[mapguide-commits] r9854 - trunk/MgDev/Web/src/mapviewerjava
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Jun 17 08:58:40 PDT 2021
Author: jng
Date: 2021-06-17 08:58:40 -0700 (Thu, 17 Jun 2021)
New Revision: 9854
   trunk/MgDev/Web/src/mapviewerjava/ajaxviewerabout.jsp
   trunk/MgDev/Web/src/mapviewerjava/buffer.jsp
   trunk/MgDev/Web/src/mapviewerjava/common.jsp
   trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp
   trunk/MgDev/Web/src/mapviewerjava/init.jsp
   trunk/MgDev/Web/src/mapviewerjava/legend.jsp
   trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp
   trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp
   trunk/MgDev/Web/src/mapviewerjava/measure.jsp
   trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp
   trunk/MgDev/Web/src/mapviewerjava/search.jsp
   trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp
   trunk/MgDev/Web/src/mapviewerjava/serveradminhelper.jsp
   trunk/MgDev/Web/src/mapviewerjava/taskframe.jsp
#2839: Migrate Java AJAX viewer over to use MapGuideApiEx.jar
Modified: trunk/MgDev/Web/src/mapviewerjava/ajaxviewerabout.jsp
--- trunk/MgDev/Web/src/mapviewerjava/ajaxviewerabout.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/ajaxviewerabout.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -57,17 +57,17 @@
     // Obtain server version info
     MgUserInformation userInfo = new MgUserInformation();
-    userInfo.SetMgSessionId(sessionId);
-    userInfo.SetClientIp(GetClientIp(request));
-    userInfo.SetClientAgent(GetClientAgent());
+    userInfo.setMgSessionId(sessionId);
+    userInfo.setClientIp(GetClientIp(request));
+    userInfo.setClientAgent(GetClientAgent());
     MgSite site = new MgSite();
-    site.Open(userInfo);
+    site.open(userInfo);
     MgServerAdmin serverAdmin = new MgServerAdmin();
-    serverAdmin.Open(userInfo);
-    MgPropertyCollection infoProps = serverAdmin.GetInformationProperties();
-    MgStringProperty versionProp = (MgStringProperty)infoProps.GetItem(MgServerInformationProperties.ServerVersion);
-    serverVersion = versionProp.GetValue();
+    serverAdmin.open(userInfo);
+    MgPropertyCollection infoProps = serverAdmin.getInformationProperties();
+    MgStringProperty versionProp = (MgStringProperty)infoProps.getItem(MgServerInformationProperties.ServerVersion);
+    serverVersion = versionProp.getValue();
     String vals[] = { titleBar,
         titleBar,
Modified: trunk/MgDev/Web/src/mapviewerjava/buffer.jsp
--- trunk/MgDev/Web/src/mapviewerjava/buffer.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/buffer.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -87,14 +87,14 @@
         InitializeWebTier();
         MgUserInformation cred = new MgUserInformation(sessionId);
-        cred.SetClientIp(GetClientIp(request));
-        cred.SetClientAgent(GetClientAgent());
+        cred.setClientIp(GetClientIp(request));
+        cred.setClientAgent(GetClientAgent());
         //connect to the site and get a feature service and a resource service instances
         MgSiteConnection site = new MgSiteConnection();
-        site.Open(cred);
-        MgFeatureService featureSrvc = (MgFeatureService)site.CreateService(MgServiceType.FeatureService);
-        MgResourceService resourceSrvc = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
+        site.open(cred);
+        MgFeatureService featureSrvc = (MgFeatureService)site.createService(MgServiceType.FeatureService);
+        MgResourceService resourceSrvc = (MgResourceService)site.createService(MgServiceType.ResourceService);
         MgResourceIdentifier dataSourceId = new MgResourceIdentifier(dataSource);
         MgResourceIdentifier layerDefId = new MgResourceIdentifier(layerDef);
@@ -102,11 +102,11 @@
         //load the map runtime state
         MgMap map = new MgMap(site);
-        map.Open(mapName);
+        map.open(mapName);
         //locate the buffer layer in the map. It might or might not already exist
-        MgLayerCollection layers = map.GetLayers();
+        MgLayerCollection layers = map.getLayers();
         MgLayer layer = FindLayer(layers, bufferName);
         String[] layerNames = layersParam.split(",");
@@ -124,14 +124,14 @@
         MgCoordinateSystemFactory srsFactory = new MgCoordinateSystemFactory();
         String srsDefMap = GetMapSrs(map);
         String mapSrsUnits = "";
-        MgCoordinateSystem srsMap = srsFactory.Create(srsDefMap);
-        boolean arbitraryMapSrs = (srsMap.GetType() == MgCoordinateSystemType.Arbitrary);
+        MgCoordinateSystem srsMap = srsFactory.create(srsDefMap);
+        boolean arbitraryMapSrs = (srsMap.getType() == MgCoordinateSystemType.Arbitrary);
         if(arbitraryMapSrs)
-            mapSrsUnits = srsMap.GetUnits();
+            mapSrsUnits = srsMap.getUnits();
         //Create/Modify layer definition
         MgByteReader layerDefContent = BuildLayerDefinitionContent();
-        resourceSrvc.SetResource(layerDefId, layerDefContent, null);
+        resourceSrvc.setResource(layerDefId, layerDefContent, null);
         if(layer == null)
@@ -140,44 +140,44 @@
             MgClassDefinition classDef = new MgClassDefinition();
-            classDef.SetName(featureName);
-            classDef.SetDescription(MgLocalizer.GetString("BUFFERCLASSDESCR", locale));
-            classDef.SetDefaultGeometryPropertyName("GEOM");
+            classDef.setName(featureName);
+            classDef.setDescription(MgLocalizer.GetString("BUFFERCLASSDESCR", locale));
+            classDef.setDefaultGeometryPropertyName("GEOM");
             //Set KEY property
             MgDataPropertyDefinition propKey = new MgDataPropertyDefinition("KEY");
-            propKey.SetDataType(MgPropertyType.Int32);
-            propKey.SetAutoGeneration(true);
-            propKey.SetReadOnly(true);
-            classDef.GetIdentityProperties().Add(propKey);
-            classDef.GetProperties().Add(propKey);
+            propKey.setDataType(MgPropertyType.Int32);
+            propKey.setAutoGeneration(true);
+            propKey.setReadOnly(true);
+            classDef.getIdentityProperties().add(propKey);
+            classDef.getProperties().add(propKey);
             //Set ID property. Hold this segment ID
             MgDataPropertyDefinition propID = new MgDataPropertyDefinition("ID");
-            propID.SetDataType(MgPropertyType.Int32);
-            classDef.GetProperties().Add(propID);
+            propID.setDataType(MgPropertyType.Int32);
+            classDef.getProperties().add(propID);
             //Set geometry property
             MgGeometricPropertyDefinition geomProp = new MgGeometricPropertyDefinition("GEOM");
-            //geomProp.SetGeometryTypes(MgFeatureGeometricType.mfgtSurface); //TODO use the constant when exposed
-            geomProp.SetGeometryTypes(4);
-            classDef.GetProperties().Add(geomProp);
+            //geomProp.setGeometryTypes(MgFeatureGeometricType.mfgtSurface); //TODO use the constant when exposed
+            geomProp.setGeometryTypes(4);
+            classDef.getProperties().add(geomProp);
             //Create the schema
             MgFeatureSchema schema = new MgFeatureSchema("BufferSchema", MgLocalizer.GetString("BUFFERSCHEMADESCR", locale));
-            schema.GetClasses().Add(classDef);
+            schema.getClasses().add(classDef);
             //finally, creation of the feature source
             MgFileFeatureSourceParams sdfParams = new MgFileFeatureSourceParams("OSGeo.SDF", "LatLong", srsDefMap, schema);
-            featureSrvc.CreateFeatureSource(dataSourceId, sdfParams);
+            featureSrvc.createFeatureSource(dataSourceId, sdfParams);
             //Add layer to map
             layer = new MgLayer(layerDefId, resourceSrvc);
-            layer.SetName(bufferName);
-            layer.SetLegendLabel(bufferName);
-            layer.SetDisplayInLegend(true);
-            layer.SetSelectable(true);
-            layers.Insert(0, layer);
+            layer.setName(bufferName);
+            layer.setLegendLabel(bufferName);
+            layer.setDisplayInLegend(true);
+            layer.setSelectable(true);
+            layers.insert(0, layer);
         else
@@ -187,7 +187,7 @@
         MgSelection sel = new MgSelection(map, selText);
-        MgReadOnlyLayerCollection selLayers = sel.GetLayers();
+        MgReadOnlyLayerCollection selLayers = sel.getLayers();
         MgAgfReaderWriter agfRW = new MgAgfReaderWriter();
         MgGeometryCollection bufferGeometries = new MgGeometryCollection();
@@ -203,11 +203,11 @@
         MgGeometryCollection inputGeometries = new MgGeometryCollection();
         int bufferFeatures = 0;
-        for(int li =0; li < selLayers.GetCount(); li++)
+        for(int li =0; li < selLayers.getCount(); li++)
-            MgLayer selLayer = (MgLayer) selLayers.GetItem(li);
+            MgLayer selLayer = (MgLayer) selLayers.getItem(li);
             boolean inputLayer = false;
-            String selLayerName = selLayer.GetName();
+            String selLayerName = selLayer.getName();
             for(int il = 0; il < layerNames.length; il++)
                 if(layerNames[il].equals(selLayerName))
@@ -221,11 +221,11 @@
             // get the data source SRS
-            MgResourceIdentifier featSourceId = new MgResourceIdentifier(selLayer.GetFeatureSourceId());
-            MgSpatialContextReader ctxs = featureSrvc.GetSpatialContexts(featSourceId, false);
+            MgResourceIdentifier featSourceId = new MgResourceIdentifier(selLayer.getFeatureSourceId());
+            MgSpatialContextReader ctxs = featureSrvc.getSpatialContexts(featSourceId, false);
             String srsDefDs = "";
-            if(ctxs != null && ctxs.ReadNext())
-                srsDefDs = ctxs.GetCoordinateSystemWkt();
+            if(ctxs != null && ctxs.readNext())
+                srsDefDs = ctxs.getCoordinateSystemWkt();
             if(srsDefDs == null || srsDefDs.length() == 0)
@@ -233,12 +233,12 @@
                 continue;
-            srsDs = srsFactory.Create(srsDefDs);
-            boolean arbitraryDsSrs = (srsDs.GetType() == MgCoordinateSystemType.Arbitrary);
+            srsDs = srsFactory.create(srsDefDs);
+            boolean arbitraryDsSrs = (srsDs.getType() == MgCoordinateSystemType.Arbitrary);
             String dsSrsUnits = "";
             if(arbitraryDsSrs)
-                dsSrsUnits = srsDs.GetUnits();
+                dsSrsUnits = srsDs.getUnits();
             // exclude layer if:
             //  the map is non-arbitrary and the layer is arbitrary or vice-versa
@@ -253,12 +253,12 @@
             // calculate distance in the data source SRS units
-            double dist = srsDs.ConvertMetersToCoordinateSystemUnits(distance);
+            double dist = srsDs.convertMetersToCoordinateSystemUnits(distance);
             // calculate great circle unless data source srs is arbitrary
             MgCoordinateSystemMeasure measure;
             if(!arbitraryDsSrs)
-                 measure = srsDs.GetMeasure();
+                 measure = srsDs.getMeasure();
             else
                  measure = null;
@@ -265,43 +265,43 @@
             // create a SRS transformer if necessary
             MgCoordinateSystemTransform srsXform;
             if(!srsDefDs.equals(srsDefMap))
-                srsXform = srsFactory.GetTransform(srsDs, srsMap);
+                srsXform = srsFactory.getTransform(srsDs, srsMap);
             else
                 srsXform = null;
-            String featureClassName = selLayer.GetFeatureClassName();
-            String filter = sel.GenerateFilter(selLayer, featureClassName);
+            String featureClassName = selLayer.getFeatureClassName();
