[mapguide-commits] r9856 - in trunk/MgDev/Doc/samples/javaviewersample: . findaddress plot query query/classes theme
svn_mapguide at osgeo.org
Thu Jun 17 09:49:08 PDT 2021
Author: jng
Date: 2021-06-17 09:49:08 -0700 (Thu, 17 Jun 2021)
New Revision: 9856
trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddress.jsp
trunk/MgDev/Doc/samples/javaviewersample/plot/plot.jsp
trunk/MgDev/Doc/samples/javaviewersample/plot/plotmain.jsp
trunk/MgDev/Doc/samples/javaviewersample/query/classes/feature.jsp
trunk/MgDev/Doc/samples/javaviewersample/query/classes/query.jsp
trunk/MgDev/Doc/samples/javaviewersample/query/querycontroller.jsp
trunk/MgDev/Doc/samples/javaviewersample/query/querymain.jsp
trunk/MgDev/Doc/samples/javaviewersample/theme/themecontroller.jsp
trunk/MgDev/Doc/samples/javaviewersample/utilityfunctions.jsp
#2839: Fix up remainder of javaviewersample to use MapGuideApiEx.jar
Modified: trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddress.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddress.jsp 2021-06-17 15:59:09 UTC (rev 9855)
+++ trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddress.jsp 2021-06-17 16:49:08 UTC (rev 9856)
@@ -59,7 +59,7 @@
MgUserInformation userInfo = new MgUserInformation(mgSessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
- siteConnection.Open(userInfo);
+ siteConnection.open(userInfo);
String address = request.getParameter("address") + ", Sheboygan, WI";
@@ -81,11 +81,11 @@
// the ResourceService object to open the map instance in
// session state.
- MgResourceService resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
- MgFeatureService featureService = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
+ MgResourceService resourceService = (MgResourceService)siteConnection.createService(MgServiceType.ResourceService);
+ MgFeatureService featureService = (MgFeatureService)siteConnection.createService(MgServiceType.FeatureService);
MgMap map = new MgMap(siteConnection);
- map.Open("Sheboygan");
+ map.open("Sheboygan");
// Check the map for the AddressMarker layer. If it does not
// exist then create a feature source to store address results
@@ -98,9 +98,9 @@
CreateAddressMarkerFeatureSource(featureService, addressMarkerDataResId);
addressLayer = CreateAddressMarkerLayer(resourceService, addressMarkerDataResId, mgSessionId);
- map.GetLayers().Insert(0, addressLayer);
+ map.getLayers().insert(0, addressLayer);
- else if (addressLayer.GetVisible())
+ else if (addressLayer.getVisible())
// If the layer exists and is visible, then display the
// previous results.
@@ -114,21 +114,21 @@
MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
MgGeometryFactory geometryFactory = new MgGeometryFactory();
- MgPoint addrPoint = geometryFactory.CreatePoint(geometryFactory.CreateCoordinateXY(Double.parseDouble(addr.lon), Double.parseDouble(addr.lat)));
+ MgPoint addrPoint = geometryFactory.createPoint(geometryFactory.createCoordinateXY(Double.parseDouble(addr.lon), Double.parseDouble(addr.lat)));
MgPropertyCollection properties = new MgPropertyCollection();
- properties.Add(new MgStringProperty("Address", addr.address1));
- properties.Add(new MgGeometryProperty("Location", geometryReaderWriter.Write(addrPoint)));
+ properties.add(new MgStringProperty("Address", addr.address1));
+ properties.add(new MgGeometryProperty("Location", geometryReaderWriter.write(addrPoint)));
MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
- commands.Add(new MgInsertFeatures("AddressMarker", properties));
+ commands.add(new MgInsertFeatures("AddressMarker", properties));
- featureService.UpdateFeatures(addressMarkerDataResId, commands, false);
+ featureService.updateFeatures(addressMarkerDataResId, commands, false);
- addressLayer.SetVisible(true);
- addressLayer.ForceRefresh();
+ addressLayer.setVisible(true);
+ addressLayer.forceRefresh();
- map.Save();
+ map.save();
success = true;
@@ -139,9 +139,9 @@
catch (MgException e)
- out.write("<tr><td>" + e.GetExceptionMessage()+ "</td></tr>");
+ out.write("<tr><td>" + e.getExceptionMessage()+ "</td></tr>");
out.write("<tr><td class=\"Spacer\"></td></tr>");
- out.write("<tr><td>" + e.GetDetails() + "</td></tr>");
+ out.write("<tr><td>" + e.getDetails() + "</td></tr>");
Modified: trunk/MgDev/Doc/samples/javaviewersample/plot/plot.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/plot/plot.jsp 2021-06-17 15:59:09 UTC (rev 9855)
+++ trunk/MgDev/Doc/samples/javaviewersample/plot/plot.jsp 2021-06-17 16:49:08 UTC (rev 9856)
@@ -37,10 +37,10 @@
// Now create an instance of MappingService and use it to plot the
// current view of the map.
