[mapguide-commits] r9976 - in trunk/MgDev: . Bindings Bindings/src/Bindings Bindings/src/Bindings/DotNet Bindings/src/Bindings/DotNet/Foundation Bindings/src/Bindings/DotNet/Geometry Bindings/src/Bindings/DotNet/MapGuideCommon Bindings/src/Bindings/DotNet/PlatformBase Bindings/src/Bindings/DotNet/Web Bindings/src/Bindings/Java Bindings/src/Bindings/Php Bindings/src/IMake Oem Portable Portable/MgPortable Server/src/Services/Mapping UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers Web/src/mapviewerjava
svn_mapguide at osgeo.org
Mon Oct 10 03:58:26 PDT 2022
Author: jng
Date: 2022-10-10 03:58:26 -0700 (Mon, 10 Oct 2022)
New Revision: 9976
trunk/MgDev/
trunk/MgDev/Bindings/TODO.txt
trunk/MgDev/Bindings/src/Bindings/Bindings.sln
trunk/MgDev/Bindings/src/Bindings/DotNet/DotNetUnmanagedApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/Web/WebApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/Java/JavaApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/Php/PhpApi.vcxproj
trunk/MgDev/Bindings/src/IMake/IMake.vcxproj
trunk/MgDev/Oem/oem.sln
trunk/MgDev/Portable/
trunk/MgDev/Portable/MgPortable/MgPortable.vcxproj
trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml
trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp
Merged revision(s) 9825-9915 from sandbox/jng/vanilla_swig:
Merged revision(s) 9824 from trunk/MgDev:
Add a CMakeLists.txt to jsoncpp so we can build it with CMake instead of relying on scons, which it and/or Python has to be in a particular version range for the build to work. Also speed up common libs subset build by using the (undiscovered until now) --build-one flag in dbxml's buildall.sh to only build xerces and skip everything else
TODO update
Merged revision(s) 9825-9863 from trunk/MgDev: Synchronize sandbox branch against latest trunk
Merged revision(s) 9874-9897 from trunk/MgDev:
#2842: Update httpd to 2.4.49 and update apr to 1.7.0
Merged revision(s) 9866-9867, 9871-9873 from sandbox/adsk/trunk:
Fix an issue that the offset of the ghost text is not proper if the font size is very small, for example, the font size is 0.4mm.
By default, the offset of the ghost text is 0.25mm.
If the height of the font is very small, for example, 0.4mm. The 0.25mm offset is relatively big.
And after the 0.25mm offset is converted to the value of the screen unit,
the value is much bigger than 1 if the user zooms to see the text. In this case, 1/10 of the font height
is used instead of 0.25mm.
Update transform grid file format according to CsMap changes.
Fix towlower / toupper to towlower / towupper for wchar_t
Revert copyright to LGPL 2.1
CS: Update method CCoordinateSystemTransform::GetExplicitGeodeticPath().
If it is an implicitly constructed path, we'll now create a [GeodeticPathDefinition] on-the-fly
#2842: Update HTTPD_VER
Update svn ignore list
Fix up IMake for Debug|x64
Update source file list for CS-Map
Merged revision(s) 9875-9881 from sandbox/adsk/trunk:
Update method CCoordinateSystemGeodeticTransformGridFile::IsValid() to add OST15 format.
Pass the 'geometry' argument to ProcessSELabelGroup, so the renderer can get the centroid of the geometry.
Merged revision(s) 9884-9896 from sandbox/jng/msvc2019:
#2843: Migrate to use MSVC 2019 as the default windows compiler
Update PlatformToolset target for MgPortable. Missed in previous merge because SVN sucks at tracking directory/file renames
Merged revision(s) 9902 from trunk/MgDev:
#2843: Missed a spot. Update CS-Map lib path
DevGuide doc: Remove unused pngmath extension
Use v142 toolset for bindings
Fix up Windows SDK references
Update TODO
Merged revision(s) 9909-9914 from trunk/MgDev:
devguide: Remove pngmath extension from sphinx-doc config
#2842: Update httpd to 2.4.52
#2842: Update httpd windows headers/libs to 2.4.52
Merged revision(s) 9908 from sandbox/adsk/trunk:
If the font height is very small, like 3mm or less. The calculated offset is large relatively to the font height.
For this case, a limitation of the offset is added. A flag - limitMaxOffset is added. It indicates the font height is very small and the limitation is needed. The maximum offset is set to 6 * screenUnitsPerPixel.