+            String filter = sel.generateFilter(selLayer, featureClassName);
             if(filter == null || filter.length() == 0)
                 continue;
-            MgClassDefinition clsDef = selLayer.GetClassDefinition();
+            MgClassDefinition clsDef = selLayer.getClassDefinition();
             MgFeatureQueryOptions query = BuildFeatureQueryOptions(clsDef);
-            query.SetFilter(filter);
+            query.setFilter(filter);
-            MgResourceIdentifier featureSource = new MgResourceIdentifier(selLayer.GetFeatureSourceId());
+            MgResourceIdentifier featureSource = new MgResourceIdentifier(selLayer.getFeatureSourceId());
-            MgFeatureReader features = featureSrvc.SelectFeatures(featureSource, featureClassName, query);
+            MgFeatureReader features = featureSrvc.selectFeatures(featureSource, featureClassName, query);
-            if(features.ReadNext())
+            if(features.readNext())
-                MgClassDefinition classDef = features.GetClassDefinition();
-                String geomPropName = classDef.GetDefaultGeometryPropertyName();
+                MgClassDefinition classDef = features.getClassDefinition();
+                String geomPropName = classDef.getDefaultGeometryPropertyName();
                 do
                     if (geomPropName == null || geomPropName.equals("")) {
-                        geomPropName = selLayer.GetFeatureGeometryName();
+                        geomPropName = selLayer.getFeatureGeometryName();
-                    MgByteReader geomReader = features.GetGeometry(geomPropName);
-                    MgGeometry geom = agfRW.Read(geomReader);
+                    MgByteReader geomReader = features.getGeometry(geomPropName);
+                    MgGeometry geom = agfRW.read(geomReader);
                     if(merge == 0)
-                        geomBuffer = geom.Buffer(dist, measure);
+                        geomBuffer = geom.buffer(dist, measure);
                         if (geomBuffer != null)
                             if(srsXform != null)
-                                geomBuffer = (MgGeometry)geomBuffer.Transform(srsXform);
+                                geomBuffer = (MgGeometry)geomBuffer.transform(srsXform);
                             AddFeatureToCollection(propCollection, agfRW, featId++, geomBuffer);
                             bufferFeatures++;
@@ -309,29 +309,29 @@
                     else
-                            geom = (MgGeometry)geom.Transform(srsXform);
-                        inputGeometries.Add(geom);
+                            geom = (MgGeometry)geom.transform(srsXform);
+                        inputGeometries.add(geom);
-                while(features.ReadNext());
+                while(features.readNext());
-                features.Close();
+                features.close();
         if(merge == 1)
-            if(inputGeometries.GetCount() > 0)
+            if(inputGeometries.getCount() > 0)
-                double dist = srsMap.ConvertMetersToCoordinateSystemUnits(distance);
+                double dist = srsMap.convertMetersToCoordinateSystemUnits(distance);
                 if(!arbitraryMapSrs)
-                    measure = srsMap.GetMeasure();
+                    measure = srsMap.getMeasure();
                 else
                     measure = null;
                 MgGeometryFactory geomFactory = new MgGeometryFactory();
-                geomBuffer = geomFactory.CreateMultiGeometry(inputGeometries).Buffer(dist, measure);
+                geomBuffer = geomFactory.createMultiGeometry(inputGeometries).buffer(dist, measure);
                     AddFeatureToCollection(propCollection, agfRW, featId, geomBuffer);
@@ -340,19 +340,19 @@
-        if(propCollection.GetCount() > 0)
+        if(propCollection.getCount() > 0)
-            commands.Add(new MgInsertFeatures(featureName, propCollection));
+            commands.add(new MgInsertFeatures(featureName, propCollection));
             //Insert the features in the temporary data source
-            ReleaseReader(featureSrvc.UpdateFeatures(dataSourceId, commands, false), commands);
+            ReleaseReader(featureSrvc.updateFeatures(dataSourceId, commands, false), commands);
         // Save the new map state
-        layer.ForceRefresh();
-        map.Save();
+        layer.forceRefresh();
+        map.save();
         //build report message
         String title = MgLocalizer.GetString("BUFFERREPORTTITLE", locale);
@@ -378,7 +378,7 @@
     catch(MgException exc)
-        OnError(MgLocalizer.GetString("BUFFERREPORTERRORTITLE", locale), exc.GetDetails(), outStream, request);
+        OnError(MgLocalizer.GetString("BUFFERREPORTERRORTITLE", locale), exc.getDetails(), outStream, request);
         return;
     catch(Exception ne)
@@ -423,10 +423,10 @@
     MgLayer layer = null;
     int i;
-    for(i = 0; i < layers.GetCount(); i++)
+    for(i = 0; i < layers.getCount(); i++)
-        MgLayer layer1 = (MgLayer) layers.GetItem(i);
-        if(layer1.GetName().equals(layerName))
+        MgLayer layer1 = (MgLayer) layers.getItem(i);
+        if(layer1.getName().equals(layerName))
             layer = layer1;
             break;
@@ -453,7 +453,7 @@
     byte[] bytes = layerTempl.getBytes("UTF-8");
     MgByteSource src = new MgByteSource(bytes, bytes.length);
-    return src.GetReader();
+    return src.getReader();
 void ClearDataSource(MgFeatureService featureSrvc, MgResourceIdentifier dataSourceId, String featureName)  throws MgException
@@ -460,8 +460,8 @@
     MgDeleteFeatures deleteCmd = new MgDeleteFeatures(featureName, "ID >= 0");
     MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
-    commands.Add(deleteCmd);
-    featureSrvc.UpdateFeatures(dataSourceId, commands, false);
+    commands.add(deleteCmd);
+    featureSrvc.updateFeatures(dataSourceId, commands, false);
 void OnError(String title, String msg, PrintWriter outStream, HttpServletRequest request) throws FileNotFoundException, IOException
@@ -476,18 +476,18 @@
     if(res == null)
         return;
-    for(int i = 0; i < res.GetCount(); i++)
+    for(int i = 0; i < res.getCount(); i++)
-        MgFeatureCommand cmd = commands.GetItem(i);
+        MgFeatureCommand cmd = commands.getItem(i);
         if(cmd instanceof MgInsertFeatures)
-            MgFeatureProperty resProp = (MgFeatureProperty)res.GetItem(i);
+            MgFeatureProperty resProp = (MgFeatureProperty)res.getItem(i);
             if(resProp != null)
-                MgFeatureReader reader = (MgFeatureReader)resProp.GetValue();
+                MgFeatureReader reader = (MgFeatureReader)resProp.getValue();
                 if(reader == null)
                     return;
-                reader.Close();
+                reader.close();
@@ -497,11 +497,11 @@
     MgPropertyCollection bufferProps = new MgPropertyCollection();
     MgInt32Property idProp = new MgInt32Property("ID", featureId);
-    bufferProps.Add(idProp);
-    MgByteReader geomReader = agfRW.Write(featureGeom);
+    bufferProps.add(idProp);
+    MgByteReader geomReader = agfRW.write(featureGeom);
     MgGeometryProperty geomProp = new MgGeometryProperty("GEOM", geomReader);
-    bufferProps.Add(geomProp);
-    propCollection.Add(bufferProps);
+    bufferProps.add(geomProp);
+    propCollection.addItem(bufferProps);
 String GetMapSrs(MgMap map)
@@ -508,7 +508,7 @@
     try
-        String srs = map.GetMapSRS();
+        String srs = map.getMapSRS();
         if(!srs.equals(""))
             return srs;
Modified: trunk/MgDev/Web/src/mapviewerjava/common.jsp
--- trunk/MgDev/Web/src/mapviewerjava/common.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/common.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -32,7 +32,7 @@
     String realpath = getServletContext().getRealPath("/");
     String configPath =  realpath + "webconfig.ini";
-    MapGuideJavaApi.MgInitializeWebTier(configPath);
+    MapGuideJavaApiEx.MgInitializeWebTier(configPath);
 String GetDefaultLocale()
@@ -265,7 +265,7 @@
     try
         MgResourceIdentifier resId = new MgResourceIdentifier(proposedResourceId);
-        validResourceId = resId.ToString();
+        validResourceId = resId.toString();
     catch(MgException e)
@@ -303,48 +303,48 @@
 MgFeatureQueryOptions BuildFeatureQueryOptions(MgClassDefinition classDef) throws MgException
     MgFeatureQueryOptions query = new MgFeatureQueryOptions();
-    MgPropertyDefinitionCollection propertyList = classDef.GetProperties();
-    for (int i = 0; i < propertyList.GetCount(); i++)
+    MgPropertyDefinitionCollection propertyList = classDef.getProperties();
+    for (int i = 0; i < propertyList.getCount(); i++)
-        MgPropertyDefinition propertyDef = propertyList.GetItem(i);
-        String property = propertyDef.GetName();
+        MgPropertyDefinition propertyDef = propertyList.getItem(i);
+        String property = propertyDef.getName();
-        if ((!property.equals(geomPropName)) && (propertyDef.GetPropertyType() == MgFeaturePropertyType.DataProperty))
+        if ((!property.equals(geomPropName)) && (propertyDef.getPropertyType() == MgFeaturePropertyType.DataProperty))
             MgDataPropertyDefinition dp = (MgDataPropertyDefinition)propertyDef;
-            int propertyType = dp.GetDataType();
+            int propertyType = dp.getDataType();
             switch (propertyType) {
                 case MgPropertyType.Boolean:
-                    query.AddFeatureProperty(property);
+                    query.addFeatureProperty(property);
                     break;
                 case MgPropertyType.Byte:
                     break;
                 case MgPropertyType.DateTime:
                     break;
                 case MgPropertyType.Single:
                     break;
                 case MgPropertyType.Double:
                     break;
                 case MgPropertyType.Int16:
                     break;
                 case MgPropertyType.Int32:
                     break;
                 case MgPropertyType.Int64:
                     break;
                 case MgPropertyType.String:
                     break;
         } else if (property.equals(geomPropName)) {
     return query;
Modified: trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp
--- trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -61,27 +61,27 @@
-            site.Open(cred);
+            site.open(cred);
             MgResourceIdentifier wli = new MgResourceIdentifier(webLayout);
             byte[] hb = fixedupHtml.getBytes("UTF-8");
             MgByteSource src = new MgByteSource(hb, hb.length);
             MgWebLayout wl = new MgWebLayout(resourceSrvc, wli);
-            MgByteReader pagestream = wl.ProcessGettingStartedPage(src.GetReader(), dwf);
+            MgByteReader pagestream = wl.processGettingStartedPage(src.getReader(), dwf);
             if(pagestream == null)
                 outStream.write(fixedupHtml);
             else
-                outStream.write(pagestream.ToString());
+                outStream.write(pagestream.toString());
         else
     catch(MgException mge) {
-        String errorMsg = EscapeForHtml(mge.GetDetails());
+        String errorMsg = EscapeForHtml(mge.getDetails());
         outStream.write(errorMsg);
     catch(Exception e) {
Modified: trunk/MgDev/Web/src/mapviewerjava/init.jsp
--- trunk/MgDev/Web/src/mapviewerjava/init.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/init.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -24,7 +24,7 @@
     // Initialize web tier with the site configuration file.  The config
     // file should be in the same folder as this script.
