[mapguide-commits] r9953 - in sandbox/jng/vanilla_swig: . Bindings Bindings/src/Bindings Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/custom
svn_mapguide at osgeo.org
Tue Aug 9 09:39:12 PDT 2022
Author: jng
Date: 2022-08-09 09:39:11 -0700 (Tue, 09 Aug 2022)
New Revision: 9953
Added:
sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/custom/
sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/custom/Localizer.cs
sandbox/jng/vanilla_swig/clean.bat
Removed:
sandbox/jng/vanilla_swig/Bindings/src/Bindings/mapadmin/
sandbox/jng/vanilla_swig/Bindings/src/Bindings/mapviewerphp/
sandbox/jng/vanilla_swig/Bindings/TODO.txt
sandbox/jng/vanilla_swig/Bindings/src/Bindings/Bindings.sln
sandbox/jng/vanilla_swig/build.bat
- Remove monolithic .net binding projects from Bindings.sln. Files to be physically removed at a later time.
- Remove stub mapadmin/mapviewerphp directories as we no longer generate constants.php that would go into these directories.
- Add missing .net implementation of MgLocalizer to our MapGuideCommon .net project
- Copy generated nuget packages to $INSTALL\Web\nuget so a MG installation will always carry these files
- Add helper clean.bat to delete what needs deleting to ensure the next build actually (re-)builds
- Update TODO.txt
Modified: sandbox/jng/vanilla_swig/Bindings/TODO.txt
--- sandbox/jng/vanilla_swig/Bindings/TODO.txt 2022-08-09 14:19:25 UTC (rev 9952)
+++ sandbox/jng/vanilla_swig/Bindings/TODO.txt 2022-08-09 16:39:11 UTC (rev 9953)
@@ -60,12 +60,13 @@
- [x] Make sure we can throw MgException
- [ ] Clean MgException stack trace formatting to match its PHP exception counterpart
- [x] Make sure that caught MgException instances are properly released
- - [ ] Get our binding building against the NTS (non-thread-safe) profile so it can be used in both IIS and Apache (via mod_fcgid)
- - [ ] Review the usage of our monkey-patched PHP traits and see whether they're still necessary
- - [ ] Especially the custom dtor for MgException-derived classes since there is now only one MgException class with no subclasses
+ - [x] Get our binding building against the NTS (non-thread-safe) profile so it can be used in both IIS and Apache (via mod_fcgid)
+ - [x] Review the usage of our monkey-patched PHP traits and see whether they're still necessary
+ - [x] Especially the custom dtor for MgException-derived classes since there is now only one MgException class with no subclasses
- [~] SKIP: Put all the generated code under a OSGeo\MapGuide namespace
- [ ] Get it building (Linux)
- - [ ] Verify test suite still passes (Windows)
+ - [~] Verify test suite still passes (Windows)
+ - There is 1 failing test that sounds inconsequential, but should still be fixed
- [ ] Verify test suite still passes (Linux)
- It should be possible to now get rid of constants.php and define our various constants in the PHP extension itself!
- [x] Pivot IMake to instead generate a SWIG interface file of constant class defns to be included in the main SWIG interface file
@@ -81,15 +82,23 @@
- Suspect that the 3rd param (MgCoordinateXY) is not passing as its parent (MgCoordinate)
- Need to setup the same parameter tests in a debuggable PHP script to find out
- - [ ] schemareport
+ - [x] schemareport
- [x] mapadmin
- [x] fusion
- [ ] mapviewernet
+ - It looks like mapviewernet *can* work with the netstandard2.0 package, but there is some setup work required first
+ - [ ] Create a new stub net48 project that consumes the created nuget packages
+ - [ ] Perform a framework-dependent publish of this project as part of build (do this after the .net bindings are built)
+ - [ ] Tools like buffer are throwing "potentially dangerous Request.Form" errors. Need to find the right setting to apply to revert to legacy behavior.