Index: trunk/MgDev
--- trunk/MgDev 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev 2022-10-10 10:58:26 UTC (rev 9976)
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
## -41,6 +41,6 ##
/sandbox/jng/utfgrid:9179-9212
/sandbox/jng/v30:8212-8227
/sandbox/jng/v4:9511-9519
-/sandbox/jng/vanilla_swig:9757-9823
+/sandbox/jng/vanilla_swig:9757-9823,9825-9915
/sandbox/jng/wfs_hits:9569-9577
/sandbox/rfc94:5099-5163
\ No newline at end of property
Modified: trunk/MgDev/Bindings/TODO.txt
--- trunk/MgDev/Bindings/TODO.txt 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/TODO.txt 2022-10-10 10:58:26 UTC (rev 9976)
@@ -3,12 +3,13 @@
- [x] Generate XML documentation for our .net wrapper binding projects
- [ ] Make sure we can build debug bindings
- [x] Fix up inconsistent stack direction in C# exceptions (C++ call stack are printed downwards, C# call stack is printed upwards)
- - [ ] Add memory leak test (ref: http://osgeo-org.1560.x6.nabble.com/Memory-Leak-in-Java-td5425579.html) and see if this still happens
+ - [ ] Add memory leak test (ref: https://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg26357.html) and see if this still happens
- [x] Check in test case admin tool
- [x] Consolidate Tools.sln into Bindings.sln
- [ ] Relocate/remove existing test code
- [x] Move packages dir up to to top-level MgDev subdirectory and make sure nuget.config sources from this dir
- [ ] Update build batch files to build bindings/portable
+ - [ ] Fix binding pre-build events to copy ACE/GEOS/lib_json dlls from their respective Oem directories
- Split .net binding into the Foundation/Geometry/PlatformBase/MapGuideCommon/Web layout (https://github.com/jumpinjackie/mapguide-api-bindings/issues/18)
- [x] Add .targets files to each C# project so that native dlls are copied properly when consumed by legacy .net framework applications/libraries
- [x] Consolidate TestCommon and TestMapGuideApi .net projects to unified netstandard2.0 libraries
@@ -39,11 +40,11 @@
- [ ] Running javadoc against the generated sources produces many errors. See if we can fix them
- [x] Verify test suite still passes (Windows)
- [ ] Verify test suite still passes (Linux)
- - [x] Migrate to SWIG 4.0.2 (https://github.com/jumpinjackie/mapguide-api-bindings/issues/36)
+ - [ ] Migrate to SWIG 4.1.0 (https://github.com/jumpinjackie/mapguide-api-bindings/issues/36)
+ - [ ] SWIG 4.1 has not been released yet, so migrate to swig git master
- [ ] Check if we can get rid of custom .net wstring marshaler (presumably SWIG 4.0 has better support in this area)
- - PHP 7 binding (https://github.com/jumpinjackie/mapguide-api-bindings/issues/21)
- - [ ] Re-base work against PHP 7.4
- - [ ] If this means we have to upgrade VS compiler from 2015, just upgrade this one project
+ - PHP 8 binding (https://github.com/jumpinjackie/mapguide-api-bindings/issues/21)
+ - [ ] Re-base work against PHP 8.1
- [ ] Make sure downcasting still works (eg. MgSiteConnection::CreateService returns an appropriate MgService-derived subclass and not MgService)
- [ ] Make sure that our byte typemaps still work (test APIs that deal with MgByteReader)
- [ ] Make sure we can throw MgException
@@ -62,9 +63,7 @@
- [ ] mapadmin
- [ ] fusion
- [ ] mapviewernet
- - If raw .aspx files cannot consume our netstandard2.0 package, convert this to a legacy ASP.net web forms project
- - Will require installer changes to properly register this ASP.net application
- - If the above is untenable, rewrite mapviewernet as a Razor Pages application
+ - If raw .aspx files cannot consume our netstandard2.0 package, retian Oem/SwigEx for the purpose of building "legacy" .net bindings
- [ ] MapGuide Developer's Guide
- [ ] viewer samples (PHP)
- [ ] viewer samples (Java)
@@ -82,8 +81,8 @@
- [ ] Add new OSGeo.MapGuide.Portable .net project for the .net portion of the SWIG glue
- [ ] Implement a sample asp.net core application that confirms the feasibility of using mg-portable for web applications in addition to desktop applications
- Either:
- - ( ) Migrate the viewer winforms library to target .net 5.0
- - ( ) Or maintain 2 versions of this library, a new .net 5.0 version of the library and a legacy full framework version
+ - ( ) Migrate the viewer winforms library to target .net 6.0
+ - ( ) Or maintain 2 versions of this library, a new .net 6.0 version of the library and a legacy full framework version
- [ ] Port over Java binding
- Old code cleanup/consolidation
- [ ] Remove old IMake
Modified: trunk/MgDev/Bindings/src/Bindings/Bindings.sln
--- trunk/MgDev/Bindings/src/Bindings/Bindings.sln 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/src/Bindings/Bindings.sln 2022-10-10 10:58:26 UTC (rev 9976)
@@ -1,7 +1,7 @@
Microsoft Visual Studio Solution File, Format Version 12.00
-# Visual Studio Version 16
-VisualStudioVersion = 16.0.30611.23
+# Visual Studio Version 17
+VisualStudioVersion = 17.0.31912.275
MinimumVisualStudioVersion = 10.0.40219.1
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DotNetUnmanagedApi", "DotNet\DotNetUnmanagedApi.vcxproj", "{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}"
ProjectSection(ProjectDependencies) = postProject
@@ -141,306 +141,224 @@
EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
