[mapguide-commits] r9982 - in trunk/MgDev: . Bindings Bindings/src/Bindings/Java Bindings/src/Bindings/Php Common Common/Foundation Common/Geometry Common/MapGuideCommon Common/MdfModel Common/MdfParser Common/PlatformBase Common/Renderers Common/Security Common/Stylization Portable/DesktopUnmanagedApi/JavaApiEx Server Server/src Server/src/Common Server/src/Common/Base Server/src/Common/Cache Server/src/Common/Manager Server/src/Common/Thread Server/src/Core Server/src/Gws Server/src/Gws/GwsCommon Server/src/Gws/GwsQueryEngine Server/src/Gws/GwsResource Server/src/Services Server/src/Services/Drawing Server/src/Services/Feature Server/src/Services/Kml Server/src/Services/Mapping Server/src/Services/Profiling Server/src/Services/Rendering Server/src/Services/Resource Server/src/Services/ServerAdmin Server/src/Services/Site Server/src/Services/Tile Server/src/UnitTesting Web Web/src Web/src/ApacheAgent Web/src/CgiAgent Web/src/HttpHandler Web/src/WebApp Web/src/WebSupport
svn_mapguide at osgeo.org
Mon Oct 10 07:07:46 PDT 2022
Author: jng
Date: 2022-10-10 07:07:45 -0700 (Mon, 10 Oct 2022)
New Revision: 9982
Removed:
trunk/MgDev/Bindings/src/Bindings/Java/Makefile.am
trunk/MgDev/Bindings/src/Bindings/Php/Makefile.am
trunk/MgDev/Common/Foundation/Makefile.am
trunk/MgDev/Common/Geometry/Makefile.am
trunk/MgDev/Common/Makefile.am
trunk/MgDev/Common/MapGuideCommon/Makefile.am
trunk/MgDev/Common/MdfModel/Makefile.am
trunk/MgDev/Common/MdfParser/Makefile.am
trunk/MgDev/Common/PlatformBase/Makefile.am
trunk/MgDev/Common/Renderers/Makefile.am
trunk/MgDev/Common/Security/Makefile.am
trunk/MgDev/Common/Stylization/Makefile.am
trunk/MgDev/Makefile.am
trunk/MgDev/Portable/DesktopUnmanagedApi/JavaApiEx/Makefile.am
trunk/MgDev/Server/Makefile.am
trunk/MgDev/Server/src/Common/Base/Makefile.am
trunk/MgDev/Server/src/Common/Cache/Makefile.am
trunk/MgDev/Server/src/Common/Makefile.am
trunk/MgDev/Server/src/Common/Manager/Makefile.am
trunk/MgDev/Server/src/Common/Thread/Makefile.am
trunk/MgDev/Server/src/Core/Makefile.am
trunk/MgDev/Server/src/Gws/GwsCommon/Makefile.am
trunk/MgDev/Server/src/Gws/GwsQueryEngine/Makefile.am
trunk/MgDev/Server/src/Gws/GwsResource/Makefile.am
trunk/MgDev/Server/src/Gws/Makefile.am
trunk/MgDev/Server/src/Makefile.am
trunk/MgDev/Server/src/Services/Drawing/Makefile.am
trunk/MgDev/Server/src/Services/Feature/Makefile.am
trunk/MgDev/Server/src/Services/Kml/Makefile.am
trunk/MgDev/Server/src/Services/Makefile.am
trunk/MgDev/Server/src/Services/Mapping/Makefile.am
trunk/MgDev/Server/src/Services/Profiling/Makefile.am
trunk/MgDev/Server/src/Services/Rendering/Makefile.am
trunk/MgDev/Server/src/Services/Resource/Makefile.am
trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am
trunk/MgDev/Server/src/Services/Site/Makefile.am
trunk/MgDev/Server/src/Services/Tile/Makefile.am
trunk/MgDev/Server/src/UnitTesting/Makefile.am
trunk/MgDev/Web/Makefile.am
trunk/MgDev/Web/src/ApacheAgent/Makefile.am
trunk/MgDev/Web/src/CgiAgent/Makefile.am
trunk/MgDev/Web/src/HttpHandler/Makefile.am
trunk/MgDev/Web/src/Makefile.am
trunk/MgDev/Web/src/WebApp/Makefile.am
trunk/MgDev/Web/src/WebSupport/Makefile.am
trunk/MgDev/acinclude.m4
trunk/MgDev/aclocal.m4
trunk/MgDev/config.guess
trunk/MgDev/config.sub
trunk/MgDev/configure
trunk/MgDev/configure.in
trunk/MgDev/depcomp
trunk/MgDev/install-sh
trunk/MgDev/ltmain.sh
trunk/MgDev/missing
trunk/MgDev/mkinstalldirs
trunk/MgDev/Bindings/TODO.txt
Remove autotools files. These files have been in a long state of disrepair and we build things on Linux via CMake anyways. No point maintaining 2 build systems on Linux
Fixes #2853
Modified: trunk/MgDev/Bindings/TODO.txt
--- trunk/MgDev/Bindings/TODO.txt 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Bindings/TODO.txt 2022-10-10 14:07:45 UTC (rev 9982)
@@ -39,7 +39,7 @@
- Java binding
- [ ] Running javadoc against the generated sources produces many errors. See if we can fix them
- [x] Verify test suite still passes (Windows)
- - [ ] Tomcat/JSP now working on Linux, but none of the JSP code compiles (lots of <MapGuide API symbol> cannot be resolved)
+ - [x] Tomcat/JSP now working on Linux, but none of the JSP code compiles (lots of <MapGuide API symbol> cannot be resolved)
- [ ] Verify test suite still passes (Linux)
- [ ] Migrate to SWIG 4.1.0 (https://github.com/jumpinjackie/mapguide-api-bindings/issues/36)
- [x] SWIG 4.1 has not been released yet, so migrate to swig git master
@@ -125,7 +125,7 @@
- .net: docfx (https://dotnet.github.io/docfx/)
- [ ] Implement a static umbrella landing site that is the gateway to the 3 generated outputs
- mg-desktop
- - [ ] Rename to MgPortable/mg-portable
+ - [x] Rename to MgPortable/mg-portable
- [ ] Add SWIG glue library that layers on top of the existing Foundation/Geometry/PlatformBase glue projects
- [ ] Add new OSGeo.MapGuide.Portable .net project for the .net portion of the SWIG glue
- [ ] Implement a sample asp.net core application that confirms the feasibility of using mg-portable for web applications in addition to desktop applications
@@ -133,8 +133,9 @@
- ( ) Migrate the viewer winforms library to target .net 6.0
- ( ) Or maintain 2 versions of this library, a new .net 6.0 version of the library and a legacy full framework version
- [ ] Port over Java binding
+ - [ ] Fix up run_tests.bat/run_tests.sh to work with new layout
- Old code cleanup/consolidation
- - [ ] Remove old IMake
- - [ ] Remove old binding projects from WebTier
+ - [x] Remove old IMake
+ - [x] Remove old binding projects from WebTier
- [ ] Fold FoundationTest into mgserver test suite
- - [ ] Remove SQLite and its related projects from Oem
\ No newline at end of file
+ - [x] Remove SQLite and its related projects from Oem
Deleted: trunk/MgDev/Bindings/src/Bindings/Java/Makefile.am
--- trunk/MgDev/Bindings/src/Bindings/Java/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Bindings/src/Bindings/Java/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,468 +0,0 @@
-AUTOMAKE_OPTIONS = foreign
-EXTRA_DIST = getclassid.code \
- catchall.code \
- java.i \
- JavaApiEx.rc \
- JavaApiEx.vcproj \
- org/osgeo/mapguide/AppThrowable.java \
- org/osgeo/mapguide/MgBase64.java \
- org/osgeo/mapguide/MgLocalizer.java
-prefix=@prefix@/webserverextensions
-INCLUDES = -I../../../Common/MdfModel \
- -I../../../Common/Foundation \
- -I../../../Common/Geometry \
- -I../../../Common/PlatformBase \
- -I../../../Common/MapGuideCommon \
- -I$(JAVA_HOME)/include \
- -I$(JAVA_HOME)/include/linux \
- -I../../../Oem/ACE/ACE_wrappers \
- -I../HttpHandler \
- -I../WebSupport \
- -I../WebApp \
- -I../../../Oem/dbxml/xerces-c-src/src
-BUILT_SOURCES = MgApi_wrap.cpp
-lib_LTLIBRARIES = libMapGuideJavaApiEx.la
-nodist_libMapGuideJavaApiEx_la_SOURCES = MgApi_wrap.cpp
-AM_CXXFLAGS = @CXXFLAGS@ -fno-strict-aliasing -fno-var-tracking-assignments -DJAVA
-libMapGuideJavaApiEx_la_LIBADD = \
- -lACE \
- -lMgFoundation \
- -lMgGeometry \
- -lMgPlatformBase \
- -lMgMapGuideCommon \
- -lMgHttpHandler \
- -lMgMdfModel \
- -lMgMdfParser \
- -lxerces-c \
- -lMgWebApp
-libMapGuideJavaApiEx_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../../../Oem/ACE/ACE_wrappers/ace \
- -L../../../Common/MdfModel \
- -L../../../Common/MdfParser \
- -L../../../Common/Foundation \
- -L../../../Common/Geometry \
- -L../../../Common/PlatformBase \
- -L../../../Common/MapGuideCommon \
- -L../HttpHandler \
- -L../WebApp \
- -L../../../Oem/dbxml/install/lib
-MgApi_wrap.cpp : \
- ../WebApp/WebApp.h \
- ../WebSupport/InitializeWebTier.cpp \
- ../../../Common/MdfModel/UnicodeString.h \
- ../HttpHandler/HttpHandlerApiDllExport.h \
- ../HttpHandler/HttpHandler.h \
- ../../../Common/Foundation/System/Object.h \
- ../../../Common/Foundation/System/Disposable.h \
- ../../../Common/Foundation/System/GuardDisposable.h \
- ../../../Common/Foundation/System/Serializable.h \
- ../../../Common/Foundation/System/NamedSerializable.h \
- ../../../Common/Foundation/Data/Collection.h \
- ../../../Common/Foundation/Data/Property.h \
- ../../../Common/Foundation/System/DisposableCollection.h \
- ../../../Common/Foundation/Data/BatchPropertyCollection.h \
- ../../../Common/Foundation/Data/ByteReader.h \
- ../../../Common/Foundation/Data/ByteSource.h \
- ../../../Common/Foundation/Data/ByteSink.h \
- ../../../Common/Foundation/Data/DateTime.h \
- ../../../Common/Foundation/Data/NullableProperty.h \
- ../../../Common/Foundation/Data/PropertyCollection.h \
- ../../../Common/Foundation/Data/PropertyDefinition.h \
- ../../../Common/Foundation/Data/StringCollection.h \
- ../../../Common/Foundation/Data/StringProperty.h \
- ../../../Common/Foundation/Data/FeaturePropertyType.h \
- ../../../Common/Foundation/Data/MimeType.h \
- ../../../Common/Foundation/Data/PropertyType.h \
- ../../../Common/Foundation/Exception/Exception.h \
- ../../../Common/Foundation/Exception/SystemException.h \
- ../../../Common/Foundation/Exception/IoException.h \
- ../../../Common/Foundation/Exception/FileIoException.h \
- ../../../Common/Foundation/Exception/ApplicationException.h \
- ../../../Common/Foundation/Exception/ThirdPartyException.h \
- ../../../Common/Foundation/Exception/StreamIoException.h \
- ../../../Common/Foundation/Exception/OutOfRangeException.h \
- ../../../Common/Foundation/Exception/ArgumentOutOfRangeException.h \
- ../../../Common/Foundation/Exception/ClassNotFoundException.h \
- ../../../Common/Foundation/Exception/ConfigurationException.h \
- ../../../Common/Foundation/Exception/ConfigurationLoadFailedException.h \
- ../../../Common/Foundation/Exception/ConfigurationSaveFailedException.h \
- ../../../Common/Foundation/Exception/DateTimeException.h \
- ../../../Common/Foundation/Exception/DecryptionException.h \
- ../../../Common/Foundation/Exception/DirectoryNotFoundException.h \
- ../../../Common/Foundation/Exception/DivideByZeroException.h \
- ../../../Common/Foundation/Exception/DomainException.h \
- ../../../Common/Foundation/Exception/DuplicateDirectoryException.h \
- ../../../Common/Foundation/Exception/DuplicateFileException.h \
- ../../../Common/Foundation/Exception/DuplicateObjectException.h \
- ../../../Common/Foundation/Exception/EncryptionException.h \
- ../../../Common/Foundation/Exception/FileNotFoundException.h \
- ../../../Common/Foundation/Exception/IndexOutOfRangeException.h \
- ../../../Common/Foundation/Exception/InvalidArgumentException.h \
- ../../../Common/Foundation/Exception/InvalidCastException.h \
- ../../../Common/Foundation/Exception/InvalidOperationException.h \
- ../../../Common/Foundation/Exception/InvalidPropertyTypeException.h \
- ../../../Common/Foundation/Exception/InvalidStreamHeaderException.h \
- ../../../Common/Foundation/Exception/LengthException.h \
- ../../../Common/Foundation/Exception/LogicException.h \
- ../../../Common/Foundation/Exception/NotFiniteNumberException.h \
- ../../../Common/Foundation/Exception/NotImplementedException.h \
- ../../../Common/Foundation/Exception/NullArgumentException.h \
- ../../../Common/Foundation/Exception/NullPropertyValueException.h \
- ../../../Common/Foundation/Exception/NullReferenceException.h \
- ../../../Common/Foundation/Exception/ObjectNotFoundException.h \
- ../../../Common/Foundation/Exception/OutOfMemoryException.h \
- ../../../Common/Foundation/Exception/OverflowException.h \
- ../../../Common/Foundation/Exception/PlatformNotSupportedException.h \
- ../../../Common/Foundation/Exception/ResourcesException.h \
- ../../../Common/Foundation/Exception/ResourcesLoadFailedException.h \
- ../../../Common/Foundation/Exception/RuntimeException.h \
- ../../../Common/Foundation/Exception/TemporaryFileNotAvailableException.h \
- ../../../Common/Foundation/Exception/UnclassifiedException.h \
- ../../../Common/Foundation/Exception/UnderflowException.h \
- ../../../Common/Foundation/Exception/XmlException.h \
- ../../../Common/Foundation/Exception/XmlParserException.h \
- ../../../Common/Geometry/GeometricEntity.h \
- ../../../Common/Geometry/Geometry.h \
- ../../../Common/Geometry/GeometryComponent.h \
- ../../../Common/Geometry/Curve.h \
- ../../../Common/Geometry/CurveSegment.h \
- ../../../Common/Geometry/Ring.h \
- ../../../Common/Geometry/Region.h \
- ../../../Common/Geometry/AgfReaderWriter.h \
- ../../../Common/Geometry/AggregateGeometry.h \
- ../../../Common/Geometry/ArcSegment.h \
- ../../../Common/Geometry/Coordinate.h \
- ../../../Common/Geometry/CoordinateCollection.h \
- ../../../Common/Geometry/CoordinateIterator.h \
- ../../../Common/Geometry/CoordinateXY.h \
- ../../../Common/Geometry/CoordinateXYM.h \
- ../../../Common/Geometry/CoordinateXYZ.h \
- ../../../Common/Geometry/CoordinateXYZM.h \
- ../../../Common/Geometry/CurvePolygon.h \
- ../../../Common/Geometry/CurvePolygonCollection.h \
- ../../../Common/Geometry/CurveRing.h \
- ../../../Common/Geometry/CurveRingCollection.h \
- ../../../Common/Geometry/CurveSegmentCollection.h \
- ../../../Common/Geometry/CurveString.h \
- ../../../Common/Geometry/CurveStringCollection.h \
- ../../../Common/Geometry/Envelope.h \
- ../../../Common/Geometry/GeometryCollection.h \
- ../../../Common/Geometry/GeometryFactory.h \
- ../../../Common/Geometry/LinearRing.h \
- ../../../Common/Geometry/LinearRingCollection.h \
- ../../../Common/Geometry/LinearSegment.h \
- ../../../Common/Geometry/LineString.h \
- ../../../Common/Geometry/LineStringCollection.h \
- ../../../Common/Geometry/Measure.h \
- ../../../Common/Geometry/MultiCurvePolygon.h \
- ../../../Common/Geometry/MultiCurveString.h \
- ../../../Common/Geometry/MultiGeometry.h \
- ../../../Common/Geometry/MultiLineString.h \
- ../../../Common/Geometry/MultiPoint.h \
- ../../../Common/Geometry/MultiPolygon.h \
- ../../../Common/Geometry/Point.h \
- ../../../Common/Geometry/PointCollection.h \
- ../../../Common/Geometry/Polygon.h \
- ../../../Common/Geometry/PolygonCollection.h \
- ../../../Common/Geometry/Transform.h \
- ../../../Common/Geometry/WktReaderWriter.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystem.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryBase.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCatalog.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCategory.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCategoryDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDatumDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefParams.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformDefParams.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryUtility.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoid.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoidDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEnum.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEnumInteger32.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFactory.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFilter.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFilterInteger32.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFormatConverter.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformation.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMathComparator.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionInformation.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemTransform.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitInformation.h \
- ../../../Common/Geometry/Exception/CoordinateSystemComputationFailedException.h \
- ../../../Common/Geometry/Exception/CoordinateSystemConversionFailedException.h \
- ../../../Common/Geometry/Exception/CoordinateSystemInitializationFailedException.h \
- ../../../Common/Geometry/Exception/CoordinateSystemLoadFailedException.h \
- ../../../Common/Geometry/Exception/CoordinateSystemMeasureFailedException.h \
- ../../../Common/Geometry/Exception/CoordinateSystemTransformFailedException.h \
- ../../../Common/Geometry/Exception/GeometryException.h \
- ../../../Common/Geometry/Exception/InvalidCoordinateSystemException.h \
- ../../../Common/Geometry/Exception/InvalidCoordinateSystemTypeException.h \
- ../../../Common/Geometry/Exception/InvalidCoordinateSystemUnitsException.h \
- ../../../Common/Geometry/CoordinateDimension.h \
- ../../../Common/Geometry/GeometricEntityType.h \
- ../../../Common/Geometry/GeometricPathInstructionType.h \
- ../../../Common/Geometry/GeometryComponentType.h \
- ../../../Common/Geometry/GeometryType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCodeFormat.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionFormatType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionLogicalType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionParameterType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitCode.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemWktFlavor.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformationMethod.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h \
- ../../../Common/PlatformBase/Data/BlobProperty.h \
- ../../../Common/PlatformBase/Data/BooleanProperty.h \
- ../../../Common/PlatformBase/Data/ByteProperty.h \
- ../../../Common/PlatformBase/Data/ClobProperty.h \
- ../../../Common/PlatformBase/Data/Color.h \
- ../../../Common/PlatformBase/Data/DateTimeProperty.h \
- ../../../Common/PlatformBase/Data/DoubleProperty.h \
- ../../../Common/PlatformBase/Data/Int16Property.h \
- ../../../Common/PlatformBase/Data/Int32Property.h \
- ../../../Common/PlatformBase/Data/Int64Property.h \
- ../../../Common/PlatformBase/Data/IntCollection.h \
- ../../../Common/PlatformBase/Data/PropertyDefinitionCollection.h \
- ../../../Common/PlatformBase/Data/SingleProperty.h \
- ../../../Common/PlatformBase/Data/StringPropertyCollection.h \
- ../../../Common/PlatformBase/Exception/ArrayTypeMismatchException.h \
- ../../../Common/PlatformBase/Exception/DuplicateResourceDataException.h \
- ../../../Common/PlatformBase/Exception/DuplicateResourceException.h \
- ../../../Common/PlatformBase/Exception/EmptyFeatureSetException.h \
- ../../../Common/PlatformBase/Exception/FdoException.h \
- ../../../Common/PlatformBase/Exception/FeatureServiceException.h \
- ../../../Common/PlatformBase/Exception/InvalidMapDefinitionException.h \
- ../../../Common/PlatformBase/Exception/InvalidRepositoryNameException.h \
- ../../../Common/PlatformBase/Exception/InvalidRepositoryTypeException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourceDataNameException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourceDataTypeException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourceNameException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourcePathException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourcePreProcessingTypeException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourceTypeException.h \
- ../../../Common/PlatformBase/Exception/LayerNotFoundException.h \
- ../../../Common/PlatformBase/Exception/ResourceBusyException.h \
- ../../../Common/PlatformBase/Exception/ResourceDataNotFoundException.h \
- ../../../Common/PlatformBase/Exception/ResourceNotFoundException.h \
- ../../../Common/PlatformBase/Exception/ServiceNotAvailableException.h \
- ../../../Common/PlatformBase/Exception/ServiceNotSupportedException.h \
- ../../../Common/PlatformBase/Exception/UserNotFoundException.h \
- ../../../Common/PlatformBase/Services/FeatureCommand.h \
- ../../../Common/PlatformBase/Services/FeatureQueryOptions.h \
- ../../../Common/PlatformBase/Services/FeatureSourceParams.h \
- ../../../Common/PlatformBase/Services/Reader.h \
- ../../../Common/PlatformBase/Services/Service.h \
- ../../../Common/PlatformBase/Services/BaseService.h \
- ../../../Common/PlatformBase/Services/ClassDefinition.h \
- ../../../Common/PlatformBase/Services/ClassDefinitionCollection.h \
- ../../../Common/PlatformBase/Services/FileFeatureSourceParams.h \
- ../../../Common/PlatformBase/Services/DataPropertyDefinition.h \
- ../../../Common/PlatformBase/Services/DataReader.h \
- ../../../Common/PlatformBase/Services/DeleteFeatures.h \
- ../../../Common/PlatformBase/Services/FeatureAggregateOptions.h \
- ../../../Common/PlatformBase/Services/FeatureCommandCollection.h \
- ../../../Common/PlatformBase/Services/FeatureProperty.h \
- ../../../Common/PlatformBase/Services/FeatureReader.h \
- ../../../Common/PlatformBase/Services/FeatureSchema.h \
- ../../../Common/PlatformBase/Services/FeatureSchemaCollection.h \
- ../../../Common/PlatformBase/Services/FeatureService.h \
- ../../../Common/PlatformBase/Services/GeometricPropertyDefinition.h \
- ../../../Common/PlatformBase/Services/GeometryProperty.h \
- ../../../Common/PlatformBase/Services/GeometryTypeInfo.h \
- ../../../Common/PlatformBase/Services/GwsFeatureReader.h \
- ../../../Common/PlatformBase/Services/InsertFeatures.h \
- ../../../Common/PlatformBase/Services/LongTransactionReader.h \
- ../../../Common/PlatformBase/Services/ObjectPropertyDefinition.h \
- ../../../Common/PlatformBase/Services/Parameter.h \
- ../../../Common/PlatformBase/Services/ParameterCollection.h \
- ../../../Common/PlatformBase/Services/Raster.h \
- ../../../Common/PlatformBase/Services/RasterProperty.h \
- ../../../Common/PlatformBase/Services/RasterPropertyDefinition.h \
- ../../../Common/PlatformBase/Services/Resource.h \
- ../../../Common/PlatformBase/Services/ResourceIdentifier.h \
- ../../../Common/PlatformBase/Services/ResourceService.h \
- ../../../Common/PlatformBase/Services/SpatialContextReader.h \
- ../../../Common/PlatformBase/Services/SqlDataReader.h \
- ../../../Common/PlatformBase/Services/Transaction.h \
- ../../../Common/PlatformBase/Services/UpdateFeatures.h \
- ../../../Common/PlatformBase/Services/Warnings.h \
- ../../../Common/PlatformBase/Services/BaseServiceDefs.h \
- ../../../Common/PlatformBase/Services/FeatureCommandType.h \
- ../../../Common/PlatformBase/Services/FeatureGeometricType.h \
- ../../../Common/PlatformBase/Services/FeatureSpatialOperations.h \
- ../../../Common/PlatformBase/Services/ObjectPropertyType.h \
- ../../../Common/PlatformBase/Services/OrderingOption.h \
- ../../../Common/PlatformBase/Services/ParameterDirection.h \
- ../../../Common/PlatformBase/Services/RasterTypes.h \
- ../../../Common/PlatformBase/Services/ReaderType.h \
- ../../../Common/PlatformBase/Services/ResourceDefs.h \
- ../../../Common/PlatformBase/Services/SpatialContextExtentType.h \
- ../../../Common/PlatformBase/MapLayer/LayerBase.h \
- ../../../Common/PlatformBase/MapLayer/LayerCollection.h \
- ../../../Common/PlatformBase/MapLayer/LayerGroup.h \
- ../../../Common/PlatformBase/MapLayer/LayerGroupCollection.h \
- ../../../Common/PlatformBase/MapLayer/MapBase.h \
- ../../../Common/PlatformBase/MapLayer/MapCollection.h \
- ../../../Common/PlatformBase/MapLayer/ReadOnlyLayerCollection.h \
- ../../../Common/PlatformBase/MapLayer/SelectionBase.h \
- ../../../Common/PlatformBase/MapLayer/LayerGroupType.h \
- ../../../Common/PlatformBase/MapLayer/LayerType.h \
- ../../../Common/MapGuideCommon/Exception/AuthenticationFailedException.h \
- ../../../Common/MapGuideCommon/Exception/ConnectionFailedException.h \
- ../../../Common/MapGuideCommon/Exception/ConnectionNotOpenException.h \
- ../../../Common/MapGuideCommon/Exception/DbException.h \
- ../../../Common/MapGuideCommon/Exception/DbXmlException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateGroupException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateNameException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateParameterException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateRepositoryException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateRoleException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateServerException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateSessionException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateUserException.h \
- ../../../Common/MapGuideCommon/Exception/DwfException.h \
- ../../../Common/MapGuideCommon/Exception/DwfSectionNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/DwfSectionResourceNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/EndOfStreamException.h \
- ../../../Common/MapGuideCommon/Exception/GroupNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidDwfPackageException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidDwfSectionException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidFeatureSourceException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidIpAddressException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidLicenseException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidLogEntryException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidPasswordException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutFontSizeUnitsException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutPositionUnitsException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutSizeUnitsException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidServerNameException.h \
- ../../../Common/MapGuideCommon/Exception/LicenseException.h \
- ../../../Common/MapGuideCommon/Exception/LicenseExpiredException.h \
- ../../../Common/MapGuideCommon/Exception/OperationProcessingException.h \
- ../../../Common/MapGuideCommon/Exception/ParameterNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/PathTooLongException.h \
- ../../../Common/MapGuideCommon/Exception/PortNotAvailableException.h \
- ../../../Common/MapGuideCommon/Exception/PrintToScaleModeNotSelectedException.h \
- ../../../Common/MapGuideCommon/Exception/RepositoryCreationFailedException.h \
- ../../../Common/MapGuideCommon/Exception/RepositoryNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/RepositoryNotOpenException.h \
- ../../../Common/MapGuideCommon/Exception/RepositoryOpenFailedException.h \
- ../../../Common/MapGuideCommon/Exception/RoleNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/ServerNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/ServerNotOnlineException.h \
- ../../../Common/MapGuideCommon/Exception/SessionExpiredException.h \
- ../../../Common/MapGuideCommon/Exception/SessionNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/UnauthorizedAccessException.h \
- ../../../Common/MapGuideCommon/Exception/UriFormatException.h \
- ../../../Common/MapGuideCommon/Services/DrawingService.h \
- ../../../Common/MapGuideCommon/Services/DwfVersion.h \
- ../../../Common/MapGuideCommon/Services/FeatureInformation.h \
- ../../../Common/MapGuideCommon/Services/KmlService.h \
- ../../../Common/MapGuideCommon/Services/Layout.h \
- ../../../Common/MapGuideCommon/Services/MappingService.h \
- ../../../Common/MapGuideCommon/Services/MapPlot.h \
- ../../../Common/MapGuideCommon/Services/MapPlotCollection.h \
- ../../../Common/MapGuideCommon/Services/PackageStatusInformation.h \
- ../../../Common/MapGuideCommon/Services/PlotSpecification.h \
- ../../../Common/MapGuideCommon/Services/ProfilingService.h \
- ../../../Common/MapGuideCommon/Services/RenderingOptions.h \
- ../../../Common/MapGuideCommon/Services/RenderingService.h \
- ../../../Common/MapGuideCommon/Services/ServerAdmin.h \
- ../../../Common/MapGuideCommon/Services/Site.h \
- ../../../Common/MapGuideCommon/Services/SiteConnection.h \
- ../../../Common/MapGuideCommon/Services/SiteInfo.h \
- ../../../Common/MapGuideCommon/Services/TileService.h \
- ../../../Common/MapGuideCommon/System/UserInformation.h \
- ../../../Common/MapGuideCommon/MapLayer/Layer.h \
- ../../../Common/MapGuideCommon/MapLayer/Map.h \
- ../../../Common/MapGuideCommon/MapLayer/Selection.h \
- ../../../Common/MapGuideCommon/Services/MappingDefs.h \
- ../../../Common/MapGuideCommon/Services/MapPlotInstruction.h \
- ../../../Common/MapGuideCommon/Services/ServerAdminDefs.h \
- ../../../Common/MapGuideCommon/Services/UnitType.h \
- ../../../Common/MapGuideCommon/System/ConfigProperties.h \
- ../WebApp/WebCommand.h \
- ../WebApp/WebUiTargetCommand.h \
- ../WebApp/WebWidget.h \
- ../WebApp/WebWidgetCollection.h \
- ../WebApp/WebUiPane.h \
- ../WebApp/WebUiSizablePane.h \
- ../WebApp/WebBufferCommand.h \
- ../WebApp/WebCommandCollection.h \
- ../WebApp/WebCommandWidget.h \
- ../WebApp/WebContextMenu.h \
- ../WebApp/WebFlyoutWidget.h \
- ../WebApp/WebGetPrintablePageCommand.h \
- ../WebApp/WebHelpCommand.h \
- ../WebApp/WebInformationPane.h \
- ../WebApp/WebInvokeScriptCommand.h \
- ../WebApp/WebInvokeUrlCommand.h \
- ../WebApp/WebLayout.h \
- ../WebApp/WebMeasureCommand.h \
- ../WebApp/WebPrintCommand.h \
- ../WebApp/WebSearchCommand.h \
- ../WebApp/WebSelectWithinCommand.h \
- ../WebApp/WebSeparatorWidget.h \
- ../WebApp/WebTaskBar.h \
- ../WebApp/WebTaskBarWidget.h \
- ../WebApp/WebTaskPane.h \
- ../WebApp/WebToolbar.h \
- ../WebApp/WebViewOptionsCommand.h \
- ../WebApp/WebActions.h \
- ../WebApp/WebTargetType.h \
- ../WebApp/WebTargetViewerType.h \
- ../WebApp/WebTaskButtonType.h \
- ../WebApp/WebWidgetType.h \
- ../HttpHandler/HttpHeader.h \
- ../HttpHandler/HttpPrimitiveValue.h \
- ../HttpHandler/HttpRequest.h \
- ../HttpHandler/HttpRequestMetadata.h \
- ../HttpHandler/HttpRequestParam.h \
- ../HttpHandler/HttpResponse.h \
- ../HttpHandler/HttpResult.h
- ../../../BuildTools/WebTools/IMake/Linux/IMake ../MapGuideApi/MapGuideApiGen.xml Java
- cp -f java.i language.i
- ../../../BuildTools/WebTools/IMake/Linux/IMake ../MapGuideApi/Constants.xml Java .
- ../../../Oem/SWIGEx/Linux/swig -dllname MapGuideJavaApiEx -c++ -java -mgjavanothrow -mgjavacasing -DJAVA -package org.osgeo.mapguide -root MgObject -baseexception MgException -clsidcode getclassid.code -clsiddata m_cls_id -catchallcode catchall.code -dispose "((MgDisposable*)arg1)->Release()" -rethrow "e->Raise();" -nodefault -noconstants -module MapGuideJavaApiEx -o MgApi_wrap.cpp -lib ../../../Oem/SWIGEx/Lib MapGuideApi.i
- rm -f org/osgeo/mapguide/*.class
- mv -f *.java org/osgeo/mapguide
- $(JAVA_HOME)/bin/javac -classpath . org/osgeo/mapguide/*.java
- $(JAVA_HOME)/bin/jar cf ../WEB-INF/lib/MapGuideApiEx.jar org/osgeo/mapguide/*.class
- $(JAVA_HOME)/bin/jar cf ../WEB-INF/lib/MapGuideApiEx-sources.jar org/osgeo/mapguide/*.java
Deleted: trunk/MgDev/Bindings/src/Bindings/Php/Makefile.am
--- trunk/MgDev/Bindings/src/Bindings/Php/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Bindings/src/Bindings/Php/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,468 +0,0 @@
- catchall.code \
- php.i \
- PhpApi.rc \
- PhpApi.vcproj \
- PhpLocalizer.cpp
- -I$(php_src)/TSRM \
- -I$(php_src)/Zend \
- -I$(php_src)/main \
- -I$(php_src) \
- -I../WebSupport \
- -I../WebApp \
-lib_LTLIBRARIES = libphp_MapGuideApi.la
-nodist_libphp_MapGuideApi_la_SOURCES = MgApi_wrap.cpp
-AM_CXXFLAGS = @CXXFLAGS@ -fno-var-tracking-assignments -DPHP -DPHPPROXYAPI_EXPORTS
-libphp_MapGuideApi_la_LIBADD = \
- -lACE \
- -lMgFoundation \
- -lMgGeometry \
- -lMgHttpHandler \
- -lMgMdfModel \
- -lMgMdfParser \
- -lxerces-c \
- -lMgWebApp
-libphp_MapGuideApi_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../WebApp \
-MgApi_wrap.cpp : \
- ../../../BuildTools/WebTools/IMake/Linux/IMake -p ../MapGuideApi/Constants.xml -l PHP -o ./constants.php -t
- cp -f php.i language.i
- ../../../BuildTools/WebTools/IMake/Linux/IMake -p ../MapGuideApi/MapGuideApiGen.xml -l PHP
- ../../../Oem/SWIGEx/Linux/swig -c++ -php -DPHPSWIG -baseexception MgException \
- -clsidcode getclassid.code \
- -clsiddata m_cls_id \
- -catchallcode catchall.code \
- -dispose "((MgDisposable*)arg1)->Release()" \
- -rethrow "e->Raise();" \
- -nodefault -o MgApi_wrap.cpp \
- -lib ../../../Oem/SWIGEx/Lib MapGuideApi.i
Deleted: trunk/MgDev/Common/Foundation/Makefile.am
--- trunk/MgDev/Common/Foundation/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Common/Foundation/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,246 +0,0 @@
-EXTRA_DIST = Foundation.vcproj Foundation.rc
-lib_LTLIBRARIES = libMgFoundation.la
-libMgFoundation_la_SOURCES = \
- FoundationBuild.cpp
-include_SOURCES = \
- Data/BatchPropertyCollection.cpp \
- Data/Byte.cpp \
- Data/ByteReader.cpp \
- Data/ByteSink.cpp \
- Data/ByteSource.cpp \
- Data/Collection.cpp \
- Data/DateTime.cpp \
- Data/MimeType.cpp \
- Data/NamedCollection.cpp \
- Data/NullableProperty.cpp \
- Data/Property.cpp \
- Data/PropertyCollection.cpp \
- Data/PropertyDefinition.cpp \
- Data/StringCollection.cpp \
- Data/StringProperty.cpp \
- Exception/ApplicationException.cpp \
- Exception/ArgumentOutOfRangeException.cpp \
- Exception/ClassNotFoundException.cpp \
- Exception/ConfigurationException.cpp \
- Exception/ConfigurationLoadFailedException.cpp \
- Exception/ConfigurationSaveFailedException.cpp \
- Exception/DateTimeException.cpp \
- Exception/DecryptionException.cpp \
- Exception/DirectoryNotFoundException.cpp \
- Exception/DivideByZeroException.cpp \
- Exception/DomainException.cpp \
- Exception/DuplicateDirectoryException.cpp \
- Exception/DuplicateFileException.cpp \
- Exception/DuplicateObjectException.cpp \
- Exception/EncryptionException.cpp \
- Exception/Exception.cpp \
- Exception/FileIoException.cpp \
- Exception/FileNotFoundException.cpp \
- Exception/GridDensityException.cpp \
- Exception/IndexOutOfRangeException.cpp \
- Exception/InvalidArgumentException.cpp \
- Exception/InvalidCastException.cpp \
- Exception/InvalidMimeTypeException.cpp \
- Exception/InvalidOperationException.cpp \
- Exception/InvalidPropertyTypeException.cpp \
- Exception/InvalidStreamHeaderException.cpp \
- Exception/IoException.cpp \
- Exception/LengthException.cpp \
- Exception/LogicException.cpp \
- Exception/NotFiniteNumberException.cpp \
- Exception/NotImplementedException.cpp \
- Exception/NullArgumentException.cpp \
- Exception/NullPropertyValueException.cpp \
- Exception/NullReferenceException.cpp \
- Exception/ObjectNotFoundException.cpp \
- Exception/OutOfMemoryException.cpp \
- Exception/OutOfRangeException.cpp \
- Exception/OverflowException.cpp \
- Exception/PlatformNotSupportedException.cpp \
- Exception/ResourcesException.cpp \
- Exception/ResourcesLoadFailedException.cpp \
- Exception/ResourceTagNotFoundException.cpp \
- Exception/RuntimeException.cpp \
- Exception/StreamIoException.cpp \
- Exception/SystemException.cpp \
- Exception/TemporaryFileNotAvailableException.cpp \
- Exception/ThirdPartyException.cpp \
- Exception/UnclassifiedException.cpp \
- Exception/UnderflowException.cpp \
- Exception/XmlException.cpp \
- Exception/XmlParserException.cpp \
- System/AceStreamHelper.cpp \
- System/ByteSourceFileImpl.cpp \
- System/ByteSourceMemoryImpl.cpp \
- System/ByteSourceSocketStreamImpl.cpp \
- System/ByteSourceStreamImpl.cpp \
- System/ClassFactory.cpp \
- System/Configuration.cpp \
- System/ConfigurationHeap.cpp \
- System/ConfigurationSection.cpp \
- System/ConfigurationSectionCollection.cpp \
- System/Disposable.cpp \
- System/DisposableCollection.cpp \
- System/FileUtil.cpp \
- System/FoundationConfigProperties.cpp \
- System/GuardDisposable.cpp \
- System/MemoryStreamHelper.cpp \
- System/NamedSerializable.cpp \
- System/Object.cpp \
- System/PacketParser.cpp \
- System/Resources.cpp \
- System/Serializable.cpp \
- System/ServerConnectionBase.cpp \
- System/SetLocale.cpp \
- System/Stream.cpp \
- System/StreamData.cpp \
- System/StreamHelper.cpp \
- System/StreamParser.cpp \
- System/StreamReader.cpp \
- System/StreamWriter.cpp \
- System/Util.cpp \
- System/XmlUtil.cpp
-noinst_HEADERS = $(include_SOURCES) \
- Foundation.h \
- FoundationDefs.h \
- Data/BatchPropertyCollection.h \
- Data/Byte.h \
- Data/ByteReader.h \
- Data/ByteSink.h \
- Data/ByteSource.h \
- Data/Collection.h \
- Data/DateTime.h \
- Data/FeaturePropertyType.h \
- Data/MimeType.h \
- Data/NamedCollection.h \
- Data/NullableProperty.h \
- Data/Property.h \
- Data/PropertyCollection.h \
- Data/PropertyDefinition.h \
- Data/PropertyType.h \
- Data/StringCollection.h \
- Data/StringProperty.h \
- Exception/ApplicationException.h \
- Exception/ArgumentOutOfRangeException.h \
- Exception/ClassNotFoundException.h \
- Exception/ConfigurationException.h \
- Exception/ConfigurationLoadFailedException.h \
- Exception/ConfigurationSaveFailedException.h \
- Exception/DateTimeException.h \
- Exception/DecryptionException.h \
- Exception/DirectoryNotFoundException.h \
- Exception/DivideByZeroException.h \
- Exception/DomainException.h \
- Exception/DuplicateDirectoryException.h \
- Exception/DuplicateFileException.h \
- Exception/DuplicateObjectException.h \
- Exception/EncryptionException.h \
- Exception/Exception.h \
- Exception/ExceptionDefs.h \
- Exception/FileIoException.h \
- Exception/FileNotFoundException.h \
- Exception/GridDensityException.h \
- Exception/IndexOutOfRangeException.h \
- Exception/InvalidArgumentException.h \
- Exception/InvalidCastException.h \
- Exception/InvalidMimeTypeException.h \
- Exception/InvalidOperationException.h \
- Exception/InvalidPropertyTypeException.h \
- Exception/InvalidStreamHeaderException.h \
- Exception/IoException.h \
- Exception/LengthException.h \
- Exception/LogicException.h \
- Exception/NotFiniteNumberException.h \
- Exception/NotImplementedException.h \
- Exception/NullArgumentException.h \
- Exception/NullPropertyValueException.h \
- Exception/NullReferenceException.h \
- Exception/ObjectNotFoundException.h \
- Exception/OutOfMemoryException.h \
- Exception/OutOfRangeException.h \
- Exception/OverflowException.h \
- Exception/PlatformNotSupportedException.h \
- Exception/ResourcesException.h \
- Exception/ResourcesLoadFailedException.h \
- Exception/ResourceTagNotFoundException.h \
- Exception/RuntimeException.h \
- Exception/StreamIoException.h \
- Exception/SystemException.h \
- Exception/TemporaryFileNotAvailableException.h \
- Exception/ThirdPartyException.h \
- Exception/UnclassifiedException.h \
- Exception/UnderflowException.h \
- Exception/XmlException.h \
- Exception/XmlParserException.h \
- System/AceStreamHelper.h \
- System/ArgumentPacket.h \
- System/BasicPacket.h \
- System/BinaryStreamArgumentPacket.h \
- System/ByteSourceFileImpl.h \
- System/ByteSourceImpl.h \
- System/ByteSourceMemoryImpl.h \
- System/ByteSourceSocketStreamImpl.h \
- System/ByteSourceStreamImpl.h \
- System/ClassFactory.h \
- System/CollectionPacket.h \
- System/Configuration.h \
- System/ConfigurationHeap.h \
- System/ConfigurationSection.h \
- System/ConfigurationSectionCollection.h \
- System/ControlPacket.h \
- System/Disposable.h \
- System/DisposableCollection.h \
- System/FileUtil.h \
- System/FoundationClassId.h \
- System/FoundationConfigProperties.h \
- System/GuardDisposable.h \
- System/LinuxMemoryStatus.h \
- System/MemoryStreamHelper.h \
- System/NamedSerializable.h \
- System/Object.h \
- System/OperationPacket.h \
- System/OperationResponsePacket.h \
- System/PacketParser.h \
- System/PacketStructure.h \
- System/Ptr.h \
- System/Resources.h \
- System/Serializable.h \
- System/ServerConnectionBase.h \
- System/SetLocale.h \
- System/Stream.h \
- System/StreamData.h \
- System/StreamHeader.h \
- System/StreamHelper.h \
- System/StreamParser.h \
- System/StreamReader.h \
- System/StreamWriter.h \
- System/Util.h \
- System/XmlDefs.h \
- System/XmlUtil.h
-INCLUDES = \
- -IData \
- -IException \
- -ISystem \
- -I../Security \
- -I../MdfModel \
- -I../../Oem/ACE/ACE_wrappers \
- -I../../Oem/dbxml/xerces-c-src/src
-libMgFoundation_la_LIBADD = \
- -lACE \
- -lMgMdfParser \
- -lMgMdfModel \
- -lxerces-c
-libMgFoundation_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../../Oem/ACE/ACE_wrappers/ace \
- -L../../Oem/dbxml/install/lib \
- -L../MdfParser \
- -L../MdfModel
Deleted: trunk/MgDev/Common/Geometry/Makefile.am
--- trunk/MgDev/Common/Geometry/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Common/Geometry/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,469 +0,0 @@
-EXTRA_DIST = Geometry.vcproj Geometry.rc Parse/script Parse/script_linux Parse/yyAwkt.y
-lib_LTLIBRARIES = libMgGeometry.la
-libMgGeometry_la_SOURCES = \
- GeometryBuild.cpp \
- ../CoordinateSystem/ArbitraryCoordsys.cpp \
- ../CoordinateSystem/CoordSysDictionaryBase.cpp \
- ../CoordinateSystem/CoordSys.cpp \
- ../CoordinateSystem/CoordSysCatalog.cpp \
- ../CoordinateSystem/CoordSysCategory.cpp \
- ../CoordinateSystem/CoordSysCategoryDictionary.cpp \
- ../CoordinateSystem/CoordSysDatum.cpp \
- ../CoordinateSystem/CoordSysDatumDictionary.cpp \
- ../CoordinateSystem/CoordSysDictionary.cpp \
- ../CoordinateSystem/CoordSysEllipsoid.cpp \
- ../CoordinateSystem/CoordSysEllipsoidDictionary.cpp \
- ../CoordinateSystem/CoordSysEnum.cpp \
- ../CoordinateSystem/CoordSysEnumCategory.cpp \
- ../CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp \
- ../CoordinateSystem/CoordSysEnumDatum.cpp \
- ../CoordinateSystem/CoordSysEnumEllipsoid.cpp \
- ../CoordinateSystem/CoordSysFormatConverter.cpp \
- ../CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp \
- ../CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp \
- ../CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp \
- ../CoordinateSystem/CoordSysGeodeticStandaloneTransformDefParams.cpp \
- ../CoordinateSystem/CoordSysGeodeticPath.cpp \
- ../CoordinateSystem/CoordSysGeodeticPathDictionary.cpp \
- ../CoordinateSystem/CoordSysGeodeticPathElement.cpp \
- ../CoordinateSystem/CoordSysGeodeticTransformation.cpp \
- ../CoordinateSystem/CoordSysGeodeticTransformDef.cpp \
- ../CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp \
- ../CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp \
- ../CoordinateSystem/CoordSysGeodeticTransformGridFile.cpp \
- ../CoordinateSystem/CoordSysMeasure.cpp \
- ../CoordinateSystem/CoordSysTransform.cpp \
- ../CoordinateSystem/CoordSysDictionaryUtility.cpp \
- ../CoordinateSystem/CoordSysEnumInteger32.cpp \
- ../CoordinateSystem/CoordSysMathComparator.cpp \
- ../CoordinateSystem/CoordSysProjectionInformation.cpp \
- ../CoordinateSystem/CoordSysUnitInformation.cpp \
- ../CoordinateSystem/CoordSysUtil.cpp \
- ../CoordinateSystem/MentorDictionary.cpp \
- ../CoordinateSystem/MentorUtil.cpp \
- ../CoordinateSystem/CoordSysWktFailureCache.cpp \
- ../CoordinateSystem/CoordSysGridGeneric.cpp \
- ../CoordinateSystem/CoordSysGrids.cpp \
- ../CoordinateSystem/CoordSysMgrsZone.cpp \
- ../CoordinateSystem/CoordSysMgrs.cpp \
- ../CoordinateSystem/CoordSysMgrsMajorRegion.cpp \
- ../CoordinateSystem/CoordSysOneGrid.cpp \
- ../CoordinateSystem/namestruct.cpp \
- ../CoordinateSystem/CriticalSection.cpp \
- ../CoordinateSystem/SmartCriticalClass.cpp
- AgfReaderWriter.cpp \
- AgfStream.cpp \
- AggregateGeometry.cpp \
- ArcSegment.cpp \
- Coordinate.cpp \
- CoordinateCollection.cpp \
- CoordinateIterator.cpp \
- CoordinateXY.cpp \
- CoordinateXYM.cpp \
- CoordinateXYZ.cpp \
- CoordinateXYZM.cpp \
- Curve.cpp \
- CurvePolygon.cpp \
- CurvePolygonCollection.cpp \
- CurveRing.cpp \
- CurveRingCollection.cpp \
- CurveSegmentCollection.cpp \
- CurveString.cpp \
- CurveStringCollection.cpp \
- Envelope.cpp \
- GeometricEntity.cpp \
- Geometry.cpp \
- GeometryClassFactory.cpp \
- GeometryCollection.cpp \
- GeometryFactory.cpp \
- GeometryUtil.cpp \
- GeometrySimplifier.cpp \
- GeosUtil.cpp \
- LinearRing.cpp \
- LinearRingCollection.cpp \
- LinearSegment.cpp \
- LineString.cpp \
- LineStringCollection.cpp \
- MultiCurvePolygon.cpp \
- MultiCurveString.cpp \
- MultiGeometry.cpp \
- MultiLineString.cpp \
- MultiPoint.cpp \
- MultiPolygon.cpp \
- Point.cpp \
- PointCollection.cpp \
- Polygon.cpp \
- PolygonCollection.cpp \
- PreparedGeometry.cpp \
- Region.cpp \
- Ring.cpp \
- WktReaderWriter.cpp\
- Buffer/BorderWalker.cpp \
- Buffer/bufrutil.cpp \
- Buffer/eventarr.cpp \
- Buffer/FloatTransform.cpp \
- Buffer/GreatCircleBufferUtil.cpp \
- Buffer/interlst.cpp \
- Buffer/interprc.cpp \
- Buffer/LatLonBorderWalker.cpp \
- Buffer/MgBuffer.cpp \
- Buffer/ogeomtry.cpp \
- Buffer/oobject.cpp \
- Buffer/opline.cpp \
- Buffer/opolygon.cpp \
- Buffer/oppolygn.cpp \
- Buffer/oppolyln.cpp \
- Buffer/orpplygn.cpp \
- Buffer/ortree.cpp \
- Buffer/planeswp.cpp \
- Buffer/plgnbufr.cpp \
- Buffer/plgnsbak.cpp \
- Buffer/plinbufr.cpp \
- Buffer/pobjbufr.cpp \
- Buffer/ppgunion.cpp \
- Buffer/progcbck.cpp \
- Buffer/sedgaloc.cpp \
- Buffer/sweepedg.cpp \
- Buffer/tuplearr.cpp \
- Buffer/vertaloc.cpp \
- Buffer/wedgaloc.cpp \
- Buffer/wedgearr.cpp \
- Buffer/wingedge.cpp \
- Buffer/worklist.cpp \
- Buffer/xordtree.cpp \
- CoordinateSystem/CoordinateSystemCache.cpp \
- CoordinateSystem/CoordinateSystemFactory.cpp \
- Exception/CoordinateSystemComputationFailedException.cpp \
- Exception/CoordinateSystemConversionFailedException.cpp \
- Exception/CoordinateSystemInitializationFailedException.cpp \
- Exception/CoordinateSystemLoadFailedException.cpp \
- Exception/CoordinateSystemMeasureFailedException.cpp \
- Exception/CoordinateSystemTransformFailedException.cpp \
- Exception/GeometryException.cpp\
- Exception/InvalidCoordinateSystemException.cpp \
- Exception/InvalidCoordinateSystemTypeException.cpp \
- Exception/InvalidCoordinateSystemUnitsException.cpp \
- Parse/ArrayHelper.cpp \
- Parse/LexAwkt.cpp \
- Parse/ParseAwkt.cpp \
- Parse/ParseAwktUtil.cpp \
- Parse/StringUtility.cpp \
- Parse/yyAwkt.cpp \
- Parse/yyAwkt_linux.cpp \
- Spatial/MathUtility.cpp \
- Spatial/SpatialUtility.cpp \
- Spatial/SpatialUtilityCircularArc.cpp \
- ../CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp\
- ../CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp\
- ../CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp\
- ../CoordinateSystem/CoordSysGeodeticStandaloneTransformDefParams.cpp\
- ../CoordinateSystem/CoordSysGeodeticPath.cpp\
- ../CoordinateSystem/CoordSysGeodeticPathDictionary.cpp\
- ../CoordinateSystem/CoordSysGeodeticPathElement.cpp\
- ../CoordinateSystem/CoordSysGeodeticTransformation.cpp\
- ../CoordinateSystem/CoordSysGeodeticTransformDef.cpp\
- ../CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp\
- ../CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp\
- ../CoordinateSystem/CoordSysGeodeticTransformGridFile.cpp\
- AgfReaderWriter.h \
- AgfStream.h \
- AggregateGeometry.h \
- ArcSegment.h \
- CloseInstruction.h \
- Coordinate.h \
- CoordinateCollection.h \
- CoordinateDimension.h \
- CoordinateIterator.h \
- CoordinateXY.h \
- CoordinateXYM.h \
- CoordinateXYZ.h \
- CoordinateXYZM.h \
- Curve.h \
- CurvePolygon.h \
- CurvePolygonCollection.h \
- CurveRing.h \
- CurveRingCollection.h \
- CurveSegment.h \
- CurveSegmentCollection.h \
- CurveString.h \
- CurveStringCollection.h \
- Envelope.h \
- GeometricDimension.h \
- GeometricEntity.h \
- GeometricEntityType.h \
- GeometricPathInstruction.h \
- GeometricPathInstructionType.h \
- GeometricPathIterator.h \
- Geometry.h \
- GeometryClassId.h \
- GeometryCollection.h \
- GeometryCommon.h \
- GeometryComponent.h \
- GeometryComponentType.h \
- GeometryExceptionDef.h \
- GeometryFactory.h \
- GeometryType.h \
- GeometrySimplifier.h \
- GeometrySimplificationAlgorithmType.h \
- GeometryUtil.h \
- GeosUtil.h \
- LinearRing.h \
- LinearRingCollection.h \
- LinearSegment.h \
- LineString.h \
- LineStringCollection.h \
- LineToInstruction.h \
- Measure.h \
- MoveToInstruction.h \
- MultiCurvePolygon.h \
- MultiCurveString.h \
- MultiGeometry.h \
- MultiLineString.h \
- MultiPoint.h \
- MultiPolygon.h \
- Point.h \
- PointCollection.h \
- Polygon.h \
- PolygonCollection.h \
- PreparedGeometry.h \
- QuadToInstruction.h \
- Region.h \
- Ring.h \
- Transform.h \
- WktReaderWriter.h \
- Buffer/BorderWalker.h \
- Buffer/buffer.h \
- Buffer/bufraloc.h \
- Buffer/bufrsort.h \
- Buffer/bufrutil.h \
- Buffer/DumpFFGF.h \
- Buffer/eventarr.h \
- Buffer/eventint.h \
- Buffer/FloatTransform.h \
- Buffer/GreatCircleBufferUtil.h \
- Buffer/interlst.h \
- Buffer/interprc.h \
- Buffer/LatLonBorderWalker.h \
- Buffer/MgBuffer.h \
- Buffer/oarray.h \
- Buffer/oextent.h \
- Buffer/ogeomtry.h \
- Buffer/olinep.h \
- Buffer/oobject.h \
- Buffer/opline.h \
- Buffer/opoint.h \
- Buffer/opolygnp.h \
- Buffer/opolygon.h \
- Buffer/oppolygn.h \
- Buffer/oppolyln.h \
- Buffer/opsprimitive.h \
- Buffer/orpplygn.h \
- Buffer/ortree.h \
- Buffer/performanceOptions.h \
- Buffer/planeswp.h \
- Buffer/plgnbufr.h \
- Buffer/plgnsbak.h \
- Buffer/plinbufr.h \
- Buffer/pobjbufr.h \
- Buffer/ppgunion.h \
- Buffer/progcbck.h \
- Buffer/sedgaloc.h \
- Buffer/sweepedg.h \
- Buffer/tuplearr.h \
- Buffer/vertaloc.h \
- Buffer/wedgaloc.h \
- Buffer/wedgearr.h \
- Buffer/wingedge.h \
- Buffer/worklist.h \
- Buffer/xordtree.h \
- CoordinateSystem/CoordinateSystem.h \
- CoordinateSystem/CoordinateSystemCache.h \
- CoordinateSystem/CoordinateSystemCatalog.h \
- CoordinateSystem/CoordinateSystemCategory.h \
- CoordinateSystem/CoordinateSystemCategoryDictionary.h \
- CoordinateSystem/CoordinateSystemCodeFormat.h \
- CoordinateSystem/CoordinateSystemCommon.h \
- CoordinateSystem/CoordinateSystemDatum.h \
- CoordinateSystem/CoordinateSystemDatumDictionary.h \
- CoordinateSystem/CoordinateSystemDictionary.h \
- CoordinateSystem/CoordinateSystemDictionaryBase.h \
- CoordinateSystem/CoordinateSystemDictionaryUtility.h \
- CoordinateSystem/CoordinateSystemEllipsoid.h \
- CoordinateSystem/CoordinateSystemEllipsoidDictionary.h \
- CoordinateSystem/CoordinateSystemEnum.h \
- CoordinateSystem/CoordinateSystemEnumInteger32.h \
- CoordinateSystem/CoordinateSystemErrorCode.h \
- CoordinateSystem/CoordinateSystemFactory.h \
- CoordinateSystem/CoordinateSystemFilter.h \
- CoordinateSystem/CoordinateSystemFilterInteger32.h \
- CoordinateSystem/CoordinateSystemFormatConverter.h \
- CoordinateSystem/CoordinateSystemGeodeticTransformation.h \
- CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h \
- CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h \
- CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h \
- CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformationMethod.h \
- CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h \
- CoordinateSystem/CoordinateSystemMathComparator.h \
- CoordinateSystem/CoordinateSystemMeasure.h \
- CoordinateSystem/CoordinateSystemProjectionCode.h \
- CoordinateSystem/CoordinateSystemProjectionFormatType.h \
- CoordinateSystem/CoordinateSystemProjectionInformation.h \
- CoordinateSystem/CoordinateSystemProjectionLogicalType.h \
- CoordinateSystem/CoordinateSystemProjectionParameterType.h \
- CoordinateSystem/CoordinateSystemTransform.h \
- CoordinateSystem/CoordinateSystemType.h \
- CoordinateSystem/CoordinateSystemUnitCode.h \
- CoordinateSystem/CoordinateSystemUnitInformation.h \
- CoordinateSystem/CoordinateSystemUnitType.h \
- CoordinateSystem/CoordinateSystemWktFlavor.h \
- CoordinateSystem/CoordinateSystemGridOrientation.h \
- CoordinateSystem/CoordinateSystemGridSpecializationType.h \
- CoordinateSystem/CoordinateSystemGrids.h \
- CoordinateSystem/CoordinateSystemGridGeneric.h \
- CoordinateSystem/CoordinateSystemMgrsGridLevel.h \
- CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h \
- CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h \
- CoordinateSystem/CoordinateSystemMgrs.h \
- Exception/CoordinateSystemComputationFailedException.h \
- Exception/CoordinateSystemConversionFailedException.h \
- Exception/CoordinateSystemInitializationFailedException.h \
- Exception/CoordinateSystemLoadFailedException.h \
- Exception/CoordinateSystemMeasureFailedException.h \
- Exception/CoordinateSystemTransformFailedException.h \
- Exception/GeometryException.h \
- Exception/InvalidCoordinateSystemException.h \
- Exception/InvalidCoordinateSystemTypeException.h \
- Exception/InvalidCoordinateSystemUnitsException.h \
- Parse/Array.h \
- Parse/ArrayHelper.h \
- Parse/LexAwkt.h \
- Parse/ParseAwkt.h \
- Parse/ParseAwktUtil.h \
- Parse/StringUtility.h \
- Parse/yyAwkt.h \
- Spatial/MathUtility.h \
- Spatial/SpatialUtility.h \
- Spatial/SpatialUtilityStatus.h \
- Spatial/SpatialUtilityCircularArc.h \
- Spatial/SpatialUtilityVectorAngle.h \
- ../CoordinateSystem/ArbitraryCoordsys.h \
- ../CoordinateSystem/CoordSys.h \
- ../CoordinateSystem/CoordSysDictionaryBase.h \
- ../CoordinateSystem/CoordSysCatalog.h \
- ../CoordinateSystem/CoordSysCategory.h \
- ../CoordinateSystem/CoordSysCategoryDictionary.h \
- ../CoordinateSystem/CoordSysCommon.h \
- ../CoordinateSystem/CoordSysDatum.h \
- ../CoordinateSystem/CoordSysDatumDictionary.h \
- ../CoordinateSystem/CoordSysDictionary.h \
- ../CoordinateSystem/CoordSysEllipsoid.h \
- ../CoordinateSystem/CoordSysEllipsoidDictionary.h \
- ../CoordinateSystem/CoordSysEnum.h \
- ../CoordinateSystem/CoordSysEnumCategory.h \
- ../CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.h \
- ../CoordinateSystem/CoordSysEnumDatum.h \
- ../CoordinateSystem/CoordSysEnumEllipsoid.h \
- ../CoordinateSystem/CoordSysFormatConverter.h \
- ../CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.h \
- ../CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.h \
- ../CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.h \
- ../CoordinateSystem/CoordSysGeodeticStandaloneTransformDefParams.h \
- ../CoordinateSystem/CoordSysGeodeticPath.h \
- ../CoordinateSystem/CoordSysGeodeticPathDictionary.h \
- ../CoordinateSystem/CoordSysGeodeticPathElement.h \
- ../CoordinateSystem/CoordSysGeodeticTransformation.h \
- ../CoordinateSystem/CoordSysGeodeticTransformDef.h \
- ../CoordinateSystem/CoordSysGeodeticTransformDefDictionary.h \
- ../CoordinateSystem/CoordSysGeodeticTransformDefParams.h \
- ../CoordinateSystem/CoordSysGeodeticTransformGridFile.h \
- ../CoordinateSystem/CoordSysMeasure.h \
- ../CoordinateSystem/CoordSysTransform.h \
- ../CoordinateSystem/CoordSysType.h \
- ../CoordinateSystem/CoordSysUtil.h \
- ../CoordinateSystem/CriticalSection.h \
- ../CoordinateSystem/SmartCriticalClass.h \
- ../CoordinateSystem/CoordSysDictionaryUtility.h \
- ../CoordinateSystem/CoordSysEnumInteger32.h \
- ../CoordinateSystem/CoordSysMathComparator.h \
- ../CoordinateSystem/CoordSysMacro.h\
- ../CoordinateSystem/CoordSysProjectionInformation.h \
- ../CoordinateSystem/CoordSysUnitInformation.h \
- ../CoordinateSystem/CsmapVersion.h \
- ../CoordinateSystem/MentorDictionary.h \
- ../CoordinateSystem/MentorUtil.h \
- ../CoordinateSystem/namestruct.h \
- ../CoordinateSystem/CoordSysWktFailureCache.h \
- ../CoordinateSystem/CoordSysGridGeneric.h \
- ../CoordinateSystem/CoordSysGrids.h \
- ../CoordinateSystem/CoordSysMgrsZone.h \
- ../CoordinateSystem/CoordSysMgrs.h \
- ../CoordinateSystem/CoordSysMgrsMajorRegion.h \
- ../CoordinateSystem/CoordSysOneGrid.h
-INCLUDES = \
- -I../Security \
- -I../MdfParser \
- -I../MdfModel \
- -I../Foundation \
- -I../Geometry \
- -I../../Oem/geos/include \
- -I../../Oem/dbxml/xerces-c-src/src \
- -I../../Oem/CsMap/CsMapDev/Include \
- -I../../Common/CoordinateSystem
-libMgGeometry_la_LIBADD = \
- -lACE \
- -lMgFoundation \
- ../../Oem/CsMap/CsMapDev/.libs/libCsmap.a \
- ../../Oem/geos/src/.libs/libgeos.a
-libMgGeometry_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../Foundation \
- -L../../Oem/CsMap/CsMapDev \
- -L../../Common/CoordinateSystem
Deleted: trunk/MgDev/Common/Makefile.am
--- trunk/MgDev/Common/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Common/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,4 +0,0 @@
-SUBDIRS = MdfModel MdfParser Security Foundation Geometry PlatformBase MapGuideCommon Stylization Renderers
-DIST_SUBDIRS = MdfModel MdfParser Security Foundation Geometry PlatformBase MapGuideCommon Stylization Renderers
-EXTRA_DIST = ProductVersion.h Schema
Deleted: trunk/MgDev/Common/MapGuideCommon/Makefile.am
--- trunk/MgDev/Common/MapGuideCommon/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Common/MapGuideCommon/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,295 +0,0 @@
-EXTRA_DIST = Resources MapGuideCommon.vcproj MapGuideCommon.rc
-lib_LTLIBRARIES = libMgMapGuideCommon.la
-libMgMapGuideCommon_la_SOURCES = \
- MapGuideCommonBuild.cpp
- Controller/Controller.cpp \
- Controller/DwfController.cpp \
- Controller/HtmlController.cpp \
- Exception/AllProviderConnectionsUsedException.cpp \
- Exception/AuthenticationFailedException.cpp \
- Exception/ConnectionFailedException.cpp \
- Exception/ConnectionNotOpenException.cpp \
- Exception/DbException.cpp \
- Exception/DbXmlException.cpp \
- Exception/DuplicateGroupException.cpp \
- Exception/DuplicateNameException.cpp \
- Exception/DuplicateParameterException.cpp \
- Exception/DuplicateRepositoryException.cpp \
- Exception/DuplicateRoleException.cpp \
- Exception/DuplicateServerException.cpp \
- Exception/DuplicateSessionException.cpp \
- Exception/DuplicateUserException.cpp \
- Exception/DwfException.cpp \
- Exception/DwfSectionNotFoundException.cpp \
- Exception/DwfSectionResourceNotFoundException.cpp \
- Exception/EndOfStreamException.cpp \
- Exception/EvaluationExpiredException.cpp \
- Exception/GroupNotFoundException.cpp \
- Exception/InvalidDwfPackageException.cpp \
- Exception/InvalidDwfSectionException.cpp \
- Exception/InvalidFeatureSourceException.cpp \
- Exception/InvalidIpAddressException.cpp \
- Exception/InvalidLicenseException.cpp \
- Exception/InvalidLogEntryException.cpp \
- Exception/InvalidOperationVersionException.cpp \
- Exception/InvalidPasswordException.cpp \
- Exception/InvalidPrintLayoutFontSizeUnitsException.cpp \
- Exception/InvalidPrintLayoutPositionUnitsException.cpp \
- Exception/InvalidPrintLayoutSizeUnitsException.cpp \
- Exception/InvalidSerialNumberException.cpp \
- Exception/InvalidServerNameException.cpp \
- Exception/LicenseException.cpp \
- Exception/LicenseExpiredException.cpp \
- Exception/LogOpenFailedException.cpp \
- Exception/OperationProcessingException.cpp \
- Exception/ParameterNotFoundException.cpp \
- Exception/PathTooLongException.cpp \
- Exception/PermissionDeniedException.cpp \
- Exception/PortNotAvailableException.cpp \
- Exception/PrintToScaleModeNotSelectedException.cpp \
- Exception/RasterTransformationNotSupportedException.cpp \
- Exception/RepositoryCreationFailedException.cpp \
- Exception/RepositoryNotFoundException.cpp \
- Exception/RepositoryNotOpenException.cpp \
- Exception/RepositoryOpenFailedException.cpp \
- Exception/RoleNotFoundException.cpp \
- Exception/ServerNotFoundException.cpp \
- Exception/ServerNotOnlineException.cpp \
- Exception/SessionExpiredException.cpp \
- Exception/SessionNotFoundException.cpp \
- Exception/StylizeLayerFailedException.cpp \
- Exception/UnauthorizedAccessException.cpp \
- Exception/UnknownTileProviderException.cpp \
- Exception/UnsupportedProviderThreadModelException.cpp \
- Exception/UnsupportedTileProviderException.cpp \
- Exception/UriFormatException.cpp \
- MapLayer/Layer.cpp \
- MapLayer/Map.cpp \
- MapLayer/Selection.cpp \
- Net/IOperationHandler.cpp \
- Services/Command.cpp \
- Services/ConnectionProperties.cpp \
- Services/CustomLogoInfo.cpp \
- Services/CustomTextInfo.cpp \
- Services/DrawingDefs.cpp \
- Services/DrawingService.cpp \
- Services/DwfVersion.cpp \
- Services/FeatureInformation.cpp \
- Services/ImageFormats.cpp \
- Services/KmlDefs.cpp \
- Services/KmlService.cpp \
- Services/Layout.cpp \
- Services/MappingDefs.cpp \
- Services/MappingService.cpp \
- Services/MapPlot.cpp \
- Services/MapPlotCollection.cpp \
- Services/PackageStatusInformation.cpp \
- Services/PlotSpecification.cpp \
- Services/PrintLayout.cpp \
- Services/ProfilingDefs.cpp \
- Services/ProfilingService.cpp \
- Services/ProxyDataReader.cpp \
- Services/ProxyDrawingService.cpp \
- Services/ProxyFeatureReader.cpp \
- Services/ProxyFeatureService.cpp \
- Services/ProxyGwsFeatureReader.cpp \
- Services/ProxyKmlService.cpp \
- Services/ProxyMappingService.cpp \
- Services/ProxyRenderingService.cpp \
- Services/ProxyResourceService.cpp \
- Services/ProxySqlDataReader.cpp \
- Services/ProxyTileService.cpp \
- Services/ProxyFeatureTransaction.cpp \
- Services/ProxyProfilingService.cpp \
- Services/RenderingDefs.cpp \
- Services/RenderingOptions.cpp \
- Services/RenderingService.cpp \
- Services/ServerAdmin.cpp \
- Services/ServerAdminDefs.cpp \
- Services/ServerConnection.cpp \
- Services/ServerConnectionEventHandler.cpp \
- Services/ServerConnectionImp.cpp \
- Services/ServerConnectionPool.cpp \
- Services/ServerConnectionStack.cpp \
- Services/ServerInformation.cpp \
- Services/Site.cpp \
- Services/SiteManager.cpp \
- Services/SiteInfo.cpp \
- Services/SiteConnection.cpp \
- Services/TileDefs.cpp \
- Services/TileService.cpp \
- Services/UnitType.cpp \
- Services/SqlResult.cpp \
- System/ConfigProperties.cpp \
- System/MapGuideCommonFactory.cpp \
- System/MapGuideStream.cpp \
- System/UserInformation.cpp \
- System/CryptographyManager.cpp \
- Util/IpUtil.cpp \
- Util/TimerUtil.cpp
- MapGuideCommon.h \
- Controller/Controller.h \
- Controller/DwfController.h \
- Controller/HtmlController.h \
- Exception/AllProviderConnectionsUsedException.h \
- Exception/AuthenticationFailedException.h \
- Exception/ConnectionFailedException.h \
- Exception/ConnectionNotOpenException.h \
- Exception/DbException.h \
- Exception/DbXmlException.h \
- Exception/DuplicateGroupException.h \
- Exception/DuplicateNameException.h \
- Exception/DuplicateParameterException.h \
- Exception/DuplicateRepositoryException.h \
- Exception/DuplicateRoleException.h \
- Exception/DuplicateServerException.h \
- Exception/DuplicateSessionException.h \
- Exception/DuplicateUserException.h \
- Exception/DwfException.h \
- Exception/DwfSectionNotFoundException.h \
- Exception/DwfSectionResourceNotFoundException.h \
- Exception/EndOfStreamException.h \
- Exception/EvaluationExpiredException.h \
- Exception/GroupNotFoundException.h \
- Exception/InvalidDwfPackageException.h \
- Exception/InvalidDwfSectionException.h \
- Exception/InvalidFeatureSourceException.h \
- Exception/InvalidIpAddressException.h \
- Exception/InvalidLicenseException.h \
- Exception/InvalidLogEntryException.h \
- Exception/InvalidOperationVersionException.h \
- Exception/InvalidPasswordException.h \
- Exception/InvalidPrintLayoutFontSizeUnitsException.h \
- Exception/InvalidPrintLayoutPositionUnitsException.h \
- Exception/InvalidPrintLayoutSizeUnitsException.h \
- Exception/InvalidSerialNumberException.h \
- Exception/InvalidServerNameException.h \
- Exception/LicenseException.h \
- Exception/LicenseExpiredException.h \
- Exception/LogOpenFailedException.h \
- Exception/OperationProcessingException.h \
- Exception/ParameterNotFoundException.h \
- Exception/PathTooLongException.h \
- Exception/PermissionDeniedException.h \
- Exception/PortNotAvailableException.h \
- Exception/PrintToScaleModeNotSelectedException.h \
- Exception/RasterTransformationNotSupportedException.h \
- Exception/RepositoryCreationFailedException.h \
- Exception/RepositoryNotFoundException.h \
- Exception/RepositoryNotOpenException.h \
- Exception/RepositoryOpenFailedException.h \
- Exception/RoleNotFoundException.h \
- Exception/ServerNotFoundException.h \
- Exception/ServerNotOnlineException.h \
- Exception/SessionExpiredException.h \
- Exception/SessionNotFoundException.h \
- Exception/StylizeLayerFailedException.h \
- Exception/UnauthorizedAccessException.h \
- Exception/UnknownTileProviderException.h \
- Exception/UnsupportedTileProviderException.h \
- Exception/UnsupportedProviderThreadModelException.h \
- Exception/UriFormatException.h \
- MapLayer/Layer.h \
- MapLayer/Map.h \
- MapLayer/Selection.h \
- Net/IOperationHandler.h \
- Services/Command.h \
- Services/ConnectionProperties.h \
- Services/CustomLogoInfo.h \
- Services/CustomTextInfo.h \
- Services/DrawingDefs.h \
- Services/DrawingService.h \
- Services/DwfVersion.h \
- Services/FeatureInformation.h \
- Services/ImageFormats.h \
- Services/KmlDefs.h \
- Services/KmlService.h \
- Services/Layout.h \
- Services/MappingDefs.h \
- Services/MappingService.h \
- Services/MapPlot.h \
- Services/MapPlotCollection.h \
- Services/MapPlotInstruction.h \
- Services/PackageStatusInformation.h \
- Services/PlotSpecification.h \
- Services/PrintLayout.h \
- Services/ProfilingDefs.h \
- Services/ProfilingService.h \
- Services/ProxyDataReader.h \
- Services/ProxyDrawingService.h \
- Services/ProxyFeatureReader.h \
- Services/ProxyFeatureService.h \
- Services/ProxyGwsFeatureReader.h \
- Services/ProxyKmlService.h \
- Services/ProxyMappingService.h \
- Services/ProxyRenderingService.h \
- Services/ProxyResourceService.h \
- Services/ProxySqlDataReader.h \
- Services/ProxyTileService.h \
- Services/ProxyFeatureTransaction.h \
- Services/ProxyProfilingService.h \
- Services/RenderingDefs.h \
- Services/RenderingOptions.h \
- Services/RenderingService.h \
- Services/ServerAdmin.h \
- Services/ServerAdminDefs.h \
- Services/ServerConnection.h \
- Services/ServerConnectionEventHandler.h \
- Services/ServerConnectionImp.h \
- Services/ServerConnectionPool.h \
- Services/ServerConnectionStack.h \
- Services/ServerInformation.h \
- Services/Site.h \
- Services/SiteManager.h \
- Services/SiteInfo.h \
- Services/SiteConnection.h \
- Services/TileDefs.h \
- Services/TileService.h \
- Services/UnitType.h \
- Services/SqlResult.h \
- System/ConfigProperties.h \
- System/MapGuideCommonClassId.h \
- System/MapGuideStream.h \
- System/UserInformation.h \
- System/CryptographyManager.h \
- Util/IpUtil.h \
- Util/TimerUtil.h
-INCLUDES = \
- -I../PlatformBase \
- -I../System \
- -I../CoordinateSystem \
- -I../Security \
- -I../MdfParser \
- -I../MdfModel \
- -I../Foundation \
- -I../Geometry \
- -I../../Oem/geos/source/headers \
-libMgMapGuideCommon_la_LIBADD = \
- -lACE \
- -lMgMdfParser \
- -lMgMdfModel \
- -lMgPlatformBase \
- -lMgFoundation \
- -lMgGeometry \
- -lMgSecurity
-libMgMapGuideCommon_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../PlatformBase \
- -L../Foundation \
- -L../Geometry \
- -L../Security \
- -L../MdfParser \
- -L../MdfModel
Deleted: trunk/MgDev/Common/MdfModel/Makefile.am
--- trunk/MgDev/Common/MdfModel/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Common/MdfModel/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,249 +0,0 @@
-AUTOMAKE_OPTIONS = foreign
-EXTRA_DIST = MdfModel.vcproj MdfModel.rc
-lib_LTLIBRARIES = libMgMdfModel.la
-libMgMdfModel_la_SOURCES = \
- Common/Color.cpp \
- Common/Extent3D.cpp \
- Common/Point3D.cpp \
- Common/Size2D.cpp \
- Common/StringObject.cpp \
- Common/Vector3D.cpp \
- PrintLayout/DataConfiguration.cpp \
- PrintLayout/MapView.cpp \
- PrintLayout/MapViewportDefinition.cpp \
- PrintLayout/PrintLayoutDefinition.cpp \
- PrintLayout/PrintLayoutElement.cpp \
- PrintLayout/PrintLayoutElementDefinition.cpp \
- PrintLayout/PrintLayoutElementStyle.cpp \
- PrintLayout/PropertyMapping.cpp \
- PrintLayout/StylizationConfiguration.cpp \
- PrintLayout/Thickness.cpp \
- AreaRule.cpp \
- AreaSymbolization2D.cpp \
- AreaTypeStyle.cpp \
- AreaUsage.cpp \
- AttributeRelate.cpp \
- BaseMapLayer.cpp \
- BaseMapLayerGroup.cpp \
- BlockSymbol.cpp \
- Box2D.cpp \
- CalculatedProperty.cpp \
- ChannelBand.cpp \
- CompositeRule.cpp \
- CompositeSymbolization.cpp \
- CompositeTypeStyle.cpp \
- CompoundSymbolDefinition.cpp \
- ConvertUTF.c \
- DisplayScale.cpp \
- DrawingLayerDefinition.cpp \
- ElevationSettings.cpp \
- Extension.cpp \
- FeatureSource.cpp \
- FeatureTypeStyle.cpp \
- Fill.cpp \
- FontSymbol.cpp \
- GraphicElement.cpp \
- GridColor.cpp \
- GridColorRule.cpp \
- GridColorStyle.cpp \
- GridLayerDefinition.cpp \
- GridScaleRange.cpp \
- GridSurfaceStyle.cpp \
- HillShade.cpp \
- Image.cpp \
- ImageSymbol.cpp \
- Label.cpp \
- LayerDefinition.cpp \
- LengthConverter.cpp \
- LineRule.cpp \
- LineSymbolization2D.cpp \
- LineTypeStyle.cpp \
- LineUsage.cpp \
- MapDefinition.cpp \
- MapLayer.cpp \
- MapLayerGroup.cpp \
- MapLayerGroupCommon.cpp \
- MarkSymbol.cpp \
- MdfModel.cpp \
- MdfRootObject.cpp \
- NameStringPair.cpp \
- Override.cpp \
- Parameter.cpp \
- Path.cpp \
- PointRule.cpp \
- PointSymbolization2D.cpp \
- PointTypeStyle.cpp \
- PointUsage.cpp \
- ProfileRenderLabelsResult.cpp \
- ProfileRenderLayerResult.cpp \
- ProfileRenderLayersResult.cpp \
- ProfileRenderLayersResultBase.cpp \
- ProfileRenderMapResult.cpp \
- ProfileRenderSelectionResult.cpp \
- ProfileRenderWatermarkResult.cpp \
- ProfileRenderWatermarksResult.cpp \
- ProfileResult.cpp \
- RelateProperty.cpp \
- ResizeBox.cpp \
- Rule.cpp \
- ScaleRange.cpp \
- SimpleSymbol.cpp \
- SimpleSymbolDefinition.cpp \
- Stroke.cpp \
- SupplementalSpatialContextInfo.cpp \
- Symbol.cpp \
- SymbolDefinition.cpp \
- SymbolInstance.cpp \
- Symbolization.cpp \
- Text.cpp \
- TextFrame.cpp \
- TextSymbol.cpp \
- ThemeLabel.cpp \
- TileSetDefinition.cpp \
- TileSetSource.cpp \
- TileStoreParameters.cpp \
- TileWatermarkPosition.cpp \
- UnicodeString.cpp \
- URLData.cpp \
- VectorLayerDefinition.cpp \
- VectorScaleRange.cpp \
- Version.cpp \
- W2DSymbol.cpp \
- WatermarkAppearance.cpp \
- WatermarkDefinition.cpp \
- WatermarkInstance.cpp \
- WatermarkPosition.cpp \
- WatermarkXOffset.cpp \
- WatermarkYOffset.cpp \
- XYWatermarkPosition.cpp
-noinst_HEADERS = \
- Common/Color.h \
- Common/Extent3D.h \
- Common/Point3D.h \
- Common/Size2D.h \
- Common/StringObject.h \
- Common/Vector3D.h \
- PrintLayout/DataConfiguration.h \
- PrintLayout/MapView.h \
- PrintLayout/MapViewportDefinition.h \
- PrintLayout/PrintLayoutDefinition.h \
- PrintLayout/PrintLayoutElement.h \
- PrintLayout/PrintLayoutElementDefinition.h \
- PrintLayout/PrintLayoutElementStyle.h \
- PrintLayout/PropertyMapping.h \
- PrintLayout/StylizationConfiguration.h \
- PrintLayout/Thickness.h \
- AreaRule.h \
- AreaSymbolization2D.h \
- AreaTypeStyle.h \
- AreaUsage.h \
- AttributeRelate.h \
- Base64.h \
- BaseMapLayer.h \
- BaseMapLayerGroup.h \
- BlockSymbol.h \
- Box2D.h \
- CalculatedProperty.h \
- ChannelBand.h \
- CompositeRule.h \
- CompositeSymbolization.h \
- CompositeTypeStyle.h \
- CompoundSymbolDefinition.h \
- ConvertUTF.h \
- DisplayScale.h \
- DrawingLayerDefinition.h \
- ElevationSettings.h \
- Extension.h \
- FeatureSource.h \
- FeatureTypeStyle.h \
- Fill.h \
- FontSymbol.h \
- GraphicElement.h \
- GridColor.h \
- GridColorRule.h \
- GridColorStyle.h \
- GridLayerDefinition.h \
- GridScaleRange.h \
- GridSurfaceStyle.h \
- HillShade.h \
- IFeatureTypeStyleVisitor.h \
- IGraphicElementVisitor.h \
- ISymbolDefinitionVisitor.h \
- ISymbolVisitor.h \
- ISymbolizationVisitor.h \
- Image.h \
- ImageSymbol.h \
- Label.h \
- LayerDefinition.h \
- LengthConverter.h \
- LineRule.h \
- LineSymbolization2D.h \
- LineTypeStyle.h \
- LineUsage.h \
- MapDefinition.h \
- MapLayer.h \
- MapLayerGroup.h \
- MapLayerGroupCommon.h \
- MarkSymbol.h \
- MdfModel.h \
- MdfOwnerCollection.h \
- MdfRootObject.h \
- NameStringPair.h \
- Override.h \
- Parameter.h \
- Path.h \
- PointRule.h \
- PointSymbolization2D.h \
- PointTypeStyle.h \
- PointUsage.h \
- ProfileRenderLabelsResult.h \
- ProfileRenderLayerResult.h \
- ProfileRenderLayersResult.h \
- ProfileRenderLayersResultBase.h \
- ProfileRenderMapResult.h \
- ProfileRenderSelectionResult.h \
- ProfileRenderWatermarkResult.h \
- ProfileRenderWatermarksResult.h \
- ProfileResult.h \
- RelateProperty.h \
- ResizeBox.h \
- Rule.h \
- ScaleRange.h \
- SimpleSymbol.h \
- SimpleSymbolDefinition.h \
- SizeContexts.h \
- Stroke.h \
- SupplementalSpatialContextInfo.h \
- Symbol.h \
- SymbolDefinition.h \
- SymbolInstance.h \
- Symbolization.h \
- Text.h \
- TextFrame.h \
- TextSymbol.h \
- ThemeLabel.h \
- TileSetDefinition.h \
- TileSetSource.h \
- TileStoreParameters.h \
- TileWatermarkPosition.h \
- UnicodeString.h \
- URLData.h \
- VectorLayerDefinition.h \
- VectorScaleRange.h \
- Version.h \
- W2DSymbol.h \
- WatermarkAppearance.h \
- WatermarkDefinition.h \
- WatermarkInstance.h \
- WatermarkOffsetUnit.h \
- WatermarkPosition.h \
- WatermarkXOffset.h \
- WatermarkYOffset.h \
- XYWatermarkPosition.h \
- stdafx.h
-libMgMdfModel_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Common/MdfParser/Makefile.am
--- trunk/MgDev/Common/MdfParser/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Common/MdfParser/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,245 +0,0 @@
-EXTRA_DIST = MdfParser.vcproj MdfParser.rc
-INCLUDES = \
- -I../MdfModel/ \
- -I../../Oem/dbxml/xerces-c-src/src/
-lib_LTLIBRARIES = libMgMdfParser.la
-libMgMdfParser_la_SOURCES = \
- Common/IOColor.cpp \
- Common/IOExtent3D.cpp \
- Common/IOPoint3D.cpp \
- Common/IOSize2D.cpp \
- Common/IOStringObjectCollection.cpp \
- Common/IOVector3D.cpp \
- PrintLayout/IODataConfiguration.cpp \
- PrintLayout/IOMapView.cpp \
- PrintLayout/IOMapViewportDefinition.cpp \
- PrintLayout/IOPrintLayoutDefinition.cpp \
- PrintLayout/IOPrintLayoutElementCollection.cpp \
- PrintLayout/IOPrintLayoutElementDefinition.cpp \
- PrintLayout/IOPrintLayoutElementStyle.cpp \
- PrintLayout/IOPropertyMappingCollection.cpp \
- PrintLayout/IOStylizationConfiguration.cpp \
- PrintLayout/IOThickness.cpp \
- FSDSAX2Parser.cpp \
- IOAreaRule.cpp \
- IOAreaSymbolization2D.cpp \
- IOAreaTypeStyle.cpp \
- IOAreaUsage.cpp \
- IOAttributeRelate.cpp \
- IOBaseMapDefinition.cpp \
- IOBaseMapLayer.cpp \
- IOBaseMapLayerGroup.cpp \
- IOBlockSymbol.cpp \
- IOCalculatedProperty.cpp \
- IOChannelBand.cpp \
- IOCompositeRule.cpp \
- IOCompositeSymbolization.cpp \
- IOCompositeTypeStyle.cpp \
- IOCompoundSymbolDefinition.cpp \
- IODrawingLayerDefinition.cpp \
- IOElevationSettings.cpp \
- IOExtension.cpp \
- IOExtra.cpp \
- IOFeatureSource.cpp \
- IOFill.cpp \
- IOFontSymbol.cpp \
- IOGraphicElement.cpp \
- IOGraphicElementCollection.cpp \
- IOGridColor.cpp \
- IOGridColorBands.cpp \
- IOGridColorRule.cpp \
- IOGridColorStyle.cpp \
- IOGridLayerDefinition.cpp \
- IOGridScaleRange.cpp \
- IOGridSurfaceStyle.cpp \
- IOHillShade.cpp \
- IOImage.cpp \
- IOImageSymbol.cpp \
- IOLabel.cpp \
- IOLineRule.cpp \
- IOLineSymbolization2D.cpp \
- IOLineTypeStyle.cpp \
- IOLineUsage.cpp \
- IOMapDefinition.cpp \
- IOMapLayer.cpp \
- IOMapLayerCommon.cpp \
- IOMapLayerGroup.cpp \
- IOMapLayerGroupCommon.cpp \
- IOMarkSymbol.cpp \
- IONameStringPair.cpp \
- IOOverride.cpp \
- IOOverrideCollection.cpp \
- IOParameter.cpp \
- IOParameterCollection.cpp \
- IOPath.cpp \
- IOPointRule.cpp \
- IOPointSymbolization2D.cpp \
- IOPointTypeStyle.cpp \
- IOPointUsage.cpp \
- IOProfileRenderLabelsResult.cpp \
- IOProfileRenderLayerResult.cpp \
- IOProfileRenderLayersResult.cpp \
- IOProfileRenderMapResult.cpp \
- IOProfileRenderSelectionResult.cpp \
- IOProfileRenderWatermarkResult.cpp \
- IOProfileRenderWatermarksResult.cpp \
- IOProfileResult.cpp \
- IORelateProperty.cpp \
- IOResizeBox.cpp \
- IOResourceRef.cpp \
- IOScaleRange.cpp \
- IOSimpleSymbol.cpp \
- IOSimpleSymbolDefinition.cpp \
- IOStroke.cpp \
- IOSupplementalSpatialContextInfo.cpp \
- IOSymbol.cpp \
- IOSymbolInstance.cpp \
- IOText.cpp \
- IOTextFrame.cpp \
- IOThemeLabel.cpp \
- IOTileSetDefinition.cpp \
- IOTileSetSource.cpp \
- IOTileStoreParameters.cpp \
- IOTileWatermarkPosition.cpp \
- IOUnknown.cpp \
- IOURLData.cpp \
- IOUtil.cpp \
- IOVectorLayerDefinition.cpp \
- IOVectorScaleRange.cpp \
- IOW2DSymbol.cpp \
- IOWatermarkAppearance.cpp \
- IOWatermarkDefinition.cpp \
- IOWatermarkInstance.cpp \
- IOWatermarkOffsetUnit.cpp \
- IOWatermarkXOffset.cpp \
- IOWatermarkYOffset.cpp \
- IOXYWatermarkPosition.cpp \
- MdfParser.cpp \
- SAX2ElementHandler.cpp \
- SAX2Parser.cpp
-noinst_HEADERS = \
- Common/IOColor.h \
- Common/IOExtent3D.h \
- Common/IOPoint3D.h \
- Common/IOSize2D.h \
- Common/IOStringObjectCollection.h \
- Common/IOVector3D.h \
- PrintLayout/IODataConfiguration.h \
- PrintLayout/IOMapView.h \
- PrintLayout/IOMapViewportDefinition.h \
- PrintLayout/IOPrintLayoutDefinition.h \
- PrintLayout/IOPrintLayoutElementCollection.h \
- PrintLayout/IOPrintLayoutElementDefinition.h \
- PrintLayout/IOPrintLayoutElementStyle.h \
- PrintLayout/IOPropertyMappingCollection.h \
- PrintLayout/IOStylizationConfiguration.h \
- PrintLayout/IOThickness.h \
- FSDSAX2Parser.h \
- IOAreaRule.h \
- IOAreaSymbolization2D.h \
- IOAreaTypeStyle.h \
- IOAreaUsage.h \
- IOAttributeRelate.h \
- IOBaseMapDefinition.h \
- IOBaseMapLayer.h \
- IOBaseMapLayerGroup.h \
- IOBlockSymbol.h \
- IOCalculatedProperty.h \
- IOChannelBand.h \
- IOCompositeRule.h \
- IOCompositeSymbolization.h \
- IOCompositeTypeStyle.h \
- IOCompoundSymbolDefinition.h \
- IODrawingLayerDefinition.h \
- IOElevationSettings.h \
- IOExtension.h \
- IOExtra.h \
- IOFeatureSource.h \
- IOFill.h \
- IOFontSymbol.h \
- IOGraphicElement.h \
- IOGraphicElementCollection.h \
- IOGridColor.h \
- IOGridColorRule.h \
- IOGridColorStyle.h \
- IOGridLayerDefinition.h \
- IOGridScaleRange.h \
- IOGridSurfaceStyle.h \
- IOHillShade.h \
- IOImage.h \
- IOImageSymbol.h \
- IOLabel.h \
- IOLineRule.h \
- IOLineSymbolization2D.h \
- IOLineTypeStyle.h \
- IOLineUsage.h \
- IOMapDefinition.h \
- IOMapLayer.h \
- IOMapLayerCommon.h \
- IOMapLayerGroup.h \
- IOMapLayerGroupCommon.h \
- IOMarkSymbol.h \
- IONameStringPair.h \
- IOOverride.h \
- IOOverrideCollection.h \
- IOParameter.h \
- IOParameterCollection.h \
- IOPath.h \
- IOPointRule.h \
- IOPointSymbolization2D.h \
- IOPointTypeStyle.h \
- IOPointUsage.h \
- IOProfileRenderLabelsResult.h \
- IOProfileRenderLayerResult.h \
- IOProfileRenderLayersResult.h \
- IOProfileRenderMapResult.h \
- IOProfileRenderSelectionResult.h \
- IOProfileRenderWatermarkResult.h \
- IOProfileRenderWatermarksResult.h \
- IOProfileResult.h \
- IORelateProperty.h \
- IOResizeBox.h \
- IOResourceRef.h \
- IOScaleRange.h \
- IOSimpleSymbol.h \
- IOSimpleSymbolDefinition.h \
- IOStroke.h \
- IOSupplementalSpatialContextInfo.h \
- IOSymbol.h \
- IOSymbolInstance.h \
- IOText.h \
- IOTextFrame.h \
- IOThemeLabel.h \
- IOTileSetDefinition.h \
- IOTileSetSource.h \
- IOTileStoreParameters.h \
- IOTileWatermarkPosition.h \
- IOUnknown.h \
- IOURLData.h \
- IOUtil.h \
- IOVectorLayerDefinition.h \
- IOVectorScaleRange.h \
- IOW2DSymbol.h \
- IOWatermarkAppearance.h \
- IOWatermarkDefinition.h \
- IOWatermarkInstance.h \
- IOWatermarkOffsetUnit.h \
- IOWatermarkXOffset.h \
- IOWatermarkYOffset.h \
- IOXYWatermarkPosition.h \
- MdfParser.h \
- SAX2ElementHandler.h \
- SAX2Parser.h \
- stdafx.h
-libMgMdfParser_la_LIBADD = -lMgMdfModel -lxerces-c
-libMgMdfParser_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../MdfModel \
Deleted: trunk/MgDev/Common/PlatformBase/Makefile.am
--- trunk/MgDev/Common/PlatformBase/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Common/PlatformBase/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,269 +0,0 @@
-EXTRA_DIST = PlatformBase.vcproj PlatformBase.rc
-lib_LTLIBRARIES = libMgPlatformBase.la
-libMgPlatformBase_la_SOURCES = \
- PlatformBaseBuild.cpp
- Data/BlobProperty.cpp \
- Data/BooleanProperty.cpp \
- Data/ByteProperty.cpp \
- Data/ClobProperty.cpp\
- Data/Color.cpp \
- Data/DateTimeProperty.cpp \
- Data/DoubleProperty.cpp \
- Data/Int16Property.cpp \
- Data/Int32Property.cpp \
- Data/Int64Property.cpp \
- Data/IntCollection.cpp \
- Data/Point3D.cpp \
- Data/PropertyDefinitionCollection.cpp \
- Data/SerializableCollection.cpp \
- Data/SingleProperty.cpp \
- Data/StringPropertyCollection.cpp \
- Data/Vector3D.cpp \
- Exception/ArrayTypeMismatchException.cpp \
- Exception/DuplicateResourceDataException.cpp \
- Exception/DuplicateResourceException.cpp \
- Exception/EmptyFeatureSetException.cpp \
- Exception/FdoException.cpp \
- Exception/FeatureServiceException.cpp \
- Exception/InvalidLayerDefinitionException.cpp \
- Exception/InvalidMapDefinitionException.cpp \
- Exception/InvalidRepositoryNameException.cpp \
- Exception/InvalidRepositoryTypeException.cpp \
- Exception/InvalidResourceDataNameException.cpp \
- Exception/InvalidResourceDataTypeException.cpp \
- Exception/InvalidResourceNameException.cpp \
- Exception/InvalidResourcePathException.cpp \
- Exception/InvalidResourcePreProcessingTypeException.cpp \
- Exception/InvalidResourceTypeException.cpp \
- Exception/InvalidSymbolDefinitionException.cpp \
- Exception/LayerNotFoundException.cpp \
- Exception/ResourceBusyException.cpp \
- Exception/ResourceDataNotFoundException.cpp \
- Exception/ResourceNotFoundException.cpp \
- Exception/ServiceNotAvailableException.cpp \
- Exception/ServiceNotSupportedException.cpp \
- Exception/UserNotFoundException.cpp \
- MapLayer/ChangeList.cpp \
- MapLayer/LayerBase.cpp \
- MapLayer/LayerCollection.cpp \
- MapLayer/LayerGroup.cpp \
- MapLayer/LayerGroupCollection.cpp \
- MapLayer/MapBase.cpp \
- MapLayer/MapCollection.cpp \
- MapLayer/ObjectChange.cpp \
- MapLayer/ReadOnlyLayerCollection.cpp \
- MapLayer/SelectionBase.cpp \
- Services/BaseServiceDefs.cpp \
- Services/ClassDefinition.cpp \
- Services/ClassDefinitionCollection.cpp \
- Services/DataPropertyDefinition.cpp \
- Services/DataReader.cpp \
- Services/DeleteFeatures.cpp \
- Services/FeatureAggregateOptions.cpp \
- Services/FeatureCommandCollection.cpp \
- Services/FeatureDefs.cpp \
- Services/FeatureProperty.cpp \
- Services/FeatureQueryOptions.cpp \
- Services/FeatureReader.cpp \
- Services/FeatureSchema.cpp \
- Services/FeatureSchemaCollection.cpp \
- Services/FeatureService.cpp \
- Services/FeatureSet.cpp \
- Services/FeatureSourceParams.cpp \
- Services/FeatureSpatialOperations.cpp \
- Services/FileFeatureSourceParams.cpp \
- Services/GeometricPropertyDefinition.cpp \
- Services/GeometryProperty.cpp \
- Services/GeometryTypeInfo.cpp \
- Services/InsertFeatures.cpp \
- Services/LockFeatures.cpp \
- Services/LongTransactionData.cpp \
- Services/LongTransactionReader.cpp \
- Services/ObjectPropertyDefinition.cpp \
- Services/OrderingOption.cpp \
- Services/Parameter.cpp \
- Services/ParameterCollection.cpp \
- Services/Raster.cpp \
- Services/RasterProperty.cpp \
- Services/RasterPropertyDefinition.cpp \
- Services/RasterTypes.cpp \
- Services/Resource.cpp \
- Services/ResourceDefs.cpp \
- Services/ResourceIdentifier.cpp \
- Services/ResourceService.cpp \
- Services/Service.cpp \
- Services/ServiceRegistry.cpp \
- Services/SpatialContextData.cpp \
- Services/SpatialContextReader.cpp \
- Services/SqlDataReader.cpp \
- Services/Transaction.cpp \
- Services/UnlockFeatures.cpp \
- Services/UpdateFeatures.cpp \
- Services/Warnings.cpp \
- Services/PrintLayoutService/MapView.cpp \
- Services/PrintLayoutService/MapViewportBase.cpp \
- Services/PrintLayoutService/PrintLayoutBase.cpp \
- Services/PrintLayoutService/PrintLayoutDefs.cpp \
- Services/PrintLayoutService/PrintLayoutElementBase.cpp \
- Services/PrintLayoutService/PrintLayoutElementCollection.cpp \
- Services/PrintLayoutService/PrintLayoutElementFactoryBase.cpp \
- Services/PrintLayoutService/PrintLayoutServiceBase.cpp \
- Services/PrintLayoutService/PropertyMapping.cpp \
- Services/PrintLayoutService/PropertyMappingCollection.cpp
- PlatformBase.h \
- Data/BlobProperty.h \
- Data/BooleanProperty.h \
- Data/ByteProperty.h \
- Data/ClobProperty.h \
- Data/Color.h \
- Data/DateTimeProperty.h \
- Data/DoubleProperty.h \
- Data/Int16Property.h \
- Data/Int32Property.h \
- Data/Int64Property.h \
- Data/IntCollection.h \
- Data/Point3D.h \
- Data/PropertyDefinitionCollection.h \
- Data/SerializableCollection.h \
- Data/SingleProperty.h \
- Data/StringPropertyCollection.h \
- Data/Vector3D.h \
- Exception/ArrayTypeMismatchException.h \
- Exception/DuplicateResourceDataException.h \
- Exception/DuplicateResourceException.h \
- Exception/EmptyFeatureSetException.h \
- Exception/FdoException.h \
- Exception/FeatureServiceException.h \
- Exception/InvalidLayerDefinitionException.h \
- Exception/InvalidMapDefinitionException.h \
- Exception/InvalidRepositoryNameException.h \
- Exception/InvalidRepositoryTypeException.h \
- Exception/InvalidResourceDataNameException.h \
- Exception/InvalidResourceDataTypeException.h \
- Exception/InvalidResourceNameException.h \
- Exception/InvalidResourcePathException.h \
- Exception/InvalidResourcePreProcessingTypeException.h \
- Exception/InvalidResourceTypeException.h \
- Exception/InvalidSymbolDefinitionException.h \
- Exception/LayerNotFoundException.h \
- Exception/ResourceBusyException.h \
- Exception/ResourceDataNotFoundException.h \
- Exception/ResourceNotFoundException.h \
- Exception/ServiceNotAvailableException.h \
- Exception/ServiceNotSupportedException.h \
- Exception/UserNotFoundException.h \
- MapLayer/ChangeList.h \
- MapLayer/LayerBase.h \
- MapLayer/LayerCollection.h \
- MapLayer/LayerGroup.h \
- MapLayer/LayerGroupCollection.h \
- MapLayer/LayerGroupType.h \
- MapLayer/LayerType.h \
- MapLayer/MapBase.h \
- MapLayer/MapCollection.h \
- MapLayer/ObjectChange.h \
- MapLayer/ReadOnlyLayerCollection.h \
- MapLayer/SelectionBase.h \
- Services/BaseService.h \
- Services/BaseServiceDefs.h \
- Services/ClassDefinition.h \
- Services/ClassDefinitionCollection.h \
- Services/DataPropertyDefinition.h \
- Services/DataReader.h \
- Services/DeleteFeatures.h \
- Services/FeatureAggregateOptions.h \
- Services/FeatureCommand.h \
- Services/FeatureCommandCollection.h \
- Services/FeatureCommandType.h \
- Services/FeatureDefs.h \
- Services/FeatureGeometricType.h \
- Services/FeatureProperty.h \
- Services/FeatureQueryOptions.h \
- Services/FeatureReader.h \
- Services/FeatureSchema.h \
- Services/FeatureSchemaCollection.h \
- Services/FeatureService.h \
- Services/FeatureServiceCommon.h \
- Services/FeatureSet.h \
- Services/FeatureSourceParams.h \
- Services/FeatureSpatialOperations.h \
- Services/FileFeatureSourceParams.h \
- Services/GeometricPropertyDefinition.h \
- Services/GeometryProperty.h \
- Services/GeometryTypeInfo.h \
- Services/GwsFeatureReader.h \
- Services/InsertFeatures.h \
- Services/LockFeatures.h \
- Services/LongTransactionData.h \
- Services/LongTransactionReader.h \
- Services/ObjectPropertyDefinition.h \
- Services/ObjectPropertyType.h \
- Services/OrderingOption.h \
- Services/ParameterDirection.h \
- Services/Parameter.h \
- Services/ParameterCollection.h \
- Services/PlatformBaseClassId.h \
- Services/Raster.h \
- Services/RasterProperty.h \
- Services/RasterPropertyDefinition.h \
- Services/RasterTypes.h \
- Services/Reader.h \
- Services/ReaderType.h \
- Services/Resource.h \
- Services/ResourceDefs.h \
- Services/ResourceIdentifier.h \
- Services/ResourceService.h \
- Services/Service.h \
- Services/ServiceRegistry.h \
- Services/SpatialContextData.h \
- Services/SpatialContextExtentType.h \
- Services/SpatialContextReader.h \
- Services/SqlDataReader.h \
- Services/Transaction.h \
- Services/UnlockFeatures.h \
- Services/UpdateFeatures.h \
- Services/Warnings.h \
- Services/PrintLayoutService/MapView.h \
- Services/PrintLayoutService/MapViewportBase.h \
- Services/PrintLayoutService/PrintLayoutBase.h \
- Services/PrintLayoutService/PrintLayoutDefs.h \
- Services/PrintLayoutService/PrintLayoutElementBase.h \
- Services/PrintLayoutService/PrintLayoutElementCollection.h \
- Services/PrintLayoutService/PrintLayoutElementFactoryBase.h \
- Services/PrintLayoutService/PrintLayoutServiceBase.h \
- Services/PrintLayoutService/PropertyMapping.h \
- Services/PrintLayoutService/PropertyMappingCollection.h
-INCLUDES = \
- -I../Security \
- -I../MdfParser \
- -I../MdfModel \
- -I../Foundation \
- -I../Geometry \
-libMgPlatformBase_la_LIBADD = \
- -lACE \
- -lMgMdfModel \
- -lMgMdfParser \
- -lMgFoundation \
- -lMgGeometry
-libMgPlatformBase_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../Foundation \
- -L../Geometry \
- -L../../Common/CoordinateSystem \
- -L../MdfParser \
- -L../MdfModel
Deleted: trunk/MgDev/Common/Renderers/Makefile.am
--- trunk/MgDev/Common/Renderers/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Common/Renderers/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,101 +0,0 @@
-EXTRA_DIST = Renderers.vcproj Renderers.rc
-INCLUDES = \
- -I../MdfModel/ \
- -I../Stylization/ \
- -I$(map_fdo_include) \
- -I$(map_fdo_include)/ExpressionEngine \
- -I../../Oem/DWFTK/develop/global/src/ \
- -I../../Oem/DWFTK/develop/global/src/dwf/ \
- -I../../Oem/gd/gd/ \
- -I../../Oem/gd/lpng \
- -I../../Oem/gd/freetype/include/ \
- -I../../Oem/agg-2.4/include \
- -I../../Oem/agg-2.4/font_freetype
-lib_LTLIBRARIES = libMgRenderers.la
-libMgRenderers_la_SOURCES = \
- AGGRenderer.cpp \
- AGGImageIO.cpp \
- AGGW2DRewriter.cpp \
- AGGFillPatterns.cpp \
- ../../Oem/agg-2.4/font_freetype/agg_font_freetype.cpp \
- CriticalSection.cpp \
- DWFRenderer.cpp \
- EPlotRenderer.cpp \
- FontManager.cpp \
- GDFillPatterns.cpp \
- GDRenderer.cpp \
- GDUtils.cpp \
- GDW2DRewriter.cpp \
- KmlContent.cpp \
- KmlLineStyle.cpp \
- KmlPolyStyle.cpp \
- KmlIconStyle.cpp \
- KmlRenderer.cpp \
- MapQuantization.cpp \
- ObservationMesh.cpp \
- RenderUtil.cpp \
- RS_ByteData.cpp \
- SymbolTrans.cpp \
- UTFGridRenderer.cpp \
- UTFGridContent.cpp \
- W2DRewriter.cpp \
- complex_polygon_gd.cpp
-noinst_HEADERS = \
- AGGRenderer.h \
- AGGImageIO.h \
- agg_context.h \
- agg_utfgrid_context.h \
- agg_mg_overloads.h \
- AGGW2DRewriter.h \
- AGGFillPatterns.h \
- CriticalSection.h \
- DWFRenderer.h \
- DWFRSInputStream.h \
- EPlotRenderer.h \
- FontManager.h \
- GDFillPatterns.h \
- GDRenderer.h \
- GDUtils.h \
- GDW2DRewriter.h \
- KmlContent.h \
- KmlLineStyle.h \
- KmlPolyStyle.h \
- KmlIconStyle.h \
- KmlRenderer.h \
- MapQuantization.h \
- MapUTFGrid.h \
- ObservationMesh.h \
- Renderers.h \
- RenderUtil.h \
- RS_ByteData.h \
- RSDWFInputStream.h \
- RSDWFOutputStream.h \
- stdafx.h \
- SymbolTrans.h \
- UTFGridRenderer.h \
- UTFGridContent.h \
- W2DRewriter.h \
- whip_fill_library.h \
- whip_hatch_library.h \
- complex_polygon_gd.h
-AM_CXXFLAGS = @CXXFLAGS@ -DDWFTK_BUILD_EXPAT
-libMgRenderers_la_LIBADD = \
- ../../Oem/gd/gd/.libs/libgd.a \
- ../../Oem/gd/freetype/objs/.libs/libfreetype.a \
- ../../Oem/gd/jpeg/.libs/libjpeg.a \
- ../../Oem/gd/lpng/libpng.a \
- ../../Oem/agg-2.4/src/libagg.a \
- -ldwfcore \
- -ldwftk
-libMgRenderers_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../../Oem/DWFTK/develop/global/src/dwfcore/.libs \
- -L../../Oem/DWFTK/develop/global/src/dwf/.libs
Deleted: trunk/MgDev/Common/Security/Makefile.am
--- trunk/MgDev/Common/Security/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Common/Security/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,15 +0,0 @@
-EXTRA_DIST = Security.vcproj
-lib_LIBRARIES = libMgSecurity.a
-libMgSecurity_a_SOURCES = \
- SecurityBuild.cpp
-noinst_HEADERS = \
- CryptographyUtil.cpp \
- CryptographyUtil.h \
- LicenseUtil.cpp \
- LicenseUtil.h \
- SecurityDefs.h
Deleted: trunk/MgDev/Common/Stylization/Makefile.am
--- trunk/MgDev/Common/Stylization/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Common/Stylization/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,220 +0,0 @@
-EXTRA_DIST = Stylization.vcproj Stylization.rc
-INCLUDES = \
- -I../MdfModel/ \
- -I../Foundation \
-lib_LTLIBRARIES = libMgStylization.la
-libMgStylization_la_SOURCES = \
- atom_element_abandonment.cpp \
- atom_element_environment.cpp \
- atom_element_location.cpp \
- atom_element_structure.cpp \
- atom_element_style.cpp \
- atom_element_textrun.cpp \
- atom_element_transform.cpp \
- atom_element_universe.cpp \
- atom_impl.cpp \
- Band.cpp \
- BandData.cpp \
- BIDIConverter.cpp \
- Color.cpp \
- DefaultStylizer.cpp \
- ExpressionFunctionArgb.cpp \
- ExpressionFunctionDecap.cpp \
- ExpressionFunctionFeatureClass.cpp \
- ExpressionFunctionFeatureId.cpp \
- ExpressionFunctionFeatureSource.cpp \
- ExpressionFunctionHtmlColor.cpp \
- ExpressionFunctionIf.cpp \
- ExpressionFunctionLayerDefinition.cpp \
- ExpressionFunctionLayerId.cpp \
- ExpressionFunctionLookup.cpp \
- ExpressionFunctionMapCenterX.cpp \
- ExpressionFunctionMapCenterY.cpp \
- ExpressionFunctionMapName.cpp \
- ExpressionFunctionMapScale.cpp \
- ExpressionFunctionRange.cpp \
- ExpressionFunctionSession.cpp \
- ExpressionFunctionUrlEncode.cpp \
- ExpressionHelper.cpp \
- GeometryAdapter.cpp \
- GeometryAlgorithms.cpp \
- GridApplyStatusReporter.cpp \
- GridChannelBand.cpp \
- GridColorBandHandler.cpp \
- GridColorBandsHandler.cpp \
- GridColorHandler.cpp \
- GridColorNullHandler.cpp \
- GridColorThemeHandler.cpp \
- GridData.cpp \
- GridStyleColorHandler.cpp \
- GridStyleSurfaceColorHandler.cpp \
- GridStyleSurfaceHandler.cpp \
- GridStylizer.cpp \
- GridStylizerReactor.cpp \
- GridTheme.cpp \
- GridThemeParser.cpp \
- KeyEncode.cpp \
- LabelRenderer.cpp \
- LabelRendererBase.cpp \
- LabelRendererLocal.cpp \
- LineBuffer.cpp \
- LineStyleDef.cpp \
- Matrix3D.cpp \
- mtext_parser.cpp \
- Point2D.cpp \
- Point3D.cpp \
- PointAdapter.cpp \
- PolygonAdapter.cpp \
- PolygonUtils.cpp \
- PolylineAdapter.cpp \
- RasterAdapter.cpp \
- RichTextEngine.cpp \
- RS_FontEngine.cpp \
- RS_TextMetrics.cpp \
- SE_AreaPositioning.cpp \
- SE_Bounds.cpp \
- SE_BufferPool.cpp \
- SE_ExpressionBase.cpp \
- SE_LineBuffer.cpp \
- SE_LineRenderer.cpp \
- SE_Matrix.cpp \
- SE_PositioningAlgorithms.cpp \
- SE_Renderer.cpp \
- SE_StyleVisitor.cpp \
- SE_SymbolDefProxies.cpp \
- SE_SymbolManager.cpp \
- SimpleOverpost.cpp \
- StylizationEngine.cpp \
- StylizationUtil.cpp \
- Stylizer.cpp \
- ThemeParameters.cpp \
- Vector2D.cpp \
- Vector3D.cpp \
- TransformMesh.cpp
-noinst_HEADERS = \
- atom.h \
- atom_element.h \
- atom_element_abandonment.h \
- atom_element_environment.h \
- atom_element_location.h \
- atom_element_structure.h \
- atom_element_style.h \
- atom_element_textrun.h \
- atom_element_transform.h \
- atom_element_universe.h \
- Band.h \
- BandData.h \
- BIDIConverter.h \
- Bounds.h \
- Color.h \
- CSysTransformer.h \
- DataValueStack.h \
- DefaultStylizer.h \
- ExpressionFunctionArgb.h \
- ExpressionFunctionDecap.h \
- ExpressionFunctionFeatureClass.h \
- ExpressionFunctionFeatureId.h \
- ExpressionFunctionFeatureSource.h \
- ExpressionFunctionHtmlColor.h \
- ExpressionFunctionIf.h \
- ExpressionFunctionLayerDefinition.h \
- ExpressionFunctionLayerId.h \
- ExpressionFunctionLookup.h \
- ExpressionFunctionMapCenterX.h \
- ExpressionFunctionMapCenterY.h \
- ExpressionFunctionMapName.h \
- ExpressionFunctionMapScale.h \
- ExpressionFunctionRange.h \
- ExpressionFunctionSession.h \
- ExpressionFunctionUrlEncode.h \
- ExpressionHelper.h \
- FeatureTypeStyleVisitor.h \
- GeometryAdapter.h \
- GeometryAlgorithms.h \
- GridApplyStatusReporter.h \
- GridChannelBand.h \
- GridColorBandHandler.h \
- GridColorBandsHandler.h \
- GridColorHandler.h \
- GridColorNullHandler.h \
- GridColorThemeHandler.h \
- GridData.h \
- GridStatusReporter.h \
- GridStyleColorHandler.h \
- GridStyleHandler.h \
- GridStyleSurfaceColorHandler.h \
- GridStyleSurfaceHandler.h \
- GridStylizer.h \
- GridStylizerReactor.h \
- GridTheme.h \
- GridThemeParser.h \
- KeyEncode.h \
- LabelRenderer.h \
- LabelRendererBase.h \
- LabelRendererLocal.h \
- LineBuffer.h \
- LineStyle.h \
- LineStyleDef.h \
- MathHelper.h \
- Matrix3D.h \
- mtext_parser.h \
- Point2D.h \
- Point3D.h \
- PointAdapter.h \
- PolygonAdapter.h \
- PolygonUtils.h \
- PolylineAdapter.h \
- RasterAdapter.h \
- Renderer.h \
- RendererStyles.h \
- RichTextEngine.h \
- RS_BufferOutputStream.h \
- RS_FeatureReader.h \
- RS_Font.h \
- RS_FontEngine.h \
- RS_InputStream.h \
- RS_OutputStream.h \
- RS_Raster.h \
- RS_SymbolManager.h \
- RS_TextMetrics.h \
- SE_AreaPositioning.h \
- SE_Bounds.h \
- SE_BufferPool.h \
- SE_ExpressionBase.h \
- SE_LineBuffer.h \
- SE_Matrix.h \
- SE_PositioningAlgorithms.h \
- SE_Renderer.h \
- SE_RendererStyles.h \
- SE_RenderProxies.h \
- SE_StyleVisitor.h \
- SE_SymbolDefProxies.h \
- SE_SymbolManager.h \
- SimpleOverpost.h \
- SLDSymbols.h \
- stdafx.h \
- Stylization.h \
- StylizationAPI.h \
- StylizationDefs.h \
- StylizationEngine.h \
- StylizationUtil.h \
- Stylizer.h \
- SymbolVisitor.h \
- ThemeParameters.h \
- Vector2D.h \
- Vector3D.h \
- TransformMesh.h
-libMgStylization_la_LIBADD = -lExpressionEngine
-libMgStylization_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L$(map_fdo_lib)
Deleted: trunk/MgDev/Makefile.am
--- trunk/MgDev/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,4 +0,0 @@
-SUBDIRS = $(map_toplevel_subdirs)
-DIST_SUBDIRS = Oem Common Server Web
-EXTRA_DIST = BuildTools/WebTools/IMake README UnitTest License.html build_oem.sh
Deleted: trunk/MgDev/Portable/DesktopUnmanagedApi/JavaApiEx/Makefile.am
--- trunk/MgDev/Portable/DesktopUnmanagedApi/JavaApiEx/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Portable/DesktopUnmanagedApi/JavaApiEx/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,468 +0,0 @@
-EXTRA_DIST = getclassid.code \
- catchall.code \
- java.i \
- JavaApiEx.rc \
- JavaApiEx.vcproj \
- org/osgeo/mapguide/AppThrowable.java \
- org/osgeo/mapguide/MgBase64.java \
- org/osgeo/mapguide/MgLocalizer.java
-prefix=@prefix@/webserverextensions
-INCLUDES = -I../../../Common/MdfModel \
- -I../../../Common/Foundation \
- -I../../../Common/Geometry \
- -I../../../Common/PlatformBase \
- -I../../../Common/MapGuideCommon \
- -I$(JAVA_HOME)/include \
- -I$(JAVA_HOME)/include/linux \
- -I../../../Oem/ACE/ACE_wrappers \
- -I../HttpHandler \
- -I../WebSupport \
- -I../WebApp \
- -I../../../Oem/dbxml/xerces-c-src/src
-BUILT_SOURCES = MgApi_wrap.cpp
-lib_LTLIBRARIES = libMapGuideJavaApiEx.la
-nodist_libMapGuideJavaApiEx_la_SOURCES = MgApi_wrap.cpp
-AM_CXXFLAGS = @CXXFLAGS@ -fno-strict-aliasing -DJAVA
-libMapGuideJavaApiEx_la_LIBADD = \
- -lACE \
- -lMgFoundation \
- -lMgGeometry \
- -lMgMapGuideCommon \
- -lMgHttpHandler \
- -lMgMdfModel \
- -lMgMdfParser \
- -lxerces-c \
- -lMgWebApp
-libMapGuideJavaApiEx_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../../../Oem/ACE/ACE_wrappers/ace \
- -L../../../Common/MdfModel \
- -L../../../Common/MdfParser \