+ - Copy the publish output into the mapviewernet/bin directory on install layout preparation. We expect this to have
+ - The OSGeo.* assemblies
+ - The supporting native dlls
+ - netstandard.dll
- If raw .aspx files cannot consume our netstandard2.0 package, retian Oem/SwigEx for the purpose of building "legacy" .net bindings
- ( ) If this is indeed the case, replace the NMake-based .net projects (that call csc.exe) with SDK-style csproj files that target net48
- - [ ] MapGuide Developer's Guide
+ - [x] MapGuide Developer's Guide
- [x] viewer samples (PHP)
- - [ ] viewer samples (Java)
+ - [x] viewer samples (Java)
- [ ] viewer samples (.net)
- Give the .net viewer samples the same migration plan as mapviewernet
- Revise API documentation strategy
Modified: sandbox/jng/vanilla_swig/Bindings/src/Bindings/Bindings.sln
--- sandbox/jng/vanilla_swig/Bindings/src/Bindings/Bindings.sln 2022-08-09 14:19:25 UTC (rev 9952)
+++ sandbox/jng/vanilla_swig/Bindings/src/Bindings/Bindings.sln 2022-08-09 16:39:11 UTC (rev 9953)
@@ -3,18 +3,6 @@
# Visual Studio Version 17
VisualStudioVersion = 17.0.31912.275
MinimumVisualStudioVersion = 10.0.40219.1
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DotNetUnmanagedApi", "DotNet\DotNetUnmanagedApi.vcxproj", "{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}"
- ProjectSection(ProjectDependencies) = postProject
- {795B1B0E-4EC8-469D-B641-E26324266FBF} = {795B1B0E-4EC8-469D-B641-E26324266FBF}
- {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44} = {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}
- {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4} = {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}
- {B601F04C-0D42-4AFC-A092-B31185E2EA8C} = {B601F04C-0D42-4AFC-A092-B31185E2EA8C}
- {B797917B-6842-467C-8B14-E00B76A91247} = {B797917B-6842-467C-8B14-E00B76A91247}
- {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425} = {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}
- {5287A594-4D4F-43FE-A281-E279AB708CF1} = {5287A594-4D4F-43FE-A281-E279AB708CF1}
- {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0} = {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}
- EndProjectSection
-EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IMake", "..\IMake\IMake.vcxproj", "{B601F04C-0D42-4AFC-A092-B31185E2EA8C}"
EndProject
Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = "Solution Items", "Solution Items", "{8B6FBCB3-F11C-4AB9-AEE5-6A272E31EA7F}"
@@ -32,13 +20,6 @@
EndProjectSection
EndProject
-Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "MapGuideDotNetApi", "..\Managed\DotNet\MapGuideDotNetApi\MapGuideDotNetApi.csproj", "{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}"
- {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E} = {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}
- EndProjectSection
-EndProject
-Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = "monolith", "monolith", "{59509894-F4A9-4C44-8B39-8B5115384DD0}"
-EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FoundationApi", "DotNet\Foundation\FoundationApi.vcxproj", "{73C62FF2-C188-4A61-929E-2F112D7E17AA}"
@@ -100,7 +81,6 @@
{B994F673-EB8E-4C65-8884-B56AB8783115} = {B994F673-EB8E-4C65-8884-B56AB8783115}
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4} = {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}
{73C62FF2-C188-4A61-929E-2F112D7E17AA} = {73C62FF2-C188-4A61-929E-2F112D7E17AA}
{42FC41FD-742B-4AED-816E-C211F1B07F3F} = {42FC41FD-742B-4AED-816E-C211F1B07F3F}
EndProjectSection
@@ -160,12 +140,6 @@
Release|x86 = Release|x86
EndGlobalSection
GlobalSection(ProjectConfigurationPlatforms) = postSolution
- {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|x64.ActiveCfg = Debug|x64
- {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|x64.Build.0 = Debug|x64
- {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|x86.ActiveCfg = Debug|x64
- {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|x64.ActiveCfg = Release|x64
- {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|x64.Build.0 = Release|x64