- Debug|Any CPU = Debug|Any CPU
Debug|x64 = Debug|x64
Debug|x86 = Debug|x86
- Release|Any CPU = Release|Any CPU
Release|x64 = Release|x64
Release|x86 = Release|x86
EndGlobalSection
GlobalSection(ProjectConfigurationPlatforms) = postSolution
- {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|Any CPU.ActiveCfg = Debug|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|x64.ActiveCfg = Debug|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|x64.Build.0 = Debug|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Debug|x86.ActiveCfg = Debug|x64
- {FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|Any CPU.ActiveCfg = Release|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|x64.ActiveCfg = Release|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|x64.Build.0 = Release|x64
{FDC09E9D-72BB-4C74-B88B-727D9D1D6C4E}.Release|x86.ActiveCfg = Release|x64
- {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|Any CPU.ActiveCfg = Debug|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|x64.ActiveCfg = Debug|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|x86.ActiveCfg = Debug|x64
- {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|Any CPU.ActiveCfg = Release|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x64.ActiveCfg = Release|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x64.Build.0 = Release|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x64.Deploy.0 = Release|x64
{B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x86.ActiveCfg = Release|x64
- {C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|Any CPU.ActiveCfg = Debug|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|x64.ActiveCfg = Debug|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|x64.Build.0 = Debug|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|x86.ActiveCfg = Debug|x64
- {C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|Any CPU.ActiveCfg = Release|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x64.ActiveCfg = Release|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x64.Build.0 = Release|x64
{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x86.ActiveCfg = Release|x64
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|Any CPU.Build.0 = Debug|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x64.ActiveCfg = Debug|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x64.Build.0 = Debug|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x86.ActiveCfg = Debug|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Debug|x86.Build.0 = Debug|Any CPU
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|Any CPU.Build.0 = Release|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x64.ActiveCfg = Release|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x64.Build.0 = Release|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x86.ActiveCfg = Release|Any CPU
{4A3F2DA2-F53F-48EE-9505-8285F3E089D4}.Release|x86.Build.0 = Release|Any CPU
- {73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|Any CPU.ActiveCfg = Debug|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|x64.ActiveCfg = Debug|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|x64.Build.0 = Debug|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Debug|x86.ActiveCfg = Debug|x64
- {73C62FF2-C188-4A61-929E-2F112D7E17AA}.Release|Any CPU.ActiveCfg = Release|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Release|x64.ActiveCfg = Release|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Release|x64.Build.0 = Release|x64
{73C62FF2-C188-4A61-929E-2F112D7E17AA}.Release|x86.ActiveCfg = Release|x64
- {120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|Any CPU.Build.0 = Debug|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|x64.ActiveCfg = Debug|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|x64.Build.0 = Debug|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|x86.ActiveCfg = Debug|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Debug|x86.Build.0 = Debug|Any CPU
- {120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|Any CPU.Build.0 = Release|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|x64.ActiveCfg = Release|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|x64.Build.0 = Release|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|x86.ActiveCfg = Release|Any CPU
{120AC2A9-5EBE-4512-9FF7-54EA04192196}.Release|x86.Build.0 = Release|Any CPU
- {B994F673-EB8E-4C65-8884-B56AB8783115}.Debug|Any CPU.ActiveCfg = Debug|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Debug|x64.ActiveCfg = Debug|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Debug|x64.Build.0 = Debug|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Debug|x86.ActiveCfg = Debug|x64
- {B994F673-EB8E-4C65-8884-B56AB8783115}.Release|Any CPU.ActiveCfg = Release|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Release|x64.ActiveCfg = Release|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Release|x64.Build.0 = Release|x64
{B994F673-EB8E-4C65-8884-B56AB8783115}.Release|x86.ActiveCfg = Release|x64