- -L../../../Common/Foundation \
- -L../../../Common/Geometry \
- -L../../../Common/PlatformBase \
- -L../../../Common/MapGuideCommon \
- -L../HttpHandler \
- -L../WebApp \
- -L../../../Oem/dbxml/install/lib
-MgApi_wrap.cpp : \
- ../WebApp/WebApp.h \
- ../WebSupport/InitializeWebTier.cpp \
- ../../../Common/MdfModel/UnicodeString.h \
- ../HttpHandler/HttpHandlerApiDllExport.h \
- ../HttpHandler/HttpHandler.h \
- ../../../Common/Foundation/System/Object.h \
- ../../../Common/Foundation/System/Disposable.h \
- ../../../Common/Foundation/System/GuardDisposable.h \
- ../../../Common/Foundation/System/Serializable.h \
- ../../../Common/Foundation/System/NamedSerializable.h \
- ../../../Common/Foundation/Data/Collection.h \
- ../../../Common/Foundation/Data/Property.h \
- ../../../Common/Foundation/System/DisposableCollection.h \
- ../../../Common/Foundation/Data/BatchPropertyCollection.h \
- ../../../Common/Foundation/Data/ByteReader.h \
- ../../../Common/Foundation/Data/ByteSource.h \
- ../../../Common/Foundation/Data/ByteSink.h \
- ../../../Common/Foundation/Data/DateTime.h \
- ../../../Common/Foundation/Data/NullableProperty.h \
- ../../../Common/Foundation/Data/PropertyCollection.h \
- ../../../Common/Foundation/Data/PropertyDefinition.h \
- ../../../Common/Foundation/Data/StringCollection.h \
- ../../../Common/Foundation/Data/StringProperty.h \
- ../../../Common/Foundation/Data/FeaturePropertyType.h \
- ../../../Common/Foundation/Data/MimeType.h \
- ../../../Common/Foundation/Data/PropertyType.h \
- ../../../Common/Foundation/Exception/Exception.h \
- ../../../Common/Foundation/Exception/SystemException.h \
- ../../../Common/Foundation/Exception/IoException.h \
- ../../../Common/Foundation/Exception/FileIoException.h \
- ../../../Common/Foundation/Exception/ApplicationException.h \
- ../../../Common/Foundation/Exception/ThirdPartyException.h \
- ../../../Common/Foundation/Exception/StreamIoException.h \
- ../../../Common/Foundation/Exception/OutOfRangeException.h \
- ../../../Common/Foundation/Exception/ArgumentOutOfRangeException.h \
- ../../../Common/Foundation/Exception/ClassNotFoundException.h \
- ../../../Common/Foundation/Exception/ConfigurationException.h \
- ../../../Common/Foundation/Exception/ConfigurationLoadFailedException.h \
- ../../../Common/Foundation/Exception/ConfigurationSaveFailedException.h \
- ../../../Common/Foundation/Exception/DateTimeException.h \
- ../../../Common/Foundation/Exception/DecryptionException.h \
- ../../../Common/Foundation/Exception/DirectoryNotFoundException.h \
- ../../../Common/Foundation/Exception/DivideByZeroException.h \
- ../../../Common/Foundation/Exception/DomainException.h \
- ../../../Common/Foundation/Exception/DuplicateDirectoryException.h \
- ../../../Common/Foundation/Exception/DuplicateFileException.h \
- ../../../Common/Foundation/Exception/DuplicateObjectException.h \
- ../../../Common/Foundation/Exception/EncryptionException.h \
- ../../../Common/Foundation/Exception/FileNotFoundException.h \
- ../../../Common/Foundation/Exception/IndexOutOfRangeException.h \
- ../../../Common/Foundation/Exception/InvalidArgumentException.h \
- ../../../Common/Foundation/Exception/InvalidCastException.h \
- ../../../Common/Foundation/Exception/InvalidOperationException.h \
- ../../../Common/Foundation/Exception/InvalidPropertyTypeException.h \
- ../../../Common/Foundation/Exception/InvalidStreamHeaderException.h \
- ../../../Common/Foundation/Exception/LengthException.h \
- ../../../Common/Foundation/Exception/LogicException.h \
- ../../../Common/Foundation/Exception/NotFiniteNumberException.h \
- ../../../Common/Foundation/Exception/NotImplementedException.h \
- ../../../Common/Foundation/Exception/NullArgumentException.h \
- ../../../Common/Foundation/Exception/NullPropertyValueException.h \
- ../../../Common/Foundation/Exception/NullReferenceException.h \
- ../../../Common/Foundation/Exception/ObjectNotFoundException.h \
- ../../../Common/Foundation/Exception/OutOfMemoryException.h \
- ../../../Common/Foundation/Exception/OverflowException.h \
- ../../../Common/Foundation/Exception/PlatformNotSupportedException.h \
- ../../../Common/Foundation/Exception/ResourcesException.h \
- ../../../Common/Foundation/Exception/ResourcesLoadFailedException.h \
- ../../../Common/Foundation/Exception/RuntimeException.h \
- ../../../Common/Foundation/Exception/TemporaryFileNotAvailableException.h \
- ../../../Common/Foundation/Exception/UnclassifiedException.h \
- ../../../Common/Foundation/Exception/UnderflowException.h \
- ../../../Common/Foundation/Exception/XmlException.h \
- ../../../Common/Foundation/Exception/XmlParserException.h \
- ../../../Common/Geometry/GeometricEntity.h \
- ../../../Common/Geometry/Geometry.h \
- ../../../Common/Geometry/GeometryComponent.h \
- ../../../Common/Geometry/Curve.h \
- ../../../Common/Geometry/CurveSegment.h \
- ../../../Common/Geometry/Ring.h \
- ../../../Common/Geometry/Region.h \
- ../../../Common/Geometry/AgfReaderWriter.h \
- ../../../Common/Geometry/AggregateGeometry.h \
- ../../../Common/Geometry/ArcSegment.h \
- ../../../Common/Geometry/Coordinate.h \
- ../../../Common/Geometry/CoordinateCollection.h \
- ../../../Common/Geometry/CoordinateIterator.h \
- ../../../Common/Geometry/CoordinateXY.h \
- ../../../Common/Geometry/CoordinateXYM.h \
- ../../../Common/Geometry/CoordinateXYZ.h \
- ../../../Common/Geometry/CoordinateXYZM.h \
- ../../../Common/Geometry/CurvePolygon.h \
- ../../../Common/Geometry/CurvePolygonCollection.h \
- ../../../Common/Geometry/CurveRing.h \
- ../../../Common/Geometry/CurveRingCollection.h \
- ../../../Common/Geometry/CurveSegmentCollection.h \
- ../../../Common/Geometry/CurveString.h \
- ../../../Common/Geometry/CurveStringCollection.h \
- ../../../Common/Geometry/Envelope.h \
- ../../../Common/Geometry/GeometryCollection.h \
- ../../../Common/Geometry/GeometryFactory.h \
- ../../../Common/Geometry/LinearRing.h \
- ../../../Common/Geometry/LinearRingCollection.h \
- ../../../Common/Geometry/LinearSegment.h \
- ../../../Common/Geometry/LineString.h \
- ../../../Common/Geometry/LineStringCollection.h \
- ../../../Common/Geometry/Measure.h \
- ../../../Common/Geometry/MultiCurvePolygon.h \
- ../../../Common/Geometry/MultiCurveString.h \
- ../../../Common/Geometry/MultiGeometry.h \
- ../../../Common/Geometry/MultiLineString.h \
- ../../../Common/Geometry/MultiPoint.h \
- ../../../Common/Geometry/MultiPolygon.h \
- ../../../Common/Geometry/Point.h \
- ../../../Common/Geometry/PointCollection.h \
- ../../../Common/Geometry/Polygon.h \
- ../../../Common/Geometry/PolygonCollection.h \
- ../../../Common/Geometry/Transform.h \
- ../../../Common/Geometry/WktReaderWriter.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystem.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryBase.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCatalog.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCategory.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCategoryDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDatumDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefParams.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformDefParams.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryUtility.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoid.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoidDictionary.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEnum.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEnumInteger32.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFactory.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFilter.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFilterInteger32.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFormatConverter.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformation.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMathComparator.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionInformation.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemTransform.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitInformation.h \
- ../../../Common/Geometry/Exception/CoordinateSystemComputationFailedException.h \
- ../../../Common/Geometry/Exception/CoordinateSystemConversionFailedException.h \
- ../../../Common/Geometry/Exception/CoordinateSystemInitializationFailedException.h \
- ../../../Common/Geometry/Exception/CoordinateSystemLoadFailedException.h \
- ../../../Common/Geometry/Exception/CoordinateSystemMeasureFailedException.h \
- ../../../Common/Geometry/Exception/CoordinateSystemTransformFailedException.h \
- ../../../Common/Geometry/Exception/GeometryException.h \
- ../../../Common/Geometry/Exception/InvalidCoordinateSystemException.h \
- ../../../Common/Geometry/Exception/InvalidCoordinateSystemTypeException.h \
- ../../../Common/Geometry/Exception/InvalidCoordinateSystemUnitsException.h \
- ../../../Common/Geometry/CoordinateDimension.h \
- ../../../Common/Geometry/GeometricEntityType.h \
- ../../../Common/Geometry/GeometricPathInstructionType.h \
- ../../../Common/Geometry/GeometryComponentType.h \
- ../../../Common/Geometry/GeometryType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCodeFormat.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionFormatType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionLogicalType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionParameterType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitCode.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemWktFlavor.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformationMethod.h \
- ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h \
- ../../../Common/PlatformBase/Data/BlobProperty.h \
- ../../../Common/PlatformBase/Data/BooleanProperty.h \
- ../../../Common/PlatformBase/Data/ByteProperty.h \
- ../../../Common/PlatformBase/Data/ClobProperty.h \
- ../../../Common/PlatformBase/Data/Color.h \
- ../../../Common/PlatformBase/Data/DateTimeProperty.h \
- ../../../Common/PlatformBase/Data/DoubleProperty.h \
- ../../../Common/PlatformBase/Data/Int16Property.h \
- ../../../Common/PlatformBase/Data/Int32Property.h \
- ../../../Common/PlatformBase/Data/Int64Property.h \
- ../../../Common/PlatformBase/Data/IntCollection.h \
- ../../../Common/PlatformBase/Data/PropertyDefinitionCollection.h \
- ../../../Common/PlatformBase/Data/SingleProperty.h \
- ../../../Common/PlatformBase/Data/StringPropertyCollection.h \
- ../../../Common/PlatformBase/Exception/ArrayTypeMismatchException.h \
- ../../../Common/PlatformBase/Exception/DuplicateResourceDataException.h \
- ../../../Common/PlatformBase/Exception/DuplicateResourceException.h \
- ../../../Common/PlatformBase/Exception/EmptyFeatureSetException.h \
- ../../../Common/PlatformBase/Exception/FdoException.h \
- ../../../Common/PlatformBase/Exception/FeatureServiceException.h \
- ../../../Common/PlatformBase/Exception/InvalidMapDefinitionException.h \
- ../../../Common/PlatformBase/Exception/InvalidRepositoryNameException.h \
- ../../../Common/PlatformBase/Exception/InvalidRepositoryTypeException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourceDataNameException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourceDataTypeException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourceNameException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourcePathException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourcePreProcessingTypeException.h \
- ../../../Common/PlatformBase/Exception/InvalidResourceTypeException.h \
- ../../../Common/PlatformBase/Exception/LayerNotFoundException.h \
- ../../../Common/PlatformBase/Exception/ResourceBusyException.h \
- ../../../Common/PlatformBase/Exception/ResourceDataNotFoundException.h \
- ../../../Common/PlatformBase/Exception/ResourceNotFoundException.h \
- ../../../Common/PlatformBase/Exception/ServiceNotAvailableException.h \
- ../../../Common/PlatformBase/Exception/ServiceNotSupportedException.h \
- ../../../Common/PlatformBase/Exception/UserNotFoundException.h \
- ../../../Common/PlatformBase/Services/FeatureCommand.h \
- ../../../Common/PlatformBase/Services/FeatureQueryOptions.h \
- ../../../Common/PlatformBase/Services/FeatureSourceParams.h \
- ../../../Common/PlatformBase/Services/Reader.h \
- ../../../Common/PlatformBase/Services/Service.h \
- ../../../Common/PlatformBase/Services/BaseService.h \
- ../../../Common/PlatformBase/Services/ClassDefinition.h \
- ../../../Common/PlatformBase/Services/ClassDefinitionCollection.h \
- ../../../Common/PlatformBase/Services/FileFeatureSourceParams.h \
- ../../../Common/PlatformBase/Services/DataPropertyDefinition.h \
- ../../../Common/PlatformBase/Services/DataReader.h \
- ../../../Common/PlatformBase/Services/DeleteFeatures.h \
- ../../../Common/PlatformBase/Services/FeatureAggregateOptions.h \
- ../../../Common/PlatformBase/Services/FeatureCommandCollection.h \
- ../../../Common/PlatformBase/Services/FeatureProperty.h \
- ../../../Common/PlatformBase/Services/FeatureReader.h \
- ../../../Common/PlatformBase/Services/FeatureSchema.h \
- ../../../Common/PlatformBase/Services/FeatureSchemaCollection.h \
- ../../../Common/PlatformBase/Services/FeatureService.h \
- ../../../Common/PlatformBase/Services/GeometricPropertyDefinition.h \
- ../../../Common/PlatformBase/Services/GeometryProperty.h \
- ../../../Common/PlatformBase/Services/GeometryTypeInfo.h \
- ../../../Common/PlatformBase/Services/GwsFeatureReader.h \
- ../../../Common/PlatformBase/Services/InsertFeatures.h \
- ../../../Common/PlatformBase/Services/LongTransactionReader.h \
- ../../../Common/PlatformBase/Services/ObjectPropertyDefinition.h \
- ../../../Common/PlatformBase/Services/Parameter.h \
- ../../../Common/PlatformBase/Services/ParameterCollection.h \
- ../../../Common/PlatformBase/Services/Raster.h \
- ../../../Common/PlatformBase/Services/RasterProperty.h \
- ../../../Common/PlatformBase/Services/RasterPropertyDefinition.h \
- ../../../Common/PlatformBase/Services/Resource.h \
- ../../../Common/PlatformBase/Services/ResourceIdentifier.h \
- ../../../Common/PlatformBase/Services/ResourceService.h \
- ../../../Common/PlatformBase/Services/SpatialContextReader.h \
- ../../../Common/PlatformBase/Services/SqlDataReader.h \
- ../../../Common/PlatformBase/Services/Transaction.h \
- ../../../Common/PlatformBase/Services/UpdateFeatures.h \
- ../../../Common/PlatformBase/Services/Warnings.h \
- ../../../Common/PlatformBase/Services/BaseServiceDefs.h \
- ../../../Common/PlatformBase/Services/FeatureCommandType.h \
- ../../../Common/PlatformBase/Services/FeatureGeometricType.h \
- ../../../Common/PlatformBase/Services/FeatureSpatialOperations.h \
- ../../../Common/PlatformBase/Services/ObjectPropertyType.h \
- ../../../Common/PlatformBase/Services/OrderingOption.h \
- ../../../Common/PlatformBase/Services/ParameterDirection.h \
- ../../../Common/PlatformBase/Services/RasterTypes.h \
- ../../../Common/PlatformBase/Services/ReaderType.h \
- ../../../Common/PlatformBase/Services/ResourceDefs.h \
- ../../../Common/PlatformBase/Services/SpatialContextExtentType.h \
- ../../../Common/PlatformBase/MapLayer/LayerBase.h \
- ../../../Common/PlatformBase/MapLayer/LayerCollection.h \
- ../../../Common/PlatformBase/MapLayer/LayerGroup.h \
- ../../../Common/PlatformBase/MapLayer/LayerGroupCollection.h \
- ../../../Common/PlatformBase/MapLayer/MapBase.h \
- ../../../Common/PlatformBase/MapLayer/MapCollection.h \
- ../../../Common/PlatformBase/MapLayer/ReadOnlyLayerCollection.h \
- ../../../Common/PlatformBase/MapLayer/SelectionBase.h \
- ../../../Common/PlatformBase/MapLayer/LayerGroupType.h \
- ../../../Common/PlatformBase/MapLayer/LayerType.h \
- ../../../Common/MapGuideCommon/Exception/AuthenticationFailedException.h \
- ../../../Common/MapGuideCommon/Exception/ConnectionFailedException.h \
- ../../../Common/MapGuideCommon/Exception/ConnectionNotOpenException.h \
- ../../../Common/MapGuideCommon/Exception/DbException.h \
- ../../../Common/MapGuideCommon/Exception/DbXmlException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateGroupException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateNameException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateParameterException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateRepositoryException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateRoleException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateServerException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateSessionException.h \
- ../../../Common/MapGuideCommon/Exception/DuplicateUserException.h \
- ../../../Common/MapGuideCommon/Exception/DwfException.h \
- ../../../Common/MapGuideCommon/Exception/DwfSectionNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/DwfSectionResourceNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/EndOfStreamException.h \
- ../../../Common/MapGuideCommon/Exception/GroupNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidDwfPackageException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidDwfSectionException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidFeatureSourceException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidIpAddressException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidLicenseException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidLogEntryException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidPasswordException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutFontSizeUnitsException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutPositionUnitsException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutSizeUnitsException.h \
- ../../../Common/MapGuideCommon/Exception/InvalidServerNameException.h \
- ../../../Common/MapGuideCommon/Exception/LicenseException.h \
- ../../../Common/MapGuideCommon/Exception/LicenseExpiredException.h \
- ../../../Common/MapGuideCommon/Exception/OperationProcessingException.h \
- ../../../Common/MapGuideCommon/Exception/ParameterNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/PathTooLongException.h \
- ../../../Common/MapGuideCommon/Exception/PortNotAvailableException.h \
- ../../../Common/MapGuideCommon/Exception/PrintToScaleModeNotSelectedException.h \
- ../../../Common/MapGuideCommon/Exception/RepositoryCreationFailedException.h \
- ../../../Common/MapGuideCommon/Exception/RepositoryNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/RepositoryNotOpenException.h \
- ../../../Common/MapGuideCommon/Exception/RepositoryOpenFailedException.h \
- ../../../Common/MapGuideCommon/Exception/RoleNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/ServerNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/ServerNotOnlineException.h \
- ../../../Common/MapGuideCommon/Exception/SessionExpiredException.h \
- ../../../Common/MapGuideCommon/Exception/SessionNotFoundException.h \
- ../../../Common/MapGuideCommon/Exception/UnauthorizedAccessException.h \
- ../../../Common/MapGuideCommon/Exception/UriFormatException.h \
- ../../../Common/MapGuideCommon/Services/DrawingService.h \
- ../../../Common/MapGuideCommon/Services/DwfVersion.h \
- ../../../Common/MapGuideCommon/Services/FeatureInformation.h \
- ../../../Common/MapGuideCommon/Services/KmlService.h \
- ../../../Common/MapGuideCommon/Services/Layout.h \
- ../../../Common/MapGuideCommon/Services/MappingService.h \
- ../../../Common/MapGuideCommon/Services/MapPlot.h \
- ../../../Common/MapGuideCommon/Services/MapPlotCollection.h \
- ../../../Common/MapGuideCommon/Services/PackageStatusInformation.h \
- ../../../Common/MapGuideCommon/Services/PlotSpecification.h \
- ../../../Common/MapGuideCommon/Services/ProfilingService.h \
- ../../../Common/MapGuideCommon/Services/RenderingOptions.h \
- ../../../Common/MapGuideCommon/Services/RenderingService.h \
- ../../../Common/MapGuideCommon/Services/ServerAdmin.h \
- ../../../Common/MapGuideCommon/Services/Site.h \
- ../../../Common/MapGuideCommon/Services/SiteConnection.h \
- ../../../Common/MapGuideCommon/Services/SiteInfo.h \
- ../../../Common/MapGuideCommon/Services/TileService.h \
- ../../../Common/MapGuideCommon/System/UserInformation.h \
- ../../../Common/MapGuideCommon/MapLayer/Layer.h \
- ../../../Common/MapGuideCommon/MapLayer/Map.h \
- ../../../Common/MapGuideCommon/MapLayer/Selection.h \
- ../../../Common/MapGuideCommon/Services/MappingDefs.h \
- ../../../Common/MapGuideCommon/Services/MapPlotInstruction.h \
- ../../../Common/MapGuideCommon/Services/ServerAdminDefs.h \
- ../../../Common/MapGuideCommon/Services/UnitType.h \
- ../../../Common/MapGuideCommon/System/ConfigProperties.h \
- ../WebApp/WebCommand.h \
- ../WebApp/WebUiTargetCommand.h \
- ../WebApp/WebWidget.h \
- ../WebApp/WebWidgetCollection.h \
- ../WebApp/WebUiPane.h \
- ../WebApp/WebUiSizablePane.h \
- ../WebApp/WebBufferCommand.h \
- ../WebApp/WebCommandCollection.h \
- ../WebApp/WebCommandWidget.h \
- ../WebApp/WebContextMenu.h \
- ../WebApp/WebFlyoutWidget.h \
- ../WebApp/WebGetPrintablePageCommand.h \
- ../WebApp/WebHelpCommand.h \
- ../WebApp/WebInformationPane.h \
- ../WebApp/WebInvokeScriptCommand.h \
- ../WebApp/WebInvokeUrlCommand.h \
- ../WebApp/WebLayout.h \
- ../WebApp/WebMeasureCommand.h \
- ../WebApp/WebPrintCommand.h \
- ../WebApp/WebSearchCommand.h \
- ../WebApp/WebSelectWithinCommand.h \
- ../WebApp/WebSeparatorWidget.h \
- ../WebApp/WebTaskBar.h \
- ../WebApp/WebTaskBarWidget.h \
- ../WebApp/WebTaskPane.h \
- ../WebApp/WebToolbar.h \
- ../WebApp/WebViewOptionsCommand.h \
- ../WebApp/WebActions.h \
- ../WebApp/WebTargetType.h \
- ../WebApp/WebTargetViewerType.h \
- ../WebApp/WebTaskButtonType.h \
- ../WebApp/WebWidgetType.h \
- ../HttpHandler/HttpHeader.h \
- ../HttpHandler/HttpPrimitiveValue.h \
- ../HttpHandler/HttpRequest.h \
- ../HttpHandler/HttpRequestMetadata.h \
- ../HttpHandler/HttpRequestParam.h \
- ../HttpHandler/HttpResponse.h \
- ../HttpHandler/HttpResult.h
- ../../../BuildTools/WebTools/IMake/Linux/IMake ../MapGuideApi/MapGuideApiGen.xml Java
- cp -f java.i language.i
- ../../../BuildTools/WebTools/IMake/Linux/IMake ../MapGuideApi/Constants.xml Java .
- ../../../Oem/SWIGEx/Linux/swig -dllname MapGuideJavaApiEx -c++ -java -mgjavanothrow -mgjavacasing -DJAVA -package org.osgeo.mapguide -root MgObject -baseexception MgException -clsidcode getclassid.code -clsiddata m_cls_id -catchallcode catchall.code -dispose "((MgDisposable*)arg1)->Release()" -rethrow "e->Raise();" -nodefault -noconstants -module MapGuideJavaApiEx -o MgApi_wrap.cpp -lib ../../../Oem/SWIGEx/Lib MapGuideApi.i
- rm -f org/osgeo/mapguide/*.class
- mv -f *.java org/osgeo/mapguide
- $(JAVA_HOME)/bin/javac -classpath . org/osgeo/mapguide/*.java
- $(JAVA_HOME)/bin/jar cf ../WEB-INF/lib/MapGuideApiEx.jar org/osgeo/mapguide/*.class
- $(JAVA_HOME)/bin/jar cf ../WEB-INF/lib/MapGuideApiEx-sources.jar org/osgeo/mapguide/*.java
Deleted: trunk/MgDev/Server/Makefile.am
--- trunk/MgDev/Server/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,4 +0,0 @@
-SUBDIRS = src
-DIST_SUBDIRS = src
-EXTRA_DIST = RepositoryAdmin Server.sln
Deleted: trunk/MgDev/Server/src/Common/Base/Makefile.am
--- trunk/MgDev/Server/src/Common/Base/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Common/Base/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,36 +0,0 @@
-EXTRA_DIST = ServerBase.vcproj ServerBase.rc
-prefix=@prefix@/server
-INCLUDES = \
- -I../../../../Oem/ACE/ACE_wrappers \
- -I../../../../Common/MdfModel \
- -I../../../../Common/Foundation \
- -I../../../../Common/Geometry \
- -I../../../../Common/MapGuideCommon \
- -I../../../../Common/PlatformBase \
- -I../../Common/Manager \
- -I../../Services/Resource \
- -I../../Services/Site
-lib_LTLIBRARIES = libMgServerBase.la
-libMgServerBase_la_SOURCES = \
- ServerBaseBuild.cpp
-include_SOURCES = \
- ClientHandler.cpp \
- IServiceHandler.cpp \
- ServerStreamData.cpp \
- ServiceOperation.cpp
-noinst_HEADERS = $(include_SOURCES) \
- ClientHandler.h \
- IServiceHandler.h \
- ServerBaseDllExport.h \
- ServerStreamData.h \
- ServiceOperation.h
-libMgServerBase_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Common/Cache/Makefile.am
--- trunk/MgDev/Server/src/Common/Cache/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Common/Cache/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,49 +0,0 @@
-EXTRA_DIST = ServerCache.vcproj ServerCache.rc
-INCLUDES = \
-lib_LTLIBRARIES = libMgServerCache.la
-libMgServerCache_la_SOURCES = \
- ServerCacheBuild.cpp
- ServerCache.cpp \
- ServerCacheEntry.cpp \
- ServerCacheItem.cpp \
- FeatureClassCacheItem.cpp \
- FeatureSchemaCacheItem.cpp \
- FeatureServiceCache.cpp \
- FeatureServiceCacheEntry.cpp \
- FeatureSourceCacheItem.cpp \
- SpatialContextCacheItem.cpp \
- ResourceLayerDefinitionCacheItem.cpp \
- ResourceServiceCache.cpp \
- ResourceServiceCacheEntry.cpp
- ServerCache.h \
- ServerCacheDllExport.h \
- ServerCacheEntry.h \
- ServerCacheItem.h \
- FeatureClassCacheItem.h \
- FeatureSchemaCacheItem.h \
- FeatureServiceCache.h \
- FeatureServiceCacheEntry.h \
- FeatureSourceCacheItem.h \
- SpatialContextCacheItem.h \
- ResourceLayerDefinitionCacheItem.h \
- ResourceServiceCache.h \
- ResourceServiceCacheEntry.h
-libMgServerCache_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Common/Makefile.am
--- trunk/MgDev/Server/src/Common/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Common/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,4 +0,0 @@
-AUTOMAKE_OPTIONS = foreign
-SUBDIRS = Base Cache Manager Thread
-DIST_SUBDIRS = Base Cache Manager Thread
-EXTRA_DIST = Dll.cpp
Deleted: trunk/MgDev/Server/src/Common/Manager/Makefile.am
--- trunk/MgDev/Server/src/Common/Manager/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Common/Manager/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,103 +0,0 @@
-EXTRA_DIST = ServerManager.vcproj ServerManager.rc
-INCLUDES = \
- -I../../../../Oem/dbxml/xerces-c-src/src \
- -I../../../../Common \
- -I../../../../Common/Security \
- -I../../../../Common/MdfParser \
- -I../../Services/Drawing \
- -I../../Services/Feature \
- -I../../Services/Kml \
- -I../../Services/Mapping \
- -I../../Services/Profiling \
- -I../../Services/Rendering \
- -I../../Services/ServerAdmin \
- -I../../Services/Site \
- -I../../Services/Tile \
- -I../Cache \
- -I../Thread
-lib_LTLIBRARIES = libMgServerManager.la
-libMgServerManager_la_SOURCES = \
- ServerManagerBuild.cpp
- CacheManager.cpp \
- Connection.cpp \
- FdoConnectionManager.cpp \
- GroupInfo.cpp \
- LicenseManager.cpp \
- LoadBalanceManager.cpp \
- LogDetail.cpp \
- LogEntryData.cpp \
- LogManager.cpp \
- LogThread.cpp \
- LongTransactionManager.cpp \
- PackageLogHandler.cpp \
- PackageLogReader.cpp \
- PackageLogWriter.cpp \
- PackageManager.cpp \
- PermissionCache.cpp \
- PermissionInfo.cpp \
- PermissionManager.cpp \
- RoleInfo.cpp \
- SecurityCache.cpp \
- SecurityManager.cpp \
- ServerManager.cpp \
- ServiceManager.cpp \
- SessionCache.cpp \
- SessionInfo.cpp \
- SessionManager.cpp \
- UnmanagedDataManager.cpp \
- UserInfo.cpp \
- WorkerThread.cpp \
- WorkerThreadData.cpp
- CacheManager.h \
- Connection.h \
- FdoConnectionManager.h \
- GroupInfo.h \
- LicenseManager.h \
- LoadBalanceManager.h \
- LogDetail.h \
- LogEntryData.h \
- LogManager.h \
- LogThread.h \
- LogType.h \
- LongTransactionManager.h \
- PackageLogHandler.h \
- PackageLogReader.h \
- PackageLogWriter.h \
- PackageManager.h \
- PermissionCache.h \
- PermissionInfo.h \
- PermissionManager.h \
- RoleInfo.h \
- SecurityCache.h \
- SecurityManager.h \
- ServerManager.h \
- ServerManagerDllExport.h \
- ServiceManager.h \
- SessionCache.h \
- SessionInfo.h \
- SessionManager.h \
- UnmanagedDataManager.h \
- UserInfo.h \
- WorkerThread.h \
- WorkerThreadData.h
-libMgServerManager_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Common/Thread/Makefile.am
--- trunk/MgDev/Server/src/Common/Thread/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Common/Thread/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,28 +0,0 @@
-EXTRA_DIST = ServerThread.vcproj ServerThread.rc
-INCLUDES = \
-lib_LTLIBRARIES = libMgServerThread.la
-libMgServerThread_la_SOURCES = \
- ServerThreadBuild.cpp
- ThreadBase.cpp
- ThreadBase.h \
- ServerThreadDllExport.h
-libMgServerThread_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Core/Makefile.am
--- trunk/MgDev/Server/src/Core/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Core/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,461 +0,0 @@
-EXTRA_DIST = serverconfig.ini ServerCore.vcproj ServerCore.rc
-mentor_dict_install_dir=@prefix@/share/gis/coordsys
-mentor_dict_source_dir=$(map_srcdir)/Oem/CsMap/CsMapDev/Dictionaries
-root_prefix=@prefix@
-INCLUDES = \
- -I../../../Oem/dbxml/xerces-c-src/src \
- -I $(map_fdo_include) \
- -I $(map_fdo_include)/ExpressionEngine \
- -I../Common \
- -I../Common/Base \
- -I../Common/Cache \
- -I../Common/Manager \
- -I../Common/Thread \
- -I../Services/Drawing \
- -I../Services/Feature \
- -I../Services/Kml \
- -I../Services/Mapping \
- -I../Services/Profiling \
- -I../Services/Rendering \
- -I../Services/Resource \
- -I../Services/ServerAdmin \
- -I../Services/Site \
- -I../Services/Tile \
- -I../../../Common \
- -I../../../Oem/gd/freetype/include \
- -I../../../Common/MdfModel \
- -I../../../Common/MdfParser \
- -I../../../Common/Stylization \
- -I../../../Common/Renderers
-bin_PROGRAMS = mgserver
-ServerCoreBuild.o : Makefile
-AM_CXXFLAGS = @CXXFLAGS@ -DACE_HAS_SVC_DLL=1
-mgserver_SOURCES = \
- ServerCoreBuild.cpp
- ClientAcceptor.cpp \
- ConnectionTimeoutEventHandler.cpp \
- DataConnectionTimeoutEventHandler.cpp \
- DataTransactionTimeoutEventHandler.cpp \
- EventTimer.cpp \
- EventTimerManager.cpp \
- FeatureServiceCacheTimeLimitEventHandler.cpp \
- main.cpp \
- LoadPackageCommand.cpp \
- OperationThread.cpp \
- PerformanceLoggingEventHandler.cpp \
- RepositoryCheckpointEventHandler.cpp \
- ResourceChangeEventHandler.cpp \
- ResourceServiceCacheTimeLimitEventHandler.cpp \
- Server.cpp \
- ServerFactory.cpp \
- ServerInteractiveCommand.cpp \
- ServiceHandlerFactory.cpp \
- ServiceRegistrationEventHandler.cpp \
- SessionTimeoutEventHandler.cpp \
- SetPwdCommand.cpp \
- SignalHandler.cpp \
- TestCommand.cpp \
- TestFdoCommand.cpp \
- TimedEvent.cpp \
- TimedEventHandler.cpp
- ClientAcceptor.h \
- ConnectionTimeoutEventHandler.h \
- DataConnectionTimeoutEventHandler.h \
- DataTransactionTimeoutEventHandler.h \
- EventTimer.h \
- EventTimerManager.h \
- FeatureServiceCacheTimeLimitEventHandler.h \
- LoadPackageCommand.h \
- OperationThread.h \
- PerformanceLoggingEventHandler.h \
- RepositoryCheckpointEventHandler.h \
- ResourceChangeEventHandler.h \
- ResourceServiceCacheTimeLimitEventHandler.h \
- Server.h \
- ServiceHandlerFactory.h \
- ServerInteractiveCommand.h \
- ServiceRegistrationEventHandler.h \
- SessionTimeoutEventHandler.h \
- SetPwdCommand.h \
- SignalHandler.h \
- TestCommand.h \
- TestFdoCommand.h \
- TimedEvent.h \
- TimedEventHandler.h
-mgserver_LDADD = \
- -lACE \
- -ldb_cxx \
- -ldbxml \
- -ldwfcore \
- -ldwftk \
- -lexpat \
- -lFDO-4.2.0 \
- -lExpressionEngine \
- -lxalanMsg \
- -lxalan-c \
- -lxerces-c \
- -lxqilla \
- -lMgFoundation \
- -lMgGeometry \
- -lMgPlatformBase \
- -lMgServerAdminService \
- -lMgServerBase \
- -lMgServerCache \
- -lMgServerDrawingService \
- -lMgServerFeatureService \
- -lMgServerKmlService \
- -lMgServerManager \
- -lMgServerMappingService \
- -lMgServerProfilingService \
- -lMgServerRenderingService \
- -lMgServerResourceService \
- -lMgServerSiteService \
- -lMgServerThread \
- -lMgServerTileService \
- -lMgMdfModel \
- -lMgMdfParser \
- -lMgStylization \
- -lMgRenderers \
- -ldl \
- ../../../Common/Security/libMgSecurity.a
-mgserver_LDFLAGS = \
- -R$(map_fdo_lib) \
- -R$(map_srcdir)/Oem/ACE/ACE_wrappers/ace \
- -R$(map_srcdir)/Oem/DWFTK/develop/global/src/dwfcore \
- -R$(map_srcdir)/Oem/DWFTK/develop/global/src/dwf \
- -R$(map_srcdir)/Oem/dbxml/install/lib \
- -R$(map_srcdir)/Common/CoordinateSystem/.libs \
- -R$(map_srcdir)/Common/MdfModel/.libs \
- -R$(map_srcdir)/Common/MdfParser/.libs \
- -R$(map_srcdir)/Common/Stylization/.libs \
- -R$(map_srcdir)/Common/Renderers/.libs \
- -R$(map_srcdir)/Common/Foundation/.libs \
- -R$(map_srcdir)/Common/Geometry/.libs \
- -R$(map_srcdir)/Common/PlatformBase/.libs \
- -R$(map_srcdir)/Common/MapGuideCommon/.libs \
- -R$(map_srcdir)/Server/src/Common/Base/.libs \
- -R$(map_srcdir)/Server/src/Common/Cache/.libs \
- -R$(map_srcdir)/Server/src/Common/Manager/.libs \
- -R$(map_srcdir)/Server/src/Common/Thread/.libs \
- -R$(map_srcdir)/Server/src/Services/Drawing/.libs \
- -R$(map_srcdir)/Server/src/Services/Feature/.libs \
- -R$(map_srcdir)/Server/src/Services/Kml/.libs \
- -R$(map_srcdir)/Server/src/Services/Mapping/.libs \
- -R$(map_srcdir)/Server/src/Services/Profiling/.libs \
- -R$(map_srcdir)/Server/src/Services/Rendering/.libs \
- -R$(map_srcdir)/Server/src/Services/Resource/.libs \
- -R$(map_srcdir)/Server/src/Services/ServerAdmin/.libs \
- -R$(map_srcdir)/Server/src/Services/Site/.libs \
- -R$(map_srcdir)/Server/src/Services/Tile/.libs \
- -R$(map_srcdir)/Server/src/$(map_unittesting_dir)/.libs \
- -L$(map_fdo_lib) \
- -L../../../Oem/DWFTK/develop/global/src/dwfcore \
- -L../../../Oem/DWFTK/develop/global/src/dwf \
- -L../../../Oem/dbxml/install/lib \
- -L$(top_builddir)/Common/CoordinateSystem \
- -L../../../Common/Stylization \
- -L../../../Common/Renderers \
- -L../Common/Base \
- -L../Common/Cache \
- -L../Common/Manager \
- -L../Common/Thread \
- -L../Services/Drawing \
- -L../Services/Feature \
- -L../Services/Kml \
- -L../Services/Mapping \
- -L../Services/Profiling \
- -L../Services/Rendering \
- -L../Services/Resource \
- -L../Services/ServerAdmin \
- -L../Services/Site \
- -L../Services/Tile
-UnitTestFiles :
- @mkdir -p ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/ResourceService/LibraryRepositoryContent.xml ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/ResourceService/SampleRepositoryHeader.xml ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/ResourceService/SampleRepositoryContent.xml ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/ResourceService/Shuttle.zip ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/ResourceService/Shuttle.zip ../UnitTestFiles/World.mgp
- @cp -f ../../../UnitTest/TestData/ResourceService/World_Countries.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/ResourceService/TEST.LayerDefinition ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/DrawingService/SpaceShip.dwf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/DrawingService/SpaceShipDrawingSource.xml ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/TEST.FeatureSource ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/TEST.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/Sheboygan_Parcels.FeatureSource ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/Sheboygan_Parcels.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/Sheboygan_BuildingOutlines.FeatureSource ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/Sheboygan_BuildingOutlines.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/Sheboygan_VotingDistricts.FeatureSource ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/Sheboygan_VotingDistricts.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/TESTChainedInner1ToManyJoin.FeatureSource ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/Empty.FeatureSource ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SDF/Empty.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SHP/Redding_Parcels.FeatureSource ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SHP/Redding_Parcels.shp ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SHP/Redding_Parcels.dbf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SHP/Redding_Parcels.shx ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_AllElements.pl ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/PlotHole.mgp ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_MultiCTS.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_MultiCTSWithTheme.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_MultiFTS.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_MultiFTSSingleCTS.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_MultiFTSWithTheme.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_SingleFTSMultiCTS.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_NoLegend.pl ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_SymbolMart.sl ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_Symbols.dwf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_Sheboygan.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_HydrographicPolygons.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_HydrographicPolygons.fs ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_HydrographicPolygons.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_Rail.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_Rail.fs ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_Rail.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_Rail.wdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_Rail_Watermark.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_RotatedPointStyles.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_SheboyganWithWatermark.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MappingService/UT_PoweredByMapGuide.wdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MdfModel/MdfTestTypeStyles.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MdfModel/MdfTestCompoundSymbol.sd ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MdfModel/MdfTestSimpleSymbol.sd ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/MdfModel/MdfTestMap.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/areasymbol.sd ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/linesymbol.sd ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/symbol.sd ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/symbolp.sd ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/MTYP1500a.sd ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyLines.fs ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyLines.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyLines.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyLines.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyLinesCrossTick.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyLinesCrossTick.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyPoints.fs ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyPoints.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyPoints.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyPoints.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyPointsParam.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyPointsParam.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyRoads.fs ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyRoads.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyRoads.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyRoads.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyParcels.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_SymbologyPolygons.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_Annotation1.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_Annotation1.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_Annotation2.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_Annotation2.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_Annotation3.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/Symbology/UT_Annotation3.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_BaseMap.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_BaseMap.tsd ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_XYZ.tsd ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_LinkedTileSet.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_StylizationFuncs.mdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_Parcels.fs ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_Parcels.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_Parcels.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_RoadCenterLines.fs ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_RoadCenterLines.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_RoadCenterLines.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_VotingDistricts.fs ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_VotingDistricts.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_VotingDistrictsFunctions.ldf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/TileService/UT_VotingDistricts.sdf ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/ServerAdmin/1.1.1.mgd ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/CoordinateSystems/epsgcodes.txt ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/CoordinateSystems/ogcwkts.txt ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SQLite/SavePointTest.sqlite ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SQLite/SavePointTest.FeatureSource ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SQLite/UT_FdoJoin.FeatureSource ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SQLite/UT_Parcels_SQLite_Join.FeatureSource ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SQLite/ParcelsJoinTest.sqlite ../UnitTestFiles
- @cp -f ../../../UnitTest/TestData/FeatureService/SQLite/JoinTest.sqlite ../UnitTestFiles
- @chmod +w ../UnitTestFiles/*.sdf
-TESTS = unittest.sh
-UnitTesting :
- test -d $(mentor_dict_install_dir) || (mkdir -p $(mentor_dict_install_dir); \
- cp -f -r $(mentor_dict_source_dir)/* $(mentor_dict_install_dir);)
- @echo "#!/bin/sh" > unittest.sh
- @echo "export MENTOR_DICTIONARY_PATH=$(mentor_dict_install_dir)" >> unittest.sh
- @echo "echo MENTOR_DICTIONARY_PATH=\$$MENTOR_DICTIONARY_PATH" >> unittest.sh
- @echo "./mgserver test" >> unittest.sh
- @chmod a+x unittest.sh
-unittest.sh : all serverconfig_linux.ini UnitTestFiles $(map_unittesting_dir)
-serverconfig_linux.ini :
- @sed -e 's#^FdoPath.*=.*#FdoPath = $(map_fdo_lib)#' \
- -e 's#^LogsPath.*=.*#LogsPath = Logs/#' \
- -e 's#^MentorDictionaryPath.*=.*#MentorDictionaryPath = ${mentor_dict_install_dir}#' \
- -e 's#^ResourcesPath.*=.*#ResourcesPath = Resources/#' \
- -e 's#^TempPath.*=.*#TempPath = Temp/#' \
- -e 's#^WmsDocumentPath.*=.*#WmsDocumentPath = Wms/#' \
- -e 's#^WfsDocumentPath.*=.*#WfsDocumentPath = Wfs/#' \
- -e 's#^TileCachePath.*=.*#TileCachePath = Repositories/TileCache/#' \
- -e 's#^LibraryResourceDataFilePath.*=.*#LibraryResourceDataFilePath = Repositories/Library/DataFiles/#' \
- -e 's#^LibraryRepositoryPath.*=.*#LibraryRepositoryPath = Repositories/Library/#' \
- -e 's#^SessionResourceDataFilePath.*=.*#SessionResourceDataFilePath = Repositories/Session/DataFiles/#' \
- -e 's#^SessionRepositoryPath.*=.*#SessionRepositoryPath = Repositories/Session/#' \
- -e 's#^SiteRepositoryPath.*=.*#SiteRepositoryPath = Repositories/Site/#' \
- -e 's#^PackagesPath.*=.*#PackagesPath = Packages/#' \
- -e 's#^ResourceSchemaFilePath.*=.*#ResourceSchemaFilePath = ../../../Common/Schema/#' \
- -e 's#^ResourceDataFileTrashFolderName.*=.*#ResourceDataFileTrashFolderName = Trash/#' \
- -e 's#^LegendFont.*=.*#LegendFont = Complex#' \
- serverconfig.ini > serverconfig_linux.ini
- @cp -f serverconfig_linux.ini serverconfig.ini
-Repositories :
- @mkdir Repositories
- @mkdir -p Repositories/Library/DataFiles
- @mkdir -p Repositories/Session/DataFiles
- @mkdir -p Repositories/Site
- @mkdir -p Repositories/TileCache
-Trash :
- @mkdir Trash
-Packages :
- @mkdir Packages
-Temp :
- @mkdir Temp
-Logs :
- @mkdir Logs
-Resources :
- @mkdir Resources
- @cp -f ../../../Common/MapGuideCommon/Resources/mapguide_en.res Resources/mapguide_en.res
-Schema :
- @mkdir Schema
- @cp -f ../../../Common/Schema/*.xsd Schema/
-all : Schema Resources Logs Temp Trash Packages Repositories serverconfig_linux.ini
-logfiledir = ${prefix}/Logs
-tempdir = ${prefix}/Temp
-trashdir = ${prefix}/Trash
-packagesdir = ${prefix}/Packages
-repositoriesdir = ${prefix}/Repositories
-repositoryadmindir = ${prefix}/RepositoryAdmin
-resourcesdir = ${prefix}/Resources
-schemadir = ${prefix}/Schema
-wmsdir = ${prefix}/Wms
-wfsdir = ${prefix}/Wfs
-fdodir = $(map_fdo_lib)
-daemondir = /var/lock/mgserver
-install-data-local:
- test -d $(logfiledir) || $(mkinstalldirs) $(logfiledir)
- test -d $(tempdir) || $(mkinstalldirs) $(tempdir)
- test -d $(trashdir) || $(mkinstalldirs) $(trashdir)
- test -d $(packagesdir) || $(mkinstalldirs) $(packagesdir)
- test -d $(repositoriesdir) || $(mkinstalldirs) $(repositoriesdir)
- test -d $(repositoriesdir)/Library || $(mkinstalldirs) $(repositoriesdir)/Library
- test -d $(repositoriesdir)/Library/DataFiles || $(mkinstalldirs) $(repositoriesdir)/Library/DataFiles
- test -d $(repositoriesdir)/Session || $(mkinstalldirs) $(repositoriesdir)/Session
- test -d $(repositoriesdir)/Session/DataFiles || $(mkinstalldirs) $(repositoriesdir)/Session/DataFiles
- test -d $(repositoriesdir)/Site || $(mkinstalldirs) $(repositoriesdir)/Site
- test -d $(repositoryadmindir) || $(mkinstalldirs) $(repositoryadmindir)
- test -d $(resourcesdir) || $(mkinstalldirs) $(resourcesdir)
- test -d $(wmsdir) || $(mkinstalldirs) $(wmsdir)
- test -d $(wfsdir) || $(mkinstalldirs) $(wfsdir)
- test -d $(fdodir) || $(mkinstalldirs) $(fdodir)
- test -d $(daemondir) || $(mkinstalldirs) $(daemondir)
- @cp -fp ../../../Common/MapGuideCommon/Resources/*.res $(resourcesdir)
- @cp -fp ../Wms/* $(wmsdir)
- @cp -fp ../Wfs/* $(wfsdir)
- test -d $(schemadir) || $(mkinstalldirs) $(schemadir)
- test -d $(mentor_dict_install_dir) || ($(mkinstalldirs) $(mentor_dict_install_dir); \
- @cp -fp ../../../Common/Schema/*.xsd $(schemadir)
- @cp -fp ../../../Oem/dbxml/install/bin/db_archive ${prefix}/bin/
- @cp -fp ../../../Oem/dbxml/install/bin/db_checkpoint ${prefix}/bin/
- @cp -fp ../../../Oem/dbxml/install/bin/db_dump ${prefix}/bin/
- @cp -fp ../../../Oem/dbxml/install/bin/db_hotbackup ${prefix}/bin/
- @cp -fp ../../../Oem/dbxml/install/bin/db_load ${prefix}/bin/
- @cp -fp ../../../Oem/dbxml/install/bin/db_recover ${prefix}/bin/
- @cp -fp ../../../Oem/dbxml/install/bin/db_upgrade ${prefix}/bin/
- @cp -fp ../../../Oem/dbxml/install/bin/db_verify ${prefix}/bin/
- @cp -fp ../../../Oem/dbxml/install/bin/dbxml ${prefix}/bin/
- @cp -fp ../../../Oem/dbxml/install/bin/dbxml_dump ${prefix}/bin/
- @cp -fp ../../../Oem/dbxml/install/bin/dbxml_load ${prefix}/bin/
- @cp -fp ../../RepositoryAdmin/*.sh $(repositoryadmindir)
- @cp -fp ../../RepositoryAdmin/*.php $(repositoryadmindir)
- @cp -fp ../../RepositoryAdmin/*.inc $(repositoryadmindir)
- @cp -fp ../../RepositoryAdmin/*.pdf $(repositoryadmindir)
- @cp -fp ../../RepositoryAdmin/license.txt $(repositoryadmindir)
- @cp -fp ../../RepositoryAdmin/php.ini $(repositoryadmindir)
-install-data-hook:
- -e 's#^LogsPath.*=.*#LogsPath = ${prefix}/Logs/#' \
- -e 's#^ResourcesPath.*=.*#ResourcesPath = ${prefix}/Resources/#' \
- -e 's#^TempPath.*=.*#TempPath = ${prefix}/Temp/#' \
- -e 's#^WmsDocumentPath.*=.*#WmsDocumentPath = ${prefix}/Wms/#' \
- -e 's#^WfsDocumentPath.*=.*#WfsDocumentPath = ${prefix}/Wfs/#' \
- -e 's#^TileCachePath.*=.*#TileCachePath = ${prefix}/Repositories/TileCache/#' \
- -e 's#^LibraryResourceDataFilePath.*=.*#LibraryResourceDataFilePath = ${prefix}/Repositories/Library/DataFiles/#' \
- -e 's#^LibraryRepositoryPath.*=.*#LibraryRepositoryPath = ${prefix}/Repositories/Library/#' \
- -e 's#^SessionResourceDataFilePath.*=.*#SessionResourceDataFilePath = ${prefix}/Repositories/Session/DataFiles/#' \
- -e 's#^SessionRepositoryPath.*=.*#SessionRepositoryPath = ${prefix}/Repositories/Session/#' \
- -e 's#^SiteRepositoryPath.*=.*#SiteRepositoryPath = ${prefix}/Repositories/Site/#' \
- -e 's#^PackagesPath.*=.*#PackagesPath = ${prefix}/Packages/#' \
- -e 's#^ResourceSchemaFilePath.*=.*#ResourceSchemaFilePath = ${prefix}/Schema/#' \
- -e 's#^ResourceDataFileTrashFolderName.*=.*#ResourceDataFileTrashFolderName = Trash#' \
- serverconfig.ini > ${prefix}/bin/serverconfig.ini
- @echo '#!/bin/bash' > ${prefix}/bin/mgserver.sh
- @echo '' >> ${prefix}/bin/mgserver.sh
- @echo 'export PATH=${prefix}/bin:$$PATH' >> ${prefix}/bin/mgserver.sh
- @echo 'export MENTOR_DICTIONARY_PATH=$(mentor_dict_install_dir)' >> ${prefix}/bin/mgserver.sh
- @echo 'export LD_LIBRARY_PATH=$(fdodir):"$$LD_LIBRARY_PATH"' >> ${prefix}/bin/mgserver.sh
- @echo 'export NLSPATH=$(map_fdo_nls):"$$NLSPATH"' >> ${prefix}/bin/mgserver.sh
- @echo 'mkdir -p /var/lock/mgserver' >> ${prefix}/bin/mgserver.sh
- @echo 'pushd ${prefix}/bin' >> ${prefix}/bin/mgserver.sh
- @cp -f ${prefix}/bin/mgserver.sh ${prefix}/bin/mgserverd.sh
- @echo './mgserver run' >> ${prefix}/bin/mgserver.sh
- @echo './mgserver daemon' >> ${prefix}/bin/mgserverd.sh
- @echo 'popd' >> ${prefix}/bin/mgserver.sh
- @echo 'popd' >> ${prefix}/bin/mgserverd.sh
- @chmod a+x ${prefix}/bin/mgserver*.sh
- @sed -e 's#/usr/local/mapguideopensource/server#${prefix}#g' mapguidectl > ${prefix}/bin/mapguidectl
- @chmod a+x ${prefix}/bin/mapguidectl
Deleted: trunk/MgDev/Server/src/Gws/GwsCommon/Makefile.am
--- trunk/MgDev/Server/src/Gws/GwsCommon/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Gws/GwsCommon/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,48 +0,0 @@
-EXTRA_DIST = GwsCommon.rc GwsCommon.vcproj
-lib_LTLIBRARIES = libMgGwsCommon.la
-libMgGwsCommon_la_SOURCES = \
- GwsCommonFactories.cpp \
- GwsCommonFdoUtils.cpp \
- GwsCsName.cpp \
- GwsDebugUtils.cpp \
- GwsException.cpp \
- GwsExtendedFeatureId.cpp \
- GwsFeatureId.cpp \
- GwsObjectImpl.cpp \
- GwsQualifiedName.cpp \
- GwsQualifiedNames.cpp \
- GwsResourceUtil.cpp \
- GwsXmlUtils.cpp \
- IGwsException.cpp
- GwsCommon.cpp
- stdafx.h \
- inc/GwsCommonImp.h \
- inc/GwsCommonUtils.h \
- inc/GwsException.h \
- inc/GwsFeatureIdSet.h \
- inc/GwsObject.h \
- inc/GwsObjectImpl.h \
- inc/GwsOperationHandler.h \
- inc/GwsResourceUtil.h \
- inc/GwsThreads.h \
- inc/GwsStatus.h
-INCLUDES = \
- -I$(map_fdo_include) \
- -I../Include \
- -I../GwsResource \
- -I./inc \
-libMgGwsCommon_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Gws/GwsQueryEngine/Makefile.am
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,74 +0,0 @@
-EXTRA_DIST = GwsQueryEngine.def GwsQueryEngine.rc GwsQueryEngine.vcproj
-lib_LTLIBRARIES = libMgGwsQueryEngine.la
-libMgGwsQueryEngine_la_SOURCES = \
- GwsBatchSortedBlockJoinQueryResults.cpp \
- GwsBinaryFeature.cpp \
- GwsBinaryFeatureReader.cpp \
- GwsBinaryFeatureWriter.cpp \
- GwsBinaryReader.cpp \
- GwsBinaryWriter.cpp \
- GwsCsQueryProcessor.cpp \
- GwsExtendedFeatureDescription.cpp \
- GwsFlatGwsIterator.cpp \
- GwsFlatFdoReader.cpp \
- GwsFdoCommand.cpp \
- GwsFdoCommandDelete.cpp \
- GwsFdoCommandInsert.cpp \
- GwsFdoCommandLock.cpp \
- GwsFdoCommandUnlock.cpp \
- GwsFdoCommandUpdate.cpp \
- GwsFeatureQueryDefinition.cpp \
- GwsFeatureQueryResults.cpp \
- GwsFeatureSourceQuery.cpp \
- GwsFeaturesPool.cpp \
- GwsJoinQueryDefinition.cpp \
- GwsJoinQueryResults.cpp \
- GwsMultiSelectIterator.cpp \
- GwsMutableFeature.cpp \
- GwsNestedLoopsJoinQueryResults.cpp \
- GwsNestedLoopSortedBlockJoinQueryResults.cpp \
- GwsPooledFeature.cpp \
- GwsPreparedFeatureQuery.cpp \
- GwsPreparedJoinQuery.cpp \
- GwsPropertyDesc.cpp \
- GwsQueryDefinition.cpp \
- GwsQueryFactories.cpp \
- GwsQueryUtils.cpp \
- GwsQueryXml.cpp \
- GwsRightBatchSortedBlockJoinQueryResults.cpp \
- GwsRightJoinQueryResults.cpp \
- GwsRightNestedLoopJoinQueryResults.cpp \
- GwsRightNestedLoopSortedBlockJoinQueryResults.cpp \
- GwsRightSortedJoinQueryResults.cpp \
- GwsSortMergeJoinQueryResults.cpp \
- utf8_.cpp
- GwsQueryEngine.cpp
- stdafx.h \
- inc/GwsBinaryFeatureReader.h \
- inc/GwsBinaryFeatureWriter.h \
- inc/GwsBinaryReader.h \
- inc/GwsBinaryWriter.h \
- inc/GwsFdoCommand.h \
- inc/GwsFlatFdoReader.h \
- inc/GwsMutableFeature.h \
- inc/GwsQuery.h \
- inc/GwsQueryDefinition.h \
- inc/GwsQueryEngineImp.h \
- inc/utf8_.h
-INCLUDES = \
- -I$(map_fdo_include)/ExpressionEngine \
- -I../Include \
- -I../GwsCommon/inc \
- -I./inc
-libMgGwsQueryEngine_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Gws/GwsResource/Makefile.am
--- trunk/MgDev/Server/src/Gws/GwsResource/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Gws/GwsResource/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,16 +0,0 @@
-EXTRA_DIST = GwsResource.vcproj GwsResource.rc
-lib_LTLIBRARIES = libMgGwsResource.la
-libMgGwsResource_la_SOURCES = \
- GwsResourceLinux.cpp
-noinst_HEADERS = \
- GwsResource.h \
- GwsResourceLinux.h
-INCLUDES = -I../INCLUDE
-libMgGwsResource_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Gws/Makefile.am
--- trunk/MgDev/Server/src/Gws/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Gws/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,4 +0,0 @@
-SUBDIRS = GwsResource GwsCommon GwsQueryEngine
-EXTRA_DIST = Include
Deleted: trunk/MgDev/Server/src/Makefile.am
--- trunk/MgDev/Server/src/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,4 +0,0 @@
-SUBDIRS = Common Gws Services $(map_unittesting_dir) Core
-DIST_SUBDIRS = Common Gws Services $(map_unittesting_dir) Core
-EXTRA_DIST = PostBuild Wms Wfs
Deleted: trunk/MgDev/Server/src/Services/Drawing/Makefile.am
--- trunk/MgDev/Server/src/Services/Drawing/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/Drawing/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,74 +0,0 @@
-EXTRA_DIST = ServerDrawingService.vcproj ServerDrawingService.rc
-INCLUDES = \
- -I../../../../Oem/DWFTK/develop/global/src \
- -I../../../../Oem/DWFTK/develop/global/src/dwf \
- -I../../Common \
- -I../../Common/Base \
- -I../../Common/ServerUtil \
- -I../Resource
-AM_CXXFLAGS = @CXXFLAGS@ -DDWFTK_BUILD_EXPAT -DDWFTK_USE_DWFCORE_ZLIB
-lib_LTLIBRARIES = libMgServerDrawingService.la
-MgServerDrawingServiceBuild.lo : Makefile
-libMgServerDrawingService_la_SOURCES = \
- ServerDrawingServiceBuild.cpp
- DrawingOperation.cpp \
- DrawingOperationFactory.cpp \
- DrawingServiceHandler.cpp \
- OpDescribeDrawing.cpp \
- OpEnumerateLayers.cpp \
- OpEnumerateSections.cpp \
- OpEnumerateSectionResources.cpp \
- OpGetCoordinateSpace.cpp \
- OpGetDrawing.cpp \
- OpGetLayer.cpp \
- OpGetSection.cpp \
- OpGetSectionResource.cpp \
- ServerDrawingService.cpp \
- ServerDrawingServiceUtil.cpp
- DrawingOperation.h \
- DrawingOperationFactory.h \
- DrawingServiceHandler.h \
- OpDescribeDrawing.h \
- OpEnumerateLayers.h \
- OpEnumerateSections.h \
- OpEnumerateSectionResources.h \
- OpGetCoordinateSpace.h \
- OpGetDrawing.h \
- OpGetLayer.h \
- OpGetSection.h \
- OpGetSectionResource.h \
- ServerDrawingDllExport.h \
- ServerDrawingService.h \
- ServerDrawingServiceUtil.h \
- ServerDrawingServiceDefs.h \
- ../../../../Common/PlatformBase/Services/Service.h
-libMgServerDrawingService_la_LIBADD = -lMgFoundation -lMgGeometry -lMgPlatformBase -lMgMapGuideCommon -lxerces-c
-libMgServerDrawingService_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../../../../Oem/dbxml/install/lib \
- -L../../../../Common/Foundation \
- -L../../../../Common/Geometry \
- -L../../../../Common/PlatformBase \
- -L../../../../Common/MapGuideCommon
Deleted: trunk/MgDev/Server/src/Services/Feature/Makefile.am
--- trunk/MgDev/Server/src/Services/Feature/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/Feature/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,246 +0,0 @@
-EXTRA_DIST = ServerFeatureService.vcproj ServerFeatureService.rc
-INCLUDES = \
- -I../../Gws/Include \
- -I../../Gws/GwsCommon/inc \
- -I../../Gws/GwsQueryEngine/inc \
- -I../../../../Common/Stylization \
- -I../../Common \
- -I../../Common/Cache \
-lib_LTLIBRARIES = libMgServerFeatureService.la
-libMgServerFeatureService_la_SOURCES = \
- ServerFeatureServiceBuild.cpp
- FeatureOperation.cpp \
- FeatureOperationFactory.cpp \
- FeatureServiceHandler.cpp \
- GwsConnectionPool.cpp \
- OpAddSavePoint.cpp \
- OpApplySchema.cpp \
- OpCreateFeatureSource.cpp \
- OpDescribeSchema.cpp \
- OpDescribeSchemaAsXml.cpp \
- OpExecuteSqlNonQuery.cpp \
- OpExecuteSqlQuery.cpp \
- OpGetCapabilities.cpp \
- OpGetConnectionPropertyValues.cpp \
- OpGetFdoCacheInfo.cpp \
- OpGetFeatureProviders.cpp \
- OpGetIdentityProperties.cpp \
- OpReleaseSavePoint.cpp \
- OpRollbackSavePoint.cpp \
- OpGetSpatialContexts.cpp \
- OpSelectFeatures.cpp \
- OpSelectFeaturesSpatial.cpp \
- OpTestConnection.cpp \
- OpTestFeatureSourceConnection.cpp \
- OpUpdateFeatures.cpp \
- ServerApplySchema.cpp \
- ServerDescribeSchema.cpp \
- ServerFeatureConnection.cpp \
- ServerFeatureService.cpp \
- ServerGetFeatureProviders.cpp \
- ServerGetProviderCapabilities.cpp \
- ServerGwsFeatureReader.cpp \
- ServerSelectFeatures.cpp \
- OpCloseFeatureReader.cpp \
- OpGetFeatures.cpp \
- ServerFeatureReader.cpp \
- ServerFdoFeatureReader.cpp \
- ServerFeatureReaderPool.cpp \
- OpGetLongTransactions.cpp \
- ServerGetConnectionPropertyValues.cpp \
- ServerGetLongTransactions.cpp \
- ServerGetSpatialContexts.cpp \
- OpGetClassDefinition.cpp \
- OpGetClasses.cpp \
- OpGetSchemas.cpp \
- OpGetRaster.cpp \
- OpCloseSqlReader.cpp \
- OpGetSqlRows.cpp \
- ServerDataReaderPool.cpp \
- ServerFeatureUtil.cpp \
- ServerSqlCommand.cpp \
- ServerSqlDataReader.cpp \
- FeatureServiceCommand.cpp \
- FeatureDistribution.cpp \
- OpCloseDataReader.cpp \
- OpGetDataRows.cpp \
- SelectAggregateCommand.cpp \
- SelectCommand.cpp \
- ServerCreateFeatureSource.cpp \
- ServerDataReader.cpp \
- ServerSqlDataReaderPool.cpp \
- FeatureNumericFunctions.cpp \
- FeatureStringFunctions.cpp \
- FeatureGeometricFunctions.cpp \
- FeatureManipulationCommand.cpp \
- ServerDeleteCommand.cpp \
- ServerInsertCommand.cpp \
- ServerUpdateCommand.cpp \
- ServerUpdateFeatures.cpp \
- OpSchemaToXml.cpp \
- OpXmlToSchema.cpp \
- ByteSourceRasterStreamImpl.cpp \
- OpDescribeWfsFeatureType.cpp \
- OpGetWfsFeature.cpp \
- OpGetWfsReader.cpp \
- FilterUtil.cpp \
- WfsQueryAdapter.cpp \
- OpEnumerateDataStores.cpp \
- OpGetSchemaMapping.cpp \
- ServerEnumerateDataStores.cpp \
- ServerGetSchemaMapping.cpp \
- OpSetLongTransaction.cpp \
- MgCSTrans.cpp \
- TransformCache.cpp \
- JoinFeatureReader.cpp \
- FdoFeatureReader.cpp \
- FdoFilterCollection.cpp \
- FdoReaderCollection.cpp \
- OpBeginTransaction.cpp \
- OpCommitTransaction.cpp \
- OpRollbackTransaction.cpp \
- OpUpdateFeaturesWithTransaction.cpp \
- ServerFeatureTransaction.cpp \
- ServerFeatureTransactionPool.cpp
- FeatureOperation.h \
- FeatureOperationFactory.h \
- FeatureServiceHandler.h \
- ServerFeatureService.h \
- GwsConnectionPool.h \
- OpAddSavePoint.h \
- OpApplySchema.h \
- OpCreateFeatureSource.h \
- OpDescribeSchema.h \
- OpDescribeSchemaAsXml.h \
- OpExecuteSqlNonQuery.h \
- OpExecuteSqlQuery.h \
- OpGetCapabilities.h \
- OpGetConnectionPropertyValues.h \
- OpGetFdoCacheInfo.h \
- OpGetFeatureProviders.h \
- OpGetSpatialContexts.h \
- OpGetIdentityProperties.h \
- OpReleaseSavePoint.h \
- OpRollbackSavePoint.h \
- OpSelectFeatures.h \
- OpSelectFeaturesSpatial.h \
- OpTestConnection.h \
- OpTestFeatureSourceConnection.h \
- OpUpdateFeatures.h \
- ServerApplySchema.h \
- ServerDescribeSchema.h \
- ServerFeatureConnection.h \
- ServerFeatureDllExport.h \
- ServerFeatureServiceDefs.h \
- ServerGetFeatureProviders.h \
- ServerGetProviderCapabilities.h \
- ../../Common/stdafx.h \
- ServerGwsFeatureReader.h \
- ServerSelectFeatures.h \
- OpCloseFeatureReader.h \
- OpGetFeatures.h \
- ServerFeatureReader.h \
- ServerFdoFeatureReader.h \
- ServerFeatureReaderPool.h \
- OpGetLongTransactions.h \
- ServerGetConnectionPropertyValues.h \
- ServerGetLongTransactions.h \
- ServerGetSpatialContexts.h \
- OpGetClassDefinition.h \
- OpGetClasses.h \
- OpGetSchemas.h \
- OpGetRaster.h \
- OpCloseSqlReader.h \
- OpGetSqlRows.h \
- ServerDataReaderPool.h \
- ServerFeatureUtil.h \
- ServerSqlCommand.h \
- ServerSqlDataReader.h \
- FeatureServiceCommand.h \
- FeatureDistribution.h \
- OpCloseDataReader.h \
- OpGetDataRows.h \
- SelectAggregateCommand.h \
- SelectCommand.h \
- ServerCreateFeatureSource.h \
- ServerDataReader.h \
- ServerSqlDataReaderPool.h \
- Matrix.h \
- DataReaderCreator.h \
- DoubleDataReaderCreator.h \
- FeatureNumericFunctions.h \
- FeatureStringFunctions.h \
- ByteDataReaderCreator.h \
- Int16DataReaderCreator.h \
- Int32DataReaderCreator.h \
- Int64DataReaderCreator.h \
- SingleDataReaderCreator.h \
- StringDataReaderCreator.h \
- UniqueFunction.h \
- FeatureGeometricFunctions.h \
- GeometryDataReaderCreator.h \
- ServerFeatureServiceExceptionDef.h \
- FeatureManipulationCommand.h \
- ServerDeleteCommand.h \
- ServerInsertCommand.h \
- ServerUpdateCommand.h \
- ServerUpdateFeatures.h \
- OpSchemaToXml.h \
- OpXmlToSchema.h \
- BooleanDataReaderCreator.h \
- ByteSourceRasterStreamImpl.h \
- DateTimeDataReaderCreator.h \
- OpDescribeWfsFeatureType.h \
- OpGetWfsFeature.h \
- OpGetWfsReader.h \
- FilterUtil.h \
- WfsQueryAdapter.h \
- OpEnumerateDataStores.h \
- OpGetSchemaMapping.h \
- ServerEnumerateDataStores.h \
- ServerGetSchemaMapping.h \
- OpSetLongTransaction.h \
- MgCSTrans.h \
- TransformCache.h \
- JoinFeatureReader.h \
- FdoFeatureReader.h \
- FdoFilterCollection.h \
- FdoReaderCollection.h \
- OpBeginTransaction.h \
- OpCommitTransaction.h \
- OpRollbackTransaction.h \
- OpUpdateFeaturesWithTransaction.h \
- ServerFeatureTransaction.h \
- ServerFeatureTransactionPool.h
-libMgServerFeatureService_la_LIBADD = -lMgGwsCommon -lMgGwsQueryEngine
-libMgServerFeatureService_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../../Gws/GwsCommon \
- -L../../Gws/GwsQueryEngine
Deleted: trunk/MgDev/Server/src/Services/Kml/Makefile.am
--- trunk/MgDev/Server/src/Services/Kml/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/Kml/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,54 +0,0 @@
-EXTRA_DIST = ServerKmlService.vcproj ServerKmlService.rc
-INCLUDES = \
- -I../../Common \
- -I../../../../Common/CoordinateSystem \
- -I../../../../Common/Renderers \
- -I../Feature \
- -I../Mapping
-AM_CXXFLAGS = @CXXFLAGS@ -DDWFTK_USE_DWFCORE_ZLIB
-lib_LTLIBRARIES = libMgServerKmlService.la
-libMgServerKmlService_la_SOURCES = \
- ServerKmlServiceBuild.cpp
- KmlOperation.cpp \
- KmlOperationFactory.cpp \
- KmlServiceHandler.cpp \
- ServerKmlService.cpp \
- OpGetMapKml.cpp \
- OpGetLayerKml.cpp \
- OpGetFeaturesKml.cpp
- KmlOperationFactory.h \
- KmlOperation.h \
- KmlServiceHandler.h \
- ServerKmlDllExport.h \
- ServerKmlService.h \
- OpGetMapKml.h \
- OpGetLayerKml.h \
- OpGetFeaturesKml.h
-libMgServerKmlService_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Services/Makefile.am
--- trunk/MgDev/Server/src/Services/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,3 +0,0 @@
-SUBDIRS = Drawing Feature Kml Mapping Profiling Rendering Resource ServerAdmin Site Tile
-DIST_SUBDIRS = Drawing Feature Kml Mapping Profiling Rendering Resource ServerAdmin Site Tile
Deleted: trunk/MgDev/Server/src/Services/Mapping/Makefile.am
--- trunk/MgDev/Server/src/Services/Mapping/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/Mapping/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,79 +0,0 @@
-EXTRA_DIST = ServerMappingService.vcproj ServerMappingService.rc
-INCLUDES = \
- -I../../Common \
- -I../Feature \
-lib_LTLIBRARIES = libMgServerMappingService.la
-libMgServerMappingService_la_SOURCES = \
- ServerMappingServiceBuild.cpp
- LegendPlotUtil.cpp \
- MappingOperation.cpp \
- MappingOperationFactory.cpp \
- MappingServiceHandler.cpp \
- MappingUtil.cpp \
- OpCreateRuntimeMap.cpp \
- OpDescribeRuntimeMap.cpp \
- OpGenerateLegendImage.cpp \
- OpGenerateLegendPlot.cpp \
- OpGenerateMultiPlot.cpp \
- OpGeneratePlot.cpp \
- OpQueryFeatures.cpp \
- OpQueryFeaturesWms.cpp \
- RSMgFeatureReader.cpp \
- RSMgRaster.cpp \
- RSMgSymbolManager.cpp \
- SEMgSymbolManager.cpp \
- ServerMappingService.cpp
- icons.h \
- LegendPlotUtil.h \
- MappingOperation.h \
- MappingOperationFactory.h \
- MappingServiceHandler.h \
- MappingUtil.h \
- OpCreateRuntimeMap.h \
- OpDescribeRuntimeMap.h \
- OpGenerateLegendImage.h \
- OpGenerateLegendPlot.h \
- OpGenerateMultiPlot.h \
- OpGeneratePlot.h \
- OpQueryFeatures.h \
- OpQueryFeaturesWms.h \
- RSMgFeatureReader.h \
- RSMgInputStream.h \
- RSMgRaster.h \
- RSMgSymbolManager.h \
- SEMgSymbolManager.h \
- ServerMappingDllExport.h \
- ServerMappingService.h \
- ServerMappingServiceDefs.h
-libMgServerMappingService_la_LIBADD =
-libMgServerMappingService_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Services/Profiling/Makefile.am
--- trunk/MgDev/Server/src/Services/Profiling/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/Profiling/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,45 +0,0 @@
-EXTRA_DIST = ServerProfilingService.vcproj ServerProfilingService.rc
-INCLUDES = \
- -I../../Common \
-lib_LTLIBRARIES = libMgServerProfilingService.la
-libMgServerProfilingService_la_SOURCES = \
- ServerProfilingServiceBuild.cpp
- ProfilingOperation.cpp \
- ProfilingOperationFactory.cpp \
- ProfilingServiceHandler.cpp \
- ServerProfilingService.cpp \
- OpProfileRenderMap.cpp \
- OpProfileRenderDynamicOverlay.cpp
- ProfilingOperationFactory.h \
- ProfilingOperation.h \
- ProfilingServiceHandler.h \
- ServerProfilingDllExport.h \
- ServerProfilingService.h \
- OpProfileRenderMap.h \
- OpProfileRenderDynamicOverlay.h
-libMgServerProfilingService_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Services/Rendering/Makefile.am
--- trunk/MgDev/Server/src/Services/Rendering/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/Rendering/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,64 +0,0 @@
-EXTRA_DIST = ServerRenderingService.vcproj ServerRenderingService.rc
-INCLUDES = \
- -I../../Common \
- -I../Feature \
- -I../Mapping
-lib_LTLIBRARIES = libMgServerRenderingService.la
-libMgServerRenderingService_la_SOURCES = \
- ServerRenderingServiceBuild.cpp
- RenderingOperation.cpp \
- RenderingOperationFactory.cpp \
- RenderingServiceHandler.cpp \
- ServerRenderingService.cpp \
- OpRenderDynamicOverlay.cpp \
- OpRenderMap.cpp \
- OpRenderTile.cpp \
- OpRenderTileXYZ.cpp \
- OpRenderTileUTFGrid.cpp \
- OpQueryFeatureProperties.cpp \
- FeatureInfoRenderer.cpp \
- FeaturePropRenderer.cpp \
- OpRenderMapLegend.cpp
- RenderingOperationFactory.h \
- RenderingOperation.h \
- RenderingServiceHandler.h \
- ServerRenderingDllExport.h \
- ServerRenderingService.h \
- OpRenderDynamicOverlay.h \
- OpRenderMap.h \
- OpRenderTile.h \
- OpRenderTileXYZ.h \
- OpRenderTileUTFGrid.h \
- OpQueryFeatureProperties.h \
- FeatureInfoRenderer.h \
- FeaturePropRenderer.h \
- OpRenderMapLegend.h
-libMgServerRenderingService_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Services/Resource/Makefile.am
--- trunk/MgDev/Server/src/Services/Resource/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/Resource/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,214 +0,0 @@
-EXTRA_DIST = ServerResourceService.vcproj ServerResourceService.rc
-INCLUDES = \
- -I../../../../Oem/dbxml/install/include \
- -I../../../../Oem/dbxml/dbxml/include \
- -I../../../../Oem/dbxml/dbxml/src \
- -I../../Common \
- -I../Feature \
- -I../Site
-lib_LTLIBRARIES = libMgServerResourceService.la
-MgServerResourceServiceBuild.lo : Makefile
-libMgServerResourceService_la_SOURCES = \
- ServerResourceServiceBuild.cpp
- ApplicationRepository.cpp \
- ApplicationRepositoryManager.cpp \
- ApplicationResourceContentManager.cpp \
- ByteSourceDwfInputStreamImpl.cpp \
- Database.cpp \
- DataBindingInfo.cpp \
- DbEnvironment.cpp \
- LibraryRepository.cpp \
- LibraryRepositoryManager.cpp \
- LibraryResourceContentManager.cpp \
- OpApplyResourcePackage.cpp \
- OpChangeResourceOwner.cpp \
- OpCopyResource.cpp \
- OpCreateRepository.cpp \
- OpDeleteRepository.cpp \
- OpDeleteResource.cpp \
- OpDeleteResourceData.cpp \
- OpEnumerateParentMapDefinitions.cpp \
- OpEnumerateParentTileSetDefinitions.cpp \
- OpEnumerateRepositories.cpp \
- OpEnumerateResourceData.cpp \
- OpEnumerateResourceDocuments.cpp \
- OpEnumerateResourceReferences.cpp \
- OpEnumerateResources.cpp \
- OpEnumerateUnmanagedData.cpp \
- OperationInfo.cpp \
- OperationParameter.cpp \
- OpGetRepositoryContent.cpp \
- OpGetRepositoryHeader.cpp \
- OpGetResourceContent.cpp \
- OpGetResourceContents.cpp \
- OpGetResourceData.cpp \
- OpGetResourceHeader.cpp \
- OpGetResourceModifiedDate.cpp \
- OpInheritPermissionsFrom.cpp \
- OpMoveResource.cpp \
- OpRenameResourceData.cpp \
- OpResourceExists.cpp \
- OpSetResource.cpp \
- OpSetResourceData.cpp \
- OpUpdateRepository.cpp \
- Repository.cpp \
- RepositoryManager.cpp \
- ResourceContainer.cpp \
- ResourceContentManager.cpp \
- ResourceDatabase.cpp \
- ResourceDataFileManager.cpp \
- ResourceDataManager.cpp \
- ResourceDataStreamManager.cpp \
- ResourceDefinitionManager.cpp \
- ResourceHeader.cpp \
- ResourceHeaderManager.cpp \
- ResourceInfo.cpp \
- ResourceManager.cpp \
- ResourceOperation.cpp \
- ResourceOperationFactory.cpp \
- ResourcePackageHandler.cpp \
- ResourcePackageLoader.cpp \
- ResourcePackageMaker.cpp \
- ResourcePackageManifestHandler.cpp \
- ResourcePackageManifestParser.cpp \
- ResourcePackageManifestSerializer.cpp \
- ResourceServiceHandler.cpp \
- ServerResourceService.cpp \
- SessionRepository.cpp \
- SessionRepositoryManager.cpp \
- SessionResourceContentManager.cpp \
- SiteRepository.cpp \
- SiteRepositoryManager.cpp \
- SiteResourceContentManager.cpp \
- SystemRepository.cpp \
- SystemRepositoryManager.cpp \
- SystemResourceContentManager.cpp \
- TagInfo.cpp \
- TagManager.cpp \
- XmlSchemaResolver.cpp \
- ZipFileHandler.cpp \
- ZipFileReader.cpp \
- ZipFileWriter.cpp
- ApplicationRepository.h \
- ApplicationRepositoryManager.h \
- ApplicationResourceContentManager.h \
- ByteSourceDwfInputStreamImpl.h \
- Database.h \
- DataBindingInfo.h \
- DbEnvironment.h \
- LibraryRepository.h \
- LibraryRepositoryManager.h \
- LibraryResourceContentManager.h \
- OpApplyResourcePackage.h \
- OpChangeResourceOwner.h \
- OpCopyResource.h \
- OpCreateRepository.h \
- OpDeleteRepository.h \
- OpDeleteResource.h \
- OpDeleteResourceData.h \
- OpEnumerateParentMapDefinitions.h \
- OpEnumerateParentTileSetDefinitions.h \
- OpEnumerateRepositories.h \
- OpEnumerateResourceData.h \
- OpEnumerateResourceDocuments.h \
- OpEnumerateResourceReferences.h \
- OpEnumerateResources.h \
- OpEnumerateUnmanagedData.h \
- OperationInfo.h \
- OperationParameter.h \
- OpGetRepositoryContent.h \
- OpGetRepositoryHeader.h \
- OpGetResourceContent.h \
- OpGetResourceContents.h \
- OpGetResourceData.h \
- OpGetResourceHeader.h \
- OpGetResourceModifiedDate.h \
- OpInheritPermissionsFrom.h \
- OpMoveResource.h \
- OpRenameResourceData.h \
- OpResourceExists.h \
- OpSetResource.h \
- OpSetResourceData.h \
- OpUpdateRepository.h \
- Repository.h \
- RepositoryManager.h \
- ResourceContainer.h \
- ResourceContentManager.h \
- ResourceDatabase.h \
- ResourceDataFileManager.h \
- ResourceDataManager.h \
- ResourceDataStreamManager.h \
- ResourceDefinitionManager.h \
- ResourceHeader.h \
- ResourceHeaderManager.h \
- ResourceInfo.h \
- ResourceManager.h \
- ResourceOperationFactory.h \
- ResourcePackageHandler.h \
- ResourcePackageLoader.h \
- ResourcePackageMaker.h \
- ResourcePackageManifestHandler.h \
- ResourcePackageManifestParser.h \
- ResourcePackageManifestSerializer.h \
- ResourceOperation.h \
- ResourceServiceDefs.h \
- ResourceServiceHandler.h \
- ServerResourceDllExport.h \
- ServerResourceService.h \
- SessionRepository.h \
- SessionRepositoryManager.h \
- SessionResourceContentManager.h \
- SiteRepository.h \
- SiteRepositoryManager.h \
- SiteResourceContentManager.h \
- SystemRepository.h \
- SystemRepositoryManager.h \
- SystemResourceContentManager.h \
- TagInfo.h \
- TagManager.h \
- XmlSchemaResolver.h \
- ZipFileHandler.h \
- ZipFileReader.h \
- ZipFileWriter.h \
-libMgServerResourceService_la_LIBADD = -lMgFoundation -lMgGeometry -lMgPlatformBase -lMgMapGuideCommon -lMgServerBase -lMgServerCache -lMgServerManager -lxerces-c -lxqilla -ldb_cxx -ldbxml
-libMgServerResourceService_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../../../../Common/MapGuideCommon \
- -L../../Common/Base \
- -L../../Common/Cache \
- -L../../Common/Manager \
Deleted: trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am
--- trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,97 +0,0 @@
-EXTRA_DIST = ServerAdminService.vcproj ServerAdminService.rc
-INCLUDES = \
- -I../../Common \
-lib_LTLIBRARIES = libMgServerAdminService.la
-libMgServerAdminService_la_SOURCES = \
- ServerAdminServiceBuild.cpp
- OpBringOnline.cpp \
- OpClearLog.cpp \
- OpDeleteLog.cpp \
- OpDeletePackage.cpp \
- OpEnableMaximumLogSize.cpp \
- OpEnumerateLogs.cpp \
- OpEnumeratePackages.cpp \
- OpGetConfigurationProperties.cpp \
- OpGetDocument.cpp \
- OpGetInformationProperties.cpp \
- OpGetLog.cpp \
- OpGetLogFile.cpp \
- OpGetPackageLog.cpp \
- OpGetPackageStatus.cpp \
- OpGetSiteStatus.cpp \
- OpGetSiteVersion.cpp \
- OpIsMaximumLogSizeEnabled.cpp \
- OpIsOnline.cpp \
- OpLoadPackage.cpp \
- OpMakePackage.cpp \
- OpNotifyResourcesChanged.cpp \
- OpRegisterServicesOnServers.cpp \
- OpRenameLog.cpp \
- OpSetConfigurationProperties.cpp \
- OpRemoveConfigurationProperties.cpp \
- OpSetDocument.cpp \
- OpTakeOffline.cpp \
- OpUnregisterServicesOnServers.cpp \
- OpSetMaximumLogSize.cpp \
- OpSetLogDelimiter.cpp \
- ServerAdminOperation.cpp \
- ServerAdminOperationFactory.cpp \
- ServerAdminService.cpp \
- ServerAdminServiceHandler.cpp
- OpBringOnline.h \
- OpClearLog.h \
- OpDeleteLog.h \
- OpDeletePackage.h \
- OpEnableMaximumLogSize.h \
- OpEnumerateLogs.h \
- OpEnumeratePackages.h \
- OpGetConfigurationProperties.h \
- OpGetDocument.h \
- OpGetInformationProperties.h \
- OpGetLog.h \
- OpGetLogFile.h \
- OpGetPackageLog.h \
- OpGetPackageStatus.h \
- OpGetSiteStatus.h \
- OpGetSiteVersion.h \
- OpIsMaximumLogSizeEnabled.h \
- OpIsOnline.h \
- OpLoadPackage.h \
- OpMakePackage.h \
- OpNotifyResourcesChanged.h \
- OpRegisterServicesOnServers.h \
- OpRemoveConfigurationProperties.h \
- OpRenameLog.h \
- OpSetConfigurationProperties.h \
- OpSetDocument.h \
- OpTakeOffline.h \
- OpUnregisterServicesOnServers.h \
- OpSetMaximumLogSize.h \
- OpSetLogDelimiter.h \
- ServerAdminDllExport.h \
- ServerAdminOperation.h \
- ServerAdminOperationFactory.h \
- ServerAdminService.h \
- ServerAdminServiceHandler.h \
-libMgServerAdminService_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Services/Site/Makefile.am
--- trunk/MgDev/Server/src/Services/Site/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/Site/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,93 +0,0 @@
-EXTRA_DIST = ServerSiteService.vcproj ServerSiteService.rc
-INCLUDES = \
- -I../../Common \
- -I../Resource
-lib_LTLIBRARIES = libMgServerSiteService.la
-libMgServerSiteService_la_SOURCES = \
- ServerSiteServiceBuild.cpp
- OpAddGroup.cpp \
- OpAddServer.cpp \
- OpAddUser.cpp \
- OpAuthenticate.cpp \
- OpCreateSession.cpp \
- OpDeleteGroups.cpp \
- OpDeleteUsers.cpp \
- OpDestroySession.cpp \
- OpEnumerateGroups.cpp \
- OpEnumerateRoles.cpp \
- OpEnumerateServers.cpp \
- OpEnumerateUsers.cpp \
- OpGetSessionTimeout.cpp \
- OpGetUserForSession.cpp \
- OpGrantGroupMembershipsToUsers.cpp \
- OpGrantRoleMembershipsToGroups.cpp \
- OpGrantRoleMembershipsToUsers.cpp \
- OpRemoveServer.cpp \
- OpRevokeGroupMembershipsFromUsers.cpp \
- OpRevokeRoleMembershipsFromGroups.cpp \
- OpRevokeRoleMembershipsFromUsers.cpp \
- OpUpdateGroup.cpp \
- OpUpdateServer.cpp \
- OpUpdateUser.cpp \
- OpRequestServer.cpp \
- ServerSiteService.cpp \
- SiteOperation.cpp \
- SiteOperationFactory.cpp \
- SiteServiceHandler.cpp \
- SiteServiceUtil.cpp
- OpAddGroup.h \
- OpAddServer.h \
- OpAddUser.h \
- OpAuthenticate.h \
- OpCreateSession.h \
- OpDeleteGroups.h \
- OpDeleteUsers.h \
- OpDestroySession.h \
- OpEnumerateGroups.h \
- OpEnumerateRoles.h \
- OpEnumerateServers.h \
- OpEnumerateUsers.h \
- OpGetSessionTimeout.h \
- OpGetUserForSession.h \
- OpGrantGroupMembershipsToUsers.h \
- OpGrantRoleMembershipsToGroups.h \
- OpGrantRoleMembershipsToUsers.h \
- OpRemoveServer.h \
- OpRevokeGroupMembershipsFromUsers.h \
- OpRevokeRoleMembershipsFromGroups.h \
- OpRevokeRoleMembershipsFromUsers.h \
- OpUpdateGroup.h \
- OpUpdateServer.h \
- OpUpdateUser.h \
- OpRequestServer.h \
- ServerSiteDllExport.h \
- ServerSiteService.h \
- SiteOperation.h \
- SiteOperationFactory.h \
- SiteServiceDefs.h \
- SiteServiceHandler.h \
- SiteServiceUtil.h
-libMgServerSiteService_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/Services/Tile/Makefile.am
--- trunk/MgDev/Server/src/Services/Tile/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/Services/Tile/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,58 +0,0 @@
-EXTRA_DIST = ServerTileService.vcproj ServerTileService.rc
-INCLUDES = \
- -I../../Common \
-lib_LTLIBRARIES = libMgServerTileService.la
-libMgServerTileService_la_SOURCES = \
- ServerTileServiceBuild.cpp
- OpClearCache.cpp \
- OpGetTile.cpp \
- OpGetTileProviders.cpp \
- OpGetDefaultTileSizeX.cpp \
- OpGetDefaultTileSizeY.cpp \
- OpSetTile.cpp \
- ServerTileService.cpp \
- TileCache.cpp \
- TileCacheDefault.cpp \
- TileCacheDefaultProvider.cpp \
- TileCacheXYZProvider.cpp \
- TileOperation.cpp \
- TileOperationFactory.cpp \
- TileServiceHandler.cpp
- OpClearCache.h \
- OpGetTile.h \
- OpGetTileProviders.h \
- OpGetDefaultTileSizeX.h \
- OpGetDefaultTileSizeY.h \
- OpSetTile.h \
- ServerTileDllExport.h \
- ServerTileService.h \
- TileCache.h \
- TileCacheDefault.h \
- TileCacheDefaultProvider.h \
- TileCacheXYZProvider.h \
- TileOperation.h \
- TileOperationFactory.h \
- TileServiceHandler.h
-libMgServerTileService_la_LDFLAGS = -release $(PACKAGE_VERSION)
Deleted: trunk/MgDev/Server/src/UnitTesting/Makefile.am
--- trunk/MgDev/Server/src/UnitTesting/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Server/src/UnitTesting/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,81 +0,0 @@
-EXTRA_DIST = UnitTesting.vcproj UnitTesting.rc
-INCLUDES = \
- -I../../../Oem/ACE/ACE_wrappers \
- -I../../../Oem/CppUnit-1.9.14/include \
- -I../../../Common/Foundation \
- -I../../../Common/Geometry \
- -I../../../Common/PlatformBase \
- -I../../../Common/MapGuideCommon \
- -I../Common \
-check_LTLIBRARIES = libMgUnitTesting.la
-libMgUnitTesting_la_SOURCES = \
- TestCoordinateSystem.cpp \
- TestDrawingService.cpp \
- TestFeatureService.cpp \
- TestGeometry.cpp\
- TestKmlService.cpp \
- TestLogManager.cpp \
- TestLogManagerThread.cpp \
- TestMappingService.cpp \
- TestMdfModel.cpp \
- TestPerformance.cpp \
- TestRenderingService.cpp \
- TestResourceService.cpp \
- TestServerAdminService.cpp \
- TestServerManager.cpp \
- TestServiceManager.cpp \
- TestSiteManager.cpp \
- TestSiteService.cpp \
- TestTileService.cpp \
- TestProfilingService.cpp \
- TestTransformMesh.cpp \
- UnitTesting.cpp
-noinst_HEADERS = \
- CppUnitExtensions.h \
- TestCoordinateSystem.h \
- TestFeatureService.h \
- TestGeometry.h \
- TestKmlService.h \
- TestLogManager.h \
- TestLogManagerThread.h \
- TestMappingService.h \
- TestMdfModel.h \
- TestPerformance.h \
- TestRenderingService.h \
- TestResourceService.h \
- TestServerAdminService.h \
- TestServerManager.h \
- TestServiceManager.h \
- TestSiteManager.h \
- TestSiteService.h \
- TestTileService.h \
- TestProfilingService.h \
- TestTransformMesh.h \
- UnitTesting.h
-libMgUnitTesting_la_LIBADD = -lcppunit
-libMgUnitTesting_la_LDFLAGS = -rpath /createshared -release $(PACKAGE_VERSION) \
- -L../../../Oem/CppUnit-1.9.14/src/cppunit
Deleted: trunk/MgDev/Web/Makefile.am
--- trunk/MgDev/Web/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Web/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,3 +0,0 @@
-SUBDIRS = src
-DIST_SUBDIRS = src
Deleted: trunk/MgDev/Web/src/ApacheAgent/Makefile.am
--- trunk/MgDev/Web/src/ApacheAgent/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Web/src/ApacheAgent/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,61 +0,0 @@
-EXTRA_DIST = ApacheAgent.vcproj
-prefix=@prefix@/webserverextensions
-INCLUDES = -I../../../Common/Foundation \
- -I$(httpd_src)/include \
- -I$(httpd_src)/srclib/apr/include \
- -I$(httpd_src)/srclib/apr-util/include \
- -I$(httpd_src)/os/unix \
- -I/usr/local/mapguideopensource/webserverextensions/apache2/include\
- -I../HttpHandler \
- -I../WebSupport \
- -I../MapAgentCommon
-lib_LTLIBRARIES = mod_mgmapagent.la
-mod_mgmapagent_la_SOURCES = ApacheAgent.cpp \
- ApachePostParser.cpp \
- ApacheReaderStreamer.cpp \
- ApacheResponseHandler.cpp \
- ../MapAgentCommon/MapAgentCommon.cpp \
- ../MapAgentCommon/MapAgentGetParser.cpp \
- ../MapAgentCommon/MapAgentStrings.cpp \
- ../WebSupport/InitializeWebTier.cpp
-noinst_HEADERS = ApachePostParser.h \
- ApacheReaderStreamer.h \
- ApacheResponseHandler.h \
- ../MapAgentCommon/MapAgentCommon.h \
- ../MapAgentCommon/MapAgentGetParser.h \
- ../MapAgentCommon/MapAgentStrings.h \
- ../WebSupport/WebSupport.h
-mod_mgmapagent_la_LIBADD = -lMgFoundation \
- -lMgGeometry \
- -lMgMdfModel \
- -lMgMdfParser \
- -lMgHttpHandler \
- -lMgWebSupport
-mod_mgmapagent_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../../../Oem/ACE/ACE_wrappers/ace \
- -L../../../Common/CoordinateSystem \
- -L../../../Common/MdfModel \
- -L../../../Common/MdfParser \
- -L../../../Common/Foundation \
- -L../../../Common/Geometry \
- -L../../../Common/PlatformBase \
- -L../../../Common/MapGuideCommon \
- -L../HttpHandler \
- -L../WebSupport \
- -module
Deleted: trunk/MgDev/Web/src/CgiAgent/Makefile.am
--- trunk/MgDev/Web/src/CgiAgent/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Web/src/CgiAgent/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,61 +0,0 @@
-EXTRA_DIST = CgiAgent.rc CgiAgent.vcproj
- -I../WebSupport \
-bin_PROGRAMS = mapagent
-mapagent_SOURCES = CgiAgent.cpp \
- CgiPostParser.cpp \
- CgiReaderStreamer.cpp \
- CgiResponseHandler.cpp \
- EchoTest.cpp \
-noinst_HEADERS = CgiPostParser.h \
- CgiReaderStreamer.h \
- CgiResponseHandler.h \
-mapagent_LDADD = -lACE \
- -lxerces-c \
- -lMgFoundation \
- -lMgGeometry \
- -lMgMapGuideCommon \
- -lMgMdfModel \
- -lMgMdfParser \
- -lMgHttpHandler \
- -lMgWebSupport \
- -llib_json
-mapagent_LDFLAGS = \
- -L../../../Oem/jsoncpp/lib \
- -L../WebSupport
Deleted: trunk/MgDev/Web/src/HttpHandler/Makefile.am
--- trunk/MgDev/Web/src/HttpHandler/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Web/src/HttpHandler/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,320 +0,0 @@
-EXTRA_DIST = HttpHandler.rc HttpHandler.vcproj
-INCLUDES = -I../../../Common/MdfModel \
- -I../../../Oem/jsoncpp/include
-lib_LTLIBRARIES = libMgHttpHandler.la
-libMgHttpHandler_la_SOURCES = HttpHandlerBuild.cpp
-include_SOURCES = \
- Dictionary.cpp \
- HttpApplyResourcePackage.cpp \
- HttpChangeResourceOwner.cpp \
- HttpClearTileCache.cpp \
- HttpCopyResource.cpp \
- HttpCreateRepository.cpp \
- HttpCreateRuntimeMap.cpp \
- HttpCreateSession.cpp \
- HttpCsConvertWktToCoordinateSystemCode.cpp \
- HttpCsConvertCoordinateSystemCodeToWkt.cpp \
- HttpCsConvertEpsgCodeToWkt.cpp \
- HttpCsConvertWktToEpsgCode.cpp \
- HttpCsEnumerateCategories.cpp \
- HttpCsEnumerateCoordinateSystems.cpp \
- HttpCsGetBaseLibrary.cpp \
- HttpCsIsValid.cpp \
- HttpCsTransformCoordinates.cpp \
- HttpDeleteRepository.cpp \
- HttpDeleteResource.cpp \
- HttpDeleteResourceData.cpp \
- HttpDescribeDrawing.cpp \
- HttpDescribeRuntimeMap.cpp \
- HttpDescribeSchema.cpp \
- HttpEnumerateDataStores.cpp \
- HttpEnumerateDrawingLayers.cpp \
- HttpEnumerateDrawingSectionResources.cpp \
- HttpEnumerateDrawingSections.cpp \
- HttpEnumerateGroups.cpp \
- HttpEnumerateRepositories.cpp \
- HttpEnumerateResourceData.cpp \
- HttpEnumerateResourceReferences.cpp \
- HttpEnumerateResources.cpp \
- HttpEnumerateUnmanagedData.cpp \
- HttpEnumerateUsers.cpp \
- HttpEnumerateApplicationContainers.cpp \
- HttpEnumerateApplicationWidgets.cpp \
- HttpEnumerateApplicationTemplates.cpp \
- HttpGeoBinaryOperation.cpp \
- HttpGeoBoundary.cpp \
- HttpGeoBuffer.cpp \
- HttpGeoConvexHull.cpp \
- HttpGeoDistance.cpp \
- HttpGeometryInfo.cpp \
- HttpGeoSimplify.cpp \
- HttpGeoSpatialPredicate.cpp \
- HttpGeoTessellate.cpp \
- HttpGetCapabilities.cpp \
- HttpGetClassDefinition.cpp \
- HttpGetClasses.cpp \
- HttpGetConnectionPropertyValues.cpp \
- HttpGetDefaultTileSizeX.cpp \
- HttpGetDefaultTileSizeY.cpp \
- HttpGetDrawing.cpp \
- HttpGetDrawingCoordinateSpace.cpp \
- HttpGetDrawingLayer.cpp \
- HttpGetDrawingSection.cpp \
- HttpGetDrawingSectionResource.cpp \
- HttpGetDwfViewerPage.cpp \
- HttpGetDynamicMapOverlayImage.cpp \
- HttpGetFdoCacheInfo.cpp \
- HttpGetFeatureProviders.cpp \
- HttpGetFeatureSetEnvelope.cpp \
- HttpGetHtmlViewerPage.cpp \
- HttpGetIdentityProperties.cpp \
- HttpGetLegendImage.cpp \
- HttpGetLongTransactions.cpp \
- HttpGetMapLegendImage.cpp \
- HttpGetMapImage.cpp \
- HttpGetPlot.cpp \
- HttpGetRepositoryContent.cpp \
- HttpGetRepositoryHeader.cpp \
- HttpGetResourceContent.cpp \
- HttpGetResourceData.cpp \
- HttpGetResourceHeader.cpp \
- HttpGetSchemaMapping.cpp \
- HttpGetSchemas.cpp \
- HttpGetSessionTimeout.cpp \
- HttpGetSiteInfo.cpp \
- HttpGetSiteStatus.cpp \
- HttpGetSiteVersion.cpp \
- HttpGetSpatialContexts.cpp \
- HttpGetTileImage.cpp \
- HttpGetTileProviders.cpp \
- HttpGetVisibleMapExtent.cpp \
- HttpKmlGetMap.cpp \
- HttpKmlGetLayer.cpp \
- HttpKmlGetFeatures.cpp \
- HttpHeader.cpp \
- HttpInheritPermissionsFrom.cpp \
- HttpMoveResource.cpp \
- HttpPrimitiveValue.cpp \
- HttpQueryMapFeatures.cpp \
- HttpReaderStreamer.cpp \
- HttpRenameResourceData.cpp \
- HttpRequest.cpp \
- HttpRequestMetadata.cpp \
- HttpRequestParam.cpp \
- HttpRequestParameters.cpp \
- HttpRequestResponseHandler.cpp \
- HttpResourceExists.cpp \
- HttpResourceStrings.cpp \
- HttpResponse.cpp \
- HttpResult.cpp \
- HttpSelectFeatures.cpp \
- HttpSelectFeaturesSpatially.cpp \
- HttpSetResource.cpp \
- HttpSetResourceData.cpp \
- HttpTestConnection.cpp \
- HttpUpdateRepository.cpp \
- HttpUtil.cpp \
- HttpWfsDescribeFeatureType.cpp \
- HttpWfsGetCapabilities.cpp \
- HttpWfsGetFeature.cpp \
- HttpWmsGetCapabilities.cpp \
- HttpWmsGetFeatureInfo.cpp \
- HttpWmsGetMap.cpp \
- NameStringValueCollection.cpp \
- NameValueCollection.cpp \
- OgcServer.cpp \
- OgcWfsException.cpp \
- OgcWfsServer.cpp \
- OgcWmsException.cpp \
- OgcWmsServer.cpp \
- ReaderByteSourceImpl.cpp \
- WfsFeatureDefinitions.cpp \
- WfsGetFeatureParams.cpp \
- WmsFeatureGeometry.cpp \
- WmsFeatureInfo.cpp \
- WmsFeatureProperties.cpp \
- WmsLayerDefinitions.cpp \
- WmsMapUtil.cpp \
- XmlParser.cpp \
- JsonDoc.cpp \
- XmlJsonConvert.cpp
-noinst_HEADERS = $(include_SOURCES) \
- Dictionary.h \
- HttpApplyResourcePackage.h \
- HttpChangeResourceOwner.h \
- HttpClearTileCache.h \
- HttpCopyResource.h \
- HttpCreateRepository.h \
- HttpCreateRuntimeMap.h \
- HttpCreateSession.h \
- HttpCsConvertWktToCoordinateSystemCode.h \
- HttpCsConvertCoordinateSystemCodeToWkt.h \
- HttpCsConvertEpsgCodeToWkt.h \
- HttpCsConvertWktToEpsgCode.h \
- HttpCsEnumerateCategories.h \
- HttpCsEnumerateCoordinateSystems.h \
- HttpCsGetBaseLibrary.h \
- HttpCsIsValid.h \
- HttpCsTransformCoordinates.h \
- HttpDeleteRepository.h \
- HttpDeleteResource.h \
- HttpDeleteResourceData.h \
- HttpDescribeDrawing.h \
- HttpDescribeRuntimeMap.h \
- HttpDescribeSchema.h \
- HttpEnumerateDataStores.h \
- HttpEnumerateDrawingLayers.h \
- HttpEnumerateDrawingSectionResources.h \
- HttpEnumerateDrawingSections.h \
- HttpEnumerateGroups.h \
- HttpEnumerateRepositories.h \
- HttpEnumerateResourceData.h \
- HttpEnumerateResourceReferences.h \
- HttpEnumerateResources.h \
- HttpEnumerateUnmanagedData.h \
- HttpEnumerateUsers.h \
- HttpEnumerateApplicationContainers.h \
- HttpEnumerateApplicationWidgets.h \
- HttpEnumerateApplicationTemplates.h \
- HttpGeoBinaryOperation.h \
- HttpGeoBoundary.h \
- HttpGeoBuffer.h \
- HttpGeoConvexHull.h \
- HttpGeoDistance.h \
- HttpGeometryInfo.h \
- HttpGeoSimplify.h \
- HttpGeoSpatialPredicate.h \
- HttpGeoTessellate.h \
- HttpGetCapabilities.h \
- HttpGetClassDefinition.h \
- HttpGetClasses.h \
- HttpGetConnectionPropertyValues.h \
- HttpGetDefaultTileSizeX.h \
- HttpGetDefaultTileSizeY.h \
- HttpGetDrawing.h \
- HttpGetDrawingCoordinateSpace.h \
- HttpGetDrawingLayer.h \
- HttpGetDrawingSection.h \
- HttpGetDrawingSectionResource.h \
- HttpGetDwfViewerPage.h \
- HttpGetDynamicMapOverlayImage.h \
- HttpGetFdoCacheInfo.h \
- HttpGetFeatureProviders.h \
- HttpGetFeatureSetEnvelope.h \
- HttpGetHtmlViewerPage.h \
- HttpGetIdentityProperties.h \
- HttpGetLegendImage.h \
- HttpGetLongTransactions.h \
- HttpGetMapLegendImage.h \
- HttpGetMapImage.h \
- HttpGetPlot.h \
- HttpGetRepositoryContent.h \
- HttpGetRepositoryHeader.h \
- HttpGetResourceContent.h \
- HttpGetResourceData.h \
- HttpGetResourceHeader.h \
- HttpGetSchemaMapping.h \
- HttpGetSchemas.h \
- HttpGetSessionTimeout.h \
- HttpGetSiteInfo.h \
- HttpGetSiteStatus.h \
- HttpGetSiteVersion.h \
- HttpGetSpatialContexts.h \
- HttpGetTileImage.h \
- HttpGetTileProviders.h \
- HttpGetVisibleMapExtent.h \
- HttpHandler.h \
- HttpHandlerApiDllExport.h \
- HttpHandlerClassId.h \
- HttpHeader.h \
- HttpInheritPermissionsFrom.h \
- HttpKmlGetMap.h \
- HttpKmlGetLayer.h \
- HttpKmlGetFeatures.h \
- HttpMoveResource.h \
- HttpPrimitiveValue.h \
- HttpPrimitiveValueTypes.h \
- HttpQueryMapFeatures.h \
- HttpReaderStreamer.h \
- HttpRenameResourceData.h \
- HttpRequest.h \
- HttpRequestMetadata.h \
- HttpRequestParam.h \
- HttpRequestParameters.h \
- HttpRequestResponseHandler.h \
- HttpResourceExists.h \
- HttpResourceStrings.h \
- HttpResponse.h \
- HttpResult.h \
- HttpSelectFeatures.h \
- HttpSelectFeaturesSpatially.h \
- HttpSetResource.h \
- HttpSetResourceData.h \
- HttpStatusCodes.h \
- HttpTestConnection.h \
- HttpUpdateRepository.h \
- HttpUtil.h \
- HttpWfsDescribeFeatureType.h \
- HttpWfsGetCapabilities.h \
- HttpWfsGetFeature.h \
- HttpWmsGetCapabilities.h \
- HttpWmsGetFeatureInfo.h \
- HttpWmsGetMap.h \
- NameStringValueCollection.h \
- NameValueCollection.h \
- OgcException.h \
- OgcFramework.h \
- OgcServer.h \
- OgcDataAccessor.h \
- OgcWfsException.h \
- OgcWfsServer.h \
- OgcWmsException.h \
- OgcWmsServer.h \
- ReaderByteSourceImpl.h \
- ResponseStream.h \
- Stream.h \
- StringStream.h \
- WfsFeatureDefinitions.h \
- WfsGetFeatureParams.h \
- WmsFeatureGeometry.h \
- WmsFeatureInfo.h \
- WmsFeatureProperties.h \
- WmsLayerDefinitions.h \
- WmsMapUtil.h \
- XmlElementEmitter.h \
- XmlParser.h \
- JsonDoc.h \
- XmlJsonConvert.h
-libMgHttpHandler_la_LIBADD = \
- -lMgFoundation \
- -lMgGeometry \
- -lMgPlatformBase \
- -llib_json \
- -lMgMdfModel \
- -lMgMdfParser
-libMgHttpHandler_la_LDFLAGS = -release $(PACKAGE_VERSION) \
Deleted: trunk/MgDev/Web/src/Makefile.am
--- trunk/MgDev/Web/src/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Web/src/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,76 +0,0 @@
-AUTOMAKE_OPTIONS = foreign
-SUBDIRS = WebApp WebSupport HttpHandler CgiAgent PhpApi JavaApi JavaApiEx ApacheAgent
-DIST_SUBDIRS = WebApp WebSupport HttpHandler CgiAgent PhpApi JavaApi JavaApiEx ApacheAgent
-EXTRA_DIST = MapGuideApi DotNetApi DotNetUnmanagedApi mapviewernet mapviewerjava mapviewerphp mapadmin mapagent stdicons viewerfiles WebTier.sln webconfig.ini WEB-INF localized schemareport webstudio PostBuild
-prefix=@prefix@/webserverextensions/www
-mentor_dict_install_dir=@prefix@/share/gis/coordsys
-apachedir = @prefix@/webserverextensions/apache2
-apachemodulesdir = ${apachedir}/modules
-apacheconfdir = ${apachedir}/conf
-mapagentdir = ${prefix}/mapagent
-mapadmindir = ${prefix}/mapadmin
-fusiondir = ${prefix}/fusion
-mapviewerphpdir = ${prefix}/mapviewerphp
-mapviewerjavadir = ${prefix}/mapviewerjava
-stdiconsdir = ${prefix}/stdicons
-localizeddir = ${prefix}/localized
-schemareportdir = ${prefix}/schemareport
-viewerfilesdir = ${prefix}/viewerfiles
-tempdir = ${prefix}/TempDir
-webinfdir = ${prefix}/WEB-INF
- test -d $(apachemodulesdir) || $(mkinstalldirs) $(apachemodulesdir)
- test -d $(mapagentdir) || $(mkinstalldirs) $(mapagentdir)
- test -d $(mapadmindir) || $(mkinstalldirs) $(mapadmindir)
- test -d $(fusiondir) || $(mkinstalldirs) $(fusiondir)
- test -d $(mapviewerphpdir) || $(mkinstalldirs) $(mapviewerphpdir)
- test -d $(mapviewerjavadir) || $(mkinstalldirs) $(mapviewerjavadir)
- test -d $(stdiconsdir) || $(mkinstalldirs) $(stdiconsdir)
- test -d $(localizeddir) || $(mkinstalldirs) $(localizeddir)
- test -d $(schemareportdir) || $(mkinstalldirs) $(schemareportdir)
- test -d $(viewerfilesdir) || $(mkinstalldirs) $(viewerfilesdir)
- test -d $(webinfdir) || $(mkinstalldirs) $(webinfdir)
- @cp -rfp mapadmin/* $(mapadmindir)
- @cp -fp PhpApi/constants.php $(mapadmindir)
- @cp -fp ../../Common/MapGuideCommon/Resources/mapguide_en.res $(resourcesdir)
- @cp -rfp ../../Oem/fusion/build/* $(fusiondir)
- @cp -rfp ../../Oem/fusionMG/* $(fusiondir)
- @cp -rfp mapviewerphp/* $(mapviewerphpdir)
- @cp -fp PhpApi/constants.php $(mapviewerphpdir)
- @find mapviewerjava -maxdepth 1 -type f -exec cp -fp {} $(mapviewerjavadir) \;
- @cp -rfp localized/* $(localizeddir)
- @cp -fp stdicons/* $(stdiconsdir)
- @cp -rfp schemareport/* $(schemareportdir)
- @cp -fp viewerfiles/* $(viewerfilesdir)
- @cp -rfp WEB-INF/* $(webinfdir)
- @pushd $(mapagentdir); ln -s ../../bin/mapagent mapagent; popd;
- @pushd $(apachemodulesdir); ln -s ../../lib/mod_mgmapagent.so mod_mgmapagent.so; popd;
- @cp -fp ../../UnitTest/WebTier/MapAgent/MapAgentForms/* $(mapagentdir)
- @cp -fp $(apacheconfdir)/mapguide.conf $(apacheconfdir)/mapguide.conf.bak
- @chmod 777 $(tempdir)
-install-data-hook:
- @sed -e 's#^ResourcesPath.*=.*#ResourcesPath = ${prefix}/Resources/#' \
- -e 's#^TempPath.*=.*#TempPath = ${prefix}/TempDir/#' \
- -e 's#^TemplateRootFolder.*=.*#TemplateRootFolder = ${fusiondir}/templates/mapguide#' \
- -e 's#^WidgetInfoFolder.*=.*#WidgetInfoFolder = ${fusiondir}/widgets/widgetinfo#' \
- -e 's#^ContainerInfoFolder.*=.*#ContainerInfoFolder = ${fusiondir}/containerinfo#' \
- webconfig.ini > ${prefix}/webconfig.ini
- @sed -e 's#^\#LoadModule mgmapagent_module.*#LoadModule mgmapagent_module modules/mod_mgmapagent.so#' \
- -e 's#^\#AddHandler mgmapagent_handler.*#AddHandler mgmapagent_handler fcgi#' \
- ${apacheconfdir}/mapguide.conf.bak > ${apacheconfdir}/mapguide.conf
- @pushd $(apachedir)/bin; ./httpd -k stop; ./httpd -k start; popd;
Deleted: trunk/MgDev/Web/src/WebApp/Makefile.am
--- trunk/MgDev/Web/src/WebApp/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Web/src/WebApp/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,92 +0,0 @@
-EXTRA_DIST = WebApp.rc WebApp.vcproj
-lib_LTLIBRARIES = libMgWebApp.la
-include_SOURCES = WebBufferCommand.cpp \
- WebCommand.cpp \
- WebCommandCollection.cpp \
- WebCommandWidget.cpp \
- WebContextMenu.cpp \
- WebFlyoutWidget.cpp \
- WebGettingStarted.cpp \
- WebGetPrintablePageCommand.cpp \
- WebHelpCommand.cpp \
- WebInformationPane.cpp \
- WebInvokeScriptCommand.cpp \
- WebInvokeUrlCommand.cpp \
- WebLayout.cpp \
- WebMeasureCommand.cpp \
- WebPrintCommand.cpp \
- WebSearchCommand.cpp \
- WebSelectWithinCommand.cpp \
- WebSeparatorWidget.cpp \
- WebTaskBarWidget.cpp \
- WebTaskBar.cpp \
- WebTaskPane.cpp \
- WebToolbar.cpp \
- WebUiPane.cpp \
- WebUiSizablePane.cpp \
- WebUiTargetCommand.cpp \
- WebViewOptionsCommand.cpp \
- WebWidget.cpp \
- WebWidgetCollection.cpp
- WebActions.h \
- WebApp.h \
- WebAppClassId.h \
- WebAppExport.h \
- WebBufferCommand.h \
- WebCommand.h \
- WebCommandCollection.h \
- WebCommandWidget.h \
- WebContextMenu.h \
- WebFlyoutWidget.h \
- WebGetPrintablePageCommand.h \
- WebHelpCommand.h \
- WebInformationPane.h \
- WebInvokeScriptCommand.h \
- WebInvokeUrlCommand.h \
- WebLayout.h \
- WebMeasureCommand.h \
- WebPrintCommand.h \
- WebSearchCommand.h \
- WebSelectWithinCommand.h \
- WebSeparatorWidget.h \
- WebTargetType.h \
- WebTargetViewerType.h \
- WebTaskBar.h \
- WebTaskBarWidget.h \
- WebTaskButtonType.h \
- WebTaskPane.h \
- WebToolbar.h \
- WebUiPane.h \
- WebUiSizablePane.h \
- WebUiTargetCommand.h \
- WebViewOptionsCommand.h \
- WebWidgetType.h \
- WebWidget.h \
- WebWidgetCollection.h
-libMgWebApp_la_SOURCES = WebAppBuild.cpp
- -I../../../Oem/dbxml/xerces-c-src/src \
-libMgWebApp_la_LIBADD = -lxerces-c -lMgFoundation -lMgGeometry -lMgPlatformBase -lMgMapGuideCommon
-libMgWebApp_la_LDFLAGS = -release $(PACKAGE_VERSION) \
- -L../../../Oem/dbxml/install/lib \
Deleted: trunk/MgDev/Web/src/WebSupport/Makefile.am
--- trunk/MgDev/Web/src/WebSupport/Makefile.am 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/Web/src/WebSupport/Makefile.am 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,25 +0,0 @@
-EXTRA_DIST =WebSupport.vcproj
-lib_LTLIBRARIES = libMgWebSupport.la
-libMgWebSupport_la_SOURCES = InitializeWebTier.cpp
-noinst_HEADERS = WebSupport.h
-libMgWebSupport_la_LIBADD = -lMgFoundation -lMgPlatformBase -lMgMapGuideCommon
-libMgWebSupport_la_LDFLAGS = -release $(PACKAGE_VERSION) \
Deleted: trunk/MgDev/acinclude.m4
--- trunk/MgDev/acinclude.m4 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/acinclude.m4 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,136 +0,0 @@
-dnl MAP_HELP_STRING(LHS, RHS)
-dnl Autoconf 2.50 can not handle substr correctly. It does have
-dnl AC_HELP_STRING, so let's try to call it if we can.