-    MapGuideJavaApi.MgInitializeWebTier( configPath );
+    MapGuideJavaApiEx.MgInitializeWebTier( configPath );
Modified: trunk/MgDev/Web/src/mapviewerjava/legend.jsp
--- trunk/MgDev/Web/src/mapviewerjava/legend.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/legend.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -89,19 +89,19 @@
     // Connect to the site and get a resource service instance
     //Load the map runtime state.
     int updateType = -1;
@@ -136,7 +136,7 @@
-    String details = EscapeForHtml(e.GetDetails());
+    String details = EscapeForHtml(e.getDetails());
     writer = response.getWriter();
     writer.write(details);
     response.setContentLength(details.length());
@@ -177,14 +177,14 @@
     ArrayList tree = new ArrayList();
     HashMap knownGroups = new HashMap();
     ArrayList unresolved = new ArrayList();
-    MgLayerGroupCollection groups = map.GetLayerGroups();
+    MgLayerGroupCollection groups = map.getLayerGroups();
-    for(int i = 0; i < groups.GetCount(); i++)
+    for(int i = 0; i < groups.getCount(); i++)
-        MgLayerGroup rtGroup = (MgLayerGroup)groups.GetItem(i);
-        TreeItem node = new TreeItem(rtGroup.GetName(), true, rtGroup, "null");
+        MgLayerGroup rtGroup = (MgLayerGroup)groups.getItem(i);
+        TreeItem node = new TreeItem(rtGroup.getName(), true, rtGroup, "null");
         knownGroups.put(node.name, node);
-        MgLayerGroup parentGroup = rtGroup.GetGroup();
+        MgLayerGroup parentGroup = rtGroup.getGroup();
         if(parentGroup == null)
             tree.add(node);
@@ -191,7 +191,7 @@
         else
-            String parentName = parentGroup.GetName();
+            String parentName = parentGroup.getName();
             TreeItem parentNode = (TreeItem)knownGroups.get(parentName);
             if(parentNode != null)
                 parentNode.Attach(node);
@@ -215,28 +215,28 @@
     // Get the layers
     // Get the resource Ids of the layers
     MgStringCollection resIds = new MgStringCollection();
-    for(int i = 0; i < layers.GetCount(); i++)
+    for(int i = 0; i < layers.getCount(); i++)
-        MgLayer rtLayer = (MgLayer) layers.GetItem(i);
-        MgResourceIdentifier resId = rtLayer.GetLayerDefinition();
-        resIds.Add(resId.ToString());
+        MgLayer rtLayer = (MgLayer) layers.getItem(i);
+        MgResourceIdentifier resId = rtLayer.getLayerDefinition();
+        resIds.add(resId.toString());
-    MgStringCollection layersData = resSrvc.GetResourceContents(resIds, null);
+    MgStringCollection layersData = resSrvc.getResourceContents(resIds, null);
-        TreeItem node = new TreeItem(rtLayer.GetName(), false, rtLayer, (String)layersData.GetItem(i));
-        MgLayerGroup parentGroup = rtLayer.GetGroup();
+        TreeItem node = new TreeItem(rtLayer.getName(), false, rtLayer, (String)layersData.getItem(i));
+        MgLayerGroup parentGroup = rtLayer.getGroup();
             tree.add(node);
         else
-            TreeItem parentNode = (TreeItem)knownGroups.get(parentGroup.GetName());
+            TreeItem parentNode = (TreeItem)knownGroups.get(parentGroup.getName());
             else
@@ -252,11 +252,11 @@
 HashMap BuildLayerMap(MgMap map) throws MgException
     HashMap layerMap = new HashMap();
-        layerMap.put(rtLayer.GetObjectId(), rtLayer);
+        layerMap.put(rtLayer.getObjectId(), rtLayer);
     return layerMap;
@@ -292,21 +292,21 @@
                         output.append(String.format("var %s = new GroupItem(\"%s\", %s, %s, %s, %s, \"%s\", \"%s\", %s);\n",
                                                            new Object[] {groupName,
-                                                           StrEscape(rtLayerGroup.GetLegendLabel()),
-                                                           rtLayerGroup.GetExpandInLegend()? "true": "false",
+                                                           StrEscape(rtLayerGroup.getLegendLabel()),
+                                                           rtLayerGroup.getExpandInLegend()? "true": "false",
                                                            parentName,
-                                                           rtLayerGroup.GetVisible()? "true": "false",
-                                                           rtLayerGroup.GetDisplayInLegend()? "true": "false",
-                                                           rtLayerGroup.GetObjectId(),
-                                                           StrEscape(rtLayerGroup.GetName()),
-                                                           (rtLayerGroup.GetLayerGroupType() == MgLayerGroupType.BaseMap || rtLayerGroup.GetLayerGroupType() == MgLayerGroupType.BaseMapFromTileSet)? "true": "false"}));
+                                                           rtLayerGroup.getVisible()? "true": "false",
+                                                           rtLayerGroup.getDisplayInLegend()? "true": "false",
+                                                           rtLayerGroup.getObjectId(),
+                                                           StrEscape(rtLayerGroup.getName()),
+                                                           (rtLayerGroup.getLayerGroupType() == MgLayerGroupType.BaseMap || rtLayerGroup.getLayerGroupType() == MgLayerGroupType.BaseMapFromTileSet)? "true": "false"}));
                     else
                         output.append(String.format("var %s = new GroupSummary(\"%s\", \"%s\", %s, %s);\n",
                                                            arrChildName,
                                                            parentName}));
@@ -327,22 +327,22 @@
                     MgLayer rtLayer = (MgLayer)node.rtObject;
                     if(fulldata)
                         String layerData = node.layerData;
                         String layerName = "lyr" + (intermediateVar++);
-                        String objectId = rtLayer.GetObjectId();
+                        String objectId = rtLayer.getObjectId();
                         output.append(String.format("var %s = new LayerItem(\"%s\", \"%s\", %s, %s, %s, %s, %s, \"%s\", \"%s\", %s);\n",
                                                            new Object[] {layerName,
-                                                           StrEscape(rtLayer.GetLegendLabel()),
-                                                           rtLayer.GetName(),
-                                                           rtLayer.GetExpandInLegend()? "true": "false",
+                                                           StrEscape(rtLayer.getLegendLabel()),
+                                                           rtLayer.getName(),
+                                                           rtLayer.getExpandInLegend()? "true": "false",
                                                            parentName,
-                                                           rtLayer.GetVisible()? "true": "false",
-                                                           rtLayer.GetDisplayInLegend()? "true": "false",
-                                                           rtLayer.GetSelectable()? "true": "false",
-                                                           resId.ToString(),
+                                                           rtLayer.getVisible()? "true": "false",
+                                                           rtLayer.getDisplayInLegend()? "true": "false",
+                                                           rtLayer.getSelectable()? "true": "false",
+                                                           resId.toString(),
                                                            objectId,
-                                                           rtLayer.GetLayerType() == MgLayerType.BaseMap? "true": "false"}));
+                                                           rtLayer.getLayerType() == MgLayerType.BaseMap? "true": "false"}));
                         output.append(String.format("%s[%d] = %s;\n",
                                                            new Object[] {container,
@@ -360,9 +360,9 @@
                         output.append(String.format("%s[%d] = new LayerSummary(\"%s\", \"%s\", \"%s\");\n",
                                                             Integer.valueOf(i),
-                                                            StrEscape(rtLayer.GetName()),
-                                                            rtLayer.GetObjectId(),
-                                                            rtLayer.GetLayerDefinition().ToString()}));
+                                                            StrEscape(rtLayer.getName()),
+                                                            rtLayer.getObjectId(),
+                                                            rtLayer.getLayerDefinition().toString()}));
@@ -485,11 +485,11 @@
         ByteArrayOutputStream bos = new ByteArrayOutputStream();
         byte[] byteBuffer = new byte[1024];
-        int numBytes = byteReader.Read(byteBuffer, 1024);
+        int numBytes = byteReader.read(byteBuffer, 1024);
         while(numBytes > 0)
             bos.write(byteBuffer, 0, numBytes);
-            numBytes = byteReader.Read(byteBuffer, 1024);
+            numBytes = byteReader.read(byteBuffer, 1024);
         stream = new ByteArrayInputStream(bos.toByteArray());
Modified: trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -59,11 +59,11 @@
     MgUserInformation cred = new MgUserInformation();
     if(sessionId != null && sessionId != "")
-        cred.SetMgSessionId(sessionId);
+        cred.setMgSessionId(sessionId);
         createSession = false;
     else if(username != null)
-        cred.SetMgUsernamePassword(username, password);
+        cred.setMgUsernamePassword(username, password);
     else
         RequestAuthentication(response);
@@ -71,17 +71,17 @@
-    cred.SetLocale(locale);
+    cred.setLocale(locale);
-    site.Open(cred);
+    site.open(cred);
     if(createSession)
-        MgSite site1 = site.GetSite();
-        sessionId = site1.CreateSession();
+        MgSite site1 = site.getSite();
+        sessionId = site1.createSession();
         if(forDwf == 0)
             orgSessionId = sessionId;
@@ -91,42 +91,42 @@
     //Get a MgWebLayout object initialized with the specified web layout definition
     MgWebLayout webLayout = null;
     MgResourceIdentifier webLayoutId = new MgResourceIdentifier(webLayoutDefinition);
     webLayout = new MgWebLayout(resourceSrvc, webLayoutId);
     //calculate the size of the variable elements of the viewer
-    MgWebToolBar toolBar = webLayout.GetToolBar();
-    MgWebUiPane statusBar = webLayout.GetStatusBar();
-    MgWebTaskPane taskPane = webLayout.GetTaskPane();
-    MgWebInformationPane infoPane = webLayout.GetInformationPane();
-    MgWebTaskBar taskBar = taskPane.GetTaskBar();
-    String mapDef = webLayout.GetMapDefinition();
+    MgWebToolBar toolBar = webLayout.getToolBar();
+    MgWebUiPane statusBar = webLayout.getStatusBar();
+    MgWebTaskPane taskPane = webLayout.getTaskPane();
+    MgWebInformationPane infoPane = webLayout.getInformationPane();
+    MgWebTaskBar taskBar = taskPane.getTaskBar();
+    String mapDef = webLayout.getMapDefinition();
-    startupScriptCode = webLayout.GetStartupScript();
-    String selectionColor = webLayout.GetSelectionColor();
- 	String mapImgFormat = webLayout.GetMapImageFormat();
- 	String selImgFormat = webLayout.GetSelectionImageFormat();
- 	int pointBuffer = webLayout.GetPointSelectionBuffer();
+    startupScriptCode = webLayout.getStartupScript();
+    String selectionColor = webLayout.getSelectionColor();
+    String mapImgFormat = webLayout.getMapImageFormat();
+    String selImgFormat = webLayout.getSelectionImageFormat();
+    int pointBuffer = webLayout.getPointSelectionBuffer();
-    boolean showTaskPane = taskPane.IsVisible();
-    boolean showTaskBar = taskBar.IsVisible();
-    boolean showStatusbar = statusBar.IsVisible();
-    boolean showToolbar = toolBar.IsVisible();
+    boolean showTaskPane = taskPane.isVisible();
+    boolean showTaskBar = taskBar.isVisible();
+    boolean showStatusbar = statusBar.isVisible();