- {15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|Any CPU.Build.0 = Debug|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|x64.ActiveCfg = Debug|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|x64.Build.0 = Debug|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|x86.ActiveCfg = Debug|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Debug|x86.Build.0 = Debug|Any CPU
- {15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|Any CPU.Build.0 = Release|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|x64.ActiveCfg = Release|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|x64.Build.0 = Release|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|x86.ActiveCfg = Release|Any CPU
{15A784CC-1DA1-4AF2-81EA-D9EABCD4B760}.Release|x86.Build.0 = Release|Any CPU
- {3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Debug|Any CPU.ActiveCfg = Debug|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Debug|x64.ActiveCfg = Debug|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Debug|x64.Build.0 = Debug|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Debug|x86.ActiveCfg = Debug|x64
- {3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Release|Any CPU.ActiveCfg = Release|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Release|x64.ActiveCfg = Release|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Release|x64.Build.0 = Release|x64
{3BAE3F0E-8F3F-404B-B29B-5881C16BD33B}.Release|x86.ActiveCfg = Release|x64
- {80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|Any CPU.Build.0 = Debug|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|x64.ActiveCfg = Debug|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|x64.Build.0 = Debug|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|x86.ActiveCfg = Debug|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Debug|x86.Build.0 = Debug|Any CPU
- {80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|Any CPU.Build.0 = Release|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|x64.ActiveCfg = Release|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|x64.Build.0 = Release|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|x86.ActiveCfg = Release|Any CPU
{80D0D30B-A9E1-464B-93ED-0EFEAD4EE102}.Release|x86.Build.0 = Release|Any CPU
- {42FC41FD-742B-4AED-816E-C211F1B07F3F}.Debug|Any CPU.ActiveCfg = Debug|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Debug|x64.ActiveCfg = Debug|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Debug|x64.Build.0 = Debug|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Debug|x86.ActiveCfg = Debug|x64
- {42FC41FD-742B-4AED-816E-C211F1B07F3F}.Release|Any CPU.ActiveCfg = Release|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Release|x64.ActiveCfg = Release|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Release|x64.Build.0 = Release|x64
{42FC41FD-742B-4AED-816E-C211F1B07F3F}.Release|x86.ActiveCfg = Release|x64
- {B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|Any CPU.Build.0 = Debug|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|x64.ActiveCfg = Debug|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|x64.Build.0 = Debug|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|x86.ActiveCfg = Debug|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Debug|x86.Build.0 = Debug|Any CPU
- {B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|Any CPU.Build.0 = Release|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|x64.ActiveCfg = Release|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|x64.Build.0 = Release|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|x86.ActiveCfg = Release|Any CPU
{B4C52243-CBA3-4FB7-BB22-4D44331D6058}.Release|x86.Build.0 = Release|Any CPU
- {0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|Any CPU.Build.0 = Debug|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|x64.ActiveCfg = Debug|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|x64.Build.0 = Debug|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|x86.ActiveCfg = Debug|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Debug|x86.Build.0 = Debug|Any CPU
- {0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|Any CPU.Build.0 = Release|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|x64.ActiveCfg = Release|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|x64.Build.0 = Release|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|x86.ActiveCfg = Release|Any CPU
{0B90819D-4066-4D6C-87E6-3BE4D8F595DE}.Release|x86.Build.0 = Release|Any CPU
- {C83BF842-ABB1-4870-8003-11EF860E6741}.Debug|Any CPU.ActiveCfg = Debug|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Debug|x64.ActiveCfg = Debug|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Debug|x64.Build.0 = Debug|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Debug|x86.ActiveCfg = Debug|x64
- {C83BF842-ABB1-4870-8003-11EF860E6741}.Release|Any CPU.ActiveCfg = Release|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Release|x64.ActiveCfg = Release|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Release|x64.Build.0 = Release|x64
{C83BF842-ABB1-4870-8003-11EF860E6741}.Release|x86.ActiveCfg = Release|x64
- {C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|Any CPU.Build.0 = Debug|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|x64.ActiveCfg = Debug|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|x64.Build.0 = Debug|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|x86.ActiveCfg = Debug|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Debug|x86.Build.0 = Debug|Any CPU
