[mapguide-commits] r9941 - sandbox/jng/vanilla_swig/Web/src/mapviewerjava
svn_mapguide at osgeo.org
Mon May 23 06:10:18 PDT 2022
Author: jng
Date: 2022-05-23 06:10:18 -0700 (Mon, 23 May 2022)
New Revision: 9941
sandbox/jng/vanilla_swig/Web/src/mapviewerjava/common.jsp
sandbox/jng/vanilla_swig/Web/src/mapviewerjava/init.jsp
sandbox/jng/vanilla_swig/Web/src/mapviewerjava/mainframe.jsp
First round of AJAX viewer fixes for Java:
- Remove references to MapGuideJavaApiEx
- Fix MgInitializeWebTier calls as the binding now respects camelCase Java naming conventions
- Remove catch blocks that caught for specific subclasses of MgException. Use the new getExceptionCode() API to test for and handle specific exception types
Modified: sandbox/jng/vanilla_swig/Web/src/mapviewerjava/common.jsp
--- sandbox/jng/vanilla_swig/Web/src/mapviewerjava/common.jsp 2022-05-23 12:37:08 UTC (rev 9940)
+++ sandbox/jng/vanilla_swig/Web/src/mapviewerjava/common.jsp 2022-05-23 13:10:18 UTC (rev 9941)
@@ -32,7 +32,7 @@
String realpath = getServletContext().getRealPath("/");
String configPath = realpath + "webconfig.ini";
- MapGuideJavaApiEx.MgInitializeWebTier(configPath);
+ MapGuideJavaApi.mgInitializeWebTier(configPath);
String GetDefaultLocale()
Modified: sandbox/jng/vanilla_swig/Web/src/mapviewerjava/init.jsp
--- sandbox/jng/vanilla_swig/Web/src/mapviewerjava/init.jsp 2022-05-23 12:37:08 UTC (rev 9940)
+++ sandbox/jng/vanilla_swig/Web/src/mapviewerjava/init.jsp 2022-05-23 13:10:18 UTC (rev 9941)
@@ -24,7 +24,7 @@
// Initialize web tier with the site configuration file. The config
// file should be in the same folder as this script.
- MapGuideJavaApiEx.MgInitializeWebTier( configPath );
+ MapGuideJavaApi.mgInitializeWebTier( configPath );
Modified: sandbox/jng/vanilla_swig/Web/src/mapviewerjava/mainframe.jsp
--- sandbox/jng/vanilla_swig/Web/src/mapviewerjava/mainframe.jsp 2022-05-23 12:37:08 UTC (rev 9940)
+++ sandbox/jng/vanilla_swig/Web/src/mapviewerjava/mainframe.jsp 2022-05-23 13:10:18 UTC (rev 9941)
@@ -549,23 +549,15 @@
response.getWriter().write(templ);
response.setContentLength(templ.length());
-catch(MgUserNotFoundException e)
- RequestAuthentication(response);
- return;
-catch(MgUnauthorizedAccessException e)
- return;
-catch(MgAuthenticationFailedException e)
- return;
catch(MgException e)
+ if (e.getExceptionCode() == MgExceptionCodes.MgUserNotFoundException ||
+ e.getExceptionCode() == MgExceptionCodes.MgUnauthorizedAccessException ||
+ e.getExceptionCode() == MgExceptionCodes.MgAuthenticationFailedException) {
+ RequestAuthentication(response);
+ return;
String msg = EscapeForHtml(e.getExceptionMessage());
response.getWriter().write(msg);
response.setContentLength(msg.length());
More information about the mapguide-commits
