[mapguide-commits] r9946 - in sandbox/jng/vanilla_swig: Bindings/src/SwigCommon/Php Doc/samples/phpsamples/common Doc/samples/phpsamples/custom_output Doc/samples/phpsamples/interacting_with_layers Doc/samples/phpviewersample Doc/samples/phpviewersample/plot
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Jun 6 05:09:55 PDT 2022
Author: jng
Date: 2022-06-06 05:09:54 -0700 (Mon, 06 Jun 2022)
New Revision: 9946
   sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/monkey_patch.i
   sandbox/jng/vanilla_swig/Doc/samples/phpsamples/common/common.php
   sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/createmapimage.php
   sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/eplot.php
   sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/multiplot.php
   sandbox/jng/vanilla_swig/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php
   sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/JSON.php
   sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/plot/plot.php
   sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/utilityfunctions.php
Fix PHP sample code
Modified: sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/monkey_patch.i
--- sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/monkey_patch.i	2022-06-06 11:36:25 UTC (rev 9945)
+++ sandbox/jng/vanilla_swig/Bindings/src/SwigCommon/Php/monkey_patch.i	2022-06-06 12:09:54 UTC (rev 9946)
@@ -32,7 +32,7 @@
 %rename(CreateStateless) MgMap::Create(MgResourceIdentifier*, STRINGPARAM, INT32, INT32, double, double, double, INT32);
 %ignore MgResource;
-%ignore MgMapBase::Open(MgResourceService*, CREFSTRING);
+%ignore MgMapBase::Open(MgResourceService*, STRINGPARAM);
 %ignore MgConfigurationLoadFailedException::GetExceptionMessage;
Modified: sandbox/jng/vanilla_swig/Doc/samples/phpsamples/common/common.php
--- sandbox/jng/vanilla_swig/Doc/samples/phpsamples/common/common.php	2022-06-06 11:36:25 UTC (rev 9945)
+++ sandbox/jng/vanilla_swig/Doc/samples/phpsamples/common/common.php	2022-06-06 12:09:54 UTC (rev 9946)
@@ -20,7 +20,5 @@
 $viewerFilesDirectory = $webRootDirectory . '/viewerfiles';
 $schemaDirectory = dirname(__FILE__);
 $webconfigFilePath = $webRootDirectory . '/webconfig.ini';
-// Include constants like MgServiceType::ResourceService
-require_once($webRootDirectory . '/mapadmin/constants.php');
\ No newline at end of file
Modified: sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/createmapimage.php
--- sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/createmapimage.php	2022-06-06 11:36:25 UTC (rev 9945)
+++ sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/createmapimage.php	2022-06-06 12:09:54 UTC (rev 9946)
@@ -23,11 +23,11 @@
 $sessionId = $args['SESSION'];
 $xmlSelection = $args['SELECTION'];
 $mapName = $args['MAPNAME'];
-$mapScale = $args['SCALE'];
-$imageHeight = $args['HEIGHT'];
-$imageWidth = $args['WIDTH'];
-$mapCenterX = $args['CENTERX'];
-$mapCenterY = $args['CENTERY'];
+$mapScale = doubleval($args['SCALE']);
+$imageHeight = intval($args['HEIGHT']);
+$imageWidth = intval($args['WIDTH']);
+$mapCenterX = doubleval($args['CENTERX']);
+$mapCenterY = doubleval($args['CENTERY']);
 try
Modified: sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/eplot.php
--- sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/eplot.php	2022-06-06 11:36:25 UTC (rev 9945)
+++ sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/eplot.php	2022-06-06 12:09:54 UTC (rev 9946)
@@ -41,8 +41,7 @@
   $dwfVersion = new MgDwfVersion("6.01", "1.2");
-  $plotSpec = new MgPlotSpecification(8.5, 11, MgPageUnitsType::Inches);
-  $plotSpec->SetMargins(0.5, 0.5, 0.5, 0.5);
+  $plotSpec = new MgPlotSpecification(8.5, 11, MgPageUnitsType::Inches, 0.5, 0.5, 0.5, 0.5);
   $layoutRes = new MgResourceIdentifier("Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout");
   $layout =  new MgLayout($layoutRes, "City of Sheboygan", MgPageUnitsType::Inches);
Modified: sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/multiplot.php
--- sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/multiplot.php	2022-06-06 11:36:25 UTC (rev 9945)
