[mapguide-commits] r10012 - in trunk/MgDev: . Bindings/src/Bindings Bindings/src/Bindings/Java Bindings/src/Bindings/Php Web/src/DevHttpServer
    svn_mapguide at osgeo.org
    Fri Nov 11 05:08:04 PST 2022
Author: jng
Date: 2022-11-11 05:08:02 -0800 (Fri, 11 Nov 2022)
New Revision: 10012
   trunk/MgDev/Bindings/src/Bindings/Bindings.sln
   trunk/MgDev/Bindings/src/Bindings/Java/JavaApi.vcxproj
   trunk/MgDev/Bindings/src/Bindings/Php/PhpApi.vcxproj
   trunk/MgDev/Web/src/DevHttpServer/DevHttpServer.vcxproj
   trunk/MgDev/Web/src/DevHttpServer/postbuild.bat
   trunk/MgDev/clean.bat
#2852: More debug binding fixes
 - Fix up postbuild.bat for MgDevHttpServer
 - Don't clean cppunit (now removed) in clean.bat
 - Fix bad paths in JavaApi and PhpApi pre-build events
 - Add MgDevHttpServer and MapAgentCommon to Bindings.sln as dependencies of the SWIG binding projects. This is because the postbuild of MgHttpDevServer conveniently copies all the required .dll files into the place where the .net binding projects will be copying the native deps from. This also allows Bindings.sln to be built from a clean slate after Oem.sln, without needing to build Server and WebTier solutions first.
Modified: trunk/MgDev/Bindings/src/Bindings/Bindings.sln
--- trunk/MgDev/Bindings/src/Bindings/Bindings.sln	2022-11-11 09:57:04 UTC (rev 10011)
+++ trunk/MgDev/Bindings/src/Bindings/Bindings.sln	2022-11-11 13:08:02 UTC (rev 10012)
@@ -17,13 +17,15 @@
 EndProject
 Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JavaApi", "Java\JavaApi.vcxproj", "{C02F44CB-D916-428D-A1A5-04E225A2A4EC}"
 	ProjectSection(ProjectDependencies) = postProject
+		{2F2003C6-D19E-439D-8519-6BFCD7E58E6B} = {2F2003C6-D19E-439D-8519-6BFCD7E58E6B}
 		{B601F04C-0D42-4AFC-A092-B31185E2EA8C} = {B601F04C-0D42-4AFC-A092-B31185E2EA8C}
 	EndProjectSection
 EndProject
 Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FoundationApi", "DotNet\Foundation\FoundationApi.vcxproj", "{73C62FF2-C188-4A61-929E-2F112D7E17AA}"
+		{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425} = {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}
-		{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425} = {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}
 	EndProjectSection
 EndProject
 Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "OSGeo.MapGuide.Foundation", "..\Managed\DotNet\OSGeo.MapGuide.Foundation\OSGeo.MapGuide.Foundation.csproj", "{120AC2A9-5EBE-4512-9FF7-54EA04192196}"
@@ -33,9 +35,10 @@
 EndProject
 Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "GeometryApi", "DotNet\Geometry\GeometryApi.vcxproj", "{B994F673-EB8E-4C65-8884-B56AB8783115}"
+		{73C62FF2-C188-4A61-929E-2F112D7E17AA} = {73C62FF2-C188-4A61-929E-2F112D7E17AA}
 		{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0} = {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}
-		{73C62FF2-C188-4A61-929E-2F112D7E17AA} = {73C62FF2-C188-4A61-929E-2F112D7E17AA}
 	EndProjectSection
 EndProject
 Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "OSGeo.MapGuide.Geometry", "..\Managed\DotNet\OSGeo.MapGuide.Geometry\OSGeo.MapGuide.Geometry.csproj", "{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}"
@@ -45,9 +48,10 @@
 EndProject
 Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PlatformBaseApi", "DotNet\PlatformBase\PlatformBaseApi.vcxproj", "{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}"