@@ -47,9 +47,9 @@
MgDwfVersion dwfVersion = new MgDwfVersion("6.01", "1.2");
MgPlotSpecification plotSpec = new MgPlotSpecification(8.5f, 11.0f, MgPageUnitsType.Inches, 0f, 0f, 0f, 0f);
- plotSpec.SetMargins(0.5f, 0.5f, 0.5f, 0.5f);
+ plotSpec.setMargins(0.5f, 0.5f, 0.5f, 0.5f);
- MgMappingService mappingService = (MgMappingService)siteConnection.CreateService(MgServiceType.MappingService);
+ MgMappingService mappingService = (MgMappingService)siteConnection.createService(MgServiceType.MappingService);
MgLayout layout = null;
String useLayout = request.getParameter("UseLayout");
@@ -63,12 +63,12 @@
MgByteReader byteReader = null;
if (scale <= 0)
- byteReader = mappingService.GeneratePlot(map, plotSpec, layout, dwfVersion);
+ byteReader = mappingService.generatePlot(map, plotSpec, layout, dwfVersion);
else
- MgCoordinate mapCenter = map.GetViewCenter().GetCoordinate();
- byteReader = mappingService.GeneratePlot(map, mapCenter, scale, plotSpec, layout, dwfVersion);
+ MgCoordinate mapCenter = map.getViewCenter().getCoordinate();
+ byteReader = mappingService.generatePlot(map, mapCenter, scale, plotSpec, layout, dwfVersion);
// Now output the resulting DWF.
@@ -77,7 +77,7 @@
- String result = e.GetExceptionMessage() + "<br><br>" + e.GetDetails();
+ String result = e.getExceptionMessage() + "<br><br>" + e.getDetails();
response.setContentType("text/html");
response.setContentLength(result.length());
Modified: trunk/MgDev/Doc/samples/javaviewersample/plot/plotmain.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/plot/plotmain.jsp 2021-06-17 15:59:09 UTC (rev 9855)
+++ trunk/MgDev/Doc/samples/javaviewersample/plot/plotmain.jsp 2021-06-17 16:49:08 UTC (rev 9856)
@@ -88,7 +88,7 @@
// Create a ResourcService object and use it to open the Map
// object from the sessions repository. Use the Map object to
@@ -96,15 +96,15 @@
// page.
- viewCenter = map.GetViewCenter();
- viewScale = map.GetViewScale();
+ viewCenter = map.getViewCenter();
+ viewScale = map.getViewScale();
- out.write(e.GetExceptionMessage());
- out.write(e.GetDetails());
+ out.write(e.getExceptionMessage());
+ out.write(e.getDetails());
return;
@@ -118,8 +118,8 @@
<table class="RegText" border="0" cellspacing="0" width="100%">
<tr><td class="Title"> Plot as DWF<hr></td></tr>
<tr><td class="SubTitle">Plot a View of the Map</td></tr>
- <tr><td>View Center X: <%= nf.format(viewCenter.GetCoordinate().GetX()) %></td></tr>
- <tr><td>View Center Y: <%= nf.format(viewCenter.GetCoordinate().GetY()) %></td></tr>
+ <tr><td>View Center X: <%= nf.format(viewCenter.getCoordinate().getX()) %></td></tr>
+ <tr><td>View Center Y: <%= nf.format(viewCenter.getCoordinate().getY()) %></td></tr>
<tr><td>View Scale: 1:<%= nf.format((int)viewScale) %><hr></td></tr>
Modified: trunk/MgDev/Doc/samples/javaviewersample/query/classes/feature.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/query/classes/feature.jsp 2021-06-17 15:59:09 UTC (rev 9855)
+++ trunk/MgDev/Doc/samples/javaviewersample/query/classes/feature.jsp 2021-06-17 16:49:08 UTC (rev 9856)
@@ -34,8 +34,8 @@
this.displayValue = displayValue;
if (centerPoint != null)
- this.centerX = centerPoint.GetCoordinate().GetX();
- this.centerY = centerPoint.GetCoordinate().GetY();
+ this.centerX = centerPoint.getCoordinate().getX();
+ this.centerY = centerPoint.getCoordinate().getY();
this.idList = new HashMap(idList);
Modified: trunk/MgDev/Doc/samples/javaviewersample/query/classes/query.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/query/classes/query.jsp 2021-06-17 15:59:09 UTC (rev 9855)
+++ trunk/MgDev/Doc/samples/javaviewersample/query/classes/query.jsp 2021-06-17 16:49:08 UTC (rev 9856)
@@ -38,7 +38,7 @@
this.args = incomingArgs;
this.site = new MgSiteConnection();
- this.site.Open(new MgUserInformation(this.args.get("SESSION")));
+ this.site.open(new MgUserInformation(this.args.get("SESSION")));
this.numOperators = new String[] {"Equal to", "Not equal to", "Greater than", "Greater than or equal to", "Less than", "Less than or equal to"};