-dnl Note: this define must be on one line so that it can be properly returned
-dnl as the help string.
-AC_DEFUN([MAP_HELP_STRING],[ifelse(regexp(AC_ACVERSION, 2\.1), -1, AC_HELP_STRING($1,$2),[ ]$1 substr([ ],len($1))$2)])dnl
-dnl MAP_SUBST(VARIABLE)
-dnl Makes VARIABLE available in generated files
-dnl (do not use @variable@ in Makefiles, but $(variable))
-AC_DEFUN([MAP_SUBST],[
- MAP_VAR_SUBST="$MAP_VAR_SUBST $1"
- AC_SUBST($1)
-dnl MAP_FAST_OUTPUT(FILENAME)
-dnl Perform substitutions on FILENAME (Makefiles only)
-AC_DEFUN([MAP_FAST_OUTPUT],[
- MAP_FAST_OUTPUT_FILES="$MAP_FAST_OUTPUT_FILES $1"
-dnl MAP_GEN_CONFIG_VARS
-dnl Creates config_vars.mk
-AC_DEFUN([MAP_GEN_CONFIG_VARS],[
- MAP_SUBST(map_srcdir)
- MAP_SUBST(bindir)
- MAP_SUBST(sbindir)
- MAP_SUBST(phpdir)
- MAP_SUBST(logfiledir)
- MAP_SUBST(libdir)
- MAP_SUBST(libexecdir)
- MAP_SUBST(htdocsdir)
- MAP_SUBST(includedir)
- MAP_SUBST(installbuilddir)
- MAP_SUBST(runtimedir)
- MAP_SUBST(other_targets)
- MAP_SUBST(progname)
- MAP_SUBST(prefix)
- MAP_SUBST(AWK)
- MAP_SUBST(CC)
- MAP_SUBST(CPP)
- MAP_SUBST(CXX)
- MAP_SUBST(CPPFLAGS)
- MAP_SUBST(CFLAGS)
- MAP_SUBST(CXXFLAGS)
- MAP_SUBST(LTFLAGS)
- MAP_SUBST(LDFLAGS)
- MAP_SUBST(LT_LDFLAGS)
- MAP_SUBST(SH_LDFLAGS)
- MAP_SUBST(LIBS)
- MAP_SUBST(DEFS)
- MAP_SUBST(INCLUDES)
- MAP_SUBST(LIBTOOL)
- abs_srcdir="`(cd $srcdir && pwd)`"
- echo creating config_vars.mk
- test -d build || $mkdir_p build
- > config_vars.mk
- for i in $MAP_VAR_SUBST; do
- eval echo "$i = \$$i" >> config_vars.mk
- done
-dnl #
-dnl # MAP_GENERATE_MAKEFILES
-dnl # Creates Makefiles
-AC_DEFUN([MAP_GENERATE_MAKEFILES],[
- $SHELL $srcdir/fastgen.sh $srcdir $ac_cv_mkdir_p $MAP_FAST_OUTPUT_FILES
-dnl ## MAP_OUTPUT(file)
-dnl ## adds "file" to the list of files generated by AC_OUTPUT
-dnl ## This macro can be used several times.
-AC_DEFUN([MAP_OUTPUT], [
- MAP_OUTPUT_FILES="$MAP_OUTPUT_FILES $1"
-dnl
-dnl MAP_DEFINE_TYPE_RLIM_T
-dnl
-dnl If rlim_t is not defined, define it to int
-dnl
-AC_DEFUN([MAP_DEFINE_TYPE_RLIM_T], [
- AC_CACHE_CHECK([for rlim_t], ac_cv_type_rlim_t, [
- AC_TRY_COMPILE([
-#include <sys/types.h>
-#include <sys/time.h>
-#include <sys/resource.h>
-], [rlim_t spoon;], [
- ac_cv_type_rlim_t=yes
- ],[ac_cv_type_rlim_t=no
- if test "$ac_cv_type_rlim_t" = "no" ; then
- AC_DEFINE(rlim_t, int,
- [Define to 'int' if <sys/resource.h> doesn't define it for us])
- fi
-dnl NOT YET IMPLEMENTED
-dnl MAP_EXPORT_ARGUMENTS
-dnl Export (via MAP_SUBST) the various path-related variables that
-dnl Autodesk MapGuide Open Source will use while generating scripts
-dnl like autoconf and the default config file.
-AC_DEFUN([MAP_SUBST_EXPANDED_ARG],[
- APR_EXPAND_VAR(exp_$1, [$]$1)
- MAP_SUBST(exp_$1)
- APR_PATH_RELATIVE(rel_$1, [$]exp_$1, ${prefix})
- MAP_SUBST(rel_$1)
-AC_DEFUN([MAP_EXPORT_ARGUMENTS],[
- MAP_SUBST_EXPANDED_ARG(exec_prefix)
- MAP_SUBST_EXPANDED_ARG(bindir)
- MAP_SUBST_EXPANDED_ARG(sbindir)
- MAP_SUBST_EXPANDED_ARG(libdir)
- MAP_SUBST_EXPANDED_ARG(libexecdir)
- MAP_SUBST_EXPANDED_ARG(mandir)
- MAP_SUBST_EXPANDED_ARG(sysconfdir)
- MAP_SUBST_EXPANDED_ARG(datadir)
- MAP_SUBST_EXPANDED_ARG(installbuilddir)
- MAP_SUBST_EXPANDED_ARG(errordir)
- MAP_SUBST_EXPANDED_ARG(iconsdir)
- MAP_SUBST_EXPANDED_ARG(htdocsdir)
- MAP_SUBST_EXPANDED_ARG(manualdir)
- MAP_SUBST_EXPANDED_ARG(cgidir)
- MAP_SUBST_EXPANDED_ARG(includedir)
- MAP_SUBST_EXPANDED_ARG(localstatedir)
- MAP_SUBST_EXPANDED_ARG(runtimedir)
- MAP_SUBST_EXPANDED_ARG(logfiledir)
- MAP_SUBST_EXPANDED_ARG(proxycachedir)
Deleted: trunk/MgDev/aclocal.m4
--- trunk/MgDev/aclocal.m4 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/aclocal.m4 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,4536 +0,0 @@
-# aclocal.m4 generated automatically by aclocal 1.6.3 -*- Autoconf -*-
-# Copyright 1996, 1997, 1998, 1999, 2000, 2001, 2002
-# Free Software Foundation, Inc.
-# This file is free software; the Free Software Foundation
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
-# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
-# PARTICULAR PURPOSE.
-AC_DEFUN(MAP_HELP_STRING,[ifelse(regexp(AC_ACVERSION, 2\.1), -1, AC_HELP_STRING($1,$2),[ ]$1 substr([ ],len($1))$2)])dnl
-AC_DEFUN(MAP_SUBST,[
- AC_SUBST($1)
-AC_DEFUN(MAP_FAST_OUTPUT,[
-AC_DEFUN(MAP_GEN_CONFIG_VARS,[
- MAP_SUBST(bindir)
- MAP_SUBST(phpdir)
- MAP_SUBST(libdir)
- MAP_SUBST(prefix)
- MAP_SUBST(AWK)
- MAP_SUBST(CC)
- MAP_SUBST(CPP)
- MAP_SUBST(CXX)
- MAP_SUBST(CFLAGS)
- MAP_SUBST(LIBS)
- MAP_SUBST(DEFS)
- > config_vars.mk
- done
-dnl #
-AC_DEFUN(MAP_GENERATE_MAKEFILES,[
-AC_DEFUN(MAP_OUTPUT, [
-dnl
-dnl
-dnl
-AC_DEFUN(MAP_DEFINE_TYPE_RLIM_T, [
- AC_TRY_COMPILE([
- fi
-AC_DEFUN(MAP_SUBST_EXPANDED_ARG,[
- MAP_SUBST(exp_$1)
- MAP_SUBST(rel_$1)
-AC_DEFUN(MAP_EXPORT_ARGUMENTS,[
-# Do all the work for Automake. -*- Autoconf -*-
-# This macro actually does too much some checks are only needed if
-# your package does certain things. But this isn't really a big deal.
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
-# 02111-1307, USA.
-# serial 8
-# There are a few dirty hacks below to avoid letting `AC_PROG_CC' be
-# written in clear, in which case automake, when reading aclocal.m4,
-# will think it sees a *use*, and therefore will trigger all it's
-# C support machinery. Also note that it means that autoscan, seeing
-# CC etc. in the Makefile, will ask for an AC_PROG_CC use...
-AC_PREREQ([2.52])
-# Autoconf 2.50 wants to disallow AM_ names. We explicitly allow
-# the ones we care about.
-m4_pattern_allow([^AM_[A-Z]+FLAGS$])dnl
-# AM_INIT_AUTOMAKE(PACKAGE, VERSION, [NO-DEFINE])
-# AM_INIT_AUTOMAKE([OPTIONS])
-# The call with PACKAGE and VERSION arguments is the old style
-# call (pre autoconf-2.50), which is being phased out. PACKAGE
-# and VERSION should now be passed to AC_INIT and removed from
-# the call to AM_INIT_AUTOMAKE.
-# We support both call styles for the transition. After
-# the next Automake release, Autoconf can make the AC_INIT
-# arguments mandatory, and then we can depend on a new Autoconf
-# release and drop the old call support.
-AC_DEFUN([AM_INIT_AUTOMAKE],
-[AC_REQUIRE([AM_SET_CURRENT_AUTOMAKE_VERSION])dnl
- AC_REQUIRE([AC_PROG_INSTALL])dnl
-# test to see if srcdir already configured
-if test "`cd $srcdir && pwd`" != "`pwd`" &&
- test -f $srcdir/config.status; then
- AC_MSG_ERROR([source directory already configured; run "make distclean" there first])
-fi
-# Define the identity of the package.
-dnl Distinguish between old-style and new-style calls.
-m4_ifval([$2],
-[m4_ifval([$3], [_AM_SET_OPTION([no-define])])dnl
- AC_SUBST([PACKAGE], [$1])dnl
- AC_SUBST([VERSION], [$2])],
-[_AM_SET_OPTIONS([$1])dnl
- AC_SUBST([PACKAGE], [AC_PACKAGE_TARNAME])dnl
- AC_SUBST([VERSION], [AC_PACKAGE_VERSION])])dnl
-_AM_IF_OPTION([no-define],,
-[AC_DEFINE_UNQUOTED(PACKAGE, "$PACKAGE", [Name of package])
- AC_DEFINE_UNQUOTED(VERSION, "$VERSION", [Version number of package])])dnl
-# Some tools Automake needs.
-AC_REQUIRE([AM_SANITY_CHECK])dnl
-AC_REQUIRE([AC_ARG_PROGRAM])dnl
-AM_MISSING_PROG(ACLOCAL, aclocal-${am__api_version})
-AM_MISSING_PROG(AUTOCONF, autoconf)
-AM_MISSING_PROG(AUTOMAKE, automake-${am__api_version})
-AM_MISSING_PROG(AUTOHEADER, autoheader)
-AM_MISSING_PROG(MAKEINFO, makeinfo)
-AM_MISSING_PROG(AMTAR, tar)
-AM_PROG_INSTALL_SH
-AM_PROG_INSTALL_STRIP
-# We need awk for the "check" target. The system "awk" is bad on
-# some platforms.
-AC_REQUIRE([AC_PROG_AWK])dnl
-AC_REQUIRE([AC_PROG_MAKE_SET])dnl
-_AM_IF_OPTION([no-dependencies],,
-[AC_PROVIDE_IFELSE([AC_PROG_][CC],
- [_AM_DEPENDENCIES(CC)],
- [define([AC_PROG_][CC],
- defn([AC_PROG_][CC])[_AM_DEPENDENCIES(CC)])])dnl
-AC_PROVIDE_IFELSE([AC_PROG_][CXX],
- [_AM_DEPENDENCIES(CXX)],
- [define([AC_PROG_][CXX],
- defn([AC_PROG_][CXX])[_AM_DEPENDENCIES(CXX)])])dnl
-# Copyright 2002 Free Software Foundation, Inc.
-# AM_AUTOMAKE_VERSION(VERSION)
-# Automake X.Y traces this macro to ensure aclocal.m4 has been
-# generated from the m4 files accompanying Automake X.Y.
-AC_DEFUN([AM_AUTOMAKE_VERSION],[am__api_version="1.6"])
-# AM_SET_CURRENT_AUTOMAKE_VERSION
-# Call AM_AUTOMAKE_VERSION so it can be traced.
-# This function is AC_REQUIREd by AC_INIT_AUTOMAKE.
-AC_DEFUN([AM_SET_CURRENT_AUTOMAKE_VERSION],
- [AM_AUTOMAKE_VERSION([1.6.3])])
-# Helper functions for option handling. -*- Autoconf -*-
-# Copyright 2001, 2002 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# serial 2
-# _AM_MANGLE_OPTION(NAME)
-AC_DEFUN([_AM_MANGLE_OPTION],
-[[_AM_OPTION_]m4_bpatsubst($1, [[^a-zA-Z0-9_]], [_])])
-# _AM_SET_OPTION(NAME)
-# Set option NAME. Presently that only means defining a flag for this option.
-AC_DEFUN([_AM_SET_OPTION],
-[m4_define(_AM_MANGLE_OPTION([$1]), 1)])
-# _AM_SET_OPTIONS(OPTIONS)
-# OPTIONS is a space-separated list of Automake options.
-AC_DEFUN([_AM_SET_OPTIONS],
-[AC_FOREACH([_AM_Option], [$1], [_AM_SET_OPTION(_AM_Option)])])
-# _AM_IF_OPTION(OPTION, IF-SET, [IF-NOT-SET])
-# Execute IF-SET if OPTION is set, IF-NOT-SET otherwise.
-AC_DEFUN([_AM_IF_OPTION],
-[m4_ifset(_AM_MANGLE_OPTION([$1]), [$2], [$3])])
-# Check to make sure that the build environment is sane.
-# Copyright 1996, 1997, 2000, 2001 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# serial 3
-# AM_SANITY_CHECK
-AC_DEFUN([AM_SANITY_CHECK],
-[AC_MSG_CHECKING([whether build environment is sane])
-# Just in case
-sleep 1
-echo timestamp > conftest.file
-# Do `set' in a subshell so we don't clobber the current shell's
-# arguments. Must try -L first in case configure is actually a
-# symlink; some systems play weird games with the mod time of symlinks
-# (eg FreeBSD returns the mod time of the symlink's containing
-# directory).
-if (
- set X `ls -Lt $srcdir/configure conftest.file 2> /dev/null`
- if test "$[*]" = "X"; then
- # -L didn't work.
- set X `ls -t $srcdir/configure conftest.file`
- fi
- rm -f conftest.file
- if test "$[*]" != "X $srcdir/configure conftest.file" \
- && test "$[*]" != "X conftest.file $srcdir/configure"; then
- # If neither matched, then we have a broken ls. This can happen
- # if, for instance, CONFIG_SHELL is bash and it inherits a
- # broken ls alias from the environment. This has actually
- # happened. Such a system could not be considered "sane".
- AC_MSG_ERROR([ls -t appears to fail. Make sure there is not a broken
-alias in your environment])
- fi
- test "$[2]" = conftest.file
-then
- # Ok.
-else
- AC_MSG_ERROR([newly created file is older than distributed files!
-Check your system clock])
-fi
-AC_MSG_RESULT(yes)])
-# -*- Autoconf -*-
-# Copyright 1997, 1999, 2000, 2001 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# serial 3
-# AM_MISSING_PROG(NAME, PROGRAM)
-AC_DEFUN([AM_MISSING_PROG],
-[AC_REQUIRE([AM_MISSING_HAS_RUN])
-$1=${$1-"${am_missing_run}$2"}
-AC_SUBST($1)])
-# AM_MISSING_HAS_RUN
-# Define MISSING if not defined so far and test if it supports --run.
-# If it does, set am_missing_run to use it, otherwise, to nothing.
-AC_DEFUN([AM_MISSING_HAS_RUN],
-[AC_REQUIRE([AM_AUX_DIR_EXPAND])dnl
-test x"${MISSING+set}" = xset || MISSING="\${SHELL} $am_aux_dir/missing"
-# Use eval to expand $SHELL
-if eval "$MISSING --run true"; then
- am_missing_run="$MISSING --run "
-else
- am_missing_run=
- AC_MSG_WARN([`missing' script is too old or missing])
-fi
-# AM_AUX_DIR_EXPAND
-# Copyright 2001 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# For projects using AC_CONFIG_AUX_DIR([foo]), Autoconf sets
-# $ac_aux_dir to `$srcdir/foo'. In other projects, it is set to
-# `$srcdir', `$srcdir/..', or `$srcdir/../..'.
-# Of course, Automake must honor this variable whenever it calls a
-# tool from the auxiliary directory. The problem is that $srcdir (and
-# therefore $ac_aux_dir as well) can be either absolute or relative,
-# depending on how configure is run. This is pretty annoying, since
-# it makes $ac_aux_dir quite unusable in subdirectories: in the top
-# source directory, any form will work fine, but in subdirectories a
-# relative path needs to be adjusted first.
-# $ac_aux_dir/missing
-# fails when called from a subdirectory if $ac_aux_dir is relative
-# $top_srcdir/$ac_aux_dir/missing
-# fails if $ac_aux_dir is absolute,
-# fails when called from a subdirectory in a VPATH build with
-# a relative $ac_aux_dir
-# The reason of the latter failure is that $top_srcdir and $ac_aux_dir
-# are both prefixed by $srcdir. In an in-source build this is usually
-# harmless because $srcdir is `.', but things will broke when you
-# start a VPATH build or use an absolute $srcdir.
-# So we could use something similar to $top_srcdir/$ac_aux_dir/missing,
-# iff we strip the leading $srcdir from $ac_aux_dir. That would be:
-# am_aux_dir='\$(top_srcdir)/'`expr "$ac_aux_dir" : "$srcdir//*\(.*\)"`
-# and then we would define $MISSING as
-# MISSING="\${SHELL} $am_aux_dir/missing"
-# This will work as long as MISSING is not called from configure, because
-# unfortunately $(top_srcdir) has no meaning in configure.
-# However there are other variables, like CC, which are often used in
-# configure, and could therefore not use this "fixed" $ac_aux_dir.
-# Another solution, used here, is to always expand $ac_aux_dir to an
-# absolute PATH. The drawback is that using absolute paths prevent a
-# configured tree to be moved without reconfiguration.
-# Rely on autoconf to set up CDPATH properly.
-AC_PREREQ([2.50])
-AC_DEFUN([AM_AUX_DIR_EXPAND], [
-# expand $ac_aux_dir to an absolute path
-am_aux_dir=`cd $ac_aux_dir && pwd`
-# AM_PROG_INSTALL_SH
-# Define $install_sh.
-# 02111-1307, USA.
-AC_DEFUN([AM_PROG_INSTALL_SH],
-install_sh=${install_sh-"$am_aux_dir/install-sh"}
-AC_SUBST(install_sh)])
-# AM_PROG_INSTALL_STRIP
-# 02111-1307, USA.
-# One issue with vendor `install' (even GNU) is that you can't
-# specify the program used to strip binaries. This is especially
-# annoying in cross-compiling environments, where the build's strip
-# is unlikely to handle the host's binaries.
-# Fortunately install-sh will honor a STRIPPROG variable, so we
-# always use install-sh in `make install-strip', and initialize
-# STRIPPROG with the value of the STRIP variable (set by the user).
-AC_DEFUN([AM_PROG_INSTALL_STRIP],
-[AC_REQUIRE([AM_PROG_INSTALL_SH])dnl
-# Installed binaries are usually stripped using `strip' when the user
-# run `make install-strip'. However `strip' might not be the right
-# tool to use in cross-compilation environments, therefore Automake
-# will honor the `STRIP' environment variable to overrule this program.
-dnl Don't test for $cross_compiling = yes, because it might be `maybe'.
-if test "$cross_compiling" != no; then
- AC_CHECK_TOOL([STRIP], [strip], :)
-fi
-INSTALL_STRIP_PROGRAM="\${SHELL} \$(install_sh) -c -s"
-AC_SUBST([INSTALL_STRIP_PROGRAM])])
-# serial 4 -*- Autoconf -*-
-# Copyright 1999, 2000, 2001 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# _AM_DEPENDENCIES(NAME)
-# See how the compiler implements dependency checking.
-# NAME is "CC", "CXX", "GCJ", or "OBJC".
-# We try a few techniques and use that to set a single cache variable.
-# We don't AC_REQUIRE the corresponding AC_PROG_CC since the latter was
-# modified to invoke _AM_DEPENDENCIES(CC); we would have a circular
-# dependency, and given that the user is not expected to run this macro,
-# just rely on AC_PROG_CC.
-AC_DEFUN([_AM_DEPENDENCIES],
-[AC_REQUIRE([AM_SET_DEPDIR])dnl
-AC_REQUIRE([AM_OUTPUT_DEPENDENCY_COMMANDS])dnl
-AC_REQUIRE([AM_MAKE_INCLUDE])dnl
-AC_REQUIRE([AM_DEP_TRACK])dnl
-ifelse([$1], CC, [depcc="$CC" am_compiler_list=],
- [$1], CXX, [depcc="$CXX" am_compiler_list=],
- [$1], OBJC, [depcc="$OBJC" am_compiler_list='gcc3 gcc'],
- [$1], GCJ, [depcc="$GCJ" am_compiler_list='gcc3 gcc'],
- [depcc="$$1" am_compiler_list=])
-AC_CACHE_CHECK([dependency style of $depcc],
- [am_cv_$1_dependencies_compiler_type],
-[if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
- # We make a subdir and do the tests there. Otherwise we can end up
- # making bogus files that we don't know about and never remove. For
- # instance it was reported that on HP-UX the gcc test will end up
- # making a dummy file named `D' -- because `-MD' means `put the output
- # in D'.
- mkdir conftest.dir
- # Copy depcomp to subdir because otherwise we won't find it if we're
- # using a relative directory.
- cp "$am_depcomp" conftest.dir
- cd conftest.dir
- am_cv_$1_dependencies_compiler_type=none
- if test "$am_compiler_list" = ""; then
- am_compiler_list=`sed -n ['s/^#*\([a-zA-Z0-9]*\))$/\1/p'] < ./depcomp`
- fi
- for depmode in $am_compiler_list; do
- # We need to recreate these files for each test, as the compiler may
- # overwrite some of them when testing with obscure command lines.
- # This happens at least with the AIX C compiler.
- echo '#include "conftest.h"' > conftest.c
- echo 'int i;' > conftest.h
- echo "${am__include} ${am__quote}conftest.Po${am__quote}" > confmf
- case $depmode in
- nosideeffect)
- # after this tag, mechanisms are not by side-effect, so they'll
- # only be used when explicitly requested
- if test "x$enable_dependency_tracking" = xyes; then
- continue
- else
- break
- fi
- none) break ;;
- esac
- # We check with `-c' and `-o' for the sake of the "dashmstdout"
- # mode. It turns out that the SunPro C++ compiler does not properly
- # handle `-M -o', and we need to detect this.
- if depmode=$depmode \
- source=conftest.c object=conftest.o \
- depfile=conftest.Po tmpdepfile=conftest.TPo \
- $SHELL ./depcomp $depcc -c conftest.c -o conftest.o >/dev/null 2>&1 &&
- grep conftest.h conftest.Po > /dev/null 2>&1 &&
- ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
- am_cv_$1_dependencies_compiler_type=$depmode
- break
- fi
- done
- cd ..
- rm -rf conftest.dir
-else
-fi
-AC_SUBST([$1DEPMODE], [depmode=$am_cv_$1_dependencies_compiler_type])
-# AM_SET_DEPDIR
-# Choose a directory name for dependency files.
-# This macro is AC_REQUIREd in _AM_DEPENDENCIES
-AC_DEFUN([AM_SET_DEPDIR],
-[rm -f .deps 2>/dev/null
-mkdir .deps 2>/dev/null
-if test -d .deps; then
- DEPDIR=.deps
-else
- # MS-DOS does not allow filenames that begin with a dot.
- DEPDIR=_deps
-fi
-rmdir .deps 2>/dev/null
-AC_SUBST([DEPDIR])
-# AM_DEP_TRACK
-AC_DEFUN([AM_DEP_TRACK],
-[AC_ARG_ENABLE(dependency-tracking,
-[ --disable-dependency-tracking Speeds up one-time builds
- --enable-dependency-tracking Do not reject slow dependency extractors])
-if test "x$enable_dependency_tracking" != xno; then
- am_depcomp="$ac_aux_dir/depcomp"
- AMDEPBACKSLASH='\'
-fi
-AM_CONDITIONAL([AMDEP], [test "x$enable_dependency_tracking" != xno])
-AC_SUBST([AMDEPBACKSLASH])
-# Generate code to set up dependency tracking. -*- Autoconf -*-
-# Copyright 1999, 2000, 2001, 2002 Free Software Foundation, Inc.
-# 02111-1307, USA.
-#serial 2
-# _AM_OUTPUT_DEPENDENCY_COMMANDS
-AC_DEFUN([_AM_OUTPUT_DEPENDENCY_COMMANDS],
-[for mf in $CONFIG_FILES; do
- # Strip MF so we end up with the name of the file.
- mf=`echo "$mf" | sed -e 's/:.*$//'`
- # Check whether this is an Automake generated Makefile or not.
- # We used to match only the files named `Makefile.in', but
- # some people rename them; so instead we look at the file content.
- # Grep'ing the first line is not enough: some people post-process
- # each Makefile.in and add a new line on top of each file to say so.
- # So let's grep whole file.
- if grep '^#.*generated by automake' $mf > /dev/null 2>&1; then
- dirpart=`AS_DIRNAME("$mf")`
- else
- continue
- fi
- grep '^DEP_FILES *= *[[^ @%:@]]' < "$mf" > /dev/null || continue
- # Extract the definition of DEP_FILES from the Makefile without
- # running `make'.
- DEPDIR=`sed -n -e '/^DEPDIR = / s///p' < "$mf"`
- test -z "$DEPDIR" && continue
- # When using ansi2knr, U may be empty or an underscore; expand it
- U=`sed -n -e '/^U = / s///p' < "$mf"`
- test -d "$dirpart/$DEPDIR" || mkdir "$dirpart/$DEPDIR"
- # We invoke sed twice because it is the simplest approach to
- # changing $(DEPDIR) to its actual value in the expansion.
- for file in `sed -n -e '
- /^DEP_FILES = .*\\\\$/ {
- s/^DEP_FILES = //
- :loop
- s/\\\\$//
- p
- n
- /\\\\$/ b loop
- p
- /^DEP_FILES = / s/^DEP_FILES = //p' < "$mf" | \
- sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
- # Make sure the directory exists.
- test -f "$dirpart/$file" && continue
- fdir=`AS_DIRNAME(["$file"])`
- AS_MKDIR_P([$dirpart/$fdir])
- # echo "creating $dirpart/$file"
- echo '# dummy' > "$dirpart/$file"
- done
-done
-])# _AM_OUTPUT_DEPENDENCY_COMMANDS
-# AM_OUTPUT_DEPENDENCY_COMMANDS
-# This macro should only be invoked once -- use via AC_REQUIRE.
-# This code is only required when automatic dependency tracking
-# is enabled. FIXME. This creates each `.P' file that we will
-# need in order to bootstrap the dependency handling code.
-AC_DEFUN([AM_OUTPUT_DEPENDENCY_COMMANDS],
-[AC_CONFIG_COMMANDS([depfiles],
- [test x"$AMDEP_TRUE" != x"" || _AM_OUTPUT_DEPENDENCY_COMMANDS],
- [AMDEP_TRUE="$AMDEP_TRUE" ac_aux_dir="$ac_aux_dir"])
-# Copyright 2001 Free Software Foundation, Inc. -*- Autoconf -*-
-# 02111-1307, USA.
-# serial 2
-# AM_MAKE_INCLUDE()
-# Check to see how make treats includes.
-AC_DEFUN([AM_MAKE_INCLUDE],
-[am_make=${MAKE-make}
-cat > confinc << 'END'
-doit:
- @echo done
-END
-# If we don't find an include directive, just comment out the code.
-AC_MSG_CHECKING([for style of include used by $am_make])
-am__include="#"
-am__quote=
-_am_result=none
-# First try GNU make style include.
-echo "include confinc" > confmf
-# We grep out `Entering directory' and `Leaving directory'
-# messages which can occur if `w' ends up in MAKEFLAGS.
-# In particular we don't look at `^make:' because GNU make might
-# be invoked under some other name (usually "gmake"), in which
-# case it prints its new name instead of `make'.
-if test "`$am_make -s -f confmf 2> /dev/null | fgrep -v 'ing directory'`" = "done"; then
- am__include=include
- am__quote=
- _am_result=GNU
-fi
-# Now try BSD make style include.
-if test "$am__include" = "#"; then
- echo '.include "confinc"' > confmf
- if test "`$am_make -s -f confmf 2> /dev/null`" = "done"; then
- am__include=.include
- am__quote="\""
- _am_result=BSD
- fi
-fi
-AC_SUBST(am__include)
-AC_SUBST(am__quote)
-AC_MSG_RESULT($_am_result)
-rm -f confinc confmf
-# AM_CONDITIONAL -*- Autoconf -*-
-# Copyright 1997, 2000, 2001 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# serial 5
-AC_PREREQ(2.52)
-# AM_CONDITIONAL(NAME, SHELL-CONDITION)
-# Define a conditional.
-AC_DEFUN([AM_CONDITIONAL],
-[ifelse([$1], [TRUE], [AC_FATAL([$0: invalid condition: $1])],
- [$1], [FALSE], [AC_FATAL([$0: invalid condition: $1])])dnl
-AC_SUBST([$1_TRUE])
-AC_SUBST([$1_FALSE])
-if $2; then
- $1_TRUE=
- $1_FALSE='#'
-else
- $1_TRUE='#'
- $1_FALSE=
-fi
-AC_CONFIG_COMMANDS_PRE(
-[if test -z "${$1_TRUE}" && test -z "${$1_FALSE}"; then
- AC_MSG_ERROR([conditional \"$1\" was never defined.
-Usually this means the macro was only invoked conditionally.])
-fi])])
-# libtool.m4 - Configure libtool for the host system. -*-Shell-script-*-
-# serial 46 AC_PROG_LIBTOOL
-AC_DEFUN([AC_PROG_LIBTOOL],
-[AC_REQUIRE([AC_LIBTOOL_SETUP])dnl
-# This can be used to rebuild libtool when needed
-LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
-# Always use our own libtool.
-LIBTOOL='$(SHELL) $(top_builddir)/libtool'
-AC_SUBST(LIBTOOL)dnl
-# Prevent multiple expansion
-define([AC_PROG_LIBTOOL], [])
-AC_DEFUN([AC_LIBTOOL_SETUP],
-[AC_PREREQ(2.13)dnl
-AC_REQUIRE([AC_ENABLE_SHARED])dnl
-AC_REQUIRE([AC_ENABLE_STATIC])dnl
-AC_REQUIRE([AC_ENABLE_FAST_INSTALL])dnl
-AC_REQUIRE([AC_CANONICAL_HOST])dnl
-AC_REQUIRE([AC_CANONICAL_BUILD])dnl
-AC_REQUIRE([AC_PROG_CC])dnl
-AC_REQUIRE([AC_PROG_LD])dnl
-AC_REQUIRE([AC_PROG_LD_RELOAD_FLAG])dnl
-AC_REQUIRE([AC_PROG_NM])dnl
-AC_REQUIRE([LT_AC_PROG_SED])dnl
-AC_REQUIRE([AC_PROG_LN_S])dnl
-AC_REQUIRE([AC_DEPLIBS_CHECK_METHOD])dnl
-AC_REQUIRE([AC_OBJEXT])dnl
-AC_REQUIRE([AC_EXEEXT])dnl
-dnl
-_LT_AC_PROG_ECHO_BACKSLASH
-# Only perform the check for file, if the check method requires it
-case $deplibs_check_method in
-file_magic*)
- if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- AC_PATH_MAGIC
- fi
-esac
-AC_CHECK_TOOL(RANLIB, ranlib, :)
-AC_CHECK_TOOL(STRIP, strip, :)
-ifdef([AC_PROVIDE_AC_LIBTOOL_DLOPEN], enable_dlopen=yes, enable_dlopen=no)
-ifdef([AC_PROVIDE_AC_LIBTOOL_WIN32_DLL],
-enable_win32_dll=yes, enable_win32_dll=no)
-AC_ARG_ENABLE(libtool-lock,
- [ --disable-libtool-lock avoid locking (might break parallel builds)])
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-*-*-irix6*)
- # Find out which ABI we are using.
- echo '[#]line __oline__ "configure"' > conftest.$ac_ext
- if AC_TRY_EVAL(ac_compile); then
- case `/usr/bin/file conftest.$ac_objext` in
- *32-bit*)
- LD="${LD-ld} -32"
- *N32*)
- LD="${LD-ld} -n32"
- *64-bit*)
- LD="${LD-ld} -64"
- esac
- fi
- rm -rf conftest*
-*-*-sco3.2v5*)
- # On SCO OpenServer 5, we need -belf to get full-featured binaries.
- SAVE_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -belf"
- AC_CACHE_CHECK([whether the C compiler needs -belf], lt_cv_cc_needs_belf,
- [AC_LANG_SAVE
- AC_LANG_C
- AC_TRY_LINK([],[],[lt_cv_cc_needs_belf=yes],[lt_cv_cc_needs_belf=no])
- AC_LANG_RESTORE])
- if test x"$lt_cv_cc_needs_belf" != x"yes"; then
- # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
- CFLAGS="$SAVE_CFLAGS"
- fi
-[*-*-cygwin* | *-*-mingw* | *-*-pw32*)
- AC_CHECK_TOOL(DLLTOOL, dlltool, false)
- AC_CHECK_TOOL(AS, as, false)
- AC_CHECK_TOOL(OBJDUMP, objdump, false)
- # recent cygwin and mingw systems supply a stub DllMain which the user
- # can override, but on older systems we have to supply one
- AC_CACHE_CHECK([if libtool should supply DllMain function], lt_cv_need_dllmain,
- [AC_TRY_LINK([],
- [extern int __attribute__((__stdcall__)) DllMain(void*, int, void*);
- DllMain (0, 0, 0);],
- [lt_cv_need_dllmain=no],[lt_cv_need_dllmain=yes])])
- case $host/$CC in
- *-*-cygwin*/gcc*-mno-cygwin*|*-*-mingw*)
- # old mingw systems require "-dll" to link a DLL, while more recent ones
- # require "-mdll"
- CFLAGS="$CFLAGS -mdll"
- AC_CACHE_CHECK([how to link DLLs], lt_cv_cc_dll_switch,
- [AC_TRY_LINK([], [], [lt_cv_cc_dll_switch=-mdll],[lt_cv_cc_dll_switch=-dll])])
- CFLAGS="$SAVE_CFLAGS" ;;
- *-*-cygwin* | *-*-pw32*)
- # cygwin systems need to pass --dll to the linker, and not link
- # crt.o which will require a WinMain at 16 definition.
- lt_cv_cc_dll_switch="-Wl,--dll -nostartfiles" ;;
- esac
-esac
-_LT_AC_LTCONFIG_HACK
-# AC_LIBTOOL_HEADER_ASSERT
-AC_DEFUN([AC_LIBTOOL_HEADER_ASSERT],
-[AC_CACHE_CHECK([whether $CC supports assert without backlinking],
- [lt_cv_func_assert_works],
- [case $host in
- *-*-solaris*)
- if test "$GCC" = yes && test "$with_gnu_ld" != yes; then
- case `$CC --version 2>/dev/null` in
- [[12]].*) lt_cv_func_assert_works=no ;;
- *) lt_cv_func_assert_works=yes ;;
- esac
- fi
- esac])
-if test "x$lt_cv_func_assert_works" = xyes; then
- AC_CHECK_HEADERS(assert.h)
-fi
-])# AC_LIBTOOL_HEADER_ASSERT
-# _LT_AC_CHECK_DLFCN
-AC_DEFUN([_LT_AC_CHECK_DLFCN],
-[AC_CHECK_HEADERS(dlfcn.h)
-])# _LT_AC_CHECK_DLFCN
-# AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE
-AC_DEFUN([AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE],
-[AC_REQUIRE([AC_CANONICAL_HOST])
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-AC_MSG_CHECKING([command to parse $NM output])
-AC_CACHE_VAL([lt_cv_sys_global_symbol_pipe], [dnl
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix. What could be older than Ultrix?!! ;)]
-# Character class describing NM global symbol codes.
-symcode='[[BCDEGRST]]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([[_A-Za-z]][[_A-Za-z0-9]]*\)'
-# Transform the above into a raw symbol and a C symbol.
-symxfrm='\1 \2\3 \3'
-# Transform an extracted symbol line into a proper C declaration
-lt_cv_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern char \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_global_symbol_to_c_name_address="sed -n -e 's/^: \([[^ ]]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([[^ ]]*\) \([[^ ]]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-# Define system-specific variables.
-case $host_os in
-aix*)
- symcode='[[BCDT]]'
-cygwin* | mingw* | pw32*)
- symcode='[[ABCDGISTW]]'
-hpux*) # Its linker distinguishes data from code symbols
- lt_cv_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern char \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
- lt_cv_global_symbol_to_c_name_address="sed -n -e 's/^: \([[^ ]]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([[^ ]]*\) \([[^ ]]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-irix* | nonstopux*)
- symcode='[[BCDEGRST]]'
-osf*)
- symcode='[[BCDEGQRST]]'
-solaris* | sysv5*)
- symcode='[[BDT]]'
-sysv4)
- symcode='[[DFNSTU]]'
-esac
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $host_os in
-mingw*)
- opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-if $NM -V 2>&1 | egrep '(GNU|with BFD)' > /dev/null; then
-fi
-# Try without a prefix undercore, then with it.
-for ac_symprfx in "" "_"; do
- # Write the raw and C identifiers.
-lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[[ ]]\($symcode$symcode*\)[[ ]][[ ]]*\($ac_symprfx\)$sympat$opt_cr$/$symxfrm/p'"
- # Check to see that the pipe works correctly.
- pipe_works=no
- rm -f conftest*
- cat > conftest.$ac_ext <<EOF
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(){}
-#ifdef __cplusplus
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-EOF
- # Now try to grab the symbols.
- nlist=conftest.nm
- if AC_TRY_EVAL(NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) && test -s "$nlist"; then
- # Try sorting and uniquifying the output.
- if sort "$nlist" | uniq > "$nlist"T; then
- mv -f "$nlist"T "$nlist"
- else
- rm -f "$nlist"T
- fi
- # Make sure that we snagged all the symbols we need.
- if egrep ' nm_test_var$' "$nlist" >/dev/null; then
- if egrep ' nm_test_func$' "$nlist" >/dev/null; then
- cat <<EOF > conftest.$ac_ext
-#ifdef __cplusplus
-extern "C" {
-#endif
-EOF
- # Now generate the symbol file.
- eval "$lt_cv_global_symbol_to_cdecl"' < "$nlist" >> conftest.$ac_ext'
- cat <<EOF >> conftest.$ac_ext
-#if defined (__STDC__) && __STDC__
-# define lt_ptr void *
-#else
-# define lt_ptr char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr address;
-lt_preloaded_symbols[[]] =
-EOF
- sed "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (lt_ptr) \&\2},/" < "$nlist" >> conftest.$ac_ext
- cat <<\EOF >> conftest.$ac_ext
- {0, (lt_ptr) 0}
-#ifdef __cplusplus
-#endif
-EOF
- # Now try linking the two files.
- mv conftest.$ac_objext conftstm.$ac_objext
- save_LIBS="$LIBS"
- save_CFLAGS="$CFLAGS"
- LIBS="conftstm.$ac_objext"
- CFLAGS="$CFLAGS$no_builtin_flag"
- if AC_TRY_EVAL(ac_link) && test -s conftest$ac_exeext; then
- pipe_works=yes
- fi
- LIBS="$save_LIBS"
- CFLAGS="$save_CFLAGS"
- else
- echo "cannot find nm_test_func in $nlist" >&AC_FD_CC
- fi
- else
- echo "cannot find nm_test_var in $nlist" >&AC_FD_CC
- fi
- else
- echo "cannot run $lt_cv_sys_global_symbol_pipe" >&AC_FD_CC
- fi
- else
- echo "$progname: failed program was:" >&AC_FD_CC
- cat conftest.$ac_ext >&5
- fi
- rm -f conftest* conftst*
- # Do not use the global_symbol_pipe unless it works.
- if test "$pipe_works" = yes; then
- break
- else
- lt_cv_sys_global_symbol_pipe=
- fi
-done
-global_symbol_pipe="$lt_cv_sys_global_symbol_pipe"
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
- global_symbol_to_cdecl=
- global_symbol_to_c_name_address=
-else
- global_symbol_to_cdecl="$lt_cv_global_symbol_to_cdecl"
- global_symbol_to_c_name_address="$lt_cv_global_symbol_to_c_name_address"
-fi
-if test -z "$global_symbol_pipe$global_symbol_to_cdec$global_symbol_to_c_name_address";
-then
- AC_MSG_RESULT(failed)
-else
- AC_MSG_RESULT(ok)
-fi
-]) # AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE
-# _LT_AC_LIBTOOL_SYS_PATH_SEPARATOR
-AC_DEFUN([_LT_AC_LIBTOOL_SYS_PATH_SEPARATOR],
-[# Find the correct PATH separator. Usually this is `:', but
-# DJGPP uses `;' like DOS.
-if test "X${PATH_SEPARATOR+set}" != Xset; then
- UNAME=${UNAME-`uname 2>/dev/null`}
- case X$UNAME in
- *-DOS) lt_cv_sys_path_separator=';' ;;
- *) lt_cv_sys_path_separator=':' ;;
- esac
- PATH_SEPARATOR=$lt_cv_sys_path_separator
-fi
-])# _LT_AC_LIBTOOL_SYS_PATH_SEPARATOR
-# _LT_AC_PROG_ECHO_BACKSLASH
-# Add some code to the start of the generated configure script which
-# will find an echo command which doesn't interpret backslashes.
-AC_DEFUN([_LT_AC_PROG_ECHO_BACKSLASH],
-[ifdef([AC_DIVERSION_NOTICE], [AC_DIVERT_PUSH(AC_DIVERSION_NOTICE)],
- [AC_DIVERT_PUSH(NOTICE)])
-_LT_AC_LIBTOOL_SYS_PATH_SEPARATOR
-# Check that we are running under the correct shell.
-SHELL=${CONFIG_SHELL-/bin/sh}
-case X$ECHO in
-X*--fallback-echo)
- # Remove one level of quotation (which was required for Make).
- ECHO=`echo "$ECHO" | sed 's,\\\\\[$]\\[$]0,'[$]0','`
-esac
-echo=${ECHO-echo}
-if test "X[$]1" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
-elif test "X[$]1" = X--fallback-echo; then
- # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t'; then
- # Yippee, $echo works!
-else
- # Restart under the correct shell.
- exec $SHELL "[$]0" --no-reexec ${1+"[$]@"}
-fi
-if test "X[$]1" = X--fallback-echo; then
- # used as fallback echo
- shift
- cat <<EOF
-EOF
- exit 0
-fi
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test "X${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
-if test -z "$ECHO"; then
-if test "X${echo_test_string+set}" != Xset; then
-# find a string as large as possible, as long as the shell can cope with it
- for cmd in 'sed 50q "[$]0"' 'sed 20q "[$]0"' 'sed 10q "[$]0"' 'sed 2q "[$]0"' 'echo test'; do
- # expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
- if (echo_test_string="`eval $cmd`") 2>/dev/null &&
- echo_test_string="`eval $cmd`" &&
- (test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
- then
- break
- fi
- done
-fi
-if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($echo "$echo_test_string") 2>/dev/null` &&
- test "X$echo_testing_string" = "X$echo_test_string"; then
-else
- # The Solaris, AIX, and Digital Unix default echo programs unquote
- # backslashes. This makes it impossible to quote backslashes using
- # echo "$something" | sed 's/\\/\\\\/g'
- # So, first we look for a working echo in the user's PATH.
- IFS="${IFS= }"; save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for dir in $PATH /usr/ucb; do
- if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
- test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
- echo="$dir/echo"
- break
- fi
- done
- IFS="$save_ifs"
- if test "X$echo" = Xecho; then
- # We didn't find a better echo, so look for alternatives.
- if test "X`(print -r '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`(print -r "$echo_test_string") 2>/dev/null` &&
- # This shell has a builtin print -r that does the trick.
- echo='print -r'
- elif (test -f /bin/ksh || test -f /bin/ksh$ac_exeext) &&
- test "X$CONFIG_SHELL" != X/bin/ksh; then
- # If we have ksh, try running configure again with it.
- ORIGINAL_CONFIG_SHELL=${CONFIG_SHELL-/bin/sh}
- export ORIGINAL_CONFIG_SHELL
- CONFIG_SHELL=/bin/ksh
- export CONFIG_SHELL
- exec $CONFIG_SHELL "[$]0" --no-reexec ${1+"[$]@"}
- else
- # Try using printf.
- echo='printf %s\n'
- if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- # Cool, printf works
- elif echo_testing_string=`($ORIGINAL_CONFIG_SHELL "[$]0" --fallback-echo '\t') 2>/dev/null` &&
- test "X$echo_testing_string" = 'X\t' &&
- echo_testing_string=`($ORIGINAL_CONFIG_SHELL "[$]0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- CONFIG_SHELL=$ORIGINAL_CONFIG_SHELL
- SHELL="$CONFIG_SHELL"
- export SHELL
- echo="$CONFIG_SHELL [$]0 --fallback-echo"
- elif echo_testing_string=`($CONFIG_SHELL "[$]0" --fallback-echo '\t') 2>/dev/null` &&
- echo_testing_string=`($CONFIG_SHELL "[$]0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- else
- # maybe with a smaller string...
- prev=:
- for cmd in 'echo test' 'sed 2q "[$]0"' 'sed 10q "[$]0"' 'sed 20q "[$]0"' 'sed 50q "[$]0"'; do
- if (test "X$echo_test_string" = "X`eval $cmd`") 2>/dev/null
- then
- break
- fi
- prev="$cmd"
- done
- if test "$prev" != 'sed 50q "[$]0"'; then
- echo_test_string=`eval $prev`
- export echo_test_string
- exec ${ORIGINAL_CONFIG_SHELL-${CONFIG_SHELL-/bin/sh}} "[$]0" ${1+"[$]@"}
- else
- # Oops. We lost completely, so just stick with echo.
- echo=echo
- fi
- fi
- fi
- fi
-fi
-fi
-# Copy echo and quote the copy suitably for passing to libtool from
-# the Makefile, instead of quoting the original, which is used later.
-ECHO=$echo
-if test "X$ECHO" = "X$CONFIG_SHELL [$]0 --fallback-echo"; then
- ECHO="$CONFIG_SHELL \\\$\[$]0 --fallback-echo"
-fi
-AC_SUBST(ECHO)
-AC_DIVERT_POP
-])# _LT_AC_PROG_ECHO_BACKSLASH
-# _LT_AC_TRY_DLOPEN_SELF (ACTION-IF-TRUE, ACTION-IF-TRUE-W-USCORE,
-# ACTION-IF-FALSE, ACTION-IF-CROSS-COMPILING)
-AC_DEFUN([_LT_AC_TRY_DLOPEN_SELF],
-[if test "$cross_compiling" = yes; then :
- [$4]
-else
- AC_REQUIRE([_LT_AC_CHECK_DLFCN])dnl
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
- lt_status=$lt_dlunknown
-[#line __oline__ "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-# define LT_DLGLOBAL RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# define LT_DLGLOBAL DL_GLOBAL
-# else
-# define LT_DLGLOBAL 0
-# endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
- find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-# ifdef RTLD_LAZY
-# define LT_DLLAZY_OR_NOW RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# define LT_DLLAZY_OR_NOW DL_LAZY
-# else
-# ifdef RTLD_NOW
-# define LT_DLLAZY_OR_NOW RTLD_NOW
-# else
-# ifdef DL_NOW
-# define LT_DLLAZY_OR_NOW DL_NOW
-# else
-# define LT_DLLAZY_OR_NOW 0
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-extern "C" void exit (int);
-#endif
-void fnord() { int i=42;}
-int main ()
- void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
- int status = $lt_dlunknown;
- if (self)
- if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
- else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
- /* dlclose (self); */
- exit (status);
-EOF
- if AC_TRY_EVAL(ac_link) && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) 2>/dev/null
- lt_status=$?
- case x$lt_status in
- x$lt_dlno_uscore) $1 ;;
- x$lt_dlneed_uscore) $2 ;;
- x$lt_unknown|x*) $3 ;;
- esac
- else :
- # compilation failed
- $3
- fi
-fi
-rm -fr conftest*
-])# _LT_AC_TRY_DLOPEN_SELF
-# AC_LIBTOOL_DLOPEN_SELF
-AC_DEFUN([AC_LIBTOOL_DLOPEN_SELF],
-[if test "x$enable_dlopen" != xyes; then
- enable_dlopen=unknown
- enable_dlopen_self=unknown
- enable_dlopen_self_static=unknown
-else
- lt_cv_dlopen=no
- lt_cv_dlopen_libs=
- case $host_os in
- beos*)
- lt_cv_dlopen="load_add_on"
- lt_cv_dlopen_self=yes
- cygwin* | mingw* | pw32*)
- lt_cv_dlopen="LoadLibrary"
- AC_CHECK_FUNC([shl_load],
- [lt_cv_dlopen="shl_load"],
- [AC_CHECK_LIB([dld], [shl_load],
- [lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"],
- [AC_CHECK_FUNC([dlopen],
- [lt_cv_dlopen="dlopen"],
- [AC_CHECK_LIB([dl], [dlopen],
- [lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"],
- [AC_CHECK_LIB([svld], [dlopen],
- [lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"],
- [AC_CHECK_LIB([dld], [dld_link],
- [lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"])
- esac
- if test "x$lt_cv_dlopen" != xno; then
- enable_dlopen=yes
- else
- enable_dlopen=no
- fi
- case $lt_cv_dlopen in
- dlopen)
- save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
- save_LDFLAGS="$LDFLAGS"
- eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
- save_LIBS="$LIBS"
- LIBS="$lt_cv_dlopen_libs $LIBS"
- AC_CACHE_CHECK([whether a program can dlopen itself],
- lt_cv_dlopen_self, [dnl
- _LT_AC_TRY_DLOPEN_SELF(
- lt_cv_dlopen_self=yes, lt_cv_dlopen_self=yes,
- lt_cv_dlopen_self=no, lt_cv_dlopen_self=cross)
- if test "x$lt_cv_dlopen_self" = xyes; then
- LDFLAGS="$LDFLAGS $link_static_flag"
- AC_CACHE_CHECK([whether a statically linked program can dlopen itself],
- lt_cv_dlopen_self_static, [dnl
- lt_cv_dlopen_self_static=yes, lt_cv_dlopen_self_static=yes,
- lt_cv_dlopen_self_static=no, lt_cv_dlopen_self_static=cross)
- fi
- CPPFLAGS="$save_CPPFLAGS"
- LDFLAGS="$save_LDFLAGS"
- LIBS="$save_LIBS"
- esac
- case $lt_cv_dlopen_self in
- yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
- *) enable_dlopen_self=unknown ;;
- esac
- case $lt_cv_dlopen_self_static in
- yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
- *) enable_dlopen_self_static=unknown ;;
- esac
-fi
-])# AC_LIBTOOL_DLOPEN_SELF
-AC_DEFUN([_LT_AC_LTCONFIG_HACK],
-[AC_REQUIRE([AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE])dnl
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e s/^X//'
-sed_quote_subst='s/\([[\\"\\`$\\\\]]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\([[\\"\\`\\\\]]\)/\\\1/g'
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Constants:
-rm="rm -f"
-# Global variables:
-default_ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except M$VC,
-# which needs '.lib').
-libext=a
-ltmain="$ac_aux_dir/ltmain.sh"
-ofile="$default_ofile"
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-need_locks="$enable_libtool_lock"
-old_CC="$CC"
-old_CFLAGS="$CFLAGS"
-# Set sane defaults for various variables
-test -z "$AR" && AR=ar
-test -z "$AR_FLAGS" && AR_FLAGS=cru
-test -z "$AS" && AS=as
-test -z "$CC" && CC=cc
-test -z "$DLLTOOL" && DLLTOOL=dlltool
-test -z "$LD" && LD=ld
-test -z "$LN_S" && LN_S="ln -s"
-test -z "$MAGIC_CMD" && MAGIC_CMD=file
-test -z "$NM" && NM=nm
-test -z "$OBJDUMP" && OBJDUMP=objdump
-test -z "$RANLIB" && RANLIB=:
-test -z "$STRIP" && STRIP=:
-test -z "$ac_objext" && ac_objext=o
-if test x"$host" != x"$build"; then
- ac_tool_prefix=${host_alias}-
-else
- ac_tool_prefix=
-fi
-# Transform linux* to *-*-linux-gnu*, to support old configure scripts.
-case $host_os in
-linux-gnu*) ;;
-linux*) host=`echo $host | sed 's/^\(.*-.*-linux\)\(.*\)$/\1-gnu\2/'`
-esac
-case $host_os in
-aix3*)
- # AIX sometimes has problems with the GCC collect2 program. For some
- # reason, if we set the COLLECT_NAMES environment variable, the problems
- # vanish in a puff of smoke.
- if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
- fi
-esac
-# Determine commands to create old-style static archives.
-old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
-old_postinstall_cmds='chmod 644 $oldlib'
-old_postuninstall_cmds=
-if test -n "$RANLIB"; then
- case $host_os in
- openbsd*)
- old_postinstall_cmds="\$RANLIB -t \$oldlib~$old_postinstall_cmds"
- old_postinstall_cmds="\$RANLIB \$oldlib~$old_postinstall_cmds"
- esac
- old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
-fi
-# Allow CC to be a program name with arguments.
-set dummy $CC
-compiler="[$]2"
-AC_MSG_CHECKING([for objdir])
-rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
- objdir=.libs
-else
- objdir=_libs
-fi
-rmdir .libs 2>/dev/null
-AC_MSG_RESULT($objdir)
-AC_ARG_WITH(pic,
-[ --with-pic try to use only PIC/non-PIC objects [default=use both]],
-pic_mode="$withval", pic_mode=default)
-test -z "$pic_mode" && pic_mode=default
-# We assume here that the value for lt_cv_prog_cc_pic will not be cached
-# in isolation, and that seeing it set (from the cache) indicates that
-# the associated values are set (in the cache) correctly too.
-AC_MSG_CHECKING([for $compiler option to produce PIC])
-AC_CACHE_VAL(lt_cv_prog_cc_pic,
-[ lt_cv_prog_cc_pic=
- lt_cv_prog_cc_shlib=
- lt_cv_prog_cc_wl=
- lt_cv_prog_cc_static=
- lt_cv_prog_cc_no_builtin=
- lt_cv_prog_cc_can_build_shared=$can_build_shared
- if test "$GCC" = yes; then
- lt_cv_prog_cc_wl='-Wl,'
- lt_cv_prog_cc_static='-static'
- case $host_os in
- aix*)
- # Below there is a dirty hack to force normal static linking with -ldl
- # The problem is because libdl dynamically linked with both libc and
- # libC (AIX C++ library), which obviously doesn't included in libraries
- # list by gcc. This cause undefined symbols with -static flags.
- # This hack allows C programs to be linked with "-static -ldl", but
- # not sure about C++ programs.
- lt_cv_prog_cc_static="$lt_cv_prog_cc_static ${lt_cv_prog_cc_wl}-lC"
- amigaos*)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- lt_cv_prog_cc_pic='-m68020 -resident32 -malways-restore-a4'
- beos* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- darwin* | rhapsody*)
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- lt_cv_prog_cc_pic='-fno-common'
- cygwin* | mingw* | pw32* | os2*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- lt_cv_prog_cc_pic='-DDLL_EXPORT'
- sysv4*MP*)
- if test -d /usr/nec; then
- lt_cv_prog_cc_pic=-Kconform_pic
- fi
- lt_cv_prog_cc_pic='-fPIC'
- esac
- else
- # PORTME Check for PIC flags for the system compiler.
- case $host_os in
- aix3* | aix4* | aix5*)
- # All AIX code is PIC.
- if test "$host_cpu" = ia64; then
- # AIX 5 now supports IA64 processor
- lt_cv_prog_cc_static='-Bstatic'
- else
- lt_cv_prog_cc_static='-bnso -bI:/lib/syscalls.exp'
- fi
- hpux9* | hpux10* | hpux11*)
- # Is there a better lt_cv_prog_cc_static that works with the bundled CC?
- lt_cv_prog_cc_static="${lt_cv_prog_cc_wl}-a ${lt_cv_prog_cc_wl}archive"
- lt_cv_prog_cc_pic='+Z'
- irix5* | irix6* | nonstopux*)
- lt_cv_prog_cc_static='-non_shared'
- # PIC (with -KPIC) is the default.
- newsos6)
- lt_cv_prog_cc_pic='-KPIC'
- osf3* | osf4* | osf5*)
- # All OSF/1 code is PIC.
- sco3.2v5*)
- lt_cv_prog_cc_pic='-Kpic'
- lt_cv_prog_cc_static='-dn'
- lt_cv_prog_cc_shlib='-belf'
- solaris*)
- sunos4*)
- lt_cv_prog_cc_pic='-PIC'
- lt_cv_prog_cc_wl='-Qoption ld '
- sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- uts4*)
- lt_cv_prog_cc_pic='-pic'
- sysv4*MP*)
- if test -d /usr/nec ;then
- lt_cv_prog_cc_pic='-Kconform_pic'
- fi
- lt_cv_prog_cc_can_build_shared=no
- esac
- fi
-if test -z "$lt_cv_prog_cc_pic"; then
- AC_MSG_RESULT([none])
-else
- AC_MSG_RESULT([$lt_cv_prog_cc_pic])
- # Check to make sure the pic_flag actually works.
- AC_MSG_CHECKING([if $compiler PIC flag $lt_cv_prog_cc_pic works])
- AC_CACHE_VAL(lt_cv_prog_cc_pic_works, [dnl
- CFLAGS="$CFLAGS $lt_cv_prog_cc_pic -DPIC"
- AC_TRY_COMPILE([], [], [dnl
- case $host_os in
- # On HP-UX, both CC and GCC only warn that PIC is supported... then
- # they create non-PIC objects. So, if there were any warnings, we
- # assume that PIC is not supported.
- if test -s conftest.err; then
- lt_cv_prog_cc_pic_works=no
- else
- lt_cv_prog_cc_pic_works=yes
- fi
- esac
- ], [dnl
- if test "X$lt_cv_prog_cc_pic_works" = Xno; then
- else
- lt_cv_prog_cc_pic=" $lt_cv_prog_cc_pic"
- fi
- AC_MSG_RESULT([$lt_cv_prog_cc_pic_works])
-fi
-# Check for any special shared library compilation flags.
-if test -n "$lt_cv_prog_cc_shlib"; then
- AC_MSG_WARN([\`$CC' requires \`$lt_cv_prog_cc_shlib' to build shared libraries])
- if echo "$old_CC $old_CFLAGS " | egrep -e "[[ ]]$lt_cv_prog_cc_shlib[[ ]]" >/dev/null; then :
- else
- AC_MSG_WARN([add \`$lt_cv_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure])
- fi
-fi
-AC_MSG_CHECKING([if $compiler static flag $lt_cv_prog_cc_static works])
-AC_CACHE_VAL([lt_cv_prog_cc_static_works], [dnl
- lt_cv_prog_cc_static_works=no
- LDFLAGS="$LDFLAGS $lt_cv_prog_cc_static"
- AC_TRY_LINK([], [], [lt_cv_prog_cc_static_works=yes])
-# Belt *and* braces to stop my trousers falling down:
-test "X$lt_cv_prog_cc_static_works" = Xno && lt_cv_prog_cc_static=
-AC_MSG_RESULT([$lt_cv_prog_cc_static_works])
-pic_flag="$lt_cv_prog_cc_pic"
-special_shlib_compile_flags="$lt_cv_prog_cc_shlib"
-wl="$lt_cv_prog_cc_wl"
-link_static_flag="$lt_cv_prog_cc_static"
-no_builtin_flag="$lt_cv_prog_cc_no_builtin"
-can_build_shared="$lt_cv_prog_cc_can_build_shared"
-# Check to see if options -o and -c are simultaneously supported by compiler
-AC_MSG_CHECKING([if $compiler supports -c -o file.$ac_objext])
-AC_CACHE_VAL([lt_cv_compiler_c_o], [
-$rm -r conftest 2>/dev/null
-mkdir conftest
-cd conftest
-echo "int some_variable = 0;" > conftest.$ac_ext
-mkdir out
-# According to Tom Tromey, Ian Lance Taylor reported there are C compilers
-# that will create temporary files in the current directory regardless of
-# the output directory. Thus, making CWD read-only will cause this test
-# to fail, enabling locking or at least warning the user not to do parallel
-# builds.
-chmod -w .
-save_CFLAGS="$CFLAGS"
-CFLAGS="$CFLAGS -o out/conftest2.$ac_objext"
-compiler_c_o=no
-if { (eval echo configure:__oline__: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>out/conftest.err; } && test -s out/conftest2.$ac_objext; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings
- if test -s out/conftest.err; then
- lt_cv_compiler_c_o=no
- else
- lt_cv_compiler_c_o=yes
- fi
-else
- # Append any errors to the config.log.
- cat out/conftest.err 1>&AC_FD_CC
-fi
-CFLAGS="$save_CFLAGS"
-chmod u+w .
-$rm conftest* out/*
-rmdir out
-cd ..
-rmdir conftest
-compiler_c_o=$lt_cv_compiler_c_o
-AC_MSG_RESULT([$compiler_c_o])
-if test x"$compiler_c_o" = x"yes"; then
- # Check to see if we can write to a .lo
- AC_MSG_CHECKING([if $compiler supports -c -o file.lo])
- AC_CACHE_VAL([lt_cv_compiler_o_lo], [
- lt_cv_compiler_o_lo=no
- CFLAGS="$CFLAGS -c -o conftest.lo"
- save_objext="$ac_objext"
- ac_objext=lo
- AC_TRY_COMPILE([], [int some_variable = 0;], [dnl
- else
- lt_cv_compiler_o_lo=yes
- fi
- ac_objext="$save_objext"
- compiler_o_lo=$lt_cv_compiler_o_lo
- AC_MSG_RESULT([$compiler_o_lo])
-else
- compiler_o_lo=no
-fi
-# Check to see if we can do hard links to lock some files if needed
-hard_links="nottested"
-if test "$compiler_c_o" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- AC_MSG_CHECKING([if we can lock with hard links])
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- AC_MSG_RESULT([$hard_links])
- if test "$hard_links" = no; then
- AC_MSG_WARN([\`$CC' does not support \`-c -o', so \`make -j' may be unsafe])
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-if test "$GCC" = yes; then
- # Check to see if options -fno-rtti -fno-exceptions are supported by compiler
- AC_MSG_CHECKING([if $compiler supports -fno-rtti -fno-exceptions])
- echo "int some_variable = 0;" > conftest.$ac_ext
- CFLAGS="$CFLAGS -fno-rtti -fno-exceptions -c conftest.$ac_ext"
- compiler_rtti_exceptions=no
- else
- compiler_rtti_exceptions=yes
- fi
- AC_MSG_RESULT([$compiler_rtti_exceptions])
- if test "$compiler_rtti_exceptions" = "yes"; then
- no_builtin_flag=' -fno-builtin -fno-rtti -fno-exceptions'
- else
- no_builtin_flag=' -fno-builtin'
- fi
-fi
-# See if the linker supports building shared libraries.
-AC_MSG_CHECKING([whether the linker ($LD) supports shared libraries])
-allow_undefined_flag=
-no_undefined_flag=
-need_lib_prefix=unknown
-need_version=unknown
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-archive_cmds=
-archive_expsym_cmds=
-old_archive_from_new_cmds=
-old_archive_from_expsyms_cmds=
-export_dynamic_flag_spec=
-whole_archive_flag_spec=
-thread_safe_flag_spec=
-hardcode_into_libs=no
-hardcode_libdir_flag_spec=
-hardcode_libdir_separator=
-hardcode_direct=no
-hardcode_minus_L=no
-hardcode_shlibpath_var=unsupported
-runpath_var=
-link_all_deplibs=unknown
-always_export_symbols=no
-export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | sed '\''s/.* //'\'' | sort | uniq > $export_symbols'
-# include_expsyms should be a list of space-separated symbols to be *always*
-# included in the symbol list
-include_expsyms=
-# exclude_expsyms can be an egrep regular expression of symbols to exclude
-# it will be wrapped by ` (' and `)$', so one must not match beginning or
-# end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
-# as well as any symbol that contains `d'.
-exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
-# Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
-# platforms (ab)use it in PIC code, but their linkers get confused if
-# the symbol is explicitly referenced. Since portable code cannot
-# rely on this symbol name, it's probably fine to never include it in
-# preloaded symbol tables.
-extract_expsyms_cmds=
-case $host_os in
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
-openbsd*)
- with_gnu_ld=no
-esac
-ld_shlibs=yes
-if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # See if GNU ld supports shared libraries.
- case $host_os in
- # On AIX, the GNU linker is very broken
- # Note:Check GNU linker on AIX 5-IA64 when/if it becomes available.
- ld_shlibs=no
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- amigaos*)
- archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec='-L$libdir'
- hardcode_minus_L=yes
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can use
- # them.
- ld_shlibs=no
- beos*)
- if $LD --help 2>&1 | egrep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs=no
- fi
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- always_export_symbols=yes
- extract_expsyms_cmds='test -f $output_objdir/impgen.c || \
- sed -e "/^# \/\* impgen\.c starts here \*\//,/^# \/\* impgen.c ends here \*\// { s/^# //;s/^# *$//; p; }" -e d < $''0 > $output_objdir/impgen.c~
- test -f $output_objdir/impgen.exe || (cd $output_objdir && \
- if test "x$HOST_CC" != "x" ; then $HOST_CC -o impgen impgen.c ; \
- else $CC -o impgen impgen.c ; fi)~
- $output_objdir/impgen $dir/$soroot > $output_objdir/$soname-def'
- old_archive_from_expsyms_cmds='$DLLTOOL --as=$AS --dllname $soname --def $output_objdir/$soname-def --output-lib $output_objdir/$newlib'
- # cygwin and mingw dlls have different entry points and sets of symbols
- # to exclude.
- # FIXME: what about values for MSVC?
- dll_entry=__cygwin_dll_entry at 12
- dll_exclude_symbols=DllMain at 12,_cygwin_dll_entry at 12,_cygwin_noncygwin_dll_entry at 12~
- case $host_os in
- mingw*)
- # mingw values
- dll_entry=_DllMainCRTStartup at 12
- dll_exclude_symbols=DllMain at 12,DllMainCRTStartup at 12,DllEntryPoint at 12~
- esac
- # mingw and cygwin differ, and it's simplest to just exclude the union
- # of the two symbol sets.
- dll_exclude_symbols=DllMain at 12,_cygwin_dll_entry at 12,_cygwin_noncygwin_dll_entry at 12,DllMainCRTStartup at 12,DllEntryPoint at 12
- # can override, but on older systems we have to supply one (in ltdll.c)
- if test "x$lt_cv_need_dllmain" = "xyes"; then
- ltdll_obj='$output_objdir/$soname-ltdll.'"$ac_objext "
- ltdll_cmds='test -f $output_objdir/$soname-ltdll.c || sed -e "/^# \/\* ltdll\.c starts here \*\//,/^# \/\* ltdll.c ends here \*\// { s/^# //; p; }" -e d < $''0 > $output_objdir/$soname-ltdll.c~
- test -f $output_objdir/$soname-ltdll.$ac_objext || (cd $output_objdir && $CC -c $soname-ltdll.c)~'
- else
- ltdll_obj=
- ltdll_cmds=
- fi
- # Extract the symbol export list from an `--export-all' def file,
- # then regenerate the def file from the symbol export list, so that
- # the compiled dll only exports the symbol export list.
- # Be careful not to strip the DATA tag left be newer dlltools.
- export_symbols_cmds="$ltdll_cmds"'
- $DLLTOOL --export-all --exclude-symbols '$dll_exclude_symbols' --output-def $output_objdir/$soname-def '$ltdll_obj'$libobjs $convenience~
- sed -e "1,/EXPORTS/d" -e "s/ @ [[0-9]]*//" -e "s/ *;.*$//" < $output_objdir/$soname-def > $export_symbols'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is.
- # If DATA tags from a recent dlltool are present, honour them!
- archive_expsym_cmds='if test "x`sed 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname-def;
- else
- echo EXPORTS > $output_objdir/$soname-def;
- _lt_hint=1;
- cat $export_symbols | while read symbol; do
- set dummy \$symbol;
- case \[$]# in
- 2) echo " \[$]2 @ \$_lt_hint ; " >> $output_objdir/$soname-def;;
- 4) echo " \[$]2 \[$]3 \[$]4 ; " >> $output_objdir/$soname-def; _lt_hint=`expr \$_lt_hint - 1`;;
- *) echo " \[$]2 @ \$_lt_hint \[$]3 ; " >> $output_objdir/$soname-def;;
- esac;
- _lt_hint=`expr 1 + \$_lt_hint`;
- done;
- fi~
- '"$ltdll_cmds"'
- $CC -Wl,--base-file,$output_objdir/$soname-base '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags~
- $DLLTOOL --as=$AS --dllname $soname --exclude-symbols '$dll_exclude_symbols' --def $output_objdir/$soname-def --base-file $output_objdir/$soname-base --output-exp $output_objdir/$soname-exp~
- $CC -Wl,--base-file,$output_objdir/$soname-base $output_objdir/$soname-exp '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags~
- $DLLTOOL --as=$AS --dllname $soname --exclude-symbols '$dll_exclude_symbols' --def $output_objdir/$soname-def --base-file $output_objdir/$soname-base --output-exp $output_objdir/$soname-exp --output-lib $output_objdir/$libname.dll.a~
- $CC $output_objdir/$soname-exp '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags'
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- archive_cmds='$CC -shared -nodefaultlibs $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared -nodefaultlibs $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris* | sysv5*)
- if $LD -v 2>&1 | egrep 'BFD 2\.8' > /dev/null; then
- ld_shlibs=no
- cat <<EOF 1>&2
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | egrep ': supported targets:.* elf' > /dev/null; then
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- else
- ld_shlibs=no
- fi
- sunos4*)
- archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct=yes
- hardcode_shlibpath_var=no
- else
- ld_shlibs=no
- fi
- esac
- if test "$ld_shlibs" = yes; then
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec='${wl}--export-dynamic'
- case $host_os in
- # dlltool doesn't understand --whole-archive et. al.
- whole_archive_flag_spec=
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | egrep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- esac
- fi
-else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$link_static_flag"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct=unsupported
- fi
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[[23]]|aix4.[[23]].*|aix5*)
- for ld_flag in $LDFLAGS; do
- case $ld_flag in
- *-brtl*)
- aix_use_runtimelinking=yes
- break
- esac
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds=''
- hardcode_libdir_separator=':'
- case $host_os in aix4.[[012]]|aix4.[[012]].*)
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- else
- # not using gcc
- shared_flag='${wl}-G'
- else
- if test "$aix_use_runtimelinking" = yes; then
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall can do strange things, so it is better to
- # generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag='-berok'
- hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:/usr/lib:/lib'
- archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag="-z nodefs"
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname ${wl}-h$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
- else
- hardcode_libdir_flag_spec='${wl}-bnolibpath ${wl}-blibpath:$libdir:/usr/lib:/lib'
- # Warning - without using the other run time loading flags,
- allow_undefined_flag='${wl}-berok'
- # This is a bit strange, but is similar to how AIX traditionally builds
- # it's shared libraries.
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"' ~$AR -crlo $objdir/$libname$release.a $objdir/$soname'
- fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- ld_shlibs=no
- hardcode_libdir_flag_spec=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | sed -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_from_new_cmds='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path='`cygpath -w "$srcfile"`'
- case "$host_os" in
- rhapsody* | darwin1.[[012]])
- allow_undefined_flag='-undefined suppress'
- *) # Darwin 1.3 on
- allow_undefined_flag='-flat_namespace -undefined suppress'
- esac
- # FIXME: Relying on posixy $() will cause problems for
- # cross-compilation, but unfortunately the echo tests do not
- # yet detect zsh echo's removal of \ escapes. Also zsh mangles
- # `"' quotes if we put them in here... so don't!
- archive_cmds='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs && $CC $(test .$module = .yes && echo -bundle || echo -dynamiclib) $allow_undefined_flag -o $lib ${lib}-master.o $deplibs$linker_flags $(test .$module != .yes && echo -install_name $rpath/$soname $verstring)'
- # We need to add '_' to the symbols in $export_symbols first
- #archive_expsym_cmds="$archive_cmds"' && strip -s $export_symbols'
- whole_archive_flag_spec='-all_load $convenience'
- freebsd1*)
- ld_shlibs=no
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd*)
- archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- case $host_os in
- hpux9*) archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib' ;;
- *) archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags' ;;
- esac
- hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator=:
- hardcode_minus_L=yes # Not in the search PATH, but as the default
- # location of the library.
- export_dynamic_flag_spec='${wl}-E'
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
- else
- archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec='-rpath $libdir'
- fi
- link_all_deplibs=yes
- netbsd*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
- else
- openbsd[[01]].* | openbsd2.[[0-7]] | openbsd2.[[0-7]].*)
- esac
- fi
- os2*)
- archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_from_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag=' -expect_unresolved \*'
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds='for i in `cat $export_symbols`; do printf "-exported_symbol " >> $lib.exp; echo "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
- #Both c and cxx compiler support -rpath directly
- fi
- sco3.2v5*)
- hardcode_runpath_var=yes
- export_dynamic_flag_spec='${wl}-Bexport'
- solaris*)
- # gcc --version < 3.0 without binutils cannot create self contained
- # shared libraries reliably, requiring libgcc.a to resolve some of
- # the object symbols generated in some cases. Libraries that use
- # assert need libgcc.a to resolve __eprintf, for example. Linking
- # a copy of libgcc.a into every shared library to guarantee resolving
- # such symbols causes other problems: According to Tim Van Holder
- # <tim.van.holder at pandora.be>, C++ libraries end up with a separate
- # (to the application) exception stack for one thing.
- no_undefined_flag=' -z defs'
- [[12]].*)
- cat <<EOF 1>&2
-*** Warning: Releases of GCC earlier than version 3.0 cannot reliably
-*** create self contained shared libraries on Solaris systems, without
-*** introducing a dependency on libgcc.a. Therefore, libtool is disabling
-*** -no-undefined support, which will at least allow you to build shared
-*** libraries. However, you may find that when you link such libraries
-*** into an application without using GCC, you have to manually add
-*** \`gcc --print-libgcc-file-name\` to the link command. We urge you to
-*** upgrade to a newer version of GCC. Another option is to rebuild your
-*** current GCC to use the GNU linker from GNU binutils 2.9.1 or newer.
-EOF
- esac
- fi
- # $CC -shared without GNU ld will not create a library from C++
- # object files and a static libstdc++, better avoid it by now
- archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- case $host_os in
- solaris2.[[0-5]] | solaris2.[[0-5]].*) ;;
- *) # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- case $host_vendor in
- sni)
- hardcode_direct=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- reload_cmds='$CC -r -o $output$reload_objs'
- hardcode_direct=no
- motorola)
- hardcode_direct=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- export_dynamic_flag_spec='-Bexport'
- sysv5*)
- no_undefined_flag=' -z text'
- uts4*)
- dgux*)
- sysv4*MP*)
- ld_shlibs=yes
- fi
- sysv4.2uw2*)
- hardcode_minus_L=no
- sysv5uw7* | unixware7*)
- no_undefined_flag='${wl}-z ${wl}text'
- archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- ld_shlibs=no
- esac
-fi
-AC_MSG_RESULT([$ld_shlibs])
-test "$ld_shlibs" = no && can_build_shared=no
-# Check hardcoding attributes.
-AC_MSG_CHECKING([how to hardcode library paths into programs])
-hardcode_action=
-if test -n "$hardcode_libdir_flag_spec" || \
- test -n "$runpath_var"; then
- # We can hardcode non-existant directories.
- if test "$hardcode_direct" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$hardcode_shlibpath_var" != no &&
- test "$hardcode_minus_L" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action=unsupported
-fi
-AC_MSG_RESULT([$hardcode_action])
-striplib=
-old_striplib=
-AC_MSG_CHECKING([whether stripping libraries is possible])
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- AC_MSG_RESULT([yes])
-else
- AC_MSG_RESULT([no])
-fi
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
-# PORTME Fill in your ld.so characteristics
-AC_MSG_CHECKING([dynamic linker characteristics])
-library_names_spec=
-libname_spec='lib$name'
-soname_spec=
-postinstall_cmds=
-postuninstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}.so$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}.so$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}.so$major ${libname}${release}.so$versuffix $libname.so'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[[01]] | aix4.[[01]].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can
- # not hardcode correct soname into executable. Probably we can
- # add versioning support to collect2, so additional links can
- # be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major $libname.so'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([[^/]]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "(cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a)"; (cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a) || exit 1; done'
-beos*)
- library_names_spec='${libname}.so'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi4*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- export_dynamic_flag_spec=-rdynamic
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
- version_type=windows
- need_version=no
- case $GCC,$host_os in
- yes,cygwin*)
- library_names_spec='$libname.dll.a'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | sed -e 's/[[.]]/-/g'`${versuffix}.dll'
- postinstall_cmds='dlpath=`bash 2>&1 -c '\''. $dir/${file}i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog .libs/$dlname \$dldir/$dlname'
- postuninstall_cmds='dldll=`bash 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- yes,mingw*)
- library_names_spec='${libname}`echo ${release} | sed -e 's/[[.]]/-/g'`${versuffix}.dll'
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | sed -e "s/^libraries://" -e "s/;/ /g" -e "s,=/,/,g"`
- yes,pw32*)
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll'
- library_names_spec='${libname}`echo ${release} | sed -e 's/[[.]]/-/g'`${versuffix}.dll $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}.$(test .$module = .yes && echo so || echo dylib) ${libname}${release}${major}.$(test .$module = .yes && echo so || echo dylib) ${libname}.$(test .$module = .yes && echo so || echo dylib)'
- soname_spec='${libname}${release}${major}.$(test .$module = .yes && echo so || echo dylib)'
- shlibpath_overrides_runpath=yes
- shlibpath_var=DYLD_LIBRARY_PATH
-freebsd1*)
- dynamic_linker=no
-freebsd*)
- objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so $libname.so'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}.so$versuffix $libname.so$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- shlibpath_overrides_runpath=no
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so${major} ${libname}.so'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- dynamic_linker="$host_os dld.sl"
- version_type=sunos
- need_version=no
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- library_names_spec='${libname}${release}.sl$versuffix ${libname}${release}.sl$major $libname.sl'
- soname_spec='${libname}${release}.sl$major'
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- *) version_type=irix ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major ${libname}${release}.so $libname.so'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 ") libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 ") libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 ") libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux-gnuoldld* | linux-gnuaout* | linux-gnucoff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux-gnu*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
- # Find out which ABI we are using (multilib Linux x86_64 hack).
- libsuff=
- case "$host_cpu" in
- x86_64*|s390x*)
- *64-bit*)
- libsuff=64
- esac
- fi
- rm -rf conftest*
- esac
- sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff}"
- sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}.so$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major ${libname}${release}.so ${libname}.so'
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-openbsd*)
- need_version=no
- openbsd2.[[89]] | openbsd2.[[89]].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname.dll $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
- version_type=osf
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- if test "$with_gnu_ld" = yes; then
- fi
- need_version=yes
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-uts4*)
-dgux*)
- need_version=no
-sysv4*MP*)
- library_names_spec='$libname.so.$versuffix $libname.so.$major $libname.so'
- soname_spec='$libname.so.$major'
- fi
- dynamic_linker=no
-esac
-AC_MSG_RESULT([$dynamic_linker])
-test "$dynamic_linker" = no && can_build_shared=no
-# Report the final consequences.
-AC_MSG_CHECKING([if libtool supports shared libraries])
-AC_MSG_RESULT([$can_build_shared])
-AC_MSG_CHECKING([whether to build shared libraries])
-test "$can_build_shared" = "no" && enable_shared=no
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case "$host_os" in
-aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
- fi
-aix4*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
-esac
-AC_MSG_RESULT([$enable_shared])
-AC_MSG_CHECKING([whether to build static libraries])
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-AC_MSG_RESULT([$enable_static])
-if test "$hardcode_action" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-AC_LIBTOOL_DLOPEN_SELF
-if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- AC_MSG_CHECKING([whether -lc should be explicitly linked in])
- AC_CACHE_VAL([lt_cv_archive_cmds_need_lc],
- [$rm conftest*
- echo 'static int dummy;' > conftest.$ac_ext
- if AC_TRY_EVAL(ac_compile); then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_cv_prog_cc_wl
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- save_allow_undefined_flag=$allow_undefined_flag
- if AC_TRY_EVAL(archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1)
- then
- lt_cv_archive_cmds_need_lc=no
- else
- lt_cv_archive_cmds_need_lc=yes
- fi
- allow_undefined_flag=$save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi])
- AC_MSG_RESULT([$lt_cv_archive_cmds_need_lc])
- esac
-fi
-need_lc=${lt_cv_archive_cmds_need_lc-yes}
-# The second clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- test -f Makefile && make "$ltmain"
-fi
- trap "$rm \"${ofile}T\"; exit 1" 1 2 15
- $rm -f "${ofile}T"
- echo creating $ofile
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS SED \
- AR AR_FLAGS CC LD LN_S NM SHELL \
- reload_flag reload_cmds wl \
- pic_flag link_static_flag no_builtin_flag export_dynamic_flag_spec \
- thread_safe_flag_spec whole_archive_flag_spec libname_spec \
- library_names_spec soname_spec \
- RANLIB old_archive_cmds old_archive_from_new_cmds old_postinstall_cmds \
- old_postuninstall_cmds archive_cmds archive_expsym_cmds postinstall_cmds \
- postuninstall_cmds extract_expsyms_cmds old_archive_from_expsyms_cmds \
- old_striplib striplib file_magic_cmd export_symbols_cmds \
- deplibs_check_method allow_undefined_flag no_undefined_flag \
- finish_cmds finish_eval global_symbol_pipe global_symbol_to_cdecl \
- global_symbol_to_c_name_address \
- hardcode_libdir_flag_spec hardcode_libdir_separator \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- compiler_c_o compiler_o_lo need_locks exclude_expsyms include_expsyms; do
- case $var in
- reload_cmds | old_archive_cmds | old_archive_from_new_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- export_symbols_cmds | archive_cmds | archive_expsym_cmds | \
- extract_expsyms_cmds | old_archive_from_expsyms_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- finish_cmds | sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- cat <<__EOF__ > "${ofile}T"
-#! $SHELL
-# `$echo "$ofile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
-# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
-# NOTE: Changes made to this file will be lost: look at ltmain.sh.