+		{B994F673-EB8E-4C65-8884-B56AB8783115} = {B994F673-EB8E-4C65-8884-B56AB8783115}
 		{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4} = {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}
-		{B994F673-EB8E-4C65-8884-B56AB8783115} = {B994F673-EB8E-4C65-8884-B56AB8783115}
 	EndProjectSection
 EndProject
 Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "OSGeo.MapGuide.PlatformBase", "..\Managed\DotNet\OSGeo.MapGuide.PlatformBase\OSGeo.MapGuide.PlatformBase.csproj", "{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}"
@@ -57,10 +61,11 @@
 EndProject
 Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MapGuideCommonApi", "DotNet\MapGuideCommon\MapGuideCommonApi.vcxproj", "{42FC41FD-742B-4AED-816E-C211F1B07F3F}"
 		{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B} = {3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}
 		{5287A594-4D4F-43FE-A281-E279AB708CF1} = {5287A594-4D4F-43FE-A281-E279AB708CF1}
 	EndProjectSection
 EndProject
 Project("{9A19103F-16F7-4668-BE54-9A1E7A4F7556}") = "OSGeo.MapGuide.MapGuideCommon", "..\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon\OSGeo.MapGuide.MapGuideCommon.csproj", "{B4C52243-CBA3-4FB7-BB22-4D44331D6058}"
@@ -75,14 +80,15 @@
 EndProject
 Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WebApi", "DotNet\Web\WebApi.vcxproj", "{C83BF842-ABB1-4870-8003-11EF860E6741}"
-		{795B1B0E-4EC8-469D-B641-E26324266FBF} = {795B1B0E-4EC8-469D-B641-E26324266FBF}
+		{42FC41FD-742B-4AED-816E-C211F1B07F3F} = {42FC41FD-742B-4AED-816E-C211F1B07F3F}
 		{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44} = {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}
+		{795B1B0E-4EC8-469D-B641-E26324266FBF} = {795B1B0E-4EC8-469D-B641-E26324266FBF}
+		{B797917B-6842-467C-8B14-E00B76A91247} = {B797917B-6842-467C-8B14-E00B76A91247}
-		{B797917B-6842-467C-8B14-E00B76A91247} = {B797917B-6842-467C-8B14-E00B76A91247}
-		{42FC41FD-742B-4AED-816E-C211F1B07F3F} = {42FC41FD-742B-4AED-816E-C211F1B07F3F}
 	EndProjectSection
 EndProject
 Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = "split", "split", "{025034E6-A625-427B-AA99-5158095ED5F9}"
@@ -111,17 +117,22 @@
 EndProject
 Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PhpApi", "Php\PhpApi.vcxproj", "{696D2664-D17F-4357-8A19-2B5DC4B29962}"
+		{5287A594-4D4F-43FE-A281-E279AB708CF1} = {5287A594-4D4F-43FE-A281-E279AB708CF1}
+		{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44} = {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}
-		{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44} = {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}
-		{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4} = {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}
+		{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B} = {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}
-		{5287A594-4D4F-43FE-A281-E279AB708CF1} = {5287A594-4D4F-43FE-A281-E279AB708CF1}
-		{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B} = {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}
+		{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4} = {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}
 	EndProjectSection
 EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DevHttpServer", "..\..\..\Web\src\DevHttpServer\DevHttpServer.vcxproj", "{2F2003C6-D19E-439D-8519-6BFCD7E58E6B}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "MapAgentCommon", "..\..\..\Web\src\MapAgentCommon\MapAgentCommon.vcxproj", "{2E11E332-CF38-4C8E-999A-29935A63AA89}"