this.numExpressions = new String[] {" = %s", " != %s", " > %s", " >= %s", " < %s", " <= %s"};
this.strOperators = new String[] {"Begins with", "Contains", "Equal to"};
@@ -65,21 +65,21 @@
return jsonArray.toString();
- public ArrayList<String> GetMapLayerNames() throws MgException
+ public ArrayList<String> getMapLayerNames() throws MgException
MgMap map = new MgMap(this.site);
- map.Open(this.args.get("MAPNAME"));
- MgLayerCollection layers = map.GetLayers();
+ map.open(this.args.get("MAPNAME"));
+ MgLayerCollection layers = map.getLayers();
ArrayList<String> layerNames = new ArrayList<String>();
- for(int i=0; i<layers.GetCount(); i++)
+ for(int i=0; i<layers.getCount(); i++)
- MgLayer layer = (MgLayer) layers.GetItem(i);
+ MgLayer layer = (MgLayer) layers.getItem(i);
//TODO: Exclue Raster and Drawing Layers???
- if(!layer.GetName().startsWith("_") && !layer.GetFeatureSourceId().toUpperCase().startsWith("SESSION"))
- layerNames.add(layer.GetLegendLabel());
+ if(!layer.getName().startsWith("_") && !layer.getFeatureSourceId().toUpperCase().startsWith("SESSION"))
+ layerNames.add(layer.getLegendLabel());
Collections.sort(layerNames);
@@ -86,26 +86,26 @@
return layerNames;
- public ArrayList<Property> GetLayerProperties() throws MgException
+ public ArrayList<Property> getLayerProperties() throws MgException
ArrayList<Property> properties = new ArrayList<Property>();
- MgLayer layer = (MgLayer) map.GetLayers().GetItem(this.args.get("LAYERNAME"));
+ MgLayer layer = (MgLayer) map.getLayers().getItem(this.args.get("LAYERNAME"));
- MgClassDefinition classDef = layer.GetClassDefinition();
+ MgClassDefinition classDef = layer.getClassDefinition();
- for(int i=0; i<classDef.GetProperties().GetCount(); i++)
+ for(int i=0; i<classDef.getProperties().getCount(); i++)
- MgPropertyDefinition propertyDef = classDef.GetProperties().GetItem(i);
+ MgPropertyDefinition propertyDef = classDef.getProperties().getItem(i);
- if(propertyDef.GetPropertyType() == MgFeaturePropertyType.DataProperty)
+ if(propertyDef.getPropertyType() == MgFeaturePropertyType.DataProperty)
MgDataPropertyDefinition propertyDataDef = (MgDataPropertyDefinition) propertyDef;
- int dataType = propertyDataDef.GetDataType();
- if(this.IsValidDataType(dataType))
+ int dataType = propertyDataDef.getDataType();
+ if(this.isValidDataType(dataType))
- properties.add(new Property(propertyDataDef.GetName(), dataType == MgPropertyType.String));
+ properties.add(new Property(propertyDataDef.getName(), dataType == MgPropertyType.String));
@@ -112,54 +112,54 @@
return properties;
- public boolean ToggleSpatialFilter() throws MgException
+ public boolean toggleSpatialFilter() throws MgException
boolean result = true;
- if(layers.Contains("_QuerySpatialFilter"))
+ if(layers.contains("_QuerySpatialFilter"))
- MgLayer layer = (MgLayer) layers.GetItem("_QuerySpatialFilter");
+ MgLayer layer = (MgLayer) layers.getItem("_QuerySpatialFilter");
if(this.args.get("VISIBLE").equals("true"))
- layer.SetVisible(true);
+ layer.setVisible(true);
else
- layer.SetVisible(false);
+ layer.setVisible(false);
- map.Save();
+ map.save();
return result;
- public boolean ShowSpatialFilter() throws MgException, FileNotFoundException, IOException
+ public boolean showSpatialFilter() throws MgException, FileNotFoundException, IOException
MgResourceIdentifier sdfResId = new MgResourceIdentifier("Session:"+this.args.get("SESSION")+"//Filter.FeatureSource");
- MgResourceService resourceService = (MgResourceService)this.site.CreateService(MgServiceType.ResourceService);
- MgFeatureService featureService = (MgFeatureService)this.site.CreateService(MgServiceType.FeatureService);
+ MgResourceService resourceService = (MgResourceService)this.site.createService(MgServiceType.ResourceService);
+ MgFeatureService featureService = (MgFeatureService)this.site.createService(MgServiceType.FeatureService);
MgFeatureCommandCollection updateCommands = new MgFeatureCommandCollection();