+    boolean showToolbar = toolBar.isVisible();
-    int taskPaneWidth = taskPane.GetWidth();
+    int taskPaneWidth = taskPane.getWidth();
     int toolbarHeight = 30;
     int taskBarHeight = 30;
     int statusbarHeight = 26;
-    taskPaneWidth = showTaskPane? taskPaneWidth: 0;
-    toolbarHeight = showToolbar? toolbarHeight: 0;
+    taskPaneWidth = showTaskPane ? taskPaneWidth: 0;
+    toolbarHeight = showToolbar ? toolbarHeight: 0;
     taskBarHeight = showTaskBar ? taskBarHeight : 0;
-    statusbarHeight = showStatusbar? statusbarHeight: 0;
+    statusbarHeight = showStatusbar ? statusbarHeight: 0;
     //Encode the initial url so that it does not trip any sub-frames (especially if this url has parameters)
-    String taskPaneUrl = URLEncoder.encode(taskPane.GetInitialTaskUrl(), "UTF-8");
+    String taskPaneUrl = URLEncoder.encode(taskPane.getInitialTaskUrl(), "UTF-8");
     String vpath = GetSurroundVirtualPath(request);
     boolean defHome = false;
     if(taskPaneUrl == null || taskPaneUrl.length() == 0) {
@@ -141,19 +141,19 @@
     // as this script is running. However the naming convention is fixed enough that we can figure out
     // what to pass to the Task Pane
     MgResourceIdentifier resId = new MgResourceIdentifier(mapDef);
-    mapName = resId.GetName();
+    mapName = resId.getName();
-    String title = webLayout.GetTitle();
+    String title = webLayout.getTitle();
-    boolean showLegend = infoPane.IsLegendBandVisible();
-    boolean showProperties = infoPane.IsPropertiesBandVisible();
+    boolean showLegend = infoPane.isLegendBandVisible();
+    boolean showProperties = infoPane.isPropertiesBandVisible();
     int infoWidth = 0;
     if(showLegend || showProperties)
-        if(infoPane.IsVisible())
+        if(infoPane.isVisible())
-            infoWidth = infoPane.GetWidth();
+            infoWidth = infoPane.getWidth();
             if(infoWidth < 5)
                 infoWidth = 5;    //ensure visible
@@ -170,18 +170,18 @@
     //view center
-    MgPoint ptCenter = webLayout.GetCenter();
+    MgPoint ptCenter = webLayout.getCenter();
     String center = "null";
     if(ptCenter != null)
-        MgCoordinate coord = ptCenter.GetCoordinate();
-        Object[] formatArgs = { Double.toString(coord.GetX()), Double.toString(coord.GetY()) };
+        MgCoordinate coord = ptCenter.getCoordinate();
+        Object[] formatArgs = { Double.toString(coord.getX()), Double.toString(coord.getY()) };
         center = MessageFormat.format("new Point({0}, {1})", formatArgs);
     //Process commands and declare command objects
-    MgWebCommandCollection commands = webLayout.GetCommands();
+    MgWebCommandCollection commands = webLayout.getCommands();
     String cmdObjects = "";
     String cmdObject = "";
     int navCmdIndex = 0;
@@ -194,16 +194,16 @@
     int selAwareCmdCount = 0;
     String selAwareCmds = "";
-    for(int i = 0; i < commands.GetCount(); i++)
+    for(int i = 0; i < commands.getCount(); i++)
-        MgWebCommand cmd = commands.GetItem(i);
-        if(!cmd.IsUsed())
+        MgWebCommand cmd = commands.getItem(i);
+        if(!cmd.isUsed())
             continue;
-        int tgtViewer = cmd.GetTargetViewerType();
+        int tgtViewer = cmd.getTargetViewerType();
         if((tgtViewer == MgWebTargetViewerType.Dwf) != (forDwf == 1) && (tgtViewer != MgWebTargetViewerType.All))
             continue;
-        String name = cmd.GetName();
-        int action = cmd.GetAction();
+        String name = cmd.getName();
+        int action = cmd.getAction();
         if (action == MgWebActions.Search)
             MgWebSearchCommand searchCmd = (MgWebSearchCommand)cmd;
@@ -210,11 +210,11 @@
             // create the column objects
             String cols = "var resCols" + searchCmdIndex + " = new Array();\n";
-            if(searchCmd.GetResultColumnCount() > 0)
+            if(searchCmd.getResultColumnCount() > 0)
-                for(int j = 0; j < searchCmd.GetResultColumnCount(); j++)
+                for(int j = 0; j < searchCmd.getResultColumnCount(); j++)
-                    Object[] formatArgs = { new Integer(searchCmdIndex), new Integer(j), StrEscape(searchCmd.GetColumnDisplayNameAt(j)), StrEscape(searchCmd.GetColumnPropertyNameAt(j)) };
+                    Object[] formatArgs = { new Integer(searchCmdIndex), new Integer(j), StrEscape(searchCmd.getColumnDisplayNameAt(j)), StrEscape(searchCmd.getColumnPropertyNameAt(j)) };
                     String col = MessageFormat.format("resCols{0,number,integer}[{1,number,integer}] = new ResultColumn(\"{2}\", \"{3}\");\n", formatArgs);
                     cols += col;
@@ -224,19 +224,19 @@
             // declare a new search command object
             Object[] formatArgs = { new Integer(i),
                                     StrEscape(name),
-                                    StrEscape(searchCmd.GetLabel()),
+                                    StrEscape(searchCmd.getLabel()),
                                     new Integer(action),
-                                    searchCmd.GetIconUrl(),
-                                    searchCmd.GetDisabledIconUrl(),
-                                    StrEscape(searchCmd.GetTooltip()),
-                                    StrEscape(searchCmd.GetDescription()),
-                                    searchCmd.GetLayer(),
-                                    StrEscape(searchCmd.GetPrompt()),
+                                    searchCmd.getIconUrl(),
+                                    searchCmd.getDisabledIconUrl(),
+                                    StrEscape(searchCmd.getTooltip()),
+                                    StrEscape(searchCmd.getDescription()),
+                                    searchCmd.getLayer(),
+                                    StrEscape(searchCmd.getPrompt()),
-                                    StrEscape(searchCmd.GetFilter()),
-                                    new Integer(searchCmd.GetMatchLimit()),
-                                    new Integer(searchCmd.GetTarget()),
-                                    searchCmd.GetTargetName() };
+                                    StrEscape(searchCmd.getFilter()),
+                                    new Integer(searchCmd.getMatchLimit()),
+                                    new Integer(searchCmd.getTarget()),
+                                    searchCmd.getTargetName() };
             cmdObject = MessageFormat.format("commands[{0,number,integer}] = new SearchCommand(\"{1}\", \"{2}\", {3,number,integer}, \"{4}\", \"{5}\", \"{6}\", \"{7}\", \"{8}\", \"{9}\", resCols{10}, \"{11}\", {12,number,integer}, {13,number,integer}, \"{14}\");\n", formatArgs);
             searchCmdIndex++;
@@ -248,24 +248,24 @@
             // create the parameter objects
             String paramObjs = "var navParams" + navCmdIndex + " = new Array();\n";
             String layers = "var layers" + navCmdIndex + " = new Array();\n";
-            if(invokeUrlCmd.GetParameterCount() > 0)
+            if(invokeUrlCmd.getParameterCount() > 0)
-                for(int j = 0; j < invokeUrlCmd.GetParameterCount(); j++)
+                for(int j = 0; j < invokeUrlCmd.getParameterCount(); j++)
-                    Object[] formatArgs = { new Integer(navCmdIndex), new Integer(j), invokeUrlCmd.GetParameterNameAt(j), invokeUrlCmd.GetParameterValueAt(j) };
+                    Object[] formatArgs = { new Integer(navCmdIndex), new Integer(j), invokeUrlCmd.getParameterNameAt(j), invokeUrlCmd.getParameterValueAt(j) };
                     String param = MessageFormat.format("navParams{0,number,integer}[{1,number,integer}] = new NavParam(\"{2}\", \"{3}\");\n", formatArgs);
                     paramObjs = paramObjs + param;
-            for( int j = 0;  j < invokeUrlCmd.GetLayerCount(); j++ )
+            for( int j = 0;  j < invokeUrlCmd.getLayerCount(); j++ )
-                Object[] formatArgs = { new Integer(navCmdIndex), new Integer(j), invokeUrlCmd.GetLayerNameAt(j) };
+                Object[] formatArgs = { new Integer(navCmdIndex), new Integer(j), invokeUrlCmd.getLayerNameAt(j) };
                 String layer = MessageFormat.format("layers{0,number,integer}[{1,number,integer}] = \"{2}\";\n", formatArgs);
                 layers = layers + layer;
             cmdObjects = cmdObjects + paramObjs + layers;
-            if(invokeUrlCmd.DisabledIfSelectionEmpty() || invokeUrlCmd.GetLayerCount() > 0)
+            if(invokeUrlCmd.disabledIfSelectionEmpty() || invokeUrlCmd.getLayerCount() > 0)
                 Object[] formatArgs = { new Integer(selAwareCmdCount), new Integer(i) };
                 selAwareCmds = selAwareCmds + MessageFormat.format("selectionAwareCmds[{0,number,integer}] = {1,number,integer};\n", formatArgs);
@@ -276,16 +276,16 @@
                                     StrEscape(name),
-                                    invokeUrlCmd.GetIconUrl(),
-                                    invokeUrlCmd.GetDisabledIconUrl(),
-                                    StrEscape( invokeUrlCmd.GetTooltip()),
-                                    StrEscape( invokeUrlCmd.GetDescription()),
-                                    invokeUrlCmd.GetUrl(),
+                                    invokeUrlCmd.getIconUrl(),
+                                    invokeUrlCmd.getDisabledIconUrl(),
+                                    StrEscape( invokeUrlCmd.getTooltip()),
+                                    StrEscape( invokeUrlCmd.getDescription()),
+                                    invokeUrlCmd.getUrl(),
-                                    invokeUrlCmd.DisabledIfSelectionEmpty() ? "true" : "false",
+                                    invokeUrlCmd.disabledIfSelectionEmpty() ? "true" : "false",
-                                    new Integer(invokeUrlCmd.GetTarget()),
-                                    invokeUrlCmd.GetTargetName() };
+                                    new Integer(invokeUrlCmd.getTarget()),
+                                    invokeUrlCmd.getTargetName() };
             cmdObject = MessageFormat.format("commands[{0,number,integer}] = new InvokeUrlCommand(\"{1}\", {2,number,integer}, \"{3}\", \"{4}\", \"{5}\", \"{6}\", \"{7}\", navParams{8,number,integer}, {9}, layers{10,number,integer}, {11,number,integer}, \"{12}\");\n", formatArgs);
             navCmdIndex++;
@@ -305,12 +305,12 @@
                                     StrEscape( name ),
                                     new Integer( action ),
-                                    targetCmd.GetIconUrl(),
-                                    targetCmd.GetDisabledIconUrl(),
-                                    StrEscape(targetCmd.GetTooltip()),
-                                    StrEscape(targetCmd.GetDescription()),
-                                    new Integer( targetCmd.GetTarget()),
-                                    targetCmd.GetTargetName() };
+                                    targetCmd.getIconUrl(),
+                                    targetCmd.getDisabledIconUrl(),
+                                    StrEscape(targetCmd.getTooltip()),
+                                    StrEscape(targetCmd.getDescription()),
+                                    new Integer( targetCmd.getTarget()),
+                                    targetCmd.getTargetName() };
             cmdObject = MessageFormat.format("commands[{0,number,integer}] = new UiTargetCommand(\"{1}\", {2,number,integer}, \"{3}\", \"{4}\", \"{5}\", \"{6}\", {7,number,integer}, \"{8}\");\n", formatArgs);
         else if(action == MgWebActions.Help)
@@ -321,13 +321,13 @@
                                     StrEscape(name),
-                                    helpCmd.GetIconUrl(),
-                                    helpCmd.GetDisabledIconUrl(),
-                                    StrEscape(helpCmd.GetTooltip()),
-                                    StrEscape(helpCmd.GetDescription()),
-                                    helpCmd.GetUrl(),
-                                    new Integer(helpCmd.GetTarget()),
-                                    helpCmd.GetTargetName() };
+                                    helpCmd.getIconUrl(),
+                                    helpCmd.getDisabledIconUrl(),