-# Copyright (C) 1996-2000 Free Software Foundation, Inc.
-# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# A sed that does not truncate output.
-SED=$lt_SED
-# Sed that helps us avoid accidentally triggering echo(1) options like -n.
-Xsed="${SED} -e s/^X//"
-if test "X\${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
-# ### BEGIN LIBTOOL CONFIG
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$need_lc
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# The default C compiler.
-CC=$lt_CC
-# Is the compiler the GNU C compiler?
-with_gcc=$GCC
-# The linker used to build libraries.
-LD=$lt_LD
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_wl
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_pic_flag
-pic_mode=$pic_mode
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_compiler_c_o
-# Can we write directly to a .lo ?
-compiler_o_lo=$lt_compiler_o_lo
-# Must we lock files when doing compilation ?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_link_static_flag
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_no_builtin_flag
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_thread_safe_flag_spec
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_archive_cmds
-archive_expsym_cmds=$lt_archive_expsym_cmds
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator
-# Set to yes if using DIR/libNAME.so during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$hardcode_direct
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$hardcode_minus_L
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$hardcode_shlibpath_var
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$fix_srcfile_path"
-# Set to yes if exported symbols are required.
-always_export_symbols=$always_export_symbols
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms
-# ### END LIBTOOL CONFIG
-__EOF__
- case $host_os in
- aix3*)
- cat <<\EOF >> "${ofile}T"
-# AIX sometimes has problems with the GCC collect2 program. For some
-# reason, if we set the COLLECT_NAMES environment variable, the problems
-# vanish in a puff of smoke.
-if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
-fi
-EOF
- esac
- case $host_os in
- cat <<'EOF' >> "${ofile}T"
- # This is a source program that is used to create dlls on Windows
- # Don't remove nor modify the starting and closing comments
-# /* ltdll.c starts here */
-# #define WIN32_LEAN_AND_MEAN
-# #include <windows.h>
-# #undef WIN32_LEAN_AND_MEAN
-# #include <stdio.h>
-# #ifndef __CYGWIN__
-# # ifdef __CYGWIN32__
-# # define __CYGWIN__ __CYGWIN32__
-# # endif
-# #endif
-# #ifdef __cplusplus
-# extern "C" {
-# #endif
-# BOOL APIENTRY DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved);
-# #endif
-# #ifdef __CYGWIN__
-# #include <cygwin/cygwin_dll.h>
-# DECLARE_CYGWIN_DLL( DllMain );
-# #endif
-# HINSTANCE __hDllInstance_base;
-# BOOL APIENTRY
-# DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved)
-# __hDllInstance_base = hInst;
-# return TRUE;
-# /* ltdll.c ends here */
- # This is a source program that is used to create import libraries
- # on Windows for dlls which lack them. Don't remove nor modify the
- # starting and closing comments
-# /* impgen.c starts here */
-# /* Copyright (C) 1999-2000 Free Software Foundation, Inc.
-# This file is part of GNU libtool.
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# GNU General Public License for more details.
-# #include <stdio.h> /* for printf() */
-# #include <unistd.h> /* for open(), lseek(), read() */
-# #include <fcntl.h> /* for O_RDONLY, O_BINARY */
-# #include <string.h> /* for strdup() */
-# /* O_BINARY isn't required (or even defined sometimes) under Unix */
-# #ifndef O_BINARY
-# #define O_BINARY 0
-# #endif
-# static unsigned int
-# pe_get16 (fd, offset)
-# int fd;
-# int offset;
-# unsigned char b[2];
-# lseek (fd, offset, SEEK_SET);
-# read (fd, b, 2);
-# return b[0] + (b[1]<<8);
-# pe_get32 (fd, offset)
-# int fd;
-# int offset;
-# unsigned char b[4];
-# read (fd, b, 4);
-# return b[0] + (b[1]<<8) + (b[2]<<16) + (b[3]<<24);
-# pe_as32 (ptr)
-# void *ptr;
-# unsigned char *b = ptr;
-# int
-# main (argc, argv)
-# int argc;
-# char *argv[];
-# int dll;
-# unsigned long pe_header_offset, opthdr_ofs, num_entries, i;
-# unsigned long export_rva, export_size, nsections, secptr, expptr;
-# unsigned long name_rvas, nexp;
-# unsigned char *expdata, *erva;
-# char *filename, *dll_name;
-# filename = argv[1];
-# dll = open(filename, O_RDONLY|O_BINARY);
-# if (dll < 1)
-# return 1;
-# dll_name = filename;
-# for (i=0; filename[i]; i++)
-# if (filename[i] == '/' || filename[i] == '\\' || filename[i] == ':')
-# dll_name = filename + i +1;
-# pe_header_offset = pe_get32 (dll, 0x3c);
-# opthdr_ofs = pe_header_offset + 4 + 20;
-# num_entries = pe_get32 (dll, opthdr_ofs + 92);
-# if (num_entries < 1) /* no exports */
-# return 1;
-# export_rva = pe_get32 (dll, opthdr_ofs + 96);
-# export_size = pe_get32 (dll, opthdr_ofs + 100);
-# nsections = pe_get16 (dll, pe_header_offset + 4 +2);
-# secptr = (pe_header_offset + 4 + 20 +
-# pe_get16 (dll, pe_header_offset + 4 + 16));
-# expptr = 0;
-# for (i = 0; i < nsections; i++)
-# char sname[8];
-# unsigned long secptr1 = secptr + 40 * i;
-# unsigned long vaddr = pe_get32 (dll, secptr1 + 12);
-# unsigned long vsize = pe_get32 (dll, secptr1 + 16);
-# unsigned long fptr = pe_get32 (dll, secptr1 + 20);
-# lseek(dll, secptr1, SEEK_SET);
-# read(dll, sname, 8);
-# if (vaddr <= export_rva && vaddr+vsize > export_rva)
-# expptr = fptr + (export_rva - vaddr);
-# if (export_rva + export_size > vaddr + vsize)
-# export_size = vsize - (export_rva - vaddr);
-# break;
-# expdata = (unsigned char*)malloc(export_size);
-# lseek (dll, expptr, SEEK_SET);
-# read (dll, expdata, export_size);
-# erva = expdata - export_rva;
-# nexp = pe_as32 (expdata+24);
-# name_rvas = pe_as32 (expdata+32);
-# printf ("EXPORTS\n");
-# for (i = 0; i<nexp; i++)
-# unsigned long name_rva = pe_as32 (erva+name_rvas+i*4);
-# printf ("\t%s @ %ld ;\n", erva+name_rva, 1+ i);
-# return 0;
-# /* impgen.c ends here */
-EOF
- esac
- # We use sed instead of cat because bash on DJGPP gets confused if
- # if finds mixed CR/LF and LF-only lines. Since sed operates in
- # text mode, it properly converts lines to CR/LF. This bash problem
- # is reportedly fixed, but why not run on old versions too?
- sed '$q' "$ltmain" >> "${ofile}T" || (rm -f "${ofile}T"; exit 1)
- mv -f "${ofile}T" "$ofile" || \
- (rm -f "$ofile" && cp "${ofile}T" "$ofile" && rm -f "${ofile}T")
- chmod +x "$ofile"
-fi
-])# _LT_AC_LTCONFIG_HACK
-# AC_LIBTOOL_DLOPEN - enable checks for dlopen support
-AC_DEFUN([AC_LIBTOOL_DLOPEN], [AC_BEFORE([$0],[AC_LIBTOOL_SETUP])])
-# AC_LIBTOOL_WIN32_DLL - declare package support for building win32 dll's
-AC_DEFUN([AC_LIBTOOL_WIN32_DLL], [AC_BEFORE([$0], [AC_LIBTOOL_SETUP])])
-# AC_ENABLE_SHARED - implement the --enable-shared flag
-# Usage: AC_ENABLE_SHARED[(DEFAULT)]
-# Where DEFAULT is either `yes' or `no'. If omitted, it defaults to
-# `yes'.
-AC_DEFUN([AC_ENABLE_SHARED],
-[define([AC_ENABLE_SHARED_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE(shared,
-changequote(<<, >>)dnl
-<< --enable-shared[=PKGS] build shared libraries [default=>>AC_ENABLE_SHARED_DEFAULT],
-changequote([, ])dnl
-[p=${PACKAGE-default}
-case $enableval in
-yes) enable_shared=yes ;;
-no) enable_shared=no ;;
- enable_shared=no
- # Look at the argument we got. We use all the common list separators.
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS="${IFS}:,"
- for pkg in $enableval; do
- if test "X$pkg" = "X$p"; then
- enable_shared=yes
- fi
- done
- IFS="$ac_save_ifs"
-esac],
-enable_shared=AC_ENABLE_SHARED_DEFAULT)dnl
-# AC_DISABLE_SHARED - set the default shared flag to --disable-shared
-AC_DEFUN([AC_DISABLE_SHARED],
-[AC_BEFORE([$0],[AC_LIBTOOL_SETUP])dnl
-AC_ENABLE_SHARED(no)])
-# AC_ENABLE_STATIC - implement the --enable-static flag
-# Usage: AC_ENABLE_STATIC[(DEFAULT)]
-# `yes'.
-AC_DEFUN([AC_ENABLE_STATIC],
-[define([AC_ENABLE_STATIC_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE(static,
-<< --enable-static[=PKGS] build static libraries [default=>>AC_ENABLE_STATIC_DEFAULT],
-case $enableval in
-yes) enable_static=yes ;;
-no) enable_static=no ;;
- enable_static=no
- enable_static=yes
- fi
- done
-esac],
-enable_static=AC_ENABLE_STATIC_DEFAULT)dnl
-# AC_DISABLE_STATIC - set the default static flag to --disable-static
-AC_DEFUN([AC_DISABLE_STATIC],
-AC_ENABLE_STATIC(no)])
-# AC_ENABLE_FAST_INSTALL - implement the --enable-fast-install flag
-# Usage: AC_ENABLE_FAST_INSTALL[(DEFAULT)]
-# `yes'.
-AC_DEFUN([AC_ENABLE_FAST_INSTALL],
-[define([AC_ENABLE_FAST_INSTALL_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE(fast-install,
-<< --enable-fast-install[=PKGS] optimize for fast installation [default=>>AC_ENABLE_FAST_INSTALL_DEFAULT],
-case $enableval in
-yes) enable_fast_install=yes ;;
-no) enable_fast_install=no ;;
- enable_fast_install=yes
- fi
- done
-esac],
-enable_fast_install=AC_ENABLE_FAST_INSTALL_DEFAULT)dnl
-# AC_DISABLE_FAST_INSTALL - set the default to --disable-fast-install
-AC_DEFUN([AC_DISABLE_FAST_INSTALL],
-AC_ENABLE_FAST_INSTALL(no)])
-# AC_LIBTOOL_PICMODE - implement the --with-pic flag
-# Usage: AC_LIBTOOL_PICMODE[(MODE)]
-# Where MODE is either `yes' or `no'. If omitted, it defaults to
-# `both'.
-AC_DEFUN([AC_LIBTOOL_PICMODE],
-pic_mode=ifelse($#,1,$1,default)])
-# AC_PATH_TOOL_PREFIX - find a file program which can recognise shared library
-AC_DEFUN([AC_PATH_TOOL_PREFIX],
-[AC_MSG_CHECKING([for $1])
-AC_CACHE_VAL(lt_cv_path_MAGIC_CMD,
-[case $MAGIC_CMD in
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a dos path.
- ac_save_MAGIC_CMD="$MAGIC_CMD"
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
-dnl $ac_dummy forces splitting on constant user-supplied paths.
-dnl POSIX.2 word splitting is done only on the output of word expansions,
-dnl not every word. This closes a longstanding sh security hole.
- ac_dummy="ifelse([$2], , $PATH, [$2])"
- for ac_dir in $ac_dummy; do
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/$1; then
- lt_cv_path_MAGIC_CMD="$ac_dir/$1"
- if test -n "$file_magic_test_file"; then
- case $deplibs_check_method in
- "file_magic "*)
- file_magic_regex="`expr \"$deplibs_check_method\" : \"file_magic \(.*\)\"`"
- MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
- if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
- egrep "$file_magic_regex" > /dev/null; then
- else
- cat <<EOF 1>&2
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such. This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem. Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
-EOF
- fi ;;
- esac
- fi
- break
- fi
- done
- MAGIC_CMD="$ac_save_MAGIC_CMD"
-esac])
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
- AC_MSG_RESULT($MAGIC_CMD)
-else
- AC_MSG_RESULT(no)
-fi
-# AC_PATH_MAGIC - find a file program which can recognise a shared library
-AC_DEFUN([AC_PATH_MAGIC],
-[AC_REQUIRE([AC_CHECK_TOOL_PREFIX])dnl
-AC_PATH_TOOL_PREFIX(${ac_tool_prefix}file, /usr/bin:$PATH)
-if test -z "$lt_cv_path_MAGIC_CMD"; then
- if test -n "$ac_tool_prefix"; then
- AC_PATH_TOOL_PREFIX(file, /usr/bin:$PATH)
- else
- MAGIC_CMD=:
- fi
-fi
-# AC_PROG_LD - find the path to the GNU or non-GNU linker
-AC_DEFUN([AC_PROG_LD],
-[AC_ARG_WITH(gnu-ld,
-[ --with-gnu-ld assume the C compiler uses GNU ld [default=no]],
-test "$withval" = no || with_gnu_ld=yes, with_gnu_ld=no)
-AC_REQUIRE([AC_PROG_CC])dnl
-AC_REQUIRE([AC_CANONICAL_HOST])dnl
-AC_REQUIRE([AC_CANONICAL_BUILD])dnl
-AC_REQUIRE([_LT_AC_LIBTOOL_SYS_PATH_SEPARATOR])dnl
-ac_prog=ld
- # Check if gcc -print-prog-name=ld gives a path.
- AC_MSG_CHECKING([for ld used by GCC])
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- [[\\/]]* | [[A-Za-z]]:[[\\/]]*)
- re_direlt='/[[^/]][[^/]]*/\.\./'
- # Canonicalize the path of ld
- ac_prog=`echo $ac_prog| sed 's%\\\\%/%g'`
- while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`echo $ac_prog| sed "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- AC_MSG_CHECKING([for GNU ld])
-else
- AC_MSG_CHECKING([for non-GNU ld])
-fi
-AC_CACHE_VAL(lt_cv_path_LD,
-[if test -z "$LD"; then
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for ac_dir in $PATH; do
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some GNU ld's only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- if "$lt_cv_path_LD" -v 2>&1 < /dev/null | egrep '(GNU|with BFD)' > /dev/null; then
- test "$with_gnu_ld" != no && break
- else
- test "$with_gnu_ld" != yes && break
- fi
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi])
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- AC_MSG_RESULT($LD)
-else
- AC_MSG_RESULT(no)
-fi
-test -z "$LD" && AC_MSG_ERROR([no acceptable ld found in \$PATH])
-AC_PROG_LD_GNU
-# AC_PROG_LD_GNU -
-AC_DEFUN([AC_PROG_LD_GNU],
-[AC_CACHE_CHECK([if the linker ($LD) is GNU ld], lt_cv_prog_gnu_ld,
-[# I'd rather use --version here, but apparently some GNU ld's only accept -v.
-if $LD -v 2>&1 </dev/null | egrep '(GNU|with BFD)' 1>&5; then
- lt_cv_prog_gnu_ld=yes
-else
- lt_cv_prog_gnu_ld=no
-fi])
-with_gnu_ld=$lt_cv_prog_gnu_ld
-# AC_PROG_LD_RELOAD_FLAG - find reload flag for linker
-# -- PORTME Some linkers may need a different reload flag.
-AC_DEFUN([AC_PROG_LD_RELOAD_FLAG],
-[AC_CACHE_CHECK([for $LD option to reload object files], lt_cv_ld_reload_flag,
-[lt_cv_ld_reload_flag='-r'])
-reload_flag=$lt_cv_ld_reload_flag
-test -n "$reload_flag" && reload_flag=" $reload_flag"
-# AC_DEPLIBS_CHECK_METHOD - how to check for library dependencies
-# -- PORTME fill in with the dynamic library characteristics
-AC_DEFUN([AC_DEPLIBS_CHECK_METHOD],
-[AC_CACHE_CHECK([how to recognise dependent libraries],
-lt_cv_deplibs_check_method,
-[lt_cv_file_magic_cmd='$MAGIC_CMD'
-lt_cv_file_magic_test_file=
-lt_cv_deplibs_check_method='unknown'
-# Need to set the preceding variable on all platforms that support
-# interlibrary dependencies.
-# 'none' -- dependencies not supported.
-# `unknown' -- same as none, but documents that we really don't know.
-# 'pass_all' -- all dependencies passed with no checks.
-# 'test_compile' -- check by making test program.
-# 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given egrep regex.
-# If you have `file' or equivalent on your system and you're not sure
-# whether `pass_all' will *always* work, you probably want this one.
-case $host_os in
-aix4* | aix5*)
- lt_cv_deplibs_check_method=pass_all
-beos*)
-bsdi4*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (shared object|dynamic lib)'
- lt_cv_file_magic_cmd='/usr/bin/file -L'
- lt_cv_file_magic_test_file=/shlib/libc.so
-cygwin* | mingw* | pw32*)
- lt_cv_deplibs_check_method='file_magic file format pei*-i386(.*architecture: i386)?'
- lt_cv_file_magic_cmd='$OBJDUMP -f'
- lt_cv_deplibs_check_method='file_magic Mach-O dynamically linked shared library'
- lt_cv_file_magic_test_file=`echo /System/Library/Frameworks/System.framework/Versions/*/System | head -1`
- lt_cv_file_magic_test_file='/usr/lib/libSystem.dylib'
- esac
-freebsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
- case $host_cpu in
- i*86 )
- # Not sure whether the presence of OpenBSD here was a mistake.
- # Let's accept both of them until this is cleared up.
- lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD)/i[[3-9]]86 (compact )?demand paged shared library'
- lt_cv_file_magic_cmd=/usr/bin/file
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
- esac
- else
- fi
-gnu*)
-hpux10.20*|hpux11*)
- lt_cv_deplibs_check_method='file_magic (s[[0-9]][[0-9]][[0-9]]|PA-RISC[[0-9]].[[0-9]]) shared library'
- lt_cv_file_magic_test_file=/usr/lib/libc.sl
- case $host_os in
- # this will be overridden with pass_all, but let us keep it just in case
- lt_cv_deplibs_check_method="file_magic ELF 32-bit MSB dynamic lib MIPS - version 1"
- case $LD in
- *-32|*"-32 ") libmagic=32-bit;;
- *-n32|*"-n32 ") libmagic=N32;;
- *-64|*"-64 ") libmagic=64-bit;;
- *) libmagic=never-match;;
- esac
- lt_cv_deplibs_check_method="file_magic ELF ${libmagic} MSB mips-[[1234]] dynamic lib MIPS - version 1"
- esac
- lt_cv_file_magic_test_file=`echo /lib${libsuff}/libc.so*`
-linux-gnu*)
- case $host_cpu in
- alpha* | hppa* | i*86 | mips | mipsel | powerpc* | sparc* | ia64* | s390* | x86_64*)
- lt_cv_deplibs_check_method=pass_all ;;
- # glibc up to 2.1.1 does not perform some relocations on ARM
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB (shared object|dynamic lib )' ;;
- esac
- lt_cv_file_magic_test_file=`echo /lib/libc.so* /lib/libc-*.so`
-netbsd*)
- lt_cv_deplibs_check_method='match_pattern /lib[[^/\.]]+\.so\.[[0-9]]+\.[[0-9]]+$'
- else
- lt_cv_deplibs_check_method='match_pattern /lib[[^/\.]]+\.so$'
- fi
-newos6*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (executable|dynamic lib)'
- lt_cv_file_magic_test_file=/usr/lib/libnls.so
-openbsd*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB shared object'
- else
- lt_cv_deplibs_check_method='file_magic OpenBSD.* shared library'
- fi
- lt_cv_deplibs_check_method='file_magic COFF format alpha shared library'
-sco3.2v5*)
-solaris*)
- lt_cv_file_magic_test_file=/lib/libc.so
-sysv5uw[[78]]* | sysv4*uw2*)
- motorola)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (shared object|dynamic lib) M[[0-9]][[0-9]]* Version [[0-9]]'
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
- ncr)
- sequent)
- lt_cv_file_magic_cmd='/bin/file'
- sni)
- lt_cv_deplibs_check_method="file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB dynamic lib"
- siemens)
- esac
-esac
-file_magic_cmd=$lt_cv_file_magic_cmd
-deplibs_check_method=$lt_cv_deplibs_check_method
-# AC_PROG_NM - find the path to a BSD-compatible name lister
-AC_DEFUN([AC_PROG_NM],
-[AC_REQUIRE([_LT_AC_LIBTOOL_SYS_PATH_SEPARATOR])dnl
-AC_MSG_CHECKING([for BSD-compatible nm])
-AC_CACHE_VAL(lt_cv_path_NM,
-[if test -n "$NM"; then
- # Let the user override the test.
- lt_cv_path_NM="$NM"
-else
- for ac_dir in $PATH /usr/ccs/bin /usr/ucb /bin; do
- tmp_nm=$ac_dir/${ac_tool_prefix}nm
- if test -f $tmp_nm || test -f $tmp_nm$ac_exeext ; then
- # Check to see if the nm accepts a BSD-compat flag.
- # Adding the `sed 1q' prevents false positives on HP-UX, which says:
- # nm: unknown option "B" ignored
- # Tru64's nm complains that /dev/null is an invalid object file
- if ($tmp_nm -B /dev/null 2>&1 | sed '1q'; exit 0) | egrep '(/dev/null|Invalid file or object type)' >/dev/null; then
- lt_cv_path_NM="$tmp_nm -B"
- break
- elif ($tmp_nm -p /dev/null 2>&1 | sed '1q'; exit 0) | egrep /dev/null >/dev/null; then
- lt_cv_path_NM="$tmp_nm -p"
- break
- else
- lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
- continue # so that we can try to find one that supports BSD flags
- fi
- fi
- done
- test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
-fi])
-NM="$lt_cv_path_NM"
-AC_MSG_RESULT([$NM])
-# AC_CHECK_LIBM - check for math library
-AC_DEFUN([AC_CHECK_LIBM],
-[AC_REQUIRE([AC_CANONICAL_HOST])dnl
-LIBM=
-case $host in
-*-*-beos* | *-*-cygwin* | *-*-pw32*)
- # These system don't have libm
-*-ncr-sysv4.3*)
- AC_CHECK_LIB(mw, _mwvalidcheckl, LIBM="-lmw")
- AC_CHECK_LIB(m, main, LIBM="$LIBM -lm")
- AC_CHECK_LIB(m, main, LIBM="-lm")
-esac
-# AC_LIBLTDL_CONVENIENCE[(dir)] - sets LIBLTDL to the link flags for
-# the libltdl convenience library and LTDLINCL to the include flags for
-# the libltdl header and adds --enable-ltdl-convenience to the
-# configure arguments. Note that LIBLTDL and LTDLINCL are not
-# AC_SUBSTed, nor is AC_CONFIG_SUBDIRS called. If DIR is not
-# provided, it is assumed to be `libltdl'. LIBLTDL will be prefixed
-# with '${top_builddir}/' and LTDLINCL will be prefixed with
-# '${top_srcdir}/' (note the single quotes!). If your package is not
-# flat and you're not using automake, define top_builddir and
-# top_srcdir appropriately in the Makefiles.
-AC_DEFUN([AC_LIBLTDL_CONVENIENCE],
- case $enable_ltdl_convenience in
- no) AC_MSG_ERROR([this package needs a convenience libltdl]) ;;
- "") enable_ltdl_convenience=yes
- ac_configure_args="$ac_configure_args --enable-ltdl-convenience" ;;
- esac
- LIBLTDL='${top_builddir}/'ifelse($#,1,[$1],['libltdl'])/libltdlc.la
- LTDLINCL='-I${top_srcdir}/'ifelse($#,1,[$1],['libltdl'])
- # For backwards non-gettext consistent compatibility...
- INCLTDL="$LTDLINCL"
-# AC_LIBLTDL_INSTALLABLE[(dir)] - sets LIBLTDL to the link flags for
-# the libltdl installable library and LTDLINCL to the include flags for
-# the libltdl header and adds --enable-ltdl-install to the configure
-# arguments. Note that LIBLTDL and LTDLINCL are not AC_SUBSTed, nor is
-# AC_CONFIG_SUBDIRS called. If DIR is not provided and an installed
-# libltdl is not found, it is assumed to be `libltdl'. LIBLTDL will
-# be prefixed with '${top_builddir}/' and LTDLINCL will be prefixed
-# with '${top_srcdir}/' (note the single quotes!). If your package is
-# not flat and you're not using automake, define top_builddir and
-# In the future, this macro may have to be called after AC_PROG_LIBTOOL.
-AC_DEFUN([AC_LIBLTDL_INSTALLABLE],
- AC_CHECK_LIB(ltdl, main,
- [test x"$enable_ltdl_install" != xyes && enable_ltdl_install=no],
- [if test x"$enable_ltdl_install" = xno; then
- AC_MSG_WARN([libltdl not installed, but installation disabled])
- else
- enable_ltdl_install=yes
- fi
- if test x"$enable_ltdl_install" = x"yes"; then
- ac_configure_args="$ac_configure_args --enable-ltdl-install"
- LIBLTDL='${top_builddir}/'ifelse($#,1,[$1],['libltdl'])/libltdl.la
- else
- ac_configure_args="$ac_configure_args --enable-ltdl-install=no"
- LIBLTDL="-lltdl"
- LTDLINCL=
- fi
-# old names
-AC_DEFUN([AM_PROG_LIBTOOL], [AC_PROG_LIBTOOL])
-AC_DEFUN([AM_ENABLE_SHARED], [AC_ENABLE_SHARED($@)])
-AC_DEFUN([AM_ENABLE_STATIC], [AC_ENABLE_STATIC($@)])
-AC_DEFUN([AM_DISABLE_SHARED], [AC_DISABLE_SHARED($@)])
-AC_DEFUN([AM_DISABLE_STATIC], [AC_DISABLE_STATIC($@)])
-AC_DEFUN([AM_PROG_LD], [AC_PROG_LD])
-AC_DEFUN([AM_PROG_NM], [AC_PROG_NM])
-# This is just to silence aclocal about the macro not being used
-ifelse([AC_DISABLE_FAST_INSTALL])
-# NOTE: This macro has been submitted for inclusion into #
-# GNU Autoconf as AC_PROG_SED. When it is available in #
-# a released version of Autoconf we should remove this #
-# macro and use it instead. #
-# LT_AC_PROG_SED
-# Check for a fully-functional sed program, that truncates
-# as few characters as possible. Prefer GNU sed if found.
-AC_DEFUN([LT_AC_PROG_SED],
-[AC_MSG_CHECKING([for a sed that does not truncate output])
-AC_CACHE_VAL(lt_cv_path_SED,
-[# Loop through the user's path and test for sed and gsed.
-# Then use that list of sed's as ones to test for truncation.
-as_executable_p="test -f"
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- for ac_prog in sed gsed; do
- for ac_exec_ext in '' $ac_executable_extensions; do
- if $as_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
- _sed_list="$_sed_list $as_dir/$ac_prog$ac_exec_ext"
- fi
- done
- done
-done
- # Create a temporary directory, and hook for its removal unless debugging.
-$debug ||
- trap 'exit_status=$?; rm -rf $tmp && exit $exit_status' 0
- trap '{ (exit 1); exit 1; }' 1 2 13 15
-# Create a (secure) tmp directory for tmp files.
-: ${TMPDIR=/tmp}
- tmp=`(umask 077 && mktemp -d -q "$TMPDIR/sedXXXXXX") 2>/dev/null` &&
- test -n "$tmp" && test -d "$tmp"
- tmp=$TMPDIR/sed$$-$RANDOM
- (umask 077 && mkdir $tmp)
- echo "$me: cannot create a temporary directory in $TMPDIR" >&2
- { (exit 1); exit 1; }
- _max=0
- _count=0
- # Add /usr/xpg4/bin/sed as it is typically found on Solaris
- # along with /bin/sed that truncates output.
- for _sed in $_sed_list /usr/xpg4/bin/sed; do
- test ! -f ${_sed} && break
- cat /dev/null > "$tmp/sed.in"
- _count=0
- echo ${ECHO_N-$ac_n} "0123456789${ECHO_C-$ac_c}" >"$tmp/sed.in"
- # Check for GNU sed and select it if it is found.
- if "${_sed}" --version 2>&1 < /dev/null | egrep '(GNU)' > /dev/null; then
- lt_cv_path_SED=${_sed}
- break
- fi
- while true; do
- cat "$tmp/sed.in" "$tmp/sed.in" >"$tmp/sed.tmp"
- mv "$tmp/sed.tmp" "$tmp/sed.in"
- cp "$tmp/sed.in" "$tmp/sed.nl"
- echo >>"$tmp/sed.nl"
- ${_sed} -e 's/a$//' < "$tmp/sed.nl" >"$tmp/sed.out" || break
- cmp -s "$tmp/sed.out" "$tmp/sed.nl" || break
- # 40000 chars as input seems more than enough
- test $_count -gt 10 && break
- _count=`expr $_count + 1`
- if test $_count -gt $_max; then
- _max=$_count
- lt_cv_path_SED=$_sed
- fi
- done
- done
- rm -rf "$tmp"
-if test "X$SED" != "X"; then
- lt_cv_path_SED=$SED
-else
- SED=$lt_cv_path_SED
-fi
-AC_MSG_RESULT([$SED])
Deleted: trunk/MgDev/config.guess
--- trunk/MgDev/config.guess 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/config.guess 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,1466 +0,0 @@
-#! /bin/sh
-# Attempt to guess a canonical system name.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-# 2000, 2001, 2002, 2003, 2004, 2005 Free Software Foundation, Inc.
-timestamp='2005-09-19'
-# This file is free software; you can redistribute it and/or modify it
-# under the terms of the GNU General Public License as published by
-# Foundation, Inc., 51 Franklin Street - Fifth Floor, Boston, MA
-# 02110-1301, USA.
-# Originally written by Per Bothner <per at bothner.com>.
-# Please send patches to <config-patches at gnu.org>. Submit a context
-# diff and a properly formatted ChangeLog entry.
-# This script attempts to guess a canonical system name similar to
-# config.sub. If it succeeds, it prints the system name on stdout, and
-# exits with 0. Otherwise, it exits with 1.
-# The plan is that this can be called by configure scripts if you
-# don't specify an explicit build system type.
-me=`echo "$0" | sed -e 's,.*/,,'`
-usage="\
-Usage: $0 [OPTION]
-Output the configuration name of the system \`$me' is run on.
-Operation modes:
- -h, --help print this help, then exit
- -t, --time-stamp print date of last modification, then exit
- -v, --version print version number, then exit
-Report bugs and patches to <config-patches at gnu.org>."
-version="\
-GNU config.guess ($timestamp)
-Originally written by Per Bothner.
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005
-Free Software Foundation, Inc.
-This is free software; see the source for copying conditions. There is NO
-warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
-help="
-Try \`$me --help' for more information."
-# Parse command line
-while test $# -gt 0 ; do
- case $1 in
- --time-stamp | --time* | -t )
- echo "$timestamp" ; exit ;;
- --version | -v )
- echo "$version" ; exit ;;
- --help | --h* | -h )
- echo "$usage"; exit ;;
- -- ) # Stop option processing
- shift; break ;;
- - ) # Use stdin as input.
- break ;;
- echo "$me: invalid option $1$help" >&2
- exit 1 ;;
- break ;;
- esac
-done
-if test $# != 0; then
- echo "$me: too many arguments$help" >&2
- exit 1
-fi
-trap 'exit 1' 1 2 15
-# CC_FOR_BUILD -- compiler used by this script. Note that the use of a
-# compiler to aid in system detection is discouraged as it requires
-# temporary files to be created and, as you can see below, it is a
-# headache to deal with in a portable fashion.
-# Historically, `CC_FOR_BUILD' used to be named `HOST_CC'. We still
-# use `HOST_CC' if defined, but it is deprecated.
-# Portable tmp directory creation inspired by the Autoconf team.
-set_cc_for_build='
-trap "exitcode=\$?; (rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null) && exit \$exitcode" 0 ;
-trap "rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null; exit 1" 1 2 13 15 ;
-: ${TMPDIR=/tmp} ;
- { tmp=`(umask 077 && mktemp -d -q "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
- { test -n "$RANDOM" && tmp=$TMPDIR/cg$$-$RANDOM && (umask 077 && mkdir $tmp) ; } ||
- { tmp=$TMPDIR/cg-$$ && (umask 077 && mkdir $tmp) && echo "Warning: creating insecure temp directory" >&2 ; } ||
- { echo "$me: cannot create a temporary directory in $TMPDIR" >&2 ; exit 1 ; } ;
-dummy=$tmp/dummy ;
-tmpfiles="$dummy.c $dummy.o $dummy.rel $dummy" ;
-case $CC_FOR_BUILD,$HOST_CC,$CC in
- ,,) echo "int x;" > $dummy.c ;
- for c in cc gcc c89 c99 ; do
- if ($c -c -o $dummy.o $dummy.c) >/dev/null 2>&1 ; then
- CC_FOR_BUILD="$c"; break ;
- fi ;
- done ;
- if test x"$CC_FOR_BUILD" = x ; then
- CC_FOR_BUILD=no_compiler_found ;
- fi
- ,,*) CC_FOR_BUILD=$CC ;;
- ,*,*) CC_FOR_BUILD=$HOST_CC ;;
-esac ; set_cc_for_build= ;'
-# This is needed to find uname on a Pyramid OSx when run in the BSD universe.
-# (ghazi at noc.rutgers.edu 1994-08-24)
-if (test -f /.attbin/uname) >/dev/null 2>&1 ; then
- PATH=$PATH:/.attbin ; export PATH
-fi
-UNAME_MACHINE=`(uname -m) 2>/dev/null` || UNAME_MACHINE=unknown
-UNAME_RELEASE=`(uname -r) 2>/dev/null` || UNAME_RELEASE=unknown
-UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown
-UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
-# Note: order is significant - the case branches are not exclusive.
-case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
- *:NetBSD:*:*)
- # NetBSD (nbsd) targets should (where applicable) match one or
- # more of the tupples: *-*-netbsdelf*, *-*-netbsdaout*,
- # *-*-netbsdecoff* and *-*-netbsd*. For targets that recently
- # switched to ELF, *-*-netbsd* would select the old
- # object file format. This provides both forward
- # compatibility and a consistent mechanism for selecting the
- # Note: NetBSD doesn't particularly care about the vendor
- # portion of the name. We always set it to "unknown".
- sysctl="sysctl -n hw.machine_arch"
- UNAME_MACHINE_ARCH=`(/sbin/$sysctl 2>/dev/null || \
- /usr/sbin/$sysctl 2>/dev/null || echo unknown)`
- case "${UNAME_MACHINE_ARCH}" in
- armeb) machine=armeb-unknown ;;
- arm*) machine=arm-unknown ;;
- sh3el) machine=shl-unknown ;;
- sh3eb) machine=sh-unknown ;;
- *) machine=${UNAME_MACHINE_ARCH}-unknown ;;
- esac
- # The Operating System including object format, if it has switched
- # to ELF recently, or will in the future.
- arm*|i386|m68k|ns32k|sh3*|sparc|vax)
- eval $set_cc_for_build
- if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
- | grep __ELF__ >/dev/null
- then
- # Once all utilities can be ECOFF (netbsdecoff) or a.out (netbsdaout).
- # Return netbsd for either. FIX?
- os=netbsd
- else
- os=netbsdelf
- fi
- os=netbsd
- esac
- # The OS release
- # Debian GNU/NetBSD machines have a different userland, and
- # thus, need a distinct triplet. However, they do not need
- # kernel version information, so it can be replaced with a
- # suitable tag, in the style of linux-gnu.
- case "${UNAME_VERSION}" in
- Debian*)
- release='-gnu'
- release=`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
- esac
- # Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
- # contains redundant information, the shorter form:
- # CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
- echo "${machine}-${os}${release}"
- exit ;;
- *:OpenBSD:*:*)
- UNAME_MACHINE_ARCH=`arch | sed 's/OpenBSD.//'`
- echo ${UNAME_MACHINE_ARCH}-unknown-openbsd${UNAME_RELEASE}
- exit ;;
- *:ekkoBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-ekkobsd${UNAME_RELEASE}
- exit ;;
- macppc:MirBSD:*:*)
- echo powerppc-unknown-mirbsd${UNAME_RELEASE}
- exit ;;
- *:MirBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-mirbsd${UNAME_RELEASE}
- exit ;;
- alpha:OSF1:*:*)
- case $UNAME_RELEASE in
- *4.0)
- UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $3}'`
- *5.*)
- UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $4}'`
- esac
- # According to Compaq, /usr/sbin/psrinfo has been available on
- # OSF/1 and Tru64 systems produced since 1995. I hope that
- # covers most systems running today. This code pipes the CPU
- # types through head -n 1, so we only detect the type of CPU 0.
- ALPHA_CPU_TYPE=`/usr/sbin/psrinfo -v | sed -n -e 's/^ The alpha \(.*\) processor.*$/\1/p' | head -n 1`
- case "$ALPHA_CPU_TYPE" in
- "EV4 (21064)")
- UNAME_MACHINE="alpha" ;;
- "EV4.5 (21064)")
- "LCA4 (21066/21068)")
- "EV5 (21164)")
- UNAME_MACHINE="alphaev5" ;;
- "EV5.6 (21164A)")
- UNAME_MACHINE="alphaev56" ;;
- "EV5.6 (21164PC)")
- UNAME_MACHINE="alphapca56" ;;
- "EV5.7 (21164PC)")
- UNAME_MACHINE="alphapca57" ;;
- "EV6 (21264)")
- UNAME_MACHINE="alphaev6" ;;
- "EV6.7 (21264A)")
- UNAME_MACHINE="alphaev67" ;;
- "EV6.8CB (21264C)")
- UNAME_MACHINE="alphaev68" ;;
- "EV6.8AL (21264B)")
- "EV6.8CX (21264D)")
- "EV6.9A (21264/EV69A)")
- UNAME_MACHINE="alphaev69" ;;
- "EV7 (21364)")
- UNAME_MACHINE="alphaev7" ;;
- "EV7.9 (21364A)")
- UNAME_MACHINE="alphaev79" ;;
- esac
- # A Pn.n version is a patched version.
- # A Vn.n version is a released version.
- # A Tn.n version is a released field test version.
- # A Xn.n version is an unreleased experimental baselevel.
- # 1.2 uses "1.2" for uname -r.
- echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[PVTX]//' | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
- exit ;;
- Alpha\ *:Windows_NT*:*)
- # How do we know it's Interix rather than the generic POSIX subsystem?
- # Should we change UNAME_MACHINE based on the output of uname instead
- # of the specific Alpha model?
- echo alpha-pc-interix
- exit ;;
- 21064:Windows_NT:50:3)
- echo alpha-dec-winnt3.5
- exit ;;
- Amiga*:UNIX_System_V:4.0:*)
- echo m68k-unknown-sysv4
- exit ;;
- *:[Aa]miga[Oo][Ss]:*:*)
- echo ${UNAME_MACHINE}-unknown-amigaos
- exit ;;
- *:[Mm]orph[Oo][Ss]:*:*)
- echo ${UNAME_MACHINE}-unknown-morphos
- exit ;;
- *:OS/390:*:*)
- echo i370-ibm-openedition
- exit ;;
- *:z/VM:*:*)
- echo s390-ibm-zvmoe
- exit ;;
- *:OS400:*:*)
- echo powerpc-ibm-os400
- exit ;;
- arm:RISC*:1.[012]*:*|arm:riscix:1.[012]*:*)
- echo arm-acorn-riscix${UNAME_RELEASE}
- exit ;;
- arm:riscos:*:*|arm:RISCOS:*:*)
- echo arm-unknown-riscos
- exit ;;
- SR2?01:HI-UX/MPP:*:* | SR8000:HI-UX/MPP:*:*)
- echo hppa1.1-hitachi-hiuxmpp
- exit ;;
- Pyramid*:OSx*:*:* | MIS*:OSx*:*:* | MIS*:SMP_DC-OSx*:*:*)
- # akee at wpdis03.wpafb.af.mil (Earle F. Ake) contributed MIS and NILE.
- if test "`(/bin/universe) 2>/dev/null`" = att ; then
- echo pyramid-pyramid-sysv3
- else
- echo pyramid-pyramid-bsd
- fi
- exit ;;
- NILE*:*:*:dcosx)
- echo pyramid-pyramid-svr4
- exit ;;
- DRS?6000:unix:4.0:6*)
- echo sparc-icl-nx6
- exit ;;
- DRS?6000:UNIX_SV:4.2*:7* | DRS?6000:isis:4.2*:7*)
- case `/usr/bin/uname -p` in
- sparc) echo sparc-icl-nx7; exit ;;
- esac ;;
- sun4H:SunOS:5.*:*)
- echo sparc-hal-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
- echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- i86pc:SunOS:5.*:*)
- echo i386-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- sun4*:SunOS:6*:*)
- # According to config.sub, this is the proper way to canonicalize
- # SunOS6. Hard to guess exactly what SunOS6 will be like, but
- # it's likely to be more like Solaris than SunOS4.
- echo sparc-sun-solaris3`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- sun4*:SunOS:*:*)
- case "`/usr/bin/arch -k`" in
- Series*|S4*)
- UNAME_RELEASE=`uname -v`
- esac
- # Japanese Language versions have a version number like `4.1.3-JL'.
- echo sparc-sun-sunos`echo ${UNAME_RELEASE}|sed -e 's/-/_/'`
- exit ;;
- sun3*:SunOS:*:*)
- echo m68k-sun-sunos${UNAME_RELEASE}
- exit ;;
- sun*:*:4.2BSD:*)
- UNAME_RELEASE=`(sed 1q /etc/motd | awk '{print substr($5,1,3)}') 2>/dev/null`
- test "x${UNAME_RELEASE}" = "x" && UNAME_RELEASE=3
- case "`/bin/arch`" in
- sun3)
- sun4)
- echo sparc-sun-sunos${UNAME_RELEASE}
- esac
- exit ;;
- aushp:SunOS:*:*)
- echo sparc-auspex-sunos${UNAME_RELEASE}
- exit ;;
- # The situation for MiNT is a little confusing. The machine name
- # can be virtually everything (everything which is not
- # "atarist" or "atariste" at least should have a processor
- # > m68000). The system name ranges from "MiNT" over "FreeMiNT"
- # to the lowercase version "mint" (or "freemint"). Finally
- # the system name "TOS" denotes a system which is actually not
- # MiNT. But MiNT is downward compatible to TOS, so this should
- # be no problem.
- atarist[e]:*MiNT:*:* | atarist[e]:*mint:*:* | atarist[e]:*TOS:*:*)
- echo m68k-atari-mint${UNAME_RELEASE}
- exit ;;
- atari*:*MiNT:*:* | atari*:*mint:*:* | atarist[e]:*TOS:*:*)
- exit ;;
- *falcon*:*MiNT:*:* | *falcon*:*mint:*:* | *falcon*:*TOS:*:*)
- exit ;;
- milan*:*MiNT:*:* | milan*:*mint:*:* | *milan*:*TOS:*:*)
- echo m68k-milan-mint${UNAME_RELEASE}
- exit ;;
- hades*:*MiNT:*:* | hades*:*mint:*:* | *hades*:*TOS:*:*)
- echo m68k-hades-mint${UNAME_RELEASE}
- exit ;;
- *:*MiNT:*:* | *:*mint:*:* | *:*TOS:*:*)
- echo m68k-unknown-mint${UNAME_RELEASE}
- exit ;;
- m68k:machten:*:*)
- echo m68k-apple-machten${UNAME_RELEASE}
- exit ;;
- powerpc:machten:*:*)
- echo powerpc-apple-machten${UNAME_RELEASE}
- exit ;;
- RISC*:Mach:*:*)
- echo mips-dec-mach_bsd4.3
- exit ;;
- RISC*:ULTRIX:*:*)
- echo mips-dec-ultrix${UNAME_RELEASE}
- exit ;;
- VAX*:ULTRIX*:*:*)
- echo vax-dec-ultrix${UNAME_RELEASE}
- exit ;;
- 2020:CLIX:*:* | 2430:CLIX:*:*)
- echo clipper-intergraph-clix${UNAME_RELEASE}
- exit ;;
- mips:*:*:UMIPS | mips:*:*:RISCos)
- sed 's/^ //' << EOF >$dummy.c
-#ifdef __cplusplus
-#include <stdio.h> /* for printf() prototype */
- int main (int argc, char *argv[]) {
-#else
- int main (argc, argv) int argc; char *argv[]; {
-#endif
- #if defined (host_mips) && defined (MIPSEB)
- #if defined (SYSTYPE_SYSV)
- printf ("mips-mips-riscos%ssysv\n", argv[1]); exit (0);
- #endif
- #if defined (SYSTYPE_SVR4)
- printf ("mips-mips-riscos%ssvr4\n", argv[1]); exit (0);
- #endif
- #if defined (SYSTYPE_BSD43) || defined(SYSTYPE_BSD)
- printf ("mips-mips-riscos%sbsd\n", argv[1]); exit (0);
- #endif
- #endif
- exit (-1);
-EOF
- $CC_FOR_BUILD -o $dummy $dummy.c &&
- dummyarg=`echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` &&
- SYSTEM_NAME=`$dummy $dummyarg` &&
- { echo "$SYSTEM_NAME"; exit; }
- echo mips-mips-riscos${UNAME_RELEASE}
- exit ;;
- Motorola:PowerMAX_OS:*:*)
- echo powerpc-motorola-powermax
- exit ;;
- Motorola:*:4.3:PL8-*)
- echo powerpc-harris-powermax
- exit ;;
- Night_Hawk:*:*:PowerMAX_OS | Synergy:PowerMAX_OS:*:*)
- exit ;;
- Night_Hawk:Power_UNIX:*:*)
- echo powerpc-harris-powerunix
- exit ;;
- m88k:CX/UX:7*:*)
- echo m88k-harris-cxux7
- exit ;;
- m88k:*:4*:R4*)
- echo m88k-motorola-sysv4
- exit ;;
- m88k:*:3*:R3*)
- echo m88k-motorola-sysv3
- exit ;;
- AViiON:dgux:*:*)
- # DG/UX returns AViiON for all architectures
- UNAME_PROCESSOR=`/usr/bin/uname -p`
- if [ $UNAME_PROCESSOR = mc88100 ] || [ $UNAME_PROCESSOR = mc88110 ]
- then
- if [ ${TARGET_BINARY_INTERFACE}x = m88kdguxelfx ] || \
- [ ${TARGET_BINARY_INTERFACE}x = x ]
- then
- echo m88k-dg-dgux${UNAME_RELEASE}
- else
- echo m88k-dg-dguxbcs${UNAME_RELEASE}
- fi
- else
- echo i586-dg-dgux${UNAME_RELEASE}
- fi
- exit ;;
- M88*:DolphinOS:*:*) # DolphinOS (SVR3)
- echo m88k-dolphin-sysv3
- exit ;;
- M88*:*:R3*:*)
- # Delta 88k system running SVR3
- exit ;;
- XD88*:*:*:*) # Tektronix XD88 system running UTekV (SVR3)
- echo m88k-tektronix-sysv3
- exit ;;
- Tek43[0-9][0-9]:UTek:*:*) # Tektronix 4300 system running UTek (BSD)
- echo m68k-tektronix-bsd
- exit ;;
- *:IRIX*:*:*)
- echo mips-sgi-irix`echo ${UNAME_RELEASE}|sed -e 's/-/_/g'`
- exit ;;
- ????????:AIX?:[12].1:2) # AIX 2.2.1 or AIX 2.1.1 is RT/PC AIX.
- echo romp-ibm-aix # uname -m gives an 8 hex-code CPU id
- exit ;; # Note that: echo "'`uname -s`'" gives 'AIX '
- i*86:AIX:*:*)
- echo i386-ibm-aix
- exit ;;
- ia64:AIX:*:*)
- if [ -x /usr/bin/oslevel ] ; then
- IBM_REV=`/usr/bin/oslevel`
- else
- IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
- fi
- echo ${UNAME_MACHINE}-ibm-aix${IBM_REV}
- exit ;;
- *:AIX:2:3)
- if grep bos325 /usr/include/stdio.h >/dev/null 2>&1; then
- #include <sys/systemcfg.h>
- main()
- if (!__power_pc())
- exit(1);
- puts("powerpc-ibm-aix3.2.5");
- exit(0);
-EOF
- if $CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy`
- then
- echo "$SYSTEM_NAME"
- else
- echo rs6000-ibm-aix3.2.5
- fi
- elif grep bos324 /usr/include/stdio.h >/dev/null 2>&1; then
- echo rs6000-ibm-aix3.2.4
- else
- fi
- exit ;;
- *:AIX:*:[45])
- IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
- if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
- IBM_ARCH=rs6000
- else
- IBM_ARCH=powerpc
- fi
- else
- fi
- echo ${IBM_ARCH}-ibm-aix${IBM_REV}
- exit ;;
- *:AIX:*:*)
- exit ;;
- ibmrt:4.4BSD:*|romp-ibm:BSD:*)
- echo romp-ibm-bsd4.4
- exit ;;
- ibmrt:*BSD:*|romp-ibm:BSD:*) # covers RT/PC BSD and
- echo romp-ibm-bsd${UNAME_RELEASE} # 4.3 with uname added to
- exit ;; # report: romp-ibm BSD 4.3
- *:BOSX:*:*)
- echo rs6000-bull-bosx
- exit ;;
- DPX/2?00:B.O.S.:*:*)
- echo m68k-bull-sysv3
- exit ;;
- 9000/[34]??:4.3bsd:1.*:*)
- echo m68k-hp-bsd
- exit ;;
- hp300:4.4BSD:*:* | 9000/[34]??:4.3bsd:2.*:*)
- echo m68k-hp-bsd4.4
- exit ;;
- 9000/[34678]??:HP-UX:*:*)
- HPUX_REV=`echo ${UNAME_RELEASE}|sed -e 's/[^.]*.[0B]*//'`
- case "${UNAME_MACHINE}" in
- 9000/31? ) HP_ARCH=m68000 ;;
- 9000/[34]?? ) HP_ARCH=m68k ;;
- 9000/[678][0-9][0-9])
- if [ -x /usr/bin/getconf ]; then
- sc_cpu_version=`/usr/bin/getconf SC_CPU_VERSION 2>/dev/null`
- sc_kernel_bits=`/usr/bin/getconf SC_KERNEL_BITS 2>/dev/null`
- case "${sc_cpu_version}" in
- 523) HP_ARCH="hppa1.0" ;; # CPU_PA_RISC1_0
- 528) HP_ARCH="hppa1.1" ;; # CPU_PA_RISC1_1
- 532) # CPU_PA_RISC2_0
- case "${sc_kernel_bits}" in
- 32) HP_ARCH="hppa2.0n" ;;
- 64) HP_ARCH="hppa2.0w" ;;
- '') HP_ARCH="hppa2.0" ;; # HP-UX 10.20
- esac ;;
- esac
- fi
- if [ "${HP_ARCH}" = "" ]; then
- #define _HPUX_SOURCE
- #include <stdlib.h>
- #include <unistd.h>
- int main ()
- #if defined(_SC_KERNEL_BITS)
- long bits = sysconf(_SC_KERNEL_BITS);
- #endif
- long cpu = sysconf (_SC_CPU_VERSION);
- switch (cpu)
- case CPU_PA_RISC1_0: puts ("hppa1.0"); break;
- case CPU_PA_RISC1_1: puts ("hppa1.1"); break;
- case CPU_PA_RISC2_0:
- switch (bits)
- case 64: puts ("hppa2.0w"); break;
- case 32: puts ("hppa2.0n"); break;
- default: puts ("hppa2.0"); break;
- } break;
- #else /* !defined(_SC_KERNEL_BITS) */
- puts ("hppa2.0"); break;
- #endif
- default: puts ("hppa1.0"); break;
- exit (0);
-EOF
- (CCOPTS= $CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null) && HP_ARCH=`$dummy`
- test -z "$HP_ARCH" && HP_ARCH=hppa
- fi ;;
- esac
- if [ ${HP_ARCH} = "hppa2.0w" ]
- then
- # hppa2.0w-hp-hpux* has a 64-bit kernel and a compiler generating
- # 32-bit code. hppa64-hp-hpux* has the same kernel and a compiler
- # generating 64-bit code. GNU and HP use different nomenclature:
- # $ CC_FOR_BUILD=cc ./config.guess
- # => hppa2.0w-hp-hpux11.23
- # $ CC_FOR_BUILD="cc +DA2.0w" ./config.guess
- # => hppa64-hp-hpux11.23
- if echo __LP64__ | (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) |
- grep __LP64__ >/dev/null
- then
- HP_ARCH="hppa2.0w"
- else
- HP_ARCH="hppa64"
- fi
- fi
- echo ${HP_ARCH}-hp-hpux${HPUX_REV}
- exit ;;
- ia64:HP-UX:*:*)
- echo ia64-hp-hpux${HPUX_REV}
- exit ;;
- 3050*:HI-UX:*:*)
- int
- main ()
- /* The order matters, because CPU_IS_HP_MC68K erroneously returns
- true for CPU_PA_RISC1_0. CPU_IS_PA_RISC returns correct
- results, however. */
- if (CPU_IS_PA_RISC (cpu))
- switch (cpu)
- case CPU_PA_RISC1_0: puts ("hppa1.0-hitachi-hiuxwe2"); break;
- case CPU_PA_RISC1_1: puts ("hppa1.1-hitachi-hiuxwe2"); break;
- case CPU_PA_RISC2_0: puts ("hppa2.0-hitachi-hiuxwe2"); break;
- default: puts ("hppa-hitachi-hiuxwe2"); break;
- else if (CPU_IS_HP_MC68K (cpu))
- puts ("m68k-hitachi-hiuxwe2");
- else puts ("unknown-hitachi-hiuxwe2");
- exit (0);
-EOF
- $CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy` &&
- echo unknown-hitachi-hiuxwe2
- exit ;;
- 9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:* )
- echo hppa1.1-hp-bsd
- exit ;;
- 9000/8??:4.3bsd:*:*)
- echo hppa1.0-hp-bsd
- exit ;;
- *9??*:MPE/iX:*:* | *3000*:MPE/iX:*:*)
- echo hppa1.0-hp-mpeix
- exit ;;
- hp7??:OSF1:*:* | hp8?[79]:OSF1:*:* )
- echo hppa1.1-hp-osf
- exit ;;
- hp8??:OSF1:*:*)
- echo hppa1.0-hp-osf
- exit ;;
- i*86:OSF1:*:*)
- if [ -x /usr/sbin/sysversion ] ; then
- echo ${UNAME_MACHINE}-unknown-osf1mk
- else
- fi
- exit ;;
- parisc*:Lites*:*:*)
- echo hppa1.1-hp-lites
- exit ;;
- C1*:ConvexOS:*:* | convex:ConvexOS:C1*:*)
- echo c1-convex-bsd
- exit ;;
- C2*:ConvexOS:*:* | convex:ConvexOS:C2*:*)
- if getsysinfo -f scalar_acc
- then echo c32-convex-bsd
- else echo c2-convex-bsd
- fi
- exit ;;
- C34*:ConvexOS:*:* | convex:ConvexOS:C34*:*)
- echo c34-convex-bsd
- exit ;;
- C38*:ConvexOS:*:* | convex:ConvexOS:C38*:*)
- echo c38-convex-bsd
- exit ;;
- C4*:ConvexOS:*:* | convex:ConvexOS:C4*:*)
- echo c4-convex-bsd
- exit ;;
- CRAY*Y-MP:*:*:*)
- echo ymp-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit ;;
- CRAY*[A-Z]90:*:*:*)
- echo ${UNAME_MACHINE}-cray-unicos${UNAME_RELEASE} \
- | sed -e 's/CRAY.*\([A-Z]90\)/\1/' \
- -e y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/ \
- -e 's/\.[^.]*$/.X/'
- exit ;;
- CRAY*TS:*:*:*)
- echo t90-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit ;;
- CRAY*T3E:*:*:*)
- echo alphaev5-cray-unicosmk${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit ;;
- CRAY*SV1:*:*:*)
- echo sv1-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit ;;
- *:UNICOS/mp:*:*)
- echo craynv-cray-unicosmp${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit ;;
- F30[01]:UNIX_System_V:*:* | F700:UNIX_System_V:*:*)
- FUJITSU_PROC=`uname -m | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
- FUJITSU_SYS=`uname -p | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/\///'`
- FUJITSU_REL=`echo ${UNAME_RELEASE} | sed -e 's/ /_/'`
- echo "${FUJITSU_PROC}-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
- exit ;;
- 5000:UNIX_System_V:4.*:*)
- FUJITSU_REL=`echo ${UNAME_RELEASE} | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/ /_/'`
- echo "sparc-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
- exit ;;
- i*86:BSD/386:*:* | i*86:BSD/OS:*:* | *:Ascend\ Embedded/OS:*:*)
- echo ${UNAME_MACHINE}-pc-bsdi${UNAME_RELEASE}
- exit ;;
- sparc*:BSD/OS:*:*)
- echo sparc-unknown-bsdi${UNAME_RELEASE}
- exit ;;
- *:BSD/OS:*:*)
- echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
- exit ;;
- *:FreeBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
- exit ;;
- i*:CYGWIN*:*)
- echo ${UNAME_MACHINE}-pc-cygwin
- exit ;;
- i*:MINGW*:*)
- echo ${UNAME_MACHINE}-pc-mingw32
- exit ;;
- i*:windows32*:*)
- # uname -m includes "-pc" on this system.
- echo ${UNAME_MACHINE}-mingw32
- exit ;;
- i*:PW*:*)
- echo ${UNAME_MACHINE}-pc-pw32
- exit ;;
- x86:Interix*:[34]*)
- echo i586-pc-interix${UNAME_RELEASE}|sed -e 's/\..*//'
- exit ;;
- [345]86:Windows_95:* | [345]86:Windows_98:* | [345]86:Windows_NT:*)
- echo i${UNAME_MACHINE}-pc-mks
- exit ;;
- i*:Windows_NT*:* | Pentium*:Windows_NT*:*)
- # It also conflicts with pre-2.0 versions of AT&T UWIN. Should we
- # UNAME_MACHINE based on the output of uname instead of i386?
- exit ;;
- i*:UWIN*:*)
- echo ${UNAME_MACHINE}-pc-uwin
- exit ;;
- amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
- echo x86_64-unknown-cygwin
- exit ;;
- p*:CYGWIN*:*)
- echo powerpcle-unknown-cygwin
- exit ;;
- prep*:SunOS:5.*:*)
- echo powerpcle-unknown-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- *:GNU:*:*)
- # the GNU system
- echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-gnu`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
- exit ;;
- *:GNU/*:*:*)
- # other systems with GNU libc and userland
- echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-gnu
- exit ;;
- i*86:Minix:*:*)
- echo ${UNAME_MACHINE}-pc-minix
- exit ;;
- arm*:Linux:*:*)
- echo ${UNAME_MACHINE}-unknown-linux-gnu
- exit ;;
- cris:Linux:*:*)
- echo cris-axis-linux-gnu
- exit ;;
- crisv32:Linux:*:*)
- echo crisv32-axis-linux-gnu
- exit ;;
- frv:Linux:*:*)
- echo frv-unknown-linux-gnu
- exit ;;
- ia64:Linux:*:*)
- exit ;;
- m32r*:Linux:*:*)
- exit ;;
- m68*:Linux:*:*)
- exit ;;
- mips:Linux:*:*)
- #undef CPU
- #undef mips
- #undef mipsel
- #if defined(__MIPSEL__) || defined(__MIPSEL) || defined(_MIPSEL) || defined(MIPSEL)
- CPU=mipsel
- #else
- #if defined(__MIPSEB__) || defined(__MIPSEB) || defined(_MIPSEB) || defined(MIPSEB)
- CPU=mips
- #else
- CPU=
- #endif
- #endif
-EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^CPU=`
- test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
- mips64:Linux:*:*)
- #undef CPU
- #undef mips64
- #undef mips64el
- CPU=mips64el
- #else
- CPU=mips64
- #else
- CPU=
- #endif
- #endif
-EOF
- or32:Linux:*:*)
- echo or32-unknown-linux-gnu
- exit ;;
- ppc:Linux:*:*)
- echo powerpc-unknown-linux-gnu
- exit ;;
- ppc64:Linux:*:*)
- echo powerpc64-unknown-linux-gnu
- exit ;;
- alpha:Linux:*:*)
- case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
- EV5) UNAME_MACHINE=alphaev5 ;;
- EV56) UNAME_MACHINE=alphaev56 ;;
- PCA56) UNAME_MACHINE=alphapca56 ;;
- PCA57) UNAME_MACHINE=alphapca56 ;;
- EV6) UNAME_MACHINE=alphaev6 ;;
- EV67) UNAME_MACHINE=alphaev67 ;;
- EV68*) UNAME_MACHINE=alphaev68 ;;
- esac
- objdump --private-headers /bin/sh | grep ld.so.1 >/dev/null
- if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
- echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
- exit ;;
- parisc:Linux:*:* | hppa:Linux:*:*)
- # Look for CPU level
- case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
- PA7*) echo hppa1.1-unknown-linux-gnu ;;
- PA8*) echo hppa2.0-unknown-linux-gnu ;;
- *) echo hppa-unknown-linux-gnu ;;
- esac
- exit ;;
- parisc64:Linux:*:* | hppa64:Linux:*:*)
- echo hppa64-unknown-linux-gnu
- exit ;;
- s390:Linux:*:* | s390x:Linux:*:*)
- echo ${UNAME_MACHINE}-ibm-linux
- exit ;;
- sh64*:Linux:*:*)
- exit ;;
- sh*:Linux:*:*)
- exit ;;
- sparc:Linux:*:* | sparc64:Linux:*:*)
- exit ;;
- x86_64:Linux:*:*)
- echo x86_64-unknown-linux-gnu
- exit ;;
- i*86:Linux:*:*)
- # The BFD linker knows what the default object file format is, so
- # first see if it will tell us. cd to the root directory to prevent
- # problems with other programs or directories called `ld' in the path.
- # Set LC_ALL=C to ensure ld outputs messages in English.
- ld_supported_targets=`cd /; LC_ALL=C ld --help 2>&1 \
- | sed -ne '/supported targets:/!d
- s/[ ][ ]*/ /g
- s/.*supported targets: *//
- s/ .*//
- p'`
- case "$ld_supported_targets" in
- elf32-i386)
- TENTATIVE="${UNAME_MACHINE}-pc-linux-gnu"
- a.out-i386-linux)
- echo "${UNAME_MACHINE}-pc-linux-gnuaout"
- exit ;;
- coff-i386)
- echo "${UNAME_MACHINE}-pc-linux-gnucoff"
- exit ;;
- # Either a pre-BFD a.out linker (linux-gnuoldld) or
- # one that does not give us useful --help.
- echo "${UNAME_MACHINE}-pc-linux-gnuoldld"
- exit ;;
- esac
- # Determine whether the default compiler is a.out or elf
- #include <features.h>
- #ifdef __ELF__
- # ifdef __GLIBC__
- # if __GLIBC__ >= 2
- LIBC=gnu
- # else
- LIBC=gnulibc1
- # endif
- # else
- LIBC=gnulibc1
- # endif
- #else
- #ifdef __INTEL_COMPILER
- LIBC=gnu
- #else
- LIBC=gnuaout
- #endif
- #endif
- #ifdef __dietlibc__
- LIBC=dietlibc
- #endif
-EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^LIBC=`
- test x"${LIBC}" != x && {
- echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
- exit
- test x"${TENTATIVE}" != x && { echo "${TENTATIVE}"; exit; }
- i*86:DYNIX/ptx:4*:*)
- # ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
- # earlier versions are messed up and put the nodename in both
- # sysname and nodename.
- echo i386-sequent-sysv4
- exit ;;
- i*86:UNIX_SV:4.2MP:2.*)
- # Unixware is an offshoot of SVR4, but it has its own version
- # number series starting with 2...
- # I am not positive that other SVR4 systems won't match this,
- # I just have to hope. -- rms.
- # Use sysv4.2uw... so that sysv4* matches it.
- echo ${UNAME_MACHINE}-pc-sysv4.2uw${UNAME_VERSION}
- exit ;;
- i*86:OS/2:*:*)
- # If we were able to find `uname', then EMX Unix compatibility
- # is probably installed.
- echo ${UNAME_MACHINE}-pc-os2-emx
- exit ;;
- i*86:XTS-300:*:STOP)
- echo ${UNAME_MACHINE}-unknown-stop
- exit ;;
- i*86:atheos:*:*)
- echo ${UNAME_MACHINE}-unknown-atheos
- exit ;;
- i*86:syllable:*:*)
- echo ${UNAME_MACHINE}-pc-syllable
- exit ;;
- i*86:LynxOS:2.*:* | i*86:LynxOS:3.[01]*:* | i*86:LynxOS:4.0*:*)
- echo i386-unknown-lynxos${UNAME_RELEASE}
- exit ;;
- i*86:*DOS:*:*)
- echo ${UNAME_MACHINE}-pc-msdosdjgpp
- exit ;;
- i*86:*:4.*:* | i*86:SYSTEM_V:4.*:*)
- UNAME_REL=`echo ${UNAME_RELEASE} | sed 's/\/MP$//'`
- if grep Novell /usr/include/link.h >/dev/null 2>/dev/null; then
- echo ${UNAME_MACHINE}-univel-sysv${UNAME_REL}
- else
- echo ${UNAME_MACHINE}-pc-sysv${UNAME_REL}
- fi
- exit ;;
- i*86:*:5:[678]*)
- # UnixWare 7.x, OpenUNIX and OpenServer 6.
- case `/bin/uname -X | grep "^Machine"` in
- *486*) UNAME_MACHINE=i486 ;;
- *Pentium) UNAME_MACHINE=i586 ;;
- *Pent*|*Celeron) UNAME_MACHINE=i686 ;;
- esac
- echo ${UNAME_MACHINE}-unknown-sysv${UNAME_RELEASE}${UNAME_SYSTEM}${UNAME_VERSION}
- exit ;;
- i*86:*:3.2:*)
- if test -f /usr/options/cb.name; then
- UNAME_REL=`sed -n 's/.*Version //p' </usr/options/cb.name`
- echo ${UNAME_MACHINE}-pc-isc$UNAME_REL
- elif /bin/uname -X 2>/dev/null >/dev/null ; then
- UNAME_REL=`(/bin/uname -X|grep Release|sed -e 's/.*= //')`
- (/bin/uname -X|grep i80486 >/dev/null) && UNAME_MACHINE=i486
- (/bin/uname -X|grep '^Machine.*Pentium' >/dev/null) \
- && UNAME_MACHINE=i586
- (/bin/uname -X|grep '^Machine.*Pent *II' >/dev/null) \
- && UNAME_MACHINE=i686
- (/bin/uname -X|grep '^Machine.*Pentium Pro' >/dev/null) \
- echo ${UNAME_MACHINE}-pc-sco$UNAME_REL
- else
- echo ${UNAME_MACHINE}-pc-sysv32
- fi
- exit ;;
- pc:*:*:*)
- # Left here for compatibility:
- # uname -m prints for DJGPP always 'pc', but it prints nothing about
- # the processor, so we play safe by assuming i386.
- echo i386-pc-msdosdjgpp
- exit ;;
- Intel:Mach:3*:*)
- echo i386-pc-mach3
- exit ;;
- paragon:*:*:*)
- echo i860-intel-osf1
- exit ;;
- i860:*:4.*:*) # i860-SVR4
- if grep Stardent /usr/include/sys/uadmin.h >/dev/null 2>&1 ; then
- echo i860-stardent-sysv${UNAME_RELEASE} # Stardent Vistra i860-SVR4
- else # Add other i860-SVR4 vendors below as they are discovered.
- echo i860-unknown-sysv${UNAME_RELEASE} # Unknown i860-SVR4
- fi
- exit ;;
- mini*:CTIX:SYS*5:*)
- # "miniframe"
- echo m68010-convergent-sysv
- exit ;;
- mc68k:UNIX:SYSTEM5:3.51m)
- echo m68k-convergent-sysv
- exit ;;
- M680?0:D-NIX:5.3:*)
- echo m68k-diab-dnix
- exit ;;
- M68*:*:R3V[5678]*:*)
- test -r /sysV68 && { echo 'm68k-motorola-sysv'; exit; } ;;
- 3[345]??:*:4.0:3.0 | 3[34]??A:*:4.0:3.0 | 3[34]??,*:*:4.0:3.0 | 3[34]??/*:*:4.0:3.0 | 4400:*:4.0:3.0 | 4850:*:4.0:3.0 | SKA40:*:4.0:3.0 | SDS2:*:4.0:3.0 | SHG2:*:4.0:3.0 | S7501*:*:4.0:3.0)
- OS_REL=''
- test -r /etc/.relid \
- && OS_REL=.`sed -n 's/[^ ]* [^ ]* \([0-9][0-9]\).*/\1/p' < /etc/.relid`
- /bin/uname -p 2>/dev/null | grep 86 >/dev/null \
- && { echo i486-ncr-sysv4.3${OS_REL}; exit; }
- /bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
- && { echo i586-ncr-sysv4.3${OS_REL}; exit; } ;;
- 3[34]??:*:4.0:* | 3[34]??,*:*:4.0:*)
- && { echo i486-ncr-sysv4; exit; } ;;
- m68*:LynxOS:2.*:* | m68*:LynxOS:3.0*:*)
- echo m68k-unknown-lynxos${UNAME_RELEASE}
- exit ;;
- mc68030:UNIX_System_V:4.*:*)
- echo m68k-atari-sysv4
- exit ;;
- TSUNAMI:LynxOS:2.*:*)
- echo sparc-unknown-lynxos${UNAME_RELEASE}
- exit ;;
- rs6000:LynxOS:2.*:*)
- echo rs6000-unknown-lynxos${UNAME_RELEASE}
- exit ;;
- PowerPC:LynxOS:2.*:* | PowerPC:LynxOS:3.[01]*:* | PowerPC:LynxOS:4.0*:*)
- echo powerpc-unknown-lynxos${UNAME_RELEASE}
- exit ;;
- SM[BE]S:UNIX_SV:*:*)
- echo mips-dde-sysv${UNAME_RELEASE}
- exit ;;
- RM*:ReliantUNIX-*:*:*)
- echo mips-sni-sysv4
- exit ;;
- RM*:SINIX-*:*:*)
- exit ;;
- *:SINIX-*:*:*)
- if uname -p 2>/dev/null >/dev/null ; then
- UNAME_MACHINE=`(uname -p) 2>/dev/null`
- echo ${UNAME_MACHINE}-sni-sysv4
- else
- echo ns32k-sni-sysv
- fi
- exit ;;
- PENTIUM:*:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
- # says <Richard.M.Bartel at ccMail.Census.GOV>
- echo i586-unisys-sysv4
- exit ;;
- *:UNIX_System_V:4*:FTX*)
- # From Gerald Hewes <hewes at openmarket.com>.
- # How about differentiating between stratus architectures? -djm
- echo hppa1.1-stratus-sysv4
- exit ;;
- *:*:*:FTX*)
- # From seanf at swdc.stratus.com.
- echo i860-stratus-sysv4
- exit ;;
- i*86:VOS:*:*)
- # From Paul.Green at stratus.com.
- echo ${UNAME_MACHINE}-stratus-vos
- exit ;;
- *:VOS:*:*)
- echo hppa1.1-stratus-vos
- exit ;;
- mc68*:A/UX:*:*)
- echo m68k-apple-aux${UNAME_RELEASE}
- exit ;;
- news*:NEWS-OS:6*:*)
- echo mips-sony-newsos6
- exit ;;
- R[34]000:*System_V*:*:* | R4000:UNIX_SYSV:*:* | R*000:UNIX_SV:*:*)
- if [ -d /usr/nec ]; then
- echo mips-nec-sysv${UNAME_RELEASE}
- else
- echo mips-unknown-sysv${UNAME_RELEASE}
- fi
- exit ;;
- BeBox:BeOS:*:*) # BeOS running on hardware made by Be, PPC only.
- echo powerpc-be-beos
- exit ;;
- BeMac:BeOS:*:*) # BeOS running on Mac or Mac clone, PPC only.
- echo powerpc-apple-beos
- exit ;;
- BePC:BeOS:*:*) # BeOS running on Intel PC compatible.
- echo i586-pc-beos
- exit ;;
- SX-4:SUPER-UX:*:*)
- echo sx4-nec-superux${UNAME_RELEASE}
- exit ;;
- SX-5:SUPER-UX:*:*)
- echo sx5-nec-superux${UNAME_RELEASE}
- exit ;;
- SX-6:SUPER-UX:*:*)
- echo sx6-nec-superux${UNAME_RELEASE}
- exit ;;
- Power*:Rhapsody:*:*)
- echo powerpc-apple-rhapsody${UNAME_RELEASE}
- exit ;;
- *:Rhapsody:*:*)
- echo ${UNAME_MACHINE}-apple-rhapsody${UNAME_RELEASE}
- exit ;;
- *:Darwin:*:*)
- UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
- case $UNAME_PROCESSOR in
- unknown) UNAME_PROCESSOR=powerpc ;;
- esac
- echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
- exit ;;
- *:procnto*:*:* | *:QNX:[0123456789]*:*)
- if test "$UNAME_PROCESSOR" = "x86"; then
- UNAME_PROCESSOR=i386
- UNAME_MACHINE=pc
- fi
- echo ${UNAME_PROCESSOR}-${UNAME_MACHINE}-nto-qnx${UNAME_RELEASE}
- exit ;;
- *:QNX:*:4*)
- echo i386-pc-qnx
- exit ;;
- NSE-?:NONSTOP_KERNEL:*:*)
- echo nse-tandem-nsk${UNAME_RELEASE}
- exit ;;
- NSR-?:NONSTOP_KERNEL:*:*)
- echo nsr-tandem-nsk${UNAME_RELEASE}
- exit ;;
- *:NonStop-UX:*:*)
- echo mips-compaq-nonstopux
- exit ;;
- BS2000:POSIX*:*:*)
- echo bs2000-siemens-sysv
- exit ;;
- DS/*:UNIX_System_V:*:*)
- echo ${UNAME_MACHINE}-${UNAME_SYSTEM}-${UNAME_RELEASE}
- exit ;;
- *:Plan9:*:*)
- # "uname -m" is not consistent, so use $cputype instead. 386
- # is converted to i386 for consistency with other x86
- # operating systems.
- if test "$cputype" = "386"; then
- UNAME_MACHINE=i386
- else
- UNAME_MACHINE="$cputype"
- fi
- echo ${UNAME_MACHINE}-unknown-plan9
- exit ;;
- *:TOPS-10:*:*)
- echo pdp10-unknown-tops10
- exit ;;
- *:TENEX:*:*)
- echo pdp10-unknown-tenex
- exit ;;
- KS10:TOPS-20:*:* | KL10:TOPS-20:*:* | TYPE4:TOPS-20:*:*)
- echo pdp10-dec-tops20
- exit ;;
- XKL-1:TOPS-20:*:* | TYPE5:TOPS-20:*:*)
- echo pdp10-xkl-tops20
- exit ;;
- *:TOPS-20:*:*)
- echo pdp10-unknown-tops20
- exit ;;
- *:ITS:*:*)
- echo pdp10-unknown-its
- exit ;;
- SEI:*:*:SEIUX)
- echo mips-sei-seiux${UNAME_RELEASE}
- exit ;;
- *:DragonFly:*:*)
- echo ${UNAME_MACHINE}-unknown-dragonfly`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
- exit ;;
- *:*VMS:*:*)
- A*) echo alpha-dec-vms ; exit ;;
- I*) echo ia64-dec-vms ; exit ;;
- V*) echo vax-dec-vms ; exit ;;
- esac ;;
- *:XENIX:*:SysV)
- echo i386-pc-xenix
- exit ;;
- i*86:skyos:*:*)
- echo ${UNAME_MACHINE}-pc-skyos`echo ${UNAME_RELEASE}` | sed -e 's/ .*$//'
- exit ;;
-esac
-#echo '(No uname command or uname output not recognized.)' 1>&2
-#echo "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" 1>&2
-eval $set_cc_for_build
-cat >$dummy.c <<EOF
-#ifdef _SEQUENT_
-# include <sys/types.h>
-# include <sys/utsname.h>
-#endif
-main ()
-#if defined (sony)
-#if defined (MIPSEB)
- /* BFD wants "bsd" instead of "newsos". Perhaps BFD should be changed,
- I don't know.... */
- printf ("mips-sony-bsd\n"); exit (0);
-#else
-#include <sys/param.h>
- printf ("m68k-sony-newsos%s\n",
-#ifdef NEWSOS4
- "4"
-#else
-#endif
- ); exit (0);
-#endif
-#endif
-#if defined (__arm) && defined (__acorn) && defined (__unix)
- printf ("arm-acorn-riscix\n"); exit (0);
-#endif
-#if defined (hp300) && !defined (hpux)
- printf ("m68k-hp-bsd\n"); exit (0);
-#endif
-#if defined (NeXT)
-#if !defined (__ARCHITECTURE__)
-#define __ARCHITECTURE__ "m68k"
-#endif
- int version;
- version=`(hostinfo | sed -n 's/.*NeXT Mach \([0-9]*\).*/\1/p') 2>/dev/null`;
- if (version < 4)
- printf ("%s-next-nextstep%d\n", __ARCHITECTURE__, version);
- else
- printf ("%s-next-openstep%d\n", __ARCHITECTURE__, version);
- exit (0);
-#endif
-#if defined (MULTIMAX) || defined (n16)
-#if defined (UMAXV)
- printf ("ns32k-encore-sysv\n"); exit (0);
-#else
-#if defined (CMU)
- printf ("ns32k-encore-mach\n"); exit (0);
-#else
- printf ("ns32k-encore-bsd\n"); exit (0);
-#endif
-#endif
-#endif
-#if defined (__386BSD__)
- printf ("i386-pc-bsd\n"); exit (0);
-#endif
-#if defined (sequent)
-#if defined (i386)
- printf ("i386-sequent-dynix\n"); exit (0);
-#endif
-#if defined (ns32000)
- printf ("ns32k-sequent-dynix\n"); exit (0);
-#endif
-#endif
-#if defined (_SEQUENT_)
- struct utsname un;
- uname(&un);
- if (strncmp(un.version, "V2", 2) == 0) {
- printf ("i386-sequent-ptx2\n"); exit (0);
- if (strncmp(un.version, "V1", 2) == 0) { /* XXX is V1 correct? */
- printf ("i386-sequent-ptx1\n"); exit (0);
- printf ("i386-sequent-ptx\n"); exit (0);
-#endif
-#if defined (vax)
-# if !defined (ultrix)
-# include <sys/param.h>
-# if defined (BSD)
-# if BSD == 43
- printf ("vax-dec-bsd4.3\n"); exit (0);
-# else
-# if BSD == 199006
- printf ("vax-dec-bsd4.3reno\n"); exit (0);
-# else
- printf ("vax-dec-bsd\n"); exit (0);
-# endif
-# endif
-# else
-# endif
-# else
- printf ("vax-dec-ultrix\n"); exit (0);
-# endif
-#endif
-#if defined (alliant) && defined (i860)
- printf ("i860-alliant-bsd\n"); exit (0);
-#endif
- exit (1);
-EOF
-$CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null && SYSTEM_NAME=`$dummy` &&
-# Apollos put the system type in the environment.
-test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit; }
-# Convex versions that predate uname can use getsysinfo(1)
-if [ -x /usr/convex/getsysinfo ]
-then
- case `getsysinfo -f cpu_type` in
- c1*)
- exit ;;
- c2*)
- fi
- exit ;;
- c34*)
- exit ;;
- c38*)
- exit ;;
- c4*)
- exit ;;
- esac
-fi
-cat >&2 <<EOF
-$0: unable to guess system type
-This script, last modified $timestamp, has failed to recognize
-the operating system you are using. It is advised that you
-download the most up to date version of the config scripts from
- http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.guess
-and
- http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.sub
-If the version you run ($0) is already up to date, please
-send the following data and any information you think might be
-pertinent to <config-patches at gnu.org> in order to provide the needed
-information to handle your system.
-config.guess timestamp = $timestamp
-uname -m = `(uname -m) 2>/dev/null || echo unknown`
-uname -r = `(uname -r) 2>/dev/null || echo unknown`
-uname -s = `(uname -s) 2>/dev/null || echo unknown`
-uname -v = `(uname -v) 2>/dev/null || echo unknown`
-/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null`
-/bin/uname -X = `(/bin/uname -X) 2>/dev/null`
-hostinfo = `(hostinfo) 2>/dev/null`
-/bin/universe = `(/bin/universe) 2>/dev/null`
-/usr/bin/arch -k = `(/usr/bin/arch -k) 2>/dev/null`
-/bin/arch = `(/bin/arch) 2>/dev/null`
-/usr/bin/oslevel = `(/usr/bin/oslevel) 2>/dev/null`
-/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null`
-UNAME_MACHINE = ${UNAME_MACHINE}
-UNAME_RELEASE = ${UNAME_RELEASE}
-UNAME_SYSTEM = ${UNAME_SYSTEM}
-UNAME_VERSION = ${UNAME_VERSION}
-EOF
-exit 1
-# Local variables:
-# eval: (add-hook 'write-file-hooks 'time-stamp)
-# time-stamp-start: "timestamp='"
-# time-stamp-format: "%:y-%02m-%02d"
-# time-stamp-end: "'"
-# End:
Deleted: trunk/MgDev/config.sub
--- trunk/MgDev/config.sub 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/config.sub 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,1580 +0,0 @@
-#! /bin/sh
-# Configuration validation subroutine script.
-timestamp='2005-07-08'
-# This file is (in principle) common to ALL GNU software.
-# The presence of a machine in this file suggests that SOME GNU software
-# can handle that machine. It does not imply ALL GNU software can.
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# 02110-1301, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# Configuration subroutine to validate and canonicalize a configuration type.
-# Supply the specified configuration type as an argument.
-# If it is invalid, we print an error message on stderr and exit with code 1.
-# Otherwise, we print the canonical config type on stdout and succeed.
-# This file is supposed to be the same for all GNU packages
-# and recognize all the CPU types, system types and aliases
-# that are meaningful with *any* GNU software.
-# Each package is responsible for reporting which valid configurations
-# it does not support. The user should be able to distinguish
-# a failure to support a valid configuration from a meaningless
-# configuration.
-# The goal of this file is to map all the various variations of a given
-# machine specification into a single specification in the form:
-# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM
-# or in some cases, the newer four-part form:
-# CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM
-# It is wrong to echo any other type of specification.
-usage="\
-Usage: $0 [OPTION] CPU-MFR-OPSYS
- $0 [OPTION] ALIAS
-Canonicalize a configuration name.
-Operation modes:
-version="\
-GNU config.sub ($timestamp)
-help="
- case $1 in
- --version | -v )
- shift; break ;;
- break ;;
- exit 1 ;;
- *local*)
- # First pass through any local machine types.
- echo $1
- exit ;;
- break ;;
- esac
-done
-case $# in
- 0) echo "$me: missing argument$help" >&2
- exit 1;;
- 1) ;;
- *) echo "$me: too many arguments$help" >&2
- exit 1;;
-esac
-# Separate what the user gave into CPU-COMPANY and OS or KERNEL-OS (if any).
-# Here we must recognize all the valid KERNEL-OS combinations.
-maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
-case $maybe_os in
- nto-qnx* | linux-gnu* | linux-dietlibc | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | \
- kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | storm-chaos* | os2-emx* | rtmk-nova*)
- os=-$maybe_os
- basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
- basic_machine=`echo $1 | sed 's/-[^-]*$//'`
- if [ $basic_machine != $1 ]
- then os=`echo $1 | sed 's/.*-/-/'`
- else os=; fi
-esac
-### Let's recognize common machines as not being operating systems so
-### that things like config.sub decstation-3100 work. We also
-### recognize some manufacturers as not being operating systems, so we
-### can provide default operating systems below.
-case $os in
- -sun*os*)
- # Prevent following clause from handling this invalid input.
- -dec* | -mips* | -sequent* | -encore* | -pc532* | -sgi* | -sony* | \
- -att* | -7300* | -3300* | -delta* | -motorola* | -sun[234]* | \
- -unicom* | -ibm* | -next | -hp | -isi* | -apollo | -altos* | \
- -convergent* | -ncr* | -news | -32* | -3600* | -3100* | -hitachi* |\
- -c[123]* | -convex* | -sun | -crds | -omron* | -dg | -ultra | -tti* | \
- -harris | -dolphin | -highlevel | -gould | -cbm | -ns | -masscomp | \
- -apple | -axis | -knuth | -cray)
- os=
- basic_machine=$1
- -sim | -cisco | -oki | -wec | -winbond)
- os=
- basic_machine=$1
- -scout)
- -wrs)
- os=-vxworks
- basic_machine=$1
- -chorusos*)
- os=-chorusos
- basic_machine=$1
- -chorusrdb)
- os=-chorusrdb
- basic_machine=$1
- -hiux*)
- os=-hiuxwe2
- -sco5)
- os=-sco3.2v5
- basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
- -sco4)
- os=-sco3.2v4
- -sco3.2.[4-9]*)
- os=`echo $os | sed -e 's/sco3.2./sco3.2v/'`
- -sco3.2v[4-9]*)
- # Don't forget version if it is 3.2v4 or newer.
- -sco*)
- os=-sco3.2v2
- -udk*)
- -isc)
- os=-isc2.2
- -clix*)
- basic_machine=clipper-intergraph
- -isc*)
- -lynx*)
- os=-lynxos
- -ptx*)
- basic_machine=`echo $1 | sed -e 's/86-.*/86-sequent/'`
- -windowsnt*)
- os=`echo $os | sed -e 's/windowsnt/winnt/'`
- -psos*)
- os=-psos
- -mint | -mint[0-9]*)
- basic_machine=m68k-atari
- os=-mint
-esac
-# Decode aliases for certain CPU-COMPANY combinations.
-case $basic_machine in
- # Recognize the basic CPU types without company name.
- # Some are omitted here because they have special meanings below.
- 1750a | 580 \
- | a29k \
- | alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
- | alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
- | am33_2.0 \
- | arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr \
- | bfin \
- | c4x | clipper \
- | d10v | d30v | dlx | dsp16xx \
- | fr30 | frv \
- | h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
- | i370 | i860 | i960 | ia64 \
- | ip2k | iq2000 \
- | m32r | m32rle | m68000 | m68k | m88k | maxq | mcore \
- | mips | mipsbe | mipseb | mipsel | mipsle \
- | mips16 \
- | mips64 | mips64el \
- | mips64vr | mips64vrel \
- | mips64orion | mips64orionel \
- | mips64vr4100 | mips64vr4100el \
- | mips64vr4300 | mips64vr4300el \
- | mips64vr5000 | mips64vr5000el \
- | mips64vr5900 | mips64vr5900el \
- | mipsisa32 | mipsisa32el \
- | mipsisa32r2 | mipsisa32r2el \
- | mipsisa64 | mipsisa64el \
- | mipsisa64r2 | mipsisa64r2el \
- | mipsisa64sb1 | mipsisa64sb1el \
- | mipsisa64sr71k | mipsisa64sr71kel \
- | mipstx39 | mipstx39el \
- | mn10200 | mn10300 \
- | ms1 \
- | msp430 \
- | ns16k | ns32k \
- | or32 \
- | pdp10 | pdp11 | pj | pjl \
- | powerpc | powerpc64 | powerpc64le | powerpcle | ppcbe \
- | pyramid \
- | sh | sh[1234] | sh[24]a | sh[23]e | sh[34]eb | shbe | shle | sh[1234]le | sh3ele \
- | sh64 | sh64le \
- | sparc | sparc64 | sparc64b | sparc86x | sparclet | sparclite \
- | sparcv8 | sparcv9 | sparcv9b \
- | strongarm \
- | tahoe | thumb | tic4x | tic80 | tron \
- | v850 | v850e \
- | we32k \
- | x86 | xscale | xscalee[bl] | xstormy16 | xtensa \
- | z8k)
- basic_machine=$basic_machine-unknown
- m32c)
- m6811 | m68hc11 | m6812 | m68hc12)
- # Motorola 68HC11/12.
- os=-none
- m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
- # We use `pc' rather than `unknown'
- # because (1) that's what they normally are, and
- # (2) the word "unknown" tends to confuse beginning users.
- i*86 | x86_64)
- basic_machine=$basic_machine-pc
- # Object if more than one company name word.
- echo Invalid configuration \`$1\': machine \`$basic_machine\' not recognized 1>&2
- exit 1
- # Recognize the basic CPU types with company name.
- 580-* \
- | a29k-* \
- | alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
- | alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
- | alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
- | arm-* | armbe-* | armle-* | armeb-* | armv*-* \
- | avr-* \
- | bfin-* | bs2000-* \
- | c[123]* | c30-* | [cjt]90-* | c4x-* | c54x-* | c55x-* | c6x-* \
- | clipper-* | craynv-* | cydra-* \
- | d10v-* | d30v-* | dlx-* \
- | elxsi-* \
- | f30[01]-* | f700-* | fr30-* | frv-* | fx80-* \
- | h8300-* | h8500-* \
- | hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
- | i*86-* | i860-* | i960-* | ia64-* \
- | ip2k-* | iq2000-* \
- | m32r-* | m32rle-* \
- | m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
- | m88110-* | m88k-* | maxq-* | mcore-* \
- | mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
- | mips16-* \
- | mips64-* | mips64el-* \
- | mips64vr-* | mips64vrel-* \
- | mips64orion-* | mips64orionel-* \
- | mips64vr4100-* | mips64vr4100el-* \
- | mips64vr4300-* | mips64vr4300el-* \
- | mips64vr5000-* | mips64vr5000el-* \
- | mips64vr5900-* | mips64vr5900el-* \
- | mipsisa32-* | mipsisa32el-* \
- | mipsisa32r2-* | mipsisa32r2el-* \
- | mipsisa64-* | mipsisa64el-* \
- | mipsisa64r2-* | mipsisa64r2el-* \
- | mipsisa64sb1-* | mipsisa64sb1el-* \
- | mipsisa64sr71k-* | mipsisa64sr71kel-* \
- | mipstx39-* | mipstx39el-* \
- | mmix-* \
- | ms1-* \
- | msp430-* \
- | none-* | np1-* | ns16k-* | ns32k-* \
- | orion-* \
- | pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
- | powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* | ppcbe-* \
- | pyramid-* \
- | romp-* | rs6000-* \
- | sh-* | sh[1234]-* | sh[24]a-* | sh[23]e-* | sh[34]eb-* | shbe-* \
- | shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
- | sparc-* | sparc64-* | sparc64b-* | sparc86x-* | sparclet-* \
- | sparclite-* \
- | sparcv8-* | sparcv9-* | sparcv9b-* | strongarm-* | sv1-* | sx?-* \
- | tahoe-* | thumb-* \
- | tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* \
- | tron-* \
- | v850-* | v850e-* | vax-* \
- | we32k-* \
- | x86-* | x86_64-* | xps100-* | xscale-* | xscalee[bl]-* \
- | xstormy16-* | xtensa-* \
- | ymp-* \
- | z8k-*)
- m32c-*)
- # Recognize the various machine names and aliases which stand
- # for a CPU type and a company and sometimes even an OS.
- 386bsd)
- basic_machine=i386-unknown
- os=-bsd
- 3b1 | 7300 | 7300-att | att-7300 | pc7300 | safari | unixpc)
- basic_machine=m68000-att
- 3b*)
- basic_machine=we32k-att
- a29khif)
- basic_machine=a29k-amd
- os=-udi
- abacus)
- basic_machine=abacus-unknown
- adobe68k)
- basic_machine=m68010-adobe
- os=-scout
- alliant | fx80)
- basic_machine=fx80-alliant
- altos | altos3068)
- basic_machine=m68k-altos
- am29k)
- basic_machine=a29k-none
- os=-bsd
- amd64)
- basic_machine=x86_64-pc
- amd64-*)
- basic_machine=x86_64-`echo $basic_machine | sed 's/^[^-]*-//'`
- amdahl)
- basic_machine=580-amdahl
- os=-sysv
- amiga | amiga-*)
- basic_machine=m68k-unknown
- amigaos | amigados)
- os=-amigaos
- amigaunix | amix)
- os=-sysv4
- apollo68)
- basic_machine=m68k-apollo
- os=-sysv
- apollo68bsd)
- os=-bsd
- aux)
- basic_machine=m68k-apple
- os=-aux
- balance)
- basic_machine=ns32k-sequent
- os=-dynix
- c90)
- basic_machine=c90-cray
- os=-unicos
- convex-c1)
- basic_machine=c1-convex
- os=-bsd
- convex-c2)
- basic_machine=c2-convex
- os=-bsd
- convex-c32)
- basic_machine=c32-convex
- os=-bsd
- convex-c34)
- basic_machine=c34-convex
- os=-bsd
- convex-c38)
- basic_machine=c38-convex
- os=-bsd
- cray | j90)
- basic_machine=j90-cray
- os=-unicos
- craynv)
- basic_machine=craynv-cray
- os=-unicosmp
- cr16c)
- basic_machine=cr16c-unknown
- os=-elf
- crds | unos)
- basic_machine=m68k-crds
- crisv32 | crisv32-* | etraxfs*)
- basic_machine=crisv32-axis
- cris | cris-* | etrax*)
- basic_machine=cris-axis
- crx)
- basic_machine=crx-unknown
- os=-elf
- da30 | da30-*)
- basic_machine=m68k-da30
- decstation | decstation-3100 | pmax | pmax-* | pmin | dec3100 | decstatn)
- basic_machine=mips-dec
- decsystem10* | dec10*)
- basic_machine=pdp10-dec
- os=-tops10
- decsystem20* | dec20*)
- os=-tops20
- delta | 3300 | motorola-3300 | motorola-delta \
- | 3300-motorola | delta-motorola)
- basic_machine=m68k-motorola
- delta88)
- basic_machine=m88k-motorola
- os=-sysv3
- djgpp)
- basic_machine=i586-pc
- os=-msdosdjgpp
- dpx20 | dpx20-*)
- basic_machine=rs6000-bull
- os=-bosx
- dpx2* | dpx2*-bull)
- basic_machine=m68k-bull
- os=-sysv3
- ebmon29k)
- os=-ebmon
- elxsi)
- basic_machine=elxsi-elxsi
- os=-bsd
- encore | umax | mmax)
- basic_machine=ns32k-encore
- es1800 | OSE68k | ose68k | ose | OSE)
- basic_machine=m68k-ericsson
- os=-ose
- fx2800)
- basic_machine=i860-alliant
- genix)
- basic_machine=ns32k-ns
- gmicro)
- basic_machine=tron-gmicro
- os=-sysv
- go32)
- basic_machine=i386-pc
- os=-go32
- h3050r* | hiux*)
- basic_machine=hppa1.1-hitachi
- os=-hiuxwe2
- h8300hms)
- basic_machine=h8300-hitachi
- os=-hms
- h8300xray)
- os=-xray
- h8500hms)
- basic_machine=h8500-hitachi
- os=-hms
- harris)
- basic_machine=m88k-harris
- os=-sysv3
- hp300-*)
- basic_machine=m68k-hp
- hp300bsd)
- os=-bsd
- hp300hpux)
- os=-hpux
- hp3k9[0-9][0-9] | hp9[0-9][0-9])
- basic_machine=hppa1.0-hp
- hp9k2[0-9][0-9] | hp9k31[0-9])
- basic_machine=m68000-hp
- hp9k3[2-9][0-9])
- hp9k6[0-9][0-9] | hp6[0-9][0-9])
- hp9k7[0-79][0-9] | hp7[0-79][0-9])
- basic_machine=hppa1.1-hp
- hp9k78[0-9] | hp78[0-9])
- # FIXME: really hppa2.0-hp
- hp9k8[67]1 | hp8[67]1 | hp9k80[24] | hp80[24] | hp9k8[78]9 | hp8[78]9 | hp9k893 | hp893)
- hp9k8[0-9][13679] | hp8[0-9][13679])
- hp9k8[0-9][0-9] | hp8[0-9][0-9])
- hppa-next)
- os=-nextstep3
- hppaosf)
- os=-osf
- hppro)
- os=-proelf
- i370-ibm* | ibm*)
- basic_machine=i370-ibm
-# I'm not sure what "Sysv32" means. Should this be sysv3.2?
- i*86v32)
- basic_machine=`echo $1 | sed -e 's/86.*/86-pc/'`
- os=-sysv32
- i*86v4*)
- os=-sysv4
- i*86v)
- os=-sysv
- i*86sol2)
- os=-solaris2
- i386mach)
- basic_machine=i386-mach
- os=-mach
- i386-vsta | vsta)
- os=-vsta
- iris | iris4d)
- basic_machine=mips-sgi
- case $os in
- -irix*)
- os=-irix4
- esac
- isi68 | isi)
- basic_machine=m68k-isi
- os=-sysv
- m88k-omron*)
- basic_machine=m88k-omron
- magnum | m3230)
- basic_machine=mips-mips
- os=-sysv
- merlin)
- basic_machine=ns32k-utek
- os=-sysv
- mingw32)
- os=-mingw32
- miniframe)
- basic_machine=m68000-convergent
- *mint | -mint[0-9]* | *MiNT | *MiNT[0-9]*)
- os=-mint
- mips3*-*)
- basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`
- mips3*)
- basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`-unknown
- monitor)
- basic_machine=m68k-rom68k
- os=-coff
- morphos)
- basic_machine=powerpc-unknown
- os=-morphos
- msdos)
- os=-msdos
- mvs)
- os=-mvs
- ncr3000)
- basic_machine=i486-ncr
- os=-sysv4
- netbsd386)
- os=-netbsd
- netwinder)
- basic_machine=armv4l-rebel
- os=-linux
- news | news700 | news800 | news900)
- basic_machine=m68k-sony
- os=-newsos
- news1000)
- basic_machine=m68030-sony
- os=-newsos
- news-3600 | risc-news)
- basic_machine=mips-sony
- os=-newsos
- necv70)
- basic_machine=v70-nec
- os=-sysv
- next | m*-next )
- basic_machine=m68k-next
- case $os in
- -nextstep* )
- -ns2*)
- os=-nextstep2
- os=-nextstep3
- esac
- nh3000)
- basic_machine=m68k-harris
- os=-cxux
- nh[45]000)
- os=-cxux
- nindy960)
- basic_machine=i960-intel
- os=-nindy
- mon960)
- os=-mon960
- nonstopux)
- basic_machine=mips-compaq
- os=-nonstopux
- np1)
- basic_machine=np1-gould
- nsr-tandem)
- basic_machine=nsr-tandem
- op50n-* | op60c-*)
- basic_machine=hppa1.1-oki
- os=-proelf
- openrisc | openrisc-*)
- basic_machine=or32-unknown
- os400)
- basic_machine=powerpc-ibm
- os=-os400
- OSE68000 | ose68000)
- basic_machine=m68000-ericsson
- os=-ose
- os68k)
- basic_machine=m68k-none
- os=-os68k
- pa-hitachi)
- os=-hiuxwe2
- paragon)
- basic_machine=i860-intel
- os=-osf
- pbd)
- basic_machine=sparc-tti
- pbb)
- basic_machine=m68k-tti
- pc532 | pc532-*)
- basic_machine=ns32k-pc532
- pentium | p5 | k5 | k6 | nexgen | viac3)
- pentiumpro | p6 | 6x86 | athlon | athlon_*)
- basic_machine=i686-pc
- pentiumii | pentium2 | pentiumiii | pentium3)
- pentium4)
- basic_machine=i786-pc
- pentium-* | p5-* | k5-* | k6-* | nexgen-* | viac3-*)
- basic_machine=i586-`echo $basic_machine | sed 's/^[^-]*-//'`
- pentiumpro-* | p6-* | 6x86-* | athlon-*)
- basic_machine=i686-`echo $basic_machine | sed 's/^[^-]*-//'`
- pentiumii-* | pentium2-* | pentiumiii-* | pentium3-*)
- pentium4-*)
- basic_machine=i786-`echo $basic_machine | sed 's/^[^-]*-//'`
- pn)
- basic_machine=pn-gould
- power) basic_machine=power-ibm
- ppc) basic_machine=powerpc-unknown
- ppc-*) basic_machine=powerpc-`echo $basic_machine | sed 's/^[^-]*-//'`
- ppcle | powerpclittle | ppc-le | powerpc-little)
- basic_machine=powerpcle-unknown
- ppcle-* | powerpclittle-*)
- basic_machine=powerpcle-`echo $basic_machine | sed 's/^[^-]*-//'`
- ppc64) basic_machine=powerpc64-unknown
- ppc64-*) basic_machine=powerpc64-`echo $basic_machine | sed 's/^[^-]*-//'`
- ppc64le | powerpc64little | ppc64-le | powerpc64-little)
- basic_machine=powerpc64le-unknown
- ppc64le-* | powerpc64little-*)
- basic_machine=powerpc64le-`echo $basic_machine | sed 's/^[^-]*-//'`
- ps2)
- basic_machine=i386-ibm
- pw32)
- basic_machine=i586-unknown
- os=-pw32
- rom68k)
- os=-coff
- rm[46]00)
- basic_machine=mips-siemens
- rtpc | rtpc-*)
- basic_machine=romp-ibm
- s390 | s390-*)
- basic_machine=s390-ibm
- s390x | s390x-*)
- basic_machine=s390x-ibm
- sa29200)
- os=-udi
- sb1)
- basic_machine=mipsisa64sb1-unknown
- sb1el)
- basic_machine=mipsisa64sb1el-unknown
- sei)
- basic_machine=mips-sei
- os=-seiux
- sequent)
- basic_machine=i386-sequent
- sh)
- basic_machine=sh-hitachi
- os=-hms
- sh64)
- basic_machine=sh64-unknown
- sparclite-wrs | simso-wrs)
- basic_machine=sparclite-wrs
- os=-vxworks
- sps7)
- os=-sysv2
- spur)
- basic_machine=spur-unknown
- st2000)
- basic_machine=m68k-tandem
- stratus)
- basic_machine=i860-stratus
- os=-sysv4
- sun2)
- basic_machine=m68000-sun
- sun2os3)
- os=-sunos3
- sun2os4)
- os=-sunos4
- sun3os3)
- basic_machine=m68k-sun
- os=-sunos3
- sun3os4)
- os=-sunos4
- sun4os3)
- basic_machine=sparc-sun
- os=-sunos3
- sun4os4)
- os=-sunos4
- sun4sol2)
- os=-solaris2
- sun3 | sun3-*)
- sun4)
- sun386 | sun386i | roadrunner)
- basic_machine=i386-sun
- sv1)
- basic_machine=sv1-cray
- os=-unicos
- symmetry)
- os=-dynix
- t3e)
- basic_machine=alphaev5-cray
- os=-unicos
- t90)
- basic_machine=t90-cray
- os=-unicos
- tic54x | c54x*)
- basic_machine=tic54x-unknown
- os=-coff
- tic55x | c55x*)
- basic_machine=tic55x-unknown
- os=-coff
- tic6x | c6x*)
- basic_machine=tic6x-unknown
- os=-coff
- tx39)
- basic_machine=mipstx39-unknown
- tx39el)
- basic_machine=mipstx39el-unknown
- toad1)
- basic_machine=pdp10-xkl
- os=-tops20
- tower | tower-32)
- basic_machine=m68k-ncr
- tpf)
- os=-tpf
- udi29k)
- os=-udi
- ultra3)
- basic_machine=a29k-nyu
- os=-sym1
- v810 | necv810)
- basic_machine=v810-nec
- os=-none
- vaxv)
- basic_machine=vax-dec
- os=-sysv
- vms)
- os=-vms
- vpp*|vx|vx-*)
- basic_machine=f301-fujitsu
- vxworks960)
- basic_machine=i960-wrs
- os=-vxworks
- vxworks68)
- basic_machine=m68k-wrs
- os=-vxworks
- vxworks29k)
- basic_machine=a29k-wrs
- os=-vxworks
- w65*)
- basic_machine=w65-wdc
- os=-none
- w89k-*)
- basic_machine=hppa1.1-winbond
- os=-proelf
- xbox)
- os=-mingw32
- xps | xps100)
- basic_machine=xps100-honeywell
- ymp)
- basic_machine=ymp-cray
- os=-unicos
- z8k-*-coff)
- basic_machine=z8k-unknown
- os=-sim
- none)
- basic_machine=none-none
- os=-none
-# Here we handle the default manufacturer of certain CPU types. It is in
-# some cases the only manufacturer, in others, it is the most popular.
- w89k)
- op50n)
- op60c)
- romp)
- mmix)
- basic_machine=mmix-knuth
- rs6000)
- basic_machine=rs6000-ibm
- vax)
- pdp10)
- # there are many clones, so DEC is not a safe bet
- basic_machine=pdp10-unknown
- pdp11)
- basic_machine=pdp11-dec
- we32k)
- sh[1234] | sh[24]a | sh[34]eb | sh[1234]le | sh[23]ele)
- basic_machine=sh-unknown
- sparc | sparcv8 | sparcv9 | sparcv9b)
- cydra)
- basic_machine=cydra-cydrome
- orion)
- basic_machine=orion-highlevel
- orion105)
- basic_machine=clipper-highlevel
- mac | mpw | mac-mpw)
- pmac | pmac-mpw)
- basic_machine=powerpc-apple
- *-unknown)
- # Make sure to match an already-canonicalized machine name.
