[mapguide-commits] r10002 - trunk/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Nov 1 03:29:05 PDT 2022
Author: jng
Date: 2022-11-01 03:29:04 -0700 (Tue, 01 Nov 2022)
New Revision: 10002
   trunk/MgDev/cmake_bootstrap.sh
   trunk/MgDev/cmake_build.sh
#2855: Don't build cppunit in cmake_bootstrap.sh
Modified: trunk/MgDev/cmake_bootstrap.sh
--- trunk/MgDev/cmake_bootstrap.sh	2022-11-01 10:23:23 UTC (rev 10001)
+++ trunk/MgDev/cmake_bootstrap.sh	2022-11-01 10:29:04 UTC (rev 10002)
@@ -2,7 +2,6 @@
 OEM_WORK_DIR=~/mapguide_oem_build
 INTERNAL_ACE=0
-INTERNAL_CPPUNIT=0
 INTERNAL_ZLIB=0
 INTERNAL_LIBPNG=0
 INTERNAL_JPEG=0
@@ -34,7 +33,6 @@
         --with-all-internal)
             INTERNAL_ACE=1
-            INTERNAL_CPPUNIT=1
             INTERNAL_ZLIB=1
             INTERNAL_LIBPNG=1
             INTERNAL_JPEG=1
@@ -46,9 +44,6 @@
         --with-internal-ace)
             INTERNAL_ACE=1
-        --with-internal-cppunit)
         --with-internal-zlib)
             INTERNAL_ZLIB=1
@@ -85,7 +80,6 @@
             echo "  --have-system-xerces [Use system-installed xerces]"
             echo "  --help [Display usage]"
             echo "  --with-internal-ace [Build/Use internal ACE]"
-            echo "  --with-internal-cppunit [Build/Use internal CppUnit]"
             echo "  --with-internal-zlib [Build/Use internal zlib]"
             echo "  --with-internal-jpeg [Build/Use internal jpeg]"
             echo "  --with-internal-libpng [Build/Use internal libpng]"
@@ -131,7 +125,6 @@
 echo "OEM Working Directory is: $OEM_WORK_DIR"
 echo "Using ccache: $USE_CCACHE"
 echo "INTERNAL_ACE       = $INTERNAL_ACE"
-echo "INTERNAL_CPPUNIT   = $INTERNAL_CPPUNIT"
 echo "INTERNAL_ZLIB      = $INTERNAL_ZLIB"
 echo "INTERNAL_LIBPNG    = $INTERNAL_LIBPNG"
 echo "INTERNAL_JPEG      = $INTERNAL_JPEG"
@@ -200,22 +193,8 @@
     env ACE_ROOT="${ACE_PATH}" make buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
     check_build
 fi
-if [ "$COMMON_SUBSET_ONLY" != "1" -a "$INTERNAL_CPPUNIT" = "1" ]; then
-    echo "Building CppUnit (internal)"
-    cp -Rf "${SOURCE_DIR}/Oem/CppUnit-1.9.14" "${OEM_WORK_DIR}/CppUnit"
-    cd "${OEM_WORK_DIR}/CppUnit" || exit
-    # Force regen of configure to cover our bases
-    aclocal -I config
-    libtoolize --copy --force
-    autoconf
-    automake --add-missing --copy --force-missing
-    # -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
-    sh ./configure --enable-silent-rules LDFLAGS="-ldl"
-    make && make install
-    check_build
-fi
 mkdir -p "${OEM_WORK_DIR}/gd"
-if [ "$COMMON_SUBSET_ONLY" != "1" -a "$INTERNAL_ZLIB" = "1" ]; then
+if [ "$COMMON_SUBSET_ONLY" != "1" ] && [ "$INTERNAL_ZLIB" = "1" ]; then
     echo "Building zlib (internal)"
     cp -Rf "${SOURCE_DIR}/Oem/gd/zlib" "${OEM_WORK_DIR}/gd/zlib"