- {C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|Any CPU.Build.0 = Release|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|x64.ActiveCfg = Release|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|x64.Build.0 = Release|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|x86.ActiveCfg = Release|Any CPU
{C266761B-BC19-4BD7-9EE8-3AE2CE7DE7A4}.Release|x86.Build.0 = Release|Any CPU
- {42199427-9825-4A45-A3D1-5C3090C57035}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {42199427-9825-4A45-A3D1-5C3090C57035}.Debug|Any CPU.Build.0 = Debug|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Debug|x64.ActiveCfg = Debug|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Debug|x64.Build.0 = Debug|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Debug|x86.ActiveCfg = Debug|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Debug|x86.Build.0 = Debug|Any CPU
- {42199427-9825-4A45-A3D1-5C3090C57035}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {42199427-9825-4A45-A3D1-5C3090C57035}.Release|Any CPU.Build.0 = Release|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Release|x64.ActiveCfg = Release|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Release|x64.Build.0 = Release|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Release|x86.ActiveCfg = Release|Any CPU
{42199427-9825-4A45-A3D1-5C3090C57035}.Release|x86.Build.0 = Release|Any CPU
- {7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|Any CPU.Build.0 = Debug|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|x64.ActiveCfg = Debug|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|x64.Build.0 = Debug|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|x86.ActiveCfg = Debug|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Debug|x86.Build.0 = Debug|Any CPU
- {7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|Any CPU.Build.0 = Release|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|x64.ActiveCfg = Release|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|x64.Build.0 = Release|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|x86.ActiveCfg = Release|Any CPU
{7A73A95F-DCCC-4880-BA8C-AE8D9D48FA59}.Release|x86.Build.0 = Release|Any CPU
- {27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|Any CPU.Build.0 = Debug|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|x64.ActiveCfg = Debug|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|x64.Build.0 = Debug|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|x86.ActiveCfg = Debug|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Debug|x86.Build.0 = Debug|Any CPU
- {27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|Any CPU.Build.0 = Release|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|x64.ActiveCfg = Release|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|x64.Build.0 = Release|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|x86.ActiveCfg = Release|Any CPU
{27210DB6-811B-4D4E-A7E0-6488E5AFA733}.Release|x86.Build.0 = Release|Any CPU
- {096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
- {096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|Any CPU.Build.0 = Debug|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|x64.ActiveCfg = Debug|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|x64.Build.0 = Debug|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|x86.ActiveCfg = Debug|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Debug|x86.Build.0 = Debug|Any CPU
- {096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|Any CPU.ActiveCfg = Release|Any CPU
- {096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|Any CPU.Build.0 = Release|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|x64.ActiveCfg = Release|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|x64.Build.0 = Release|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|x86.ActiveCfg = Release|Any CPU
{096D661F-DEA7-4EAB-95BB-F6A0E0AF59FF}.Release|x86.Build.0 = Release|Any CPU
- {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Debug|Any CPU.ActiveCfg = Debug|Win32
{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Debug|x64.ActiveCfg = Debug|x64
{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Debug|x64.Build.0 = Debug|x64
{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Debug|x86.ActiveCfg = Debug|Win32
{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Debug|x86.Build.0 = Debug|Win32
- {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Release|Any CPU.ActiveCfg = Release|Win32
{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Release|x64.ActiveCfg = Release|x64
{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Release|x64.Build.0 = Release|x64
{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Release|x86.ActiveCfg = Release|Win32
{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}.Release|x86.Build.0 = Release|Win32
- {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Debug|Any CPU.ActiveCfg = Debug|Win32
{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Debug|x64.ActiveCfg = Debug|x64
