[mapguide-commits] r9863 - sandbox/jng/vanilla_swig/Bindings
svn_mapguide at osgeo.org
Fri Jul 16 01:22:18 PDT 2021
Author: jng
Date: 2021-07-16 01:22:17 -0700 (Fri, 16 Jul 2021)
New Revision: 9863
sandbox/jng/vanilla_swig/Bindings/TODO.txt
TODO update
Modified: sandbox/jng/vanilla_swig/Bindings/TODO.txt
--- sandbox/jng/vanilla_swig/Bindings/TODO.txt 2021-06-19 09:20:45 UTC (rev 9862)
+++ sandbox/jng/vanilla_swig/Bindings/TODO.txt 2021-07-16 08:22:17 UTC (rev 9863)
@@ -9,6 +9,7 @@
- [ ] Relocate/remove existing test code
- [x] Move packages dir up to to top-level MgDev subdirectory and make sure nuget.config sources from this dir
- [ ] Update build batch files to build bindings/portable
+ - [ ] Fix binding pre-build events to copy ACE/GEOS/lib_json dlls from their respective Oem directories
- Split .net binding into the Foundation/Geometry/PlatformBase/MapGuideCommon/Web layout (https://github.com/jumpinjackie/mapguide-api-bindings/issues/18)
- [x] Add .targets files to each C# project so that native dlls are copied properly when consumed by legacy .net framework applications/libraries
- [x] Consolidate TestCommon and TestMapGuideApi .net projects to unified netstandard2.0 libraries
More information about the mapguide-commits