+++ sandbox/jng/vanilla_swig/Doc/samples/phpsamples/custom_output/multiplot.php	2022-06-06 12:09:54 UTC (rev 9946)
@@ -41,8 +41,7 @@
   $layout = null;
Modified: sandbox/jng/vanilla_swig/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php
--- sandbox/jng/vanilla_swig/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php	2022-06-06 11:36:25 UTC (rev 9945)
+++ sandbox/jng/vanilla_swig/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php	2022-06-06 12:09:54 UTC (rev 9946)
@@ -79,18 +79,15 @@
       '&MAPNAME=' . $mgMapName . '">Run again</a></p>';
-    catch (MgLayerNotFoundException $e)
-      echo '<p>Layer not found</p>';
-    catch (MgObjectNotFoundException $e)
     catch (MgException $e)
-      echo $e->GetExceptionMessage();
-      echo $e->GetDetails();
+      if ($e->GetExceptionCode() == MgExceptionCodes::MgLayerNotFoundException ||
+          $e->GetExceptionCode() == MgExceptionCodes::MgObjectNotFoundException) {
+        echo '<p>Layer not found</p>';
+      } else {
+        echo $e->GetExceptionMessage();
+        echo $e->GetDetails();
Modified: sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/JSON.php
--- sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/JSON.php	2022-06-06 11:36:25 UTC (rev 9945)
+++ sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/JSON.php	2022-06-06 12:09:54 UTC (rev 9946)
@@ -114,6 +114,8 @@
 class Services_JSON
+    private int $use;
     * constructs a new JSON instance
@@ -130,7 +132,7 @@
     *                                   bubble up with an error, so all return values
     *                                   from encode() should be checked with isError()
-    function Services_JSON($use = 0)
+    function __construct($use = 0)
         $this->use = $use;
@@ -153,7 +155,7 @@
             return mb_convert_encoding($utf16, 'UTF-8', 'UTF-16');
-        $bytes = (ord($utf16{0}) << 8) | ord($utf16{1});
+        $bytes = (ord($utf16[0]) << 8) | ord($utf16[1]);
         switch(true) {
             case ((0x7F & $bytes) == $bytes):
@@ -206,17 +208,17 @@
             case 2:
                 // return a UTF-16 character from a 2-byte UTF-8 char
                 // see: http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
-                return chr(0x07 & (ord($utf8{0}) >> 2))
-                     . chr((0xC0 & (ord($utf8{0}) << 6))
-                         | (0x3F & ord($utf8{1})));
+                return chr(0x07 & (ord($utf8[0]) >> 2))
+                     . chr((0xC0 & (ord($utf8[0]) << 6))
+                         | (0x3F & ord($utf8[1])));
             case 3:
                 // return a UTF-16 character from a 3-byte UTF-8 char
-                return chr((0xF0 & (ord($utf8{0}) << 4))
-                         | (0x0F & (ord($utf8{1}) >> 2)))
-                     . chr((0xC0 & (ord($utf8{1}) << 6))
-                         | (0x7F & ord($utf8{2})));
+                return chr((0xF0 & (ord($utf8[0]) << 4))
+                         | (0x0F & (ord($utf8[1]) >> 2)))
+                     . chr((0xC0 & (ord($utf8[1]) << 6))
+                         | (0x7F & ord($utf8[2])));
         // ignoring UTF-32 for now, sorry
@@ -261,7 +263,7 @@
                 for ($c = 0; $c < $strlen_var; ++$c) {
-                    $ord_var_c = ord($var{$c});
+                    $ord_var_c = ord($var[$c]);
                     switch (true) {
                         case $ord_var_c == 0x08:
@@ -284,18 +286,18 @@
                         case $ord_var_c == 0x2F:
                         case $ord_var_c == 0x5C:
                             // double quote, slash, slosh
-                            $ascii .= '\\'.$var{$c};
+                            $ascii .= '\\'.$var[$c];
                             break;
                         case (($ord_var_c >= 0x20) && ($ord_var_c <= 0x7F)):
                             // characters U-00000000 - U-0000007F (same as ASCII)
-                            $ascii .= $var{$c};
+                            $ascii .= $var[$c];
                             break;
                         case (($ord_var_c & 0xE0) == 0xC0):