- exit 1
-esac
-# Here we canonicalize certain aliases for manufacturers.
- *-digital*)
- basic_machine=`echo $basic_machine | sed 's/digital.*/dec/'`
- *-commodore*)
- basic_machine=`echo $basic_machine | sed 's/commodore.*/cbm/'`
-esac
-# Decode manufacturer-specific aliases for certain operating systems.
-if [ x"$os" != x"" ]
-then
-case $os in
- # First match some system type aliases
- # that might get confused with valid system types.
- # -solaris* is a basic system type, with this one exception.
- -solaris1 | -solaris1.*)
- os=`echo $os | sed -e 's|solaris1|sunos4|'`
- -solaris)
- os=-solaris2
- -svr4*)
- os=-sysv4
- -unixware*)
- os=-sysv4.2uw
- -gnu/linux*)
- os=`echo $os | sed -e 's|gnu/linux|linux-gnu|'`
- # First accept the basic system types.
- # The portable systems comes first.
- # Each alternative MUST END IN A *, to match a version number.
- # -sysv* is not here because it comes later, after sysvr4.
- -gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
- | -*vms* | -sco* | -esix* | -isc* | -aix* | -sunos | -sunos[34]*\
- | -hpux* | -unos* | -osf* | -luna* | -dgux* | -solaris* | -sym* \
- | -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
- | -aos* \
- | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
- | -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
- | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* | -openbsd* \
- | -ekkobsd* | -kfreebsd* | -freebsd* | -riscix* | -lynxos* \
- | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
- | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
- | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
- | -chorusos* | -chorusrdb* \
- | -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
- | -mingw32* | -linux-gnu* | -linux-uclibc* | -uxpv* | -beos* | -mpeix* | -udk* \
- | -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
- | -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
- | -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
- | -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
- | -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
- | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
- | -skyos* | -haiku*)
- # Remember, each alternative MUST END IN *, to match a version number.
- -qnx*)
- case $basic_machine in
- x86-* | i*86-*)
- os=-nto$os
- esac
- -nto-qnx*)
- -nto*)
- os=`echo $os | sed -e 's|nto|nto-qnx|'`
- -sim | -es1800* | -hms* | -xray | -os68k* | -none* | -v88r* \
- | -windows* | -osx | -abug | -netware* | -os9* | -beos* | -haiku* \
- | -macos* | -mpw* | -magic* | -mmixware* | -mon960* | -lnews*)
- -mac*)
- os=`echo $os | sed -e 's|mac|macos|'`
- -linux-dietlibc)
- os=-linux-dietlibc
- -linux*)
- os=`echo $os | sed -e 's|linux|linux-gnu|'`
- -sunos5*)
- os=`echo $os | sed -e 's|sunos5|solaris2|'`
- -sunos6*)
- os=`echo $os | sed -e 's|sunos6|solaris3|'`
- -opened*)
- os=-openedition
- -os400*)
- os=-os400
- -wince*)
- os=-wince
- -osfrose*)
- os=-osfrose
- -osf*)
- os=-osf
- -utek*)
- os=-bsd
- -dynix*)
- os=-bsd
- -acis*)
- os=-aos
- -atheos*)
- os=-atheos
- -syllable*)
- os=-syllable
- -386bsd)
- os=-bsd
- -ctix* | -uts*)
- os=-sysv
- -nova*)
- os=-rtmk-nova
- -ns2 )
- os=-nextstep2
- -nsk*)
- os=-nsk
- # Preserve the version number of sinix5.
- -sinix5.*)
- os=`echo $os | sed -e 's|sinix|sysv|'`
- -sinix*)
- os=-sysv4
- -tpf*)
- os=-tpf
- -triton*)
- os=-sysv3
- -oss*)
- os=-sysv3
- -svr4)
- os=-sysv4
- -svr3)
- os=-sysv3
- -sysvr4)
- os=-sysv4
- # This must come after -sysvr4.
- -sysv*)
- -ose*)
- os=-ose
- -es1800*)
- os=-ose
- -xenix)
- os=-xenix
- -*mint | -mint[0-9]* | -*MiNT | -MiNT[0-9]*)
- os=-mint
- -aros*)
- os=-aros
- -kaos*)
- os=-kaos
- -zvmoe)
- os=-zvmoe
- -none)
- # Get rid of the `-' at the beginning of $os.
- os=`echo $os | sed 's/[^-]*-//'`
- echo Invalid configuration \`$1\': system \`$os\' not recognized 1>&2
- exit 1
-esac
-else
-# Here we handle the default operating systems that come with various machines.
-# The value should be what the vendor currently ships out the door with their
-# machine or put another way, the most popular os provided with the machine.
-# Note that if you're going to try to match "-MANUFACTURER" here (say,
-# "-sun"), then you have to tell the case statement up towards the top
-# that MANUFACTURER isn't an operating system. Otherwise, code above
-# will signal an error saying that MANUFACTURER isn't an operating
-# system, and we'll never get to this point.
- *-acorn)
- os=-riscix1.2
- arm*-rebel)
- os=-linux
- arm*-semi)
- os=-aout
- c4x-* | tic4x-*)
- os=-coff
- # This must come before the *-dec entry.
- pdp10-*)
- os=-tops20
- pdp11-*)
- os=-none
- *-dec | vax-*)
- os=-ultrix4.2
- m68*-apollo)
- os=-domain
- i386-sun)
- os=-sunos4.0.2
- m68000-sun)
- os=-sunos3
- # This also exists in the configure program, but was not the
- # default.
- # os=-sunos4
- m68*-cisco)
- os=-aout
- mips*-cisco)
- os=-elf
- mips*-*)
- os=-elf
- or32-*)
- os=-coff
- *-tti) # must be before sparc entry or we get the wrong os.
- os=-sysv3
- sparc-* | *-sun)
- os=-sunos4.1.1
- *-be)
- os=-beos
- *-haiku)
- os=-haiku
- *-ibm)
- os=-aix
- *-knuth)
- os=-mmixware
- *-wec)
- os=-proelf
- *-winbond)
- os=-proelf
- *-oki)
- os=-proelf
- *-hp)
- os=-hpux
- *-hitachi)
- os=-hiux
- i860-* | *-att | *-ncr | *-altos | *-motorola | *-convergent)
- os=-sysv
- *-cbm)
- os=-amigaos
- *-dg)
- os=-dgux
- *-dolphin)
- os=-sysv3
- m68k-ccur)
- os=-rtu
- m88k-omron*)
- os=-luna
- *-next )
- os=-nextstep
- *-sequent)
- os=-ptx
- *-crds)
- os=-unos
- *-ns)
- os=-genix
- i370-*)
- os=-mvs
- *-next)
- os=-nextstep3
- *-gould)
- os=-sysv
- *-highlevel)
- os=-bsd
- *-encore)
- os=-bsd
- *-sgi)
- os=-irix
- *-siemens)
- os=-sysv4
- *-masscomp)
- os=-rtu
- f30[01]-fujitsu | f700-fujitsu)
- os=-uxpv
- *-rom68k)
- os=-coff
- *-*bug)
- os=-coff
- *-apple)
- os=-macos
- *-atari*)
- os=-mint
- os=-none
-esac
-fi
-# Here we handle the case where we know the os, and the CPU type, but not the
-# manufacturer. We pick the logical manufacturer.
-vendor=unknown
- *-unknown)
- case $os in
- -riscix*)
- vendor=acorn
- -sunos*)
- vendor=sun
- -aix*)
- vendor=ibm
- -beos*)
- vendor=be
- -hpux*)
- vendor=hp
- -mpeix*)
- vendor=hp
- -hiux*)
- vendor=hitachi
- -unos*)
- vendor=crds
- -dgux*)
- vendor=dg
- -luna*)
- vendor=omron
- -genix*)
- vendor=ns
- -mvs* | -opened*)
- vendor=ibm
- -os400*)
- vendor=ibm
- -ptx*)
- vendor=sequent
- -tpf*)
- vendor=ibm
- -vxsim* | -vxworks* | -windiss*)
- vendor=wrs
- -aux*)
- vendor=apple
- -hms*)
- vendor=hitachi
- -mpw* | -macos*)
- vendor=apple
- vendor=atari
- -vos*)
- vendor=stratus
- esac
- basic_machine=`echo $basic_machine | sed "s/unknown/$vendor/"`
-esac
-echo $basic_machine$os
-exit
-# Local variables:
-# End:
Deleted: trunk/MgDev/configure
--- trunk/MgDev/configure 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/configure 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,21535 +0,0 @@
-#! /bin/sh
-# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.59 for mapguide 2.0.0.
-# Report bugs to <http://mapguide.osgeo.org>.
-# Copyright (C) 2003 Free Software Foundation, Inc.
-# This configure script is free software; the Free Software Foundation
-# gives unlimited permission to copy, distribute and modify it.
-## M4sh Initialization. ##
-# Be Bourne compatible
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
- emulate sh
- NULLCMD=:
- # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '${1+"$@"}'='"$@"'
-elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
- set -o posix
-fi
-DUALCASE=1; export DUALCASE # for MKS sh
-# Support unset when possible.
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
- as_unset=unset
-else
- as_unset=false
-fi
-# Work around bugs in pre-3.0 UWIN ksh.
-$as_unset ENV MAIL MAILPATH
-PS1='$ '
-PS2='> '
-PS4='+ '
-# NLS nuisances.
-for as_var in \
- LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
- LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
- LC_TELEPHONE LC_TIME
-do
- if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
- eval $as_var=C; export $as_var
- else
- $as_unset $as_var
- fi
-done
-# Required to use basename.
-if expr a : '\(a\)' >/dev/null 2>&1; then
- as_expr=expr
-else
- as_expr=false
-fi
-if (basename /) >/dev/null 2>&1 && test "X`basename / 2>&1`" = "X/"; then
- as_basename=basename
-else
- as_basename=false
-fi
-# Name of the executable.
-as_me=`$as_basename "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)$' \| \
- . : '\(.\)' 2>/dev/null ||
-echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{ s//\1/; q; }
- /^X\/\(\/\/\)$/{ s//\1/; q; }
- /^X\/\(\/\).*/{ s//\1/; q; }
- s/.*/./; q'`
-# PATH needs CR, and LINENO needs CR and PATH.
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
-# The user is always right.
-if test "${PATH_SEPARATOR+set}" != set; then
- echo "#! /bin/sh" >conf$$.sh
- echo "exit 0" >>conf$$.sh
- chmod +x conf$$.sh
- if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
- PATH_SEPARATOR=';'
- else
- PATH_SEPARATOR=:
- fi
- rm -f conf$$.sh
-fi
- as_lineno_1=$LINENO
- as_lineno_2=$LINENO
- as_lineno_3=`(expr $as_lineno_1 + 1) 2>/dev/null`
- test "x$as_lineno_1" != "x$as_lineno_2" &&
- test "x$as_lineno_3" = "x$as_lineno_2" || {
- # Find who we are. Look in the path if we contain no path at all
- # relative or not.
- case $0 in
- *[\\/]* ) as_myself=$0 ;;
- *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
-done
- esac
- # We did not find ourselves, most probably we were run as `sh COMMAND'
- # in which case we are not to be found in the path.
- if test "x$as_myself" = x; then
- as_myself=$0
- fi
- if test ! -f "$as_myself"; then
- { echo "$as_me: error: cannot find myself; rerun with an absolute path" >&2
- { (exit 1); exit 1; }; }
- fi
- case $CONFIG_SHELL in
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
-do
- IFS=$as_save_IFS
- for as_base in sh bash ksh sh5; do
- case $as_dir in
- if ("$as_dir/$as_base" -c '
- test "x$as_lineno_3" = "x$as_lineno_2" ') 2>/dev/null; then
- $as_unset BASH_ENV || test "${BASH_ENV+set}" != set || { BASH_ENV=; export BASH_ENV; }
- $as_unset ENV || test "${ENV+set}" != set || { ENV=; export ENV; }
- CONFIG_SHELL=$as_dir/$as_base
- export CONFIG_SHELL
- exec "$CONFIG_SHELL" "$0" ${1+"$@"}
- fi;;
- esac
- done
-done
- esac
- # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
- # uniformly replaced by the line number. The first 'sed' inserts a
- # line-number line before each line; the second 'sed' does the real
- # work. The second script uses 'N' to pair each line-number line
- # with the numbered line, and appends trailing '-' during
- # substitution so that $LINENO is not a special case at line end.
- # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
- # second 'sed' script. Blame Lee E. McMahon for sed's syntax. :-)
- sed '=' <$as_myself |
- sed '
- N
- s,$,-,
- : loop
- s,^\(['$as_cr_digits']*\)\(.*\)[$]LINENO\([^'$as_cr_alnum'_]\),\1\2\1\3,
- t loop
- s,-$,,
- s,^['$as_cr_digits']*\n,,
- ' >$as_me.lineno &&
- chmod +x $as_me.lineno ||
- { echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
- # Don't try to exec as it changes $[0], causing all sort of problems
- # (the dirname of $[0] is not the place where we might find the
- # original and so on. Autoconf is especially sensible to this).
- . ./$as_me.lineno
- # Exit status is that of the last command.
- exit
-case `echo "testing\c"; echo 1,2,3`,`echo -n testing; echo 1,2,3` in
- *c*,-n*) ECHO_N= ECHO_C='
-' ECHO_T=' ' ;;
- *c*,* ) ECHO_N=-n ECHO_C= ECHO_T= ;;
- *) ECHO_N= ECHO_C='\c' ECHO_T= ;;
-esac
- as_expr=expr
-else
- as_expr=false
-fi
-rm -f conf$$ conf$$.exe conf$$.file
-echo >conf$$.file
-if ln -s conf$$.file conf$$ 2>/dev/null; then
- # We could just check for DJGPP; but this test a) works b) is more generic
- # and c) will remain valid once DJGPP supports symlinks (DJGPP 2.04).
- if test -f conf$$.exe; then
- # Don't use ln at all; we don't have any links
- as_ln_s='cp -p'
- else
- as_ln_s='ln -s'
- fi
-elif ln conf$$.file conf$$ 2>/dev/null; then
- as_ln_s=ln
-else
- as_ln_s='cp -p'
-fi
-if mkdir -p . 2>/dev/null; then
- as_mkdir_p=:
-else
- test -d ./-p && rmdir ./-p
- as_mkdir_p=false
-fi
-as_executable_p="test -f"
-# Sed expression to map a string onto a valid CPP name.
-as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
-# Sed expression to map a string onto a valid variable name.
-as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
-# IFS
-# We need space, tab and new line, in precisely that order.
-as_nl='
-IFS=" $as_nl"
-# CDPATH.
-$as_unset CDPATH
-# Check that we are running under the correct shell.
-SHELL=${CONFIG_SHELL-/bin/sh}
-case X$ECHO in
-X*--fallback-echo)
- # Remove one level of quotation (which was required for Make).
- ECHO=`echo "$ECHO" | sed 's,\\\\\$\\$0,'$0','`
-esac
-echo=${ECHO-echo}
-if test "X$1" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
-elif test "X$1" = X--fallback-echo; then
- # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t' ; then
- # Yippee, $echo works!
-else
- # Restart under the correct shell.
- exec $SHELL "$0" --no-reexec ${1+"$@"}
-fi
-if test "X$1" = X--fallback-echo; then
- # used as fallback echo
- shift
- cat <<EOF
-EOF
- exit 0
-fi
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test "X${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
-if test -z "$ECHO"; then
-if test "X${echo_test_string+set}" != Xset; then
-# find a string as large as possible, as long as the shell can cope with it
- for cmd in 'sed 50q "$0"' 'sed 20q "$0"' 'sed 10q "$0"' 'sed 2q "$0"' 'echo test'; do
- # expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
- if (echo_test_string="`eval $cmd`") 2>/dev/null &&
- echo_test_string="`eval $cmd`" &&
- (test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
- then
- break
- fi
- done
-fi
-if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($echo "$echo_test_string") 2>/dev/null` &&
- test "X$echo_testing_string" = "X$echo_test_string"; then
-else
- # The Solaris, AIX, and Digital Unix default echo programs unquote
- # backslashes. This makes it impossible to quote backslashes using
- # echo "$something" | sed 's/\\/\\\\/g'
- # So, first we look for a working echo in the user's PATH.
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for dir in $PATH /usr/ucb; do
- IFS="$lt_save_ifs"
- if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
- test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
- echo="$dir/echo"
- break
- fi
- done
- if test "X$echo" = Xecho; then
- # We didn't find a better echo, so look for alternatives.
- if test "X`(print -r '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`(print -r "$echo_test_string") 2>/dev/null` &&
- # This shell has a builtin print -r that does the trick.
- echo='print -r'
- elif (test -f /bin/ksh || test -f /bin/ksh$ac_exeext) &&
- test "X$CONFIG_SHELL" != X/bin/ksh; then
- # If we have ksh, try running configure again with it.
- ORIGINAL_CONFIG_SHELL=${CONFIG_SHELL-/bin/sh}
- export ORIGINAL_CONFIG_SHELL
- CONFIG_SHELL=/bin/ksh
- exec $CONFIG_SHELL "$0" --no-reexec ${1+"$@"}
- else
- # Try using printf.
- echo='printf %s\n'
- if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- # Cool, printf works
- elif echo_testing_string=`($ORIGINAL_CONFIG_SHELL "$0" --fallback-echo '\t') 2>/dev/null` &&
- test "X$echo_testing_string" = 'X\t' &&
- echo_testing_string=`($ORIGINAL_CONFIG_SHELL "$0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- CONFIG_SHELL=$ORIGINAL_CONFIG_SHELL
- SHELL="$CONFIG_SHELL"
- export SHELL
- echo="$CONFIG_SHELL $0 --fallback-echo"
- elif echo_testing_string=`($CONFIG_SHELL "$0" --fallback-echo '\t') 2>/dev/null` &&
- echo_testing_string=`($CONFIG_SHELL "$0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- else
- # maybe with a smaller string...
- prev=:
- for cmd in 'echo test' 'sed 2q "$0"' 'sed 10q "$0"' 'sed 20q "$0"' 'sed 50q "$0"'; do
- if (test "X$echo_test_string" = "X`eval $cmd`") 2>/dev/null
- then
- break
- fi
- prev="$cmd"
- done
- if test "$prev" != 'sed 50q "$0"'; then
- echo_test_string=`eval $prev`
- export echo_test_string
- exec ${ORIGINAL_CONFIG_SHELL-${CONFIG_SHELL-/bin/sh}} "$0" ${1+"$@"}
- else
- # Oops. We lost completely, so just stick with echo.
- echo=echo
- fi
- fi
- fi
- fi
-fi
-fi
-# Copy echo and quote the copy suitably for passing to libtool from
-# the Makefile, instead of quoting the original, which is used later.
-ECHO=$echo
-if test "X$ECHO" = "X$CONFIG_SHELL $0 --fallback-echo"; then
- ECHO="$CONFIG_SHELL \\\$\$0 --fallback-echo"
-fi
-tagnames=${tagnames+${tagnames},}CXX
-tagnames=${tagnames+${tagnames},}F77
-# Name of the host.
-# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
-# so uname gets run too.
-ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
-exec 6>&1
-# Initializations.
-ac_default_prefix=/usr/local
-ac_config_libobj_dir=.
-cross_compiling=no
-subdirs=
-MFLAGS=
-MAKEFLAGS=
-# Maximum number of lines to put in a shell here document.
-# This variable seems obsolete. It should probably be removed, and
-# only ac_max_sed_lines should be used.
-: ${ac_max_here_lines=38}
-# Identity of this package.
-PACKAGE_NAME='mapguide'
-PACKAGE_TARNAME='mapguide'
-PACKAGE_VERSION='2.0.0'
-PACKAGE_STRING='mapguide 2.0.0'
-PACKAGE_BUGREPORT='http://mapguide.osgeo.org'
-ac_unique_file="configure.in"
-ac_default_prefix=/usr/local/mapguideopensource
-# Factoring default headers for most tests.
-ac_includes_default="\
-#include <stdio.h>
-#if HAVE_SYS_TYPES_H
-#endif
-#if HAVE_SYS_STAT_H
-# include <sys/stat.h>
-#endif
-#if STDC_HEADERS
-# include <stdlib.h>
-# include <stddef.h>
-#else
-# if HAVE_STDLIB_H
-# endif
-#endif
-#if HAVE_STRING_H
-# if !STDC_HEADERS && HAVE_MEMORY_H
-# include <memory.h>
-# endif
-# include <string.h>
-#endif
-#if HAVE_STRINGS_H
-# include <strings.h>
-#endif
-#if HAVE_INTTYPES_H
-# include <inttypes.h>
-#else
-# if HAVE_STDINT_H
-# include <stdint.h>
-# endif
-#endif
-#if HAVE_UNISTD_H
-# include <unistd.h>
-#endif"
-ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS INSTALL_PROGRAM INSTALL_SCRIPT INSTALL_DATA CYGPATH_W PACKAGE VERSION ACLOCAL AUTOCONF AUTOMAKE AUTOHEADER MAKEINFO install_sh STRIP ac_ct_STRIP INSTALL_STRIP_PROGRAM mkdir_p AWK SET_MAKE am__leading_dot AMTAR am__tar am__untar CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT DEPDIR am__include am__quote AMDEP_TRUE AMDEP_FALSE AMDEPBACKSLASH CCDEPMODE am__fastdepCC_TRUE am__fastdepCC_FALSE CXX CXXFLAGS ac_ct_CXX CXXDEPMODE am__fastdepCXX_TRUE am__fastdepCXX_FALSE build build_cpu build_vendor build_os host host_cpu host_vendor host_os EGREP LN_S ECHO AR ac_ct_AR RANLIB ac_ct_RANLIB CPP CXXCPP F77 FFLAGS ac_ct_F77 LIBTOOL map_coordsys_dir map_coo
rdsys_dir_path map_coordsys_include_path map_unittesting_dir map_fdo_include map_fdo_lib map_toplevel_subdirs map_srcdir LIBOBJS LTLIBOBJS'
-ac_subst_files=''
-# Initialize some variables set by options.
-ac_init_help=
-ac_init_version=false
-# The variables have the same names as the options, with
-# dashes changed to underlines.
-cache_file=/dev/null
-exec_prefix=NONE
-no_create=
-no_recursion=
-prefix=NONE
-program_prefix=NONE
-program_suffix=NONE
-program_transform_name=s,x,x,
-silent=
-site=
-srcdir=
-verbose=
-x_includes=NONE
-x_libraries=NONE
-# Installation directory options.
-# These are left unexpanded so users can "make install exec_prefix=/foo"
-# and all the variables that are supposed to be based on exec_prefix
-# by default will actually change.
-# Use braces instead of parens because sh, perl, etc. also accept them.
-bindir='${exec_prefix}/bin'
-sbindir='${exec_prefix}/sbin'
-libexecdir='${exec_prefix}/libexec'
-datadir='${prefix}/share'
-sysconfdir='${prefix}/etc'
-sharedstatedir='${prefix}/com'
-localstatedir='${prefix}/var'
-libdir='${exec_prefix}/lib'
-includedir='${prefix}/include'
-oldincludedir='/usr/include'
-infodir='${prefix}/info'
-mandir='${prefix}/man'
-ac_prev=
-for ac_option
-do
- # If the previous option needs an argument, assign it.
- if test -n "$ac_prev"; then
- eval "$ac_prev=\$ac_option"
- ac_prev=
- continue
- fi
- ac_optarg=`expr "x$ac_option" : 'x[^=]*=\(.*\)'`
- # Accept the important Cygnus configure options, so we can diagnose typos.
- case $ac_option in
- -bindir | --bindir | --bindi | --bind | --bin | --bi)
- ac_prev=bindir ;;
- -bindir=* | --bindir=* | --bindi=* | --bind=* | --bin=* | --bi=*)
- bindir=$ac_optarg ;;
- -build | --build | --buil | --bui | --bu)
- ac_prev=build_alias ;;
- -build=* | --build=* | --buil=* | --bui=* | --bu=*)
- build_alias=$ac_optarg ;;
- -cache-file | --cache-file | --cache-fil | --cache-fi \
- | --cache-f | --cache- | --cache | --cach | --cac | --ca | --c)
- ac_prev=cache_file ;;
- -cache-file=* | --cache-file=* | --cache-fil=* | --cache-fi=* \
- | --cache-f=* | --cache-=* | --cache=* | --cach=* | --cac=* | --ca=* | --c=*)
- cache_file=$ac_optarg ;;
- --config-cache | -C)
- cache_file=config.cache ;;
- -datadir | --datadir | --datadi | --datad | --data | --dat | --da)
- ac_prev=datadir ;;
- -datadir=* | --datadir=* | --datadi=* | --datad=* | --data=* | --dat=* \
- | --da=*)
- datadir=$ac_optarg ;;
- -disable-* | --disable-*)
- ac_feature=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
- # Reject names that are not valid shell variable names.
- expr "x$ac_feature" : ".*[^-_$as_cr_alnum]" >/dev/null &&
- { echo "$as_me: error: invalid feature name: $ac_feature" >&2
- ac_feature=`echo $ac_feature | sed 's/-/_/g'`
- eval "enable_$ac_feature=no" ;;
- -enable-* | --enable-*)
- ac_feature=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
- *=*) ac_optarg=`echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"`;;
- *) ac_optarg=yes ;;
- esac
- eval "enable_$ac_feature='$ac_optarg'" ;;
- -exec-prefix | --exec_prefix | --exec-prefix | --exec-prefi \
- | --exec-pref | --exec-pre | --exec-pr | --exec-p | --exec- \
- | --exec | --exe | --ex)
- ac_prev=exec_prefix ;;
- -exec-prefix=* | --exec_prefix=* | --exec-prefix=* | --exec-prefi=* \
- | --exec-pref=* | --exec-pre=* | --exec-pr=* | --exec-p=* | --exec-=* \
- | --exec=* | --exe=* | --ex=*)
- exec_prefix=$ac_optarg ;;
- -gas | --gas | --ga | --g)
- # Obsolete; use --with-gas.
- with_gas=yes ;;
- -help | --help | --hel | --he | -h)
- ac_init_help=long ;;
- -help=r* | --help=r* | --hel=r* | --he=r* | -hr*)
- ac_init_help=recursive ;;
- -help=s* | --help=s* | --hel=s* | --he=s* | -hs*)
- ac_init_help=short ;;
- -host | --host | --hos | --ho)
- ac_prev=host_alias ;;
- -host=* | --host=* | --hos=* | --ho=*)
- host_alias=$ac_optarg ;;
- -includedir | --includedir | --includedi | --included | --include \
- | --includ | --inclu | --incl | --inc)
- ac_prev=includedir ;;
- -includedir=* | --includedir=* | --includedi=* | --included=* | --include=* \
- | --includ=* | --inclu=* | --incl=* | --inc=*)
- includedir=$ac_optarg ;;
- -infodir | --infodir | --infodi | --infod | --info | --inf)
- ac_prev=infodir ;;
- -infodir=* | --infodir=* | --infodi=* | --infod=* | --info=* | --inf=*)
- infodir=$ac_optarg ;;
- -libdir | --libdir | --libdi | --libd)
- ac_prev=libdir ;;
- -libdir=* | --libdir=* | --libdi=* | --libd=*)
- libdir=$ac_optarg ;;
- -libexecdir | --libexecdir | --libexecdi | --libexecd | --libexec \
- | --libexe | --libex | --libe)
- ac_prev=libexecdir ;;
- -libexecdir=* | --libexecdir=* | --libexecdi=* | --libexecd=* | --libexec=* \
- | --libexe=* | --libex=* | --libe=*)
- libexecdir=$ac_optarg ;;
- -localstatedir | --localstatedir | --localstatedi | --localstated \
- | --localstate | --localstat | --localsta | --localst \
- | --locals | --local | --loca | --loc | --lo)
- ac_prev=localstatedir ;;
- -localstatedir=* | --localstatedir=* | --localstatedi=* | --localstated=* \
- | --localstate=* | --localstat=* | --localsta=* | --localst=* \
- | --locals=* | --local=* | --loca=* | --loc=* | --lo=*)
- localstatedir=$ac_optarg ;;
- -mandir | --mandir | --mandi | --mand | --man | --ma | --m)
- ac_prev=mandir ;;
- -mandir=* | --mandir=* | --mandi=* | --mand=* | --man=* | --ma=* | --m=*)
- mandir=$ac_optarg ;;
- -nfp | --nfp | --nf)
- # Obsolete; use --without-fp.
- with_fp=no ;;
- -no-create | --no-create | --no-creat | --no-crea | --no-cre \
- | --no-cr | --no-c | -n)
- no_create=yes ;;
- -no-recursion | --no-recursion | --no-recursio | --no-recursi \
- | --no-recurs | --no-recur | --no-recu | --no-rec | --no-re | --no-r)
- no_recursion=yes ;;
- -oldincludedir | --oldincludedir | --oldincludedi | --oldincluded \
- | --oldinclude | --oldinclud | --oldinclu | --oldincl | --oldinc \
- | --oldin | --oldi | --old | --ol | --o)
- ac_prev=oldincludedir ;;
- -oldincludedir=* | --oldincludedir=* | --oldincludedi=* | --oldincluded=* \
- | --oldinclude=* | --oldinclud=* | --oldinclu=* | --oldincl=* | --oldinc=* \
- | --oldin=* | --oldi=* | --old=* | --ol=* | --o=*)
- oldincludedir=$ac_optarg ;;
- -prefix | --prefix | --prefi | --pref | --pre | --pr | --p)
- ac_prev=prefix ;;
- -prefix=* | --prefix=* | --prefi=* | --pref=* | --pre=* | --pr=* | --p=*)
- prefix=$ac_optarg ;;
- -program-prefix | --program-prefix | --program-prefi | --program-pref \
- | --program-pre | --program-pr | --program-p)
- ac_prev=program_prefix ;;
- -program-prefix=* | --program-prefix=* | --program-prefi=* \
- | --program-pref=* | --program-pre=* | --program-pr=* | --program-p=*)
- program_prefix=$ac_optarg ;;
- -program-suffix | --program-suffix | --program-suffi | --program-suff \
- | --program-suf | --program-su | --program-s)
- ac_prev=program_suffix ;;
- -program-suffix=* | --program-suffix=* | --program-suffi=* \
- | --program-suff=* | --program-suf=* | --program-su=* | --program-s=*)
- program_suffix=$ac_optarg ;;
- -program-transform-name | --program-transform-name \
- | --program-transform-nam | --program-transform-na \
- | --program-transform-n | --program-transform- \
- | --program-transform | --program-transfor \
- | --program-transfo | --program-transf \
- | --program-trans | --program-tran \
- | --progr-tra | --program-tr | --program-t)
- ac_prev=program_transform_name ;;
- -program-transform-name=* | --program-transform-name=* \
- | --program-transform-nam=* | --program-transform-na=* \
- | --program-transform-n=* | --program-transform-=* \
- | --program-transform=* | --program-transfor=* \
- | --program-transfo=* | --program-transf=* \
- | --program-trans=* | --program-tran=* \
- | --progr-tra=* | --program-tr=* | --program-t=*)
- program_transform_name=$ac_optarg ;;
- -q | -quiet | --quiet | --quie | --qui | --qu | --q \
- | -silent | --silent | --silen | --sile | --sil)
- silent=yes ;;
- -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
- ac_prev=sbindir ;;
- -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
- | --sbi=* | --sb=*)
- sbindir=$ac_optarg ;;
- -sharedstatedir | --sharedstatedir | --sharedstatedi \
- | --sharedstated | --sharedstate | --sharedstat | --sharedsta \
- | --sharedst | --shareds | --shared | --share | --shar \
- | --sha | --sh)
- ac_prev=sharedstatedir ;;
- -sharedstatedir=* | --sharedstatedir=* | --sharedstatedi=* \
- | --sharedstated=* | --sharedstate=* | --sharedstat=* | --sharedsta=* \
- | --sharedst=* | --shareds=* | --shared=* | --share=* | --shar=* \
- | --sha=* | --sh=*)
- sharedstatedir=$ac_optarg ;;
- -site | --site | --sit)
- ac_prev=site ;;
- -site=* | --site=* | --sit=*)
- site=$ac_optarg ;;
- -srcdir | --srcdir | --srcdi | --srcd | --src | --sr)
- ac_prev=srcdir ;;
- -srcdir=* | --srcdir=* | --srcdi=* | --srcd=* | --src=* | --sr=*)
- srcdir=$ac_optarg ;;
- -sysconfdir | --sysconfdir | --sysconfdi | --sysconfd | --sysconf \
- | --syscon | --sysco | --sysc | --sys | --sy)
- ac_prev=sysconfdir ;;
- -sysconfdir=* | --sysconfdir=* | --sysconfdi=* | --sysconfd=* | --sysconf=* \
- | --syscon=* | --sysco=* | --sysc=* | --sys=* | --sy=*)
- sysconfdir=$ac_optarg ;;
- -target | --target | --targe | --targ | --tar | --ta | --t)
- ac_prev=target_alias ;;
- -target=* | --target=* | --targe=* | --targ=* | --tar=* | --ta=* | --t=*)
- target_alias=$ac_optarg ;;
- -v | -verbose | --verbose | --verbos | --verbo | --verb)
- verbose=yes ;;
- -version | --version | --versio | --versi | --vers | -V)
- ac_init_version=: ;;
- -with-* | --with-*)
- ac_package=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
- expr "x$ac_package" : ".*[^-_$as_cr_alnum]" >/dev/null &&
- { echo "$as_me: error: invalid package name: $ac_package" >&2
- ac_package=`echo $ac_package| sed 's/-/_/g'`
- esac
- eval "with_$ac_package='$ac_optarg'" ;;
- -without-* | --without-*)
- ac_package=`expr "x$ac_option" : 'x-*without-\(.*\)'`
- ac_package=`echo $ac_package | sed 's/-/_/g'`
- eval "with_$ac_package=no" ;;
- --x)
- # Obsolete; use --with-x.
- with_x=yes ;;
- -x-includes | --x-includes | --x-include | --x-includ | --x-inclu \
- | --x-incl | --x-inc | --x-in | --x-i)
- ac_prev=x_includes ;;
- -x-includes=* | --x-includes=* | --x-include=* | --x-includ=* | --x-inclu=* \
- | --x-incl=* | --x-inc=* | --x-in=* | --x-i=*)
- x_includes=$ac_optarg ;;
- -x-libraries | --x-libraries | --x-librarie | --x-librari \
- | --x-librar | --x-libra | --x-libr | --x-lib | --x-li | --x-l)
- ac_prev=x_libraries ;;
- -x-libraries=* | --x-libraries=* | --x-librarie=* | --x-librari=* \
- | --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
- x_libraries=$ac_optarg ;;
- -*) { echo "$as_me: error: unrecognized option: $ac_option
-Try \`$0 --help' for more information." >&2
- ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
- expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
- { echo "$as_me: error: invalid variable name: $ac_envvar" >&2
- ac_optarg=`echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"`
- eval "$ac_envvar='$ac_optarg'"
- export $ac_envvar ;;
- # FIXME: should be removed in autoconf 3.0.
- echo "$as_me: WARNING: you should use --build, --host, --target" >&2
- expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
- echo "$as_me: WARNING: invalid host type: $ac_option" >&2
- : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
- esac
-done
-if test -n "$ac_prev"; then
- ac_option=--`echo $ac_prev | sed 's/_/-/g'`
- { echo "$as_me: error: missing argument to $ac_option" >&2
-fi
-# Be sure to have absolute paths.
-for ac_var in exec_prefix prefix
-do
- eval ac_val=$`echo $ac_var`
- case $ac_val in
- [\\/$]* | ?:[\\/]* | NONE | '' ) ;;
- *) { echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2
- { (exit 1); exit 1; }; };;
- esac
-done
-for ac_var in bindir sbindir libexecdir datadir sysconfdir sharedstatedir \
- localstatedir libdir includedir oldincludedir infodir mandir
-do
- case $ac_val in
- esac
-done
-# There might be people who depend on the old broken behavior: `$host'
-# used to hold the argument of --host etc.
-# FIXME: To remove some day.
-build=$build_alias
-host=$host_alias
-target=$target_alias
-if test "x$host_alias" != x; then
- if test "x$build_alias" = x; then
- cross_compiling=maybe
- echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
- If a cross compiler is detected then cross compile mode will be used." >&2
- elif test "x$build_alias" != "x$host_alias"; then
- cross_compiling=yes
- fi
-fi
-ac_tool_prefix=
-test -n "$host_alias" && ac_tool_prefix=$host_alias-
-test "$silent" = yes && exec 6>/dev/null
-# Find the source files, if location was not specified.
-if test -z "$srcdir"; then
- ac_srcdir_defaulted=yes
- # Try the directory containing this script, then its parent.
- ac_confdir=`(dirname "$0") 2>/dev/null ||
-$as_expr X"$0" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$0" : 'X\(//\)[^/]' \| \
- X"$0" : 'X\(/\)' \| \
-echo X"$0" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
- /^X\(\/\/\)[^/].*/{ s//\1/; q; }
- /^X\(\/\/\)$/{ s//\1/; q; }
- /^X\(\/\).*/{ s//\1/; q; }
- s/.*/./; q'`
- srcdir=$ac_confdir
- if test ! -r $srcdir/$ac_unique_file; then
- srcdir=..
- fi
-else
- ac_srcdir_defaulted=no
-fi
-if test ! -r $srcdir/$ac_unique_file; then
- if test "$ac_srcdir_defaulted" = yes; then
- { echo "$as_me: error: cannot find sources ($ac_unique_file) in $ac_confdir or .." >&2
- else
- { echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2
- fi
-fi
-(cd $srcdir && test -r ./$ac_unique_file) 2>/dev/null ||
- { echo "$as_me: error: sources are in $srcdir, but \`cd $srcdir' does not work" >&2
-srcdir=`echo "$srcdir" | sed 's%\([^\\/]\)[\\/]*$%\1%'`
-ac_env_build_alias_set=${build_alias+set}
-ac_env_build_alias_value=$build_alias
-ac_cv_env_build_alias_set=${build_alias+set}
-ac_cv_env_build_alias_value=$build_alias
-ac_env_host_alias_set=${host_alias+set}
-ac_env_host_alias_value=$host_alias
-ac_cv_env_host_alias_set=${host_alias+set}
-ac_cv_env_host_alias_value=$host_alias
-ac_env_target_alias_set=${target_alias+set}
-ac_env_target_alias_value=$target_alias
-ac_cv_env_target_alias_set=${target_alias+set}
-ac_cv_env_target_alias_value=$target_alias
-ac_env_CC_set=${CC+set}
-ac_env_CC_value=$CC
-ac_cv_env_CC_set=${CC+set}
-ac_cv_env_CC_value=$CC
-ac_env_CFLAGS_set=${CFLAGS+set}
-ac_env_CFLAGS_value=$CFLAGS
-ac_cv_env_CFLAGS_set=${CFLAGS+set}
-ac_cv_env_CFLAGS_value=$CFLAGS
-ac_env_LDFLAGS_set=${LDFLAGS+set}
-ac_env_LDFLAGS_value=$LDFLAGS
-ac_cv_env_LDFLAGS_set=${LDFLAGS+set}
-ac_cv_env_LDFLAGS_value=$LDFLAGS
-ac_env_CPPFLAGS_set=${CPPFLAGS+set}
-ac_env_CPPFLAGS_value=$CPPFLAGS
-ac_cv_env_CPPFLAGS_set=${CPPFLAGS+set}
-ac_cv_env_CPPFLAGS_value=$CPPFLAGS
-ac_env_CXX_set=${CXX+set}
-ac_env_CXX_value=$CXX
-ac_cv_env_CXX_set=${CXX+set}
-ac_cv_env_CXX_value=$CXX
-ac_env_CXXFLAGS_set=${CXXFLAGS+set}
-ac_env_CXXFLAGS_value=$CXXFLAGS
-ac_cv_env_CXXFLAGS_set=${CXXFLAGS+set}
-ac_cv_env_CXXFLAGS_value=$CXXFLAGS
-ac_env_CPP_set=${CPP+set}
-ac_env_CPP_value=$CPP
-ac_cv_env_CPP_set=${CPP+set}
-ac_cv_env_CPP_value=$CPP
-ac_env_CXXCPP_set=${CXXCPP+set}
-ac_env_CXXCPP_value=$CXXCPP
-ac_cv_env_CXXCPP_set=${CXXCPP+set}
-ac_cv_env_CXXCPP_value=$CXXCPP
-ac_env_F77_set=${F77+set}
-ac_env_F77_value=$F77
-ac_cv_env_F77_set=${F77+set}
-ac_cv_env_F77_value=$F77
-ac_env_FFLAGS_set=${FFLAGS+set}
-ac_env_FFLAGS_value=$FFLAGS
-ac_cv_env_FFLAGS_set=${FFLAGS+set}
-ac_cv_env_FFLAGS_value=$FFLAGS
-# Report the --help message.
-if test "$ac_init_help" = "long"; then
- # Omit some internal or obsolete options to make the list less imposing.
- # This message is too long to be a string in the A/UX 3.1 sh.
- cat <<_ACEOF
-\`configure' configures mapguide 2.0.0 to adapt to many kinds of systems.
-Usage: $0 [OPTION]... [VAR=VALUE]...
-To assign environment variables (e.g., CC, CFLAGS...), specify them as
-VAR=VALUE. See below for descriptions of some of the useful variables.
-Defaults for the options are specified in brackets.
-Configuration:
- -h, --help display this help and exit
- --help=short display options specific to this package
- --help=recursive display the short help of all the included packages
- -V, --version display version information and exit
- -q, --quiet, --silent do not print \`checking...' messages
- --cache-file=FILE cache test results in FILE [disabled]
- -C, --config-cache alias for \`--cache-file=config.cache'
- -n, --no-create do not create output files
- --srcdir=DIR find the sources in DIR [configure dir or \`..']
-_ACEOF
- cat <<_ACEOF
-Installation directories:
- --prefix=PREFIX install architecture-independent files in PREFIX
- [$ac_default_prefix]
- --exec-prefix=EPREFIX install architecture-dependent files in EPREFIX
- [PREFIX]
-By default, \`make install' will install all the files in
-\`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc. You can specify
-an installation prefix other than \`$ac_default_prefix' using \`--prefix',
-for instance \`--prefix=\$HOME'.
-For better control, use the options below.
-Fine tuning of the installation directories:
- --bindir=DIR user executables [EPREFIX/bin]
- --sbindir=DIR system admin executables [EPREFIX/sbin]
- --libexecdir=DIR program executables [EPREFIX/libexec]
- --datadir=DIR read-only architecture-independent data [PREFIX/share]
- --sysconfdir=DIR read-only single-machine data [PREFIX/etc]
- --sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com]
- --localstatedir=DIR modifiable single-machine data [PREFIX/var]
- --libdir=DIR object code libraries [EPREFIX/lib]
- --includedir=DIR C header files [PREFIX/include]
- --oldincludedir=DIR C header files for non-gcc [/usr/include]
- --infodir=DIR info documentation [PREFIX/info]
- --mandir=DIR man documentation [PREFIX/man]
-_ACEOF
- cat <<\_ACEOF
-Program names:
- --program-prefix=PREFIX prepend PREFIX to installed program names
- --program-suffix=SUFFIX append SUFFIX to installed program names
- --program-transform-name=PROGRAM run sed PROGRAM on installed program names
-System types:
- --build=BUILD configure for building on BUILD [guessed]
- --host=HOST cross-compile to build programs to run on HOST [BUILD]
-_ACEOF
-fi
-if test -n "$ac_init_help"; then
- case $ac_init_help in
- short | recursive ) echo "Configuration of mapguide 2.0.0:";;
- esac
- cat <<\_ACEOF
-Optional Features:
- --disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
- --enable-FEATURE[=ARG] include FEATURE [ARG=yes]
- --disable-dependency-tracking speeds up one-time build
- --enable-dependency-tracking do not reject slow dependency extractors
- --enable-shared[=PKGS]
- build shared libraries [default=yes]
- --enable-static[=PKGS]
- build static libraries [default=yes]
- --enable-fast-install[=PKGS]
- optimize for fast installation [default=yes]
- --disable-libtool-lock avoid locking (might break parallel builds)
- --enable-optimized enable optimized build default=no
- --enable-server enable server build default=yes
- --enable-webtier enable webtier build default=yes
-Optional Packages:
- --with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
- --without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
- --with-gnu-ld assume the C compiler uses GNU ld [default=no]
- --with-pic try to use only PIC/non-PIC objects [default=use
- both]
- --with-tags[=TAGS]
- include additional configurations [automatic]
- --with-php specify php headers dir prefix as args default=no
- --with-fdo-include specifies custom dir for fdo include files
- default=DEFAULT
- --with-fdo-lib specifies custom path for fdo libraries
- default=DEFAULT
-Some influential environment variables:
- CC C compiler command
- CFLAGS C compiler flags
- LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
- nonstandard directory <lib dir>
- CPPFLAGS C/C++ preprocessor flags, e.g. -I<include dir> if you have
- headers in a nonstandard directory <include dir>
- CXX C++ compiler command
- CXXFLAGS C++ compiler flags
- CPP C preprocessor
- CXXCPP C++ preprocessor
- F77 Fortran 77 compiler command
- FFLAGS Fortran 77 compiler flags
-Use these variables to override the choices made by `configure' or to help
-it to find libraries and programs with nonstandard names/locations.
-Report bugs to <http://mapguide.osgeo.org>.
-_ACEOF
-fi
-if test "$ac_init_help" = "recursive"; then
- # If there are subdirs, report their specific --help.
- ac_popdir=`pwd`
- for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue
- test -d $ac_dir || continue
- ac_builddir=.
-if test "$ac_dir" != .; then
- ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
- # A "../" for each directory in $ac_dir_suffix.
- ac_top_builddir=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,../,g'`
-else
- ac_dir_suffix= ac_top_builddir=
-fi
-case $srcdir in
- .) # No --srcdir option. We are building in place.
- ac_srcdir=.
- if test -z "$ac_top_builddir"; then
- ac_top_srcdir=.
- else
- ac_top_srcdir=`echo $ac_top_builddir | sed 's,/$,,'`
- fi ;;
- [\\/]* | ?:[\\/]* ) # Absolute path.
- ac_srcdir=$srcdir$ac_dir_suffix;
- ac_top_srcdir=$srcdir ;;
- *) # Relative path.
- ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
- ac_top_srcdir=$ac_top_builddir$srcdir ;;
-esac
-# Do not use `cd foo && pwd` to compute absolute paths, because
-# the directories may not exist.
-case `pwd` in
-.) ac_abs_builddir="$ac_dir";;
- case "$ac_dir" in
- .) ac_abs_builddir=`pwd`;;
- [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
- *) ac_abs_builddir=`pwd`/"$ac_dir";;
- esac;;
-esac
-case $ac_abs_builddir in
-.) ac_abs_top_builddir=${ac_top_builddir}.;;
- case ${ac_top_builddir}. in
- .) ac_abs_top_builddir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
- *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
- esac;;
-esac
-.) ac_abs_srcdir=$ac_srcdir;;
- case $ac_srcdir in
- .) ac_abs_srcdir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
- *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
- esac;;
-esac
-.) ac_abs_top_srcdir=$ac_top_srcdir;;
- case $ac_top_srcdir in
- .) ac_abs_top_srcdir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
- *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
- esac;;
-esac
- cd $ac_dir
- # Check for guested configure; otherwise get Cygnus style configure.
- if test -f $ac_srcdir/configure.gnu; then
- echo
- $SHELL $ac_srcdir/configure.gnu --help=recursive
- elif test -f $ac_srcdir/configure; then
- echo
- $SHELL $ac_srcdir/configure --help=recursive
- elif test -f $ac_srcdir/configure.ac ||
- test -f $ac_srcdir/configure.in; then
- echo
- $ac_configure --help
- else
- echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
- fi
- cd $ac_popdir
- done
-fi
-test -n "$ac_init_help" && exit 0
-if $ac_init_version; then
- cat <<\_ACEOF
-mapguide configure 2.0.0
-generated by GNU Autoconf 2.59
-Copyright (C) 2003 Free Software Foundation, Inc.
-This configure script is free software; the Free Software Foundation
-gives unlimited permission to copy, distribute and modify it.
-_ACEOF
- exit 0
-fi
-exec 5>config.log
-cat >&5 <<_ACEOF
-This file contains any messages produced by compilers while
-running configure, to aid debugging if configure makes a mistake.
-It was created by mapguide $as_me 2.0.0, which was
-generated by GNU Autoconf 2.59. Invocation command line was
- $ $0 $@
-_ACEOF
-cat <<_ASUNAME
-## Platform. ##
-hostname = `(hostname || uname -n) 2>/dev/null | sed 1q`
-uname -m = `(uname -m) 2>/dev/null || echo unknown`
-uname -r = `(uname -r) 2>/dev/null || echo unknown`
-uname -s = `(uname -s) 2>/dev/null || echo unknown`
-uname -v = `(uname -v) 2>/dev/null || echo unknown`
-/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null || echo unknown`
-/bin/uname -X = `(/bin/uname -X) 2>/dev/null || echo unknown`
-/bin/arch = `(/bin/arch) 2>/dev/null || echo unknown`
-/usr/bin/arch -k = `(/usr/bin/arch -k) 2>/dev/null || echo unknown`
-/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null || echo unknown`
-hostinfo = `(hostinfo) 2>/dev/null || echo unknown`
-/bin/machine = `(/bin/machine) 2>/dev/null || echo unknown`
-/usr/bin/oslevel = `(/usr/bin/oslevel) 2>/dev/null || echo unknown`
-/bin/universe = `(/bin/universe) 2>/dev/null || echo unknown`
-_ASUNAME
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-do
- IFS=$as_save_IFS
- echo "PATH: $as_dir"
-done
-} >&5
-cat >&5 <<_ACEOF
-## Core tests. ##
-_ACEOF
-# Keep a trace of the command line.
-# Strip out --no-create and --no-recursion so they do not pile up.
-# Strip out --silent because we don't want to record it for future runs.
-# Also quote any args containing shell meta-characters.
-# Make two passes to allow for proper duplicate-argument suppression.
-ac_configure_args=
-ac_configure_args0=
-ac_configure_args1=
-ac_sep=
-ac_must_keep_next=false
-for ac_pass in 1 2
-do
- for ac_arg
- do
- case $ac_arg in
- -no-create | --no-c* | -n | -no-recursion | --no-r*) continue ;;
- continue ;;
- ac_arg=`echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
- esac
- case $ac_pass in
- 1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;;
- 2)
- ac_configure_args1="$ac_configure_args1 '$ac_arg'"
- if test $ac_must_keep_next = true; then
- ac_must_keep_next=false # Got value, back to normal.
- else
- case $ac_arg in
- *=* | --config-cache | -C | -disable-* | --disable-* \
- | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \
- | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \
- | -with-* | --with-* | -without-* | --without-* | --x)
- case "$ac_configure_args0 " in
- "$ac_configure_args1"*" '$ac_arg' "* ) continue ;;
- esac
- -* ) ac_must_keep_next=true ;;
- esac
- fi
- ac_configure_args="$ac_configure_args$ac_sep'$ac_arg'"
- # Get rid of the leading space.
- ac_sep=" "
- esac
- done
-done
-$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; }
-$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; }
-# When interrupted or exit'd, cleanup temporary files, and complete
-# config.log. We remove comments because anyway the quotes in there
-# would cause problems or look ugly.
-# WARNING: Be sure not to use single quotes in there, as some shells,
-# such as our DU 5.0 friend, will then `close' the trap.
-trap 'exit_status=$?
- # Save into config.log some information that might help in debugging.
- echo
- cat <<\_ASBOX
-## Cache variables. ##
-_ASBOX
- echo
- # The following way of writing the cache mishandles newlines in values,
- (set) 2>&1 |
- case `(ac_space='"'"' '"'"'; set | grep ac_space) 2>&1` in
- *ac_space=\ *)
- sed -n \
- "s/'"'"'/'"'"'\\\\'"'"''"'"'/g;
- s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='"'"'\\2'"'"'/p"
- sed -n \
- "s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
- esac;
- echo
- cat <<\_ASBOX
-## Output variables. ##
-_ASBOX
- echo
- for ac_var in $ac_subst_vars
- do
- echo "$ac_var='"'"'$ac_val'"'"'"
- done | sort
- echo
- if test -n "$ac_subst_files"; then
- cat <<\_ASBOX
-## Output files. ##
-_ASBOX
- echo
- for ac_var in $ac_subst_files
- do
- done | sort
- echo
- fi
- if test -s confdefs.h; then
- cat <<\_ASBOX
-## confdefs.h. ##
-_ASBOX
- echo
- sed "/^$/d" confdefs.h | sort
- echo
- fi
- test "$ac_signal" != 0 &&
- echo "$as_me: caught signal $ac_signal"
- echo "$as_me: exit $exit_status"
- } >&5
- rm -f core *.core &&
- rm -rf conftest* confdefs* conf$$* $ac_clean_files &&
- exit $exit_status
- ' 0
-for ac_signal in 1 2 13 15; do
- trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal
-done
-ac_signal=0
-# confdefs.h avoids OS command line length limits that DEFS can exceed.
-rm -rf conftest* confdefs.h
-# AIX cpp loses on an empty file, so make sure it contains at least a newline.
-echo >confdefs.h
-# Predefined preprocessor variables.
-cat >>confdefs.h <<_ACEOF
-#define PACKAGE_NAME "$PACKAGE_NAME"
-_ACEOF
-#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
-_ACEOF
-#define PACKAGE_VERSION "$PACKAGE_VERSION"
-_ACEOF
-#define PACKAGE_STRING "$PACKAGE_STRING"
-_ACEOF
-#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
-_ACEOF
-# Let the site file select an alternate cache file if it wants to.
-# Prefer explicitly selected file to automatically selected ones.
-if test -z "$CONFIG_SITE"; then
- if test "x$prefix" != xNONE; then
- CONFIG_SITE="$prefix/share/config.site $prefix/etc/config.site"
- else
- CONFIG_SITE="$ac_default_prefix/share/config.site $ac_default_prefix/etc/config.site"
- fi
-fi
-for ac_site_file in $CONFIG_SITE; do
- if test -r "$ac_site_file"; then
- { echo "$as_me:$LINENO: loading site script $ac_site_file" >&5
-echo "$as_me: loading site script $ac_site_file" >&6;}
- sed 's/^/| /' "$ac_site_file" >&5
- . "$ac_site_file"
- fi
-done
-if test -r "$cache_file"; then
- # Some versions of bash will fail to source /dev/null (special
- # files actually), so we avoid doing that.
- if test -f "$cache_file"; then
- { echo "$as_me:$LINENO: loading cache $cache_file" >&5
-echo "$as_me: loading cache $cache_file" >&6;}
- case $cache_file in
- [\\/]* | ?:[\\/]* ) . $cache_file;;
- *) . ./$cache_file;;
- esac
- fi
-else
- { echo "$as_me:$LINENO: creating cache $cache_file" >&5
-echo "$as_me: creating cache $cache_file" >&6;}
- >$cache_file
-fi
-# Check that the precious variables saved in the cache have kept the same
-# value.
-ac_cache_corrupted=false
-for ac_var in `(set) 2>&1 |
- sed -n 's/^ac_env_\([a-zA-Z_0-9]*\)_set=.*/\1/p'`; do
- eval ac_old_set=\$ac_cv_env_${ac_var}_set
- eval ac_new_set=\$ac_env_${ac_var}_set
- eval ac_old_val="\$ac_cv_env_${ac_var}_value"
- eval ac_new_val="\$ac_env_${ac_var}_value"
- case $ac_old_set,$ac_new_set in
- set,)
- { echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
-echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
- ac_cache_corrupted=: ;;
- ,set)
- { echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5
-echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
- if test "x$ac_old_val" != "x$ac_new_val"; then
- { echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
-echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
- { echo "$as_me:$LINENO: former value: $ac_old_val" >&5
-echo "$as_me: former value: $ac_old_val" >&2;}
- { echo "$as_me:$LINENO: current value: $ac_new_val" >&5
-echo "$as_me: current value: $ac_new_val" >&2;}
- fi;;
- esac
- # Pass precious variables to config.status.
- if test "$ac_new_set" = set; then
- case $ac_new_val in
- ac_arg=$ac_var=`echo "$ac_new_val" | sed "s/'/'\\\\\\\\''/g"` ;;
- *) ac_arg=$ac_var=$ac_new_val ;;
- esac
- case " $ac_configure_args " in
- *" '$ac_arg' "*) ;; # Avoid dups. Use of quotes ensures accuracy.
- *) ac_configure_args="$ac_configure_args '$ac_arg'" ;;
- esac
- fi
-done
-if $ac_cache_corrupted; then
- { echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5
-echo "$as_me: error: changes in the environment can compromise the build" >&2;}
- { { echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5
-echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;}
-fi
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-am__api_version="1.9"
-ac_aux_dir=
-for ac_dir in $srcdir $srcdir/.. $srcdir/../..; do
- if test -f $ac_dir/install-sh; then
- ac_aux_dir=$ac_dir
- ac_install_sh="$ac_aux_dir/install-sh -c"
- break
- elif test -f $ac_dir/install.sh; then
- ac_install_sh="$ac_aux_dir/install.sh -c"
- break
- elif test -f $ac_dir/shtool; then
- ac_install_sh="$ac_aux_dir/shtool install -c"
- break
- fi
-done
-if test -z "$ac_aux_dir"; then
- { { echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in $srcdir $srcdir/.. $srcdir/../.." >&5
-echo "$as_me: error: cannot find install-sh or install.sh in $srcdir $srcdir/.. $srcdir/../.." >&2;}
-fi
-ac_config_guess="$SHELL $ac_aux_dir/config.guess"
-ac_config_sub="$SHELL $ac_aux_dir/config.sub"
-ac_configure="$SHELL $ac_aux_dir/configure" # This should be Cygnus configure.
-# Find a good install program. We prefer a C program (faster),
-# so one script is as good as another. But avoid the broken or
-# incompatible versions:
-# SysV /etc/install, /usr/sbin/install
-# SunOS /usr/etc/install
-# IRIX /sbin/install
-# AIX /bin/install
-# AmigaOS /C/install, which installs bootblocks on floppy discs
-# AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag
-# AFS /usr/afsws/bin/install, which mishandles nonexistent args
-# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
-# OS/2's system install, which has a completely different semantic
-# ./install, which can be erroneously created by make from ./install.sh.
-echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
-echo $ECHO_N "checking for a BSD-compatible install... $ECHO_C" >&6
-if test -z "$INSTALL"; then
-if test "${ac_cv_path_install+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
-do
- IFS=$as_save_IFS
- # Account for people who put trailing slashes in PATH elements.
-case $as_dir/ in
- ./ | .// | /cC/* | \
- /etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
- ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
- /usr/ucb/* ) ;;
- # OSF1 and SCO ODT 3.0 have their own names for install.
- # Don't use installbsd from OSF since it installs stuff as root
- # by default.
- for ac_prog in ginstall scoinst install; do
- for ac_exec_ext in '' $ac_executable_extensions; do
- if $as_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
- if test $ac_prog = install &&
- grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
- # AIX install. It has an incompatible calling convention.
- elif test $ac_prog = install &&
- grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
- # program-specific install script used by HP pwplus--don't use.
- else
- ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
- break 3
- fi
- fi
- done
- done
-esac
-done
-fi
- if test "${ac_cv_path_install+set}" = set; then
- INSTALL=$ac_cv_path_install
- else
- # As a last resort, use the slow shell script. We don't cache a
- # path for INSTALL within a source directory, because that will
- # break other packages using the cache if that directory is
- # removed, or if the path is relative.
- INSTALL=$ac_install_sh
- fi
-fi
-echo "$as_me:$LINENO: result: $INSTALL" >&5
-echo "${ECHO_T}$INSTALL" >&6
-# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
-# It thinks the first close brace ends the variable substitution.
-test -z "$INSTALL_PROGRAM" && INSTALL_PROGRAM='${INSTALL}'
-test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
-test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
-echo "$as_me:$LINENO: checking whether build environment is sane" >&5
-echo $ECHO_N "checking whether build environment is sane... $ECHO_C" >&6
-# Just in case
-sleep 1
-echo timestamp > conftest.file
-# Do `set' in a subshell so we don't clobber the current shell's
-# arguments. Must try -L first in case configure is actually a
-# symlink; some systems play weird games with the mod time of symlinks
-# (eg FreeBSD returns the mod time of the symlink's containing
-# directory).
-if (
- set X `ls -Lt $srcdir/configure conftest.file 2> /dev/null`
- if test "$*" = "X"; then
- # -L didn't work.
- set X `ls -t $srcdir/configure conftest.file`
- fi
- rm -f conftest.file
- if test "$*" != "X $srcdir/configure conftest.file" \
- && test "$*" != "X conftest.file $srcdir/configure"; then
- # If neither matched, then we have a broken ls. This can happen
- # if, for instance, CONFIG_SHELL is bash and it inherits a
- # broken ls alias from the environment. This has actually
- # happened. Such a system could not be considered "sane".
- { { echo "$as_me:$LINENO: error: ls -t appears to fail. Make sure there is not a broken
-alias in your environment" >&5
-echo "$as_me: error: ls -t appears to fail. Make sure there is not a broken
-alias in your environment" >&2;}
- fi
- test "$2" = conftest.file
-then
- # Ok.
-else
- { { echo "$as_me:$LINENO: error: newly created file is older than distributed files!
-Check your system clock" >&5
-echo "$as_me: error: newly created file is older than distributed files!
-Check your system clock" >&2;}
-fi
-echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6
-test "$program_prefix" != NONE &&
- program_transform_name="s,^,$program_prefix,;$program_transform_name"
-# Use a double $ so make ignores it.
-test "$program_suffix" != NONE &&
- program_transform_name="s,\$,$program_suffix,;$program_transform_name"
-# Double any \ or $. echo might interpret backslashes.
-# By default was `s,x,x', remove it if useless.
-cat <<\_ACEOF >conftest.sed
-s/[\\$]/&&/g;s/;s,x,x,$//
-_ACEOF
-program_transform_name=`echo $program_transform_name | sed -f conftest.sed`
-rm conftest.sed
-# expand $ac_aux_dir to an absolute path
-am_aux_dir=`cd $ac_aux_dir && pwd`
-test x"${MISSING+set}" = xset || MISSING="\${SHELL} $am_aux_dir/missing"
-# Use eval to expand $SHELL
-if eval "$MISSING --run true"; then
- am_missing_run="$MISSING --run "
-else
- am_missing_run=
- { echo "$as_me:$LINENO: WARNING: \`missing' script is too old or missing" >&5
-echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
-fi
-if mkdir -p --version . >/dev/null 2>&1 && test ! -d ./--version; then
- # We used to keeping the `.' as first argument, in order to
- # allow $(mkdir_p) to be used without argument. As in
- # $(mkdir_p) $(somedir)
- # where $(somedir) is conditionally defined. However this is wrong
- # for two reasons:
- # 1. if the package is installed by a user who cannot write `.'
- # make install will fail,
- # 2. the above comment should most certainly read
- # $(mkdir_p) $(DESTDIR)$(somedir)
- # so it does not work when $(somedir) is undefined and
- # $(DESTDIR) is not.
- # To support the latter case, we have to write
- # test -z "$(somedir)" || $(mkdir_p) $(DESTDIR)$(somedir),
- # so the `.' trick is pointless.
- mkdir_p='mkdir -p --'
-else
- # On NextStep and OpenStep, the `mkdir' command does not
- # recognize any option. It will interpret all options as
- # directories to create, and then abort because `.' already
- # exists.
- for d in ./-p ./--version;
- do
- test -d $d && rmdir $d
- done
- # $(mkinstalldirs) is defined by Automake if mkinstalldirs exists.
- if test -f "$ac_aux_dir/mkinstalldirs"; then
- mkdir_p='$(mkinstalldirs)'
- else
- mkdir_p='$(install_sh) -d'
- fi
-fi
-for ac_prog in gawk mawk nawk awk
-do
- # Extract the first word of "$ac_prog", so it can be a program name with args.
-set dummy $ac_prog; ac_word=$2
-echo "$as_me:$LINENO: checking for $ac_word" >&5
-echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
-if test "${ac_cv_prog_AWK+set}" = set; then
-else
- if test -n "$AWK"; then
- ac_cv_prog_AWK="$AWK" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
- ac_cv_prog_AWK="$ac_prog"
- echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
- break 2
- fi
-done
-done
-fi
-fi
-AWK=$ac_cv_prog_AWK
-if test -n "$AWK"; then
- echo "$as_me:$LINENO: result: $AWK" >&5
-echo "${ECHO_T}$AWK" >&6
-else
- echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
- test -n "$AWK" && break
-done
-echo "$as_me:$LINENO: checking whether ${MAKE-make} sets \$(MAKE)" >&5
-echo $ECHO_N "checking whether ${MAKE-make} sets \$(MAKE)... $ECHO_C" >&6
-set dummy ${MAKE-make}; ac_make=`echo "$2" | sed 'y,:./+-,___p_,'`
-if eval "test \"\${ac_cv_prog_make_${ac_make}_set+set}\" = set"; then
-else
- cat >conftest.make <<\_ACEOF
-all:
- @echo 'ac_maketemp="$(MAKE)"'
-_ACEOF
-# GNU make sometimes prints "make[1]: Entering...", which would confuse us.
-eval `${MAKE-make} -f conftest.make 2>/dev/null | grep temp=`
-if test -n "$ac_maketemp"; then
- eval ac_cv_prog_make_${ac_make}_set=yes
-else
- eval ac_cv_prog_make_${ac_make}_set=no
-fi
-rm -f conftest.make
-fi
-if eval "test \"`echo '$ac_cv_prog_make_'${ac_make}_set`\" = yes"; then
- echo "$as_me:$LINENO: result: yes" >&5
- SET_MAKE=
-else
- SET_MAKE="MAKE=${MAKE-make}"
-fi
-rm -rf .tst 2>/dev/null
-mkdir .tst 2>/dev/null
-if test -d .tst; then
- am__leading_dot=.
-else
- am__leading_dot=_
-fi
-rmdir .tst 2>/dev/null
-# test to see if srcdir already configured
-if test "`cd $srcdir && pwd`" != "`pwd`" &&
- test -f $srcdir/config.status; then
- { { echo "$as_me:$LINENO: error: source directory already configured; run \"make distclean\" there first" >&5
-echo "$as_me: error: source directory already configured; run \"make distclean\" there first" >&2;}
-fi
-# test whether we have cygpath
-if test -z "$CYGPATH_W"; then
- if (cygpath --version) >/dev/null 2>/dev/null; then
- CYGPATH_W='cygpath -w'
- else
- CYGPATH_W=echo
- fi
-fi
-# Define the identity of the package.
- PACKAGE='mapguide'
- VERSION='2.0.0'
-#define PACKAGE "$PACKAGE"
-_ACEOF
-#define VERSION "$VERSION"
-_ACEOF
-# Some tools Automake needs.
-ACLOCAL=${ACLOCAL-"${am_missing_run}aclocal-${am__api_version}"}
-AUTOCONF=${AUTOCONF-"${am_missing_run}autoconf"}
-AUTOMAKE=${AUTOMAKE-"${am_missing_run}automake-${am__api_version}"}
-AUTOHEADER=${AUTOHEADER-"${am_missing_run}autoheader"}
-MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
-install_sh=${install_sh-"$am_aux_dir/install-sh"}
-# Installed binaries are usually stripped using `strip' when the user
-# run `make install-strip'. However `strip' might not be the right
-# tool to use in cross-compilation environments, therefore Automake
-# will honor the `STRIP' environment variable to overrule this program.
-if test "$cross_compiling" != no; then
- if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
-set dummy ${ac_tool_prefix}strip; ac_word=$2
-if test "${ac_cv_prog_STRIP+set}" = set; then
-else
- if test -n "$STRIP"; then
- ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_STRIP="${ac_tool_prefix}strip"
- break 2
- fi
-done
-done
-fi
-fi
-STRIP=$ac_cv_prog_STRIP
-if test -n "$STRIP"; then
- echo "$as_me:$LINENO: result: $STRIP" >&5
-echo "${ECHO_T}$STRIP" >&6
-else
-fi
-fi
-if test -z "$ac_cv_prog_STRIP"; then
- ac_ct_STRIP=$STRIP
- # Extract the first word of "strip", so it can be a program name with args.
-set dummy strip; ac_word=$2
-if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then
-else
- if test -n "$ac_ct_STRIP"; then
- ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_STRIP="strip"
- break 2
- fi
-done
-done
- test -z "$ac_cv_prog_ac_ct_STRIP" && ac_cv_prog_ac_ct_STRIP=":"
-fi
-fi
-ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
-if test -n "$ac_ct_STRIP"; then
- echo "$as_me:$LINENO: result: $ac_ct_STRIP" >&5
-echo "${ECHO_T}$ac_ct_STRIP" >&6
-else
-fi
- STRIP=$ac_ct_STRIP
-else
- STRIP="$ac_cv_prog_STRIP"
-fi
-fi
-INSTALL_STRIP_PROGRAM="\${SHELL} \$(install_sh) -c -s"
-# We need awk for the "check" target. The system "awk" is bad on
-# some platforms.
-# Always define AMTAR for backward compatibility.
-AMTAR=${AMTAR-"${am_missing_run}tar"}
-am__tar='${AMTAR} chof - "$$tardir"'; am__untar='${AMTAR} xf -'
-fi
- else
- CYGPATH_W=echo
- fi
-fi
- VERSION='2.0.0'
-_ACEOF
-_ACEOF
-else
-else
-do
- IFS=$as_save_IFS
- break 2
- fi
-done
-done
-fi
-fi
-else
-fi
-fi
-else
-else
-do
- IFS=$as_save_IFS
- break 2
- fi
-done
-done
-fi
-fi
-else
-fi
-else
-fi
-fi
-# some platforms.
-echo "$as_me:$LINENO: checking how to create a pax tar archive" >&5
-echo $ECHO_N "checking how to create a pax tar archive... $ECHO_C" >&6
-# Loop over all known methods to create a tar archive until one works.
-_am_tools='gnutar pax cpio none'
-_am_tools=${am_cv_prog_tar_pax-$_am_tools}
-# Do not fold the above two line into one, because Tru64 sh and
-# Solaris sh will not grok spaces in the rhs of `-'.
-for _am_tool in $_am_tools
-do
- case $_am_tool in
- gnutar)
- for _am_tar in tar gnutar gtar;
- do
- { echo "$as_me:$LINENO: $_am_tar --version" >&5
- ($_am_tar --version) >&5 2>&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); } && break
- done
- am__tar="$_am_tar --format=posix -chf - "'"$$tardir"'
- am__tar_="$_am_tar --format=posix -chf - "'"$tardir"'
- am__untar="$_am_tar -xf -"
- plaintar)
- # Must skip GNU tar: if it does not support --format= it doesn't create
- # ustar tarball either.
- (tar --version) >/dev/null 2>&1 && continue
- am__tar='tar chf - "$$tardir"'
- am__tar_='tar chf - "$tardir"'
- am__untar='tar xf -'
- pax)
- am__tar='pax -L -x pax -w "$$tardir"'
- am__tar_='pax -L -x pax -w "$tardir"'
- am__untar='pax -r'
- cpio)
- am__tar='find "$$tardir" -print | cpio -o -H pax -L'
- am__tar_='find "$tardir" -print | cpio -o -H pax -L'
- am__untar='cpio -i -H pax -d'
- none)
- am__tar=false
- am__tar_=false
- am__untar=false
- esac
- # If the value was cached, stop now. We just wanted to have am__tar
- # and am__untar set.
- test -n "${am_cv_prog_tar_pax}" && break
- # tar/untar a dummy directory, and stop if the command works
- rm -rf conftest.dir
- mkdir conftest.dir
- echo GrepMe > conftest.dir/file
- { echo "$as_me:$LINENO: tardir=conftest.dir && eval $am__tar_ >conftest.tar" >&5
- (tardir=conftest.dir && eval $am__tar_ >conftest.tar) >&5 2>&5
- ac_status=$?
- if test -s conftest.tar; then
- { echo "$as_me:$LINENO: $am__untar <conftest.tar" >&5
- ($am__untar <conftest.tar) >&5 2>&5
- ac_status=$?
- grep GrepMe conftest.dir/file >/dev/null 2>&1 && break
- fi
-done
-rm -rf conftest.dir
-if test "${am_cv_prog_tar_pax+set}" = set; then
-else
- am_cv_prog_tar_pax=$_am_tool
-fi
-echo "$as_me:$LINENO: result: $am_cv_prog_tar_pax" >&5
-echo "${ECHO_T}$am_cv_prog_tar_pax" >&6
-ac_ext=c
-ac_ext=c
-if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
-set dummy ${ac_tool_prefix}gcc; ac_word=$2
-if test "${ac_cv_prog_CC+set}" = set; then
-else
- if test -n "$CC"; then
- ac_cv_prog_CC="$CC" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="${ac_tool_prefix}gcc"
- break 2
- fi
-done
-done
-fi
-fi
-CC=$ac_cv_prog_CC
-if test -n "$CC"; then
- echo "$as_me:$LINENO: result: $CC" >&5
-echo "${ECHO_T}$CC" >&6
-else
-fi
-fi
-if test -z "$ac_cv_prog_CC"; then
- ac_ct_CC=$CC
- # Extract the first word of "gcc", so it can be a program name with args.
-set dummy gcc; ac_word=$2
-if test "${ac_cv_prog_ac_ct_CC+set}" = set; then
-else
- if test -n "$ac_ct_CC"; then
- ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CC="gcc"
- break 2
- fi
-done
-done
-fi
-fi
-ac_ct_CC=$ac_cv_prog_ac_ct_CC
-if test -n "$ac_ct_CC"; then
- echo "$as_me:$LINENO: result: $ac_ct_CC" >&5
-echo "${ECHO_T}$ac_ct_CC" >&6
-else
-fi
- CC=$ac_ct_CC
-else
- CC="$ac_cv_prog_CC"
-fi
-if test -z "$CC"; then
- # Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
-set dummy ${ac_tool_prefix}cc; ac_word=$2
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="${ac_tool_prefix}cc"
- break 2
- fi
-done
-done
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
-fi
- ac_ct_CC=$CC
- # Extract the first word of "cc", so it can be a program name with args.
-set dummy cc; ac_word=$2
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CC="cc"
- break 2
- fi
-done
-done
-fi
-fi
-else
-fi
- CC=$ac_ct_CC
-else
-fi
-fi
-else
-else
- ac_prog_rejected=no
-do
- IFS=$as_save_IFS
- if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
- ac_prog_rejected=yes
- continue
- fi
- ac_cv_prog_CC="cc"
- break 2
- fi
-done
-done
-if test $ac_prog_rejected = yes; then
- # We found a bogon in the path, so make sure we never use it.
- set dummy $ac_cv_prog_CC
- shift
- if test $# != 0; then
- # We chose a different compiler from the bogus one.
- # However, it has the same basename, so the bogon will be chosen
- # first if we set CC to just the basename; use the full file name.
- shift
- ac_cv_prog_CC="$as_dir/$ac_word${1+' '}$@"
- fi
-fi
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
-fi
- for ac_prog in cl
- do
- # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
-set dummy $ac_tool_prefix$ac_prog; ac_word=$2
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
- test -n "$CC" && break
- done
-fi
- ac_ct_CC=$CC
- for ac_prog in cl
-do
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CC="$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-else
-fi
- test -n "$ac_ct_CC" && break
-done
- CC=$ac_ct_CC
-fi
-fi
-test -z "$CC" && { { echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH
-See \`config.log' for more details." >&5
-echo "$as_me: error: no acceptable C compiler found in \$PATH
-See \`config.log' for more details." >&2;}
-# Provide some information about the compiler.
-echo "$as_me:$LINENO:" \
- "checking for C compiler version" >&5
-ac_compiler=`set X $ac_compile; echo $2`
-{ (eval echo "$as_me:$LINENO: \"$ac_compiler --version </dev/null >&5\"") >&5
- (eval $ac_compiler --version </dev/null >&5) 2>&5
- ac_status=$?
-{ (eval echo "$as_me:$LINENO: \"$ac_compiler -v </dev/null >&5\"") >&5
- (eval $ac_compiler -v </dev/null >&5) 2>&5
- ac_status=$?
-{ (eval echo "$as_me:$LINENO: \"$ac_compiler -V </dev/null >&5\"") >&5
- (eval $ac_compiler -V </dev/null >&5) 2>&5
- ac_status=$?
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-ac_clean_files_save=$ac_clean_files
-ac_clean_files="$ac_clean_files a.out a.exe b.out"
-# Try to create an executable without -o first, disregard a.out.
-# It will help us diagnose broken compilers, and finding out an intuition
-# of exeext.
-echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
-echo $ECHO_N "checking for C compiler default output file name... $ECHO_C" >&6
-ac_link_default=`echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
-if { (eval echo "$as_me:$LINENO: \"$ac_link_default\"") >&5
- (eval $ac_link_default) 2>&5
- ac_status=$?
- (exit $ac_status); }; then
- # Find the output, starting from the most likely. This scheme is
-# not robust to junk in `.', hence go to wildcards (a.*) only as a last
-# resort.
-# Be careful to initialize this variable, since it used to be cached.
-# Otherwise an old cache value of `no' led to `EXEEXT = no' in a Makefile.
-ac_cv_exeext=
-# b.out is created by i960 compilers.
-for ac_file in a_out.exe a.exe conftest.exe a.out conftest a.* conftest.* b.out
-do
- test -f "$ac_file" || continue
- case $ac_file in
- *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj )
- conftest.$ac_ext )
- # This is the source file.
- [ab].out )
- # We found the default executable, but exeext='' is most
- # certainly right.
- break;;
- ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
- # FIXME: I believe we export ac_cv_exeext for Libtool,
- # but it would be cool to find out if it's true. Does anybody
- # maintain Libtool? --akim.
- export ac_cv_exeext
- break;;
- break;;
- esac
-done
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-{ { echo "$as_me:$LINENO: error: C compiler cannot create executables
-echo "$as_me: error: C compiler cannot create executables
- { (exit 77); exit 77; }; }
-fi
-ac_exeext=$ac_cv_exeext
-echo "$as_me:$LINENO: result: $ac_file" >&5
-echo "${ECHO_T}$ac_file" >&6
-# Check the compiler produces executables we can run. If not, either
-# the compiler is broken, or we cross compile.
-echo "$as_me:$LINENO: checking whether the C compiler works" >&5
-echo $ECHO_N "checking whether the C compiler works... $ECHO_C" >&6
-# FIXME: These cross compiler hacks should be removed for Autoconf 3.0
-# If not cross compiling, check that we can run a simple program.
-if test "$cross_compiling" != yes; then
- if { ac_try='./$ac_file'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; }; then
- cross_compiling=no
- else
- if test "$cross_compiling" = maybe; then
- else
- { { echo "$as_me:$LINENO: error: cannot run C compiled programs.
-If you meant to cross compile, use \`--host'.
-echo "$as_me: error: cannot run C compiled programs.
- fi
- fi
-fi
-rm -f a.out a.exe conftest$ac_cv_exeext b.out
-ac_clean_files=$ac_clean_files_save
-echo "$as_me:$LINENO: checking whether we are cross compiling" >&5
-echo $ECHO_N "checking whether we are cross compiling... $ECHO_C" >&6
-echo "$as_me:$LINENO: result: $cross_compiling" >&5
-echo "${ECHO_T}$cross_compiling" >&6
-echo "$as_me:$LINENO: checking for suffix of executables" >&5
-echo $ECHO_N "checking for suffix of executables... $ECHO_C" >&6
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>&5
- ac_status=$?
- # If both `conftest.exe' and `conftest' are `present' (well, observable)
-# catch `conftest.exe'. For instance with Cygwin, `ls conftest' will
-# work properly (i.e., refer to `conftest.exe'), while it won't with
-# `rm'.
-for ac_file in conftest.exe conftest conftest.*; do
- case $ac_file in
- *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj ) ;;
- *.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
- break;;
- * ) break;;
- esac
-done
-else
- { { echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link
-echo "$as_me: error: cannot compute suffix of executables: cannot compile and link
-fi
-rm -f conftest$ac_cv_exeext
-echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5
-echo "${ECHO_T}$ac_cv_exeext" >&6
-rm -f conftest.$ac_ext
-EXEEXT=$ac_cv_exeext
-ac_exeext=$EXEEXT
-echo "$as_me:$LINENO: checking for suffix of object files" >&5
-echo $ECHO_N "checking for suffix of object files... $ECHO_C" >&6
-if test "${ac_cv_objext+set}" = set; then
-else
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.o conftest.obj
-if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- for ac_file in `(ls conftest.o conftest.obj; ls conftest.*) 2>/dev/null`; do
- case $ac_file in
- *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg ) ;;
- *) ac_cv_objext=`expr "$ac_file" : '.*\.\(.*\)'`
- break;;
- esac
-done
-else
-{ { echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile
-echo "$as_me: error: cannot compute suffix of object files: cannot compile
-fi
-rm -f conftest.$ac_cv_objext conftest.$ac_ext
-fi
-echo "$as_me:$LINENO: result: $ac_cv_objext" >&5
-echo "${ECHO_T}$ac_cv_objext" >&6
-OBJEXT=$ac_cv_objext
-ac_objext=$OBJEXT
-echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5
-echo $ECHO_N "checking whether we are using the GNU C compiler... $ECHO_C" >&6
-if test "${ac_cv_c_compiler_gnu+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-#ifndef __GNUC__
- choke me
-#endif
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext
- (eval $ac_compile) 2>conftest.er1
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- cat conftest.err >&5
- { ac_try='test -z "$ac_c_werror_flag"
- || test ! -s conftest.err'
- ac_status=$?
- (exit $ac_status); }; } &&
- { ac_try='test -s conftest.$ac_objext'
- ac_status=$?
- ac_compiler_gnu=yes
-else
-ac_compiler_gnu=no
-fi
-rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
-ac_cv_c_compiler_gnu=$ac_compiler_gnu
-fi
-echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5
-echo "${ECHO_T}$ac_cv_c_compiler_gnu" >&6
-GCC=`test $ac_compiler_gnu = yes && echo yes`
-ac_test_CFLAGS=${CFLAGS+set}
-ac_save_CFLAGS=$CFLAGS
-CFLAGS="-g"
-echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5
-echo $ECHO_N "checking whether $CC accepts -g... $ECHO_C" >&6
-if test "${ac_cv_prog_cc_g+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_prog_cc_g=yes
-else
-ac_cv_prog_cc_g=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
-echo "${ECHO_T}$ac_cv_prog_cc_g" >&6
-if test "$ac_test_CFLAGS" = set; then
- CFLAGS=$ac_save_CFLAGS
-elif test $ac_cv_prog_cc_g = yes; then
- if test "$GCC" = yes; then
- CFLAGS="-g -O2"
- else
- CFLAGS="-g"
- fi
-else
- CFLAGS="-O2"
- else
- CFLAGS=
- fi
-fi
-echo "$as_me:$LINENO: checking for $CC option to accept ANSI C" >&5
-echo $ECHO_N "checking for $CC option to accept ANSI C... $ECHO_C" >&6
-if test "${ac_cv_prog_cc_stdc+set}" = set; then
-else
- ac_cv_prog_cc_stdc=no
-ac_save_CC=$CC
-/* confdefs.h. */
-_ACEOF
-#include <stdarg.h>
-#include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
-struct buf { int x; };
-FILE * (*rcsopen) (struct buf *, struct stat *, int);
-static char *e (p, i)
- char **p;
- int i;
- return p[i];
-static char *f (char * (*g) (char **, int), char **p, ...)
- char *s;
- va_list v;
- va_start (v,p);
- s = g (p, va_arg (v,int));
- va_end (v);
- return s;
-/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default. It has
- function prototypes and stuff, but not '\xHH' hex character constants.
- These don't provoke an error unfortunately, instead are silently treated
- as 'x'. The following induces an error, until -std1 is added to get
- proper ANSI mode. Curiously '\x00'!='x' always comes out true, for an
- array size at least. It's necessary to write '\x00'==0 to get something
- that's true only with -std1. */
-int osf4_cc_array ['\x00' == 0 ? 1 : -1];
-int test (int i, double x);
-struct s1 {int (*f) (int a);};
-struct s2 {int (*f) (double a);};
-int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int);
-int argc;
-char **argv;
-int
-main ()
-return f (e, argv, 0) != argv[0] || f (e, argv, 1) != argv[1];
- return 0;
-_ACEOF
-# Don't try gcc -ansi; that turns off useful extensions and
-# breaks some systems' header files.
-# AIX -qlanglvl=ansi
-# Ultrix and OSF/1 -std1
-# HP-UX 10.20 and later -Ae
-# HP-UX older versions -Aa -D_HPUX_SOURCE
-# SVR4 -Xc -D__EXTENSIONS__
-for ac_arg in "" -qlanglvl=ansi -std1 -Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
-do
- CC="$ac_save_CC $ac_arg"
- rm -f conftest.$ac_objext
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_prog_cc_stdc=$ac_arg
-break
-else
-fi
-done
-rm -f conftest.$ac_ext conftest.$ac_objext
-CC=$ac_save_CC
-fi
-case "x$ac_cv_prog_cc_stdc" in
- x|xno)
- echo "$as_me:$LINENO: result: none needed" >&5
-echo "${ECHO_T}none needed" >&6 ;;
- echo "$as_me:$LINENO: result: $ac_cv_prog_cc_stdc" >&5
-echo "${ECHO_T}$ac_cv_prog_cc_stdc" >&6
- CC="$CC $ac_cv_prog_cc_stdc" ;;
-esac
-# Some people use a C++ compiler to compile C. Since we use `exit',
-# in C++ we need to declare it. In case someone uses the same compiler
-# for both compiling C and C++ we need to have the C++ compiler decide
-# the declaration of exit, since it's the most demanding environment.
-#ifndef __cplusplus
- choke me
-#endif
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- for ac_declaration in \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
-/* confdefs.h. */
-_ACEOF
-$ac_declaration
-#include <stdlib.h>
-int
-main ()
-exit (42);
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-else
-continue
-fi
-/* confdefs.h. */
-_ACEOF
-$ac_declaration
-int
-main ()
-exit (42);
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- break
-else
-fi
-done
-rm -f conftest*
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
-fi
-ac_ext=c
-DEPDIR="${am__leading_dot}deps"
- ac_config_commands="$ac_config_commands depfiles"
-am_make=${MAKE-make}
-cat > confinc << 'END'
-am__doit:
- @echo done
-.PHONY: am__doit
-END
-# If we don't find an include directive, just comment out the code.
-echo "$as_me:$LINENO: checking for style of include used by $am_make" >&5
-echo $ECHO_N "checking for style of include used by $am_make... $ECHO_C" >&6
-am__include="#"
-am__quote=
-_am_result=none
-# First try GNU make style include.
-echo "include confinc" > confmf
-# We grep out `Entering directory' and `Leaving directory'
-# messages which can occur if `w' ends up in MAKEFLAGS.
-# In particular we don't look at `^make:' because GNU make might
-# be invoked under some other name (usually "gmake"), in which
-# case it prints its new name instead of `make'.
-if test "`$am_make -s -f confmf 2> /dev/null | grep -v 'ing directory'`" = "done"; then
- am__include=include
- am__quote=
- _am_result=GNU
-fi
-# Now try BSD make style include.
-if test "$am__include" = "#"; then
- echo '.include "confinc"' > confmf
- if test "`$am_make -s -f confmf 2> /dev/null`" = "done"; then
- am__include=.include
- am__quote="\""
- _am_result=BSD
- fi
-fi
-echo "$as_me:$LINENO: result: $_am_result" >&5
-echo "${ECHO_T}$_am_result" >&6
-rm -f confinc confmf
-# Check whether --enable-dependency-tracking or --disable-dependency-tracking was given.
-if test "${enable_dependency_tracking+set}" = set; then
- enableval="$enable_dependency_tracking"
-fi;
-if test "x$enable_dependency_tracking" != xno; then
- am_depcomp="$ac_aux_dir/depcomp"
- AMDEPBACKSLASH='\'
-fi
- AMDEP_TRUE=
- AMDEP_FALSE='#'
-else
- AMDEP_TRUE='#'
- AMDEP_FALSE=
-fi
-depcc="$CC" am_compiler_list=
-echo "$as_me:$LINENO: checking dependency style of $depcc" >&5
-echo $ECHO_N "checking dependency style of $depcc... $ECHO_C" >&6
-if test "${am_cv_CC_dependencies_compiler_type+set}" = set; then
-else
- if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
- # We make a subdir and do the tests there. Otherwise we can end up
- # making bogus files that we don't know about and never remove. For
- # instance it was reported that on HP-UX the gcc test will end up
- # making a dummy file named `D' -- because `-MD' means `put the output
- # in D'.
- # Copy depcomp to subdir because otherwise we won't find it if we're
- # using a relative directory.
- cp "$am_depcomp" conftest.dir
- cd conftest.dir
- # We will build objects and dependencies in a subdirectory because
- # it helps to detect inapplicable dependency modes. For instance
- # both Tru64's cc and ICC support -MD to output dependencies as a
- # side effect of compilation, but ICC will put the dependencies in
- # the current directory while Tru64 will put them in the object
- # directory.
- mkdir sub
- am_cv_CC_dependencies_compiler_type=none
- if test "$am_compiler_list" = ""; then
- am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
- fi
- for depmode in $am_compiler_list; do
- # Setup a source with many dependencies, because some compilers
- # like to wrap large dependency lists on column 80 (with \), and
- # we should not choose a depcomp mode which is confused by this.
- # We need to recreate these files for each test, as the compiler may
- # overwrite some of them when testing with obscure command lines.
- # This happens at least with the AIX C compiler.
- : > sub/conftest.c
- for i in 1 2 3 4 5 6; do
- echo '#include "conftst'$i'.h"' >> sub/conftest.c
- # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
- # Solaris 8's {/usr,}/bin/sh.
- touch sub/conftst$i.h
- done
- echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
- case $depmode in
- nosideeffect)
- # after this tag, mechanisms are not by side-effect, so they'll
- # only be used when explicitly requested
- if test "x$enable_dependency_tracking" = xyes; then
- continue
- else
- break
- fi
- none) break ;;
- esac
- # We check with `-c' and `-o' for the sake of the "dashmstdout"
- # mode. It turns out that the SunPro C++ compiler does not properly
- # handle `-M -o', and we need to detect this.
- if depmode=$depmode \
- source=sub/conftest.c object=sub/conftest.${OBJEXT-o} \
- depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
- $SHELL ./depcomp $depcc -c -o sub/conftest.${OBJEXT-o} sub/conftest.c \
- >/dev/null 2>conftest.err &&
- grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
- grep sub/conftest.${OBJEXT-o} sub/conftest.Po > /dev/null 2>&1 &&
- ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
- # icc doesn't choke on unknown options, it will just issue warnings
- # or remarks (even with -Werror). So we grep stderr for any message
- # that says an option was ignored or not supported.
- # When given -MP, icc 7.0 and 7.1 complain thusly:
- # icc: Command line warning: ignoring option '-M'; no argument required
- # The diagnosis changed in icc 8.0:
- # icc: Command line remark: option '-MP' not supported
- if (grep 'ignoring option' conftest.err ||
- grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
- am_cv_CC_dependencies_compiler_type=$depmode
- break
- fi
- fi
- done
- cd ..
-else
-fi
-fi
-echo "$as_me:$LINENO: result: $am_cv_CC_dependencies_compiler_type" >&5
-echo "${ECHO_T}$am_cv_CC_dependencies_compiler_type" >&6
-CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
-if
- test "x$enable_dependency_tracking" != xno \
- && test "$am_cv_CC_dependencies_compiler_type" = gcc3; then
- am__fastdepCC_TRUE=
- am__fastdepCC_FALSE='#'
-else
- am__fastdepCC_TRUE='#'
-fi
-else
- # in D'.
- cd conftest.dir
- # directory.
- mkdir sub
- fi
- done
- case $depmode in
- nosideeffect)
- continue
- else
- break
- fi
- none) break ;;
- esac
- break
- fi
- fi
- done
- cd ..
-else
-fi
-fi
-if
-else
-fi
-ac_ext=cc
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-ac_ext=cc
- for ac_prog in $CCC g++ c++ gpp aCC CC cxx cc++ cl FCC KCC RCC xlC_r xlC
- do
-if test "${ac_cv_prog_CXX+set}" = set; then
-else
- if test -n "$CXX"; then
- ac_cv_prog_CXX="$CXX" # Let the user override the test.
-else
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- ac_cv_prog_CXX="$ac_tool_prefix$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-CXX=$ac_cv_prog_CXX
-if test -n "$CXX"; then
- echo "$as_me:$LINENO: result: $CXX" >&5
-echo "${ECHO_T}$CXX" >&6
-else
-fi
- test -n "$CXX" && break
- done
-fi
-if test -z "$CXX"; then
- ac_ct_CXX=$CXX
-do
-if test "${ac_cv_prog_ac_ct_CXX+set}" = set; then
-else
- if test -n "$ac_ct_CXX"; then
- ac_cv_prog_ac_ct_CXX="$ac_ct_CXX" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CXX="$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-ac_ct_CXX=$ac_cv_prog_ac_ct_CXX
-if test -n "$ac_ct_CXX"; then
- echo "$as_me:$LINENO: result: $ac_ct_CXX" >&5
-echo "${ECHO_T}$ac_ct_CXX" >&6
-else
-fi
- test -n "$ac_ct_CXX" && break
-done
-test -n "$ac_ct_CXX" || ac_ct_CXX="g++"
- CXX=$ac_ct_CXX
-fi
- "checking for C++ compiler version" >&5
- ac_status=$?
- ac_status=$?
- ac_status=$?
-echo "$as_me:$LINENO: checking whether we are using the GNU C++ compiler" >&5
-echo $ECHO_N "checking whether we are using the GNU C++ compiler... $ECHO_C" >&6
-if test "${ac_cv_cxx_compiler_gnu+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-#ifndef __GNUC__
- choke me
-#endif
- return 0;
-_ACEOF
- ac_status=$?
- { ac_try='test -z "$ac_cxx_werror_flag"
- ac_status=$?
- ac_status=$?
-else
-ac_compiler_gnu=no
-fi
-ac_cv_cxx_compiler_gnu=$ac_compiler_gnu
-fi
-echo "$as_me:$LINENO: result: $ac_cv_cxx_compiler_gnu" >&5
-echo "${ECHO_T}$ac_cv_cxx_compiler_gnu" >&6
-GXX=`test $ac_compiler_gnu = yes && echo yes`
-ac_test_CXXFLAGS=${CXXFLAGS+set}
-ac_save_CXXFLAGS=$CXXFLAGS
-CXXFLAGS="-g"
-echo "$as_me:$LINENO: checking whether $CXX accepts -g" >&5
-echo $ECHO_N "checking whether $CXX accepts -g... $ECHO_C" >&6
-if test "${ac_cv_prog_cxx_g+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_prog_cxx_g=yes
-else
-ac_cv_prog_cxx_g=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_cxx_g" >&5
-echo "${ECHO_T}$ac_cv_prog_cxx_g" >&6
-if test "$ac_test_CXXFLAGS" = set; then
- CXXFLAGS=$ac_save_CXXFLAGS
-elif test $ac_cv_prog_cxx_g = yes; then
- if test "$GXX" = yes; then
- CXXFLAGS="-g -O2"
- else
- CXXFLAGS="-g"
- fi
-else
- CXXFLAGS="-O2"
- else
- CXXFLAGS=
- fi
-fi
-for ac_declaration in \
-do
-/* confdefs.h. */
-_ACEOF
-$ac_declaration
-int
-main ()
-exit (42);
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-else
-continue
-fi
-/* confdefs.h. */
-_ACEOF
-$ac_declaration
-int
-main ()
-exit (42);
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- break
-else
-fi
-done
-rm -f conftest*
-fi
-ac_ext=cc
-depcc="$CXX" am_compiler_list=
-if test "${am_cv_CXX_dependencies_compiler_type+set}" = set; then
-else
- # in D'.
- cd conftest.dir
- # directory.
- mkdir sub
- am_cv_CXX_dependencies_compiler_type=none
- fi
- done
- case $depmode in
- nosideeffect)
- continue
- else
- break
- fi
- none) break ;;
- esac
- am_cv_CXX_dependencies_compiler_type=$depmode
- break
- fi
- fi
- done
- cd ..
-else
-fi
-fi
-echo "$as_me:$LINENO: result: $am_cv_CXX_dependencies_compiler_type" >&5
-echo "${ECHO_T}$am_cv_CXX_dependencies_compiler_type" >&6
-CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
-if
- && test "$am_cv_CXX_dependencies_compiler_type" = gcc3; then
- am__fastdepCXX_TRUE=
- am__fastdepCXX_FALSE='#'
-else
- am__fastdepCXX_TRUE='#'
-fi
-else
- # in D'.
- cd conftest.dir
- # directory.
- mkdir sub
- fi
- done
- case $depmode in
- nosideeffect)
- continue
- else
- break
- fi
- none) break ;;
- esac
- break
- fi
- fi
- done
- cd ..
-else
-fi
-fi
-if
-else
-fi
-# Check whether --enable-shared or --disable-shared was given.
-if test "${enable_shared+set}" = set; then
- enableval="$enable_shared"
- p=${PACKAGE-default}
- case $enableval in
- yes) enable_shared=yes ;;
- no) enable_shared=no ;;
- enable_shared=no
- # Look at the argument we got. We use all the common list separators.
- lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
- for pkg in $enableval; do
- IFS="$lt_save_ifs"
- if test "X$pkg" = "X$p"; then
- enable_shared=yes
- fi
- done
- esac
-else
- enable_shared=yes
-fi;
-# Check whether --enable-static or --disable-static was given.
-if test "${enable_static+set}" = set; then
- enableval="$enable_static"
- yes) enable_static=yes ;;
- no) enable_static=no ;;
- enable_static=no
- enable_static=yes
- fi
- done
- esac
-else
- enable_static=yes
-fi;
-# Check whether --enable-fast-install or --disable-fast-install was given.
-if test "${enable_fast_install+set}" = set; then
- enableval="$enable_fast_install"
- yes) enable_fast_install=yes ;;
- no) enable_fast_install=no ;;
- enable_fast_install=no
- enable_fast_install=yes
- fi
- done
- esac
-else
-fi;
-# Make sure we can run config.sub.
-$ac_config_sub sun4 >/dev/null 2>&1 ||
- { { echo "$as_me:$LINENO: error: cannot run $ac_config_sub" >&5
-echo "$as_me: error: cannot run $ac_config_sub" >&2;}
-echo "$as_me:$LINENO: checking build system type" >&5
-echo $ECHO_N "checking build system type... $ECHO_C" >&6
-if test "${ac_cv_build+set}" = set; then
-else
- ac_cv_build_alias=$build_alias
-test -z "$ac_cv_build_alias" &&
- ac_cv_build_alias=`$ac_config_guess`
- { { echo "$as_me:$LINENO: error: cannot guess build type; you must specify one" >&5
-echo "$as_me: error: cannot guess build type; you must specify one" >&2;}
- { (exit 1); exit 1; }; }
-ac_cv_build=`$ac_config_sub $ac_cv_build_alias` ||
- { { echo "$as_me:$LINENO: error: $ac_config_sub $ac_cv_build_alias failed" >&5
-echo "$as_me: error: $ac_config_sub $ac_cv_build_alias failed" >&2;}
-fi
-echo "$as_me:$LINENO: result: $ac_cv_build" >&5
-echo "${ECHO_T}$ac_cv_build" >&6
-build=$ac_cv_build
-build_cpu=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\1/'`
-build_vendor=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\2/'`
-build_os=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
-echo "$as_me:$LINENO: checking host system type" >&5
-echo $ECHO_N "checking host system type... $ECHO_C" >&6
-if test "${ac_cv_host+set}" = set; then
-else
- ac_cv_host_alias=$host_alias
-test -z "$ac_cv_host_alias" &&
- ac_cv_host_alias=$ac_cv_build_alias
-ac_cv_host=`$ac_config_sub $ac_cv_host_alias` ||
- { { echo "$as_me:$LINENO: error: $ac_config_sub $ac_cv_host_alias failed" >&5
-echo "$as_me: error: $ac_config_sub $ac_cv_host_alias failed" >&2;}
-fi
-echo "$as_me:$LINENO: result: $ac_cv_host" >&5
-echo "${ECHO_T}$ac_cv_host" >&6
-host=$ac_cv_host
-host_cpu=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\1/'`
-host_vendor=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\2/'`
-host_os=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
-echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
-echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6
-if test "${lt_cv_path_SED+set}" = set; then
-else
- # Loop through the user's path and test for sed and gsed.
-# Then use that list of sed's as ones to test for truncation.
-do
- IFS=$as_save_IFS
- for lt_ac_prog in sed gsed; do
- if $as_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
- lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
- fi
- done
- done
-done
-lt_ac_max=0
-lt_ac_count=0
-# Add /usr/xpg4/bin/sed as it is typically found on Solaris
-# along with /bin/sed that truncates output.
-for lt_ac_sed in $lt_ac_sed_list /usr/xpg4/bin/sed; do
- test ! -f $lt_ac_sed && break
- cat /dev/null > conftest.in
- lt_ac_count=0
- echo $ECHO_N "0123456789$ECHO_C" >conftest.in
- # Check for GNU sed and select it if it is found.
- if "$lt_ac_sed" --version 2>&1 < /dev/null | grep 'GNU' > /dev/null; then
- lt_cv_path_SED=$lt_ac_sed
- break
- fi
- while true; do
- cat conftest.in conftest.in >conftest.tmp
- mv conftest.tmp conftest.in
- cp conftest.in conftest.nl
- echo >>conftest.nl
- $lt_ac_sed -e 's/a$//' < conftest.nl >conftest.out || break
- cmp -s conftest.out conftest.nl || break
- # 10000 chars as input seems more than enough
- test $lt_ac_count -gt 10 && break
- lt_ac_count=`expr $lt_ac_count + 1`
- if test $lt_ac_count -gt $lt_ac_max; then
- lt_ac_max=$lt_ac_count
- fi
- done
-done
-SED=$lt_cv_path_SED
-fi
-echo "$as_me:$LINENO: result: $SED" >&5
-echo "${ECHO_T}$SED" >&6
-echo "$as_me:$LINENO: checking for egrep" >&5
-echo $ECHO_N "checking for egrep... $ECHO_C" >&6
-if test "${ac_cv_prog_egrep+set}" = set; then
-else
- if echo a | (grep -E '(a|b)') >/dev/null 2>&1
- then ac_cv_prog_egrep='grep -E'
- else ac_cv_prog_egrep='egrep'
- fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_egrep" >&5
-echo "${ECHO_T}$ac_cv_prog_egrep" >&6
- EGREP=$ac_cv_prog_egrep
-# Check whether --with-gnu-ld or --without-gnu-ld was given.
-if test "${with_gnu_ld+set}" = set; then
- withval="$with_gnu_ld"
- test "$withval" = no || with_gnu_ld=yes
-else
- with_gnu_ld=no
-fi;
-ac_prog=ld
-if test "$GCC" = yes; then
- # Check if gcc -print-prog-name=ld gives a path.
- echo "$as_me:$LINENO: checking for ld used by $CC" >&5
-echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- re_direlt='/[^/][^/]*/\.\./'
- # Canonicalize the pathname of ld
- ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
- while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- echo "$as_me:$LINENO: checking for GNU ld" >&5
-echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
-else
- echo "$as_me:$LINENO: checking for non-GNU ld" >&5
-echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
-fi
-if test "${lt_cv_path_LD+set}" = set; then
-else
- if test -z "$LD"; then
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for ac_dir in $PATH; do
- test -z "$ac_dir" && ac_dir=.
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some GNU ld's only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
- *GNU* | *'with BFD'*)
- test "$with_gnu_ld" != no && break
- test "$with_gnu_ld" != yes && break
- esac
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi
-fi
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- echo "$as_me:$LINENO: result: $LD" >&5
-echo "${ECHO_T}$LD" >&6
-else
-fi
-test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
-echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
-echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
-echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
-if test "${lt_cv_prog_gnu_ld+set}" = set; then
-else
- # I'd rather use --version here, but apparently some GNU ld's only accept -v.
-case `$LD -v 2>&1 </dev/null` in
-*GNU* | *'with BFD'*)
- lt_cv_prog_gnu_ld=yes
- lt_cv_prog_gnu_ld=no
-esac
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
-echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
-with_gnu_ld=$lt_cv_prog_gnu_ld
-echo "$as_me:$LINENO: checking for $LD option to reload object files" >&5
-echo $ECHO_N "checking for $LD option to reload object files... $ECHO_C" >&6
-if test "${lt_cv_ld_reload_flag+set}" = set; then
-else
- lt_cv_ld_reload_flag='-r'
-fi
-echo "$as_me:$LINENO: result: $lt_cv_ld_reload_flag" >&5
-echo "${ECHO_T}$lt_cv_ld_reload_flag" >&6
-reload_flag=$lt_cv_ld_reload_flag
-case $reload_flag in
-*) reload_flag=" $reload_flag" ;;
-esac
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-echo "$as_me:$LINENO: checking for BSD-compatible nm" >&5
-echo $ECHO_N "checking for BSD-compatible nm... $ECHO_C" >&6
-if test "${lt_cv_path_NM+set}" = set; then
-else
- if test -n "$NM"; then
- # Let the user override the test.