- {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|x86.ActiveCfg = Release|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|x64.ActiveCfg = Debug|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|x86.ActiveCfg = Debug|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x64.ActiveCfg = Release|x64
@@ -178,14 +152,6 @@
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x64.ActiveCfg = Release|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x64.Build.0 = Release|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x86.ActiveCfg = Release|x64
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x64.ActiveCfg = Debug|Any CPU
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x64.Build.0 = Debug|Any CPU
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x86.ActiveCfg = Debug|Any CPU
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x86.Build.0 = Debug|Any CPU
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x64.ActiveCfg = Release|Any CPU
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x64.Build.0 = Release|Any CPU
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x86.ActiveCfg = Release|Any CPU
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x86.Build.0 = Release|Any CPU
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|x64.ActiveCfg = Debug|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|x64.Build.0 = Debug|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|x86.ActiveCfg = Debug|x64
@@ -389,11 +355,8 @@
HideSolutionNode = FALSE
EndGlobalSection
GlobalSection(NestedProjects) = preSolution
- {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E} = {59509894-F4A9-4C44-8B39-8B5115384DD0}
{B601F04C-0D42-4AFC-A092-B31185E2EA8C} = {99132700-5CAD-4540-9939-7502C1A448EA}
{C02F44CB-D916-428D-A1A5-04E225A2A4EC} = {664329B8-67BD-4D38-AE4B-A2920B038C09}
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4} = {59509894-F4A9-4C44-8B39-8B5115384DD0}
- {59509894-F4A9-4C44-8B39-8B5115384DD0} = {A9257857-9844-4CEA-AF02-A7D8AB8F46AB}
{73C62FF2-C188-4A61-929E-2F112D7E17AA} = {025034E6-A625-427B-AA99-5158095ED5F9}
{120AC2A9-5EBE-4512-9FF7-54EA04192196} = {025034E6-A625-427B-AA99-5158095ED5F9}
{B994F673-EB8E-4C65-8884-B56AB8783115} = {025034E6-A625-427B-AA99-5158095ED5F9}
Added: sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/custom/Localizer.cs
--- sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/custom/Localizer.cs (rev 0)
+++ sandbox/jng/vanilla_swig/Bindings/src/Managed/DotNet/OSGeo.MapGuide.MapGuideCommon/custom/Localizer.cs 2022-08-09 16:39:11 UTC (rev 9953)
@@ -0,0 +1,158 @@
+ Copyright (C) 2004-2011 by Autodesk, Inc.
+ This library is free software; you can redistribute it and/or
+ modify it under the terms of version 2.1 of the GNU Lesser
+ General Public License as published by the Free Software Foundation.
+ This library is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+ Lesser General Public License for more details.
+ You should have received a copy of the GNU Lesser General Public
+ License along with this library; if not, write to the Free Software
+ Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+using System;
+using System.Text;
+using System.Collections;
+using System.IO;
+namespace OSGeo.MapGuide
+public class MgLocalizer
+ protected static String english = "en";
+ protected static String localizationPath = "";
+ protected static Hashtable languages = new Hashtable();
+ public static void SetLocalizedFilesPath(String path)
+ localizationPath = path;
+ public static String Localize(String text, String locale, int os)
+ String fontSuffix = (os == 0 ? "Windows" : (os == 1 ? "Macintosh" : "Linux"));
+ Hashtable sb = null;
+ try
+ sb = GetStringBundle(locale);
+ catch (Exception)
+ return "";
+ int len = text.Length;
+ for (int i = 0; i < len; )
+ int pos1 = text.IndexOf("__#", i);
+ if (pos1 != -1)
+ int pos2 = text.IndexOf("#__", pos1 + 3);
+ if (pos2 != -1)
+ String id = text.Substring(pos1 + 3, pos2 - pos1 - 3);
+ String locStr;