MgLayer layer = null;
- layer = (MgLayer) layers.GetItem("_QuerySpatialFilter");
- updateCommands.Add(new MgDeleteFeatures("Filter", "ID like '%'"));
+ layer = (MgLayer) layers.getItem("_QuerySpatialFilter");
+ updateCommands.add(new MgDeleteFeatures("Filter", "ID like '%'"));
else
// Create the Feature Source (SDF)
- MgFeatureSchema sdfSchema = this.CreateFilterSchema();
- MgFileFeatureSourceParams sdfParams = new MgFileFeatureSourceParams("OSGeo.SDF", "MAPCS", map.GetMapSRS(), sdfSchema);
- featureService.CreateFeatureSource(sdfResId, sdfParams);
+ MgFeatureSchema sdfSchema = this.createFilterSchema();
+ MgFileFeatureSourceParams sdfParams = new MgFileFeatureSourceParams("OSGeo.SDF", "MAPCS", map.getMapSRS(), sdfSchema);
+ featureService.createFeatureSource(sdfResId, sdfParams);
// Create the Layer
@@ -175,76 +175,76 @@
strBuffer.append(lineSep);
String layerDefinition = strBuffer.toString();
- layerDefinition = layerDefinition.replaceAll("%s", sdfResId.ToString());
+ layerDefinition = layerDefinition.replaceAll("%s", sdfResId.toString());
MgByteSource byteSource = new MgByteSource(layerDefinition.getBytes(), layerDefinition.length());
- resourceService.SetResource(layerResId, byteSource.GetReader(), null);
+ resourceService.setResource(layerResId, byteSource.getReader(), null);
layer = new MgLayer(layerResId, resourceService);
- layer.SetName("_QuerySpatialFilter");
- layer.SetLegendLabel("_QuerySpatialFilter");
- layer.SetDisplayInLegend(false);
- layer.SetSelectable(false);
+ layer.setName("_QuerySpatialFilter");
+ layer.setLegendLabel("_QuerySpatialFilter");
+ layer.setDisplayInLegend(false);
+ layer.setSelectable(false);
- layers.Insert(0, layer);
+ layers.insert(0, layer);
// Make the layer visible
- map.Save();
+ map.save();
// Add the geometry to the filter feature source
- MgPolygon polygon = this.CreatePolygonFromGeomText(this.args.get("GEOMTEXT"));
+ MgPolygon polygon = this.createPolygonFromGeomText(this.args.get("GEOMTEXT"));
MgAgfReaderWriter agfWriter = new MgAgfReaderWriter();
- MgByteReader byteReader = agfWriter.Write(polygon);
+ MgByteReader byteReader = agfWriter.write(polygon);
MgPropertyCollection propertyValues = new MgPropertyCollection();
- propertyValues.Add(new MgGeometryProperty("Geometry", byteReader));
+ propertyValues.add(new MgGeometryProperty("Geometry", byteReader));
- updateCommands.Add(new MgInsertFeatures("Filter", propertyValues));
+ updateCommands.add(new MgInsertFeatures("Filter", propertyValues));
- featureService.UpdateFeatures(sdfResId, updateCommands, false);
+ featureService.updateFeatures(sdfResId, updateCommands, false);
return result;
- public ArrayList<Feature> Execute() throws MgException
+ public ArrayList<Feature> execute() throws MgException
ArrayList<Feature> result = new ArrayList<Feature>();
- MgResourceIdentifier resId = new MgResourceIdentifier(layer.GetFeatureSourceId());
- String featureGeometry = layer.GetFeatureGeometryName();
+ MgResourceIdentifier resId = new MgResourceIdentifier(layer.getFeatureSourceId());
+ String featureGeometry = layer.getFeatureGeometryName();
// Initialize the coordinate system transform
- MgGeometricPropertyDefinition geomProp = (MgGeometricPropertyDefinition) classDef.GetProperties().GetItem(featureGeometry);
- String spatialContext = geomProp.GetSpatialContextAssociation();
+ MgGeometricPropertyDefinition geomProp = (MgGeometricPropertyDefinition) classDef.getProperties().getItem(featureGeometry);
+ String spatialContext = geomProp.getSpatialContextAssociation();
MgCoordinateSystemTransform csTransform = null;
MgCoordinateSystemTransform csInverseTransform = null;
MgCoordinateSystemFactory coordSysFactory = new MgCoordinateSystemFactory();
- MgSpatialContextReader scReader = featureService.GetSpatialContexts(resId, false);
- while(scReader.ReadNext() && csTransform==null)
+ MgSpatialContextReader scReader = featureService.getSpatialContexts(resId, false);
+ while(scReader.readNext() && csTransform==null)
