build.0 = Release|x64
- {B8F98547-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.ActiveCfg = Debug|Win32
- {B8F98547-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.Build.0 = Debug|Win32
- {B8F98547-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.ActiveCfg = Debug|x64
- {B8F98547-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.Build.0 = Debug|x64
- {B8F98547-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.ActiveCfg = Release|Win32
- {B8F98547-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.Build.0 = Release|Win32
- {B8F98547-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.ActiveCfg = Release|x64
- {B8F98547-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.Build.0 = Release|x64
- {839995CD-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.ActiveCfg = Debug|Win32
- {839995CD-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.Build.0 = Debug|Win32
- {839995CD-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.ActiveCfg = Debug|x64
- {839995CD-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.Build.0 = Debug|x64
- {839995CD-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.ActiveCfg = Release|Win32
- {839995CD-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.Build.0 = Release|Win32
- {839995CD-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.ActiveCfg = Release|x64
- {839995CD-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.Build.0 = Release|x64
- {479FDD0E-FECA-1BAD-BE72-3C5B13526565}.Debug|Win32.ActiveCfg = Debug|Win32
- {479FDD0E-FECA-1BAD-BE72-3C5B13526565}.Debug|Win32.Build.0 = Debug|Win32
- {479FDD0E-FECA-1BAD-BE72-3C5B13526565}.Debug|x64.ActiveCfg = Debug|x64
- {479FDD0E-FECA-1BAD-BE72-3C5B13526565}.Debug|x64.Build.0 = Debug|x64
- {479FDD0E-FECA-1BAD-BE72-3C5B13526565}.Release|Win32.ActiveCfg = Release|Win32
- {479FDD0E-FECA-1BAD-BE72-3C5B13526565}.Release|Win32.Build.0 = Release|Win32
- {479FDD0E-FECA-1BAD-BE72-3C5B13526565}.Release|x64.ActiveCfg = Release|x64
- {479FDD0E-FECA-1BAD-BE72-3C5B13526565}.Release|x64.Build.0 = Release|x64
- {47AFDD0E-FECA-1BAD-BE72-3C5B13526565}.Debug|Win32.ActiveCfg = Debug|Win32
- {47AFDD0E-FECA-1BAD-BE72-3C5B13526565}.Debug|Win32.Build.0 = Debug|Win32
- {47AFDD0E-FECA-1BAD-BE72-3C5B13526565}.Debug|x64.ActiveCfg = Debug|x64
- {47AFDD0E-FECA-1BAD-BE72-3C5B13526565}.Debug|x64.Build.0 = Debug|x64
- {47AFDD0E-FECA-1BAD-BE72-3C5B13526565}.Release|Win32.ActiveCfg = Release|Win32
- {47AFDD0E-FECA-1BAD-BE72-3C5B13526565}.Release|Win32.Build.0 = Release|Win32
- {47AFDD0E-FECA-1BAD-BE72-3C5B13526565}.Release|x64.ActiveCfg = Release|x64
- {47AFDD0E-FECA-1BAD-BE72-3C5B13526565}.Release|x64.Build.0 = Release|x64
- {CD7ACAFF-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {CD7ACAFF-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {CD7ACAFF-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {CD7ACAFF-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {CD7ACAFF-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {CD7ACAFF-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {CD7ACAFF-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {CD7ACAFF-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {071AC791-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {071AC791-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {071AC791-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {071AC791-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {071AC791-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {071AC791-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {071AC791-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {071AC791-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {072AC791-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {072AC791-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {072AC791-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {072AC791-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {072AC791-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {072AC791-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {072AC791-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {072AC791-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {741AB165-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {741AB165-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {741AB165-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {741AB165-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {741AB165-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {741AB165-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {741AB165-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {741AB165-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {25926B98-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {25926B98-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {25926B98-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {25926B98-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {25926B98-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {25926B98-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {25926B98-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {25926B98-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {25A26B98-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {25A26B98-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {25A26B98-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {25A26B98-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {25A26B98-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {25A26B98-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {25A26B98-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {25A26B98-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {A4ACFB20-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {A4ACFB20-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {A4ACFB20-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {A4ACFB20-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {A4ACFB20-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {A4ACFB20-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {A4ACFB20-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {A4ACFB20-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {E43B5210-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {E43B5210-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {E43B5210-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {E43B5210-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {E43B5210-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {E43B5210-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {E43B5210-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {E43B5210-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {91B436D0-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {91B436D0-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {91B436D0-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {91B436D0-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {91B436D0-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {91B436D0-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {91B436D0-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {91B436D0-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {039899CB-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {039899CB-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {039899CB-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {039899CB-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {039899CB-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {039899CB-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {039899CB-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {039899CB-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {14E3314A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {14E3314A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {14E3314A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {14E3314A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {14E3314A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {14E3314A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {14E3314A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {14E3314A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {9FB54B2A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {9FB54B2A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {9FB54B2A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {9FB54B2A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {9FB54B2A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {9FB54B2A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {9FB54B2A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {9FB54B2A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {FDC54B2A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {FDC54B2A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {FDC54B2A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {FDC54B2A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {FDC54B2A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {FDC54B2A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {FDC54B2A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {FDC54B2A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {BE4CC735-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {BE4CC735-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {BE4CC735-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {BE4CC735-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {BE4CC735-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {BE4CC735-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {BE4CC735-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {BE4CC735-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {A32D8BF0-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {A32D8BF0-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {A32D8BF0-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {A32D8BF0-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {A32D8BF0-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {A32D8BF0-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {A32D8BF0-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {A32D8BF0-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {17ECC734-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {17ECC734-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {17ECC734-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {17ECC734-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {17ECC734-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {17ECC734-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {17ECC734-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {17ECC734-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {02E1116E-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {02E1116E-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {02E1116E-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {02E1116E-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {02E1116E-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {02E1116E-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {02E1116E-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {02E1116E-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {892C5420-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {892C5420-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {892C5420-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {892C5420-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {892C5420-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {892C5420-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {892C5420-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {892C5420-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {1D1735B6-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {1D1735B6-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {1D1735B6-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {1D1735B6-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {1D1735B6-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {1D1735B6-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {1D1735B6-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {1D1735B6-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {807F39EF-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {807F39EF-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {807F39EF-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {807F39EF-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {807F39EF-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {807F39EF-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {807F39EF-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {807F39EF-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {A4CB6018-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {A4CB6018-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {A4CB6018-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {A4CB6018-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {A4CB6018-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {A4CB6018-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {A4CB6018-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {A4CB6018-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {A4FB6018-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
- {A4FB6018-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
- {A4FB6018-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
- {A4FB6018-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
- {A4FB6018-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
- {A4FB6018-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
- {A4FB6018-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
- {A4FB6018-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
- {8ED0EFF7-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.ActiveCfg = Debug|Win32
- {8ED0EFF7-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.Build.0 = Debug|Win32
- {8ED0EFF7-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.ActiveCfg = Debug|x64
- {8ED0EFF7-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.Build.0 = Debug|x64
- {8ED0EFF7-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.ActiveCfg = Release|Win32
- {8ED0EFF7-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.Build.0 = Release|Win32
- {8ED0EFF7-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.ActiveCfg = Release|x64
- {8ED0EFF7-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.Build.0 = Release|x64
- {79C583DB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.ActiveCfg = Debug|Win32
- {79C583DB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.Build.0 = Debug|Win32
- {79C583DB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.ActiveCfg = Debug|x64
- {79C583DB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.Build.0 = Debug|x64
- {79C583DB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.ActiveCfg = Release|Win32
- {79C583DB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.Build.0 = Release|Win32
- {79C583DB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.ActiveCfg = Release|x64
- {79C583DB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.Build.0 = Release|x64
- {34746FFB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.ActiveCfg = Debug|Win32
- {34746FFB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.Build.0 = Debug|Win32
- {34746FFB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.ActiveCfg = Debug|x64
- {34746FFB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.Build.0 = Debug|x64
- {34746FFB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.ActiveCfg = Release|Win32
- {34746FFB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.Build.0 = Release|Win32
- {34746FFB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.ActiveCfg = Release|x64
- {34746FFB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.Build.0 = Release|x64
- {FAB2E9D3-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.ActiveCfg = Debug|Win32
- {FAB2E9D3-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.Build.0 = Debug|Win32
- {FAB2E9D3-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.ActiveCfg = Debug|x64
- {FAB2E9D3-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.Build.0 = Debug|x64
- {FAB2E9D3-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.ActiveCfg = Release|Win32
- {FAB2E9D3-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.Build.0 = Release|Win32
- {FAB2E9D3-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.ActiveCfg = Release|x64
- {FAB2E9D3-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.Build.0 = Release|x64
- {4767D3BB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.ActiveCfg = Debug|Win32
- {4767D3BB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.Build.0 = Debug|Win32
- {4767D3BB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.ActiveCfg = Debug|x64
- {4767D3BB-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.Build.0 = Debug|x64
- {4767D3BB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.ActiveCfg = Release|Win32
- {4767D3BB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.Build.0 = Release|Win32
- {4767D3BB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.ActiveCfg = Release|x64
- {4767D3BB-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.Build.0 = Release|x64
- {A1B7128D-FECA-1BAD-4B17-3E25DE61956F}.Debug|Win32.ActiveCfg = Debug|Win32
- {A1B7128D-FECA-1BAD-4B17-3E25DE61956F}.Debug|Win32.Build.0 = Debug|Win32
- {A1B7128D-FECA-1BAD-4B17-3E25DE61956F}.Debug|x64.ActiveCfg = Debug|x64
- {A1B7128D-FECA-1BAD-4B17-3E25DE61956F}.Debug|x64.Build.0 = Debug|x64
- {A1B7128D-FECA-1BAD-4B17-3E25DE61956F}.Release|Win32.ActiveCfg = Release|Win32
- {A1B7128D-FECA-1BAD-4B17-3E25DE61956F}.Release|Win32.Build.0 = Release|Win32
- {A1B7128D-FECA-1BAD-4B17-3E25DE61956F}.Release|x64.ActiveCfg = Release|x64
- {A1B7128D-FECA-1BAD-4B17-3E25DE61956F}.Release|x64.Build.0 = Release|x64
- {DC859D1C-FECA-1BAD-1120-8ECA0471D6B5}.Debug|Win32.ActiveCfg = Debug|Win32
- {DC859D1C-FECA-1BAD-1120-8ECA0471D6B5}.Debug|Win32.Build.0 = Debug|Win32
- {DC859D1C-FECA-1BAD-1120-8ECA0471D6B5}.Debug|x64.ActiveCfg = Debug|x64
- {DC859D1C-FECA-1BAD-1120-8ECA0471D6B5}.Debug|x64.Build.0 = Debug|x64
- {DC859D1C-FECA-1BAD-1120-8ECA0471D6B5}.Release|Win32.ActiveCfg = Release|Win32
- {DC859D1C-FECA-1BAD-1120-8ECA0471D6B5}.Release|Win32.Build.0 = Release|Win32
- {DC859D1C-FECA-1BAD-1120-8ECA0471D6B5}.Release|x64.ActiveCfg = Release|x64
- {DC859D1C-FECA-1BAD-1120-8ECA0471D6B5}.Release|x64.Build.0 = Release|x64
- {DCEA7D1C-FECA-1BAD-1120-8ECA0471D6B5}.Debug|Win32.ActiveCfg = Debug|Win32
- {DCEA7D1C-FECA-1BAD-1120-8ECA0471D6B5}.Debug|Win32.Build.0 = Debug|Win32
- {DCEA7D1C-FECA-1BAD-1120-8ECA0471D6B5}.Debug|x64.ActiveCfg = Debug|x64
- {DCEA7D1C-FECA-1BAD-1120-8ECA0471D6B5}.Debug|x64.Build.0 = Debug|x64
- {DCEA7D1C-FECA-1BAD-1120-8ECA0471D6B5}.Release|Win32.ActiveCfg = Release|Win32
- {DCEA7D1C-FECA-1BAD-1120-8ECA0471D6B5}.Release|Win32.Build.0 = Release|Win32
- {DCEA7D1C-FECA-1BAD-1120-8ECA0471D6B5}.Release|x64.ActiveCfg = Release|x64
- {DCEA7D1C-FECA-1BAD-1120-8ECA0471D6B5}.Release|x64.Build.0 = Release|x64
- {EC6BC324-FECA-1BAD-F396-8E392B1F0415}.Debug|Win32.ActiveCfg = Debug|Win32
- {EC6BC324-FECA-1BAD-F396-8E392B1F0415}.Debug|Win32.Build.0 = Debug|Win32
- {EC6BC324-FECA-1BAD-F396-8E392B1F0415}.Debug|x64.ActiveCfg = Debug|x64
- {EC6BC324-FECA-1BAD-F396-8E392B1F0415}.Debug|x64.Build.0 = Debug|x64
- {EC6BC324-FECA-1BAD-F396-8E392B1F0415}.Release|Win32.ActiveCfg = Release|Win32
- {EC6BC324-FECA-1BAD-F396-8E392B1F0415}.Release|Win32.Build.0 = Release|Win32
- {EC6BC324-FECA-1BAD-F396-8E392B1F0415}.Release|x64.ActiveCfg = Release|x64
- {EC6BC324-FECA-1BAD-F396-8E392B1F0415}.Release|x64.Build.0 = Release|x64
- {8DA65250-FECA-1BAD-1BE2-2E43250F5E17}.Debug|Win32.ActiveCfg = Debug|Win32
- {8DA65250-FECA-1BAD-1BE2-2E43250F5E17}.Debug|Win32.Build.0 = Debug|Win32
- {8DA65250-FECA-1BAD-1BE2-2E43250F5E17}.Debug|x64.ActiveCfg = Debug|x64
- {8DA65250-FECA-1BAD-1BE2-2E43250F5E17}.Debug|x64.Build.0 = Debug|x64
- {8DA65250-FECA-1BAD-1BE2-2E43250F5E17}.Release|Win32.ActiveCfg = Release|Win32
- {8DA65250-FECA-1BAD-1BE2-2E43250F5E17}.Release|Win32.Build.0 = Release|Win32
- {8DA65250-FECA-1BAD-1BE2-2E43250F5E17}.Release|x64.ActiveCfg = Release|x64
- {8DA65250-FECA-1BAD-1BE2-2E43250F5E17}.Release|x64.Build.0 = Release|x64
- {14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1}.Debug|Win32.ActiveCfg = Debug|Win32
- {14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1}.Debug|Win32.Build.0 = Debug|Win32
- {14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1}.Debug|x64.ActiveCfg = Debug|x64
- {14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1}.Debug|x64.Build.0 = Debug|x64
- {14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1}.Release|Win32.ActiveCfg = Release|Win32
- {14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1}.Release|Win32.Build.0 = Release|Win32
- {14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1}.Release|x64.ActiveCfg = Release|x64
- {14DAD4DD-FECA-1BAD-6AF0-8A634041F2D1}.Release|x64.Build.0 = Release|x64
- {528A9BEF-FECA-1BAD-0251-FF46ED064212}.Debug|Win32.ActiveCfg = Debug|Win32
- {528A9BEF-FECA-1BAD-0251-FF46ED064212}.Debug|Win32.Build.0 = Debug|Win32
- {528A9BEF-FECA-1BAD-0251-FF46ED064212}.Debug|x64.ActiveCfg = Debug|x64
- {528A9BEF-FECA-1BAD-0251-FF46ED064212}.Debug|x64.Build.0 = Debug|x64
- {528A9BEF-FECA-1BAD-0251-FF46ED064212}.Release|Win32.ActiveCfg = Release|Win32
- {528A9BEF-FECA-1BAD-0251-FF46ED064212}.Release|Win32.Build.0 = Release|Win32
- {528A9BEF-FECA-1BAD-0251-FF46ED064212}.Release|x64.ActiveCfg = Release|x64
- {528A9BEF-FECA-1BAD-0251-FF46ED064212}.Release|x64.Build.0 = Release|x64
- {80ED1E19-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {80ED1E19-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
- {80ED1E19-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
- {80ED1E19-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
- {80ED1E19-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
- {80ED1E19-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
- {80ED1E19-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
- {80ED1E19-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
- {2A3225FA-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {2A3225FA-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
- {2A3225FA-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
- {2A3225FA-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
- {2A3225FA-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
- {2A3225FA-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
- {2A3225FA-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
- {2A3225FA-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
- {F387C13A-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {F387C13A-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
- {F387C13A-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
- {F387C13A-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
- {F387C13A-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
- {F387C13A-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
- {F387C13A-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
- {F387C13A-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
- {52C62291-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {52C62291-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
- {52C62291-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
- {52C62291-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
- {52C62291-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
- {52C62291-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
- {52C62291-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
- {52C62291-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
- {D68CF3BC-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {D68CF3BC-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
- {D68CF3BC-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
- {D68CF3BC-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
- {D68CF3BC-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
- {D68CF3BC-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
- {D68CF3BC-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
- {D68CF3BC-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
- {904CF31D-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {904CF31D-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
- {904CF31D-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
- {904CF31D-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
- {904CF31D-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
- {904CF31D-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
- {904CF31D-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
- {904CF31D-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
- {CA960BF8-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {CA960BF8-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
- {CA960BF8-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
- {CA960BF8-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
- {CA960BF8-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
- {CA960BF8-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
- {CA960BF8-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
- {CA960BF8-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
- {9D05756B-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
- {9D05756B-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
- {9D05756B-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
- {9D05756B-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
- {9D05756B-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
- {9D05756B-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
- {9D05756B-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
- {9D05756B-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
- {95F3D6E0-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {95F3D6E0-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.Build.0 = Debug|Win32
- {95F3D6E0-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.ActiveCfg = Debug|x64
- {95F3D6E0-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.Build.0 = Debug|x64
- {95F3D6E0-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.ActiveCfg = Release|Win32
- {95F3D6E0-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.Build.0 = Release|Win32
- {95F3D6E0-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.ActiveCfg = Release|x64
- {95F3D6E0-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.Build.0 = Release|x64
- {2E4FB39E-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {2E4FB39E-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.Build.0 = Debug|Win32
- {2E4FB39E-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.ActiveCfg = Debug|x64
- {2E4FB39E-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.Build.0 = Debug|x64
- {2E4FB39E-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.ActiveCfg = Release|Win32
- {2E4FB39E-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.Build.0 = Release|Win32
- {2E4FB39E-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.ActiveCfg = Release|x64
- {2E4FB39E-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.Build.0 = Release|x64
- {306FB39F-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {306FB39F-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.Build.0 = Debug|Win32
- {306FB39F-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.ActiveCfg = Debug|x64
- {306FB39F-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.Build.0 = Debug|x64
- {306FB39F-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.ActiveCfg = Release|Win32
- {306FB39F-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.Build.0 = Release|Win32
- {306FB39F-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.ActiveCfg = Release|x64
- {306FB39F-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.Build.0 = Release|x64
- {8CE0384B-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {8CE0384B-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.Build.0 = Debug|Win32
- {8CE0384B-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.ActiveCfg = Debug|x64
- {8CE0384B-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.Build.0 = Debug|x64
- {8CE0384B-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.ActiveCfg = Release|Win32
- {8CE0384B-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.Build.0 = Release|Win32
- {8CE0384B-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.ActiveCfg = Release|x64
- {8CE0384B-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.Build.0 = Release|x64
- {92C0384A-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.ActiveCfg = Debug|Win32
- {92C0384A-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.Build.0 = Debug|Win32
- {92C0384A-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.ActiveCfg = Debug|x64
- {92C0384A-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.Build.0 = Debug|x64
- {92C0384A-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.ActiveCfg = Release|Win32
- {92C0384A-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.Build.0 = Release|Win32
- {92C0384A-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.ActiveCfg = Release|x64
- {92C0384A-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.Build.0 = Release|x64
- {A9A9AB69-FECA-1BAD-FAD8-7885071DD3E2}.Debug|Win32.ActiveCfg = Debug|Win32
- {A9A9AB69-FECA-1BAD-FAD8-7885071DD3E2}.Debug|Win32.Build.0 = Debug|Win32
- {A9A9AB69-FECA-1BAD-FAD8-7885071DD3E2}.Debug|x64.ActiveCfg = Debug|x64
- {A9A9AB69-FECA-1BAD-FAD8-7885071DD3E2}.Debug|x64.Build.0 = Debug|x64
- {A9A9AB69-FECA-1BAD-FAD8-7885071DD3E2}.Release|Win32.ActiveCfg = Release|Win32
- {A9A9AB69-FECA-1BAD-FAD8-7885071DD3E2}.Release|Win32.Build.0 = Release|Win32
- {A9A9AB69-FECA-1BAD-FAD8-7885071DD3E2}.Release|x64.ActiveCfg = Release|x64
- {A9A9AB69-FECA-1BAD-FAD8-7885071DD3E2}.Release|x64.Build.0 = Release|x64
- {BD437886-FECA-1BAD-FAD8-7885071DD3E2}.Debug|Win32.ActiveCfg = Debug|Win32
- {BD437886-FECA-1BAD-FAD8-7885071DD3E2}.Debug|Win32.Build.0 = Debug|Win32
- {BD437886-FECA-1BAD-FAD8-7885071DD3E2}.Debug|x64.ActiveCfg = Debug|x64
- {BD437886-FECA-1BAD-FAD8-7885071DD3E2}.Debug|x64.Build.0 = Debug|x64
- {BD437886-FECA-1BAD-FAD8-7885071DD3E2}.Release|Win32.ActiveCfg = Release|Win32
- {BD437886-FECA-1BAD-FAD8-7885071DD3E2}.Release|Win32.Build.0 = Release|Win32
- {BD437886-FECA-1BAD-FAD8-7885071DD3E2}.Release|x64.ActiveCfg = Release|x64
- {BD437886-FECA-1BAD-FAD8-7885071DD3E2}.Release|x64.Build.0 = Release|x64
- {561AAD84-FECA-1BAD-5029-42D0E18BA5D0}.Debug|Win32.ActiveCfg = Debug|Win32
- {561AAD84-FECA-1BAD-5029-42D0E18BA5D0}.Debug|Win32.Build.0 = Debug|Win32
- {561AAD84-FECA-1BAD-5029-42D0E18BA5D0}.Debug|x64.ActiveCfg = Debug|x64
- {561AAD84-FECA-1BAD-5029-42D0E18BA5D0}.Debug|x64.Build.0 = Debug|x64
- {561AAD84-FECA-1BAD-5029-42D0E18BA5D0}.Release|Win32.ActiveCfg = Release|Win32
- {561AAD84-FECA-1BAD-5029-42D0E18BA5D0}.Release|Win32.Build.0 = Release|Win32
- {561AAD84-FECA-1BAD-5029-42D0E18BA5D0}.Release|x64.ActiveCfg = Release|x64
- {561AAD84-FECA-1BAD-5029-42D0E18BA5D0}.Release|x64.Build.0 = Release|x64
- {1250DDDC-FECA-1BAD-5029-42D0E18BA5D0}.Debug|Win32.ActiveCfg = Debug|Win32
- {1250DDDC-FECA-1BAD-5029-42D0E18BA5D0}.Debug|Win32.Build.0 = Debug|Win32
- {1250DDDC-FECA-1BAD-5029-42D0E18BA5D0}.Debug|x64.ActiveCfg = Debug|x64
- {1250DDDC-FECA-1BAD-5029-42D0E18BA5D0}.Debug|x64.Build.0 = Debug|x64
- {1250DDDC-FECA-1BAD-5029-42D0E18BA5D0}.Release|Win32.ActiveCfg = Release|Win32
- {1250DDDC-FECA-1BAD-5029-42D0E18BA5D0}.Release|Win32.Build.0 = Release|Win32
- {1250DDDC-FECA-1BAD-5029-42D0E18BA5D0}.Release|x64.ActiveCfg = Release|x64
- {1250DDDC-FECA-1BAD-5029-42D0E18BA5D0}.Release|x64.Build.0 = Release|x64
- {334CEDB3-FECA-1BAD-A238-81D6AD345D00}.Debug|Win32.ActiveCfg = Debug|Win32
- {334CEDB3-FECA-1BAD-A238-81D6AD345D00}.Debug|Win32.Build.0 = Debug|Win32
- {334CEDB3-FECA-1BAD-A238-81D6AD345D00}.Debug|x64.ActiveCfg = Debug|x64
- {334CEDB3-FECA-1BAD-A238-81D6AD345D00}.Debug|x64.Build.0 = Debug|x64
- {334CEDB3-FECA-1BAD-A238-81D6AD345D00}.Release|Win32.ActiveCfg = Release|Win32
- {334CEDB3-FECA-1BAD-A238-81D6AD345D00}.Release|Win32.Build.0 = Release|Win32
- {334CEDB3-FECA-1BAD-A238-81D6AD345D00}.Release|x64.ActiveCfg = Release|x64
- {334CEDB3-FECA-1BAD-A238-81D6AD345D00}.Release|x64.Build.0 = Release|x64
- {3268FEB3-FECA-1BAD-A22A-C0E6EC045D12}.Debug|Win32.ActiveCfg = Debug|Win32
- {3268FEB3-FECA-1BAD-A22A-C0E6EC045D12}.Debug|Win32.Build.0 = Debug|Win32
- {3268FEB3-FECA-1BAD-A22A-C0E6EC045D12}.Debug|x64.ActiveCfg = Debug|x64
- {3268FEB3-FECA-1BAD-A22A-C0E6EC045D12}.Debug|x64.Build.0 = Debug|x64
- {3268FEB3-FECA-1BAD-A22A-C0E6EC045D12}.Release|Win32.ActiveCfg = Release|Win32
- {3268FEB3-FECA-1BAD-A22A-C0E6EC045D12}.Release|Win32.Build.0 = Release|Win32
- {3268FEB3-FECA-1BAD-A22A-C0E6EC045D12}.Release|x64.ActiveCfg = Release|x64
- {3268FEB3-FECA-1BAD-A22A-C0E6EC045D12}.Release|x64.Build.0 = Release|x64
- {E8B0F002-FECA-1BAD-BF87-400DF0C83E7D}.Debug|Win32.ActiveCfg = Debug|Win32
- {E8B0F002-FECA-1BAD-BF87-400DF0C83E7D}.Debug|Win32.Build.0 = Debug|Win32
- {E8B0F002-FECA-1BAD-BF87-400DF0C83E7D}.Debug|x64.ActiveCfg = Debug|x64
- {E8B0F002-FECA-1BAD-BF87-400DF0C83E7D}.Debug|x64.Build.0 = Debug|x64
- {E8B0F002-FECA-1BAD-BF87-400DF0C83E7D}.Release|Win32.ActiveCfg = Release|Win32
- {E8B0F002-FECA-1BAD-BF87-400DF0C83E7D}.Release|Win32.Build.0 = Release|Win32
- {E8B0F002-FECA-1BAD-BF87-400DF0C83E7D}.Release|x64.ActiveCfg = Release|x64
- {E8B0F002-FECA-1BAD-BF87-400DF0C83E7D}.Release|x64.Build.0 = Release|x64
- {BA83D332-FECA-1BAD-3A9E-1C813063C5A6}.Debug|Win32.ActiveCfg = Debug|Win32
- {BA83D332-FECA-1BAD-3A9E-1C813063C5A6}.Debug|Win32.Build.0 = Debug|Win32
- {BA83D332-FECA-1BAD-3A9E-1C813063C5A6}.Debug|x64.ActiveCfg = Debug|x64
- {BA83D332-FECA-1BAD-3A9E-1C813063C5A6}.Debug|x64.Build.0 = Debug|x64
- {BA83D332-FECA-1BAD-3A9E-1C813063C5A6}.Release|Win32.ActiveCfg = Release|Win32
- {BA83D332-FECA-1BAD-3A9E-1C813063C5A6}.Release|Win32.Build.0 = Release|Win32
- {BA83D332-FECA-1BAD-3A9E-1C813063C5A6}.Release|x64.ActiveCfg = Release|x64
- {BA83D332-FECA-1BAD-3A9E-1C813063C5A6}.Release|x64.Build.0 = Release|x64
- {16EC56EC-FECA-1BAD-5062-8A636F3FD3CA}.Debug|Win32.ActiveCfg = Debug|Win32
- {16EC56EC-FECA-1BAD-5062-8A636F3FD3CA}.Debug|Win32.Build.0 = Debug|Win32
- {16EC56EC-FECA-1BAD-5062-8A636F3FD3CA}.Debug|x64.ActiveCfg = Debug|x64
- {16EC56EC-FECA-1BAD-5062-8A636F3FD3CA}.Debug|x64.Build.0 = Debug|x64
- {16EC56EC-FECA-1BAD-5062-8A636F3FD3CA}.Release|Win32.ActiveCfg = Release|Win32
- {16EC56EC-FECA-1BAD-5062-8A636F3FD3CA}.Release|Win32.Build.0 = Release|Win32
- {16EC56EC-FECA-1BAD-5062-8A636F3FD3CA}.Release|x64.ActiveCfg = Release|x64
- {16EC56EC-FECA-1BAD-5062-8A636F3FD3CA}.Release|x64.Build.0 = Release|x64
- {01EC56EC-FECA-1BAD-5112-8A636F3FD2BA}.Debug|Win32.ActiveCfg = Debug|Win32
- {01EC56EC-FECA-1BAD-5112-8A636F3FD2BA}.Debug|Win32.Build.0 = Debug|Win32
- {01EC56EC-FECA-1BAD-5112-8A636F3FD2BA}.Debug|x64.ActiveCfg = Debug|x64
- {01EC56EC-FECA-1BAD-5112-8A636F3FD2BA}.Debug|x64.Build.0 = Debug|x64
- {01EC56EC-FECA-1BAD-5112-8A636F3FD2BA}.Release|Win32.ActiveCfg = Release|Win32
- {01EC56EC-FECA-1BAD-5112-8A636F3FD2BA}.Release|Win32.Build.0 = Release|Win32
- {01EC56EC-FECA-1BAD-5112-8A636F3FD2BA}.Release|x64.ActiveCfg = Release|x64
- {01EC56EC-FECA-1BAD-5112-8A636F3FD2BA}.Release|x64.Build.0 = Release|x64
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|Win32.ActiveCfg = Debug|Win32
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|Win32.Build.0 = Debug|Win32
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|x64.ActiveCfg = Debug|x64
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|x64.Build.0 = Debug|x64
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Release|Win32.ActiveCfg = Release|Win32
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Release|Win32.Build.0 = Release|Win32
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Release|x64.ActiveCfg = Release|x64
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Release|x64.Build.0 = Release|x64
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Debug|Win32.ActiveCfg = Debug|Win32
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Debug|Win32.Build.0 = Debug|Win32
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Debug|x64.ActiveCfg = Debug|x64
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Debug|x64.Build.0 = Debug|x64
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Release|Win32.ActiveCfg = Release|Win32
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Release|Win32.Build.0 = Release|Win32
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Release|x64.ActiveCfg = Release|x64
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Release|x64.Build.0 = Release|x64
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|Win32.ActiveCfg = Debug|Win32
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|Win32.Build.0 = Debug|Win32
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|x64.ActiveCfg = Debug|x64
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|x64.Build.0 = Debug|x64
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Release|Win32.ActiveCfg = Release|Win32
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Release|Win32.Build.0 = Release|Win32
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Release|x64.ActiveCfg = Release|x64
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Release|x64.Build.0 = Release|x64
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Debug|Win32.ActiveCfg = Debug|Win32
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Debug|Win32.Build.0 = Debug|Win32
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Debug|x64.ActiveCfg = Debug|x64
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Debug|x64.Build.0 = Debug|x64
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Release|Win32.ActiveCfg = Release|Win32
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Release|Win32.Build.0 = Release|Win32
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Release|x64.ActiveCfg = Release|x64
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Release|x64.Build.0 = Release|x64
- {AC7EC721-FECA-1BAD-F826-8A6564C116DB}.Debug|Win32.ActiveCfg = Debug|Win32
- {AC7EC721-FECA-1BAD-F826-8A6564C116DB}.Debug|Win32.Build.0 = Debug|Win32
- {AC7EC721-FECA-1BAD-F826-8A6564C116DB}.Debug|x64.ActiveCfg = Debug|x64
- {AC7EC721-FECA-1BAD-F826-8A6564C116DB}.Debug|x64.Build.0 = Debug|x64
- {AC7EC721-FECA-1BAD-F826-8A6564C116DB}.Release|Win32.ActiveCfg = Release|Win32
- {AC7EC721-FECA-1BAD-F826-8A6564C116DB}.Release|Win32.Build.0 = Release|Win32
- {AC7EC721-FECA-1BAD-F826-8A6564C116DB}.Release|x64.ActiveCfg = Release|x64
- {AC7EC721-FECA-1BAD-F826-8A6564C116DB}.Release|x64.Build.0 = Release|x64
- {AC37E721-FECA-1BAD-F826-8A6564C116DB}.Debug|Win32.ActiveCfg = Debug|Win32
- {AC37E721-FECA-1BAD-F826-8A6564C116DB}.Debug|Win32.Build.0 = Debug|Win32
- {AC37E721-FECA-1BAD-F826-8A6564C116DB}.Debug|x64.ActiveCfg = Debug|x64
- {AC37E721-FECA-1BAD-F826-8A6564C116DB}.Debug|x64.Build.0 = Debug|x64
- {AC37E721-FECA-1BAD-F826-8A6564C116DB}.Release|Win32.ActiveCfg = Release|Win32
- {AC37E721-FECA-1BAD-F826-8A6564C116DB}.Release|Win32.Build.0 = Release|Win32
- {AC37E721-FECA-1BAD-F826-8A6564C116DB}.Release|x64.ActiveCfg = Release|x64
- {AC37E721-FECA-1BAD-F826-8A6564C116DB}.Release|x64.Build.0 = Release|x64
- {453BE26D-FECA-1BAD-BA50-D9E259FB2871}.Debug|Win32.ActiveCfg = Debug|Win32
- {453BE26D-FECA-1BAD-BA50-D9E259FB2871}.Debug|Win32.Build.0 = Debug|Win32
- {453BE26D-FECA-1BAD-BA50-D9E259FB2871}.Debug|x64.ActiveCfg = Debug|x64
- {453BE26D-FECA-1BAD-BA50-D9E259FB2871}.Debug|x64.Build.0 = Debug|x64
- {453BE26D-FECA-1BAD-BA50-D9E259FB2871}.Release|Win32.ActiveCfg = Release|Win32
- {453BE26D-FECA-1BAD-BA50-D9E259FB2871}.Release|Win32.Build.0 = Release|Win32
- {453BE26D-FECA-1BAD-BA50-D9E259FB2871}.Release|x64.ActiveCfg = Release|x64
- {453BE26D-FECA-1BAD-BA50-D9E259FB2871}.Release|x64.Build.0 = Release|x64
- {889BA050-FECA-1BAD-BA50-D9E259FB2871}.Debug|Win32.ActiveCfg = Debug|Win32
- {889BA050-FECA-1BAD-BA50-D9E259FB2871}.Debug|Win32.Build.0 = Debug|Win32
- {889BA050-FECA-1BAD-BA50-D9E259FB2871}.Debug|x64.ActiveCfg = Debug|x64
- {889BA050-FECA-1BAD-BA50-D9E259FB2871}.Debug|x64.Build.0 = Debug|x64
- {889BA050-FECA-1BAD-BA50-D9E259FB2871}.Release|Win32.ActiveCfg = Release|Win32
- {889BA050-FECA-1BAD-BA50-D9E259FB2871}.Release|Win32.Build.0 = Release|Win32
- {889BA050-FECA-1BAD-BA50-D9E259FB2871}.Release|x64.ActiveCfg = Release|x64
- {889BA050-FECA-1BAD-BA50-D9E259FB2871}.Release|x64.Build.0 = Release|x64
- {52CC1DD2-FECA-1BAD-B420-8ED027BFCEB0}.Debug|Win32.ActiveCfg = Debug|Win32
- {52CC1DD2-FECA-1BAD-B420-8ED027BFCEB0}.Debug|Win32.Build.0 = Debug|Win32
- {52CC1DD2-FECA-1BAD-B420-8ED027BFCEB0}.Debug|x64.ActiveCfg = Debug|x64
- {52CC1DD2-FECA-1BAD-B420-8ED027BFCEB0}.Debug|x64.Build.0 = Debug|x64
- {52CC1DD2-FECA-1BAD-B420-8ED027BFCEB0}.Release|Win32.ActiveCfg = Release|Win32
- {52CC1DD2-FECA-1BAD-B420-8ED027BFCEB0}.Release|Win32.Build.0 = Release|Win32
- {52CC1DD2-FECA-1BAD-B420-8ED027BFCEB0}.Release|x64.ActiveCfg = Release|x64
- {52CC1DD2-FECA-1BAD-B420-8ED027BFCEB0}.Release|x64.Build.0 = Release|x64
- {3AD864B0-FECA-1BAD-1373-0D9555D094CD}.Debug|Win32.ActiveCfg = Debug|Win32
- {3AD864B0-FECA-1BAD-1373-0D9555D094CD}.Debug|Win32.Build.0 = Debug|Win32
- {3AD864B0-FECA-1BAD-1373-0D9555D094CD}.Debug|x64.ActiveCfg = Debug|x64
- {3AD864B0-FECA-1BAD-1373-0D9555D094CD}.Debug|x64.Build.0 = Debug|x64
- {3AD864B0-FECA-1BAD-1373-0D9555D094CD}.Release|Win32.ActiveCfg = Release|Win32
- {3AD864B0-FECA-1BAD-1373-0D9555D094CD}.Release|Win32.Build.0 = Release|Win32
- {3AD864B0-FECA-1BAD-1373-0D9555D094CD}.Release|x64.ActiveCfg = Release|x64
- {3AD864B0-FECA-1BAD-1373-0D9555D094CD}.Release|x64.Build.0 = Release|x64
- {01B8743A-FECA-1BAD-1373-0D9555D094CD}.Debug|Win32.ActiveCfg = Debug|Win32
- {01B8743A-FECA-1BAD-1373-0D9555D094CD}.Debug|Win32.Build.0 = Debug|Win32
- {01B8743A-FECA-1BAD-1373-0D9555D094CD}.Debug|x64.ActiveCfg = Debug|x64
- {01B8743A-FECA-1BAD-1373-0D9555D094CD}.Debug|x64.Build.0 = Debug|x64
- {01B8743A-FECA-1BAD-1373-0D9555D094CD}.Release|Win32.ActiveCfg = Release|Win32
- {01B8743A-FECA-1BAD-1373-0D9555D094CD}.Release|Win32.Build.0 = Release|Win32
- {01B8743A-FECA-1BAD-1373-0D9555D094CD}.Release|x64.ActiveCfg = Release|x64
- {01B8743A-FECA-1BAD-1373-0D9555D094CD}.Release|x64.Build.0 = Release|x64
- {12448205-FECA-1BAD-3BEF-EB20432B4020}.Debug|Win32.ActiveCfg = Debug|Win32
- {12448205-FECA-1BAD-3BEF-EB20432B4020}.Debug|Win32.Build.0 = Debug|Win32
- {12448205-FECA-1BAD-3BEF-EB20432B4020}.Debug|x64.ActiveCfg = Debug|x64
- {12448205-FECA-1BAD-3BEF-EB20432B4020}.Debug|x64.Build.0 = Debug|x64
- {12448205-FECA-1BAD-3BEF-EB20432B4020}.Release|Win32.ActiveCfg = Release|Win32
- {12448205-FECA-1BAD-3BEF-EB20432B4020}.Release|Win32.Build.0 = Release|Win32
- {12448205-FECA-1BAD-3BEF-EB20432B4020}.Release|x64.ActiveCfg = Release|x64
- {12448205-FECA-1BAD-3BEF-EB20432B4020}.Release|x64.Build.0 = Release|x64
- {2924928F-FECA-1BAD-3BEF-EB20432B4020}.Debug|Win32.ActiveCfg = Debug|Win32
- {2924928F-FECA-1BAD-3BEF-EB20432B4020}.Debug|Win32.Build.0 = Debug|Win32
- {2924928F-FECA-1BAD-3BEF-EB20432B4020}.Debug|x64.ActiveCfg = Debug|x64
- {2924928F-FECA-1BAD-3BEF-EB20432B4020}.Debug|x64.Build.0 = Debug|x64
- {2924928F-FECA-1BAD-3BEF-EB20432B4020}.Release|Win32.ActiveCfg = Release|Win32
- {2924928F-FECA-1BAD-3BEF-EB20432B4020}.Release|Win32.Build.0 = Release|Win32
- {2924928F-FECA-1BAD-3BEF-EB20432B4020}.Release|x64.ActiveCfg = Release|x64
- {2924928F-FECA-1BAD-3BEF-EB20432B4020}.Release|x64.Build.0 = Release|x64
- {33F9D729-FECA-1BAD-1A52-BE0C301D82A2}.Debug|Win32.ActiveCfg = Debug|Win32
- {33F9D729-FECA-1BAD-1A52-BE0C301D82A2}.Debug|Win32.Build.0 = Debug|Win32
- {33F9D729-FECA-1BAD-1A52-BE0C301D82A2}.Debug|x64.ActiveCfg = Debug|x64
- {33F9D729-FECA-1BAD-1A52-BE0C301D82A2}.Debug|x64.Build.0 = Debug|x64
- {33F9D729-FECA-1BAD-1A52-BE0C301D82A2}.Release|Win32.ActiveCfg = Release|Win32
- {33F9D729-FECA-1BAD-1A52-BE0C301D82A2}.Release|Win32.Build.0 = Release|Win32
- {33F9D729-FECA-1BAD-1A52-BE0C301D82A2}.Release|x64.ActiveCfg = Release|x64
- {33F9D729-FECA-1BAD-1A52-BE0C301D82A2}.Release|x64.Build.0 = Release|x64
- {0899C7A3-FECA-1BAD-1A52-BE0C301D82A2}.Debug|Win32.ActiveCfg = Debug|Win32
- {0899C7A3-FECA-1BAD-1A52-BE0C301D82A2}.Debug|Win32.Build.0 = Debug|Win32
- {0899C7A3-FECA-1BAD-1A52-BE0C301D82A2}.Debug|x64.ActiveCfg = Debug|x64
- {0899C7A3-FECA-1BAD-1A52-BE0C301D82A2}.Debug|x64.Build.0 = Debug|x64
- {0899C7A3-FECA-1BAD-1A52-BE0C301D82A2}.Release|Win32.ActiveCfg = Release|Win32
- {0899C7A3-FECA-1BAD-1A52-BE0C301D82A2}.Release|Win32.Build.0 = Release|Win32
- {0899C7A3-FECA-1BAD-1A52-BE0C301D82A2}.Release|x64.ActiveCfg = Release|x64
- {0899C7A3-FECA-1BAD-1A52-BE0C301D82A2}.Release|x64.Build.0 = Release|x64
- {462EE343-FECA-1BAD-6F85-8A64CD2507FC}.Debug|Win32.ActiveCfg = Debug|Win32
- {462EE343-FECA-1BAD-6F85-8A64CD2507FC}.Debug|Win32.Build.0 = Debug|Win32
- {462EE343-FECA-1BAD-6F85-8A64CD2507FC}.Debug|x64.ActiveCfg = Debug|x64
- {462EE343-FECA-1BAD-6F85-8A64CD2507FC}.Debug|x64.Build.0 = Debug|x64
- {462EE343-FECA-1BAD-6F85-8A64CD2507FC}.Release|Win32.ActiveCfg = Release|Win32
- {462EE343-FECA-1BAD-6F85-8A64CD2507FC}.Release|Win32.Build.0 = Release|Win32
- {462EE343-FECA-1BAD-6F85-8A64CD2507FC}.Release|x64.ActiveCfg = Release|x64
- {462EE343-FECA-1BAD-6F85-8A64CD2507FC}.Release|x64.Build.0 = Release|x64
- {7D4EF3C9-FECA-1BAD-6F85-8A64CD2507FC}.Debug|Win32.ActiveCfg = Debug|Win32
- {7D4EF3C9-FECA-1BAD-6F85-8A64CD2507FC}.Debug|Win32.Build.0 = Debug|Win32
- {7D4EF3C9-FECA-1BAD-6F85-8A64CD2507FC}.Debug|x64.ActiveCfg = Debug|x64
- {7D4EF3C9-FECA-1BAD-6F85-8A64CD2507FC}.Debug|x64.Build.0 = Debug|x64
- {7D4EF3C9-FECA-1BAD-6F85-8A64CD2507FC}.Release|Win32.ActiveCfg = Release|Win32
- {7D4EF3C9-FECA-1BAD-6F85-8A64CD2507FC}.Release|Win32.Build.0 = Release|Win32
- {7D4EF3C9-FECA-1BAD-6F85-8A64CD2507FC}.Release|x64.ActiveCfg = Release|x64
- {7D4EF3C9-FECA-1BAD-6F85-8A64CD2507FC}.Release|x64.Build.0 = Release|x64
- {02AC1EF2-FECA-1BAD-2246-8A6466E9CA6C}.Debug|Win32.ActiveCfg = Debug|Win32
- {02AC1EF2-FECA-1BAD-2246-8A6466E9CA6C}.Debug|Win32.Build.0 = Debug|Win32
- {02AC1EF2-FECA-1BAD-2246-8A6466E9CA6C}.Debug|x64.ActiveCfg = Debug|x64
- {02AC1EF2-FECA-1BAD-2246-8A6466E9CA6C}.Debug|x64.Build.0 = Debug|x64
- {02AC1EF2-FECA-1BAD-2246-8A6466E9CA6C}.Release|Win32.ActiveCfg = Release|Win32
- {02AC1EF2-FECA-1BAD-2246-8A6466E9CA6C}.Release|Win32.Build.0 = Release|Win32
- {02AC1EF2-FECA-1BAD-2246-8A6466E9CA6C}.Release|x64.ActiveCfg = Release|x64
- {02AC1EF2-FECA-1BAD-2246-8A6466E9CA6C}.Release|x64.Build.0 = Release|x64
- {536D0A81-FECA-1BAD-5646-8F0A8605F692}.Debug|Win32.ActiveCfg = Debug|Win32
- {536D0A81-FECA-1BAD-5646-8F0A8605F692}.Debug|Win32.Build.0 = Debug|Win32
- {536D0A81-FECA-1BAD-5646-8F0A8605F692}.Debug|x64.ActiveCfg = Debug|x64
- {536D0A81-FECA-1BAD-5646-8F0A8605F692}.Debug|x64.Build.0 = Debug|x64
- {536D0A81-FECA-1BAD-5646-8F0A8605F692}.Release|Win32.ActiveCfg = Release|Win32
- {536D0A81-FECA-1BAD-5646-8F0A8605F692}.Release|Win32.Build.0 = Release|Win32
- {536D0A81-FECA-1BAD-5646-8F0A8605F692}.Release|x64.ActiveCfg = Release|x64
- {536D0A81-FECA-1BAD-5646-8F0A8605F692}.Release|x64.Build.0 = Release|x64
- {648DF6B8-FECA-1BAD-5646-8F0A8605F692}.Debug|Win32.ActiveCfg = Debug|Win32
- {648DF6B8-FECA-1BAD-5646-8F0A8605F692}.Debug|Win32.Build.0 = Debug|Win32
- {648DF6B8-FECA-1BAD-5646-8F0A8605F692}.Debug|x64.ActiveCfg = Debug|x64
- {648DF6B8-FECA-1BAD-5646-8F0A8605F692}.Debug|x64.Build.0 = Debug|x64
- {648DF6B8-FECA-1BAD-5646-8F0A8605F692}.Release|Win32.ActiveCfg = Release|Win32
- {648DF6B8-FECA-1BAD-5646-8F0A8605F692}.Release|Win32.Build.0 = Release|Win32
- {648DF6B8-FECA-1BAD-5646-8F0A8605F692}.Release|x64.ActiveCfg = Release|x64
- {648DF6B8-FECA-1BAD-5646-8F0A8605F692}.Release|x64.Build.0 = Release|x64
- {34E9264B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {34E9264B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {34E9264B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {34E9264B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {34E9264B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {34E9264B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {34E9264B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {34E9264B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {30EA754B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {30EA754B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {30EA754B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {30EA754B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {30EA754B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {30EA754B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {30EA754B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {30EA754B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {52DBB421-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {52DBB421-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {52DBB421-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {52DBB421-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {52DBB421-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {52DBB421-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {52DBB421-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {52DBB421-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {DBF833EE-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {DBF833EE-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {DBF833EE-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {DBF833EE-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {DBF833EE-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {DBF833EE-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {DBF833EE-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {DBF833EE-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5817751F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5817751F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5817751F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5817751F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5817751F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5817751F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5817751F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5817751F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {8BC79562-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {8BC79562-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {8BC79562-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {8BC79562-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {8BC79562-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {8BC79562-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {8BC79562-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {8BC79562-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {86ABA561-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {86ABA561-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {86ABA561-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {86ABA561-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {86ABA561-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {86ABA561-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {86ABA561-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {86ABA561-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {CC9842E0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {CC9842E0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {CC9842E0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {CC9842E0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {CC9842E0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {CC9842E0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {CC9842E0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {CC9842E0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {51E3710F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {51E3710F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {51E3710F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {51E3710F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {51E3710F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {51E3710F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {51E3710F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {51E3710F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {A9C8A905-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {A9C8A905-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {A9C8A905-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {A9C8A905-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {A9C8A905-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {A9C8A905-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {A9C8A905-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {A9C8A905-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {EF5B40ED-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {EF5B40ED-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {EF5B40ED-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {EF5B40ED-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {EF5B40ED-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {EF5B40ED-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {EF5B40ED-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {EF5B40ED-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {970E15BD-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {970E15BD-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {970E15BD-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {970E15BD-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {970E15BD-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {970E15BD-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {970E15BD-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {970E15BD-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B50B25C8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B50B25C8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B50B25C8-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B50B25C8-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B50B25C8-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B50B25C8-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B50B25C8-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B50B25C8-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {32DF2C31-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {32DF2C31-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {32DF2C31-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {32DF2C31-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {32DF2C31-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {32DF2C31-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {32DF2C31-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {32DF2C31-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {748CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {748CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {748CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {748CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {748CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {748CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {748CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {748CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {AAECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {AAECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {AAECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {AAECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {AAECBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {AAECBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {AAECBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {AAECBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {156CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {156CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {156CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {156CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {156CBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {156CBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {156CBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {156CBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {60ACBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {60ACBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {60ACBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {60ACBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {60ACBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {60ACBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {60ACBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {60ACBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {6A9CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {6A9CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {6A9CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {6A9CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {6A9CBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {6A9CBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {6A9CBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {6A9CBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {77ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {77ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {77ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {77ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {77ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {77ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {77ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {77ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {437CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {437CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {437CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {437CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {437CBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {437CBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {437CBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {437CBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {42ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {42ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {42ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {42ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {42ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {42ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {42ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {42ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {46DCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {46DCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {46DCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {46DCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {46DCBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {46DCBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {46DCBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {46DCBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {467CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {467CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {467CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {467CBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {467CBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {467CBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {467CBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {467CBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {57ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {57ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {57ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {57ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {57ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {57ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {57ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {57ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {54CCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {54CCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {54CCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {54CCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {54CCBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {54CCBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {54CCBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {54CCBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {A2BCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {A2BCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {A2BCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {A2BCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {A2BCBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {A2BCBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {A2BCBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {A2BCBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {A1ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {A1ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {A1ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {A1ECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {A1ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {A1ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {A1ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {A1ECBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B4BCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B4BCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B4BCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B4BCBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B4BCBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B4BCBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B4BCBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B4BCBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {62D8584E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {62D8584E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {62D8584E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {62D8584E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {62D8584E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {62D8584E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {62D8584E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {62D8584E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {BBECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {BBECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {BBECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {BBECBC8E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {BBECBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {BBECBC8E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {BBECBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {BBECBC8E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {33CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {33CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {33CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {33CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {33CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {33CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {33CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {33CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {127CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {127CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {127CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {127CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {127CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {127CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {127CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {127CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {10CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {10CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {10CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {10CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {10CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {10CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {10CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {10CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {10ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {10ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {10ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {10ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {10ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {10ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {10ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {10ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {60CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {60CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {60CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {60CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {60CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {60CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {60CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {60CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {73ECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {73ECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {73ECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {73ECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {73ECBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {73ECBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {73ECBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {73ECBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {73BCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {73BCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {73BCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {73BCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {73BCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {73BCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {73BCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {73BCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {70CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {70CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {70CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {70CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {70CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {70CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {70CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {70CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {707CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {707CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {707CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {707CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {707CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {707CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {707CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {707CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {77FCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {77FCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {77FCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {77FCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {77FCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {77FCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {77FCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {77FCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {44DCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {44DCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {44DCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {44DCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {44DCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {44DCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {44DCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {44DCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {537CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {537CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {537CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {537CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {537CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {537CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {537CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {537CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {52ECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {52ECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {52ECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {52ECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {52ECBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {52ECBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {52ECBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {52ECBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {517CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {517CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {517CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {517CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {517CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {517CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {517CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {517CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {57ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {57ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {57ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {57ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {57ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {57ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {57ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {57ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {566CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {566CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {566CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {566CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {566CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {566CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {566CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {566CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {A46CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {A46CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {A46CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {A46CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {A46CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {A46CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {A46CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {A46CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B2FCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B2FCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B2FCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B2FCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B2FCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B2FCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B2FCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B2FCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B2CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B2CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B2CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B2CCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B2CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B2CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B2CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B2CCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B7DCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B7DCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B7DCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B7DCBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B7DCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B7DCBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B7DCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B7DCBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B4ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B4ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B4ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B4ACBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B4ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B4ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B4ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B4ACBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {26BCBC88-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {26BCBC88-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {26BCBC88-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {26BCBC88-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {26BCBC88-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {26BCBC88-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {26BCBC88-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {26BCBC88-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {82F87D5C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {82F87D5C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {82F87D5C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {82F87D5C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {82F87D5C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {82F87D5C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {82F87D5C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {82F87D5C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {4FA3F23A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {4FA3F23A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {4FA3F23A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {4FA3F23A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {4FA3F23A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {4FA3F23A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {4FA3F23A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {4FA3F23A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {34EB414B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {34EB414B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {34EB414B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {34EB414B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {34EB414B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {34EB414B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {34EB414B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {34EB414B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {AC665185-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {AC665185-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {AC665185-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {AC665185-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {AC665185-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {AC665185-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {AC665185-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {AC665185-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {1E46DF32-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {1E46DF32-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {1E46DF32-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {1E46DF32-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {1E46DF32-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {1E46DF32-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {1E46DF32-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {1E46DF32-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {FFFF62B6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {FFFF62B6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {FFFF62B6-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {FFFF62B6-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {FFFF62B6-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {FFFF62B6-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {FFFF62B6-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {FFFF62B6-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {2FB0A8A8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {2FB0A8A8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {2FB0A8A8-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {2FB0A8A8-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {2FB0A8A8-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {2FB0A8A8-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {2FB0A8A8-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {2FB0A8A8-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {9ED51704-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {9ED51704-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {9ED51704-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {9ED51704-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {9ED51704-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {9ED51704-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {9ED51704-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {9ED51704-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {6D8F104F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {6D8F104F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {6D8F104F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {6D8F104F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {6D8F104F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {6D8F104F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {6D8F104F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {6D8F104F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {008794E1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {008794E1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {008794E1-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {008794E1-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {008794E1-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {008794E1-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {008794E1-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {008794E1-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529F283-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529F283-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529F283-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529F283-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529F283-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529F283-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529F283-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529F283-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529F183-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529F183-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529F183-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529F183-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529F183-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529F183-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529F183-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529F183-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529F083-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529F083-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529F083-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529F083-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529F083-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529F083-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529F083-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529F083-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529F783-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529F783-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529F783-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529F783-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529F783-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529F783-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529F783-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529F783-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529F683-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529F683-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529F683-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529F683-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529F683-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529F683-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529F683-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529F683-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529F583-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529F583-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529F583-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529F583-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529F583-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529F583-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529F583-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529F583-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529F483-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529F483-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529F483-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529F483-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529F483-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529F483-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529F483-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529F483-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529FA83-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529FA83-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529FA83-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529FA83-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529FA83-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529FA83-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529FA83-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529FA83-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529E383-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529E383-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529E383-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529E383-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529E383-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529E383-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529E383-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529E383-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529E283-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529E283-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529E283-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529E283-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529E283-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529E283-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529E283-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529E283-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529E183-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529E183-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529E183-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529E183-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529E183-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529E183-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529E183-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529E183-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529E083-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529E083-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529E083-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529E083-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529E083-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529E083-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529E083-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529E083-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529E783-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529E783-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529E783-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529E783-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529E783-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529E783-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529E783-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529E783-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529E683-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529E683-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529E683-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529E683-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529E683-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529E683-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529E683-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529E683-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529E583-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529E583-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529E583-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529E583-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529E583-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529E583-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529E583-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529E583-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529E483-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529E483-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529E483-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529E483-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529E483-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529E483-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529E483-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529E483-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529EB83-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529EB83-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529EB83-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529EB83-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529EB83-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529EB83-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529EB83-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529EB83-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529EA83-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529EA83-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529EA83-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529EA83-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529EA83-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529EA83-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529EA83-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529EA83-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529D383-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529D383-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529D383-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529D383-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529D383-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529D383-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529D383-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529D383-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529D283-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529D283-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529D283-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529D283-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529D283-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529D283-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529D283-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529D283-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529D183-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529D183-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529D183-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529D183-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529D183-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529D183-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529D183-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529D183-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529D083-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529D083-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529D083-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529D083-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529D083-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529D083-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529D083-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529D083-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529D783-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529D783-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529D783-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529D783-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529D783-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529D783-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529D783-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529D783-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529D683-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529D683-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529D683-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529D683-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529D683-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529D683-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529D683-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529D683-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529D583-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529D583-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529D583-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529D583-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529D583-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529D583-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529D583-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529D583-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529D483-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529D483-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529D483-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529D483-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529D483-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529D483-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529D483-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529D483-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529DB83-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529DB83-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529DB83-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529DB83-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529DB83-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529DB83-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529DB83-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529DB83-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529DA83-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529DA83-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529DA83-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529DA83-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529DA83-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529DA83-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529DA83-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529DA83-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529C283-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529C283-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529C283-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529C283-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529C283-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529C283-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529C283-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529C283-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529C183-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529C183-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529C183-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529C183-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529C183-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529C183-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529C183-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529C183-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529C083-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529C083-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529C083-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529C083-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529C083-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529C083-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529C083-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529C083-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5529C783-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5529C783-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5529C783-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5529C783-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5529C783-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5529C783-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5529C783-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5529C783-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {6D2CA44F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {6D2CA44F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {6D2CA44F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {6D2CA44F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {6D2CA44F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {6D2CA44F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {6D2CA44F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {6D2CA44F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {30F5DD4B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {30F5DD4B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {30F5DD4B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {30F5DD4B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {30F5DD4B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {30F5DD4B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {30F5DD4B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {30F5DD4B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {366E72B2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {366E72B2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {366E72B2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {366E72B2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {366E72B2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {366E72B2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {366E72B2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {366E72B2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {11324DB7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {11324DB7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {11324DB7-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {11324DB7-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {11324DB7-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {11324DB7-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {11324DB7-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {11324DB7-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {34ECDF4B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {34ECDF4B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {34ECDF4B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {34ECDF4B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {34ECDF4B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {34ECDF4B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {34ECDF4B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {34ECDF4B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {3C02174F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {3C02174F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {3C02174F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {3C02174F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {3C02174F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {3C02174F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {3C02174F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {3C02174F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {3E83A429-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {3E83A429-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {3E83A429-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {3E83A429-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {3E83A429-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {3E83A429-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {3E83A429-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {3E83A429-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {39877CCD-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {39877CCD-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {39877CCD-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {39877CCD-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {39877CCD-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {39877CCD-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {39877CCD-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {39877CCD-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {1AEFC74F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {1AEFC74F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {1AEFC74F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {1AEFC74F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {1AEFC74F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {1AEFC74F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {1AEFC74F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {1AEFC74F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {4B5D0400-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {4B5D0400-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {4B5D0400-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {4B5D0400-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {4B5D0400-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {4B5D0400-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {4B5D0400-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {4B5D0400-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {CCD7A008-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {CCD7A008-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {CCD7A008-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {CCD7A008-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {CCD7A008-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {CCD7A008-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {CCD7A008-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {CCD7A008-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {E752892A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {E752892A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {E752892A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {E752892A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {E752892A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {E752892A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {E752892A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {E752892A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {94D725D8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {94D725D8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {94D725D8-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {94D725D8-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {94D725D8-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {94D725D8-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {94D725D8-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {94D725D8-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {30817C4B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {30817C4B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {30817C4B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {30817C4B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {30817C4B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {30817C4B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {30817C4B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {30817C4B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {9F3490D0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {9F3490D0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {9F3490D0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {9F3490D0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {9F3490D0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {9F3490D0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {9F3490D0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {9F3490D0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {45203563-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {45203563-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {45203563-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {45203563-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {45203563-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {45203563-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {45203563-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {45203563-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {740D6579-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {740D6579-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {740D6579-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {740D6579-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {740D6579-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {740D6579-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {740D6579-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {740D6579-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {269E164F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {269E164F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {269E164F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {269E164F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {269E164F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {269E164F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {269E164F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {269E164F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {1514270A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {1514270A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {1514270A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {1514270A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {1514270A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {1514270A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {1514270A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {1514270A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {940D90C9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {940D90C9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {940D90C9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {940D90C9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {940D90C9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {940D90C9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {940D90C9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {940D90C9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {78A7ABFA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {78A7ABFA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {78A7ABFA-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {78A7ABFA-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {78A7ABFA-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {78A7ABFA-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {78A7ABFA-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {78A7ABFA-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {11661016-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {11661016-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {11661016-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {11661016-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {11661016-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {11661016-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {11661016-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {11661016-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {863BAECF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {863BAECF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {863BAECF-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {863BAECF-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {863BAECF-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {863BAECF-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {863BAECF-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {863BAECF-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {794AD569-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {794AD569-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {794AD569-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {794AD569-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {794AD569-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {794AD569-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {794AD569-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {794AD569-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {E5AFA072-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {E5AFA072-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {E5AFA072-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {E5AFA072-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {E5AFA072-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {E5AFA072-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {E5AFA072-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {E5AFA072-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {2FDE2CEB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {2FDE2CEB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {2FDE2CEB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {2FDE2CEB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {2FDE2CEB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {2FDE2CEB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {2FDE2CEB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {2FDE2CEB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {77EF2A91-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {77EF2A91-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {77EF2A91-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {77EF2A91-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {77EF2A91-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {77EF2A91-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {77EF2A91-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {77EF2A91-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {2FE80887-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {2FE80887-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {2FE80887-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {2FE80887-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {2FE80887-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {2FE80887-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {2FE80887-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {2FE80887-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {3BEF931C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {3BEF931C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {3BEF931C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {3BEF931C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {3BEF931C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {3BEF931C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {3BEF931C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {3BEF931C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {90661056-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {90661056-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {90661056-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {90661056-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {90661056-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {90661056-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {90661056-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {90661056-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {C1F0BF96-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {C1F0BF96-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {C1F0BF96-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {C1F0BF96-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {C1F0BF96-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {C1F0BF96-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {C1F0BF96-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {C1F0BF96-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {D3C585B5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {D3C585B5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {D3C585B5-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {D3C585B5-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {D3C585B5-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {D3C585B5-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {D3C585B5-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {D3C585B5-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {A6160401-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {A6160401-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {A6160401-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {A6160401-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {A6160401-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {A6160401-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {A6160401-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {A6160401-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {0E41A728-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {0E41A728-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {0E41A728-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {0E41A728-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {0E41A728-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {0E41A728-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {0E41A728-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {0E41A728-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {637774A1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {637774A1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {637774A1-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {637774A1-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {637774A1-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {637774A1-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {637774A1-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {637774A1-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {77EBBFC1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {77EBBFC1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {77EBBFC1-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {77EBBFC1-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {77EBBFC1-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {77EBBFC1-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {77EBBFC1-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {77EBBFC1-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {22F24DC8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {22F24DC8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {22F24DC8-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {22F24DC8-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {22F24DC8-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {22F24DC8-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {22F24DC8-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {22F24DC8-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B8480FB0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B8480FB0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B8480FB0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B8480FB0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B8480FB0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B8480FB0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B8480FB0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B8480FB0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {3260374D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {3260374D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {3260374D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {3260374D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {3260374D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {3260374D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {3260374D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {3260374D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {518F9F2B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {518F9F2B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {518F9F2B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {518F9F2B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {518F9F2B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {518F9F2B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {518F9F2B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {518F9F2B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {4F87D6F7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {4F87D6F7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {4F87D6F7-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {4F87D6F7-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {4F87D6F7-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {4F87D6F7-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {4F87D6F7-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {4F87D6F7-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {E6B1F618-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {E6B1F618-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {E6B1F618-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {E6B1F618-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {E6B1F618-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {E6B1F618-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {E6B1F618-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {E6B1F618-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {2ED72803-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {2ED72803-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {2ED72803-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {2ED72803-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {2ED72803-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {2ED72803-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {2ED72803-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {2ED72803-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {8306C04F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {8306C04F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {8306C04F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {8306C04F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {8306C04F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {8306C04F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {8306C04F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {8306C04F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {82185432-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {82185432-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {82185432-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {82185432-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {82185432-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {82185432-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {82185432-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {82185432-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {4C9614F0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {4C9614F0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {4C9614F0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {4C9614F0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {4C9614F0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {4C9614F0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {4C9614F0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {4C9614F0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {34E7334B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {34E7334B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {34E7334B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {34E7334B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {34E7334B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {34E7334B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {34E7334B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {34E7334B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {777203E0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {777203E0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {777203E0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {777203E0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {777203E0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {777203E0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {777203E0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {777203E0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {F5E705C6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {F5E705C6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {F5E705C6-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {F5E705C6-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {F5E705C6-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {F5E705C6-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {F5E705C6-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {F5E705C6-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {0C173300-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {0C173300-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {0C173300-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {0C173300-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {0C173300-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {0C173300-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {0C173300-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {0C173300-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {87182A4F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {87182A4F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {87182A4F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {87182A4F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {87182A4F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {87182A4F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {87182A4F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {87182A4F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {EF6E83F2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {EF6E83F2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {EF6E83F2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {EF6E83F2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {EF6E83F2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {EF6E83F2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {EF6E83F2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {EF6E83F2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {CB215F5B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {CB215F5B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {CB215F5B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {CB215F5B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {CB215F5B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {CB215F5B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {CB215F5B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {CB215F5B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {FE3A26D9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {FE3A26D9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {FE3A26D9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {FE3A26D9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {FE3A26D9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {FE3A26D9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {FE3A26D9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {FE3A26D9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {C4177A79-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {C4177A79-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {C4177A79-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {C4177A79-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {C4177A79-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {C4177A79-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {C4177A79-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {C4177A79-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {D9BA315B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {D9BA315B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {D9BA315B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {D9BA315B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {D9BA315B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {D9BA315B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {D9BA315B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {D9BA315B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {1A0DFBB5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {1A0DFBB5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {1A0DFBB5-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {1A0DFBB5-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {1A0DFBB5-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {1A0DFBB5-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {1A0DFBB5-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {1A0DFBB5-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {54907DB9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {54907DB9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {54907DB9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {54907DB9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {54907DB9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {54907DB9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {54907DB9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {54907DB9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B138A9E6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B138A9E6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B138A9E6-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B138A9E6-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B138A9E6-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B138A9E6-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B138A9E6-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B138A9E6-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {E70221C0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {E70221C0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {E70221C0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {E70221C0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {E70221C0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {E70221C0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {E70221C0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {E70221C0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {FC1CE235-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {FC1CE235-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {FC1CE235-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {FC1CE235-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {FC1CE235-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {FC1CE235-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {FC1CE235-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {FC1CE235-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {1BFA5D70-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {1BFA5D70-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {1BFA5D70-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {1BFA5D70-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {1BFA5D70-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {1BFA5D70-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {1BFA5D70-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {1BFA5D70-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {CA465956-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {CA465956-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {CA465956-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {CA465956-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {CA465956-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {CA465956-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {CA465956-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {CA465956-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B04C6E15-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B04C6E15-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B04C6E15-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B04C6E15-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B04C6E15-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B04C6E15-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B04C6E15-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B04C6E15-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B313D44F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B313D44F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B313D44F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B313D44F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B313D44F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B313D44F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B313D44F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B313D44F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {620AEFBB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {620AEFBB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {620AEFBB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {620AEFBB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {620AEFBB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {620AEFBB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {620AEFBB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {620AEFBB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {1FABABC9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {1FABABC9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {1FABABC9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {1FABABC9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {1FABABC9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {1FABABC9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {1FABABC9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {1FABABC9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {BB5C843A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {BB5C843A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {BB5C843A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {BB5C843A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {BB5C843A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {BB5C843A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {BB5C843A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {BB5C843A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {45DE2142-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {45DE2142-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {45DE2142-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {45DE2142-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {45DE2142-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {45DE2142-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {45DE2142-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {45DE2142-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {6376AA6C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {6376AA6C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {6376AA6C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {6376AA6C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {6376AA6C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {6376AA6C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {6376AA6C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {6376AA6C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {34A8F04B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {34A8F04B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {34A8F04B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {34A8F04B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {34A8F04B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {34A8F04B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {34A8F04B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {34A8F04B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {18E5B4BF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {18E5B4BF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {18E5B4BF-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {18E5B4BF-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {18E5B4BF-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {18E5B4BF-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {18E5B4BF-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {18E5B4BF-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {D81E30F4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {D81E30F4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {D81E30F4-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {D81E30F4-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {D81E30F4-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {D81E30F4-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {D81E30F4-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {D81E30F4-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {608B0802-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {608B0802-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {608B0802-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {608B0802-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {608B0802-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {608B0802-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {608B0802-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {608B0802-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {862137E8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {862137E8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {862137E8-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {862137E8-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {862137E8-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {862137E8-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {862137E8-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {862137E8-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {31C2364B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {31C2364B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {31C2364B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {31C2364B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {31C2364B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {31C2364B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {31C2364B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {31C2364B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {282892D7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {282892D7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {282892D7-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {282892D7-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {282892D7-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {282892D7-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {282892D7-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {282892D7-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {FBA0E89B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {FBA0E89B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {FBA0E89B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {FBA0E89B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {FBA0E89B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {FBA0E89B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {FBA0E89B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {FBA0E89B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {A9C58CA8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {A9C58CA8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {A9C58CA8-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {A9C58CA8-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {A9C58CA8-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {A9C58CA8-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {A9C58CA8-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {A9C58CA8-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {3E957B1D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {3E957B1D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {3E957B1D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {3E957B1D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {3E957B1D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {3E957B1D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {3E957B1D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {3E957B1D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {68E7637D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {68E7637D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {68E7637D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {68E7637D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {68E7637D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {68E7637D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {68E7637D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {68E7637D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {A3EED43F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {A3EED43F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {A3EED43F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {A3EED43F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {A3EED43F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {A3EED43F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {A3EED43F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {A3EED43F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {E2C033C9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {E2C033C9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {E2C033C9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {E2C033C9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {E2C033C9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {E2C033C9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {E2C033C9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {E2C033C9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B679D409-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B679D409-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B679D409-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B679D409-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B679D409-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B679D409-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B679D409-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B679D409-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {72488C19-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {72488C19-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {72488C19-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {72488C19-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {72488C19-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {72488C19-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {72488C19-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {72488C19-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {058F37A7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {058F37A7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {058F37A7-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {058F37A7-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {058F37A7-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {058F37A7-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {058F37A7-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {058F37A7-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {E86CC116-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {E86CC116-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {E86CC116-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {E86CC116-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {E86CC116-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {E86CC116-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {E86CC116-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {E86CC116-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {D9C7290D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {D9C7290D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {D9C7290D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {D9C7290D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {D9C7290D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {D9C7290D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {D9C7290D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {D9C7290D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {0002E439-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {0002E439-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {0002E439-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {0002E439-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {0002E439-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {0002E439-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {0002E439-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {0002E439-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {E7AB357C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {E7AB357C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {E7AB357C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {E7AB357C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {E7AB357C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {E7AB357C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {E7AB357C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {E7AB357C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {7DFE101C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {7DFE101C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {7DFE101C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {7DFE101C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {7DFE101C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {7DFE101C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {7DFE101C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {7DFE101C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {4E98661D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {4E98661D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {4E98661D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {4E98661D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {4E98661D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {4E98661D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {4E98661D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {4E98661D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {29C72C7F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {29C72C7F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {29C72C7F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {29C72C7F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {29C72C7F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {29C72C7F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {29C72C7F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {29C72C7F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {9C98AD50-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {9C98AD50-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {9C98AD50-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {9C98AD50-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {9C98AD50-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {9C98AD50-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {9C98AD50-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {9C98AD50-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {E1DC3B68-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {E1DC3B68-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {E1DC3B68-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {E1DC3B68-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {E1DC3B68-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {E1DC3B68-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {E1DC3B68-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {E1DC3B68-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {6E2BAD6D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {6E2BAD6D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {6E2BAD6D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {6E2BAD6D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {6E2BAD6D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {6E2BAD6D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {6E2BAD6D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {6E2BAD6D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {A4066E0F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {A4066E0F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {A4066E0F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {A4066E0F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {A4066E0F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {A4066E0F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {A4066E0F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {A4066E0F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B5B6828B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B5B6828B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B5B6828B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B5B6828B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B5B6828B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B5B6828B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B5B6828B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B5B6828B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {FFF76235-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {FFF76235-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {FFF76235-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {FFF76235-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {FFF76235-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {FFF76235-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {FFF76235-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {FFF76235-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {F8261501-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {F8261501-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {F8261501-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {F8261501-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {F8261501-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {F8261501-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {F8261501-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {F8261501-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {0D83A720-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {0D83A720-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {0D83A720-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {0D83A720-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {0D83A720-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {0D83A720-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {0D83A720-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {0D83A720-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {EF6957B6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {EF6957B6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {EF6957B6-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {EF6957B6-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {EF6957B6-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {EF6957B6-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {EF6957B6-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {EF6957B6-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {86E324C6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {86E324C6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {86E324C6-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {86E324C6-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {86E324C6-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {86E324C6-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {86E324C6-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {86E324C6-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {C26033CC-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {C26033CC-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {C26033CC-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {C26033CC-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {C26033CC-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {C26033CC-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {C26033CC-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {C26033CC-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {40840508-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {40840508-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {40840508-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {40840508-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {40840508-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {40840508-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {40840508-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {40840508-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {64795331-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {64795331-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {64795331-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {64795331-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {64795331-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {64795331-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {64795331-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {64795331-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {2EA41430-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {2EA41430-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {2EA41430-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {2EA41430-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {2EA41430-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {2EA41430-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {2EA41430-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {2EA41430-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {44D74CF6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {44D74CF6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {44D74CF6-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {44D74CF6-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {44D74CF6-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {44D74CF6-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {44D74CF6-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {44D74CF6-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {BAAB251F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {BAAB251F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {BAAB251F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {BAAB251F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {BAAB251F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {BAAB251F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {BAAB251F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {BAAB251F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {277C4A71-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {277C4A71-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {277C4A71-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {277C4A71-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {277C4A71-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {277C4A71-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {277C4A71-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {277C4A71-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {619D55B1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {619D55B1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {619D55B1-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {619D55B1-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {619D55B1-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {619D55B1-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {619D55B1-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {619D55B1-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {7B224AC0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {7B224AC0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {7B224AC0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {7B224AC0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {7B224AC0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {7B224AC0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {7B224AC0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {7B224AC0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {3A470A1E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {3A470A1E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {3A470A1E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {3A470A1E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {3A470A1E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {3A470A1E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {3A470A1E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {3A470A1E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {CC9064D6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {CC9064D6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {CC9064D6-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {CC9064D6-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {CC9064D6-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {CC9064D6-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {CC9064D6-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {CC9064D6-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {FE481648-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {FE481648-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {FE481648-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {FE481648-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {FE481648-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {FE481648-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {FE481648-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {FE481648-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {86AD5535-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {86AD5535-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {86AD5535-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {86AD5535-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {86AD5535-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {86AD5535-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {86AD5535-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {86AD5535-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {1378A6F3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {1378A6F3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {1378A6F3-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {1378A6F3-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {1378A6F3-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {1378A6F3-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {1378A6F3-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {1378A6F3-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {34AA50AB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {34AA50AB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {34AA50AB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {34AA50AB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {34AA50AB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {34AA50AB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {34AA50AB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {34AA50AB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {2C78048B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {2C78048B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {2C78048B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {2C78048B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {2C78048B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {2C78048B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {2C78048B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {2C78048B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5591B076-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5591B076-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5591B076-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5591B076-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5591B076-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5591B076-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5591B076-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5591B076-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {8FAE40E2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {8FAE40E2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {8FAE40E2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {8FAE40E2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {8FAE40E2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {8FAE40E2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {8FAE40E2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {8FAE40E2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {31D7284B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {31D7284B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {31D7284B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {31D7284B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {31D7284B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {31D7284B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {31D7284B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {31D7284B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {62E0164B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {62E0164B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {62E0164B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {62E0164B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {62E0164B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {62E0164B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {62E0164B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {62E0164B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {77E3D41D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {77E3D41D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {77E3D41D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {77E3D41D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {77E3D41D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {77E3D41D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {77E3D41D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {77E3D41D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {22F24C33-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {22F24C33-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {22F24C33-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {22F24C33-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {22F24C33-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {22F24C33-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {22F24C33-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {22F24C33-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {52444370-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {52444370-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {52444370-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {52444370-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {52444370-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {52444370-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {52444370-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {52444370-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B6A3F318-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B6A3F318-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B6A3F318-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B6A3F318-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B6A3F318-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B6A3F318-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B6A3F318-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B6A3F318-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {F8915692-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {F8915692-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {F8915692-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {F8915692-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {F8915692-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {F8915692-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {F8915692-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {F8915692-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B213B165-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B213B165-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B213B165-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B213B165-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B213B165-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B213B165-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B213B165-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B213B165-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {97522E31-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {97522E31-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {97522E31-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {97522E31-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {97522E31-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {97522E31-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {97522E31-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {97522E31-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {3F7C5145-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {3F7C5145-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {3F7C5145-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {3F7C5145-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {3F7C5145-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {3F7C5145-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {3F7C5145-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {3F7C5145-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {B3512BAC-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {B3512BAC-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {B3512BAC-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {B3512BAC-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {B3512BAC-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {B3512BAC-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {B3512BAC-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {B3512BAC-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {6BB42F4E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {6BB42F4E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {6BB42F4E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {6BB42F4E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {6BB42F4E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {6BB42F4E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {6BB42F4E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {6BB42F4E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {15117F4E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {15117F4E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {15117F4E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {15117F4E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {15117F4E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {15117F4E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {15117F4E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {15117F4E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {3E7EF9FB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {3E7EF9FB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {3E7EF9FB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {3E7EF9FB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {3E7EF9FB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {3E7EF9FB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {3E7EF9FB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {3E7EF9FB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {2E8E98B3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {2E8E98B3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {2E8E98B3-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {2E8E98B3-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {2E8E98B3-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {2E8E98B3-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {2E8E98B3-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {2E8E98B3-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {97BF2115-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {97BF2115-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {97BF2115-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {97BF2115-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {97BF2115-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {97BF2115-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {97BF2115-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {97BF2115-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {4CD277F5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {4CD277F5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {4CD277F5-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {4CD277F5-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {4CD277F5-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {4CD277F5-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {4CD277F5-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {4CD277F5-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {03EBC4EF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {03EBC4EF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {03EBC4EF-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {03EBC4EF-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {03EBC4EF-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {03EBC4EF-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {03EBC4EF-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {03EBC4EF-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {76CBB621-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {76CBB621-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {76CBB621-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {76CBB621-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {76CBB621-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {76CBB621-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {76CBB621-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {76CBB621-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {34FD304B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {34FD304B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {34FD304B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {34FD304B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {34FD304B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {34FD304B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {34FD304B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {34FD304B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {51477B19-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {51477B19-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {51477B19-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {51477B19-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {51477B19-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {51477B19-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {51477B19-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {51477B19-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {318A084B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {318A084B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {318A084B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {318A084B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {318A084B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {318A084B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {318A084B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {318A084B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {DEBBE52E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {DEBBE52E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {DEBBE52E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {DEBBE52E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {DEBBE52E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {DEBBE52E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {DEBBE52E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {DEBBE52E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {40EDEECF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {40EDEECF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {40EDEECF-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {40EDEECF-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {40EDEECF-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {40EDEECF-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {40EDEECF-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {40EDEECF-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {87B0433A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {87B0433A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {87B0433A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {87B0433A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {87B0433A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {87B0433A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {87B0433A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {87B0433A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {09C5437D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {09C5437D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {09C5437D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {09C5437D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {09C5437D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {09C5437D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {09C5437D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {09C5437D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {639E00F5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {639E00F5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {639E00F5-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {639E00F5-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {639E00F5-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {639E00F5-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {639E00F5-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {639E00F5-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {8BA1383A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {8BA1383A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {8BA1383A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {8BA1383A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {8BA1383A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {8BA1383A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {8BA1383A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {8BA1383A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {443878E8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {443878E8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {443878E8-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {443878E8-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {443878E8-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {443878E8-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {443878E8-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {443878E8-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {19D5BCD8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {19D5BCD8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {19D5BCD8-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {19D5BCD8-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {19D5BCD8-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {19D5BCD8-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {19D5BCD8-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {19D5BCD8-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {2E973B7C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {2E973B7C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {2E973B7C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {2E973B7C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {2E973B7C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {2E973B7C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {2E973B7C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {2E973B7C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {C54B9598-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {C54B9598-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {C54B9598-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {C54B9598-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {C54B9598-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {C54B9598-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {C54B9598-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {C54B9598-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {148CB6EE-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {148CB6EE-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {148CB6EE-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {148CB6EE-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {148CB6EE-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {148CB6EE-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {148CB6EE-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {148CB6EE-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {94D249FB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {94D249FB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {94D249FB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {94D249FB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {94D249FB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {94D249FB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {94D249FB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {94D249FB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {13E544B0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {13E544B0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {13E544B0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {13E544B0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {13E544B0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {13E544B0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {13E544B0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {13E544B0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {E9D167C3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {E9D167C3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {E9D167C3-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {E9D167C3-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {E9D167C3-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {E9D167C3-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {E9D167C3-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {E9D167C3-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {42BEE677-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {42BEE677-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {42BEE677-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {42BEE677-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {42BEE677-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {42BEE677-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {42BEE677-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {42BEE677-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {92CC9D6C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {92CC9D6C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {92CC9D6C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {92CC9D6C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {92CC9D6C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {92CC9D6C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {92CC9D6C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {92CC9D6C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {5B5CE00D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {5B5CE00D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {5B5CE00D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {5B5CE00D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {5B5CE00D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {5B5CE00D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {5B5CE00D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {5B5CE00D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {1D7FC04E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {1D7FC04E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {1D7FC04E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {1D7FC04E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {1D7FC04E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {1D7FC04E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {1D7FC04E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {1D7FC04E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {740B4307-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {740B4307-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {740B4307-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {740B4307-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {740B4307-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {740B4307-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {740B4307-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {740B4307-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {31AD874B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {31AD874B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {31AD874B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {31AD874B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {31AD874B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {31AD874B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {31AD874B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {31AD874B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {568DF4C9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {568DF4C9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {568DF4C9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {568DF4C9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {568DF4C9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {568DF4C9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {568DF4C9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {568DF4C9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {2CC6636C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {2CC6636C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {2CC6636C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {2CC6636C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {2CC6636C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {2CC6636C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {2CC6636C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {2CC6636C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {37EED14E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {37EED14E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {37EED14E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {37EED14E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {37EED14E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {37EED14E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {37EED14E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {37EED14E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {06DC4BEF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {06DC4BEF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {06DC4BEF-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {06DC4BEF-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {06DC4BEF-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {06DC4BEF-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {06DC4BEF-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {06DC4BEF-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {8FCB14EA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
- {8FCB14EA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
- {8FCB14EA-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
- {8FCB14EA-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
- {8FCB14EA-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
- {8FCB14EA-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
- {8FCB14EA-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
- {8FCB14EA-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
- {14DB45BD-FECA-1BAD-6AF0-8A634041EBC7}.Debug|Win32.ActiveCfg = Debug|Win32
- {14DB45BD-FECA-1BAD-6AF0-8A634041EBC7}.Debug|Win32.Build.0 = Debug|Win32
- {14DB45BD-FECA-1BAD-6AF0-8A634041EBC7}.Debug|x64.ActiveCfg = Debug|x64
- {14DB45BD-FECA-1BAD-6AF0-8A634041EBC7}.Debug|x64.Build.0 = Debug|x64
- {14DB45BD-FECA-1BAD-6AF0-8A634041EBC7}.Release|Win32.ActiveCfg = Release|Win32
- {14DB45BD-FECA-1BAD-6AF0-8A634041EBC7}.Release|Win32.Build.0 = Release|Win32
- {14DB45BD-FECA-1BAD-6AF0-8A634041EBC7}.Release|x64.ActiveCfg = Release|x64
- {14DB45BD-FECA-1BAD-6AF0-8A634041EBC7}.Release|x64.Build.0 = Release|x64
- {01EC101A-FECA-1BAD-2431-8A1141F31173}.Debug|Win32.ActiveCfg = Debug|Win32
- {01EC101A-FECA-1BAD-2431-8A1141F31173}.Debug|Win32.Build.0 = Debug|Win32
- {01EC101A-FECA-1BAD-2431-8A1141F31173}.Debug|x64.ActiveCfg = Debug|x64
- {01EC101A-FECA-1BAD-2431-8A1141F31173}.Debug|x64.Build.0 = Debug|x64
- {01EC101A-FECA-1BAD-2431-8A1141F31173}.Release|Win32.ActiveCfg = Release|Win32
- {01EC101A-FECA-1BAD-2431-8A1141F31173}.Release|Win32.Build.0 = Release|Win32
- {01EC101A-FECA-1BAD-2431-8A1141F31173}.Release|x64.ActiveCfg = Release|x64
- {01EC101A-FECA-1BAD-2431-8A1141F31173}.Release|x64.Build.0 = Release|x64
- EndGlobalSection
- GlobalSection(SolutionProperties) = preSolution
- HideSolutionNode = FALSE
- EndGlobalSection
-EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc11.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc11.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc11.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -7,7 +7,7 @@
