[mapguide-commits] r9858 - trunk/MgDev/Web/src/mapviewerjava
svn_mapguide at osgeo.org
Fri Jun 18 03:40:26 PDT 2021
Author: jng
Date: 2021-06-18 03:40:26 -0700 (Fri, 18 Jun 2021)
New Revision: 9858
trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp
#2839: Fix bad string check that caused tiled maps to not load in java AJAX viewer
Modified: trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp 2021-06-18 10:39:36 UTC (rev 9857)
+++ trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp 2021-06-18 10:40:26 UTC (rev 9858)
@@ -76,9 +76,10 @@
if (null != tileSetId)
//Can't load map if it points to a non-default tile set provider
- if (map.getTileSetProvider() != "Default")
+ String tsProvider = map.getTileSetProvider();
+ if (!tsProvider.equals("Default"))
- throw new RuntimeException(MessageFormat.format(MgLocalizer.GetString("ERR_UNSUPPORTED_TILESET", locale), new Object[] { map.getTileSetProvider() }));
+ throw new RuntimeException(MessageFormat.format(MgLocalizer.GetString("ERR_UNSUPPORTED_TILESET", locale), new Object[] { tsProvider }));
//Overwrite the map definition with tile set id (this is for GETTILE requests) and
//use size settings from that tile set
More information about the mapguide-commits