+EndProject
 Global
 	GlobalSection(SolutionConfigurationPlatforms) = preSolution
 		Debug|x64 = Debug|x64
@@ -301,6 +312,22 @@
 		{696D2664-D17F-4357-8A19-2B5DC4B29962}.Release|x64.Build.0 = Release|x64
 		{696D2664-D17F-4357-8A19-2B5DC4B29962}.Release|x86.ActiveCfg = Release|x64
 		{696D2664-D17F-4357-8A19-2B5DC4B29962}.Release|x86.Build.0 = Release|x64
+		{2F2003C6-D19E-439D-8519-6BFCD7E58E6B}.Debug|x64.ActiveCfg = Debug|x64
+		{2F2003C6-D19E-439D-8519-6BFCD7E58E6B}.Debug|x64.Build.0 = Debug|x64
+		{2F2003C6-D19E-439D-8519-6BFCD7E58E6B}.Debug|x86.ActiveCfg = Debug|Win32
+		{2F2003C6-D19E-439D-8519-6BFCD7E58E6B}.Debug|x86.Build.0 = Debug|Win32
+		{2F2003C6-D19E-439D-8519-6BFCD7E58E6B}.Release|x64.ActiveCfg = Release|x64
+		{2F2003C6-D19E-439D-8519-6BFCD7E58E6B}.Release|x64.Build.0 = Release|x64
+		{2F2003C6-D19E-439D-8519-6BFCD7E58E6B}.Release|x86.ActiveCfg = Release|Win32
+		{2F2003C6-D19E-439D-8519-6BFCD7E58E6B}.Release|x86.Build.0 = Release|Win32
+		{2E11E332-CF38-4C8E-999A-29935A63AA89}.Debug|x64.ActiveCfg = Debug|x64
+		{2E11E332-CF38-4C8E-999A-29935A63AA89}.Debug|x64.Build.0 = Debug|x64
+		{2E11E332-CF38-4C8E-999A-29935A63AA89}.Debug|x86.ActiveCfg = Debug|Win32
+		{2E11E332-CF38-4C8E-999A-29935A63AA89}.Debug|x86.Build.0 = Debug|Win32
+		{2E11E332-CF38-4C8E-999A-29935A63AA89}.Release|x64.ActiveCfg = Release|x64
+		{2E11E332-CF38-4C8E-999A-29935A63AA89}.Release|x64.Build.0 = Release|x64
+		{2E11E332-CF38-4C8E-999A-29935A63AA89}.Release|x86.ActiveCfg = Release|Win32
+		{2E11E332-CF38-4C8E-999A-29935A63AA89}.Release|x86.Build.0 = Release|Win32
 	EndGlobalSection
 	GlobalSection(SolutionProperties) = preSolution
 		HideSolutionNode = FALSE
@@ -330,6 +357,8 @@
 		{795B1B0E-4EC8-469D-B641-E26324266FBF} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
 		{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
 		{696D2664-D17F-4357-8A19-2B5DC4B29962} = {323AEA7C-774B-49D8-8D34-7A766288C549}
+		{2F2003C6-D19E-439D-8519-6BFCD7E58E6B} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
+		{2E11E332-CF38-4C8E-999A-29935A63AA89} = {8CF61B8E-3BE0-4F25-B663-DFB082A67F00}
 	EndGlobalSection
 	GlobalSection(ExtensibilityGlobals) = postSolution
 		SolutionGuid = {733BCCC2-0431-4AB7-ABB6-AAE81AB54C48}
Modified: trunk/MgDev/Bindings/src/Bindings/Java/JavaApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/Java/JavaApi.vcxproj	2022-11-11 09:57:04 UTC (rev 10011)
+++ trunk/MgDev/Bindings/src/Bindings/Java/JavaApi.vcxproj	2022-11-11 13:08:02 UTC (rev 10012)
@@ -92,11 +92,11 @@
 echo Building java classes...
 "$(JAVA_HOME)\bin\javac" -classpath . org\osgeo\mapguide\*.java
 echo Building JAR file
-"$(JAVA_HOME)\bin\jar" cf $(SolutionDir)..\..\..\packages\Java\Release\x64\MapGuideApi.jar org\osgeo\mapguide\*.class
+"$(JAVA_HOME)\bin\jar" cf $(SolutionDir)..\..\..\packages\Java\$(Configuration)\x64\MapGuideApi.jar org\osgeo\mapguide\*.class
 echo Building -sources JAR file
-"$(JAVA_HOME)\bin\jar" cf  $(SolutionDir)..\..\..\packages\Java\Release\x64\MapGuideApi-sources.jar org\osgeo\mapguide\*.java
+"$(JAVA_HOME)\bin\jar" cf  $(SolutionDir)..\..\..\packages\Java\$(Configuration)\x64\MapGuideApi-sources.jar org\osgeo\mapguide\*.java
 rem echo Building javadoc
-rem "$(JAVA_HOME)\bin\javadoc" -d $(SolutionDir)..\..\..\packages\Java\Release\x64\html org\osgeo\mapguide\*.java