# this file will be lost the next time it is generated.
# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type vc11 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE -workers 16 -name_modifier "*_vc11"
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type vc11 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE -workers 12 -name_modifier "*_vc11"
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML_XML_Svc_Conf_Parser", "ACEXML\apps\svcconf\ACEXML_XML_Svc_Conf_Parser_vc11.vcxproj", "{97A5797C-FECA-1BAD-5984-FE664DEC7B87}"
ProjectSection(ProjectDependencies) = postProject
{47BC56EC-FECA-1BAD-6757-8A6300006755} = {47BC56EC-FECA-1BAD-6757-8A6300006755}
@@ -2930,6 +2930,12 @@
{40EDEECE-FECA-1BAD-2431-8A1100722433} = {40EDEECE-FECA-1BAD-2431-8A1100722433}
EndProjectSection
EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_35_Test", "tests\Compiler_Features_35_Test_vc11.vcxproj", "{5529C682-FECA-1BAD-2431-8A1100722433}"
+ ProjectSection(ProjectDependencies) = postProject
+ {47BC56EC-FECA-1BAD-6757-8A6300006755} = {47BC56EC-FECA-1BAD-6757-8A6300006755}
+ {40EDEECE-FECA-1BAD-2431-8A1100722433} = {40EDEECE-FECA-1BAD-2431-8A1100722433}
+ EndProjectSection
+EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Config_Test", "tests\Config_Test_vc11.vcxproj", "{6D2CA44E-FECA-1BAD-2431-8A1100722433}"
@@ -8297,6 +8303,14 @@
{5529C782-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
{5529C782-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
{5529C782-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529C682-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529C682-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529C682-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529C682-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529C682-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529C682-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529C682-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529C682-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
{6D2CA44E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
{6D2CA44E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
{6D2CA44E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc12.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc12.sln (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_vc12.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,9579 @@
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio 2012
+# $Id: VC12WorkspaceCreator.pm 2211 2014-06-26 18:11:09Z elliott_c $
+# This file was generated by MPC. Any changes made directly to
+# this file will be lost the next time it is generated.
+# MPC Command:
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type vc12 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE -workers 12 -name_modifier "*_vc12"
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML_XML_Svc_Conf_Parser", "ACEXML\apps\svcconf\ACEXML_XML_Svc_Conf_Parser_vc12.vcxproj", "{97A5797F-FECA-1BAD-5984-FE664DEC7B87}"
+ {47BC56EF-FECA-1BAD-6757-8A6300006755} = {47BC56EF-FECA-1BAD-6757-8A6300006755}
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C} = {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57} = {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML", "ACEXML\common\ACEXML_vc12.vcxproj", "{D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SAXPrint", "ACEXML\examples\SAXPrint\SAXPrint_vc12.vcxproj", "{E9FB1B9F-FECA-1BAD-4F93-FEB4C47D7318}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML_Parser", "ACEXML\parser\parser\ACEXML_Parser_vc12.vcxproj", "{4E55F4D9-FECA-1BAD-5520-8D0596E4677C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ContentHandler_Test", "ACEXML\tests\ContentHandler_Test_vc12.vcxproj", "{15144843-FECA-1BAD-2431-8A119E86733F}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HttpCharStream_Test", "ACEXML\tests\HttpCharStream_Test_vc12.vcxproj", "{84DB702A-FECA-1BAD-2431-8A119E86733F}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "NamespaceSupport_Test", "ACEXML\tests\NamespaceSupport_Test_vc12.vcxproj", "{A18276CA-FECA-1BAD-2431-8A119E86733F}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Transcoder_Test", "ACEXML\tests\Transcoder_Test_vc12.vcxproj", "{613B4530-FECA-1BAD-2431-8A119E86733F}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "util", "ACEXML\tests\util\util_vc12.vcxproj", "{3F2C5699-FECA-1BAD-22FE-8A6433D1CA9B}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_agent", "ASNMP\agent\asnmp_agent_vc12.vcxproj", "{4C260F9C-FECA-1BAD-1396-8A04829757EE}"
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA} = {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_lib", "ASNMP\asnmp\asnmp_lib_vc12.vcxproj", "{B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get_async", "ASNMP\examples\get\asnmp_example_get_async_vc12.vcxproj", "{B8E6506F-FECA-1BAD-6126-8A63C208BB19}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get", "ASNMP\examples\get\asnmp_example_get_vc12.vcxproj", "{2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_next", "ASNMP\examples\next\asnmp_example_next_vc12.vcxproj", "{BE5253E1-FECA-1BAD-82F6-8A65208B2128}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_set", "ASNMP\examples\set\asnmp_example_set_vc12.vcxproj", "{6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_trap", "ASNMP\examples\trap\asnmp_example_trap_vc12.vcxproj", "{D71253FA-FECA-1BAD-3462-8A64208A97BC}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_walk", "ASNMP\examples\walk\asnmp_example_walk_vc12.vcxproj", "{EBA253F8-FECA-1BAD-17A9-8A64208AB477}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Address_Test", "ASNMP\tests\asnmp_tests_Address_Test_vc12.vcxproj", "{95AC7E5B-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Counter64_Test", "ASNMP\tests\asnmp_tests_Counter64_Test_vc12.vcxproj", "{E4E31748-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Counter_Test", "ASNMP\tests\asnmp_tests_Counter_Test_vc12.vcxproj", "{357C1F59-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Gauge_Test", "ASNMP\tests\asnmp_tests_Gauge_Test_vc12.vcxproj", "{204D0427-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Integer_Test", "ASNMP\tests\asnmp_tests_Integer_Test_vc12.vcxproj", "{24DF1F53-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Octet_Test", "ASNMP\tests\asnmp_tests_Octet_Test_vc12.vcxproj", "{286C3527-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Oid_Test", "ASNMP\tests\asnmp_tests_Oid_Test_vc12.vcxproj", "{5AB0250B-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Target_Test", "ASNMP\tests\asnmp_tests_Target_Test_vc12.vcxproj", "{4AC951A9-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Varbind_Test", "ASNMP\tests\asnmp_tests_Varbind_Test_vc12.vcxproj", "{D2A1B94C-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Kokyu", "Kokyu\Kokyu_vc12.vcxproj", "{DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DSRT_MIF", "Kokyu\tests\DSRT_MIF\DSRT_MIF_vc12.vcxproj", "{8DCD31F0-FECA-1BAD-B9D0-9C126E572303}"
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5} = {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "EDF", "Kokyu\tests\EDF\EDF_vc12.vcxproj", "{008C56EF-FECA-1BAD-4104-8A6369AD5684}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FIFO", "Kokyu\tests\FIFO\FIFO_vc12.vcxproj", "{C21C56A9-FECA-1BAD-2D2D-8A679AD55509}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE", "ace\ACE_vc12.vcxproj", "{47BC56EF-FECA-1BAD-6757-8A6300006755}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_Compression", "ace\Compression\ACE_Compression_vc12.vcxproj", "{B0AF43A5-FECA-1BAD-EA06-BB371373EA04}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_RLECompression", "ace\Compression\rle\ACE_RLECompression_vc12.vcxproj", "{F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}"
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04} = {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_ETCL_Parser", "ace\ETCL\ACE_ETCL_Parser_vc12.vcxproj", "{42B1A785-FECA-1BAD-007E-8A67757B007A}"
+ {1769265B-FECA-1BAD-007E-8A67757B007A} = {1769265B-FECA-1BAD-007E-8A67757B007A}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_ETCL", "ace\ETCL\ACE_ETCL_vc12.vcxproj", "{1769265B-FECA-1BAD-007E-8A67757B007A}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Monitor_Control", "ace\Monitor_Control\Monitor_Control_vc12.vcxproj", "{7153B6F6-FECA-1BAD-D619-74620E01B14C}"
+ {42B1A785-FECA-1BAD-007E-8A67757B007A} = {42B1A785-FECA-1BAD-007E-8A67757B007A}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Gateway", "apps\Gateway\Gateway\Gateway_vc12.vcxproj", "{067840C9-FECA-1BAD-216B-EB0100066773}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "gatewayd", "apps\Gateway\Gateway\gatewayd_vc12.vcxproj", "{7FCD34CA-FECA-1BAD-216B-EB0100066773}"
+ {067840C9-FECA-1BAD-216B-EB0100066773} = {067840C9-FECA-1BAD-216B-EB0100066773}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Gateway_Peer", "apps\Gateway\Peer\Gateway_Peer_vc12.vcxproj", "{40ED3A0C-FECA-1BAD-6320-8A6461A17566}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "gateway_peerd", "apps\Gateway\Peer\gateway_peerd_vc12.vcxproj", "{16BA989E-FECA-1BAD-6320-8A6461A17566}"
+ {40ED3A0C-FECA-1BAD-6320-8A6461A17566} = {40ED3A0C-FECA-1BAD-6320-8A6461A17566}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "blobby", "apps\JAWS\clients\Blobby\blobby_vc12.vcxproj", "{557C3242-FECA-1BAD-945B-8C296561D98E}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "http_client", "apps\JAWS\clients\Caching\http_client_vc12.vcxproj", "{DA99C342-FECA-1BAD-EF85-EF1657C132F1}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JAWS_server", "apps\JAWS\server\JAWS_server_vc12.vcxproj", "{F6EAD3CA-FECA-1BAD-5020-8D317F23EE66}"
+ {52DC56A5-FECA-1BAD-5020-8D317F23EE66} = {52DC56A5-FECA-1BAD-5020-8D317F23EE66}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JAWS", "apps\JAWS\server\JAWS_vc12.vcxproj", "{52DC56A5-FECA-1BAD-5020-8D317F23EE66}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HTTPU", "apps\JAWS2\HTTPU\HTTPU_vc12.vcxproj", "{05BC523A-FECA-1BAD-3377-8A0C67CCAF11}"
+ {30CC520F-FECA-1BAD-6000-8A0F467CFFC7} = {30CC520F-FECA-1BAD-6000-8A0F467CFFC7}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JAWS2", "apps\JAWS2\JAWS\JAWS2_vc12.vcxproj", "{30CC520F-FECA-1BAD-6000-8A0F467CFFC7}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JAWS3_server", "apps\JAWS3\jaws3\JAWS3_server_vc12.vcxproj", "{50CAD380-FECA-1BAD-6001-8A0F66EDDE47}"
+ {30DC520F-FECA-1BAD-6001-8A0F66EDDE47} = {30DC520F-FECA-1BAD-6001-8A0F66EDDE47}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JAWS3", "apps\JAWS3\jaws3\JAWS3_vc12.vcxproj", "{30DC520F-FECA-1BAD-6001-8A0F66EDDE47}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "drwho__client", "apps\drwho\drwho__client_vc12.vcxproj", "{3706C571-FECA-1BAD-51ED-8A0071935788}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "drwho__server", "apps\drwho\drwho__server_vc12.vcxproj", "{0C66D5FB-FECA-1BAD-51ED-8A0071935788}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "gperf_docs", "apps\gperf\gperf_docs_vc12.vcxproj", "{E4BE1579-FECA-1BAD-6223-DAF371906421}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "gperf", "apps\gperf\src\gperf_vc12.vcxproj", "{348C50ED-FECA-1BAD-6244-8A036423F5D3}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "adainset", "apps\gperf\tests\adainset_vc12.vcxproj", "{42CB7112-FECA-1BAD-2431-8A1123F3B457}"
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3} = {348C50ED-FECA-1BAD-6244-8A036423F5D3}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "cinset", "apps\gperf\tests\cinset_vc12.vcxproj", "{42AC3312-FECA-1BAD-2431-8A1123F3B457}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "cppinset", "apps\gperf\tests\cppinset_vc12.vcxproj", "{42C82012-FECA-1BAD-2431-8A1123F3B457}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "iinset2", "apps\gperf\tests\iinset2_vc12.vcxproj", "{37CAA97E-FECA-1BAD-2431-8A1123F3B457}"
+ {42AC3912-FECA-1BAD-2431-8A1123F3B457} = {42AC3912-FECA-1BAD-2431-8A1123F3B457}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "iinset", "apps\gperf\tests\iinset_vc12.vcxproj", "{42AC3912-FECA-1BAD-2431-8A1123F3B457}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "m3inset", "apps\gperf\tests\m3inset_vc12.vcxproj", "{42AAB312-FECA-1BAD-2431-8A1123F3B457}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "pinset", "apps\gperf\tests\pinset_vc12.vcxproj", "{42AC2012-FECA-1BAD-2431-8A1123F3B457}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "preinset", "apps\gperf\tests\preinset_vc12.vcxproj", "{42DB1512-FECA-1BAD-2431-8A1123F3B457}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "taoinset", "apps\gperf\tests\taoinset_vc12.vcxproj", "{42DE2F12-FECA-1BAD-2431-8A1123F3B457}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "tinset", "apps\gperf\tests\tinset_vc12.vcxproj", "{42AC2412-FECA-1BAD-2431-8A1123F3B457}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "mkcsregdb", "apps\mkcsregdb\mkcsregdb_vc12.vcxproj", "{047112A8-FECA-1BAD-314B-5E27D22340B9}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "soreduce", "apps\soreduce\soreduce_vc12.vcxproj", "{25C9D2D8-FECA-1BAD-3350-D2205825444D}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PerlACE", "bin\PerlACE\PerlACE_vc12.vcxproj", "{47B934A3-FECA-1BAD-A757-FC47A624E189}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "bin", "bin\bin_vc12.vcxproj", "{5F0C56ED-FECA-1BAD-64FC-8A63000064FE}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "AO2", "examples\APG\Active_Objects\AO2_vc12.vcxproj", "{4CCC56EF-FECA-1BAD-1A31-155B449A6390}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "AO", "examples\APG\Active_Objects\AO_vc12.vcxproj", "{551C56EB-FECA-1BAD-1A31-155B449A6390}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ARGV_Example", "examples\APG\Config\ARGV_Example_vc12.vcxproj", "{188778D5-FECA-1BAD-80F5-8C3AFDFBF954}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Config_HA_Status", "examples\APG\Config\Config_HA_Status_vc12.vcxproj", "{095D6AC2-FECA-1BAD-80F5-8C3AFDFBF954}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Get_Opt_Long", "examples\APG\Config\Get_Opt_Long_vc12.vcxproj", "{A9242710-FECA-1BAD-80F5-8C3AFDFBF954}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Get_Opt", "examples\APG\Config\Get_Opt_vc12.vcxproj", "{97A844F0-FECA-1BAD-80F5-8C3AFDFBF954}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Allocator", "examples\APG\Containers\Allocator_vc12.vcxproj", "{3CB6FFBD-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Array", "examples\APG\Containers\Array_vc12.vcxproj", "{567C528E-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Containers_Hash_Map", "examples\APG\Containers\Containers_Hash_Map_vc12.vcxproj", "{A9C04CB6-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Containers_Map_Manager", "examples\APG\Containers\Containers_Map_Manager_vc12.vcxproj", "{936F819E-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLList", "examples\APG\Containers\DLList_vc12.vcxproj", "{F4AC1661-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Hash_Map_Hash", "examples\APG\Containers\Hash_Map_Hash_vc12.vcxproj", "{28D737B3-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Map_Manager_Specialization", "examples\APG\Containers\Map_Manager_Specialization_vc12.vcxproj", "{8C34A592-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Queues", "examples\APG\Containers\Queues_vc12.vcxproj", "{22DC00D9-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RB_Tree_Functors", "examples\APG\Containers\RB_Tree_Functors_vc12.vcxproj", "{A53B149D-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RB_Tree", "examples\APG\Containers\RB_Tree_vc12.vcxproj", "{53B93148-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sets", "examples\APG\Containers\Sets_vc12.vcxproj", "{33DC56BE-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Stacks", "examples\APG\Containers\Stacks_vc12.vcxproj", "{4CDC02CC-FECA-1BAD-8408-181CEBDC7FA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Change_Instance_Default", "examples\APG\Logging\Change_Instance_Default_vc12.vcxproj", "{BE1CBFB2-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Change_Mask", "examples\APG\Logging\Change_Mask_vc12.vcxproj", "{2B244654-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Howto_Syslog", "examples\APG\Logging\Howto_Syslog_vc12.vcxproj", "{39B6F240-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Simple1", "examples\APG\Logging\Simple1_vc12.vcxproj", "{B6F9094D-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Simple2", "examples\APG\Logging\Simple2_vc12.vcxproj", "{B6C9094D-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Trace_Return", "examples\APG\Logging\Trace_Return_vc12.vcxproj", "{735CF29B-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Callback2", "examples\APG\Logging\Use_Callback2_vc12.vcxproj", "{439BF989-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Callback", "examples\APG\Logging\Use_Callback_vc12.vcxproj", "{35E92C1D-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_LogManager", "examples\APG\Logging\Use_LogManager_vc12.vcxproj", "{B85FB33C-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Logger", "examples\APG\Logging\Use_Logger_vc12.vcxproj", "{509CEC7A-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Logging_Server", "examples\APG\Logging\Use_Logging_Server_vc12.vcxproj", "{5F1E495F-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Logging_Strategy", "examples\APG\Logging\Use_Logging_Strategy_vc12.vcxproj", "{F262F3C4-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Multiple_Sinks", "examples\APG\Logging\Use_Multiple_Sinks_vc12.vcxproj", "{E0E6E68F-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Ostream", "examples\APG\Logging\Use_Ostream_vc12.vcxproj", "{0237D2DA-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Stderr", "examples\APG\Logging\Use_Stderr_vc12.vcxproj", "{679CF2C9-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Use_Syslog", "examples\APG\Logging\Use_Syslog_vc12.vcxproj", "{EBCCF20E-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Wrap_Macros_Alt", "examples\APG\Logging\Wrap_Macros_Alt_vc12.vcxproj", "{D0DD1AE5-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Wrap_Macros", "examples\APG\Logging\Wrap_Macros_vc12.vcxproj", "{5CB9ED9A-FECA-1BAD-1F85-E0F2D0B685B8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UDP_Broadcast", "examples\APG\Misc_IPC\UDP_Broadcast_vc12.vcxproj", "{2FF8C4DF-FECA-1BAD-9E67-34351C2F1FBE}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UDP_Multicast", "examples\APG\Misc_IPC\UDP_Multicast_vc12.vcxproj", "{2F0FE10F-FECA-1BAD-9E67-34351C2F1FBE}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UDP_Unicast", "examples\APG\Misc_IPC\UDP_Unicast_vc12.vcxproj", "{65F66E1B-FECA-1BAD-9E67-34351C2F1FBE}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Netlocal_Reader", "examples\APG\Naming\Netlocal_Reader_vc12.vcxproj", "{A7B170F6-FECA-1BAD-BF85-8CE4FD25C624}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Netlocal", "examples\APG\Naming\Netlocal_vc12.vcxproj", "{47647442-FECA-1BAD-BF85-8CE4FD25C624}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Nodelocal_Shared_Reader", "examples\APG\Naming\Nodelocal_Shared_Reader_vc12.vcxproj", "{FFAEE1A1-FECA-1BAD-BF85-8CE4FD25C624}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Nodelocal_Shared", "examples\APG\Naming\Nodelocal_Shared_vc12.vcxproj", "{C69D6137-FECA-1BAD-BF85-8CE4FD25C624}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Nodelocal", "examples\APG\Naming\Nodelocal_vc12.vcxproj", "{43A57542-FECA-1BAD-BF85-8CE4FD25C624}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HA_Proactive_Status", "examples\APG\Proactor\HA_Proactive_Status_vc12.vcxproj", "{C87BBBBD-FECA-1BAD-4287-FEF4D6EEE17E}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Manager_Death", "examples\APG\Processes\Process_Manager_Death_vc12.vcxproj", "{605A430B-FECA-1BAD-4556-C3316EC87AEE}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Manager_Spawn", "examples\APG\Processes\Process_Manager_Spawn_vc12.vcxproj", "{633A426E-FECA-1BAD-4556-C3316EC87AEE}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Mutex", "examples\APG\Processes\Process_Mutex_vc12.vcxproj", "{A748383D-FECA-1BAD-4556-C3316EC87AEE}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Spawn", "examples\APG\Processes\Spawn_vc12.vcxproj", "{710C53AD-FECA-1BAD-4556-C3316EC87AEE}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Client", "examples\APG\Reactor\Client_vc12.vcxproj", "{29AC1344-FECA-1BAD-4280-FE54CE10D8BD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HAStatus_AC", "examples\APG\Reactor\HAStatus_AC_vc12.vcxproj", "{619E35C9-FECA-1BAD-4280-FE54CE10D8BD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HAStatus", "examples\APG\Reactor\HAStatus_vc12.vcxproj", "{229012CD-FECA-1BAD-4280-FE54CE10D8BD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Timers", "examples\APG\Reactor\Reactor_Timers_vc12.vcxproj", "{775BA027-FECA-1BAD-4280-FE54CE10D8BD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reschedule", "examples\APG\Reactor\Reschedule_vc12.vcxproj", "{7E9908D8-FECA-1BAD-4280-FE54CE10D8BD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Schedule_Timers", "examples\APG\Reactor\Schedule_Timers_vc12.vcxproj", "{0679A1F3-FECA-1BAD-4280-FE54CE10D8BD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Cancel", "examples\APG\Reactor\Timer_Cancel_vc12.vcxproj", "{B80BE3C1-FECA-1BAD-4280-FE54CE10D8BD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_State_Data", "examples\APG\Reactor\Timer_State_Data_vc12.vcxproj", "{D6888D7E-FECA-1BAD-4280-FE54CE10D8BD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Malloc", "examples\APG\Shared_Memory\Malloc_vc12.vcxproj", "{B9DC1D91-FECA-1BAD-5E18-93A5247C7980}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mem_Map", "examples\APG\Shared_Memory\Mem_Map_vc12.vcxproj", "{A6E8E560-FECA-1BAD-5E18-93A5247C7980}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PI_Malloc", "examples\APG\Shared_Memory\PI_Malloc_vc12.vcxproj", "{BC90ED91-FECA-1BAD-5E18-93A5247C7980}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Pool_Growth", "examples\APG\Shared_Memory\Pool_Growth_vc12.vcxproj", "{7BF5E6A6-FECA-1BAD-5E18-93A5247C7980}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Memory_Hash_Map", "examples\APG\Shared_Memory\Shared_Memory_Hash_Map_vc12.vcxproj", "{B949D56E-FECA-1BAD-5E18-93A5247C7980}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SigAction", "examples\APG\Signals\SigAction_vc12.vcxproj", "{EC5361A9-FECA-1BAD-87B1-FF92CFD61D8C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SigGuard", "examples\APG\Signals\SigGuard_vc12.vcxproj", "{74F9A5E8-FECA-1BAD-87B1-FF92CFD61D8C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SigHandler", "examples\APG\Signals\SigHandler_vc12.vcxproj", "{E73FB169-FECA-1BAD-87B1-FF92CFD61D8C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SigHandlers", "examples\APG\Signals\SigHandlers_vc12.vcxproj", "{6AE22EC4-FECA-1BAD-87B1-FF92CFD61D8C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SigInfo", "examples\APG\Signals\SigInfo_vc12.vcxproj", "{901909D4-FECA-1BAD-87B1-FF92CFD61D8C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sockets_Basic_Robust", "examples\APG\Sockets\Sockets_Basic_Robust_vc12.vcxproj", "{C488C49F-FECA-1BAD-D231-FFF6CFB2480C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sockets_Basic", "examples\APG\Sockets\Sockets_Basic_vc12.vcxproj", "{12FF38F4-FECA-1BAD-D231-FFF6CFB2480C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sockets_Iovec", "examples\APG\Sockets\Sockets_Iovec_vc12.vcxproj", "{4EFF384A-FECA-1BAD-D231-FFF6CFB2480C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sockets_Server", "examples\APG\Sockets\Sockets_Server_vc12.vcxproj", "{C0FAA65B-FECA-1BAD-D231-FFF6CFB2480C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Answerer", "examples\APG\Streams\Answerer_vc12.vcxproj", "{528BC2F9-FECA-1BAD-37A1-FE57CE13AD9C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HA_Configurable_Server_Dynamic", "examples\APG\Svc_Config\HA_Configurable_Server_Dynamic_vc12.vcxproj", "{80877026-FECA-1BAD-87B5-E33A12FA7C15}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HA_Configurable_Server_Static", "examples\APG\Svc_Config\HA_Configurable_Server_Static_vc12.vcxproj", "{9D29F359-FECA-1BAD-87B5-E33A12FA7C15}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Config_HA_Status", "examples\APG\Svc_Config\Svc_Config_HA_Status_vc12.vcxproj", "{0FAD6A96-FECA-1BAD-87B5-E33A12FA7C15}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Async_Cancel", "examples\APG\ThreadManagement\Async_Cancel_vc12.vcxproj", "{0CAAE3D5-FECA-1BAD-B689-C9110A2960DF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Coop_Cancel", "examples\APG\ThreadManagement\Coop_Cancel_vc12.vcxproj", "{1AA9E397-FECA-1BAD-B689-C9110A2960DF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ExitHandler", "examples\APG\ThreadManagement\ExitHandler_vc12.vcxproj", "{9C2CB16D-FECA-1BAD-B689-C9110A2960DF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Pool", "examples\APG\ThreadManagement\Pool_vc12.vcxproj", "{892C56BD-FECA-1BAD-B689-C9110A2960DF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Priorities", "examples\APG\ThreadManagement\Priorities_vc12.vcxproj", "{B593D209-FECA-1BAD-B689-C9110A2960DF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Signals2", "examples\APG\ThreadManagement\Signals2_vc12.vcxproj", "{A099A76C-FECA-1BAD-B689-C9110A2960DF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Signals", "examples\APG\ThreadManagement\Signals_vc12.vcxproj", "{6BD909F3-FECA-1BAD-B689-C9110A2960DF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Start_Hook", "examples\APG\ThreadManagement\Start_Hook_vc12.vcxproj", "{DD7A0755-FECA-1BAD-B689-C9110A2960DF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "State", "examples\APG\ThreadManagement\State_vc12.vcxproj", "{72BC53A9-FECA-1BAD-B689-C9110A2960DF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Futures", "examples\APG\ThreadPools\Futures_vc12.vcxproj", "{52D844D9-FECA-1BAD-EB45-BD55AD295160}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "LF_ThreadPool", "examples\APG\ThreadPools\LF_ThreadPool_vc12.vcxproj", "{2BD8657E-FECA-1BAD-EB45-BD55AD295160}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TP_Reactor", "examples\APG\ThreadPools\TP_Reactor_vc12.vcxproj", "{6996159F-FECA-1BAD-EB45-BD55AD295160}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Task_ThreadPool", "examples\APG\ThreadPools\Task_ThreadPool_vc12.vcxproj", "{2BDD47A3-FECA-1BAD-EB45-BD55AD295160}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ThreadPool", "examples\APG\ThreadPools\ThreadPool_vc12.vcxproj", "{DBD861FD-FECA-1BAD-EB45-BD55AD295160}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Atomic_Op", "examples\APG\ThreadSafety\Atomic_Op_vc12.vcxproj", "{AC8ECD1D-FECA-1BAD-2D78-F933D2AB8F03}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Barrier", "examples\APG\ThreadSafety\Barrier_vc12.vcxproj", "{E2C810BF-FECA-1BAD-2D78-F933D2AB8F03}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mutex", "examples\APG\ThreadSafety\Mutex_vc12.vcxproj", "{326C5249-FECA-1BAD-2D78-F933D2AB8F03}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RW_Lock", "examples\APG\ThreadSafety\RW_Lock_vc12.vcxproj", "{85592451-FECA-1BAD-2D78-F933D2AB8F03}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Semaphore", "examples\APG\ThreadSafety\Semaphore_vc12.vcxproj", "{91EFE085-FECA-1BAD-2D78-F933D2AB8F03}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TSS", "examples\APG\ThreadSafety\TSS_vc12.vcxproj", "{06DC56EE-FECA-1BAD-2D78-F933D2AB8F03}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Tokens_Deadlock", "examples\APG\ThreadSafety\Tokens_Deadlock_vc12.vcxproj", "{13EB4812-FECA-1BAD-2D78-F933D2AB8F03}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Tokens", "examples\APG\ThreadSafety\Tokens_vc12.vcxproj", "{29DC0476-FECA-1BAD-2D78-F933D2AB8F03}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Activate", "examples\APG\Threads\Activate_vc12.vcxproj", "{72FB140B-FECA-1BAD-3731-F897C8D3AD0C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Condition_Variables", "examples\APG\Threads\Condition_Variables_vc12.vcxproj", "{5158FB62-FECA-1BAD-3731-F897C8D3AD0C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Guards", "examples\APG\Threads\Guards_vc12.vcxproj", "{53DC16DD-FECA-1BAD-3731-F897C8D3AD0C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Blocks", "examples\APG\Threads\Message_Blocks_vc12.vcxproj", "{1BCCA966-FECA-1BAD-3731-F897C8D3AD0C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Queue", "examples\APG\Threads\Message_Queue_vc12.vcxproj", "{76CD583A-FECA-1BAD-3731-F897C8D3AD0C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mutexes", "examples\APG\Threads\Mutexes_vc12.vcxproj", "{F2D8F4C9-FECA-1BAD-3731-F897C8D3AD0C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Alarm", "examples\APG\Timers\Alarm_vc12.vcxproj", "{743C5291-FECA-1BAD-B251-8D4CFC8DCBF0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Task", "examples\APG\Timers\Task_vc12.vcxproj", "{755C56B9-FECA-1BAD-B251-8D4CFC8DCBF0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timers", "examples\APG\Timers\Timers_vc12.vcxproj", "{35DC0410-FECA-1BAD-B251-8D4CFC8DCBF0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Upcall", "examples\APG\Timers\Upcall_vc12.vcxproj", "{6A2C048E-FECA-1BAD-B251-8D4CFC8DCBF0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_CCM_App_Client", "examples\ASX\CCM_App\ASX_CCM_App_Client_vc12.vcxproj", "{DBB4543C-FECA-1BAD-F21F-3D1BDD5F2C60}"
+ {E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60} = {E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_CCM_App_Lib", "examples\ASX\CCM_App\ASX_CCM_App_Lib_vc12.vcxproj", "{C843776B-FECA-1BAD-F21F-3D1BDD5F2C60}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_CCM_App_Server", "examples\ASX\CCM_App\ASX_CCM_App_Server_vc12.vcxproj", "{E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60}"
+ {C843776B-FECA-1BAD-F21F-3D1BDD5F2C60} = {C843776B-FECA-1BAD-F21F-3D1BDD5F2C60}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Event_Server", "examples\ASX\Event_Server\Event_Server\Event_Server_vc12.vcxproj", "{115DF38C-FECA-1BAD-0396-8A213C52C5E6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Transceiver", "examples\ASX\Event_Server\Transceiver\Transceiver_vc12.vcxproj", "{26B503D0-FECA-1BAD-B367-1F304733F83A}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_Message_Queue_Bounded_Buffer", "examples\ASX\Message_Queue\ASX_Message_Queue_Bounded_Buffer_vc12.vcxproj", "{86DE2A45-FECA-1BAD-1624-F77E007731F8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_Message_Queue_Buffer_Stream", "examples\ASX\Message_Queue\ASX_Message_Queue_Buffer_Stream_vc12.vcxproj", "{F679CE5D-FECA-1BAD-1624-F77E007731F8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ASX_Message_Queue_Priority_Buffer", "examples\ASX\Message_Queue\ASX_Message_Queue_Priority_Buffer_vc12.vcxproj", "{3ECD46F2-FECA-1BAD-1624-F77E007731F8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UPIPE_Event_Server", "examples\ASX\UPIPE_Event_Server\UPIPE_Event_Server_vc12.vcxproj", "{4111B37C-FECA-1BAD-53DA-CAD1A7F87CBD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bounded_Packet_Relay", "examples\Bounded_Packet_Relay\Bounded_Packet_Relay_vc12.vcxproj", "{402C7D4A-FECA-1BAD-150E-88D9A0C7F2AA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_Iterative_Logging_Server", "examples\C++NPv1\C++NPv1_Iterative_Logging_Server_vc12.vcxproj", "{77B1F4AE-FECA-1BAD-B753-CBFC9FE5DD76}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_Logging_Client", "examples\C++NPv1\C++NPv1_Logging_Client_vc12.vcxproj", "{817A184A-FECA-1BAD-B753-CBFC9FE5DD76}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_PPC_Logging_Server", "examples\C++NPv1\C++NPv1_PPC_Logging_Server_vc12.vcxproj", "{E997FE0B-FECA-1BAD-B753-CBFC9FE5DD76}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_RTTPC_Logging_Server", "examples\C++NPv1\C++NPv1_RTTPC_Logging_Server_vc12.vcxproj", "{83BF1DB9-FECA-1BAD-B753-CBFC9FE5DD76}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_Reactive_Logging_Server_Ex", "examples\C++NPv1\C++NPv1_Reactive_Logging_Server_Ex_vc12.vcxproj", "{663FE280-FECA-1BAD-B753-CBFC9FE5DD76}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_Reactive_Logging_Server", "examples\C++NPv1\C++NPv1_Reactive_Logging_Server_vc12.vcxproj", "{560013D0-FECA-1BAD-B753-CBFC9FE5DD76}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv1_TPC_Logging_Server", "examples\C++NPv1\C++NPv1_TPC_Logging_Server_vc12.vcxproj", "{ED97FE0B-FECA-1BAD-B753-CBFC9FE5DD76}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_CLD", "examples\C++NPv2\C++NPv2_CLD_vc12.vcxproj", "{71572394-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_Configurable_Log_Server", "examples\C++NPv2\C++NPv2_Configurable_Log_Server_vc12.vcxproj", "{2D05C715-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_Display_Logfile", "examples\C++NPv2\C++NPv2_Display_Logfile_vc12.vcxproj", "{3908C846-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_Reactor_Log_Server", "examples\C++NPv2\C++NPv2_Reactor_Log_Server_vc12.vcxproj", "{4DF6061E-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_SLD", "examples\C++NPv2\C++NPv2_SLD_vc12.vcxproj", "{71572395-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_SLDex", "examples\C++NPv2\C++NPv2_SLDex_vc12.vcxproj", "{C919288A-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_SR_Configurable_Log_Server", "examples\C++NPv2\C++NPv2_SR_Configurable_Log_Server_vc12.vcxproj", "{BF9E69B9-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_Select_Reactor_Log_Server", "examples\C++NPv2\C++NPv2_Select_Reactor_Log_Server_vc12.vcxproj", "{7223E97D-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_TPLS", "examples\C++NPv2\C++NPv2_TPLS_vc12.vcxproj", "{C66B010B-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_TP_Reactor_Log_Server", "examples\C++NPv2\C++NPv2_TP_Reactor_Log_Server_vc12.vcxproj", "{F71CCF45-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "C++NPv2_WFMO_Reactor_Log_Server", "examples\C++NPv2\C++NPv2_WFMO_Reactor_Log_Server_vc12.vcxproj", "{79179A28-FECA-1BAD-B750-CBFC9FE5DD75}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Blocking_Acceptor", "examples\Connection\blocking\Connection_Blocking_Acceptor_vc12.vcxproj", "{99B2D4AF-FECA-1BAD-63A6-43B4A3F0BDAC}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Blocking_Connector", "examples\Connection\blocking\Connection_Blocking_Connector_vc12.vcxproj", "{2F08A8E5-FECA-1BAD-63A6-43B4A3F0BDAC}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Misc_Handler", "examples\Connection\misc\Connection_Misc_Handler_vc12.vcxproj", "{638C735A-FECA-1BAD-3D13-3640622B5736}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Misc_Test_Upipe", "examples\Connection\misc\Connection_Misc_Test_Upipe_vc12.vcxproj", "{E8BB71D9-FECA-1BAD-3D13-3640622B5736}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_LSockClient", "examples\Connection\non_blocking\Connection_Non_Blocking_LSockClient_vc12.vcxproj", "{D754F4F0-FECA-1BAD-D57C-7CD528BEBF5B}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_LSockServer", "examples\Connection\non_blocking\Connection_Non_Blocking_LSockServer_vc12.vcxproj", "{EC34E47A-FECA-1BAD-D57C-7CD528BEBF5B}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_SPipeClient", "examples\Connection\non_blocking\Connection_Non_Blocking_SPipeClient_vc12.vcxproj", "{242714F1-FECA-1BAD-D57C-7CD528BEBF5B}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_SPipeServer", "examples\Connection\non_blocking\Connection_Non_Blocking_SPipeServer_vc12.vcxproj", "{1F47047B-FECA-1BAD-D57C-7CD528BEBF5B}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_SockClient", "examples\Connection\non_blocking\Connection_Non_Blocking_SockClient_vc12.vcxproj", "{7A8F763F-FECA-1BAD-D57C-7CD528BEBF5B}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_SockServer", "examples\Connection\non_blocking\Connection_Non_Blocking_SockServer_vc12.vcxproj", "{41EF66B5-FECA-1BAD-D57C-7CD528BEBF5B}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_TLIClient", "examples\Connection\non_blocking\Connection_Non_Blocking_TLIClient_vc12.vcxproj", "{9CCFEE13-FECA-1BAD-D57C-7CD528BEBF5B}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Connection_Non_Blocking_TLIServer", "examples\Connection\non_blocking\Connection_Non_Blocking_TLIServer_vc12.vcxproj", "{A7AFFE99-FECA-1BAD-D57C-7CD528BEBF5B}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Main", "examples\DLL\DLL_Main_vc12.vcxproj", "{6F4CDF50-FECA-1BAD-408E-8A636A279EF6}"
+ {AAE476EA-FECA-1BAD-408E-8A636A279EF6} = {AAE476EA-FECA-1BAD-408E-8A636A279EF6}
+ {3274CCC2-FECA-1BAD-408E-8A636A279EF6} = {3274CCC2-FECA-1BAD-408E-8A636A279EF6}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Newsweek", "examples\DLL\DLL_Newsweek_vc12.vcxproj", "{AAE476EA-FECA-1BAD-408E-8A636A279EF6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Today", "examples\DLL\DLL_Today_vc12.vcxproj", "{3274CCC2-FECA-1BAD-408E-8A636A279EF6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Export_Lib", "examples\Export\Export_Lib_vc12.vcxproj", "{FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Export_Test", "examples\Export\Export_Test_vc12.vcxproj", "{1BC4074D-FECA-1BAD-6856-8E4C79C8CEF6}"
+ {FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6} = {FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IOStream_Client", "examples\IOStream\client\IOStream_Client_vc12.vcxproj", "{6AD03907-FECA-1BAD-C7A1-4C9D6A84AD84}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IOStream_Server", "examples\IOStream\server\IOStream_Server_vc12.vcxproj", "{51B0298D-FECA-1BAD-6417-4D956B8C0E32}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "atm_sap_client", "examples\IPC_SAP\ATM_SAP\atm_sap_client_vc12.vcxproj", "{ACC9A56C-FECA-1BAD-8562-EC4B26346A25}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "atm_sap_server", "examples\IPC_SAP\ATM_SAP\atm_sap_server_vc12.vcxproj", "{97A9B5E6-FECA-1BAD-8562-EC4B26346A25}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "dev_sap_reader", "examples\IPC_SAP\DEV_SAP\reader\dev_sap_reader_vc12.vcxproj", "{B7A9B0FF-FECA-1BAD-4A76-D4027A608480}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "dev_sap_writer", "examples\IPC_SAP\DEV_SAP\writer\dev_sap_writer_vc12.vcxproj", "{B7A9B486-FECA-1BAD-DA76-D4457A271480}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Fifo_Sap_Msg_Client", "examples\IPC_SAP\FIFO_SAP\Fifo_Sap_Msg_Client_vc12.vcxproj", "{9CF44625-FECA-1BAD-8564-85690EE67112}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Fifo_Sap_Msg_Server", "examples\IPC_SAP\FIFO_SAP\Fifo_Sap_Msg_Server_vc12.vcxproj", "{A79456AF-FECA-1BAD-8564-85690EE67112}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "fifo_sap_client", "examples\IPC_SAP\FIFO_SAP\fifo_sap_client_vc12.vcxproj", "{ACCFCC4E-FECA-1BAD-8564-85690EE67112}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "fifo_sap_server", "examples\IPC_SAP\FIFO_SAP\fifo_sap_server_vc12.vcxproj", "{97AFDCC4-FECA-1BAD-8564-85690EE67112}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "fifo_sap_test", "examples\IPC_SAP\FIFO_SAP\fifo_sap_test_vc12.vcxproj", "{3E293566-FECA-1BAD-8564-85690EE67112}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "file_sap_client", "examples\IPC_SAP\FILE_SAP\file_sap_client_vc12.vcxproj", "{ACCFCCE4-FECA-1BAD-FBC0-B3C30E4C7112}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Inclient", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Inclient_vc12.vcxproj", "{22B6B3AB-FECA-1BAD-8565-D33D58B27113}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Inserver", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Inserver_vc12.vcxproj", "{19D6A321-FECA-1BAD-8565-D33D58B27113}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Memclient", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Memclient_vc12.vcxproj", "{9849EDB4-FECA-1BAD-8565-D33D58B27113}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Memserver", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Memserver_vc12.vcxproj", "{A329FD3E-FECA-1BAD-8565-D33D58B27113}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Unclient", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Unclient_vc12.vcxproj", "{22AAB3AB-FECA-1BAD-8565-D33D58B27113}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_CPP_Unserver", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_CPP_Unserver_vc12.vcxproj", "{19CAA321-FECA-1BAD-8565-D33D58B27113}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_C_Inclient", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_C_Inclient_vc12.vcxproj", "{C64D7624-FECA-1BAD-8565-D33D58B27113}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_C_Inserver", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_C_Inserver_vc12.vcxproj", "{FD2D66AE-FECA-1BAD-8565-D33D58B27113}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sock_Sap_FD_Unclient", "examples\IPC_SAP\SOCK_SAP\Sock_Sap_FD_Unclient_vc12.vcxproj", "{9DE5854A-FECA-1BAD-8565-D33D58B27113}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Client", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Client_vc12.vcxproj", "{8EBFAF04-FECA-1BAD-A714-C623708DC274}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Consumer_Msg", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Consumer_Msg_vc12.vcxproj", "{6C78F769-FECA-1BAD-A714-C623708DC274}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Consumer_Read", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Consumer_Read_vc12.vcxproj", "{B9E64ED2-FECA-1BAD-A714-C623708DC274}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_NPClient", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_NPClient_vc12.vcxproj", "{3A5B53E3-FECA-1BAD-A714-C623708DC274}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_NPServer", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_NPServer_vc12.vcxproj", "{013B4369-FECA-1BAD-A714-C623708DC274}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Producer_Msg", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Producer_Msg_vc12.vcxproj", "{BC08177B-FECA-1BAD-A714-C623708DC274}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Producer_Read", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Producer_Read_vc12.vcxproj", "{BEE84FFF-FECA-1BAD-A714-C623708DC274}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_SAP_Server", "examples\IPC_SAP\SPIPE_SAP\SPIPE_SAP_Server_vc12.vcxproj", "{B5DFBF8E-FECA-1BAD-A714-C623708DC274}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_ATM_Client", "examples\IPC_SAP\TLI_SAP\TLI_SAP_ATM_Client_vc12.vcxproj", "{CD284401-FECA-1BAD-A742-DAEF32B06A25}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_ATM_Server", "examples\IPC_SAP\TLI_SAP\TLI_SAP_ATM_Server_vc12.vcxproj", "{F648548B-FECA-1BAD-A742-DAEF32B06A25}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_CPP_Client", "examples\IPC_SAP\TLI_SAP\TLI_SAP_CPP_Client_vc12.vcxproj", "{CF754401-FECA-1BAD-A742-DAEF32B06A25}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_CPP_Server", "examples\IPC_SAP\TLI_SAP\TLI_SAP_CPP_Server_vc12.vcxproj", "{F415548B-FECA-1BAD-A742-DAEF32B06A25}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_Db_Client", "examples\IPC_SAP\TLI_SAP\TLI_SAP_Db_Client_vc12.vcxproj", "{77832930-FECA-1BAD-A742-DAEF32B06A25}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_Db_Server", "examples\IPC_SAP\TLI_SAP\TLI_SAP_Db_Server_vc12.vcxproj", "{4CE339BA-FECA-1BAD-A742-DAEF32B06A25}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_Ftp_Client", "examples\IPC_SAP\TLI_SAP\TLI_SAP_Ftp_Client_vc12.vcxproj", "{C8154401-FECA-1BAD-A742-DAEF32B06A25}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TLI_SAP_Ftp_Server", "examples\IPC_SAP\TLI_SAP\TLI_SAP_Ftp_Server_vc12.vcxproj", "{F375548B-FECA-1BAD-A742-DAEF32B06A25}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UPIPE_SAP_Ex1", "examples\IPC_SAP\UPIPE_SAP\UPIPE_SAP_Ex1_vc12.vcxproj", "{FFF627B4-FECA-1BAD-A712-C623708DC272}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UPIPE_SAP_Ex2", "examples\IPC_SAP\UPIPE_SAP\UPIPE_SAP_Ex2_vc12.vcxproj", "{FFC627B4-FECA-1BAD-A712-C623708DC272}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UPIPE_SAP_Ex3", "examples\IPC_SAP\UPIPE_SAP\UPIPE_SAP_Ex3_vc12.vcxproj", "{FFD627B4-FECA-1BAD-A712-C623708DC272}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Msg_Test_Callback", "examples\Log_Msg\Log_Msg_Test_Callback_vc12.vcxproj", "{0F4C02C4-FECA-1BAD-BA55-C0F194E8D070}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Msg_Test_Log_Msg", "examples\Log_Msg\Log_Msg_Test_Log_Msg_vc12.vcxproj", "{033DAD28-FECA-1BAD-BA55-C0F194E8D070}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Msg_Test_Ostream", "examples\Log_Msg\Log_Msg_Test_Ostream_vc12.vcxproj", "{919D8037-FECA-1BAD-BA55-C0F194E8D070}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Logger_Acceptor_Server", "examples\Logger\Acceptor-server\Logger_Acceptor_Server_vc12.vcxproj", "{7230CC0D-FECA-1BAD-662F-43CDC449C088}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Logger_client", "examples\Logger\client\Logger_client_vc12.vcxproj", "{388BC7ED-FECA-1BAD-6284-F3732ECE18EC}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Logger_Simple_Server", "examples\Logger\simple-server\Logger_Simple_Server_vc12.vcxproj", "{257E89DB-FECA-1BAD-035B-A790F8AEE4FF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Map_Manager", "examples\Map_Manager\Map_Manager_vc12.vcxproj", "{B497E168-FECA-1BAD-3A45-311BD15FE43D}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mem_Map_IO_Tests", "examples\Mem_Map\IO-tests\Mem_Map_IO_Tests_vc12.vcxproj", "{362AC472-FECA-1BAD-926E-E34A898F3061}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mem_Map_File_Reverse", "examples\Mem_Map\file-reverse\Mem_Map_File_Reverse_vc12.vcxproj", "{870D7112-FECA-1BAD-997C-981CB0707EDF}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Dump", "examples\Misc\Misc_Test_Dump_vc12.vcxproj", "{40CE5CBD-FECA-1BAD-BE51-8A67A27959F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Get_Opt", "examples\Misc\Misc_Test_Get_Opt_vc12.vcxproj", "{B7091252-FECA-1BAD-BE51-8A67A27959F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Profile_Timer", "examples\Misc\Misc_Test_Profile_Timer_vc12.vcxproj", "{9016F8E6-FECA-1BAD-BE51-8A67A27959F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Read_Buffer", "examples\Misc\Misc_Test_Read_Buffer_vc12.vcxproj", "{071FC37F-FECA-1BAD-BE51-8A67A27959F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Set", "examples\Misc\Misc_Test_Set_vc12.vcxproj", "{140E764F-FECA-1BAD-BE51-8A67A27959F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Sstring", "examples\Misc\Misc_Test_Sstring_vc12.vcxproj", "{C838447D-FECA-1BAD-BE51-8A67A27959F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Timestamp", "examples\Misc\Misc_Test_Timestamp_vc12.vcxproj", "{CE954689-FECA-1BAD-BE51-8A67A27959F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Trace", "examples\Misc\Misc_Test_Trace_vc12.vcxproj", "{C79CF289-FECA-1BAD-BE51-8A67A27959F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bytes_Sent", "examples\Monitor\Bytes_Sent\Bytes_Sent_vc12.vcxproj", "{6C4E704E-FECA-1BAD-57C8-A8090AE02194}"
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C} = {7153B6F6-FECA-1BAD-D619-74620E01B14C}
+ {FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5} = {FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "CPU_Load", "examples\Monitor\CPU_Load\CPU_Load_vc12.vcxproj", "{87EA0651-FECA-1BAD-A972-EF683B232306}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Constraint", "examples\Monitor\Constraint\Constraint_vc12.vcxproj", "{AC3515AC-FECA-1BAD-7BCF-1E57BCBE0D93}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Group", "examples\Monitor\Group\Group_vc12.vcxproj", "{92EC52EF-FECA-1BAD-4822-8A23A725AAA8}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MC_Test_Utilities", "examples\Monitor\MC_Test_Utilities_vc12.vcxproj", "{FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Memory_Usage", "examples\Monitor\Memory_Usage\Memory_Usage_vc12.vcxproj", "{5A399C85-FECA-1BAD-E4AF-D6C5D6D0BA85}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Queue_Size", "examples\Monitor\Message_Queue_Size\Message_Queue_Size_vc12.vcxproj", "{11AA315E-FECA-1BAD-5016-EC184EF1264A}"
+ ProjectSection(ProjectDependencies) = postProject
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Num_Threads", "examples\Monitor\Num_Threads\Num_Threads_vc12.vcxproj", "{F05679AC-FECA-1BAD-7E09-28972A531BE9}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "NT_Service", "examples\NT_Service\NT_Service_vc12.vcxproj", "{AEA604BB-FECA-1BAD-0BE6-2F4603877603}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Naming_Multiple_Contexts", "examples\Naming\Naming_Multiple_Contexts_vc12.vcxproj", "{688206D7-FECA-1BAD-BF85-8EE479601925}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Naming_Non_Existent", "examples\Naming\Naming_Non_Existent_vc12.vcxproj", "{35A13A15-FECA-1BAD-BF85-8EE479601925}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Naming_Open", "examples\Naming\Naming_Open_vc12.vcxproj", "{F4B3D457-FECA-1BAD-BF85-8EE479601925}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Naming_Writers", "examples\Naming\Naming_Writers_vc12.vcxproj", "{CDF61A72-FECA-1BAD-BF85-8EE479601925}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "OS_Process_Imore", "examples\OS\Process\OS_Process_Imore_vc12.vcxproj", "{01D25764-FECA-1BAD-56E7-2D2A01EB2B05}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "OS_Process_Process", "examples\OS\Process\OS_Process_Process_vc12.vcxproj", "{5ADC56EB-FECA-1BAD-56E7-2D2A01EB2B05}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Dgram_CO", "examples\Reactor\Dgram\Reactor_Dgram_CO_vc12.vcxproj", "{20FA65D1-FECA-1BAD-333D-0D85A7384955}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Dgram", "examples\Reactor\Dgram\Reactor_Dgram_vc12.vcxproj", "{23142888-FECA-1BAD-333D-0D85A7384955}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_FIFO_Client", "examples\Reactor\FIFO\Reactor_FIFO_Client_vc12.vcxproj", "{47F2CB3A-FECA-1BAD-6E59-A21D8A7389FD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_FIFO_Server", "examples\Reactor\FIFO\Reactor_FIFO_Server_vc12.vcxproj", "{7C92DBB0-FECA-1BAD-6E59-A21D8A7389FD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Demuxing", "examples\Reactor\Misc\Reactor_Misc_Demuxing_vc12.vcxproj", "{CA061238-FECA-1BAD-FD25-A21D8A731A81}"
+ {47BC56EF-FECA-1BAD-6757-8A6300006755} = {47BC56EF-FECA-1BAD-6757-8A6300006755}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Early_Timeouts", "examples\Reactor\Misc\Reactor_Misc_Early_Timeouts_vc12.vcxproj", "{725C36C9-FECA-1BAD-FD25-A21D8A731A81}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Event_Handler_t", "examples\Reactor\Misc\Reactor_Misc_Event_Handler_t_vc12.vcxproj", "{A162739F-FECA-1BAD-FD25-A21D8A731A81}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Notification", "examples\Reactor\Misc\Reactor_Misc_Notification_vc12.vcxproj", "{15018119-FECA-1BAD-FD25-A21D8A731A81}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Pingpong", "examples\Reactor\Misc\Reactor_Misc_Pingpong_vc12.vcxproj", "{AA12D010-FECA-1BAD-FD25-A21D8A731A81}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Reactors", "examples\Reactor\Misc\Reactor_Misc_Reactors_vc12.vcxproj", "{B7501F54-FECA-1BAD-FD25-A21D8A731A81}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Signals_1", "examples\Reactor\Misc\Reactor_Misc_Signals_1_vc12.vcxproj", "{5424A142-FECA-1BAD-FD25-A21D8A731A81}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Signals_2", "examples\Reactor\Misc\Reactor_Misc_Signals_2_vc12.vcxproj", "{5414A142-FECA-1BAD-FD25-A21D8A731A81}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Misc_Timer_Queue", "examples\Reactor\Misc\Reactor_Misc_Timer_Queue_vc12.vcxproj", "{9BE1FEA0-FECA-1BAD-FD25-A21D8A731A81}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Multicast_Client", "examples\Reactor\Multicast\Reactor_Multicast_Client_vc12.vcxproj", "{F803EF29-FECA-1BAD-D1A8-860E7607F174}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Multicast_Server", "examples\Reactor\Multicast\Reactor_Multicast_Server_vc12.vcxproj", "{C363FFA3-FECA-1BAD-D1A8-860E7607F174}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Ntalker", "examples\Reactor\Ntalker\Reactor_Ntalker_vc12.vcxproj", "{EAB287E5-FECA-1BAD-EFA7-6773336A8585}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Cancel", "examples\Reactor\Proactor\Proactor_Cancel_vc12.vcxproj", "{01AE9704-FECA-1BAD-4285-FEF4D045C8F0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_End_Event_Loops", "examples\Reactor\Proactor\Proactor_End_Event_Loops_vc12.vcxproj", "{9FC93C2D-FECA-1BAD-4285-FEF4D045C8F0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Multiple_Loops", "examples\Reactor\Proactor\Proactor_Multiple_Loops_vc12.vcxproj", "{FB3493EE-FECA-1BAD-4285-FEF4D045C8F0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Post_Completions", "examples\Reactor\Proactor\Proactor_Post_Completions_vc12.vcxproj", "{52A8E79D-FECA-1BAD-4285-FEF4D045C8F0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Proactor", "examples\Reactor\Proactor\Proactor_Proactor_vc12.vcxproj", "{BA1F88DD-FECA-1BAD-4285-FEF4D045C8F0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Timeout", "examples\Reactor\Proactor\Proactor_Timeout_vc12.vcxproj", "{BA81302C-FECA-1BAD-4285-FEF4D045C8F0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Udp_Proactor", "examples\Reactor\Proactor\Proactor_Udp_Proactor_vc12.vcxproj", "{9A299D48-FECA-1BAD-4285-FEF4D045C8F0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TP_Reactor_Client", "examples\Reactor\TP_Reactor\TP_Reactor_Client_vc12.vcxproj", "{6E3E4773-FECA-1BAD-4795-2E5476BD3033}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TP_Reactor_Server", "examples\Reactor\TP_Reactor\TP_Reactor_Server_vc12.vcxproj", "{555E57F9-FECA-1BAD-4795-2E5476BD3033}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_APC", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_APC_vc12.vcxproj", "{17FB573A-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Abandoned", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Abandoned_vc12.vcxproj", "{429B09C3-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Console_Input", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Console_Input_vc12.vcxproj", "{D0378C08-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Directory_Changes", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Directory_Changes_vc12.vcxproj", "{567A6CD0-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Exceptions", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Exceptions_vc12.vcxproj", "{9F0B01D9-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Handle_Close", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Handle_Close_vc12.vcxproj", "{DFE640AB-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Multithreading", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Multithreading_vc12.vcxproj", "{B6AE0B90-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Network_Events", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Network_Events_vc12.vcxproj", "{EB8FF8F9-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Prerun_State_Changes", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Prerun_State_Changes_vc12.vcxproj", "{10F4AFD2-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Registration", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Registration_vc12.vcxproj", "{EA987F89-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Registry_Changes", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Registry_Changes_vc12.vcxproj", "{2A170B07-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Removals", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Removals_vc12.vcxproj", "{76DC5F1B-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Suspended_Removals", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Suspended_Removals_vc12.vcxproj", "{5A6E7EF4-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Talker", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Talker_vc12.vcxproj", "{B2D150A3-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Timeouts", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Timeouts_vc12.vcxproj", "{2EDA9FA3-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Window_Messages", "examples\Reactor\WFMO_Reactor\WFMO_Reactor_Window_Messages_vc12.vcxproj", "{81B72E19-FECA-1BAD-701A-2E512E45D4CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Registry_Iterator", "examples\Registry\Registry_Iterator_vc12.vcxproj", "{61316AEE-FECA-1BAD-435E-C97DA4B8E121}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Registry_Update", "examples\Registry\Registry_Update_vc12.vcxproj", "{31E5B797-FECA-1BAD-435E-C97DA4B8E121}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Semaphores_Starter", "examples\Semaphores\Semaphores_Starter_vc12.vcxproj", "{259D7266-FECA-1BAD-8172-3C0D10CCFC97}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Semaphores_Worker", "examples\Semaphores\Semaphores_Worker_vc12.vcxproj", "{43B94101-FECA-1BAD-8172-3C0D10CCFC97}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Bcast", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Bcast_vc12.vcxproj", "{D97D0DAE-FECA-1BAD-DD12-8A69A8383EB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Loc_Dgram", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Loc_Dgram_vc12.vcxproj", "{0C95901A-FECA-1BAD-DD12-8A69A8383EB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Loc_Fifo", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Loc_Fifo_vc12.vcxproj", "{F5A6CA86-FECA-1BAD-DD12-8A69A8383EB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Loc_Pipe", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Loc_Pipe_vc12.vcxproj", "{E306CA90-FECA-1BAD-DD12-8A69A8383EB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Loc_Spipe", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Loc_Spipe_vc12.vcxproj", "{AD15917C-FECA-1BAD-DD12-8A69A8383EB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Loc_Stream", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Loc_Stream_vc12.vcxproj", "{9DA02FCA-FECA-1BAD-DD12-8A69A8383EB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Rem_Dgram", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Rem_Dgram_vc12.vcxproj", "{0D7F701A-FECA-1BAD-DD12-8A69A8383EB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Rem_Stream", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Rem_Stream_vc12.vcxproj", "{830E2FCA-FECA-1BAD-DD12-8A69A8383EB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Rem_Svc_Dir", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Rem_Svc_Dir_vc12.vcxproj", "{7DEBC7DA-FECA-1BAD-DD12-8A69A8383EB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Client_Rem_Thr_Stream", "examples\Service_Configurator\IPC-tests\client\Svc_Cfg_IPC_Client_Rem_Thr_Stream_vc12.vcxproj", "{58DE56ED-FECA-1BAD-DD12-8A69A8383EB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Server_Lib", "examples\Service_Configurator\IPC-tests\server\Svc_Cfg_IPC_Server_Lib_vc12.vcxproj", "{AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Cfg_IPC_Server_Test", "examples\Service_Configurator\IPC-tests\server\Svc_Cfg_IPC_Server_Test_vc12.vcxproj", "{36D2F548-FECA-1BAD-7EA4-8B61A9309D00}"
+ {AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00} = {AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Configurator_Misc_Main", "examples\Service_Configurator\Misc\Service_Configurator_Misc_Main_vc12.vcxproj", "{14E0A6C5-FECA-1BAD-ECF7-1F18EF61CB2B}"
+ {1C035593-FECA-1BAD-ECF7-1F18EF61CB2B} = {1C035593-FECA-1BAD-ECF7-1F18EF61CB2B}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Configurator_Misc_Timer", "examples\Service_Configurator\Misc\Service_Configurator_Misc_Timer_vc12.vcxproj", "{1C035593-FECA-1BAD-ECF7-1F18EF61CB2B}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Malloc_Multiple", "examples\Shared_Malloc\Shared_Malloc_Multiple_vc12.vcxproj", "{AF1D8F89-FECA-1BAD-4CD2-91813C3C36BA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Malloc_Persistence", "examples\Shared_Malloc\Shared_Malloc_Persistence_vc12.vcxproj", "{49CD7F93-FECA-1BAD-4CD2-91813C3C36BA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Malloc_Posind", "examples\Shared_Malloc\Shared_Malloc_Posind_vc12.vcxproj", "{A479EB8C-FECA-1BAD-4CD2-91813C3C36BA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Malloc", "examples\Shared_Malloc\Shared_Malloc_vc12.vcxproj", "{DDEDE8CF-FECA-1BAD-4CD2-91813C3C36BA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Memory_MM", "examples\Shared_Memory\Shared_Memory_MM_vc12.vcxproj", "{B2DA08F4-FECA-1BAD-5E18-91853C382470}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Shared_Memory_SV", "examples\Shared_Memory\Shared_Memory_SV_vc12.vcxproj", "{AD6A08F4-FECA-1BAD-5E18-91853C382470}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Smart_Pointers_Gadget", "examples\Smart_Pointers\Smart_Pointers_Gadget_vc12.vcxproj", "{45E08B3B-FECA-1BAD-474B-E6C11145E1EB}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Smart_Pointers_Widget", "examples\Smart_Pointers\Smart_Pointers_Widget_vc12.vcxproj", "{45E09BBB-FECA-1BAD-474B-E6C11145E1EB}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Synch", "examples\Synch\Synch_vc12.vcxproj", "{956C53A4-FECA-1BAD-F85A-8A37278A8232}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Message_Queues_MQ_Client", "examples\System_V_IPC\SV_Message_Queues\SV_Message_Queues_MQ_Client_vc12.vcxproj", "{3135F524-FECA-1BAD-6606-BBB2EAC4C36E}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Message_Queues_MQ_Server", "examples\System_V_IPC\SV_Message_Queues\SV_Message_Queues_MQ_Server_vc12.vcxproj", "{0A55E5AE-FECA-1BAD-6606-BBB2EAC4C36E}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Message_Queues_TMQ_Client", "examples\System_V_IPC\SV_Message_Queues\SV_Message_Queues_TMQ_Client_vc12.vcxproj", "{B8F98545-FECA-1BAD-6606-BBB2EAC4C36E}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Message_Queues_TMQ_Server", "examples\System_V_IPC\SV_Message_Queues\SV_Message_Queues_TMQ_Server_vc12.vcxproj", "{839995CF-FECA-1BAD-6606-BBB2EAC4C36E}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Semaphores_1", "examples\System_V_IPC\SV_Semaphores\SV_Semaphores_1_vc12.vcxproj", "{479FDD0C-FECA-1BAD-BE72-3C5B13526565}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Semaphores_2", "examples\System_V_IPC\SV_Semaphores\SV_Semaphores_2_vc12.vcxproj", "{47AFDD0C-FECA-1BAD-BE72-3C5B13526565}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Auto_Event", "examples\Threads\Threads_Auto_Event_vc12.vcxproj", "{CD7ACAFD-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Barrier1", "examples\Threads\Threads_Barrier1_vc12.vcxproj", "{071AC793-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Barrier2", "examples\Threads\Threads_Barrier2_vc12.vcxproj", "{072AC793-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Cancel", "examples\Threads\Threads_Cancel_vc12.vcxproj", "{741AB167-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Future1", "examples\Threads\Threads_Future1_vc12.vcxproj", "{25926B9A-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Future2", "examples\Threads\Threads_Future2_vc12.vcxproj", "{25A26B9A-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Manual_Event", "examples\Threads\Threads_Manual_Event_vc12.vcxproj", "{A4ACFB22-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Process_Mutex", "examples\Threads\Threads_Process_Mutex_vc12.vcxproj", "{E43B5212-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Process_Semaphore", "examples\Threads\Threads_Process_Semaphore_vc12.vcxproj", "{91B436D2-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Reader_Writer", "examples\Threads\Threads_Reader_Writer_vc12.vcxproj", "{039899C9-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Recursive_Mutex", "examples\Threads\Threads_Recursive_Mutex_vc12.vcxproj", "{14E33148-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Task_Five", "examples\Threads\Threads_Task_Five_vc12.vcxproj", "{9FB54B28-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Task_Four", "examples\Threads\Threads_Task_Four_vc12.vcxproj", "{FDC54B28-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Task_One", "examples\Threads\Threads_Task_One_vc12.vcxproj", "{BE4CC737-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Task_Three", "examples\Threads\Threads_Task_Three_vc12.vcxproj", "{A32D8BF2-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Task_Two", "examples\Threads\Threads_Task_Two_vc12.vcxproj", "{17ECC736-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Thread_Manager", "examples\Threads\Threads_Thread_Manager_vc12.vcxproj", "{02E1116C-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Thread_Pool", "examples\Threads\Threads_Thread_Pool_vc12.vcxproj", "{892C5422-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Thread_Specific", "examples\Threads\Threads_Thread_Specific_vc12.vcxproj", "{1D1735B4-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Token", "examples\Threads\Threads_Token_vc12.vcxproj", "{807F39ED-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Tss1", "examples\Threads\Threads_Tss1_vc12.vcxproj", "{A4CB601A-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Threads_Tss2", "examples\Threads\Threads_Tss2_vc12.vcxproj", "{A4FB601A-FECA-1BAD-3731-D8978C8E5D14}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Async", "examples\Timer_Queue\Timer_Queue_Async_vc12.vcxproj", "{8ED0EFF5-FECA-1BAD-60CC-ADC54D81BEB4}"
+ {79C583D9-FECA-1BAD-60CC-ADC54D81BEB4} = {79C583D9-FECA-1BAD-60CC-ADC54D81BEB4}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Library", "examples\Timer_Queue\Timer_Queue_Library_vc12.vcxproj", "{79C583D9-FECA-1BAD-60CC-ADC54D81BEB4}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Reactor", "examples\Timer_Queue\Timer_Queue_Reactor_vc12.vcxproj", "{34746FF9-FECA-1BAD-60CC-ADC54D81BEB4}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Thread_Custom_Handlers", "examples\Timer_Queue\Timer_Queue_Thread_Custom_Handlers_vc12.vcxproj", "{FAB2E9D1-FECA-1BAD-60CC-ADC54D81BEB4}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Thread", "examples\Timer_Queue\Timer_Queue_Thread_vc12.vcxproj", "{4767D3B9-FECA-1BAD-60CC-ADC54D81BEB4}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Web_Crawler", "examples\Web_Crawler\Web_Crawler_vc12.vcxproj", "{A1B7128F-FECA-1BAD-4B17-3E25DE61956F}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "direct_logging", "netsvcs\clients\Logger\direct_logging_vc12.vcxproj", "{DC859D1E-FECA-1BAD-1120-8ECA0471D6B5}"
+ {14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1} = {14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "indirect_logging", "netsvcs\clients\Logger\indirect_logging_vc12.vcxproj", "{DCEA7D1E-FECA-1BAD-1120-8ECA0471D6B5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Netsvcs_Client_Test", "netsvcs\clients\Naming\Client\Netsvcs_Client_Test_vc12.vcxproj", "{EC6BC326-FECA-1BAD-F396-8E392B1F0415}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Netsvcs_Dump_Restore", "netsvcs\clients\Naming\Dump_Restore\Netsvcs_Dump_Restore_vc12.vcxproj", "{8DA65252-FECA-1BAD-1BE2-2E43250F5E17}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "netsvcs", "netsvcs\lib\netsvcs_vc12.vcxproj", "{14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Netsvcs_server", "netsvcs\servers\Netsvcs_server_vc12.vcxproj", "{528A9BED-FECA-1BAD-0251-FF46ED064212}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Basic_Perf", "performance-tests\Misc\Misc_Basic_Perf_vc12.vcxproj", "{80ED1E1B-FECA-1BAD-BE51-8A67F3FC84F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Childbirth_Time", "performance-tests\Misc\Misc_Childbirth_Time_vc12.vcxproj", "{2A3225F8-FECA-1BAD-BE51-8A67F3FC84F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Context_Switch_Time", "performance-tests\Misc\Misc_Context_Switch_Time_vc12.vcxproj", "{F387C138-FECA-1BAD-BE51-8A67F3FC84F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Preempt", "performance-tests\Misc\Misc_Preempt_vc12.vcxproj", "{52C62293-FECA-1BAD-BE51-8A67F3FC84F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Guard", "performance-tests\Misc\Misc_Test_Guard_vc12.vcxproj", "{D68CF3BE-FECA-1BAD-BE51-8A67F3FC84F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Mutex", "performance-tests\Misc\Misc_Test_Mutex_vc12.vcxproj", "{904CF31F-FECA-1BAD-BE51-8A67F3FC84F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Naming", "performance-tests\Misc\Misc_Test_Naming_vc12.vcxproj", "{CA960BFA-FECA-1BAD-BE51-8A67F3FC84F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Misc_Test_Singleton", "performance-tests\Misc\Misc_Test_Singleton_vc12.vcxproj", "{9D057569-FECA-1BAD-BE51-8A67F3FC84F5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SCTP_SOCK_SEQPACK_Association_Test", "performance-tests\SCTP\SCTP_SOCK_SEQPACK_Association_Test_vc12.vcxproj", "{95F3D6E2-FECA-1BAD-7612-8A66F3FD4CB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SCTP_SOCK_SEQPACK_Clt", "performance-tests\SCTP\SCTP_SOCK_SEQPACK_Clt_vc12.vcxproj", "{2E4FB39C-FECA-1BAD-7612-8A66F3FD4CB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SCTP_SOCK_SEQPACK_Srv", "performance-tests\SCTP\SCTP_SOCK_SEQPACK_Srv_vc12.vcxproj", "{306FB39D-FECA-1BAD-7612-8A66F3FD4CB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SCTP_SOCK_STREAM_Clt", "performance-tests\SCTP\SCTP_SOCK_STREAM_Clt_vc12.vcxproj", "{8CE03849-FECA-1BAD-7612-8A66F3FD4CB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SCTP_SOCK_STREAM_Srv", "performance-tests\SCTP\SCTP_SOCK_STREAM_Srv_vc12.vcxproj", "{92C03848-FECA-1BAD-7612-8A66F3FD4CB6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svr_Conc_Leader_Follower_RT_CORBA", "performance-tests\Server_Concurrency\Leader_Follower\Svr_Conc_Leader_Follower_RT_CORBA_vc12.vcxproj", "{A9A9AB6B-FECA-1BAD-FAD8-7885071DD3E2}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svr_Conc_Leader_Follower", "performance-tests\Server_Concurrency\Leader_Follower\Svr_Conc_Leader_Follower_vc12.vcxproj", "{BD437884-FECA-1BAD-FAD8-7885071DD3E2}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svr_Conc_Queue_Based_Workers_RTCorba", "performance-tests\Server_Concurrency\Queue_Based_Workers\Svr_Conc_Queue_Based_Workers_RTCorba_vc12.vcxproj", "{561AAD86-FECA-1BAD-5029-42D0E18BA5D0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svr_Conc_Queue_Based_Workers", "performance-tests\Server_Concurrency\Queue_Based_Workers\Svr_Conc_Queue_Based_Workers_vc12.vcxproj", "{1250DDDE-FECA-1BAD-5029-42D0E18BA5D0}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Synch_Benchmarks_Base_Test", "performance-tests\Synch-Benchmarks\Base_Test\Synch_Benchmarks_Base_Test_vc12.vcxproj", "{334CEDB1-FECA-1BAD-A238-81D6AD345D00}"
+ {BA83D330-FECA-1BAD-3A9E-1C813063C5A6} = {BA83D330-FECA-1BAD-3A9E-1C813063C5A6}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Synch_Benchmarks_Perf_Test", "performance-tests\Synch-Benchmarks\Perf_Test\Synch_Benchmarks_Perf_Test_vc12.vcxproj", "{3268FEB1-FECA-1BAD-A22A-C0E6EC045D12}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Synch_Benchmarks", "performance-tests\Synch-Benchmarks\Synch_Benchmarks_vc12.vcxproj", "{E8B0F000-FECA-1BAD-BF87-400DF0C83E7D}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Synch_Lib", "performance-tests\Synch-Benchmarks\Synch_Lib\Synch_Lib_vc12.vcxproj", "{BA83D330-FECA-1BAD-3A9E-1C813063C5A6}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TCP", "performance-tests\TCP\TCP_vc12.vcxproj", "{16EC56EE-FECA-1BAD-5062-8A636F3FD3CA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UDP", "performance-tests\UDP\UDP_vc12.vcxproj", "{01EC56EE-FECA-1BAD-5112-8A636F3FD2BA}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HTBP", "protocols\ace\HTBP\HTBP_vc12.vcxproj", "{17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "INet", "protocols\ace\INet\INet_vc12.vcxproj", "{92AC56A6-FECA-1BAD-F826-8A65F7EE4449}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RMCast", "protocols\ace\RMCast\RMCast_vc12.vcxproj", "{74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TMCast", "protocols\ace\TMCast\TMCast_vc12.vcxproj", "{74AC067E-FECA-1BAD-5646-8F6AEF953BB3}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FTP_Simple_exec", "protocols\examples\INet\FTP_Simple_exec_vc12.vcxproj", "{AC7EC723-FECA-1BAD-F826-8A6564C116DB}"
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449} = {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HTTP_Simple_exec", "protocols\examples\INet\HTTP_Simple_exec_vc12.vcxproj", "{AC37E723-FECA-1BAD-F826-8A6564C116DB}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Send_Msg_Receiver", "protocols\examples\RMCast\Send_Msg\Send_Msg_Receiver_vc12.vcxproj", "{453BE26F-FECA-1BAD-BA50-D9E259FB2871}"
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3} = {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Send_Msg_Sender", "protocols\examples\RMCast\Send_Msg\Send_Msg_Sender_vc12.vcxproj", "{889BA052-FECA-1BAD-BA50-D9E259FB2871}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Member", "protocols\examples\TMCast\Member\Member_vc12.vcxproj", "{52CC1DD0-FECA-1BAD-B420-8ED027BFCEB0}"
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3} = {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Tests_Client", "protocols\tests\HTBP\Reactor_Tests\Reactor_Tests_Client_vc12.vcxproj", "{3AD864B2-FECA-1BAD-1373-0D9555D094CD}"
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D} = {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Tests_Server", "protocols\tests\HTBP\Reactor_Tests\Reactor_Tests_Server_vc12.vcxproj", "{01B87438-FECA-1BAD-1373-0D9555D094CD}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Send_Large_Msg_Client", "protocols\tests\HTBP\Send_Large_Msg\Send_Large_Msg_Client_vc12.vcxproj", "{12448207-FECA-1BAD-3BEF-EB20432B4020}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Send_Large_Msg_Server", "protocols\tests\HTBP\Send_Large_Msg\Send_Large_Msg_Server_vc12.vcxproj", "{2924928D-FECA-1BAD-3BEF-EB20432B4020}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SendRecv_Test_Client", "protocols\tests\HTBP\Send_Recv_Tests\SendRecv_Test_Client_vc12.vcxproj", "{33F9D72B-FECA-1BAD-1A52-BE0C301D82A2}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SendRecv_Test_Server", "protocols\tests\HTBP\Send_Recv_Tests\SendRecv_Test_Server_vc12.vcxproj", "{0899C7A1-FECA-1BAD-1A52-BE0C301D82A2}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Ping_Client", "protocols\tests\HTBP\ping\Ping_Client_vc12.vcxproj", "{462EE341-FECA-1BAD-6F85-8A64CD2507FC}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Ping_Server", "protocols\tests\HTBP\ping\Ping_Server_vc12.vcxproj", "{7D4EF3CB-FECA-1BAD-6F85-8A64CD2507FC}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_Get", "protocols\tests\INet\MT_Get\MT_Get_vc12.vcxproj", "{02AC1EF0-FECA-1BAD-2246-8A6466E9CA6C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RMCast_Receiver", "protocols\tests\RMCast\RMCast_Receiver_vc12.vcxproj", "{536D0A83-FECA-1BAD-5646-8F0A8605F692}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RMCast_Sender", "protocols\tests\RMCast\RMCast_Sender_vc12.vcxproj", "{648DF6BA-FECA-1BAD-5646-8F0A8605F692}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_Test", "tests\ACE_Test_vc12.vcxproj", "{34E92649-FECA-1BAD-2431-8A1100722433}"
+ {40EDEECD-FECA-1BAD-2431-8A1100722433} = {40EDEECD-FECA-1BAD-2431-8A1100722433}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ARGV_Test", "tests\ARGV_Test_vc12.vcxproj", "{30EA7549-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Aio_Platform_Test", "tests\Aio_Platform_Test_vc12.vcxproj", "{52DBB423-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Arg_Shifter_Test", "tests\Arg_Shifter_Test_vc12.vcxproj", "{DBF833EC-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Array_Map_Test", "tests\Array_Map_Test_vc12.vcxproj", "{5817751D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Atomic_Op_Test", "tests\Atomic_Op_Test_vc12.vcxproj", "{8BC79560-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Auto_Event_Test", "tests\Auto_Event_Test_vc12.vcxproj", "{86ABA563-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Auto_IncDec_Test", "tests\Auto_IncDec_Test_vc12.vcxproj", "{CC9842E2-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Barrier_Test", "tests\Barrier_Test_vc12.vcxproj", "{51E3710D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Based_Pointer_Test_Lib", "tests\Based_Pointer_Test_Lib_vc12.vcxproj", "{A9C8A907-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Based_Pointer_Test", "tests\Based_Pointer_Test_vc12.vcxproj", "{EF5B40EF-FECA-1BAD-2431-8A1100722433}"
+ {A9C8A907-FECA-1BAD-2431-8A1100722433} = {A9C8A907-FECA-1BAD-2431-8A1100722433}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Basic_Types_Test", "tests\Basic_Types_Test_vc12.vcxproj", "{970E15BF-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bound_Ptr_Test", "tests\Bound_Ptr_Test_vc12.vcxproj", "{B50B25CA-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Buffer_Stream_Test", "tests\Buffer_Stream_Test_vc12.vcxproj", "{32DF2C33-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_1576_Regression_Test", "tests\Bug_1576_Regression_Test_vc12.vcxproj", "{748CBC8F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_1890_Regression_Test", "tests\Bug_1890_Regression_Test_vc12.vcxproj", "{AAECBC8F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2368_Regression_Test", "tests\Bug_2368_Regression_Test_vc12.vcxproj", "{156CBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2434_Regression_Test", "tests\Bug_2434_Regression_Test_vc12.vcxproj", "{60ACBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2497_Regression_Test", "tests\Bug_2497_Regression_Test_vc12.vcxproj", "{6A9CBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2540_Regression_Test", "tests\Bug_2540_Regression_Test_vc12.vcxproj", "{77ECBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2609_Regression_Test", "tests\Bug_2609_Regression_Test_vc12.vcxproj", "{437CBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2610_Regression_Test", "tests\Bug_2610_Regression_Test_vc12.vcxproj", "{42ECBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2653_Regression_Test", "tests\Bug_2653_Regression_Test_vc12.vcxproj", "{46DCBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2659_Regression_Test", "tests\Bug_2659_Regression_Test_vc12.vcxproj", "{467CBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2740_Regression_Test", "tests\Bug_2740_Regression_Test_vc12.vcxproj", "{57ECBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2772_Regression_Test", "tests\Bug_2772_Regression_Test_vc12.vcxproj", "{54CCBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2815_Regression_Test", "tests\Bug_2815_Regression_Test_vc12.vcxproj", "{A2BCBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2820_Regression_Test", "tests\Bug_2820_Regression_Test_vc12.vcxproj", "{A1ECBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2975_Regression_Test", "tests\Bug_2975_Regression_Test_vc12.vcxproj", "{B4BCBC8C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2980_Regression_Dll", "tests\Bug_2980_Regression_Dll_vc12.vcxproj", "{62D8584C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_2980_Regression_Test", "tests\Bug_2980_Regression_Test_vc12.vcxproj", "{BBECBC8C-FECA-1BAD-2431-8A1100722433}"
+ {62D8584C-FECA-1BAD-2431-8A1100722433} = {62D8584C-FECA-1BAD-2431-8A1100722433}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3102_Regression_Test", "tests\Bug_3102_Regression_Test_vc12.vcxproj", "{33CCBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3319_Regression_Test", "tests\Bug_3319_Regression_Test_vc12.vcxproj", "{127CBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3332_Regression_Test", "tests\Bug_3332_Regression_Test_vc12.vcxproj", "{10CCBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3334_Regression_Test", "tests\Bug_3334_Regression_Test_vc12.vcxproj", "{10ACBC8D-FECA-1BAD-2431-8A1100722433}"
+ {B213B167-FECA-1BAD-2431-8A1100722433} = {B213B167-FECA-1BAD-2431-8A1100722433}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3432_Regression_Test", "tests\Bug_3432_Regression_Test_vc12.vcxproj", "{60CCBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3500_Regression_Test", "tests\Bug_3500_Regression_Test_vc12.vcxproj", "{73ECBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3505_Regression_Test", "tests\Bug_3505_Regression_Test_vc12.vcxproj", "{73BCBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3532_Regression_Test", "tests\Bug_3532_Regression_Test_vc12.vcxproj", "{70CCBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3539_Regression_Test", "tests\Bug_3539_Regression_Test_vc12.vcxproj", "{707CBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3541_Regression_Test", "tests\Bug_3541_Regression_Test_vc12.vcxproj", "{77FCBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3673_Regression_Test", "tests\Bug_3673_Regression_Test_vc12.vcxproj", "{44DCBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3709_Regression_Test", "tests\Bug_3709_Regression_Test_vc12.vcxproj", "{537CBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3710_Regression_Test", "tests\Bug_3710_Regression_Test_vc12.vcxproj", "{52ECBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3729_Regression_Test", "tests\Bug_3729_Regression_Test_vc12.vcxproj", "{517CBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3744_Regression_Test", "tests\Bug_3744_Regression_Test_vc12.vcxproj", "{57ACBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3758_Regression_Test", "tests\Bug_3758_Regression_Test_vc12.vcxproj", "{566CBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3878_Regression_Test", "tests\Bug_3878_Regression_Test_vc12.vcxproj", "{A46CBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3911_Regression_Test", "tests\Bug_3911_Regression_Test_vc12.vcxproj", "{B2FCBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3912_Regression_Test", "tests\Bug_3912_Regression_Test_vc12.vcxproj", "{B2CCBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3943_Regression_Test", "tests\Bug_3943_Regression_Test_vc12.vcxproj", "{B7DCBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_3974_Regression_Test", "tests\Bug_3974_Regression_Test_vc12.vcxproj", "{B4ACBC8D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Bug_4055_Regression_Test", "tests\Bug_4055_Regression_Test_vc12.vcxproj", "{26BCBC8A-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "CDR_Array_Test", "tests\CDR_Array_Test_vc12.vcxproj", "{82F87D5E-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "CDR_File_Test", "tests\CDR_File_Test_vc12.vcxproj", "{4FA3F238-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "CDR_Test", "tests\CDR_Test_vc12.vcxproj", "{34EB4149-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Cache_Map_Manager_Test", "tests\Cache_Map_Manager_Test_vc12.vcxproj", "{AC665187-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Cached_Accept_Conn_Test", "tests\Cached_Accept_Conn_Test_vc12.vcxproj", "{1E46DF30-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Cached_Allocator_Test", "tests\Cached_Allocator_Test_vc12.vcxproj", "{FFFF62B4-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Cached_Conn_Test", "tests\Cached_Conn_Test_vc12.vcxproj", "{2FB0A8AA-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Capabilities_Test", "tests\Capabilities_Test_vc12.vcxproj", "{9ED51706-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Codecs_Test", "tests\Codecs_Test_vc12.vcxproj", "{6D8F104D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Collection_Test", "tests\Collection_Test_vc12.vcxproj", "{008794E3-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_01_Test", "tests\Compiler_Features_01_Test_vc12.vcxproj", "{5529F281-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_02_Test", "tests\Compiler_Features_02_Test_vc12.vcxproj", "{5529F181-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_03_Test", "tests\Compiler_Features_03_Test_vc12.vcxproj", "{5529F081-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_04_Test", "tests\Compiler_Features_04_Test_vc12.vcxproj", "{5529F781-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_05_Test", "tests\Compiler_Features_05_Test_vc12.vcxproj", "{5529F681-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_06_Test", "tests\Compiler_Features_06_Test_vc12.vcxproj", "{5529F581-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_07_Test", "tests\Compiler_Features_07_Test_vc12.vcxproj", "{5529F481-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_09_Test", "tests\Compiler_Features_09_Test_vc12.vcxproj", "{5529FA81-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_10_Test", "tests\Compiler_Features_10_Test_vc12.vcxproj", "{5529E381-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_11_Test", "tests\Compiler_Features_11_Test_vc12.vcxproj", "{5529E281-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_12_Test", "tests\Compiler_Features_12_Test_vc12.vcxproj", "{5529E181-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_13_Test", "tests\Compiler_Features_13_Test_vc12.vcxproj", "{5529E081-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_14_Test", "tests\Compiler_Features_14_Test_vc12.vcxproj", "{5529E781-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_15_Test", "tests\Compiler_Features_15_Test_vc12.vcxproj", "{5529E681-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_16_Test", "tests\Compiler_Features_16_Test_vc12.vcxproj", "{5529E581-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_17_Test", "tests\Compiler_Features_17_Test_vc12.vcxproj", "{5529E481-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_18_Test", "tests\Compiler_Features_18_Test_vc12.vcxproj", "{5529EB81-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_19_Test", "tests\Compiler_Features_19_Test_vc12.vcxproj", "{5529EA81-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_20_Test", "tests\Compiler_Features_20_Test_vc12.vcxproj", "{5529D381-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_21_Test", "tests\Compiler_Features_21_Test_vc12.vcxproj", "{5529D281-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_22_Test", "tests\Compiler_Features_22_Test_vc12.vcxproj", "{5529D181-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_23_Test", "tests\Compiler_Features_23_Test_vc12.vcxproj", "{5529D081-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_24_Test", "tests\Compiler_Features_24_Test_vc12.vcxproj", "{5529D781-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_25_Test", "tests\Compiler_Features_25_Test_vc12.vcxproj", "{5529D681-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_26_Test", "tests\Compiler_Features_26_Test_vc12.vcxproj", "{5529D581-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_27_Test", "tests\Compiler_Features_27_Test_vc12.vcxproj", "{5529D481-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_28_Test", "tests\Compiler_Features_28_Test_vc12.vcxproj", "{5529DB81-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_29_Test", "tests\Compiler_Features_29_Test_vc12.vcxproj", "{5529DA81-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_31_Test", "tests\Compiler_Features_31_Test_vc12.vcxproj", "{5529C281-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_32_Test", "tests\Compiler_Features_32_Test_vc12.vcxproj", "{5529C181-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_33_Test", "tests\Compiler_Features_33_Test_vc12.vcxproj", "{5529C081-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_34_Test", "tests\Compiler_Features_34_Test_vc12.vcxproj", "{5529C781-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Compiler_Features_35_Test", "tests\Compiler_Features_35_Test_vc12.vcxproj", "{5529C681-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Config_Test", "tests\Config_Test_vc12.vcxproj", "{6D2CA44D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Conn_Test", "tests\Conn_Test_vc12.vcxproj", "{30F5DD49-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Test_Lib", "tests\DLL_Test_Lib_vc12.vcxproj", "{366E72B0-FECA-1BAD-2431-8A1100722433}"
+ {11324DB5-FECA-1BAD-2431-8A1100722433} = {11324DB5-FECA-1BAD-2431-8A1100722433}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Test_Parent_Lib", "tests\DLL_Test_Parent_Lib_vc12.vcxproj", "{11324DB5-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL_Test", "tests\DLL_Test_vc12.vcxproj", "{34ECDF49-FECA-1BAD-2431-8A1100722433}"
+ {366E72B0-FECA-1BAD-2431-8A1100722433} = {366E72B0-FECA-1BAD-2431-8A1100722433}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLList_Test", "tests\DLList_Test_vc12.vcxproj", "{3C02174D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Date_Time_Test", "tests\Date_Time_Test_vc12.vcxproj", "{3E83A42B-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Dev_Poll_Reactor_Test", "tests\Dev_Poll_Reactor_Test_vc12.vcxproj", "{39877CCF-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Dirent_Test", "tests\Dirent_Test_vc12.vcxproj", "{1AEFC74D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Dynamic_Priority_Test", "tests\Dynamic_Priority_Test_vc12.vcxproj", "{4B5D0402-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Dynamic_Test", "tests\Dynamic_Test_vc12.vcxproj", "{CCD7A00A-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Enum_Interfaces_Test", "tests\Enum_Interfaces_Test_vc12.vcxproj", "{E7528928-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Env_Value_Test", "tests\Env_Value_Test_vc12.vcxproj", "{94D725DA-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FIFO_Test", "tests\FIFO_Test_vc12.vcxproj", "{30817C49-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Framework_Component_DLL", "tests\Framework_Component_DLL_vc12.vcxproj", "{9F3490D2-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Framework_Component_Test", "tests\Framework_Component_Test_vc12.vcxproj", "{45203561-FECA-1BAD-2431-8A1100722433}"
