[mapguide-commits] r9948 - in sandbox/jng/vanilla_swig: Doc/samples/javasamples Doc/samples/javasamples/hello_map Doc/samples/javasamples/interacting_with_layers Doc/samples/javaviewersample Web/src/viewerfiles
svn_mapguide at osgeo.org
Mon Jun 20 02:10:57 PDT 2022
Author: jng
Date: 2022-06-20 02:10:56 -0700 (Mon, 20 Jun 2022)
New Revision: 9948
sandbox/jng/vanilla_swig/Doc/samples/javasamples/hello_map/display_spatial_reference.jsp
sandbox/jng/vanilla_swig/Doc/samples/javasamples/index.jsp
sandbox/jng/vanilla_swig/Doc/samples/javasamples/interacting_with_layers/layer_visibility.jsp
sandbox/jng/vanilla_swig/Doc/samples/javasamples/interacting_with_layers/toggle_roads_label.jsp
sandbox/jng/vanilla_swig/Doc/samples/javasamples/main.jsp
sandbox/jng/vanilla_swig/Doc/samples/javaviewersample/utilityfunctions.jsp
sandbox/jng/vanilla_swig/Web/src/viewerfiles/ajaxmappane.templ
Fix up java viewer samples and fix up ajaxmappane.templ to guard against non-existent commands
Modified: sandbox/jng/vanilla_swig/Doc/samples/javasamples/hello_map/display_spatial_reference.jsp
--- sandbox/jng/vanilla_swig/Doc/samples/javasamples/hello_map/display_spatial_reference.jsp 2022-06-06 12:12:30 UTC (rev 9947)
+++ sandbox/jng/vanilla_swig/Doc/samples/javasamples/hello_map/display_spatial_reference.jsp 2022-06-20 09:10:56 UTC (rev 9948)
@@ -42,7 +42,7 @@
// Basic initialization needs to be done every time.
- MapGuideJavaApiEx.MgInitializeWebTier(webconfigFilePath);
+ MapGuideJavaApi.mgInitializeWebTier(webconfigFilePath);
// Get the user information using the session id,
// and set up a connection to the site server.
Modified: sandbox/jng/vanilla_swig/Doc/samples/javasamples/index.jsp
--- sandbox/jng/vanilla_swig/Doc/samples/javasamples/index.jsp 2022-06-06 12:12:30 UTC (rev 9947)
+++ sandbox/jng/vanilla_swig/Doc/samples/javasamples/index.jsp 2022-06-20 09:10:56 UTC (rev 9948)
@@ -61,9 +61,9 @@
Viewer Samples
</h1>
<ul>
- <li><a href="../javaviewersample/dwfviewersample.jsp?SESSION=<?= $sessionId ?>&MAPNAME=<?= $mapName ?>" target="_blank">Using DWF Viewer</a></li>
- <li><a href="../javaviewersample/ajaxviewersample.jsp?SESSION=<?= $sessionId ?>&MAPNAME=<?= $mapName ?>" target="_blank">Using Ajax Viewer</a></li>
- <li><a href="../javaviewersample/ajaxtiledviewersample.jsp?SESSION=<?= $sessionId ?>&MAPNAME=<?= $mapName ?>" target="_blank">Using Tiled Ajax Viewer</a></li>
+ <li><a href="../javaviewersample/dwfviewersample.jsp?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" target="_blank">Using DWF Viewer</a></li>
+ <li><a href="../javaviewersample/ajaxviewersample.jsp?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" target="_blank">Using Ajax Viewer</a></li>
+ <li><a href="../javaviewersample/ajaxtiledviewersample.jsp?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" target="_blank">Using Tiled Ajax Viewer</a></li>
</ul>
String helpDir = webExtensionsDirectory + "www/Help/";
Modified: sandbox/jng/vanilla_swig/Doc/samples/javasamples/interacting_with_layers/layer_visibility.jsp
--- sandbox/jng/vanilla_swig/Doc/samples/javasamples/interacting_with_layers/layer_visibility.jsp 2022-06-06 12:12:30 UTC (rev 9947)
+++ sandbox/jng/vanilla_swig/Doc/samples/javasamples/interacting_with_layers/layer_visibility.jsp 2022-06-20 09:10:56 UTC (rev 9948)
@@ -39,7 +39,7 @@
try
Modified: sandbox/jng/vanilla_swig/Doc/samples/javasamples/interacting_with_layers/toggle_roads_label.jsp
--- sandbox/jng/vanilla_swig/Doc/samples/javasamples/interacting_with_layers/toggle_roads_label.jsp 2022-06-06 12:12:30 UTC (rev 9947)
+++ sandbox/jng/vanilla_swig/Doc/samples/javasamples/interacting_with_layers/toggle_roads_label.jsp 2022-06-20 09:10:56 UTC (rev 9948)
@@ -51,7 +51,7 @@
// the Web Extensions session identifier stored in PHP
// session state.