+                                    StrEscape(helpCmd.getTooltip()),
+                                    StrEscape(helpCmd.getDescription()),
+                                    helpCmd.getUrl(),
+                                    new Integer(helpCmd.getTarget()),
+                                    helpCmd.getTargetName() };
             cmdObject = MessageFormat.format("commands[{0,number,integer}] = new HelpCommand(\"{1}\", {2,number,integer}, \"{3}\", \"{4}\", \"{5}\", \"{6}\", \"{7}\", {8,number,integer}, \"{9}\");\n", formatArgs);
         else if(action == MgWebActions.PrintMap)
@@ -336,10 +336,10 @@
             // declare the print layouts
             String layouts = "var layouts" + printCmdIndex + " = new Array();\n";
-            for(int j = 0; j < printCmd.GetPrintLayoutCount(); j++)
+            for(int j = 0; j < printCmd.getPrintLayoutCount(); j++)
                 String layout = "";
-                Object[] formatArgs = { new Integer(printCmdIndex), new Integer(j), printCmd.GetPrintLayoutAt(j) };
+                Object[] formatArgs = { new Integer(printCmdIndex), new Integer(j), printCmd.getPrintLayoutAt(j) };
                 layout = MessageFormat.format("layouts{0,number,integer}[{1,number,integer}] = \"{2}\";\n", formatArgs);
                 layouts = layouts + layout;
@@ -349,10 +349,10 @@
                                     StrEscape( name ),
-                                    printCmd.GetIconUrl(),
-                                    printCmd.GetDisabledIconUrl(),
-                                    StrEscape( printCmd.GetTooltip()),
-                                    StrEscape( printCmd.GetDescription()),
+                                    printCmd.getIconUrl(),
+                                    printCmd.getDisabledIconUrl(),
+                                    StrEscape( printCmd.getTooltip()),
+                                    StrEscape( printCmd.getDescription()),
                                     new Integer(printCmdIndex) };
             cmdObject = MessageFormat.format("commands[{0,number,integer}] = new PrintCommand(\"{1}\", {2,number,integer}, \"{3}\", \"{4}\", \"{5}\", \"{6}\", layouts{7,number,integer});\n", formatArgs );
             printCmdIndex++;
@@ -365,14 +365,14 @@
                                     StrEscape(name),
-                                    invokeScriptCmd.GetIconUrl(),
-                                    invokeScriptCmd.GetDisabledIconUrl(),
-                                    StrEscape( invokeScriptCmd.GetTooltip()),
-                                    StrEscape( invokeScriptCmd.GetDescription()),
+                                    invokeScriptCmd.getIconUrl(),
+                                    invokeScriptCmd.getDisabledIconUrl(),
+                                    StrEscape( invokeScriptCmd.getTooltip()),
+                                    StrEscape( invokeScriptCmd.getDescription()),
                                     new Integer( scriptCmdIndex ) };
             cmdObject = MessageFormat.format("commands[{0,number,integer}] = new InvokeScriptCommand(\"{1}\", {2,number,integer}, \"{3}\", \"{4}\", \"{5}\", \"{6}\", {7,number,integer});\n", formatArgs);
-            userCode = userCode + "\nfunction UserFunc" + scriptCmdIndex + "()\n{\n" + invokeScriptCmd.GetScriptCode() + "\n}\n";
+            userCode = userCode + "\nfunction UserFunc" + scriptCmdIndex + "()\n{\n" + invokeScriptCmd.getScriptCode() + "\n}\n";
             Object[] formatArgs2 = { new Integer(scriptCmdIndex), new Integer(scriptCmdIndex) };
             userCodeCalls = userCodeCalls + MessageFormat.format("case {0,number,integer}: UserFunc{0,number,integer}(); break;\n", formatArgs2);
@@ -384,10 +384,10 @@
                                     name,
-                                    cmd.GetIconUrl(),
-                                    cmd.GetDisabledIconUrl(),
-                                    StrEscape(cmd.GetTooltip()),
-                                    StrEscape(cmd.GetDescription()) };
+                                    cmd.getIconUrl(),
+                                    cmd.getDisabledIconUrl(),
+                                    StrEscape(cmd.getTooltip()),
+                                    StrEscape(cmd.getDescription()) };
             cmdObject = MessageFormat.format("commands[{0,number,integer}] = new BasicCommand(\"{1}\", {2,number,integer}, \"{3}\", \"{4}\", \"{5}\", \"{6}\");\n", formatArgs);
         cmdObjects = cmdObjects + cmdObject;
@@ -397,15 +397,15 @@
     //Declare toolbar items
-    String toolbarDef = DeclareUiItems(toolBar.GetWidgets(), "toolbarItems");
+    String toolbarDef = DeclareUiItems(toolBar.getWidgets(), "toolbarItems");
     //Declare task items
-    String taskListDef = DeclareUiItems(taskBar.GetTaskList(), "taskItems");
+    String taskListDef = DeclareUiItems(taskBar.getTaskList(), "taskItems");
     //Declare context menu items
-    MgWebContextMenu ctxMenu = webLayout.GetContextMenu();
+    MgWebContextMenu ctxMenu = webLayout.getContextMenu();
     String ctxMenuDef;
-    if(ctxMenu.IsVisible())
+    if(ctxMenu.isVisible())
         ctxMenuDef = DeclareUiItems(ctxMenu, "ctxMenuItems");
     else
         ctxMenuDef = "";
@@ -412,17 +412,17 @@
     //task items texts
     String taskItemTexts = "";
-    MgWebWidgetCollection taskButtons = taskBar.GetTaskButtons();
+    MgWebWidgetCollection taskButtons = taskBar.getTaskButtons();
     for(int i = 0; i < 4; i ++)
-        MgWebTaskBarWidget btn = (MgWebTaskBarWidget)taskButtons.GetWidget(i);
+        MgWebTaskBarWidget btn = (MgWebTaskBarWidget)taskButtons.getWidget(i);
         if(i > 0)
             taskItemTexts += ",";
-        taskItemTexts += "\"" + StrEscape(btn.GetName()) + "\"," +
-                            "\"" + StrEscape(btn.GetTooltip()) + "\"," +
-                            "\"" + StrEscape(btn.GetDescription()) + "\"," +
-                            "\"" + StrEscape(btn.GetIconUrl()) + "\"," +
-                            "\"" + StrEscape(btn.GetDisabledIconUrl()) + "\"";
+        taskItemTexts += "\"" + StrEscape(btn.getName()) + "\"," +
+                            "\"" + StrEscape(btn.getTooltip()) + "\"," +
+                            "\"" + StrEscape(btn.getDescription()) + "\"," +
+                            "\"" + StrEscape(btn.getIconUrl()) + "\"," +
+                            "\"" + StrEscape(btn.getDisabledIconUrl()) + "\"";
     //transmit the session to the map pane if one was specified to this request
@@ -449,9 +449,9 @@
                         showProperties? "1": "0",
                         String.valueOf(infoWidth),
                         locale,
-                        String.valueOf(webLayout.GetHyperlinkTarget()),
-                        webLayout.GetHyperlinkTargetFrame(),
-                        webLayout.IsZoomControlVisible()? "1": "0",
+                        String.valueOf(webLayout.getHyperlinkTarget()),
+                        webLayout.getHyperlinkTargetFrame(),
+                        webLayout.isZoomControlVisible()? "1": "0",
                         selectionColor,
                         mapImgFormat,
                         selImgFormat,
@@ -481,9 +481,9 @@
                         locale,
                         selectionColor,
                         mapImgFormat,
                         selImgFormat,
@@ -508,10 +508,10 @@
     String int0 = "0";
     String int1 = "1";
     String[] vals = {
-                      webLayout.GetTitle(),
+                      webLayout.getTitle(),
                       GetRootVirtualFolder(request) + "/mapagent/mapagent.fcgi",
-                      webLayout.GetEnablePingServer()? int1 : int0,
-                      String.valueOf(site.GetSite().GetSessionTimeout()),
+                      webLayout.getEnablePingServer()? int1 : int0,
+                      String.valueOf(site.getSite().getSessionTimeout()),
                       locale,
                       showToolbar ? int1 : int0,
                       showStatusbar ? int1 : int0,
@@ -523,7 +523,7 @@
                       mapDef,
                       String.valueOf(taskPaneWidth),
                       center,
-                      String.valueOf(webLayout.GetScale()),
+                      String.valueOf(webLayout.getScale()),
                       StrEscape(title),
                       (forDwf == 1)? "1" : "0",
                       cmdObjects,
@@ -566,7 +566,7 @@
-    String msg = EscapeForHtml(e.GetExceptionMessage());
+    String msg = EscapeForHtml(e.getExceptionMessage());
     response.getWriter().write(msg);
     response.setContentLength(msg.length());
@@ -596,10 +596,10 @@
     if(coll != null)
-        for(int i = 0, j = 0; i < coll.GetCount(); i++)
+        for(int i = 0, j = 0; i < coll.getCount(); i++)
-            MgWebWidget item = coll.GetWidget(i);
-            int it = item.GetType();
+            MgWebWidget item = coll.getWidget(i);
+            int it = item.getType();
             if (it == MgWebWidgetType.Separator)
                 Object[] formatArgs = { varname, new Integer(j++) };
@@ -607,11 +607,11 @@
             else if ( it == MgWebWidgetType.Command && item instanceof MgWebCommandWidget )
-                MgWebCommand cmd = ((MgWebCommandWidget)item).GetCommand();
-                Integer cmdIndex = (Integer)cmds.get(cmd.GetName());
+                MgWebCommand cmd = ((MgWebCommandWidget)item).getCommand();
+                Integer cmdIndex = (Integer)cmds.get(cmd.getName());
                 if(cmdIndex == null)
                     continue;
-                Object[] formatArgs = { varname, new Integer(j++), StrEscape(cmd.GetLabel()), cmdIndex };
+                Object[] formatArgs = { varname, new Integer(j++), StrEscape(cmd.getLabel()), cmdIndex };
                 def = def + MessageFormat.format("{0}[{1,number,integer}] = new CommandItem(\"{2}\", {3,number,integer});\n", formatArgs);
             else
@@ -621,8 +621,8 @@
                 String htmlName = "FlyoutDiv" + curFlyout;
                 Object[] formatArgs1 = { subVarname };
                 def = def + MessageFormat.format("var {0} = new Array()\n", formatArgs1);
-                def = def + DeclareUiItems(((MgWebFlyoutWidget) item).GetSubItems(), subVarname);
-                Object[] formatArgs2 = { varname, new Integer(j++), StrEscape( ((MgWebFlyoutWidget) item).GetLabel() ), subVarname, StrEscape( htmlName ), ((MgWebFlyoutWidget) item).GetIconUrl() };
+                def = def + DeclareUiItems(((MgWebFlyoutWidget) item).getSubItems(), subVarname);
+                Object[] formatArgs2 = { varname, new Integer(j++), StrEscape( ((MgWebFlyoutWidget) item).getLabel() ), subVarname, StrEscape( htmlName ), ((MgWebFlyoutWidget) item).getIconUrl() };
                 def = def + MessageFormat.format("{0}[{1,number,integer}] = new FlyoutItem(\"{2}\", {3}, \"{4}\", \"{5}\");\n", formatArgs2);
Modified: trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -54,55 +54,55 @@
     // create the map instance and store it with the session
     MgResourceIdentifier resId = new MgResourceIdentifier(mapDefinition);
-    String mapName = resId.GetName();
-    map.Create(resId, mapName);
+    String mapName = resId.getName();
+    map.create(resId, mapName);
-    MgResourceIdentifier tileSetId = map.GetTileSetDefinition();
+    MgResourceIdentifier tileSetId = map.getTileSetDefinition();
-    MgTileService tileSrvc = (MgTileService)site.CreateService(MgServiceType.TileService);
-    int tileSizeX = tileSrvc.GetDefaultTileSizeX();
-    int tileSizeY = tileSrvc.GetDefaultTileSizeY();
+    MgTileService tileSrvc = (MgTileService)site.createService(MgServiceType.TileService);
+    int tileSizeX = tileSrvc.getDefaultTileSizeX();
+    int tileSizeY = tileSrvc.getDefaultTileSizeY();
     if (null != tileSetId)
         //Can't load map if it points to a non-default tile set provider
-        if (map.GetTileSetProvider() != "Default")
+        if (map.getTileSetProvider() != "Default")
-            throw new RuntimeException(MessageFormat.format(MgLocalizer.GetString("ERR_UNSUPPORTED_TILESET", locale), new Object[] { map.GetTileSetProvider() }));