+ {9F3490D2-FECA-1BAD-2431-8A1100722433} = {9F3490D2-FECA-1BAD-2431-8A1100722433}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Future_Set_Test", "tests\Future_Set_Test_vc12.vcxproj", "{740D657B-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Future_Test", "tests\Future_Test_vc12.vcxproj", "{269E164D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Get_Opt_Test", "tests\Get_Opt_Test_vc12.vcxproj", "{15142708-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Handle_Set_Test", "tests\Handle_Set_Test_vc12.vcxproj", "{940D90CB-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Hash_Map_Bucket_Iterator_Test", "tests\Hash_Map_Bucket_Iterator_Test_vc12.vcxproj", "{78A7ABF8-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Hash_Map_Manager_Test", "tests\Hash_Map_Manager_Test_vc12.vcxproj", "{11661014-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Hash_Multi_Map_Manager_Test", "tests\Hash_Multi_Map_Manager_Test_vc12.vcxproj", "{863BAECD-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "High_Res_Timer_Test", "tests\High_Res_Timer_Test_vc12.vcxproj", "{794AD56B-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "INET_Addr_Test_IPV6", "tests\INET_Addr_Test_IPV6_vc12.vcxproj", "{E5AFA070-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "INET_Addr_Test", "tests\INET_Addr_Test_vc12.vcxproj", "{2FDE2CE9-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IOStream_Test", "tests\IOStream_Test_vc12.vcxproj", "{77EF2A93-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Integer_Truncate_Test", "tests\Integer_Truncate_Test_vc12.vcxproj", "{2FE80885-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Intrusive_Auto_Ptr_Test", "tests\Intrusive_Auto_Ptr_Test_vc12.vcxproj", "{3BEF931E-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Lazy_Map_Manager_Test", "tests\Lazy_Map_Manager_Test_vc12.vcxproj", "{90661054-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Library_Unload", "tests\Library_Unload_vc12.vcxproj", "{C1F0BF94-FECA-1BAD-2431-8A1100722433}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Msg_Backend_Test", "tests\Log_Msg_Backend_Test_vc12.vcxproj", "{D3C585B7-FECA-1BAD-2431-8A1100722433}"
+ ProjectSection(ProjectDependencies) = postProject
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Msg_Test", "tests\Log_Msg_Test_vc12.vcxproj", "{A6160403-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Log_Thread_Inheritance_Test", "tests\Log_Thread_Inheritance_Test_vc12.vcxproj", "{0E41A72A-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Logging_Strategy_Test", "tests\Logging_Strategy_Test_vc12.vcxproj", "{637774A3-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MEM_Stream_Test", "tests\MEM_Stream_Test_vc12.vcxproj", "{77EBBFC3-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MM_Shared_Memory_Test", "tests\MM_Shared_Memory_Test_vc12.vcxproj", "{22F24DCA-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_NonBlocking_Connect_Test", "tests\MT_NonBlocking_Connect_Test_vc12.vcxproj", "{B8480FB2-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_Reactor_Timer_Test", "tests\MT_Reactor_Timer_Test_vc12.vcxproj", "{3260374F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_Reactor_Upcall_Test", "tests\MT_Reactor_Upcall_Test_vc12.vcxproj", "{518F9F29-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_Ref_Counted_Event_Handler_Test", "tests\MT_Ref_Counted_Event_Handler_Test_vc12.vcxproj", "{4F87D6F5-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_Reference_Counted_Notify_Test", "tests\MT_Reference_Counted_Notify_Test_vc12.vcxproj", "{E6B1F61A-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MT_SOCK_Test", "tests\MT_SOCK_Test_vc12.vcxproj", "{2ED72801-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Malloc_Test", "tests\Malloc_Test_vc12.vcxproj", "{8306C04D-FECA-1BAD-2431-8A1100722433}"
+ {47BC56EF-FECA-1BAD-6757-8A6300006755} = {47BC56EF-FECA-1BAD-6757-8A6300006755}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Manual_Event_Test", "tests\Manual_Event_Test_vc12.vcxproj", "{82185430-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Map_Manager_Test", "tests\Map_Manager_Test_vc12.vcxproj", "{4C9614F2-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Map_Test", "tests\Map_Test_vc12.vcxproj", "{34E73349-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Max_Default_Port_Test_IPV6", "tests\Max_Default_Port_Test_IPV6_vc12.vcxproj", "{777203E2-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Max_Default_Port_Test", "tests\Max_Default_Port_Test_vc12.vcxproj", "{F5E705C4-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Mem_Map_Test", "tests\Mem_Map_Test_vc12.vcxproj", "{0C173302-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Memcpy_Test", "tests\Memcpy_Test_vc12.vcxproj", "{87182A4D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Block_Large_Copy_Test", "tests\Message_Block_Large_Copy_Test_vc12.vcxproj", "{EF6E83F0-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Block_Test", "tests\Message_Block_Test_vc12.vcxproj", "{CB215F59-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Queue_Notifications_Test", "tests\Message_Queue_Notifications_Test_vc12.vcxproj", "{FE3A26DB-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Queue_Test_Ex", "tests\Message_Queue_Test_Ex_vc12.vcxproj", "{C4177A7B-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Message_Queue_Test", "tests\Message_Queue_Test_vc12.vcxproj", "{D9BA3159-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Missing_Svc_Conf_Test", "tests\Missing_Svc_Conf_Test_vc12.vcxproj", "{1A0DFBB7-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Monotonic_Manual_Event_Test", "tests\Monotonic_Manual_Event_Test_vc12.vcxproj", "{54907DBB-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Monotonic_Message_Queue_Test", "tests\Monotonic_Message_Queue_Test_vc12.vcxproj", "{B138A9E4-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Monotonic_Task_Test", "tests\Monotonic_Task_Test_vc12.vcxproj", "{E70221C2-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Multicast_Test_IPV6", "tests\Multicast_Test_IPV6_vc12.vcxproj", "{FC1CE237-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Multicast_Test", "tests\Multicast_Test_vc12.vcxproj", "{1BFA5D72-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Multihomed_INET_Addr_Test_IPV6", "tests\Multihomed_INET_Addr_Test_IPV6_vc12.vcxproj", "{CA465954-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Multihomed_INET_Addr_Test", "tests\Multihomed_INET_Addr_Test_vc12.vcxproj", "{B04C6E17-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Naming_Test", "tests\Naming_Test_vc12.vcxproj", "{B313D44D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Network_Adapters_Test", "tests\Network_Adapters_Test_vc12.vcxproj", "{620AEFB9-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "New_Fail_Test", "tests\New_Fail_Test_vc12.vcxproj", "{1FABABCB-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "NonBlocking_Conn_Test", "tests\NonBlocking_Conn_Test_vc12.vcxproj", "{BB5C8438-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Notification_Queue_Unit_Test", "tests\Notification_Queue_Unit_Test_vc12.vcxproj", "{45DE2140-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Notify_Performance_Test", "tests\Notify_Performance_Test_vc12.vcxproj", "{6376AA6E-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "OS_Test", "tests\OS_Test_vc12.vcxproj", "{34A8F049-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Object_Manager_Flipping_Test", "tests\Object_Manager_Flipping_Test_vc12.vcxproj", "{18E5B4BD-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Object_Manager_Test", "tests\Object_Manager_Test_vc12.vcxproj", "{D81E30F6-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Obstack_Test", "tests\Obstack_Test_vc12.vcxproj", "{608B0800-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "OrdMultiSet_Test", "tests\OrdMultiSet_Test_vc12.vcxproj", "{862137EA-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Pipe_Test", "tests\Pipe_Test_vc12.vcxproj", "{31C23649-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Priority_Buffer_Test", "tests\Priority_Buffer_Test_vc12.vcxproj", "{282892D5-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Priority_Reactor_Test", "tests\Priority_Reactor_Test_vc12.vcxproj", "{FBA0E899-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Priority_Task_Test", "tests\Priority_Task_Test_vc12.vcxproj", "{A9C58CAA-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Scatter_Gather_Test", "tests\Proactor_Scatter_Gather_Test_vc12.vcxproj", "{3E957B1F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Test_IPV6", "tests\Proactor_Test_IPV6_vc12.vcxproj", "{68E7637F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Test", "tests\Proactor_Test_vc12.vcxproj", "{A3EED43D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_Timer_Test", "tests\Proactor_Timer_Test_vc12.vcxproj", "{E2C033CB-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Proactor_UDP_Test", "tests\Proactor_UDP_Test_vc12.vcxproj", "{B679D40B-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Env_Test", "tests\Process_Env_Test_vc12.vcxproj", "{72488C1B-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Manager_Test", "tests\Process_Manager_Test_vc12.vcxproj", "{058F37A5-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Manual_Event_Test", "tests\Process_Manual_Event_Test_vc12.vcxproj", "{E86CC114-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Mutex_Test", "tests\Process_Mutex_Test_vc12.vcxproj", "{D9C7290F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Semaphore_Test", "tests\Process_Semaphore_Test_vc12.vcxproj", "{0002E43B-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Strategy_Test", "tests\Process_Strategy_Test_vc12.vcxproj", "{E7AB357E-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Process_Test", "tests\Process_Test_vc12.vcxproj", "{7DFE101E-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RB_Tree_Test", "tests\RB_Tree_Test_vc12.vcxproj", "{4E98661F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RW_Process_Mutex_Test", "tests\RW_Process_Mutex_Test_vc12.vcxproj", "{29C72C7D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Dispatch_Order_Test_Dev_Poll", "tests\Reactor_Dispatch_Order_Test_Dev_Poll_vc12.vcxproj", "{9C98AD52-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Dispatch_Order_Test", "tests\Reactor_Dispatch_Order_Test_vc12.vcxproj", "{E1DC3B6A-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Exceptions_Test", "tests\Reactor_Exceptions_Test_vc12.vcxproj", "{6E2BAD6F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Fairness_Test", "tests\Reactor_Fairness_Test_vc12.vcxproj", "{A4066E0D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Notification_Queue_Test", "tests\Reactor_Notification_Queue_Test_vc12.vcxproj", "{B5B68289-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Notify_Test", "tests\Reactor_Notify_Test_vc12.vcxproj", "{FFF76237-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Performance_Test", "tests\Reactor_Performance_Test_vc12.vcxproj", "{F8261503-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Registration_Test", "tests\Reactor_Registration_Test_vc12.vcxproj", "{0D83A722-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Remove_Resume_Test_Dev_Poll", "tests\Reactor_Remove_Resume_Test_Dev_Poll_vc12.vcxproj", "{EF6957B4-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Remove_Resume_Test", "tests\Reactor_Remove_Resume_Test_vc12.vcxproj", "{86E324C4-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactor_Timer_Test", "tests\Reactor_Timer_Test_vc12.vcxproj", "{C26033CE-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reactors_Test", "tests\Reactors_Test_vc12.vcxproj", "{4084050A-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reader_Writer_Test", "tests\Reader_Writer_Test_vc12.vcxproj", "{64795333-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Recursive_Condition_Bug_Test", "tests\Recursive_Condition_Bug_Test_vc12.vcxproj", "{2EA41432-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Recursive_Condition_Test", "tests\Recursive_Condition_Test_vc12.vcxproj", "{44D74CF4-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Recursive_Mutex_Test", "tests\Recursive_Mutex_Test_vc12.vcxproj", "{BAAB251D-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Refcounted_Auto_Ptr_Test", "tests\Refcounted_Auto_Ptr_Test_vc12.vcxproj", "{277C4A73-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Refcounted_Event_Handler_Test_DevPoll", "tests\Refcounted_Event_Handler_Test_DevPoll_vc12.vcxproj", "{619D55B3-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reference_Counted_Event_Handler_Test", "tests\Reference_Counted_Event_Handler_Test_vc12.vcxproj", "{7B224AC2-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Reverse_Lock_Test", "tests\Reverse_Lock_Test_vc12.vcxproj", "{3A470A1C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Connector_Test", "tests\SOCK_Connector_Test_vc12.vcxproj", "{CC9064D4-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Dgram_Bcast_Test", "tests\SOCK_Dgram_Bcast_Test_vc12.vcxproj", "{FE48164A-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Dgram_Test", "tests\SOCK_Dgram_Test_vc12.vcxproj", "{86AD5537-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Netlink_Test", "tests\SOCK_Netlink_Test_vc12.vcxproj", "{1378A6F1-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_SEQPACK_SCTP_Test", "tests\SOCK_SEQPACK_SCTP_Test_vc12.vcxproj", "{34AA50A9-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Send_Recv_Test_IPV6", "tests\SOCK_Send_Recv_Test_IPV6_vc12.vcxproj", "{2C780489-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Send_Recv_Test", "tests\SOCK_Send_Recv_Test_vc12.vcxproj", "{5591B074-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Test_IPv6", "tests\SOCK_Test_IPv6_vc12.vcxproj", "{8FAE40E0-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SOCK_Test", "tests\SOCK_Test_vc12.vcxproj", "{31D72849-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SPIPE_Test", "tests\SPIPE_Test_vc12.vcxproj", "{62E01649-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SString_Test", "tests\SString_Test_vc12.vcxproj", "{77E3D41F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SV_Shared_Memory_Test", "tests\SV_Shared_Memory_Test_vc12.vcxproj", "{22F24C31-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Semaphore_Test", "tests\Semaphore_Test_vc12.vcxproj", "{52444372-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sendfile_Test", "tests\Sendfile_Test_vc12.vcxproj", "{B6A3F31A-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Config_DLL", "tests\Service_Config_DLL_vc12.vcxproj", "{F8915690-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Config_Stream_DLL", "tests\Service_Config_Stream_DLL_vc12.vcxproj", "{B213B167-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Config_Stream_Test", "tests\Service_Config_Stream_Test_vc12.vcxproj", "{97522E33-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Service_Config_Test", "tests\Service_Config_Test_vc12.vcxproj", "{3F7C5147-FECA-1BAD-2431-8A1100722433}"
+ {F8915690-FECA-1BAD-2431-8A1100722433} = {F8915690-FECA-1BAD-2431-8A1100722433}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sig_Handlers_Test", "tests\Sig_Handlers_Test_vc12.vcxproj", "{B3512BAE-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Signal_Test", "tests\Signal_Test_vc12.vcxproj", "{6BB42F4C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Sigset_Ops_Test", "tests\Sigset_Ops_Test_vc12.vcxproj", "{15117F4C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Simple_Message_Block_Test", "tests\Simple_Message_Block_Test_vc12.vcxproj", "{3E7EF9F9-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Singleton_Test", "tests\Singleton_Test_vc12.vcxproj", "{2E8E98B1-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Stack_Trace_Test", "tests\Stack_Trace_Test_vc12.vcxproj", "{97BF2117-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Svc_Handler_Test", "tests\Svc_Handler_Test_vc12.vcxproj", "{4CD277F7-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TP_Reactor_Test", "tests\TP_Reactor_Test_vc12.vcxproj", "{03EBC4ED-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TSS_Static_Test", "tests\TSS_Static_Test_vc12.vcxproj", "{76CBB623-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TSS_Test", "tests\TSS_Test_vc12.vcxproj", "{34FD3049-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Task_Ex_Test", "tests\Task_Ex_Test_vc12.vcxproj", "{51477B1B-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Task_Test", "tests\Task_Test_vc12.vcxproj", "{318A0849-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Task_Wait_Test", "tests\Task_Wait_Test_vc12.vcxproj", "{DEBBE52C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Test_Output", "tests\Test_Output_vc12.vcxproj", "{40EDEECD-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Attrs_Test", "tests\Thread_Attrs_Test_vc12.vcxproj", "{87B04338-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Creation_Threshold_Test", "tests\Thread_Creation_Threshold_Test_vc12.vcxproj", "{09C5437F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Manager_Test", "tests\Thread_Manager_Test_vc12.vcxproj", "{639E00F7-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Mutex_Test", "tests\Thread_Mutex_Test_vc12.vcxproj", "{8BA13838-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Pool_Reactor_Resume_Test", "tests\Thread_Pool_Reactor_Resume_Test_vc12.vcxproj", "{443878EA-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Pool_Reactor_Test", "tests\Thread_Pool_Reactor_Test_vc12.vcxproj", "{19D5BCDA-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Pool_Test", "tests\Thread_Pool_Test_vc12.vcxproj", "{2E973B7E-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Thread_Timer_Queue_Adapter_Test", "tests\Thread_Timer_Queue_Adapter_Test_vc12.vcxproj", "{C54B959A-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Time_Service_Test", "tests\Time_Service_Test_vc12.vcxproj", "{148CB6EC-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Time_Value_Test", "tests\Time_Value_Test_vc12.vcxproj", "{94D249F9-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timeprobe_Test", "tests\Timeprobe_Test_vc12.vcxproj", "{13E544B2-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Cancellation_Test", "tests\Timer_Cancellation_Test_vc12.vcxproj", "{E9D167C1-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Reference_Counting_Test", "tests\Timer_Queue_Reference_Counting_Test_vc12.vcxproj", "{42BEE675-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Timer_Queue_Test", "tests\Timer_Queue_Test_vc12.vcxproj", "{92CC9D6E-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Token_Strategy_Test", "tests\Token_Strategy_Test_vc12.vcxproj", "{5B5CE00F-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Tokens_Test", "tests\Tokens_Test_vc12.vcxproj", "{1D7FC04C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UPIPE_SAP_Test", "tests\UPIPE_SAP_Test_vc12.vcxproj", "{740B4305-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "UUID_Test", "tests\UUID_Test_vc12.vcxproj", "{31AD8749-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Unbounded_Set_Test", "tests\Unbounded_Set_Test_vc12.vcxproj", "{568DF4CB-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Upgradable_RW_Test", "tests\Upgradable_RW_Test_vc12.vcxproj", "{2CC6636E-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Vector_Test", "tests\Vector_Test_vc12.vcxproj", "{37EED14C-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WFMO_Reactor_Test", "tests\WFMO_Reactor_Test_vc12.vcxproj", "{06DC4BED-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Wild_Match_Test", "tests\Wild_Match_Test_vc12.vcxproj", "{8FCB14E8-FECA-1BAD-2431-8A1100722433}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "websvcs", "websvcs\lib\websvcs_vc12.vcxproj", "{14DB45BF-FECA-1BAD-6AF0-8A634041EBC7}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Websvcs_Test", "websvcs\tests\Websvcs_Test_vc12.vcxproj", "{01EC1018-FECA-1BAD-2431-8A1141F31173}"
+ {14DB45BF-FECA-1BAD-6AF0-8A634041EBC7} = {14DB45BF-FECA-1BAD-6AF0-8A634041EBC7}
+ EndProjectSection
+EndProject
+Global
+ GlobalSection(SolutionConfigurationPlatforms) = preSolution
+ Debug|Win32 = Debug|Win32
+ Debug|x64 = Debug|x64
+ Release|Win32 = Release|Win32
+ Release|x64 = Release|x64
+ EndGlobalSection
+ GlobalSection(ProjectConfigurationPlatforms) = postSolution
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Debug|Win32.ActiveCfg = Debug|Win32
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Debug|Win32.Build.0 = Debug|Win32
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Debug|x64.ActiveCfg = Debug|x64
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Debug|x64.Build.0 = Debug|x64
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Release|Win32.ActiveCfg = Release|Win32
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Release|Win32.Build.0 = Release|Win32
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Release|x64.ActiveCfg = Release|x64
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Release|x64.Build.0 = Release|x64
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|Win32.Build.0 = Debug|Win32
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|x64.ActiveCfg = Debug|x64
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|x64.Build.0 = Debug|x64
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|Win32.ActiveCfg = Release|Win32
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|Win32.Build.0 = Release|Win32
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|x64.ActiveCfg = Release|x64
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|x64.Build.0 = Release|x64
+ {E9FB1B9F-FECA-1BAD-4F93-FEB4C47D7318}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E9FB1B9F-FECA-1BAD-4F93-FEB4C47D7318}.Debug|Win32.Build.0 = Debug|Win32
+ {E9FB1B9F-FECA-1BAD-4F93-FEB4C47D7318}.Debug|x64.ActiveCfg = Debug|x64
+ {E9FB1B9F-FECA-1BAD-4F93-FEB4C47D7318}.Debug|x64.Build.0 = Debug|x64
+ {E9FB1B9F-FECA-1BAD-4F93-FEB4C47D7318}.Release|Win32.ActiveCfg = Release|Win32
+ {E9FB1B9F-FECA-1BAD-4F93-FEB4C47D7318}.Release|Win32.Build.0 = Release|Win32
+ {E9FB1B9F-FECA-1BAD-4F93-FEB4C47D7318}.Release|x64.ActiveCfg = Release|x64
+ {E9FB1B9F-FECA-1BAD-4F93-FEB4C47D7318}.Release|x64.Build.0 = Release|x64
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Debug|Win32.Build.0 = Debug|Win32
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Debug|x64.ActiveCfg = Debug|x64
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Debug|x64.Build.0 = Debug|x64
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Release|Win32.ActiveCfg = Release|Win32
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Release|Win32.Build.0 = Release|Win32
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Release|x64.ActiveCfg = Release|x64
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Release|x64.Build.0 = Release|x64
+ {15144843-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.ActiveCfg = Debug|Win32
+ {15144843-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.Build.0 = Debug|Win32
+ {15144843-FECA-1BAD-2431-8A119E86733F}.Debug|x64.ActiveCfg = Debug|x64
+ {15144843-FECA-1BAD-2431-8A119E86733F}.Debug|x64.Build.0 = Debug|x64
+ {15144843-FECA-1BAD-2431-8A119E86733F}.Release|Win32.ActiveCfg = Release|Win32
+ {15144843-FECA-1BAD-2431-8A119E86733F}.Release|Win32.Build.0 = Release|Win32
+ {15144843-FECA-1BAD-2431-8A119E86733F}.Release|x64.ActiveCfg = Release|x64
+ {15144843-FECA-1BAD-2431-8A119E86733F}.Release|x64.Build.0 = Release|x64
+ {84DB702A-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.ActiveCfg = Debug|Win32
+ {84DB702A-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.Build.0 = Debug|Win32
+ {84DB702A-FECA-1BAD-2431-8A119E86733F}.Debug|x64.ActiveCfg = Debug|x64
+ {84DB702A-FECA-1BAD-2431-8A119E86733F}.Debug|x64.Build.0 = Debug|x64
+ {84DB702A-FECA-1BAD-2431-8A119E86733F}.Release|Win32.ActiveCfg = Release|Win32
+ {84DB702A-FECA-1BAD-2431-8A119E86733F}.Release|Win32.Build.0 = Release|Win32
+ {84DB702A-FECA-1BAD-2431-8A119E86733F}.Release|x64.ActiveCfg = Release|x64
+ {84DB702A-FECA-1BAD-2431-8A119E86733F}.Release|x64.Build.0 = Release|x64
+ {A18276CA-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A18276CA-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.Build.0 = Debug|Win32
+ {A18276CA-FECA-1BAD-2431-8A119E86733F}.Debug|x64.ActiveCfg = Debug|x64
+ {A18276CA-FECA-1BAD-2431-8A119E86733F}.Debug|x64.Build.0 = Debug|x64
+ {A18276CA-FECA-1BAD-2431-8A119E86733F}.Release|Win32.ActiveCfg = Release|Win32
+ {A18276CA-FECA-1BAD-2431-8A119E86733F}.Release|Win32.Build.0 = Release|Win32
+ {A18276CA-FECA-1BAD-2431-8A119E86733F}.Release|x64.ActiveCfg = Release|x64
+ {A18276CA-FECA-1BAD-2431-8A119E86733F}.Release|x64.Build.0 = Release|x64
+ {613B4530-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.ActiveCfg = Debug|Win32
+ {613B4530-FECA-1BAD-2431-8A119E86733F}.Debug|Win32.Build.0 = Debug|Win32
+ {613B4530-FECA-1BAD-2431-8A119E86733F}.Debug|x64.ActiveCfg = Debug|x64
+ {613B4530-FECA-1BAD-2431-8A119E86733F}.Debug|x64.Build.0 = Debug|x64
+ {613B4530-FECA-1BAD-2431-8A119E86733F}.Release|Win32.ActiveCfg = Release|Win32
+ {613B4530-FECA-1BAD-2431-8A119E86733F}.Release|Win32.Build.0 = Release|Win32
+ {613B4530-FECA-1BAD-2431-8A119E86733F}.Release|x64.ActiveCfg = Release|x64
+ {613B4530-FECA-1BAD-2431-8A119E86733F}.Release|x64.Build.0 = Release|x64
+ {3F2C5699-FECA-1BAD-22FE-8A6433D1CA9B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3F2C5699-FECA-1BAD-22FE-8A6433D1CA9B}.Debug|Win32.Build.0 = Debug|Win32
+ {3F2C5699-FECA-1BAD-22FE-8A6433D1CA9B}.Debug|x64.ActiveCfg = Debug|x64
+ {3F2C5699-FECA-1BAD-22FE-8A6433D1CA9B}.Debug|x64.Build.0 = Debug|x64
+ {3F2C5699-FECA-1BAD-22FE-8A6433D1CA9B}.Release|Win32.ActiveCfg = Release|Win32
+ {3F2C5699-FECA-1BAD-22FE-8A6433D1CA9B}.Release|Win32.Build.0 = Release|Win32
+ {3F2C5699-FECA-1BAD-22FE-8A6433D1CA9B}.Release|x64.ActiveCfg = Release|x64
+ {3F2C5699-FECA-1BAD-22FE-8A6433D1CA9B}.Release|x64.Build.0 = Release|x64
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Debug|Win32.Build.0 = Debug|Win32
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Debug|x64.ActiveCfg = Debug|x64
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Debug|x64.Build.0 = Debug|x64
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Release|Win32.ActiveCfg = Release|Win32
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Release|Win32.Build.0 = Release|Win32
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Release|x64.ActiveCfg = Release|x64
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Release|x64.Build.0 = Release|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.Build.0 = Debug|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.ActiveCfg = Debug|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.Build.0 = Debug|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.ActiveCfg = Release|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.Build.0 = Release|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.ActiveCfg = Release|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.Build.0 = Release|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.Build.0 = Debug|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.ActiveCfg = Debug|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.Build.0 = Debug|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.ActiveCfg = Release|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.Build.0 = Release|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|x64.ActiveCfg = Release|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|x64.Build.0 = Release|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.Build.0 = Debug|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.ActiveCfg = Debug|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.Build.0 = Debug|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.ActiveCfg = Release|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.Build.0 = Release|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|x64.ActiveCfg = Release|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|x64.Build.0 = Release|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.Build.0 = Debug|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.ActiveCfg = Debug|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.Build.0 = Debug|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.ActiveCfg = Release|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.Build.0 = Release|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|x64.ActiveCfg = Release|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|x64.Build.0 = Release|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.Build.0 = Debug|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.ActiveCfg = Debug|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.Build.0 = Debug|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.ActiveCfg = Release|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.Build.0 = Release|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|x64.ActiveCfg = Release|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|x64.Build.0 = Release|x64
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|Win32.Build.0 = Debug|Win32
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|x64.ActiveCfg = Debug|x64
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|x64.Build.0 = Debug|x64
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|Win32.ActiveCfg = Release|Win32
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|Win32.Build.0 = Release|Win32
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|x64.ActiveCfg = Release|x64
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|x64.Build.0 = Release|x64
+ {8DCD31F0-FECA-1BAD-B9D0-9C126E572303}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8DCD31F0-FECA-1BAD-B9D0-9C126E572303}.Debug|Win32.Build.0 = Debug|Win32
+ {8DCD31F0-FECA-1BAD-B9D0-9C126E572303}.Debug|x64.ActiveCfg = Debug|x64
+ {8DCD31F0-FECA-1BAD-B9D0-9C126E572303}.Debug|x64.Build.0 = Debug|x64
+ {8DCD31F0-FECA-1BAD-B9D0-9C126E572303}.Release|Win32.ActiveCfg = Release|Win32
+ {8DCD31F0-FECA-1BAD-B9D0-9C126E572303}.Release|Win32.Build.0 = Release|Win32
+ {8DCD31F0-FECA-1BAD-B9D0-9C126E572303}.Release|x64.ActiveCfg = Release|x64
+ {8DCD31F0-FECA-1BAD-B9D0-9C126E572303}.Release|x64.Build.0 = Release|x64
+ {008C56EF-FECA-1BAD-4104-8A6369AD5684}.Debug|Win32.ActiveCfg = Debug|Win32
+ {008C56EF-FECA-1BAD-4104-8A6369AD5684}.Debug|Win32.Build.0 = Debug|Win32
+ {008C56EF-FECA-1BAD-4104-8A6369AD5684}.Debug|x64.ActiveCfg = Debug|x64
+ {008C56EF-FECA-1BAD-4104-8A6369AD5684}.Debug|x64.Build.0 = Debug|x64
+ {008C56EF-FECA-1BAD-4104-8A6369AD5684}.Release|Win32.ActiveCfg = Release|Win32
+ {008C56EF-FECA-1BAD-4104-8A6369AD5684}.Release|Win32.Build.0 = Release|Win32
+ {008C56EF-FECA-1BAD-4104-8A6369AD5684}.Release|x64.ActiveCfg = Release|x64
+ {008C56EF-FECA-1BAD-4104-8A6369AD5684}.Release|x64.Build.0 = Release|x64
+ {C21C56A9-FECA-1BAD-2D2D-8A679AD55509}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C21C56A9-FECA-1BAD-2D2D-8A679AD55509}.Debug|Win32.Build.0 = Debug|Win32
+ {C21C56A9-FECA-1BAD-2D2D-8A679AD55509}.Debug|x64.ActiveCfg = Debug|x64
+ {C21C56A9-FECA-1BAD-2D2D-8A679AD55509}.Debug|x64.Build.0 = Debug|x64
+ {C21C56A9-FECA-1BAD-2D2D-8A679AD55509}.Release|Win32.ActiveCfg = Release|Win32
+ {C21C56A9-FECA-1BAD-2D2D-8A679AD55509}.Release|Win32.Build.0 = Release|Win32
+ {C21C56A9-FECA-1BAD-2D2D-8A679AD55509}.Release|x64.ActiveCfg = Release|x64
+ {C21C56A9-FECA-1BAD-2D2D-8A679AD55509}.Release|x64.Build.0 = Release|x64
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Debug|Win32.ActiveCfg = Debug|Win32
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Debug|Win32.Build.0 = Debug|Win32
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Debug|x64.ActiveCfg = Debug|x64
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Debug|x64.Build.0 = Debug|x64
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Release|Win32.ActiveCfg = Release|Win32
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Release|Win32.Build.0 = Release|Win32
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Release|x64.ActiveCfg = Release|x64
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Release|x64.Build.0 = Release|x64
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Debug|Win32.Build.0 = Debug|Win32
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Debug|x64.ActiveCfg = Debug|x64
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Debug|x64.Build.0 = Debug|x64
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Release|Win32.ActiveCfg = Release|Win32
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Release|Win32.Build.0 = Release|Win32
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Release|x64.ActiveCfg = Release|x64
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Release|x64.Build.0 = Release|x64
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Debug|Win32.Build.0 = Debug|Win32
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Debug|x64.ActiveCfg = Debug|x64
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Debug|x64.Build.0 = Debug|x64
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Release|Win32.ActiveCfg = Release|Win32
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Release|Win32.Build.0 = Release|Win32
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Release|x64.ActiveCfg = Release|x64
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Release|x64.Build.0 = Release|x64
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.Build.0 = Debug|Win32
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Debug|x64.ActiveCfg = Debug|x64
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Debug|x64.Build.0 = Debug|x64
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Release|Win32.ActiveCfg = Release|Win32
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Release|Win32.Build.0 = Release|Win32
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Release|x64.ActiveCfg = Release|x64
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Release|x64.Build.0 = Release|x64
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.Build.0 = Debug|Win32
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Debug|x64.ActiveCfg = Debug|x64
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Debug|x64.Build.0 = Debug|x64
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Release|Win32.ActiveCfg = Release|Win32
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Release|Win32.Build.0 = Release|Win32
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Release|x64.ActiveCfg = Release|x64
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Release|x64.Build.0 = Release|x64
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Debug|Win32.Build.0 = Debug|Win32
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Debug|x64.ActiveCfg = Debug|x64
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Debug|x64.Build.0 = Debug|x64
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Release|Win32.ActiveCfg = Release|Win32
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Release|Win32.Build.0 = Release|Win32
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Release|x64.ActiveCfg = Release|x64
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Release|x64.Build.0 = Release|x64
+ {067840C9-FECA-1BAD-216B-EB0100066773}.Debug|Win32.ActiveCfg = Debug|Win32
+ {067840C9-FECA-1BAD-216B-EB0100066773}.Debug|Win32.Build.0 = Debug|Win32
+ {067840C9-FECA-1BAD-216B-EB0100066773}.Debug|x64.ActiveCfg = Debug|x64
+ {067840C9-FECA-1BAD-216B-EB0100066773}.Debug|x64.Build.0 = Debug|x64
+ {067840C9-FECA-1BAD-216B-EB0100066773}.Release|Win32.ActiveCfg = Release|Win32
+ {067840C9-FECA-1BAD-216B-EB0100066773}.Release|Win32.Build.0 = Release|Win32
+ {067840C9-FECA-1BAD-216B-EB0100066773}.Release|x64.ActiveCfg = Release|x64
+ {067840C9-FECA-1BAD-216B-EB0100066773}.Release|x64.Build.0 = Release|x64
+ {7FCD34CA-FECA-1BAD-216B-EB0100066773}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7FCD34CA-FECA-1BAD-216B-EB0100066773}.Debug|Win32.Build.0 = Debug|Win32
+ {7FCD34CA-FECA-1BAD-216B-EB0100066773}.Debug|x64.ActiveCfg = Debug|x64
+ {7FCD34CA-FECA-1BAD-216B-EB0100066773}.Debug|x64.Build.0 = Debug|x64
+ {7FCD34CA-FECA-1BAD-216B-EB0100066773}.Release|Win32.ActiveCfg = Release|Win32
+ {7FCD34CA-FECA-1BAD-216B-EB0100066773}.Release|Win32.Build.0 = Release|Win32
+ {7FCD34CA-FECA-1BAD-216B-EB0100066773}.Release|x64.ActiveCfg = Release|x64
+ {7FCD34CA-FECA-1BAD-216B-EB0100066773}.Release|x64.Build.0 = Release|x64
+ {40ED3A0C-FECA-1BAD-6320-8A6461A17566}.Debug|Win32.ActiveCfg = Debug|Win32
+ {40ED3A0C-FECA-1BAD-6320-8A6461A17566}.Debug|Win32.Build.0 = Debug|Win32
+ {40ED3A0C-FECA-1BAD-6320-8A6461A17566}.Debug|x64.ActiveCfg = Debug|x64
+ {40ED3A0C-FECA-1BAD-6320-8A6461A17566}.Debug|x64.Build.0 = Debug|x64
+ {40ED3A0C-FECA-1BAD-6320-8A6461A17566}.Release|Win32.ActiveCfg = Release|Win32
+ {40ED3A0C-FECA-1BAD-6320-8A6461A17566}.Release|Win32.Build.0 = Release|Win32
+ {40ED3A0C-FECA-1BAD-6320-8A6461A17566}.Release|x64.ActiveCfg = Release|x64
+ {40ED3A0C-FECA-1BAD-6320-8A6461A17566}.Release|x64.Build.0 = Release|x64
+ {16BA989E-FECA-1BAD-6320-8A6461A17566}.Debug|Win32.ActiveCfg = Debug|Win32
+ {16BA989E-FECA-1BAD-6320-8A6461A17566}.Debug|Win32.Build.0 = Debug|Win32
+ {16BA989E-FECA-1BAD-6320-8A6461A17566}.Debug|x64.ActiveCfg = Debug|x64
+ {16BA989E-FECA-1BAD-6320-8A6461A17566}.Debug|x64.Build.0 = Debug|x64
+ {16BA989E-FECA-1BAD-6320-8A6461A17566}.Release|Win32.ActiveCfg = Release|Win32
+ {16BA989E-FECA-1BAD-6320-8A6461A17566}.Release|Win32.Build.0 = Release|Win32
+ {16BA989E-FECA-1BAD-6320-8A6461A17566}.Release|x64.ActiveCfg = Release|x64
+ {16BA989E-FECA-1BAD-6320-8A6461A17566}.Release|x64.Build.0 = Release|x64
+ {557C3242-FECA-1BAD-945B-8C296561D98E}.Debug|Win32.ActiveCfg = Debug|Win32
+ {557C3242-FECA-1BAD-945B-8C296561D98E}.Debug|Win32.Build.0 = Debug|Win32
+ {557C3242-FECA-1BAD-945B-8C296561D98E}.Debug|x64.ActiveCfg = Debug|x64
+ {557C3242-FECA-1BAD-945B-8C296561D98E}.Debug|x64.Build.0 = Debug|x64
+ {557C3242-FECA-1BAD-945B-8C296561D98E}.Release|Win32.ActiveCfg = Release|Win32
+ {557C3242-FECA-1BAD-945B-8C296561D98E}.Release|Win32.Build.0 = Release|Win32
+ {557C3242-FECA-1BAD-945B-8C296561D98E}.Release|x64.ActiveCfg = Release|x64
+ {557C3242-FECA-1BAD-945B-8C296561D98E}.Release|x64.Build.0 = Release|x64
+ {DA99C342-FECA-1BAD-EF85-EF1657C132F1}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DA99C342-FECA-1BAD-EF85-EF1657C132F1}.Debug|Win32.Build.0 = Debug|Win32
+ {DA99C342-FECA-1BAD-EF85-EF1657C132F1}.Debug|x64.ActiveCfg = Debug|x64
+ {DA99C342-FECA-1BAD-EF85-EF1657C132F1}.Debug|x64.Build.0 = Debug|x64
+ {DA99C342-FECA-1BAD-EF85-EF1657C132F1}.Release|Win32.ActiveCfg = Release|Win32
+ {DA99C342-FECA-1BAD-EF85-EF1657C132F1}.Release|Win32.Build.0 = Release|Win32
+ {DA99C342-FECA-1BAD-EF85-EF1657C132F1}.Release|x64.ActiveCfg = Release|x64
+ {DA99C342-FECA-1BAD-EF85-EF1657C132F1}.Release|x64.Build.0 = Release|x64
+ {F6EAD3CA-FECA-1BAD-5020-8D317F23EE66}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F6EAD3CA-FECA-1BAD-5020-8D317F23EE66}.Debug|Win32.Build.0 = Debug|Win32
+ {F6EAD3CA-FECA-1BAD-5020-8D317F23EE66}.Debug|x64.ActiveCfg = Debug|x64
+ {F6EAD3CA-FECA-1BAD-5020-8D317F23EE66}.Debug|x64.Build.0 = Debug|x64
+ {F6EAD3CA-FECA-1BAD-5020-8D317F23EE66}.Release|Win32.ActiveCfg = Release|Win32
+ {F6EAD3CA-FECA-1BAD-5020-8D317F23EE66}.Release|Win32.Build.0 = Release|Win32
+ {F6EAD3CA-FECA-1BAD-5020-8D317F23EE66}.Release|x64.ActiveCfg = Release|x64
+ {F6EAD3CA-FECA-1BAD-5020-8D317F23EE66}.Release|x64.Build.0 = Release|x64
+ {52DC56A5-FECA-1BAD-5020-8D317F23EE66}.Debug|Win32.ActiveCfg = Debug|Win32
+ {52DC56A5-FECA-1BAD-5020-8D317F23EE66}.Debug|Win32.Build.0 = Debug|Win32
+ {52DC56A5-FECA-1BAD-5020-8D317F23EE66}.Debug|x64.ActiveCfg = Debug|x64
+ {52DC56A5-FECA-1BAD-5020-8D317F23EE66}.Debug|x64.Build.0 = Debug|x64
+ {52DC56A5-FECA-1BAD-5020-8D317F23EE66}.Release|Win32.ActiveCfg = Release|Win32
+ {52DC56A5-FECA-1BAD-5020-8D317F23EE66}.Release|Win32.Build.0 = Release|Win32
+ {52DC56A5-FECA-1BAD-5020-8D317F23EE66}.Release|x64.ActiveCfg = Release|x64
+ {52DC56A5-FECA-1BAD-5020-8D317F23EE66}.Release|x64.Build.0 = Release|x64
+ {05BC523A-FECA-1BAD-3377-8A0C67CCAF11}.Debug|Win32.ActiveCfg = Debug|Win32
+ {05BC523A-FECA-1BAD-3377-8A0C67CCAF11}.Debug|Win32.Build.0 = Debug|Win32
+ {05BC523A-FECA-1BAD-3377-8A0C67CCAF11}.Debug|x64.ActiveCfg = Debug|x64
+ {05BC523A-FECA-1BAD-3377-8A0C67CCAF11}.Debug|x64.Build.0 = Debug|x64
+ {05BC523A-FECA-1BAD-3377-8A0C67CCAF11}.Release|Win32.ActiveCfg = Release|Win32
+ {05BC523A-FECA-1BAD-3377-8A0C67CCAF11}.Release|Win32.Build.0 = Release|Win32
+ {05BC523A-FECA-1BAD-3377-8A0C67CCAF11}.Release|x64.ActiveCfg = Release|x64
+ {05BC523A-FECA-1BAD-3377-8A0C67CCAF11}.Release|x64.Build.0 = Release|x64
+ {30CC520F-FECA-1BAD-6000-8A0F467CFFC7}.Debug|Win32.ActiveCfg = Debug|Win32
+ {30CC520F-FECA-1BAD-6000-8A0F467CFFC7}.Debug|Win32.Build.0 = Debug|Win32
+ {30CC520F-FECA-1BAD-6000-8A0F467CFFC7}.Debug|x64.ActiveCfg = Debug|x64
+ {30CC520F-FECA-1BAD-6000-8A0F467CFFC7}.Debug|x64.Build.0 = Debug|x64
+ {30CC520F-FECA-1BAD-6000-8A0F467CFFC7}.Release|Win32.ActiveCfg = Release|Win32
+ {30CC520F-FECA-1BAD-6000-8A0F467CFFC7}.Release|Win32.Build.0 = Release|Win32
+ {30CC520F-FECA-1BAD-6000-8A0F467CFFC7}.Release|x64.ActiveCfg = Release|x64
+ {30CC520F-FECA-1BAD-6000-8A0F467CFFC7}.Release|x64.Build.0 = Release|x64
+ {50CAD380-FECA-1BAD-6001-8A0F66EDDE47}.Debug|Win32.ActiveCfg = Debug|Win32
+ {50CAD380-FECA-1BAD-6001-8A0F66EDDE47}.Debug|Win32.Build.0 = Debug|Win32
+ {50CAD380-FECA-1BAD-6001-8A0F66EDDE47}.Debug|x64.ActiveCfg = Debug|x64
+ {50CAD380-FECA-1BAD-6001-8A0F66EDDE47}.Debug|x64.Build.0 = Debug|x64
+ {50CAD380-FECA-1BAD-6001-8A0F66EDDE47}.Release|Win32.ActiveCfg = Release|Win32
+ {50CAD380-FECA-1BAD-6001-8A0F66EDDE47}.Release|Win32.Build.0 = Release|Win32
+ {50CAD380-FECA-1BAD-6001-8A0F66EDDE47}.Release|x64.ActiveCfg = Release|x64
+ {50CAD380-FECA-1BAD-6001-8A0F66EDDE47}.Release|x64.Build.0 = Release|x64
+ {30DC520F-FECA-1BAD-6001-8A0F66EDDE47}.Debug|Win32.ActiveCfg = Debug|Win32
+ {30DC520F-FECA-1BAD-6001-8A0F66EDDE47}.Debug|Win32.Build.0 = Debug|Win32
+ {30DC520F-FECA-1BAD-6001-8A0F66EDDE47}.Debug|x64.ActiveCfg = Debug|x64
+ {30DC520F-FECA-1BAD-6001-8A0F66EDDE47}.Debug|x64.Build.0 = Debug|x64
+ {30DC520F-FECA-1BAD-6001-8A0F66EDDE47}.Release|Win32.ActiveCfg = Release|Win32
+ {30DC520F-FECA-1BAD-6001-8A0F66EDDE47}.Release|Win32.Build.0 = Release|Win32
+ {30DC520F-FECA-1BAD-6001-8A0F66EDDE47}.Release|x64.ActiveCfg = Release|x64
+ {30DC520F-FECA-1BAD-6001-8A0F66EDDE47}.Release|x64.Build.0 = Release|x64
+ {3706C571-FECA-1BAD-51ED-8A0071935788}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3706C571-FECA-1BAD-51ED-8A0071935788}.Debug|Win32.Build.0 = Debug|Win32
+ {3706C571-FECA-1BAD-51ED-8A0071935788}.Debug|x64.ActiveCfg = Debug|x64
+ {3706C571-FECA-1BAD-51ED-8A0071935788}.Debug|x64.Build.0 = Debug|x64
+ {3706C571-FECA-1BAD-51ED-8A0071935788}.Release|Win32.ActiveCfg = Release|Win32
+ {3706C571-FECA-1BAD-51ED-8A0071935788}.Release|Win32.Build.0 = Release|Win32
+ {3706C571-FECA-1BAD-51ED-8A0071935788}.Release|x64.ActiveCfg = Release|x64
+ {3706C571-FECA-1BAD-51ED-8A0071935788}.Release|x64.Build.0 = Release|x64
+ {0C66D5FB-FECA-1BAD-51ED-8A0071935788}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0C66D5FB-FECA-1BAD-51ED-8A0071935788}.Debug|Win32.Build.0 = Debug|Win32
+ {0C66D5FB-FECA-1BAD-51ED-8A0071935788}.Debug|x64.ActiveCfg = Debug|x64
+ {0C66D5FB-FECA-1BAD-51ED-8A0071935788}.Debug|x64.Build.0 = Debug|x64
+ {0C66D5FB-FECA-1BAD-51ED-8A0071935788}.Release|Win32.ActiveCfg = Release|Win32
+ {0C66D5FB-FECA-1BAD-51ED-8A0071935788}.Release|Win32.Build.0 = Release|Win32
+ {0C66D5FB-FECA-1BAD-51ED-8A0071935788}.Release|x64.ActiveCfg = Release|x64
+ {0C66D5FB-FECA-1BAD-51ED-8A0071935788}.Release|x64.Build.0 = Release|x64
+ {E4BE1579-FECA-1BAD-6223-DAF371906421}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E4BE1579-FECA-1BAD-6223-DAF371906421}.Debug|Win32.Build.0 = Debug|Win32
+ {E4BE1579-FECA-1BAD-6223-DAF371906421}.Debug|x64.ActiveCfg = Debug|x64
+ {E4BE1579-FECA-1BAD-6223-DAF371906421}.Debug|x64.Build.0 = Debug|x64
+ {E4BE1579-FECA-1BAD-6223-DAF371906421}.Release|Win32.ActiveCfg = Release|Win32
+ {E4BE1579-FECA-1BAD-6223-DAF371906421}.Release|Win32.Build.0 = Release|Win32
+ {E4BE1579-FECA-1BAD-6223-DAF371906421}.Release|x64.ActiveCfg = Release|x64
+ {E4BE1579-FECA-1BAD-6223-DAF371906421}.Release|x64.Build.0 = Release|x64
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Debug|Win32.ActiveCfg = Debug|Win32
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Debug|Win32.Build.0 = Debug|Win32
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Debug|x64.ActiveCfg = Debug|x64
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Debug|x64.Build.0 = Debug|x64
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Release|Win32.ActiveCfg = Release|Win32
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Release|Win32.Build.0 = Release|Win32
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Release|x64.ActiveCfg = Release|x64
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Release|x64.Build.0 = Release|x64
+ {42CB7112-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42CB7112-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
+ {42CB7112-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
+ {42CB7112-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
+ {42CB7112-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
+ {42CB7112-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
+ {42CB7112-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
+ {42CB7112-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
+ {42AC3312-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42AC3312-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
+ {42AC3312-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
+ {42AC3312-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
+ {42AC3312-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
+ {42AC3312-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
+ {42AC3312-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
+ {42AC3312-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
+ {42C82012-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42C82012-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
+ {42C82012-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
+ {42C82012-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
+ {42C82012-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
+ {42C82012-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
+ {42C82012-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
+ {42C82012-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
+ {37CAA97E-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
+ {37CAA97E-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
+ {37CAA97E-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
+ {37CAA97E-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
+ {37CAA97E-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
+ {37CAA97E-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
+ {37CAA97E-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
+ {37CAA97E-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
+ {42AC3912-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42AC3912-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
+ {42AC3912-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
+ {42AC3912-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
+ {42AC3912-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
+ {42AC3912-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
+ {42AC3912-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
+ {42AC3912-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
+ {42AAB312-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42AAB312-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
+ {42AAB312-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
+ {42AAB312-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
+ {42AAB312-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
+ {42AAB312-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
+ {42AAB312-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
+ {42AAB312-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
+ {42AC2012-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42AC2012-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
+ {42AC2012-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
+ {42AC2012-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
+ {42AC2012-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
+ {42AC2012-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
+ {42AC2012-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
+ {42AC2012-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
+ {42DB1512-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42DB1512-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
+ {42DB1512-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
+ {42DB1512-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
+ {42DB1512-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
+ {42DB1512-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
+ {42DB1512-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
+ {42DB1512-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
+ {42DE2F12-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42DE2F12-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
+ {42DE2F12-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
+ {42DE2F12-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
+ {42DE2F12-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
+ {42DE2F12-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
+ {42DE2F12-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
+ {42DE2F12-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
+ {42AC2412-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42AC2412-FECA-1BAD-2431-8A1123F3B457}.Debug|Win32.Build.0 = Debug|Win32
+ {42AC2412-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.ActiveCfg = Debug|x64
+ {42AC2412-FECA-1BAD-2431-8A1123F3B457}.Debug|x64.Build.0 = Debug|x64
+ {42AC2412-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.ActiveCfg = Release|Win32
+ {42AC2412-FECA-1BAD-2431-8A1123F3B457}.Release|Win32.Build.0 = Release|Win32
+ {42AC2412-FECA-1BAD-2431-8A1123F3B457}.Release|x64.ActiveCfg = Release|x64
+ {42AC2412-FECA-1BAD-2431-8A1123F3B457}.Release|x64.Build.0 = Release|x64
+ {047112A8-FECA-1BAD-314B-5E27D22340B9}.Debug|Win32.ActiveCfg = Debug|Win32
+ {047112A8-FECA-1BAD-314B-5E27D22340B9}.Debug|Win32.Build.0 = Debug|Win32
+ {047112A8-FECA-1BAD-314B-5E27D22340B9}.Debug|x64.ActiveCfg = Debug|x64
+ {047112A8-FECA-1BAD-314B-5E27D22340B9}.Debug|x64.Build.0 = Debug|x64
+ {047112A8-FECA-1BAD-314B-5E27D22340B9}.Release|Win32.ActiveCfg = Release|Win32
+ {047112A8-FECA-1BAD-314B-5E27D22340B9}.Release|Win32.Build.0 = Release|Win32
+ {047112A8-FECA-1BAD-314B-5E27D22340B9}.Release|x64.ActiveCfg = Release|x64
+ {047112A8-FECA-1BAD-314B-5E27D22340B9}.Release|x64.Build.0 = Release|x64
+ {25C9D2D8-FECA-1BAD-3350-D2205825444D}.Debug|Win32.ActiveCfg = Debug|Win32
+ {25C9D2D8-FECA-1BAD-3350-D2205825444D}.Debug|Win32.Build.0 = Debug|Win32
+ {25C9D2D8-FECA-1BAD-3350-D2205825444D}.Debug|x64.ActiveCfg = Debug|x64
+ {25C9D2D8-FECA-1BAD-3350-D2205825444D}.Debug|x64.Build.0 = Debug|x64
+ {25C9D2D8-FECA-1BAD-3350-D2205825444D}.Release|Win32.ActiveCfg = Release|Win32
+ {25C9D2D8-FECA-1BAD-3350-D2205825444D}.Release|Win32.Build.0 = Release|Win32
+ {25C9D2D8-FECA-1BAD-3350-D2205825444D}.Release|x64.ActiveCfg = Release|x64
+ {25C9D2D8-FECA-1BAD-3350-D2205825444D}.Release|x64.Build.0 = Release|x64
+ {47B934A3-FECA-1BAD-A757-FC47A624E189}.Debug|Win32.ActiveCfg = Debug|Win32
+ {47B934A3-FECA-1BAD-A757-FC47A624E189}.Debug|Win32.Build.0 = Debug|Win32
+ {47B934A3-FECA-1BAD-A757-FC47A624E189}.Debug|x64.ActiveCfg = Debug|x64
+ {47B934A3-FECA-1BAD-A757-FC47A624E189}.Debug|x64.Build.0 = Debug|x64
+ {47B934A3-FECA-1BAD-A757-FC47A624E189}.Release|Win32.ActiveCfg = Release|Win32
+ {47B934A3-FECA-1BAD-A757-FC47A624E189}.Release|Win32.Build.0 = Release|Win32
+ {47B934A3-FECA-1BAD-A757-FC47A624E189}.Release|x64.ActiveCfg = Release|x64
+ {47B934A3-FECA-1BAD-A757-FC47A624E189}.Release|x64.Build.0 = Release|x64
+ {5F0C56ED-FECA-1BAD-64FC-8A63000064FE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5F0C56ED-FECA-1BAD-64FC-8A63000064FE}.Debug|Win32.Build.0 = Debug|Win32
+ {5F0C56ED-FECA-1BAD-64FC-8A63000064FE}.Debug|x64.ActiveCfg = Debug|x64
+ {5F0C56ED-FECA-1BAD-64FC-8A63000064FE}.Debug|x64.Build.0 = Debug|x64
+ {5F0C56ED-FECA-1BAD-64FC-8A63000064FE}.Release|Win32.ActiveCfg = Release|Win32
+ {5F0C56ED-FECA-1BAD-64FC-8A63000064FE}.Release|Win32.Build.0 = Release|Win32
+ {5F0C56ED-FECA-1BAD-64FC-8A63000064FE}.Release|x64.ActiveCfg = Release|x64
+ {5F0C56ED-FECA-1BAD-64FC-8A63000064FE}.Release|x64.Build.0 = Release|x64
+ {4CCC56EF-FECA-1BAD-1A31-155B449A6390}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4CCC56EF-FECA-1BAD-1A31-155B449A6390}.Debug|Win32.Build.0 = Debug|Win32
+ {4CCC56EF-FECA-1BAD-1A31-155B449A6390}.Debug|x64.ActiveCfg = Debug|x64
+ {4CCC56EF-FECA-1BAD-1A31-155B449A6390}.Debug|x64.Build.0 = Debug|x64
+ {4CCC56EF-FECA-1BAD-1A31-155B449A6390}.Release|Win32.ActiveCfg = Release|Win32
+ {4CCC56EF-FECA-1BAD-1A31-155B449A6390}.Release|Win32.Build.0 = Release|Win32
+ {4CCC56EF-FECA-1BAD-1A31-155B449A6390}.Release|x64.ActiveCfg = Release|x64
+ {4CCC56EF-FECA-1BAD-1A31-155B449A6390}.Release|x64.Build.0 = Release|x64
+ {551C56EB-FECA-1BAD-1A31-155B449A6390}.Debug|Win32.ActiveCfg = Debug|Win32
+ {551C56EB-FECA-1BAD-1A31-155B449A6390}.Debug|Win32.Build.0 = Debug|Win32
+ {551C56EB-FECA-1BAD-1A31-155B449A6390}.Debug|x64.ActiveCfg = Debug|x64
+ {551C56EB-FECA-1BAD-1A31-155B449A6390}.Debug|x64.Build.0 = Debug|x64
+ {551C56EB-FECA-1BAD-1A31-155B449A6390}.Release|Win32.ActiveCfg = Release|Win32
+ {551C56EB-FECA-1BAD-1A31-155B449A6390}.Release|Win32.Build.0 = Release|Win32
+ {551C56EB-FECA-1BAD-1A31-155B449A6390}.Release|x64.ActiveCfg = Release|x64
+ {551C56EB-FECA-1BAD-1A31-155B449A6390}.Release|x64.Build.0 = Release|x64
+ {188778D5-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.ActiveCfg = Debug|Win32
+ {188778D5-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.Build.0 = Debug|Win32
+ {188778D5-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.ActiveCfg = Debug|x64
+ {188778D5-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.Build.0 = Debug|x64
+ {188778D5-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.ActiveCfg = Release|Win32
+ {188778D5-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.Build.0 = Release|Win32
+ {188778D5-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.ActiveCfg = Release|x64
+ {188778D5-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.Build.0 = Release|x64
+ {095D6AC2-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.ActiveCfg = Debug|Win32
+ {095D6AC2-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.Build.0 = Debug|Win32
+ {095D6AC2-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.ActiveCfg = Debug|x64
+ {095D6AC2-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.Build.0 = Debug|x64
+ {095D6AC2-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.ActiveCfg = Release|Win32
+ {095D6AC2-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.Build.0 = Release|Win32
+ {095D6AC2-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.ActiveCfg = Release|x64
+ {095D6AC2-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.Build.0 = Release|x64
+ {A9242710-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A9242710-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.Build.0 = Debug|Win32
+ {A9242710-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.ActiveCfg = Debug|x64
+ {A9242710-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.Build.0 = Debug|x64
+ {A9242710-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.ActiveCfg = Release|Win32
+ {A9242710-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.Build.0 = Release|Win32
+ {A9242710-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.ActiveCfg = Release|x64
+ {A9242710-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.Build.0 = Release|x64
+ {97A844F0-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.ActiveCfg = Debug|Win32
+ {97A844F0-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|Win32.Build.0 = Debug|Win32
+ {97A844F0-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.ActiveCfg = Debug|x64
+ {97A844F0-FECA-1BAD-80F5-8C3AFDFBF954}.Debug|x64.Build.0 = Debug|x64
+ {97A844F0-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.ActiveCfg = Release|Win32
+ {97A844F0-FECA-1BAD-80F5-8C3AFDFBF954}.Release|Win32.Build.0 = Release|Win32
+ {97A844F0-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.ActiveCfg = Release|x64
+ {97A844F0-FECA-1BAD-80F5-8C3AFDFBF954}.Release|x64.Build.0 = Release|x64
+ {3CB6FFBD-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3CB6FFBD-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {3CB6FFBD-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {3CB6FFBD-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {3CB6FFBD-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {3CB6FFBD-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {3CB6FFBD-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {3CB6FFBD-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {567C528E-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {567C528E-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {567C528E-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {567C528E-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {567C528E-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {567C528E-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {567C528E-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {567C528E-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {A9C04CB6-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A9C04CB6-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {A9C04CB6-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {A9C04CB6-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {A9C04CB6-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {A9C04CB6-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {A9C04CB6-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {A9C04CB6-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {936F819E-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {936F819E-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {936F819E-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {936F819E-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {936F819E-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {936F819E-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {936F819E-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {936F819E-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {F4AC1661-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F4AC1661-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {F4AC1661-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {F4AC1661-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {F4AC1661-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {F4AC1661-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {F4AC1661-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {F4AC1661-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {28D737B3-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {28D737B3-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {28D737B3-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {28D737B3-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {28D737B3-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {28D737B3-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {28D737B3-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {28D737B3-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {8C34A592-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8C34A592-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {8C34A592-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {8C34A592-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {8C34A592-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {8C34A592-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {8C34A592-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {8C34A592-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {22DC00D9-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {22DC00D9-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {22DC00D9-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {22DC00D9-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {22DC00D9-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {22DC00D9-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {22DC00D9-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {22DC00D9-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {A53B149D-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A53B149D-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {A53B149D-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {A53B149D-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {A53B149D-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {A53B149D-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {A53B149D-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {A53B149D-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {53B93148-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {53B93148-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {53B93148-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {53B93148-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {53B93148-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {53B93148-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {53B93148-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {53B93148-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {33DC56BE-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {33DC56BE-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {33DC56BE-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {33DC56BE-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {33DC56BE-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {33DC56BE-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {33DC56BE-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {33DC56BE-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {4CDC02CC-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4CDC02CC-FECA-1BAD-8408-181CEBDC7FA8}.Debug|Win32.Build.0 = Debug|Win32
+ {4CDC02CC-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.ActiveCfg = Debug|x64
+ {4CDC02CC-FECA-1BAD-8408-181CEBDC7FA8}.Debug|x64.Build.0 = Debug|x64
+ {4CDC02CC-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.ActiveCfg = Release|Win32
+ {4CDC02CC-FECA-1BAD-8408-181CEBDC7FA8}.Release|Win32.Build.0 = Release|Win32
+ {4CDC02CC-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.ActiveCfg = Release|x64
+ {4CDC02CC-FECA-1BAD-8408-181CEBDC7FA8}.Release|x64.Build.0 = Release|x64
+ {BE1CBFB2-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BE1CBFB2-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {BE1CBFB2-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {BE1CBFB2-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {BE1CBFB2-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {BE1CBFB2-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {BE1CBFB2-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {BE1CBFB2-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {2B244654-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2B244654-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {2B244654-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {2B244654-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {2B244654-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {2B244654-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {2B244654-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {2B244654-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {39B6F240-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {39B6F240-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {39B6F240-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {39B6F240-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {39B6F240-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {39B6F240-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {39B6F240-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {39B6F240-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {B6F9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B6F9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {B6F9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {B6F9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {B6F9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {B6F9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {B6F9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {B6F9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {B6C9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B6C9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {B6C9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {B6C9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {B6C9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {B6C9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {B6C9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {B6C9094D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {735CF29B-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {735CF29B-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {735CF29B-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {735CF29B-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {735CF29B-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {735CF29B-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {735CF29B-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {735CF29B-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {439BF989-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {439BF989-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {439BF989-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {439BF989-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {439BF989-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {439BF989-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {439BF989-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {439BF989-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {35E92C1D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {35E92C1D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {35E92C1D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {35E92C1D-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {35E92C1D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {35E92C1D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {35E92C1D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {35E92C1D-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {B85FB33C-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B85FB33C-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {B85FB33C-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {B85FB33C-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {B85FB33C-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {B85FB33C-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {B85FB33C-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {B85FB33C-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {509CEC7A-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {509CEC7A-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {509CEC7A-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {509CEC7A-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {509CEC7A-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {509CEC7A-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {509CEC7A-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {509CEC7A-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {5F1E495F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5F1E495F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {5F1E495F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {5F1E495F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {5F1E495F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {5F1E495F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {5F1E495F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {5F1E495F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {F262F3C4-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F262F3C4-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {F262F3C4-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {F262F3C4-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {F262F3C4-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {F262F3C4-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {F262F3C4-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {F262F3C4-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {E0E6E68F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E0E6E68F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {E0E6E68F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {E0E6E68F-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {E0E6E68F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {E0E6E68F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {E0E6E68F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {E0E6E68F-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {0237D2DA-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0237D2DA-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {0237D2DA-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {0237D2DA-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {0237D2DA-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {0237D2DA-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {0237D2DA-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {0237D2DA-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {679CF2C9-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {679CF2C9-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {679CF2C9-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {679CF2C9-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {679CF2C9-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {679CF2C9-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {679CF2C9-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {679CF2C9-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {EBCCF20E-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EBCCF20E-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {EBCCF20E-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {EBCCF20E-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {EBCCF20E-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {EBCCF20E-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {EBCCF20E-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {EBCCF20E-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {D0DD1AE5-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D0DD1AE5-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {D0DD1AE5-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {D0DD1AE5-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {D0DD1AE5-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {D0DD1AE5-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {D0DD1AE5-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {D0DD1AE5-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {5CB9ED9A-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5CB9ED9A-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|Win32.Build.0 = Debug|Win32
+ {5CB9ED9A-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.ActiveCfg = Debug|x64
+ {5CB9ED9A-FECA-1BAD-1F85-E0F2D0B685B8}.Debug|x64.Build.0 = Debug|x64
+ {5CB9ED9A-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.ActiveCfg = Release|Win32
+ {5CB9ED9A-FECA-1BAD-1F85-E0F2D0B685B8}.Release|Win32.Build.0 = Release|Win32
+ {5CB9ED9A-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.ActiveCfg = Release|x64
+ {5CB9ED9A-FECA-1BAD-1F85-E0F2D0B685B8}.Release|x64.Build.0 = Release|x64
+ {2FF8C4DF-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2FF8C4DF-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.Build.0 = Debug|Win32
+ {2FF8C4DF-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.ActiveCfg = Debug|x64
+ {2FF8C4DF-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.Build.0 = Debug|x64
+ {2FF8C4DF-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.ActiveCfg = Release|Win32
+ {2FF8C4DF-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.Build.0 = Release|Win32
+ {2FF8C4DF-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.ActiveCfg = Release|x64
+ {2FF8C4DF-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.Build.0 = Release|x64
+ {2F0FE10F-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2F0FE10F-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.Build.0 = Debug|Win32
+ {2F0FE10F-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.ActiveCfg = Debug|x64
+ {2F0FE10F-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.Build.0 = Debug|x64
+ {2F0FE10F-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.ActiveCfg = Release|Win32
+ {2F0FE10F-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.Build.0 = Release|Win32
+ {2F0FE10F-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.ActiveCfg = Release|x64
+ {2F0FE10F-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.Build.0 = Release|x64
+ {65F66E1B-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {65F66E1B-FECA-1BAD-9E67-34351C2F1FBE}.Debug|Win32.Build.0 = Debug|Win32
+ {65F66E1B-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.ActiveCfg = Debug|x64
+ {65F66E1B-FECA-1BAD-9E67-34351C2F1FBE}.Debug|x64.Build.0 = Debug|x64
+ {65F66E1B-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.ActiveCfg = Release|Win32
+ {65F66E1B-FECA-1BAD-9E67-34351C2F1FBE}.Release|Win32.Build.0 = Release|Win32
+ {65F66E1B-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.ActiveCfg = Release|x64
+ {65F66E1B-FECA-1BAD-9E67-34351C2F1FBE}.Release|x64.Build.0 = Release|x64
+ {A7B170F6-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A7B170F6-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.Build.0 = Debug|Win32
+ {A7B170F6-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.ActiveCfg = Debug|x64
+ {A7B170F6-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.Build.0 = Debug|x64
+ {A7B170F6-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.ActiveCfg = Release|Win32
+ {A7B170F6-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.Build.0 = Release|Win32
+ {A7B170F6-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.ActiveCfg = Release|x64
+ {A7B170F6-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.Build.0 = Release|x64
+ {47647442-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.ActiveCfg = Debug|Win32
+ {47647442-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.Build.0 = Debug|Win32
+ {47647442-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.ActiveCfg = Debug|x64
+ {47647442-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.Build.0 = Debug|x64
+ {47647442-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.ActiveCfg = Release|Win32
+ {47647442-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.Build.0 = Release|Win32
+ {47647442-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.ActiveCfg = Release|x64
+ {47647442-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.Build.0 = Release|x64
+ {FFAEE1A1-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FFAEE1A1-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.Build.0 = Debug|Win32
+ {FFAEE1A1-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.ActiveCfg = Debug|x64
+ {FFAEE1A1-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.Build.0 = Debug|x64
+ {FFAEE1A1-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.ActiveCfg = Release|Win32
+ {FFAEE1A1-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.Build.0 = Release|Win32
+ {FFAEE1A1-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.ActiveCfg = Release|x64
+ {FFAEE1A1-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.Build.0 = Release|x64
+ {C69D6137-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C69D6137-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.Build.0 = Debug|Win32
+ {C69D6137-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.ActiveCfg = Debug|x64
+ {C69D6137-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.Build.0 = Debug|x64
+ {C69D6137-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.ActiveCfg = Release|Win32
+ {C69D6137-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.Build.0 = Release|Win32
+ {C69D6137-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.ActiveCfg = Release|x64
+ {C69D6137-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.Build.0 = Release|x64
+ {43A57542-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.ActiveCfg = Debug|Win32
+ {43A57542-FECA-1BAD-BF85-8CE4FD25C624}.Debug|Win32.Build.0 = Debug|Win32
+ {43A57542-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.ActiveCfg = Debug|x64
+ {43A57542-FECA-1BAD-BF85-8CE4FD25C624}.Debug|x64.Build.0 = Debug|x64
+ {43A57542-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.ActiveCfg = Release|Win32
+ {43A57542-FECA-1BAD-BF85-8CE4FD25C624}.Release|Win32.Build.0 = Release|Win32
+ {43A57542-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.ActiveCfg = Release|x64
+ {43A57542-FECA-1BAD-BF85-8CE4FD25C624}.Release|x64.Build.0 = Release|x64
+ {C87BBBBD-FECA-1BAD-4287-FEF4D6EEE17E}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C87BBBBD-FECA-1BAD-4287-FEF4D6EEE17E}.Debug|Win32.Build.0 = Debug|Win32
+ {C87BBBBD-FECA-1BAD-4287-FEF4D6EEE17E}.Debug|x64.ActiveCfg = Debug|x64
+ {C87BBBBD-FECA-1BAD-4287-FEF4D6EEE17E}.Debug|x64.Build.0 = Debug|x64
+ {C87BBBBD-FECA-1BAD-4287-FEF4D6EEE17E}.Release|Win32.ActiveCfg = Release|Win32
+ {C87BBBBD-FECA-1BAD-4287-FEF4D6EEE17E}.Release|Win32.Build.0 = Release|Win32
+ {C87BBBBD-FECA-1BAD-4287-FEF4D6EEE17E}.Release|x64.ActiveCfg = Release|x64
+ {C87BBBBD-FECA-1BAD-4287-FEF4D6EEE17E}.Release|x64.Build.0 = Release|x64
+ {605A430B-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {605A430B-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.Build.0 = Debug|Win32
+ {605A430B-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.ActiveCfg = Debug|x64
+ {605A430B-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.Build.0 = Debug|x64
+ {605A430B-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.ActiveCfg = Release|Win32
+ {605A430B-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.Build.0 = Release|Win32
+ {605A430B-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.ActiveCfg = Release|x64
+ {605A430B-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.Build.0 = Release|x64
+ {633A426E-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {633A426E-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.Build.0 = Debug|Win32
+ {633A426E-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.ActiveCfg = Debug|x64
+ {633A426E-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.Build.0 = Debug|x64
+ {633A426E-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.ActiveCfg = Release|Win32
+ {633A426E-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.Build.0 = Release|Win32
+ {633A426E-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.ActiveCfg = Release|x64
+ {633A426E-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.Build.0 = Release|x64
+ {A748383D-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A748383D-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.Build.0 = Debug|Win32
+ {A748383D-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.ActiveCfg = Debug|x64
+ {A748383D-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.Build.0 = Debug|x64
+ {A748383D-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.ActiveCfg = Release|Win32
+ {A748383D-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.Build.0 = Release|Win32
+ {A748383D-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.ActiveCfg = Release|x64
+ {A748383D-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.Build.0 = Release|x64
+ {710C53AD-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {710C53AD-FECA-1BAD-4556-C3316EC87AEE}.Debug|Win32.Build.0 = Debug|Win32
+ {710C53AD-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.ActiveCfg = Debug|x64
+ {710C53AD-FECA-1BAD-4556-C3316EC87AEE}.Debug|x64.Build.0 = Debug|x64
+ {710C53AD-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.ActiveCfg = Release|Win32
+ {710C53AD-FECA-1BAD-4556-C3316EC87AEE}.Release|Win32.Build.0 = Release|Win32
+ {710C53AD-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.ActiveCfg = Release|x64
+ {710C53AD-FECA-1BAD-4556-C3316EC87AEE}.Release|x64.Build.0 = Release|x64
+ {29AC1344-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {29AC1344-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
+ {29AC1344-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
+ {29AC1344-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
+ {29AC1344-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
+ {29AC1344-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
+ {29AC1344-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
+ {29AC1344-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
+ {619E35C9-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {619E35C9-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
+ {619E35C9-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
+ {619E35C9-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
+ {619E35C9-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
+ {619E35C9-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
+ {619E35C9-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
+ {619E35C9-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
+ {229012CD-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {229012CD-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
+ {229012CD-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
+ {229012CD-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
+ {229012CD-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
+ {229012CD-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
+ {229012CD-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
+ {229012CD-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
+ {775BA027-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {775BA027-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
+ {775BA027-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
+ {775BA027-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
+ {775BA027-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
+ {775BA027-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
+ {775BA027-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
+ {775BA027-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
+ {7E9908D8-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7E9908D8-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
+ {7E9908D8-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
+ {7E9908D8-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
+ {7E9908D8-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
+ {7E9908D8-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
+ {7E9908D8-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
+ {7E9908D8-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
+ {0679A1F3-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0679A1F3-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
+ {0679A1F3-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
+ {0679A1F3-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
+ {0679A1F3-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
+ {0679A1F3-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
+ {0679A1F3-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
+ {0679A1F3-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
+ {B80BE3C1-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B80BE3C1-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
+ {B80BE3C1-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
+ {B80BE3C1-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
+ {B80BE3C1-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
+ {B80BE3C1-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
+ {B80BE3C1-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
+ {B80BE3C1-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
+ {D6888D7E-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D6888D7E-FECA-1BAD-4280-FE54CE10D8BD}.Debug|Win32.Build.0 = Debug|Win32
+ {D6888D7E-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.ActiveCfg = Debug|x64
+ {D6888D7E-FECA-1BAD-4280-FE54CE10D8BD}.Debug|x64.Build.0 = Debug|x64
+ {D6888D7E-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.ActiveCfg = Release|Win32
+ {D6888D7E-FECA-1BAD-4280-FE54CE10D8BD}.Release|Win32.Build.0 = Release|Win32
+ {D6888D7E-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.ActiveCfg = Release|x64
+ {D6888D7E-FECA-1BAD-4280-FE54CE10D8BD}.Release|x64.Build.0 = Release|x64
+ {B9DC1D91-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B9DC1D91-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.Build.0 = Debug|Win32
+ {B9DC1D91-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.ActiveCfg = Debug|x64
+ {B9DC1D91-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.Build.0 = Debug|x64
+ {B9DC1D91-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.ActiveCfg = Release|Win32
+ {B9DC1D91-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.Build.0 = Release|Win32
+ {B9DC1D91-FECA-1BAD-5E18-93A5247C7980}.Release|x64.ActiveCfg = Release|x64
+ {B9DC1D91-FECA-1BAD-5E18-93A5247C7980}.Release|x64.Build.0 = Release|x64
+ {A6E8E560-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A6E8E560-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.Build.0 = Debug|Win32
+ {A6E8E560-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.ActiveCfg = Debug|x64
+ {A6E8E560-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.Build.0 = Debug|x64
+ {A6E8E560-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.ActiveCfg = Release|Win32
+ {A6E8E560-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.Build.0 = Release|Win32
+ {A6E8E560-FECA-1BAD-5E18-93A5247C7980}.Release|x64.ActiveCfg = Release|x64
+ {A6E8E560-FECA-1BAD-5E18-93A5247C7980}.Release|x64.Build.0 = Release|x64
+ {BC90ED91-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BC90ED91-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.Build.0 = Debug|Win32
+ {BC90ED91-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.ActiveCfg = Debug|x64
+ {BC90ED91-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.Build.0 = Debug|x64
+ {BC90ED91-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.ActiveCfg = Release|Win32
+ {BC90ED91-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.Build.0 = Release|Win32
+ {BC90ED91-FECA-1BAD-5E18-93A5247C7980}.Release|x64.ActiveCfg = Release|x64
+ {BC90ED91-FECA-1BAD-5E18-93A5247C7980}.Release|x64.Build.0 = Release|x64
+ {7BF5E6A6-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7BF5E6A6-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.Build.0 = Debug|Win32
+ {7BF5E6A6-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.ActiveCfg = Debug|x64
+ {7BF5E6A6-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.Build.0 = Debug|x64
+ {7BF5E6A6-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.ActiveCfg = Release|Win32
+ {7BF5E6A6-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.Build.0 = Release|Win32
+ {7BF5E6A6-FECA-1BAD-5E18-93A5247C7980}.Release|x64.ActiveCfg = Release|x64
+ {7BF5E6A6-FECA-1BAD-5E18-93A5247C7980}.Release|x64.Build.0 = Release|x64
+ {B949D56E-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B949D56E-FECA-1BAD-5E18-93A5247C7980}.Debug|Win32.Build.0 = Debug|Win32
+ {B949D56E-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.ActiveCfg = Debug|x64
+ {B949D56E-FECA-1BAD-5E18-93A5247C7980}.Debug|x64.Build.0 = Debug|x64
+ {B949D56E-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.ActiveCfg = Release|Win32
+ {B949D56E-FECA-1BAD-5E18-93A5247C7980}.Release|Win32.Build.0 = Release|Win32
+ {B949D56E-FECA-1BAD-5E18-93A5247C7980}.Release|x64.ActiveCfg = Release|x64
+ {B949D56E-FECA-1BAD-5E18-93A5247C7980}.Release|x64.Build.0 = Release|x64
+ {EC5361A9-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EC5361A9-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.Build.0 = Debug|Win32
+ {EC5361A9-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.ActiveCfg = Debug|x64
+ {EC5361A9-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.Build.0 = Debug|x64
+ {EC5361A9-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.ActiveCfg = Release|Win32
+ {EC5361A9-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.Build.0 = Release|Win32
+ {EC5361A9-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.ActiveCfg = Release|x64
+ {EC5361A9-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.Build.0 = Release|x64
+ {74F9A5E8-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {74F9A5E8-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.Build.0 = Debug|Win32
+ {74F9A5E8-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.ActiveCfg = Debug|x64
+ {74F9A5E8-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.Build.0 = Debug|x64
+ {74F9A5E8-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.ActiveCfg = Release|Win32
+ {74F9A5E8-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.Build.0 = Release|Win32
+ {74F9A5E8-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.ActiveCfg = Release|x64
+ {74F9A5E8-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.Build.0 = Release|x64