@@ -86,18 +86,15 @@
"&MAPNAME=" + mapName + "\">Run again</a></p>");
- catch (MgLayerNotFoundException e)
- out.println("<p>Layer not found</p>");
- catch (MgObjectNotFoundException e)
catch (MgException e)
- out.println(e.getExceptionMessage());
- out.println(e.getDetails());
+ if (e.getExceptionCode().equals(MgExceptionCodes.MgLayerNotFoundException)
+ || e.getExceptionCode().equals(MgExceptionCodes.MgObjectNotFoundException)) {
+ out.println("<p>Layer not found</p>");
+ } else {
+ out.println(e.getExceptionMessage());
+ out.println(e.getDetails());
Modified: sandbox/jng/vanilla_swig/Doc/samples/javasamples/main.jsp
--- sandbox/jng/vanilla_swig/Doc/samples/javasamples/main.jsp 2022-06-06 12:12:30 UTC (rev 9947)
+++ sandbox/jng/vanilla_swig/Doc/samples/javasamples/main.jsp 2022-06-20 09:10:56 UTC (rev 9948)
@@ -30,7 +30,7 @@
// Initialize web tier with the site configuration file. The config
// file should be in the same folder as this script.
String configPath = realpath + "webconfig.ini";
- MapGuideJavaApiEx.MgInitializeWebTier( configPath );
+ MapGuideJavaApi.mgInitializeWebTier( configPath );
MgUserInformation userInfo = new MgUserInformation("Author", "author");
MgSite site = new MgSite();
Modified: sandbox/jng/vanilla_swig/Doc/samples/javaviewersample/utilityfunctions.jsp
--- sandbox/jng/vanilla_swig/Doc/samples/javaviewersample/utilityfunctions.jsp 2022-06-06 12:12:30 UTC (rev 9947)
+++ sandbox/jng/vanilla_swig/Doc/samples/javaviewersample/utilityfunctions.jsp 2022-06-20 09:10:56 UTC (rev 9948)
@@ -26,7 +26,7 @@
String GetQueryXmlTemplatePath()
Modified: sandbox/jng/vanilla_swig/Web/src/viewerfiles/ajaxmappane.templ
--- sandbox/jng/vanilla_swig/Web/src/viewerfiles/ajaxmappane.templ 2022-06-06 12:12:30 UTC (rev 9947)
+++ sandbox/jng/vanilla_swig/Web/src/viewerfiles/ajaxmappane.templ 2022-06-20 09:10:56 UTC (rev 9948)
@@ -1162,7 +1162,9 @@
else if(item.type == 1)
var cmd = parent.commands[item.cmdIndex];
- addMenuOption(menuObj, item.name, item.cmdIndex, 1, cmd.icon, cmd.iconDisabled, cmd.enabled);
+ if (cmd) {
+ addMenuOption(menuObj, item.name, item.cmdIndex, 1, cmd.icon, cmd.iconDisabled, cmd.enabled);
else if(item.type == 3)
More information about the mapguide-commits