- if(spatialContext.equals(scReader.GetName()))
+ if(spatialContext.equals(scReader.getName()))
- MgCoordinateSystem source = coordSysFactory.Create(scReader.GetCoordinateSystemWkt());
- MgCoordinateSystem target = coordSysFactory.Create(map.GetMapSRS());
- csTransform = coordSysFactory.GetTransform(source, target);
- csInverseTransform = coordSysFactory.GetTransform(target, source);
+ MgCoordinateSystem source = coordSysFactory.create(scReader.getCoordinateSystemWkt());
+ MgCoordinateSystem target = coordSysFactory.create(map.getMapSRS());
+ csTransform = coordSysFactory.getTransform(source, target);
+ csInverseTransform = coordSysFactory.getTransform(target, source);
- scReader.Close();
+ scReader.close();
// Execute the query
@@ -264,29 +264,29 @@
propertyFilter = propertyFilter + this.numExpressions[operator].replaceAll("%s", this.args.get("VALUE"));
- queryOptions.SetFilter(propertyFilter);
+ queryOptions.setFilter(propertyFilter);
if(this.args.get("USESPATIALFILTER").equals("true"))
- MgGeometry geometry = (MgGeometry) polygon.Transform(csInverseTransform);
- queryOptions.SetSpatialFilter(featureGeometry, geometry, MgFeatureSpatialOperations.Intersects);
+ MgGeometry geometry = (MgGeometry) polygon.transform(csInverseTransform);
+ queryOptions.setSpatialFilter(featureGeometry, geometry, MgFeatureSpatialOperations.Intersects);
int count = 0;
- MgFeatureReader featureReader = layer.SelectFeatures(queryOptions);
+ MgFeatureReader featureReader = layer.selectFeatures(queryOptions);
String displayValue = null;
- while(featureReader.ReadNext() && (queryMax <= 0 || count < queryMax))
+ while(featureReader.readNext() && (queryMax <= 0 || count < queryMax))
- MgByteReader byteReader = featureReader.GetGeometry(featureGeometry);
+ MgByteReader byteReader = featureReader.getGeometry(featureGeometry);
MgPoint centerPoint = null;
try
- MgGeometry geometry = geometryReaderWriter.Read(byteReader);
- centerPoint = geometry.GetCentroid();
- centerPoint = (MgPoint) centerPoint.Transform(csTransform);
+ MgGeometry geometry = geometryReaderWriter.read(byteReader);
+ centerPoint = geometry.getCentroid();
+ centerPoint = (MgPoint) centerPoint.transform(csTransform);
catch (MgException ex) //Maybe because of bad geometry
@@ -293,34 +293,34 @@
centerPoint = null;
- Map idList = new HashMap(this.GetFeatureIdList(featureReader));
+ Map idList = new HashMap(this.getFeatureIdList(featureReader));
- int propertyType = featureReader.GetPropertyType(this.args.get("OUTPUTPROPERTY"));
+ int propertyType = featureReader.getPropertyType(this.args.get("OUTPUTPROPERTY"));
switch(propertyType)
case MgPropertyType.Boolean :
- displayValue = String.valueOf(featureReader.GetBoolean(this.args.get("OUTPUTPROPERTY")));
+ displayValue = String.valueOf(featureReader.getBoolean(this.args.get("OUTPUTPROPERTY")));
break;
case MgPropertyType.Byte :
- displayValue = String.valueOf(featureReader.GetByte(this.args.get("OUTPUTPROPERTY")));
+ displayValue = String.valueOf(featureReader.getByte(this.args.get("OUTPUTPROPERTY")));
break;
case MgPropertyType.Single :
- displayValue = String.valueOf(featureReader.GetSingle(this.args.get("OUTPUTPROPERTY")));
+ displayValue = String.valueOf(featureReader.getSingle(this.args.get("OUTPUTPROPERTY")));
break;
case MgPropertyType.Double :
- displayValue = String.valueOf(featureReader.GetDouble(this.args.get("OUTPUTPROPERTY")));
+ displayValue = String.valueOf(featureReader.getDouble(this.args.get("OUTPUTPROPERTY")));
break;
case MgPropertyType.Int16 :
- displayValue = String.valueOf(featureReader.GetInt16(this.args.get("OUTPUTPROPERTY")));
+ displayValue = String.valueOf(featureReader.getInt16(this.args.get("OUTPUTPROPERTY")));
break;
case MgPropertyType.Int32 :
- displayValue = String.valueOf(featureReader.GetInt32(this.args.get("OUTPUTPROPERTY")));
+ displayValue = String.valueOf(featureReader.getInt32(this.args.get("OUTPUTPROPERTY")));
break;
case MgPropertyType.Int64 :