+ {E73FB169-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E73FB169-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.Build.0 = Debug|Win32
+ {E73FB169-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.ActiveCfg = Debug|x64
+ {E73FB169-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.Build.0 = Debug|x64
+ {E73FB169-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.ActiveCfg = Release|Win32
+ {E73FB169-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.Build.0 = Release|Win32
+ {E73FB169-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.ActiveCfg = Release|x64
+ {E73FB169-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.Build.0 = Release|x64
+ {6AE22EC4-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6AE22EC4-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.Build.0 = Debug|Win32
+ {6AE22EC4-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.ActiveCfg = Debug|x64
+ {6AE22EC4-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.Build.0 = Debug|x64
+ {6AE22EC4-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.ActiveCfg = Release|Win32
+ {6AE22EC4-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.Build.0 = Release|Win32
+ {6AE22EC4-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.ActiveCfg = Release|x64
+ {6AE22EC4-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.Build.0 = Release|x64
+ {901909D4-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {901909D4-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|Win32.Build.0 = Debug|Win32
+ {901909D4-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.ActiveCfg = Debug|x64
+ {901909D4-FECA-1BAD-87B1-FF92CFD61D8C}.Debug|x64.Build.0 = Debug|x64
+ {901909D4-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.ActiveCfg = Release|Win32
+ {901909D4-FECA-1BAD-87B1-FF92CFD61D8C}.Release|Win32.Build.0 = Release|Win32
+ {901909D4-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.ActiveCfg = Release|x64
+ {901909D4-FECA-1BAD-87B1-FF92CFD61D8C}.Release|x64.Build.0 = Release|x64
+ {C488C49F-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C488C49F-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.Build.0 = Debug|Win32
+ {C488C49F-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.ActiveCfg = Debug|x64
+ {C488C49F-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.Build.0 = Debug|x64
+ {C488C49F-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.ActiveCfg = Release|Win32
+ {C488C49F-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.Build.0 = Release|Win32
+ {C488C49F-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.ActiveCfg = Release|x64
+ {C488C49F-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.Build.0 = Release|x64
+ {12FF38F4-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {12FF38F4-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.Build.0 = Debug|Win32
+ {12FF38F4-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.ActiveCfg = Debug|x64
+ {12FF38F4-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.Build.0 = Debug|x64
+ {12FF38F4-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.ActiveCfg = Release|Win32
+ {12FF38F4-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.Build.0 = Release|Win32
+ {12FF38F4-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.ActiveCfg = Release|x64
+ {12FF38F4-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.Build.0 = Release|x64
+ {4EFF384A-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4EFF384A-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.Build.0 = Debug|Win32
+ {4EFF384A-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.ActiveCfg = Debug|x64
+ {4EFF384A-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.Build.0 = Debug|x64
+ {4EFF384A-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.ActiveCfg = Release|Win32
+ {4EFF384A-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.Build.0 = Release|Win32
+ {4EFF384A-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.ActiveCfg = Release|x64
+ {4EFF384A-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.Build.0 = Release|x64
+ {C0FAA65B-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C0FAA65B-FECA-1BAD-D231-FFF6CFB2480C}.Debug|Win32.Build.0 = Debug|Win32
+ {C0FAA65B-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.ActiveCfg = Debug|x64
+ {C0FAA65B-FECA-1BAD-D231-FFF6CFB2480C}.Debug|x64.Build.0 = Debug|x64
+ {C0FAA65B-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.ActiveCfg = Release|Win32
+ {C0FAA65B-FECA-1BAD-D231-FFF6CFB2480C}.Release|Win32.Build.0 = Release|Win32
+ {C0FAA65B-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.ActiveCfg = Release|x64
+ {C0FAA65B-FECA-1BAD-D231-FFF6CFB2480C}.Release|x64.Build.0 = Release|x64
+ {528BC2F9-FECA-1BAD-37A1-FE57CE13AD9C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {528BC2F9-FECA-1BAD-37A1-FE57CE13AD9C}.Debug|Win32.Build.0 = Debug|Win32
+ {528BC2F9-FECA-1BAD-37A1-FE57CE13AD9C}.Debug|x64.ActiveCfg = Debug|x64
+ {528BC2F9-FECA-1BAD-37A1-FE57CE13AD9C}.Debug|x64.Build.0 = Debug|x64
+ {528BC2F9-FECA-1BAD-37A1-FE57CE13AD9C}.Release|Win32.ActiveCfg = Release|Win32
+ {528BC2F9-FECA-1BAD-37A1-FE57CE13AD9C}.Release|Win32.Build.0 = Release|Win32
+ {528BC2F9-FECA-1BAD-37A1-FE57CE13AD9C}.Release|x64.ActiveCfg = Release|x64
+ {528BC2F9-FECA-1BAD-37A1-FE57CE13AD9C}.Release|x64.Build.0 = Release|x64
+ {80877026-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.ActiveCfg = Debug|Win32
+ {80877026-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.Build.0 = Debug|Win32
+ {80877026-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.ActiveCfg = Debug|x64
+ {80877026-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.Build.0 = Debug|x64
+ {80877026-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.ActiveCfg = Release|Win32
+ {80877026-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.Build.0 = Release|Win32
+ {80877026-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.ActiveCfg = Release|x64
+ {80877026-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.Build.0 = Release|x64
+ {9D29F359-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9D29F359-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.Build.0 = Debug|Win32
+ {9D29F359-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.ActiveCfg = Debug|x64
+ {9D29F359-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.Build.0 = Debug|x64
+ {9D29F359-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.ActiveCfg = Release|Win32
+ {9D29F359-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.Build.0 = Release|Win32
+ {9D29F359-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.ActiveCfg = Release|x64
+ {9D29F359-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.Build.0 = Release|x64
+ {0FAD6A96-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0FAD6A96-FECA-1BAD-87B5-E33A12FA7C15}.Debug|Win32.Build.0 = Debug|Win32
+ {0FAD6A96-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.ActiveCfg = Debug|x64
+ {0FAD6A96-FECA-1BAD-87B5-E33A12FA7C15}.Debug|x64.Build.0 = Debug|x64
+ {0FAD6A96-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.ActiveCfg = Release|Win32
+ {0FAD6A96-FECA-1BAD-87B5-E33A12FA7C15}.Release|Win32.Build.0 = Release|Win32
+ {0FAD6A96-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.ActiveCfg = Release|x64
+ {0FAD6A96-FECA-1BAD-87B5-E33A12FA7C15}.Release|x64.Build.0 = Release|x64
+ {0CAAE3D5-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0CAAE3D5-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
+ {0CAAE3D5-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
+ {0CAAE3D5-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
+ {0CAAE3D5-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
+ {0CAAE3D5-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
+ {0CAAE3D5-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
+ {0CAAE3D5-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
+ {1AA9E397-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1AA9E397-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
+ {1AA9E397-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
+ {1AA9E397-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
+ {1AA9E397-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
+ {1AA9E397-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
+ {1AA9E397-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
+ {1AA9E397-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
+ {9C2CB16D-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9C2CB16D-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
+ {9C2CB16D-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
+ {9C2CB16D-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
+ {9C2CB16D-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
+ {9C2CB16D-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
+ {9C2CB16D-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
+ {9C2CB16D-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
+ {892C56BD-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {892C56BD-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
+ {892C56BD-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
+ {892C56BD-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
+ {892C56BD-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
+ {892C56BD-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
+ {892C56BD-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
+ {892C56BD-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
+ {B593D209-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B593D209-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
+ {B593D209-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
+ {B593D209-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
+ {B593D209-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
+ {B593D209-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
+ {B593D209-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
+ {B593D209-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
+ {A099A76C-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A099A76C-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
+ {A099A76C-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
+ {A099A76C-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
+ {A099A76C-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
+ {A099A76C-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
+ {A099A76C-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
+ {A099A76C-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
+ {6BD909F3-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6BD909F3-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
+ {6BD909F3-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
+ {6BD909F3-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
+ {6BD909F3-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
+ {6BD909F3-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
+ {6BD909F3-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
+ {6BD909F3-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
+ {DD7A0755-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DD7A0755-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
+ {DD7A0755-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
+ {DD7A0755-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
+ {DD7A0755-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
+ {DD7A0755-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
+ {DD7A0755-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
+ {DD7A0755-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
+ {72BC53A9-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {72BC53A9-FECA-1BAD-B689-C9110A2960DF}.Debug|Win32.Build.0 = Debug|Win32
+ {72BC53A9-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.ActiveCfg = Debug|x64
+ {72BC53A9-FECA-1BAD-B689-C9110A2960DF}.Debug|x64.Build.0 = Debug|x64
+ {72BC53A9-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.ActiveCfg = Release|Win32
+ {72BC53A9-FECA-1BAD-B689-C9110A2960DF}.Release|Win32.Build.0 = Release|Win32
+ {72BC53A9-FECA-1BAD-B689-C9110A2960DF}.Release|x64.ActiveCfg = Release|x64
+ {72BC53A9-FECA-1BAD-B689-C9110A2960DF}.Release|x64.Build.0 = Release|x64
+ {52D844D9-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.ActiveCfg = Debug|Win32
+ {52D844D9-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.Build.0 = Debug|Win32
+ {52D844D9-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.ActiveCfg = Debug|x64
+ {52D844D9-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.Build.0 = Debug|x64
+ {52D844D9-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.ActiveCfg = Release|Win32
+ {52D844D9-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.Build.0 = Release|Win32
+ {52D844D9-FECA-1BAD-EB45-BD55AD295160}.Release|x64.ActiveCfg = Release|x64
+ {52D844D9-FECA-1BAD-EB45-BD55AD295160}.Release|x64.Build.0 = Release|x64
+ {2BD8657E-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2BD8657E-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.Build.0 = Debug|Win32
+ {2BD8657E-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.ActiveCfg = Debug|x64
+ {2BD8657E-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.Build.0 = Debug|x64
+ {2BD8657E-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.ActiveCfg = Release|Win32
+ {2BD8657E-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.Build.0 = Release|Win32
+ {2BD8657E-FECA-1BAD-EB45-BD55AD295160}.Release|x64.ActiveCfg = Release|x64
+ {2BD8657E-FECA-1BAD-EB45-BD55AD295160}.Release|x64.Build.0 = Release|x64
+ {6996159F-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6996159F-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.Build.0 = Debug|Win32
+ {6996159F-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.ActiveCfg = Debug|x64
+ {6996159F-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.Build.0 = Debug|x64
+ {6996159F-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.ActiveCfg = Release|Win32
+ {6996159F-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.Build.0 = Release|Win32
+ {6996159F-FECA-1BAD-EB45-BD55AD295160}.Release|x64.ActiveCfg = Release|x64
+ {6996159F-FECA-1BAD-EB45-BD55AD295160}.Release|x64.Build.0 = Release|x64
+ {2BDD47A3-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2BDD47A3-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.Build.0 = Debug|Win32
+ {2BDD47A3-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.ActiveCfg = Debug|x64
+ {2BDD47A3-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.Build.0 = Debug|x64
+ {2BDD47A3-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.ActiveCfg = Release|Win32
+ {2BDD47A3-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.Build.0 = Release|Win32
+ {2BDD47A3-FECA-1BAD-EB45-BD55AD295160}.Release|x64.ActiveCfg = Release|x64
+ {2BDD47A3-FECA-1BAD-EB45-BD55AD295160}.Release|x64.Build.0 = Release|x64
+ {DBD861FD-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DBD861FD-FECA-1BAD-EB45-BD55AD295160}.Debug|Win32.Build.0 = Debug|Win32
+ {DBD861FD-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.ActiveCfg = Debug|x64
+ {DBD861FD-FECA-1BAD-EB45-BD55AD295160}.Debug|x64.Build.0 = Debug|x64
+ {DBD861FD-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.ActiveCfg = Release|Win32
+ {DBD861FD-FECA-1BAD-EB45-BD55AD295160}.Release|Win32.Build.0 = Release|Win32
+ {DBD861FD-FECA-1BAD-EB45-BD55AD295160}.Release|x64.ActiveCfg = Release|x64
+ {DBD861FD-FECA-1BAD-EB45-BD55AD295160}.Release|x64.Build.0 = Release|x64
+ {AC8ECD1D-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AC8ECD1D-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
+ {AC8ECD1D-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
+ {AC8ECD1D-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
+ {AC8ECD1D-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
+ {AC8ECD1D-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
+ {AC8ECD1D-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
+ {AC8ECD1D-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
+ {E2C810BF-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E2C810BF-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
+ {E2C810BF-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
+ {E2C810BF-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
+ {E2C810BF-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
+ {E2C810BF-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
+ {E2C810BF-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
+ {E2C810BF-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
+ {326C5249-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
+ {326C5249-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
+ {326C5249-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
+ {326C5249-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
+ {326C5249-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
+ {326C5249-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
+ {326C5249-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
+ {326C5249-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
+ {85592451-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
+ {85592451-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
+ {85592451-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
+ {85592451-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
+ {85592451-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
+ {85592451-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
+ {85592451-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
+ {85592451-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
+ {91EFE085-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
+ {91EFE085-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
+ {91EFE085-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
+ {91EFE085-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
+ {91EFE085-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
+ {91EFE085-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
+ {91EFE085-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
+ {91EFE085-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
+ {06DC56EE-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
+ {06DC56EE-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
+ {06DC56EE-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
+ {06DC56EE-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
+ {06DC56EE-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
+ {06DC56EE-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
+ {06DC56EE-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
+ {06DC56EE-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
+ {13EB4812-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
+ {13EB4812-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
+ {13EB4812-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
+ {13EB4812-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
+ {13EB4812-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
+ {13EB4812-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
+ {13EB4812-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
+ {13EB4812-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
+ {29DC0476-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.ActiveCfg = Debug|Win32
+ {29DC0476-FECA-1BAD-2D78-F933D2AB8F03}.Debug|Win32.Build.0 = Debug|Win32
+ {29DC0476-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.ActiveCfg = Debug|x64
+ {29DC0476-FECA-1BAD-2D78-F933D2AB8F03}.Debug|x64.Build.0 = Debug|x64
+ {29DC0476-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.ActiveCfg = Release|Win32
+ {29DC0476-FECA-1BAD-2D78-F933D2AB8F03}.Release|Win32.Build.0 = Release|Win32
+ {29DC0476-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.ActiveCfg = Release|x64
+ {29DC0476-FECA-1BAD-2D78-F933D2AB8F03}.Release|x64.Build.0 = Release|x64
+ {72FB140B-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {72FB140B-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
+ {72FB140B-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
+ {72FB140B-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
+ {72FB140B-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
+ {72FB140B-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
+ {72FB140B-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
+ {72FB140B-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
+ {5158FB62-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5158FB62-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
+ {5158FB62-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
+ {5158FB62-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
+ {5158FB62-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
+ {5158FB62-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
+ {5158FB62-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
+ {5158FB62-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
+ {53DC16DD-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {53DC16DD-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
+ {53DC16DD-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
+ {53DC16DD-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
+ {53DC16DD-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
+ {53DC16DD-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
+ {53DC16DD-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
+ {53DC16DD-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
+ {1BCCA966-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1BCCA966-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
+ {1BCCA966-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
+ {1BCCA966-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
+ {1BCCA966-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
+ {1BCCA966-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
+ {1BCCA966-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
+ {1BCCA966-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
+ {76CD583A-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {76CD583A-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
+ {76CD583A-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
+ {76CD583A-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
+ {76CD583A-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
+ {76CD583A-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
+ {76CD583A-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
+ {76CD583A-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
+ {F2D8F4C9-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F2D8F4C9-FECA-1BAD-3731-F897C8D3AD0C}.Debug|Win32.Build.0 = Debug|Win32
+ {F2D8F4C9-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.ActiveCfg = Debug|x64
+ {F2D8F4C9-FECA-1BAD-3731-F897C8D3AD0C}.Debug|x64.Build.0 = Debug|x64
+ {F2D8F4C9-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.ActiveCfg = Release|Win32
+ {F2D8F4C9-FECA-1BAD-3731-F897C8D3AD0C}.Release|Win32.Build.0 = Release|Win32
+ {F2D8F4C9-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.ActiveCfg = Release|x64
+ {F2D8F4C9-FECA-1BAD-3731-F897C8D3AD0C}.Release|x64.Build.0 = Release|x64
+ {743C5291-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {743C5291-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.Build.0 = Debug|Win32
+ {743C5291-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.ActiveCfg = Debug|x64
+ {743C5291-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.Build.0 = Debug|x64
+ {743C5291-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.ActiveCfg = Release|Win32
+ {743C5291-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.Build.0 = Release|Win32
+ {743C5291-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.ActiveCfg = Release|x64
+ {743C5291-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.Build.0 = Release|x64
+ {755C56B9-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {755C56B9-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.Build.0 = Debug|Win32
+ {755C56B9-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.ActiveCfg = Debug|x64
+ {755C56B9-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.Build.0 = Debug|x64
+ {755C56B9-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.ActiveCfg = Release|Win32
+ {755C56B9-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.Build.0 = Release|Win32
+ {755C56B9-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.ActiveCfg = Release|x64
+ {755C56B9-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.Build.0 = Release|x64
+ {35DC0410-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {35DC0410-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.Build.0 = Debug|Win32
+ {35DC0410-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.ActiveCfg = Debug|x64
+ {35DC0410-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.Build.0 = Debug|x64
+ {35DC0410-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.ActiveCfg = Release|Win32
+ {35DC0410-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.Build.0 = Release|Win32
+ {35DC0410-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.ActiveCfg = Release|x64
+ {35DC0410-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.Build.0 = Release|x64
+ {6A2C048E-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6A2C048E-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|Win32.Build.0 = Debug|Win32
+ {6A2C048E-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.ActiveCfg = Debug|x64
+ {6A2C048E-FECA-1BAD-B251-8D4CFC8DCBF0}.Debug|x64.Build.0 = Debug|x64
+ {6A2C048E-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.ActiveCfg = Release|Win32
+ {6A2C048E-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|Win32.Build.0 = Release|Win32
+ {6A2C048E-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.ActiveCfg = Release|x64
+ {6A2C048E-FECA-1BAD-B251-8D4CFC8DCBF0}.Release|x64.Build.0 = Release|x64
+ {DBB4543C-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DBB4543C-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.Build.0 = Debug|Win32
+ {DBB4543C-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.ActiveCfg = Debug|x64
+ {DBB4543C-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.Build.0 = Debug|x64
+ {DBB4543C-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.ActiveCfg = Release|Win32
+ {DBB4543C-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.Build.0 = Release|Win32
+ {DBB4543C-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.ActiveCfg = Release|x64
+ {DBB4543C-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.Build.0 = Release|x64
+ {C843776B-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C843776B-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.Build.0 = Debug|Win32
+ {C843776B-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.ActiveCfg = Debug|x64
+ {C843776B-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.Build.0 = Debug|x64
+ {C843776B-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.ActiveCfg = Release|Win32
+ {C843776B-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.Build.0 = Release|Win32
+ {C843776B-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.ActiveCfg = Release|x64
+ {C843776B-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.Build.0 = Release|x64
+ {E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|Win32.Build.0 = Debug|Win32
+ {E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.ActiveCfg = Debug|x64
+ {E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60}.Debug|x64.Build.0 = Debug|x64
+ {E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.ActiveCfg = Release|Win32
+ {E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|Win32.Build.0 = Release|Win32
+ {E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.ActiveCfg = Release|x64
+ {E0D444B6-FECA-1BAD-F21F-3D1BDD5F2C60}.Release|x64.Build.0 = Release|x64
+ {115DF38C-FECA-1BAD-0396-8A213C52C5E6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {115DF38C-FECA-1BAD-0396-8A213C52C5E6}.Debug|Win32.Build.0 = Debug|Win32
+ {115DF38C-FECA-1BAD-0396-8A213C52C5E6}.Debug|x64.ActiveCfg = Debug|x64
+ {115DF38C-FECA-1BAD-0396-8A213C52C5E6}.Debug|x64.Build.0 = Debug|x64
+ {115DF38C-FECA-1BAD-0396-8A213C52C5E6}.Release|Win32.ActiveCfg = Release|Win32
+ {115DF38C-FECA-1BAD-0396-8A213C52C5E6}.Release|Win32.Build.0 = Release|Win32
+ {115DF38C-FECA-1BAD-0396-8A213C52C5E6}.Release|x64.ActiveCfg = Release|x64
+ {115DF38C-FECA-1BAD-0396-8A213C52C5E6}.Release|x64.Build.0 = Release|x64
+ {26B503D0-FECA-1BAD-B367-1F304733F83A}.Debug|Win32.ActiveCfg = Debug|Win32
+ {26B503D0-FECA-1BAD-B367-1F304733F83A}.Debug|Win32.Build.0 = Debug|Win32
+ {26B503D0-FECA-1BAD-B367-1F304733F83A}.Debug|x64.ActiveCfg = Debug|x64
+ {26B503D0-FECA-1BAD-B367-1F304733F83A}.Debug|x64.Build.0 = Debug|x64
+ {26B503D0-FECA-1BAD-B367-1F304733F83A}.Release|Win32.ActiveCfg = Release|Win32
+ {26B503D0-FECA-1BAD-B367-1F304733F83A}.Release|Win32.Build.0 = Release|Win32
+ {26B503D0-FECA-1BAD-B367-1F304733F83A}.Release|x64.ActiveCfg = Release|x64
+ {26B503D0-FECA-1BAD-B367-1F304733F83A}.Release|x64.Build.0 = Release|x64
+ {86DE2A45-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {86DE2A45-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.Build.0 = Debug|Win32
+ {86DE2A45-FECA-1BAD-1624-F77E007731F8}.Debug|x64.ActiveCfg = Debug|x64
+ {86DE2A45-FECA-1BAD-1624-F77E007731F8}.Debug|x64.Build.0 = Debug|x64
+ {86DE2A45-FECA-1BAD-1624-F77E007731F8}.Release|Win32.ActiveCfg = Release|Win32
+ {86DE2A45-FECA-1BAD-1624-F77E007731F8}.Release|Win32.Build.0 = Release|Win32
+ {86DE2A45-FECA-1BAD-1624-F77E007731F8}.Release|x64.ActiveCfg = Release|x64
+ {86DE2A45-FECA-1BAD-1624-F77E007731F8}.Release|x64.Build.0 = Release|x64
+ {F679CE5D-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F679CE5D-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.Build.0 = Debug|Win32
+ {F679CE5D-FECA-1BAD-1624-F77E007731F8}.Debug|x64.ActiveCfg = Debug|x64
+ {F679CE5D-FECA-1BAD-1624-F77E007731F8}.Debug|x64.Build.0 = Debug|x64
+ {F679CE5D-FECA-1BAD-1624-F77E007731F8}.Release|Win32.ActiveCfg = Release|Win32
+ {F679CE5D-FECA-1BAD-1624-F77E007731F8}.Release|Win32.Build.0 = Release|Win32
+ {F679CE5D-FECA-1BAD-1624-F77E007731F8}.Release|x64.ActiveCfg = Release|x64
+ {F679CE5D-FECA-1BAD-1624-F77E007731F8}.Release|x64.Build.0 = Release|x64
+ {3ECD46F2-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3ECD46F2-FECA-1BAD-1624-F77E007731F8}.Debug|Win32.Build.0 = Debug|Win32
+ {3ECD46F2-FECA-1BAD-1624-F77E007731F8}.Debug|x64.ActiveCfg = Debug|x64
+ {3ECD46F2-FECA-1BAD-1624-F77E007731F8}.Debug|x64.Build.0 = Debug|x64
+ {3ECD46F2-FECA-1BAD-1624-F77E007731F8}.Release|Win32.ActiveCfg = Release|Win32
+ {3ECD46F2-FECA-1BAD-1624-F77E007731F8}.Release|Win32.Build.0 = Release|Win32
+ {3ECD46F2-FECA-1BAD-1624-F77E007731F8}.Release|x64.ActiveCfg = Release|x64
+ {3ECD46F2-FECA-1BAD-1624-F77E007731F8}.Release|x64.Build.0 = Release|x64
+ {4111B37C-FECA-1BAD-53DA-CAD1A7F87CBD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4111B37C-FECA-1BAD-53DA-CAD1A7F87CBD}.Debug|Win32.Build.0 = Debug|Win32
+ {4111B37C-FECA-1BAD-53DA-CAD1A7F87CBD}.Debug|x64.ActiveCfg = Debug|x64
+ {4111B37C-FECA-1BAD-53DA-CAD1A7F87CBD}.Debug|x64.Build.0 = Debug|x64
+ {4111B37C-FECA-1BAD-53DA-CAD1A7F87CBD}.Release|Win32.ActiveCfg = Release|Win32
+ {4111B37C-FECA-1BAD-53DA-CAD1A7F87CBD}.Release|Win32.Build.0 = Release|Win32
+ {4111B37C-FECA-1BAD-53DA-CAD1A7F87CBD}.Release|x64.ActiveCfg = Release|x64
+ {4111B37C-FECA-1BAD-53DA-CAD1A7F87CBD}.Release|x64.Build.0 = Release|x64
+ {402C7D4A-FECA-1BAD-150E-88D9A0C7F2AA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {402C7D4A-FECA-1BAD-150E-88D9A0C7F2AA}.Debug|Win32.Build.0 = Debug|Win32
+ {402C7D4A-FECA-1BAD-150E-88D9A0C7F2AA}.Debug|x64.ActiveCfg = Debug|x64
+ {402C7D4A-FECA-1BAD-150E-88D9A0C7F2AA}.Debug|x64.Build.0 = Debug|x64
+ {402C7D4A-FECA-1BAD-150E-88D9A0C7F2AA}.Release|Win32.ActiveCfg = Release|Win32
+ {402C7D4A-FECA-1BAD-150E-88D9A0C7F2AA}.Release|Win32.Build.0 = Release|Win32
+ {402C7D4A-FECA-1BAD-150E-88D9A0C7F2AA}.Release|x64.ActiveCfg = Release|x64
+ {402C7D4A-FECA-1BAD-150E-88D9A0C7F2AA}.Release|x64.Build.0 = Release|x64
+ {77B1F4AE-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
+ {77B1F4AE-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
+ {77B1F4AE-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
+ {77B1F4AE-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
+ {77B1F4AE-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
+ {77B1F4AE-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
+ {77B1F4AE-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
+ {77B1F4AE-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
+ {817A184A-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
+ {817A184A-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
+ {817A184A-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
+ {817A184A-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
+ {817A184A-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
+ {817A184A-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
+ {817A184A-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
+ {817A184A-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
+ {E997FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E997FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
+ {E997FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
+ {E997FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
+ {E997FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
+ {E997FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
+ {E997FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
+ {E997FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
+ {83BF1DB9-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
+ {83BF1DB9-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
+ {83BF1DB9-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
+ {83BF1DB9-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
+ {83BF1DB9-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
+ {83BF1DB9-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
+ {83BF1DB9-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
+ {83BF1DB9-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
+ {663FE280-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
+ {663FE280-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
+ {663FE280-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
+ {663FE280-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
+ {663FE280-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
+ {663FE280-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
+ {663FE280-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
+ {663FE280-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
+ {560013D0-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
+ {560013D0-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
+ {560013D0-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
+ {560013D0-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
+ {560013D0-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
+ {560013D0-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
+ {560013D0-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
+ {560013D0-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
+ {ED97FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.ActiveCfg = Debug|Win32
+ {ED97FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|Win32.Build.0 = Debug|Win32
+ {ED97FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.ActiveCfg = Debug|x64
+ {ED97FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Debug|x64.Build.0 = Debug|x64
+ {ED97FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.ActiveCfg = Release|Win32
+ {ED97FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Release|Win32.Build.0 = Release|Win32
+ {ED97FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.ActiveCfg = Release|x64
+ {ED97FE0B-FECA-1BAD-B753-CBFC9FE5DD76}.Release|x64.Build.0 = Release|x64
+ {71572394-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {71572394-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {71572394-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {71572394-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {71572394-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {71572394-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {71572394-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {71572394-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {2D05C715-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2D05C715-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {2D05C715-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {2D05C715-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {2D05C715-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {2D05C715-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {2D05C715-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {2D05C715-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {3908C846-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3908C846-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {3908C846-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {3908C846-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {3908C846-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {3908C846-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {3908C846-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {3908C846-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {4DF6061E-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4DF6061E-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {4DF6061E-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {4DF6061E-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {4DF6061E-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {4DF6061E-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {4DF6061E-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {4DF6061E-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {71572395-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {71572395-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {71572395-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {71572395-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {71572395-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {71572395-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {71572395-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {71572395-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {C919288A-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C919288A-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {C919288A-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {C919288A-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {C919288A-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {C919288A-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {C919288A-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {C919288A-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {BF9E69B9-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BF9E69B9-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {BF9E69B9-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {BF9E69B9-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {BF9E69B9-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {BF9E69B9-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {BF9E69B9-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {BF9E69B9-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {7223E97D-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7223E97D-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {7223E97D-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {7223E97D-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {7223E97D-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {7223E97D-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {7223E97D-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {7223E97D-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {C66B010B-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C66B010B-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {C66B010B-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {C66B010B-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {C66B010B-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {C66B010B-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {C66B010B-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {C66B010B-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {F71CCF45-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F71CCF45-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {F71CCF45-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {F71CCF45-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {F71CCF45-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {F71CCF45-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {F71CCF45-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {F71CCF45-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {79179A28-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.ActiveCfg = Debug|Win32
+ {79179A28-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|Win32.Build.0 = Debug|Win32
+ {79179A28-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.ActiveCfg = Debug|x64
+ {79179A28-FECA-1BAD-B750-CBFC9FE5DD75}.Debug|x64.Build.0 = Debug|x64
+ {79179A28-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.ActiveCfg = Release|Win32
+ {79179A28-FECA-1BAD-B750-CBFC9FE5DD75}.Release|Win32.Build.0 = Release|Win32
+ {79179A28-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.ActiveCfg = Release|x64
+ {79179A28-FECA-1BAD-B750-CBFC9FE5DD75}.Release|x64.Build.0 = Release|x64
+ {99B2D4AF-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|Win32.ActiveCfg = Debug|Win32
+ {99B2D4AF-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|Win32.Build.0 = Debug|Win32
+ {99B2D4AF-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|x64.ActiveCfg = Debug|x64
+ {99B2D4AF-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|x64.Build.0 = Debug|x64
+ {99B2D4AF-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|Win32.ActiveCfg = Release|Win32
+ {99B2D4AF-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|Win32.Build.0 = Release|Win32
+ {99B2D4AF-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|x64.ActiveCfg = Release|x64
+ {99B2D4AF-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|x64.Build.0 = Release|x64
+ {2F08A8E5-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2F08A8E5-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|Win32.Build.0 = Debug|Win32
+ {2F08A8E5-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|x64.ActiveCfg = Debug|x64
+ {2F08A8E5-FECA-1BAD-63A6-43B4A3F0BDAC}.Debug|x64.Build.0 = Debug|x64
+ {2F08A8E5-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|Win32.ActiveCfg = Release|Win32
+ {2F08A8E5-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|Win32.Build.0 = Release|Win32
+ {2F08A8E5-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|x64.ActiveCfg = Release|x64
+ {2F08A8E5-FECA-1BAD-63A6-43B4A3F0BDAC}.Release|x64.Build.0 = Release|x64
+ {638C735A-FECA-1BAD-3D13-3640622B5736}.Debug|Win32.ActiveCfg = Debug|Win32
+ {638C735A-FECA-1BAD-3D13-3640622B5736}.Debug|Win32.Build.0 = Debug|Win32
+ {638C735A-FECA-1BAD-3D13-3640622B5736}.Debug|x64.ActiveCfg = Debug|x64
+ {638C735A-FECA-1BAD-3D13-3640622B5736}.Debug|x64.Build.0 = Debug|x64
+ {638C735A-FECA-1BAD-3D13-3640622B5736}.Release|Win32.ActiveCfg = Release|Win32
+ {638C735A-FECA-1BAD-3D13-3640622B5736}.Release|Win32.Build.0 = Release|Win32
+ {638C735A-FECA-1BAD-3D13-3640622B5736}.Release|x64.ActiveCfg = Release|x64
+ {638C735A-FECA-1BAD-3D13-3640622B5736}.Release|x64.Build.0 = Release|x64
+ {E8BB71D9-FECA-1BAD-3D13-3640622B5736}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E8BB71D9-FECA-1BAD-3D13-3640622B5736}.Debug|Win32.Build.0 = Debug|Win32
+ {E8BB71D9-FECA-1BAD-3D13-3640622B5736}.Debug|x64.ActiveCfg = Debug|x64
+ {E8BB71D9-FECA-1BAD-3D13-3640622B5736}.Debug|x64.Build.0 = Debug|x64
+ {E8BB71D9-FECA-1BAD-3D13-3640622B5736}.Release|Win32.ActiveCfg = Release|Win32
+ {E8BB71D9-FECA-1BAD-3D13-3640622B5736}.Release|Win32.Build.0 = Release|Win32
+ {E8BB71D9-FECA-1BAD-3D13-3640622B5736}.Release|x64.ActiveCfg = Release|x64
+ {E8BB71D9-FECA-1BAD-3D13-3640622B5736}.Release|x64.Build.0 = Release|x64
+ {D754F4F0-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D754F4F0-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
+ {D754F4F0-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
+ {D754F4F0-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
+ {D754F4F0-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
+ {D754F4F0-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
+ {D754F4F0-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
+ {D754F4F0-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
+ {EC34E47A-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EC34E47A-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
+ {EC34E47A-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
+ {EC34E47A-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
+ {EC34E47A-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
+ {EC34E47A-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
+ {EC34E47A-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
+ {EC34E47A-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
+ {242714F1-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {242714F1-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
+ {242714F1-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
+ {242714F1-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
+ {242714F1-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
+ {242714F1-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
+ {242714F1-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
+ {242714F1-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
+ {1F47047B-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1F47047B-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
+ {1F47047B-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
+ {1F47047B-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
+ {1F47047B-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
+ {1F47047B-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
+ {1F47047B-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
+ {1F47047B-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
+ {7A8F763F-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7A8F763F-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
+ {7A8F763F-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
+ {7A8F763F-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
+ {7A8F763F-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
+ {7A8F763F-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
+ {7A8F763F-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
+ {7A8F763F-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
+ {41EF66B5-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {41EF66B5-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
+ {41EF66B5-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
+ {41EF66B5-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
+ {41EF66B5-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
+ {41EF66B5-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
+ {41EF66B5-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
+ {41EF66B5-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
+ {9CCFEE13-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9CCFEE13-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
+ {9CCFEE13-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
+ {9CCFEE13-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
+ {9CCFEE13-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
+ {9CCFEE13-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
+ {9CCFEE13-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
+ {9CCFEE13-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
+ {A7AFFE99-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A7AFFE99-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|Win32.Build.0 = Debug|Win32
+ {A7AFFE99-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.ActiveCfg = Debug|x64
+ {A7AFFE99-FECA-1BAD-D57C-7CD528BEBF5B}.Debug|x64.Build.0 = Debug|x64
+ {A7AFFE99-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.ActiveCfg = Release|Win32
+ {A7AFFE99-FECA-1BAD-D57C-7CD528BEBF5B}.Release|Win32.Build.0 = Release|Win32
+ {A7AFFE99-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.ActiveCfg = Release|x64
+ {A7AFFE99-FECA-1BAD-D57C-7CD528BEBF5B}.Release|x64.Build.0 = Release|x64
+ {6F4CDF50-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6F4CDF50-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.Build.0 = Debug|Win32
+ {6F4CDF50-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.ActiveCfg = Debug|x64
+ {6F4CDF50-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.Build.0 = Debug|x64
+ {6F4CDF50-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.ActiveCfg = Release|Win32
+ {6F4CDF50-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.Build.0 = Release|Win32
+ {6F4CDF50-FECA-1BAD-408E-8A636A279EF6}.Release|x64.ActiveCfg = Release|x64
+ {6F4CDF50-FECA-1BAD-408E-8A636A279EF6}.Release|x64.Build.0 = Release|x64
+ {AAE476EA-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AAE476EA-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.Build.0 = Debug|Win32
+ {AAE476EA-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.ActiveCfg = Debug|x64
+ {AAE476EA-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.Build.0 = Debug|x64
+ {AAE476EA-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.ActiveCfg = Release|Win32
+ {AAE476EA-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.Build.0 = Release|Win32
+ {AAE476EA-FECA-1BAD-408E-8A636A279EF6}.Release|x64.ActiveCfg = Release|x64
+ {AAE476EA-FECA-1BAD-408E-8A636A279EF6}.Release|x64.Build.0 = Release|x64
+ {3274CCC2-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3274CCC2-FECA-1BAD-408E-8A636A279EF6}.Debug|Win32.Build.0 = Debug|Win32
+ {3274CCC2-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.ActiveCfg = Debug|x64
+ {3274CCC2-FECA-1BAD-408E-8A636A279EF6}.Debug|x64.Build.0 = Debug|x64
+ {3274CCC2-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.ActiveCfg = Release|Win32
+ {3274CCC2-FECA-1BAD-408E-8A636A279EF6}.Release|Win32.Build.0 = Release|Win32
+ {3274CCC2-FECA-1BAD-408E-8A636A279EF6}.Release|x64.ActiveCfg = Release|x64
+ {3274CCC2-FECA-1BAD-408E-8A636A279EF6}.Release|x64.Build.0 = Release|x64
+ {FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|Win32.Build.0 = Debug|Win32
+ {FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|x64.ActiveCfg = Debug|x64
+ {FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|x64.Build.0 = Debug|x64
+ {FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6}.Release|Win32.ActiveCfg = Release|Win32
+ {FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6}.Release|Win32.Build.0 = Release|Win32
+ {FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6}.Release|x64.ActiveCfg = Release|x64
+ {FD3AD3F0-FECA-1BAD-6856-8E4C79C8CEF6}.Release|x64.Build.0 = Release|x64
+ {1BC4074D-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1BC4074D-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|Win32.Build.0 = Debug|Win32
+ {1BC4074D-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|x64.ActiveCfg = Debug|x64
+ {1BC4074D-FECA-1BAD-6856-8E4C79C8CEF6}.Debug|x64.Build.0 = Debug|x64
+ {1BC4074D-FECA-1BAD-6856-8E4C79C8CEF6}.Release|Win32.ActiveCfg = Release|Win32
+ {1BC4074D-FECA-1BAD-6856-8E4C79C8CEF6}.Release|Win32.Build.0 = Release|Win32
+ {1BC4074D-FECA-1BAD-6856-8E4C79C8CEF6}.Release|x64.ActiveCfg = Release|x64
+ {1BC4074D-FECA-1BAD-6856-8E4C79C8CEF6}.Release|x64.Build.0 = Release|x64
+ {6AD03907-FECA-1BAD-C7A1-4C9D6A84AD84}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6AD03907-FECA-1BAD-C7A1-4C9D6A84AD84}.Debug|Win32.Build.0 = Debug|Win32
+ {6AD03907-FECA-1BAD-C7A1-4C9D6A84AD84}.Debug|x64.ActiveCfg = Debug|x64
+ {6AD03907-FECA-1BAD-C7A1-4C9D6A84AD84}.Debug|x64.Build.0 = Debug|x64
+ {6AD03907-FECA-1BAD-C7A1-4C9D6A84AD84}.Release|Win32.ActiveCfg = Release|Win32
+ {6AD03907-FECA-1BAD-C7A1-4C9D6A84AD84}.Release|Win32.Build.0 = Release|Win32
+ {6AD03907-FECA-1BAD-C7A1-4C9D6A84AD84}.Release|x64.ActiveCfg = Release|x64
+ {6AD03907-FECA-1BAD-C7A1-4C9D6A84AD84}.Release|x64.Build.0 = Release|x64
+ {51B0298D-FECA-1BAD-6417-4D956B8C0E32}.Debug|Win32.ActiveCfg = Debug|Win32
+ {51B0298D-FECA-1BAD-6417-4D956B8C0E32}.Debug|Win32.Build.0 = Debug|Win32
+ {51B0298D-FECA-1BAD-6417-4D956B8C0E32}.Debug|x64.ActiveCfg = Debug|x64
+ {51B0298D-FECA-1BAD-6417-4D956B8C0E32}.Debug|x64.Build.0 = Debug|x64
+ {51B0298D-FECA-1BAD-6417-4D956B8C0E32}.Release|Win32.ActiveCfg = Release|Win32
+ {51B0298D-FECA-1BAD-6417-4D956B8C0E32}.Release|Win32.Build.0 = Release|Win32
+ {51B0298D-FECA-1BAD-6417-4D956B8C0E32}.Release|x64.ActiveCfg = Release|x64
+ {51B0298D-FECA-1BAD-6417-4D956B8C0E32}.Release|x64.Build.0 = Release|x64
+ {ACC9A56C-FECA-1BAD-8562-EC4B26346A25}.Debug|Win32.ActiveCfg = Debug|Win32
+ {ACC9A56C-FECA-1BAD-8562-EC4B26346A25}.Debug|Win32.Build.0 = Debug|Win32
+ {ACC9A56C-FECA-1BAD-8562-EC4B26346A25}.Debug|x64.ActiveCfg = Debug|x64
+ {ACC9A56C-FECA-1BAD-8562-EC4B26346A25}.Debug|x64.Build.0 = Debug|x64
+ {ACC9A56C-FECA-1BAD-8562-EC4B26346A25}.Release|Win32.ActiveCfg = Release|Win32
+ {ACC9A56C-FECA-1BAD-8562-EC4B26346A25}.Release|Win32.Build.0 = Release|Win32
+ {ACC9A56C-FECA-1BAD-8562-EC4B26346A25}.Release|x64.ActiveCfg = Release|x64
+ {ACC9A56C-FECA-1BAD-8562-EC4B26346A25}.Release|x64.Build.0 = Release|x64
+ {97A9B5E6-FECA-1BAD-8562-EC4B26346A25}.Debug|Win32.ActiveCfg = Debug|Win32
+ {97A9B5E6-FECA-1BAD-8562-EC4B26346A25}.Debug|Win32.Build.0 = Debug|Win32
+ {97A9B5E6-FECA-1BAD-8562-EC4B26346A25}.Debug|x64.ActiveCfg = Debug|x64
+ {97A9B5E6-FECA-1BAD-8562-EC4B26346A25}.Debug|x64.Build.0 = Debug|x64
+ {97A9B5E6-FECA-1BAD-8562-EC4B26346A25}.Release|Win32.ActiveCfg = Release|Win32
+ {97A9B5E6-FECA-1BAD-8562-EC4B26346A25}.Release|Win32.Build.0 = Release|Win32
+ {97A9B5E6-FECA-1BAD-8562-EC4B26346A25}.Release|x64.ActiveCfg = Release|x64
+ {97A9B5E6-FECA-1BAD-8562-EC4B26346A25}.Release|x64.Build.0 = Release|x64
+ {B7A9B0FF-FECA-1BAD-4A76-D4027A608480}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B7A9B0FF-FECA-1BAD-4A76-D4027A608480}.Debug|Win32.Build.0 = Debug|Win32
+ {B7A9B0FF-FECA-1BAD-4A76-D4027A608480}.Debug|x64.ActiveCfg = Debug|x64
+ {B7A9B0FF-FECA-1BAD-4A76-D4027A608480}.Debug|x64.Build.0 = Debug|x64
+ {B7A9B0FF-FECA-1BAD-4A76-D4027A608480}.Release|Win32.ActiveCfg = Release|Win32
+ {B7A9B0FF-FECA-1BAD-4A76-D4027A608480}.Release|Win32.Build.0 = Release|Win32
+ {B7A9B0FF-FECA-1BAD-4A76-D4027A608480}.Release|x64.ActiveCfg = Release|x64
+ {B7A9B0FF-FECA-1BAD-4A76-D4027A608480}.Release|x64.Build.0 = Release|x64
+ {B7A9B486-FECA-1BAD-DA76-D4457A271480}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B7A9B486-FECA-1BAD-DA76-D4457A271480}.Debug|Win32.Build.0 = Debug|Win32
+ {B7A9B486-FECA-1BAD-DA76-D4457A271480}.Debug|x64.ActiveCfg = Debug|x64
+ {B7A9B486-FECA-1BAD-DA76-D4457A271480}.Debug|x64.Build.0 = Debug|x64
+ {B7A9B486-FECA-1BAD-DA76-D4457A271480}.Release|Win32.ActiveCfg = Release|Win32
+ {B7A9B486-FECA-1BAD-DA76-D4457A271480}.Release|Win32.Build.0 = Release|Win32
+ {B7A9B486-FECA-1BAD-DA76-D4457A271480}.Release|x64.ActiveCfg = Release|x64
+ {B7A9B486-FECA-1BAD-DA76-D4457A271480}.Release|x64.Build.0 = Release|x64
+ {9CF44625-FECA-1BAD-8564-85690EE67112}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9CF44625-FECA-1BAD-8564-85690EE67112}.Debug|Win32.Build.0 = Debug|Win32
+ {9CF44625-FECA-1BAD-8564-85690EE67112}.Debug|x64.ActiveCfg = Debug|x64
+ {9CF44625-FECA-1BAD-8564-85690EE67112}.Debug|x64.Build.0 = Debug|x64
+ {9CF44625-FECA-1BAD-8564-85690EE67112}.Release|Win32.ActiveCfg = Release|Win32
+ {9CF44625-FECA-1BAD-8564-85690EE67112}.Release|Win32.Build.0 = Release|Win32
+ {9CF44625-FECA-1BAD-8564-85690EE67112}.Release|x64.ActiveCfg = Release|x64
+ {9CF44625-FECA-1BAD-8564-85690EE67112}.Release|x64.Build.0 = Release|x64
+ {A79456AF-FECA-1BAD-8564-85690EE67112}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A79456AF-FECA-1BAD-8564-85690EE67112}.Debug|Win32.Build.0 = Debug|Win32
+ {A79456AF-FECA-1BAD-8564-85690EE67112}.Debug|x64.ActiveCfg = Debug|x64
+ {A79456AF-FECA-1BAD-8564-85690EE67112}.Debug|x64.Build.0 = Debug|x64
+ {A79456AF-FECA-1BAD-8564-85690EE67112}.Release|Win32.ActiveCfg = Release|Win32
+ {A79456AF-FECA-1BAD-8564-85690EE67112}.Release|Win32.Build.0 = Release|Win32
+ {A79456AF-FECA-1BAD-8564-85690EE67112}.Release|x64.ActiveCfg = Release|x64
+ {A79456AF-FECA-1BAD-8564-85690EE67112}.Release|x64.Build.0 = Release|x64
+ {ACCFCC4E-FECA-1BAD-8564-85690EE67112}.Debug|Win32.ActiveCfg = Debug|Win32
+ {ACCFCC4E-FECA-1BAD-8564-85690EE67112}.Debug|Win32.Build.0 = Debug|Win32
+ {ACCFCC4E-FECA-1BAD-8564-85690EE67112}.Debug|x64.ActiveCfg = Debug|x64
+ {ACCFCC4E-FECA-1BAD-8564-85690EE67112}.Debug|x64.Build.0 = Debug|x64
+ {ACCFCC4E-FECA-1BAD-8564-85690EE67112}.Release|Win32.ActiveCfg = Release|Win32
+ {ACCFCC4E-FECA-1BAD-8564-85690EE67112}.Release|Win32.Build.0 = Release|Win32
+ {ACCFCC4E-FECA-1BAD-8564-85690EE67112}.Release|x64.ActiveCfg = Release|x64
+ {ACCFCC4E-FECA-1BAD-8564-85690EE67112}.Release|x64.Build.0 = Release|x64
+ {97AFDCC4-FECA-1BAD-8564-85690EE67112}.Debug|Win32.ActiveCfg = Debug|Win32
+ {97AFDCC4-FECA-1BAD-8564-85690EE67112}.Debug|Win32.Build.0 = Debug|Win32
+ {97AFDCC4-FECA-1BAD-8564-85690EE67112}.Debug|x64.ActiveCfg = Debug|x64
+ {97AFDCC4-FECA-1BAD-8564-85690EE67112}.Debug|x64.Build.0 = Debug|x64
+ {97AFDCC4-FECA-1BAD-8564-85690EE67112}.Release|Win32.ActiveCfg = Release|Win32
+ {97AFDCC4-FECA-1BAD-8564-85690EE67112}.Release|Win32.Build.0 = Release|Win32
+ {97AFDCC4-FECA-1BAD-8564-85690EE67112}.Release|x64.ActiveCfg = Release|x64
+ {97AFDCC4-FECA-1BAD-8564-85690EE67112}.Release|x64.Build.0 = Release|x64
+ {3E293566-FECA-1BAD-8564-85690EE67112}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3E293566-FECA-1BAD-8564-85690EE67112}.Debug|Win32.Build.0 = Debug|Win32
+ {3E293566-FECA-1BAD-8564-85690EE67112}.Debug|x64.ActiveCfg = Debug|x64
+ {3E293566-FECA-1BAD-8564-85690EE67112}.Debug|x64.Build.0 = Debug|x64
+ {3E293566-FECA-1BAD-8564-85690EE67112}.Release|Win32.ActiveCfg = Release|Win32
+ {3E293566-FECA-1BAD-8564-85690EE67112}.Release|Win32.Build.0 = Release|Win32
+ {3E293566-FECA-1BAD-8564-85690EE67112}.Release|x64.ActiveCfg = Release|x64
+ {3E293566-FECA-1BAD-8564-85690EE67112}.Release|x64.Build.0 = Release|x64
+ {ACCFCCE4-FECA-1BAD-FBC0-B3C30E4C7112}.Debug|Win32.ActiveCfg = Debug|Win32
+ {ACCFCCE4-FECA-1BAD-FBC0-B3C30E4C7112}.Debug|Win32.Build.0 = Debug|Win32
+ {ACCFCCE4-FECA-1BAD-FBC0-B3C30E4C7112}.Debug|x64.ActiveCfg = Debug|x64
+ {ACCFCCE4-FECA-1BAD-FBC0-B3C30E4C7112}.Debug|x64.Build.0 = Debug|x64
+ {ACCFCCE4-FECA-1BAD-FBC0-B3C30E4C7112}.Release|Win32.ActiveCfg = Release|Win32
+ {ACCFCCE4-FECA-1BAD-FBC0-B3C30E4C7112}.Release|Win32.Build.0 = Release|Win32
+ {ACCFCCE4-FECA-1BAD-FBC0-B3C30E4C7112}.Release|x64.ActiveCfg = Release|x64
+ {ACCFCCE4-FECA-1BAD-FBC0-B3C30E4C7112}.Release|x64.Build.0 = Release|x64
+ {22B6B3AB-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
+ {22B6B3AB-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
+ {22B6B3AB-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
+ {22B6B3AB-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
+ {22B6B3AB-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
+ {22B6B3AB-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
+ {22B6B3AB-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
+ {22B6B3AB-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
+ {19D6A321-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
+ {19D6A321-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
+ {19D6A321-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
+ {19D6A321-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
+ {19D6A321-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
+ {19D6A321-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
+ {19D6A321-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
+ {19D6A321-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
+ {9849EDB4-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9849EDB4-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
+ {9849EDB4-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
+ {9849EDB4-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
+ {9849EDB4-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
+ {9849EDB4-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
+ {9849EDB4-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
+ {9849EDB4-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
+ {A329FD3E-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A329FD3E-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
+ {A329FD3E-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
+ {A329FD3E-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
+ {A329FD3E-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
+ {A329FD3E-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
+ {A329FD3E-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
+ {A329FD3E-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
+ {22AAB3AB-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
+ {22AAB3AB-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
+ {22AAB3AB-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
+ {22AAB3AB-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
+ {22AAB3AB-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
+ {22AAB3AB-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
+ {22AAB3AB-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
+ {22AAB3AB-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
+ {19CAA321-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
+ {19CAA321-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
+ {19CAA321-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
+ {19CAA321-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
+ {19CAA321-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
+ {19CAA321-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
+ {19CAA321-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
+ {19CAA321-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
+ {C64D7624-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C64D7624-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
+ {C64D7624-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
+ {C64D7624-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
+ {C64D7624-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
+ {C64D7624-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
+ {C64D7624-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
+ {C64D7624-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
+ {FD2D66AE-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FD2D66AE-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
+ {FD2D66AE-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
+ {FD2D66AE-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
+ {FD2D66AE-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
+ {FD2D66AE-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
+ {FD2D66AE-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
+ {FD2D66AE-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
+ {9DE5854A-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9DE5854A-FECA-1BAD-8565-D33D58B27113}.Debug|Win32.Build.0 = Debug|Win32
+ {9DE5854A-FECA-1BAD-8565-D33D58B27113}.Debug|x64.ActiveCfg = Debug|x64
+ {9DE5854A-FECA-1BAD-8565-D33D58B27113}.Debug|x64.Build.0 = Debug|x64
+ {9DE5854A-FECA-1BAD-8565-D33D58B27113}.Release|Win32.ActiveCfg = Release|Win32
+ {9DE5854A-FECA-1BAD-8565-D33D58B27113}.Release|Win32.Build.0 = Release|Win32
+ {9DE5854A-FECA-1BAD-8565-D33D58B27113}.Release|x64.ActiveCfg = Release|x64
+ {9DE5854A-FECA-1BAD-8565-D33D58B27113}.Release|x64.Build.0 = Release|x64
+ {8EBFAF04-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8EBFAF04-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
+ {8EBFAF04-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
+ {8EBFAF04-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
+ {8EBFAF04-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
+ {8EBFAF04-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
+ {8EBFAF04-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
+ {8EBFAF04-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
+ {6C78F769-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6C78F769-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
+ {6C78F769-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
+ {6C78F769-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
+ {6C78F769-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
+ {6C78F769-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
+ {6C78F769-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
+ {6C78F769-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
+ {B9E64ED2-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B9E64ED2-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
+ {B9E64ED2-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
+ {B9E64ED2-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
+ {B9E64ED2-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
+ {B9E64ED2-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
+ {B9E64ED2-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
+ {B9E64ED2-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
+ {3A5B53E3-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3A5B53E3-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
+ {3A5B53E3-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
+ {3A5B53E3-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
+ {3A5B53E3-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
+ {3A5B53E3-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
+ {3A5B53E3-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
+ {3A5B53E3-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
+ {013B4369-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
+ {013B4369-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
+ {013B4369-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
+ {013B4369-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
+ {013B4369-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
+ {013B4369-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
+ {013B4369-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
+ {013B4369-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
+ {BC08177B-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BC08177B-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
+ {BC08177B-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
+ {BC08177B-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
+ {BC08177B-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
+ {BC08177B-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
+ {BC08177B-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
+ {BC08177B-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
+ {BEE84FFF-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BEE84FFF-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
+ {BEE84FFF-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
+ {BEE84FFF-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
+ {BEE84FFF-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
+ {BEE84FFF-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
+ {BEE84FFF-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
+ {BEE84FFF-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
+ {B5DFBF8E-FECA-1BAD-A714-C623708DC274}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B5DFBF8E-FECA-1BAD-A714-C623708DC274}.Debug|Win32.Build.0 = Debug|Win32
+ {B5DFBF8E-FECA-1BAD-A714-C623708DC274}.Debug|x64.ActiveCfg = Debug|x64
+ {B5DFBF8E-FECA-1BAD-A714-C623708DC274}.Debug|x64.Build.0 = Debug|x64
+ {B5DFBF8E-FECA-1BAD-A714-C623708DC274}.Release|Win32.ActiveCfg = Release|Win32
+ {B5DFBF8E-FECA-1BAD-A714-C623708DC274}.Release|Win32.Build.0 = Release|Win32
+ {B5DFBF8E-FECA-1BAD-A714-C623708DC274}.Release|x64.ActiveCfg = Release|x64
+ {B5DFBF8E-FECA-1BAD-A714-C623708DC274}.Release|x64.Build.0 = Release|x64
+ {CD284401-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CD284401-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
+ {CD284401-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
+ {CD284401-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
+ {CD284401-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
+ {CD284401-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
+ {CD284401-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
+ {CD284401-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
+ {F648548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F648548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
+ {F648548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
+ {F648548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
+ {F648548B-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
+ {F648548B-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
+ {F648548B-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
+ {F648548B-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
+ {CF754401-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CF754401-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
+ {CF754401-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
+ {CF754401-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
+ {CF754401-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
+ {CF754401-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
+ {CF754401-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
+ {CF754401-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
+ {F415548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F415548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
+ {F415548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
+ {F415548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
+ {F415548B-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
+ {F415548B-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
+ {F415548B-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
+ {F415548B-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
+ {77832930-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
+ {77832930-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
+ {77832930-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
+ {77832930-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
+ {77832930-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
+ {77832930-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
+ {77832930-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
+ {77832930-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
+ {4CE339BA-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4CE339BA-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
+ {4CE339BA-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
+ {4CE339BA-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
+ {4CE339BA-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
+ {4CE339BA-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
+ {4CE339BA-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
+ {4CE339BA-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
+ {C8154401-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C8154401-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
+ {C8154401-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
+ {C8154401-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
+ {C8154401-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
+ {C8154401-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
+ {C8154401-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
+ {C8154401-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
+ {F375548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F375548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|Win32.Build.0 = Debug|Win32
+ {F375548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.ActiveCfg = Debug|x64
+ {F375548B-FECA-1BAD-A742-DAEF32B06A25}.Debug|x64.Build.0 = Debug|x64
+ {F375548B-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.ActiveCfg = Release|Win32
+ {F375548B-FECA-1BAD-A742-DAEF32B06A25}.Release|Win32.Build.0 = Release|Win32
+ {F375548B-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.ActiveCfg = Release|x64
+ {F375548B-FECA-1BAD-A742-DAEF32B06A25}.Release|x64.Build.0 = Release|x64
+ {FFF627B4-FECA-1BAD-A712-C623708DC272}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FFF627B4-FECA-1BAD-A712-C623708DC272}.Debug|Win32.Build.0 = Debug|Win32
+ {FFF627B4-FECA-1BAD-A712-C623708DC272}.Debug|x64.ActiveCfg = Debug|x64
+ {FFF627B4-FECA-1BAD-A712-C623708DC272}.Debug|x64.Build.0 = Debug|x64
+ {FFF627B4-FECA-1BAD-A712-C623708DC272}.Release|Win32.ActiveCfg = Release|Win32
+ {FFF627B4-FECA-1BAD-A712-C623708DC272}.Release|Win32.Build.0 = Release|Win32
+ {FFF627B4-FECA-1BAD-A712-C623708DC272}.Release|x64.ActiveCfg = Release|x64
+ {FFF627B4-FECA-1BAD-A712-C623708DC272}.Release|x64.Build.0 = Release|x64
+ {FFC627B4-FECA-1BAD-A712-C623708DC272}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FFC627B4-FECA-1BAD-A712-C623708DC272}.Debug|Win32.Build.0 = Debug|Win32
+ {FFC627B4-FECA-1BAD-A712-C623708DC272}.Debug|x64.ActiveCfg = Debug|x64
+ {FFC627B4-FECA-1BAD-A712-C623708DC272}.Debug|x64.Build.0 = Debug|x64
+ {FFC627B4-FECA-1BAD-A712-C623708DC272}.Release|Win32.ActiveCfg = Release|Win32
+ {FFC627B4-FECA-1BAD-A712-C623708DC272}.Release|Win32.Build.0 = Release|Win32
+ {FFC627B4-FECA-1BAD-A712-C623708DC272}.Release|x64.ActiveCfg = Release|x64
+ {FFC627B4-FECA-1BAD-A712-C623708DC272}.Release|x64.Build.0 = Release|x64
+ {FFD627B4-FECA-1BAD-A712-C623708DC272}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FFD627B4-FECA-1BAD-A712-C623708DC272}.Debug|Win32.Build.0 = Debug|Win32
+ {FFD627B4-FECA-1BAD-A712-C623708DC272}.Debug|x64.ActiveCfg = Debug|x64
+ {FFD627B4-FECA-1BAD-A712-C623708DC272}.Debug|x64.Build.0 = Debug|x64
+ {FFD627B4-FECA-1BAD-A712-C623708DC272}.Release|Win32.ActiveCfg = Release|Win32
+ {FFD627B4-FECA-1BAD-A712-C623708DC272}.Release|Win32.Build.0 = Release|Win32
+ {FFD627B4-FECA-1BAD-A712-C623708DC272}.Release|x64.ActiveCfg = Release|x64
+ {FFD627B4-FECA-1BAD-A712-C623708DC272}.Release|x64.Build.0 = Release|x64
+ {0F4C02C4-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0F4C02C4-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.Build.0 = Debug|Win32
+ {0F4C02C4-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.ActiveCfg = Debug|x64
+ {0F4C02C4-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.Build.0 = Debug|x64
+ {0F4C02C4-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.ActiveCfg = Release|Win32
+ {0F4C02C4-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.Build.0 = Release|Win32
+ {0F4C02C4-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.ActiveCfg = Release|x64
+ {0F4C02C4-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.Build.0 = Release|x64
+ {033DAD28-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.ActiveCfg = Debug|Win32
+ {033DAD28-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.Build.0 = Debug|Win32
+ {033DAD28-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.ActiveCfg = Debug|x64
+ {033DAD28-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.Build.0 = Debug|x64
+ {033DAD28-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.ActiveCfg = Release|Win32
+ {033DAD28-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.Build.0 = Release|Win32
+ {033DAD28-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.ActiveCfg = Release|x64
+ {033DAD28-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.Build.0 = Release|x64
+ {919D8037-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.ActiveCfg = Debug|Win32
+ {919D8037-FECA-1BAD-BA55-C0F194E8D070}.Debug|Win32.Build.0 = Debug|Win32
+ {919D8037-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.ActiveCfg = Debug|x64
+ {919D8037-FECA-1BAD-BA55-C0F194E8D070}.Debug|x64.Build.0 = Debug|x64
+ {919D8037-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.ActiveCfg = Release|Win32
+ {919D8037-FECA-1BAD-BA55-C0F194E8D070}.Release|Win32.Build.0 = Release|Win32
+ {919D8037-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.ActiveCfg = Release|x64
+ {919D8037-FECA-1BAD-BA55-C0F194E8D070}.Release|x64.Build.0 = Release|x64
+ {7230CC0D-FECA-1BAD-662F-43CDC449C088}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7230CC0D-FECA-1BAD-662F-43CDC449C088}.Debug|Win32.Build.0 = Debug|Win32
+ {7230CC0D-FECA-1BAD-662F-43CDC449C088}.Debug|x64.ActiveCfg = Debug|x64
+ {7230CC0D-FECA-1BAD-662F-43CDC449C088}.Debug|x64.Build.0 = Debug|x64
+ {7230CC0D-FECA-1BAD-662F-43CDC449C088}.Release|Win32.ActiveCfg = Release|Win32
+ {7230CC0D-FECA-1BAD-662F-43CDC449C088}.Release|Win32.Build.0 = Release|Win32
+ {7230CC0D-FECA-1BAD-662F-43CDC449C088}.Release|x64.ActiveCfg = Release|x64
+ {7230CC0D-FECA-1BAD-662F-43CDC449C088}.Release|x64.Build.0 = Release|x64
+ {388BC7ED-FECA-1BAD-6284-F3732ECE18EC}.Debug|Win32.ActiveCfg = Debug|Win32
+ {388BC7ED-FECA-1BAD-6284-F3732ECE18EC}.Debug|Win32.Build.0 = Debug|Win32
+ {388BC7ED-FECA-1BAD-6284-F3732ECE18EC}.Debug|x64.ActiveCfg = Debug|x64
+ {388BC7ED-FECA-1BAD-6284-F3732ECE18EC}.Debug|x64.Build.0 = Debug|x64
+ {388BC7ED-FECA-1BAD-6284-F3732ECE18EC}.Release|Win32.ActiveCfg = Release|Win32
+ {388BC7ED-FECA-1BAD-6284-F3732ECE18EC}.Release|Win32.Build.0 = Release|Win32
+ {388BC7ED-FECA-1BAD-6284-F3732ECE18EC}.Release|x64.ActiveCfg = Release|x64
+ {388BC7ED-FECA-1BAD-6284-F3732ECE18EC}.Release|x64.Build.0 = Release|x64
+ {257E89DB-FECA-1BAD-035B-A790F8AEE4FF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {257E89DB-FECA-1BAD-035B-A790F8AEE4FF}.Debug|Win32.Build.0 = Debug|Win32
+ {257E89DB-FECA-1BAD-035B-A790F8AEE4FF}.Debug|x64.ActiveCfg = Debug|x64
+ {257E89DB-FECA-1BAD-035B-A790F8AEE4FF}.Debug|x64.Build.0 = Debug|x64
+ {257E89DB-FECA-1BAD-035B-A790F8AEE4FF}.Release|Win32.ActiveCfg = Release|Win32
+ {257E89DB-FECA-1BAD-035B-A790F8AEE4FF}.Release|Win32.Build.0 = Release|Win32
+ {257E89DB-FECA-1BAD-035B-A790F8AEE4FF}.Release|x64.ActiveCfg = Release|x64
+ {257E89DB-FECA-1BAD-035B-A790F8AEE4FF}.Release|x64.Build.0 = Release|x64
+ {B497E168-FECA-1BAD-3A45-311BD15FE43D}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B497E168-FECA-1BAD-3A45-311BD15FE43D}.Debug|Win32.Build.0 = Debug|Win32
+ {B497E168-FECA-1BAD-3A45-311BD15FE43D}.Debug|x64.ActiveCfg = Debug|x64
+ {B497E168-FECA-1BAD-3A45-311BD15FE43D}.Debug|x64.Build.0 = Debug|x64
+ {B497E168-FECA-1BAD-3A45-311BD15FE43D}.Release|Win32.ActiveCfg = Release|Win32
+ {B497E168-FECA-1BAD-3A45-311BD15FE43D}.Release|Win32.Build.0 = Release|Win32
+ {B497E168-FECA-1BAD-3A45-311BD15FE43D}.Release|x64.ActiveCfg = Release|x64
+ {B497E168-FECA-1BAD-3A45-311BD15FE43D}.Release|x64.Build.0 = Release|x64
+ {362AC472-FECA-1BAD-926E-E34A898F3061}.Debug|Win32.ActiveCfg = Debug|Win32
+ {362AC472-FECA-1BAD-926E-E34A898F3061}.Debug|Win32.Build.0 = Debug|Win32
+ {362AC472-FECA-1BAD-926E-E34A898F3061}.Debug|x64.ActiveCfg = Debug|x64
+ {362AC472-FECA-1BAD-926E-E34A898F3061}.Debug|x64.Build.0 = Debug|x64
+ {362AC472-FECA-1BAD-926E-E34A898F3061}.Release|Win32.ActiveCfg = Release|Win32
+ {362AC472-FECA-1BAD-926E-E34A898F3061}.Release|Win32.Build.0 = Release|Win32
+ {362AC472-FECA-1BAD-926E-E34A898F3061}.Release|x64.ActiveCfg = Release|x64
+ {362AC472-FECA-1BAD-926E-E34A898F3061}.Release|x64.Build.0 = Release|x64
+ {870D7112-FECA-1BAD-997C-981CB0707EDF}.Debug|Win32.ActiveCfg = Debug|Win32
+ {870D7112-FECA-1BAD-997C-981CB0707EDF}.Debug|Win32.Build.0 = Debug|Win32
+ {870D7112-FECA-1BAD-997C-981CB0707EDF}.Debug|x64.ActiveCfg = Debug|x64
+ {870D7112-FECA-1BAD-997C-981CB0707EDF}.Debug|x64.Build.0 = Debug|x64
+ {870D7112-FECA-1BAD-997C-981CB0707EDF}.Release|Win32.ActiveCfg = Release|Win32
+ {870D7112-FECA-1BAD-997C-981CB0707EDF}.Release|Win32.Build.0 = Release|Win32
+ {870D7112-FECA-1BAD-997C-981CB0707EDF}.Release|x64.ActiveCfg = Release|x64
+ {870D7112-FECA-1BAD-997C-981CB0707EDF}.Release|x64.Build.0 = Release|x64
+ {40CE5CBD-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {40CE5CBD-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
+ {40CE5CBD-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
+ {40CE5CBD-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
+ {40CE5CBD-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
+ {40CE5CBD-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
+ {40CE5CBD-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
+ {40CE5CBD-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
+ {B7091252-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B7091252-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
+ {B7091252-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
+ {B7091252-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
+ {B7091252-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
+ {B7091252-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
+ {B7091252-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
+ {B7091252-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
+ {9016F8E6-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9016F8E6-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
+ {9016F8E6-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
+ {9016F8E6-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
+ {9016F8E6-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
+ {9016F8E6-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
+ {9016F8E6-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
+ {9016F8E6-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
+ {071FC37F-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {071FC37F-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
+ {071FC37F-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
+ {071FC37F-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
+ {071FC37F-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
+ {071FC37F-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
+ {071FC37F-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
+ {071FC37F-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
+ {140E764F-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {140E764F-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
+ {140E764F-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
+ {140E764F-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
+ {140E764F-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
+ {140E764F-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
+ {140E764F-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
+ {140E764F-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
+ {C838447D-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C838447D-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
+ {C838447D-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
+ {C838447D-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
+ {C838447D-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
+ {C838447D-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
+ {C838447D-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
+ {C838447D-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
+ {CE954689-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CE954689-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
+ {CE954689-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
+ {CE954689-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
+ {CE954689-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
+ {CE954689-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
+ {CE954689-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
+ {CE954689-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
+ {C79CF289-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C79CF289-FECA-1BAD-BE51-8A67A27959F5}.Debug|Win32.Build.0 = Debug|Win32
+ {C79CF289-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.ActiveCfg = Debug|x64
+ {C79CF289-FECA-1BAD-BE51-8A67A27959F5}.Debug|x64.Build.0 = Debug|x64
+ {C79CF289-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.ActiveCfg = Release|Win32
+ {C79CF289-FECA-1BAD-BE51-8A67A27959F5}.Release|Win32.Build.0 = Release|Win32
+ {C79CF289-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.ActiveCfg = Release|x64
+ {C79CF289-FECA-1BAD-BE51-8A67A27959F5}.Release|x64.Build.0 = Release|x64
+ {6C4E704E-FECA-1BAD-57C8-A8090AE02194}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6C4E704E-FECA-1BAD-57C8-A8090AE02194}.Debug|Win32.Build.0 = Debug|Win32
+ {6C4E704E-FECA-1BAD-57C8-A8090AE02194}.Debug|x64.ActiveCfg = Debug|x64
+ {6C4E704E-FECA-1BAD-57C8-A8090AE02194}.Debug|x64.Build.0 = Debug|x64
+ {6C4E704E-FECA-1BAD-57C8-A8090AE02194}.Release|Win32.ActiveCfg = Release|Win32
+ {6C4E704E-FECA-1BAD-57C8-A8090AE02194}.Release|Win32.Build.0 = Release|Win32
+ {6C4E704E-FECA-1BAD-57C8-A8090AE02194}.Release|x64.ActiveCfg = Release|x64
+ {6C4E704E-FECA-1BAD-57C8-A8090AE02194}.Release|x64.Build.0 = Release|x64
+ {87EA0651-FECA-1BAD-A972-EF683B232306}.Debug|Win32.ActiveCfg = Debug|Win32
+ {87EA0651-FECA-1BAD-A972-EF683B232306}.Debug|Win32.Build.0 = Debug|Win32
+ {87EA0651-FECA-1BAD-A972-EF683B232306}.Debug|x64.ActiveCfg = Debug|x64
+ {87EA0651-FECA-1BAD-A972-EF683B232306}.Debug|x64.Build.0 = Debug|x64
+ {87EA0651-FECA-1BAD-A972-EF683B232306}.Release|Win32.ActiveCfg = Release|Win32
+ {87EA0651-FECA-1BAD-A972-EF683B232306}.Release|Win32.Build.0 = Release|Win32
+ {87EA0651-FECA-1BAD-A972-EF683B232306}.Release|x64.ActiveCfg = Release|x64
+ {87EA0651-FECA-1BAD-A972-EF683B232306}.Release|x64.Build.0 = Release|x64
+ {AC3515AC-FECA-1BAD-7BCF-1E57BCBE0D93}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AC3515AC-FECA-1BAD-7BCF-1E57BCBE0D93}.Debug|Win32.Build.0 = Debug|Win32
+ {AC3515AC-FECA-1BAD-7BCF-1E57BCBE0D93}.Debug|x64.ActiveCfg = Debug|x64
+ {AC3515AC-FECA-1BAD-7BCF-1E57BCBE0D93}.Debug|x64.Build.0 = Debug|x64
+ {AC3515AC-FECA-1BAD-7BCF-1E57BCBE0D93}.Release|Win32.ActiveCfg = Release|Win32
+ {AC3515AC-FECA-1BAD-7BCF-1E57BCBE0D93}.Release|Win32.Build.0 = Release|Win32
+ {AC3515AC-FECA-1BAD-7BCF-1E57BCBE0D93}.Release|x64.ActiveCfg = Release|x64
+ {AC3515AC-FECA-1BAD-7BCF-1E57BCBE0D93}.Release|x64.Build.0 = Release|x64
+ {92EC52EF-FECA-1BAD-4822-8A23A725AAA8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {92EC52EF-FECA-1BAD-4822-8A23A725AAA8}.Debug|Win32.Build.0 = Debug|Win32
+ {92EC52EF-FECA-1BAD-4822-8A23A725AAA8}.Debug|x64.ActiveCfg = Debug|x64
+ {92EC52EF-FECA-1BAD-4822-8A23A725AAA8}.Debug|x64.Build.0 = Debug|x64
+ {92EC52EF-FECA-1BAD-4822-8A23A725AAA8}.Release|Win32.ActiveCfg = Release|Win32
+ {92EC52EF-FECA-1BAD-4822-8A23A725AAA8}.Release|Win32.Build.0 = Release|Win32
+ {92EC52EF-FECA-1BAD-4822-8A23A725AAA8}.Release|x64.ActiveCfg = Release|x64
+ {92EC52EF-FECA-1BAD-4822-8A23A725AAA8}.Release|x64.Build.0 = Release|x64
+ {FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5}.Debug|Win32.Build.0 = Debug|Win32
+ {FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5}.Debug|x64.ActiveCfg = Debug|x64
+ {FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5}.Debug|x64.Build.0 = Debug|x64
+ {FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5}.Release|Win32.ActiveCfg = Release|Win32
+ {FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5}.Release|Win32.Build.0 = Release|Win32
+ {FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5}.Release|x64.ActiveCfg = Release|x64
+ {FC680E2D-FECA-1BAD-6ECA-CFEF95E288A5}.Release|x64.Build.0 = Release|x64
+ {5A399C85-FECA-1BAD-E4AF-D6C5D6D0BA85}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5A399C85-FECA-1BAD-E4AF-D6C5D6D0BA85}.Debug|Win32.Build.0 = Debug|Win32
+ {5A399C85-FECA-1BAD-E4AF-D6C5D6D0BA85}.Debug|x64.ActiveCfg = Debug|x64
+ {5A399C85-FECA-1BAD-E4AF-D6C5D6D0BA85}.Debug|x64.Build.0 = Debug|x64
+ {5A399C85-FECA-1BAD-E4AF-D6C5D6D0BA85}.Release|Win32.ActiveCfg = Release|Win32
+ {5A399C85-FECA-1BAD-E4AF-D6C5D6D0BA85}.Release|Win32.Build.0 = Release|Win32
+ {5A399C85-FECA-1BAD-E4AF-D6C5D6D0BA85}.Release|x64.ActiveCfg = Release|x64
+ {5A399C85-FECA-1BAD-E4AF-D6C5D6D0BA85}.Release|x64.Build.0 = Release|x64
+ {11AA315E-FECA-1BAD-5016-EC184EF1264A}.Debug|Win32.ActiveCfg = Debug|Win32
+ {11AA315E-FECA-1BAD-5016-EC184EF1264A}.Debug|Win32.Build.0 = Debug|Win32
+ {11AA315E-FECA-1BAD-5016-EC184EF1264A}.Debug|x64.ActiveCfg = Debug|x64
+ {11AA315E-FECA-1BAD-5016-EC184EF1264A}.Debug|x64.Build.0 = Debug|x64
+ {11AA315E-FECA-1BAD-5016-EC184EF1264A}.Release|Win32.ActiveCfg = Release|Win32
+ {11AA315E-FECA-1BAD-5016-EC184EF1264A}.Release|Win32.Build.0 = Release|Win32
+ {11AA315E-FECA-1BAD-5016-EC184EF1264A}.Release|x64.ActiveCfg = Release|x64
+ {11AA315E-FECA-1BAD-5016-EC184EF1264A}.Release|x64.Build.0 = Release|x64
+ {F05679AC-FECA-1BAD-7E09-28972A531BE9}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F05679AC-FECA-1BAD-7E09-28972A531BE9}.Debug|Win32.Build.0 = Debug|Win32
+ {F05679AC-FECA-1BAD-7E09-28972A531BE9}.Debug|x64.ActiveCfg = Debug|x64
+ {F05679AC-FECA-1BAD-7E09-28972A531BE9}.Debug|x64.Build.0 = Debug|x64
+ {F05679AC-FECA-1BAD-7E09-28972A531BE9}.Release|Win32.ActiveCfg = Release|Win32
+ {F05679AC-FECA-1BAD-7E09-28972A531BE9}.Release|Win32.Build.0 = Release|Win32
+ {F05679AC-FECA-1BAD-7E09-28972A531BE9}.Release|x64.ActiveCfg = Release|x64
+ {F05679AC-FECA-1BAD-7E09-28972A531BE9}.Release|x64.Build.0 = Release|x64
+ {AEA604BB-FECA-1BAD-0BE6-2F4603877603}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AEA604BB-FECA-1BAD-0BE6-2F4603877603}.Debug|Win32.Build.0 = Debug|Win32
+ {AEA604BB-FECA-1BAD-0BE6-2F4603877603}.Debug|x64.ActiveCfg = Debug|x64
+ {AEA604BB-FECA-1BAD-0BE6-2F4603877603}.Debug|x64.Build.0 = Debug|x64
+ {AEA604BB-FECA-1BAD-0BE6-2F4603877603}.Release|Win32.ActiveCfg = Release|Win32
+ {AEA604BB-FECA-1BAD-0BE6-2F4603877603}.Release|Win32.Build.0 = Release|Win32
+ {AEA604BB-FECA-1BAD-0BE6-2F4603877603}.Release|x64.ActiveCfg = Release|x64
+ {AEA604BB-FECA-1BAD-0BE6-2F4603877603}.Release|x64.Build.0 = Release|x64