+            throw new RuntimeException(MessageFormat.format(MgLocalizer.GetString("ERR_UNSUPPORTED_TILESET", locale), new Object[] { map.getTileSetProvider() }));
         //Overwrite the map definition with tile set id (this is for GETTILE requests) and
         //use size settings from that tile set
-        mapDefinition = tileSetId.ToString();
-        tileSizeX = tileSrvc.GetDefaultTileSizeX(tileSetId);
-        tileSizeY = tileSrvc.GetDefaultTileSizeY(tileSetId);
+        mapDefinition = tileSetId.toString();
+        tileSizeX = tileSrvc.getDefaultTileSizeX(tileSetId);
+        tileSizeY = tileSrvc.getDefaultTileSizeY(tileSetId);
     //create an empty selection object and store it in the session repository
     MgSelection sel = new MgSelection(map);
-    sel.Save(resourceSrvc, mapName);
+    sel.save(resourceSrvc, mapName);
     //get the map extent and calculate the scale factor
-    MgEnvelope mapExtent = map.GetMapExtent();
+    MgEnvelope mapExtent = map.getMapExtent();
     double metersPerUnit;
     String unitsType;
     if(srs != null && srs.length() > 0)
         MgCoordinateSystemFactory csFactory = new MgCoordinateSystemFactory();
-        MgCoordinateSystem cs = csFactory.Create(srs);
-        metersPerUnit = cs.ConvertCoordinateSystemUnitsToMeters(1.0);
-        unitsType = cs.GetUnits();
+        MgCoordinateSystem cs = csFactory.create(srs);
+        metersPerUnit = cs.convertCoordinateSystemUnitsToMeters(1.0);
+        unitsType = cs.getUnits();
     else
@@ -110,9 +110,9 @@
         unitsType = MgLocalizer.GetString("DISTANCEMETERS", locale);
-    MgCoordinate llExtent = mapExtent.GetLowerLeftCoordinate();
-    MgCoordinate urExtent = mapExtent.GetUpperRightCoordinate();
-    String bgColor = map.GetBackgroundColor();
+    MgCoordinate llExtent = mapExtent.getLowerLeftCoordinate();
+    MgCoordinate urExtent = mapExtent.getUpperRightCoordinate();
+    String bgColor = map.getBackgroundColor();
     if(bgColor.length() == 8)
         bgColor = "#" + bgColor.substring(2);
@@ -126,9 +126,9 @@
     // Create a sorted set of display scales
     TreeSet scales = new TreeSet();
-    for(int i = 0; i < map.GetFiniteDisplayScaleCount(); i++)
+    for(int i = 0; i < map.getFiniteDisplayScaleCount(); i++)
-        scales.add(new Double(map.GetFiniteDisplayScaleAt(i)));
+        scales.add(new Double(map.getFiniteDisplayScaleAt(i)));
     Iterator iter = scales.iterator();
     int i = 0;
@@ -138,7 +138,7 @@
         i++;
     MgResourceIdentifier mapStateId = new MgResourceIdentifier("Session:" + sessionId + "//" + mapName + "." + MgResourceType.Map);
-    map.Save(resourceSrvc, mapStateId);
+    map.save(resourceSrvc, mapStateId);
     //load html template code and format it
@@ -154,8 +154,8 @@
                 showLegend != 0 ? "true": "false",
                 showProperties != 0 ? "true": "false",
                 sessionId,
-                String.valueOf(llExtent.GetX()), String.valueOf(llExtent.GetY()),
-                String.valueOf(urExtent.GetX()), String.valueOf(urExtent.GetY()),
+                String.valueOf(llExtent.getX()), String.valueOf(llExtent.getY()),
+                String.valueOf(urExtent.getX()), String.valueOf(urExtent.getY()),
                 String.valueOf(metersPerUnit),
                 unitsType,
                 bgColor,
Modified: trunk/MgDev/Web/src/mapviewerjava/measure.jsp
--- trunk/MgDev/Web/src/mapviewerjava/measure.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/measure.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -82,14 +82,14 @@
-        site.Open(cred);
+        site.open(cred);
@@ -97,8 +97,8 @@
         //load the map runtime state and locate the measure layer
         srs = GetMapSrs(map);
         MgLayer layer = FindLayer(layers, layerDef);
@@ -107,7 +107,7 @@
             total = 0;
             if(layer != null)
-                layers.Remove(layer);
+                layers.remove(layer);
             if(DataSourceExists(resourceSrvc, dataSourceId))
                 ClearDataSource(featureSrvc, dataSourceId, featureName);
@@ -114,15 +114,15 @@
         else
-            MgCoordinateSystem srsMap = srsFactory.Create(srs);
+            MgCoordinateSystem srsMap = srsFactory.create(srs);
-            int srsType = srsMap.GetType();
+            int srsType = srsMap.getType();
             if(srsType == MgCoordinateSystemType.Geographic)
-                distance = srsMap.MeasureGreatCircleDistance(x1, y1, x2, y2);
+                distance = srsMap.measureGreatCircleDistance(x1, y1, x2, y2);
             else
-                distance = srsMap.MeasureEuclideanDistance(x1, y1, x2, y2);
+                distance = srsMap.measureEuclideanDistance(x1, y1, x2, y2);
-            distance = srsMap.ConvertCoordinateSystemUnitsToMeters(distance);
+            distance = srsMap.convertCoordinateSystemUnitsToMeters(distance);
             if (units.equals("mi")) distance *= 0.000621371192;  //get miles
             if (units.equals("km")) distance *= 0.001;           //get kilometers
@@ -135,9 +135,9 @@
             MgCoordinateCollection coordinates = new MgCoordinateCollection();
-            coordinates.Add(geomFactory.CreateCoordinateXY(x1, y1));
-            coordinates.Add(geomFactory.CreateCoordinateXY(x2, y2));
-            MgLineString geom = geomFactory.CreateLineString(coordinates);
+            coordinates.add(geomFactory.createCoordinateXY(x1, y1));
+            coordinates.add(geomFactory.createCoordinateXY(x2, y2));
+            MgLineString geom = geomFactory.createLineString(coordinates);
             if(segId == 1)
@@ -149,41 +149,41 @@
-                    classDef.SetDescription(MgLocalizer.GetString("MEASUREFEATURECLASS", locale));
+                    classDef.setDescription(MgLocalizer.GetString("MEASUREFEATURECLASS", locale));
                     //Set KEY property
                     MgDataPropertyDefinition prop = new MgDataPropertyDefinition("KEY");
-                    prop.SetDataType(MgPropertyType.Int32);
-                    prop.SetAutoGeneration(true);
-                    prop.SetReadOnly(true);
-                    classDef.GetIdentityProperties().Add(prop);
-                    classDef.GetProperties().Add(prop);
+                    prop.setDataType(MgPropertyType.Int32);
+                    prop.setAutoGeneration(true);
+                    prop.setReadOnly(true);
+                    classDef.getIdentityProperties().add(prop);
+                    classDef.getProperties().add(prop);
                     //Set PARTIAL property. Hold the distance for this segment
                     prop = new MgDataPropertyDefinition("PARTIAL");
-                    prop.SetDataType(MgPropertyType.Double);
+                    prop.setDataType(MgPropertyType.Double);
                     //Set TOTAL property. Hold the total distance up to this segment, including it
                     prop = new MgDataPropertyDefinition("TOTAL");
                     //Create the schema
                     MgFeatureSchema schema = new MgFeatureSchema("MeasureSchema", MgLocalizer.GetString("MEASURESCHEMADESCR", locale));
                     MgFileFeatureSourceParams parameters = new MgFileFeatureSourceParams("OSGeo.SDF", "MapSrs", srs, schema);
-                    featureSrvc.CreateFeatureSource(dataSourceId, parameters);
+                    featureSrvc.createFeatureSource(dataSourceId, parameters);
                     //build map tip
                     String unitText = "";
@@ -198,7 +198,7 @@
                     //Create the layer definition
                     MgByteReader layerDefContent = BuildLayerDefinitionContent(dataSource, featureName, tip);
                 else
@@ -211,9 +211,9 @@
                     legendName = MgLocalizer.GetString("MEASURELAYER", locale);
-                    layer.SetLegendLabel(legendName);
+                    layer.setLegendLabel(legendName);
             // create a feature representing this segment and insert it into the data source
@@ -221,32 +221,32 @@
             MgPropertyCollection measureProps = new MgPropertyCollection();
             MgDoubleProperty partialProp = new MgDoubleProperty("PARTIAL", distance);
-            measureProps.Add(partialProp);
+            measureProps.add(partialProp);
             MgDoubleProperty totalProp = new MgDoubleProperty("TOTAL", total);
-            measureProps.Add(totalProp);
+            measureProps.add(totalProp);
             MgAgfReaderWriter agf = new MgAgfReaderWriter();
-            MgByteReader geomReader = agf.Write(geom);
+            MgByteReader geomReader = agf.write(geom);
             MgGeometryProperty geometryProp = new MgGeometryProperty("GEOM", geomReader);
-            measureProps.Add(geometryProp);
+            measureProps.add(geometryProp);
             MgInsertFeatures cmd = new MgInsertFeatures(featureName, measureProps);
-            commands.Add(cmd);
+            commands.add(cmd);
             //Insert the distance feature in the temporary data source
-            ReleaseReader(featureSrvc.UpdateFeatures(dataSourceId, commands, false));
+            ReleaseReader(featureSrvc.updateFeatures(dataSourceId, commands, false));
         if(layer != null)
-        map.Save();
+        map.save();
-        OnError(MgLocalizer.GetString("MEASUREERROR", locale), exc.GetDetails(), outStream, request);
+        OnError(MgLocalizer.GetString("MEASUREERROR", locale), exc.getDetails(), outStream, request);
         return;
     catch(Exception ne)
@@ -303,7 +303,7 @@
 String GetMapSrs(MgMap map) throws MgException
-    srs = map.GetMapSRS();
+    srs = map.getMapSRS();
     if(!srs.equals(""))
         return srs;
@@ -316,10 +316,10 @@
     int i;
-        if(layer1.GetLayerDefinition().ToString().equals(layerDef))
+        if(layer1.getLayerDefinition().toString().equals(layerDef))
             layer = layer1;
             break;
@@ -330,7 +330,7 @@
 boolean DataSourceExists(MgResourceService resourceSrvc, MgResourceIdentifier resId) throws MgException
-    return resourceSrvc.ResourceExists(resId);
+    return resourceSrvc.resourceExists(resId);
 MgByteReader BuildLayerDefinitionContent(String dataSource, String featureName, String tip) throws MgException, Exception
@@ -347,7 +347,7 @@
@@ -354,8 +354,8 @@
     MgDeleteFeatures deleteCmd = new MgDeleteFeatures(featureName, "KEY >= 0");
@@ -369,16 +369,16 @@
     if(res == null)
         return;
-    MgProperty prop = res.GetItem(0);
+    MgProperty prop = res.getItem(0);
     if(prop == null)
         return;
     if (prop instanceof MgStringProperty)
-        throw new RuntimeException(((MgStringProperty)prop).GetValue());
+        throw new RuntimeException(((MgStringProperty)prop).getValue());
     MgFeatureProperty resProp = (MgFeatureProperty)prop;
     if(reader == null)
         return;
-    reader.Close();
+    reader.close();
Modified: trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp
--- trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -55,8 +55,8 @@
     catch (MgException e)
         response.setContentType("text/html");
-        out.write ("ERROR:" + e.GetExceptionMessage() + "<br />");
-        out.write (e.GetStackTrace() + "<br />");
+        out.write ("ERROR:" + e.getExceptionMessage() + "<br />");
+        out.write (e.getStackTrace() + "<br />");
@@ -94,13 +94,13 @@
     for (int i = 0; i < coordinates.length; ++i)
-        coordinateCollection.Add(geometryFactory.CreateCoordinateXY(numberFormat.parse(coordinates[i]).doubleValue(), numberFormat.parse(coordinates[++i]).doubleValue()));
+        coordinateCollection.add(geometryFactory.createCoordinateXY(numberFormat.parse(coordinates[i]).doubleValue(), numberFormat.parse(coordinates[++i]).doubleValue()));
-    coordinateCollection.Add(geometryFactory.CreateCoordinateXY(numberFormat.parse(coordinates[0]).doubleValue(), numberFormat.parse(coordinates[1]).doubleValue()));
-    MgLinearRing linearRing = geometryFactory.CreateLinearRing(coordinateCollection);
+    coordinateCollection.add(geometryFactory.createCoordinateXY(numberFormat.parse(coordinates[0]).doubleValue(), numberFormat.parse(coordinates[1]).doubleValue()));
+    MgLinearRing linearRing = geometryFactory.createLinearRing(coordinateCollection);
-    return geometryFactory.CreatePolygon(linearRing, null);