     cd "${OEM_WORK_DIR}/gd/zlib" || exit
@@ -222,14 +201,14 @@
     if [ "$USE_CCACHE" = "1" ]; then
         # Aliasing CC=ccache gcc breaks the gcc check in this configure script that
         # would've inserted the required -fPIC flag. So specify manually
-        CFLAGS="-O3 -fPIC" sh ./configure
+        CFLAGS="-O3 -fPIC" sh ./configure --static
     else
-        sh ./configure
+        sh ./configure --static
     fi
     check_build
 fi
-if [ "$COMMON_SUBSET_ONLY" != "1" -a "$INTERNAL_LIBPNG" = "1" ]; then
+if [ "$COMMON_SUBSET_ONLY" != "1" ] && [ "$INTERNAL_LIBPNG" = "1" ]; then
     echo "Building libpng (internal)"
     cp -Rf "${SOURCE_DIR}/Oem/gd/lpng" "${OEM_WORK_DIR}/gd/lpng"
     cd "${OEM_WORK_DIR}/gd/lpng" || exit
@@ -245,7 +224,7 @@
         check_build
     fi
 fi
-if [ "$COMMON_SUBSET_ONLY" != "1" -a "$INTERNAL_JPEG" = "1" ]; then
+if [ "$COMMON_SUBSET_ONLY" != "1" ] && [ "$INTERNAL_JPEG" = "1" ]; then
     echo "Building libjpeg (internal)"
     cp -Rf "${SOURCE_DIR}/Oem/gd/jpeg" "${OEM_WORK_DIR}/gd/jpeg"
     cd "${OEM_WORK_DIR}/gd/jpeg" || exit
@@ -270,7 +249,7 @@
         check_build
     fi
 fi
-if [ "$COMMON_SUBSET_ONLY" != "1" -a "$INTERNAL_FREETYPE" = "1" ]; then
+if [ "$COMMON_SUBSET_ONLY" != "1" ] && [ "$INTERNAL_FREETYPE" = "1" ]; then
     echo "Building freetype (internal)"
     cp -Rf "${SOURCE_DIR}/Oem/gd/freetype" "${OEM_WORK_DIR}/gd/freetype"
     cd "${OEM_WORK_DIR}/gd/freetype" || exit
@@ -301,7 +280,7 @@
     PHP_ZLIB_DIR="$OEM_WORK_DIR/install/zlib"
 fi
-if [ "$COMMON_SUBSET_ONLY" != "1" -a "$INTERNAL_GD" = "1" ]; then
+if [ "$COMMON_SUBSET_ONLY" != "1" ] && [ "$INTERNAL_GD" = "1" ]; then
     echo "Building GD (internal)"
     cp -Rf "${SOURCE_DIR}/Oem/gd/gd" "${OEM_WORK_DIR}/gd/gd"
     cd "${OEM_WORK_DIR}/gd/gd" || exit
@@ -424,10 +403,6 @@
 if [ "$INTERNAL_ACE" = "1" ]; then
     OUT_INTERNAL_ACE=TRUE
 fi
-OUT_INTERNAL_CPPUNIT=FALSE
-if [ "$INTERNAL_CPPUNIT" = "1" ]; then
-    OUT_INTERNAL_CPPUNIT=TRUE
-fi
 OUT_INTERNAL_ZLIB=FALSE
 if [ "$INTERNAL_ZLIB" = "1" ]; then
     OUT_INTERNAL_ZLIB=TRUE
@@ -464,7 +439,6 @@
     echo "export BUILD_CONFIG=$BUILD_CONFIG"
     echo "export HAVE_SYSTEM_XERCES=$HAVE_SYSTEM_XERCES"
     echo "export INTERNAL_ACE=$OUT_INTERNAL_ACE"
-    echo "export INTERNAL_CPPUNIT=$OUT_INTERNAL_CPPUNIT"
     echo "export INTERNAL_ZLIB=$OUT_INTERNAL_ZLIB"
     echo "export INTERNAL_LIBPNG=$OUT_INTERNAL_LIBPNG"
     echo "export INTERNAL_JPEG=$OUT_INTERNAL_JPEG"
Modified: trunk/MgDev/cmake_build.sh
--- trunk/MgDev/cmake_build.sh	2022-11-01 10:23:23 UTC (rev 10001)
+++ trunk/MgDev/cmake_build.sh	2022-11-01 10:29:04 UTC (rev 10002)
@@ -118,10 +118,10 @@
 echo "Setting up CMake in: $CMAKE_BUILD_DIR"
 cd "$CMAKE_BUILD_DIR" || exit
