[mapguide-commits] r9868 - in sandbox/adsk/trunk: Common/PlatformBase Common/PlatformBase/MapLayer Web/src/DotNetUnmanagedApi/PlatformBase
svn_mapguide at osgeo.org
Tue Sep 14 20:04:15 PDT 2021
Author: christinebao
Date: 2021-09-14 20:04:13 -0700 (Tue, 14 Sep 2021)
New Revision: 9868
Added:
sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroupOrder.h
sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerBase.h
sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroup.h
sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.h
sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.vcxproj
sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.vcxproj.filters
sandbox/adsk/trunk/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
Add Order support for layer and group
1. Add base class - MgLayerGroupOrder
2. Change MgLayerBase and MgLayerGroup base class to MgLayerGroupOrder
Modified: sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerBase.h
--- sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerBase.h 2021-09-07 02:05:35 UTC (rev 9867)
+++ sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerBase.h 2021-09-15 03:04:13 UTC (rev 9868)
@@ -1,19 +1,14 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
+// (C) Copyright 2021 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
+// The information contained herein is confidential, proprietary
+// to Autodesk, Inc., and considered a trade secret as defined
+// in section 499C of the penal code of the State of California.
+// Use of this information by anyone other than authorized
+// employees of Autodesk, Inc. is granted only under a written
+// non-disclosure agreement, expressly prescribing the scope
+// and manner of such use.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#ifndef _MG_LAYER_BASE_H_
#define _MG_LAYER_BASE_H_
@@ -46,7 +41,7 @@
/// \brief
/// Gets and sets properties of a layer.
/// \todo
-class MG_PLATFORMBASE_API MgLayerBase : public MgNamedSerializable
+class MG_PLATFORMBASE_API MgLayerBase : public MgLayerGroupOrder
MG_DECL_DYNCREATE()
DECLARE_CLASSNAME(MgLayerBase)
Modified: sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroup.h
--- sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroup.h 2021-09-07 02:05:35 UTC (rev 9867)
+++ sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroup.h 2021-09-15 03:04:13 UTC (rev 9868)
@@ -1,19 +1,14 @@
#ifndef _MG_LAYER_GROUP_H_
#define _MG_LAYER_GROUP_H_
@@ -36,7 +31,7 @@
/// \todo
/// * [[Job for Philip: Clarify what a layer group is.]]
/// * [[Job for Phliip: Add an example.]]
-class MG_PLATFORMBASE_API MgLayerGroup : public MgNamedSerializable
+class MG_PLATFORMBASE_API MgLayerGroup : public MgLayerGroupOrder
MG_DECL_DYNCREATE()
DECLARE_CLASSNAME(MgLayerGroup)
Added: sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroupOrder.h
--- sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroupOrder.h (rev 0)
+++ sandbox/adsk/trunk/Common/PlatformBase/MapLayer/LayerGroupOrder.h 2021-09-15 03:04:13 UTC (rev 9868)
@@ -0,0 +1,96 @@
+#pragma once
+/// \cond INTERNAL
+/// Get and Set Layer and Group Order in current group in Display Manager.
+class MG_PLATFORMBASE_API MgLayerGroupOrder : public MgNamedSerializable
+ MG_DECL_DYNCREATE()
+ DECLARE_CLASSNAME(MgLayerGroupOrder)
+EXTERNAL_API:
+ MgLayerGroupOrder() {}
+ virtual ~MgLayerGroupOrder() {}
+PUBLISHED_API:
+ /// Set the order
+ void SetDMOrder(INT32 order)
+ m_orderInGroup = order;
+ /// Get the order
+ INT32 GetDMOrder()
+ return m_orderInGroup;
+INTERNAL_API:
+ /// \brief
+ /// Get the name of the object.