{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Debug|x64.Build.0 = Debug|x64
{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Debug|x86.ActiveCfg = Debug|Win32
{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Debug|x86.Build.0 = Debug|Win32
- {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Release|Any CPU.ActiveCfg = Release|Win32
{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Release|x64.ActiveCfg = Release|x64
{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Release|x64.Build.0 = Release|x64
{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Release|x86.ActiveCfg = Release|Win32
{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}.Release|x86.Build.0 = Release|Win32
- {5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|Any CPU.ActiveCfg = Debug|Win32
{5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|x64.ActiveCfg = Debug|x64
{5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|x64.Build.0 = Debug|x64
{5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|x86.ActiveCfg = Debug|Win32
{5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|x86.Build.0 = Debug|Win32
- {5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|Any CPU.ActiveCfg = Release|Win32
{5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|x64.ActiveCfg = Release|x64
{5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|x64.Build.0 = Release|x64
{5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|x86.ActiveCfg = Release|Win32
{5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|x86.Build.0 = Release|Win32
- {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Debug|Any CPU.ActiveCfg = Debug|Win32
{C50254F2-654A-48DE-AF5B-20605AEF8D10}.Debug|x64.ActiveCfg = Debug|x64
{C50254F2-654A-48DE-AF5B-20605AEF8D10}.Debug|x64.Build.0 = Debug|x64
{C50254F2-654A-48DE-AF5B-20605AEF8D10}.Debug|x86.ActiveCfg = Debug|Win32
{C50254F2-654A-48DE-AF5B-20605AEF8D10}.Debug|x86.Build.0 = Debug|Win32
- {C50254F2-654A-48DE-AF5B-20605AEF8D10}.Release|Any CPU.ActiveCfg = Release|Win32
{C50254F2-654A-48DE-AF5B-20605AEF8D10}.Release|x64.ActiveCfg = Release|x64
{C50254F2-654A-48DE-AF5B-20605AEF8D10}.Release|x64.Build.0 = Release|x64
{C50254F2-654A-48DE-AF5B-20605AEF8D10}.Release|x86.ActiveCfg = Release|Win32
{C50254F2-654A-48DE-AF5B-20605AEF8D10}.Release|x86.Build.0 = Release|Win32
- {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Debug|Any CPU.ActiveCfg = Debug|Win32
{85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Debug|x64.ActiveCfg = Debug|x64
{85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Debug|x64.Build.0 = Debug|x64
{85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Debug|x86.ActiveCfg = Debug|Win32
{85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Debug|x86.Build.0 = Debug|Win32
- {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Release|Any CPU.ActiveCfg = Release|Win32
{85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Release|x64.ActiveCfg = Release|x64
{85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Release|x64.Build.0 = Release|x64
{85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Release|x86.ActiveCfg = Release|Win32
{85882748-DD71-4D2B-9E5A-03AF8C8D91B7}.Release|x86.Build.0 = Release|Win32
- {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Debug|Any CPU.ActiveCfg = Debug|Win32
{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Debug|x64.ActiveCfg = Debug|x64
{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Debug|x64.Build.0 = Debug|x64
{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Debug|x86.ActiveCfg = Debug|Win32
{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Debug|x86.Build.0 = Debug|Win32
- {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Release|Any CPU.ActiveCfg = Release|Win32
{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Release|x64.ActiveCfg = Release|x64
{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Release|x64.Build.0 = Release|x64
{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Release|x86.ActiveCfg = Release|Win32
{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}.Release|x86.Build.0 = Release|Win32
- {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Debug|Any CPU.ActiveCfg = Debug|Win32
{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Debug|x64.ActiveCfg = Debug|x64
{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Debug|x64.Build.0 = Debug|x64
{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Debug|x86.ActiveCfg = Debug|Win32
{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Debug|x86.Build.0 = Debug|Win32
- {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Release|Any CPU.ActiveCfg = Release|Win32
{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Release|x64.ActiveCfg = Release|x64
{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Release|x64.Build.0 = Release|x64
{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Release|x86.ActiveCfg = Release|Win32
{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}.Release|x86.Build.0 = Release|Win32
- {B797917B-6842-467C-8B14-E00B76A91247}.Debug|Any CPU.ActiveCfg = Debug|Win32
{B797917B-6842-467C-8B14-E00B76A91247}.Debug|x64.ActiveCfg = Debug|x64
{B797917B-6842-467C-8B14-E00B76A91247}.Debug|x64.Build.0 = Debug|x64