- displayValue = String.valueOf(featureReader.GetInt64(this.args.get("OUTPUTPROPERTY")));
+ displayValue = String.valueOf(featureReader.getInt64(this.args.get("OUTPUTPROPERTY")));
break;
case MgPropertyType.String :
- displayValue = featureReader.GetString(this.args.get("OUTPUTPROPERTY"));
+ displayValue = featureReader.getString(this.args.get("OUTPUTPROPERTY"));
break;
case MgPropertyType.DateTime :
case MgPropertyType.Null :
@@ -339,15 +339,15 @@
return result;
- public String GetSelectionXML() throws MgException, JSONException
+ public String getSelectionXML() throws MgException, JSONException
- String featureClass = layer.GetFeatureClassName();
+ String featureClass = layer.getFeatureClassName();
MgDataPropertyDefinition dataPropDef = null;
@@ -358,32 +358,32 @@
String key = (String) it.next();
Object value = json.get(key);
- dataPropDef = (MgDataPropertyDefinition) classDef.GetProperties().GetItem(key);
- switch(dataPropDef.GetDataType())
+ dataPropDef = (MgDataPropertyDefinition) classDef.getProperties().getItem(key);
+ switch(dataPropDef.getDataType())
- properties.Add(new MgBooleanProperty(key, Boolean.valueOf(value.toString())));
+ properties.add(new MgBooleanProperty(key, Boolean.valueOf(value.toString())));
break;
- properties.Add(new MgByteProperty(key, Byte.valueOf(value.toString())));
+ properties.add(new MgByteProperty(key, Byte.valueOf(value.toString())));
break;
- properties.Add(new MgSingleProperty(key, Float.valueOf(value.toString())));
+ properties.add(new MgSingleProperty(key, Float.valueOf(value.toString())));
break;
- properties.Add(new MgDoubleProperty(key, Double.valueOf(value.toString())));
+ properties.add(new MgDoubleProperty(key, Double.valueOf(value.toString())));
break;
- properties.Add(new MgInt16Property(key, Short.valueOf(value.toString())));
+ properties.add(new MgInt16Property(key, Short.valueOf(value.toString())));
break;
- properties.Add(new MgInt32Property(key, Integer.valueOf(value.toString())));
+ properties.add(new MgInt32Property(key, Integer.valueOf(value.toString())));
break;
- properties.Add(new MgInt64Property(key, Long.valueOf(value.toString())));
+ properties.add(new MgInt64Property(key, Long.valueOf(value.toString())));
break;
- properties.Add(new MgStringProperty(key, value.toString()));
+ properties.add(new MgStringProperty(key, value.toString()));
break;
@@ -397,49 +397,49 @@
MgSelection selection = new MgSelection(map);
- selection.AddFeatureIds(layer, featureClass, properties);
+ selection.addFeatureIds(layer, featureClass, properties);
- return selection.ToXml();
+ return selection.toXml();
- private Map GetFeatureIdList(MgFeatureReader featureReader) throws MgException
+ private Map getFeatureIdList(MgFeatureReader featureReader) throws MgException
- MgClassDefinition classDef = featureReader.GetClassDefinition();
- MgPropertyDefinitionCollection idProps = classDef.GetIdentityProperties();
+ MgClassDefinition classDef = featureReader.getClassDefinition();
+ MgPropertyDefinitionCollection idProps = classDef.getIdentityProperties();
Map idList = new HashMap();
- for(int i=0; i<idProps.GetCount(); i++)
+ for(int i=0; i<idProps.getCount(); i++)
- MgDataPropertyDefinition idProp = (MgDataPropertyDefinition) idProps.GetItem(i);
+ MgDataPropertyDefinition idProp = (MgDataPropertyDefinition) idProps.getItem(i);
- switch(idProp.GetDataType())
+ switch(idProp.getDataType())
- idList.put(idProp.GetName(), featureReader.GetBoolean(idProp.GetName()));
+ idList.put(idProp.getName(), featureReader.getBoolean(idProp.getName()));
break;
- idList.put(idProp.GetName(), featureReader.GetByte(idProp.GetName()));
+ idList.put(idProp.getName(), featureReader.getByte(idProp.getName()));
break;
- idList.put(idProp.GetName(), featureReader.GetSingle(idProp.GetName()));
+ idList.put(idProp.getName(), featureReader.getSingle(idProp.getName()));
break;
- idList.put(idProp.GetName(), featureReader.GetDouble(idProp.GetName()));
+ idList.put(idProp.getName(), featureReader.getDouble(idProp.getName()));
break;