- lt_cv_path_NM="$NM"
-else
- for ac_dir in $PATH /usr/ccs/bin /usr/ucb /bin; do
- tmp_nm="$ac_dir/${ac_tool_prefix}nm"
- if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
- # Check to see if the nm accepts a BSD-compat flag.
- # Adding the `sed 1q' prevents false positives on HP-UX, which says:
- # nm: unknown option "B" ignored
- # Tru64's nm complains that /dev/null is an invalid object file
- case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
- */dev/null* | *'Invalid file or object type'*)
- lt_cv_path_NM="$tmp_nm -B"
- break
- case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
- */dev/null*)
- lt_cv_path_NM="$tmp_nm -p"
- break
- lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
- continue # so that we can try to find one that supports BSD flags
- esac
- esac
- fi
- done
- test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
-fi
-fi
-echo "$as_me:$LINENO: result: $lt_cv_path_NM" >&5
-echo "${ECHO_T}$lt_cv_path_NM" >&6
-NM="$lt_cv_path_NM"
-echo "$as_me:$LINENO: checking whether ln -s works" >&5
-echo $ECHO_N "checking whether ln -s works... $ECHO_C" >&6
-LN_S=$as_ln_s
-if test "$LN_S" = "ln -s"; then
-else
- echo "$as_me:$LINENO: result: no, using $LN_S" >&5
-echo "${ECHO_T}no, using $LN_S" >&6
-fi
-echo "$as_me:$LINENO: checking how to recognise dependent libraries" >&5
-echo $ECHO_N "checking how to recognise dependent libraries... $ECHO_C" >&6
-if test "${lt_cv_deplibs_check_method+set}" = set; then
-else
- lt_cv_file_magic_cmd='$MAGIC_CMD'
-lt_cv_file_magic_test_file=
-lt_cv_deplibs_check_method='unknown'
-# Need to set the preceding variable on all platforms that support
-# interlibrary dependencies.
-# 'none' -- dependencies not supported.
-# `unknown' -- same as none, but documents that we really don't know.
-# 'pass_all' -- all dependencies passed with no checks.
-# 'test_compile' -- check by making test program.
-# 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given extended regex.
-# If you have `file' or equivalent on your system and you're not sure
-# whether `pass_all' will *always* work, you probably want this one.
-case $host_os in
-aix4* | aix5*)
- lt_cv_deplibs_check_method=pass_all
-beos*)
-bsdi4*)
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib)'
- lt_cv_file_magic_cmd='/usr/bin/file -L'
- lt_cv_file_magic_test_file=/shlib/libc.so
-cygwin*)
- # func_win32_libid is a shell function defined in ltmain.sh
- lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
- lt_cv_file_magic_cmd='func_win32_libid'
-mingw* | pw32*)
- # Base MSYS/MinGW do not provide the 'file' command needed by
- # func_win32_libid shell function, so use a weaker test based on 'objdump'.
- lt_cv_deplibs_check_method='file_magic file format pei*-i386(.*architecture: i386)?'
- lt_cv_file_magic_cmd='$OBJDUMP -f'
-darwin* | rhapsody*)
-freebsd* | kfreebsd*-gnu)
- if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
- case $host_cpu in
- i*86 )
- # Not sure whether the presence of OpenBSD here was a mistake.
- # Let's accept both of them until this is cleared up.
- lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD)/i[3-9]86 (compact )?demand paged shared library'
- lt_cv_file_magic_cmd=/usr/bin/file
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
- esac
- else
- fi
-gnu*)
-hpux10.20* | hpux11*)
- case "$host_cpu" in
- ia64*)
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - IA64'
- lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
- hppa*64*)
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - PA-RISC [0-9].[0-9]'
- lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9].[0-9]) shared library'
- lt_cv_file_magic_test_file=/usr/lib/libc.sl
- esac
-irix5* | irix6* | nonstopux*)
- case $LD in
- *-32|*"-32 ") libmagic=32-bit;;
- *-n32|*"-n32 ") libmagic=N32;;
- *-64|*"-64 ") libmagic=64-bit;;
- *) libmagic=never-match;;
- esac
-# This must be Linux ELF.
-linux*)
- case $host_cpu in
- alpha*|hppa*|i*86|ia64*|m68*|mips*|powerpc*|sparc*|s390*|sh*|x86_64*)
- lt_cv_deplibs_check_method=pass_all ;;
- # glibc up to 2.1.1 does not perform some relocations on ARM
- # this will be overridden with pass_all, but let us keep it just in case
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB (shared object|dynamic lib )' ;;
- esac
- lt_cv_file_magic_test_file=`echo /lib/libc.so* /lib/libc-*.so`
-netbsd*)
- lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
- else
- lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|_pic\.a)$'
- fi
-newos6*)
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (executable|dynamic lib)'
- lt_cv_file_magic_test_file=/usr/lib/libnls.so
-nto-qnx*)
- lt_cv_deplibs_check_method=unknown
-openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB shared object'
- else
- lt_cv_deplibs_check_method='file_magic OpenBSD.* shared library'
- fi
-osf3* | osf4* | osf5*)
-sco3.2v5*)
-solaris*)
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- case $host_vendor in
- motorola)
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib) M[0-9][0-9]* Version [0-9]'
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
- ncr)
- sequent)
- lt_cv_file_magic_cmd='/bin/file'
- sni)
- lt_cv_deplibs_check_method="file_magic ELF [0-9][0-9]*-bit [LM]SB dynamic lib"
- lt_cv_file_magic_test_file=/lib/libc.so
- siemens)
- esac
-sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7* | sysv4*uw2*)
-esac
-fi
-echo "$as_me:$LINENO: result: $lt_cv_deplibs_check_method" >&5
-echo "${ECHO_T}$lt_cv_deplibs_check_method" >&6
-file_magic_cmd=$lt_cv_file_magic_cmd
-deplibs_check_method=$lt_cv_deplibs_check_method
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-# Check whether --enable-libtool-lock or --disable-libtool-lock was given.
-if test "${enable_libtool_lock+set}" = set; then
- enableval="$enable_libtool_lock"
-fi;
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-ia64-*-hpux*)
- # Find out which ABI we are using.
- echo 'int i;' > conftest.$ac_ext
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- ac_status=$?
- case `/usr/bin/file conftest.$ac_objext` in
- *ELF-32*)
- HPUX_IA64_MODE="32"
- *ELF-64*)
- HPUX_IA64_MODE="64"
- esac
- fi
- rm -rf conftest*
-*-*-irix6*)
- echo '#line 4599 "configure"' > conftest.$ac_ext
- ac_status=$?
- if test "$lt_cv_prog_gnu_ld" = yes; then
- *32-bit*)
- LD="${LD-ld} -melf32bsmip"
- *N32*)
- LD="${LD-ld} -melf32bmipn32"
- *64-bit*)
- LD="${LD-ld} -melf64bmip"
- esac
- else
- *32-bit*)
- LD="${LD-ld} -32"
- *N32*)
- LD="${LD-ld} -n32"
- *64-bit*)
- LD="${LD-ld} -64"
- esac
- fi
- fi
- rm -rf conftest*
-x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*|s390*-*linux*|sparc*-*linux*)
- ac_status=$?
- case "`/usr/bin/file conftest.o`" in
- *32-bit*)
- case $host in
- x86_64-*linux*)
- LD="${LD-ld} -m elf_i386"
- ppc64-*linux*|powerpc64-*linux*)
- LD="${LD-ld} -m elf32ppclinux"
- s390x-*linux*)
- LD="${LD-ld} -m elf_s390"
- sparc64-*linux*)
- LD="${LD-ld} -m elf32_sparc"
- esac
- *64-bit*)
- case $host in
- x86_64-*linux*)
- LD="${LD-ld} -m elf_x86_64"
- ppc*-*linux*|powerpc*-*linux*)
- LD="${LD-ld} -m elf64ppc"
- s390*-*linux*)
- LD="${LD-ld} -m elf64_s390"
- sparc*-*linux*)
- LD="${LD-ld} -m elf64_sparc"
- esac
- esac
- fi
- rm -rf conftest*
-*-*-sco3.2v5*)
- # On SCO OpenServer 5, we need -belf to get full-featured binaries.
- SAVE_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -belf"
- echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
-echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6
-if test "${lt_cv_cc_needs_belf+set}" = set; then
-else
- ac_ext=c
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- ac_status=$?
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- lt_cv_cc_needs_belf=yes
-else
-lt_cv_cc_needs_belf=no
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
- ac_ext=c
-fi
-echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
-echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6
- if test x"$lt_cv_cc_needs_belf" != x"yes"; then
- # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
- CFLAGS="$SAVE_CFLAGS"
- fi
-esac
-need_locks="$enable_libtool_lock"
-ac_ext=c
-echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
-echo $ECHO_N "checking how to run the C preprocessor... $ECHO_C" >&6
-# On Suns, sometimes $CPP names a directory.
-if test -n "$CPP" && test -d "$CPP"; then
- CPP=
-fi
-if test -z "$CPP"; then
- if test "${ac_cv_prog_CPP+set}" = set; then
-else
- # Double quotes because CPP needs to be expanded
- for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
- do
- ac_preproc_ok=false
-for ac_c_preproc_warn_flag in '' yes
-do
- # Use a header file that comes with gcc, so configuring glibc
- # with a fresh cross-compiler works.
- # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- # <limits.h> exists even on freestanding compilers.
- # On the NeXT, cc -E runs the code through the compiler's parser,
- # not just through cpp. "Syntax error" is here to catch this case.
-/* confdefs.h. */
-_ACEOF
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
- Syntax error
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
- (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
- ac_status=$?
- (exit $ac_status); } >/dev/null; then
- if test -s conftest.err; then
- ac_cpp_err=$ac_c_preproc_warn_flag
- ac_cpp_err=$ac_cpp_err$ac_c_werror_flag
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-if test -z "$ac_cpp_err"; then
-else
- # Broken: fails on valid input.
-continue
-fi
-rm -f conftest.err conftest.$ac_ext
- # OK, works on sane cases. Now check whether non-existent headers
- # can be detected and how.
-/* confdefs.h. */
-_ACEOF
-#include <ac_nonexistent.h>
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
- # Broken: success on invalid input.
-continue
-else
- # Passes both tests.
-ac_preproc_ok=:
-break
-fi
-done
-# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-if $ac_preproc_ok; then
- break
-fi
- done
- ac_cv_prog_CPP=$CPP
-fi
- CPP=$ac_cv_prog_CPP
-else
-fi
-echo "$as_me:$LINENO: result: $CPP" >&5
-echo "${ECHO_T}$CPP" >&6
-ac_preproc_ok=false
-do
-/* confdefs.h. */
-_ACEOF
-#ifdef __STDC__
-#else
-#endif
- Syntax error
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-else
-continue
-fi
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-continue
-else
-ac_preproc_ok=:
-break
-fi
-done
-else
- { { echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
-echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
-fi
-ac_ext=c
-echo "$as_me:$LINENO: checking for ANSI C header files" >&5
-echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
-if test "${ac_cv_header_stdc+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-#include <string.h>
-#include <float.h>
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_header_stdc=yes
-else
-ac_cv_header_stdc=no
-fi
-if test $ac_cv_header_stdc = yes; then
- # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then
-else
- ac_cv_header_stdc=no
-fi
-rm -f conftest*
-fi
- # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- $EGREP "free" >/dev/null 2>&1; then
-else
-fi
-rm -f conftest*
-fi
- # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
- if test "$cross_compiling" = yes; then
-else
-/* confdefs.h. */
-_ACEOF
-#include <ctype.h>
-#if ((' ' & 0x0FF) == 0x020)
-# define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
-# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
-#else
-# define ISLOWER(c) \
- (('a' <= (c) && (c) <= 'i') \
- || ('j' <= (c) && (c) <= 'r') \
- || ('s' <= (c) && (c) <= 'z'))
-# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
-#endif
-#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
-int
-main ()
- int i;
- for (i = 0; i < 256; i++)
- if (XOR (islower (i), ISLOWER (i))
- || toupper (i) != TOUPPER (i))
- exit(2);
- exit (0);
-_ACEOF
-rm -f conftest$ac_exeext
- ac_status=$?
- (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
- ac_status=$?
-else
- echo "$as_me: program exited with status $ac_status" >&5
-echo "$as_me: failed program was:" >&5
-( exit $ac_status )
-fi
-rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
-fi
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
-echo "${ECHO_T}$ac_cv_header_stdc" >&6
-cat >>confdefs.h <<\_ACEOF
-#define STDC_HEADERS 1
-_ACEOF
-fi
-# On IRIX 5.3, sys/types and inttypes.h are conflicting.
-for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
- inttypes.h stdint.h unistd.h
-do
-as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
-echo "$as_me:$LINENO: checking for $ac_header" >&5
-echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6
-if eval "test \"\${$as_ac_Header+set}\" = set"; then
-else
-/* confdefs.h. */
-_ACEOF
-$ac_includes_default
-#include <$ac_header>
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- eval "$as_ac_Header=yes"
-else
-eval "$as_ac_Header=no"
-fi
-fi
-echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Header'}'`" >&5
-echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
-if test `eval echo '${'$as_ac_Header'}'` = yes; then
- cat >>confdefs.h <<_ACEOF
-#define `echo "HAVE_$ac_header" | $as_tr_cpp` 1
-_ACEOF
-fi
-done
-for ac_header in dlfcn.h
-do
- echo "$as_me:$LINENO: checking for $ac_header" >&5
- echo $ECHO_N "(cached) $ECHO_C" >&6
-fi
-else
- # Is the header compilable?
-echo "$as_me:$LINENO: checking $ac_header usability" >&5
-echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_header_compiler=yes
-else
-ac_header_compiler=no
-fi
-echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
-echo "${ECHO_T}$ac_header_compiler" >&6
-# Is the header present?
-echo "$as_me:$LINENO: checking $ac_header presence" >&5
-echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
- ac_header_preproc=yes
-else
- ac_header_preproc=no
-fi
-echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
-echo "${ECHO_T}$ac_header_preproc" >&6
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
- yes:no: )
- { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
-echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
-echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
-echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
-echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
-echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
-echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
- cat <<\_ASBOX
-## Report this to http://mapguide.osgeo.org ##
-_ASBOX
- sed "s/^/$as_me: WARNING: /" >&2
-esac
-else
- eval "$as_ac_Header=\$ac_header_preproc"
-fi
-fi
-_ACEOF
-fi
-done
-ac_ext=cc
-echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
-echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6
-if test -z "$CXXCPP"; then
- if test "${ac_cv_prog_CXXCPP+set}" = set; then
-else
- # Double quotes because CXXCPP needs to be expanded
- for CXXCPP in "$CXX -E" "/lib/cpp"
- do
-for ac_cxx_preproc_warn_flag in '' yes
-do
-/* confdefs.h. */
-_ACEOF
-#ifdef __STDC__
-#else
-#endif
- Syntax error
-_ACEOF
- ac_status=$?
- ac_cpp_err=$ac_cxx_preproc_warn_flag
- ac_cpp_err=$ac_cpp_err$ac_cxx_werror_flag
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-else
-continue
-fi
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-continue
-else
-ac_preproc_ok=:
-break
-fi
-done
- break
-fi
- done
- ac_cv_prog_CXXCPP=$CXXCPP
-fi
- CXXCPP=$ac_cv_prog_CXXCPP
-else
-fi
-echo "$as_me:$LINENO: result: $CXXCPP" >&5
-echo "${ECHO_T}$CXXCPP" >&6
-do
-/* confdefs.h. */
-_ACEOF
-#ifdef __STDC__
-#else
-#endif
- Syntax error
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-else
-continue
-fi
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-continue
-else
-ac_preproc_ok=:
-break
-fi
-done
-else
- { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
-echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
-fi
-ac_ext=cc
-ac_ext=f
-ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
-ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_f77_compiler_gnu
- for ac_prog in g77 f77 xlf frt pgf77 fort77 fl32 af77 f90 xlf90 pgf90 epcf90 f95 fort xlf95 ifc efc pgf95 lf95 gfortran
- do
-if test "${ac_cv_prog_F77+set}" = set; then
-else
- if test -n "$F77"; then
- ac_cv_prog_F77="$F77" # Let the user override the test.
-else
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-do
- IFS=$as_save_IFS
- for ac_exec_ext in '' $ac_executable_extensions; do
- ac_cv_prog_F77="$ac_tool_prefix$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-F77=$ac_cv_prog_F77
-if test -n "$F77"; then
- echo "$as_me:$LINENO: result: $F77" >&5
-echo "${ECHO_T}$F77" >&6
-else
-fi
- test -n "$F77" && break
- done
-fi
-if test -z "$F77"; then
- ac_ct_F77=$F77
-do
-if test "${ac_cv_prog_ac_ct_F77+set}" = set; then
-else
- if test -n "$ac_ct_F77"; then
- ac_cv_prog_ac_ct_F77="$ac_ct_F77" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_F77="$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-ac_ct_F77=$ac_cv_prog_ac_ct_F77
-if test -n "$ac_ct_F77"; then
- echo "$as_me:$LINENO: result: $ac_ct_F77" >&5
-echo "${ECHO_T}$ac_ct_F77" >&6
-else
-fi
- test -n "$ac_ct_F77" && break
-done
- F77=$ac_ct_F77
-fi
-echo "$as_me:5707:" \
- "checking for Fortran 77 compiler version" >&5
- ac_status=$?
- ac_status=$?
- ac_status=$?
-rm -f a.out
-# If we don't use `.F' as extension, the preprocessor is not run on the
-# input file. (Note that this only needs to work for GNU compilers.)
-ac_save_ext=$ac_ext
-ac_ext=F
-echo "$as_me:$LINENO: checking whether we are using the GNU Fortran 77 compiler" >&5
-echo $ECHO_N "checking whether we are using the GNU Fortran 77 compiler... $ECHO_C" >&6
-if test "${ac_cv_f77_compiler_gnu+set}" = set; then
-else
- program main
-#ifndef __GNUC__
- choke me
-#endif
- end
-_ACEOF
- ac_status=$?
- { ac_try='test -z "$ac_f77_werror_flag"
- ac_status=$?
- ac_status=$?
-else
-ac_compiler_gnu=no
-fi
-ac_cv_f77_compiler_gnu=$ac_compiler_gnu
-fi
-echo "$as_me:$LINENO: result: $ac_cv_f77_compiler_gnu" >&5
-echo "${ECHO_T}$ac_cv_f77_compiler_gnu" >&6
-ac_ext=$ac_save_ext
-ac_test_FFLAGS=${FFLAGS+set}
-ac_save_FFLAGS=$FFLAGS
-FFLAGS=
-echo "$as_me:$LINENO: checking whether $F77 accepts -g" >&5
-echo $ECHO_N "checking whether $F77 accepts -g... $ECHO_C" >&6
-if test "${ac_cv_prog_f77_g+set}" = set; then
-else
- FFLAGS=-g
- program main
- end
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_prog_f77_g=yes
-else
-ac_cv_prog_f77_g=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_f77_g" >&5
-echo "${ECHO_T}$ac_cv_prog_f77_g" >&6
-if test "$ac_test_FFLAGS" = set; then
- FFLAGS=$ac_save_FFLAGS
-elif test $ac_cv_prog_f77_g = yes; then
- if test "x$ac_cv_f77_compiler_gnu" = xyes; then
- FFLAGS="-g -O2"
- else
- FFLAGS="-g"
- fi
-else
- FFLAGS="-O2"
- else
- FFLAGS=
- fi
-fi
-G77=`test $ac_compiler_gnu = yes && echo yes`
-ac_ext=cc
-# Autoconf 2.13's AC_OBJEXT and AC_EXEEXT macros only works for C compilers!
-# find the maximum length of command line arguments
-echo "$as_me:$LINENO: checking the maximum length of command line arguments" >&5
-echo $ECHO_N "checking the maximum length of command line arguments... $ECHO_C" >&6
-if test "${lt_cv_sys_max_cmd_len+set}" = set; then
-else
- i=0
- teststring="ABCD"
- case $build_os in
- msdosdjgpp*)
- # On DJGPP, this test can blow up pretty badly due to problems in libc
- # (any single argument exceeding 2000 bytes causes a buffer overrun
- # during glob expansion). Even if it were fixed, the result of this
- # check would be larger than it should be.
- lt_cv_sys_max_cmd_len=12288; # 12K is about right
- gnu*)
- # Under GNU Hurd, this test is not required because there is
- # no limit to the length of command line arguments.
- # Libtool will interpret -1 as no limit whatsoever
- lt_cv_sys_max_cmd_len=-1;
- cygwin* | mingw*)
- # On Win9x/ME, this test blows up -- it succeeds, but takes
- # about 5 minutes as the teststring grows exponentially.
- # Worse, since 9x/ME are not pre-emptively multitasking,
- # you end up with a "frozen" computer, even though with patience
- # the test eventually succeeds (with a max line length of 256k).
- # Instead, let's just punt: use the minimum linelength reported by
- # all of the supported platforms: 8192 (on NT/2K/XP).
- lt_cv_sys_max_cmd_len=8192;
- amigaos*)
- # On AmigaOS with pdksh, this test takes hours, literally.
- # So we just punt and use a minimum line length of 8192.
- # If test is not a shell built-in, we'll probably end up computing a
- # maximum length that is only half of the actual maximum length, but
- # we can't tell.
- while (test "X"`$CONFIG_SHELL $0 --fallback-echo "X$teststring" 2>/dev/null` \
- = "XX$teststring") >/dev/null 2>&1 &&
- new_result=`expr "X$teststring" : ".*" 2>&1` &&
- lt_cv_sys_max_cmd_len=$new_result &&
- test $i != 17 # 1/2 MB should be enough
- do
- i=`expr $i + 1`
- teststring=$teststring$teststring
- done
- teststring=
- # Add a significant safety factor because C++ compilers can tack on massive
- # amounts of additional arguments before passing them to the linker.
- # It appears as though 1/2 is a usable value.
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
- esac
-fi
-if test -n $lt_cv_sys_max_cmd_len ; then
- echo "$as_me:$LINENO: result: $lt_cv_sys_max_cmd_len" >&5
-echo "${ECHO_T}$lt_cv_sys_max_cmd_len" >&6
-else
- echo "$as_me:$LINENO: result: none" >&5
-echo "${ECHO_T}none" >&6
-fi
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-echo "$as_me:$LINENO: checking command to parse $NM output from $compiler object" >&5
-echo $ECHO_N "checking command to parse $NM output from $compiler object... $ECHO_C" >&6
-if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
-else
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix. What could be older than Ultrix?!! ;)]
-# Character class describing NM global symbol codes.
-symcode='[BCDEGRST]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
-# Transform the above into a raw symbol and a C symbol.
-symxfrm='\1 \2\3 \3'
-# Transform an extracted symbol line into a proper C declaration
-lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern int \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-# Define system-specific variables.
-case $host_os in
-aix*)
- symcode='[BCDT]'
-cygwin* | mingw* | pw32*)
- symcode='[ABCDGISTW]'
-hpux*) # Its linker distinguishes data from code symbols
- if test "$host_cpu" = ia64; then
- symcode='[ABCDEGRST]'
- fi
- lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
- lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-irix* | nonstopux*)
- symcode='[BCDEGRST]'
-osf*)
- symcode='[BCDEGQRST]'
-solaris* | sysv5*)
- symcode='[BDRT]'
-sysv4)
- symcode='[DFNSTU]'
-esac
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $build_os in
-mingw*)
- opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-case `$NM -V 2>&1` in
- symcode='[ABCDGIRSTW]' ;;
-esac
-# Try without a prefix undercore, then with it.
-for ac_symprfx in "" "_"; do
- # Write the raw and C identifiers.
- lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ ]\($symcode$symcode*\)[ ][ ]*\($ac_symprfx\)$sympat$opt_cr$/$symxfrm/p'"
- # Check to see that the pipe works correctly.
- pipe_works=no
- rm -f conftest*
- cat > conftest.$ac_ext <<EOF
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(){}
-#ifdef __cplusplus
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-EOF
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- # Now try to grab the symbols.
- nlist=conftest.nm
- if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
- (eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
- ac_status=$?
- (exit $ac_status); } && test -s "$nlist"; then
- # Try sorting and uniquifying the output.
- if sort "$nlist" | uniq > "$nlist"T; then
- mv -f "$nlist"T "$nlist"
- else
- rm -f "$nlist"T
- fi
- # Make sure that we snagged all the symbols we need.
- if grep ' nm_test_var$' "$nlist" >/dev/null; then
- if grep ' nm_test_func$' "$nlist" >/dev/null; then
- cat <<EOF > conftest.$ac_ext
-#ifdef __cplusplus
-extern "C" {
-#endif
-EOF
- # Now generate the symbol file.
- eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | grep -v main >> conftest.$ac_ext'
- cat <<EOF >> conftest.$ac_ext
-#if defined (__STDC__) && __STDC__
-# define lt_ptr_t void *
-#else
-# define lt_ptr_t char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr_t address;
-lt_preloaded_symbols[] =
-EOF
- $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (lt_ptr_t) \&\2},/" < "$nlist" | grep -v main >> conftest.$ac_ext
- cat <<\EOF >> conftest.$ac_ext
- {0, (lt_ptr_t) 0}
-#ifdef __cplusplus
-#endif
-EOF
- # Now try linking the two files.
- mv conftest.$ac_objext conftstm.$ac_objext
- lt_save_LIBS="$LIBS"
- lt_save_CFLAGS="$CFLAGS"
- LIBS="conftstm.$ac_objext"
- CFLAGS="$CFLAGS$lt_prog_compiler_no_builtin_flag"
- if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- ac_status=$?
- (exit $ac_status); } && test -s conftest${ac_exeext}; then
- pipe_works=yes
- fi
- LIBS="$lt_save_LIBS"
- CFLAGS="$lt_save_CFLAGS"
- else
- echo "cannot find nm_test_func in $nlist" >&5
- fi
- else
- echo "cannot find nm_test_var in $nlist" >&5
- fi
- else
- echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
- fi
- else
- echo "$progname: failed program was:" >&5
- cat conftest.$ac_ext >&5
- fi
- rm -f conftest* conftst*
- # Do not use the global_symbol_pipe unless it works.
- if test "$pipe_works" = yes; then
- break
- else
- fi
-done
-fi
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
-fi
-if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
- echo "$as_me:$LINENO: result: failed" >&5
-echo "${ECHO_T}failed" >&6
-else
- echo "$as_me:$LINENO: result: ok" >&5
-echo "${ECHO_T}ok" >&6
-fi
-echo "$as_me:$LINENO: checking for objdir" >&5
-echo $ECHO_N "checking for objdir... $ECHO_C" >&6
-if test "${lt_cv_objdir+set}" = set; then
-else
- rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
- lt_cv_objdir=.libs
-else
- # MS-DOS does not allow filenames that begin with a dot.
- lt_cv_objdir=_libs
-fi
-rmdir .libs 2>/dev/null
-fi
-echo "$as_me:$LINENO: result: $lt_cv_objdir" >&5
-echo "${ECHO_T}$lt_cv_objdir" >&6
-objdir=$lt_cv_objdir
-case $host_os in
-aix3*)
- # AIX sometimes has problems with the GCC collect2 program. For some
- # reason, if we set the COLLECT_NAMES environment variable, the problems
- # vanish in a puff of smoke.
- if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
- fi
-esac
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e s/^X//'
-sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g'
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Sed substitution to avoid accidental globbing in evaled expressions
-no_glob_subst='s/\*/\\\*/g'
-# Constants:
-rm="rm -f"
-# Global variables:
-default_ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except M$VC,
-# which needs '.lib').
-libext=a
-ltmain="$ac_aux_dir/ltmain.sh"
-ofile="$default_ofile"
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}ar", so it can be a program name with args.
-set dummy ${ac_tool_prefix}ar; ac_word=$2
-echo "$as_me:$LINENO: checking for $ac_word" >&5
-echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
-if test "${ac_cv_prog_AR+set}" = set; then
-else
- if test -n "$AR"; then
- ac_cv_prog_AR="$AR" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
- ac_cv_prog_AR="${ac_tool_prefix}ar"
- echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
- break 2
- fi
-done
-done
-fi
-fi
-AR=$ac_cv_prog_AR
-if test -n "$AR"; then
- echo "$as_me:$LINENO: result: $AR" >&5
-echo "${ECHO_T}$AR" >&6
-else
- echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
-fi
-if test -z "$ac_cv_prog_AR"; then
- ac_ct_AR=$AR
- # Extract the first word of "ar", so it can be a program name with args.
-set dummy ar; ac_word=$2
-if test "${ac_cv_prog_ac_ct_AR+set}" = set; then
-else
- if test -n "$ac_ct_AR"; then
- ac_cv_prog_ac_ct_AR="$ac_ct_AR" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_AR="ar"
- break 2
- fi
-done
-done
- test -z "$ac_cv_prog_ac_ct_AR" && ac_cv_prog_ac_ct_AR="false"
-fi
-fi
-ac_ct_AR=$ac_cv_prog_ac_ct_AR
-if test -n "$ac_ct_AR"; then
- echo "$as_me:$LINENO: result: $ac_ct_AR" >&5
-echo "${ECHO_T}$ac_ct_AR" >&6
-else
-fi
- AR=$ac_ct_AR
-else
- AR="$ac_cv_prog_AR"
-fi
- # Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
-set dummy ${ac_tool_prefix}ranlib; ac_word=$2
-if test "${ac_cv_prog_RANLIB+set}" = set; then
-else
- if test -n "$RANLIB"; then
- ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
- break 2
- fi
-done
-done
-fi
-fi
-RANLIB=$ac_cv_prog_RANLIB
-if test -n "$RANLIB"; then
- echo "$as_me:$LINENO: result: $RANLIB" >&5
-echo "${ECHO_T}$RANLIB" >&6
-else
-fi
-fi
-if test -z "$ac_cv_prog_RANLIB"; then
- ac_ct_RANLIB=$RANLIB
- # Extract the first word of "ranlib", so it can be a program name with args.
-set dummy ranlib; ac_word=$2
-if test "${ac_cv_prog_ac_ct_RANLIB+set}" = set; then
-else
- if test -n "$ac_ct_RANLIB"; then
- ac_cv_prog_ac_ct_RANLIB="$ac_ct_RANLIB" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_RANLIB="ranlib"
- break 2
- fi
-done
-done
- test -z "$ac_cv_prog_ac_ct_RANLIB" && ac_cv_prog_ac_ct_RANLIB=":"
-fi
-fi
-ac_ct_RANLIB=$ac_cv_prog_ac_ct_RANLIB
-if test -n "$ac_ct_RANLIB"; then
- echo "$as_me:$LINENO: result: $ac_ct_RANLIB" >&5
-echo "${ECHO_T}$ac_ct_RANLIB" >&6
-else
-fi
- RANLIB=$ac_ct_RANLIB
-else
- RANLIB="$ac_cv_prog_RANLIB"
-fi
- # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
-set dummy ${ac_tool_prefix}strip; ac_word=$2
-if test "${ac_cv_prog_STRIP+set}" = set; then
-else
- if test -n "$STRIP"; then
- ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_STRIP="${ac_tool_prefix}strip"
- break 2
- fi
-done
-done
-fi
-fi
-STRIP=$ac_cv_prog_STRIP
-if test -n "$STRIP"; then
- echo "$as_me:$LINENO: result: $STRIP" >&5
-echo "${ECHO_T}$STRIP" >&6
-else
-fi
-fi
-if test -z "$ac_cv_prog_STRIP"; then
- ac_ct_STRIP=$STRIP
- # Extract the first word of "strip", so it can be a program name with args.
-set dummy strip; ac_word=$2
-if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then
-else
- if test -n "$ac_ct_STRIP"; then
- ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_STRIP="strip"
- break 2
- fi
-done
-done
- test -z "$ac_cv_prog_ac_ct_STRIP" && ac_cv_prog_ac_ct_STRIP=":"
-fi
-fi
-ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
-if test -n "$ac_ct_STRIP"; then
- echo "$as_me:$LINENO: result: $ac_ct_STRIP" >&5
-echo "${ECHO_T}$ac_ct_STRIP" >&6
-else
-fi
- STRIP=$ac_ct_STRIP
-else
- STRIP="$ac_cv_prog_STRIP"
-fi
-old_CC="$CC"
-old_CFLAGS="$CFLAGS"
-# Set sane defaults for various variables
-test -z "$AR" && AR=ar
-test -z "$AR_FLAGS" && AR_FLAGS=cru
-test -z "$AS" && AS=as
-test -z "$CC" && CC=cc
-test -z "$LTCC" && LTCC=$CC
-test -z "$DLLTOOL" && DLLTOOL=dlltool
-test -z "$LD" && LD=ld
-test -z "$LN_S" && LN_S="ln -s"
-test -z "$MAGIC_CMD" && MAGIC_CMD=file
-test -z "$NM" && NM=nm
-test -z "$SED" && SED=sed
-test -z "$OBJDUMP" && OBJDUMP=objdump
-test -z "$RANLIB" && RANLIB=:
-test -z "$STRIP" && STRIP=:
-test -z "$ac_objext" && ac_objext=o
-# Determine commands to create old-style static archives.
-old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
-old_postinstall_cmds='chmod 644 $oldlib'
-old_postuninstall_cmds=
- case $host_os in
- openbsd*)
- old_postinstall_cmds="\$RANLIB -t \$oldlib~$old_postinstall_cmds"
- old_postinstall_cmds="\$RANLIB \$oldlib~$old_postinstall_cmds"
- esac
- old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
-fi
-# Only perform the check for file, if the check method requires it
-case $deplibs_check_method in
-file_magic*)
- if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
-echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6
-if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
-else
- case $MAGIC_CMD in
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
- lt_save_MAGIC_CMD="$MAGIC_CMD"
- ac_dummy="/usr/bin$PATH_SEPARATOR$PATH"
- for ac_dir in $ac_dummy; do
- if test -f $ac_dir/${ac_tool_prefix}file; then
- lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
- if test -n "$file_magic_test_file"; then
- case $deplibs_check_method in
- "file_magic "*)
- file_magic_regex="`expr \"$deplibs_check_method\" : \"file_magic \(.*\)\"`"
- MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
- if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
- $EGREP "$file_magic_regex" > /dev/null; then
- else
- cat <<EOF 1>&2
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such. This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem. Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
-EOF
- fi ;;
- esac
- fi
- break
- fi
- done
- MAGIC_CMD="$lt_save_MAGIC_CMD"
-esac
-fi
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
- echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
-echo "${ECHO_T}$MAGIC_CMD" >&6
-else
-fi
-if test -z "$lt_cv_path_MAGIC_CMD"; then
- if test -n "$ac_tool_prefix"; then
- echo "$as_me:$LINENO: checking for file" >&5
-echo $ECHO_N "checking for file... $ECHO_C" >&6
-else
- if test -f $ac_dir/file; then
- lt_cv_path_MAGIC_CMD="$ac_dir/file"
- "file_magic "*)
- else
- cat <<EOF 1>&2
-EOF
- fi ;;
- esac
- fi
- break
- fi
- done
-esac
-fi
-else
-fi
- else
- MAGIC_CMD=:
- fi
-fi
- fi
-esac
-enable_dlopen=no
-enable_win32_dll=no
-fi;
-# Check whether --with-pic or --without-pic was given.
-if test "${with_pic+set}" = set; then
- withval="$with_pic"
- pic_mode="$withval"
-else
- pic_mode=default
-fi;
-test -z "$pic_mode" && pic_mode=default
-# Use C for the default configuration in the libtool script
-tagname=
-lt_save_CC="$CC"
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-# Source file extension for C test sources.
-ac_ext=c
-# Object file extension for compiled C test sources.
-objext=o
-objext=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code="int some_variable = 0;\n"
-# Code to be used in simple link tests
-lt_simple_link_test_code='int main(){return(0);}\n'
-LTCC=${LTCC-"$CC"}
-compiler=$CC
-# Check for any special shared library compilation flags.
-lt_prog_cc_shlib=
-if test "$GCC" = no; then
- case $host_os in
- sco3.2v5*)
- lt_prog_cc_shlib='-belf'
- esac
-fi
-if test -n "$lt_prog_cc_shlib"; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' requires \`$lt_prog_cc_shlib' to build shared libraries" >&5
-echo "$as_me: WARNING: \`$CC' requires \`$lt_prog_cc_shlib' to build shared libraries" >&2;}
- if echo "$old_CC $old_CFLAGS " | grep "[ ]$lt_prog_cc_shlib[ ]" >/dev/null; then :
- else
- { echo "$as_me:$LINENO: WARNING: add \`$lt_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&5
-echo "$as_me: WARNING: add \`$lt_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&2;}
- lt_cv_prog_cc_can_build_shared=no
- fi
-fi
-# Check to make sure the static flag actually works.
-echo "$as_me:$LINENO: checking if $compiler static flag $lt_prog_compiler_static works" >&5
-echo $ECHO_N "checking if $compiler static flag $lt_prog_compiler_static works... $ECHO_C" >&6
-if test "${lt_prog_compiler_static_works+set}" = set; then
-else
- lt_prog_compiler_static_works=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $lt_prog_compiler_static"
- printf "$lt_simple_link_test_code" > conftest.$ac_ext
- if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings
- # Append any errors to the config.log.
- cat conftest.err 1>&5
- else
- lt_prog_compiler_static_works=yes
- fi
- fi
- $rm conftest*
- LDFLAGS="$save_LDFLAGS"
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works" >&5
-echo "${ECHO_T}$lt_prog_compiler_static_works" >&6
-if test x"$lt_prog_compiler_static_works" = xyes; then
-else
- lt_prog_compiler_static=
-fi
-lt_prog_compiler_no_builtin_flag=
- lt_prog_compiler_no_builtin_flag=' -fno-builtin'
-echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
-echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
-if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
-else
- lt_cv_prog_compiler_rtti_exceptions=no
- ac_outfile=conftest.$ac_objext
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- lt_compiler_flag="-fno-rtti -fno-exceptions"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}? :&$lt_compiler_flag :; t' \
- -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:6741: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- cat conftest.err >&5
- echo "$as_me:6745: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s "$ac_outfile"; then
- if test ! -s conftest.err; then
- lt_cv_prog_compiler_rtti_exceptions=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
-if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
- lt_prog_compiler_no_builtin_flag="$lt_prog_compiler_no_builtin_flag -fno-rtti -fno-exceptions"
-else
-fi
-fi
-lt_prog_compiler_wl=
-lt_prog_compiler_pic=
-lt_prog_compiler_static=
-echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
-echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
- if test "$GCC" = yes; then
- lt_prog_compiler_wl='-Wl,'
- lt_prog_compiler_static='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- # AIX 5 now supports IA64 processor
- lt_prog_compiler_static='-Bstatic'
- fi
- amigaos*)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- lt_prog_compiler_pic='-m68020 -resident32 -malways-restore-a4'
- beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | pw32* | os2*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- lt_prog_compiler_pic='-DDLL_EXPORT'
- darwin* | rhapsody*)
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- lt_prog_compiler_pic='-fno-common'
- msdosdjgpp*)
- # Just because we use GCC doesn't mean we suddenly get shared libraries
- # on systems that don't support them.
- lt_prog_compiler_can_build_shared=no
- enable_shared=no
- sysv4*MP*)
- if test -d /usr/nec; then
- lt_prog_compiler_pic=-Kconform_pic
- fi
- hpux*)
- # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
- # not for PA HP-UX.
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic='-fPIC'
- esac
- esac
- else
- # PORTME Check for flag to pass linker flags through the system compiler.
- case $host_os in
- aix*)
- else
- lt_prog_compiler_static='-bnso -bI:/lib/syscalls.exp'
- fi
- hpux9* | hpux10* | hpux11*)
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic='+Z'
- esac
- # Is there a better lt_prog_compiler_static that works with the bundled CC?
- lt_prog_compiler_static='${wl}-a ${wl}archive'
- irix5* | irix6* | nonstopux*)
- # PIC (with -KPIC) is the default.
- lt_prog_compiler_static='-non_shared'
- newsos6)
- lt_prog_compiler_pic='-KPIC'
- linux*)
- case $CC in
- icc* | ecc*)
- ccc*)
- # All Alpha code is PIC.
- esac
- osf3* | osf4* | osf5*)
- # All OSF/1 code is PIC.
- sco3.2v5*)
- lt_prog_compiler_pic='-Kpic'
- lt_prog_compiler_static='-dn'
- solaris*)
- sunos4*)
- lt_prog_compiler_wl='-Qoption ld '
- lt_prog_compiler_pic='-PIC'
- sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- sysv4*MP*)
- if test -d /usr/nec ;then
- lt_prog_compiler_pic='-Kconform_pic'
- fi
- uts4*)
- lt_prog_compiler_pic='-pic'
- esac
- fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic" >&6
-# Check to make sure the PIC flag actually works.
-if test -n "$lt_prog_compiler_pic"; then
-echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic works... $ECHO_C" >&6
-if test "${lt_prog_compiler_pic_works+set}" = set; then
-else
- lt_prog_compiler_pic_works=no
- lt_compiler_flag="$lt_prog_compiler_pic -DPIC"
- (eval echo "\"\$as_me:6974: $lt_compile\"" >&5)
- ac_status=$?
- echo "$as_me:6978: \$? = $ac_status" >&5
- lt_prog_compiler_pic_works=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_works" >&6
-if test x"$lt_prog_compiler_pic_works" = xyes; then
- case $lt_prog_compiler_pic in
- *) lt_prog_compiler_pic=" $lt_prog_compiler_pic" ;;
- esac
-else
-fi
-fi
-case "$host_os" in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- lt_prog_compiler_pic="$lt_prog_compiler_pic -DPIC"
-esac
-echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
-if test "${lt_cv_prog_compiler_c_o+set}" = set; then
-else
- lt_cv_prog_compiler_c_o=no
- $rm -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval echo "\"\$as_me:7034: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&5
- echo "$as_me:7038: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- if test ! -s out/conftest.err; then
- lt_cv_prog_compiler_c_o=yes
- fi
- fi
- chmod u+w .
- $rm conftest*
- # SGI C++ compiler will create directory out/ii_files/ for
- # template instantiation
- test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
- $rm out/* && rmdir out
- cd ..
- rmdir conftest
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o" >&6
-hard_links="nottested"
-if test "$lt_cv_prog_compiler_c_o" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
-echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- echo "$as_me:$LINENO: result: $hard_links" >&5
-echo "${ECHO_T}$hard_links" >&6
- if test "$hard_links" = no; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
- runpath_var=
- allow_undefined_flag=
- enable_shared_with_static_runtimes=no
- archive_cmds=
- archive_expsym_cmds=
- old_archive_From_new_cmds=
- old_archive_from_expsyms_cmds=
- export_dynamic_flag_spec=
- whole_archive_flag_spec=
- thread_safe_flag_spec=
- hardcode_libdir_flag_spec=
- hardcode_libdir_flag_spec_ld=
- hardcode_libdir_separator=
- hardcode_direct=no
- hardcode_minus_L=no
- hardcode_shlibpath_var=unsupported
- link_all_deplibs=unknown
- hardcode_automatic=no
- module_cmds=
- module_expsym_cmds=
- always_export_symbols=no
- export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- # include_expsyms should be a list of space-separated symbols to be *always*
- # included in the symbol list
- include_expsyms=
- # exclude_expsyms can be an extended regexp of symbols to exclude
- # it will be wrapped by ` (' and `)$', so one must not match beginning or
- # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
- # as well as any symbol that contains `d'.
- exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
- # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
- # platforms (ab)use it in PIC code, but their linkers get confused if
- # the symbol is explicitly referenced. Since portable code cannot
- # rely on this symbol name, it's probably fine to never include it in
- # preloaded symbol tables.
- extract_expsyms_cmds=
- case $host_os in
- cygwin* | mingw* | pw32*)
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
- openbsd*)
- with_gnu_ld=no
- esac
- ld_shlibs=yes
- if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix3* | aix4* | aix5*)
- # On AIX/PPC, the GNU linker is very broken
- if test "$host_cpu" != ia64; then
- ld_shlibs=no
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- fi
- amigaos*)
- archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec='-L$libdir'
- hardcode_minus_L=yes
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can't use
- # them.
- ld_shlibs=no
- beos*)
- if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs=no
- fi
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, ) is actually meaningless,
- # as there is no search path for DLLs.
- enable_shared_with_static_runtimes=yes
- export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- archive_expsym_cmds='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- else
- ld_shlibs=no
- fi
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris* | sysv5*)
- if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
- ld_shlibs=no
- cat <<EOF 1>&2
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- else
- ld_shlibs=no
- fi
- sunos4*)
- archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct=yes
- hardcode_shlibpath_var=no
- linux*)
- tmp_archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_cmds="$tmp_archive_cmds"
- supports_anon_versioning=no
- case `$LD -v 2>/dev/null` in
- *\ 01.* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
- *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
- *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
- *\ 2.11.*) ;; # other 2.11 versions
- *) supports_anon_versioning=yes ;;
- esac
- if test $supports_anon_versioning = yes; then
- archive_expsym_cmds='$echo "{ global:" > $output_objdir/$libname.ver~
-cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
-$echo "local: *; };" >> $output_objdir/$libname.ver~
- $CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- else
- archive_expsym_cmds="$tmp_archive_cmds"
- fi
- else
- ld_shlibs=no
- fi
- else
- ld_shlibs=no
- fi
- esac
- if test "$ld_shlibs" = yes; then
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec='${wl}--export-dynamic'
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- fi
- else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- always_export_symbols=yes
- archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$link_static_flag"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct=unsupported
- fi
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
- export_symbols_cmds='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- else
- export_symbols_cmds='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- fi
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix5*)
- for ld_flag in $LDFLAGS; do
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- aix_use_runtimelinking=yes
- break
- fi
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds=''
- hardcode_libdir_separator=':'
- link_all_deplibs=yes
- case $host_os in aix4.012|aix4.012.*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- { ac_try='test -z "$ac_c_werror_flag"
- || test ! -s conftest.err'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; } &&
- ac_status=$?
- (exit $ac_status); }; }; then
-aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-# Check for a 64-bit object if we didn't find anything.
-if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-}'`; fi
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-fi
-if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
- hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
- archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag="-z nodefs"
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
- else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-}'`; fi
-else
-fi
- # Warning - without using the other run time loading flags,
- no_undefined_flag=' ${wl}-bernotok'
- allow_undefined_flag=' ${wl}-berok'
- # -bexpall does not export symbols beginning with underscore (_)
- # Exported symbols can be pulled into shared objects from archives
- whole_archive_flag_spec=' '
- archive_cmds_need_lc=yes
- # This is similar to how AIX traditionally builds it's shared libraries.
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- ld_shlibs=no
- bsdi4*)
- export_dynamic_flag_spec=-rdynamic
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- hardcode_libdir_flag_spec=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- shrext_cmds=".dll"
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_From_new_cmds='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path='`cygpath -w "$srcfile"`'
- if test "$GXX" = yes ; then
- archive_cmds_need_lc=no
- case "$host_os" in
- rhapsody* | darwin1.[012])
- allow_undefined_flag='-undefined suppress'
- *) # Darwin 1.3 on
- if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
- allow_undefined_flag='-flat_namespace -undefined suppress'
- else
- case ${MACOSX_DEPLOYMENT_TARGET} in
- 10.[012])
- 10.*)
- allow_undefined_flag='-undefined dynamic_lookup'
- esac
- fi
- esac
- lt_int_apple_cc_single_mod=no
- output_verbose_link_cmd='echo'
- if $CC -dumpspecs 2>&1 | grep 'single_module' >/dev/null ; then
- lt_int_apple_cc_single_mod=yes
- fi
- if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
- archive_cmds='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- else
- archive_cmds='$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- fi
- module_cmds='$CC ${wl}-bind_at_load $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
- archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- fi
- module_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- hardcode_automatic=yes
- whole_archive_flag_spec='-all_load $convenience'
- else
- ld_shlibs=no
- fi
- dgux*)
- archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- freebsd1*)
- ld_shlibs=no
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd* | kfreebsd*-gnu)
- archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- hpux9*)
- archive_cmds='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- fi
- hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator=:
- # hardcode_minus_L: Not really in the search PATH,
- # but as the default location of the library.
- export_dynamic_flag_spec='${wl}-E'
- hpux10* | hpux11*)
- if test "$GCC" = yes -a "$with_gnu_ld" = no; then
- case "$host_cpu" in
- hppa*64*|ia64*)
- archive_cmds='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_cmds='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- esac
- else
- hppa*64*|ia64*)
- archive_cmds='$LD -b +h $soname -o $lib $libobjs $deplibs $linker_flags'
- archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
- esac
- fi
- if test "$with_gnu_ld" = no; then
- hppa*64*)
- hardcode_libdir_flag_spec_ld='+b $libdir'
- ia64*)
- esac
- fi
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec_ld='-rpath $libdir'
- fi
- hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
- netbsd*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
- else
- case $host_os in
- openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
- esac
- fi
- os2*)
- archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_From_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag=' -expect_unresolved \*'
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
- # Both c and cxx compiler support -rpath directly
- hardcode_libdir_flag_spec='-rpath $libdir'
- fi
- sco3.2v5*)
- export_dynamic_flag_spec='${wl}-Bexport'
- hardcode_runpath_var=yes
- solaris*)
- no_undefined_flag=' -z text'
- archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
- else
- archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- fi
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- *) # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- case $host_vendor in
- sni)
- hardcode_direct=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- reload_cmds='$CC -r -o $output$reload_objs'
- motorola)
- hardcode_direct=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- export_dynamic_flag_spec='-Bexport'
- sysv4*MP*)
- ld_shlibs=yes
- fi
- sysv4.2uw2*)
- sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7*)
- no_undefined_flag='${wl}-z ${wl}text'
- else
- archive_cmds='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- sysv5*)
- # $CC -shared without GNU ld will not create a library from C++
- # object files and a static libstdc++, better avoid it by now
- uts4*)
- ld_shlibs=no
- esac
- fi
-echo "$as_me:$LINENO: result: $ld_shlibs" >&5
-echo "${ECHO_T}$ld_shlibs" >&6
-test "$ld_shlibs" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-# Do we need to explicitly link libc?
-case "x$archive_cmds_need_lc" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
- $rm conftest*
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- (exit $ac_status); } 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_prog_compiler_wl
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$allow_undefined_flag
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
- (eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- else
- fi
- allow_undefined_flag=$lt_save_allow_undefined_flag
- else
- fi
- $rm conftest*
- echo "$as_me:$LINENO: result: $archive_cmds_need_lc" >&5
-echo "${ECHO_T}$archive_cmds_need_lc" >&6
- esac
- fi
-esac
-echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
-echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
-library_names_spec=
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-postuninstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
- if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi4*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
- version_type=windows
- need_version=no
- case $GCC,$host_os in
- yes,cygwin* | yes,mingw* | yes,pw32*)
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
- mingw*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
- # It is most probably a Windows format PATH printed by
- # mingw gcc, but we are running on Cygwin. Gcc prints its search
- # path with ; separators, and with drive letters. We can handle the
- # drive letters (cygwin fileutils understands them), so leave them,
- # especially as we might pass files found there to a mingw objdump,
- # which wouldn't understand a cygwinified path. Ahh.
- else
- fi
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/./-/g'`${versuffix}${shared_ext}'
- esac
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='$(test .$module = .yes && echo .so || echo .dylib)'
- # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
- sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
- else
- sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
- fi
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd1*)
- dynamic_linker=no
-kfreebsd*-gnu)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- shlibpath_overrides_runpath=no
- dynamic_linker='GNU ld.so'
-freebsd*)
- objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- freebsd3.01* | freebsdelf3.01*)
- *) # from 3.2 on
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- if test "$lt_cv_prog_gnu_ld" = yes; then
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # find out which ABI we are using
- libsuff=
- x86_64*|s390x*|powerpc64*)
- echo '#line 8368 "configure"' > conftest.$ac_ext
- ac_status=$?
- (exit $ac_status); }; then
- case `/usr/bin/file conftest.$ac_objext` in
- *64-bit*)
- libsuff=64
- sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
- esac
- fi
- rm -rf conftest*
- esac
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`$SED -e 's/:,\t/ /g;s/=^=*$//;s/=^= * / /g' /etc/ld.so.conf | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-knetbsd*-gnu)
- need_version=no
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-nto-qnx*)
- need_version=no
-openbsd*)
- need_version=yes
- case $host_os in
- openbsd2.[89] | openbsd2.[89].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
- version_type=osf
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- fi
- need_version=yes
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-uts4*)
- dynamic_linker=no
-esac
-echo "$as_me:$LINENO: result: $dynamic_linker" >&5
-echo "${ECHO_T}$dynamic_linker" >&6
-test "$dynamic_linker" = no && can_build_shared=no
-echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action=
-if test -n "$hardcode_libdir_flag_spec" || \
- test -n "$runpath_var " || \
- test "X$hardcode_automatic"="Xyes" ; then
- # We can hardcode non-existant directories.
- if test "$hardcode_direct" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, )" != no &&
- test "$hardcode_minus_L" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action=unsupported
-fi
-echo "$as_me:$LINENO: result: $hardcode_action" >&5
-echo "${ECHO_T}$hardcode_action" >&6
-if test "$hardcode_action" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-striplib=
-old_striplib=
-echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
-echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6
-else
-# FIXME - insert some real tests, host_os isn't really good enough
- case $host_os in
- darwin*)
- if test -n "$STRIP" ; then
- striplib="$STRIP -x"
- else
-fi
- esac
-fi
-if test "x$enable_dlopen" != xyes; then
- enable_dlopen=unknown
- enable_dlopen_self=unknown
- enable_dlopen_self_static=unknown
-else
- lt_cv_dlopen=no
- lt_cv_dlopen_libs=
- case $host_os in
- beos*)
- lt_cv_dlopen="load_add_on"
- lt_cv_dlopen_self=yes
- mingw* | pw32*)
- lt_cv_dlopen="LoadLibrary"
- cygwin*)
- lt_cv_dlopen="dlopen"
- darwin*)
- # if libdl is installed we need to link against it
- echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
-echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
-if test "${ac_cv_lib_dl_dlopen+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- ac_check_lib_save_LIBS=$LIBS
-LIBS="-ldl $LIBS"
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-/* Override any gcc2 internal prototype to avoid an error. */
-#ifdef __cplusplus
-extern "C"
-#endif
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); } &&
- ac_status=$?
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- ac_cv_lib_dl_dlopen=yes
-else
-ac_cv_lib_dl_dlopen=no
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-LIBS=$ac_check_lib_save_LIBS
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
-if test $ac_cv_lib_dl_dlopen = yes; then
- lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
-else
- lt_cv_dlopen="dyld"
-fi
- echo "$as_me:$LINENO: checking for shl_load" >&5
-echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
-if test "${ac_cv_func_shl_load+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
- For example, HP-UX 11i <limits.h> declares gettimeofday. */
-#define shl_load innocuous_shl_load
-/* System header to define __stub macros and hopefully few prototypes,
- which can conflict with char shl_load (); below.
- Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- <limits.h> exists even on freestanding compilers. */
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
-#undef shl_load
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-/* The GNU C library defines this for functions which it implements
- to always fail with ENOSYS. Some functions are actually named
- something starting with __ and the normal name is an alias. */
-#if defined (__stub_shl_load) || defined (__stub___shl_load)
-choke me
-#else
-char (*f) () = shl_load;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != shl_load;
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_func_shl_load=yes
-else
-ac_cv_func_shl_load=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
-echo "${ECHO_T}$ac_cv_func_shl_load" >&6
-if test $ac_cv_func_shl_load = yes; then
- lt_cv_dlopen="shl_load"
-else
- echo "$as_me:$LINENO: checking for shl_load in -ldld" >&5
-echo $ECHO_N "checking for shl_load in -ldld... $ECHO_C" >&6
-if test "${ac_cv_lib_dld_shl_load+set}" = set; then
-else
-LIBS="-ldld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-int
-main ()
-shl_load ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_dld_shl_load=yes
-else
-ac_cv_lib_dld_shl_load=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_shl_load" >&6
-if test $ac_cv_lib_dld_shl_load = yes; then
- lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"
-else
- echo "$as_me:$LINENO: checking for dlopen" >&5
-echo $ECHO_N "checking for dlopen... $ECHO_C" >&6
-if test "${ac_cv_func_dlopen+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
-#define dlopen innocuous_dlopen
- which can conflict with char dlopen (); below.
-#ifdef __STDC__
-#else
-#endif
-#undef dlopen
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-#if defined (__stub_dlopen) || defined (__stub___dlopen)
-choke me
-#else
-char (*f) () = dlopen;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != dlopen;
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_func_dlopen=yes
-else
-ac_cv_func_dlopen=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
-echo "${ECHO_T}$ac_cv_func_dlopen" >&6
-if test $ac_cv_func_dlopen = yes; then
-else
-else
-LIBS="-ldl $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-else
-fi
-fi
-else
- echo "$as_me:$LINENO: checking for dlopen in -lsvld" >&5
-echo $ECHO_N "checking for dlopen in -lsvld... $ECHO_C" >&6
-if test "${ac_cv_lib_svld_dlopen+set}" = set; then
-else
-LIBS="-lsvld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_svld_dlopen=yes
-else
-ac_cv_lib_svld_dlopen=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_svld_dlopen" >&6
-if test $ac_cv_lib_svld_dlopen = yes; then
- lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
-else
- echo "$as_me:$LINENO: checking for dld_link in -ldld" >&5
-echo $ECHO_N "checking for dld_link in -ldld... $ECHO_C" >&6
-if test "${ac_cv_lib_dld_dld_link+set}" = set; then
-else
-LIBS="-ldld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dld_link ();
-int
-main ()
-dld_link ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_dld_dld_link=yes
-else
-ac_cv_lib_dld_dld_link=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_dld_link" >&6
-if test $ac_cv_lib_dld_dld_link = yes; then
- lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"
-fi
-fi
-fi
-fi
-fi
-fi
- esac
- if test "x$lt_cv_dlopen" != xno; then
- enable_dlopen=yes
- else
- enable_dlopen=no
- fi
- case $lt_cv_dlopen in
- dlopen)
- save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
- eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
- save_LIBS="$LIBS"
- LIBS="$lt_cv_dlopen_libs $LIBS"
- echo "$as_me:$LINENO: checking whether a program can dlopen itself" >&5
-echo $ECHO_N "checking whether a program can dlopen itself... $ECHO_C" >&6
-if test "${lt_cv_dlopen_self+set}" = set; then
-else
- if test "$cross_compiling" = yes; then :
- lt_cv_dlopen_self=cross
-else
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
- lt_status=$lt_dlunknown
- cat > conftest.$ac_ext <<EOF
-#line 9239 "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-# define LT_DLGLOBAL RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# define LT_DLGLOBAL DL_GLOBAL
-# else
-# define LT_DLGLOBAL 0
-# endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
- find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-# ifdef RTLD_LAZY
-# define LT_DLLAZY_OR_NOW RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# define LT_DLLAZY_OR_NOW DL_LAZY
-# else
-# ifdef RTLD_NOW
-# define LT_DLLAZY_OR_NOW RTLD_NOW
-# else
-# ifdef DL_NOW
-# define LT_DLLAZY_OR_NOW DL_NOW
-# else
-# define LT_DLLAZY_OR_NOW 0
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-extern "C" void exit (int);
-#endif
-void fnord() { int i=42;}
-int main ()
- void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
- int status = $lt_dlunknown;
- if (self)
- if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
- else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
- /* dlclose (self); */
- exit (status);
-EOF
- if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>&5
- ac_status=$?
- (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) 2>/dev/null
- lt_status=$?
- case x$lt_status in
- x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_unknown|x*) lt_cv_dlopen_self=no ;;
- esac
- else :
- # compilation failed
- lt_cv_dlopen_self=no
- fi
-fi
-rm -fr conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_dlopen_self" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self" >&6
- if test "x$lt_cv_dlopen_self" = xyes; then
- LDFLAGS="$LDFLAGS $link_static_flag"
- echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
-echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
-if test "${lt_cv_dlopen_self_static+set}" = set; then
-else
- lt_cv_dlopen_self_static=cross
-else
-#line 9337 "configure"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# else
-# endif
-#endif
-# ifdef RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# else
-# ifdef RTLD_NOW
-# else
-# ifdef DL_NOW
-# else
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-#endif
-int main ()
- if (self)
- exit (status);
-EOF
- ac_status=$?
- lt_status=$?
- x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_unknown|x*) lt_cv_dlopen_self_static=no ;;
- esac
- else :
- lt_cv_dlopen_self_static=no
- fi
-fi
-rm -fr conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_dlopen_self_static" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self_static" >&6
- fi
- CPPFLAGS="$save_CPPFLAGS"
- LIBS="$save_LIBS"
- esac
- case $lt_cv_dlopen_self in
- yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
- *) enable_dlopen_self=unknown ;;
- esac
- case $lt_cv_dlopen_self_static in
- yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
- *) enable_dlopen_self_static=unknown ;;
- esac
-fi
-# Report which librarie types wil actually be built
-echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
-echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
-echo "$as_me:$LINENO: result: $can_build_shared" >&5
-echo "${ECHO_T}$can_build_shared" >&6
-echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
-echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
-test "$can_build_shared" = "no" && enable_shared=no
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case "$host_os" in
-aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
- fi
-aix4* | aix5*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
- else
- 10.[012])
- 10.*)
- esac
- fi
- esac
- archive_cmds='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs$compiler_flags -install_name $rpath/$soname $verstring'
- module_cmds='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs$compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- ld_shlibs=no
- fi
-esac
-echo "$as_me:$LINENO: result: $enable_shared" >&5
-echo "${ECHO_T}$enable_shared" >&6
-echo "$as_me:$LINENO: checking whether to build static libraries" >&5
-echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-echo "$as_me:$LINENO: result: $enable_static" >&5
-echo "${ECHO_T}$enable_static" >&6
-# The else clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
- # See if we are running on zsh, and set the options which allow our commands through
- # without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
- fi
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM \
- SED SHELL STRIP \
- libname_spec library_names_spec soname_spec extract_expsyms_cmds \
- old_striplib striplib file_magic_cmd finish_cmds finish_eval \
- deplibs_check_method reload_flag reload_cmds need_locks \
- lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
- lt_cv_sys_global_symbol_to_c_name_address \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- old_postinstall_cmds old_postuninstall_cmds \
- compiler \
- CC \
- LD \
- lt_prog_compiler_wl \
- lt_prog_compiler_pic \
- lt_prog_compiler_static \
- lt_prog_compiler_no_builtin_flag \
- export_dynamic_flag_spec \
- thread_safe_flag_spec \
- whole_archive_flag_spec \
- enable_shared_with_static_runtimes \
- old_archive_cmds \
- old_archive_from_new_cmds \
- predep_objects \
- postdep_objects \
- predeps \
- postdeps \
- compiler_lib_search_path \
- archive_cmds \
- archive_expsym_cmds \
- postinstall_cmds \
- postuninstall_cmds \
- old_archive_from_expsyms_cmds \
- allow_undefined_flag \
- no_undefined_flag \
- export_symbols_cmds \
- hardcode_libdir_flag_spec \
- hardcode_libdir_flag_spec_ld \
- hardcode_libdir_separator \
- hardcode_automatic \
- module_cmds \
- module_expsym_cmds \
- lt_cv_prog_compiler_c_o \
- exclude_expsyms \
- include_expsyms; do
- case $var in
- old_archive_cmds | \
- old_archive_from_new_cmds | \
- archive_cmds | \
- archive_expsym_cmds | \
- module_cmds | \
- module_expsym_cmds | \
- old_archive_from_expsyms_cmds | \
- export_symbols_cmds | \
- extract_expsyms_cmds | reload_cmds | finish_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- case $lt_echo in
- *'\$0 --fallback-echo"')
- lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
- esac
-cfgfile="${ofile}T"
- trap "$rm \"$cfgfile\"; exit 1" 1 2 15
- $rm -f "$cfgfile"
- { echo "$as_me:$LINENO: creating $ofile" >&5
-echo "$as_me: creating $ofile" >&6;}
- cat <<__EOF__ >> "$cfgfile"
-#! $SHELL
-# `$echo "$cfgfile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
-# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
-# NOTE: Changes made to this file will be lost: look at ltmain.sh.
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001
-# Free Software Foundation, Inc.
-# This file is part of GNU Libtool:
-# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# A sed program that does not truncate output.
-SED=$lt_SED
-# Sed that helps us avoid accidentally triggering echo(1) options like -n.
-Xsed="$SED -e s/^X//"
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test "X\${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
-# The names of the tagged configurations supported by this script.
-available_tags=
-# ### BEGIN LIBTOOL CONFIG
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$archive_cmds_need_lc
-# Whether or not to disallow shared libs when runtime libs are static
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# A C compiler.
-LTCC=$lt_LTCC
-# A language-specific compiler.
-CC=$lt_compiler
-# Is the compiler the GNU C compiler?
-with_gcc=$GCC
-# An ERE matcher.
-EGREP=$lt_EGREP
-# The linker used to build libraries.
-LD=$lt_LD
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$lt_STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_lt_prog_compiler_wl
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally ".so").
-shrext_cmds='$shrext_cmds'
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_lt_prog_compiler_pic
-pic_mode=$pic_mode
-# What is the maximum length of a command?
-max_cmd_len=$lt_cv_sys_max_cmd_len
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o
-# Must we lock files when doing compilation ?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_lt_prog_compiler_static
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_thread_safe_flag_spec
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_archive_cmds
-archive_expsym_cmds=$lt_archive_expsym_cmds
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to build a loadable module (assumed same as above if empty)
-module_cmds=$lt_module_cmds
-module_expsym_cmds=$lt_module_expsym_cmds
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Dependencies to place before the objects being linked to create a
-# shared library.
-predep_objects=$lt_predep_objects
-# Dependencies to place after the objects being linked to create a
-# shared library.
-postdep_objects=$lt_postdep_objects
-# shared library.
-predeps=$lt_predeps
-# shared library.
-postdeps=$lt_postdeps
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_compiler_lib_search_path
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
-# If ld is used when linking, flag to hardcode \$libdir into
-# a binary during linking. This must work even if \$libdir does
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator
-# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$hardcode_direct
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$hardcode_minus_L
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$hardcode_shlibpath_var
-# Set to yes if building a shared library automatically hardcodes DIR into the library
-# and all subsequent libraries and executables linked against it.
-hardcode_automatic=$hardcode_automatic
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$fix_srcfile_path"
-# Set to yes if exported symbols are required.
-always_export_symbols=$always_export_symbols
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms
-# ### END LIBTOOL CONFIG
-__EOF__
- case $host_os in
- aix3*)
- cat <<\EOF >> "$cfgfile"
-# AIX sometimes has problems with the GCC collect2 program. For some
-# reason, if we set the COLLECT_NAMES environment variable, the problems
-# vanish in a puff of smoke.
-if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
-fi
-EOF
- esac
- # We use sed instead of cat because bash on DJGPP gets confused if
- # if finds mixed CR/LF and LF-only lines. Since sed operates in
- # text mode, it properly converts lines to CR/LF. This bash problem
- # is reportedly fixed, but why not run on old versions too?
- sed '$q' "$ltmain" >> "$cfgfile" || (rm -f "$cfgfile"; exit 1)
- mv -f "$cfgfile" "$ofile" || \
- (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
- chmod +x "$ofile"
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
- if test -f "$ltmain_in"; then
- test -f Makefile && make "$ltmain"
- fi
-fi
-ac_ext=cc
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-CC="$lt_save_CC"
-# Check whether --with-tags or --without-tags was given.
-if test "${with_tags+set}" = set; then
- withval="$with_tags"
- tagnames="$withval"
-fi;
-if test -f "$ltmain" && test -n "$tagnames"; then
- if test ! -f "${ofile}"; then
- { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not exist" >&5
-echo "$as_me: WARNING: output file \`$ofile' does not exist" >&2;}
- fi
- if test -z "$LTCC"; then
- eval "`$SHELL ${ofile} --config | grep '^LTCC='`"
- { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not look like a libtool script" >&5
-echo "$as_me: WARNING: output file \`$ofile' does not look like a libtool script" >&2;}
- else
- { echo "$as_me:$LINENO: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&5
-echo "$as_me: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&2;}
- fi
- fi
- # Extract list of available tagged configurations in $ofile.
- # Note that this assumes the entire list is on one line.
- available_tags=`grep "^available_tags=" "${ofile}" | $SED -e 's/available_tags=\(.*$\)/\1/' -e 's/\"//g'`
- lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
- for tagname in $tagnames; do
- IFS="$lt_save_ifs"
- # Check whether tagname contains only valid characters
- case `$echo "X$tagname" | $Xsed -e 's:[-_ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890,/]::g'` in
- *) { { echo "$as_me:$LINENO: error: invalid tag name: $tagname" >&5
-echo "$as_me: error: invalid tag name: $tagname" >&2;}
- { (exit 1); exit 1; }; }
- esac
- if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "${ofile}" > /dev/null
- then
- { { echo "$as_me:$LINENO: error: tag name \"$tagname\" already exists" >&5
-echo "$as_me: error: tag name \"$tagname\" already exists" >&2;}
- fi
- # Update the list of available tags.
- if test -n "$tagname"; then
- echo appending configuration tag \"$tagname\" to $ofile
- case $tagname in
- CXX)
- if test -n "$CXX" && test "X$CXX" != "Xno"; then
- ac_ext=cc
-archive_cmds_need_lc_CXX=no
-allow_undefined_flag_CXX=
-always_export_symbols_CXX=no
-archive_expsym_cmds_CXX=
-export_dynamic_flag_spec_CXX=
-hardcode_direct_CXX=no
-hardcode_libdir_flag_spec_CXX=
-hardcode_libdir_flag_spec_ld_CXX=
-hardcode_libdir_separator_CXX=
-hardcode_minus_L_CXX=no
-hardcode_automatic_CXX=no
-module_cmds_CXX=
-module_expsym_cmds_CXX=
-link_all_deplibs_CXX=unknown
-old_archive_cmds_CXX=$old_archive_cmds
-no_undefined_flag_CXX=
-whole_archive_flag_spec_CXX=
-enable_shared_with_static_runtimes_CXX=no
-# Dependencies to place before and after the object being linked:
-predep_objects_CXX=
-postdep_objects_CXX=
-predeps_CXX=
-postdeps_CXX=
-compiler_lib_search_path_CXX=
-# Source file extension for C++ test sources.
-ac_ext=cc
-# Object file extension for compiled C++ test sources.
-objext=o
-objext_CXX=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code="int some_variable = 0;\n"
-# Code to be used in simple link tests
-lt_simple_link_test_code='int main(int, char *) { return(0); }\n'
-# ltmain only uses $CC for tagged configurations so make sure $CC is set.
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-lt_save_CC=$CC
-lt_save_LD=$LD
-lt_save_GCC=$GCC
-GCC=$GXX
-lt_save_with_gnu_ld=$with_gnu_ld
-lt_save_path_LD=$lt_cv_path_LD
-if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
- lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
-else
- unset lt_cv_prog_gnu_ld
-fi
-if test -n "${lt_cv_path_LDCXX+set}"; then
- lt_cv_path_LD=$lt_cv_path_LDCXX
-else
- unset lt_cv_path_LD
-fi
-test -z "${LDCXX+set}" || LD=$LDCXX
-CC=${CXX-"c++"}
-compiler=$CC
-compiler_CXX=$CC
-cc_basename=`$echo X"$compiler" | $Xsed -e 's%^.*/%%'`
-# We don't want -fno-exception wen compiling C++ code, so set the
-# no_builtin_flag separately
-if test "$GXX" = yes; then
- lt_prog_compiler_no_builtin_flag_CXX=' -fno-builtin'
-else
-fi
- # Set up default GNU C++ configuration
-# Check whether --with-gnu-ld or --without-gnu-ld was given.
-if test "${with_gnu_ld+set}" = set; then
- withval="$with_gnu_ld"
- test "$withval" = no || with_gnu_ld=yes
-else
- with_gnu_ld=no
-fi;
-ac_prog=ld
- # Check if gcc -print-prog-name=ld gives a path.
- echo "$as_me:$LINENO: checking for ld used by $CC" >&5
-echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- re_direlt='/[^/][^/]*/\.\./'
- # Canonicalize the pathname of ld
- ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
- while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- echo "$as_me:$LINENO: checking for GNU ld" >&5
-echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
-else
- echo "$as_me:$LINENO: checking for non-GNU ld" >&5
-echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
-fi
-if test "${lt_cv_path_LD+set}" = set; then
-else
- if test -z "$LD"; then
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for ac_dir in $PATH; do
- test -z "$ac_dir" && ac_dir=.
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some GNU ld's only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
- *GNU* | *'with BFD'*)
- test "$with_gnu_ld" != no && break
- test "$with_gnu_ld" != yes && break
- esac
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi
-fi
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- echo "$as_me:$LINENO: result: $LD" >&5
-echo "${ECHO_T}$LD" >&6
-else
- echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
-test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
-echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
-echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
-echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
-if test "${lt_cv_prog_gnu_ld+set}" = set; then
-else
- # I'd rather use --version here, but apparently some GNU ld's only accept -v.
-case `$LD -v 2>&1 </dev/null` in
-*GNU* | *'with BFD'*)
- lt_cv_prog_gnu_ld=yes
- lt_cv_prog_gnu_ld=no
-esac
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
-echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
-with_gnu_ld=$lt_cv_prog_gnu_ld
- # Check if GNU C++ uses GNU ld as the underlying linker, since the
- # archiving commands below assume that GNU ld is being used.
- if test "$with_gnu_ld" = yes; then
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- hardcode_libdir_flag_spec_CXX='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec_CXX='${wl}--export-dynamic'
- # If archive_cmds runs LD, not CC, wlarc should be empty
- # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
- # investigate it a little bit more. (MM)
- wlarc='${wl}'
- # ancient GNU ld didn't support --whole-archive et. al.
- if eval "`$CC -print-prog-name=ld` --help 2>&1" | \
- grep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec_CXX="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- else
- with_gnu_ld=no
- wlarc=
- # A generic and very simple default shared library creation
- # command for GNU C++ for the case where it uses the native
- # linker, instead of GNU ld. If possible, this setting should
- # overridden to take advantage of the native linker features on
- # the platform it is being used on.
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
- fi
- # Commands to make compiler produce verbose output that lists
- # what "hidden" libraries, object files and flags are used when
- # linking a shared library.
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "\-L"'
-else
- GXX=no
- with_gnu_ld=no
- wlarc=
-fi
-# PORTME: fill in a description of your system's C++ link characteristics
-echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
-ld_shlibs_CXX=yes
-case $host_os in
- aix3*)
- # FIXME: insert proper C++ library support
- ld_shlibs_CXX=no
- aix4* | aix5*)
- if test "$host_cpu" = ia64; then
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix5*)
- for ld_flag in $LDFLAGS; do
- case $ld_flag in
- *-brtl*)
- aix_use_runtimelinking=yes
- break
- esac
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds_CXX=''
- hardcode_direct_CXX=yes
- hardcode_libdir_separator_CXX=':'
- link_all_deplibs_CXX=yes
- if test "$GXX" = yes; then
- case $host_os in aix4.012|aix4.012.*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- hardcode_direct_CXX=unsupported
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- hardcode_minus_L_CXX=yes
- hardcode_libdir_flag_spec_CXX='-L$libdir'
- fi
- esac
- shared_flag='-shared'
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- always_export_symbols_CXX=yes
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag_CXX='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- cat conftest.err >&5
- { ac_try='test -z "$ac_cxx_werror_flag"
- || test ! -s conftest.err'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; } &&
- ac_status=$?
- (exit $ac_status); }; }; then
-aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-# Check for a 64-bit object if we didn't find anything.
-if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-}'`; fi
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-fi
-if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
- hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
- archive_expsym_cmds_CXX="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec_CXX='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag_CXX="-z nodefs"
- archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
- else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-}'`; fi
-else
-fi
- # Warning - without using the other run time loading flags,
- no_undefined_flag_CXX=' ${wl}-bernotok'
- allow_undefined_flag_CXX=' ${wl}-berok'
- # -bexpall does not export symbols beginning with underscore (_)
- # Exported symbols can be pulled into shared objects from archives
- whole_archive_flag_spec_CXX=' '
- archive_cmds_need_lc_CXX=yes
- # This is similar to how AIX traditionally builds it's shared libraries.
- archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- chorus*)
- case $cc_basename in
- ld_shlibs_CXX=no
- esac
- cygwin* | mingw* | pw32*)
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, CXX) is actually meaningless,
- # as there is no search path for DLLs.
- allow_undefined_flag_CXX=unsupported
- always_export_symbols_CXX=no
- enable_shared_with_static_runtimes_CXX=yes
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- archive_expsym_cmds_CXX='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- else
- ld_shlibs_CXX=no
- fi
- darwin* | rhapsody*)
- archive_cmds_need_lc_CXX=no
- case "$host_os" in
- rhapsody* | darwin1.[012])
- allow_undefined_flag_CXX='-undefined suppress'
- *) # Darwin 1.3 on
- if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
- allow_undefined_flag_CXX='-flat_namespace -undefined suppress'
- else
- case ${MACOSX_DEPLOYMENT_TARGET} in
- 10.[012])
- 10.*)
- allow_undefined_flag_CXX='-undefined dynamic_lookup'
- esac
- fi
- esac
- lt_int_apple_cc_single_mod=no
- output_verbose_link_cmd='echo'
- if $CC -dumpspecs 2>&1 | grep 'single_module' >/dev/null ; then
- lt_int_apple_cc_single_mod=yes
- fi
- if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
- archive_cmds_CXX='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- else
- archive_cmds_CXX='$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- fi
- module_cmds_CXX='$CC ${wl}-bind_at_load $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
- archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- fi
- module_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- hardcode_direct_CXX=no
- hardcode_automatic_CXX=yes
- hardcode_shlibpath_var_CXX=unsupported
- whole_archive_flag_spec_CXX='-all_load $convenience'
- else
- ld_shlibs_CXX=no
- fi
- dgux*)
- ec++)
- ld_shlibs_CXX=no
- ghcx)
- # Green Hills C++ Compiler
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- freebsd12*)
- # C++ shared libraries reported to be fairly broken before switch to ELF
- ld_shlibs_CXX=no
- freebsd-elf*)
- freebsd* | kfreebsd*-gnu)
- # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
- # conventions
- ld_shlibs_CXX=yes
- gnu*)
- hpux9*)
- hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator_CXX=:
- export_dynamic_flag_spec_CXX='${wl}-E'
- hardcode_minus_L_CXX=yes # Not in the search PATH,
- # but as the default
- # location of the library.
- CC)
- ld_shlibs_CXX=no
- aCC)
- archive_cmds_CXX='$rm $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- # There doesn't appear to be a way to prevent this compiler from
- # explicitly linking system object files so we need to strip them
- # from the output so that they don't get included in the library
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- archive_cmds_CXX='$rm $output_objdir/$soname~$CC -shared -nostdlib -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- ld_shlibs_CXX=no
- fi
- esac
- hpux10*|hpux11*)
- if test $with_gnu_ld = no; then
- case "$host_cpu" in
- hppa*64*)
- hardcode_libdir_flag_spec_ld_CXX='+b $libdir'
- ia64*)
- esac
- fi
- hppa*64*)
- hardcode_shlibpath_var_CXX=no
- ia64*)
- esac
- CC)
- ld_shlibs_CXX=no
- aCC)
- hppa*64*|ia64*)
- archive_cmds_CXX='$LD -b +h $soname -o $lib $linker_flags $libobjs $deplibs'
- archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- ia64*|hppa*64*)
- archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- fi
- else
- ld_shlibs_CXX=no
- fi
- esac
- irix5* | irix6*)
- CC)
- # SGI C++
- archive_cmds_CXX='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib'
- # Archives containing C++ object files must be created using
- # "CC -ar", where "CC" is the IRIX C++ compiler. This is
- # necessary to make sure instantiated templates are included
- # in the archive.
- old_archive_cmds_CXX='$CC -ar -WR,-u -o $oldlib $oldobjs'
- if test "$with_gnu_ld" = no; then
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${objdir}/so_locations -o $lib'
- else
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` -o $lib'
- fi
- fi
- esac
- hardcode_libdir_flag_spec_CXX='${wl}-rpath ${wl}$libdir'
- linux*)
- KCC)
- # Kuck and Associates, Inc. (KAI) C++ Compiler
- # KCC will only create a shared library if the output file
- # ends with ".so" (or ".sl" for HP-UX), so rename the library
- # to its proper name (with version) after linking.
- archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
- archive_expsym_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | grep "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- hardcode_libdir_flag_spec_CXX='${wl}--rpath,$libdir'
- # "CC -Bstatic", where "CC" is the KAI C++ compiler.
- old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs'
- icpc)
- # Intel C++
- with_gnu_ld=yes
- archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- hardcode_libdir_flag_spec_CXX='${wl}-rpath,$libdir'
- whole_archive_flag_spec_CXX='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
- cxx)
- # Compaq C++
- archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec_CXX='-rpath $libdir'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- esac
- lynxos*)
- ld_shlibs_CXX=no
- m88k*)
- ld_shlibs_CXX=no
- mvs*)
- cxx)
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds_CXX='$LD -Bshareable -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
- wlarc=
- hardcode_libdir_flag_spec_CXX='-R$libdir'
- fi
- # Workaround some broken pre-1.5 toolchains
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
- osf3*)
- KCC)
- RCC)
- # Rational C++ 2.4.1
- ld_shlibs_CXX=no
- cxx)
- allow_undefined_flag_CXX=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && echo ${wl}-set_version $verstring` -update_registry ${objdir}/so_locations -o $lib'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld" | grep -v "ld:"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- if test "$GXX" = yes && test "$with_gnu_ld" = no; then
- archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${objdir}/so_locations -o $lib'
- else
- ld_shlibs_CXX=no
- fi
- esac
- osf4* | osf5*)
- KCC)
- # the KAI C++ compiler.
- old_archive_cmds_CXX='$CC -o $oldlib $oldobjs'
- RCC)
- ld_shlibs_CXX=no
- cxx)
- allow_undefined_flag_CXX=' -expect_unresolved \*'
- archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib'
- archive_expsym_cmds_CXX='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
- echo "-hidden">> $lib.exp~
- $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname -Wl,-input -Wl,$lib.exp `test -n "$verstring" && echo -set_version $verstring` -update_registry $objdir/so_locations -o $lib~
- $rm $lib.exp'
- # dependencies.
- archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${objdir}/so_locations -o $lib'
- else
- ld_shlibs_CXX=no
- fi
- esac
- psos*)
- ld_shlibs_CXX=no
- sco*)
- CC)
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- sunos4*)
- CC)
- # Sun C++ 4.x
- ld_shlibs_CXX=no
- lcc)
- # Lucid
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- solaris*)
- CC)
- # Sun C++ 4.2, 5.x and Centerline C++
- no_undefined_flag_CXX=' -zdefs'
- archive_cmds_CXX='$CC -G${allow_undefined_flag} -nolib -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- archive_expsym_cmds_CXX='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -G${allow_undefined_flag} -nolib ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- case $host_os in
- solaris2.0-5 | solaris2.0-5.*) ;;
- # The C++ compiler is used as linker so we must use $wl
- # flag to pass the commands to the underlying system
- # linker.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec_CXX='${wl}-z ${wl}allextract$convenience ${wl}-z ${wl}defaultextract'
- esac
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep "\-[LR]"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- # "CC -xar", where "CC" is the Sun C++ compiler. This is
- # in the archive.
- old_archive_cmds_CXX='$CC -xar -o $oldlib $oldobjs'
- gcx)
- archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- # The C++ compiler must be used to create the archive.
- old_archive_cmds_CXX='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
- # GNU C++ compiler with Solaris linker
- no_undefined_flag_CXX=' ${wl}-z ${wl}defs'
- if $CC --version | grep -v '^2\.7' > /dev/null; then
- archive_cmds_CXX='$CC -shared -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -shared -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- output_verbose_link_cmd="$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
- else
- # g++ 2.7 appears to require `-G' NOT `-shared' on this
- # platform.
- archive_cmds_CXX='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- output_verbose_link_cmd="$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
- fi
- hardcode_libdir_flag_spec_CXX='${wl}-R $wl$libdir'
- fi
- esac
- sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7*)
- tandem*)
- NCC)
- # NonStop-UX NCC 3.20
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- vxworks*)
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
-esac
-echo "$as_me:$LINENO: result: $ld_shlibs_CXX" >&5
-echo "${ECHO_T}$ld_shlibs_CXX" >&6
-test "$ld_shlibs_CXX" = no && can_build_shared=no
-GCC_CXX="$GXX"
-LD_CXX="$LD"
-cat > conftest.$ac_ext <<EOF
-class Foo
-public:
- Foo (void) { a = 0; }
-private:
- int a;
-EOF
-if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- (exit $ac_status); }; then
- # Parse the compiler output and extract the necessary
- # objects, libraries and library flags.
- # Sentinel used to keep track of whether or not we are before
- # the conftest object file.
- pre_test_object_deps_done=no
- # The `*' in the case matches for architectures that use `case' in
- # $output_verbose_cmd can trigger glob expansion during the loop
- # eval without this substitution.
- output_verbose_link_cmd="`$echo \"X$output_verbose_link_cmd\" | $Xsed -e \"$no_glob_subst\"`"
- for p in `eval $output_verbose_link_cmd`; do
- case $p in
- -L* | -R* | -l*)
- # Some compilers place space between "-{L,R}" and the path.
- # Remove the space.
- if test $p = "-L" \
- || test $p = "-R"; then
- prev=$p
- continue
- else
- prev=
- fi
- if test "$pre_test_object_deps_done" = no; then
- case $p in
- -L* | -R*)
- # Internal compiler library paths should come after those
- # provided the user. The postdeps already come after the
- # user supplied libs so there is no need to process them.
- if test -z "$compiler_lib_search_path_CXX"; then
- compiler_lib_search_path_CXX="${prev}${p}"
- else
- compiler_lib_search_path_CXX="${compiler_lib_search_path_CXX} ${prev}${p}"
- fi
- # The "-l" case would never come before the object being
- # linked, so don't bother handling this case.
- esac
- else
- if test -z "$postdeps_CXX"; then
- postdeps_CXX="${prev}${p}"
- else
- postdeps_CXX="${postdeps_CXX} ${prev}${p}"
- fi
- fi
- *.$objext)
- # This assumes that the test object file only shows up
- # once in the compiler output.
- if test "$p" = "conftest.$objext"; then
- pre_test_object_deps_done=yes
- continue
- fi
- if test -z "$predep_objects_CXX"; then
- predep_objects_CXX="$p"
- else
- predep_objects_CXX="$predep_objects_CXX $p"
- fi
- else
- if test -z "$postdep_objects_CXX"; then
- postdep_objects_CXX="$p"
- else
- postdep_objects_CXX="$postdep_objects_CXX $p"
- fi
- fi
- *) ;; # Ignore the rest.
- esac
- done
- # Clean up.
- rm -f a.out a.exe
-else
- echo "libtool.m4: error: problem compiling CXX test program"
-fi
-$rm -f confest.$objext
-case " $postdeps_CXX " in
-*" -lc "*) archive_cmds_need_lc_CXX=no ;;
-esac
-lt_prog_compiler_wl_CXX=
-lt_prog_compiler_pic_CXX=
-lt_prog_compiler_static_CXX=
-echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
-echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
- # C++ specific cases for pic, static, wl, etc.
- lt_prog_compiler_wl_CXX='-Wl,'
- lt_prog_compiler_static_CXX='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- # AIX 5 now supports IA64 processor
- lt_prog_compiler_static_CXX='-Bstatic'
- fi
- amigaos*)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- lt_prog_compiler_pic_CXX='-m68020 -resident32 -malways-restore-a4'
- beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | os2* | pw32*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- lt_prog_compiler_pic_CXX='-DDLL_EXPORT'
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- lt_prog_compiler_pic_CXX='-fno-common'
- *djgpp*)
- # DJGPP does not support shared libraries at all
- sysv4*MP*)
- if test -d /usr/nec; then
- lt_prog_compiler_pic_CXX=-Kconform_pic
- fi
- hpux*)
- # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
- # not for PA HP-UX.
- hppa*64*|ia64*)
- lt_prog_compiler_pic_CXX='-fPIC'
- esac
- esac
- else
- case $host_os in
- aix4* | aix5*)
- else
- lt_prog_compiler_static_CXX='-bnso -bI:/lib/syscalls.exp'
- fi
- chorus*)
- cxch68)
- # _LT_AC_TAGVAR(lt_prog_compiler_static, CXX)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
- esac
- dgux*)
- ec++)
- lt_prog_compiler_pic_CXX='-KPIC'
- ghcx)
- lt_prog_compiler_pic_CXX='-pic'
- esac
- # FreeBSD uses GNU C++
- hpux9* | hpux10* | hpux11*)
- CC)
- lt_prog_compiler_static_CXX="${ac_cv_prog_cc_wl}-a ${ac_cv_prog_cc_wl}archive"
- if test "$host_cpu" != ia64; then
- lt_prog_compiler_pic_CXX='+Z'
- fi
- aCC)
- hppa*64*|ia64*)
- # +Z the default
- esac
- esac
- irix5* | irix6* | nonstopux*)
- CC)
- lt_prog_compiler_static_CXX='-non_shared'
- # CC pic flag -KPIC is the default.
- esac
- linux*)
- KCC)
- # KAI C++ Compiler
- lt_prog_compiler_wl_CXX='--backend -Wl,'
- icpc)
- # Intel C++
- cxx)
- # Compaq C++
- # Make sure the PIC flag is empty. It appears that all Alpha
- # Linux and Compaq Tru64 Unix objects are PIC.
- esac
- lynxos*)
- m88k*)
- mvs*)
- cxx)
- lt_prog_compiler_pic_CXX='-W c,exportall'
- esac
- netbsd*)
- osf3* | osf4* | osf5*)
- KCC)
- RCC)
- cxx)
- # Digital/Compaq C++
- esac
- psos*)
- sco*)
- CC)
- esac
- solaris*)
- CC)
- lt_prog_compiler_wl_CXX='-Qoption ld '
- gcx)
- lt_prog_compiler_pic_CXX='-PIC'
- esac
- sunos4*)
- CC)
- # Sun C++ 4.x
- lcc)
- # Lucid
- esac
- tandem*)
- NCC)
- esac
- unixware*)
- vxworks*)
- lt_prog_compiler_can_build_shared_CXX=no
- esac
- fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_CXX" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_CXX" >&6
-# Check to make sure the PIC flag actually works.
-if test -n "$lt_prog_compiler_pic_CXX"; then
-echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... $ECHO_C" >&6
-if test "${lt_prog_compiler_pic_works_CXX+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- lt_prog_compiler_pic_works_CXX=no
- ac_outfile=conftest.$ac_objext
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- lt_compiler_flag="$lt_prog_compiler_pic_CXX -DPIC"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}? :&$lt_compiler_flag :; t' \
- -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:11516: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- echo "$as_me:11520: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s "$ac_outfile"; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings
- if test ! -s conftest.err; then
- lt_prog_compiler_pic_works_CXX=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_CXX" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_works_CXX" >&6
-if test x"$lt_prog_compiler_pic_works_CXX" = xyes; then
- case $lt_prog_compiler_pic_CXX in
- *) lt_prog_compiler_pic_CXX=" $lt_prog_compiler_pic_CXX" ;;
- esac
-else
-fi
-fi
-case "$host_os" in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- lt_prog_compiler_pic_CXX="$lt_prog_compiler_pic_CXX -DPIC"
-esac
-echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
-if test "${lt_cv_prog_compiler_c_o_CXX+set}" = set; then
-else
- lt_cv_prog_compiler_c_o_CXX=no
- $rm -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval echo "\"\$as_me:11576: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&5
- echo "$as_me:11580: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- if test ! -s out/conftest.err; then
- lt_cv_prog_compiler_c_o_CXX=yes
- fi
- fi
- chmod u+w .
- $rm conftest*
- # SGI C++ compiler will create directory out/ii_files/ for
- # template instantiation
- test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
- $rm out/* && rmdir out
- cd ..
- rmdir conftest
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_CXX" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o_CXX" >&6
-hard_links="nottested"
-if test "$lt_cv_prog_compiler_c_o_CXX" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
-echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- echo "$as_me:$LINENO: result: $hard_links" >&5
-echo "${ECHO_T}$hard_links" >&6
- if test "$hard_links" = no; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
- need_locks=warn
- fi
-else
- need_locks=no
-fi
- export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- case $host_os in
- aix4* | aix5*)
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
- export_symbols_cmds_CXX='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- else
- export_symbols_cmds_CXX='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- fi
- pw32*)
- export_symbols_cmds_CXX="$ltdll_cmds"
- cygwin* | mingw*)
- export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
- esac
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-# Do we need to explicitly link libc?
-case "x$archive_cmds_need_lc_CXX" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds_CXX in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
- $rm conftest*
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); } 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_prog_compiler_wl_CXX
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$allow_undefined_flag_CXX
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
- (eval $archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- else
- fi
- allow_undefined_flag_CXX=$lt_save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi
- $rm conftest*
- echo "$as_me:$LINENO: result: $archive_cmds_need_lc_CXX" >&5
-echo "${ECHO_T}$archive_cmds_need_lc_CXX" >&6
- esac
- fi
-esac
-echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
-echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
- if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi4*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
-cygwin* | mingw* | pw32*)
- version_type=windows
- shrext_cmds=".dll"
- need_version=no
- case $GCC,$host_os in
- yes,cygwin* | yes,mingw* | yes,pw32*)
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
- mingw*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
- # It is most probably a Windows format PATH printed by
- # mingw gcc, but we are running on Cygwin. Gcc prints its search
- # path with ; separators, and with drive letters. We can handle the
- # drive letters (cygwin fileutils understands them), so leave them,
- # especially as we might pass files found there to a mingw objdump,
- # which wouldn't understand a cygwinified path. Ahh.
- else
- fi
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/./-/g'`${versuffix}${shared_ext}'
- esac
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='$(test .$module = .yes && echo .so || echo .dylib)'
- # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
- if test "$GCC" = yes; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
- else
- sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
- fi
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd1*)
- dynamic_linker=no
-kfreebsd*-gnu)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- shlibpath_overrides_runpath=no
- dynamic_linker='GNU ld.so'
-freebsd*)
- objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- freebsd3.01* | freebsdelf3.01*)
- *) # from 3.2 on
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- if test "$lt_cv_prog_gnu_ld" = yes; then
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # find out which ABI we are using
- libsuff=
- x86_64*|s390x*|powerpc64*)
- echo '#line 12087 "configure"' > conftest.$ac_ext
- ac_status=$?
- case `/usr/bin/file conftest.$ac_objext` in
- *64-bit*)
- libsuff=64
- sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
- esac
- fi
- rm -rf conftest*
- esac
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`$SED -e 's/:,\t/ /g;s/=^=*$//;s/=^= * / /g' /etc/ld.so.conf | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-knetbsd*-gnu)
- need_version=no
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-nto-qnx*)
- need_version=no
-openbsd*)
- need_version=yes
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- case $host_os in
- openbsd2.[89] | openbsd2.[89].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
- version_type=osf
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- fi
- need_version=yes
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- case $host_vendor in
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-uts4*)
- dynamic_linker=no
-esac
-echo "$as_me:$LINENO: result: $dynamic_linker" >&5
-echo "${ECHO_T}$dynamic_linker" >&6
-test "$dynamic_linker" = no && can_build_shared=no
-echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action_CXX=
-if test -n "$hardcode_libdir_flag_spec_CXX" || \
- test -n "$runpath_var CXX" || \
- test "X$hardcode_automatic_CXX"="Xyes" ; then
- # We can hardcode non-existant directories.
- if test "$hardcode_direct_CXX" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, CXX)" != no &&
- test "$hardcode_minus_L_CXX" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action_CXX=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action_CXX=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action_CXX=unsupported
-fi
-echo "$as_me:$LINENO: result: $hardcode_action_CXX" >&5
-echo "${ECHO_T}$hardcode_action_CXX" >&6
-if test "$hardcode_action_CXX" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-striplib=
-old_striplib=
-echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
-echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6
-else
-# FIXME - insert some real tests, host_os isn't really good enough
- case $host_os in
- darwin*)
- if test -n "$STRIP" ; then
- striplib="$STRIP -x"
- else
-fi
- esac
-fi
-if test "x$enable_dlopen" != xyes; then
- enable_dlopen=unknown
- enable_dlopen_self=unknown
- enable_dlopen_self_static=unknown
-else
- lt_cv_dlopen=no
- lt_cv_dlopen_libs=
- case $host_os in
- beos*)
- lt_cv_dlopen="load_add_on"
- lt_cv_dlopen_self=yes
- mingw* | pw32*)
- lt_cv_dlopen="LoadLibrary"
- cygwin*)
- lt_cv_dlopen="dlopen"
- darwin*)
- # if libdl is installed we need to link against it
- echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
-echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
-if test "${ac_cv_lib_dl_dlopen+set}" = set; then
-else
- ac_check_lib_save_LIBS=$LIBS
-LIBS="-ldl $LIBS"
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-/* Override any gcc2 internal prototype to avoid an error. */
-#ifdef __cplusplus
-extern "C"
-#endif
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- (exit $ac_status); } &&
- ac_status=$?
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- ac_cv_lib_dl_dlopen=yes
-else
-ac_cv_lib_dl_dlopen=no
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-LIBS=$ac_check_lib_save_LIBS
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
-if test $ac_cv_lib_dl_dlopen = yes; then
- lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
-else
- lt_cv_dlopen="dyld"
-fi
- echo "$as_me:$LINENO: checking for shl_load" >&5
-echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
-if test "${ac_cv_func_shl_load+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
- For example, HP-UX 11i <limits.h> declares gettimeofday. */
-#define shl_load innocuous_shl_load
-/* System header to define __stub macros and hopefully few prototypes,
- which can conflict with char shl_load (); below.
- Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- <limits.h> exists even on freestanding compilers. */
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
-#undef shl_load
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-/* The GNU C library defines this for functions which it implements
- to always fail with ENOSYS. Some functions are actually named
- something starting with __ and the normal name is an alias. */
-#if defined (__stub_shl_load) || defined (__stub___shl_load)
-choke me
-#else
-char (*f) () = shl_load;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != shl_load;
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_func_shl_load=yes
-else
-ac_cv_func_shl_load=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
-echo "${ECHO_T}$ac_cv_func_shl_load" >&6
-if test $ac_cv_func_shl_load = yes; then
- lt_cv_dlopen="shl_load"
-else
- echo "$as_me:$LINENO: checking for shl_load in -ldld" >&5
-echo $ECHO_N "checking for shl_load in -ldld... $ECHO_C" >&6
-if test "${ac_cv_lib_dld_shl_load+set}" = set; then
-else
-LIBS="-ldld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-int
-main ()
-shl_load ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_dld_shl_load=yes
-else
-ac_cv_lib_dld_shl_load=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_shl_load" >&6
-if test $ac_cv_lib_dld_shl_load = yes; then
- lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"
-else
- echo "$as_me:$LINENO: checking for dlopen" >&5
-echo $ECHO_N "checking for dlopen... $ECHO_C" >&6
-if test "${ac_cv_func_dlopen+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
-#define dlopen innocuous_dlopen
- which can conflict with char dlopen (); below.
-#ifdef __STDC__
-#else
-#endif
-#undef dlopen
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-#if defined (__stub_dlopen) || defined (__stub___dlopen)
-choke me
-#else
-char (*f) () = dlopen;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != dlopen;
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_func_dlopen=yes
-else
-ac_cv_func_dlopen=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
-echo "${ECHO_T}$ac_cv_func_dlopen" >&6
-if test $ac_cv_func_dlopen = yes; then
-else
-else
-LIBS="-ldl $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-else
-fi
-fi
-else
- echo "$as_me:$LINENO: checking for dlopen in -lsvld" >&5
-echo $ECHO_N "checking for dlopen in -lsvld... $ECHO_C" >&6
-if test "${ac_cv_lib_svld_dlopen+set}" = set; then
-else
-LIBS="-lsvld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_svld_dlopen=yes
-else
-ac_cv_lib_svld_dlopen=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_svld_dlopen" >&6
-if test $ac_cv_lib_svld_dlopen = yes; then
- lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
-else
- echo "$as_me:$LINENO: checking for dld_link in -ldld" >&5
-echo $ECHO_N "checking for dld_link in -ldld... $ECHO_C" >&6
-if test "${ac_cv_lib_dld_dld_link+set}" = set; then
-else
-LIBS="-ldld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dld_link ();
-int
-main ()
-dld_link ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_dld_dld_link=yes
-else
-ac_cv_lib_dld_dld_link=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_dld_link" >&6
-if test $ac_cv_lib_dld_dld_link = yes; then
- lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"
-fi
-fi
-fi
-fi
-fi
-fi
- esac
- if test "x$lt_cv_dlopen" != xno; then
- enable_dlopen=yes
- else
- enable_dlopen=no
- fi
- case $lt_cv_dlopen in
- dlopen)
- save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
- save_LDFLAGS="$LDFLAGS"
- eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
- save_LIBS="$LIBS"
- LIBS="$lt_cv_dlopen_libs $LIBS"
- echo "$as_me:$LINENO: checking whether a program can dlopen itself" >&5
-echo $ECHO_N "checking whether a program can dlopen itself... $ECHO_C" >&6
-if test "${lt_cv_dlopen_self+set}" = set; then
-else
- if test "$cross_compiling" = yes; then :
- lt_cv_dlopen_self=cross
-else
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
- lt_status=$lt_dlunknown
- cat > conftest.$ac_ext <<EOF
-#line 12958 "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-# define LT_DLGLOBAL RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# define LT_DLGLOBAL DL_GLOBAL
-# else
-# define LT_DLGLOBAL 0
-# endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
- find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-# ifdef RTLD_LAZY
-# define LT_DLLAZY_OR_NOW RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# define LT_DLLAZY_OR_NOW DL_LAZY
-# else
-# ifdef RTLD_NOW
-# define LT_DLLAZY_OR_NOW RTLD_NOW
-# else
-# ifdef DL_NOW
-# define LT_DLLAZY_OR_NOW DL_NOW
-# else
-# define LT_DLLAZY_OR_NOW 0
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-extern "C" void exit (int);
-#endif
-void fnord() { int i=42;}
-int main ()
- void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
- int status = $lt_dlunknown;
- if (self)
- if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
- else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
- /* dlclose (self); */
- exit (status);
-EOF
- if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>&5
- ac_status=$?
- (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) 2>/dev/null
- lt_status=$?
- case x$lt_status in
- x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_unknown|x*) lt_cv_dlopen_self=no ;;
- esac
- else :
- # compilation failed
- lt_cv_dlopen_self=no
- fi
-fi
-rm -fr conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_dlopen_self" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self" >&6
- if test "x$lt_cv_dlopen_self" = xyes; then
- LDFLAGS="$LDFLAGS $link_static_flag"
- echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
-echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
-if test "${lt_cv_dlopen_self_static+set}" = set; then
-else
- lt_cv_dlopen_self_static=cross
-else
-#line 13056 "configure"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# else
-# endif
-#endif
-# ifdef RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# else
-# ifdef RTLD_NOW
-# else
-# ifdef DL_NOW
-# else
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-#endif
-int main ()
- if (self)
- exit (status);
-EOF
- ac_status=$?
- lt_status=$?
- x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_unknown|x*) lt_cv_dlopen_self_static=no ;;
- esac
- else :
- lt_cv_dlopen_self_static=no
- fi
-fi
-rm -fr conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_dlopen_self_static" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self_static" >&6
- fi
- CPPFLAGS="$save_CPPFLAGS"
- LDFLAGS="$save_LDFLAGS"
- LIBS="$save_LIBS"
- esac
- case $lt_cv_dlopen_self in
- yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
- *) enable_dlopen_self=unknown ;;
- esac
- case $lt_cv_dlopen_self_static in
- yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
- *) enable_dlopen_self_static=unknown ;;
- esac
-fi
-# The else clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
- # See if we are running on zsh, and set the options which allow our commands through
- # without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
- fi
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM \
- SED SHELL STRIP \
- libname_spec library_names_spec soname_spec extract_expsyms_cmds \
- old_striplib striplib file_magic_cmd finish_cmds finish_eval \
- deplibs_check_method reload_flag reload_cmds need_locks \
- lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
- lt_cv_sys_global_symbol_to_c_name_address \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- old_postinstall_cmds old_postuninstall_cmds \
- compiler_CXX \
- CC_CXX \
- LD_CXX \
- lt_prog_compiler_wl_CXX \
- lt_prog_compiler_pic_CXX \
- lt_prog_compiler_static_CXX \
- lt_prog_compiler_no_builtin_flag_CXX \
- export_dynamic_flag_spec_CXX \
- thread_safe_flag_spec_CXX \
- whole_archive_flag_spec_CXX \
- enable_shared_with_static_runtimes_CXX \
- old_archive_cmds_CXX \
- old_archive_from_new_cmds_CXX \
- predep_objects_CXX \
- postdep_objects_CXX \
- predeps_CXX \
- postdeps_CXX \
- compiler_lib_search_path_CXX \
- archive_cmds_CXX \
- archive_expsym_cmds_CXX \
- postinstall_cmds_CXX \
- postuninstall_cmds_CXX \
- old_archive_from_expsyms_cmds_CXX \
- allow_undefined_flag_CXX \
- no_undefined_flag_CXX \
- export_symbols_cmds_CXX \
- hardcode_libdir_flag_spec_CXX \
- hardcode_libdir_flag_spec_ld_CXX \
- hardcode_libdir_separator_CXX \
- hardcode_automatic_CXX \
- module_cmds_CXX \
- module_expsym_cmds_CXX \
- lt_cv_prog_compiler_c_o_CXX \
- exclude_expsyms_CXX \
- include_expsyms_CXX; do
- case $var in
- old_archive_cmds_CXX | \
- old_archive_from_new_cmds_CXX | \
- archive_cmds_CXX | \
- archive_expsym_cmds_CXX | \
- module_cmds_CXX | \
- module_expsym_cmds_CXX | \
- old_archive_from_expsyms_cmds_CXX | \
- export_symbols_cmds_CXX | \
- extract_expsyms_cmds | reload_cmds | finish_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- case $lt_echo in
- *'\$0 --fallback-echo"')
- lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
- esac
-cfgfile="$ofile"
- cat <<__EOF__ >> "$cfgfile"
-# ### BEGIN LIBTOOL TAG CONFIG: $tagname
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$archive_cmds_need_lc_CXX
-# Whether or not to disallow shared libs when runtime libs are static
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_CXX
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# A C compiler.