+ /// \return
+ /// Returns the name of object
+ virtual STRING GetName() { return L""; }
+ /// \brief
+ /// Does it allow to set the name
+ /// \return
+ /// true - allows to set the name
+ /// false - can not set the name
+ virtual bool CanSetName() { return false; }
+ /// \brief
+ /// Serialize data to a stream
+ /// \param stream
+ /// Stream
+ virtual void Serialize(MgStream* stream) {}
+ /// \brief
+ /// Deserialize data from a stream
+ /// \param stream
+ /// Stream
+ virtual void Deserialize(MgStream* stream) {}
+ /// \brief
+ /// Dispose this object.
+ /// \return
+ /// Returns nothing
+ virtual void Dispose() {}
+private:
+ INT32 m_orderInGroup{ -1 }; // Order in Group in Display Manager
+/// \endcond
Modified: sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.h
--- sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.h 2021-09-07 02:05:35 UTC (rev 9867)
+++ sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.h 2021-09-15 03:04:13 UTC (rev 9868)
@@ -1,19 +1,14 @@
#ifndef MGPLATFORMBASE_H_
#define MGPLATFORMBASE_H_
@@ -155,6 +150,7 @@
#include "MapLayer/LayerType.h"
#include "MapLayer/LayerGroupType.h"
+#include "MapLayer/LayerGroupOrder.h"
#include "MapLayer/LayerBase.h"
#include "MapLayer/LayerCollection.h"
#include "MapLayer/LayerGroup.h"
Modified: sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.vcxproj
--- sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.vcxproj 2021-09-07 02:05:35 UTC (rev 9867)
+++ sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.vcxproj 2021-09-15 03:04:13 UTC (rev 9868)
@@ -1,4 +1,4 @@
-<?xml version="1.0" encoding="utf-8"?>
+<?xml version="1.0" encoding="utf-8"?>
<Project DefaultTargets="Build" ToolsVersion="14.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
<ItemGroup Label="ProjectConfigurations">
<ProjectConfiguration Include="Debug|Win32">
@@ -897,6 +897,7 @@
<ClInclude Include="Exception\ServiceNotAvailableException.h" />
<ClInclude Include="Exception\ServiceNotSupportedException.h" />
<ClInclude Include="Exception\UserNotFoundException.h" />
+ <ClInclude Include="MapLayer\LayerGroupOrder.h" />
<ClInclude Include="Services\BaseService.h" />
<ClInclude Include="Services\BaseServiceDefs.h" />
<ClInclude Include="Services\ClassDefinition.h" />
Modified: sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.vcxproj.filters
--- sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.vcxproj.filters 2021-09-07 02:05:35 UTC (rev 9867)
+++ sandbox/adsk/trunk/Common/PlatformBase/PlatformBase.vcxproj.filters 2021-09-15 03:04:13 UTC (rev 9868)
@@ -1,4 +1,4 @@
<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
<ItemGroup>
<Filter Include="Data">
@@ -736,6 +736,9 @@
<ClInclude Include="Services\GeoJsonWriter.h">
<Filter>Services</Filter>
</ClInclude>
+ <ClInclude Include="MapLayer\LayerGroupOrder.h">
+ <Filter>MapLayer</Filter>
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="PlatformBase.rc" />
Modified: sandbox/adsk/trunk/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
--- sandbox/adsk/trunk/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml 2021-09-07 02:05:35 UTC (rev 9867)
+++ sandbox/adsk/trunk/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml 2021-09-15 03:04:13 UTC (rev 9868)
@@ -168,6 +168,7 @@
<Header path="../../../../Common/PlatformBase/Services/UpdateFeatures.h" />
<Header path="../../../../Common/PlatformBase/Services/Warnings.h" />
+ <Header path="../../../../Common/PlatformBase/MapLayer/LayerGroupOrder.h" />
<Header path="../../../../Common/PlatformBase/MapLayer/LayerBase.h" />
<Header path="../../../../Common/PlatformBase/MapLayer/LayerCollection.h" />
<Header path="../../../../Common/PlatformBase/MapLayer/LayerGroup.h" />
More information about the mapguide-commits