- idList.put(idProp.GetName(), featureReader.GetInt16(idProp.GetName()));
+ idList.put(idProp.getName(), featureReader.getInt16(idProp.getName()));
break;
- idList.put(idProp.GetName(), featureReader.GetInt32(idProp.GetName()));
+ idList.put(idProp.getName(), featureReader.getInt32(idProp.getName()));
break;
- idList.put(idProp.GetName(), featureReader.GetInt64(idProp.GetName()));
+ idList.put(idProp.getName(), featureReader.getInt64(idProp.getName()));
break;
- idList.put(idProp.GetName(), featureReader.GetString(idProp.GetName()));
+ idList.put(idProp.getName(), featureReader.getString(idProp.getName()));
break;
- idList.put(idProp.GetName(), featureReader.GetDateTime(idProp.GetName()));
+ idList.put(idProp.getName(), featureReader.getDateTime(idProp.getName()));
break;
case MgPropertyType.Blob :
@@ -454,7 +454,7 @@
return idList;
- private boolean IsValidDataType(int type)
+ private boolean isValidDataType(int type)
boolean valid = true;
@@ -473,39 +473,39 @@
return valid;
- private MgFeatureSchema CreateFilterSchema() throws MgException
+ private MgFeatureSchema createFilterSchema() throws MgException
MgFeatureSchema filterSchema = new MgFeatureSchema();
- filterSchema.SetName("FilterSchema");
+ filterSchema.setName("FilterSchema");
MgClassDefinition filterClass = new MgClassDefinition();
- filterClass.SetName("Filter");
- MgPropertyDefinitionCollection properties = filterClass.GetProperties();
+ filterClass.setName("Filter");
+ MgPropertyDefinitionCollection properties = filterClass.getProperties();
MgDataPropertyDefinition idProperty = new MgDataPropertyDefinition("ID");
- idProperty.SetDataType(MgPropertyType.Int32);
- idProperty.SetReadOnly(true);
- idProperty.SetNullable(false);
- idProperty.SetAutoGeneration(true);
- properties.Add(idProperty);
+ idProperty.setDataType(MgPropertyType.Int32);
+ idProperty.setReadOnly(true);
+ idProperty.setNullable(false);
+ idProperty.setAutoGeneration(true);
+ properties.add(idProperty);
MgGeometricPropertyDefinition geometryProperty = new MgGeometricPropertyDefinition("Geometry");
- geometryProperty.SetGeometryTypes(MgFeatureGeometricType.Surface);
- geometryProperty.SetHasElevation(false);
- geometryProperty.SetHasMeasure(false);
- geometryProperty.SetReadOnly(false);
- geometryProperty.SetSpatialContextAssociation("MAPCS");
- properties.Add(geometryProperty);
+ geometryProperty.setGeometryTypes(MgFeatureGeometricType.Surface);
+ geometryProperty.setHasElevation(false);
+ geometryProperty.setHasMeasure(false);
+ geometryProperty.setReadOnly(false);
+ geometryProperty.setSpatialContextAssociation("MAPCS");
+ properties.add(geometryProperty);
- filterClass.GetIdentityProperties().Add(idProperty);
- filterClass.SetDefaultGeometryPropertyName("Geometry");
+ filterClass.getIdentityProperties().add(idProperty);
+ filterClass.setDefaultGeometryPropertyName("Geometry");
- filterSchema.GetClasses().Add(filterClass);
+ filterSchema.getClasses().add(filterClass);
return filterSchema;
- private MgPolygon CreatePolygonFromGeomText(String geomText) throws MgException
+ private MgPolygon createPolygonFromGeomText(String geomText) throws MgException
@@ -515,12 +515,12 @@
MgCoordinateCollection coords = new MgCoordinateCollection();
for(int i=0; i<count; i++)
- MgCoordinate coord = geometryFactory.CreateCoordinateXY(Double.valueOf(vertices[(i*2)+1]), Double.valueOf(vertices[(i*2)+2]));
- coords.Add(coord);
+ MgCoordinate coord = geometryFactory.createCoordinateXY(Double.valueOf(vertices[(i*2)+1]), Double.valueOf(vertices[(i*2)+2]));
+ coords.add(coord);
- MgLinearRing linearRing = geometryFactory.CreateLinearRing(coords);
- MgPolygon polygon = geometryFactory.CreatePolygon(linearRing, null);
+ MgLinearRing linearRing = geometryFactory.createLinearRing(coords);
+ MgPolygon polygon = geometryFactory.createPolygon(linearRing, null);
return polygon;
Modified: trunk/MgDev/Doc/samples/javaviewersample/query/querycontroller.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/query/querycontroller.jsp 2021-06-17 15:59:09 UTC (rev 9855)