{B797917B-6842-467C-8B14-E00B76A91247}.Debug|x86.ActiveCfg = Debug|Win32
{B797917B-6842-467C-8B14-E00B76A91247}.Debug|x86.Build.0 = Debug|Win32
- {B797917B-6842-467C-8B14-E00B76A91247}.Release|Any CPU.ActiveCfg = Release|Win32
{B797917B-6842-467C-8B14-E00B76A91247}.Release|x64.ActiveCfg = Release|x64
{B797917B-6842-467C-8B14-E00B76A91247}.Release|x64.Build.0 = Release|x64
{B797917B-6842-467C-8B14-E00B76A91247}.Release|x86.ActiveCfg = Release|Win32
{B797917B-6842-467C-8B14-E00B76A91247}.Release|x86.Build.0 = Release|Win32
- {795B1B0E-4EC8-469D-B641-E26324266FBF}.Debug|Any CPU.ActiveCfg = Debug|Win32
{795B1B0E-4EC8-469D-B641-E26324266FBF}.Debug|x64.ActiveCfg = Debug|x64
{795B1B0E-4EC8-469D-B641-E26324266FBF}.Debug|x64.Build.0 = Debug|x64
{795B1B0E-4EC8-469D-B641-E26324266FBF}.Debug|x86.ActiveCfg = Debug|Win32
{795B1B0E-4EC8-469D-B641-E26324266FBF}.Debug|x86.Build.0 = Debug|Win32
- {795B1B0E-4EC8-469D-B641-E26324266FBF}.Release|Any CPU.ActiveCfg = Release|Win32
{795B1B0E-4EC8-469D-B641-E26324266FBF}.Release|x64.ActiveCfg = Release|x64
{795B1B0E-4EC8-469D-B641-E26324266FBF}.Release|x64.Build.0 = Release|x64
{795B1B0E-4EC8-469D-B641-E26324266FBF}.Release|x86.ActiveCfg = Release|Win32
{795B1B0E-4EC8-469D-B641-E26324266FBF}.Release|x86.Build.0 = Release|Win32
- {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Debug|Any CPU.ActiveCfg = Debug|Win32
{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Debug|x64.ActiveCfg = Debug|x64
{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Debug|x64.Build.0 = Debug|x64
{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Debug|x86.ActiveCfg = Debug|Win32
{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Debug|x86.Build.0 = Debug|Win32
- {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Release|Any CPU.ActiveCfg = Release|Win32
{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Release|x64.ActiveCfg = Release|x64
{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Release|x64.Build.0 = Release|x64
{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}.Release|x86.ActiveCfg = Release|Win32
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/DotNetUnmanagedApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/DotNetUnmanagedApi.vcxproj 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/DotNetUnmanagedApi.vcxproj 2022-10-10 10:58:26 UTC (rev 9976)
@@ -19,12 +19,12 @@
<PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="Configuration">
<ConfigurationType>DynamicLibrary</ConfigurationType>
<CharacterSet>Unicode</CharacterSet>
- <PlatformToolset>v140</PlatformToolset>
+ <PlatformToolset>v142</PlatformToolset>
</PropertyGroup>
<PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="Configuration">
</PropertyGroup>
<Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
<ImportGroup Label="ExtensionSettings">
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApi.vcxproj 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApi.vcxproj 2022-10-10 10:58:26 UTC (rev 9976)
@@ -19,12 +19,12 @@
</PropertyGroup>
</PropertyGroup>
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApi.vcxproj 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApi.vcxproj 2022-10-10 10:58:26 UTC (rev 9976)
@@ -19,12 +19,12 @@
</PropertyGroup>
</PropertyGroup>
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApi.vcxproj 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApi.vcxproj 2022-10-10 10:58:26 UTC (rev 9976)
@@ -19,12 +19,12 @@
</PropertyGroup>
</PropertyGroup>
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj 2022-10-10 10:58:26 UTC (rev 9976)
@@ -19,12 +19,12 @@
</PropertyGroup>
</PropertyGroup>
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/Web/WebApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/Web/WebApi.vcxproj 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/Web/WebApi.vcxproj 2022-10-10 10:58:26 UTC (rev 9976)
@@ -19,12 +19,12 @@
</PropertyGroup>
</PropertyGroup>
Modified: trunk/MgDev/Bindings/src/Bindings/Java/JavaApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/Java/JavaApi.vcxproj 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/src/Bindings/Java/JavaApi.vcxproj 2022-10-10 10:58:26 UTC (rev 9976)
@@ -19,12 +19,12 @@
</PropertyGroup>
</PropertyGroup>
Modified: trunk/MgDev/Bindings/src/Bindings/Php/PhpApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/Php/PhpApi.vcxproj 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/src/Bindings/Php/PhpApi.vcxproj 2022-10-10 10:58:26 UTC (rev 9976)
@@ -19,12 +19,12 @@
</PropertyGroup>
</PropertyGroup>
Modified: trunk/MgDev/Bindings/src/IMake/IMake.vcxproj
--- trunk/MgDev/Bindings/src/IMake/IMake.vcxproj 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Bindings/src/IMake/IMake.vcxproj 2022-10-10 10:58:26 UTC (rev 9976)
@@ -13,17 +13,17 @@
<PropertyGroup Label="Globals">
<ProjectGuid>{B601F04C-0D42-4AFC-A092-B31185E2EA8C}</ProjectGuid>
<Keyword>Win32Proj</Keyword>
- <WindowsTargetPlatformVersion>8.1</WindowsTargetPlatformVersion>
+ <WindowsTargetPlatformVersion>10.0</WindowsTargetPlatformVersion>
</PropertyGroup>
<Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
<ConfigurationType>Application</ConfigurationType>
<CharacterSet>MultiByte</CharacterSet>
</PropertyGroup>