+ locStr = (String)sb[id == "@font" || id == "@fontsize" ? id + fontSuffix : id];
+ if (locStr == null)
+ locStr = "";
+ int locLen = locStr.Length;
+ String begin, end;
+ if (pos1 > 0)
+ begin = text.Substring(0, pos1);
+ else
+ begin = "";
+ end = text.Substring(pos2 + 3);
+ text = begin + locStr + end;
+ len = len - 6 - id.Length + locLen;
+ i = pos1 + locLen;
+ else
+ i = len;
+ else
+ i = len;
+ return text;
+ public static String GetString(String id, String locale)
+ try
+ catch (Exception)
+ return "";
+ String s = (String)sb[id];
+ if (s == null)
+ return "";
+ return s;
+ protected static Hashtable GetStringBundle(String locale)
+ if (locale.Equals(""))
+ locale = english;
+ else
+ locale = locale.ToLower();
+ if (!languages.ContainsKey(locale))
+ StreamReader sr = null;
+ String fname = localizationPath + locale;
+ try
+ if (!File.Exists(fname))
+ // requested locale is not supported, default to English
+ if (languages.ContainsKey(english))
+ return (Hashtable)languages[english];
+ fname = localizationPath + english;
+ sr = new StreamReader(fname, Encoding.UTF8);
+ string line;
+ Hashtable sb = new Hashtable();
+ while ((line = sr.ReadLine()) != null)
+ line = line.Trim();
+ if (line.Equals("") || line[0] == '#')
+ continue;
+ int sep = line.IndexOf('=');
+ if (sep == -1)
+ continue;
+ String key = line.Substring(0, sep).Trim();
+ if (key.Equals(""))
+ continue;
+ sb[key] = line.Substring(sep + 1).Trim();
+ languages[locale] = sb;
+ catch (Exception)
+ return null;
+ finally
+ if (sr != null)
+ try { sr.Close(); }
+ catch (Exception) { }
+ return (Hashtable)languages[locale];
Modified: sandbox/jng/vanilla_swig/build.bat
--- sandbox/jng/vanilla_swig/build.bat 2022-08-09 14:19:25 UTC (rev 9952)
+++ sandbox/jng/vanilla_swig/build.bat 2022-08-09 16:39:11 UTC (rev 9953)
@@ -369,6 +369,8 @@
%XCOPY_SINGLE% "%CD%\packages\Java\%CONFIGURATION%\x64\*.dll" "%MG_OUTPUT_WEB%\Tomcat\bin"
echo [install]: Web Tier - .net Bindings
%XCOPY% "%CD%\packages\DotNet\%CONFIGURATION%\netstandard2.0" "%MG_OUTPUT_WEB%\www\mapviewernet\bin"
+if not exist "%MG_OUTPUT_WEB%\nuget" mkdir "%MG_OUTPUT_WEB%\nuget"
+copy /Y "%CD%\packages\DotNet\%CONFIGURATION%\*.nupkg" "%MG_OUTPUT_WEB%\nuget"
REM Required for Web Tier unit tests
echo [build]: Web Tier - Clean fusion
call %ANT% clean -f "%MG_OEM%\fusion\build.xml"
Added: sandbox/jng/vanilla_swig/clean.bat
--- sandbox/jng/vanilla_swig/clean.bat (rev 0)
+++ sandbox/jng/vanilla_swig/clean.bat 2022-08-09 16:39:11 UTC (rev 9953)
@@ -0,0 +1,32 @@
+ at echo off
+echo [clean]: Oem
+if exist Oem\ACE\ACE_wrappers\lib64 rd /S /Q Oem\ACE\ACE_wrappers\lib64
+if exist Oem\ACE\ACE_wrappers\obj64 rd /S /Q Oem\ACE\ACE_wrappers\obj64
+if exist Oem\CppUnit-1.9.14\lib64 rd /S /Q Oem\CppUnit-1.9.14\lib64
+if exist Oem\CppUnit-1.9.14\src\cppunit\Release64 rd /S /Q Oem\CppUnit-1.9.14\src\cppunit\Release64
+if exist Oem\CppUnit-1.9.14\src\obj64 rd /S /Q Oem\CppUnit-1.9.14\src\obj64
+if exist Oem\CsMap\CsMapDev\bin160 rd /S /Q Oem\CsMap\CsMapDev\bin160
+if exist Oem\CsMap\CsMapDev\lib160 rd /S /Q Oem\CsMap\CsMapDev\lib160
+if exist Oem\CsMap\CsMapDev\obj160 rd /S /Q Oem\CsMap\CsMapDev\obj160
+echo [clean]: Packages
+if exist packages\DotNet rd /S /Q packages\DotNet
+if exist packages\Java rd /S /Q packages\Java
+if exist packages\Php rd /S /Q packages\Php
+echo [clean]: Common
+if exist Common\bin rd /S /Q Common\bin
+if exist Common\lib rd /S /Q Common\lib
+if exist Common\obj rd /S /Q Common\obj
+echo [clean]: Server
+if exist Server\bin rd /S /Q Server\bin
+if exist Server\lib rd /S /Q Server\lib
+if exist Server\obj rd /S /Q Server\obj
+echo [clean]: Web
+if exist Web\bin rd /S /Q Web\bin
+if exist Web\lib rd /S /Q Web\lib
+if exist Web\obj rd /S /Q Web\obj
+echo [clean]: Portable
+if exist Portable\bin rd /S /Q Portable\bin
+if exist Portable\lib rd /S /Q Portable\lib
+if exist Portable\obj rd /S /Q Portable\obj
+echo [clean]: Doc
+if exist Doc\MgOpensource_WebAPIReference rd /S /Q Doc\MgOpensource_WebAPIReference
\ No newline at end of file
More information about the mapguide-commits