 if test $USE_NINJA -eq 1; then
-    cmake -G Ninja "$SOURCE_DIR" -DMG_INSTALL_PREFIX=$MG_INST_PREFIX -DMG_CPU=$BUILD_CPU -DWITH_JAVA=TRUE -DUSE_LD_GOLD=$USE_LD_GOLD -DSANITIZE_ADDRESS=$USE_ASAN -DPHP_VER=$PHP_VER -DHTTPD_VER=$HTTPD_VER -DCMAKE_BUILD_TYPE=$BUILD_CONFIG -DMG_OEM_WORK_DIR=$OEM_WORK_DIR -DMG_LINUXAPT_WORK_DIR=$LINUXAPT_WORK_DIR -DINTERNAL_XERCES=$INTERNAL_XERCES -DINTERNAL_ACE=$INTERNAL_ACE -DINTERNAL_CPPUNIT=$INTERNAL_CPPUNIT -DINTERNAL_ZLIB=$INTERNAL_ZLIB -DINTERNAL_JPEG=$INTERNAL_JPEG -DINTERNAL_PNG=$INTERNAL_PNG -DINTERNAL_FREETYPE=$INTERNAL_FREETYPE -DINTERNAL_GD=$INTERNAL_GD -DINTERNAL_JSON=$INTERNAL_JSON -DINTERNAL_GEOS=$INTERNAL_GEOS -DCOMMON_SUBSET_ONLY=$COMMON_SUBSET_ONLY
+    cmake -G Ninja "$SOURCE_DIR" -DMG_INSTALL_PREFIX=$MG_INST_PREFIX -DMG_CPU=$BUILD_CPU -DWITH_JAVA=TRUE -DUSE_LD_GOLD=$USE_LD_GOLD -DSANITIZE_ADDRESS=$USE_ASAN -DPHP_VER=$PHP_VER -DHTTPD_VER=$HTTPD_VER -DCMAKE_BUILD_TYPE=$BUILD_CONFIG -DMG_OEM_WORK_DIR=$OEM_WORK_DIR -DMG_LINUXAPT_WORK_DIR=$LINUXAPT_WORK_DIR -DINTERNAL_XERCES=$INTERNAL_XERCES -DINTERNAL_ACE=$INTERNAL_ACE -DINTERNAL_ZLIB=$INTERNAL_ZLIB -DINTERNAL_JPEG=$INTERNAL_JPEG -DINTERNAL_PNG=$INTERNAL_PNG -DINTERNAL_FREETYPE=$INTERNAL_FREETYPE -DINTERNAL_GD=$INTERNAL_GD -DINTERNAL_JSON=$INTERNAL_JSON -DINTERNAL_GEOS=$INTERNAL_GEOS -DCOMMON_SUBSET_ONLY=$COMMON_SUBSET_ONLY
     check_build
 else
-    cmake "$SOURCE_DIR" -DMG_INSTALL_PREFIX=$MG_INST_PREFIX -DMG_CPU=$BUILD_CPU -DWITH_JAVA=TRUE -DUSE_LD_GOLD=$USE_LD_GOLD -DSANITIZE_ADDRESS=$USE_ASAN -DPHP_VER=$PHP_VER -DHTTPD_VER=$HTTPD_VER -DCMAKE_BUILD_TYPE=$BUILD_CONFIG -DMG_OEM_WORK_DIR=$OEM_WORK_DIR -DMG_LINUXAPT_WORK_DIR=$LINUXAPT_WORK_DIR -DINTERNAL_XERCES=$INTERNAL_XERCES -DINTERNAL_ACE=$INTERNAL_ACE -DINTERNAL_CPPUNIT=$INTERNAL_CPPUNIT -DINTERNAL_ZLIB=$INTERNAL_ZLIB -DINTERNAL_JPEG=$INTERNAL_JPEG -DINTERNAL_PNG=$INTERNAL_PNG -DINTERNAL_FREETYPE=$INTERNAL_FREETYPE -DINTERNAL_GD=$INTERNAL_GD -DINTERNAL_JSON=$INTERNAL_JSON -DINTERNAL_GEOS=$INTERNAL_GEOS -DCOMMON_SUBSET_ONLY=$COMMON_SUBSET_ONLY
+    cmake "$SOURCE_DIR" -DMG_INSTALL_PREFIX=$MG_INST_PREFIX -DMG_CPU=$BUILD_CPU -DWITH_JAVA=TRUE -DUSE_LD_GOLD=$USE_LD_GOLD -DSANITIZE_ADDRESS=$USE_ASAN -DPHP_VER=$PHP_VER -DHTTPD_VER=$HTTPD_VER -DCMAKE_BUILD_TYPE=$BUILD_CONFIG -DMG_OEM_WORK_DIR=$OEM_WORK_DIR -DMG_LINUXAPT_WORK_DIR=$LINUXAPT_WORK_DIR -DINTERNAL_XERCES=$INTERNAL_XERCES -DINTERNAL_ACE=$INTERNAL_ACE -DINTERNAL_ZLIB=$INTERNAL_ZLIB -DINTERNAL_JPEG=$INTERNAL_JPEG -DINTERNAL_PNG=$INTERNAL_PNG -DINTERNAL_FREETYPE=$INTERNAL_FREETYPE -DINTERNAL_GD=$INTERNAL_GD -DINTERNAL_JSON=$INTERNAL_JSON -DINTERNAL_GEOS=$INTERNAL_GEOS -DCOMMON_SUBSET_ONLY=$COMMON_SUBSET_ONLY
     check_build
 fi
 cmake --build .
More information about the mapguide-commits mailing list