+ {688206D7-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.ActiveCfg = Debug|Win32
+ {688206D7-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.Build.0 = Debug|Win32
+ {688206D7-FECA-1BAD-BF85-8EE479601925}.Debug|x64.ActiveCfg = Debug|x64
+ {688206D7-FECA-1BAD-BF85-8EE479601925}.Debug|x64.Build.0 = Debug|x64
+ {688206D7-FECA-1BAD-BF85-8EE479601925}.Release|Win32.ActiveCfg = Release|Win32
+ {688206D7-FECA-1BAD-BF85-8EE479601925}.Release|Win32.Build.0 = Release|Win32
+ {688206D7-FECA-1BAD-BF85-8EE479601925}.Release|x64.ActiveCfg = Release|x64
+ {688206D7-FECA-1BAD-BF85-8EE479601925}.Release|x64.Build.0 = Release|x64
+ {35A13A15-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.ActiveCfg = Debug|Win32
+ {35A13A15-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.Build.0 = Debug|Win32
+ {35A13A15-FECA-1BAD-BF85-8EE479601925}.Debug|x64.ActiveCfg = Debug|x64
+ {35A13A15-FECA-1BAD-BF85-8EE479601925}.Debug|x64.Build.0 = Debug|x64
+ {35A13A15-FECA-1BAD-BF85-8EE479601925}.Release|Win32.ActiveCfg = Release|Win32
+ {35A13A15-FECA-1BAD-BF85-8EE479601925}.Release|Win32.Build.0 = Release|Win32
+ {35A13A15-FECA-1BAD-BF85-8EE479601925}.Release|x64.ActiveCfg = Release|x64
+ {35A13A15-FECA-1BAD-BF85-8EE479601925}.Release|x64.Build.0 = Release|x64
+ {F4B3D457-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F4B3D457-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.Build.0 = Debug|Win32
+ {F4B3D457-FECA-1BAD-BF85-8EE479601925}.Debug|x64.ActiveCfg = Debug|x64
+ {F4B3D457-FECA-1BAD-BF85-8EE479601925}.Debug|x64.Build.0 = Debug|x64
+ {F4B3D457-FECA-1BAD-BF85-8EE479601925}.Release|Win32.ActiveCfg = Release|Win32
+ {F4B3D457-FECA-1BAD-BF85-8EE479601925}.Release|Win32.Build.0 = Release|Win32
+ {F4B3D457-FECA-1BAD-BF85-8EE479601925}.Release|x64.ActiveCfg = Release|x64
+ {F4B3D457-FECA-1BAD-BF85-8EE479601925}.Release|x64.Build.0 = Release|x64
+ {CDF61A72-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CDF61A72-FECA-1BAD-BF85-8EE479601925}.Debug|Win32.Build.0 = Debug|Win32
+ {CDF61A72-FECA-1BAD-BF85-8EE479601925}.Debug|x64.ActiveCfg = Debug|x64
+ {CDF61A72-FECA-1BAD-BF85-8EE479601925}.Debug|x64.Build.0 = Debug|x64
+ {CDF61A72-FECA-1BAD-BF85-8EE479601925}.Release|Win32.ActiveCfg = Release|Win32
+ {CDF61A72-FECA-1BAD-BF85-8EE479601925}.Release|Win32.Build.0 = Release|Win32
+ {CDF61A72-FECA-1BAD-BF85-8EE479601925}.Release|x64.ActiveCfg = Release|x64
+ {CDF61A72-FECA-1BAD-BF85-8EE479601925}.Release|x64.Build.0 = Release|x64
+ {01D25764-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|Win32.ActiveCfg = Debug|Win32
+ {01D25764-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|Win32.Build.0 = Debug|Win32
+ {01D25764-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|x64.ActiveCfg = Debug|x64
+ {01D25764-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|x64.Build.0 = Debug|x64
+ {01D25764-FECA-1BAD-56E7-2D2A01EB2B05}.Release|Win32.ActiveCfg = Release|Win32
+ {01D25764-FECA-1BAD-56E7-2D2A01EB2B05}.Release|Win32.Build.0 = Release|Win32
+ {01D25764-FECA-1BAD-56E7-2D2A01EB2B05}.Release|x64.ActiveCfg = Release|x64
+ {01D25764-FECA-1BAD-56E7-2D2A01EB2B05}.Release|x64.Build.0 = Release|x64
+ {5ADC56EB-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5ADC56EB-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|Win32.Build.0 = Debug|Win32
+ {5ADC56EB-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|x64.ActiveCfg = Debug|x64
+ {5ADC56EB-FECA-1BAD-56E7-2D2A01EB2B05}.Debug|x64.Build.0 = Debug|x64
+ {5ADC56EB-FECA-1BAD-56E7-2D2A01EB2B05}.Release|Win32.ActiveCfg = Release|Win32
+ {5ADC56EB-FECA-1BAD-56E7-2D2A01EB2B05}.Release|Win32.Build.0 = Release|Win32
+ {5ADC56EB-FECA-1BAD-56E7-2D2A01EB2B05}.Release|x64.ActiveCfg = Release|x64
+ {5ADC56EB-FECA-1BAD-56E7-2D2A01EB2B05}.Release|x64.Build.0 = Release|x64
+ {20FA65D1-FECA-1BAD-333D-0D85A7384955}.Debug|Win32.ActiveCfg = Debug|Win32
+ {20FA65D1-FECA-1BAD-333D-0D85A7384955}.Debug|Win32.Build.0 = Debug|Win32
+ {20FA65D1-FECA-1BAD-333D-0D85A7384955}.Debug|x64.ActiveCfg = Debug|x64
+ {20FA65D1-FECA-1BAD-333D-0D85A7384955}.Debug|x64.Build.0 = Debug|x64
+ {20FA65D1-FECA-1BAD-333D-0D85A7384955}.Release|Win32.ActiveCfg = Release|Win32
+ {20FA65D1-FECA-1BAD-333D-0D85A7384955}.Release|Win32.Build.0 = Release|Win32
+ {20FA65D1-FECA-1BAD-333D-0D85A7384955}.Release|x64.ActiveCfg = Release|x64
+ {20FA65D1-FECA-1BAD-333D-0D85A7384955}.Release|x64.Build.0 = Release|x64
+ {23142888-FECA-1BAD-333D-0D85A7384955}.Debug|Win32.ActiveCfg = Debug|Win32
+ {23142888-FECA-1BAD-333D-0D85A7384955}.Debug|Win32.Build.0 = Debug|Win32
+ {23142888-FECA-1BAD-333D-0D85A7384955}.Debug|x64.ActiveCfg = Debug|x64
+ {23142888-FECA-1BAD-333D-0D85A7384955}.Debug|x64.Build.0 = Debug|x64
+ {23142888-FECA-1BAD-333D-0D85A7384955}.Release|Win32.ActiveCfg = Release|Win32
+ {23142888-FECA-1BAD-333D-0D85A7384955}.Release|Win32.Build.0 = Release|Win32
+ {23142888-FECA-1BAD-333D-0D85A7384955}.Release|x64.ActiveCfg = Release|x64
+ {23142888-FECA-1BAD-333D-0D85A7384955}.Release|x64.Build.0 = Release|x64
+ {47F2CB3A-FECA-1BAD-6E59-A21D8A7389FD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {47F2CB3A-FECA-1BAD-6E59-A21D8A7389FD}.Debug|Win32.Build.0 = Debug|Win32
+ {47F2CB3A-FECA-1BAD-6E59-A21D8A7389FD}.Debug|x64.ActiveCfg = Debug|x64
+ {47F2CB3A-FECA-1BAD-6E59-A21D8A7389FD}.Debug|x64.Build.0 = Debug|x64
+ {47F2CB3A-FECA-1BAD-6E59-A21D8A7389FD}.Release|Win32.ActiveCfg = Release|Win32
+ {47F2CB3A-FECA-1BAD-6E59-A21D8A7389FD}.Release|Win32.Build.0 = Release|Win32
+ {47F2CB3A-FECA-1BAD-6E59-A21D8A7389FD}.Release|x64.ActiveCfg = Release|x64
+ {47F2CB3A-FECA-1BAD-6E59-A21D8A7389FD}.Release|x64.Build.0 = Release|x64
+ {7C92DBB0-FECA-1BAD-6E59-A21D8A7389FD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7C92DBB0-FECA-1BAD-6E59-A21D8A7389FD}.Debug|Win32.Build.0 = Debug|Win32
+ {7C92DBB0-FECA-1BAD-6E59-A21D8A7389FD}.Debug|x64.ActiveCfg = Debug|x64
+ {7C92DBB0-FECA-1BAD-6E59-A21D8A7389FD}.Debug|x64.Build.0 = Debug|x64
+ {7C92DBB0-FECA-1BAD-6E59-A21D8A7389FD}.Release|Win32.ActiveCfg = Release|Win32
+ {7C92DBB0-FECA-1BAD-6E59-A21D8A7389FD}.Release|Win32.Build.0 = Release|Win32
+ {7C92DBB0-FECA-1BAD-6E59-A21D8A7389FD}.Release|x64.ActiveCfg = Release|x64
+ {7C92DBB0-FECA-1BAD-6E59-A21D8A7389FD}.Release|x64.Build.0 = Release|x64
+ {CA061238-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CA061238-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
+ {CA061238-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
+ {CA061238-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
+ {CA061238-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
+ {CA061238-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
+ {CA061238-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
+ {CA061238-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
+ {725C36C9-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
+ {725C36C9-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
+ {725C36C9-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
+ {725C36C9-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
+ {725C36C9-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
+ {725C36C9-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
+ {725C36C9-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
+ {725C36C9-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
+ {A162739F-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A162739F-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
+ {A162739F-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
+ {A162739F-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
+ {A162739F-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
+ {A162739F-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
+ {A162739F-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
+ {A162739F-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
+ {15018119-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
+ {15018119-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
+ {15018119-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
+ {15018119-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
+ {15018119-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
+ {15018119-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
+ {15018119-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
+ {15018119-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
+ {AA12D010-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AA12D010-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
+ {AA12D010-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
+ {AA12D010-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
+ {AA12D010-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
+ {AA12D010-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
+ {AA12D010-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
+ {AA12D010-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
+ {B7501F54-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B7501F54-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
+ {B7501F54-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
+ {B7501F54-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
+ {B7501F54-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
+ {B7501F54-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
+ {B7501F54-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
+ {B7501F54-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
+ {5424A142-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5424A142-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
+ {5424A142-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
+ {5424A142-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
+ {5424A142-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
+ {5424A142-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
+ {5424A142-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
+ {5424A142-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
+ {5414A142-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5414A142-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
+ {5414A142-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
+ {5414A142-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
+ {5414A142-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
+ {5414A142-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
+ {5414A142-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
+ {5414A142-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
+ {9BE1FEA0-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9BE1FEA0-FECA-1BAD-FD25-A21D8A731A81}.Debug|Win32.Build.0 = Debug|Win32
+ {9BE1FEA0-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.ActiveCfg = Debug|x64
+ {9BE1FEA0-FECA-1BAD-FD25-A21D8A731A81}.Debug|x64.Build.0 = Debug|x64
+ {9BE1FEA0-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.ActiveCfg = Release|Win32
+ {9BE1FEA0-FECA-1BAD-FD25-A21D8A731A81}.Release|Win32.Build.0 = Release|Win32
+ {9BE1FEA0-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.ActiveCfg = Release|x64
+ {9BE1FEA0-FECA-1BAD-FD25-A21D8A731A81}.Release|x64.Build.0 = Release|x64
+ {F803EF29-FECA-1BAD-D1A8-860E7607F174}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F803EF29-FECA-1BAD-D1A8-860E7607F174}.Debug|Win32.Build.0 = Debug|Win32
+ {F803EF29-FECA-1BAD-D1A8-860E7607F174}.Debug|x64.ActiveCfg = Debug|x64
+ {F803EF29-FECA-1BAD-D1A8-860E7607F174}.Debug|x64.Build.0 = Debug|x64
+ {F803EF29-FECA-1BAD-D1A8-860E7607F174}.Release|Win32.ActiveCfg = Release|Win32
+ {F803EF29-FECA-1BAD-D1A8-860E7607F174}.Release|Win32.Build.0 = Release|Win32
+ {F803EF29-FECA-1BAD-D1A8-860E7607F174}.Release|x64.ActiveCfg = Release|x64
+ {F803EF29-FECA-1BAD-D1A8-860E7607F174}.Release|x64.Build.0 = Release|x64
+ {C363FFA3-FECA-1BAD-D1A8-860E7607F174}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C363FFA3-FECA-1BAD-D1A8-860E7607F174}.Debug|Win32.Build.0 = Debug|Win32
+ {C363FFA3-FECA-1BAD-D1A8-860E7607F174}.Debug|x64.ActiveCfg = Debug|x64
+ {C363FFA3-FECA-1BAD-D1A8-860E7607F174}.Debug|x64.Build.0 = Debug|x64
+ {C363FFA3-FECA-1BAD-D1A8-860E7607F174}.Release|Win32.ActiveCfg = Release|Win32
+ {C363FFA3-FECA-1BAD-D1A8-860E7607F174}.Release|Win32.Build.0 = Release|Win32
+ {C363FFA3-FECA-1BAD-D1A8-860E7607F174}.Release|x64.ActiveCfg = Release|x64
+ {C363FFA3-FECA-1BAD-D1A8-860E7607F174}.Release|x64.Build.0 = Release|x64
+ {EAB287E5-FECA-1BAD-EFA7-6773336A8585}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EAB287E5-FECA-1BAD-EFA7-6773336A8585}.Debug|Win32.Build.0 = Debug|Win32
+ {EAB287E5-FECA-1BAD-EFA7-6773336A8585}.Debug|x64.ActiveCfg = Debug|x64
+ {EAB287E5-FECA-1BAD-EFA7-6773336A8585}.Debug|x64.Build.0 = Debug|x64
+ {EAB287E5-FECA-1BAD-EFA7-6773336A8585}.Release|Win32.ActiveCfg = Release|Win32
+ {EAB287E5-FECA-1BAD-EFA7-6773336A8585}.Release|Win32.Build.0 = Release|Win32
+ {EAB287E5-FECA-1BAD-EFA7-6773336A8585}.Release|x64.ActiveCfg = Release|x64
+ {EAB287E5-FECA-1BAD-EFA7-6773336A8585}.Release|x64.Build.0 = Release|x64
+ {01AE9704-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {01AE9704-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
+ {01AE9704-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
+ {01AE9704-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
+ {01AE9704-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
+ {01AE9704-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
+ {01AE9704-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
+ {01AE9704-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
+ {9FC93C2D-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9FC93C2D-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
+ {9FC93C2D-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
+ {9FC93C2D-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
+ {9FC93C2D-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
+ {9FC93C2D-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
+ {9FC93C2D-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
+ {9FC93C2D-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
+ {FB3493EE-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FB3493EE-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
+ {FB3493EE-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
+ {FB3493EE-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
+ {FB3493EE-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
+ {FB3493EE-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
+ {FB3493EE-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
+ {FB3493EE-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
+ {52A8E79D-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {52A8E79D-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
+ {52A8E79D-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
+ {52A8E79D-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
+ {52A8E79D-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
+ {52A8E79D-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
+ {52A8E79D-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
+ {52A8E79D-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
+ {BA1F88DD-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BA1F88DD-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
+ {BA1F88DD-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
+ {BA1F88DD-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
+ {BA1F88DD-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
+ {BA1F88DD-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
+ {BA1F88DD-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
+ {BA1F88DD-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
+ {BA81302C-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BA81302C-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
+ {BA81302C-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
+ {BA81302C-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
+ {BA81302C-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
+ {BA81302C-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
+ {BA81302C-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
+ {BA81302C-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
+ {9A299D48-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9A299D48-FECA-1BAD-4285-FEF4D045C8F0}.Debug|Win32.Build.0 = Debug|Win32
+ {9A299D48-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.ActiveCfg = Debug|x64
+ {9A299D48-FECA-1BAD-4285-FEF4D045C8F0}.Debug|x64.Build.0 = Debug|x64
+ {9A299D48-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.ActiveCfg = Release|Win32
+ {9A299D48-FECA-1BAD-4285-FEF4D045C8F0}.Release|Win32.Build.0 = Release|Win32
+ {9A299D48-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.ActiveCfg = Release|x64
+ {9A299D48-FECA-1BAD-4285-FEF4D045C8F0}.Release|x64.Build.0 = Release|x64
+ {6E3E4773-FECA-1BAD-4795-2E5476BD3033}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6E3E4773-FECA-1BAD-4795-2E5476BD3033}.Debug|Win32.Build.0 = Debug|Win32
+ {6E3E4773-FECA-1BAD-4795-2E5476BD3033}.Debug|x64.ActiveCfg = Debug|x64
+ {6E3E4773-FECA-1BAD-4795-2E5476BD3033}.Debug|x64.Build.0 = Debug|x64
+ {6E3E4773-FECA-1BAD-4795-2E5476BD3033}.Release|Win32.ActiveCfg = Release|Win32
+ {6E3E4773-FECA-1BAD-4795-2E5476BD3033}.Release|Win32.Build.0 = Release|Win32
+ {6E3E4773-FECA-1BAD-4795-2E5476BD3033}.Release|x64.ActiveCfg = Release|x64
+ {6E3E4773-FECA-1BAD-4795-2E5476BD3033}.Release|x64.Build.0 = Release|x64
+ {555E57F9-FECA-1BAD-4795-2E5476BD3033}.Debug|Win32.ActiveCfg = Debug|Win32
+ {555E57F9-FECA-1BAD-4795-2E5476BD3033}.Debug|Win32.Build.0 = Debug|Win32
+ {555E57F9-FECA-1BAD-4795-2E5476BD3033}.Debug|x64.ActiveCfg = Debug|x64
+ {555E57F9-FECA-1BAD-4795-2E5476BD3033}.Debug|x64.Build.0 = Debug|x64
+ {555E57F9-FECA-1BAD-4795-2E5476BD3033}.Release|Win32.ActiveCfg = Release|Win32
+ {555E57F9-FECA-1BAD-4795-2E5476BD3033}.Release|Win32.Build.0 = Release|Win32
+ {555E57F9-FECA-1BAD-4795-2E5476BD3033}.Release|x64.ActiveCfg = Release|x64
+ {555E57F9-FECA-1BAD-4795-2E5476BD3033}.Release|x64.Build.0 = Release|x64
+ {17FB573A-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {17FB573A-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {17FB573A-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {17FB573A-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {17FB573A-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {17FB573A-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {17FB573A-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {17FB573A-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {429B09C3-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {429B09C3-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {429B09C3-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {429B09C3-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {429B09C3-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {429B09C3-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {429B09C3-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {429B09C3-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {D0378C08-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D0378C08-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {D0378C08-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {D0378C08-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {D0378C08-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {D0378C08-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {D0378C08-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {D0378C08-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {567A6CD0-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {567A6CD0-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {567A6CD0-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {567A6CD0-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {567A6CD0-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {567A6CD0-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {567A6CD0-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {567A6CD0-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {9F0B01D9-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9F0B01D9-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {9F0B01D9-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {9F0B01D9-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {9F0B01D9-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {9F0B01D9-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {9F0B01D9-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {9F0B01D9-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {DFE640AB-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DFE640AB-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {DFE640AB-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {DFE640AB-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {DFE640AB-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {DFE640AB-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {DFE640AB-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {DFE640AB-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {B6AE0B90-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B6AE0B90-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {B6AE0B90-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {B6AE0B90-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {B6AE0B90-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {B6AE0B90-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {B6AE0B90-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {B6AE0B90-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {EB8FF8F9-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EB8FF8F9-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {EB8FF8F9-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {EB8FF8F9-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {EB8FF8F9-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {EB8FF8F9-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {EB8FF8F9-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {EB8FF8F9-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {10F4AFD2-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {10F4AFD2-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {10F4AFD2-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {10F4AFD2-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {10F4AFD2-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {10F4AFD2-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {10F4AFD2-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {10F4AFD2-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {EA987F89-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EA987F89-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {EA987F89-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {EA987F89-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {EA987F89-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {EA987F89-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {EA987F89-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {EA987F89-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {2A170B07-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2A170B07-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {2A170B07-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {2A170B07-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {2A170B07-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {2A170B07-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {2A170B07-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {2A170B07-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {76DC5F1B-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {76DC5F1B-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {76DC5F1B-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {76DC5F1B-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {76DC5F1B-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {76DC5F1B-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {76DC5F1B-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {76DC5F1B-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {5A6E7EF4-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5A6E7EF4-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {5A6E7EF4-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {5A6E7EF4-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {5A6E7EF4-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {5A6E7EF4-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {5A6E7EF4-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {5A6E7EF4-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {B2D150A3-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B2D150A3-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {B2D150A3-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {B2D150A3-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {B2D150A3-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {B2D150A3-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {B2D150A3-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {B2D150A3-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {2EDA9FA3-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2EDA9FA3-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {2EDA9FA3-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {2EDA9FA3-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {2EDA9FA3-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {2EDA9FA3-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {2EDA9FA3-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {2EDA9FA3-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {81B72E19-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {81B72E19-FECA-1BAD-701A-2E512E45D4CA}.Debug|Win32.Build.0 = Debug|Win32
+ {81B72E19-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.ActiveCfg = Debug|x64
+ {81B72E19-FECA-1BAD-701A-2E512E45D4CA}.Debug|x64.Build.0 = Debug|x64
+ {81B72E19-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.ActiveCfg = Release|Win32
+ {81B72E19-FECA-1BAD-701A-2E512E45D4CA}.Release|Win32.Build.0 = Release|Win32
+ {81B72E19-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.ActiveCfg = Release|x64
+ {81B72E19-FECA-1BAD-701A-2E512E45D4CA}.Release|x64.Build.0 = Release|x64
+ {61316AEE-FECA-1BAD-435E-C97DA4B8E121}.Debug|Win32.ActiveCfg = Debug|Win32
+ {61316AEE-FECA-1BAD-435E-C97DA4B8E121}.Debug|Win32.Build.0 = Debug|Win32
+ {61316AEE-FECA-1BAD-435E-C97DA4B8E121}.Debug|x64.ActiveCfg = Debug|x64
+ {61316AEE-FECA-1BAD-435E-C97DA4B8E121}.Debug|x64.Build.0 = Debug|x64
+ {61316AEE-FECA-1BAD-435E-C97DA4B8E121}.Release|Win32.ActiveCfg = Release|Win32
+ {61316AEE-FECA-1BAD-435E-C97DA4B8E121}.Release|Win32.Build.0 = Release|Win32
+ {61316AEE-FECA-1BAD-435E-C97DA4B8E121}.Release|x64.ActiveCfg = Release|x64
+ {61316AEE-FECA-1BAD-435E-C97DA4B8E121}.Release|x64.Build.0 = Release|x64
+ {31E5B797-FECA-1BAD-435E-C97DA4B8E121}.Debug|Win32.ActiveCfg = Debug|Win32
+ {31E5B797-FECA-1BAD-435E-C97DA4B8E121}.Debug|Win32.Build.0 = Debug|Win32
+ {31E5B797-FECA-1BAD-435E-C97DA4B8E121}.Debug|x64.ActiveCfg = Debug|x64
+ {31E5B797-FECA-1BAD-435E-C97DA4B8E121}.Debug|x64.Build.0 = Debug|x64
+ {31E5B797-FECA-1BAD-435E-C97DA4B8E121}.Release|Win32.ActiveCfg = Release|Win32
+ {31E5B797-FECA-1BAD-435E-C97DA4B8E121}.Release|Win32.Build.0 = Release|Win32
+ {31E5B797-FECA-1BAD-435E-C97DA4B8E121}.Release|x64.ActiveCfg = Release|x64
+ {31E5B797-FECA-1BAD-435E-C97DA4B8E121}.Release|x64.Build.0 = Release|x64
+ {259D7266-FECA-1BAD-8172-3C0D10CCFC97}.Debug|Win32.ActiveCfg = Debug|Win32
+ {259D7266-FECA-1BAD-8172-3C0D10CCFC97}.Debug|Win32.Build.0 = Debug|Win32
+ {259D7266-FECA-1BAD-8172-3C0D10CCFC97}.Debug|x64.ActiveCfg = Debug|x64
+ {259D7266-FECA-1BAD-8172-3C0D10CCFC97}.Debug|x64.Build.0 = Debug|x64
+ {259D7266-FECA-1BAD-8172-3C0D10CCFC97}.Release|Win32.ActiveCfg = Release|Win32
+ {259D7266-FECA-1BAD-8172-3C0D10CCFC97}.Release|Win32.Build.0 = Release|Win32
+ {259D7266-FECA-1BAD-8172-3C0D10CCFC97}.Release|x64.ActiveCfg = Release|x64
+ {259D7266-FECA-1BAD-8172-3C0D10CCFC97}.Release|x64.Build.0 = Release|x64
+ {43B94101-FECA-1BAD-8172-3C0D10CCFC97}.Debug|Win32.ActiveCfg = Debug|Win32
+ {43B94101-FECA-1BAD-8172-3C0D10CCFC97}.Debug|Win32.Build.0 = Debug|Win32
+ {43B94101-FECA-1BAD-8172-3C0D10CCFC97}.Debug|x64.ActiveCfg = Debug|x64
+ {43B94101-FECA-1BAD-8172-3C0D10CCFC97}.Debug|x64.Build.0 = Debug|x64
+ {43B94101-FECA-1BAD-8172-3C0D10CCFC97}.Release|Win32.ActiveCfg = Release|Win32
+ {43B94101-FECA-1BAD-8172-3C0D10CCFC97}.Release|Win32.Build.0 = Release|Win32
+ {43B94101-FECA-1BAD-8172-3C0D10CCFC97}.Release|x64.ActiveCfg = Release|x64
+ {43B94101-FECA-1BAD-8172-3C0D10CCFC97}.Release|x64.Build.0 = Release|x64
+ {D97D0DAE-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D97D0DAE-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
+ {D97D0DAE-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
+ {D97D0DAE-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
+ {D97D0DAE-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
+ {D97D0DAE-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
+ {D97D0DAE-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
+ {D97D0DAE-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
+ {0C95901A-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0C95901A-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
+ {0C95901A-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
+ {0C95901A-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
+ {0C95901A-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
+ {0C95901A-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
+ {0C95901A-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
+ {0C95901A-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
+ {F5A6CA86-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F5A6CA86-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
+ {F5A6CA86-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
+ {F5A6CA86-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
+ {F5A6CA86-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
+ {F5A6CA86-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
+ {F5A6CA86-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
+ {F5A6CA86-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
+ {E306CA90-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E306CA90-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
+ {E306CA90-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
+ {E306CA90-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
+ {E306CA90-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
+ {E306CA90-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
+ {E306CA90-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
+ {E306CA90-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
+ {AD15917C-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AD15917C-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
+ {AD15917C-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
+ {AD15917C-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
+ {AD15917C-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
+ {AD15917C-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
+ {AD15917C-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
+ {AD15917C-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
+ {9DA02FCA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9DA02FCA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
+ {9DA02FCA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
+ {9DA02FCA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
+ {9DA02FCA-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
+ {9DA02FCA-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
+ {9DA02FCA-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
+ {9DA02FCA-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
+ {0D7F701A-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0D7F701A-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
+ {0D7F701A-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
+ {0D7F701A-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
+ {0D7F701A-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
+ {0D7F701A-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
+ {0D7F701A-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
+ {0D7F701A-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
+ {830E2FCA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {830E2FCA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
+ {830E2FCA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
+ {830E2FCA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
+ {830E2FCA-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
+ {830E2FCA-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
+ {830E2FCA-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
+ {830E2FCA-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
+ {7DEBC7DA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7DEBC7DA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
+ {7DEBC7DA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
+ {7DEBC7DA-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
+ {7DEBC7DA-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
+ {7DEBC7DA-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
+ {7DEBC7DA-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
+ {7DEBC7DA-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
+ {58DE56ED-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {58DE56ED-FECA-1BAD-DD12-8A69A8383EB6}.Debug|Win32.Build.0 = Debug|Win32
+ {58DE56ED-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.ActiveCfg = Debug|x64
+ {58DE56ED-FECA-1BAD-DD12-8A69A8383EB6}.Debug|x64.Build.0 = Debug|x64
+ {58DE56ED-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.ActiveCfg = Release|Win32
+ {58DE56ED-FECA-1BAD-DD12-8A69A8383EB6}.Release|Win32.Build.0 = Release|Win32
+ {58DE56ED-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.ActiveCfg = Release|x64
+ {58DE56ED-FECA-1BAD-DD12-8A69A8383EB6}.Release|x64.Build.0 = Release|x64
+ {AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00}.Debug|Win32.Build.0 = Debug|Win32
+ {AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00}.Debug|x64.ActiveCfg = Debug|x64
+ {AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00}.Debug|x64.Build.0 = Debug|x64
+ {AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00}.Release|Win32.ActiveCfg = Release|Win32
+ {AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00}.Release|Win32.Build.0 = Release|Win32
+ {AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00}.Release|x64.ActiveCfg = Release|x64
+ {AFEBBCD0-FECA-1BAD-7EA4-8B61A9309D00}.Release|x64.Build.0 = Release|x64
+ {36D2F548-FECA-1BAD-7EA4-8B61A9309D00}.Debug|Win32.ActiveCfg = Debug|Win32
+ {36D2F548-FECA-1BAD-7EA4-8B61A9309D00}.Debug|Win32.Build.0 = Debug|Win32
+ {36D2F548-FECA-1BAD-7EA4-8B61A9309D00}.Debug|x64.ActiveCfg = Debug|x64
+ {36D2F548-FECA-1BAD-7EA4-8B61A9309D00}.Debug|x64.Build.0 = Debug|x64
+ {36D2F548-FECA-1BAD-7EA4-8B61A9309D00}.Release|Win32.ActiveCfg = Release|Win32
+ {36D2F548-FECA-1BAD-7EA4-8B61A9309D00}.Release|Win32.Build.0 = Release|Win32
+ {36D2F548-FECA-1BAD-7EA4-8B61A9309D00}.Release|x64.ActiveCfg = Release|x64
+ {36D2F548-FECA-1BAD-7EA4-8B61A9309D00}.Release|x64.Build.0 = Release|x64
+ {14E0A6C5-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {14E0A6C5-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|Win32.Build.0 = Debug|Win32
+ {14E0A6C5-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|x64.ActiveCfg = Debug|x64
+ {14E0A6C5-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|x64.Build.0 = Debug|x64
+ {14E0A6C5-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|Win32.ActiveCfg = Release|Win32
+ {14E0A6C5-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|Win32.Build.0 = Release|Win32
+ {14E0A6C5-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|x64.ActiveCfg = Release|x64
+ {14E0A6C5-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|x64.Build.0 = Release|x64
+ {1C035593-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1C035593-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|Win32.Build.0 = Debug|Win32
+ {1C035593-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|x64.ActiveCfg = Debug|x64
+ {1C035593-FECA-1BAD-ECF7-1F18EF61CB2B}.Debug|x64.Build.0 = Debug|x64
+ {1C035593-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|Win32.ActiveCfg = Release|Win32
+ {1C035593-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|Win32.Build.0 = Release|Win32
+ {1C035593-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|x64.ActiveCfg = Release|x64
+ {1C035593-FECA-1BAD-ECF7-1F18EF61CB2B}.Release|x64.Build.0 = Release|x64
+ {AF1D8F89-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AF1D8F89-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.Build.0 = Debug|Win32
+ {AF1D8F89-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.ActiveCfg = Debug|x64
+ {AF1D8F89-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.Build.0 = Debug|x64
+ {AF1D8F89-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.ActiveCfg = Release|Win32
+ {AF1D8F89-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.Build.0 = Release|Win32
+ {AF1D8F89-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.ActiveCfg = Release|x64
+ {AF1D8F89-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.Build.0 = Release|x64
+ {49CD7F93-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {49CD7F93-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.Build.0 = Debug|Win32
+ {49CD7F93-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.ActiveCfg = Debug|x64
+ {49CD7F93-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.Build.0 = Debug|x64
+ {49CD7F93-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.ActiveCfg = Release|Win32
+ {49CD7F93-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.Build.0 = Release|Win32
+ {49CD7F93-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.ActiveCfg = Release|x64
+ {49CD7F93-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.Build.0 = Release|x64
+ {A479EB8C-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A479EB8C-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.Build.0 = Debug|Win32
+ {A479EB8C-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.ActiveCfg = Debug|x64
+ {A479EB8C-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.Build.0 = Debug|x64
+ {A479EB8C-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.ActiveCfg = Release|Win32
+ {A479EB8C-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.Build.0 = Release|Win32
+ {A479EB8C-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.ActiveCfg = Release|x64
+ {A479EB8C-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.Build.0 = Release|x64
+ {DDEDE8CF-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DDEDE8CF-FECA-1BAD-4CD2-91813C3C36BA}.Debug|Win32.Build.0 = Debug|Win32
+ {DDEDE8CF-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.ActiveCfg = Debug|x64
+ {DDEDE8CF-FECA-1BAD-4CD2-91813C3C36BA}.Debug|x64.Build.0 = Debug|x64
+ {DDEDE8CF-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.ActiveCfg = Release|Win32
+ {DDEDE8CF-FECA-1BAD-4CD2-91813C3C36BA}.Release|Win32.Build.0 = Release|Win32
+ {DDEDE8CF-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.ActiveCfg = Release|x64
+ {DDEDE8CF-FECA-1BAD-4CD2-91813C3C36BA}.Release|x64.Build.0 = Release|x64
+ {B2DA08F4-FECA-1BAD-5E18-91853C382470}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B2DA08F4-FECA-1BAD-5E18-91853C382470}.Debug|Win32.Build.0 = Debug|Win32
+ {B2DA08F4-FECA-1BAD-5E18-91853C382470}.Debug|x64.ActiveCfg = Debug|x64
+ {B2DA08F4-FECA-1BAD-5E18-91853C382470}.Debug|x64.Build.0 = Debug|x64
+ {B2DA08F4-FECA-1BAD-5E18-91853C382470}.Release|Win32.ActiveCfg = Release|Win32
+ {B2DA08F4-FECA-1BAD-5E18-91853C382470}.Release|Win32.Build.0 = Release|Win32
+ {B2DA08F4-FECA-1BAD-5E18-91853C382470}.Release|x64.ActiveCfg = Release|x64
+ {B2DA08F4-FECA-1BAD-5E18-91853C382470}.Release|x64.Build.0 = Release|x64
+ {AD6A08F4-FECA-1BAD-5E18-91853C382470}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AD6A08F4-FECA-1BAD-5E18-91853C382470}.Debug|Win32.Build.0 = Debug|Win32
+ {AD6A08F4-FECA-1BAD-5E18-91853C382470}.Debug|x64.ActiveCfg = Debug|x64
+ {AD6A08F4-FECA-1BAD-5E18-91853C382470}.Debug|x64.Build.0 = Debug|x64
+ {AD6A08F4-FECA-1BAD-5E18-91853C382470}.Release|Win32.ActiveCfg = Release|Win32
+ {AD6A08F4-FECA-1BAD-5E18-91853C382470}.Release|Win32.Build.0 = Release|Win32
+ {AD6A08F4-FECA-1BAD-5E18-91853C382470}.Release|x64.ActiveCfg = Release|x64
+ {AD6A08F4-FECA-1BAD-5E18-91853C382470}.Release|x64.Build.0 = Release|x64
+ {45E08B3B-FECA-1BAD-474B-E6C11145E1EB}.Debug|Win32.ActiveCfg = Debug|Win32
+ {45E08B3B-FECA-1BAD-474B-E6C11145E1EB}.Debug|Win32.Build.0 = Debug|Win32
+ {45E08B3B-FECA-1BAD-474B-E6C11145E1EB}.Debug|x64.ActiveCfg = Debug|x64
+ {45E08B3B-FECA-1BAD-474B-E6C11145E1EB}.Debug|x64.Build.0 = Debug|x64
+ {45E08B3B-FECA-1BAD-474B-E6C11145E1EB}.Release|Win32.ActiveCfg = Release|Win32
+ {45E08B3B-FECA-1BAD-474B-E6C11145E1EB}.Release|Win32.Build.0 = Release|Win32
+ {45E08B3B-FECA-1BAD-474B-E6C11145E1EB}.Release|x64.ActiveCfg = Release|x64
+ {45E08B3B-FECA-1BAD-474B-E6C11145E1EB}.Release|x64.Build.0 = Release|x64
+ {45E09BBB-FECA-1BAD-474B-E6C11145E1EB}.Debug|Win32.ActiveCfg = Debug|Win32
+ {45E09BBB-FECA-1BAD-474B-E6C11145E1EB}.Debug|Win32.Build.0 = Debug|Win32
+ {45E09BBB-FECA-1BAD-474B-E6C11145E1EB}.Debug|x64.ActiveCfg = Debug|x64
+ {45E09BBB-FECA-1BAD-474B-E6C11145E1EB}.Debug|x64.Build.0 = Debug|x64
+ {45E09BBB-FECA-1BAD-474B-E6C11145E1EB}.Release|Win32.ActiveCfg = Release|Win32
+ {45E09BBB-FECA-1BAD-474B-E6C11145E1EB}.Release|Win32.Build.0 = Release|Win32
+ {45E09BBB-FECA-1BAD-474B-E6C11145E1EB}.Release|x64.ActiveCfg = Release|x64
+ {45E09BBB-FECA-1BAD-474B-E6C11145E1EB}.Release|x64.Build.0 = Release|x64
+ {956C53A4-FECA-1BAD-F85A-8A37278A8232}.Debug|Win32.ActiveCfg = Debug|Win32
+ {956C53A4-FECA-1BAD-F85A-8A37278A8232}.Debug|Win32.Build.0 = Debug|Win32
+ {956C53A4-FECA-1BAD-F85A-8A37278A8232}.Debug|x64.ActiveCfg = Debug|x64
+ {956C53A4-FECA-1BAD-F85A-8A37278A8232}.Debug|x64.Build.0 = Debug|x64
+ {956C53A4-FECA-1BAD-F85A-8A37278A8232}.Release|Win32.ActiveCfg = Release|Win32
+ {956C53A4-FECA-1BAD-F85A-8A37278A8232}.Release|Win32.Build.0 = Release|Win32
+ {956C53A4-FECA-1BAD-F85A-8A37278A8232}.Release|x64.ActiveCfg = Release|x64
+ {956C53A4-FECA-1BAD-F85A-8A37278A8232}.Release|x64.Build.0 = Release|x64
+ {3135F524-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3135F524-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.Build.0 = Debug|Win32
+ {3135F524-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.ActiveCfg = Debug|x64
+ {3135F524-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.Build.0 = Debug|x64
+ {3135F524-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.ActiveCfg = Release|Win32
+ {3135F524-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.Build.0 = Release|Win32
+ {3135F524-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.ActiveCfg = Release|x64
+ {3135F524-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.Build.0 = Release|x64
+ {0A55E5AE-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0A55E5AE-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.Build.0 = Debug|Win32
+ {0A55E5AE-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.ActiveCfg = Debug|x64
+ {0A55E5AE-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.Build.0 = Debug|x64
+ {0A55E5AE-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.ActiveCfg = Release|Win32
+ {0A55E5AE-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.Build.0 = Release|Win32
+ {0A55E5AE-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.ActiveCfg = Release|x64
+ {0A55E5AE-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.Build.0 = Release|x64
+ {B8F98545-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B8F98545-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.Build.0 = Debug|Win32
+ {B8F98545-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.ActiveCfg = Debug|x64
+ {B8F98545-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.Build.0 = Debug|x64
+ {B8F98545-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.ActiveCfg = Release|Win32
+ {B8F98545-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.Build.0 = Release|Win32
+ {B8F98545-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.ActiveCfg = Release|x64
+ {B8F98545-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.Build.0 = Release|x64
+ {839995CF-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.ActiveCfg = Debug|Win32
+ {839995CF-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|Win32.Build.0 = Debug|Win32
+ {839995CF-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.ActiveCfg = Debug|x64
+ {839995CF-FECA-1BAD-6606-BBB2EAC4C36E}.Debug|x64.Build.0 = Debug|x64
+ {839995CF-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.ActiveCfg = Release|Win32
+ {839995CF-FECA-1BAD-6606-BBB2EAC4C36E}.Release|Win32.Build.0 = Release|Win32
+ {839995CF-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.ActiveCfg = Release|x64
+ {839995CF-FECA-1BAD-6606-BBB2EAC4C36E}.Release|x64.Build.0 = Release|x64
+ {479FDD0C-FECA-1BAD-BE72-3C5B13526565}.Debug|Win32.ActiveCfg = Debug|Win32
+ {479FDD0C-FECA-1BAD-BE72-3C5B13526565}.Debug|Win32.Build.0 = Debug|Win32
+ {479FDD0C-FECA-1BAD-BE72-3C5B13526565}.Debug|x64.ActiveCfg = Debug|x64
+ {479FDD0C-FECA-1BAD-BE72-3C5B13526565}.Debug|x64.Build.0 = Debug|x64
+ {479FDD0C-FECA-1BAD-BE72-3C5B13526565}.Release|Win32.ActiveCfg = Release|Win32
+ {479FDD0C-FECA-1BAD-BE72-3C5B13526565}.Release|Win32.Build.0 = Release|Win32
+ {479FDD0C-FECA-1BAD-BE72-3C5B13526565}.Release|x64.ActiveCfg = Release|x64
+ {479FDD0C-FECA-1BAD-BE72-3C5B13526565}.Release|x64.Build.0 = Release|x64
+ {47AFDD0C-FECA-1BAD-BE72-3C5B13526565}.Debug|Win32.ActiveCfg = Debug|Win32
+ {47AFDD0C-FECA-1BAD-BE72-3C5B13526565}.Debug|Win32.Build.0 = Debug|Win32
+ {47AFDD0C-FECA-1BAD-BE72-3C5B13526565}.Debug|x64.ActiveCfg = Debug|x64
+ {47AFDD0C-FECA-1BAD-BE72-3C5B13526565}.Debug|x64.Build.0 = Debug|x64
+ {47AFDD0C-FECA-1BAD-BE72-3C5B13526565}.Release|Win32.ActiveCfg = Release|Win32
+ {47AFDD0C-FECA-1BAD-BE72-3C5B13526565}.Release|Win32.Build.0 = Release|Win32
+ {47AFDD0C-FECA-1BAD-BE72-3C5B13526565}.Release|x64.ActiveCfg = Release|x64
+ {47AFDD0C-FECA-1BAD-BE72-3C5B13526565}.Release|x64.Build.0 = Release|x64
+ {CD7ACAFD-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CD7ACAFD-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {CD7ACAFD-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {CD7ACAFD-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {CD7ACAFD-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {CD7ACAFD-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {CD7ACAFD-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {CD7ACAFD-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {071AC793-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {071AC793-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {071AC793-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {071AC793-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {071AC793-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {071AC793-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {071AC793-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {071AC793-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {072AC793-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {072AC793-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {072AC793-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {072AC793-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {072AC793-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {072AC793-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {072AC793-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {072AC793-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {741AB167-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {741AB167-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {741AB167-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {741AB167-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {741AB167-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {741AB167-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {741AB167-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {741AB167-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {25926B9A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {25926B9A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {25926B9A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {25926B9A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {25926B9A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {25926B9A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {25926B9A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {25926B9A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {25A26B9A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {25A26B9A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {25A26B9A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {25A26B9A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {25A26B9A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {25A26B9A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {25A26B9A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {25A26B9A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {A4ACFB22-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A4ACFB22-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {A4ACFB22-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {A4ACFB22-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {A4ACFB22-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {A4ACFB22-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {A4ACFB22-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {A4ACFB22-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {E43B5212-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E43B5212-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {E43B5212-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {E43B5212-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {E43B5212-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {E43B5212-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {E43B5212-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {E43B5212-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {91B436D2-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {91B436D2-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {91B436D2-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {91B436D2-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {91B436D2-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {91B436D2-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {91B436D2-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {91B436D2-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {039899C9-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {039899C9-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {039899C9-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {039899C9-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {039899C9-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {039899C9-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {039899C9-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {039899C9-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {14E33148-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {14E33148-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {14E33148-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {14E33148-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {14E33148-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {14E33148-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {14E33148-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {14E33148-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {9FB54B28-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9FB54B28-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {9FB54B28-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {9FB54B28-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {9FB54B28-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {9FB54B28-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {9FB54B28-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {9FB54B28-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {FDC54B28-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FDC54B28-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {FDC54B28-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {FDC54B28-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {FDC54B28-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {FDC54B28-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {FDC54B28-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {FDC54B28-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {BE4CC737-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BE4CC737-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {BE4CC737-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {BE4CC737-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {BE4CC737-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {BE4CC737-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {BE4CC737-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {BE4CC737-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {A32D8BF2-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A32D8BF2-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {A32D8BF2-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {A32D8BF2-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {A32D8BF2-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {A32D8BF2-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {A32D8BF2-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {A32D8BF2-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {17ECC736-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {17ECC736-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {17ECC736-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {17ECC736-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {17ECC736-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {17ECC736-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {17ECC736-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {17ECC736-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {02E1116C-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {02E1116C-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {02E1116C-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {02E1116C-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {02E1116C-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {02E1116C-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {02E1116C-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {02E1116C-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {892C5422-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {892C5422-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {892C5422-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {892C5422-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {892C5422-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {892C5422-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {892C5422-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {892C5422-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {1D1735B4-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1D1735B4-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {1D1735B4-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {1D1735B4-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {1D1735B4-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {1D1735B4-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {1D1735B4-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {1D1735B4-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {807F39ED-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {807F39ED-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {807F39ED-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {807F39ED-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {807F39ED-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {807F39ED-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {807F39ED-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {807F39ED-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {A4CB601A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A4CB601A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {A4CB601A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {A4CB601A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {A4CB601A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {A4CB601A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {A4CB601A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {A4CB601A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {A4FB601A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A4FB601A-FECA-1BAD-3731-D8978C8E5D14}.Debug|Win32.Build.0 = Debug|Win32
+ {A4FB601A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.ActiveCfg = Debug|x64
+ {A4FB601A-FECA-1BAD-3731-D8978C8E5D14}.Debug|x64.Build.0 = Debug|x64
+ {A4FB601A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.ActiveCfg = Release|Win32
+ {A4FB601A-FECA-1BAD-3731-D8978C8E5D14}.Release|Win32.Build.0 = Release|Win32
+ {A4FB601A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.ActiveCfg = Release|x64
+ {A4FB601A-FECA-1BAD-3731-D8978C8E5D14}.Release|x64.Build.0 = Release|x64
+ {8ED0EFF5-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8ED0EFF5-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.Build.0 = Debug|Win32
+ {8ED0EFF5-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.ActiveCfg = Debug|x64
+ {8ED0EFF5-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.Build.0 = Debug|x64
+ {8ED0EFF5-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.ActiveCfg = Release|Win32
+ {8ED0EFF5-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.Build.0 = Release|Win32
+ {8ED0EFF5-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.ActiveCfg = Release|x64
+ {8ED0EFF5-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.Build.0 = Release|x64
+ {79C583D9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.ActiveCfg = Debug|Win32
+ {79C583D9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.Build.0 = Debug|Win32
+ {79C583D9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.ActiveCfg = Debug|x64
+ {79C583D9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.Build.0 = Debug|x64
+ {79C583D9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.ActiveCfg = Release|Win32
+ {79C583D9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.Build.0 = Release|Win32
+ {79C583D9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.ActiveCfg = Release|x64
+ {79C583D9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.Build.0 = Release|x64
+ {34746FF9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.ActiveCfg = Debug|Win32
+ {34746FF9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.Build.0 = Debug|Win32
+ {34746FF9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.ActiveCfg = Debug|x64
+ {34746FF9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.Build.0 = Debug|x64
+ {34746FF9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.ActiveCfg = Release|Win32
+ {34746FF9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.Build.0 = Release|Win32
+ {34746FF9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.ActiveCfg = Release|x64
+ {34746FF9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.Build.0 = Release|x64
+ {FAB2E9D1-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FAB2E9D1-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.Build.0 = Debug|Win32
+ {FAB2E9D1-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.ActiveCfg = Debug|x64
+ {FAB2E9D1-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.Build.0 = Debug|x64
+ {FAB2E9D1-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.ActiveCfg = Release|Win32
+ {FAB2E9D1-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.Build.0 = Release|Win32
+ {FAB2E9D1-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.ActiveCfg = Release|x64
+ {FAB2E9D1-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.Build.0 = Release|x64
+ {4767D3B9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4767D3B9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|Win32.Build.0 = Debug|Win32
+ {4767D3B9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.ActiveCfg = Debug|x64
+ {4767D3B9-FECA-1BAD-60CC-ADC54D81BEB4}.Debug|x64.Build.0 = Debug|x64
+ {4767D3B9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.ActiveCfg = Release|Win32
+ {4767D3B9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|Win32.Build.0 = Release|Win32
+ {4767D3B9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.ActiveCfg = Release|x64
+ {4767D3B9-FECA-1BAD-60CC-ADC54D81BEB4}.Release|x64.Build.0 = Release|x64
+ {A1B7128F-FECA-1BAD-4B17-3E25DE61956F}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A1B7128F-FECA-1BAD-4B17-3E25DE61956F}.Debug|Win32.Build.0 = Debug|Win32
+ {A1B7128F-FECA-1BAD-4B17-3E25DE61956F}.Debug|x64.ActiveCfg = Debug|x64
+ {A1B7128F-FECA-1BAD-4B17-3E25DE61956F}.Debug|x64.Build.0 = Debug|x64
+ {A1B7128F-FECA-1BAD-4B17-3E25DE61956F}.Release|Win32.ActiveCfg = Release|Win32
+ {A1B7128F-FECA-1BAD-4B17-3E25DE61956F}.Release|Win32.Build.0 = Release|Win32
+ {A1B7128F-FECA-1BAD-4B17-3E25DE61956F}.Release|x64.ActiveCfg = Release|x64
+ {A1B7128F-FECA-1BAD-4B17-3E25DE61956F}.Release|x64.Build.0 = Release|x64
+ {DC859D1E-FECA-1BAD-1120-8ECA0471D6B5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DC859D1E-FECA-1BAD-1120-8ECA0471D6B5}.Debug|Win32.Build.0 = Debug|Win32
+ {DC859D1E-FECA-1BAD-1120-8ECA0471D6B5}.Debug|x64.ActiveCfg = Debug|x64
+ {DC859D1E-FECA-1BAD-1120-8ECA0471D6B5}.Debug|x64.Build.0 = Debug|x64
+ {DC859D1E-FECA-1BAD-1120-8ECA0471D6B5}.Release|Win32.ActiveCfg = Release|Win32
+ {DC859D1E-FECA-1BAD-1120-8ECA0471D6B5}.Release|Win32.Build.0 = Release|Win32
+ {DC859D1E-FECA-1BAD-1120-8ECA0471D6B5}.Release|x64.ActiveCfg = Release|x64
+ {DC859D1E-FECA-1BAD-1120-8ECA0471D6B5}.Release|x64.Build.0 = Release|x64
+ {DCEA7D1E-FECA-1BAD-1120-8ECA0471D6B5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DCEA7D1E-FECA-1BAD-1120-8ECA0471D6B5}.Debug|Win32.Build.0 = Debug|Win32
+ {DCEA7D1E-FECA-1BAD-1120-8ECA0471D6B5}.Debug|x64.ActiveCfg = Debug|x64
+ {DCEA7D1E-FECA-1BAD-1120-8ECA0471D6B5}.Debug|x64.Build.0 = Debug|x64
+ {DCEA7D1E-FECA-1BAD-1120-8ECA0471D6B5}.Release|Win32.ActiveCfg = Release|Win32
+ {DCEA7D1E-FECA-1BAD-1120-8ECA0471D6B5}.Release|Win32.Build.0 = Release|Win32
+ {DCEA7D1E-FECA-1BAD-1120-8ECA0471D6B5}.Release|x64.ActiveCfg = Release|x64
+ {DCEA7D1E-FECA-1BAD-1120-8ECA0471D6B5}.Release|x64.Build.0 = Release|x64
+ {EC6BC326-FECA-1BAD-F396-8E392B1F0415}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EC6BC326-FECA-1BAD-F396-8E392B1F0415}.Debug|Win32.Build.0 = Debug|Win32
+ {EC6BC326-FECA-1BAD-F396-8E392B1F0415}.Debug|x64.ActiveCfg = Debug|x64
+ {EC6BC326-FECA-1BAD-F396-8E392B1F0415}.Debug|x64.Build.0 = Debug|x64
+ {EC6BC326-FECA-1BAD-F396-8E392B1F0415}.Release|Win32.ActiveCfg = Release|Win32
+ {EC6BC326-FECA-1BAD-F396-8E392B1F0415}.Release|Win32.Build.0 = Release|Win32
+ {EC6BC326-FECA-1BAD-F396-8E392B1F0415}.Release|x64.ActiveCfg = Release|x64
+ {EC6BC326-FECA-1BAD-F396-8E392B1F0415}.Release|x64.Build.0 = Release|x64
+ {8DA65252-FECA-1BAD-1BE2-2E43250F5E17}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8DA65252-FECA-1BAD-1BE2-2E43250F5E17}.Debug|Win32.Build.0 = Debug|Win32
+ {8DA65252-FECA-1BAD-1BE2-2E43250F5E17}.Debug|x64.ActiveCfg = Debug|x64
+ {8DA65252-FECA-1BAD-1BE2-2E43250F5E17}.Debug|x64.Build.0 = Debug|x64
+ {8DA65252-FECA-1BAD-1BE2-2E43250F5E17}.Release|Win32.ActiveCfg = Release|Win32
+ {8DA65252-FECA-1BAD-1BE2-2E43250F5E17}.Release|Win32.Build.0 = Release|Win32
+ {8DA65252-FECA-1BAD-1BE2-2E43250F5E17}.Release|x64.ActiveCfg = Release|x64
+ {8DA65252-FECA-1BAD-1BE2-2E43250F5E17}.Release|x64.Build.0 = Release|x64
+ {14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1}.Debug|Win32.ActiveCfg = Debug|Win32
+ {14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1}.Debug|Win32.Build.0 = Debug|Win32
+ {14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1}.Debug|x64.ActiveCfg = Debug|x64
+ {14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1}.Debug|x64.Build.0 = Debug|x64
+ {14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1}.Release|Win32.ActiveCfg = Release|Win32
+ {14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1}.Release|Win32.Build.0 = Release|Win32
+ {14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1}.Release|x64.ActiveCfg = Release|x64
+ {14DAD4DF-FECA-1BAD-6AF0-8A634041F2D1}.Release|x64.Build.0 = Release|x64
+ {528A9BED-FECA-1BAD-0251-FF46ED064212}.Debug|Win32.ActiveCfg = Debug|Win32
+ {528A9BED-FECA-1BAD-0251-FF46ED064212}.Debug|Win32.Build.0 = Debug|Win32
+ {528A9BED-FECA-1BAD-0251-FF46ED064212}.Debug|x64.ActiveCfg = Debug|x64
+ {528A9BED-FECA-1BAD-0251-FF46ED064212}.Debug|x64.Build.0 = Debug|x64
+ {528A9BED-FECA-1BAD-0251-FF46ED064212}.Release|Win32.ActiveCfg = Release|Win32
+ {528A9BED-FECA-1BAD-0251-FF46ED064212}.Release|Win32.Build.0 = Release|Win32
+ {528A9BED-FECA-1BAD-0251-FF46ED064212}.Release|x64.ActiveCfg = Release|x64
+ {528A9BED-FECA-1BAD-0251-FF46ED064212}.Release|x64.Build.0 = Release|x64
+ {80ED1E1B-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {80ED1E1B-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
+ {80ED1E1B-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
+ {80ED1E1B-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
+ {80ED1E1B-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
+ {80ED1E1B-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
+ {80ED1E1B-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
+ {80ED1E1B-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
+ {2A3225F8-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2A3225F8-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
+ {2A3225F8-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
+ {2A3225F8-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
+ {2A3225F8-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
+ {2A3225F8-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
+ {2A3225F8-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
+ {2A3225F8-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
+ {F387C138-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F387C138-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
+ {F387C138-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
+ {F387C138-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
+ {F387C138-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
+ {F387C138-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
+ {F387C138-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
+ {F387C138-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
+ {52C62293-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {52C62293-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
+ {52C62293-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
+ {52C62293-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
+ {52C62293-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
+ {52C62293-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
+ {52C62293-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
+ {52C62293-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
+ {D68CF3BE-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D68CF3BE-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
+ {D68CF3BE-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
+ {D68CF3BE-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
+ {D68CF3BE-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
+ {D68CF3BE-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
+ {D68CF3BE-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
+ {D68CF3BE-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
+ {904CF31F-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {904CF31F-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
+ {904CF31F-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
+ {904CF31F-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
+ {904CF31F-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
+ {904CF31F-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
+ {904CF31F-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
+ {904CF31F-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
+ {CA960BFA-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CA960BFA-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
+ {CA960BFA-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
+ {CA960BFA-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
+ {CA960BFA-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
+ {CA960BFA-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
+ {CA960BFA-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
+ {CA960BFA-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
+ {9D057569-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9D057569-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|Win32.Build.0 = Debug|Win32
+ {9D057569-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.ActiveCfg = Debug|x64
+ {9D057569-FECA-1BAD-BE51-8A67F3FC84F5}.Debug|x64.Build.0 = Debug|x64
+ {9D057569-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.ActiveCfg = Release|Win32
+ {9D057569-FECA-1BAD-BE51-8A67F3FC84F5}.Release|Win32.Build.0 = Release|Win32
+ {9D057569-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.ActiveCfg = Release|x64
+ {9D057569-FECA-1BAD-BE51-8A67F3FC84F5}.Release|x64.Build.0 = Release|x64
+ {95F3D6E2-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {95F3D6E2-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.Build.0 = Debug|Win32
+ {95F3D6E2-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.ActiveCfg = Debug|x64
+ {95F3D6E2-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.Build.0 = Debug|x64
+ {95F3D6E2-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.ActiveCfg = Release|Win32
+ {95F3D6E2-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.Build.0 = Release|Win32
+ {95F3D6E2-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.ActiveCfg = Release|x64
+ {95F3D6E2-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.Build.0 = Release|x64
+ {2E4FB39C-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2E4FB39C-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.Build.0 = Debug|Win32
+ {2E4FB39C-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.ActiveCfg = Debug|x64
+ {2E4FB39C-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.Build.0 = Debug|x64
+ {2E4FB39C-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.ActiveCfg = Release|Win32
+ {2E4FB39C-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.Build.0 = Release|Win32
+ {2E4FB39C-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.ActiveCfg = Release|x64
+ {2E4FB39C-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.Build.0 = Release|x64
+ {306FB39D-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {306FB39D-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.Build.0 = Debug|Win32
+ {306FB39D-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.ActiveCfg = Debug|x64
+ {306FB39D-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.Build.0 = Debug|x64
+ {306FB39D-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.ActiveCfg = Release|Win32
+ {306FB39D-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.Build.0 = Release|Win32
+ {306FB39D-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.ActiveCfg = Release|x64
+ {306FB39D-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.Build.0 = Release|x64
+ {8CE03849-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8CE03849-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.Build.0 = Debug|Win32
+ {8CE03849-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.ActiveCfg = Debug|x64
+ {8CE03849-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.Build.0 = Debug|x64
+ {8CE03849-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.ActiveCfg = Release|Win32
+ {8CE03849-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.Build.0 = Release|Win32
+ {8CE03849-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.ActiveCfg = Release|x64
+ {8CE03849-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.Build.0 = Release|x64
+ {92C03848-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {92C03848-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|Win32.Build.0 = Debug|Win32
+ {92C03848-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.ActiveCfg = Debug|x64
+ {92C03848-FECA-1BAD-7612-8A66F3FD4CB6}.Debug|x64.Build.0 = Debug|x64
+ {92C03848-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.ActiveCfg = Release|Win32
+ {92C03848-FECA-1BAD-7612-8A66F3FD4CB6}.Release|Win32.Build.0 = Release|Win32
+ {92C03848-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.ActiveCfg = Release|x64
+ {92C03848-FECA-1BAD-7612-8A66F3FD4CB6}.Release|x64.Build.0 = Release|x64
+ {A9A9AB6B-FECA-1BAD-FAD8-7885071DD3E2}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A9A9AB6B-FECA-1BAD-FAD8-7885071DD3E2}.Debug|Win32.Build.0 = Debug|Win32
+ {A9A9AB6B-FECA-1BAD-FAD8-7885071DD3E2}.Debug|x64.ActiveCfg = Debug|x64
+ {A9A9AB6B-FECA-1BAD-FAD8-7885071DD3E2}.Debug|x64.Build.0 = Debug|x64
+ {A9A9AB6B-FECA-1BAD-FAD8-7885071DD3E2}.Release|Win32.ActiveCfg = Release|Win32
+ {A9A9AB6B-FECA-1BAD-FAD8-7885071DD3E2}.Release|Win32.Build.0 = Release|Win32
+ {A9A9AB6B-FECA-1BAD-FAD8-7885071DD3E2}.Release|x64.ActiveCfg = Release|x64
+ {A9A9AB6B-FECA-1BAD-FAD8-7885071DD3E2}.Release|x64.Build.0 = Release|x64
+ {BD437884-FECA-1BAD-FAD8-7885071DD3E2}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BD437884-FECA-1BAD-FAD8-7885071DD3E2}.Debug|Win32.Build.0 = Debug|Win32
+ {BD437884-FECA-1BAD-FAD8-7885071DD3E2}.Debug|x64.ActiveCfg = Debug|x64
+ {BD437884-FECA-1BAD-FAD8-7885071DD3E2}.Debug|x64.Build.0 = Debug|x64
+ {BD437884-FECA-1BAD-FAD8-7885071DD3E2}.Release|Win32.ActiveCfg = Release|Win32
+ {BD437884-FECA-1BAD-FAD8-7885071DD3E2}.Release|Win32.Build.0 = Release|Win32
+ {BD437884-FECA-1BAD-FAD8-7885071DD3E2}.Release|x64.ActiveCfg = Release|x64
+ {BD437884-FECA-1BAD-FAD8-7885071DD3E2}.Release|x64.Build.0 = Release|x64
+ {561AAD86-FECA-1BAD-5029-42D0E18BA5D0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {561AAD86-FECA-1BAD-5029-42D0E18BA5D0}.Debug|Win32.Build.0 = Debug|Win32
+ {561AAD86-FECA-1BAD-5029-42D0E18BA5D0}.Debug|x64.ActiveCfg = Debug|x64
+ {561AAD86-FECA-1BAD-5029-42D0E18BA5D0}.Debug|x64.Build.0 = Debug|x64
+ {561AAD86-FECA-1BAD-5029-42D0E18BA5D0}.Release|Win32.ActiveCfg = Release|Win32
+ {561AAD86-FECA-1BAD-5029-42D0E18BA5D0}.Release|Win32.Build.0 = Release|Win32
+ {561AAD86-FECA-1BAD-5029-42D0E18BA5D0}.Release|x64.ActiveCfg = Release|x64
+ {561AAD86-FECA-1BAD-5029-42D0E18BA5D0}.Release|x64.Build.0 = Release|x64
+ {1250DDDE-FECA-1BAD-5029-42D0E18BA5D0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1250DDDE-FECA-1BAD-5029-42D0E18BA5D0}.Debug|Win32.Build.0 = Debug|Win32
+ {1250DDDE-FECA-1BAD-5029-42D0E18BA5D0}.Debug|x64.ActiveCfg = Debug|x64
+ {1250DDDE-FECA-1BAD-5029-42D0E18BA5D0}.Debug|x64.Build.0 = Debug|x64
+ {1250DDDE-FECA-1BAD-5029-42D0E18BA5D0}.Release|Win32.ActiveCfg = Release|Win32
+ {1250DDDE-FECA-1BAD-5029-42D0E18BA5D0}.Release|Win32.Build.0 = Release|Win32
+ {1250DDDE-FECA-1BAD-5029-42D0E18BA5D0}.Release|x64.ActiveCfg = Release|x64
+ {1250DDDE-FECA-1BAD-5029-42D0E18BA5D0}.Release|x64.Build.0 = Release|x64
+ {334CEDB1-FECA-1BAD-A238-81D6AD345D00}.Debug|Win32.ActiveCfg = Debug|Win32
+ {334CEDB1-FECA-1BAD-A238-81D6AD345D00}.Debug|Win32.Build.0 = Debug|Win32
+ {334CEDB1-FECA-1BAD-A238-81D6AD345D00}.Debug|x64.ActiveCfg = Debug|x64
+ {334CEDB1-FECA-1BAD-A238-81D6AD345D00}.Debug|x64.Build.0 = Debug|x64
+ {334CEDB1-FECA-1BAD-A238-81D6AD345D00}.Release|Win32.ActiveCfg = Release|Win32
+ {334CEDB1-FECA-1BAD-A238-81D6AD345D00}.Release|Win32.Build.0 = Release|Win32
+ {334CEDB1-FECA-1BAD-A238-81D6AD345D00}.Release|x64.ActiveCfg = Release|x64
+ {334CEDB1-FECA-1BAD-A238-81D6AD345D00}.Release|x64.Build.0 = Release|x64
+ {3268FEB1-FECA-1BAD-A22A-C0E6EC045D12}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3268FEB1-FECA-1BAD-A22A-C0E6EC045D12}.Debug|Win32.Build.0 = Debug|Win32
+ {3268FEB1-FECA-1BAD-A22A-C0E6EC045D12}.Debug|x64.ActiveCfg = Debug|x64
+ {3268FEB1-FECA-1BAD-A22A-C0E6EC045D12}.Debug|x64.Build.0 = Debug|x64
+ {3268FEB1-FECA-1BAD-A22A-C0E6EC045D12}.Release|Win32.ActiveCfg = Release|Win32
+ {3268FEB1-FECA-1BAD-A22A-C0E6EC045D12}.Release|Win32.Build.0 = Release|Win32
+ {3268FEB1-FECA-1BAD-A22A-C0E6EC045D12}.Release|x64.ActiveCfg = Release|x64
+ {3268FEB1-FECA-1BAD-A22A-C0E6EC045D12}.Release|x64.Build.0 = Release|x64
+ {E8B0F000-FECA-1BAD-BF87-400DF0C83E7D}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E8B0F000-FECA-1BAD-BF87-400DF0C83E7D}.Debug|Win32.Build.0 = Debug|Win32
+ {E8B0F000-FECA-1BAD-BF87-400DF0C83E7D}.Debug|x64.ActiveCfg = Debug|x64
+ {E8B0F000-FECA-1BAD-BF87-400DF0C83E7D}.Debug|x64.Build.0 = Debug|x64
+ {E8B0F000-FECA-1BAD-BF87-400DF0C83E7D}.Release|Win32.ActiveCfg = Release|Win32
+ {E8B0F000-FECA-1BAD-BF87-400DF0C83E7D}.Release|Win32.Build.0 = Release|Win32
+ {E8B0F000-FECA-1BAD-BF87-400DF0C83E7D}.Release|x64.ActiveCfg = Release|x64
+ {E8B0F000-FECA-1BAD-BF87-400DF0C83E7D}.Release|x64.Build.0 = Release|x64
+ {BA83D330-FECA-1BAD-3A9E-1C813063C5A6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BA83D330-FECA-1BAD-3A9E-1C813063C5A6}.Debug|Win32.Build.0 = Debug|Win32
+ {BA83D330-FECA-1BAD-3A9E-1C813063C5A6}.Debug|x64.ActiveCfg = Debug|x64
+ {BA83D330-FECA-1BAD-3A9E-1C813063C5A6}.Debug|x64.Build.0 = Debug|x64
+ {BA83D330-FECA-1BAD-3A9E-1C813063C5A6}.Release|Win32.ActiveCfg = Release|Win32
+ {BA83D330-FECA-1BAD-3A9E-1C813063C5A6}.Release|Win32.Build.0 = Release|Win32
+ {BA83D330-FECA-1BAD-3A9E-1C813063C5A6}.Release|x64.ActiveCfg = Release|x64
+ {BA83D330-FECA-1BAD-3A9E-1C813063C5A6}.Release|x64.Build.0 = Release|x64
+ {16EC56EE-FECA-1BAD-5062-8A636F3FD3CA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {16EC56EE-FECA-1BAD-5062-8A636F3FD3CA}.Debug|Win32.Build.0 = Debug|Win32
+ {16EC56EE-FECA-1BAD-5062-8A636F3FD3CA}.Debug|x64.ActiveCfg = Debug|x64
+ {16EC56EE-FECA-1BAD-5062-8A636F3FD3CA}.Debug|x64.Build.0 = Debug|x64
+ {16EC56EE-FECA-1BAD-5062-8A636F3FD3CA}.Release|Win32.ActiveCfg = Release|Win32
+ {16EC56EE-FECA-1BAD-5062-8A636F3FD3CA}.Release|Win32.Build.0 = Release|Win32
+ {16EC56EE-FECA-1BAD-5062-8A636F3FD3CA}.Release|x64.ActiveCfg = Release|x64
+ {16EC56EE-FECA-1BAD-5062-8A636F3FD3CA}.Release|x64.Build.0 = Release|x64
+ {01EC56EE-FECA-1BAD-5112-8A636F3FD2BA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {01EC56EE-FECA-1BAD-5112-8A636F3FD2BA}.Debug|Win32.Build.0 = Debug|Win32
+ {01EC56EE-FECA-1BAD-5112-8A636F3FD2BA}.Debug|x64.ActiveCfg = Debug|x64
+ {01EC56EE-FECA-1BAD-5112-8A636F3FD2BA}.Debug|x64.Build.0 = Debug|x64
+ {01EC56EE-FECA-1BAD-5112-8A636F3FD2BA}.Release|Win32.ActiveCfg = Release|Win32
+ {01EC56EE-FECA-1BAD-5112-8A636F3FD2BA}.Release|Win32.Build.0 = Release|Win32
+ {01EC56EE-FECA-1BAD-5112-8A636F3FD2BA}.Release|x64.ActiveCfg = Release|x64
+ {01EC56EE-FECA-1BAD-5112-8A636F3FD2BA}.Release|x64.Build.0 = Release|x64
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|Win32.ActiveCfg = Debug|Win32
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|Win32.Build.0 = Debug|Win32
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|x64.ActiveCfg = Debug|x64
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|x64.Build.0 = Debug|x64
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Release|Win32.ActiveCfg = Release|Win32
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Release|Win32.Build.0 = Release|Win32
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Release|x64.ActiveCfg = Release|x64
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Release|x64.Build.0 = Release|x64
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Debug|Win32.ActiveCfg = Debug|Win32
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Debug|Win32.Build.0 = Debug|Win32
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Debug|x64.ActiveCfg = Debug|x64
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Debug|x64.Build.0 = Debug|x64
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Release|Win32.ActiveCfg = Release|Win32
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Release|Win32.Build.0 = Release|Win32
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Release|x64.ActiveCfg = Release|x64
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Release|x64.Build.0 = Release|x64
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|Win32.ActiveCfg = Debug|Win32
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|Win32.Build.0 = Debug|Win32
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|x64.ActiveCfg = Debug|x64
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|x64.Build.0 = Debug|x64
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Release|Win32.ActiveCfg = Release|Win32
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Release|Win32.Build.0 = Release|Win32
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Release|x64.ActiveCfg = Release|x64
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Release|x64.Build.0 = Release|x64
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Debug|Win32.ActiveCfg = Debug|Win32
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Debug|Win32.Build.0 = Debug|Win32
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Debug|x64.ActiveCfg = Debug|x64
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Debug|x64.Build.0 = Debug|x64
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Release|Win32.ActiveCfg = Release|Win32
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Release|Win32.Build.0 = Release|Win32
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Release|x64.ActiveCfg = Release|x64
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Release|x64.Build.0 = Release|x64
+ {AC7EC723-FECA-1BAD-F826-8A6564C116DB}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AC7EC723-FECA-1BAD-F826-8A6564C116DB}.Debug|Win32.Build.0 = Debug|Win32
+ {AC7EC723-FECA-1BAD-F826-8A6564C116DB}.Debug|x64.ActiveCfg = Debug|x64
+ {AC7EC723-FECA-1BAD-F826-8A6564C116DB}.Debug|x64.Build.0 = Debug|x64
+ {AC7EC723-FECA-1BAD-F826-8A6564C116DB}.Release|Win32.ActiveCfg = Release|Win32
+ {AC7EC723-FECA-1BAD-F826-8A6564C116DB}.Release|Win32.Build.0 = Release|Win32
+ {AC7EC723-FECA-1BAD-F826-8A6564C116DB}.Release|x64.ActiveCfg = Release|x64
+ {AC7EC723-FECA-1BAD-F826-8A6564C116DB}.Release|x64.Build.0 = Release|x64
+ {AC37E723-FECA-1BAD-F826-8A6564C116DB}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AC37E723-FECA-1BAD-F826-8A6564C116DB}.Debug|Win32.Build.0 = Debug|Win32
+ {AC37E723-FECA-1BAD-F826-8A6564C116DB}.Debug|x64.ActiveCfg = Debug|x64
+ {AC37E723-FECA-1BAD-F826-8A6564C116DB}.Debug|x64.Build.0 = Debug|x64
+ {AC37E723-FECA-1BAD-F826-8A6564C116DB}.Release|Win32.ActiveCfg = Release|Win32
+ {AC37E723-FECA-1BAD-F826-8A6564C116DB}.Release|Win32.Build.0 = Release|Win32
+ {AC37E723-FECA-1BAD-F826-8A6564C116DB}.Release|x64.ActiveCfg = Release|x64
+ {AC37E723-FECA-1BAD-F826-8A6564C116DB}.Release|x64.Build.0 = Release|x64
+ {453BE26F-FECA-1BAD-BA50-D9E259FB2871}.Debug|Win32.ActiveCfg = Debug|Win32
+ {453BE26F-FECA-1BAD-BA50-D9E259FB2871}.Debug|Win32.Build.0 = Debug|Win32
+ {453BE26F-FECA-1BAD-BA50-D9E259FB2871}.Debug|x64.ActiveCfg = Debug|x64
+ {453BE26F-FECA-1BAD-BA50-D9E259FB2871}.Debug|x64.Build.0 = Debug|x64
+ {453BE26F-FECA-1BAD-BA50-D9E259FB2871}.Release|Win32.ActiveCfg = Release|Win32
+ {453BE26F-FECA-1BAD-BA50-D9E259FB2871}.Release|Win32.Build.0 = Release|Win32
+ {453BE26F-FECA-1BAD-BA50-D9E259FB2871}.Release|x64.ActiveCfg = Release|x64
+ {453BE26F-FECA-1BAD-BA50-D9E259FB2871}.Release|x64.Build.0 = Release|x64
+ {889BA052-FECA-1BAD-BA50-D9E259FB2871}.Debug|Win32.ActiveCfg = Debug|Win32
+ {889BA052-FECA-1BAD-BA50-D9E259FB2871}.Debug|Win32.Build.0 = Debug|Win32
+ {889BA052-FECA-1BAD-BA50-D9E259FB2871}.Debug|x64.ActiveCfg = Debug|x64
+ {889BA052-FECA-1BAD-BA50-D9E259FB2871}.Debug|x64.Build.0 = Debug|x64
+ {889BA052-FECA-1BAD-BA50-D9E259FB2871}.Release|Win32.ActiveCfg = Release|Win32
+ {889BA052-FECA-1BAD-BA50-D9E259FB2871}.Release|Win32.Build.0 = Release|Win32
+ {889BA052-FECA-1BAD-BA50-D9E259FB2871}.Release|x64.ActiveCfg = Release|x64
+ {889BA052-FECA-1BAD-BA50-D9E259FB2871}.Release|x64.Build.0 = Release|x64
+ {52CC1DD0-FECA-1BAD-B420-8ED027BFCEB0}.Debug|Win32.ActiveCfg = Debug|Win32
+ {52CC1DD0-FECA-1BAD-B420-8ED027BFCEB0}.Debug|Win32.Build.0 = Debug|Win32
+ {52CC1DD0-FECA-1BAD-B420-8ED027BFCEB0}.Debug|x64.ActiveCfg = Debug|x64
+ {52CC1DD0-FECA-1BAD-B420-8ED027BFCEB0}.Debug|x64.Build.0 = Debug|x64
+ {52CC1DD0-FECA-1BAD-B420-8ED027BFCEB0}.Release|Win32.ActiveCfg = Release|Win32
+ {52CC1DD0-FECA-1BAD-B420-8ED027BFCEB0}.Release|Win32.Build.0 = Release|Win32
+ {52CC1DD0-FECA-1BAD-B420-8ED027BFCEB0}.Release|x64.ActiveCfg = Release|x64
+ {52CC1DD0-FECA-1BAD-B420-8ED027BFCEB0}.Release|x64.Build.0 = Release|x64
+ {3AD864B2-FECA-1BAD-1373-0D9555D094CD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3AD864B2-FECA-1BAD-1373-0D9555D094CD}.Debug|Win32.Build.0 = Debug|Win32
+ {3AD864B2-FECA-1BAD-1373-0D9555D094CD}.Debug|x64.ActiveCfg = Debug|x64
+ {3AD864B2-FECA-1BAD-1373-0D9555D094CD}.Debug|x64.Build.0 = Debug|x64
+ {3AD864B2-FECA-1BAD-1373-0D9555D094CD}.Release|Win32.ActiveCfg = Release|Win32
+ {3AD864B2-FECA-1BAD-1373-0D9555D094CD}.Release|Win32.Build.0 = Release|Win32
+ {3AD864B2-FECA-1BAD-1373-0D9555D094CD}.Release|x64.ActiveCfg = Release|x64
+ {3AD864B2-FECA-1BAD-1373-0D9555D094CD}.Release|x64.Build.0 = Release|x64
+ {01B87438-FECA-1BAD-1373-0D9555D094CD}.Debug|Win32.ActiveCfg = Debug|Win32
+ {01B87438-FECA-1BAD-1373-0D9555D094CD}.Debug|Win32.Build.0 = Debug|Win32
+ {01B87438-FECA-1BAD-1373-0D9555D094CD}.Debug|x64.ActiveCfg = Debug|x64
+ {01B87438-FECA-1BAD-1373-0D9555D094CD}.Debug|x64.Build.0 = Debug|x64
+ {01B87438-FECA-1BAD-1373-0D9555D094CD}.Release|Win32.ActiveCfg = Release|Win32
+ {01B87438-FECA-1BAD-1373-0D9555D094CD}.Release|Win32.Build.0 = Release|Win32
+ {01B87438-FECA-1BAD-1373-0D9555D094CD}.Release|x64.ActiveCfg = Release|x64
+ {01B87438-FECA-1BAD-1373-0D9555D094CD}.Release|x64.Build.0 = Release|x64
+ {12448207-FECA-1BAD-3BEF-EB20432B4020}.Debug|Win32.ActiveCfg = Debug|Win32
+ {12448207-FECA-1BAD-3BEF-EB20432B4020}.Debug|Win32.Build.0 = Debug|Win32
+ {12448207-FECA-1BAD-3BEF-EB20432B4020}.Debug|x64.ActiveCfg = Debug|x64
+ {12448207-FECA-1BAD-3BEF-EB20432B4020}.Debug|x64.Build.0 = Debug|x64
+ {12448207-FECA-1BAD-3BEF-EB20432B4020}.Release|Win32.ActiveCfg = Release|Win32
+ {12448207-FECA-1BAD-3BEF-EB20432B4020}.Release|Win32.Build.0 = Release|Win32
+ {12448207-FECA-1BAD-3BEF-EB20432B4020}.Release|x64.ActiveCfg = Release|x64
+ {12448207-FECA-1BAD-3BEF-EB20432B4020}.Release|x64.Build.0 = Release|x64
+ {2924928D-FECA-1BAD-3BEF-EB20432B4020}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2924928D-FECA-1BAD-3BEF-EB20432B4020}.Debug|Win32.Build.0 = Debug|Win32
+ {2924928D-FECA-1BAD-3BEF-EB20432B4020}.Debug|x64.ActiveCfg = Debug|x64
+ {2924928D-FECA-1BAD-3BEF-EB20432B4020}.Debug|x64.Build.0 = Debug|x64
+ {2924928D-FECA-1BAD-3BEF-EB20432B4020}.Release|Win32.ActiveCfg = Release|Win32
+ {2924928D-FECA-1BAD-3BEF-EB20432B4020}.Release|Win32.Build.0 = Release|Win32
+ {2924928D-FECA-1BAD-3BEF-EB20432B4020}.Release|x64.ActiveCfg = Release|x64
+ {2924928D-FECA-1BAD-3BEF-EB20432B4020}.Release|x64.Build.0 = Release|x64
+ {33F9D72B-FECA-1BAD-1A52-BE0C301D82A2}.Debug|Win32.ActiveCfg = Debug|Win32
+ {33F9D72B-FECA-1BAD-1A52-BE0C301D82A2}.Debug|Win32.Build.0 = Debug|Win32
+ {33F9D72B-FECA-1BAD-1A52-BE0C301D82A2}.Debug|x64.ActiveCfg = Debug|x64
+ {33F9D72B-FECA-1BAD-1A52-BE0C301D82A2}.Debug|x64.Build.0 = Debug|x64
+ {33F9D72B-FECA-1BAD-1A52-BE0C301D82A2}.Release|Win32.ActiveCfg = Release|Win32
+ {33F9D72B-FECA-1BAD-1A52-BE0C301D82A2}.Release|Win32.Build.0 = Release|Win32
+ {33F9D72B-FECA-1BAD-1A52-BE0C301D82A2}.Release|x64.ActiveCfg = Release|x64
+ {33F9D72B-FECA-1BAD-1A52-BE0C301D82A2}.Release|x64.Build.0 = Release|x64
+ {0899C7A1-FECA-1BAD-1A52-BE0C301D82A2}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0899C7A1-FECA-1BAD-1A52-BE0C301D82A2}.Debug|Win32.Build.0 = Debug|Win32
+ {0899C7A1-FECA-1BAD-1A52-BE0C301D82A2}.Debug|x64.ActiveCfg = Debug|x64
+ {0899C7A1-FECA-1BAD-1A52-BE0C301D82A2}.Debug|x64.Build.0 = Debug|x64
+ {0899C7A1-FECA-1BAD-1A52-BE0C301D82A2}.Release|Win32.ActiveCfg = Release|Win32
+ {0899C7A1-FECA-1BAD-1A52-BE0C301D82A2}.Release|Win32.Build.0 = Release|Win32
+ {0899C7A1-FECA-1BAD-1A52-BE0C301D82A2}.Release|x64.ActiveCfg = Release|x64
+ {0899C7A1-FECA-1BAD-1A52-BE0C301D82A2}.Release|x64.Build.0 = Release|x64
+ {462EE341-FECA-1BAD-6F85-8A64CD2507FC}.Debug|Win32.ActiveCfg = Debug|Win32
+ {462EE341-FECA-1BAD-6F85-8A64CD2507FC}.Debug|Win32.Build.0 = Debug|Win32
+ {462EE341-FECA-1BAD-6F85-8A64CD2507FC}.Debug|x64.ActiveCfg = Debug|x64
+ {462EE341-FECA-1BAD-6F85-8A64CD2507FC}.Debug|x64.Build.0 = Debug|x64
+ {462EE341-FECA-1BAD-6F85-8A64CD2507FC}.Release|Win32.ActiveCfg = Release|Win32
+ {462EE341-FECA-1BAD-6F85-8A64CD2507FC}.Release|Win32.Build.0 = Release|Win32
+ {462EE341-FECA-1BAD-6F85-8A64CD2507FC}.Release|x64.ActiveCfg = Release|x64
+ {462EE341-FECA-1BAD-6F85-8A64CD2507FC}.Release|x64.Build.0 = Release|x64
+ {7D4EF3CB-FECA-1BAD-6F85-8A64CD2507FC}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7D4EF3CB-FECA-1BAD-6F85-8A64CD2507FC}.Debug|Win32.Build.0 = Debug|Win32
+ {7D4EF3CB-FECA-1BAD-6F85-8A64CD2507FC}.Debug|x64.ActiveCfg = Debug|x64
+ {7D4EF3CB-FECA-1BAD-6F85-8A64CD2507FC}.Debug|x64.Build.0 = Debug|x64
+ {7D4EF3CB-FECA-1BAD-6F85-8A64CD2507FC}.Release|Win32.ActiveCfg = Release|Win32
+ {7D4EF3CB-FECA-1BAD-6F85-8A64CD2507FC}.Release|Win32.Build.0 = Release|Win32
+ {7D4EF3CB-FECA-1BAD-6F85-8A64CD2507FC}.Release|x64.ActiveCfg = Release|x64
+ {7D4EF3CB-FECA-1BAD-6F85-8A64CD2507FC}.Release|x64.Build.0 = Release|x64