+rem "$(JAVA_HOME)\bin\javadoc" -d $(SolutionDir)..\..\..\packages\Java\$(Configuration)\x64\html org\osgeo\mapguide\*.java
 popd</Command>
     </PostBuildEvent>
   </ItemDefinitionGroup>
@@ -140,11 +140,11 @@
 popd</Command>
     </PostBuildEvent>
Modified: trunk/MgDev/Bindings/src/Bindings/Php/PhpApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/Php/PhpApi.vcxproj	2022-11-11 09:57:04 UTC (rev 10011)
+++ trunk/MgDev/Bindings/src/Bindings/Php/PhpApi.vcxproj	2022-11-11 13:08:02 UTC (rev 10012)
@@ -55,7 +55,7 @@
   </PropertyGroup>
   <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
     <PreBuildEvent>
-      <Command>"..\..\IMake\Win32\IMake.exe" -p "$(ProjectDir)..\MapGuideApi\Constants.xml" -l PHP -o ./constants.i -t
+      <Command>"..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)..\MapGuideApi\Constants.xml" -l PHP -o ./constants.i -t
 copy .\php.i "$(ProjectDir)language.i"
 "..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)..\MapGuideApi\MapGuideApiGen.xml" -l PHP
 "$(SWIG_DIR)\swig.exe" -c++ -php -DWIN32 -DPHPSWIG -nodefaultctor -nodefaultdtor -o "$(ProjectDir)MgApi_wrap.cpp" MapGuideApi.i
Modified: trunk/MgDev/Web/src/DevHttpServer/DevHttpServer.vcxproj
--- trunk/MgDev/Web/src/DevHttpServer/DevHttpServer.vcxproj	2022-11-11 09:57:04 UTC (rev 10011)
+++ trunk/MgDev/Web/src/DevHttpServer/DevHttpServer.vcxproj	2022-11-11 13:08:02 UTC (rev 10012)
@@ -144,7 +144,7 @@
       <TargetMachine>MachineX64</TargetMachine>
     </Link>
     <PostBuildEvent>
-      <Command>call postbuild.bat "$(TargetDir)" "$(ProjectDir)" "$(Configuration)64"</Command>
+      <Command>call postbuild.bat "$(TargetDir)" "$(ProjectDir)" $(Configuration)64</Command>
     </PostBuildEvent>
   <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
@@ -202,7 +202,7 @@
     </Link>
     <PostBuildEvent>
     </PostBuildEvent>
   <ItemGroup>
Modified: trunk/MgDev/Web/src/DevHttpServer/postbuild.bat
--- trunk/MgDev/Web/src/DevHttpServer/postbuild.bat	2022-11-11 09:57:04 UTC (rev 10011)
+++ trunk/MgDev/Web/src/DevHttpServer/postbuild.bat	2022-11-11 13:08:02 UTC (rev 10012)
@@ -9,6 +9,11 @@
   SET CONFDIR=Debug
+echo TARGET_DIR = %TARGET_DIR%
+echo CONFDIR = %CONFDIR%
+echo TYPE_BUILD = %TYPE_BUILD%
+echo LIBDIR = %LIBDIR%
 echo Copying to %TARGET_DIR%
 IF NOT EXIST "%TARGET_DIR%Resources" mkdir "%TARGET_DIR%Resources"
Modified: trunk/MgDev/clean.bat
--- trunk/MgDev/clean.bat	2022-11-11 09:57:04 UTC (rev 10011)
+++ trunk/MgDev/clean.bat	2022-11-11 13:08:02 UTC (rev 10012)
@@ -2,13 +2,11 @@
 echo [clean]: Oem
 if exist Oem\ACE\ACE_wrappers\lib64 rd /S /Q Oem\ACE\ACE_wrappers\lib64
 if exist Oem\ACE\ACE_wrappers\obj64 rd /S /Q Oem\ACE\ACE_wrappers\obj64
-if exist Oem\CppUnit-1.9.14\lib64 rd /S /Q Oem\CppUnit-1.9.14\lib64
-if exist Oem\CppUnit-1.9.14\src\cppunit\Release64 rd /S /Q Oem\CppUnit-1.9.14\src\cppunit\Release64
-if exist Oem\CppUnit-1.9.14\src\obj64 rd /S /Q Oem\CppUnit-1.9.14\src\obj64
 if exist Oem\CsMap\CsMapDev\bin160 rd /S /Q Oem\CsMap\CsMapDev\bin160
 if exist Oem\CsMap\CsMapDev\lib160 rd /S /Q Oem\CsMap\CsMapDev\lib160
 if exist Oem\CsMap\CsMapDev\obj160 rd /S /Q Oem\CsMap\CsMapDev\obj160
 echo [clean]: Packages
+if exist Bindings\packages rd /S /Q Bindings\packages
 if exist packages\DotNet rd /S /Q packages\DotNet
 if exist packages\Java rd /S /Q packages\Java
 if exist packages\Php rd /S /Q packages\Php
More information about the mapguide-commits