-LTCC=$lt_LTCC
-# A language-specific compiler.
-CC=$lt_compiler_CXX
-# Is the compiler the GNU C compiler?
-with_gcc=$GCC_CXX
-# An ERE matcher.
-EGREP=$lt_EGREP
-# The linker used to build libraries.
-LD=$lt_LD_CXX
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$lt_STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_lt_prog_compiler_wl_CXX
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally ".so").
-shrext_cmds='$shrext_cmds'
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_lt_prog_compiler_pic_CXX
-pic_mode=$pic_mode
-# What is the maximum length of a command?
-max_cmd_len=$lt_cv_sys_max_cmd_len
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o_CXX
-# Must we lock files when doing compilation ?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_lt_prog_compiler_static_CXX
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_CXX
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_CXX
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec_CXX
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_thread_safe_flag_spec_CXX
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds_CXX
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_CXX
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_CXX
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_archive_cmds_CXX
-archive_expsym_cmds=$lt_archive_expsym_cmds_CXX
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to build a loadable module (assumed same as above if empty)
-module_cmds=$lt_module_cmds_CXX
-module_expsym_cmds=$lt_module_expsym_cmds_CXX
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Dependencies to place before the objects being linked to create a
-# shared library.
-predep_objects=$lt_predep_objects_CXX
-# Dependencies to place after the objects being linked to create a
-# shared library.
-postdep_objects=$lt_postdep_objects_CXX
-# shared library.
-predeps=$lt_predeps_CXX
-# shared library.
-postdeps=$lt_postdeps_CXX
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_compiler_lib_search_path_CXX
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag_CXX
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag_CXX
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action_CXX
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_CXX
-# If ld is used when linking, flag to hardcode \$libdir into
-# a binary during linking. This must work even if \$libdir does
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_CXX
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator_CXX
-# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$hardcode_direct_CXX
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$hardcode_minus_L_CXX
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$hardcode_shlibpath_var_CXX
-# Set to yes if building a shared library automatically hardcodes DIR into the library
-# and all subsequent libraries and executables linked against it.
-hardcode_automatic=$hardcode_automatic_CXX
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs_CXX
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$fix_srcfile_path_CXX"
-# Set to yes if exported symbols are required.
-always_export_symbols=$always_export_symbols_CXX
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds_CXX
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms_CXX
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms_CXX
-# ### END LIBTOOL TAG CONFIG: $tagname
-__EOF__
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
- if test -f "$ltmain_in"; then
- test -f Makefile && make "$ltmain"
- fi
-fi
-ac_ext=cc
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-CC=$lt_save_CC
-LDCXX=$LD
-LD=$lt_save_LD
-GCC=$lt_save_GCC
-with_gnu_ldcxx=$with_gnu_ld
-with_gnu_ld=$lt_save_with_gnu_ld
-lt_cv_path_LDCXX=$lt_cv_path_LD
-lt_cv_path_LD=$lt_save_path_LD
-lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
-lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
- else
- tagname=""
- fi
- F77)
- if test -n "$F77" && test "X$F77" != "Xno"; then
-ac_ext=f
-ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
-ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_f77_compiler_gnu
-archive_cmds_need_lc_F77=no
-allow_undefined_flag_F77=
-always_export_symbols_F77=no
-archive_expsym_cmds_F77=
-export_dynamic_flag_spec_F77=
-hardcode_direct_F77=no
-hardcode_libdir_flag_spec_F77=
-hardcode_libdir_flag_spec_ld_F77=
-hardcode_libdir_separator_F77=
-hardcode_minus_L_F77=no
-hardcode_automatic_F77=no
-module_cmds_F77=
-module_expsym_cmds_F77=
-link_all_deplibs_F77=unknown
-old_archive_cmds_F77=$old_archive_cmds
-no_undefined_flag_F77=
-whole_archive_flag_spec_F77=
-enable_shared_with_static_runtimes_F77=no
-# Source file extension for f77 test sources.
-ac_ext=f
-# Object file extension for compiled f77 test sources.
-objext=o
-objext_F77=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code=" subroutine t\n return\n end\n"
-# Code to be used in simple link tests
-lt_simple_link_test_code=" program t\n end\n"
-# ltmain only uses $CC for tagged configurations so make sure $CC is set.
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-lt_save_CC="$CC"
-CC=${F77-"f77"}
-compiler=$CC
-compiler_F77=$CC
-cc_basename=`$echo X"$compiler" | $Xsed -e 's%^.*/%%'`
-echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
-echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
-echo "$as_me:$LINENO: result: $can_build_shared" >&5
-echo "${ECHO_T}$can_build_shared" >&6
-echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
-echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
-test "$can_build_shared" = "no" && enable_shared=no
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case "$host_os" in
-aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
- fi
-aix4* | aix5*)
-esac
-echo "$as_me:$LINENO: result: $enable_shared" >&5
-echo "${ECHO_T}$enable_shared" >&6
-echo "$as_me:$LINENO: checking whether to build static libraries" >&5
-echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-echo "$as_me:$LINENO: result: $enable_static" >&5
-echo "${ECHO_T}$enable_static" >&6
-test "$ld_shlibs_F77" = no && can_build_shared=no
-GCC_F77="$G77"
-LD_F77="$LD"
-lt_prog_compiler_wl_F77=
-lt_prog_compiler_pic_F77=
-lt_prog_compiler_static_F77=
- lt_prog_compiler_wl_F77='-Wl,'
- lt_prog_compiler_static_F77='-static'
- case $host_os in
- aix*)
- if test "$host_cpu" = ia64; then
- lt_prog_compiler_static_F77='-Bstatic'
- fi
- amigaos*)
- # like `-m68040'.
- lt_prog_compiler_pic_F77='-m68020 -resident32 -malways-restore-a4'
- mingw* | pw32* | os2*)
- lt_prog_compiler_pic_F77='-DDLL_EXPORT'
- darwin* | rhapsody*)
- lt_prog_compiler_pic_F77='-fno-common'
- msdosdjgpp*)
- # Just because we use GCC doesn't mean we suddenly get shared libraries
- # on systems that don't support them.
- lt_prog_compiler_can_build_shared_F77=no
- enable_shared=no
- sysv4*MP*)
- lt_prog_compiler_pic_F77=-Kconform_pic
- fi
- hpux*)
- case "$host_cpu" in
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic_F77='-fPIC'
- esac
- esac
- else
- # PORTME Check for flag to pass linker flags through the system compiler.
- case $host_os in
- aix*)
- else
- lt_prog_compiler_static_F77='-bnso -bI:/lib/syscalls.exp'
- fi
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic_F77='+Z'
- esac
- # Is there a better lt_prog_compiler_static that works with the bundled CC?
- lt_prog_compiler_static_F77='${wl}-a ${wl}archive'
- # PIC (with -KPIC) is the default.
- lt_prog_compiler_static_F77='-non_shared'
- newsos6)
- lt_prog_compiler_pic_F77='-KPIC'
- linux*)
- case $CC in
- icc* | ecc*)
- ccc*)
- # All Alpha code is PIC.
- esac
- # All OSF/1 code is PIC.
- sco3.2v5*)
- lt_prog_compiler_pic_F77='-Kpic'
- lt_prog_compiler_static_F77='-dn'
- solaris*)
- sunos4*)
- lt_prog_compiler_wl_F77='-Qoption ld '
- lt_prog_compiler_pic_F77='-PIC'
- sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- sysv4*MP*)
- lt_prog_compiler_pic_F77='-Kconform_pic'
- fi
- uts4*)
- lt_prog_compiler_pic_F77='-pic'
- esac
- fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_F77" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_F77" >&6
-if test -n "$lt_prog_compiler_pic_F77"; then
-echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works... $ECHO_C" >&6
-if test "${lt_prog_compiler_pic_works_F77+set}" = set; then
-else
- lt_prog_compiler_pic_works_F77=no
- lt_compiler_flag="$lt_prog_compiler_pic_F77"
- (eval echo "\"\$as_me:13883: $lt_compile\"" >&5)
- ac_status=$?
- cat conftest.err >&5
- echo "$as_me:13887: \$? = $ac_status" >&5
- lt_prog_compiler_pic_works_F77=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_F77" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_works_F77" >&6
-if test x"$lt_prog_compiler_pic_works_F77" = xyes; then
- case $lt_prog_compiler_pic_F77 in
- *) lt_prog_compiler_pic_F77=" $lt_prog_compiler_pic_F77" ;;
- esac
-else
-fi
-fi
-case "$host_os" in
- *djgpp*)
- lt_prog_compiler_pic_F77="$lt_prog_compiler_pic_F77"
-esac
-if test "${lt_cv_prog_compiler_c_o_F77+set}" = set; then
-else
- lt_cv_prog_compiler_c_o_F77=no
- mkdir conftest
- cd conftest
- mkdir out
- (eval echo "\"\$as_me:13943: $lt_compile\"" >&5)
- ac_status=$?
- echo "$as_me:13947: \$? = $ac_status" >&5
- then
- lt_cv_prog_compiler_c_o_F77=yes
- fi
- fi
- chmod u+w .
- $rm conftest*
- cd ..
- rmdir conftest
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_F77" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o_F77" >&6
-if test "$lt_cv_prog_compiler_c_o_F77" = no && test "$need_locks" != no; then
- hard_links=yes
- $rm conftest*
- touch conftest.a
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
- runpath_var=
- allow_undefined_flag_F77=
- enable_shared_with_static_runtimes_F77=no
- archive_cmds_F77=
- archive_expsym_cmds_F77=
- old_archive_From_new_cmds_F77=
- old_archive_from_expsyms_cmds_F77=
- export_dynamic_flag_spec_F77=
- whole_archive_flag_spec_F77=
- thread_safe_flag_spec_F77=
- hardcode_libdir_flag_spec_F77=
- hardcode_libdir_flag_spec_ld_F77=
- hardcode_libdir_separator_F77=
- hardcode_direct_F77=no
- hardcode_minus_L_F77=no
- hardcode_shlibpath_var_F77=unsupported
- link_all_deplibs_F77=unknown
- hardcode_automatic_F77=no
- module_cmds_F77=
- module_expsym_cmds_F77=
- always_export_symbols_F77=no
- export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- # include_expsyms should be a list of space-separated symbols to be *always*
- # included in the symbol list
- include_expsyms_F77=
- # exclude_expsyms can be an extended regexp of symbols to exclude
- # it will be wrapped by ` (' and `)$', so one must not match beginning or
- # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
- # as well as any symbol that contains `d'.
- exclude_expsyms_F77="_GLOBAL_OFFSET_TABLE_"
- # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
- # platforms (ab)use it in PIC code, but their linkers get confused if
- # the symbol is explicitly referenced. Since portable code cannot
- # rely on this symbol name, it's probably fine to never include it in
- # preloaded symbol tables.
- extract_expsyms_cmds=
- case $host_os in
- cygwin* | mingw* | pw32*)
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
- openbsd*)
- with_gnu_ld=no
- esac
- ld_shlibs_F77=yes
- if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix3* | aix4* | aix5*)
- # On AIX/PPC, the GNU linker is very broken
- ld_shlibs_F77=no
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- fi
- amigaos*)
- archive_cmds_F77='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec_F77='-L$libdir'
- hardcode_minus_L_F77=yes
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can't use
- # them.
- ld_shlibs_F77=no
- beos*)
- if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag_F77=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds_F77='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs_F77=no
- fi
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, F77) is actually meaningless,
- # as there is no search path for DLLs.
- enable_shared_with_static_runtimes_F77=yes
- export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- archive_expsym_cmds_F77='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- else
- ld_shlibs=no
- fi
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds_F77='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris* | sysv5*)
- if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
- ld_shlibs_F77=no
- cat <<EOF 1>&2
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- else
- ld_shlibs_F77=no
- fi
- sunos4*)
- archive_cmds_F77='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct_F77=yes
- hardcode_shlibpath_var_F77=no
- linux*)
- tmp_archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_cmds_F77="$tmp_archive_cmds"
- supports_anon_versioning=no
- case `$LD -v 2>/dev/null` in
- *\ 01.* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
- *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
- *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
- *\ 2.11.*) ;; # other 2.11 versions
- *) supports_anon_versioning=yes ;;
- esac
- if test $supports_anon_versioning = yes; then
- archive_expsym_cmds_F77='$echo "{ global:" > $output_objdir/$libname.ver~
-cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
-$echo "local: *; };" >> $output_objdir/$libname.ver~
- $CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- else
- archive_expsym_cmds_F77="$tmp_archive_cmds"
- fi
- else
- ld_shlibs_F77=no
- fi
- else
- ld_shlibs_F77=no
- fi
- esac
- if test "$ld_shlibs_F77" = yes; then
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec_F77='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec_F77='${wl}--export-dynamic'
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec_F77="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- fi
- else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- always_export_symbols_F77=yes
- archive_expsym_cmds_F77='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$link_static_flag"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct_F77=unsupported
- fi
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- export_symbols_cmds_F77='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- else
- export_symbols_cmds_F77='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- fi
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix5*)
- for ld_flag in $LDFLAGS; do
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- aix_use_runtimelinking=yes
- break
- fi
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds_F77=''
- hardcode_libdir_separator_F77=':'
- link_all_deplibs_F77=yes
- case $host_os in aix4.012|aix4.012.*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag_F77='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- cat >conftest.$ac_ext <<_ACEOF
- program main
- end
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- { ac_try='test -z "$ac_f77_werror_flag"
- || test ! -s conftest.err'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; } &&
- ac_status=$?
- (exit $ac_status); }; }; then
-aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-# Check for a 64-bit object if we didn't find anything.
-if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-}'`; fi
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-fi
-if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
- hardcode_libdir_flag_spec_F77='${wl}-blibpath:$libdir:'"$aix_libpath"
- archive_expsym_cmds_F77="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec_F77='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag_F77="-z nodefs"
- archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
- else
- program main
- end
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-}'`; fi
-else
-fi
- # Warning - without using the other run time loading flags,
- no_undefined_flag_F77=' ${wl}-bernotok'
- allow_undefined_flag_F77=' ${wl}-berok'
- # -bexpall does not export symbols beginning with underscore (_)
- # Exported symbols can be pulled into shared objects from archives
- whole_archive_flag_spec_F77=' '
- archive_cmds_need_lc_F77=yes
- # This is similar to how AIX traditionally builds it's shared libraries.
- archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- ld_shlibs_F77=no
- bsdi4*)
- export_dynamic_flag_spec_F77=-rdynamic
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- hardcode_libdir_flag_spec_F77=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds_F77='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_From_new_cmds_F77='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds_F77='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path='`cygpath -w "$srcfile"`'
- if test "$GXX" = yes ; then
- archive_cmds_need_lc_F77=no
- case "$host_os" in
- rhapsody* | darwin1.[012])
- allow_undefined_flag_F77='-undefined suppress'
- *) # Darwin 1.3 on
- if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
- allow_undefined_flag_F77='-flat_namespace -undefined suppress'
- else
- case ${MACOSX_DEPLOYMENT_TARGET} in
- 10.[012])
- 10.*)
- allow_undefined_flag_F77='-undefined dynamic_lookup'
- esac
- fi
- esac
- lt_int_apple_cc_single_mod=no
- output_verbose_link_cmd='echo'
- if $CC -dumpspecs 2>&1 | grep 'single_module' >/dev/null ; then
- lt_int_apple_cc_single_mod=yes
- fi
- if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
- archive_cmds_F77='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- else
- archive_cmds_F77='$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- fi
- module_cmds_F77='$CC ${wl}-bind_at_load $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
- archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- fi
- module_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- hardcode_automatic_F77=yes
- whole_archive_flag_spec_F77='-all_load $convenience'
- else
- ld_shlibs_F77=no
- fi
- dgux*)
- archive_cmds_F77='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- freebsd1*)
- ld_shlibs_F77=no
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec_F77='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd* | kfreebsd*-gnu)
- archive_cmds_F77='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- hpux9*)
- archive_cmds_F77='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- archive_cmds_F77='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- fi
- hardcode_libdir_flag_spec_F77='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator_F77=:
- # hardcode_minus_L: Not really in the search PATH,
- # but as the default location of the library.
- export_dynamic_flag_spec_F77='${wl}-E'
- hpux10* | hpux11*)
- if test "$GCC" = yes -a "$with_gnu_ld" = no; then
- hppa*64*|ia64*)
- archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_cmds_F77='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- esac
- else
- hppa*64*|ia64*)
- archive_cmds_F77='$LD -b +h $soname -o $lib $libobjs $deplibs $linker_flags'
- archive_cmds_F77='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
- esac
- fi
- if test "$with_gnu_ld" = no; then
- hppa*64*)
- hardcode_libdir_flag_spec_ld_F77='+b $libdir'
- ia64*)
- esac
- fi
- irix5* | irix6* | nonstopux*)
- archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds_F77='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec_ld_F77='-rpath $libdir'
- fi
- hardcode_libdir_flag_spec_F77='${wl}-rpath ${wl}$libdir'
- netbsd*)
- archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- archive_cmds_F77='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- openbsd*)
- archive_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- hardcode_libdir_flag_spec_F77='${wl}-rpath,$libdir'
- else
- case $host_os in
- openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
- esac
- fi
- os2*)
- archive_cmds_F77='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_From_new_cmds_F77='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- allow_undefined_flag_F77=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag_F77=' -expect_unresolved \*'
- archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds_F77='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
- # Both c and cxx compiler support -rpath directly
- hardcode_libdir_flag_spec_F77='-rpath $libdir'
- fi
- sco3.2v5*)
- export_dynamic_flag_spec_F77='${wl}-Bexport'
- hardcode_runpath_var=yes
- solaris*)
- no_undefined_flag_F77=' -z text'
- archive_cmds_F77='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_F77='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
- else
- archive_cmds_F77='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- fi
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- *) # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec_F77='-z allextract$convenience -z defaultextract' ;;
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds_F77='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds_F77='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- sni)
- hardcode_direct_F77=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- archive_cmds_F77='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- reload_cmds_F77='$CC -r -o $output$reload_objs'
- motorola)
- hardcode_direct_F77=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- export_dynamic_flag_spec_F77='-Bexport'
- sysv4*MP*)
- if test -d /usr/nec; then
- ld_shlibs_F77=yes
- fi
- sysv4.2uw2*)
- sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7*)
- no_undefined_flag_F77='${wl}-z ${wl}text'
- if test "$GCC" = yes; then
- else
- archive_cmds_F77='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- sysv5*)
- # $CC -shared without GNU ld will not create a library from C++
- # object files and a static libstdc++, better avoid it by now
- uts4*)
- ld_shlibs_F77=no
- esac
- fi
-echo "$as_me:$LINENO: result: $ld_shlibs_F77" >&5
-echo "${ECHO_T}$ld_shlibs_F77" >&6
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-# Do we need to explicitly link libc?
-case "x$archive_cmds_need_lc_F77" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds_F77 in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
- $rm conftest*
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); } 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_prog_compiler_wl_F77
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$allow_undefined_flag_F77
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
- (eval $archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- else
- fi
- allow_undefined_flag_F77=$lt_save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi
- $rm conftest*
- echo "$as_me:$LINENO: result: $archive_cmds_need_lc_F77" >&5
-echo "${ECHO_T}$archive_cmds_need_lc_F77" >&6
- esac
- fi
-esac
-echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
-echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
- if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi4*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
-cygwin* | mingw* | pw32*)
- version_type=windows
- shrext_cmds=".dll"
- need_version=no
- case $GCC,$host_os in
- yes,cygwin* | yes,mingw* | yes,pw32*)
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
- mingw*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
- # It is most probably a Windows format PATH printed by
- # mingw gcc, but we are running on Cygwin. Gcc prints its search
- # path with ; separators, and with drive letters. We can handle the
- # drive letters (cygwin fileutils understands them), so leave them,
- # especially as we might pass files found there to a mingw objdump,
- # which wouldn't understand a cygwinified path. Ahh.
- else
- fi
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/./-/g'`${versuffix}${shared_ext}'
- esac
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='$(test .$module = .yes && echo .so || echo .dylib)'
- # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
- sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
- else
- sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
- fi
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd1*)
- dynamic_linker=no
-kfreebsd*-gnu)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- shlibpath_overrides_runpath=no
- dynamic_linker='GNU ld.so'
-freebsd*)
- objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- freebsd3.01* | freebsdelf3.01*)
- *) # from 3.2 on
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- if test "$lt_cv_prog_gnu_ld" = yes; then
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # find out which ABI we are using
- libsuff=
- x86_64*|s390x*|powerpc64*)
- echo '#line 15257 "configure"' > conftest.$ac_ext
- ac_status=$?
- (exit $ac_status); }; then
- case `/usr/bin/file conftest.$ac_objext` in
- *64-bit*)
- libsuff=64
- sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
- esac
- fi
- rm -rf conftest*
- esac
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`$SED -e 's/:,\t/ /g;s/=^=*$//;s/=^= * / /g' /etc/ld.so.conf | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-knetbsd*-gnu)
- need_version=no
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-nto-qnx*)
- need_version=no
-openbsd*)
- need_version=yes
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- case $host_os in
- openbsd2.[89] | openbsd2.[89].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
- version_type=osf
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- fi
- need_version=yes
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- case $host_vendor in
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-uts4*)
- dynamic_linker=no
-esac
-echo "$as_me:$LINENO: result: $dynamic_linker" >&5
-echo "${ECHO_T}$dynamic_linker" >&6
-test "$dynamic_linker" = no && can_build_shared=no
-echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action_F77=
-if test -n "$hardcode_libdir_flag_spec_F77" || \
- test -n "$runpath_var F77" || \
- test "X$hardcode_automatic_F77"="Xyes" ; then
- # We can hardcode non-existant directories.
- if test "$hardcode_direct_F77" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, F77)" != no &&
- test "$hardcode_minus_L_F77" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action_F77=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action_F77=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action_F77=unsupported
-fi
-echo "$as_me:$LINENO: result: $hardcode_action_F77" >&5
-echo "${ECHO_T}$hardcode_action_F77" >&6
-if test "$hardcode_action_F77" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-striplib=
-old_striplib=
-echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
-echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6
-else
-# FIXME - insert some real tests, host_os isn't really good enough
- case $host_os in
- darwin*)
- if test -n "$STRIP" ; then
- striplib="$STRIP -x"
- else
- echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
- esac
-fi
-# The else clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
- # See if we are running on zsh, and set the options which allow our commands through
- # without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
- fi
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM \
- SED SHELL STRIP \
- libname_spec library_names_spec soname_spec extract_expsyms_cmds \
- old_striplib striplib file_magic_cmd finish_cmds finish_eval \
- deplibs_check_method reload_flag reload_cmds need_locks \
- lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
- lt_cv_sys_global_symbol_to_c_name_address \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- old_postinstall_cmds old_postuninstall_cmds \
- compiler_F77 \
- CC_F77 \
- LD_F77 \
- lt_prog_compiler_wl_F77 \
- lt_prog_compiler_pic_F77 \
- lt_prog_compiler_static_F77 \
- lt_prog_compiler_no_builtin_flag_F77 \
- export_dynamic_flag_spec_F77 \
- thread_safe_flag_spec_F77 \
- whole_archive_flag_spec_F77 \
- enable_shared_with_static_runtimes_F77 \
- old_archive_cmds_F77 \
- old_archive_from_new_cmds_F77 \
- predep_objects_F77 \
- postdep_objects_F77 \
- predeps_F77 \
- postdeps_F77 \
- compiler_lib_search_path_F77 \
- archive_cmds_F77 \
- archive_expsym_cmds_F77 \
- postinstall_cmds_F77 \
- postuninstall_cmds_F77 \
- old_archive_from_expsyms_cmds_F77 \
- allow_undefined_flag_F77 \
- no_undefined_flag_F77 \
- export_symbols_cmds_F77 \
- hardcode_libdir_flag_spec_F77 \
- hardcode_libdir_flag_spec_ld_F77 \
- hardcode_libdir_separator_F77 \
- hardcode_automatic_F77 \
- module_cmds_F77 \
- module_expsym_cmds_F77 \
- lt_cv_prog_compiler_c_o_F77 \
- exclude_expsyms_F77 \
- include_expsyms_F77; do
- case $var in
- old_archive_cmds_F77 | \
- old_archive_from_new_cmds_F77 | \
- archive_cmds_F77 | \
- archive_expsym_cmds_F77 | \
- module_cmds_F77 | \
- module_expsym_cmds_F77 | \
- old_archive_from_expsyms_cmds_F77 | \
- export_symbols_cmds_F77 | \
- extract_expsyms_cmds | reload_cmds | finish_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- case $lt_echo in
- *'\$0 --fallback-echo"')
- lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
- esac
-cfgfile="$ofile"
- cat <<__EOF__ >> "$cfgfile"
-# ### BEGIN LIBTOOL TAG CONFIG: $tagname
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$archive_cmds_need_lc_F77
-# Whether or not to disallow shared libs when runtime libs are static
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_F77
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# A C compiler.
-LTCC=$lt_LTCC
-# A language-specific compiler.
-CC=$lt_compiler_F77
-# Is the compiler the GNU C compiler?
-with_gcc=$GCC_F77
-# An ERE matcher.
-EGREP=$lt_EGREP
-# The linker used to build libraries.
-LD=$lt_LD_F77
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$lt_STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_lt_prog_compiler_wl_F77
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally ".so").
-shrext_cmds='$shrext_cmds'
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_lt_prog_compiler_pic_F77
-pic_mode=$pic_mode
-# What is the maximum length of a command?
-max_cmd_len=$lt_cv_sys_max_cmd_len
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o_F77
-# Must we lock files when doing compilation ?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_lt_prog_compiler_static_F77
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_F77
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_F77
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec_F77
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_thread_safe_flag_spec_F77
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds_F77
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_F77
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_F77
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_archive_cmds_F77
-archive_expsym_cmds=$lt_archive_expsym_cmds_F77
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to build a loadable module (assumed same as above if empty)
-module_cmds=$lt_module_cmds_F77
-module_expsym_cmds=$lt_module_expsym_cmds_F77
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Dependencies to place before the objects being linked to create a
-# shared library.
-predep_objects=$lt_predep_objects_F77
-# Dependencies to place after the objects being linked to create a
-# shared library.
-postdep_objects=$lt_postdep_objects_F77
-# shared library.
-predeps=$lt_predeps_F77
-# shared library.
-postdeps=$lt_postdeps_F77
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_compiler_lib_search_path_F77
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag_F77
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag_F77
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action_F77
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_F77
-# If ld is used when linking, flag to hardcode \$libdir into
-# a binary during linking. This must work even if \$libdir does
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_F77
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator_F77
-# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$hardcode_direct_F77
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$hardcode_minus_L_F77
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$hardcode_shlibpath_var_F77
-# Set to yes if building a shared library automatically hardcodes DIR into the library
-# and all subsequent libraries and executables linked against it.
-hardcode_automatic=$hardcode_automatic_F77
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs_F77
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$fix_srcfile_path_F77"
-# Set to yes if exported symbols are required.
-always_export_symbols=$always_export_symbols_F77
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds_F77
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms_F77
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms_F77
-# ### END LIBTOOL TAG CONFIG: $tagname
-__EOF__
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
- if test -f "$ltmain_in"; then
- test -f Makefile && make "$ltmain"
- fi
-fi
-ac_ext=cc
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-CC="$lt_save_CC"
- else
- tagname=""
- fi
- GCJ)
- if test -n "$GCJ" && test "X$GCJ" != "Xno"; then
-# Source file extension for Java test sources.
-ac_ext=java
-# Object file extension for compiled Java test sources.
-objext=o
-objext_GCJ=$objext
-lt_simple_compile_test_code="class foo {}\n"
-lt_simple_link_test_code='public class conftest { public static void main(String argv) {}; }\n'
-LTCC=${LTCC-"$CC"}
-compiler=$CC
-lt_save_CC="$CC"
-CC=${GCJ-"gcj"}
-compiler=$CC
-compiler_GCJ=$CC
-# GCJ did not exist at the time GCC didn't implicitly link libc in.
-archive_cmds_need_lc_GCJ=no
-lt_prog_compiler_no_builtin_flag_GCJ=
- lt_prog_compiler_no_builtin_flag_GCJ=' -fno-builtin'
-echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
-echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
-if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- lt_cv_prog_compiler_rtti_exceptions=no
- ac_outfile=conftest.$ac_objext
- lt_compiler_flag="-fno-rtti -fno-exceptions"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}? :&$lt_compiler_flag :; t' \
- -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:15998: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- echo "$as_me:16002: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s "$ac_outfile"; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings
- if test ! -s conftest.err; then
- lt_cv_prog_compiler_rtti_exceptions=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
-if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
- lt_prog_compiler_no_builtin_flag_GCJ="$lt_prog_compiler_no_builtin_flag_GCJ -fno-rtti -fno-exceptions"
-else
-fi
-fi
-lt_prog_compiler_wl_GCJ=
-lt_prog_compiler_pic_GCJ=
-lt_prog_compiler_static_GCJ=
-echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
-echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
- lt_prog_compiler_wl_GCJ='-Wl,'
- lt_prog_compiler_static_GCJ='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- # AIX 5 now supports IA64 processor
- lt_prog_compiler_static_GCJ='-Bstatic'
- fi
- amigaos*)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- lt_prog_compiler_pic_GCJ='-m68020 -resident32 -malways-restore-a4'
- beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | pw32* | os2*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- lt_prog_compiler_pic_GCJ='-DDLL_EXPORT'
- darwin* | rhapsody*)
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- lt_prog_compiler_pic_GCJ='-fno-common'
- msdosdjgpp*)
- # Just because we use GCC doesn't mean we suddenly get shared libraries
- # on systems that don't support them.
- lt_prog_compiler_can_build_shared_GCJ=no
- enable_shared=no
- sysv4*MP*)
- lt_prog_compiler_pic_GCJ=-Kconform_pic
- fi
- hpux*)
- # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
- # not for PA HP-UX.
- case "$host_cpu" in
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic_GCJ='-fPIC'
- esac
- esac
- else
- # PORTME Check for flag to pass linker flags through the system compiler.
- case $host_os in
- aix*)
- if test "$host_cpu" = ia64; then
- else
- lt_prog_compiler_static_GCJ='-bnso -bI:/lib/syscalls.exp'
- fi
- hpux9* | hpux10* | hpux11*)
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic_GCJ='+Z'
- esac
- # Is there a better lt_prog_compiler_static that works with the bundled CC?
- lt_prog_compiler_static_GCJ='${wl}-a ${wl}archive'
- # PIC (with -KPIC) is the default.
- lt_prog_compiler_static_GCJ='-non_shared'
- newsos6)
- lt_prog_compiler_pic_GCJ='-KPIC'
- linux*)
- case $CC in
- icc* | ecc*)
- ccc*)
- # All Alpha code is PIC.
- esac
- osf3* | osf4* | osf5*)
- # All OSF/1 code is PIC.
- sco3.2v5*)
- lt_prog_compiler_pic_GCJ='-Kpic'
- lt_prog_compiler_static_GCJ='-dn'
- solaris*)
- sunos4*)
- lt_prog_compiler_wl_GCJ='-Qoption ld '
- lt_prog_compiler_pic_GCJ='-PIC'
- sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- sysv4*MP*)
- lt_prog_compiler_pic_GCJ='-Kconform_pic'
- fi
- uts4*)
- lt_prog_compiler_pic_GCJ='-pic'
- esac
- fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_GCJ" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_GCJ" >&6
-# Check to make sure the PIC flag actually works.
-if test -n "$lt_prog_compiler_pic_GCJ"; then
-echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works... $ECHO_C" >&6
-if test "${lt_prog_compiler_pic_works_GCJ+set}" = set; then
-else
- lt_prog_compiler_pic_works_GCJ=no
- lt_compiler_flag="$lt_prog_compiler_pic_GCJ"
- (eval echo "\"\$as_me:16231: $lt_compile\"" >&5)
- ac_status=$?
- cat conftest.err >&5
- echo "$as_me:16235: \$? = $ac_status" >&5
- lt_prog_compiler_pic_works_GCJ=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_GCJ" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_works_GCJ" >&6
-if test x"$lt_prog_compiler_pic_works_GCJ" = xyes; then
- case $lt_prog_compiler_pic_GCJ in
- *) lt_prog_compiler_pic_GCJ=" $lt_prog_compiler_pic_GCJ" ;;
- esac
-else
-fi
-fi
-case "$host_os" in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- lt_prog_compiler_pic_GCJ="$lt_prog_compiler_pic_GCJ"
-esac
-echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
-if test "${lt_cv_prog_compiler_c_o_GCJ+set}" = set; then
-else
- lt_cv_prog_compiler_c_o_GCJ=no
- $rm -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval echo "\"\$as_me:16291: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&5
- echo "$as_me:16295: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- if test ! -s out/conftest.err; then
- lt_cv_prog_compiler_c_o_GCJ=yes
- fi
- fi
- chmod u+w .
- $rm conftest*
- # SGI C++ compiler will create directory out/ii_files/ for
- # template instantiation
- test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
- $rm out/* && rmdir out
- cd ..
- rmdir conftest
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_GCJ" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o_GCJ" >&6
-hard_links="nottested"
-if test "$lt_cv_prog_compiler_c_o_GCJ" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
-echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- echo "$as_me:$LINENO: result: $hard_links" >&5
-echo "${ECHO_T}$hard_links" >&6
- if test "$hard_links" = no; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
- runpath_var=
- allow_undefined_flag_GCJ=
- enable_shared_with_static_runtimes_GCJ=no
- archive_cmds_GCJ=
- archive_expsym_cmds_GCJ=
- old_archive_From_new_cmds_GCJ=
- old_archive_from_expsyms_cmds_GCJ=
- export_dynamic_flag_spec_GCJ=
- whole_archive_flag_spec_GCJ=
- thread_safe_flag_spec_GCJ=
- hardcode_libdir_flag_spec_GCJ=
- hardcode_libdir_flag_spec_ld_GCJ=
- hardcode_libdir_separator_GCJ=
- hardcode_direct_GCJ=no
- hardcode_minus_L_GCJ=no
- hardcode_shlibpath_var_GCJ=unsupported
- link_all_deplibs_GCJ=unknown
- hardcode_automatic_GCJ=no
- module_cmds_GCJ=
- module_expsym_cmds_GCJ=
- always_export_symbols_GCJ=no
- export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- # include_expsyms should be a list of space-separated symbols to be *always*
- # included in the symbol list
- include_expsyms_GCJ=
- # exclude_expsyms can be an extended regexp of symbols to exclude
- # it will be wrapped by ` (' and `)$', so one must not match beginning or
- # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
- # as well as any symbol that contains `d'.
- exclude_expsyms_GCJ="_GLOBAL_OFFSET_TABLE_"
- # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
- # platforms (ab)use it in PIC code, but their linkers get confused if
- # the symbol is explicitly referenced. Since portable code cannot
- # rely on this symbol name, it's probably fine to never include it in
- # preloaded symbol tables.
- extract_expsyms_cmds=
- case $host_os in
- cygwin* | mingw* | pw32*)
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
- openbsd*)
- with_gnu_ld=no
- esac
- ld_shlibs_GCJ=yes
- if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix3* | aix4* | aix5*)
- # On AIX/PPC, the GNU linker is very broken
- if test "$host_cpu" != ia64; then
- ld_shlibs_GCJ=no
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- fi
- amigaos*)
- archive_cmds_GCJ='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec_GCJ='-L$libdir'
- hardcode_minus_L_GCJ=yes
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can't use
- # them.
- ld_shlibs_GCJ=no
- beos*)
- if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag_GCJ=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds_GCJ='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs_GCJ=no
- fi
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, GCJ) is actually meaningless,
- # as there is no search path for DLLs.
- enable_shared_with_static_runtimes_GCJ=yes
- export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- archive_expsym_cmds_GCJ='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- else
- ld_shlibs=no
- fi
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds_GCJ='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris* | sysv5*)
- if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
- ld_shlibs_GCJ=no
- cat <<EOF 1>&2
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- else
- ld_shlibs_GCJ=no
- fi
- sunos4*)
- archive_cmds_GCJ='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct_GCJ=yes
- hardcode_shlibpath_var_GCJ=no
- linux*)
- tmp_archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_cmds_GCJ="$tmp_archive_cmds"
- supports_anon_versioning=no
- case `$LD -v 2>/dev/null` in
- *\ 01.* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
- *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
- *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
- *\ 2.11.*) ;; # other 2.11 versions
- *) supports_anon_versioning=yes ;;
- esac
- if test $supports_anon_versioning = yes; then
- archive_expsym_cmds_GCJ='$echo "{ global:" > $output_objdir/$libname.ver~
-cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
-$echo "local: *; };" >> $output_objdir/$libname.ver~
- $CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- else
- archive_expsym_cmds_GCJ="$tmp_archive_cmds"
- fi
- else
- ld_shlibs_GCJ=no
- fi
- else
- ld_shlibs_GCJ=no
- fi
- esac
- if test "$ld_shlibs_GCJ" = yes; then
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec_GCJ='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec_GCJ='${wl}--export-dynamic'
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec_GCJ="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- fi
- else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- always_export_symbols_GCJ=yes
- archive_expsym_cmds_GCJ='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$link_static_flag"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct_GCJ=unsupported
- fi
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
- export_symbols_cmds_GCJ='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- else
- export_symbols_cmds_GCJ='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- fi
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix5*)
- for ld_flag in $LDFLAGS; do
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- aix_use_runtimelinking=yes
- break
- fi
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds_GCJ=''
- hardcode_libdir_separator_GCJ=':'
- link_all_deplibs_GCJ=yes
- case $host_os in aix4.012|aix4.012.*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag_GCJ='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- (exit $ac_status); } &&
- { ac_try='test -z "$ac_cxx_werror_flag"
- || test ! -s conftest.err'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; } &&
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- (exit $ac_status); }; }; then
-aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-# Check for a 64-bit object if we didn't find anything.
-if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-}'`; fi
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
- hardcode_libdir_flag_spec_GCJ='${wl}-blibpath:$libdir:'"$aix_libpath"
- archive_expsym_cmds_GCJ="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec_GCJ='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag_GCJ="-z nodefs"
- archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
- else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-}'`; fi
-else
-fi
- # Warning - without using the other run time loading flags,
- no_undefined_flag_GCJ=' ${wl}-bernotok'
- allow_undefined_flag_GCJ=' ${wl}-berok'
- # -bexpall does not export symbols beginning with underscore (_)
- # Exported symbols can be pulled into shared objects from archives
- whole_archive_flag_spec_GCJ=' '
- archive_cmds_need_lc_GCJ=yes
- # This is similar to how AIX traditionally builds it's shared libraries.
- archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- ld_shlibs_GCJ=no
- bsdi4*)
- export_dynamic_flag_spec_GCJ=-rdynamic
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- hardcode_libdir_flag_spec_GCJ=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds_GCJ='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_From_new_cmds_GCJ='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds_GCJ='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path='`cygpath -w "$srcfile"`'
- if test "$GXX" = yes ; then
- archive_cmds_need_lc_GCJ=no
- case "$host_os" in
- rhapsody* | darwin1.[012])
- allow_undefined_flag_GCJ='-undefined suppress'
- *) # Darwin 1.3 on
- if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
- allow_undefined_flag_GCJ='-flat_namespace -undefined suppress'
- else
- case ${MACOSX_DEPLOYMENT_TARGET} in
- 10.[012])
- 10.*)
- allow_undefined_flag_GCJ='-undefined dynamic_lookup'
- esac
- fi
- esac
- lt_int_apple_cc_single_mod=no
- output_verbose_link_cmd='echo'
- if $CC -dumpspecs 2>&1 | grep 'single_module' >/dev/null ; then
- lt_int_apple_cc_single_mod=yes
- fi
- if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
- archive_cmds_GCJ='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- else
- archive_cmds_GCJ='$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- fi
- module_cmds_GCJ='$CC ${wl}-bind_at_load $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
- archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- fi
- module_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- hardcode_automatic_GCJ=yes
- whole_archive_flag_spec_GCJ='-all_load $convenience'
- else
- ld_shlibs_GCJ=no
- fi
- dgux*)
- archive_cmds_GCJ='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- freebsd1*)
- ld_shlibs_GCJ=no
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec_GCJ='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd* | kfreebsd*-gnu)
- archive_cmds_GCJ='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- hpux9*)
- archive_cmds_GCJ='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- archive_cmds_GCJ='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- fi
- hardcode_libdir_flag_spec_GCJ='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator_GCJ=:
- # hardcode_minus_L: Not really in the search PATH,
- # but as the default location of the library.
- export_dynamic_flag_spec_GCJ='${wl}-E'
- hpux10* | hpux11*)
- if test "$GCC" = yes -a "$with_gnu_ld" = no; then
- hppa*64*|ia64*)
- archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_cmds_GCJ='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- esac
- else
- hppa*64*|ia64*)
- archive_cmds_GCJ='$LD -b +h $soname -o $lib $libobjs $deplibs $linker_flags'
- archive_cmds_GCJ='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
- esac
- fi
- if test "$with_gnu_ld" = no; then
- hppa*64*)
- hardcode_libdir_flag_spec_ld_GCJ='+b $libdir'
- ia64*)
- esac
- fi
- irix5* | irix6* | nonstopux*)
- archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds_GCJ='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec_ld_GCJ='-rpath $libdir'
- fi
- hardcode_libdir_flag_spec_GCJ='${wl}-rpath ${wl}$libdir'
- netbsd*)
- archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- archive_cmds_GCJ='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- openbsd*)
- archive_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- hardcode_libdir_flag_spec_GCJ='${wl}-rpath,$libdir'
- else
- case $host_os in
- openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
- esac
- fi
- os2*)
- archive_cmds_GCJ='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_From_new_cmds_GCJ='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- allow_undefined_flag_GCJ=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag_GCJ=' -expect_unresolved \*'
- archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds_GCJ='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
- # Both c and cxx compiler support -rpath directly
- hardcode_libdir_flag_spec_GCJ='-rpath $libdir'
- fi
- sco3.2v5*)
- export_dynamic_flag_spec_GCJ='${wl}-Bexport'
- hardcode_runpath_var=yes
- solaris*)
- no_undefined_flag_GCJ=' -z text'
- if test "$GCC" = yes; then
- archive_cmds_GCJ='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_GCJ='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
- else
- archive_cmds_GCJ='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- fi
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- *) # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec_GCJ='-z allextract$convenience -z defaultextract' ;;
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds_GCJ='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds_GCJ='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- sni)
- hardcode_direct_GCJ=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- archive_cmds_GCJ='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- reload_cmds_GCJ='$CC -r -o $output$reload_objs'
- motorola)
- hardcode_direct_GCJ=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- export_dynamic_flag_spec_GCJ='-Bexport'
- sysv4*MP*)
- if test -d /usr/nec; then
- ld_shlibs_GCJ=yes
- fi
- sysv4.2uw2*)
- sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7*)
- no_undefined_flag_GCJ='${wl}-z ${wl}text'
- else
- archive_cmds_GCJ='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- sysv5*)
- # $CC -shared without GNU ld will not create a library from C++
- # object files and a static libstdc++, better avoid it by now
- uts4*)
- ld_shlibs_GCJ=no
- esac
- fi
-echo "$as_me:$LINENO: result: $ld_shlibs_GCJ" >&5
-echo "${ECHO_T}$ld_shlibs_GCJ" >&6
-test "$ld_shlibs_GCJ" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-# Do we need to explicitly link libc?
-case "x$archive_cmds_need_lc_GCJ" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds_GCJ in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
- $rm conftest*
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); } 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_prog_compiler_wl_GCJ
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$allow_undefined_flag_GCJ
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
- (eval $archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- else
- fi
- allow_undefined_flag_GCJ=$lt_save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi
- $rm conftest*
- echo "$as_me:$LINENO: result: $archive_cmds_need_lc_GCJ" >&5
-echo "${ECHO_T}$archive_cmds_need_lc_GCJ" >&6
- esac
- fi
-esac
-echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
-echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
- if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi4*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
-cygwin* | mingw* | pw32*)
- version_type=windows
- shrext_cmds=".dll"
- need_version=no
- case $GCC,$host_os in
- yes,cygwin* | yes,mingw* | yes,pw32*)
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
- mingw*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
- # It is most probably a Windows format PATH printed by
- # mingw gcc, but we are running on Cygwin. Gcc prints its search
- # path with ; separators, and with drive letters. We can handle the
- # drive letters (cygwin fileutils understands them), so leave them,
- # especially as we might pass files found there to a mingw objdump,
- # which wouldn't understand a cygwinified path. Ahh.
- else
- fi
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/./-/g'`${versuffix}${shared_ext}'
- esac
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_overrides_runpath=yes
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='$(test .$module = .yes && echo .so || echo .dylib)'
- # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
- sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
- else
- sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
- fi
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
- shlibpath_var=LD_LIBRARY_PATH
-freebsd1*)
- dynamic_linker=no
-kfreebsd*-gnu)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- shlibpath_overrides_runpath=no
- dynamic_linker='GNU ld.so'
-freebsd*)
- objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- freebsd3.01* | freebsdelf3.01*)
- *) # from 3.2 on
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- if test "$lt_cv_prog_gnu_ld" = yes; then
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # find out which ABI we are using
- libsuff=
- x86_64*|s390x*|powerpc64*)
- echo '#line 17625 "configure"' > conftest.$ac_ext
- ac_status=$?
- (exit $ac_status); }; then
- case `/usr/bin/file conftest.$ac_objext` in
- *64-bit*)
- libsuff=64
- sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
- esac
- fi
- rm -rf conftest*
- esac
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`$SED -e 's/:,\t/ /g;s/=^=*$//;s/=^= * / /g' /etc/ld.so.conf | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-knetbsd*-gnu)
- need_version=no
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-nto-qnx*)
- need_version=no
-openbsd*)
- need_version=yes
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- case $host_os in
- openbsd2.[89] | openbsd2.[89].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
- version_type=osf
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- fi
- need_version=yes
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- case $host_vendor in
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-uts4*)
- dynamic_linker=no
-esac
-echo "$as_me:$LINENO: result: $dynamic_linker" >&5
-echo "${ECHO_T}$dynamic_linker" >&6
-test "$dynamic_linker" = no && can_build_shared=no
-echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action_GCJ=
-if test -n "$hardcode_libdir_flag_spec_GCJ" || \
- test -n "$runpath_var GCJ" || \
- test "X$hardcode_automatic_GCJ"="Xyes" ; then
- # We can hardcode non-existant directories.
- if test "$hardcode_direct_GCJ" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, GCJ)" != no &&
- test "$hardcode_minus_L_GCJ" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action_GCJ=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action_GCJ=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action_GCJ=unsupported
-fi
-echo "$as_me:$LINENO: result: $hardcode_action_GCJ" >&5
-echo "${ECHO_T}$hardcode_action_GCJ" >&6
-if test "$hardcode_action_GCJ" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-striplib=
-old_striplib=
-echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
-echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6
-else
-# FIXME - insert some real tests, host_os isn't really good enough
- case $host_os in
- darwin*)
- if test -n "$STRIP" ; then
- striplib="$STRIP -x"
- else
- echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
- esac
-fi
-if test "x$enable_dlopen" != xyes; then
- enable_dlopen=unknown
- enable_dlopen_self=unknown
- enable_dlopen_self_static=unknown
-else
- lt_cv_dlopen=no
- lt_cv_dlopen_libs=
- case $host_os in
- beos*)
- lt_cv_dlopen="load_add_on"
- lt_cv_dlopen_self=yes
- mingw* | pw32*)
- lt_cv_dlopen="LoadLibrary"
- cygwin*)
- lt_cv_dlopen="dlopen"
- darwin*)
- # if libdl is installed we need to link against it
- echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
-echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
-if test "${ac_cv_lib_dl_dlopen+set}" = set; then
-else
- ac_check_lib_save_LIBS=$LIBS
-LIBS="-ldl $LIBS"
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-/* Override any gcc2 internal prototype to avoid an error. */
-#ifdef __cplusplus
-extern "C"
-#endif
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_dl_dlopen=yes
-else
-ac_cv_lib_dl_dlopen=no
-fi
-LIBS=$ac_check_lib_save_LIBS
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
-if test $ac_cv_lib_dl_dlopen = yes; then
- lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
-else
- lt_cv_dlopen="dyld"
-fi
- echo "$as_me:$LINENO: checking for shl_load" >&5
-echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
-if test "${ac_cv_func_shl_load+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
- For example, HP-UX 11i <limits.h> declares gettimeofday. */
-#define shl_load innocuous_shl_load
-/* System header to define __stub macros and hopefully few prototypes,
- which can conflict with char shl_load (); below.
- Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- <limits.h> exists even on freestanding compilers. */
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
-#undef shl_load
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-/* The GNU C library defines this for functions which it implements
- to always fail with ENOSYS. Some functions are actually named
- something starting with __ and the normal name is an alias. */
-#if defined (__stub_shl_load) || defined (__stub___shl_load)
-choke me
-#else
-char (*f) () = shl_load;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != shl_load;
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_func_shl_load=yes
-else
-ac_cv_func_shl_load=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
-echo "${ECHO_T}$ac_cv_func_shl_load" >&6
-if test $ac_cv_func_shl_load = yes; then
- lt_cv_dlopen="shl_load"
-else
- echo "$as_me:$LINENO: checking for shl_load in -ldld" >&5
-echo $ECHO_N "checking for shl_load in -ldld... $ECHO_C" >&6
-if test "${ac_cv_lib_dld_shl_load+set}" = set; then
-else
-LIBS="-ldld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-int
-main ()
-shl_load ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_dld_shl_load=yes
-else
-ac_cv_lib_dld_shl_load=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_shl_load" >&6
-if test $ac_cv_lib_dld_shl_load = yes; then
- lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"
-else
- echo "$as_me:$LINENO: checking for dlopen" >&5
-echo $ECHO_N "checking for dlopen... $ECHO_C" >&6
-if test "${ac_cv_func_dlopen+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
-#define dlopen innocuous_dlopen
- which can conflict with char dlopen (); below.
-#ifdef __STDC__
-#else
-#endif
-#undef dlopen
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-#if defined (__stub_dlopen) || defined (__stub___dlopen)
-choke me
-#else
-char (*f) () = dlopen;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != dlopen;
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_func_dlopen=yes
-else
-ac_cv_func_dlopen=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
-echo "${ECHO_T}$ac_cv_func_dlopen" >&6
-if test $ac_cv_func_dlopen = yes; then
-else
-else
-LIBS="-ldl $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-else
-fi
-fi
-else
- echo "$as_me:$LINENO: checking for dlopen in -lsvld" >&5
-echo $ECHO_N "checking for dlopen in -lsvld... $ECHO_C" >&6
-if test "${ac_cv_lib_svld_dlopen+set}" = set; then
-else
-LIBS="-lsvld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_svld_dlopen=yes
-else
-ac_cv_lib_svld_dlopen=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_svld_dlopen" >&6
-if test $ac_cv_lib_svld_dlopen = yes; then
- lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
-else
- echo "$as_me:$LINENO: checking for dld_link in -ldld" >&5
-echo $ECHO_N "checking for dld_link in -ldld... $ECHO_C" >&6
-if test "${ac_cv_lib_dld_dld_link+set}" = set; then
-else
-LIBS="-ldld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dld_link ();
-int
-main ()
-dld_link ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_dld_dld_link=yes
-else
-ac_cv_lib_dld_dld_link=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_dld_link" >&6
-if test $ac_cv_lib_dld_dld_link = yes; then
- lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"
-fi
-fi
-fi
-fi
-fi
-fi
- esac
- if test "x$lt_cv_dlopen" != xno; then
- enable_dlopen=yes
- else
- enable_dlopen=no
- fi
- case $lt_cv_dlopen in
- dlopen)
- save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
- save_LDFLAGS="$LDFLAGS"
- eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
- save_LIBS="$LIBS"
- LIBS="$lt_cv_dlopen_libs $LIBS"
- echo "$as_me:$LINENO: checking whether a program can dlopen itself" >&5
-echo $ECHO_N "checking whether a program can dlopen itself... $ECHO_C" >&6
-if test "${lt_cv_dlopen_self+set}" = set; then
-else
- if test "$cross_compiling" = yes; then :
- lt_cv_dlopen_self=cross
-else
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
- lt_status=$lt_dlunknown
- cat > conftest.$ac_ext <<EOF
-#line 18496 "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-# define LT_DLGLOBAL RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# define LT_DLGLOBAL DL_GLOBAL
-# else
-# define LT_DLGLOBAL 0
-# endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
- find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-# ifdef RTLD_LAZY
-# define LT_DLLAZY_OR_NOW RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# define LT_DLLAZY_OR_NOW DL_LAZY
-# else
-# ifdef RTLD_NOW
-# define LT_DLLAZY_OR_NOW RTLD_NOW
-# else
-# ifdef DL_NOW
-# define LT_DLLAZY_OR_NOW DL_NOW
-# else
-# define LT_DLLAZY_OR_NOW 0
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-extern "C" void exit (int);
-#endif
-void fnord() { int i=42;}
-int main ()
- void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
- int status = $lt_dlunknown;
- if (self)
- if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
- else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
- /* dlclose (self); */
- exit (status);
-EOF
- if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>&5
- ac_status=$?
- (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) 2>/dev/null
- lt_status=$?
- case x$lt_status in
- x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_unknown|x*) lt_cv_dlopen_self=no ;;
- esac
- else :
- # compilation failed
- lt_cv_dlopen_self=no
- fi
-fi
-rm -fr conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_dlopen_self" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self" >&6
- if test "x$lt_cv_dlopen_self" = xyes; then
- LDFLAGS="$LDFLAGS $link_static_flag"
- echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
-echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
-if test "${lt_cv_dlopen_self_static+set}" = set; then
-else
- lt_cv_dlopen_self_static=cross
-else
-#line 18594 "configure"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# else
-# endif
-#endif
-# ifdef RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# else
-# ifdef RTLD_NOW
-# else
-# ifdef DL_NOW
-# else
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-#endif
-int main ()
- if (self)
- exit (status);
-EOF
- ac_status=$?
- lt_status=$?
- x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_unknown|x*) lt_cv_dlopen_self_static=no ;;
- esac
- else :
- lt_cv_dlopen_self_static=no
- fi
-fi
-rm -fr conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_dlopen_self_static" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self_static" >&6
- fi
- CPPFLAGS="$save_CPPFLAGS"
- LDFLAGS="$save_LDFLAGS"
- LIBS="$save_LIBS"
- esac
- case $lt_cv_dlopen_self in
- yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
- *) enable_dlopen_self=unknown ;;
- esac
- case $lt_cv_dlopen_self_static in
- yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
- *) enable_dlopen_self_static=unknown ;;
- esac
-fi
-# The else clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
- # See if we are running on zsh, and set the options which allow our commands through
- # without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
- fi
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM \
- SED SHELL STRIP \
- libname_spec library_names_spec soname_spec extract_expsyms_cmds \
- old_striplib striplib file_magic_cmd finish_cmds finish_eval \
- deplibs_check_method reload_flag reload_cmds need_locks \
- lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
- lt_cv_sys_global_symbol_to_c_name_address \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- old_postinstall_cmds old_postuninstall_cmds \
- compiler_GCJ \
- CC_GCJ \
- LD_GCJ \
- lt_prog_compiler_wl_GCJ \
- lt_prog_compiler_pic_GCJ \
- lt_prog_compiler_static_GCJ \
- lt_prog_compiler_no_builtin_flag_GCJ \
- export_dynamic_flag_spec_GCJ \
- thread_safe_flag_spec_GCJ \
- whole_archive_flag_spec_GCJ \
- enable_shared_with_static_runtimes_GCJ \
- old_archive_cmds_GCJ \
- old_archive_from_new_cmds_GCJ \
- predep_objects_GCJ \
- postdep_objects_GCJ \
- predeps_GCJ \
- postdeps_GCJ \
- compiler_lib_search_path_GCJ \
- archive_cmds_GCJ \
- archive_expsym_cmds_GCJ \
- postinstall_cmds_GCJ \
- postuninstall_cmds_GCJ \
- old_archive_from_expsyms_cmds_GCJ \
- allow_undefined_flag_GCJ \
- no_undefined_flag_GCJ \
- export_symbols_cmds_GCJ \
- hardcode_libdir_flag_spec_GCJ \
- hardcode_libdir_flag_spec_ld_GCJ \
- hardcode_libdir_separator_GCJ \
- hardcode_automatic_GCJ \
- module_cmds_GCJ \
- module_expsym_cmds_GCJ \
- lt_cv_prog_compiler_c_o_GCJ \
- exclude_expsyms_GCJ \
- include_expsyms_GCJ; do
- case $var in
- old_archive_cmds_GCJ | \
- old_archive_from_new_cmds_GCJ | \
- archive_cmds_GCJ | \
- archive_expsym_cmds_GCJ | \
- module_cmds_GCJ | \
- module_expsym_cmds_GCJ | \
- old_archive_from_expsyms_cmds_GCJ | \
- export_symbols_cmds_GCJ | \
- extract_expsyms_cmds | reload_cmds | finish_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- case $lt_echo in
- *'\$0 --fallback-echo"')
- lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
- esac
-cfgfile="$ofile"
- cat <<__EOF__ >> "$cfgfile"
-# ### BEGIN LIBTOOL TAG CONFIG: $tagname
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$archive_cmds_need_lc_GCJ
-# Whether or not to disallow shared libs when runtime libs are static
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_GCJ
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# A C compiler.
-LTCC=$lt_LTCC
-# A language-specific compiler.
-CC=$lt_compiler_GCJ
-# Is the compiler the GNU C compiler?
-with_gcc=$GCC_GCJ
-# An ERE matcher.
-EGREP=$lt_EGREP
-# The linker used to build libraries.
-LD=$lt_LD_GCJ
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$lt_STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_lt_prog_compiler_wl_GCJ
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally ".so").
-shrext_cmds='$shrext_cmds'
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_lt_prog_compiler_pic_GCJ
-pic_mode=$pic_mode
-# What is the maximum length of a command?
-max_cmd_len=$lt_cv_sys_max_cmd_len
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o_GCJ
-# Must we lock files when doing compilation ?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_lt_prog_compiler_static_GCJ
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_GCJ
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_GCJ
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec_GCJ
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_thread_safe_flag_spec_GCJ
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds_GCJ
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_GCJ
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_GCJ
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_archive_cmds_GCJ
-archive_expsym_cmds=$lt_archive_expsym_cmds_GCJ
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to build a loadable module (assumed same as above if empty)
-module_cmds=$lt_module_cmds_GCJ
-module_expsym_cmds=$lt_module_expsym_cmds_GCJ
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Dependencies to place before the objects being linked to create a
-# shared library.
-predep_objects=$lt_predep_objects_GCJ
-# Dependencies to place after the objects being linked to create a
-# shared library.
-postdep_objects=$lt_postdep_objects_GCJ
-# shared library.
-predeps=$lt_predeps_GCJ
-# shared library.
-postdeps=$lt_postdeps_GCJ
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_compiler_lib_search_path_GCJ
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag_GCJ
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag_GCJ
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action_GCJ
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_GCJ
-# If ld is used when linking, flag to hardcode \$libdir into
-# a binary during linking. This must work even if \$libdir does
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_GCJ
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator_GCJ
-# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$hardcode_direct_GCJ
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$hardcode_minus_L_GCJ
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$hardcode_shlibpath_var_GCJ
-# Set to yes if building a shared library automatically hardcodes DIR into the library
-# and all subsequent libraries and executables linked against it.
-hardcode_automatic=$hardcode_automatic_GCJ
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs_GCJ
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$fix_srcfile_path_GCJ"
-# Set to yes if exported symbols are required.
-always_export_symbols=$always_export_symbols_GCJ
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds_GCJ
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms_GCJ
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms_GCJ
-# ### END LIBTOOL TAG CONFIG: $tagname
-__EOF__
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
- if test -f "$ltmain_in"; then
- test -f Makefile && make "$ltmain"
- fi
-fi
-ac_ext=cc
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-CC="$lt_save_CC"
- else
- tagname=""
- fi
- RC)
-# Source file extension for RC test sources.
-ac_ext=rc
-# Object file extension for compiled RC test sources.
-objext=o
-objext_RC=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code='sample MENU { MENUITEM "&Soup", 100, CHECKED }\n'
-# Code to be used in simple link tests
-lt_simple_link_test_code="$lt_simple_compile_test_code"
-# ltmain only uses $CC for tagged configurations so make sure $CC is set.
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-lt_save_CC="$CC"
-CC=${RC-"windres"}
-compiler=$CC
-compiler_RC=$CC
-lt_cv_prog_compiler_c_o_RC=yes
- fi
- SED SHELL STRIP \
- compiler_RC \
- CC_RC \
- LD_RC \
- lt_prog_compiler_wl_RC \
- lt_prog_compiler_pic_RC \
- lt_prog_compiler_static_RC \
- lt_prog_compiler_no_builtin_flag_RC \
- export_dynamic_flag_spec_RC \
- thread_safe_flag_spec_RC \
- whole_archive_flag_spec_RC \
- enable_shared_with_static_runtimes_RC \
- old_archive_cmds_RC \
- old_archive_from_new_cmds_RC \
- predep_objects_RC \
- postdep_objects_RC \
- predeps_RC \
- postdeps_RC \
- compiler_lib_search_path_RC \
- archive_cmds_RC \
- archive_expsym_cmds_RC \
- postinstall_cmds_RC \
- postuninstall_cmds_RC \
- old_archive_from_expsyms_cmds_RC \
- allow_undefined_flag_RC \
- no_undefined_flag_RC \
- export_symbols_cmds_RC \
- hardcode_libdir_flag_spec_RC \
- hardcode_libdir_flag_spec_ld_RC \
- hardcode_libdir_separator_RC \
- hardcode_automatic_RC \
- module_cmds_RC \
- module_expsym_cmds_RC \
- lt_cv_prog_compiler_c_o_RC \
- exclude_expsyms_RC \
- include_expsyms_RC; do
- case $var in
- old_archive_cmds_RC | \
- old_archive_from_new_cmds_RC | \
- archive_cmds_RC | \
- archive_expsym_cmds_RC | \
- module_cmds_RC | \
- module_expsym_cmds_RC | \
- old_archive_from_expsyms_cmds_RC | \
- export_symbols_cmds_RC | \
- esac
- done
- case $lt_echo in
- esac
-cfgfile="$ofile"
-SHELL=$lt_SHELL
-build_libtool_need_lc=$archive_cmds_need_lc_RC
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_RC
-# The host system.
-host=$host
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-# A C compiler.
-LTCC=$lt_LTCC
-CC=$lt_compiler_RC
-with_gcc=$GCC_RC
-# An ERE matcher.
-EGREP=$lt_EGREP
-LD=$lt_LD_RC
-LN_S=$lt_LN_S
-NM=$lt_NM
-STRIP=$lt_STRIP
-DLLTOOL="$DLLTOOL"
-OBJDUMP="$OBJDUMP"
-AS="$AS"
-objdir=$objdir
-wl=$lt_lt_prog_compiler_wl_RC
-libext="$libext"
-exeext="$exeext"
-pic_flag=$lt_lt_prog_compiler_pic_RC
-pic_mode=$pic_mode
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o_RC
-link_static_flag=$lt_lt_prog_compiler_static_RC
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_RC
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_RC
-whole_archive_flag_spec=$lt_whole_archive_flag_spec_RC
-thread_safe_flag_spec=$lt_thread_safe_flag_spec_RC
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds_RC
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_RC
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_RC
-archive_cmds=$lt_archive_cmds_RC
-archive_expsym_cmds=$lt_archive_expsym_cmds_RC
-module_cmds=$lt_module_cmds_RC
-module_expsym_cmds=$lt_module_expsym_cmds_RC
-# shared library.
-predep_objects=$lt_predep_objects_RC
-# shared library.
-postdep_objects=$lt_postdep_objects_RC
-# shared library.
-predeps=$lt_predeps_RC
-# shared library.
-postdeps=$lt_postdeps_RC
-compiler_lib_search_path=$lt_compiler_lib_search_path_RC
-allow_undefined_flag=$lt_allow_undefined_flag_RC
-no_undefined_flag=$lt_no_undefined_flag_RC
-hardcode_action=$hardcode_action_RC
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_RC
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_RC
-hardcode_libdir_separator=$lt_hardcode_libdir_separator_RC
-hardcode_direct=$hardcode_direct_RC
-hardcode_minus_L=$hardcode_minus_L_RC
-hardcode_shlibpath_var=$hardcode_shlibpath_var_RC
-hardcode_automatic=$hardcode_automatic_RC
-link_all_deplibs=$link_all_deplibs_RC
-fix_srcfile_path="$fix_srcfile_path_RC"
-always_export_symbols=$always_export_symbols_RC
-export_symbols_cmds=$lt_export_symbols_cmds_RC
-exclude_expsyms=$lt_exclude_expsyms_RC
-include_expsyms=$lt_include_expsyms_RC
-__EOF__
-else
- fi
-fi
-ac_ext=cc
-CC="$lt_save_CC"
- { { echo "$as_me:$LINENO: error: Unsupported tag name: $tagname" >&5
-echo "$as_me: error: Unsupported tag name: $tagname" >&2;}
- { (exit 1); exit 1; }; }
- esac
- # Append the new tag name to the list of available tags.
- if test -n "$tagname" ; then
- available_tags="$available_tags $tagname"
- fi
- fi
- done
- IFS="$lt_save_ifs"
- # Now substitute the updated list of available tags.
- if eval "sed -e 's/^available_tags=.*\$/available_tags=\"$available_tags\"/' \"$ofile\" > \"${ofile}T\""; then
- mv "${ofile}T" "$ofile"
- chmod +x "$ofile"
- else
- rm -f "${ofile}T"
- { { echo "$as_me:$LINENO: error: unable to update list of available tagged configurations." >&5
-echo "$as_me: error: unable to update list of available tagged configurations." >&2;}
- fi
-fi
-# This can be used to rebuild libtool when needed
-LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
-# Always use our own libtool.
-LIBTOOL='$(SHELL) $(top_builddir)/libtool'
-# Prevent multiple expansion
-# Check for std headers
-echo "$as_me:$LINENO: checking for ANSI C header files" >&5
-echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
-if test "${ac_cv_header_stdc+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
-/* confdefs.h. */
-_ACEOF
-#include <stdlib.h>
-#include <stdarg.h>
-#include <string.h>
-#include <float.h>
-int
-main ()
- return 0;
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>conftest.er1
- ac_status=$?
- cat conftest.err >&5
- ac_status=$?
- { ac_try='test -s conftest.$ac_objext'
- ac_status=$?
- ac_cv_header_stdc=yes
-else
-ac_cv_header_stdc=no
-fi
-rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
-if test $ac_cv_header_stdc = yes; then
- # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then
-else
- ac_cv_header_stdc=no
-fi
-rm -f conftest*
-fi
- # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- $EGREP "free" >/dev/null 2>&1; then
-else
-fi
-rm -f conftest*
-fi
- # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
-else
-/* confdefs.h. */
-_ACEOF
-#include <ctype.h>
-#if ((' ' & 0x0FF) == 0x020)
-# define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
-# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
-#else
-# define ISLOWER(c) \
- (('a' <= (c) && (c) <= 'i') \
- || ('j' <= (c) && (c) <= 'r') \
- || ('s' <= (c) && (c) <= 'z'))
-# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
-#endif
-#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
-int
-main ()
- int i;
- for (i = 0; i < 256; i++)
- if (XOR (islower (i), ISLOWER (i))
- || toupper (i) != TOUPPER (i))
- exit(2);
- exit (0);
-_ACEOF
-rm -f conftest$ac_exeext
- ac_status=$?
- (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
- ac_status=$?
-else
- echo "$as_me: program exited with status $ac_status" >&5
-echo "$as_me: failed program was:" >&5
-( exit $ac_status )
-fi
-rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
-fi
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
-echo "${ECHO_T}$ac_cv_header_stdc" >&6
-cat >>confdefs.h <<\_ACEOF
-#define STDC_HEADERS 1
-_ACEOF
-fi
-for ac_header in unistd.h math.h netdb.h netinet/in.h sys/types.h sys/socket.h
-do
-as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
-if eval "test \"\${$as_ac_Header+set}\" = set"; then
- echo "$as_me:$LINENO: checking for $ac_header" >&5
-echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6
-fi
-echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Header'}'`" >&5
-echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
-else
- # Is the header compilable?
-echo "$as_me:$LINENO: checking $ac_header usability" >&5
-echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-$ac_includes_default
-#include <$ac_header>
-_ACEOF
-rm -f conftest.$ac_objext
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- { ac_try='test -z "$ac_cxx_werror_flag"
- || test ! -s conftest.err'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; } &&
- ac_status=$?
- (exit $ac_status); }; }; then
- ac_header_compiler=yes
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-ac_header_compiler=no
-fi
-echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
-echo "${ECHO_T}$ac_header_compiler" >&6
-# Is the header present?
-echo "$as_me:$LINENO: checking $ac_header presence" >&5
-echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
- (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
- ac_status=$?
- (exit $ac_status); } >/dev/null; then
- if test -s conftest.err; then
- ac_cpp_err=$ac_cxx_preproc_warn_flag
- ac_cpp_err=$ac_cpp_err$ac_cxx_werror_flag
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-if test -z "$ac_cpp_err"; then
- ac_header_preproc=yes
-else
- ac_header_preproc=no
-fi
-rm -f conftest.err conftest.$ac_ext
-echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
-echo "${ECHO_T}$ac_header_preproc" >&6
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_cxx_preproc_warn_flag in
- yes:no: )
- { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
-echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
-echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
-echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
-echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
-echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
-echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
- cat <<\_ASBOX
-## Report this to http://mapguide.osgeo.org ##
-_ASBOX
- sed "s/^/$as_me: WARNING: /" >&2
-esac
-echo "$as_me:$LINENO: checking for $ac_header" >&5
-else
- eval "$as_ac_Header=\$ac_header_preproc"
-fi
-fi
-if test `eval echo '${'$as_ac_Header'}'` = yes; then
- cat >>confdefs.h <<_ACEOF
-#define `echo "HAVE_$ac_header" | $as_tr_cpp` 1
-_ACEOF
-else
- { { echo "$as_me:$LINENO: error: required header file missing" >&5
-echo "$as_me: error: required header file missing" >&2;}
-fi
-done
-for ac_func in gethostbyname socket htons connect shutdown
-do
-as_ac_var=`echo "ac_cv_func_$ac_func" | $as_tr_sh`
-echo "$as_me:$LINENO: checking for $ac_func" >&5
-echo $ECHO_N "checking for $ac_func... $ECHO_C" >&6
-if eval "test \"\${$as_ac_var+set}\" = set"; then
-else
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-/* Define $ac_func to an innocuous variant, in case <limits.h> declares $ac_func.
-#define $ac_func innocuous_$ac_func
- which can conflict with char $ac_func (); below.
-#ifdef __STDC__
-#else
-#endif
-#undef $ac_func
-#ifdef __cplusplus
-extern "C"
-#endif
-char $ac_func ();
-#if defined (__stub_$ac_func) || defined (__stub___$ac_func)
-choke me
-#else
-char (*f) () = $ac_func;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != $ac_func;
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- ac_status=$?
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- eval "$as_ac_var=yes"
-else
-eval "$as_ac_var=no"
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-fi
-echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_var'}'`" >&5
-echo "${ECHO_T}`eval echo '${'$as_ac_var'}'`" >&6
-if test `eval echo '${'$as_ac_var'}'` = yes; then
-#define `echo "HAVE_$ac_func" | $as_tr_cpp` 1
-_ACEOF
-else
- { { echo "$as_me:$LINENO: error: required standard library function missing" >&5
-echo "$as_me: error: required standard library function missing" >&2;}
-fi
-done
-map_using_proj4="yes"
-map_unittesting_dir="UnitTesting"
-{ echo "$as_me:$LINENO: Using PROJ4 CoordinateSystem" >&5
-echo "$as_me: Using PROJ4 CoordinateSystem" >&6;}
-map_coordsys_dir="CoordinateSystem"
-map_coordsys_dir_path="Common/CoordinateSystem"
-map_coordsys_include_path="Common/CoordinateSystem"
-# Check for php
-# Note : Not yet implemented
-# Check whether --with-php or --without-php was given.
-if test "${with_php+set}" = set; then
- withval="$with_php"
- with_php=$withval
-else
- with_php=no
-fi;
-if test $with_php = "no"; then
- { echo "$as_me:$LINENO: Using php 5.3.1 from included Oem Directory" >&5
-echo "$as_me: Using php 5.3.1 from included Oem Directory" >&6;}
-else
- { echo "$as_me:$LINENO: \"WARNING!!: Using custom specified php include dir is not supported in this release.\"" >&5
-echo "$as_me: \"WARNING!!: Using custom specified php include dir is not supported in this release.\"" >&6;}
-fi
-# custom Fdo path specification
-# Check whether --with-fdo-include or --without-fdo-include was given.
-if test "${with_fdo_include+set}" = set; then
- withval="$with_fdo_include"
- custom_inc=$withval
-else
- custom_inc=DEFAULT
-fi;
-if test $custom_inc = "DEFAULT"; then
- map_fdo_include="/usr/local/fdo-3.8.0/include"
- if test -d $map_fdo_include; then
- { echo "$as_me:$LINENO: Building with default location of FDO include files at /usr/local/fdo-3.8.0/include" >&5
-echo "$as_me: Building with default location of FDO include files at /usr/local/fdo-3.8.0/include" >&6;}
- else
- { { echo "$as_me:$LINENO: error: the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option" >&5
-echo "$as_me: error: the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option" >&2;}
- fi
-else
- if test -d $custom_inc; then
- map_fdo_include="$custom_inc"
- { echo "$as_me:$LINENO: Building with custom location of FDO include dir at $map_fdo_include" >&5
-echo "$as_me: Building with custom location of FDO include dir at $map_fdo_include" >&6;}
- else
- { { echo "$as_me:$LINENO: error: the specified FDO include path $custom_inc is not a valid directory" >&5
-echo "$as_me: error: the specified FDO include path $custom_inc is not a valid directory" >&2;}
- fi
-fi
-# Check whether --with-fdo-lib or --without-fdo-lib was given.
-if test "${with_fdo_lib+set}" = set; then
- withval="$with_fdo_lib"
- custom_lib=$withval
-else
- custom_lib=DEFAULT
-fi;
-if test $custom_lib = "DEFAULT"; then
- map_fdo_lib="/usr/local/fdo-3.8.0/lib"
- if test -d $map_fdo_lib; then
- { echo "$as_me:$LINENO: Building with default location of FDO libraries at /usr/local/fdo-3.8.0/lib" >&5
-echo "$as_me: Building with default location of FDO libraries at /usr/local/fdo-3.8.0/lib" >&6;}
- else
- { { echo "$as_me:$LINENO: error: the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option" >&5
-echo "$as_me: error: the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option" >&2;}
- fi
-else
- if test -d $custom_lib; then
- map_fdo_lib="$custom_lib"
- { echo "$as_me:$LINENO: Building with custom location of FDO libraries at $custom_lib" >&5
-echo "$as_me: Building with custom location of FDO libraries at $custom_lib" >&6;}
- else
- { { echo "$as_me:$LINENO: error: the specified FDO library path $custom_lib is not a valid directory" >&5
-echo "$as_me: error: the specified FDO library path $custom_lib is not a valid directory" >&2;}
- fi
-fi
-# Compiler version checking
-{ echo "$as_me:$LINENO: Checking GCC Version" >&5
-echo "$as_me: Checking GCC Version" >&6;}
-gcc --version > gccver.txt
-sed -e '/^gcc version 3.2/ p' gccver.txt > gcc32.txt
-# Check for Debug or Release build settings
-# Check whether --enable-optimized or --disable-optimized was given.
-if test "${enable_optimized+set}" = set; then
- enableval="$enable_optimized"
- enable_optimized=$enableval
-else
- enable_optimized=no
-fi;
-if test $enable_optimized = no; then
- { echo "$as_me:$LINENO: Using debug configuration" >&5
-echo "$as_me: Using debug configuration" >&6;}
- if test -s gcc32.txt; then
- { echo "$as_me:$LINENO: gcc 3.2.x requires less strict compiler flags. Please pay attention to warnings!" >&5
-echo "$as_me: gcc 3.2.x requires less strict compiler flags. Please pay attention to warnings!" >&6;}
- CXXFLAGS="-g -D_DEBUG"
- else
- { echo "$as_me:$LINENO: this version of gcc is not actively supported" >&5
-echo "$as_me: this version of gcc is not actively supported" >&6;}
- fi
-else
- { echo "$as_me:$LINENO: Using optimized configuration" >&5
-echo "$as_me: Using optimized configuration" >&6;}
- if test -s "gcc32.txt"; then
- { echo "$as_me:$LINENO: gcc 3.2.x . Please pay attention to warnings!" >&5
-echo "$as_me: gcc 3.2.x . Please pay attention to warnings!" >&6;}
- CXXFLAGS="-O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions"
- else
- { echo "$as_me:$LINENO: this gcc version is not actively supported." >&5
-echo "$as_me: this gcc version is not actively supported." >&6;}
- fi
-fi
-# Setup Subdirs
-{ echo "$as_me:$LINENO: Building Common Libraries" >&5
-echo "$as_me: Building Common Libraries" >&6;}
-map_toplevel_subdirs="Oem Common"
-# Check whether --enable-server or --disable-server was given.
-if test "${enable_server+set}" = set; then
- enableval="$enable_server"
- enable_server=$enableval
-else
- enable_server=yes
-fi;
-if test $enable_server = yes; then
- { echo "$as_me:$LINENO: Building Server" >&5
-echo "$as_me: Building Server" >&6;}
- map_toplevel_subdirs="$map_toplevel_subdirs Server"
-else
- { echo "$as_me:$LINENO: Ignoring Server" >&5
-echo "$as_me: Ignoring Server" >&6;}
-fi
-# Check whether --enable-webtier or --disable-webtier was given.
-if test "${enable_webtier+set}" = set; then
- enableval="$enable_webtier"
- enable_webtier=$enableval
-else
- enable_webtier=yes
-fi;
-if test $enable_webtier = yes; then
- { echo "$as_me:$LINENO: Building Web Tier" >&5
-echo "$as_me: Building Web Tier" >&6;}
- map_toplevel_subdirs="$map_toplevel_subdirs Web"
-else
- { echo "$as_me:$LINENO: Ignoring Web Tier" >&5
-echo "$as_me: Ignoring Web Tier" >&6;}
-fi
-rm gccver.txt
-rm gcc32.txt
-map_srcdir=`(cd $srcdir && pwd)`
-# All Makefile.am in the entire structure that need to be generated.
-# TODO: move them all to the macro file.
- ac_config_files="$ac_config_files Makefile"
-# MAP_CONFIG_FILES_OEM
- ac_config_files="$ac_config_files Oem/Makefile"
-# MAP_CONFIG_FILES_COMMON
- ac_config_files="$ac_config_files Common/Makefile Common/MdfModel/Makefile Common/MdfParser/Makefile Common/Security/Makefile Common/Foundation/Makefile Common/Geometry/Makefile Common/PlatformBase/Makefile Common/MapGuideCommon/Makefile Common/Stylization/Makefile Common/Renderers/Makefile"
-# MAP_CONFIG_FILES_SERVER
- ac_config_files="$ac_config_files Server/Makefile Server/src/Makefile Server/src/Gws/Makefile Server/src/Gws/GwsResource/Makefile Server/src/Gws/GwsCommon/Makefile Server/src/Gws/GwsQueryEngine/Makefile Server/src/Common/Makefile Server/src/Common/Base/Makefile Server/src/Common/Cache/Makefile Server/src/Common/Manager/Makefile Server/src/Common/Thread/Makefile Server/src/Services/Makefile Server/src/Services/Feature/Makefile Server/src/Services/Kml/Makefile Server/src/Services/Mapping/Makefile Server/src/Services/Resource/Makefile Server/src/Services/Site/Makefile Server/src/Services/Drawing/Makefile Server/src/Services/Rendering/Makefile Server/src/Services/ServerAdmin/Makefile Server/src/Services/Tile/Makefile Server/src/Core/Makefile"
- ac_config_files="$ac_config_files Server/src/UnitTesting/Makefile"
-# MAP_CONFIG_FILES_WEBTIER
- ac_config_files="$ac_config_files Web/Makefile Web/src/Makefile Web/src/WebApp/Makefile Web/src/WebSupport/Makefile Web/src/JavaApi/Makefile Web/src/PhpApi/Makefile Web/src/HttpHandler/Makefile Web/src/CgiAgent/Makefile Web/src/ApacheAgent/Makefile"
-cat >confcache <<\_ACEOF
-# This file is a shell script that caches the results of configure
-# tests run on this system so they can be shared between configure
-# scripts and configure runs, see configure's option --config-cache.
-# It is not useful on other systems. If it contains results you don't
-# want to keep, you may remove or edit it.
-# config.status only pays attention to the cache file if you give it
-# the --recheck option to rerun configure.
-# `ac_cv_env_foo' variables (set or unset) will be overridden when
-# loading this file, other *unset* `ac_cv_foo' will be assigned the
-# following values.
-_ACEOF
-# The following way of writing the cache mishandles newlines in values,
-# but we know of no workaround that is simple, portable, and efficient.
-# So, don't put newlines in cache variables' values.
-# Ultrix sh set writes to stderr and can't be redirected directly,
-# and sets the high bit in the cache file unless we assign to the vars.
- (set) 2>&1 |
- case `(ac_space=' '; set | grep ac_space) 2>&1` in
- *ac_space=\ *)
- # `set' does not quote correctly, so add quotes (double-quote
- # substitution turns \\\\ into \\, and sed turns \\ into \).
- sed -n \
- "s/'/'\\\\''/g;
- s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
- # `set' quotes correctly as required by POSIX, so do not add quotes.
- sed -n \
- "s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
- esac;
- sed '
- t clear
- : clear
- s/^\([^=]*\)=\(.*[{}].*\)$/test "${\1+set}" = set || &/
- t end
- /^ac_cv_env/!s/^\([^=]*\)=\(.*\)$/\1=${\1=\2}/
- : end' >>confcache
-if diff $cache_file confcache >/dev/null 2>&1; then :; else
- if test -w $cache_file; then
- test "x$cache_file" != "x/dev/null" && echo "updating cache $cache_file"
- cat confcache >$cache_file
- else
- echo "not updating unwritable cache $cache_file"
- fi
-fi
-rm -f confcache
-test "x$prefix" = xNONE && prefix=$ac_default_prefix
-# Let make expand exec_prefix.
-test "x$exec_prefix" = xNONE && exec_prefix='${prefix}'
-# VPATH may cause trouble with some makes, so we remove $(srcdir),
-# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
-# trailing colons and then remove the whole line if VPATH becomes empty
-# (actually we leave an empty line to preserve line numbers).
-if test "x$srcdir" = x.; then
- ac_vpsub='/^[ ]*VPATH[ ]*=/{
-s/:*\$(srcdir):*/:/;
-s/:*\${srcdir}:*/:/;
-s/:*@srcdir@:*/:/;
-s/^\([^=]*=[ ]*\):*/\1/;
-s/:*$//;
-s/^[^=]*=[ ]*$//;
-fi
-# Transform confdefs.h into DEFS.
-# Protect against shell expansion while executing Makefile rules.
-# Protect against Makefile macro expansion.
-# If the first sed substitution is executed (which looks for macros that
-# take arguments), then we branch to the quote section. Otherwise,
-# look for a macro that doesn't take arguments.
-cat >confdef2opt.sed <<\_ACEOF
-t clear
-: clear
-s,^[ ]*#[ ]*define[ ][ ]*\([^ (][^ (]*([^)]*)\)[ ]*\(.*\),-D\1=\2,g
-t quote
-s,^[ ]*#[ ]*define[ ][ ]*\([^ ][^ ]*\)[ ]*\(.*\),-D\1=\2,g
-t quote
-d
-: quote
-s,[ `~#$^&*(){}\\|;'"<>?],\\&,g
-s,\[,\\&,g
-s,\],\\&,g
-s,\$,$$,g
-p
-_ACEOF
-# We use echo to avoid assuming a particular line-breaking character.
-# The extra dot is to prevent the shell from consuming trailing
-# line-breaks from the sub-command output. A line-break within
-# single-quotes doesn't work because, if this script is created in a
-# platform that uses two characters for line-breaks (e.g., DOS), tr
-# would break.
-ac_LF_and_DOT=`echo; echo .`
-DEFS=`sed -n -f confdef2opt.sed confdefs.h | tr "$ac_LF_and_DOT" ' .'`
-rm -f confdef2opt.sed
-ac_libobjs=
-ac_ltlibobjs=
-for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
- # 1. Remove the extension, and $U if already installed.
- ac_i=`echo "$ac_i" |
- sed 's/\$U\././;s/\.o$//;s/\.obj$//'`
- # 2. Add them.
- ac_libobjs="$ac_libobjs $ac_i\$U.$ac_objext"
- ac_ltlibobjs="$ac_ltlibobjs $ac_i"'$U.lo'
-done
-LIBOBJS=$ac_libobjs
-LTLIBOBJS=$ac_ltlibobjs
-if test -z "${AMDEP_TRUE}" && test -z "${AMDEP_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"AMDEP\" was never defined.
-Usually this means the macro was only invoked conditionally." >&5
-echo "$as_me: error: conditional \"AMDEP\" was never defined.
-Usually this means the macro was only invoked conditionally." >&2;}
-fi
-if test -z "${am__fastdepCC_TRUE}" && test -z "${am__fastdepCC_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCC\" was never defined.
-echo "$as_me: error: conditional \"am__fastdepCC\" was never defined.
-fi
-fi
-if test -z "${am__fastdepCXX_TRUE}" && test -z "${am__fastdepCXX_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCXX\" was never defined.
-echo "$as_me: error: conditional \"am__fastdepCXX\" was never defined.
-fi
-fi
-: ${CONFIG_STATUS=./config.status}
-ac_clean_files_save=$ac_clean_files
-ac_clean_files="$ac_clean_files $CONFIG_STATUS"
-{ echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5
-echo "$as_me: creating $CONFIG_STATUS" >&6;}
-cat >$CONFIG_STATUS <<_ACEOF
-#! $SHELL
-# Generated by $as_me.
-# Run this file to recreate the current configuration.
-# Compiler output produced by configure, useful for debugging
-# configure, is in config.log if it exists.
-debug=false
-ac_cs_recheck=false
-ac_cs_silent=false
-SHELL=\${CONFIG_SHELL-$SHELL}
-_ACEOF
-cat >>$CONFIG_STATUS <<\_ACEOF
-## M4sh Initialization. ##
-# Be Bourne compatible
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
- emulate sh
- NULLCMD=:
- # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '${1+"$@"}'='"$@"'
-elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
- set -o posix
-fi
-DUALCASE=1; export DUALCASE # for MKS sh
-# Support unset when possible.
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
- as_unset=unset
-else
- as_unset=false
-fi
-# Work around bugs in pre-3.0 UWIN ksh.
-$as_unset ENV MAIL MAILPATH
-PS1='$ '
-PS2='> '
-PS4='+ '
-# NLS nuisances.
-for as_var in \
- LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
- LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
- LC_TELEPHONE LC_TIME
-do
- if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
- eval $as_var=C; export $as_var
- else
- $as_unset $as_var
- fi
-done
-# Required to use basename.
-if expr a : '\(a\)' >/dev/null 2>&1; then
- as_expr=expr
-else
- as_expr=false
-fi
-if (basename /) >/dev/null 2>&1 && test "X`basename / 2>&1`" = "X/"; then
- as_basename=basename
-else
- as_basename=false
-fi
-# Name of the executable.
-as_me=`$as_basename "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)$' \| \
- . : '\(.\)' 2>/dev/null ||
-echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{ s//\1/; q; }
- /^X\/\(\/\/\)$/{ s//\1/; q; }
- /^X\/\(\/\).*/{ s//\1/; q; }
- s/.*/./; q'`
-# PATH needs CR, and LINENO needs CR and PATH.
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
-# The user is always right.
-if test "${PATH_SEPARATOR+set}" != set; then
- echo "#! /bin/sh" >conf$$.sh
- echo "exit 0" >>conf$$.sh
- chmod +x conf$$.sh
- if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
- PATH_SEPARATOR=';'
- else
- PATH_SEPARATOR=:
- fi
- rm -f conf$$.sh
-fi
- as_lineno_1=$LINENO
- as_lineno_2=$LINENO
- as_lineno_3=`(expr $as_lineno_1 + 1) 2>/dev/null`
- test "x$as_lineno_1" != "x$as_lineno_2" &&
- test "x$as_lineno_3" = "x$as_lineno_2" || {
- # Find who we are. Look in the path if we contain no path at all
- # relative or not.
- case $0 in
- *[\\/]* ) as_myself=$0 ;;
- *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
-done
- esac
- # We did not find ourselves, most probably we were run as `sh COMMAND'
- # in which case we are not to be found in the path.
- if test "x$as_myself" = x; then
- as_myself=$0
- fi
- if test ! -f "$as_myself"; then
- { { echo "$as_me:$LINENO: error: cannot find myself; rerun with an absolute path" >&5
-echo "$as_me: error: cannot find myself; rerun with an absolute path" >&2;}
- fi
- case $CONFIG_SHELL in
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
-do
- IFS=$as_save_IFS
- for as_base in sh bash ksh sh5; do
- case $as_dir in
- if ("$as_dir/$as_base" -c '
- test "x$as_lineno_3" = "x$as_lineno_2" ') 2>/dev/null; then
- $as_unset BASH_ENV || test "${BASH_ENV+set}" != set || { BASH_ENV=; export BASH_ENV; }
- $as_unset ENV || test "${ENV+set}" != set || { ENV=; export ENV; }
- CONFIG_SHELL=$as_dir/$as_base
- export CONFIG_SHELL
- exec "$CONFIG_SHELL" "$0" ${1+"$@"}
- fi;;
- esac
- done
-done
- esac
- # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
- # uniformly replaced by the line number. The first 'sed' inserts a
- # line-number line before each line; the second 'sed' does the real
- # work. The second script uses 'N' to pair each line-number line
- # with the numbered line, and appends trailing '-' during
- # substitution so that $LINENO is not a special case at line end.
- # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
- # second 'sed' script. Blame Lee E. McMahon for sed's syntax. :-)
- sed '=' <$as_myself |
- sed '
- N
- s,$,-,
- : loop
- s,^\(['$as_cr_digits']*\)\(.*\)[$]LINENO\([^'$as_cr_alnum'_]\),\1\2\1\3,
- t loop
- s,-$,,
- s,^['$as_cr_digits']*\n,,
- ' >$as_me.lineno &&
- chmod +x $as_me.lineno ||
- { { echo "$as_me:$LINENO: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&5
-echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2;}
- # Don't try to exec as it changes $[0], causing all sort of problems
- # (the dirname of $[0] is not the place where we might find the
- # original and so on. Autoconf is especially sensible to this).
- . ./$as_me.lineno
- # Exit status is that of the last command.
- exit
-case `echo "testing\c"; echo 1,2,3`,`echo -n testing; echo 1,2,3` in
- *c*,-n*) ECHO_N= ECHO_C='
-' ECHO_T=' ' ;;
- *c*,* ) ECHO_N=-n ECHO_C= ECHO_T= ;;
- *) ECHO_N= ECHO_C='\c' ECHO_T= ;;
-esac
- as_expr=expr
-else
- as_expr=false
-fi
-rm -f conf$$ conf$$.exe conf$$.file
-echo >conf$$.file
-if ln -s conf$$.file conf$$ 2>/dev/null; then
- # We could just check for DJGPP; but this test a) works b) is more generic
- # and c) will remain valid once DJGPP supports symlinks (DJGPP 2.04).
- if test -f conf$$.exe; then
- # Don't use ln at all; we don't have any links
- as_ln_s='cp -p'
- else
- as_ln_s='ln -s'
- fi
-elif ln conf$$.file conf$$ 2>/dev/null; then
- as_ln_s=ln
-else
- as_ln_s='cp -p'
-fi
-if mkdir -p . 2>/dev/null; then
- as_mkdir_p=:
-else
- test -d ./-p && rmdir ./-p
- as_mkdir_p=false
-fi
-as_executable_p="test -f"
-# Sed expression to map a string onto a valid CPP name.
-as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
-# Sed expression to map a string onto a valid variable name.
-as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
-# IFS
-# We need space, tab and new line, in precisely that order.
-as_nl='
-IFS=" $as_nl"
-# CDPATH.
-$as_unset CDPATH
-exec 6>&1
-# Open the log real soon, to keep \$[0] and so on meaningful, and to
-# report actual input values of CONFIG_FILES etc. instead of their
-# values after options handling. Logging --version etc. is OK.
-exec 5>>config.log
- echo
- sed 'h;s/./-/g;s/^.../## /;s/...$/ ##/;p;x;p;x' <<_ASBOX
-## Running $as_me. ##
-_ASBOX
-} >&5
-cat >&5 <<_CSEOF
-This file was extended by mapguide $as_me 2.0.0, which was
-generated by GNU Autoconf 2.59. Invocation command line was
- CONFIG_FILES = $CONFIG_FILES
- CONFIG_HEADERS = $CONFIG_HEADERS
- CONFIG_LINKS = $CONFIG_LINKS
- CONFIG_COMMANDS = $CONFIG_COMMANDS
- $ $0 $@
-_CSEOF
-echo "on `(hostname || uname -n) 2>/dev/null | sed 1q`" >&5
-echo >&5
-_ACEOF
-# Files that config.status was made for.
-if test -n "$ac_config_files"; then
- echo "config_files=\"$ac_config_files\"" >>$CONFIG_STATUS
-fi
-if test -n "$ac_config_headers"; then
- echo "config_headers=\"$ac_config_headers\"" >>$CONFIG_STATUS
-fi
-if test -n "$ac_config_links"; then
- echo "config_links=\"$ac_config_links\"" >>$CONFIG_STATUS
-fi
-if test -n "$ac_config_commands"; then
- echo "config_commands=\"$ac_config_commands\"" >>$CONFIG_STATUS
-fi
-ac_cs_usage="\
-\`$as_me' instantiates files from templates according to the
-current configuration.
-Usage: $0 [OPTIONS] [FILE]...
- -h, --help print this help, then exit
- -V, --version print version number, then exit
- -q, --quiet do not print progress messages
- -d, --debug don't remove temporary files
- --recheck update $as_me by reconfiguring in the same conditions
- --file=FILE[:TEMPLATE]
- instantiate the configuration file FILE
-Configuration files:
-$config_files
-Configuration commands:
-$config_commands
-Report bugs to <bug-autoconf at gnu.org>."
-_ACEOF
-cat >>$CONFIG_STATUS <<_ACEOF
-ac_cs_version="\\
-mapguide config.status 2.0.0
-configured by $0, generated by GNU Autoconf 2.59,
- with options \\"`echo "$ac_configure_args" | sed 's/[\\""\`\$]/\\\\&/g'`\\"
-Copyright (C) 2003 Free Software Foundation, Inc.
-This config.status script is free software; the Free Software Foundation
-gives unlimited permission to copy, distribute and modify it."
-srcdir=$srcdir
-INSTALL="$INSTALL"
-_ACEOF
-# If no file are specified by the user, then we need to provide default
-# value. By we need to know if files were specified by the user.
-ac_need_defaults=:
-while test $# != 0
-do
- case $1 in
- ac_option=`expr "x$1" : 'x\([^=]*\)='`
- ac_optarg=`expr "x$1" : 'x[^=]*=\(.*\)'`
- ac_shift=:
- ac_option=$1
- ac_optarg=$2
- ac_shift=shift
- *) # This is not an option, so the user has probably given explicit
- # arguments.
- ac_option=$1
- ac_need_defaults=false;;
- esac
- case $ac_option in
- # Handling of the options.
-_ACEOF
- -recheck | --recheck | --rechec | --reche | --rech | --rec | --re | --r)
- ac_cs_recheck=: ;;
- --version | --vers* | -V )
- echo "$ac_cs_version"; exit 0 ;;
- --he | --h)
- # Conflict between --help and --header
- { { echo "$as_me:$LINENO: error: ambiguous option: $1
-Try \`$0 --help' for more information." >&5
-echo "$as_me: error: ambiguous option: $1
-Try \`$0 --help' for more information." >&2;}
- { (exit 1); exit 1; }; };;
- --help | --hel | -h )
- echo "$ac_cs_usage"; exit 0 ;;
- --debug | --d* | -d )
- debug=: ;;
- --file | --fil | --fi | --f )
- $ac_shift
- CONFIG_FILES="$CONFIG_FILES $ac_optarg"
- --header | --heade | --head | --hea )
- $ac_shift
- CONFIG_HEADERS="$CONFIG_HEADERS $ac_optarg"
- -q | -quiet | --quiet | --quie | --qui | --qu | --q \
- | -silent | --silent | --silen | --sile | --sil | --si | --s)
- ac_cs_silent=: ;;
- # This is an error.
- -*) { { echo "$as_me:$LINENO: error: unrecognized option: $1
-echo "$as_me: error: unrecognized option: $1
- { (exit 1); exit 1; }; } ;;
- *) ac_config_targets="$ac_config_targets $1" ;;
- esac
- shift
-done
-ac_configure_extra_args=
-if $ac_cs_silent; then
- exec 6>/dev/null
- ac_configure_extra_args="$ac_configure_extra_args --silent"
-fi
-_ACEOF
-if \$ac_cs_recheck; then
- echo "running $SHELL $0 " $ac_configure_args \$ac_configure_extra_args " --no-create --no-recursion" >&6
- exec $SHELL $0 $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
-fi
-_ACEOF
-# INIT-COMMANDS section.
-AMDEP_TRUE="$AMDEP_TRUE" ac_aux_dir="$ac_aux_dir"
-_ACEOF
-for ac_config_target in $ac_config_targets
-do
- case "$ac_config_target" in
- # Handling of arguments.
- "Makefile" ) CONFIG_FILES="$CONFIG_FILES Makefile" ;;
- "Oem/Makefile" ) CONFIG_FILES="$CONFIG_FILES Oem/Makefile" ;;
- "Common/Makefile" ) CONFIG_FILES="$CONFIG_FILES Common/Makefile" ;;
- "Common/MdfModel/Makefile" ) CONFIG_FILES="$CONFIG_FILES Common/MdfModel/Makefile" ;;
- "Common/MdfParser/Makefile" ) CONFIG_FILES="$CONFIG_FILES Common/MdfParser/Makefile" ;;
- "Common/Security/Makefile" ) CONFIG_FILES="$CONFIG_FILES Common/Security/Makefile" ;;
- "Common/Foundation/Makefile" ) CONFIG_FILES="$CONFIG_FILES Common/Foundation/Makefile" ;;
- "Common/Geometry/Makefile" ) CONFIG_FILES="$CONFIG_FILES Common/Geometry/Makefile" ;;
- "Common/PlatformBase/Makefile" ) CONFIG_FILES="$CONFIG_FILES Common/PlatformBase/Makefile" ;;
- "Common/MapGuideCommon/Makefile" ) CONFIG_FILES="$CONFIG_FILES Common/MapGuideCommon/Makefile" ;;
- "Common/Stylization/Makefile" ) CONFIG_FILES="$CONFIG_FILES Common/Stylization/Makefile" ;;
- "Common/Renderers/Makefile" ) CONFIG_FILES="$CONFIG_FILES Common/Renderers/Makefile" ;;
- "Server/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/Makefile" ;;
- "Server/src/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Makefile" ;;
- "Server/src/Gws/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Gws/Makefile" ;;
- "Server/src/Gws/GwsResource/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Gws/GwsResource/Makefile" ;;
- "Server/src/Gws/GwsCommon/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Gws/GwsCommon/Makefile" ;;
- "Server/src/Gws/GwsQueryEngine/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Gws/GwsQueryEngine/Makefile" ;;
- "Server/src/Common/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Common/Makefile" ;;
- "Server/src/Common/Base/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Common/Base/Makefile" ;;
- "Server/src/Common/Cache/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Common/Cache/Makefile" ;;
- "Server/src/Common/Manager/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Common/Manager/Makefile" ;;
- "Server/src/Common/Thread/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Common/Thread/Makefile" ;;
- "Server/src/Services/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/Makefile" ;;
- "Server/src/Services/Feature/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/Feature/Makefile" ;;
- "Server/src/Services/Kml/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/Kml/Makefile" ;;
- "Server/src/Services/Mapping/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/Mapping/Makefile" ;;
- "Server/src/Services/Resource/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/Resource/Makefile" ;;
- "Server/src/Services/Site/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/Site/Makefile" ;;
- "Server/src/Services/Drawing/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/Drawing/Makefile" ;;
- "Server/src/Services/Profiling/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/Profiling/Makefile" ;;
- "Server/src/Services/Rendering/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/Rendering/Makefile" ;;
- "Server/src/Services/ServerAdmin/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/ServerAdmin/Makefile" ;;
- "Server/src/Services/Tile/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Services/Tile/Makefile" ;;
- "Server/src/Core/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/Core/Makefile" ;;
- "Server/src/UnitTesting/Makefile" ) CONFIG_FILES="$CONFIG_FILES Server/src/UnitTesting/Makefile" ;;
- "Web/Makefile" ) CONFIG_FILES="$CONFIG_FILES Web/Makefile" ;;
- "Web/src/Makefile" ) CONFIG_FILES="$CONFIG_FILES Web/src/Makefile" ;;
- "Web/src/WebApp/Makefile" ) CONFIG_FILES="$CONFIG_FILES Web/src/WebApp/Makefile" ;;
- "Web/src/WebSupport/Makefile" ) CONFIG_FILES="$CONFIG_FILES Web/src/WebSupport/Makefile" ;;
- "Web/src/JavaApi/Makefile" ) CONFIG_FILES="$CONFIG_FILES Web/src/JavaApi/Makefile" ;;
- "Web/src/PhpApi/Makefile" ) CONFIG_FILES="$CONFIG_FILES Web/src/PhpApi/Makefile" ;;
- "Web/src/HttpHandler/Makefile" ) CONFIG_FILES="$CONFIG_FILES Web/src/HttpHandler/Makefile" ;;
- "Web/src/CgiAgent/Makefile" ) CONFIG_FILES="$CONFIG_FILES Web/src/CgiAgent/Makefile" ;;
- "Web/src/ApacheAgent/Makefile" ) CONFIG_FILES="$CONFIG_FILES Web/src/ApacheAgent/Makefile" ;;
- "depfiles" ) CONFIG_COMMANDS="$CONFIG_COMMANDS depfiles" ;;
- *) { { echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
-echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
- esac
-done
-# If the user did not use the arguments to specify the items to instantiate,
-# then the envvar interface is used. Set only those that are not.
-# We use the long form for the default assignment because of an extremely
-# bizarre bug on SunOS 4.1.3.
-if $ac_need_defaults; then
- test "${CONFIG_FILES+set}" = set || CONFIG_FILES=$config_files
- test "${CONFIG_COMMANDS+set}" = set || CONFIG_COMMANDS=$config_commands
-fi
-# Have a temporary directory for convenience. Make it in the build tree
-# simply because there is no reason to put it here, and in addition,
-# creating and moving files from /tmp can sometimes cause problems.
-# Create a temporary directory, and hook for its removal unless debugging.
-$debug ||
- trap 'exit_status=$?; rm -rf $tmp && exit $exit_status' 0
- trap '{ (exit 1); exit 1; }' 1 2 13 15
-# Create a (secure) tmp directory for tmp files.
- tmp=`(umask 077 && mktemp -d -q "./confstatXXXXXX") 2>/dev/null` &&
- test -n "$tmp" && test -d "$tmp"
- tmp=./confstat$$-$RANDOM
- (umask 077 && mkdir $tmp)
- echo "$me: cannot create a temporary directory in ." >&2
-_ACEOF
-# CONFIG_FILES section.
-# No need to generate the scripts if there are no CONFIG_FILES.
-# This happens for instance when ./config.status config.h
-if test -n "\$CONFIG_FILES"; then
- # Protect against being on the right side of a sed subst in config.status.