+ {02AC1EF0-FECA-1BAD-2246-8A6466E9CA6C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {02AC1EF0-FECA-1BAD-2246-8A6466E9CA6C}.Debug|Win32.Build.0 = Debug|Win32
+ {02AC1EF0-FECA-1BAD-2246-8A6466E9CA6C}.Debug|x64.ActiveCfg = Debug|x64
+ {02AC1EF0-FECA-1BAD-2246-8A6466E9CA6C}.Debug|x64.Build.0 = Debug|x64
+ {02AC1EF0-FECA-1BAD-2246-8A6466E9CA6C}.Release|Win32.ActiveCfg = Release|Win32
+ {02AC1EF0-FECA-1BAD-2246-8A6466E9CA6C}.Release|Win32.Build.0 = Release|Win32
+ {02AC1EF0-FECA-1BAD-2246-8A6466E9CA6C}.Release|x64.ActiveCfg = Release|x64
+ {02AC1EF0-FECA-1BAD-2246-8A6466E9CA6C}.Release|x64.Build.0 = Release|x64
+ {536D0A83-FECA-1BAD-5646-8F0A8605F692}.Debug|Win32.ActiveCfg = Debug|Win32
+ {536D0A83-FECA-1BAD-5646-8F0A8605F692}.Debug|Win32.Build.0 = Debug|Win32
+ {536D0A83-FECA-1BAD-5646-8F0A8605F692}.Debug|x64.ActiveCfg = Debug|x64
+ {536D0A83-FECA-1BAD-5646-8F0A8605F692}.Debug|x64.Build.0 = Debug|x64
+ {536D0A83-FECA-1BAD-5646-8F0A8605F692}.Release|Win32.ActiveCfg = Release|Win32
+ {536D0A83-FECA-1BAD-5646-8F0A8605F692}.Release|Win32.Build.0 = Release|Win32
+ {536D0A83-FECA-1BAD-5646-8F0A8605F692}.Release|x64.ActiveCfg = Release|x64
+ {536D0A83-FECA-1BAD-5646-8F0A8605F692}.Release|x64.Build.0 = Release|x64
+ {648DF6BA-FECA-1BAD-5646-8F0A8605F692}.Debug|Win32.ActiveCfg = Debug|Win32
+ {648DF6BA-FECA-1BAD-5646-8F0A8605F692}.Debug|Win32.Build.0 = Debug|Win32
+ {648DF6BA-FECA-1BAD-5646-8F0A8605F692}.Debug|x64.ActiveCfg = Debug|x64
+ {648DF6BA-FECA-1BAD-5646-8F0A8605F692}.Debug|x64.Build.0 = Debug|x64
+ {648DF6BA-FECA-1BAD-5646-8F0A8605F692}.Release|Win32.ActiveCfg = Release|Win32
+ {648DF6BA-FECA-1BAD-5646-8F0A8605F692}.Release|Win32.Build.0 = Release|Win32
+ {648DF6BA-FECA-1BAD-5646-8F0A8605F692}.Release|x64.ActiveCfg = Release|x64
+ {648DF6BA-FECA-1BAD-5646-8F0A8605F692}.Release|x64.Build.0 = Release|x64
+ {34E92649-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {34E92649-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {34E92649-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {34E92649-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {34E92649-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {34E92649-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {34E92649-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {34E92649-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {30EA7549-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {30EA7549-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {30EA7549-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {30EA7549-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {30EA7549-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {30EA7549-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {30EA7549-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {30EA7549-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {52DBB423-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {52DBB423-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {52DBB423-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {52DBB423-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {52DBB423-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {52DBB423-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {52DBB423-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {52DBB423-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {DBF833EC-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DBF833EC-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {DBF833EC-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {DBF833EC-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {DBF833EC-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {DBF833EC-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {DBF833EC-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {DBF833EC-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5817751D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5817751D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5817751D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5817751D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5817751D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5817751D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5817751D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5817751D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {8BC79560-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8BC79560-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {8BC79560-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {8BC79560-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {8BC79560-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {8BC79560-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {8BC79560-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {8BC79560-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {86ABA563-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {86ABA563-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {86ABA563-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {86ABA563-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {86ABA563-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {86ABA563-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {86ABA563-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {86ABA563-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {CC9842E2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CC9842E2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {CC9842E2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {CC9842E2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {CC9842E2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {CC9842E2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {CC9842E2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {CC9842E2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {51E3710D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {51E3710D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {51E3710D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {51E3710D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {51E3710D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {51E3710D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {51E3710D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {51E3710D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {A9C8A907-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A9C8A907-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {A9C8A907-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {A9C8A907-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {A9C8A907-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {A9C8A907-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {A9C8A907-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {A9C8A907-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {EF5B40EF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EF5B40EF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {EF5B40EF-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {EF5B40EF-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {EF5B40EF-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {EF5B40EF-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {EF5B40EF-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {EF5B40EF-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {970E15BF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {970E15BF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {970E15BF-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {970E15BF-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {970E15BF-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {970E15BF-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {970E15BF-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {970E15BF-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B50B25CA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B50B25CA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B50B25CA-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B50B25CA-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B50B25CA-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B50B25CA-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B50B25CA-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B50B25CA-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {32DF2C33-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {32DF2C33-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {32DF2C33-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {32DF2C33-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {32DF2C33-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {32DF2C33-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {32DF2C33-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {32DF2C33-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {748CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {748CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {748CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {748CBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {748CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {748CBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {748CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {748CBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {AAECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AAECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {AAECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {AAECBC8F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {AAECBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {AAECBC8F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {AAECBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {AAECBC8F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {156CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {156CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {156CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {156CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {156CBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {156CBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {156CBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {156CBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {60ACBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {60ACBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {60ACBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {60ACBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {60ACBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {60ACBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {60ACBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {60ACBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {6A9CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6A9CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {6A9CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {6A9CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {6A9CBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {6A9CBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {6A9CBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {6A9CBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {77ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {77ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {77ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {77ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {77ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {77ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {77ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {77ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {437CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {437CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {437CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {437CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {437CBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {437CBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {437CBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {437CBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {42ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {42ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {42ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {42ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {42ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {42ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {42ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {46DCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {46DCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {46DCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {46DCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {46DCBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {46DCBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {46DCBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {46DCBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {467CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {467CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {467CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {467CBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {467CBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {467CBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {467CBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {467CBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {57ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {57ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {57ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {57ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {57ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {57ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {57ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {57ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {54CCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {54CCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {54CCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {54CCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {54CCBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {54CCBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {54CCBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {54CCBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {A2BCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A2BCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {A2BCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {A2BCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {A2BCBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {A2BCBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {A2BCBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {A2BCBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {A1ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A1ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {A1ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {A1ECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {A1ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {A1ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {A1ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {A1ECBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B4BCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B4BCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B4BCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B4BCBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B4BCBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B4BCBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B4BCBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B4BCBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {62D8584C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {62D8584C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {62D8584C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {62D8584C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {62D8584C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {62D8584C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {62D8584C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {62D8584C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {BBECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BBECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {BBECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {BBECBC8C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {BBECBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {BBECBC8C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {BBECBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {BBECBC8C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {33CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {33CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {33CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {33CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {33CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {33CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {33CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {33CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {127CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {127CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {127CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {127CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {127CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {127CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {127CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {127CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {10CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {10CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {10CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {10CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {10CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {10CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {10CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {10CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {10ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {10ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {10ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {10ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {10ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {10ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {10ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {10ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {60CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {60CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {60CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {60CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {60CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {60CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {60CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {60CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {73ECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {73ECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {73ECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {73ECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {73ECBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {73ECBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {73ECBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {73ECBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {73BCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {73BCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {73BCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {73BCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {73BCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {73BCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {73BCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {73BCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {70CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {70CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {70CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {70CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {70CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {70CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {70CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {70CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {707CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {707CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {707CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {707CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {707CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {707CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {707CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {707CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {77FCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {77FCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {77FCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {77FCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {77FCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {77FCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {77FCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {77FCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {44DCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {44DCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {44DCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {44DCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {44DCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {44DCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {44DCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {44DCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {537CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {537CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {537CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {537CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {537CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {537CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {537CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {537CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {52ECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {52ECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {52ECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {52ECBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {52ECBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {52ECBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {52ECBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {52ECBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {517CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {517CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {517CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {517CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {517CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {517CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {517CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {517CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {57ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {57ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {57ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {57ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {57ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {57ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {57ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {57ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {566CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {566CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {566CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {566CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {566CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {566CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {566CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {566CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {A46CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A46CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {A46CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {A46CBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {A46CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {A46CBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {A46CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {A46CBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B2FCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B2FCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B2FCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B2FCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B2FCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B2FCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B2FCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B2FCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B2CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B2CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B2CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B2CCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B2CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B2CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B2CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B2CCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B7DCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B7DCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B7DCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B7DCBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B7DCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B7DCBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B7DCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B7DCBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B4ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B4ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B4ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B4ACBC8D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B4ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B4ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B4ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B4ACBC8D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {26BCBC8A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {26BCBC8A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {26BCBC8A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {26BCBC8A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {26BCBC8A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {26BCBC8A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {26BCBC8A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {26BCBC8A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {82F87D5E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {82F87D5E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {82F87D5E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {82F87D5E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {82F87D5E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {82F87D5E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {82F87D5E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {82F87D5E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {4FA3F238-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4FA3F238-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {4FA3F238-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {4FA3F238-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {4FA3F238-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {4FA3F238-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {4FA3F238-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {4FA3F238-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {34EB4149-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {34EB4149-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {34EB4149-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {34EB4149-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {34EB4149-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {34EB4149-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {34EB4149-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {34EB4149-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {AC665187-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AC665187-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {AC665187-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {AC665187-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {AC665187-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {AC665187-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {AC665187-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {AC665187-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {1E46DF30-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1E46DF30-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {1E46DF30-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {1E46DF30-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {1E46DF30-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {1E46DF30-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {1E46DF30-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {1E46DF30-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {FFFF62B4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FFFF62B4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {FFFF62B4-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {FFFF62B4-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {FFFF62B4-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {FFFF62B4-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {FFFF62B4-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {FFFF62B4-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {2FB0A8AA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2FB0A8AA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {2FB0A8AA-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {2FB0A8AA-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {2FB0A8AA-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {2FB0A8AA-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {2FB0A8AA-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {2FB0A8AA-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {9ED51706-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9ED51706-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {9ED51706-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {9ED51706-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {9ED51706-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {9ED51706-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {9ED51706-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {9ED51706-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {6D8F104D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6D8F104D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {6D8F104D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {6D8F104D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {6D8F104D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {6D8F104D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {6D8F104D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {6D8F104D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {008794E3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {008794E3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {008794E3-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {008794E3-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {008794E3-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {008794E3-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {008794E3-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {008794E3-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529F281-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529F281-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529F281-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529F281-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529F281-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529F281-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529F281-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529F281-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529F181-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529F181-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529F181-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529F181-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529F181-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529F181-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529F181-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529F181-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529F081-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529F081-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529F081-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529F081-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529F081-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529F081-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529F081-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529F081-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529F781-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529F781-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529F781-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529F781-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529F781-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529F781-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529F781-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529F781-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529F681-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529F681-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529F681-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529F681-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529F681-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529F681-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529F681-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529F681-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529F581-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529F581-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529F581-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529F581-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529F581-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529F581-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529F581-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529F581-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529F481-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529F481-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529F481-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529F481-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529F481-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529F481-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529F481-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529F481-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529FA81-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529FA81-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529FA81-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529FA81-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529FA81-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529FA81-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529FA81-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529FA81-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529E381-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529E381-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529E381-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529E381-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529E381-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529E381-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529E381-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529E381-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529E281-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529E281-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529E281-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529E281-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529E281-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529E281-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529E281-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529E281-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529E181-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529E181-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529E181-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529E181-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529E181-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529E181-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529E181-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529E181-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529E081-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529E081-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529E081-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529E081-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529E081-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529E081-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529E081-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529E081-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529E781-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529E781-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529E781-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529E781-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529E781-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529E781-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529E781-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529E781-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529E681-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529E681-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529E681-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529E681-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529E681-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529E681-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529E681-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529E681-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529E581-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529E581-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529E581-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529E581-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529E581-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529E581-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529E581-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529E581-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529E481-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529E481-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529E481-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529E481-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529E481-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529E481-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529E481-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529E481-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529EB81-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529EB81-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529EB81-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529EB81-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529EB81-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529EB81-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529EB81-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529EB81-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529EA81-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529EA81-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529EA81-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529EA81-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529EA81-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529EA81-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529EA81-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529EA81-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529D381-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529D381-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529D381-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529D381-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529D381-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529D381-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529D381-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529D381-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529D281-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529D281-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529D281-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529D281-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529D281-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529D281-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529D281-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529D281-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529D181-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529D181-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529D181-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529D181-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529D181-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529D181-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529D181-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529D181-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529D081-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529D081-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529D081-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529D081-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529D081-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529D081-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529D081-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529D081-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529D781-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529D781-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529D781-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529D781-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529D781-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529D781-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529D781-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529D781-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529D681-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529D681-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529D681-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529D681-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529D681-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529D681-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529D681-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529D681-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529D581-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529D581-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529D581-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529D581-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529D581-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529D581-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529D581-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529D581-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529D481-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529D481-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529D481-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529D481-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529D481-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529D481-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529D481-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529D481-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529DB81-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529DB81-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529DB81-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529DB81-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529DB81-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529DB81-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529DB81-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529DB81-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529DA81-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529DA81-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529DA81-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529DA81-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529DA81-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529DA81-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529DA81-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529DA81-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529C281-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529C281-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529C281-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529C281-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529C281-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529C281-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529C281-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529C281-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529C181-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529C181-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529C181-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529C181-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529C181-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529C181-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529C181-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529C181-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529C081-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529C081-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529C081-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529C081-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529C081-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529C081-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529C081-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529C081-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529C781-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529C781-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529C781-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529C781-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529C781-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529C781-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529C781-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529C781-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5529C681-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5529C681-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5529C681-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5529C681-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5529C681-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5529C681-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5529C681-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5529C681-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {6D2CA44D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6D2CA44D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {6D2CA44D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {6D2CA44D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {6D2CA44D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {6D2CA44D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {6D2CA44D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {6D2CA44D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {30F5DD49-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {30F5DD49-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {30F5DD49-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {30F5DD49-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {30F5DD49-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {30F5DD49-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {30F5DD49-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {30F5DD49-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {366E72B0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {366E72B0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {366E72B0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {366E72B0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {366E72B0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {366E72B0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {366E72B0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {366E72B0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {11324DB5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {11324DB5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {11324DB5-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {11324DB5-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {11324DB5-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {11324DB5-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {11324DB5-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {11324DB5-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {34ECDF49-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {34ECDF49-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {34ECDF49-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {34ECDF49-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {34ECDF49-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {34ECDF49-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {34ECDF49-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {34ECDF49-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {3C02174D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3C02174D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {3C02174D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {3C02174D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {3C02174D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {3C02174D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {3C02174D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {3C02174D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {3E83A42B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3E83A42B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {3E83A42B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {3E83A42B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {3E83A42B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {3E83A42B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {3E83A42B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {3E83A42B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {39877CCF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {39877CCF-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {39877CCF-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {39877CCF-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {39877CCF-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {39877CCF-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {39877CCF-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {39877CCF-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {1AEFC74D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1AEFC74D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {1AEFC74D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {1AEFC74D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {1AEFC74D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {1AEFC74D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {1AEFC74D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {1AEFC74D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {4B5D0402-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4B5D0402-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {4B5D0402-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {4B5D0402-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {4B5D0402-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {4B5D0402-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {4B5D0402-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {4B5D0402-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {CCD7A00A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CCD7A00A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {CCD7A00A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {CCD7A00A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {CCD7A00A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {CCD7A00A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {CCD7A00A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {CCD7A00A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {E7528928-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E7528928-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {E7528928-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {E7528928-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {E7528928-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {E7528928-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {E7528928-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {E7528928-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {94D725DA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {94D725DA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {94D725DA-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {94D725DA-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {94D725DA-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {94D725DA-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {94D725DA-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {94D725DA-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {30817C49-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {30817C49-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {30817C49-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {30817C49-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {30817C49-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {30817C49-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {30817C49-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {30817C49-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {9F3490D2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9F3490D2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {9F3490D2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {9F3490D2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {9F3490D2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {9F3490D2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {9F3490D2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {9F3490D2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {45203561-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {45203561-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {45203561-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {45203561-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {45203561-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {45203561-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {45203561-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {45203561-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {740D657B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {740D657B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {740D657B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {740D657B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {740D657B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {740D657B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {740D657B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {740D657B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {269E164D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {269E164D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {269E164D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {269E164D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {269E164D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {269E164D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {269E164D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {269E164D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {15142708-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {15142708-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {15142708-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {15142708-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {15142708-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {15142708-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {15142708-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {15142708-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {940D90CB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {940D90CB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {940D90CB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {940D90CB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {940D90CB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {940D90CB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {940D90CB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {940D90CB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {78A7ABF8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {78A7ABF8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {78A7ABF8-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {78A7ABF8-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {78A7ABF8-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {78A7ABF8-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {78A7ABF8-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {78A7ABF8-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {11661014-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {11661014-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {11661014-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {11661014-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {11661014-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {11661014-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {11661014-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {11661014-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {863BAECD-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {863BAECD-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {863BAECD-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {863BAECD-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {863BAECD-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {863BAECD-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {863BAECD-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {863BAECD-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {794AD56B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {794AD56B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {794AD56B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {794AD56B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {794AD56B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {794AD56B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {794AD56B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {794AD56B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {E5AFA070-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E5AFA070-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {E5AFA070-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {E5AFA070-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {E5AFA070-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {E5AFA070-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {E5AFA070-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {E5AFA070-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {2FDE2CE9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2FDE2CE9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {2FDE2CE9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {2FDE2CE9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {2FDE2CE9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {2FDE2CE9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {2FDE2CE9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {2FDE2CE9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {77EF2A93-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {77EF2A93-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {77EF2A93-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {77EF2A93-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {77EF2A93-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {77EF2A93-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {77EF2A93-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {77EF2A93-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {2FE80885-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2FE80885-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {2FE80885-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {2FE80885-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {2FE80885-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {2FE80885-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {2FE80885-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {2FE80885-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {3BEF931E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3BEF931E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {3BEF931E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {3BEF931E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {3BEF931E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {3BEF931E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {3BEF931E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {3BEF931E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {90661054-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {90661054-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {90661054-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {90661054-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {90661054-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {90661054-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {90661054-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {90661054-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {C1F0BF94-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C1F0BF94-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {C1F0BF94-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {C1F0BF94-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {C1F0BF94-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {C1F0BF94-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {C1F0BF94-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {C1F0BF94-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {D3C585B7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D3C585B7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {D3C585B7-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {D3C585B7-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {D3C585B7-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {D3C585B7-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {D3C585B7-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {D3C585B7-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {A6160403-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A6160403-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {A6160403-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {A6160403-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {A6160403-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {A6160403-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {A6160403-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {A6160403-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {0E41A72A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0E41A72A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {0E41A72A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {0E41A72A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {0E41A72A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {0E41A72A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {0E41A72A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {0E41A72A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {637774A3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {637774A3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {637774A3-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {637774A3-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {637774A3-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {637774A3-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {637774A3-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {637774A3-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {77EBBFC3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {77EBBFC3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {77EBBFC3-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {77EBBFC3-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {77EBBFC3-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {77EBBFC3-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {77EBBFC3-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {77EBBFC3-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {22F24DCA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {22F24DCA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {22F24DCA-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {22F24DCA-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {22F24DCA-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {22F24DCA-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {22F24DCA-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {22F24DCA-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B8480FB2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B8480FB2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B8480FB2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B8480FB2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B8480FB2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B8480FB2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B8480FB2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B8480FB2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {3260374F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3260374F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {3260374F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {3260374F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {3260374F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {3260374F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {3260374F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {3260374F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {518F9F29-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {518F9F29-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {518F9F29-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {518F9F29-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {518F9F29-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {518F9F29-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {518F9F29-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {518F9F29-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {4F87D6F5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4F87D6F5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {4F87D6F5-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {4F87D6F5-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {4F87D6F5-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {4F87D6F5-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {4F87D6F5-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {4F87D6F5-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {E6B1F61A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E6B1F61A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {E6B1F61A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {E6B1F61A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {E6B1F61A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {E6B1F61A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {E6B1F61A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {E6B1F61A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {2ED72801-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2ED72801-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {2ED72801-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {2ED72801-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {2ED72801-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {2ED72801-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {2ED72801-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {2ED72801-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {8306C04D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8306C04D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {8306C04D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {8306C04D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {8306C04D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {8306C04D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {8306C04D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {8306C04D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {82185430-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {82185430-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {82185430-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {82185430-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {82185430-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {82185430-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {82185430-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {82185430-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {4C9614F2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4C9614F2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {4C9614F2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {4C9614F2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {4C9614F2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {4C9614F2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {4C9614F2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {4C9614F2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {34E73349-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {34E73349-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {34E73349-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {34E73349-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {34E73349-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {34E73349-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {34E73349-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {34E73349-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {777203E2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {777203E2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {777203E2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {777203E2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {777203E2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {777203E2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {777203E2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {777203E2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {F5E705C4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F5E705C4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {F5E705C4-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {F5E705C4-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {F5E705C4-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {F5E705C4-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {F5E705C4-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {F5E705C4-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {0C173302-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0C173302-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {0C173302-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {0C173302-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {0C173302-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {0C173302-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {0C173302-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {0C173302-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {87182A4D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {87182A4D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {87182A4D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {87182A4D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {87182A4D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {87182A4D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {87182A4D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {87182A4D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {EF6E83F0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EF6E83F0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {EF6E83F0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {EF6E83F0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {EF6E83F0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {EF6E83F0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {EF6E83F0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {EF6E83F0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {CB215F59-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CB215F59-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {CB215F59-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {CB215F59-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {CB215F59-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {CB215F59-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {CB215F59-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {CB215F59-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {FE3A26DB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FE3A26DB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {FE3A26DB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {FE3A26DB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {FE3A26DB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {FE3A26DB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {FE3A26DB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {FE3A26DB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {C4177A7B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C4177A7B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {C4177A7B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {C4177A7B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {C4177A7B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {C4177A7B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {C4177A7B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {C4177A7B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {D9BA3159-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D9BA3159-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {D9BA3159-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {D9BA3159-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {D9BA3159-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {D9BA3159-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {D9BA3159-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {D9BA3159-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {1A0DFBB7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1A0DFBB7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {1A0DFBB7-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {1A0DFBB7-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {1A0DFBB7-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {1A0DFBB7-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {1A0DFBB7-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {1A0DFBB7-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {54907DBB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {54907DBB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {54907DBB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {54907DBB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {54907DBB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {54907DBB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {54907DBB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {54907DBB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B138A9E4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B138A9E4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B138A9E4-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B138A9E4-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B138A9E4-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B138A9E4-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B138A9E4-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B138A9E4-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {E70221C2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E70221C2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {E70221C2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {E70221C2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {E70221C2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {E70221C2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {E70221C2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {E70221C2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {FC1CE237-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FC1CE237-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {FC1CE237-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {FC1CE237-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {FC1CE237-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {FC1CE237-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {FC1CE237-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {FC1CE237-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {1BFA5D72-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1BFA5D72-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {1BFA5D72-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {1BFA5D72-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {1BFA5D72-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {1BFA5D72-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {1BFA5D72-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {1BFA5D72-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {CA465954-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CA465954-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {CA465954-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {CA465954-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {CA465954-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {CA465954-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {CA465954-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {CA465954-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B04C6E17-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B04C6E17-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B04C6E17-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B04C6E17-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B04C6E17-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B04C6E17-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B04C6E17-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B04C6E17-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B313D44D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B313D44D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B313D44D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B313D44D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B313D44D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B313D44D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B313D44D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B313D44D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {620AEFB9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {620AEFB9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {620AEFB9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {620AEFB9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {620AEFB9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {620AEFB9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {620AEFB9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {620AEFB9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {1FABABCB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1FABABCB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {1FABABCB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {1FABABCB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {1FABABCB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {1FABABCB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {1FABABCB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {1FABABCB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {BB5C8438-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BB5C8438-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {BB5C8438-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {BB5C8438-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {BB5C8438-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {BB5C8438-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {BB5C8438-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {BB5C8438-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {45DE2140-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {45DE2140-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {45DE2140-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {45DE2140-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {45DE2140-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {45DE2140-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {45DE2140-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {45DE2140-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {6376AA6E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6376AA6E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {6376AA6E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {6376AA6E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {6376AA6E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {6376AA6E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {6376AA6E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {6376AA6E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {34A8F049-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {34A8F049-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {34A8F049-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {34A8F049-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {34A8F049-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {34A8F049-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {34A8F049-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {34A8F049-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {18E5B4BD-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {18E5B4BD-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {18E5B4BD-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {18E5B4BD-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {18E5B4BD-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {18E5B4BD-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {18E5B4BD-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {18E5B4BD-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {D81E30F6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D81E30F6-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {D81E30F6-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {D81E30F6-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {D81E30F6-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {D81E30F6-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {D81E30F6-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {D81E30F6-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {608B0800-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {608B0800-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {608B0800-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {608B0800-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {608B0800-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {608B0800-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {608B0800-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {608B0800-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {862137EA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {862137EA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {862137EA-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {862137EA-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {862137EA-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {862137EA-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {862137EA-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {862137EA-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {31C23649-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {31C23649-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {31C23649-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {31C23649-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {31C23649-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {31C23649-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {31C23649-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {31C23649-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {282892D5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {282892D5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {282892D5-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {282892D5-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {282892D5-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {282892D5-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {282892D5-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {282892D5-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {FBA0E899-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FBA0E899-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {FBA0E899-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {FBA0E899-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {FBA0E899-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {FBA0E899-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {FBA0E899-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {FBA0E899-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {A9C58CAA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A9C58CAA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {A9C58CAA-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {A9C58CAA-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {A9C58CAA-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {A9C58CAA-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {A9C58CAA-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {A9C58CAA-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {3E957B1F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3E957B1F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {3E957B1F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {3E957B1F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {3E957B1F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {3E957B1F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {3E957B1F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {3E957B1F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {68E7637F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {68E7637F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {68E7637F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {68E7637F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {68E7637F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {68E7637F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {68E7637F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {68E7637F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {A3EED43D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A3EED43D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {A3EED43D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {A3EED43D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {A3EED43D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {A3EED43D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {A3EED43D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {A3EED43D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {E2C033CB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E2C033CB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {E2C033CB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {E2C033CB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {E2C033CB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {E2C033CB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {E2C033CB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {E2C033CB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B679D40B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B679D40B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B679D40B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B679D40B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B679D40B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B679D40B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B679D40B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B679D40B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {72488C1B