+    return geometryFactory.createPolygon(linearRing, null);
 BufferedImage GenerateMap(Size<Integer> size) throws MgException, IOException
@@ -109,30 +109,30 @@
     MgUserInformation userInfo = new MgUserInformation(sessionId);
     MgSiteConnection siteConnection = new MgSiteConnection();
-    siteConnection.Open(userInfo);
-    MgRenderingService renderingService = (MgRenderingService) siteConnection.CreateService(MgServiceType.RenderingService);
+    siteConnection.open(userInfo);
+    MgRenderingService renderingService = (MgRenderingService) siteConnection.createService(MgServiceType.RenderingService);
     MgMap map = new MgMap(siteConnection);
     MgSelection selection = new MgSelection(map);
     // Caculate the generated picture size
-    MgEnvelope envelope = captureBox.Envelope();
-    MgEnvelope normalizedE = normalizedCapture.Envelope();
-    Size<Double> size1 = new Size<Double>(envelope.GetWidth(), envelope.GetHeight());
-    Size<Double> size2 = new Size<Double>(normalizedE.GetWidth(), normalizedE.GetHeight());
+    MgEnvelope envelope = captureBox.envelope();
+    MgEnvelope normalizedE = normalizedCapture.envelope();
+    Size<Double> size1 = new Size<Double>(envelope.getWidth(), envelope.getHeight());
+    Size<Double> size2 = new Size<Double>(normalizedE.getWidth(), normalizedE.getHeight());
     Size<Double> toSize = new Size<Double>(size1.width / size2.width * size.width, size1.height / size2.height * size.height);
-    MgCoordinate center = captureBox.GetCentroid().GetCoordinate();
+    MgCoordinate center = captureBox.getCentroid().getCoordinate();
-    map.SetDisplayDpi(printDpi);
-    String colorString = map.GetBackgroundColor();
+    map.setDisplayDpi(printDpi);
+    String colorString = map.getBackgroundColor();
     // The returned color string is in AARRGGBB format. But the constructor of MgColor needs a string in RRGGBBAA format
     colorString = colorString.substring(2, 8) + colorString.substring(0, 2);
     MgColor color = new MgColor(colorString);
-    MgByteReader mgReader = renderingService.RenderMap(map,
+    MgByteReader mgReader = renderingService.renderMap(map,
                                                     selection,
                                                     center,
                                                     scaleDenominator,
@@ -142,7 +142,7 @@
                                                     "PNG",
                                                     false);
     File tempImage = File.createTempFile(UUID.randomUUID().toString(), "png");
-    mgReader.ToFile(tempImage.getAbsolutePath());
+    mgReader.toFile(tempImage.getAbsolutePath());
     BufferedImage image = ImageIO.read(tempImage);
     tempImage.delete();
Modified: trunk/MgDev/Web/src/mapviewerjava/search.jsp
--- trunk/MgDev/Web/src/mapviewerjava/search.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/search.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -81,24 +81,24 @@
-        site.Open(cred);
+        site.open(cred);
         //Create a temporary map runtime object, locate the layer
         int i, j;
-            layer = (MgLayer)layers.GetItem(i);
-            if(layer.GetName().equals(layerName))
+            layer = (MgLayer)layers.getItem(i);
+            if(layer.getName().equals(layerName))
                 break;
@@ -116,16 +116,16 @@
         boolean displayAll = (resProps.size() == 0);
         //query the features
-        MgClassDefinition clsDef = layer.GetClassDefinition();
+        MgClassDefinition clsDef = layer.getClassDefinition();
         MgFeatureQueryOptions opts = BuildFeatureQueryOptions(clsDef);
-        opts.SetFilter(filter);
-        String featureClassName = layer.GetFeatureClassName();
-        features = layer.SelectFeatures(opts);
-        boolean hasResult = features.ReadNext();
+        opts.setFilter(filter);
+        String featureClassName = layer.getFeatureClassName();
+        features = layer.selectFeatures(opts);
+        boolean hasResult = features.readNext();
         if(hasResult)
-            int colCount = displayAll ? features.GetPropertyCount(): resProps.size();
+            int colCount = displayAll ? features.getPropertyCount(): resProps.size();
             //output the beginning of the document (head section and beginning of body section)
             String templ = MgLocalizer.Localize(LoadTemplate("/viewerfiles/search.templ"), locale, GetClientOS(request));
@@ -136,13 +136,13 @@
             outStream.write(Substitute(templ, vals));
-            MgPropertyDefinitionCollection classDefProps = classDef.GetIdentityProperties();
-            ArrayList idPropNames = new ArrayList(classDefProps.GetCount());
-            for(j = 0; j < classDefProps.GetCount(); j++)
+            MgPropertyDefinitionCollection classDefProps = classDef.getIdentityProperties();
+            ArrayList idPropNames = new ArrayList(classDefProps.getCount());
+            for(j = 0; j < classDefProps.getCount(); j++)
-                MgPropertyDefinition idProp = classDefProps.GetItem(j);
-                idPropNames.add(idProp.GetName());
+                MgPropertyDefinition idProp = classDefProps.getItem(j);
+                idPropNames.add(idProp.getName());
             //table headings
@@ -151,7 +151,7 @@
                 for(i = 0; i < colCount; i++)
-                    resProps.add(features.GetPropertyName(i));
+                    resProps.add(features.getPropertyName(i));
                     outStream.write("<td class=\"SearchHeading\"> " + (String)resProps.get(i) + "</td>");
@@ -171,35 +171,35 @@
                     String prop = (String)resProps.get(i);
-                    int propType = features.GetPropertyType(prop);
+                    int propType = features.getPropertyType(prop);
                     String val = "";
-                    if (!features.IsNull(prop))
+                    if (!features.isNull(prop))
                         switch(propType)
-                                val = features.GetBoolean(prop)? "True": "False";
+                                val = features.getBoolean(prop)? "True": "False";
                                 break;
-                                val = String.valueOf(features.GetSingle(prop));
+                                val = String.valueOf(features.getSingle(prop));
                                 break;
-                                val = String.valueOf(features.GetDouble(prop));
+                                val = String.valueOf(features.getDouble(prop));
                                 break;
-                                val = String.valueOf(features.GetInt16(prop));
+                                val = String.valueOf(features.getInt16(prop));
                                 break;
-                                val = String.valueOf(features.GetInt32(prop));
+                                val = String.valueOf(features.getInt32(prop));
                                 break;
-                                val = String.valueOf(features.GetInt64(prop));
+                                val = String.valueOf(features.getInt64(prop));
                                 break;
-                                val = features.GetString(prop);
+                                val = features.getString(prop);
                                 break;
-                                val = features.GetDateTime(prop).ToString();
+                                val = features.getDateTime(prop).toString();
                                 break;
@@ -211,33 +211,33 @@
                     for (Iterator it = idPropNames.iterator(); it.hasNext(); )
                         String id = (String) it.next();
-                        idPropType = features.GetPropertyType(id);
+                        idPropType = features.getPropertyType(id);
                         switch (idPropType)
-                                idProps.Add(new MgInt32Property(id, features.GetInt32(id)));
+                                idProps.add(new MgInt32Property(id, features.getInt32(id)));
                                 break;
-                                idProps.Add(new MgStringProperty(id, features.GetString(id)));
+                                idProps.add(new MgStringProperty(id, features.getString(id)));
                                 break;
-                                idProps.Add(new MgInt64Property(id, features.GetInt64(id)));
+                                idProps.add(new MgInt64Property(id, features.getInt64(id)));
                                 break;
-                                idProps.Add(new MgDoubleProperty(id, features.GetDouble(id)));
+                                idProps.add(new MgDoubleProperty(id, features.getDouble(id)));
                                 break;
-                                idProps.Add(new MgSingleProperty(id, features.GetSingle(id)));
+                                idProps.add(new MgSingleProperty(id, features.getSingle(id)));
                                 break;
-                                idProps.Add(new MgDateTimeProperty(id, features.GetDateTime(id)));
+                                idProps.add(new MgDateTimeProperty(id, features.getDateTime(id)));
                                 break;
                             default:
                                 throw new SearchError(MessageFormat.format(MgLocalizer.GetString("SEARCHTYYPENOTSUP", locale), new Object[] {String.valueOf(idPropType)}), searchError);
-                    sel.AddFeatureIds(layer, featureClassName, idProps);
-                    String selText = EscapeForHtml(sel.ToXml());
+                    sel.addFeatureIds(layer, featureClassName, idProps);
+                    String selText = EscapeForHtml(sel.toXml());
                     outStream.write("<td class=\"" + ((row%2)==0 ? "Search" : "Search2") + "\" id=\"" + row +  ":" + i + "\" onmousemove=\"SelectRow(" + row + ")\" onclick=\"CellClicked('" + selText + "')\"> " + val + "</td>\n");
@@ -244,7 +244,7 @@
                 outStream.write("</tr>");
                 if(++ row == matchLimit)
                     break;
-            } while(features.ReadNext());
+            } while(features.readNext());
         else
@@ -256,9 +256,9 @@
         if(features != null)
             // Close the feature reader
-            features.Close();
+            features.close();
-        OnError(searchError, ae.GetExceptionMessage() + "<br>" + ae.GetStackTrace(), outStream, request);
+        OnError(searchError, ae.getExceptionMessage() + "<br>" + ae.getStackTrace(), outStream, request);
     catch(SearchError exc)
@@ -265,7 +265,7 @@
-            features.Close();
+            features.close();
         OnError(exc.title, exc.getMessage(), outStream, request);
Modified: trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp
--- trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -43,21 +43,21 @@
         InitializeWebTier();
         MgUserInformation cred = new MgUserInformation(sessionId);
-        cred.SetClientIp(GetClientIp(request));
-        cred.SetClientAgent(GetClientAgent());
+        cred.setClientIp(GetClientIp(request));
+        cred.setClientAgent(GetClientAgent());
         //connect to the site and get an instance of each service used in this script
         MgSiteConnection site = new MgSiteConnection();
-        site.Open(cred);
-        MgFeatureService featureSrvc = (MgFeatureService)site.CreateService(MgServiceType.FeatureService);
-        MgRenderingService renderingSrvc = (MgRenderingService)site.CreateService(MgServiceType.RenderingService);
-        MgResourceService resourceSrvc = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
+        site.open(cred);
+        MgFeatureService featureSrvc = (MgFeatureService)site.createService(MgServiceType.FeatureService);
+        MgRenderingService renderingSrvc = (MgRenderingService)site.createService(MgServiceType.RenderingService);
+        MgResourceService resourceSrvc = (MgResourceService)site.createService(MgServiceType.ResourceService);
         MgMap map = new MgMap(site);
-        map.Open(mapName);
+        map.open(mapName);
         String[] layersList = layers.split(",");
         if(layersList.length > 0)