+++ trunk/MgDev/Doc/samples/javaviewersample/query/querycontroller.jsp 2021-06-17 16:49:08 UTC (rev 9856)
@@ -51,7 +51,7 @@
case Command.GETLAYERPROPERTIES:
responseType = "text/plain";
- ArrayList<Property> arrayList = query.GetLayerProperties();
+ ArrayList<Property> arrayList = query.getLayerProperties();
for(int i=0;i<arrayList.size();i++)
jsonObj.put("name", arrayList.get(i).name);
@@ -62,15 +62,15 @@
break;
case Command.TOGGLESPATIALFILTER:
- responseString = json.put(query.ToggleSpatialFilter()).toString();
+ responseString = json.put(query.toggleSpatialFilter()).toString();
break;
case Command.SHOWSPATIALFILTER:
- responseString = json.put(query.ShowSpatialFilter()).toString();
+ responseString = json.put(query.showSpatialFilter()).toString();
break;
case Command.EXECUTEQUERY:
- ArrayList<Feature> resultList = query.Execute();
+ ArrayList<Feature> resultList = query.execute();
for(int i=0;i<resultList.size();i++)
jsonObj.put("displayValue", resultList.get(i).displayValue);
@@ -83,7 +83,7 @@
break;
case Command.GETSELECTIONXML:
responseType = "text/xml";
- responseString = query.GetSelectionXML();
+ responseString = query.getSelectionXML();
break;
Modified: trunk/MgDev/Doc/samples/javaviewersample/query/querymain.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/query/querymain.jsp 2021-06-17 15:59:09 UTC (rev 9855)
+++ trunk/MgDev/Doc/samples/javaviewersample/query/querymain.jsp 2021-06-17 16:49:08 UTC (rev 9856)
@@ -46,12 +46,12 @@
query = new Query(args);
- layerNames = query.GetMapLayerNames();
+ layerNames = query.getMapLayerNames();
- errorMsg = e.GetExceptionMessage();
- errorDetail = e.GetDetails();
+ errorMsg = e.getExceptionMessage();
+ errorDetail = e.getDetails();
<html>
@@ -202,10 +202,7 @@
else
reqHandler = new XMLHttpRequest();
- if (msie)
- reqHandler.open("POST", "querycontroller.jsp", false);
- else
- reqHandler.open("POST", "../javaviewersample/query/querycontroller.jsp", false);
+ reqHandler.open("POST", "querycontroller.jsp", false);
reqHandler.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
reqHandler.send(reqParams);
Modified: trunk/MgDev/Doc/samples/javaviewersample/theme/themecontroller.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/theme/themecontroller.jsp 2021-06-17 15:59:09 UTC (rev 9855)
+++ trunk/MgDev/Doc/samples/javaviewersample/theme/themecontroller.jsp 2021-06-17 16:49:08 UTC (rev 9856)
@@ -55,7 +55,7 @@
case Command.GETLAYERINFO:
- LayerInfo layerInfo = theme.GetLayerInfo();
+ LayerInfo layerInfo = theme.getLayerInfo();
ArrayList<Property> propArrayList = layerInfo.properties;
for(int i=0; i<propArrayList.size(); i++)
@@ -83,7 +83,7 @@
break;
case Command.GETPROPERTYMINMAXCOUNT:
- ArrayList<String> arrayList = theme.GetPropertyMinMaxCount();
+ ArrayList<String> arrayList = theme.getPropertyMinMaxCount();
jsonArr.put(arrayList.get(i));
@@ -92,7 +92,7 @@
break;
case Command.APPLYTHEME:
- responseString = theme.ApplyTheme();
+ responseString = theme.applyTheme();
break;
Modified: trunk/MgDev/Doc/samples/javaviewersample/utilityfunctions.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/utilityfunctions.jsp 2021-06-17 15:59:09 UTC (rev 9855)
+++ trunk/MgDev/Doc/samples/javaviewersample/utilityfunctions.jsp 2021-06-17 16:49:08 UTC (rev 9856)
@@ -34,7 +34,7 @@
String realpath = getServletContext().getRealPath("/");
// Initialize web tier with the site configuration file. The config
// file should be in the same folder as this script.
- String xmlTemplatePath = realpath + "javaviewersample\\query\\templates\\filterlayerdefinition.xml";
+ String xmlTemplatePath = realpath + "javaviewersample/query/templates/filterlayerdefinition.xml";
return xmlTemplatePath;
@@ -43,7 +43,7 @@
- String xmlTemplatePath = realpath + "javaviewersample\\theme\\templates\\arearuletemplate.xml";
+ String xmlTemplatePath = realpath + "javaviewersample/theme/templates/arearuletemplate.xml";
More information about the mapguide-commits