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {72488C1B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {72488C1B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {72488C1B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {72488C1B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {72488C1B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {72488C1B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {72488C1B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {058F37A5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {058F37A5-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {058F37A5-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {058F37A5-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {058F37A5-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {058F37A5-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {058F37A5-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {058F37A5-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {E86CC114-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E86CC114-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {E86CC114-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {E86CC114-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {E86CC114-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {E86CC114-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {E86CC114-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {E86CC114-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {D9C7290F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D9C7290F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {D9C7290F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {D9C7290F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {D9C7290F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {D9C7290F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {D9C7290F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {D9C7290F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {0002E43B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0002E43B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {0002E43B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {0002E43B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {0002E43B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {0002E43B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {0002E43B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {0002E43B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {E7AB357E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E7AB357E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {E7AB357E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {E7AB357E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {E7AB357E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {E7AB357E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {E7AB357E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {E7AB357E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {7DFE101E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7DFE101E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {7DFE101E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {7DFE101E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {7DFE101E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {7DFE101E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {7DFE101E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {7DFE101E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {4E98661F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4E98661F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {4E98661F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {4E98661F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {4E98661F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {4E98661F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {4E98661F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {4E98661F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {29C72C7D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {29C72C7D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {29C72C7D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {29C72C7D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {29C72C7D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {29C72C7D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {29C72C7D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {29C72C7D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {9C98AD52-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {9C98AD52-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {9C98AD52-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {9C98AD52-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {9C98AD52-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {9C98AD52-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {9C98AD52-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {9C98AD52-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {E1DC3B6A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E1DC3B6A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {E1DC3B6A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {E1DC3B6A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {E1DC3B6A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {E1DC3B6A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {E1DC3B6A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {E1DC3B6A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {6E2BAD6F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6E2BAD6F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {6E2BAD6F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {6E2BAD6F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {6E2BAD6F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {6E2BAD6F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {6E2BAD6F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {6E2BAD6F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {A4066E0D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {A4066E0D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {A4066E0D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {A4066E0D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {A4066E0D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {A4066E0D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {A4066E0D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {A4066E0D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B5B68289-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B5B68289-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B5B68289-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B5B68289-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B5B68289-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B5B68289-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B5B68289-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B5B68289-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {FFF76237-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FFF76237-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {FFF76237-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {FFF76237-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {FFF76237-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {FFF76237-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {FFF76237-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {FFF76237-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {F8261503-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F8261503-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {F8261503-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {F8261503-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {F8261503-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {F8261503-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {F8261503-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {F8261503-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {0D83A722-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {0D83A722-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {0D83A722-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {0D83A722-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {0D83A722-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {0D83A722-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {0D83A722-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {0D83A722-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {EF6957B4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EF6957B4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {EF6957B4-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {EF6957B4-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {EF6957B4-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {EF6957B4-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {EF6957B4-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {EF6957B4-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {86E324C4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {86E324C4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {86E324C4-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {86E324C4-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {86E324C4-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {86E324C4-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {86E324C4-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {86E324C4-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {C26033CE-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C26033CE-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {C26033CE-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {C26033CE-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {C26033CE-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {C26033CE-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {C26033CE-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {C26033CE-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {4084050A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4084050A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {4084050A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {4084050A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {4084050A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {4084050A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {4084050A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {4084050A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {64795333-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {64795333-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {64795333-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {64795333-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {64795333-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {64795333-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {64795333-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {64795333-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {2EA41432-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2EA41432-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {2EA41432-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {2EA41432-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {2EA41432-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {2EA41432-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {2EA41432-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {2EA41432-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {44D74CF4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {44D74CF4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {44D74CF4-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {44D74CF4-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {44D74CF4-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {44D74CF4-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {44D74CF4-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {44D74CF4-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {BAAB251D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BAAB251D-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {BAAB251D-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {BAAB251D-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {BAAB251D-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {BAAB251D-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {BAAB251D-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {BAAB251D-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {277C4A73-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {277C4A73-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {277C4A73-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {277C4A73-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {277C4A73-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {277C4A73-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {277C4A73-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {277C4A73-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {619D55B3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {619D55B3-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {619D55B3-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {619D55B3-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {619D55B3-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {619D55B3-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {619D55B3-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {619D55B3-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {7B224AC2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7B224AC2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {7B224AC2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {7B224AC2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {7B224AC2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {7B224AC2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {7B224AC2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {7B224AC2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {3A470A1C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3A470A1C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {3A470A1C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {3A470A1C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {3A470A1C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {3A470A1C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {3A470A1C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {3A470A1C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {CC9064D4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {CC9064D4-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {CC9064D4-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {CC9064D4-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {CC9064D4-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {CC9064D4-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {CC9064D4-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {CC9064D4-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {FE48164A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {FE48164A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {FE48164A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {FE48164A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {FE48164A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {FE48164A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {FE48164A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {FE48164A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {86AD5537-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {86AD5537-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {86AD5537-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {86AD5537-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {86AD5537-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {86AD5537-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {86AD5537-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {86AD5537-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {1378A6F1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1378A6F1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {1378A6F1-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {1378A6F1-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {1378A6F1-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {1378A6F1-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {1378A6F1-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {1378A6F1-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {34AA50A9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {34AA50A9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {34AA50A9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {34AA50A9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {34AA50A9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {34AA50A9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {34AA50A9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {34AA50A9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {2C780489-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2C780489-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {2C780489-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {2C780489-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {2C780489-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {2C780489-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {2C780489-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {2C780489-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5591B074-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5591B074-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5591B074-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5591B074-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5591B074-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5591B074-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5591B074-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5591B074-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {8FAE40E0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8FAE40E0-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {8FAE40E0-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {8FAE40E0-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {8FAE40E0-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {8FAE40E0-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {8FAE40E0-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {8FAE40E0-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {31D72849-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {31D72849-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {31D72849-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {31D72849-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {31D72849-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {31D72849-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {31D72849-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {31D72849-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {62E01649-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {62E01649-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {62E01649-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {62E01649-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {62E01649-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {62E01649-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {62E01649-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {62E01649-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {77E3D41F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {77E3D41F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {77E3D41F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {77E3D41F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {77E3D41F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {77E3D41F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {77E3D41F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {77E3D41F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {22F24C31-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {22F24C31-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {22F24C31-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {22F24C31-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {22F24C31-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {22F24C31-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {22F24C31-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {22F24C31-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {52444372-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {52444372-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {52444372-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {52444372-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {52444372-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {52444372-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {52444372-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {52444372-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B6A3F31A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B6A3F31A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B6A3F31A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B6A3F31A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B6A3F31A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B6A3F31A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B6A3F31A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B6A3F31A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {F8915690-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F8915690-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {F8915690-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {F8915690-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {F8915690-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {F8915690-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {F8915690-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {F8915690-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B213B167-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B213B167-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B213B167-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B213B167-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B213B167-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B213B167-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B213B167-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B213B167-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {97522E33-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {97522E33-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {97522E33-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {97522E33-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {97522E33-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {97522E33-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {97522E33-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {97522E33-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {3F7C5147-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3F7C5147-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {3F7C5147-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {3F7C5147-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {3F7C5147-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {3F7C5147-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {3F7C5147-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {3F7C5147-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {B3512BAE-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B3512BAE-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {B3512BAE-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {B3512BAE-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {B3512BAE-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {B3512BAE-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {B3512BAE-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {B3512BAE-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {6BB42F4C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6BB42F4C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {6BB42F4C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {6BB42F4C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {6BB42F4C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {6BB42F4C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {6BB42F4C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {6BB42F4C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {15117F4C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {15117F4C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {15117F4C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {15117F4C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {15117F4C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {15117F4C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {15117F4C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {15117F4C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {3E7EF9F9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {3E7EF9F9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {3E7EF9F9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {3E7EF9F9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {3E7EF9F9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {3E7EF9F9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {3E7EF9F9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {3E7EF9F9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {2E8E98B1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2E8E98B1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {2E8E98B1-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {2E8E98B1-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {2E8E98B1-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {2E8E98B1-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {2E8E98B1-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {2E8E98B1-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {97BF2117-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {97BF2117-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {97BF2117-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {97BF2117-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {97BF2117-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {97BF2117-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {97BF2117-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {97BF2117-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {4CD277F7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4CD277F7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {4CD277F7-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {4CD277F7-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {4CD277F7-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {4CD277F7-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {4CD277F7-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {4CD277F7-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {03EBC4ED-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {03EBC4ED-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {03EBC4ED-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {03EBC4ED-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {03EBC4ED-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {03EBC4ED-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {03EBC4ED-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {03EBC4ED-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {76CBB623-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {76CBB623-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {76CBB623-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {76CBB623-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {76CBB623-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {76CBB623-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {76CBB623-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {76CBB623-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {34FD3049-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {34FD3049-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {34FD3049-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {34FD3049-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {34FD3049-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {34FD3049-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {34FD3049-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {34FD3049-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {51477B1B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {51477B1B-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {51477B1B-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {51477B1B-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {51477B1B-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {51477B1B-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {51477B1B-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {51477B1B-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {318A0849-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {318A0849-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {318A0849-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {318A0849-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {318A0849-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {318A0849-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {318A0849-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {318A0849-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {DEBBE52C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DEBBE52C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {DEBBE52C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {DEBBE52C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {DEBBE52C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {DEBBE52C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {DEBBE52C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {DEBBE52C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {40EDEECD-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {40EDEECD-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {40EDEECD-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {40EDEECD-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {40EDEECD-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {40EDEECD-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {40EDEECD-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {40EDEECD-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {87B04338-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {87B04338-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {87B04338-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {87B04338-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {87B04338-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {87B04338-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {87B04338-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {87B04338-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {09C5437F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {09C5437F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {09C5437F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {09C5437F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {09C5437F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {09C5437F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {09C5437F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {09C5437F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {639E00F7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {639E00F7-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {639E00F7-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {639E00F7-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {639E00F7-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {639E00F7-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {639E00F7-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {639E00F7-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {8BA13838-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8BA13838-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {8BA13838-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {8BA13838-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {8BA13838-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {8BA13838-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {8BA13838-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {8BA13838-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {443878EA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {443878EA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {443878EA-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {443878EA-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {443878EA-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {443878EA-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {443878EA-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {443878EA-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {19D5BCDA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {19D5BCDA-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {19D5BCDA-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {19D5BCDA-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {19D5BCDA-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {19D5BCDA-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {19D5BCDA-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {19D5BCDA-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {2E973B7E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2E973B7E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {2E973B7E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {2E973B7E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {2E973B7E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {2E973B7E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {2E973B7E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {2E973B7E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {C54B959A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C54B959A-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {C54B959A-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {C54B959A-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {C54B959A-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {C54B959A-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {C54B959A-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {C54B959A-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {148CB6EC-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {148CB6EC-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {148CB6EC-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {148CB6EC-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {148CB6EC-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {148CB6EC-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {148CB6EC-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {148CB6EC-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {94D249F9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {94D249F9-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {94D249F9-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {94D249F9-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {94D249F9-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {94D249F9-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {94D249F9-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {94D249F9-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {13E544B2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {13E544B2-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {13E544B2-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {13E544B2-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {13E544B2-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {13E544B2-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {13E544B2-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {13E544B2-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {E9D167C1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E9D167C1-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {E9D167C1-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {E9D167C1-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {E9D167C1-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {E9D167C1-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {E9D167C1-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {E9D167C1-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {42BEE675-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42BEE675-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {42BEE675-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {42BEE675-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {42BEE675-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {42BEE675-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {42BEE675-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {42BEE675-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {92CC9D6E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {92CC9D6E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {92CC9D6E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {92CC9D6E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {92CC9D6E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {92CC9D6E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {92CC9D6E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {92CC9D6E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {5B5CE00F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5B5CE00F-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {5B5CE00F-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {5B5CE00F-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {5B5CE00F-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {5B5CE00F-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {5B5CE00F-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {5B5CE00F-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {1D7FC04C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1D7FC04C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {1D7FC04C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {1D7FC04C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {1D7FC04C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {1D7FC04C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {1D7FC04C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {1D7FC04C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {740B4305-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {740B4305-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {740B4305-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {740B4305-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {740B4305-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {740B4305-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {740B4305-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {740B4305-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {31AD8749-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {31AD8749-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {31AD8749-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {31AD8749-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {31AD8749-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {31AD8749-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {31AD8749-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {31AD8749-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {568DF4CB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {568DF4CB-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {568DF4CB-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {568DF4CB-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {568DF4CB-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {568DF4CB-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {568DF4CB-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {568DF4CB-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {2CC6636E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2CC6636E-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {2CC6636E-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {2CC6636E-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {2CC6636E-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {2CC6636E-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {2CC6636E-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {2CC6636E-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {37EED14C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {37EED14C-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {37EED14C-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {37EED14C-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {37EED14C-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {37EED14C-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {37EED14C-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {37EED14C-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {06DC4BED-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {06DC4BED-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {06DC4BED-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {06DC4BED-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {06DC4BED-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {06DC4BED-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {06DC4BED-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {06DC4BED-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {8FCB14E8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.ActiveCfg = Debug|Win32
+ {8FCB14E8-FECA-1BAD-2431-8A1100722433}.Debug|Win32.Build.0 = Debug|Win32
+ {8FCB14E8-FECA-1BAD-2431-8A1100722433}.Debug|x64.ActiveCfg = Debug|x64
+ {8FCB14E8-FECA-1BAD-2431-8A1100722433}.Debug|x64.Build.0 = Debug|x64
+ {8FCB14E8-FECA-1BAD-2431-8A1100722433}.Release|Win32.ActiveCfg = Release|Win32
+ {8FCB14E8-FECA-1BAD-2431-8A1100722433}.Release|Win32.Build.0 = Release|Win32
+ {8FCB14E8-FECA-1BAD-2431-8A1100722433}.Release|x64.ActiveCfg = Release|x64
+ {8FCB14E8-FECA-1BAD-2431-8A1100722433}.Release|x64.Build.0 = Release|x64
+ {14DB45BF-FECA-1BAD-6AF0-8A634041EBC7}.Debug|Win32.ActiveCfg = Debug|Win32
+ {14DB45BF-FECA-1BAD-6AF0-8A634041EBC7}.Debug|Win32.Build.0 = Debug|Win32
+ {14DB45BF-FECA-1BAD-6AF0-8A634041EBC7}.Debug|x64.ActiveCfg = Debug|x64
+ {14DB45BF-FECA-1BAD-6AF0-8A634041EBC7}.Debug|x64.Build.0 = Debug|x64
+ {14DB45BF-FECA-1BAD-6AF0-8A634041EBC7}.Release|Win32.ActiveCfg = Release|Win32
+ {14DB45BF-FECA-1BAD-6AF0-8A634041EBC7}.Release|Win32.Build.0 = Release|Win32
+ {14DB45BF-FECA-1BAD-6AF0-8A634041EBC7}.Release|x64.ActiveCfg = Release|x64
+ {14DB45BF-FECA-1BAD-6AF0-8A634041EBC7}.Release|x64.Build.0 = Release|x64
+ {01EC1018-FECA-1BAD-2431-8A1141F31173}.Debug|Win32.ActiveCfg = Debug|Win32
+ {01EC1018-FECA-1BAD-2431-8A1141F31173}.Debug|Win32.Build.0 = Debug|Win32
+ {01EC1018-FECA-1BAD-2431-8A1141F31173}.Debug|x64.ActiveCfg = Debug|x64
+ {01EC1018-FECA-1BAD-2431-8A1141F31173}.Debug|x64.Build.0 = Debug|x64
+ {01EC1018-FECA-1BAD-2431-8A1141F31173}.Release|Win32.ActiveCfg = Release|Win32
+ {01EC1018-FECA-1BAD-2431-8A1141F31173}.Release|Win32.Build.0 = Release|Win32
+ {01EC1018-FECA-1BAD-2431-8A1141F31173}.Release|x64.ActiveCfg = Release|x64
+ {01EC1018-FECA-1BAD-2431-8A1141F31173}.Release|x64.Build.0 = Release|x64
+ EndGlobalSection
+ GlobalSection(SolutionProperties) = preSolution
+ HideSolutionNode = FALSE
+ EndGlobalSection
+EndGlobal
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc10.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc10.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc10.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,235 +0,0 @@
-Microsoft Visual Studio Solution File, Format Version 11.00
-# Visual Studio 2010
-# $Id: VC10WorkspaceCreator.pm 2035 2011-10-06 15:05:21Z johnnyw $
-# This file was generated by MPC. Any changes made directly to
-# this file will be lost the next time it is generated.
-# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type vc10 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE -workers 16 -name_modifier "*_vc10"
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML_XML_Svc_Conf_Parser", "ACEXML\apps\svcconf\ACEXML_XML_Svc_Conf_Parser_vc10.vcxproj", "{97A5797D-FECA-1BAD-5984-FE664DEC7B87}"
- ProjectSection(ProjectDependencies) = postProject
- {47BC56ED-FECA-1BAD-6757-8A6300006755} = {47BC56ED-FECA-1BAD-6757-8A6300006755}
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C} = {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57} = {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML", "ACEXML\common\ACEXML_vc10.vcxproj", "{D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML_Parser", "ACEXML\parser\parser\ACEXML_Parser_vc10.vcxproj", "{4E55F4DB-FECA-1BAD-5520-8D0596E4677C}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Kokyu", "Kokyu\Kokyu_vc10.vcxproj", "{DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE", "ace\ACE_vc10.vcxproj", "{47BC56ED-FECA-1BAD-6757-8A6300006755}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_Compression", "ace\Compression\ACE_Compression_vc10.vcxproj", "{B0AF43A7-FECA-1BAD-EA06-BB371373EA04}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_RLECompression", "ace\Compression\rle\ACE_RLECompression_vc10.vcxproj", "{F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}"
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04} = {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_ETCL_Parser", "ace\ETCL\ACE_ETCL_Parser_vc10.vcxproj", "{42B1A787-FECA-1BAD-007E-8A67757B007A}"
- {17692659-FECA-1BAD-007E-8A67757B007A} = {17692659-FECA-1BAD-007E-8A67757B007A}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_ETCL", "ace\ETCL\ACE_ETCL_vc10.vcxproj", "{17692659-FECA-1BAD-007E-8A67757B007A}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Monitor_Control", "ace\Monitor_Control\Monitor_Control_vc10.vcxproj", "{7153B6F4-FECA-1BAD-D619-74620E01B14C}"
- {42B1A787-FECA-1BAD-007E-8A67757B007A} = {42B1A787-FECA-1BAD-007E-8A67757B007A}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "QoS", "ace\QoS\QoS_vc10.vcxproj", "{6ADC56EC-FECA-1BAD-7781-8A636757A7A3}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "gperf", "apps\gperf\src\gperf_vc10.vcxproj", "{348C50EF-FECA-1BAD-6244-8A036423F5D3}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HTBP", "protocols\ace\HTBP\HTBP_vc10.vcxproj", "{17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "INet", "protocols\ace\INet\INet_vc10.vcxproj", "{92AC56A4-FECA-1BAD-F826-8A65F7EE4449}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RMCast", "protocols\ace\RMCast\RMCast_vc10.vcxproj", "{74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TMCast", "protocols\ace\TMCast\TMCast_vc10.vcxproj", "{74AC067C-FECA-1BAD-5646-8F6AEF953BB3}"
- EndProjectSection
-EndProject
-Global
- GlobalSection(SolutionConfigurationPlatforms) = preSolution
- Debug|Win32 = Debug|Win32
- Debug|x64 = Debug|x64
- Release|Win32 = Release|Win32
- Release|x64 = Release|x64
- EndGlobalSection
- GlobalSection(ProjectConfigurationPlatforms) = postSolution
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Debug|Win32.ActiveCfg = Debug|Win32
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Debug|Win32.Build.0 = Debug|Win32
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Debug|x64.ActiveCfg = Debug|x64
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Debug|x64.Build.0 = Debug|x64
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Release|Win32.ActiveCfg = Release|Win32
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Release|Win32.Build.0 = Release|Win32
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Release|x64.ActiveCfg = Release|x64
- {97A5797D-FECA-1BAD-5984-FE664DEC7B87}.Release|x64.Build.0 = Release|x64
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|Win32.ActiveCfg = Debug|Win32
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|Win32.Build.0 = Debug|Win32
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|x64.ActiveCfg = Debug|x64
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|x64.Build.0 = Debug|x64
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|Win32.ActiveCfg = Release|Win32
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|Win32.Build.0 = Release|Win32
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|x64.ActiveCfg = Release|x64
- {D92C1399-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|x64.Build.0 = Release|x64
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Debug|Win32.ActiveCfg = Debug|Win32
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Debug|Win32.Build.0 = Debug|Win32
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Debug|x64.ActiveCfg = Debug|x64
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Debug|x64.Build.0 = Debug|x64
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Release|Win32.ActiveCfg = Release|Win32
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Release|Win32.Build.0 = Release|Win32
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Release|x64.ActiveCfg = Release|x64
- {4E55F4DB-FECA-1BAD-5520-8D0596E4677C}.Release|x64.Build.0 = Release|x64
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|Win32.ActiveCfg = Debug|Win32
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|Win32.Build.0 = Debug|Win32
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|x64.ActiveCfg = Debug|x64
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|x64.Build.0 = Debug|x64
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|Win32.ActiveCfg = Release|Win32
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|Win32.Build.0 = Release|Win32
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|x64.ActiveCfg = Release|x64
- {DEBC5230-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|x64.Build.0 = Release|x64
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Debug|Win32.ActiveCfg = Debug|Win32
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Debug|Win32.Build.0 = Debug|Win32
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Debug|x64.ActiveCfg = Debug|x64
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Debug|x64.Build.0 = Debug|x64
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Release|Win32.ActiveCfg = Release|Win32
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Release|Win32.Build.0 = Release|Win32
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Release|x64.ActiveCfg = Release|x64
- {47BC56ED-FECA-1BAD-6757-8A6300006755}.Release|x64.Build.0 = Release|x64
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Debug|Win32.ActiveCfg = Debug|Win32
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Debug|Win32.Build.0 = Debug|Win32
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Debug|x64.ActiveCfg = Debug|x64
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Debug|x64.Build.0 = Debug|x64
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Release|Win32.ActiveCfg = Release|Win32
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Release|Win32.Build.0 = Release|Win32
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Release|x64.ActiveCfg = Release|x64
- {B0AF43A7-FECA-1BAD-EA06-BB371373EA04}.Release|x64.Build.0 = Release|x64
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Debug|Win32.ActiveCfg = Debug|Win32
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Debug|Win32.Build.0 = Debug|Win32
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Debug|x64.ActiveCfg = Debug|x64
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Debug|x64.Build.0 = Debug|x64
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Release|Win32.ActiveCfg = Release|Win32
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Release|Win32.Build.0 = Release|Win32
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Release|x64.ActiveCfg = Release|x64
- {F5DBB22D-FECA-1BAD-4E51-F42FEA0697D6}.Release|x64.Build.0 = Release|x64
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.ActiveCfg = Debug|Win32
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.Build.0 = Debug|Win32
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Debug|x64.ActiveCfg = Debug|x64
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Debug|x64.Build.0 = Debug|x64
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Release|Win32.ActiveCfg = Release|Win32
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Release|Win32.Build.0 = Release|Win32
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Release|x64.ActiveCfg = Release|x64
- {42B1A787-FECA-1BAD-007E-8A67757B007A}.Release|x64.Build.0 = Release|x64
- {17692659-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.ActiveCfg = Debug|Win32
- {17692659-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.Build.0 = Debug|Win32
- {17692659-FECA-1BAD-007E-8A67757B007A}.Debug|x64.ActiveCfg = Debug|x64
- {17692659-FECA-1BAD-007E-8A67757B007A}.Debug|x64.Build.0 = Debug|x64
- {17692659-FECA-1BAD-007E-8A67757B007A}.Release|Win32.ActiveCfg = Release|Win32
- {17692659-FECA-1BAD-007E-8A67757B007A}.Release|Win32.Build.0 = Release|Win32
- {17692659-FECA-1BAD-007E-8A67757B007A}.Release|x64.ActiveCfg = Release|x64
- {17692659-FECA-1BAD-007E-8A67757B007A}.Release|x64.Build.0 = Release|x64
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Debug|Win32.ActiveCfg = Debug|Win32
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Debug|Win32.Build.0 = Debug|Win32
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Debug|x64.ActiveCfg = Debug|x64
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Debug|x64.Build.0 = Debug|x64
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Release|Win32.ActiveCfg = Release|Win32
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Release|Win32.Build.0 = Release|Win32
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Release|x64.ActiveCfg = Release|x64
- {7153B6F4-FECA-1BAD-D619-74620E01B14C}.Release|x64.Build.0 = Release|x64
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Debug|Win32.ActiveCfg = Debug|Win32
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Debug|Win32.Build.0 = Debug|Win32
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Debug|x64.ActiveCfg = Debug|x64
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Debug|x64.Build.0 = Debug|x64
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Release|Win32.ActiveCfg = Release|Win32
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Release|Win32.Build.0 = Release|Win32
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Release|x64.ActiveCfg = Release|x64
- {6ADC56EC-FECA-1BAD-7781-8A636757A7A3}.Release|x64.Build.0 = Release|x64
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Debug|Win32.ActiveCfg = Debug|Win32
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Debug|Win32.Build.0 = Debug|Win32
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Debug|x64.ActiveCfg = Debug|x64
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Debug|x64.Build.0 = Debug|x64
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Release|Win32.ActiveCfg = Release|Win32
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Release|Win32.Build.0 = Release|Win32
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Release|x64.ActiveCfg = Release|x64
- {348C50EF-FECA-1BAD-6244-8A036423F5D3}.Release|x64.Build.0 = Release|x64
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|Win32.ActiveCfg = Debug|Win32
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|Win32.Build.0 = Debug|Win32
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|x64.ActiveCfg = Debug|x64
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|x64.Build.0 = Debug|x64
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Release|Win32.ActiveCfg = Release|Win32
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Release|Win32.Build.0 = Release|Win32
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Release|x64.ActiveCfg = Release|x64
- {17EC56A4-FECA-1BAD-D072-8A67F7EE4C1D}.Release|x64.Build.0 = Release|x64
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Debug|Win32.ActiveCfg = Debug|Win32
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Debug|Win32.Build.0 = Debug|Win32
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Debug|x64.ActiveCfg = Debug|x64
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Debug|x64.Build.0 = Debug|x64
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Release|Win32.ActiveCfg = Release|Win32
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Release|Win32.Build.0 = Release|Win32
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Release|x64.ActiveCfg = Release|x64
- {92AC56A4-FECA-1BAD-F826-8A65F7EE4449}.Release|x64.Build.0 = Release|x64
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|Win32.ActiveCfg = Debug|Win32
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|Win32.Build.0 = Debug|Win32
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|x64.ActiveCfg = Debug|x64
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|x64.Build.0 = Debug|x64
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Release|Win32.ActiveCfg = Release|Win32
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Release|Win32.Build.0 = Release|Win32
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Release|x64.ActiveCfg = Release|x64
- {74AC007C-FECA-1BAD-5646-8F0AEFF53BB3}.Release|x64.Build.0 = Release|x64
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Debug|Win32.ActiveCfg = Debug|Win32
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Debug|Win32.Build.0 = Debug|Win32
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Debug|x64.ActiveCfg = Debug|x64
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Debug|x64.Build.0 = Debug|x64
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Release|Win32.ActiveCfg = Release|Win32
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Release|Win32.Build.0 = Release|Win32
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Release|x64.ActiveCfg = Release|x64
- {74AC067C-FECA-1BAD-5646-8F6AEF953BB3}.Release|x64.Build.0 = Release|x64
- EndGlobalSection
- GlobalSection(SolutionProperties) = preSolution
- HideSolutionNode = FALSE
- EndGlobalSection
-EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc11.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc11.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc11.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -7,7 +7,7 @@
# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type vc11 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE -workers 16 -name_modifier "*_vc11"
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type vc11 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE -workers 12 -name_modifier "*_vc11"
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML_XML_Svc_Conf_Parser", "ACEXML\apps\svcconf\ACEXML_XML_Svc_Conf_Parser_vc11.vcxproj", "{97A5797C-FECA-1BAD-5984-FE664DEC7B87}"
{47BC56EC-FECA-1BAD-6757-8A6300006755} = {47BC56EC-FECA-1BAD-6757-8A6300006755}
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc12.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc12.sln (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ACE_wrappers_vc12.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,222 @@
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio 2012
+# $Id: VC12WorkspaceCreator.pm 2211 2014-06-26 18:11:09Z elliott_c $
+# This file was generated by MPC. Any changes made directly to
+# this file will be lost the next time it is generated.
+# MPC Command:
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type vc12 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE -workers 12 -name_modifier "*_vc12"
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML_XML_Svc_Conf_Parser", "ACEXML\apps\svcconf\ACEXML_XML_Svc_Conf_Parser_vc12.vcxproj", "{97A5797F-FECA-1BAD-5984-FE664DEC7B87}"
+ ProjectSection(ProjectDependencies) = postProject
+ {47BC56EF-FECA-1BAD-6757-8A6300006755} = {47BC56EF-FECA-1BAD-6757-8A6300006755}
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C} = {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57} = {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML", "ACEXML\common\ACEXML_vc12.vcxproj", "{D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACEXML_Parser", "ACEXML\parser\parser\ACEXML_Parser_vc12.vcxproj", "{4E55F4D9-FECA-1BAD-5520-8D0596E4677C}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Kokyu", "Kokyu\Kokyu_vc12.vcxproj", "{DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE", "ace\ACE_vc12.vcxproj", "{47BC56EF-FECA-1BAD-6757-8A6300006755}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_Compression", "ace\Compression\ACE_Compression_vc12.vcxproj", "{B0AF43A5-FECA-1BAD-EA06-BB371373EA04}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_RLECompression", "ace\Compression\rle\ACE_RLECompression_vc12.vcxproj", "{F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}"
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04} = {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_ETCL_Parser", "ace\ETCL\ACE_ETCL_Parser_vc12.vcxproj", "{42B1A785-FECA-1BAD-007E-8A67757B007A}"
+ {1769265B-FECA-1BAD-007E-8A67757B007A} = {1769265B-FECA-1BAD-007E-8A67757B007A}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE_ETCL", "ace\ETCL\ACE_ETCL_vc12.vcxproj", "{1769265B-FECA-1BAD-007E-8A67757B007A}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Monitor_Control", "ace\Monitor_Control\Monitor_Control_vc12.vcxproj", "{7153B6F6-FECA-1BAD-D619-74620E01B14C}"
+ {42B1A785-FECA-1BAD-007E-8A67757B007A} = {42B1A785-FECA-1BAD-007E-8A67757B007A}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "gperf", "apps\gperf\src\gperf_vc12.vcxproj", "{348C50ED-FECA-1BAD-6244-8A036423F5D3}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "HTBP", "protocols\ace\HTBP\HTBP_vc12.vcxproj", "{17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "INet", "protocols\ace\INet\INet_vc12.vcxproj", "{92AC56A6-FECA-1BAD-F826-8A65F7EE4449}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "RMCast", "protocols\ace\RMCast\RMCast_vc12.vcxproj", "{74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "TMCast", "protocols\ace\TMCast\TMCast_vc12.vcxproj", "{74AC067E-FECA-1BAD-5646-8F6AEF953BB3}"
+ EndProjectSection
+EndProject
+Global
+ GlobalSection(SolutionConfigurationPlatforms) = preSolution
+ Debug|Win32 = Debug|Win32
+ Debug|x64 = Debug|x64
+ Release|Win32 = Release|Win32
+ Release|x64 = Release|x64
+ EndGlobalSection
+ GlobalSection(ProjectConfigurationPlatforms) = postSolution
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Debug|Win32.ActiveCfg = Debug|Win32
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Debug|Win32.Build.0 = Debug|Win32
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Debug|x64.ActiveCfg = Debug|x64
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Debug|x64.Build.0 = Debug|x64
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Release|Win32.ActiveCfg = Release|Win32
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Release|Win32.Build.0 = Release|Win32
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Release|x64.ActiveCfg = Release|x64
+ {97A5797F-FECA-1BAD-5984-FE664DEC7B87}.Release|x64.Build.0 = Release|x64
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|Win32.Build.0 = Debug|Win32
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|x64.ActiveCfg = Debug|x64
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Debug|x64.Build.0 = Debug|x64
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|Win32.ActiveCfg = Release|Win32
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|Win32.Build.0 = Release|Win32
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|x64.ActiveCfg = Release|x64
+ {D92C139B-FECA-1BAD-BB9C-8C3AE91CCB57}.Release|x64.Build.0 = Release|x64
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Debug|Win32.Build.0 = Debug|Win32
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Debug|x64.ActiveCfg = Debug|x64
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Debug|x64.Build.0 = Debug|x64
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Release|Win32.ActiveCfg = Release|Win32
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Release|Win32.Build.0 = Release|Win32
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Release|x64.ActiveCfg = Release|x64
+ {4E55F4D9-FECA-1BAD-5520-8D0596E4677C}.Release|x64.Build.0 = Release|x64
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|Win32.Build.0 = Debug|Win32
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|x64.ActiveCfg = Debug|x64
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Debug|x64.Build.0 = Debug|x64
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|Win32.ActiveCfg = Release|Win32
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|Win32.Build.0 = Release|Win32
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|x64.ActiveCfg = Release|x64
+ {DEBC5232-FECA-1BAD-9CE7-8A2E004D9CE5}.Release|x64.Build.0 = Release|x64
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Debug|Win32.ActiveCfg = Debug|Win32
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Debug|Win32.Build.0 = Debug|Win32
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Debug|x64.ActiveCfg = Debug|x64
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Debug|x64.Build.0 = Debug|x64
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Release|Win32.ActiveCfg = Release|Win32
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Release|Win32.Build.0 = Release|Win32
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Release|x64.ActiveCfg = Release|x64
+ {47BC56EF-FECA-1BAD-6757-8A6300006755}.Release|x64.Build.0 = Release|x64
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Debug|Win32.Build.0 = Debug|Win32
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Debug|x64.ActiveCfg = Debug|x64
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Debug|x64.Build.0 = Debug|x64
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Release|Win32.ActiveCfg = Release|Win32
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Release|Win32.Build.0 = Release|Win32
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Release|x64.ActiveCfg = Release|x64
+ {B0AF43A5-FECA-1BAD-EA06-BB371373EA04}.Release|x64.Build.0 = Release|x64
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Debug|Win32.Build.0 = Debug|Win32
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Debug|x64.ActiveCfg = Debug|x64
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Debug|x64.Build.0 = Debug|x64
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Release|Win32.ActiveCfg = Release|Win32
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Release|Win32.Build.0 = Release|Win32
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Release|x64.ActiveCfg = Release|x64
+ {F5DBB22F-FECA-1BAD-4E51-F42FEA0697D6}.Release|x64.Build.0 = Release|x64
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.ActiveCfg = Debug|Win32
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.Build.0 = Debug|Win32
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Debug|x64.ActiveCfg = Debug|x64
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Debug|x64.Build.0 = Debug|x64
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Release|Win32.ActiveCfg = Release|Win32
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Release|Win32.Build.0 = Release|Win32
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Release|x64.ActiveCfg = Release|x64
+ {42B1A785-FECA-1BAD-007E-8A67757B007A}.Release|x64.Build.0 = Release|x64
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.ActiveCfg = Debug|Win32
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Debug|Win32.Build.0 = Debug|Win32
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Debug|x64.ActiveCfg = Debug|x64
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Debug|x64.Build.0 = Debug|x64
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Release|Win32.ActiveCfg = Release|Win32
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Release|Win32.Build.0 = Release|Win32
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Release|x64.ActiveCfg = Release|x64
+ {1769265B-FECA-1BAD-007E-8A67757B007A}.Release|x64.Build.0 = Release|x64
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Debug|Win32.Build.0 = Debug|Win32
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Debug|x64.ActiveCfg = Debug|x64
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Debug|x64.Build.0 = Debug|x64
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Release|Win32.ActiveCfg = Release|Win32
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Release|Win32.Build.0 = Release|Win32
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Release|x64.ActiveCfg = Release|x64
+ {7153B6F6-FECA-1BAD-D619-74620E01B14C}.Release|x64.Build.0 = Release|x64
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Debug|Win32.ActiveCfg = Debug|Win32
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Debug|Win32.Build.0 = Debug|Win32
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Debug|x64.ActiveCfg = Debug|x64
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Debug|x64.Build.0 = Debug|x64
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Release|Win32.ActiveCfg = Release|Win32
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Release|Win32.Build.0 = Release|Win32
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Release|x64.ActiveCfg = Release|x64
+ {348C50ED-FECA-1BAD-6244-8A036423F5D3}.Release|x64.Build.0 = Release|x64
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|Win32.ActiveCfg = Debug|Win32
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|Win32.Build.0 = Debug|Win32
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|x64.ActiveCfg = Debug|x64
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Debug|x64.Build.0 = Debug|x64
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Release|Win32.ActiveCfg = Release|Win32
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Release|Win32.Build.0 = Release|Win32
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Release|x64.ActiveCfg = Release|x64
+ {17EC56A6-FECA-1BAD-D072-8A67F7EE4C1D}.Release|x64.Build.0 = Release|x64
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Debug|Win32.ActiveCfg = Debug|Win32
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Debug|Win32.Build.0 = Debug|Win32
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Debug|x64.ActiveCfg = Debug|x64
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Debug|x64.Build.0 = Debug|x64
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Release|Win32.ActiveCfg = Release|Win32
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Release|Win32.Build.0 = Release|Win32
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Release|x64.ActiveCfg = Release|x64
+ {92AC56A6-FECA-1BAD-F826-8A65F7EE4449}.Release|x64.Build.0 = Release|x64
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|Win32.ActiveCfg = Debug|Win32
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|Win32.Build.0 = Debug|Win32
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|x64.ActiveCfg = Debug|x64
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Debug|x64.Build.0 = Debug|x64
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Release|Win32.ActiveCfg = Release|Win32
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Release|Win32.Build.0 = Release|Win32
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Release|x64.ActiveCfg = Release|x64
+ {74AC007E-FECA-1BAD-5646-8F0AEFF53BB3}.Release|x64.Build.0 = Release|x64
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Debug|Win32.ActiveCfg = Debug|Win32
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Debug|Win32.Build.0 = Debug|Win32
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Debug|x64.ActiveCfg = Debug|x64
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Debug|x64.Build.0 = Debug|x64
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Release|Win32.ActiveCfg = Release|Win32
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Release|Win32.Build.0 = Release|Win32
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Release|x64.ActiveCfg = Release|x64
+ {74AC067E-FECA-1BAD-5646-8F6AEF953BB3}.Release|x64.Build.0 = Release|x64
+ EndGlobalSection
+ EndGlobalSection
+EndGlobal
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc10.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc10.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc10.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,241 +0,0 @@
-# MPC Command:
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_agent", "agent\asnmp_agent_vc10.vcxproj", "{4C260F9E-FECA-1BAD-1396-8A04829757EE}"
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA} = {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_lib", "asnmp\asnmp_lib_vc10.vcxproj", "{B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get_async", "examples\get\asnmp_example_get_async_vc10.vcxproj", "{B8E6506D-FECA-1BAD-6126-8A63C208BB19}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get", "examples\get\asnmp_example_get_vc10.vcxproj", "{2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_next", "examples\next\asnmp_example_next_vc10.vcxproj", "{BE5253E3-FECA-1BAD-82F6-8A65208B2128}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_set", "examples\set\asnmp_example_set_vc10.vcxproj", "{6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_trap", "examples\trap\asnmp_example_trap_vc10.vcxproj", "{D71253F8-FECA-1BAD-3462-8A64208A97BC}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_walk", "examples\walk\asnmp_example_walk_vc10.vcxproj", "{EBA253FA-FECA-1BAD-17A9-8A64208AB477}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Address_Test", "tests\asnmp_tests_Address_Test_vc10.vcxproj", "{95AC7E59-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Counter64_Test", "tests\asnmp_tests_Counter64_Test_vc10.vcxproj", "{E4E3174A-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Counter_Test", "tests\asnmp_tests_Counter_Test_vc10.vcxproj", "{357C1F5B-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Gauge_Test", "tests\asnmp_tests_Gauge_Test_vc10.vcxproj", "{204D0425-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Integer_Test", "tests\asnmp_tests_Integer_Test_vc10.vcxproj", "{24DF1F51-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Octet_Test", "tests\asnmp_tests_Octet_Test_vc10.vcxproj", "{286C3525-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Oid_Test", "tests\asnmp_tests_Oid_Test_vc10.vcxproj", "{5AB02509-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Target_Test", "tests\asnmp_tests_Target_Test_vc10.vcxproj", "{4AC951AB-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Varbind_Test", "tests\asnmp_tests_Varbind_Test_vc10.vcxproj", "{D2A1B94E-FECA-1BAD-2431-8A1182826049}"
- EndProjectSection
-EndProject
-Global
- EndGlobalSection
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Debug|Win32.ActiveCfg = Debug|Win32
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Debug|Win32.Build.0 = Debug|Win32
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Debug|x64.ActiveCfg = Debug|x64
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Debug|x64.Build.0 = Debug|x64
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Release|Win32.ActiveCfg = Release|Win32
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Release|Win32.Build.0 = Release|Win32
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Release|x64.ActiveCfg = Release|x64
- {4C260F9E-FECA-1BAD-1396-8A04829757EE}.Release|x64.Build.0 = Release|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.ActiveCfg = Debug|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.Build.0 = Debug|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.ActiveCfg = Debug|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.Build.0 = Debug|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.ActiveCfg = Release|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.Build.0 = Release|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.ActiveCfg = Release|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.Build.0 = Release|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.ActiveCfg = Debug|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.Build.0 = Debug|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.ActiveCfg = Debug|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.Build.0 = Debug|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.ActiveCfg = Release|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.Build.0 = Release|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|x64.ActiveCfg = Release|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|x64.Build.0 = Release|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.ActiveCfg = Debug|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.Build.0 = Debug|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.ActiveCfg = Debug|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.Build.0 = Debug|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.ActiveCfg = Release|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.Build.0 = Release|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|x64.ActiveCfg = Release|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|x64.Build.0 = Release|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.ActiveCfg = Debug|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.Build.0 = Debug|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.ActiveCfg = Debug|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.Build.0 = Debug|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.ActiveCfg = Release|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.Build.0 = Release|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|x64.ActiveCfg = Release|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|x64.Build.0 = Release|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.ActiveCfg = Debug|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.Build.0 = Debug|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.ActiveCfg = Debug|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.Build.0 = Debug|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.ActiveCfg = Release|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.Build.0 = Release|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|x64.ActiveCfg = Release|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|x64.Build.0 = Release|x64
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {95AC7E59-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {E4E3174A-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {357C1F5B-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {204D0425-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {204D0425-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {204D0425-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {204D0425-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {204D0425-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {204D0425-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {204D0425-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {204D0425-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {24DF1F51-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {286C3525-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {286C3525-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {286C3525-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {286C3525-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {286C3525-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {286C3525-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {286C3525-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {286C3525-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {5AB02509-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {4AC951AB-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
- {D2A1B94E-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
- EndGlobalSection
- EndGlobalSection
-EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc11.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc11.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc11.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -7,7 +7,7 @@
# MPC Command:
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_agent", "agent\asnmp_agent_vc11.vcxproj", "{4C260F9F-FECA-1BAD-1396-8A04829757EE}"
{B9A9DCB1-FECA-1BAD-58A2-8A0582961CDA} = {B9A9DCB1-FECA-1BAD-58A2-8A0582961CDA}
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc12.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc12.sln (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/ASNMP_vc12.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,241 @@
+# MPC Command:
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_agent", "agent\asnmp_agent_vc12.vcxproj", "{4C260F9C-FECA-1BAD-1396-8A04829757EE}"
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA} = {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_lib", "asnmp\asnmp_lib_vc12.vcxproj", "{B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get_async", "examples\get\asnmp_example_get_async_vc12.vcxproj", "{B8E6506F-FECA-1BAD-6126-8A63C208BB19}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get", "examples\get\asnmp_example_get_vc12.vcxproj", "{2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_next", "examples\next\asnmp_example_next_vc12.vcxproj", "{BE5253E1-FECA-1BAD-82F6-8A65208B2128}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_set", "examples\set\asnmp_example_set_vc12.vcxproj", "{6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_trap", "examples\trap\asnmp_example_trap_vc12.vcxproj", "{D71253FA-FECA-1BAD-3462-8A64208A97BC}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_walk", "examples\walk\asnmp_example_walk_vc12.vcxproj", "{EBA253F8-FECA-1BAD-17A9-8A64208AB477}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Address_Test", "tests\asnmp_tests_Address_Test_vc12.vcxproj", "{95AC7E5B-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Counter64_Test", "tests\asnmp_tests_Counter64_Test_vc12.vcxproj", "{E4E31748-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Counter_Test", "tests\asnmp_tests_Counter_Test_vc12.vcxproj", "{357C1F59-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Gauge_Test", "tests\asnmp_tests_Gauge_Test_vc12.vcxproj", "{204D0427-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Integer_Test", "tests\asnmp_tests_Integer_Test_vc12.vcxproj", "{24DF1F53-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Octet_Test", "tests\asnmp_tests_Octet_Test_vc12.vcxproj", "{286C3527-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Oid_Test", "tests\asnmp_tests_Oid_Test_vc12.vcxproj", "{5AB0250B-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Target_Test", "tests\asnmp_tests_Target_Test_vc12.vcxproj", "{4AC951A9-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_tests_Varbind_Test", "tests\asnmp_tests_Varbind_Test_vc12.vcxproj", "{D2A1B94C-FECA-1BAD-2431-8A1182826049}"
+ EndProjectSection
+EndProject
+Global
+ EndGlobalSection
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Debug|Win32.Build.0 = Debug|Win32
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Debug|x64.ActiveCfg = Debug|x64
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Debug|x64.Build.0 = Debug|x64
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Release|Win32.ActiveCfg = Release|Win32
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Release|Win32.Build.0 = Release|Win32
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Release|x64.ActiveCfg = Release|x64
+ {4C260F9C-FECA-1BAD-1396-8A04829757EE}.Release|x64.Build.0 = Release|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.Build.0 = Debug|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.ActiveCfg = Debug|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.Build.0 = Debug|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.ActiveCfg = Release|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.Build.0 = Release|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.ActiveCfg = Release|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.Build.0 = Release|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.Build.0 = Debug|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.ActiveCfg = Debug|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.Build.0 = Debug|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.ActiveCfg = Release|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.Build.0 = Release|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|x64.ActiveCfg = Release|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|x64.Build.0 = Release|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.Build.0 = Debug|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.ActiveCfg = Debug|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.Build.0 = Debug|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.ActiveCfg = Release|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.Build.0 = Release|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|x64.ActiveCfg = Release|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|x64.Build.0 = Release|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.Build.0 = Debug|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.ActiveCfg = Debug|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.Build.0 = Debug|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.ActiveCfg = Release|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.Build.0 = Release|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|x64.ActiveCfg = Release|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|x64.Build.0 = Release|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.Build.0 = Debug|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.ActiveCfg = Debug|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.Build.0 = Debug|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.ActiveCfg = Release|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.Build.0 = Release|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|x64.ActiveCfg = Release|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|x64.Build.0 = Release|x64
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {95AC7E5B-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {E4E31748-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {357C1F59-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {204D0427-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {24DF1F53-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {286C3527-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {5AB0250B-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {4AC951A9-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Debug|Win32.Build.0 = Debug|Win32
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Debug|x64.ActiveCfg = Debug|x64
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Debug|x64.Build.0 = Debug|x64
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Release|Win32.ActiveCfg = Release|Win32
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Release|Win32.Build.0 = Release|Win32
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Release|x64.ActiveCfg = Release|x64
+ {D2A1B94C-FECA-1BAD-2431-8A1182826049}.Release|x64.Build.0 = Release|x64
+ EndGlobalSection
+ EndGlobalSection
+EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/GNUmakefile
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/GNUmakefile 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/GNUmakefile 2021-08-16 06:26:30 UTC (rev 9865)
@@ -8,7 +8,7 @@
# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type gnuace -exclude "TAO/TAO_*.mwc,TAO/CIAO/CIAO_*.mwc" -workers 16 -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type gnuace -exclude "TAO/TAO_*.mwc,TAO/CIAO/CIAO_*.mwc" -workers 12 -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/GNUmakefile
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/GNUmakefile 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/GNUmakefile 2021-08-16 06:26:30 UTC (rev 9865)
@@ -8,7 +8,7 @@
# MPC Command:
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/GNUmakefile.asnmp_agent
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/GNUmakefile.asnmp_agent 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/GNUmakefile.asnmp_agent 2021-08-16 06:26:30 UTC (rev 9865)
@@ -4,7 +4,7 @@
# @file GNUmakefile.asnmp_agent
-# $Id: gnu.mpd 95691 2012-04-10 20:11:35Z mitza $
+# $Id: gnu.mpd 97814 2014-07-27 15:46:43Z wotte $
# This file was automatically generated by MPC. Any changes made directly to
@@ -68,7 +68,12 @@
ifeq ($(findstring k, $(MAKEFLAGS)),k)
LIBCHECK = 1
else
- LIBCHECK ?= $(filter-out $(foreach lib,asnmp ACE,$(findstring $(lib),$(foreach libpath,. $(if $(ARCH),./$(ARCH)) ../../lib $(if $(ARCH),../../lib/$(ARCH)) /usr/lib /usr/lib64 $(INSLIB),$(wildcard $(libpath)/$(LIB_PREFIX)$(lib).* $(libpath)/$(lib).lib)))),asnmp ACE)
+ ifeq ($(LIBCHECK_PREFIX),)
+ # If the user hasn't specified a place to look for installed libraries, let's set
+ # a reasonable default
+ LIBCHECK_PREFIX = /usr
+ endif
+ LIBCHECK ?= $(filter-out $(foreach lib,asnmp ACE,$(findstring $(lib),$(foreach libpath,. $(if $(ARCH),./$(ARCH)) ../../lib $(if $(ARCH),../../lib/$(ARCH)) $(LIBCHECK_PREFIX)/lib $(LIBCHECK_PREFIX)/lib64 $(LIBCHECK_EXTRA_PATHS) $(INSLIB),$(wildcard $(libpath)/$(LIB_PREFIX)$(lib).* $(libpath)/$(lib).lib)))),asnmp ACE)
ifeq ($(LIBCHECK),)
LIBCHECK = 1
endif
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc10.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc10.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc10.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,33 +0,0 @@
-Microsoft Visual Studio Solution File, Format Version 11.00
-# Visual Studio 2010
-# $Id: VC10WorkspaceCreator.pm 2035 2011-10-06 15:05:21Z johnnyw $
-# This file was generated by MPC. Any changes made directly to
-# this file will be lost the next time it is generated.
-# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type vc10 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE -workers 16 -name_modifier "*_vc10"
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_agent", "asnmp_agent_vc10.vcxproj", "{4C260F9E-FECA-1BAD-1396-8A04829757EE}"
-EndProject
-Global
- EndGlobalSection
- EndGlobalSection
- EndGlobalSection
-EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc11.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc11.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc11.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -7,7 +7,7 @@
# MPC Command:
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_agent", "asnmp_agent_vc11.vcxproj", "{4C260F9F-FECA-1BAD-1396-8A04829757EE}"
EndProject
Global
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc12.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc12.sln (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/agent_vc12.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,33 @@
+# MPC Command:
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_agent", "asnmp_agent_vc12.vcxproj", "{4C260F9C-FECA-1BAD-1396-8A04829757EE}"
+EndProject
+Global
+ EndGlobalSection
+ EndGlobalSection
+ GlobalSection(SolutionProperties) = preSolution
+ HideSolutionNode = FALSE
+ EndGlobalSection
+EndGlobal
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc10.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc10.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc10.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,304 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<Project DefaultTargets="Build" ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
- <ItemGroup Label="ProjectConfigurations">
- <ProjectConfiguration Include="Debug|Win32">
- <Configuration>Debug</Configuration>
- <Platform>Win32</Platform>
- </ProjectConfiguration>
- <ProjectConfiguration Include="Release|Win32">
- <Configuration>Release</Configuration>
- <ProjectConfiguration Include="Debug|x64">
- <Platform>x64</Platform>
- <ProjectConfiguration Include="Release|x64">
- </ItemGroup>
- <PropertyGroup Label="Globals">
- <ProjectName>asnmp_agent</ProjectName>
- <ProjectGuid>{4C260F9E-FECA-1BAD-1396-8A04829757EE}</ProjectGuid>
- <RootNamespace>asnmp_agent</RootNamespace>
- <Keyword>Win32Proj</Keyword>
- </PropertyGroup>
- <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
- <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
- <ConfigurationType>Application</ConfigurationType>
- <UseDebugLibraries>true</UseDebugLibraries>
- <CharacterSet>NotSet</CharacterSet>
- <PlatformToolset>v100</PlatformToolset>
- </PropertyGroup>
- <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
- <UseDebugLibraries>false</UseDebugLibraries>
- <WholeProgramOptimization>true</WholeProgramOptimization>
- </PropertyGroup>
- <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="Configuration">
- </PropertyGroup>
- <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="Configuration">
- </PropertyGroup>
- <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
- <ImportGroup Label="ExtensionSettings">
- </ImportGroup>
- <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
- <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
- </ImportGroup>
- <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
- </ImportGroup>
- <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="PropertySheets">
- </ImportGroup>
- <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="PropertySheets">
- </ImportGroup>
- <PropertyGroup Label="UserMacros" />
- <PropertyGroup>
- <_ProjectFileVersion>10.0.30319.1</_ProjectFileVersion>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">.\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_agent_vc10\I386\</IntDir>
- <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</LinkIncremental>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">agent</TargetName>
- <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'"></LocalDebuggerCommandArguments>
- <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">$(OutDir)</LocalDebuggerWorkingDirectory>
- <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
- <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
- <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_agent_vc10\I386\</IntDir>
- <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">false</LinkIncremental>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">agent</TargetName>
- <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Release|Win32'"></LocalDebuggerCommandArguments>
- <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">$(OutDir)</LocalDebuggerWorkingDirectory>
- <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
- <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
- <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">.\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_agent_vc10\AMD64\</IntDir>
- <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</LinkIncremental>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">agent</TargetName>
- <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Debug|x64'"></LocalDebuggerCommandArguments>
- <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">$(OutDir)</LocalDebuggerWorkingDirectory>
- <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
- <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
- <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_agent_vc10\AMD64\</IntDir>
- <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|x64'">false</LinkIncremental>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">agent</TargetName>
- <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Release|x64'"></LocalDebuggerCommandArguments>
- <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Release|x64'">$(OutDir)</LocalDebuggerWorkingDirectory>
- <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
- <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
- <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
- </PropertyGroup>
- <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
- <Midl>
- <PreprocessorDefinitions>%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <AdditionalIncludeDirectories>%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
- <TargetEnvironment>Win32</TargetEnvironment>
- <TypeLibraryName>%(Filename).tlb</TypeLibraryName>
- <HeaderFileName>%(Filename).h</HeaderFileName>
- <InterfaceIdentifierFileName>%(Filename)_i.c</InterfaceIdentifierFileName>
- <ProxyFileName>%(Filename)_p.c</ProxyFileName>
- </Midl>
- <ClCompile>
- <Optimization>Disabled</Optimization>
- <AdditionalIncludeDirectories>..\..;..\..\ASNMP;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
- <PreprocessorDefinitions>_DEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <MinimalRebuild>false</MinimalRebuild>
- <RuntimeLibrary>MultiThreadedDebugDLL</RuntimeLibrary>
- <RuntimeTypeInfo>true</RuntimeTypeInfo>
- <WarningLevel>Level3</WarningLevel>
- <DisableSpecificWarnings>4355;%(DisableSpecificWarnings)</DisableSpecificWarnings>
- </ClCompile>
- <ResourceCompile>
- <PreprocessorDefinitions>_DEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <Culture>1033</Culture>
- </ResourceCompile>
- <Link>
- <SubSystem>Console</SubSystem>
- <GenerateDebugInformation>true</GenerateDebugInformation>
- <AdditionalDependencies>ACEd.lib;asnmpd.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
- <OutputFile>$(OutDir)agent.exe</OutputFile>
- <AdditionalLibraryDirectories>.;..\..\lib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
- </Link>
-<!-- "postclean" was made-up by MPC for use by vs_postclean.pl.
- Check if msbuild has any support for a custom post-cleaning step
-<!-- No known equivalent for DeploymentTool in vc10:
- </ItemDefinitionGroup>
- <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
- <Midl>
- </Midl>
- <ClCompile>
- <Optimization>MaxSpeed</Optimization>
- <IntrinsicFunctions>true</IntrinsicFunctions>
- <PreprocessorDefinitions>NDEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
- </ClCompile>
- <ResourceCompile>
- <PreprocessorDefinitions>NDEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <Link>
- <AdditionalDependencies>ACE.lib;asnmp.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
- <OptimizeReferences>true</OptimizeReferences>
- <EnableCOMDATFolding>true</EnableCOMDATFolding>
- </Link>
- <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
- <Midl>
- <TargetEnvironment>x64</TargetEnvironment>
- </Midl>
- <ClCompile>
- <PreprocessorDefinitions>_DEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
- </ClCompile>
- <ResourceCompile>
- <PreprocessorDefinitions>_DEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;_WIN64;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <Link>
- Though we can set TargetMachine explicitly, VC++
- can figure it out by project type. We don't need
- to set it by ourselves.
-<!-- <TargetMachine>0</TargetMachine>-->
- <AdditionalOptions>/machine:AMD64 %(AdditionalOptions)</AdditionalOptions>
- </Link>
- <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
- <Midl>
- </Midl>
- <ClCompile>
- <PreprocessorDefinitions>NDEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- </ClCompile>
- <ResourceCompile>
- <PreprocessorDefinitions>NDEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;_WIN64;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <Link>
- </Link>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- <ClCompile Include="agent_impl.cpp">
- </ClCompile>
- <ClCompile Include="main.cpp">
- </ClCompile>
- <ClCompile Include="snmp_agent.cpp">
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- <ClInclude Include="agent_impl.h" />
- <ClInclude Include="snmp_agent.h" />
- </ItemGroup>
- <ItemGroup>
- <None Include="agent.mpc">
- <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
- <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
- <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
- <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
- </None>
- </ItemGroup>
- <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
- <ImportGroup Label="ExtensionTargets">
- </ImportGroup>
-</Project>
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc10.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc10.vcxproj.filters 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc10.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,41 +0,0 @@
-<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
- <ItemGroup>
- <Filter Include="Source Files">
- <UniqueIdentifier>{B1F27843-FECA-1BAD-1396-8A04829757EE}</UniqueIdentifier>
- <Extensions>cpp;cxx;cc;c;C</Extensions>
- </Filter>
- <Filter Include="Header Files">
- <UniqueIdentifier>{06319535-FECA-1BAD-1396-8A04829757EE}</UniqueIdentifier>
- <Extensions>h;hpp;hxx;hh</Extensions>
- </Filter>
- <Filter Include="Build Files">
- <UniqueIdentifier>{A1909F1C-FECA-1BAD-1396-8A04829757EE}</UniqueIdentifier>
- <Extensions>mpc;mpb;mwc</Extensions>
- </Filter>
- </ItemGroup>
- <ItemGroup>
- <Filter>Source Files</Filter>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- <ClInclude Include="agent_impl.h">
- <Filter>Header Files</Filter>
- </ClInclude>
- <ClInclude Include="snmp_agent.h">
- </ClInclude>
- </ItemGroup>
- <ItemGroup>
- <Filter>Build Files</Filter>
- </None>
- </ItemGroup>
-</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc11.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc11.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc11.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,304 +1,608 @@
- </ItemGroup>
- <ProjectGuid>{4C260F9F-FECA-1BAD-1396-8A04829757EE}</ProjectGuid>
- </PropertyGroup>
- <PlatformToolset>v110</PlatformToolset>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- <PropertyGroup>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_agent_vc11\I386\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_agent_vc11\I386\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_agent_vc11\AMD64\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_agent_vc11\AMD64\</IntDir>
- </PropertyGroup>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
- </ImportGroup>
-</Project>
+<?xml version="1.0" encoding="utf-8"?>
+<Project DefaultTargets="Build" ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup Label="ProjectConfigurations">
+ <ProjectConfiguration Include="Debug|Win32">
+ <Configuration>Debug</Configuration>
+ <Platform>Win32</Platform>
+ </ProjectConfiguration>
+ <ProjectConfiguration Include="Release|Win32">
+ <Configuration>Release</Configuration>
+ <ProjectConfiguration Include="Debug|x64">
+ <Platform>x64</Platform>
+ <ProjectConfiguration Include="Release|x64">
+ </ItemGroup>
+ <PropertyGroup Label="Globals">
+ <ProjectName>asnmp_agent</ProjectName>
+ <ProjectGuid>{4C260F9F-FECA-1BAD-1396-8A04829757EE}</ProjectGuid>
+ <RootNamespace>asnmp_agent</RootNamespace>
+ <Keyword>Win32Proj</Keyword>
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
+ <ConfigurationType>Application</ConfigurationType>
+ <UseDebugLibraries>true</UseDebugLibraries>
+ <CharacterSet>NotSet</CharacterSet>
+ <PlatformToolset>v110</PlatformToolset>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
+ <UseDebugLibraries>false</UseDebugLibraries>
+ <WholeProgramOptimization>true</WholeProgramOptimization>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="Configuration">
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="Configuration">
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
+ <ImportGroup Label="ExtensionSettings">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
+ <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="PropertySheets">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="PropertySheets">
+ </ImportGroup>
+ <PropertyGroup Label="UserMacros" />
+ <PropertyGroup>
+ <_ProjectFileVersion>10.0.30319.1</_ProjectFileVersion>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">.\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_agent_vc11\I386\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</LinkIncremental>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">agent</TargetName>
+ <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'"></LocalDebuggerCommandArguments>
+ <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">$(OutDir)</LocalDebuggerWorkingDirectory>
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_agent_vc11\I386\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">false</LinkIncremental>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">agent</TargetName>
+ <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Release|Win32'"></LocalDebuggerCommandArguments>
+ <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">$(OutDir)</LocalDebuggerWorkingDirectory>
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">.\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_agent_vc11\AMD64\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</LinkIncremental>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">agent</TargetName>
+ <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Debug|x64'"></LocalDebuggerCommandArguments>
+ <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">$(OutDir)</LocalDebuggerWorkingDirectory>
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_agent_vc11\AMD64\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|x64'">false</LinkIncremental>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">agent</TargetName>
+ <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Release|x64'"></LocalDebuggerCommandArguments>
+ <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Release|x64'">$(OutDir)</LocalDebuggerWorkingDirectory>
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
+ </PropertyGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <Midl>
+ <PreprocessorDefinitions>%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <AdditionalIncludeDirectories>%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <TargetEnvironment>Win32</TargetEnvironment>
+ <TypeLibraryName>%(Filename).tlb</TypeLibraryName>
+ <HeaderFileName>%(Filename).h</HeaderFileName>
+ <InterfaceIdentifierFileName>%(Filename)_i.c</InterfaceIdentifierFileName>
+ <ProxyFileName>%(Filename)_p.c</ProxyFileName>
+ </Midl>
+ <ClCompile>
+ <Optimization>Disabled</Optimization>
+ <AdditionalIncludeDirectories>..\..;..\..\ASNMP;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <PreprocessorDefinitions>_DEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <MinimalRebuild>false</MinimalRebuild>
+ <RuntimeLibrary>MultiThreadedDebugDLL</RuntimeLibrary>
+ <RuntimeTypeInfo>true</RuntimeTypeInfo>
+ <WarningLevel>Level3</WarningLevel>
+ <DisableSpecificWarnings>4355;%(DisableSpecificWarnings)</DisableSpecificWarnings>
+ </ClCompile>
+ <ResourceCompile>
+ <PreprocessorDefinitions>_DEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <Culture>1033</Culture>
+ </ResourceCompile>
+ <Link>
+ <SubSystem>Console</SubSystem>
+ <GenerateDebugInformation>true</GenerateDebugInformation>
+ <AdditionalDependencies>ACEd.lib;asnmpd.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <OutputFile>$(OutDir)agent.exe</OutputFile>
+ <AdditionalLibraryDirectories>.;..\..\lib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+ </Link>
+<!-- "postclean" was made-up by MPC for use by vs_postclean.pl.
+ Check if msbuild has any support for a custom post-cleaning step
+<!-- No known equivalent for DeploymentTool in vc10:
+ </ItemDefinitionGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <Midl>
+ </Midl>
+ <ClCompile>
+ <Optimization>MaxSpeed</Optimization>
+ <IntrinsicFunctions>true</IntrinsicFunctions>
+ <PreprocessorDefinitions>NDEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
+ </ClCompile>
+ <ResourceCompile>
+ <PreprocessorDefinitions>NDEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <Link>
+ <AdditionalDependencies>ACE.lib;asnmp.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <OptimizeReferences>true</OptimizeReferences>
+ <EnableCOMDATFolding>true</EnableCOMDATFolding>
+ </Link>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
+ <Midl>
+ <TargetEnvironment>x64</TargetEnvironment>
+ </Midl>
+ <ClCompile>
+ <PreprocessorDefinitions>_DEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ </ClCompile>
+ <ResourceCompile>
+ <PreprocessorDefinitions>_DEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;_WIN64;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <Link>
+ Though we can set TargetMachine explicitly, VC++
+ can figure it out by project type. We don't need
+ to set it by ourselves.
+<!-- <TargetMachine>0</TargetMachine>-->
+ <AdditionalOptions>/machine:AMD64 %(AdditionalOptions)</AdditionalOptions>
+ </Link>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
+ <Midl>
+ </Midl>
+ <ClCompile>
+ <PreprocessorDefinitions>NDEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ </ClCompile>
+ <ResourceCompile>
+ <PreprocessorDefinitions>NDEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;_WIN64;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <Link>
+ </Link>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ <ClCompile Include="agent_impl.cpp">
+ </ClCompile>
+ <ClCompile Include="main.cpp">
+ </ClCompile>
+ <ClCompile Include="snmp_agent.cpp">
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="agent_impl.h" />
+ <ClInclude Include="snmp_agent.h" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="agent.mpc">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </None>
+ </ItemGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
+ <ImportGroup Label="ExtensionTargets">
+ </ImportGroup>
+</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc11.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc11.vcxproj.filters 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc11.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,41 +1,82 @@
- <ItemGroup>
- </Filter>
- </Filter>
- </Filter>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </ClInclude>
- </ClInclude>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
-</Project>
+<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup>
+ <Filter Include="Source Files">
+ <UniqueIdentifier>{B1F27843-FECA-1BAD-1396-8A04829757EE}</UniqueIdentifier>
+ <Extensions>cpp;cxx;cc;c;C</Extensions>
+ </Filter>
+ <Filter Include="Header Files">
+ <UniqueIdentifier>{06319535-FECA-1BAD-1396-8A04829757EE}</UniqueIdentifier>
+ <Extensions>h;hpp;hxx;hh</Extensions>
+ </Filter>
+ <Filter Include="Build Files">
+ <UniqueIdentifier>{A1909F1C-FECA-1BAD-1396-8A04829757EE}</UniqueIdentifier>
+ <Extensions>mpc;mpb;mwc</Extensions>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ <Filter>Source Files</Filter>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="agent_impl.h">
+ <Filter>Header Files</Filter>
+ </ClInclude>
+ <ClInclude Include="snmp_agent.h">
+ </ClInclude>
+ </ItemGroup>
+ <ItemGroup>
+ <Filter>Build Files</Filter>
+ </None>
+ </ItemGroup>
+</Project>
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc12.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc12.vcxproj (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc12.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,608 @@
+ </ItemGroup>
+ <ProjectGuid>{4C260F9C-FECA-1BAD-1396-8A04829757EE}</ProjectGuid>
+ </PropertyGroup>
+ <PlatformToolset>v120</PlatformToolset>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ <PropertyGroup>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_agent_vc12\I386\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_agent_vc12\I386\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_agent_vc12\AMD64\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_agent_vc12\AMD64\</IntDir>
+ </PropertyGroup>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+ </ImportGroup>
+</Project>
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc12.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc12.vcxproj.filters (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/agent/asnmp_agent_vc12.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,82 @@
+ <ItemGroup>
+ </Filter>
+ </Filter>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </ClInclude>
+ </ClInclude>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/GNUmakefile
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/GNUmakefile 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/GNUmakefile 2021-08-16 06:26:30 UTC (rev 9865)
@@ -8,7 +8,7 @@
# MPC Command:
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/GNUmakefile.asnmp_lib
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/GNUmakefile.asnmp_lib 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/GNUmakefile.asnmp_lib 2021-08-16 06:26:30 UTC (rev 9865)
@@ -4,7 +4,7 @@
# @file GNUmakefile.asnmp_lib
@@ -91,7 +91,12 @@
LIBCHECK = 1
else
- LIBCHECK ?= $(filter-out $(foreach lib,ACE,$(findstring $(lib),$(foreach libpath,. $(if $(ARCH),./$(ARCH)) ../../lib $(if $(ARCH),../../lib/$(ARCH)) /usr/lib /usr/lib64 $(INSLIB),$(wildcard $(libpath)/$(LIB_PREFIX)$(lib).* $(libpath)/$(lib).lib)))),ACE)
+ endif
+ LIBCHECK ?= $(filter-out $(foreach lib,ACE,$(findstring $(lib),$(foreach libpath,. $(if $(ARCH),./$(ARCH)) ../../lib $(if $(ARCH),../../lib/$(ARCH)) $(LIBCHECK_PREFIX)/lib $(LIBCHECK_PREFIX)/lib64 $(LIBCHECK_EXTRA_PATHS) $(INSLIB),$(wildcard $(libpath)/$(LIB_PREFIX)$(lib).* $(libpath)/$(lib).lib)))),ACE)
ifeq ($(LIBCHECK),)
LIBCHECK = 1
endif
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asn1.cpp
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asn1.cpp 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asn1.cpp 2021-08-16 06:26:30 UTC (rev 9865)
@@ -3,7 +3,7 @@
* @file asn1.cpp
- * $Id: asn1.cpp 97246 2013-08-07 07:10:20Z johnnyw $
+ * $Id: asn1.cpp 97885 2014-09-09 06:39:00Z johnnyw $
* The Vb class is an encapsulation of the snmp variable binding.
* This module contains the class definition for the variable binding (VB)
@@ -50,6 +50,7 @@
#include "asnmp/asn1.h"
#include "asnmp/snmp.h"
#include "ace/OS_NS_string.h"
+#include "ace/Global_Macros.h"
* parse_int - pulls a long out of an ASN int type.
@@ -375,7 +376,7 @@
ACE_TRACE("asn1::parse_header");
u_char *bufp = data;
- register int header_len;
+ ACE_REGISTER int header_len;
u_long asn_length;
/* this only works on data types < 30, i.e. no extension octets */
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc10.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc10.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc10.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,344 +0,0 @@
- </ItemGroup>
- <ProjectName>asnmp_lib</ProjectName>
- <ProjectGuid>{B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}</ProjectGuid>
- <RootNamespace>asnmp_lib</RootNamespace>
- </PropertyGroup>
- <ConfigurationType>DynamicLibrary</ConfigurationType>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- <PropertyGroup>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\..\lib\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_lib_vc10\I386\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">asnmpd</TargetName>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\..\lib\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_lib_vc10\I386\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">asnmp</TargetName>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\lib\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_lib_vc10\AMD64\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">asnmpd</TargetName>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\lib\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_lib_vc10\AMD64\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">asnmp</TargetName>
- </PropertyGroup>
- <Midl>
- </Midl>
- <ClCompile>
- <PreprocessorDefinitions>ASNMP_BUILD_DLL;_DEBUG;WIN32;_WINDOWS;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
- </ClCompile>
- <ResourceCompile>
- <Link>
- <AdditionalDependencies>ACEd.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
- <OutputFile>$(OutDir)asnmpd.dll</OutputFile>
- <ImportLibrary>..\..\lib\asnmpd.lib</ImportLibrary>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- <PreprocessorDefinitions>ASNMP_BUILD_DLL;NDEBUG;WIN32;_WINDOWS;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- </ClCompile>
- <ResourceCompile>
- <Link>
- <AdditionalDependencies>ACE.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
- <OutputFile>$(OutDir)asnmp.dll</OutputFile>
- <ImportLibrary>..\..\lib\asnmp.lib</ImportLibrary>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- <PreprocessorDefinitions>ASNMP_BUILD_DLL;_DEBUG;WIN32;_WINDOWS;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- <PreprocessorDefinitions>ASNMP_BUILD_DLL;NDEBUG;WIN32;_WINDOWS;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- <ClCompile Include="address.cpp">
- </ClCompile>
- <ClCompile Include="asn1.cpp">
- </ClCompile>
- <ClCompile Include="counter.cpp">
- </ClCompile>
- <ClCompile Include="ctr64.cpp">
- </ClCompile>
- <ClCompile Include="gauge.cpp">
- </ClCompile>
- <ClCompile Include="integer.cpp">
- </ClCompile>
- <ClCompile Include="octet.cpp">
- </ClCompile>
- <ClCompile Include="oid.cpp">
- </ClCompile>
- <ClCompile Include="pdu.cpp">
- </ClCompile>
- <ClCompile Include="sagent.cpp">
- </ClCompile>
- <ClCompile Include="snmp.cpp">
- </ClCompile>
- <ClCompile Include="target.cpp">
- </ClCompile>
- <ClCompile Include="timetick.cpp">
- </ClCompile>
- <ClCompile Include="transaction.cpp">
- </ClCompile>
- <ClCompile Include="vb.cpp">
- </ClCompile>
- <ClCompile Include="wpdu.cpp">
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- <ClInclude Include="address.h" />
- <ClInclude Include="asn1.h" />
- <ClInclude Include="counter.h" />
- <ClInclude Include="ctr64.h" />
- <ClInclude Include="gauge.h" />
- <ClInclude Include="integer.h" />
- <ClInclude Include="octet.h" />
- <ClInclude Include="oid.h" />
- <ClInclude Include="pdu.h" />
- <ClInclude Include="sagent.h" />
- <ClInclude Include="snmp.h" />
- <ClInclude Include="target.h" />
- <ClInclude Include="timetick.h" />
- <ClInclude Include="transaction.h" />
- <ClInclude Include="vb.h" />
- <ClInclude Include="wpdu.h" />
- </ItemGroup>
- <ItemGroup>
- <None Include="asnmp.mpc">
- </None>
- </ItemGroup>
- </ImportGroup>
-</Project>
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc10.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc10.vcxproj.filters 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc10.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,122 +0,0 @@
- <ItemGroup>
- <UniqueIdentifier>{B1F27843-FECA-1BAD-58A2-8A0582961CDA}</UniqueIdentifier>
- </Filter>
- <UniqueIdentifier>{06319535-FECA-1BAD-58A2-8A0582961CDA}</UniqueIdentifier>
- </Filter>
- <UniqueIdentifier>{A1909F1C-FECA-1BAD-58A2-8A0582961CDA}</UniqueIdentifier>
- </Filter>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- <ClInclude Include="address.h">
- </ClInclude>
- <ClInclude Include="asn1.h">
- </ClInclude>
- <ClInclude Include="counter.h">
- </ClInclude>
- <ClInclude Include="ctr64.h">
- </ClInclude>
- <ClInclude Include="gauge.h">
- </ClInclude>
- <ClInclude Include="integer.h">
- </ClInclude>
- <ClInclude Include="octet.h">
- </ClInclude>
- <ClInclude Include="oid.h">
- </ClInclude>
- <ClInclude Include="pdu.h">
- </ClInclude>
- <ClInclude Include="sagent.h">
- </ClInclude>
- <ClInclude Include="snmp.h">
- </ClInclude>
- <ClInclude Include="target.h">
- </ClInclude>
- <ClInclude Include="timetick.h">
- </ClInclude>
- <ClInclude Include="transaction.h">
- </ClInclude>
- <ClInclude Include="vb.h">
- </ClInclude>
- <ClInclude Include="wpdu.h">
- </ClInclude>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
-</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc11.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc11.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc11.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,344 +1,688 @@
- </ItemGroup>
- <ProjectGuid>{B9A9DCB1-FECA-1BAD-58A2-8A0582961CDA}</ProjectGuid>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- <PropertyGroup>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_lib_vc11\I386\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_lib_vc11\I386\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_lib_vc11\AMD64\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_lib_vc11\AMD64\</IntDir>
- </PropertyGroup>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
- </ImportGroup>
-</Project>
+ </ItemGroup>
+ <ProjectName>asnmp_lib</ProjectName>
+ <ProjectGuid>{B9A9DCB1-FECA-1BAD-58A2-8A0582961CDA}</ProjectGuid>
+ <RootNamespace>asnmp_lib</RootNamespace>
+ </PropertyGroup>
+ <ConfigurationType>DynamicLibrary</ConfigurationType>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ <PropertyGroup>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\..\lib\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_lib_vc11\I386\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">asnmpd</TargetName>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\..\lib\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_lib_vc11\I386\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">asnmp</TargetName>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\lib\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_lib_vc11\AMD64\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">asnmpd</TargetName>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\lib\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_lib_vc11\AMD64\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">asnmp</TargetName>
+ </PropertyGroup>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ <PreprocessorDefinitions>ASNMP_BUILD_DLL;_DEBUG;WIN32;_WINDOWS;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ <AdditionalDependencies>ACEd.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <OutputFile>$(OutDir)asnmpd.dll</OutputFile>
+ <ImportLibrary>..\..\lib\asnmpd.lib</ImportLibrary>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ <PreprocessorDefinitions>ASNMP_BUILD_DLL;NDEBUG;WIN32;_WINDOWS;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ <AdditionalDependencies>ACE.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <OutputFile>$(OutDir)asnmp.dll</OutputFile>
+ <ImportLibrary>..\..\lib\asnmp.lib</ImportLibrary>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ <PreprocessorDefinitions>ASNMP_BUILD_DLL;_DEBUG;WIN32;_WINDOWS;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ <PreprocessorDefinitions>ASNMP_BUILD_DLL;NDEBUG;WIN32;_WINDOWS;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ <ClCompile Include="address.cpp">
+ </ClCompile>
+ <ClCompile Include="asn1.cpp">
+ </ClCompile>
+ <ClCompile Include="counter.cpp">
+ </ClCompile>
+ <ClCompile Include="ctr64.cpp">
+ </ClCompile>
+ <ClCompile Include="gauge.cpp">
+ </ClCompile>
+ <ClCompile Include="integer.cpp">
+ </ClCompile>
+ <ClCompile Include="octet.cpp">
+ </ClCompile>
+ <ClCompile Include="oid.cpp">
+ </ClCompile>
+ <ClCompile Include="pdu.cpp">
+ </ClCompile>
+ <ClCompile Include="sagent.cpp">
+ </ClCompile>
+ <ClCompile Include="snmp.cpp">
+ </ClCompile>
+ <ClCompile Include="target.cpp">
+ </ClCompile>
+ <ClCompile Include="timetick.cpp">
+ </ClCompile>
+ <ClCompile Include="transaction.cpp">
+ </ClCompile>
+ <ClCompile Include="vb.cpp">
+ </ClCompile>
+ <ClCompile Include="wpdu.cpp">
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="address.h" />
+ <ClInclude Include="asn1.h" />
+ <ClInclude Include="counter.h" />
+ <ClInclude Include="ctr64.h" />
+ <ClInclude Include="gauge.h" />
+ <ClInclude Include="integer.h" />
+ <ClInclude Include="octet.h" />
+ <ClInclude Include="oid.h" />
+ <ClInclude Include="pdu.h" />
+ <ClInclude Include="sagent.h" />
+ <ClInclude Include="snmp.h" />
+ <ClInclude Include="target.h" />
+ <ClInclude Include="timetick.h" />
+ <ClInclude Include="transaction.h" />
+ <ClInclude Include="vb.h" />
+ <ClInclude Include="wpdu.h" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="asnmp.mpc">
+ </None>
+ </ItemGroup>
+ </ImportGroup>
+</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc11.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc11.vcxproj.filters 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc11.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,122 +1,244 @@
- <ItemGroup>
- </Filter>
- </Filter>
- </Filter>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ClInclude>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
-</Project>
+ <ItemGroup>
+ <UniqueIdentifier>{B1F27843-FECA-1BAD-58A2-8A0582961CDA}</UniqueIdentifier>
+ </Filter>
+ <UniqueIdentifier>{06319535-FECA-1BAD-58A2-8A0582961CDA}</UniqueIdentifier>
+ </Filter>
+ <UniqueIdentifier>{A1909F1C-FECA-1BAD-58A2-8A0582961CDA}</UniqueIdentifier>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="address.h">
+ </ClInclude>
+ <ClInclude Include="asn1.h">
+ </ClInclude>
+ <ClInclude Include="counter.h">
+ </ClInclude>
+ <ClInclude Include="ctr64.h">
+ </ClInclude>
+ <ClInclude Include="gauge.h">
+ </ClInclude>
+ <ClInclude Include="integer.h">
+ </ClInclude>
+ <ClInclude Include="octet.h">
+ </ClInclude>
+ <ClInclude Include="oid.h">
+ </ClInclude>
+ <ClInclude Include="pdu.h">
+ </ClInclude>
+ <ClInclude Include="sagent.h">
+ </ClInclude>
+ <ClInclude Include="snmp.h">
+ </ClInclude>
+ <ClInclude Include="target.h">
+ </ClInclude>
+ <ClInclude Include="timetick.h">
+ </ClInclude>
+ <ClInclude Include="transaction.h">
+ </ClInclude>
+ <ClInclude Include="vb.h">
+ </ClInclude>
+ <ClInclude Include="wpdu.h">
+ </ClInclude>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+</Project>
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc12.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc12.vcxproj (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc12.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,688 @@
+ </ItemGroup>
+ <ProjectGuid>{B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}</ProjectGuid>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ <PropertyGroup>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_lib_vc12\I386\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_lib_vc12\I386\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_lib_vc12\AMD64\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_lib_vc12\AMD64\</IntDir>
+ </PropertyGroup>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+ </ImportGroup>
+</Project>
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc12.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc12.vcxproj.filters (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_lib_vc12.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,244 @@
+ <ItemGroup>
+ </Filter>
+ </Filter>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ClInclude>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+</Project>
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc10.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc10.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc10.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,33 +0,0 @@
-# MPC Command:
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_lib", "asnmp_lib_vc10.vcxproj", "{B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}"
-EndProject
-Global
- GlobalSection(SolutionConfigurationPlatforms) = preSolution
- Debug|Win32 = Debug|Win32
- Debug|x64 = Debug|x64
- Release|Win32 = Release|Win32
- Release|x64 = Release|x64
- EndGlobalSection
- GlobalSection(ProjectConfigurationPlatforms) = postSolution
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.ActiveCfg = Debug|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.Build.0 = Debug|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.ActiveCfg = Debug|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.Build.0 = Debug|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.ActiveCfg = Release|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.Build.0 = Release|Win32
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.ActiveCfg = Release|x64
- {B9A9DCB0-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.Build.0 = Release|x64
- EndGlobalSection
- GlobalSection(SolutionProperties) = preSolution
- HideSolutionNode = FALSE
- EndGlobalSection
-EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc11.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc11.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc11.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -7,7 +7,7 @@
# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type vc11 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE -workers 16 -name_modifier "*_vc11"
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type vc11 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE -workers 12 -name_modifier "*_vc11"
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_lib", "asnmp_lib_vc11.vcxproj", "{B9A9DCB1-FECA-1BAD-58A2-8A0582961CDA}"
EndProject
Global
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc12.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc12.sln (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/asnmp/asnmp_vc12.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,33 @@
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio 2012
+# $Id: VC12WorkspaceCreator.pm 2211 2014-06-26 18:11:09Z elliott_c $
+# This file was generated by MPC. Any changes made directly to
+# this file will be lost the next time it is generated.
+# MPC Command:
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type vc12 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE -workers 12 -name_modifier "*_vc12"
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_lib", "asnmp_lib_vc12.vcxproj", "{B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}"
+EndProject
+Global
+ GlobalSection(SolutionConfigurationPlatforms) = preSolution
+ Debug|Win32 = Debug|Win32
+ Debug|x64 = Debug|x64
+ Release|Win32 = Release|Win32
+ Release|x64 = Release|x64
+ EndGlobalSection
+ GlobalSection(ProjectConfigurationPlatforms) = postSolution
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|Win32.Build.0 = Debug|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.ActiveCfg = Debug|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Debug|x64.Build.0 = Debug|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.ActiveCfg = Release|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|Win32.Build.0 = Release|Win32
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.ActiveCfg = Release|x64
+ {B9A9DCB2-FECA-1BAD-58A2-8A0582961CDA}.Release|x64.Build.0 = Release|x64
+ EndGlobalSection
+ EndGlobalSection
+EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/GNUmakefile
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/GNUmakefile 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/GNUmakefile 2021-08-16 06:26:30 UTC (rev 9865)
@@ -8,7 +8,7 @@
# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type gnuace -exclude "TAO/TAO_*.mwc,TAO/CIAO/CIAO_*.mwc" -workers 16 -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type gnuace -exclude "TAO/TAO_*.mwc,TAO/CIAO/CIAO_*.mwc" -workers 12 -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc10.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc10.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc10.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,83 +0,0 @@
-# MPC Command:
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get_async", "get\asnmp_example_get_async_vc10.vcxproj", "{B8E6506D-FECA-1BAD-6126-8A63C208BB19}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get", "get\asnmp_example_get_vc10.vcxproj", "{2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_next", "next\asnmp_example_next_vc10.vcxproj", "{BE5253E3-FECA-1BAD-82F6-8A65208B2128}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_set", "set\asnmp_example_set_vc10.vcxproj", "{6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_trap", "trap\asnmp_example_trap_vc10.vcxproj", "{D71253F8-FECA-1BAD-3462-8A64208A97BC}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_walk", "walk\asnmp_example_walk_vc10.vcxproj", "{EBA253FA-FECA-1BAD-17A9-8A64208AB477}"
-EndProject
-Global
- EndGlobalSection
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
- {B8E6506D-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
- {2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.ActiveCfg = Debug|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.Build.0 = Debug|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.ActiveCfg = Debug|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.Build.0 = Debug|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.ActiveCfg = Release|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.Build.0 = Release|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|x64.ActiveCfg = Release|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|x64.Build.0 = Release|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.ActiveCfg = Debug|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.Build.0 = Debug|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.ActiveCfg = Debug|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.Build.0 = Debug|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.ActiveCfg = Release|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.Build.0 = Release|Win32
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|x64.ActiveCfg = Release|x64
- {6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}.Release|x64.Build.0 = Release|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.ActiveCfg = Debug|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.Build.0 = Debug|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.ActiveCfg = Debug|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.Build.0 = Debug|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.ActiveCfg = Release|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.Build.0 = Release|Win32
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|x64.ActiveCfg = Release|x64
- {D71253F8-FECA-1BAD-3462-8A64208A97BC}.Release|x64.Build.0 = Release|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.ActiveCfg = Debug|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.Build.0 = Debug|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.ActiveCfg = Debug|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.Build.0 = Debug|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.ActiveCfg = Release|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.Build.0 = Release|Win32
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|x64.ActiveCfg = Release|x64
- {EBA253FA-FECA-1BAD-17A9-8A64208AB477}.Release|x64.Build.0 = Release|x64
- EndGlobalSection
- EndGlobalSection
-EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc11.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc11.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc11.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -7,7 +7,7 @@
# MPC Command:
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get_async", "get\asnmp_example_get_async_vc11.vcxproj", "{B8E6506C-FECA-1BAD-6126-8A63C208BB19}"
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get", "get\asnmp_example_get_vc11.vcxproj", "{2AB3B6B8-FECA-1BAD-6126-8A63C208BB19}"
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc12.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc12.sln (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/examples_vc12.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,83 @@
+# MPC Command:
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get_async", "get\asnmp_example_get_async_vc12.vcxproj", "{B8E6506F-FECA-1BAD-6126-8A63C208BB19}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get", "get\asnmp_example_get_vc12.vcxproj", "{2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_next", "next\asnmp_example_next_vc12.vcxproj", "{BE5253E1-FECA-1BAD-82F6-8A65208B2128}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_set", "set\asnmp_example_set_vc12.vcxproj", "{6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_trap", "trap\asnmp_example_trap_vc12.vcxproj", "{D71253FA-FECA-1BAD-3462-8A64208A97BC}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_walk", "walk\asnmp_example_walk_vc12.vcxproj", "{EBA253F8-FECA-1BAD-17A9-8A64208AB477}"
+EndProject
+Global
+ EndGlobalSection
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
+ {B8E6506F-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.ActiveCfg = Debug|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|Win32.Build.0 = Debug|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.ActiveCfg = Debug|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Debug|x64.Build.0 = Debug|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.ActiveCfg = Release|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|Win32.Build.0 = Release|Win32
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|x64.ActiveCfg = Release|x64
+ {2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}.Release|x64.Build.0 = Release|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.Build.0 = Debug|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.ActiveCfg = Debug|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.Build.0 = Debug|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.ActiveCfg = Release|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.Build.0 = Release|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|x64.ActiveCfg = Release|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|x64.Build.0 = Release|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.ActiveCfg = Debug|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|Win32.Build.0 = Debug|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.ActiveCfg = Debug|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Debug|x64.Build.0 = Debug|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.ActiveCfg = Release|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|Win32.Build.0 = Release|Win32
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|x64.ActiveCfg = Release|x64
+ {6AB3B6BA-FECA-1BAD-7526-8A63C208AF19}.Release|x64.Build.0 = Release|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.ActiveCfg = Debug|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|Win32.Build.0 = Debug|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.ActiveCfg = Debug|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Debug|x64.Build.0 = Debug|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.ActiveCfg = Release|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|Win32.Build.0 = Release|Win32
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|x64.ActiveCfg = Release|x64
+ {D71253FA-FECA-1BAD-3462-8A64208A97BC}.Release|x64.Build.0 = Release|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.ActiveCfg = Debug|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|Win32.Build.0 = Debug|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.ActiveCfg = Debug|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Debug|x64.Build.0 = Debug|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.ActiveCfg = Release|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|Win32.Build.0 = Release|Win32
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|x64.ActiveCfg = Release|x64
+ {EBA253F8-FECA-1BAD-17A9-8A64208AB477}.Release|x64.Build.0 = Release|x64
+ EndGlobalSection
+ GlobalSection(SolutionProperties) = preSolution
+ HideSolutionNode = FALSE
+ EndGlobalSection
+EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile 2021-08-16 06:26:30 UTC (rev 9865)
@@ -8,7 +8,7 @@
# MPC Command:
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile.asnmp_example_get
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile.asnmp_example_get 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile.asnmp_example_get 2021-08-16 06:26:30 UTC (rev 9865)
@@ -4,7 +4,7 @@
# @file GNUmakefile.asnmp_example_get
-# $Id: gnu.mpd 95691 2012-04-10 20:11:35Z mitza $
+# $Id: gnu.mpd 97814 2014-07-27 15:46:43Z wotte $
# This file was automatically generated by MPC. Any changes made directly to
@@ -66,7 +66,12 @@
ifeq ($(findstring k, $(MAKEFLAGS)),k)
LIBCHECK = 1
else
- LIBCHECK ?= $(filter-out $(foreach lib,asnmp ACE,$(findstring $(lib),$(foreach libpath,. $(if $(ARCH),./$(ARCH)) ../../../lib $(if $(ARCH),../../../lib/$(ARCH)) /usr/lib /usr/lib64 $(INSLIB),$(wildcard $(libpath)/$(LIB_PREFIX)$(lib).* $(libpath)/$(lib).lib)))),asnmp ACE)
+ ifeq ($(LIBCHECK_PREFIX),)
+ # If the user hasn't specified a place to look for installed libraries, let's set
+ # a reasonable default
+ LIBCHECK_PREFIX = /usr
+ endif
+ LIBCHECK ?= $(filter-out $(foreach lib,asnmp ACE,$(findstring $(lib),$(foreach libpath,. $(if $(ARCH),./$(ARCH)) ../../../lib $(if $(ARCH),../../../lib/$(ARCH)) $(LIBCHECK_PREFIX)/lib $(LIBCHECK_PREFIX)/lib64 $(LIBCHECK_EXTRA_PATHS) $(INSLIB),$(wildcard $(libpath)/$(LIB_PREFIX)$(lib).* $(libpath)/$(lib).lib)))),asnmp ACE)
ifeq ($(LIBCHECK),)
LIBCHECK = 1
endif
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile.asnmp_example_get_async
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile.asnmp_example_get_async 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/GNUmakefile.asnmp_example_get_async 2021-08-16 06:26:30 UTC (rev 9865)
@@ -4,7 +4,7 @@
# @file GNUmakefile.asnmp_example_get_async
@@ -66,7 +66,12 @@
LIBCHECK = 1
else
+ endif
ifeq ($(LIBCHECK),)
LIBCHECK = 1
endif
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc10.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc10.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc10.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,296 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<Project DefaultTargets="Build" ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
- <ItemGroup Label="ProjectConfigurations">
- <ProjectConfiguration Include="Debug|Win32">
- <Configuration>Debug</Configuration>
- <Platform>Win32</Platform>
- </ProjectConfiguration>
- <ProjectConfiguration Include="Release|Win32">
- <Configuration>Release</Configuration>
- <ProjectConfiguration Include="Debug|x64">
- <Platform>x64</Platform>
- <ProjectConfiguration Include="Release|x64">
- </ItemGroup>
- <PropertyGroup Label="Globals">
- <ProjectName>asnmp_example_get_async</ProjectName>
- <ProjectGuid>{B8E6506D-FECA-1BAD-6126-8A63C208BB19}</ProjectGuid>
- <RootNamespace>asnmp_example_get_async</RootNamespace>
- <Keyword>Win32Proj</Keyword>
- </PropertyGroup>
- <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
- <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
- <ConfigurationType>Application</ConfigurationType>
- <UseDebugLibraries>true</UseDebugLibraries>
- <CharacterSet>NotSet</CharacterSet>
- <PlatformToolset>v100</PlatformToolset>
- </PropertyGroup>
- <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
- <UseDebugLibraries>false</UseDebugLibraries>
- <WholeProgramOptimization>true</WholeProgramOptimization>
- </PropertyGroup>
- <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="Configuration">
- </PropertyGroup>
- <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="Configuration">
- </PropertyGroup>
- <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
- <ImportGroup Label="ExtensionSettings">
- </ImportGroup>
- <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
- <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
- </ImportGroup>
- <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
- </ImportGroup>
- <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="PropertySheets">
- </ImportGroup>
- <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="PropertySheets">
- </ImportGroup>
- <PropertyGroup Label="UserMacros" />
- <PropertyGroup>
- <_ProjectFileVersion>10.0.30319.1</_ProjectFileVersion>
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">.\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_get_async_vc10\I386\</IntDir>
- <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</LinkIncremental>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">get_async</TargetName>
- <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'"></LocalDebuggerCommandArguments>
- <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">$(OutDir)</LocalDebuggerWorkingDirectory>
- <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
- <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
- <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_get_async_vc10\I386\</IntDir>
- <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">false</LinkIncremental>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">get_async</TargetName>
- <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Release|Win32'"></LocalDebuggerCommandArguments>
- <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">$(OutDir)</LocalDebuggerWorkingDirectory>
- <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
- <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
- <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">.\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_get_async_vc10\AMD64\</IntDir>
- <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</LinkIncremental>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">get_async</TargetName>
- <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Debug|x64'"></LocalDebuggerCommandArguments>
- <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">$(OutDir)</LocalDebuggerWorkingDirectory>
- <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
- <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
- <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
- <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\</OutDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_get_async_vc10\AMD64\</IntDir>
- <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|x64'">false</LinkIncremental>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">get_async</TargetName>
- <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Release|x64'"></LocalDebuggerCommandArguments>
- <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Release|x64'">$(OutDir)</LocalDebuggerWorkingDirectory>
- <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
- <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
- <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
- </PropertyGroup>
- <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
- <Midl>
- <PreprocessorDefinitions>%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <AdditionalIncludeDirectories>%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
- <TargetEnvironment>Win32</TargetEnvironment>
- <TypeLibraryName>%(Filename).tlb</TypeLibraryName>
- <HeaderFileName>%(Filename).h</HeaderFileName>
- <InterfaceIdentifierFileName>%(Filename)_i.c</InterfaceIdentifierFileName>
- <ProxyFileName>%(Filename)_p.c</ProxyFileName>
- </Midl>
- <ClCompile>
- <Optimization>Disabled</Optimization>
- <AdditionalIncludeDirectories>..\..\..;..\..\..\ASNMP;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
- <PreprocessorDefinitions>_DEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <MinimalRebuild>false</MinimalRebuild>
- <RuntimeLibrary>MultiThreadedDebugDLL</RuntimeLibrary>
- <RuntimeTypeInfo>true</RuntimeTypeInfo>
- <WarningLevel>Level3</WarningLevel>
- <DisableSpecificWarnings>4355;%(DisableSpecificWarnings)</DisableSpecificWarnings>
- </ClCompile>
- <ResourceCompile>
- <PreprocessorDefinitions>_DEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <Culture>1033</Culture>
- </ResourceCompile>
- <Link>
- <SubSystem>Console</SubSystem>
- <GenerateDebugInformation>true</GenerateDebugInformation>
- <AdditionalDependencies>ACEd.lib;asnmpd.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
- <OutputFile>$(OutDir)get_async.exe</OutputFile>
- <AdditionalLibraryDirectories>.;..\..\..\lib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
- </Link>
-<!-- "postclean" was made-up by MPC for use by vs_postclean.pl.
- Check if msbuild has any support for a custom post-cleaning step
-<!-- No known equivalent for DeploymentTool in vc10:
- </ItemDefinitionGroup>
- <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
- <Midl>
- </Midl>
- <ClCompile>
- <Optimization>MaxSpeed</Optimization>
- <IntrinsicFunctions>true</IntrinsicFunctions>
- <PreprocessorDefinitions>NDEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
- </ClCompile>
- <ResourceCompile>
- <PreprocessorDefinitions>NDEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <Link>
- <AdditionalDependencies>ACE.lib;asnmp.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
- <OptimizeReferences>true</OptimizeReferences>
- <EnableCOMDATFolding>true</EnableCOMDATFolding>
- </Link>
- <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
- <Midl>
- <TargetEnvironment>x64</TargetEnvironment>
- </Midl>
- <ClCompile>
- <PreprocessorDefinitions>_DEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
- </ClCompile>
- <ResourceCompile>
- <PreprocessorDefinitions>_DEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;_WIN64;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <Link>
- Though we can set TargetMachine explicitly, VC++
- can figure it out by project type. We don't need
- to set it by ourselves.
-<!-- <TargetMachine>0</TargetMachine>-->
- <AdditionalOptions>/machine:AMD64 %(AdditionalOptions)</AdditionalOptions>
- </Link>
- <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
- <Midl>
- </Midl>
- <ClCompile>
- <PreprocessorDefinitions>NDEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- </ClCompile>
- <ResourceCompile>
- <PreprocessorDefinitions>NDEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;_WIN64;%(PreprocessorDefinitions)</PreprocessorDefinitions>
- <Link>
- </Link>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- <ClCompile Include="get_async.cpp">
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- <None Include="get.mpc">
- <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
- <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
- <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
- <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
- </None>
- </ItemGroup>
- <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
- <ImportGroup Label="ExtensionTargets">
- </ImportGroup>
-</Project>
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc10.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc10.vcxproj.filters 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc10.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,23 +0,0 @@
-<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
- <ItemGroup>
- <Filter Include="Source Files">
- <UniqueIdentifier>{B1F27843-FECA-1BAD-6126-8A63C208BB19}</UniqueIdentifier>
- <Extensions>cpp;cxx;cc;c;C</Extensions>
- </Filter>
- <Filter Include="Build Files">
- <UniqueIdentifier>{A1909F1C-FECA-1BAD-6126-8A63C208BB19}</UniqueIdentifier>
- <Extensions>mpc;mpb;mwc</Extensions>
- </Filter>
- </ItemGroup>
- <ItemGroup>
- <Filter>Source Files</Filter>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- <Filter>Build Files</Filter>
- </None>
- </ItemGroup>
-</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc11.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc11.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc11.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,296 +1,592 @@
- </ItemGroup>
- <ProjectGuid>{B8E6506C-FECA-1BAD-6126-8A63C208BB19}</ProjectGuid>
- </PropertyGroup>
- <PlatformToolset>v110</PlatformToolset>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- <PropertyGroup>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_get_async_vc11\I386\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_get_async_vc11\I386\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_get_async_vc11\AMD64\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_get_async_vc11\AMD64\</IntDir>
- </PropertyGroup>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
- </ImportGroup>
-</Project>
+<?xml version="1.0" encoding="utf-8"?>
+<Project DefaultTargets="Build" ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup Label="ProjectConfigurations">
+ <ProjectConfiguration Include="Debug|Win32">
+ <Configuration>Debug</Configuration>
+ <Platform>Win32</Platform>
+ </ProjectConfiguration>
+ <ProjectConfiguration Include="Release|Win32">
+ <Configuration>Release</Configuration>
+ <ProjectConfiguration Include="Debug|x64">
+ <Platform>x64</Platform>
+ <ProjectConfiguration Include="Release|x64">
+ </ItemGroup>
+ <PropertyGroup Label="Globals">
+ <ProjectName>asnmp_example_get_async</ProjectName>
+ <ProjectGuid>{B8E6506C-FECA-1BAD-6126-8A63C208BB19}</ProjectGuid>
+ <RootNamespace>asnmp_example_get_async</RootNamespace>
+ <Keyword>Win32Proj</Keyword>
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
+ <ConfigurationType>Application</ConfigurationType>
+ <UseDebugLibraries>true</UseDebugLibraries>
+ <CharacterSet>NotSet</CharacterSet>
+ <PlatformToolset>v110</PlatformToolset>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
+ <UseDebugLibraries>false</UseDebugLibraries>
+ <WholeProgramOptimization>true</WholeProgramOptimization>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="Configuration">
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="Configuration">
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
+ <ImportGroup Label="ExtensionSettings">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
+ <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="PropertySheets">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="PropertySheets">
+ </ImportGroup>
+ <PropertyGroup Label="UserMacros" />
+ <PropertyGroup>
+ <_ProjectFileVersion>10.0.30319.1</_ProjectFileVersion>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">.\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_get_async_vc11\I386\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</LinkIncremental>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">get_async</TargetName>
+ <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'"></LocalDebuggerCommandArguments>
+ <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">$(OutDir)</LocalDebuggerWorkingDirectory>
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_get_async_vc11\I386\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">false</LinkIncremental>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">get_async</TargetName>
+ <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Release|Win32'"></LocalDebuggerCommandArguments>
+ <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">$(OutDir)</LocalDebuggerWorkingDirectory>
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">.\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_get_async_vc11\AMD64\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</LinkIncremental>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">get_async</TargetName>
+ <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Debug|x64'"></LocalDebuggerCommandArguments>
+ <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">$(OutDir)</LocalDebuggerWorkingDirectory>
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_get_async_vc11\AMD64\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|x64'">false</LinkIncremental>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">get_async</TargetName>
+ <LocalDebuggerCommandArguments Condition="'$(Configuration)|$(Platform)'=='Release|x64'"></LocalDebuggerCommandArguments>
+ <LocalDebuggerWorkingDirectory Condition="'$(Configuration)|$(Platform)'=='Release|x64'">$(OutDir)</LocalDebuggerWorkingDirectory>
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
+ </PropertyGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <Midl>
+ <PreprocessorDefinitions>%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <AdditionalIncludeDirectories>%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <TargetEnvironment>Win32</TargetEnvironment>
+ <TypeLibraryName>%(Filename).tlb</TypeLibraryName>
+ <HeaderFileName>%(Filename).h</HeaderFileName>
+ <InterfaceIdentifierFileName>%(Filename)_i.c</InterfaceIdentifierFileName>
+ <ProxyFileName>%(Filename)_p.c</ProxyFileName>
+ </Midl>
+ <ClCompile>
+ <Optimization>Disabled</Optimization>
+ <AdditionalIncludeDirectories>..\..\..;..\..\..\ASNMP;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <PreprocessorDefinitions>_DEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <MinimalRebuild>false</MinimalRebuild>
+ <RuntimeLibrary>MultiThreadedDebugDLL</RuntimeLibrary>
+ <RuntimeTypeInfo>true</RuntimeTypeInfo>
+ <WarningLevel>Level3</WarningLevel>
+ <DisableSpecificWarnings>4355;%(DisableSpecificWarnings)</DisableSpecificWarnings>
+ </ClCompile>
+ <ResourceCompile>
+ <PreprocessorDefinitions>_DEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <Culture>1033</Culture>
+ </ResourceCompile>
+ <Link>
+ <SubSystem>Console</SubSystem>
+ <GenerateDebugInformation>true</GenerateDebugInformation>
+ <AdditionalDependencies>ACEd.lib;asnmpd.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <OutputFile>$(OutDir)get_async.exe</OutputFile>
+ <AdditionalLibraryDirectories>.;..\..\..\lib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+ </Link>
+<!-- "postclean" was made-up by MPC for use by vs_postclean.pl.
+ Check if msbuild has any support for a custom post-cleaning step
+<!-- No known equivalent for DeploymentTool in vc10:
+ </ItemDefinitionGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <Midl>
+ </Midl>
+ <ClCompile>
+ <Optimization>MaxSpeed</Optimization>
+ <IntrinsicFunctions>true</IntrinsicFunctions>
+ <PreprocessorDefinitions>NDEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
+ </ClCompile>
+ <ResourceCompile>
+ <PreprocessorDefinitions>NDEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <Link>
+ <AdditionalDependencies>ACE.lib;asnmp.lib;iphlpapi.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <OptimizeReferences>true</OptimizeReferences>
+ <EnableCOMDATFolding>true</EnableCOMDATFolding>
+ </Link>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
+ <Midl>
+ <TargetEnvironment>x64</TargetEnvironment>
+ </Midl>
+ <ClCompile>
+ <PreprocessorDefinitions>_DEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MPC_LIB_MODIFIER="d";%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ </ClCompile>
+ <ResourceCompile>
+ <PreprocessorDefinitions>_DEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;_WIN64;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <Link>
+ Though we can set TargetMachine explicitly, VC++
+ can figure it out by project type. We don't need
+ to set it by ourselves.
+<!-- <TargetMachine>0</TargetMachine>-->
+ <AdditionalOptions>/machine:AMD64 %(AdditionalOptions)</AdditionalOptions>
+ </Link>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
+ <Midl>
+ </Midl>
+ <ClCompile>
+ <PreprocessorDefinitions>NDEBUG;WIN32;_CONSOLE;_CRT_NONSTDC_NO_WARNINGS;_AMD64_;_WIN64;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ </ClCompile>
+ <ResourceCompile>
+ <PreprocessorDefinitions>NDEBUG;_CRT_SECURE_NO_WARNINGS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;_WIN64;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <Link>
+ </Link>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ <ClCompile Include="get_async.cpp">
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="get.mpc">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </None>
+ </ItemGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
+ <ImportGroup Label="ExtensionTargets">
+ </ImportGroup>
+</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc11.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc11.vcxproj.filters 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc11.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,23 +1,46 @@
- <ItemGroup>
- </Filter>
- </Filter>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
-</Project>
+<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup>
+ <Filter Include="Source Files">
+ <UniqueIdentifier>{B1F27843-FECA-1BAD-6126-8A63C208BB19}</UniqueIdentifier>
+ <Extensions>cpp;cxx;cc;c;C</Extensions>
+ </Filter>
+ <Filter Include="Build Files">
+ <UniqueIdentifier>{A1909F1C-FECA-1BAD-6126-8A63C208BB19}</UniqueIdentifier>
+ <Extensions>mpc;mpb;mwc</Extensions>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ <Filter>Source Files</Filter>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <Filter>Build Files</Filter>
+ </None>
+ </ItemGroup>
+</Project>
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc12.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc12.vcxproj (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc12.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,592 @@
+ </ItemGroup>
+ <ProjectGuid>{B8E6506F-FECA-1BAD-6126-8A63C208BB19}</ProjectGuid>
+ </PropertyGroup>
+ <PlatformToolset>v120</PlatformToolset>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ <PropertyGroup>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_get_async_vc12\I386\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_get_async_vc12\I386\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_get_async_vc12\AMD64\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_get_async_vc12\AMD64\</IntDir>
+ </PropertyGroup>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+ </ImportGroup>
+</Project>
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc12.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc12.vcxproj.filters (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_async_vc12.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,46 @@
+ <ItemGroup>
+ </Filter>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+</Project>
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc10.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc10.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc10.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,296 +0,0 @@
- </ItemGroup>
- <ProjectName>asnmp_example_get</ProjectName>
- <ProjectGuid>{2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}</ProjectGuid>
- <RootNamespace>asnmp_example_get</RootNamespace>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- <PropertyGroup>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_get_vc10\I386\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">get</TargetName>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_get_vc10\I386\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">get</TargetName>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_get_vc10\AMD64\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">get</TargetName>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_get_vc10\AMD64\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">get</TargetName>
- </PropertyGroup>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- <OutputFile>$(OutDir)get.exe</OutputFile>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- <ClCompile Include="get.cpp">
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
- </ImportGroup>
-</Project>
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc10.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc10.vcxproj.filters 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc10.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,23 +0,0 @@
- <ItemGroup>
- </Filter>
- </Filter>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
-</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc11.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc11.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc11.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,296 +1,592 @@
- </ItemGroup>
- <ProjectGuid>{2AB3B6B8-FECA-1BAD-6126-8A63C208BB19}</ProjectGuid>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- <PropertyGroup>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_get_vc11\I386\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_get_vc11\I386\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_get_vc11\AMD64\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_get_vc11\AMD64\</IntDir>
- </PropertyGroup>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
- </ImportGroup>
-</Project>
+ </ItemGroup>
+ <ProjectName>asnmp_example_get</ProjectName>
+ <ProjectGuid>{2AB3B6B8-FECA-1BAD-6126-8A63C208BB19}</ProjectGuid>
+ <RootNamespace>asnmp_example_get</RootNamespace>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ <PropertyGroup>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_get_vc11\I386\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">get</TargetName>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_get_vc11\I386\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">get</TargetName>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_get_vc11\AMD64\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">get</TargetName>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_get_vc11\AMD64\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">get</TargetName>
+ </PropertyGroup>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ <OutputFile>$(OutDir)get.exe</OutputFile>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ <ClCompile Include="get.cpp">
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+ </ImportGroup>
+</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc11.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc11.vcxproj.filters 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc11.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,23 +1,46 @@
- <ItemGroup>
- </Filter>
- </Filter>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
-</Project>
+ <ItemGroup>
+ </Filter>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+</Project>
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc12.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc12.vcxproj (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc12.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,592 @@
+ </ItemGroup>
+ <ProjectGuid>{2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}</ProjectGuid>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ <PropertyGroup>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_get_vc12\I386\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_get_vc12\I386\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_get_vc12\AMD64\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_get_vc12\AMD64\</IntDir>
+ </PropertyGroup>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+ </ImportGroup>
+</Project>
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc12.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc12.vcxproj.filters (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/asnmp_example_get_vc12.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,46 @@
+ <ItemGroup>
+ </Filter>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+</Project>
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc10.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc10.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc10.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,43 +0,0 @@
-Microsoft Visual Studio Solution File, Format Version 11.00
-# Visual Studio 2010
-# $Id: VC10WorkspaceCreator.pm 2035 2011-10-06 15:05:21Z johnnyw $
-# This file was generated by MPC. Any changes made directly to
-# this file will be lost the next time it is generated.
-# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type vc10 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE -workers 16 -name_modifier "*_vc10"
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get_async", "asnmp_example_get_async_vc10.vcxproj", "{B8E6506D-FECA-1BAD-6126-8A63C208BB19}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get", "asnmp_example_get_vc10.vcxproj", "{2AB3B6B9-FECA-1BAD-6126-8A63C208BB19}"
-EndProject
-Global
- EndGlobalSection
- EndGlobalSection
- EndGlobalSection
-EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc11.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc11.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc11.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -7,7 +7,7 @@
# MPC Command:
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get_async", "asnmp_example_get_async_vc11.vcxproj", "{B8E6506C-FECA-1BAD-6126-8A63C208BB19}"
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get", "asnmp_example_get_vc11.vcxproj", "{2AB3B6B8-FECA-1BAD-6126-8A63C208BB19}"
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc12.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc12.sln (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/get/get_vc12.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,43 @@
+# MPC Command:
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get_async", "asnmp_example_get_async_vc12.vcxproj", "{B8E6506F-FECA-1BAD-6126-8A63C208BB19}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_get", "asnmp_example_get_vc12.vcxproj", "{2AB3B6BB-FECA-1BAD-6126-8A63C208BB19}"
+EndProject
+Global
+ EndGlobalSection
+ EndGlobalSection
+ EndGlobalSection
+EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/GNUmakefile
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/GNUmakefile 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/GNUmakefile 2021-08-16 06:26:30 UTC (rev 9865)
@@ -8,7 +8,7 @@
# MPC Command:
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/GNUmakefile.asnmp_example_next
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/GNUmakefile.asnmp_example_next 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/GNUmakefile.asnmp_example_next 2021-08-16 06:26:30 UTC (rev 9865)
@@ -4,7 +4,7 @@
# @file GNUmakefile.asnmp_example_next
@@ -66,7 +66,12 @@
LIBCHECK = 1
else
+ endif
ifeq ($(LIBCHECK),)
LIBCHECK = 1
endif
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc10.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc10.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc10.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,296 +0,0 @@
- </ItemGroup>
- <ProjectName>asnmp_example_next</ProjectName>
- <ProjectGuid>{BE5253E3-FECA-1BAD-82F6-8A65208B2128}</ProjectGuid>
- <RootNamespace>asnmp_example_next</RootNamespace>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- <PropertyGroup>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_next_vc10\I386\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">next</TargetName>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_next_vc10\I386\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">next</TargetName>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_next_vc10\AMD64\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">next</TargetName>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_next_vc10\AMD64\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">next</TargetName>
- </PropertyGroup>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- <OutputFile>$(OutDir)next.exe</OutputFile>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- <ClCompile Include="next.cpp">
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- <None Include="next.mpc">
- </None>
- </ItemGroup>
- </ImportGroup>
-</Project>
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc10.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc10.vcxproj.filters 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc10.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,23 +0,0 @@
- <ItemGroup>
- <UniqueIdentifier>{B1F27843-FECA-1BAD-82F6-8A65208B2128}</UniqueIdentifier>
- </Filter>
- <UniqueIdentifier>{A1909F1C-FECA-1BAD-82F6-8A65208B2128}</UniqueIdentifier>
- </Filter>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
-</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc11.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc11.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc11.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,296 +1,592 @@
- </ItemGroup>
- <ProjectGuid>{BE5253E2-FECA-1BAD-82F6-8A65208B2128}</ProjectGuid>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- <PropertyGroup>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_next_vc11\I386\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_next_vc11\I386\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_next_vc11\AMD64\</IntDir>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_next_vc11\AMD64\</IntDir>
- </PropertyGroup>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
- </ImportGroup>
-</Project>
+ </ItemGroup>
+ <ProjectName>asnmp_example_next</ProjectName>
+ <ProjectGuid>{BE5253E2-FECA-1BAD-82F6-8A65208B2128}</ProjectGuid>
+ <RootNamespace>asnmp_example_next</RootNamespace>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ <PropertyGroup>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_next_vc11\I386\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">next</TargetName>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_next_vc11\I386\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">next</TargetName>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_next_vc11\AMD64\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">next</TargetName>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_next_vc11\AMD64\</IntDir>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">next</TargetName>
+ </PropertyGroup>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ <OutputFile>$(OutDir)next.exe</OutputFile>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ <ClCompile Include="next.cpp">
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="next.mpc">
+ </None>
+ </ItemGroup>
+ </ImportGroup>
+</Project>
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc11.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc11.vcxproj.filters 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc11.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,23 +1,46 @@
- <ItemGroup>
- </Filter>
- </Filter>
- </ItemGroup>
- <ItemGroup>
- </ClCompile>
- </ItemGroup>
- <ItemGroup>
- </None>
- </ItemGroup>
-</Project>
+ <ItemGroup>
+ <UniqueIdentifier>{B1F27843-FECA-1BAD-82F6-8A65208B2128}</UniqueIdentifier>
+ </Filter>
+ <UniqueIdentifier>{A1909F1C-FECA-1BAD-82F6-8A65208B2128}</UniqueIdentifier>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+</Project>
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc12.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc12.vcxproj (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc12.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,592 @@
+ </ItemGroup>
+ <ProjectGuid>{BE5253E1-FECA-1BAD-82F6-8A65208B2128}</ProjectGuid>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ </ImportGroup>
+ <PropertyGroup>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_next_vc12\I386\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_next_vc12\I386\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_next_vc12\AMD64\</IntDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_next_vc12\AMD64\</IntDir>
+ </PropertyGroup>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <Midl>
+ </Midl>
+ <ClCompile>
+ </ClCompile>
+ <ResourceCompile>
+ <Link>
+ </Link>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+ </ImportGroup>
+</Project>
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc12.vcxproj.filters
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc12.vcxproj.filters (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/asnmp_example_next_vc12.vcxproj.filters 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,46 @@
+ <ItemGroup>
+ </Filter>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ </None>
+ </ItemGroup>
+</Project>
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc10.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc10.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc10.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,33 +0,0 @@
-# MPC Command:
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_next", "asnmp_example_next_vc10.vcxproj", "{BE5253E3-FECA-1BAD-82F6-8A65208B2128}"
-EndProject
-Global
- GlobalSection(SolutionConfigurationPlatforms) = preSolution
- Debug|Win32 = Debug|Win32
- Debug|x64 = Debug|x64
- Release|Win32 = Release|Win32
- Release|x64 = Release|x64
- EndGlobalSection
- GlobalSection(ProjectConfigurationPlatforms) = postSolution
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.ActiveCfg = Debug|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.Build.0 = Debug|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.ActiveCfg = Debug|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.Build.0 = Debug|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.ActiveCfg = Release|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.Build.0 = Release|Win32
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|x64.ActiveCfg = Release|x64
- {BE5253E3-FECA-1BAD-82F6-8A65208B2128}.Release|x64.Build.0 = Release|x64
- EndGlobalSection
- GlobalSection(SolutionProperties) = preSolution
- HideSolutionNode = FALSE
- EndGlobalSection
-EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc11.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc11.sln 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc11.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -7,7 +7,7 @@
# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type vc11 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE -workers 16 -name_modifier "*_vc11"
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type vc11 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE -workers 12 -name_modifier "*_vc11"
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_next", "asnmp_example_next_vc11.vcxproj", "{BE5253E2-FECA-1BAD-82F6-8A65208B2128}"
EndProject
Global
Added: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc12.sln
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc12.sln (rev 0)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/next/next_vc12.sln 2021-08-16 06:26:30 UTC (rev 9865)
@@ -0,0 +1,33 @@
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio 2012
+# $Id: VC12WorkspaceCreator.pm 2211 2014-06-26 18:11:09Z elliott_c $
+# This file was generated by MPC. Any changes made directly to
+# this file will be lost the next time it is generated.
+# MPC Command:
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type vc12 -exclude TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_OpenDDS.mwc,TAO/CIAO/CIAO_TAO_DAnCE_OpenDDS_shapes.mwc -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE -workers 12 -name_modifier "*_vc12"
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "asnmp_example_next", "asnmp_example_next_vc12.vcxproj", "{BE5253E1-FECA-1BAD-82F6-8A65208B2128}"
+EndProject
+Global
+ GlobalSection(SolutionConfigurationPlatforms) = preSolution
+ Debug|Win32 = Debug|Win32
+ Debug|x64 = Debug|x64
+ Release|Win32 = Release|Win32
+ Release|x64 = Release|x64
+ EndGlobalSection
+ GlobalSection(ProjectConfigurationPlatforms) = postSolution
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.ActiveCfg = Debug|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|Win32.Build.0 = Debug|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.ActiveCfg = Debug|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Debug|x64.Build.0 = Debug|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.ActiveCfg = Release|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|Win32.Build.0 = Release|Win32
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|x64.ActiveCfg = Release|x64
+ {BE5253E1-FECA-1BAD-82F6-8A65208B2128}.Release|x64.Build.0 = Release|x64
+ EndGlobalSection
+ EndGlobalSection
+EndGlobal
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/GNUmakefile
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/GNUmakefile 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/GNUmakefile 2021-08-16 06:26:30 UTC (rev 9865)
@@ -8,7 +8,7 @@
# MPC Command:
-# /home/build/DOC_ROOT/stage-904/ACE_wrappers/bin/mwc.pl -type gnuace -exclude "TAO/TAO_*.mwc,TAO/CIAO/CIAO_*.mwc" -workers 16 -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-904/ACE_wrappers/TAO/DAnCE
+# /home/build/DOC_ROOT/stage-916/ACE_wrappers/bin/mwc.pl -type gnuace -exclude "TAO/TAO_*.mwc,TAO/CIAO/CIAO_*.mwc" -workers 12 -recurse -hierarchy -relative ACE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers -relative TAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO -relative CIAO_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/CIAO -relative DANCE_ROOT=/home/build/DOC_ROOT/stage-916/ACE_wrappers/TAO/DAnCE
Modified: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/GNUmakefile.asnmp_example_set
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/GNUmakefile.asnmp_example_set 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/GNUmakefile.asnmp_example_set 2021-08-16 06:26:30 UTC (rev 9865)
@@ -4,7 +4,7 @@
# @file GNUmakefile.asnmp_example_set
@@ -66,7 +66,12 @@
LIBCHECK = 1
else
+ endif
ifeq ($(LIBCHECK),)
LIBCHECK = 1
endif
Deleted: sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/asnmp_example_set_vc10.vcxproj
--- sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/asnmp_example_set_vc10.vcxproj 2021-07-16 09:04:49 UTC (rev 9864)
+++ sandbox/adsk/trunk/Oem/ACE/ACE_wrappers/ASNMP/examples/set/asnmp_example_set_vc10.vcxproj 2021-08-16 06:26:30 UTC (rev 9865)
@@ -1,296 +0,0 @@
- </ItemGroup>
- <ProjectName>asnmp_example_set</ProjectName>
- <ProjectGuid>{6AB3B6B8-FECA-1BAD-7526-8A63C208AF19}</ProjectGuid>
- <RootNamespace>asnmp_example_set</RootNamespace>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- </ImportGroup>
- <PropertyGroup>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Debug\asnmp_example_set_vc10\I386\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">set</TargetName>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Release\asnmp_example_set_vc10\I386\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">set</TargetName>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Debug\asnmp_example_set_vc10\AMD64\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">set</TargetName>
- <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Release\asnmp_example_set_vc10\AMD64\</IntDir>
- <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">set</TargetName>
- </PropertyGroup>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- <OutputFile>$(OutDir)set.exe</OutputFile>
- </Link>
- <Midl>
- </Midl>
- <ClCompile>
- </ClCompile>
- <ResourceCompile>
- <Link>
- </Link>
- <Midl>