@@ -65,7 +65,7 @@
             MgStringCollection layerNames = new MgStringCollection();
             for(int i = 0; i < layersList.length; i++)
-                layerNames.Add(layersList[i]);
+                layerNames.add(layersList[i]);
             // create a multi-polygon or a multi-geometry containing the input selected features
@@ -75,22 +75,22 @@
                 // Query all the features belonging the the layer list that intersects with the input geometries
-                MgFeatureInformation fi = renderingSrvc.QueryFeatures(map, layerNames, inputGeom, MgFeatureSpatialOperations.Intersects, -1);
+                MgFeatureInformation fi = renderingSrvc.queryFeatures(map, layerNames, inputGeom, MgFeatureSpatialOperations.Intersects, -1);
                 if(fi !=  null)
-                    MgSelection resultSel = fi.GetSelection();
+                    MgSelection resultSel = fi.getSelection();
                     if(resultSel != null)
                         // Return XML
-                        resultSel.Save(resourceSrvc, mapName);
+                        resultSel.save(resourceSrvc, mapName);
                         //this needs to be re-opened for some reason
                         resultSel = new MgSelection(map);
-                        resultSel.Open(resourceSrvc, mapName);
-                        MgReadOnlyLayerCollection resLayers = resultSel.GetLayers();
-                        if (resLayers != null && resLayers.GetCount() >= 0)
+                        resultSel.open(resourceSrvc, mapName);
+                        MgReadOnlyLayerCollection resLayers = resultSel.getLayers();
+                        if (resLayers != null && resLayers.getCount() >= 0)
                             response.addHeader("Content-type", "text/xml");
-                            outStream.write(resultSel.ToXml());
+                            outStream.write(resultSel.toXml());
@@ -99,7 +99,7 @@
-        outStream.write("\nException: " + exc.GetDetails());
+        outStream.write("\nException: " + exc.getDetails());
         return;
     catch(Exception ne)
@@ -113,7 +113,7 @@
 MgGeometry MultiGeometryFromSelection(MgFeatureService featureSrvc, MgMap map, String selText) throws MgException
     MgSelection sel = new MgSelection(map, selText);
-    MgReadOnlyLayerCollection selLayers = sel.GetLayers();
+    MgReadOnlyLayerCollection selLayers = sel.getLayers();
     if(selLayers == null)
         return null;
     MgGeometryCollection geomColl = new MgGeometryCollection();
@@ -120,26 +120,26 @@
     MgAgfReaderWriter agfRW = new MgAgfReaderWriter();
     boolean simplyPolygonOnly = true;
-    for(int i = 0; i < selLayers.GetCount(); i++)
+    for(int i = 0; i < selLayers.getCount(); i++)
-        MgLayer layer = (MgLayer) selLayers.GetItem(i);
-        String filter = sel.GenerateFilter(layer, layer.GetFeatureClassName());
+        MgLayer layer = (MgLayer) selLayers.getItem(i);
+        String filter = sel.generateFilter(layer, layer.getFeatureClassName());
-        MgResourceIdentifier featureSource = new MgResourceIdentifier(layer.GetFeatureSourceId());
-        MgFeatureReader features = featureSrvc.SelectFeatures(featureSource, layer.GetFeatureClassName(), query);
+        MgResourceIdentifier featureSource = new MgResourceIdentifier(layer.getFeatureSourceId());
+        MgFeatureReader features = featureSrvc.selectFeatures(featureSource, layer.getFeatureClassName(), query);
-                int type = geom.GetGeometryType();
+                int type = geom.getGeometryType();
                 if(type == MgGeometryType.MultiPolygon || type == MgGeometryType.CurvePolygon || type == MgGeometryType.MultiCurvePolygon)
                     simplyPolygonOnly = false;
@@ -148,13 +148,13 @@
                     continue;
-                geomColl.Add(geom);
+                geomColl.add(geom);
-            features.Close();
+            features.close();
-    if(geomColl.GetCount() == 0)
+    if(geomColl.getCount() == 0)
         return null;
@@ -163,15 +163,15 @@
     if(simplyPolygonOnly)
         MgPolygonCollection polyColl = new MgPolygonCollection();
-        for(int j = 0; j < geomColl.GetCount(); j++)
+        for(int j = 0; j < geomColl.getCount(); j++)
-            polyColl.Add((MgPolygon)geomColl.GetItem(j));
+            polyColl.add((MgPolygon)geomColl.getItem(j));
-        return gf.CreateMultiPolygon(polyColl);
+        return gf.createMultiPolygon(polyColl);
     else
-        return gf.CreateMultiGeometry(geomColl);
+        return gf.createMultiGeometry(geomColl);
Modified: trunk/MgDev/Web/src/mapviewerjava/serveradminhelper.jsp
--- trunk/MgDev/Web/src/mapviewerjava/serveradminhelper.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/serveradminhelper.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -38,23 +38,23 @@
-        cred.SetMgUsernamePassword("Administrator", "admin");
-        cred.SetLocale(GetDefaultLocale());
+        cred.setMgUsernamePassword("Administrator", "admin");
+        cred.setLocale(GetDefaultLocale());
         MgServerAdmin serverAdmin = new MgServerAdmin();
-        serverAdmin.Open("localhost", cred);
+        serverAdmin.open("localhost", cred);
         String operation = request.getParameter("OPERATION");
         // Get all information properties
-        MgPropertyCollection infoProp = serverAdmin.GetInformationProperties();
+        MgPropertyCollection infoProp = serverAdmin.getInformationProperties();
         if (operation.equals("ONLINE"))
-            serverAdmin.BringOnline();
-            if (serverAdmin.IsOnline())
+            serverAdmin.bringOnline();
+            if (serverAdmin.isOnline())
                 outStream.write("Server online<p>");
@@ -65,8 +65,8 @@
         else if (operation.equals("OFFLINE"))
-            serverAdmin.TakeOffline();
+            serverAdmin.takeOffline();
@@ -77,63 +77,63 @@
         else if (operation.equals("GETTOTALPHYSICALMEMORY"))
-            MgInt64Property nMemory = (MgInt64Property)infoProp.GetItem("TotalPhysicalMemory");
-            outStream.write("Total Physical Memory: " + nMemory.GetValue() + " bytes");
+            MgInt64Property nMemory = (MgInt64Property)infoProp.getItem("TotalPhysicalMemory");
+            outStream.write("Total Physical Memory: " + nMemory.getValue() + " bytes");
         else if (operation.equals("GETAVAILABLEPHYSICALMEMORY"))
-            MgInt64Property nMemory = (MgInt64Property)infoProp.GetItem("AvailablePhysicalMemory");
-            outStream.write("Available Physical Memory: " + nMemory.GetValue() + " bytes");
+            MgInt64Property nMemory = (MgInt64Property)infoProp.getItem("AvailablePhysicalMemory");
+            outStream.write("Available Physical Memory: " + nMemory.getValue() + " bytes");
         else if (operation.equals("GETTOTALVIRTUALMEMORY"))
-            MgInt64Property nMemory = (MgInt64Property)infoProp.GetItem("TotalVirtualMemory");
-            outStream.write("Total Virtual Memory: " + nMemory.GetValue() + " bytes");
+            MgInt64Property nMemory = (MgInt64Property)infoProp.getItem("TotalVirtualMemory");
+            outStream.write("Total Virtual Memory: " + nMemory.getValue() + " bytes");
         else if (operation.equals("GETAVAILABLEVIRTUALMEMORY"))
-            MgInt64Property nMemory = (MgInt64Property)infoProp.GetItem("AvailableVirtualMemory");
-            outStream.write("Available Virtual Memory: " + nMemory.GetValue() + " bytes");
+            MgInt64Property nMemory = (MgInt64Property)infoProp.getItem("AvailableVirtualMemory");
+            outStream.write("Available Virtual Memory: " + nMemory.getValue() + " bytes");
         else if (operation.equals("GETCPUUTILIZATION"))
-            MgInt32Property nCpuLoad = (MgInt32Property)infoProp.GetItem("CpuUtilization");
-            outStream.write("Current CPU Utilization: " + nCpuLoad.GetValue() + "%");
+            MgInt32Property nCpuLoad = (MgInt32Property)infoProp.getItem("CpuUtilization");
+            outStream.write("Current CPU Utilization: " + nCpuLoad.getValue() + "%");
         else if (operation.equals("GETUPTIME"))
-            MgInt32Property nUptime = (MgInt32Property)infoProp.GetItem("Uptime");
-            outStream.write("Server uptime: " + nUptime.GetValue() + " seconds");
+            MgInt32Property nUptime = (MgInt32Property)infoProp.getItem("Uptime");
+            outStream.write("Server uptime: " + nUptime.getValue() + " seconds");
         else if (operation.equals("GETAVERAGEOPERATIONTIME"))
-            MgInt32Property nTime = (MgInt32Property)infoProp.GetItem("AverageOperationTime");
-            outStream.write("Average Operation Time: " + nTime.GetValue() + " milliseconds");
+            MgInt32Property nTime = (MgInt32Property)infoProp.getItem("AverageOperationTime");
+            outStream.write("Average Operation Time: " + nTime.getValue() + " milliseconds");
         else if (operation.equals("GETTOTALOPERATIONTIME"))
-            MgInt32Property nTime = (MgInt32Property)infoProp.GetItem("TotalOperationTime");
-            outStream.write("Total Operation Time: " + nTime.GetValue() + " seconds");
+            MgInt32Property nTime = (MgInt32Property)infoProp.getItem("TotalOperationTime");
+            outStream.write("Total Operation Time: " + nTime.getValue() + " seconds");
         else if (operation.equals("GETADMINQUEUECOUNT"))
-            MgInt32Property nCount = (MgInt32Property)infoProp.GetItem("AdminOperationsQueueCount");
-            outStream.write("Admin queue count: " + nCount.GetValue());
+            MgInt32Property nCount = (MgInt32Property)infoProp.getItem("AdminOperationsQueueCount");
+            outStream.write("Admin queue count: " + nCount.getValue());
         else if (operation.equals("GETCLIENTQUEUECOUNT"))
-            MgInt32Property nCount = (MgInt32Property)infoProp.GetItem("ClientOperationsQueueCount");
-            outStream.write("Client queue count: " + nCount.GetValue());
+            MgInt32Property nCount = (MgInt32Property)infoProp.getItem("ClientOperationsQueueCount");
+            outStream.write("Client queue count: " + nCount.getValue());
         else if (operation.equals("GETSITEQUEUECOUNT"))
-            MgInt32Property nCount = (MgInt32Property)infoProp.GetItem("SiteOperationsQueueCount");
-            outStream.write("Site queue count: " + nCount.GetValue());
+            MgInt32Property nCount = (MgInt32Property)infoProp.getItem("SiteOperationsQueueCount");
+            outStream.write("Site queue count: " + nCount.getValue());
         else if (operation.equals("SERVERVERSION"))
-            MgStringProperty version = (MgStringProperty)infoProp.GetItem("ServerVersion");
-            outStream.write("Server version: " + version.GetValue());
+            MgStringProperty version = (MgStringProperty)infoProp.getItem("ServerVersion");
+            outStream.write("Server version: " + version.getValue());
         else
@@ -142,7 +142,7 @@
     catch (MgException mge)
-        outStream.write(mge.GetDetails());
+        outStream.write(mge.getDetails());
Modified: trunk/MgDev/Web/src/mapviewerjava/taskframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/taskframe.jsp	2021-06-12 09:03:31 UTC (rev 9853)
+++ trunk/MgDev/Web/src/mapviewerjava/taskframe.jsp	2021-06-17 15:58:40 UTC (rev 9854)
@@ -42,19 +42,19 @@
         //connect to the site and get a feature service and a resource service instances
-        site.Open(cred);
+        site.open(cred);
         //Get the MgWebLayout object
         MgResourceIdentifier webLayoutResId = new MgResourceIdentifier(webLayoutId);
         MgWebLayout webLayout = new MgWebLayout(resourceSrvc, webLayoutResId);
-        String taskPaneUrl = taskPane.GetInitialTaskUrl();
+        String taskPaneUrl = taskPane.getInitialTaskUrl();
         if (taskPaneUrl == null || taskPaneUrl.length() == 0)
@@ -86,7 +86,7 @@
     catch (MgException exc)
-        OnError(MgLocalizer.GetString("TASKS", locale), exc.GetExceptionMessage(), response.getWriter(), request);
+        OnError(MgLocalizer.GetString("TASKS", locale), exc.getExceptionMessage(), response.getWriter(), request);
         return;
     catch (Exception ne)
More information about the mapguide-commits mailing list