                             // characters U-00000080 - U-000007FF, mask 110XXXXX
                             // see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
-                            $char = pack('C*', $ord_var_c, ord($var{$c + 1}));
+                            $char = pack('C*', $ord_var_c, ord($var[$c + 1]));
                             $c += 1;
                             $utf16 = $this->utf82utf16($char);
                             $ascii .= sprintf('\u%04s', bin2hex($utf16));
@@ -305,8 +307,8 @@
                             // characters U-00000800 - U-0000FFFF, mask 1110XXXX
-                                         ord($var{$c + 1}),
-                                         ord($var{$c + 2}));
+                                         ord($var[$c + 1]),
+                                         ord($var[$c + 2]));
                             $c += 2;
@@ -316,9 +318,9 @@
                             // characters U-00010000 - U-001FFFFF, mask 11110XXX
-                                         ord($var{$c + 2}),
-                                         ord($var{$c + 3}));
+                                         ord($var[$c + 2]),
+                                         ord($var[$c + 3]));
                             $c += 3;
@@ -328,10 +330,10 @@
                             // characters U-00200000 - U-03FFFFFF, mask 111110XX
-                                         ord($var{$c + 3}),
-                                         ord($var{$c + 4}));
+                                         ord($var[$c + 3]),
+                                         ord($var[$c + 4]));
                             $c += 4;
@@ -341,11 +343,11 @@
                             // characters U-04000000 - U-7FFFFFFF, mask 1111110X
-                                         ord($var{$c + 4}),
-                                         ord($var{$c + 5}));
+                                         ord($var[$c + 4]),
+                                         ord($var[$c + 5]));
                             $c += 5;
@@ -520,7 +522,7 @@
                     for ($c = 0; $c < $strlen_chrs; ++$c) {
                         $substr_chrs_c_2 = substr($chrs, $c, 2);
-                        $ord_chrs_c = ord($chrs{$c});
+                        $ord_chrs_c = ord($chrs[$c]);
                         switch (true) {
                             case $substr_chrs_c_2 == '\b':
@@ -550,7 +552,7 @@
                             case $substr_chrs_c_2 == '\\/':
                                 if (($delim == '"' && $substr_chrs_c_2 != '\\\'') ||
                                    ($delim == "'" && $substr_chrs_c_2 != '\\"')) {
-                                    $utf8 .= $chrs{++$c};
+                                    $utf8 .= $chrs[++$c];
                                 break;
@@ -563,7 +565,7 @@
                                 break;
                             case ($ord_chrs_c >= 0x20) && ($ord_chrs_c <= 0x7F):
-                                $utf8 .= $chrs{$c};
+                                $utf8 .= $chrs[$c];
                                 break;
                             case ($ord_chrs_c & 0xE0) == 0xC0:
@@ -610,7 +612,7 @@
                 } elseif (preg_match('/^\[.*\]$/s', $str) || preg_match('/^\{.*\}$/s', $str)) {
                     // array, or object notation
-                    if ($str{0} == '[') {
+                    if ($str[0] == '[') {
                         $stk = array(SERVICES_JSON_IN_ARR);
                         $arr = array();
                     } else {
@@ -649,7 +651,7 @@
                         $top = end($stk);
-                        if (($c == $strlen_chrs) || (($chrs{$c} == ',') && ($top['what'] == SERVICES_JSON_SLICE))) {
+                        if (($c == $strlen_chrs) || (($chrs[$c] == ',') && ($top['what'] == SERVICES_JSON_SLICE))) {
                             // found a comma that is not inside a string, array, etc.,
                             // OR we've reached the end of the character list
                             $slice = substr($chrs, $top['where'], ($c - $top['where']));
@@ -691,12 +693,12 @@