</PropertyGroup>
Modified: trunk/MgDev/Oem/oem.sln
--- trunk/MgDev/Oem/oem.sln 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Oem/oem.sln 2022-10-10 10:58:26 UTC (rev 9976)
@@ -1,6 +1,6 @@
-VisualStudioVersion = 16.0.30709.132
+VisualStudioVersion = 17.0.31903.59
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ACE", "ACE\ACE_wrappers\ace\ACE.vcxproj", "{BD537C9A-FECA-1BAD-6757-8A6363336A1C}"
EndProject
@@ -314,6 +314,14 @@
{9415DE9A-E01E-47C1-A159-EB1E1D4E518C}.Release|Win32.Build.0 = Release (Read-Write WChar LIB)|Win32
{9415DE9A-E01E-47C1-A159-EB1E1D4E518C}.Release|x64.ActiveCfg = Release (Read-Write WChar LIB)|x64
{9415DE9A-E01E-47C1-A159-EB1E1D4E518C}.Release|x64.Build.0 = Release (Read-Write WChar LIB)|x64
+ {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|Win32.ActiveCfg = Debug|Win32
+ {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|Win32.Build.0 = Debug|Win32
+ {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|x64.ActiveCfg = Debug|x64
+ {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Debug|x64.Build.0 = Debug|x64
+ {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|Win32.ActiveCfg = Release|Win32
+ {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|Win32.Build.0 = Release|Win32
+ {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x64.ActiveCfg = Release|x64
+ {B601F04C-0D42-4AFC-A092-B31185E2EA8C}.Release|x64.Build.0 = Release|x64
{DB542A13-DE6E-3E82-BA87-7AE2885324B1}.Debug|Win32.ActiveCfg = Debug|Win32
{DB542A13-DE6E-3E82-BA87-7AE2885324B1}.Debug|Win32.Build.0 = Debug|Win32
{DB542A13-DE6E-3E82-BA87-7AE2885324B1}.Debug|x64.ActiveCfg = Debug|x64
Index: trunk/MgDev/Portable
--- trunk/MgDev/Portable 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Portable 2022-10-10 10:58:26 UTC (rev 9976)
Property changes on: trunk/MgDev/Portable
## -14,5 +14,5 ##
/sandbox/jng/msvc2019/Desktop:9884-9896
/sandbox/jng/v30/Desktop:8215-8216,8218-8219
/sandbox/jng/vanilla_swig/Desktop:9812-9814
-/sandbox/jng/vanilla_swig/Portable:9815-9823
+/sandbox/jng/vanilla_swig/Portable:9815-9823,9825-9915
/sandbox/rfc94/Desktop:5099-5163
Modified: trunk/MgDev/Portable/MgPortable/MgPortable.vcxproj
--- trunk/MgDev/Portable/MgPortable/MgPortable.vcxproj 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Portable/MgPortable/MgPortable.vcxproj 2022-10-10 10:58:26 UTC (rev 9976)
@@ -21,7 +21,7 @@
<ProjectGuid>{CBC0339F-E68B-48BA-9059-945483BEBDCA}</ProjectGuid>
<RootNamespace>MgPortable</RootNamespace>
</PropertyGroup>
<PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
@@ -28,25 +28,25 @@
<WholeProgramOptimization>true</WholeProgramOptimization>
</PropertyGroup>
<PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
</PropertyGroup>
</PropertyGroup>
</PropertyGroup>
Index: trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2022-10-10 10:58:26 UTC (rev 9976)
Property changes on: trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
## -6,4 +6,5 ##
/sandbox/jng/createruntimemap/Server/src/Services/Mapping/MappingUtil.cpp:7486-7555
/sandbox/jng/flatten_exceptions/Server/src/Services/Mapping/MappingUtil.cpp:9743-9755
/sandbox/jng/ogc/Server/src/Services/Mapping/MappingUtil.cpp:9240-9255
+/sandbox/jng/vanilla_swig/Server/src/Services/Mapping/MappingUtil.cpp:9825-9915
/sandbox/rfc94/Server/src/Services/Mapping/MappingUtil.cpp:5099-5163
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml 2022-10-10 10:58:26 UTC (rev 9976)
@@ -3,28 +3,28 @@
<General>
<IconName>LayerDefinitionVector</IconName>
</General>
- <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
+ <Security>
<Inherited>true</Inherited>
</Security>
<Metadata>
<Simple>
- <Property xsi:noNamespaceSchemaLocation="Property-1.0.0.xsd">
+ <Property>
<Name>_Queryable</Name>
<Value>1</Value>
</Property>
+ <Property>
<Name>_Bounds</Name>
<Value><Bounds SRS="EPSG:4326" west="-87.74" south="43.68" east="-87.69" north="43.815"/></Value>
</Property>
+ <Property>
<Name>_Title</Name>
<Value>Parcels</Value>
</Property>
+ <Property>
<Name>_Opaque</Name>
<Value>0</Value>
</Property>
+ <Property>
<Name>_IsPublished</Name>
<Value>1</Value>
</Property>
Modified: trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp 2022-10-10 10:22:05 UTC (rev 9975)
+++ trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp 2022-10-10 10:58:26 UTC (rev 9976)
@@ -549,21 +549,26 @@
response.getWriter().write(templ);
response.setContentLength(templ.length());
+catch(MgUserNotFoundException e)
+ RequestAuthentication(response);
+ return;
+catch(MgUnauthorizedAccessException e)
+ return;
+catch(MgAuthenticationFailedException e)
+ return;
catch(MgException e)
- if (e.GetExceptionCode() == MgExceptionCodes.MgUnauthorizedAccessException ||
- e.GetExceptionCode() == MgExceptionCodes.MgUserNotFoundException ||
- e.GetExceptionCode() == MgExceptionCodes.MgAuthenticationFailedException)
- RequestAuthentication(response);
- return;
- else
- String msg = EscapeForHtml(e.GetExceptionMessage());
- response.getWriter().write(msg);
- response.setContentLength(msg.length());
+ String msg = EscapeForHtml(e.getExceptionMessage());
+ response.getWriter().write(msg);
+ response.setContentLength(msg.length());
catch(Exception ne)
More information about the mapguide-commits
