[mapguide-commits] r10015 - trunk/MgDev
svn_mapguide at osgeo.org
Fri Nov 11 05:48:01 PST 2022
Author: jng
Date: 2022-11-11 05:48:01 -0800 (Fri, 11 Nov 2022)
New Revision: 10015
trunk/MgDev/setenvironment64.bat
#2852: Replace nuget.config unconditionally in setenvironment64.bat
Modified: trunk/MgDev/setenvironment64.bat
--- trunk/MgDev/setenvironment64.bat 2022-11-11 13:30:09 UTC (rev 10014)
+++ trunk/MgDev/setenvironment64.bat 2022-11-11 13:48:01 UTC (rev 10015)
@@ -159,10 +159,8 @@
echo swig.exe was found in: %SWIG_DIR% and will be referred to when building language bindings
-if not exist nuget.config (
- echo Using nuget.%PCONF%.config as default nuget.config
- copy /Y nuget.%PCONF%.config nuget.config
+echo Using nuget.%PCONF%.config as default nuget.config
+copy /Y nuget.%PCONF%.config nuget.config
echo Type build.bat to build MapGuide
More information about the mapguide-commits