-                        } elseif ((($chrs{$c} == '"') || ($chrs{$c} == "'")) && ($top['what'] != SERVICES_JSON_IN_STR)) {
+                        } elseif ((($chrs[$c] == '"') || ($chrs[$c] == "'")) && ($top['what'] != SERVICES_JSON_IN_STR)) {
                             // found a quote, and we are not inside a string
-                            array_push($stk, array('what' => SERVICES_JSON_IN_STR, 'where' => $c, 'delim' => $chrs{$c}));
+                            array_push($stk, array('what' => SERVICES_JSON_IN_STR, 'where' => $c, 'delim' => $chrs[$c]));
                             //print("Found start of string at {$c}\n");
-                        } elseif (($chrs{$c} == $top['delim']) &&
+                        } elseif (($chrs[$c] == $top['delim']) &&
                                  ($top['what'] == SERVICES_JSON_IN_STR) &&
                                  ((strlen(substr($chrs, 0, $c)) - strlen(rtrim(substr($chrs, 0, $c), '\\'))) % 2 != 1)) {
                             // found a quote, we're in a string, and it's not escaped
@@ -705,24 +707,24 @@
                             array_pop($stk);
                             //print("Found end of string at {$c}: ".substr($chrs, $top['where'], (1 + 1 + $c - $top['where']))."\n");
-                        } elseif (($chrs{$c} == '[') &&
+                        } elseif (($chrs[$c] == '[') &&
                                  in_array($top['what'], array(SERVICES_JSON_SLICE, SERVICES_JSON_IN_ARR, SERVICES_JSON_IN_OBJ))) {
                             // found a left-bracket, and we are in an array, object, or slice
                             array_push($stk, array('what' => SERVICES_JSON_IN_ARR, 'where' => $c, 'delim' => false));
                             //print("Found start of array at {$c}\n");
-                        } elseif (($chrs{$c} == ']') && ($top['what'] == SERVICES_JSON_IN_ARR)) {
+                        } elseif (($chrs[$c] == ']') && ($top['what'] == SERVICES_JSON_IN_ARR)) {
                             // found a right-bracket, and we're in an array
                             array_pop($stk);
                             //print("Found end of array at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
-                        } elseif (($chrs{$c} == '{') &&
+                        } elseif (($chrs[$c] == '{') &&
                             // found a left-brace, and we are in an array, object, or slice
                             array_push($stk, array('what' => SERVICES_JSON_IN_OBJ, 'where' => $c, 'delim' => false));
                             //print("Found start of object at {$c}\n");
-                        } elseif (($chrs{$c} == '}') && ($top['what'] == SERVICES_JSON_IN_OBJ)) {
+                        } elseif (($chrs[$c] == '}') && ($top['what'] == SERVICES_JSON_IN_OBJ)) {
                             // found a right-brace, and we're in an object
                             array_pop($stk);
                             //print("Found end of object at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
Modified: sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/plot/plot.php
--- sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/plot/plot.php	2022-06-06 11:36:25 UTC (rev 9945)
+++ sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/plot/plot.php	2022-06-06 12:09:54 UTC (rev 9946)
@@ -42,8 +42,7 @@
     // current view of the map.
     $mappingService = $siteConnection->CreateService(MgServiceType::MappingService);
Modified: sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/utilityfunctions.php
--- sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/utilityfunctions.php	2022-06-06 11:36:25 UTC (rev 9945)
+++ sandbox/jng/vanilla_swig/Doc/samples/phpviewersample/utilityfunctions.php	2022-06-06 12:09:54 UTC (rev 9946)
@@ -30,9 +30,6 @@
 	$web_Dir = substr($thisFile, 0, $pos+1);
 	$configFilePath = $web_Dir . "../webconfig.ini";
-	include $web_Dir . "../mapviewerphp/constants.php";
 	// Searches the map for a layer with the specified name.
 	function GetXmlPath()
More information about the mapguide-commits mailing list