- sed 's/,@/@@/; s/@,/@@/; s/,;t t\$/@;t t/; /@;t t\$/s/[\\\\&,]/\\\\&/g;
- s/@@/,@/; s/@@/@,/; s/@;t t\$/,;t t/' >\$tmp/subs.sed <<\\CEOF
-s, at SHELL@,$SHELL,;t t
-s, at PATH_SEPARATOR@,$PATH_SEPARATOR,;t t
-s, at PACKAGE_NAME@,$PACKAGE_NAME,;t t
-s, at PACKAGE_TARNAME@,$PACKAGE_TARNAME,;t t
-s, at PACKAGE_VERSION@,$PACKAGE_VERSION,;t t
-s, at PACKAGE_STRING@,$PACKAGE_STRING,;t t
-s, at PACKAGE_BUGREPORT@,$PACKAGE_BUGREPORT,;t t
-s, at exec_prefix@,$exec_prefix,;t t
-s, at prefix@,$prefix,;t t
-s, at program_transform_name@,$program_transform_name,;t t
-s, at bindir@,$bindir,;t t
-s, at sbindir@,$sbindir,;t t
-s, at libexecdir@,$libexecdir,;t t
-s, at datadir@,$datadir,;t t
-s, at sysconfdir@,$sysconfdir,;t t
-s, at sharedstatedir@,$sharedstatedir,;t t
-s, at localstatedir@,$localstatedir,;t t
-s, at libdir@,$libdir,;t t
-s, at includedir@,$includedir,;t t
-s, at oldincludedir@,$oldincludedir,;t t
-s, at infodir@,$infodir,;t t
-s, at mandir@,$mandir,;t t
-s, at build_alias@,$build_alias,;t t
-s, at host_alias@,$host_alias,;t t
-s, at target_alias@,$target_alias,;t t
-s, at DEFS@,$DEFS,;t t
-s, at ECHO_C@,$ECHO_C,;t t
-s, at ECHO_N@,$ECHO_N,;t t
-s, at ECHO_T@,$ECHO_T,;t t
-s, at LIBS@,$LIBS,;t t
-s, at INSTALL_PROGRAM@,$INSTALL_PROGRAM,;t t
-s, at INSTALL_SCRIPT@,$INSTALL_SCRIPT,;t t
-s, at INSTALL_DATA@,$INSTALL_DATA,;t t
-s, at CYGPATH_W@,$CYGPATH_W,;t t
-s, at PACKAGE@,$PACKAGE,;t t
-s, at VERSION@,$VERSION,;t t
-s, at ACLOCAL@,$ACLOCAL,;t t
-s, at AUTOCONF@,$AUTOCONF,;t t
-s, at AUTOMAKE@,$AUTOMAKE,;t t
-s, at AUTOHEADER@,$AUTOHEADER,;t t
-s, at MAKEINFO@,$MAKEINFO,;t t
-s, at install_sh@,$install_sh,;t t
-s, at STRIP@,$STRIP,;t t
-s, at ac_ct_STRIP@,$ac_ct_STRIP,;t t
-s, at INSTALL_STRIP_PROGRAM@,$INSTALL_STRIP_PROGRAM,;t t
-s, at mkdir_p@,$mkdir_p,;t t
-s, at AWK@,$AWK,;t t
-s, at SET_MAKE@,$SET_MAKE,;t t
-s, at am__leading_dot@,$am__leading_dot,;t t
-s, at AMTAR@,$AMTAR,;t t
-s, at am__tar@,$am__tar,;t t
-s, at am__untar@,$am__untar,;t t
-s, at CC@,$CC,;t t
-s, at CFLAGS@,$CFLAGS,;t t
-s, at LDFLAGS@,$LDFLAGS,;t t
-s, at CPPFLAGS@,$CPPFLAGS,;t t
-s, at ac_ct_CC@,$ac_ct_CC,;t t
-s, at EXEEXT@,$EXEEXT,;t t
-s, at OBJEXT@,$OBJEXT,;t t
-s, at DEPDIR@,$DEPDIR,;t t
-s, at am__include@,$am__include,;t t
-s, at am__quote@,$am__quote,;t t
-s, at AMDEP_TRUE@,$AMDEP_TRUE,;t t
-s, at AMDEP_FALSE@,$AMDEP_FALSE,;t t
-s, at AMDEPBACKSLASH@,$AMDEPBACKSLASH,;t t
-s, at CCDEPMODE@,$CCDEPMODE,;t t
-s, at am__fastdepCC_TRUE@,$am__fastdepCC_TRUE,;t t
-s, at am__fastdepCC_FALSE@,$am__fastdepCC_FALSE,;t t
-s, at CXX@,$CXX,;t t
-s, at CXXFLAGS@,$CXXFLAGS,;t t
-s, at ac_ct_CXX@,$ac_ct_CXX,;t t
-s, at CXXDEPMODE@,$CXXDEPMODE,;t t
-s, at am__fastdepCXX_TRUE@,$am__fastdepCXX_TRUE,;t t
-s, at am__fastdepCXX_FALSE@,$am__fastdepCXX_FALSE,;t t
-s, at build@,$build,;t t
-s, at build_cpu@,$build_cpu,;t t
-s, at build_vendor@,$build_vendor,;t t
-s, at build_os@,$build_os,;t t
-s, at host@,$host,;t t
-s, at host_cpu@,$host_cpu,;t t
-s, at host_vendor@,$host_vendor,;t t
-s, at host_os@,$host_os,;t t
-s, at EGREP@,$EGREP,;t t
-s, at LN_S@,$LN_S,;t t
-s, at ECHO@,$ECHO,;t t
-s, at AR@,$AR,;t t
-s, at ac_ct_AR@,$ac_ct_AR,;t t
-s, at RANLIB@,$RANLIB,;t t
-s, at ac_ct_RANLIB@,$ac_ct_RANLIB,;t t
-s, at CPP@,$CPP,;t t
-s, at CXXCPP@,$CXXCPP,;t t
-s, at F77@,$F77,;t t
-s, at FFLAGS@,$FFLAGS,;t t
-s, at ac_ct_F77@,$ac_ct_F77,;t t
-s, at LIBTOOL@,$LIBTOOL,;t t
-s, at map_coordsys_dir@,$map_coordsys_dir,;t t
-s, at map_coordsys_dir_path@,$map_coordsys_dir_path,;t t
-s, at map_coordsys_include_path@,$map_coordsys_include_path,;t t
-s, at map_unittesting_dir@,$map_unittesting_dir,;t t
-s, at map_fdo_include@,$map_fdo_include,;t t
-s, at map_fdo_lib@,$map_fdo_lib,;t t
-s, at map_toplevel_subdirs@,$map_toplevel_subdirs,;t t
-s, at map_srcdir@,$map_srcdir,;t t
-s, at LIBOBJS@,$LIBOBJS,;t t
-s, at LTLIBOBJS@,$LTLIBOBJS,;t t
-CEOF
-_ACEOF
- cat >>$CONFIG_STATUS <<\_ACEOF
- # Split the substitutions into bite-sized pieces for seds with
- # small command number limits, like on Digital OSF/1 and HP-UX.
- ac_max_sed_lines=48
- ac_sed_frag=1 # Number of current file.
- ac_beg=1 # First line for current file.
- ac_end=$ac_max_sed_lines # Line after last line for current file.
- ac_more_lines=:
- ac_sed_cmds=
- while $ac_more_lines; do
- if test $ac_beg -gt 1; then
- sed "1,${ac_beg}d; ${ac_end}q" $tmp/subs.sed >$tmp/subs.frag
- else
- sed "${ac_end}q" $tmp/subs.sed >$tmp/subs.frag
- fi
- if test ! -s $tmp/subs.frag; then
- ac_more_lines=false
- else
- # The purpose of the label and of the branching condition is to
- # speed up the sed processing (if there are no `@' at all, there
- # is no need to browse any of the substitutions).
- # These are the two extra sed commands mentioned above.
- (echo ':t
- /@[a-zA-Z_][a-zA-Z_0-9]*@/!b' && cat $tmp/subs.frag) >$tmp/subs-$ac_sed_frag.sed
- if test -z "$ac_sed_cmds"; then
- ac_sed_cmds="sed -f $tmp/subs-$ac_sed_frag.sed"
- else
- ac_sed_cmds="$ac_sed_cmds | sed -f $tmp/subs-$ac_sed_frag.sed"
- fi
- ac_sed_frag=`expr $ac_sed_frag + 1`
- ac_beg=$ac_end
- ac_end=`expr $ac_end + $ac_max_sed_lines`
- fi
- done
- ac_sed_cmds=cat
- fi
-fi # test -n "$CONFIG_FILES"
-_ACEOF
-for ac_file in : $CONFIG_FILES; do test "x$ac_file" = x: && continue
- # Support "outfile[:infile[:infile...]]", defaulting infile="outfile.in".
- case $ac_file in
- - | *:- | *:-:* ) # input from stdin
- cat >$tmp/stdin
- ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
- ac_file=`echo "$ac_file" | sed 's,:.*,,'` ;;
- *:* ) ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
- * ) ac_file_in=$ac_file.in ;;
- esac
- # Compute @srcdir@, @top_srcdir@, and @INSTALL@ for subdirectories.
- ac_dir=`(dirname "$ac_file") 2>/dev/null ||
-$as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$ac_file" : 'X\(//\)[^/]' \| \
- X"$ac_file" : 'X\(//\)$' \| \
- X"$ac_file" : 'X\(/\)' \| \
-echo X"$ac_file" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
- /^X\(\/\/\)[^/].*/{ s//\1/; q; }
- /^X\(\/\/\)$/{ s//\1/; q; }
- /^X\(\/\).*/{ s//\1/; q; }
- s/.*/./; q'`
- { if $as_mkdir_p; then
- mkdir -p "$ac_dir"
- else
- as_dir="$ac_dir"
- as_dirs=
- while test ! -d "$as_dir"; do
- as_dirs="$as_dir $as_dirs"
- as_dir=`(dirname "$as_dir") 2>/dev/null ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| \
-echo X"$as_dir" |
- s/.*/./; q'`
- done
- test ! -n "$as_dirs" || mkdir $as_dirs
- fi || { { echo "$as_me:$LINENO: error: cannot create directory \"$ac_dir\"" >&5
-echo "$as_me: error: cannot create directory \"$ac_dir\"" >&2;}
- { (exit 1); exit 1; }; }; }
- ac_builddir=.
-if test "$ac_dir" != .; then
- ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
- # A "../" for each directory in $ac_dir_suffix.
- ac_top_builddir=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,../,g'`
-else
- ac_dir_suffix= ac_top_builddir=
-fi
-case $srcdir in
- .) # No --srcdir option. We are building in place.
- ac_srcdir=.
- if test -z "$ac_top_builddir"; then
- ac_top_srcdir=.
- else
- ac_top_srcdir=`echo $ac_top_builddir | sed 's,/$,,'`
- fi ;;
- [\\/]* | ?:[\\/]* ) # Absolute path.
- ac_srcdir=$srcdir$ac_dir_suffix;
- ac_top_srcdir=$srcdir ;;
- *) # Relative path.
- ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
- ac_top_srcdir=$ac_top_builddir$srcdir ;;
-esac
-# Do not use `cd foo && pwd` to compute absolute paths, because
-# the directories may not exist.
-case `pwd` in
-.) ac_abs_builddir="$ac_dir";;
- case "$ac_dir" in
- .) ac_abs_builddir=`pwd`;;
- [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
- *) ac_abs_builddir=`pwd`/"$ac_dir";;
- esac;;
-esac
-case $ac_abs_builddir in
-.) ac_abs_top_builddir=${ac_top_builddir}.;;
- case ${ac_top_builddir}. in
- .) ac_abs_top_builddir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
- *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
- esac;;
-esac
-.) ac_abs_srcdir=$ac_srcdir;;
- case $ac_srcdir in
- .) ac_abs_srcdir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
- *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
- esac;;
-esac
-.) ac_abs_top_srcdir=$ac_top_srcdir;;
- case $ac_top_srcdir in
- .) ac_abs_top_srcdir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
- *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
- esac;;
-esac
- case $INSTALL in
- [\\/$]* | ?:[\\/]* ) ac_INSTALL=$INSTALL ;;
- *) ac_INSTALL=$ac_top_builddir$INSTALL ;;
- esac
- if test x"$ac_file" != x-; then
- { echo "$as_me:$LINENO: creating $ac_file" >&5
-echo "$as_me: creating $ac_file" >&6;}
- rm -f "$ac_file"
- fi
- # Let's still pretend it is `configure' which instantiates (i.e., don't
- # use $as_me), people would be surprised to read:
- # /* config.h. Generated by config.status. */
- if test x"$ac_file" = x-; then
- configure_input=
- else
- configure_input="$ac_file. "
- fi
- configure_input=$configure_input"Generated from `echo $ac_file_in |
- sed 's,.*/,,'` by configure."
- # First look for the input files in the build tree, otherwise in the
- # src tree.
- ac_file_inputs=`IFS=:
- for f in $ac_file_in; do
- case $f in
- -) echo $tmp/stdin ;;
- # Absolute (can't be DOS-style, as IFS=:)
- test -f "$f" || { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
-echo "$as_me: error: cannot find input file: $f" >&2;}
- echo "$f";;
- *) # Relative
- if test -f "$f"; then
- # Build tree
- echo "$f"
- elif test -f "$srcdir/$f"; then
- # Source tree
- echo "$srcdir/$f"
- else
- # /dev/null tree
- { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
- fi;;
- esac
- done` || { (exit 1); exit 1; }
-_ACEOF
- sed "$ac_vpsub
-$extrasub
-_ACEOF
-:t
-/@[a-zA-Z_][a-zA-Z_0-9]*@/!b
-s, at configure_input@,$configure_input,;t t
-s, at srcdir@,$ac_srcdir,;t t
-s, at abs_srcdir@,$ac_abs_srcdir,;t t
-s, at top_srcdir@,$ac_top_srcdir,;t t
-s, at abs_top_srcdir@,$ac_abs_top_srcdir,;t t
-s, at builddir@,$ac_builddir,;t t
-s, at abs_builddir@,$ac_abs_builddir,;t t
-s, at top_builddir@,$ac_top_builddir,;t t
-s, at abs_top_builddir@,$ac_abs_top_builddir,;t t
-s, at INSTALL@,$ac_INSTALL,;t t
-" $ac_file_inputs | (eval "$ac_sed_cmds") >$tmp/out
- rm -f $tmp/stdin
- mv $tmp/out $ac_file
- else
- cat $tmp/out
- rm -f $tmp/out
- fi
-done
-_ACEOF
-# CONFIG_COMMANDS section.
-for ac_file in : $CONFIG_COMMANDS; do test "x$ac_file" = x: && continue
- ac_dest=`echo "$ac_file" | sed 's,:.*,,'`
- ac_source=`echo "$ac_file" | sed 's,[^:]*:,,'`
- ac_dir=`(dirname "$ac_dest") 2>/dev/null ||
-$as_expr X"$ac_dest" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$ac_dest" : 'X\(//\)[^/]' \| \
- X"$ac_dest" : 'X\(//\)$' \| \
- X"$ac_dest" : 'X\(/\)' \| \
-echo X"$ac_dest" |
- s/.*/./; q'`
- else
- as_dir="$ac_dir"
- as_dirs=
-echo X"$as_dir" |
- s/.*/./; q'`
- done
- ac_builddir=.
-else
-fi
-case $srcdir in
- ac_srcdir=.
- ac_top_srcdir=.
- else
- fi ;;
-esac
-case `pwd` in
- case "$ac_dir" in
- esac;;
-esac
- esac;;
-esac
- esac;;
-esac
- esac;;
-esac
- { echo "$as_me:$LINENO: executing $ac_dest commands" >&5
-echo "$as_me: executing $ac_dest commands" >&6;}
- case $ac_dest in
- depfiles ) test x"$AMDEP_TRUE" != x"" || for mf in $CONFIG_FILES; do
- # Strip MF so we end up with the name of the file.
- mf=`echo "$mf" | sed -e 's/:.*$//'`
- # Check whether this is an Automake generated Makefile or not.
- # We used to match only the files named `Makefile.in', but
- # some people rename them; so instead we look at the file content.
- # Grep'ing the first line is not enough: some people post-process
- # each Makefile.in and add a new line on top of each file to say so.
- # So let's grep whole file.
- if grep '^#.*generated by automake' $mf > /dev/null 2>&1; then
- dirpart=`(dirname "$mf") 2>/dev/null ||
-$as_expr X"$mf" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$mf" : 'X\(//\)[^/]' \| \
- X"$mf" : 'X\(//\)$' \| \
- X"$mf" : 'X\(/\)' \| \
-echo X"$mf" |
- s/.*/./; q'`
- else
- continue
- fi
- # Extract the definition of DEPDIR, am__include, and am__quote
- # from the Makefile without running `make'.
- DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
- test -z "$DEPDIR" && continue
- am__include=`sed -n 's/^am__include = //p' < "$mf"`
- test -z "am__include" && continue
- am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
- # When using ansi2knr, U may be empty or an underscore; expand it
- U=`sed -n 's/^U = //p' < "$mf"`
- # Find all dependency output files, they are included files with
- # $(DEPDIR) in their names. We invoke sed twice because it is the
- # simplest approach to changing $(DEPDIR) to its actual value in the
- # expansion.
- for file in `sed -n "
- s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
- sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
- # Make sure the directory exists.
- test -f "$dirpart/$file" && continue
- fdir=`(dirname "$file") 2>/dev/null ||
-$as_expr X"$file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$file" : 'X\(//\)[^/]' \| \
- X"$file" : 'X\(//\)$' \| \
- X"$file" : 'X\(/\)' \| \
-echo X"$file" |
- s/.*/./; q'`
- mkdir -p $dirpart/$fdir
- else
- as_dir=$dirpart/$fdir
- as_dirs=
-echo X"$as_dir" |
- s/.*/./; q'`
- done
- fi || { { echo "$as_me:$LINENO: error: cannot create directory $dirpart/$fdir" >&5
-echo "$as_me: error: cannot create directory $dirpart/$fdir" >&2;}
- # echo "creating $dirpart/$file"
- echo '# dummy' > "$dirpart/$file"
- done
-done
- esac
-done
-_ACEOF
-{ (exit 0); exit 0; }
-_ACEOF
-chmod +x $CONFIG_STATUS
-ac_clean_files=$ac_clean_files_save
-# configure is writing to config.log, and then calls config.status.
-# config.status does its own redirection, appending to config.log.
-# Unfortunately, on DOS this fails, as config.log is still kept open
-# by configure, so config.status won't be able to write to it; its
-# output is simply discarded. So we exec the FD to /dev/null,
-# effectively closing config.log, so it can be properly (re)opened and
-# appended to by config.status. When coming back to configure, we
-# need to make the FD available again.
-if test "$no_create" != yes; then
- ac_cs_success=:
- ac_config_status_args=
- test "$silent" = yes &&
- ac_config_status_args="$ac_config_status_args --quiet"
- exec 5>/dev/null
- $SHELL $CONFIG_STATUS $ac_config_status_args || ac_cs_success=false
- exec 5>>config.log
- # Use ||, not &&, to avoid exiting from the if with $? = 1, which
- # would make configure fail if this is the last instruction.
- $ac_cs_success || { (exit 1); exit 1; }
-fi
Deleted: trunk/MgDev/configure.in
--- trunk/MgDev/configure.in 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/configure.in 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,292 +0,0 @@
-#------------------configure.in----------------------------------------
-dnl Configure.in for MapGuide Open Source
-# Variables
-# Following are the makefile directories
-AC_INIT(mapguide,4.0.0,http://mapguide.osgeo.org)
-AC_CONFIG_SRCDIR(configure.in)
-AM_INIT_AUTOMAKE
-AM_INIT_AUTOMAKE([1.9 tar-pax subdir-objects])
-# Enable silent rules if supported. Allows for less verbose output while still displaying any compiler/linker warnings/errors
-m4_ifdef([AM_SILENT_RULES], [AM_SILENT_RULES])
-AC_PREFIX_DEFAULT(/usr/local/mapguideopensource)
-AC_LANG_C
-AC_PROG_CC
-AC_LANG_CPLUSPLUS
-AC_PROG_CXX
-AM_PROG_LIBTOOL
-AC_HEADER_STDC
-AC_CHECK_HEADERS(unistd.h math.h netdb.h netinet/in.h sys/types.h sys/socket.h,,AC_MSG_ERROR([required header file missing]))
-AC_CHECK_FUNCS(gethostbyname socket htons connect shutdown,,AC_MSG_ERROR([required standard library function missing]))
-dnl *******************************************************
-dnl CoordinateSystem Configuration
-map_using_proj4="no"
-AC_MSG_NOTICE([Using Mentor CoordinateSystem])
-AC_SUBST(map_coordsys_dir,"CoordinateSystem")
-AC_SUBST(map_coordsys_dir_path,"Common/CoordinateSystem")
-AC_SUBST(map_coordsys_include_path,"Common/CoordinateSystem")
-AC_SUBST(map_unittesting_dir)
-map_opt_oem_subdirs="CsMap"
-map_opt_oem_distsubdirs=""
-dnl PHP 5.6.40 Configuration
-AC_ARG_WITH([php],
- MAP_HELP_STRING([--with-php],
- [specify php headers dir prefix as args [[default=no]]]),
- [with_php=$withval],
- [with_php=no])
- AC_MSG_NOTICE([Using php 5.6.40 from included Oem Directory])
- php_src=`pwd`/Oem/LinuxApt/php-5.6.40
-else
- AC_MSG_NOTICE([Using custom PHP source directory])
- php_src=$with_php
-fi
-if test -d $php_src; then
- AC_MSG_NOTICE([PHP source directory is: $php_src])
-else
- AC_MSG_ERROR([PHP source directory ($php_src) does not exist])
-fi
-AC_SUBST(php_src)
-dnl httpd 2.4.37 Configuration
-AC_ARG_WITH([httpd],
- MAP_HELP_STRING([--with-httpd],
- [specify httpd source dir prefix as args [[default=no]]]),
- [with_httpd=$withval],
- [with_httpd=no])
-if test $with_httpd = "no"; then
- AC_MSG_NOTICE([Using httpd 2.4.37 from included Oem Directory])
- httpd_src=`pwd`/Oem/LinuxApt/httpd-2.4.37
-else
- AC_MSG_NOTICE([Using custom httpd source directory])
- httpd_src=$with_httpd
-fi
-if test -d $http_src; then
- AC_MSG_NOTICE([httpd source directory is: $httpd_src])
-else
- AC_MSG_ERROR([httpd source directory ($httpd_src) does not exist])
-fi
-AC_SUBST(httpd_src)
-dnl FDO 4.2.0 Configuration
-dnl Include / lib paths
-AC_ARG_WITH([fdo-include],
- MAP_HELP_STRING([--with-fdo-include],
- [specifies custom dir for fdo include files [[default=DEFAULT]]]),
- [custom_inc=$withval],
- [custom_inc=DEFAULT])
- map_fdo_include="/usr/local/fdo-4.2.0/include"
- AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-4.2.0/include])
- else
- AC_MSG_ERROR([the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option])
- fi
-else
- AC_MSG_NOTICE([Building with custom location of FDO include dir at $map_fdo_include])
- else
- AC_MSG_ERROR([the specified FDO include path $custom_inc is not a valid directory])
- fi
-fi
-AC_ARG_WITH([fdo-lib],
- MAP_HELP_STRING([--with-fdo-lib],
- [specifies custom path for fdo libraries [[default=DEFAULT]]]),
- [custom_lib=$withval],
- [custom_lib=DEFAULT])
- map_fdo_lib="/usr/local/fdo-4.2.0/lib"
- AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-4.2.0/lib])
- else
- AC_MSG_ERROR([the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option])
- fi
-else
- AC_MSG_NOTICE([Building with custom location of FDO libraries at $custom_lib])
- else
- AC_MSG_ERROR([the specified FDO library path $custom_lib is not a valid directory])
- fi
-fi
-map_fdo_nls="/usr/local/fdo-4.2.0/nls/%N"
-AC_SUBST(map_fdo_include)
-AC_SUBST(map_fdo_lib)
-AC_SUBST(map_fdo_nls)
-dnl GCC Compiler Configuration
-AC_MSG_NOTICE([Checking GCC Version])
-AC_ARG_ENABLE([optimized],
- MAP_HELP_STRING([--enable-optimized],
- [enable optimized build [[default=no]]]),
- [enable_optimized=$enableval],
- [enable_optimized=no])
-AC_ARG_ENABLE([64bit],
- MAP_HELP_STRING([--enable-64bit],
- [enable 64-bit build [[default=no]]]),
- [enable_64bit=$enableval],
- [enable_64bit=no])
- AC_MSG_NOTICE([Using debug configuration])
- if test $enable_64bit = no; then
- AC_MSG_NOTICE([Using 32-bit CXXFLAGS])
- CXXFLAGS="-g -D_DEBUG -m32"
- AC_SUBST(CXXFLAGS, ["-g -D_DEBUG -m32"])
- else
- #TODO: Review. i686 is not a valid march/mtune value for 64-bit compilation
- #TODO: Sticking -fPIC globally is probably a bit of a thermonuclear solution, but we
- # *absolutely* must be sure this flag is used when compiling static libraries
- AC_MSG_NOTICE([Using 64-bit CXXFLAGS])
- CXXFLAGS="-g -D_DEBUG -m64 -fPIC"
- AC_SUBST(CXXFLAGS, ["-g -D_DEBUG -m64 -fPIC"])
- fi
-else
- AC_MSG_NOTICE([Using optimized configuration])
- CXXFLAGS="-O2 -g -pipe -m32 -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions"
- AC_SUBST(CXXFLAGS, ["-O2 -g -pipe -m32 -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions -Wno-write-strings"])
- else
- CXXFLAGS="-O2 -g -pipe -m64 -fPIC -fno-use-cxa-atexit -fexceptions"
- AC_SUBST(CXXFLAGS, ["-O2 -g -pipe -m64 -fPIC -fno-use-cxa-atexit -fexceptions -Wno-write-strings"])
- fi
-fi
-dnl Server / WebTier Toggle
-# Setup Subdirs
-AC_MSG_NOTICE([Building Common Libraries])
-AC_ARG_ENABLE([server],
- MAP_HELP_STRING([--enable-server],
- [enable server build [[default=yes]]]),
- [enable_server=$enableval],
- [enable_server=yes])
- AC_MSG_NOTICE([Building Server])
-else
- AC_MSG_NOTICE([Ignoring Server])
-fi
-AC_ARG_ENABLE([webtier],
- MAP_HELP_STRING([--enable-webtier],
- [enable webtier build [[default=yes]]]),
- [enable_webtier=$enableval],
- [enable_webtier=yes])
- AC_MSG_NOTICE([Building Web Tier])
-else
- AC_MSG_NOTICE([Ignoring Web Tier])
-fi
-AC_SUBST(map_toplevel_subdirs)
-dnl Cleanup and Output Makefiles
-rm gccver.txt
-rm gcc32.txt
-AC_SUBST(map_srcdir)
-AC_CONFIG_FILES(Makefile)
-AC_CONFIG_FILES([Oem/Makefile])
-AC_CONFIG_FILES([Common/Makefile \
- Common/MdfModel/Makefile \
- Common/MdfParser/Makefile \
- Common/Security/Makefile \
- Common/Foundation/Makefile \
- Common/Geometry/Makefile \
- Common/PlatformBase/Makefile \
- Common/MapGuideCommon/Makefile \
- Common/Stylization/Makefile \
- Common/Renderers/Makefile])
-AC_CONFIG_FILES([Server/Makefile \
- Server/src/Makefile \
- Server/src/Gws/Makefile \
- Server/src/Gws/GwsResource/Makefile \
- Server/src/Gws/GwsCommon/Makefile \
- Server/src/Gws/GwsQueryEngine/Makefile \
- Server/src/Common/Makefile \
- Server/src/Common/Base/Makefile \
- Server/src/Common/Cache/Makefile \
- Server/src/Common/Manager/Makefile \
- Server/src/Common/Thread/Makefile \
- Server/src/Services/Makefile \
- Server/src/Services/Feature/Makefile \
- Server/src/Services/Kml/Makefile \
- Server/src/Services/Mapping/Makefile \
- Server/src/Services/Resource/Makefile \
- Server/src/Services/Site/Makefile \
- Server/src/Services/Drawing/Makefile \
- Server/src/Services/Profiling/Makefile \
- Server/src/Services/Rendering/Makefile \
- Server/src/Services/ServerAdmin/Makefile \
- Server/src/Services/Tile/Makefile \
- Server/src/Core/Makefile])
-AC_CONFIG_FILES([Server/src/UnitTesting/Makefile])
-AC_CONFIG_FILES([Web/Makefile \
- Web/src/Makefile \
- Web/src/WebApp/Makefile \
- Web/src/WebSupport/Makefile \
- Web/src/JavaApi/Makefile \
- Web/src/JavaApiEx/Makefile \
- Web/src/PhpApi/Makefile \
- Web/src/HttpHandler/Makefile \
- Web/src/CgiAgent/Makefile \
- Web/src/ApacheAgent/Makefile])
-AC_OUTPUT
Deleted: trunk/MgDev/depcomp
--- trunk/MgDev/depcomp 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/depcomp 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,423 +0,0 @@
-#! /bin/sh
-# depcomp - compile a program generating dependencies as side-effects
-# Copyright 1999, 2000 Free Software Foundation, Inc.
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
-# 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# Originally written by Alexandre Oliva <oliva at dcc.unicamp.br>.
-if test -z "$depmode" || test -z "$source" || test -z "$object"; then
- echo "depcomp: Variables source, object and depmode must be set" 1>&2
- exit 1
-fi
-# `libtool' can also be set to `yes' or `no'.
-if test -z "$depfile"; then
- base=`echo "$object" | sed -e 's,^.*/,,' -e 's,\.\([^.]*\)$,.P\1,'`
- dir=`echo "$object" | sed 's,/.*$,/,'`
- if test "$dir" = "$object"; then
- dir=
- fi
- # FIXME: should be _deps on DOS.
- depfile="$dir.deps/$base"
-fi
-tmpdepfile=${tmpdepfile-`echo "$depfile" | sed 's/\.\([^.]*\)$/.T\1/'`}
-rm -f "$tmpdepfile"
-# Some modes work just like other modes, but use different flags. We
-# parameterize here, but still list the modes in the big case below,
-# to make depend.m4 easier to write. Note that we *cannot* use a case
-# here, because this file can only contain one case statement.
-if test "$depmode" = hp; then
- # HP compiler uses -M and no extra arg.
- gccflag=-M
- depmode=gcc
-fi
-if test "$depmode" = dashXmstdout; then
- # This is just like dashmstdout with a different argument.
- dashmflag=-xM
- depmode=dashmstdout
-fi
-case "$depmode" in
-gcc3)
-## gcc 3 implements dependency tracking that does exactly what
-## we want. Yay! Note: for some reason libtool 1.4 doesn't like
-## it if -MD -MP comes after the -MF stuff. Hmm.
- "$@" -MT "$object" -MD -MP -MF "$tmpdepfile"
- stat=$?
- if test $stat -eq 0; then :
- else
- rm -f "$tmpdepfile"
- exit $stat
- fi
- mv "$tmpdepfile" "$depfile"
-gcc)
-## There are various ways to get dependency output from gcc. Here's
-## why we pick this rather obscure method:
-## - Don't want to use -MD because we'd like the dependencies to end
-## up in a subdir. Having to rename by hand is ugly.
-## (We might end up doing this anyway to support other compilers.)
-## - The DEPENDENCIES_OUTPUT environment variable makes gcc act like
-## -MM, not -M (despite what the docs say).
-## - Using -M directly means running the compiler twice (even worse
-## than renaming).
- if test -z "$gccflag"; then
- gccflag=-MD,
- fi
- "$@" -Wp,"$gccflag$tmpdepfile"
- stat=$?
- else
- exit $stat
- fi
- rm -f "$depfile"
- echo "$object : \\" > "$depfile"
- alpha=ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz
-## The second -e expression handles DOS-style file names with drive letters.
- sed -e 's/^[^:]*: / /' \
- -e 's/^['$alpha']:\/[^:]*: / /' < "$tmpdepfile" >> "$depfile"
-## This next piece of magic avoids the `deleted header file' problem.
-## The problem is that when a header file which appears in a .P file
-## is deleted, the dependency causes make to die (because there is
-## typically no way to rebuild the header). We avoid this by adding
-## dummy dependencies for each header file. Too bad gcc doesn't do
-## this for us directly.
- tr ' ' '
-' < "$tmpdepfile" |
-## Some versions of gcc put a space before the `:'. On the theory
-## that the space means something, we add a space to the output as
-## well.
-## Some versions of the HPUX 10.20 sed can't process this invocation
-## correctly. Breaking it into two sed invocations is a workaround.
- sed -e 's/^\\$//' -e '/^$/d' -e '/:$/d' | sed -e 's/$/ :/' >> "$depfile"
-hp)
- # This case exists only to let depend.m4 do its work. It works by
- # looking at the text of this script. This case will never be run,
- # since it is checked for above.
- exit 1
-sgi)
- if test "$libtool" = yes; then
- "$@" "-Wp,-MDupdate,$tmpdepfile"
- else
- "$@" -MDupdate "$tmpdepfile"
- fi
- stat=$?
- else
- exit $stat
- fi
- rm -f "$depfile"
- if test -f "$tmpdepfile"; then # yes, the sourcefile depend on other files
- # Clip off the initial element (the dependent). Don't try to be
- # clever and replace this with sed code, as IRIX sed won't handle
- # lines with more than a fixed number of characters (4096 in
- # IRIX 6.2 sed, 8192 in IRIX 6.5). We also remove comment lines;
- # the IRIX cc adds comments like `#:fec' to the end of the
- # dependency line.
- tr ' ' '
-' < "$tmpdepfile" \
- | sed -e 's/^.*\.o://' -e 's/#.*$//' -e '/^$/ d' | \
- tr '
-' ' ' >> $depfile
- echo >> $depfile
- # The second pass generates a dummy entry for each header file.
- tr ' ' '
- | sed -e 's/^.*\.o://' -e 's/#.*$//' -e '/^$/ d' -e 's/$/:/' \
- >> $depfile
- else
- # The sourcefile does not contain any dependencies, so just
- # store a dummy comment line, to avoid errors with the Makefile
- # "include basename.Plo" scheme.
- echo "#dummy" > "$depfile"
- fi
-aix)
- # The C for AIX Compiler uses -M and outputs the dependencies
- # in a .u file. This file always lives in the current directory.
- # Also, the AIX compiler puts `$object:' at the start of each line;
- # $object doesn't have directory information.
- stripped=`echo "$object" | sed -e 's,^.*/,,' -e 's/\(.*\)\..*$/\1/'`
- tmpdepfile="$stripped.u"
- outname="$stripped.o"
- "$@" -Wc,-M
- else
- "$@" -M
- fi
- stat=$?
- else
- exit $stat
- fi
- # Each line is of the form `foo.o: dependent.h'.
- # Do two passes, one to just change these to
- # `$object: dependent.h' and one to simply `dependent.h:'.
- sed -e "s,^$outname:,$object :," < "$tmpdepfile" > "$depfile"
- sed -e "s,^$outname: \(.*\)$,\1:," < "$tmpdepfile" >> "$depfile"
- else
- fi
-tru64)
- # The Tru64 compiler uses -MD to generate dependencies as a side
- # effect. `cc -MD -o foo.o ...' puts the dependencies into `foo.o.d'.
- # At least on Alpha/Redhat 6.1, Compaq CCC V6.2-504 seems to put
- # dependencies in `foo.d' instead, so we check for that too.
- # Subdirectories are respected.
- dir=`echo "$object" | sed -e 's|/[^/]*$|/|'`
- test "x$dir" = "x$object" && dir=
- base=`echo "$object" | sed -e 's|^.*/||' -e 's/\.o$//' -e 's/\.lo$//'`
- tmpdepfile1="$dir.libs/$base.lo.d"
- tmpdepfile2="$dir.libs/$base.d"
- "$@" -Wc,-MD
- else
- tmpdepfile1="$dir$base.o.d"
- tmpdepfile2="$dir$base.d"
- "$@" -MD
- fi
- stat=$?
- else
- rm -f "$tmpdepfile1" "$tmpdepfile2"
- exit $stat
- fi
- if test -f "$tmpdepfile1"; then
- tmpdepfile="$tmpdepfile1"
- else
- tmpdepfile="$tmpdepfile2"
- fi
- sed -e "s,^.*\.[a-z]*:,$object:," < "$tmpdepfile" > "$depfile"
- # That's a space and a tab in the [].
- sed -e 's,^.*\.[a-z]*:[ ]*,,' -e 's,$,:,' < "$tmpdepfile" >> "$depfile"
- else
- fi
-#nosideeffect)
- # This comment above is used by automake to tell side-effect
- # dependency tracking mechanisms from slower ones.
-dashmstdout)
- # Important note: in order to support this mode, a compiler *must*
- # always write the proprocessed file to stdout, regardless of -o.
- "$@" || exit $?
- # Remove the call to Libtool.
- while test $1 != '--mode=compile'; do
- shift
- done
- shift
- fi
- # Remove `-o $object'. We will use -o /dev/null later,
- # however we can't do the remplacement now because
- # `-o $object' might simply not be used
- IFS=" "
- for arg
- do
- case $arg in
- -o)
- shift
- $object)
- shift
- set fnord "$@" "$arg"
- shift # fnord
- shift # $arg
- esac
- done
- test -z "$dashmflag" && dashmflag=-M
- "$@" -o /dev/null $dashmflag | sed 's:^[^:]*\:[ ]*:'"$object"'\: :' > "$tmpdepfile"
- rm -f "$depfile"
- cat < "$tmpdepfile" > "$depfile"
- tr ' ' '
-' < "$tmpdepfile" | \
-dashXmstdout)
- # This case only exists to satisfy depend.m4. It is never actually
- # run, as this mode is specially recognized in the preamble.
- exit 1
-makedepend)
- "$@" || exit $?
- # X makedepend
- shift
- cleared=no
- for arg in "$@"; do
- case $cleared in
- no)
- set ""; shift
- cleared=yes ;;
- esac
- case "$arg" in
- -D*|-I*)
- set fnord "$@" "$arg"; shift ;;
- esac
- done
- obj_suffix="`echo $object | sed 's/^.*\././'`"
- touch "$tmpdepfile"
- ${MAKEDEPEND-makedepend} -o"$obj_suffix" -f"$tmpdepfile" "$@"
- rm -f "$depfile"
- sed '1,2d' "$tmpdepfile" | tr ' ' '
- rm -f "$tmpdepfile" "$tmpdepfile".bak
-cpp)
- # always write the proprocessed file to stdout.
- "$@" || exit $?
- shift
- done
- shift
- fi
- IFS=" "
- for arg
- do
- case $arg in
- -o)
- shift
- $object)
- shift
- shift # fnord
- shift # $arg
- esac
- done
- "$@" -E |
- sed -n '/^# [0-9][0-9]* "\([^"]*\)".*/ s:: \1 \\:p' |
- sed '$ s: \\$::' > "$tmpdepfile"
- rm -f "$depfile"
- cat < "$tmpdepfile" >> "$depfile"
- sed < "$tmpdepfile" '/^$/d;s/^ //;s/ \\$//;s/$/ :/' >> "$depfile"
-msvisualcpp)
- # always write the proprocessed file to stdout, regardless of -o,
- # because we must use -o when running libtool.
- "$@" || exit $?
- IFS=" "
- for arg
- do
- case "$arg" in
- "-Gm"|"/Gm"|"-Gi"|"/Gi"|"-ZI"|"/ZI")
- set fnord "$@"
- shift
- shift
- shift
- shift
- esac
- done
- "$@" -E |
- sed -n '/^#line [0-9][0-9]* "\([^"]*\)"/ s::echo "`cygpath -u \\"\1\\"`":p' | sort | uniq > "$tmpdepfile"
- rm -f "$depfile"
- . "$tmpdepfile" | sed 's% %\\ %g' | sed -n '/^\(.*\)$/ s:: \1 \\:p' >> "$depfile"
- echo " " >> "$depfile"
- . "$tmpdepfile" | sed 's% %\\ %g' | sed -n '/^\(.*\)$/ s::\1\::p' >> "$depfile"
-none)
- exec "$@"
- echo "Unknown depmode $depmode" 1>&2
- exit 1
-esac
-exit 0
Deleted: trunk/MgDev/install-sh
--- trunk/MgDev/install-sh 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/install-sh 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,251 +0,0 @@
-#!/bin/sh
-# install - install a program, script, or datafile
-# This comes from X11R5 (mit/util/scripts/install.sh).
-# Copyright 1991 by the Massachusetts Institute of Technology
-# Permission to use, copy, modify, distribute, and sell this software and its
-# documentation for any purpose is hereby granted without fee, provided that
-# the above copyright notice appear in all copies and that both that
-# copyright notice and this permission notice appear in supporting
-# documentation, and that the name of M.I.T. not be used in advertising or
-# publicity pertaining to distribution of the software without specific,
-# written prior permission. M.I.T. makes no representations about the
-# suitability of this software for any purpose. It is provided "as is"
-# without express or implied warranty.
-# Calling this script install-sh is preferred over install.sh, to prevent
-# `make' implicit rules from creating a file called install from it
-# when there is no Makefile.
-# This script is compatible with the BSD install script, but was written
-# from scratch. It can only install one file at a time, a restriction
-# shared with many OS's install programs.
-# set DOITPROG to echo to test this script
-# Don't use :- since 4.3BSD and earlier shells don't like it.
-doit="${DOITPROG-}"
-# put in absolute paths if you don't have them in your path; or use env. vars.
-mvprog="${MVPROG-mv}"
-cpprog="${CPPROG-cp}"
-chmodprog="${CHMODPROG-chmod}"
-chownprog="${CHOWNPROG-chown}"
-chgrpprog="${CHGRPPROG-chgrp}"
-stripprog="${STRIPPROG-strip}"
-rmprog="${RMPROG-rm}"
-mkdirprog="${MKDIRPROG-mkdir}"
-transformbasename=""
-transform_arg=""
-instcmd="$mvprog"
-chmodcmd="$chmodprog 0755"
-chowncmd=""
-chgrpcmd=""
-stripcmd=""
-rmcmd="$rmprog -f"
-mvcmd="$mvprog"
-src=""
-dst=""
-dir_arg=""
-while [ x"$1" != x ]; do
- case $1 in
- -c) instcmd="$cpprog"
- shift
- continue;;
- -d) dir_arg=true
- shift
- continue;;
- -m) chmodcmd="$chmodprog $2"
- shift
- shift
- continue;;
- -o) chowncmd="$chownprog $2"
- shift
- shift
- continue;;
- -g) chgrpcmd="$chgrpprog $2"
- shift
- shift
- continue;;
- -s) stripcmd="$stripprog"
- shift
- continue;;
- -t=*) transformarg=`echo $1 | sed 's/-t=//'`
- shift
- continue;;
- -b=*) transformbasename=`echo $1 | sed 's/-b=//'`
- shift
- continue;;
- *) if [ x"$src" = x ]
- then
- src=$1
- else
- # this colon is to work around a 386BSD /bin/sh bug
- dst=$1
- fi
- shift
- continue;;
- esac
-done
-if [ x"$src" = x ]
-then
- echo "install: no input file specified"
- exit 1
-else
-fi
-if [ x"$dir_arg" != x ]; then
- dst=$src
- src=""
- if [ -d $dst ]; then
- instcmd=:
- chmodcmd=""
- else
- instcmd=$mkdirprog
- fi
-else
-# Waiting for this to be detected by the "$instcmd $src $dsttmp" command
-# might cause directories to be created, which would be especially bad
-# if $src (and thus $dsttmp) contains '*'.
- if [ -f "$src" ] || [ -d "$src" ]
- then
- else
- echo "install: $src does not exist"
- exit 1
- fi
- if [ x"$dst" = x ]
- then
- echo "install: no destination specified"
- exit 1
- else
- fi
-# If destination is a directory, append the input filename; if your system
-# does not like double slashes in filenames, you may need to add some logic
- if [ -d $dst ]
- then
- dst="$dst"/`basename $src`
- else
- fi
-fi
-## this sed command emulates the dirname command
-dstdir=`echo $dst | sed -e 's,[^/]*$,,;s,/$,,;s,^$,.,'`
-# Make sure that the destination directory exists.
-# this part is taken from Noah Friedman's mkinstalldirs script
-# Skip lots of stat calls in the usual case.
-if [ ! -d "$dstdir" ]; then
-defaultIFS='
-IFS="${IFS-${defaultIFS}}"
-oIFS="${IFS}"
-# Some sh's can't handle IFS=/ for some reason.
-IFS='%'
-set - `echo ${dstdir} | sed -e 's@/@%@g' -e 's@^%@/@'`
-IFS="${oIFS}"
-pathcomp=''
-while [ $# -ne 0 ] ; do
- pathcomp="${pathcomp}${1}"
- shift
- if [ ! -d "${pathcomp}" ] ;
- then
- $mkdirprog "${pathcomp}"
- else
- fi
- pathcomp="${pathcomp}/"
-done
-fi
-then
- $doit $instcmd $dst &&
- if [ x"$chowncmd" != x ]; then $doit $chowncmd $dst; else : ; fi &&
- if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd $dst; else : ; fi &&
- if [ x"$stripcmd" != x ]; then $doit $stripcmd $dst; else : ; fi &&
- if [ x"$chmodcmd" != x ]; then $doit $chmodcmd $dst; else : ; fi
-else
-# If we're going to rename the final executable, determine the name now.
- if [ x"$transformarg" = x ]
- then
- dstfile=`basename $dst`
- else
- dstfile=`basename $dst $transformbasename |
- sed $transformarg`$transformbasename
- fi
-# don't allow the sed command to completely eliminate the filename
- if [ x"$dstfile" = x ]
- then
- else
- fi
-# Make a temp file name in the proper directory.
- dsttmp=$dstdir/#inst.$$#
-# Move or copy the file name to the temp name
- $doit $instcmd $src $dsttmp &&
- trap "rm -f ${dsttmp}" 0 &&
-# and set any options; do chmod last to preserve setuid bits
-# If any of these fail, we abort the whole thing. If we want to
-# ignore errors from any of these, just make sure not to ignore
-# errors from the above "$doit $instcmd $src $dsttmp" command.
- if [ x"$chowncmd" != x ]; then $doit $chowncmd $dsttmp; else :;fi &&
- if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd $dsttmp; else :;fi &&
- if [ x"$stripcmd" != x ]; then $doit $stripcmd $dsttmp; else :;fi &&
- if [ x"$chmodcmd" != x ]; then $doit $chmodcmd $dsttmp; else :;fi &&
-# Now rename the file to the real destination.
- $doit $rmcmd -f $dstdir/$dstfile &&
- $doit $mvcmd $dsttmp $dstdir/$dstfile
-fi &&
-exit 0
Deleted: trunk/MgDev/ltmain.sh
--- trunk/MgDev/ltmain.sh 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/ltmain.sh 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,5118 +0,0 @@
-# ltmain.sh - Provide generalized library-building support services.
-# NOTE: Changing this file will not affect anything until you rerun configure.
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001
-# Free Software Foundation, Inc.
-# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# Check that we have a working $echo.
-if test "X$1" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
-elif test "X$1" = X--fallback-echo; then
- # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t'; then
- # Yippee, $echo works!
-else
- # Restart under the correct shell, and then maybe $echo will work.
- exec $SHELL "$0" --no-reexec ${1+"$@"}
-fi
-if test "X$1" = X--fallback-echo; then
- # used as fallback echo
- shift
- cat <<EOF
-EOF
- exit 0
-fi
-# define SED for historic ltconfig's generated by Libtool 1.3
-test -z "$SED" && SED=sed
-# The name of this program.
-progname=`$echo "$0" | ${SED} 's%^.*/%%'`
-modename="$progname"
-# Constants.
-PROGRAM=ltmain.sh
-PACKAGE=libtool
-VERSION=1.4.3
-TIMESTAMP=" (1.922.2.111 2002/10/23 02:54:36)"
-default_mode=
-help="Try \`$progname --help' for more information."
-magic="%%%MAGIC variable%%%"
-mkdir="mkdir"
-mv="mv -f"
-rm="rm -f"
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed="${SED}"' -e 1s/^X//'
-sed_quote_subst='s/\([\\`\\"$\\\\]\)/\\\1/g'
-# test EBCDIC or ASCII
-case `echo A|od -x` in
- *[Cc]1*) # EBCDIC based system
- SP2NL="tr '\100' '\n'"
- NL2SP="tr '\r\n' '\100\100'"
- *) # Assume ASCII based system
- SP2NL="tr '\040' '\012'"
- NL2SP="tr '\015\012' '\040\040'"
-esac
-# NLS nuisances.
-# Only set LANG and LC_ALL to C if already set.
-# These must not be set unconditionally because not all systems understand
-# e.g. LANG=C (notably SCO).
-# We save the old values to restore during execute mode.
-if test "${LC_ALL+set}" = set; then
- save_LC_ALL="$LC_ALL"; LC_ALL=C; export LC_ALL
-fi
-if test "${LANG+set}" = set; then
- save_LANG="$LANG"; LANG=C; export LANG
-fi
-# Make sure IFS has a sensible default
-: ${IFS=" "}
-if test "$build_libtool_libs" != yes && test "$build_old_libs" != yes; then
- echo "$modename: not configured to build any kind of library" 1>&2
- echo "Fatal configuration error. See the $PACKAGE docs for more information." 1>&2
- exit 1
-fi
-# Global variables.
-mode=$default_mode
-nonopt=
-prev=
-prevopt=
-run=
-show="$echo"
-show_help=
-execute_dlfiles=
-lo2o="s/\\.lo\$/.${objext}/"
-o2lo="s/\\.${objext}\$/.lo/"
-# Parse our command line options once, thoroughly.
-while test $# -gt 0
-do
- arg="$1"
- shift
- case $arg in
- -*=*) optarg=`$echo "X$arg" | $Xsed -e 's/[-_a-zA-Z0-9]*=//'` ;;
- *) optarg= ;;
- esac
- # If the previous option needs an argument, assign it.
- if test -n "$prev"; then
- case $prev in
- execute_dlfiles)
- execute_dlfiles="$execute_dlfiles $arg"
- eval "$prev=\$arg"
- esac
- prev=
- prevopt=
- continue
- fi
- # Have we seen a non-optional argument yet?
- case $arg in
- --help)
- show_help=yes
- --version)
- echo "$PROGRAM (GNU $PACKAGE) $VERSION$TIMESTAMP"
- exit 0
- --config)
- ${SED} -e '1,/^# ### BEGIN LIBTOOL CONFIG/d' -e '/^# ### END LIBTOOL CONFIG/,$d' $0
- exit 0
- --debug)
- echo "$progname: enabling shell trace mode"
- set -x
- --dry-run | -n)
- run=:
- --features)
- echo "host: $host"
- if test "$build_libtool_libs" = yes; then
- echo "enable shared libraries"
- else
- echo "disable shared libraries"
- fi
- if test "$build_old_libs" = yes; then
- echo "enable static libraries"
- else
- echo "disable static libraries"
- fi
- exit 0
- --finish) mode="finish" ;;
- --mode) prevopt="--mode" prev=mode ;;
- --mode=*) mode="$optarg" ;;
- --preserve-dup-deps) duplicate_deps="yes" ;;
- --quiet | --silent)
- show=:
- -dlopen)
- prevopt="-dlopen"
- prev=execute_dlfiles
- $echo "$modename: unrecognized option \`$arg'" 1>&2
- $echo "$help" 1>&2
- exit 1
- nonopt="$arg"
- break
- esac
-done
-if test -n "$prevopt"; then
- $echo "$modename: option \`$prevopt' requires an argument" 1>&2
- exit 1
-fi
-# If this variable is set in any of the actions, the command in it
-# will be execed at the end. This prevents here-documents from being
-# left over by shells.
-exec_cmd=
-if test -z "$show_help"; then
- # Infer the operation mode.
- if test -z "$mode"; then
- case $nonopt in
- *cc | *++ | gcc* | *-gcc* | xlc*)
- mode=link
- for arg
- do
- case $arg in
- -c)
- mode=compile
- break
- esac
- done
- *db | *dbx | *strace | *truss)
- mode=execute
- *install*|cp|mv)
- mode=install
- *rm)
- mode=uninstall
- # If we have no mode, but dlfiles were specified, then do execute mode.
- test -n "$execute_dlfiles" && mode=execute
- # Just use the default operation mode.
- if test -n "$nonopt"; then
- $echo "$modename: warning: cannot infer operation mode from \`$nonopt'" 1>&2
- else
- $echo "$modename: warning: cannot infer operation mode without MODE-ARGS" 1>&2
- fi
- fi
- esac
- fi
- # Only execute mode is allowed to have -dlopen flags.
- if test -n "$execute_dlfiles" && test "$mode" != execute; then
- $echo "$modename: unrecognized option \`-dlopen'" 1>&2
- exit 1
- fi
- # Change the help message to a mode-specific one.
- generic_help="$help"
- help="Try \`$modename --help --mode=$mode' for more information."
- # These modes are in order of execution frequency so that they run quickly.
- case $mode in
- # libtool compile mode
- compile)
- modename="$modename: compile"
- # Get the compilation command and the source file.
- base_compile=
- prev=
- lastarg=
- srcfile="$nonopt"
- suppress_output=
- user_target=no
- for arg
- do
- case $prev in
- xcompiler)
- # Aesthetically quote the previous argument.
- prev=
- lastarg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- # Double-quote args containing other shell metacharacters.
- # Many Bourne shells cannot handle close brackets correctly
- # in scan sets, so we specify it separately.
- arg="\"$arg\""
- esac
- # Add the previous argument to base_compile.
- if test -z "$base_compile"; then
- base_compile="$lastarg"
- else
- base_compile="$base_compile $lastarg"
- fi
- continue
- esac
- # Accept any command-line options.
- case $arg in
- -o)
- if test "$user_target" != "no"; then
- $echo "$modename: you cannot specify \`-o' more than once" 1>&2
- exit 1
- fi
- user_target=next
- -static)
- build_old_libs=yes
- continue
- -prefer-pic)
- pic_mode=yes
- continue
- -prefer-non-pic)
- pic_mode=no
- continue
- -Xcompiler)
- prev=xcompiler
- continue
- -Wc,*)
- args=`$echo "X$arg" | $Xsed -e "s/^-Wc,//"`
- lastarg=
- save_ifs="$IFS"; IFS=','
- for arg in $args; do
- IFS="$save_ifs"
- case $arg in
- arg="\"$arg\""
- esac
- lastarg="$lastarg $arg"
- done
- IFS="$save_ifs"
- lastarg=`$echo "X$lastarg" | $Xsed -e "s/^ //"`
- # Add the arguments to base_compile.
- else
- fi
- continue
- esac
- case $user_target in
- next)
- # The next one is the -o target name
- user_target=yes
- continue
- yes)
- # We got the output file
- user_target=set
- libobj="$arg"
- continue
- esac
- # Accept the current argument as the source file.
- lastarg="$srcfile"
- srcfile="$arg"
- # Backslashify any backslashes, double quotes, and dollar signs.
- # These are the only characters that are still specially
- # interpreted inside of double-quoted scrings.
- lastarg=`$echo "X$lastarg" | $Xsed -e "$sed_quote_subst"`
- case $lastarg in
- lastarg="\"$lastarg\""
- esac
- else
- fi
- done
- set)
- no)
- # Get the name of the library object.
- libobj=`$echo "X$srcfile" | $Xsed -e 's%^.*/%%'`
- $echo "$modename: you must specify a target with \`-o'" 1>&2
- exit 1
- esac
- # Recognize several different file suffixes.
- # If the user specifies -o file.o, it is replaced with file.lo
- xform='[cCFSfmso]'
- case $libobj in
- *.ada) xform=ada ;;
- *.adb) xform=adb ;;
- *.ads) xform=ads ;;
- *.asm) xform=asm ;;
- *.c++) xform=c++ ;;
- *.cc) xform=cc ;;
- *.cpp) xform=cpp ;;
- *.cxx) xform=cxx ;;
- *.f90) xform=f90 ;;
- *.for) xform=for ;;
- esac
- libobj=`$echo "X$libobj" | $Xsed -e "s/\.$xform$/.lo/"`
- case $libobj in
- *.lo) obj=`$echo "X$libobj" | $Xsed -e "$lo2o"` ;;
- $echo "$modename: cannot determine name of library object from \`$libobj'" 1>&2
- exit 1
- esac
- $echo "$modename: you must specify a compilation command" 1>&2
- exit 1
- fi
- # Delete any leftover library objects.
- removelist="$obj $libobj"
- else
- removelist="$libobj"
- fi
- $run $rm $removelist
- trap "$run $rm $removelist; exit 1" 1 2 15
- # On Cygwin there's no "real" PIC flag so we must build both object types
- case $host_os in
- cygwin* | mingw* | pw32* | os2*)
- pic_mode=default
- esac
- if test "$pic_mode" = no && test "$deplibs_check_method" != pass_all; then
- # non-PIC code in shared libraries is not supported
- pic_mode=default
- fi
- # Calculate the filename of the output object if compiler does
- # not support -o with -c
- if test "$compiler_c_o" = no; then
- output_obj=`$echo "X$srcfile" | $Xsed -e 's%^.*/%%' -e 's%\.[^.]*$%%'`.${objext}
- lockfile="$output_obj.lock"
- removelist="$removelist $output_obj $lockfile"
- else
- need_locks=no
- lockfile=
- fi
- # Lock this critical section if it is needed
- # We use this script file to make the link, it avoids creating a new file
- if test "$need_locks" = yes; then
- until $run ln "$0" "$lockfile" 2>/dev/null; do
- $show "Waiting for $lockfile to be removed"
- sleep 2
- done
- elif test "$need_locks" = warn; then
- if test -f "$lockfile"; then
- echo "\
-*** ERROR, $lockfile exists and contains:
-`cat $lockfile 2>/dev/null`
-This indicates that another process is trying to use the same
-temporary object file, and libtool could not work around it because
-your compiler does not support \`-c' and \`-o' together. If you
-repeat this compilation, it may succeed, by chance, but you had better
-avoid parallel builds (make -j) in this platform, or get a better
-compiler."
- exit 1
- fi
- echo $srcfile > "$lockfile"
- fi
- if test -n "$fix_srcfile_path"; then
- eval srcfile=\"$fix_srcfile_path\"
- fi
- # Only build a PIC object if we are building libtool libraries.
- # Without this assignment, base_compile gets emptied.
- fbsd_hideous_sh_bug=$base_compile
- if test "$pic_mode" != no; then
- # All platforms use -DPIC, to notify preprocessed assembler code.
- command="$base_compile $srcfile $pic_flag -DPIC"
- else
- # Don't build PIC code
- command="$base_compile $srcfile"
- fi
- lo_libobj="$libobj"
- dir=`$echo "X$libobj" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$dir" = "X$libobj"; then
- dir="$objdir"
- else
- dir="$dir/$objdir"
- fi
- libobj="$dir/"`$echo "X$libobj" | $Xsed -e 's%^.*/%%'`
- if test -d "$dir"; then
- $show "$rm $libobj"
- $run $rm $libobj
- else
- $show "$mkdir $dir"
- $run $mkdir $dir
- status=$?
- if test $status -ne 0 && test ! -d $dir; then
- exit $status
- fi
- fi
- fi
- if test "$compiler_o_lo" = yes; then
- output_obj="$libobj"
- command="$command -o $output_obj"
- elif test "$compiler_c_o" = yes; then
- output_obj="$obj"
- fi
- $run $rm "$output_obj"
- $show "$command"
- if $run eval "$command"; then :
- else
- test -n "$output_obj" && $run $rm $removelist
- exit 1
- fi
- if test "$need_locks" = warn &&
- test x"`cat $lockfile 2>/dev/null`" != x"$srcfile"; then
- echo "\
-*** ERROR, $lockfile contains:
-but it should contain:
-$srcfile
-compiler."
- exit 1
- fi
- # Just move the object if needed, then go on to compile the next one
- if test x"$output_obj" != x"$libobj"; then
- $show "$mv $output_obj $libobj"
- if $run $mv $output_obj $libobj; then :
- else
- error=$?
- exit $error
- fi
- fi
- # If we have no pic_flag, then copy the object into place and finish.
- if (test -z "$pic_flag" || test "$pic_mode" != default) &&
- test "$build_old_libs" = yes; then
- # Rename the .lo from within objdir to obj
- if test -f $obj; then
- $show $rm $obj
- $run $rm $obj
- fi
- $show "$mv $libobj $obj"
- if $run $mv $libobj $obj; then :
- else
- error=$?
- exit $error
- fi
- xdir=`$echo "X$obj" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$xdir" = "X$obj"; then
- xdir="."
- else
- xdir="$xdir"
- fi
- baseobj=`$echo "X$obj" | $Xsed -e "s%.*/%%"`
- libobj=`$echo "X$baseobj" | $Xsed -e "$o2lo"`
- # Now arrange that obj and lo_libobj become the same file
- $show "(cd $xdir && $LN_S $baseobj $libobj)"
- if $run eval '(cd $xdir && $LN_S $baseobj $libobj)'; then
- # Unlock the critical section if it was locked
- if test "$need_locks" != no; then
- $run $rm "$lockfile"
- fi
- exit 0
- else
- error=$?
- exit $error
- fi
- fi
- # Allow error messages only from the first compilation.
- suppress_output=' >/dev/null 2>&1'
- fi
- # Only build a position-dependent object if we build old libraries.
- if test "$pic_mode" != yes; then
- else
- fi
- if test "$compiler_c_o" = yes; then
- command="$command -o $obj"
- output_obj="$obj"
- fi
- # Suppress compiler output if we already did a PIC compilation.
- command="$command$suppress_output"
- $show "$command"
- else
- exit 1
- fi
- echo "\
-$srcfile
-compiler."
- exit 1
- fi
- if test x"$output_obj" != x"$obj"; then
- $show "$mv $output_obj $obj"
- if $run $mv $output_obj $obj; then :
- else
- error=$?
- exit $error
- fi
- fi
- # Create an invalid libtool object if no PIC, so that we do not
- # accidentally link it into a program.
- if test "$build_libtool_libs" != yes; then
- $show "echo timestamp > $libobj"
- $run eval "echo timestamp > \$libobj" || exit $?
- else
- # Move the .lo from within objdir
- $show "$mv $libobj $lo_libobj"
- if $run $mv $libobj $lo_libobj; then :
- else
- error=$?
- exit $error
- fi
- fi
- fi
- fi
- exit 0
- # libtool link mode
- link | relink)
- modename="$modename: link"
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2*)
- # It is impossible to link a dll without this setting, and
- # we shouldn't force the makefile maintainer to figure out
- # which system we are compiling for in order to pass an extra
- # flag for every libtool invokation.
- # allow_undefined=no
- # FIXME: Unfortunately, there are problems with the above when trying
- # to make a dll which has undefined symbols, in which case not
- # even a static library is built. For now, we need to specify
- # -no-undefined on the libtool link line when we can be certain
- # that all symbols are satisfied, otherwise we get a static library.
- allow_undefined=yes
- esac
- libtool_args="$nonopt"
- compile_command="$nonopt"
- finalize_command="$nonopt"
- compile_rpath=
- finalize_rpath=
- compile_shlibpath=
- finalize_shlibpath=
- convenience=
- old_convenience=
- deplibs=
- old_deplibs=
- compiler_flags=
- linker_flags=
- dllsearchpath=
- lib_search_path=`pwd`
- inst_prefix_dir=
- avoid_version=no
- dlfiles=
- dlprefiles=
- dlself=no
- export_dynamic=no
- export_symbols=
- export_symbols_regex=
- generated=
- libobjs=
- ltlibs=
- module=no
- no_install=no
- objs=
- prefer_static_libs=no
- preload=no
- prev=
- prevarg=
- release=
- rpath=
- xrpath=
- perm_rpath=
- temp_rpath=
- thread_safe=no
- vinfo=
- # We need to know -static, to get the right output filenames.
- for arg
- do
- case $arg in
- -all-static | -static)
- if test "X$arg" = "X-all-static"; then
- if test "$build_libtool_libs" = yes && test -z "$link_static_flag"; then
- $echo "$modename: warning: complete static linking is impossible in this configuration" 1>&2
- fi
- if test -n "$link_static_flag"; then
- dlopen_self=$dlopen_self_static
- fi
- else
- if test -z "$pic_flag" && test -n "$link_static_flag"; then
- fi
- fi
- build_libtool_libs=no
- prefer_static_libs=yes
- break
- esac
- done
- # See if our shared archives depend on static archives.
- test -n "$old_archive_from_new_cmds" && build_old_libs=yes
- # Go through the arguments, transforming them on the way.
- while test $# -gt 0; do
- arg="$1"
- shift
- case $arg in
- qarg=\"`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`\" ### testsuite: skip nested quoting test
- *) qarg=$arg ;;
- esac
- libtool_args="$libtool_args $qarg"
- case $prev in
- output)
- compile_command="$compile_command @OUTPUT@"
- finalize_command="$finalize_command @OUTPUT@"
- esac
- case $prev in
- dlfiles|dlprefiles)
- if test "$preload" = no; then
- # Add the symbol object into the linking commands.
- compile_command="$compile_command @SYMFILE@"
- finalize_command="$finalize_command @SYMFILE@"
- preload=yes
- fi
- case $arg in
- *.la | *.lo) ;; # We handle these cases below.
- force)
- if test "$dlself" = no; then
- dlself=needless
- export_dynamic=yes
- fi
- prev=
- continue
- self)
- if test "$prev" = dlprefiles; then
- dlself=yes
- elif test "$prev" = dlfiles && test "$dlopen_self" != yes; then
- dlself=yes
- else
- dlself=needless
- fi
- prev=
- continue
- if test "$prev" = dlfiles; then
- dlfiles="$dlfiles $arg"
- else
- dlprefiles="$dlprefiles $arg"
- fi
- prev=
- continue
- esac
- expsyms)
- export_symbols="$arg"
- if test ! -f "$arg"; then
- $echo "$modename: symbol file \`$arg' does not exist"
- exit 1
- fi
- prev=
- continue
- expsyms_regex)
- export_symbols_regex="$arg"
- prev=
- continue
- inst_prefix)
- inst_prefix_dir="$arg"
- prev=
- continue
- release)
- release="-$arg"
- prev=
- continue
- rpath | xrpath)
- # We need an absolute path.
- case $arg in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- $echo "$modename: only absolute run-paths are allowed" 1>&2
- exit 1
- esac
- if test "$prev" = rpath; then
- case "$rpath " in
- *" $arg "*) ;;
- *) rpath="$rpath $arg" ;;
- esac
- else
- case "$xrpath " in
- *" $arg "*) ;;
- *) xrpath="$xrpath $arg" ;;
- esac
- fi
- prev=
- continue
- xcompiler)
- compiler_flags="$compiler_flags $qarg"
- prev=
- compile_command="$compile_command $qarg"
- finalize_command="$finalize_command $qarg"
- continue
- xlinker)
- linker_flags="$linker_flags $qarg"
- compiler_flags="$compiler_flags $wl$qarg"
- prev=
- compile_command="$compile_command $wl$qarg"
- finalize_command="$finalize_command $wl$qarg"
- continue
- eval "$prev=\"\$arg\""
- prev=
- continue
- esac
- fi # test -n $prev
- prevarg="$arg"
- case $arg in
- -all-static)
- compile_command="$compile_command $link_static_flag"
- finalize_command="$finalize_command $link_static_flag"
- fi
- continue
- -allow-undefined)
- # FIXME: remove this flag sometime in the future.
- $echo "$modename: \`-allow-undefined' is deprecated because it is the default" 1>&2
- continue
- -avoid-version)
- avoid_version=yes
- continue
- -dlopen)
- prev=dlfiles
- continue
- -dlpreopen)
- prev=dlprefiles
- continue
- -export-dynamic)
- continue
- -export-symbols | -export-symbols-regex)
- if test -n "$export_symbols" || test -n "$export_symbols_regex"; then
- $echo "$modename: more than one -exported-symbols argument is not allowed"
- exit 1
- fi
- if test "X$arg" = "X-export-symbols"; then
- prev=expsyms
- else
- prev=expsyms_regex
- fi
- continue
- -inst-prefix-dir)
- prev=inst_prefix
- continue
- # The native IRIX linker understands -LANG:*, -LIST:* and -LNO:*
- # so, if we see these flags be careful not to treat them like -L
- -L[A-Z][A-Z]*:*)
- case $with_gcc/$host in
- no/*-*-irix* | no/*-*-nonstopux*)
- compile_command="$compile_command $arg"
- finalize_command="$finalize_command $arg"
- esac
- continue
- -L*)
- dir=`$echo "X$arg" | $Xsed -e 's/^-L//'`
- case $dir in
- absdir=`cd "$dir" && pwd`
- if test -z "$absdir"; then
- $echo "$modename: cannot determine absolute directory name of \`$dir'" 1>&2
- exit 1
- fi
- dir="$absdir"
- esac
- case "$deplibs " in
- *" -L$dir "*) ;;
- deplibs="$deplibs -L$dir"
- lib_search_path="$lib_search_path $dir"
- esac
- case $host in
- case :$dllsearchpath: in
- *":$dir:"*) ;;
- *) dllsearchpath="$dllsearchpath:$dir";;
- esac
- esac
- continue
- -l*)
- if test "X$arg" = "X-lc" || test "X$arg" = "X-lm"; then
- case $host in
- *-*-cygwin* | *-*-pw32* | *-*-beos*)
- # These systems don't actually have a C or math library (as such)
- continue
- *-*-mingw* | *-*-os2*)
- # These systems don't actually have a C library (as such)
- test "X$arg" = "X-lc" && continue
- *-*-openbsd* | *-*-freebsd*)
- # Do not include libc due to us having libc/libc_r.
- esac
- elif test "X$arg" = "X-lc_r"; then
- case $host in
- # Do not include libc_r directly, use -pthread flag.
- continue
- esac
- fi
- deplibs="$deplibs $arg"
- continue
- -module)
- module=yes
- continue
- -no-fast-install)
- fast_install=no
- continue
- -no-install)
- case $host in
- # The PATH hackery in wrapper scripts is required on Windows
- # in order for the loader to find any dlls it needs.
- $echo "$modename: warning: \`-no-install' is ignored for $host" 1>&2
- $echo "$modename: warning: assuming \`-no-fast-install' instead" 1>&2
- fast_install=no
- *) no_install=yes ;;
- esac
- continue
- -no-undefined)
- allow_undefined=no
- continue
- -o) prev=output ;;
- -release)
- prev=release
- continue
- -rpath)
- prev=rpath
- continue
- -R)
- prev=xrpath
- continue
- -R*)
- dir=`$echo "X$arg" | $Xsed -e 's/^-R//'`
- case $dir in
- exit 1
- esac
- *" $dir "*) ;;
- *) xrpath="$xrpath $dir" ;;
- esac
- continue
- -static)
- # The effects of -static are defined in a previous loop.
- # We used to do the same as -all-static on platforms that
- # didn't have a PIC flag, but the assumption that the effects
- # would be equivalent was wrong. It would break on at least
- # Digital Unix and AIX.
- continue
- -thread-safe)
- thread_safe=yes
- continue
- -version-info)
- prev=vinfo
- continue
- -Wc,*)
- args=`$echo "X$arg" | $Xsed -e "$sed_quote_subst" -e 's/^-Wc,//'`
- arg=
- for flag in $args; do
- IFS="$save_ifs"
- case $flag in
- flag="\"$flag\""
- esac
- arg="$arg $wl$flag"
- compiler_flags="$compiler_flags $flag"
- done
- IFS="$save_ifs"
- arg=`$echo "X$arg" | $Xsed -e "s/^ //"`
- -Wl,*)
- args=`$echo "X$arg" | $Xsed -e "$sed_quote_subst" -e 's/^-Wl,//'`
- arg=
- IFS="$save_ifs"
- case $flag in
- flag="\"$flag\""
- esac
- compiler_flags="$compiler_flags $wl$flag"
- linker_flags="$linker_flags $flag"
- done
- IFS="$save_ifs"
- -Xcompiler)
- prev=xcompiler
- continue
- -Xlinker)
- prev=xlinker
- continue
- # Some other compiler flag.
- # Unknown arguments in both finalize_command and compile_command need
- # to be aesthetically quoted because they are evaled later.
- arg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- *.lo | *.$objext)
- # A library or standard object.
- # This file was specified with -dlopen.
- if test "$build_libtool_libs" = yes && test "$dlopen_support" = yes; then
- prev=
- continue
- else
- # If libtool objects are unsupported, then we need to preload.
- prev=dlprefiles
- fi
- fi
- # Preload the old-style object.
- dlprefiles="$dlprefiles "`$echo "X$arg" | $Xsed -e "$lo2o"`
- prev=
- else
- case $arg in
- *.lo) libobjs="$libobjs $arg" ;;
- *) objs="$objs $arg" ;;
- esac
- fi
- *.$libext)
- # An archive.
- old_deplibs="$old_deplibs $arg"
- continue
- *.la)
- # A libtool-controlled library.
- # This library was specified with -dlopen.
- prev=
- elif test "$prev" = dlprefiles; then
- # The library was specified with -dlpreopen.
- prev=
- else
- fi
- continue
- # Some other compiler argument.
- case $arg in
- arg="\"$arg\""
- esac
- esac # arg
- # Now actually substitute the argument into the commands.
- if test -n "$arg"; then
- fi
- done # argument parsing loop
- $echo "$modename: the \`$prevarg' option requires an argument" 1>&2
- exit 1
- fi
- if test "$export_dynamic" = yes && test -n "$export_dynamic_flag_spec"; then
- eval arg=\"$export_dynamic_flag_spec\"
- fi
- # calculate the name of the file, without its directory
- outputname=`$echo "X$output" | $Xsed -e 's%^.*/%%'`
- libobjs_save="$libobjs"
- if test -n "$shlibpath_var"; then
- # get the directories listed in $shlibpath_var
- eval shlib_search_path=\`\$echo \"X\${$shlibpath_var}\" \| \$Xsed -e \'s/:/ /g\'\`
- else
- shlib_search_path=
- fi
- eval sys_lib_search_path=\"$sys_lib_search_path_spec\"
- eval sys_lib_dlsearch_path=\"$sys_lib_dlsearch_path_spec\"
- output_objdir=`$echo "X$output" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$output_objdir" = "X$output"; then
- output_objdir="$objdir"
- else
- output_objdir="$output_objdir/$objdir"
- fi
- # Create the object directory.
- if test ! -d $output_objdir; then
- $show "$mkdir $output_objdir"
- $run $mkdir $output_objdir
- status=$?
- if test $status -ne 0 && test ! -d $output_objdir; then
- exit $status
- fi
- fi
- # Determine the type of output
- case $output in
- $echo "$modename: you must specify an output file" 1>&2
- exit 1
- *.$libext) linkmode=oldlib ;;
- *.lo | *.$objext) linkmode=obj ;;
- *.la) linkmode=lib ;;
- *) linkmode=prog ;; # Anything else should be a program.
- esac
- specialdeplibs=
- libs=
- # Find all interdependent deplibs by searching for libraries
- # that are linked more than once (e.g. -la -lb -la)
- for deplib in $deplibs; do
- if test "X$duplicate_deps" = "Xyes" ; then
- case "$libs " in
- *" $deplib "*) specialdeplibs="$specialdeplibs $deplib" ;;
- esac
- fi
- libs="$libs $deplib"
- done
- deplibs=
- newdependency_libs=
- newlib_search_path=
- need_relink=no # whether we're linking any uninstalled libtool libraries
- notinst_deplibs= # not-installed libtool libraries
- notinst_path= # paths that contain not-installed libtool libraries
- case $linkmode in
- lib)
- passes="conv link"
- for file in $dlfiles $dlprefiles; do
- case $file in
- *.la) ;;
- $echo "$modename: libraries can \`-dlopen' only libtool libraries: $file" 1>&2
- exit 1
- esac
- done
- prog)
- compile_deplibs=
- finalize_deplibs=
- alldeplibs=no
- newdlfiles=
- newdlprefiles=
- passes="conv scan dlopen dlpreopen link"
- *) passes="conv"
- esac
- for pass in $passes; do
- if test $linkmode = prog; then
- # Determine which files to process
- case $pass in
- dlopen)
- libs="$dlfiles"
- save_deplibs="$deplibs" # Collect dlpreopened libraries
- deplibs=
- dlpreopen) libs="$dlprefiles" ;;
- link) libs="$deplibs %DEPLIBS% $dependency_libs" ;;
- esac
- fi
- for deplib in $libs; do
- lib=
- found=no
- case $deplib in
- -l*)
- if test $linkmode = oldlib && test $linkmode = obj; then
- $echo "$modename: warning: \`-l' is ignored for archives/objects: $deplib" 1>&2
- continue
- fi
- if test $pass = conv; then
- deplibs="$deplib $deplibs"
- continue
- fi
- name=`$echo "X$deplib" | $Xsed -e 's/^-l//'`
- for searchdir in $newlib_search_path $lib_search_path $sys_lib_search_path $shlib_search_path; do
- # Search the libtool library
- lib="$searchdir/lib${name}.la"
- if test -f "$lib"; then
- found=yes
- break
- fi
- done
- if test "$found" != yes; then
- # deplib doesn't seem to be a libtool library
- if test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$deplib $compile_deplibs"
- finalize_deplibs="$deplib $finalize_deplibs"
- else
- test $linkmode = lib && newdependency_libs="$deplib $newdependency_libs"
- fi
- continue
- fi
- ;; # -l
- -L*)
- case $linkmode in
- lib)
- test $pass = conv && continue
- newdependency_libs="$deplib $newdependency_libs"
- newlib_search_path="$newlib_search_path "`$echo "X$deplib" | $Xsed -e 's/^-L//'`
- prog)
- continue
- fi
- if test $pass = scan; then
- else
- fi
- $echo "$modename: warning: \`-L' is ignored for archives/objects: $deplib" 1>&2
- esac # linkmode
- continue
- ;; # -L
- -R*)
- if test $pass = link; then
- dir=`$echo "X$deplib" | $Xsed -e 's/^-R//'`
- # Make sure the xrpath contains only unique directories.
- *" $dir "*) ;;
- esac
- fi
- continue
- *.la) lib="$deplib" ;;
- *.$libext)
- continue
- fi
- case $linkmode in
- lib)
- if test "$deplibs_check_method" != pass_all; then
- echo
- echo "*** Warning: Trying to link with static lib archive $deplib."
- echo "*** I have the capability to make that library automatically link in when"
- echo "*** you link to this library. But I can only do this if you have a"
- echo "*** shared version of the library, which you do not appear to have"
- echo "*** because the file extensions .$libext of this argument makes me believe"
- echo "*** that it is just a static archive that I should not used here."
- else
- echo
- echo "*** Warning: Linking the shared library $output against the"
- echo "*** static library $deplib is not portable!"
- fi
- continue
- prog)
- if test $pass != link; then
- else
- fi
- continue
- esac # linkmode
- ;; # *.$libext
- *.lo | *.$objext)
- if test $pass = dlpreopen || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
- # If there is no dlopen support or we're linking statically,
- # we need to preload.
- newdlprefiles="$newdlprefiles $deplib"
- else
- newdlfiles="$newdlfiles $deplib"
- fi
- continue
- %DEPLIBS%)
- alldeplibs=yes
- continue
- esac # case $deplib
- if test $found = yes || test -f "$lib"; then :
- else
- $echo "$modename: cannot find the library \`$lib'" 1>&2
- exit 1
- fi
- # Check to see that this really is a libtool archive.
- if (${SED} -e '2q' $lib | egrep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then :
- else
- $echo "$modename: \`$lib' is not a valid libtool archive" 1>&2
- exit 1
- fi
- ladir=`$echo "X$lib" | $Xsed -e 's%/[^/]*$%%'`
- test "X$ladir" = "X$lib" && ladir="."
- dlname=
- dlopen=
- dlpreopen=
- libdir=
- library_names=
- old_library=
- # If the library was installed with an old release of libtool,
- # it will not redefine variable installed.
- installed=yes
- # Read the .la file
- case $lib in
- */* | *\\*) . $lib ;;
- *) . ./$lib ;;
- esac
- if test "$linkmode,$pass" = "lib,link" ||
- test "$linkmode,$pass" = "prog,scan" ||
- { test $linkmode = oldlib && test $linkmode = obj; }; then
- # Add dl[pre]opened files of deplib
- test -n "$dlopen" && dlfiles="$dlfiles $dlopen"
- test -n "$dlpreopen" && dlprefiles="$dlprefiles $dlpreopen"
- fi
- # Only check for convenience libraries
- deplibs="$lib $deplibs"
- if test -z "$libdir"; then
- if test -z "$old_library"; then
- $echo "$modename: cannot find name of link library for \`$lib'" 1>&2
- exit 1
- fi
- # It is a libtool convenience library, so add in its objects.
- convenience="$convenience $ladir/$objdir/$old_library"
- old_convenience="$old_convenience $ladir/$objdir/$old_library"
- tmp_libs=
- for deplib in $dependency_libs; do
- case "$tmp_libs " in
- esac
- fi
- tmp_libs="$tmp_libs $deplib"
- done
- elif test $linkmode != prog && test $linkmode != lib; then
- $echo "$modename: \`$lib' is not a convenience library" 1>&2
- exit 1
- fi
- continue
- fi # $pass = conv
- # Get the name of the library we link against.
- linklib=
- for l in $old_library $library_names; do
- linklib="$l"
- done
- if test -z "$linklib"; then
- exit 1
- fi
- if test $pass = dlopen; then
- $echo "$modename: cannot -dlopen a convenience library: \`$lib'" 1>&2
- exit 1
- fi
- if test -z "$dlname" || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
- # If there is no dlname, no dlopen support or we're linking
- # statically, we need to preload.
- dlprefiles="$dlprefiles $lib"
- else
- newdlfiles="$newdlfiles $lib"
- fi
- continue
- fi # $pass = dlopen
- case $ladir in
- [\\/]* | [A-Za-z]:[\\/]*) abs_ladir="$ladir" ;;
- abs_ladir=`cd "$ladir" && pwd`
- if test -z "$abs_ladir"; then
- $echo "$modename: warning: cannot determine absolute directory name of \`$ladir'" 1>&2
- $echo "$modename: passing it literally to the linker, although it might fail" 1>&2
- abs_ladir="$ladir"
- fi
- esac
- laname=`$echo "X$lib" | $Xsed -e 's%^.*/%%'`
- # Find the relevant object directory and library name.
- if test "X$installed" = Xyes; then
- if test ! -f "$libdir/$linklib" && test -f "$abs_ladir/$linklib"; then
- $echo "$modename: warning: library \`$lib' was moved." 1>&2
- dir="$ladir"
- absdir="$abs_ladir"
- libdir="$abs_ladir"
- else
- dir="$libdir"
- absdir="$libdir"
- fi
- else
- dir="$ladir/$objdir"
- absdir="$abs_ladir/$objdir"
- # Remove this search path later
- notinst_path="$notinst_path $abs_ladir"
- fi # $installed = yes
- name=`$echo "X$laname" | $Xsed -e 's/\.la$//' -e 's/^lib//'`
- # This library was specified with -dlpreopen.
- if test $pass = dlpreopen; then
- $echo "$modename: cannot -dlpreopen a convenience library: \`$lib'" 1>&2
- exit 1
- fi
- # Prefer using a static library (so that no silly _DYNAMIC symbols
- # are required to link).
- if test -n "$old_library"; then
- newdlprefiles="$newdlprefiles $dir/$old_library"
- # Otherwise, use the dlname, so that lt_dlopen finds it.
- elif test -n "$dlname"; then
- newdlprefiles="$newdlprefiles $dir/$dlname"
- else
- newdlprefiles="$newdlprefiles $dir/$linklib"
- fi
- fi # $pass = dlpreopen
- # Link the convenience library
- if test $linkmode = lib; then
- deplibs="$dir/$old_library $deplibs"
- elif test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$dir/$old_library $compile_deplibs"
- finalize_deplibs="$dir/$old_library $finalize_deplibs"
- else
- fi
- continue
- fi
- if test $linkmode = prog && test $pass != link; then
- newlib_search_path="$newlib_search_path $ladir"
- linkalldeplibs=no
- if test "$link_all_deplibs" != no || test -z "$library_names" ||
- test "$build_libtool_libs" = no; then
- linkalldeplibs=yes
- fi
- tmp_libs=
- case $deplib in
- -L*) newlib_search_path="$newlib_search_path "`$echo "X$deplib" | $Xsed -e 's/^-L//'`;; ### testsuite: skip nested quoting test
- esac
- # Need to link against all dependency_libs?
- if test $linkalldeplibs = yes; then
- else
- # Need to hardcode shared library paths
- # or/and link against static libraries
- fi
- esac
- fi
- done # for deplib
- continue
- fi # $linkmode = prog...
- link_static=no # Whether the deplib will be linked statically
- if test -n "$library_names" &&
- { test "$prefer_static_libs" = no || test -z "$old_library"; }; then
- # Link against this shared library
- if test "$linkmode,$pass" = "prog,link" ||
- { test $linkmode = lib && test $hardcode_into_libs = yes; }; then
- # Hardcode the library path.
- # Skip directories that are in the system default run-time
- # search path.
- case " $sys_lib_dlsearch_path " in
- *" $absdir "*) ;;
- case "$compile_rpath " in
- *" $absdir "*) ;;
- *) compile_rpath="$compile_rpath $absdir"
- esac
- esac
- *" $libdir "*) ;;
- case "$finalize_rpath " in
- *" $libdir "*) ;;
- *) finalize_rpath="$finalize_rpath $libdir"
- esac
- esac
- # We need to hardcode the library path
- # Make sure the rpath contains only unique directories.
- case "$temp_rpath " in
- *" $dir "*) ;;
- *" $absdir "*) ;;
- *) temp_rpath="$temp_rpath $dir" ;;
- esac
- fi
- fi
- fi # $linkmode,$pass = prog,link...
- if test "$alldeplibs" = yes &&
- { test "$deplibs_check_method" = pass_all ||
- { test "$build_libtool_libs" = yes &&
- test -n "$library_names"; }; }; then
- # We only need to search for static libraries
- continue
- fi
- if test "$installed" = no; then
- notinst_deplibs="$notinst_deplibs $lib"
- need_relink=yes
- fi
- if test -n "$old_archive_from_expsyms_cmds"; then
- # figure out the soname
- set dummy $library_names
- realname="$2"
- shift; shift
- libname=`eval \\$echo \"$libname_spec\"`
- # use dlname if we got it. it's perfectly good, no?
- if test -n "$dlname"; then
- soname="$dlname"
- elif test -n "$soname_spec"; then
- # bleh windows
- case $host in
- *cygwin*)
- major=`expr $current - $age`
- versuffix="-$major"
- esac
- eval soname=\"$soname_spec\"
- else
- soname="$realname"
- fi
- # Make a new name for the extract_expsyms_cmds to use
- soroot="$soname"
- soname=`echo $soroot | ${SED} -e 's/^.*\///'`
- newlib="libimp-`echo $soname | ${SED} 's/^lib//;s/\.dll$//'`.a"
- # If the library has no export list, then create one now
- if test -f "$output_objdir/$soname-def"; then :
- else
- $show "extracting exported symbol list from \`$soname'"
- save_ifs="$IFS"; IFS='~'
- eval cmds=\"$extract_expsyms_cmds\"
- for cmd in $cmds; do
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd" || exit $?
- done
- IFS="$save_ifs"
- fi
- # Create $newlib
- if test -f "$output_objdir/$newlib"; then :; else
- $show "generating import library for \`$soname'"
- eval cmds=\"$old_archive_from_expsyms_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- fi
- # make sure the library variables are pointing to the new library
- dir=$output_objdir
- linklib=$newlib
- fi # test -n $old_archive_from_expsyms_cmds
- if test $linkmode = prog || test "$mode" != relink; then
- add_shlibpath=
- add_dir=
- add=
- lib_linked=yes
- case $hardcode_action in
- immediate | unsupported)
- if test "$hardcode_direct" = no; then
- add="$dir/$linklib"
- elif test "$hardcode_minus_L" = no; then
- case $host in
- *-*-sunos*) add_shlibpath="$dir" ;;
- esac
- add_dir="-L$dir"
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = no; then
- add_shlibpath="$dir"
- add="-l$name"
- else
- lib_linked=no
- fi
- relink)
- if test "$hardcode_direct" = yes; then
- elif test "$hardcode_minus_L" = yes; then
- add_dir="-L$dir"
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = yes; then
- add="-l$name"
- else
- lib_linked=no
- fi
- *) lib_linked=no ;;
- esac
- if test "$lib_linked" != yes; then
- $echo "$modename: configuration error: unsupported hardcode properties"
- exit 1
- fi
- if test -n "$add_shlibpath"; then
- case :$compile_shlibpath: in
- *":$add_shlibpath:"*) ;;
- *) compile_shlibpath="$compile_shlibpath$add_shlibpath:" ;;
- esac
- fi
- test -n "$add_dir" && compile_deplibs="$add_dir $compile_deplibs"
- test -n "$add" && compile_deplibs="$add $compile_deplibs"
- else
- test -n "$add_dir" && deplibs="$add_dir $deplibs"
- test -n "$add" && deplibs="$add $deplibs"
- if test "$hardcode_direct" != yes && \
- test "$hardcode_minus_L" != yes && \
- test "$hardcode_shlibpath_var" = yes; then
- case :$finalize_shlibpath: in
- *":$libdir:"*) ;;
- *) finalize_shlibpath="$finalize_shlibpath$libdir:" ;;
- esac
- fi
- fi
- fi
- if test $linkmode = prog || test "$mode" = relink; then
- add_shlibpath=
- add_dir=
- add=
- # Finalize command for both is simple: just hardcode it.
- add="$libdir/$linklib"
- # Try looking first in the location we're being installed to.
- add_dir=
- if test -n "$inst_prefix_dir"; then
- case "$libdir" in
- add_dir="-L$inst_prefix_dir$libdir"
- esac
- fi
- add_dir="-L$libdir $add_dir"
- add="-l$name"
- *":$libdir:"*) ;;
- esac
- add="-l$name"
- else
- # We cannot seem to hardcode it, guess we'll fake it.
- add_dir=
- case "$libdir" in
- esac
- fi
- add_dir="-L$libdir $add_dir "
- add="-l$name"
- fi
- test -n "$add_dir" && finalize_deplibs="$add_dir $finalize_deplibs"
- test -n "$add" && finalize_deplibs="$add $finalize_deplibs"
- else
- fi
- fi
- elif test $linkmode = prog; then
- continue
- fi
- # Try to link the static library
- # Here we assume that one of hardcode_direct or hardcode_minus_L
- # is not unsupported. This is valid on all known static and
- # shared platforms.
- if test "$hardcode_direct" != unsupported; then
- test -n "$old_library" && linklib="$old_library"
- compile_deplibs="$dir/$linklib $compile_deplibs"
- finalize_deplibs="$dir/$linklib $finalize_deplibs"
- else
- compile_deplibs="-l$name -L$dir $compile_deplibs"
- finalize_deplibs="-l$name -L$dir $finalize_deplibs"
- fi
- elif test "$build_libtool_libs" = yes; then
- # Not a shared library
- # We're trying link a shared library against a static one
- # but the system doesn't support it.
- # Just print a warning and add the library to dependency_libs so
- # that the program can be linked against the static library.
- echo
- echo "*** Warning: This system can not link to static lib archive $lib."
- echo "*** shared version of the library, which you do not appear to have."
- if test "$module" = yes; then
- echo "*** But as you try to build a module library, libtool will still create "
- echo "*** a static module, that should work as long as the dlopening application"
- echo "*** is linked with the -dlopen flag to resolve symbols at runtime."
- if test -z "$global_symbol_pipe"; then
- echo
- echo "*** However, this would only work if libtool was able to extract symbol"
- echo "*** lists from a program, using \`nm' or equivalent, but libtool could"
- echo "*** not find such a program. So, this module is probably useless."
- echo "*** \`nm' from GNU binutils and a full rebuild may help."
- fi
- if test "$build_old_libs" = no; then
- build_libtool_libs=module
- else
- fi
- fi
- else
- convenience="$convenience $dir/$old_library"
- old_convenience="$old_convenience $dir/$old_library"
- link_static=yes
- fi
- fi # link shared/static library?
- if test -n "$dependency_libs" &&
- { test $hardcode_into_libs != yes || test $build_old_libs = yes ||
- test $link_static = yes; }; then
- # Extract -R from dependency_libs
- temp_deplibs=
- for libdir in $dependency_libs; do
- case $libdir in
- -R*) temp_xrpath=`$echo "X$libdir" | $Xsed -e 's/^-R//'`
- case " $xrpath " in
- *" $temp_xrpath "*) ;;
- *) xrpath="$xrpath $temp_xrpath";;
- esac;;
- *) temp_deplibs="$temp_deplibs $libdir";;
- esac
- done
- dependency_libs="$temp_deplibs"
- fi
- newlib_search_path="$newlib_search_path $absdir"
- # Link against this library
- test "$link_static" = no && newdependency_libs="$abs_ladir/$laname $newdependency_libs"
- # ... and its dependency_libs
- tmp_libs=
- esac
- fi
- done
- if test $link_all_deplibs != no; then
- # Add the search paths of all dependency libraries
- case $deplib in
- -L*) path="$deplib" ;;
- *.la)
- dir=`$echo "X$deplib" | $Xsed -e 's%/[^/]*$%%'`
- test "X$dir" = "X$deplib" && dir="."
- case $dir in
- [\\/]* | [A-Za-z]:[\\/]*) absdir="$dir" ;;
- $echo "$modename: warning: cannot determine absolute directory name of \`$dir'" 1>&2
- absdir="$dir"
- fi
- esac
- if grep "^installed=no" $deplib > /dev/null; then
- path="-L$absdir/$objdir"
- else
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $deplib`
- $echo "$modename: \`$deplib' is not a valid libtool archive" 1>&2
- exit 1
- fi
- if test "$absdir" != "$libdir"; then
- $echo "$modename: warning: \`$deplib' seems to be moved" 1>&2
- fi
- path="-L$absdir"
- fi
- *) continue ;;
- esac
- case " $deplibs " in
- *" $path "*) ;;
- *) deplibs="$deplibs $path" ;;
- esac
- done
- fi # link_all_deplibs != no
- fi # linkmode = lib
- done # for deplib in $libs
- # Link the dlpreopened libraries before other libraries
- for deplib in $save_deplibs; do
- done
- fi
- if test $pass != dlopen; then
- test $pass != scan && dependency_libs="$newdependency_libs"
- if test $pass != conv; then
- # Make sure lib_search_path contains only unique directories.
- lib_search_path=
- for dir in $newlib_search_path; do
- case "$lib_search_path " in
- *" $dir "*) ;;
- *) lib_search_path="$lib_search_path $dir" ;;
- esac
- done
- fi
- if test "$linkmode,$pass" != "prog,link"; then
- vars="deplibs"
- else
- vars="compile_deplibs finalize_deplibs"
- fi
- for var in $vars dependency_libs; do
- # Add libraries to $var in reverse order
- eval tmp_libs=\"\$$var\"
- new_libs=
- for deplib in $tmp_libs; do
- case $deplib in
- -L*) new_libs="$deplib $new_libs" ;;
- case " $specialdeplibs " in
- *" $deplib "*) new_libs="$deplib $new_libs" ;;
- case " $new_libs " in
- *" $deplib "*) ;;
- *) new_libs="$deplib $new_libs" ;;
- esac
- esac
- esac
- done
- tmp_libs=
- for deplib in $new_libs; do
- case $deplib in
- -L*)
- case " $tmp_libs " in
- *" $deplib "*) ;;
- *) tmp_libs="$tmp_libs $deplib" ;;
- esac
- esac
- done
- eval $var=\"$tmp_libs\"
- done # for var
- fi
- if test "$pass" = "conv" &&
- { test "$linkmode" = "lib" || test "$linkmode" = "prog"; }; then
- libs="$deplibs" # reset libs
- deplibs=
- fi
- done # for pass
- dlfiles="$newdlfiles"
- dlprefiles="$newdlprefiles"
- fi
- case $linkmode in
- oldlib)
- if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
- $echo "$modename: warning: \`-dlopen' is ignored for archives" 1>&2
- fi
- if test -n "$rpath"; then
- $echo "$modename: warning: \`-rpath' is ignored for archives" 1>&2
- fi
- if test -n "$xrpath"; then
- $echo "$modename: warning: \`-R' is ignored for archives" 1>&2
- fi
- if test -n "$vinfo"; then
- $echo "$modename: warning: \`-version-info' is ignored for archives" 1>&2
- fi
- if test -n "$release"; then
- $echo "$modename: warning: \`-release' is ignored for archives" 1>&2
- fi
- $echo "$modename: warning: \`-export-symbols' is ignored for archives" 1>&2
- fi
- # Now set the variables for building old libraries.
- oldlibs="$output"
- objs="$objs$old_deplibs"
- lib)
- # Make sure we only generate libraries of the form `libNAME.la'.
- case $outputname in
- lib*)
- name=`$echo "X$outputname" | $Xsed -e 's/\.la$//' -e 's/^lib//'`
- eval libname=\"$libname_spec\"
- if test "$module" = no; then
- $echo "$modename: libtool library \`$output' must begin with \`lib'" 1>&2
- exit 1
- fi
- if test "$need_lib_prefix" != no; then
- # Add the "lib" prefix for modules if required
- name=`$echo "X$outputname" | $Xsed -e 's/\.la$//'`
- else
- libname=`$echo "X$outputname" | $Xsed -e 's/\.la$//'`
- fi
- esac
- if test -n "$objs"; then
- $echo "$modename: cannot build libtool library \`$output' from non-libtool objects on this host:$objs" 2>&1
- exit 1
- else
- echo
- echo "*** Warning: Linking the shared library $output against the non-libtool"
- echo "*** objects $objs is not portable!"
- libobjs="$libobjs $objs"
- fi
- fi
- if test "$dlself" != no; then
- $echo "$modename: warning: \`-dlopen self' is ignored for libtool libraries" 1>&2
- fi
- set dummy $rpath
- if test $# -gt 2; then
- $echo "$modename: warning: ignoring multiple \`-rpath's for a libtool library" 1>&2
- fi
- install_libdir="$2"
- oldlibs=
- if test -z "$rpath"; then
- # Building a libtool convenience library.
- libext=al
- oldlibs="$output_objdir/$libname.$libext $oldlibs"
- build_libtool_libs=convenience
- fi
- $echo "$modename: warning: \`-version-info' is ignored for convenience libraries" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for convenience libraries" 1>&2
- fi
- else
- # Parse the version information argument.
- save_ifs="$IFS"; IFS=':'
- set dummy $vinfo 0 0 0
- IFS="$save_ifs"
- if test -n "$8"; then
- $echo "$modename: too many parameters to \`-version-info'" 1>&2
- exit 1
- fi
- current="$2"
- revision="$3"
- age="$4"
- # Check that each of the things are valid numbers.
- case $current in
- [0-9]*) ;;
- $echo "$modename: CURRENT \`$current' is not a nonnegative integer" 1>&2
- $echo "$modename: \`$vinfo' is not valid version information" 1>&2
- exit 1
- esac
- case $revision in
- [0-9]*) ;;
- $echo "$modename: REVISION \`$revision' is not a nonnegative integer" 1>&2
- exit 1
- esac
- case $age in
- [0-9]*) ;;
- $echo "$modename: AGE \`$age' is not a nonnegative integer" 1>&2
- exit 1
- esac
- if test $age -gt $current; then
- $echo "$modename: AGE \`$age' is greater than the current interface number \`$current'" 1>&2
- exit 1
- fi
- # Calculate the version variables.
- major=
- versuffix=
- verstring=
- case $version_type in
- none) ;;
- darwin)
- # Like Linux, but with the current version available in
- # verstring for coding it into the library header
- major=.`expr $current - $age`
- versuffix="$major.$age.$revision"
- # Darwin ld doesn't like 0 for these options...
- minor_current=`expr $current + 1`
- verstring="-compatibility_version $minor_current -current_version $minor_current.$revision"
- freebsd-aout)
- major=".$current"
- versuffix=".$current.$revision";
- freebsd-elf)
- major=".$current"
- versuffix=".$current";
- irix | nonstopux)
- major=`expr $current - $age + 1`
- nonstopux) verstring_prefix=nonstopux ;;
- *) verstring_prefix=sgi ;;
- esac
- verstring="$verstring_prefix$major.$revision"
- # Add in all the interfaces that we are compatible with.
- loop=$revision
- while test $loop != 0; do
- iface=`expr $revision - $loop`
- loop=`expr $loop - 1`
- verstring="$verstring_prefix$major.$iface:$verstring"
- done
- # Before this point, $major must not contain `.'.
- major=.$major
- versuffix="$major.$revision"
- linux)
- osf)
- versuffix=".$current.$age.$revision"
- verstring="$current.$age.$revision"
- loop=$age
- iface=`expr $current - $loop`
- verstring="$verstring:${iface}.0"
- done
- # Make executables depend on our current version.
- verstring="$verstring:${current}.0"
- sunos)
- major=".$current"
- windows)
- # Use '-' rather than '.', since we only want one
- # extension on DOS 8.3 filesystems.
- $echo "$modename: unknown library version type \`$version_type'" 1>&2
- exit 1
- esac
- # Clear the version info if we defaulted, and they specified a release.
- if test -z "$vinfo" && test -n "$release"; then
- major=
- verstring="0.0"
- darwin)
- # we can't check for "0.0" in archive_cmds due to quoting
- # problems, so we reset it completely
- verstring=""
- verstring="0.0"
- esac
- if test "$need_version" = no; then
- versuffix=
- else
- versuffix=".0.0"
- fi
- fi
- # Remove version info from name if versioning should be avoided
- if test "$avoid_version" = yes && test "$need_version" = no; then
- major=
- versuffix=
- verstring=""
- fi
- # Check to see if the archive will have undefined symbols.
- if test "$allow_undefined" = yes; then
- if test "$allow_undefined_flag" = unsupported; then
- $echo "$modename: warning: undefined symbols not allowed in $host shared libraries" 1>&2
- fi
- else
- # Don't allow undefined symbols.
- allow_undefined_flag="$no_undefined_flag"
- fi
- fi
- if test "$mode" != relink; then
- # Remove our outputs.
- $show "${rm}r $output_objdir/$outputname $output_objdir/$libname.* $output_objdir/${libname}${release}.*"
- $run ${rm}r $output_objdir/$outputname $output_objdir/$libname.* $output_objdir/${libname}${release}.*
- fi
- if test "$build_old_libs" = yes && test "$build_libtool_libs" != convenience ; then
- oldlibs="$oldlibs $output_objdir/$libname.$libext"
- # Transform .lo files to .o files.
- oldobjs="$objs "`$echo "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}'$/d' -e "$lo2o" | $NL2SP`
- fi
- # Eliminate all temporary directories.
- for path in $notinst_path; do
- lib_search_path=`echo "$lib_search_path " | ${SED} -e 's% $path % %g'`
- deplibs=`echo "$deplibs " | ${SED} -e 's% -L$path % %g'`
- dependency_libs=`echo "$dependency_libs " | ${SED} -e 's% -L$path % %g'`
- done
- # If the user specified any rpath flags, then add them.
- temp_xrpath=
- for libdir in $xrpath; do
- temp_xrpath="$temp_xrpath -R$libdir"
- *" $libdir "*) ;;
- *) finalize_rpath="$finalize_rpath $libdir" ;;
- esac
- done
- if test $hardcode_into_libs != yes || test $build_old_libs = yes; then
- dependency_libs="$temp_xrpath $dependency_libs"
- fi
- fi
- # Make sure dlfiles contains only unique files that won't be dlpreopened
- old_dlfiles="$dlfiles"
- dlfiles=
- for lib in $old_dlfiles; do
- case " $dlprefiles $dlfiles " in
- *" $lib "*) ;;
- *) dlfiles="$dlfiles $lib" ;;
- esac
- done
- # Make sure dlprefiles contains only unique files
- old_dlprefiles="$dlprefiles"
- dlprefiles=
- for lib in $old_dlprefiles; do
- case "$dlprefiles " in
- *" $lib "*) ;;
- *) dlprefiles="$dlprefiles $lib" ;;
- esac
- done
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-beos*)
- # these systems don't actually have a c library (as such)!
- *-*-rhapsody* | *-*-darwin1.[012])
- # Rhapsody C library is in the System framework
- deplibs="$deplibs -framework System"
- *-*-netbsd*)
- # Don't link with libc until the a.out ld.so is fixed.
- # Add libc to deplibs on all other systems if necessary.
- if test $build_libtool_need_lc = "yes"; then
- deplibs="$deplibs -lc"
- fi
- esac
- fi
- # Transform deplibs into only deplibs that can be linked in shared.
- name_save=$name
- libname_save=$libname
- release_save=$release
- versuffix_save=$versuffix
- major_save=$major
- # I'm not sure if I'm treating the release correctly. I think
- # release should show up in the -l (ie -lgmp5) so we don't want to
- # add it in twice. Is that correct?
- release=""
- versuffix=""
- major=""
- newdeplibs=
- droppeddeps=no
- case $deplibs_check_method in
- pass_all)
- # Don't check for shared/static. Everything works.
- # This might be a little naive. We might want to check
- # whether the library exists or not. But this is on
- # osf3 & osf4 and I'm not really sure... Just
- # implementing what was already the behaviour.
- newdeplibs=$deplibs
- test_compile)
- # This code stresses the "libraries are programs" paradigm to its
- # limits. Maybe even breaks it. We compile a program, linking it
- # against the deplibs as a proxy for the library. Then we can check
- # whether they linked in statically or dynamically with ldd.
- $rm conftest.c
- cat > conftest.c <<EOF
- int main() { return 0; }
-EOF
- $rm conftest
- $CC -o conftest conftest.c $deplibs
- if test $? -eq 0 ; then
- ldd_output=`ldd conftest`
- for i in $deplibs; do
- name="`expr $i : '-l\(.*\)'`"
- # If $name is empty we are operating on a -L argument.
- if test -n "$name" && test "$name" != "0"; then
- deplib_matches=`eval \\$echo \"$library_names_spec\"`
- set dummy $deplib_matches
- deplib_match=$2
- if test `expr "$ldd_output" : ".*$deplib_match"` -ne 0 ; then
- newdeplibs="$newdeplibs $i"
- else
- droppeddeps=yes
- echo
- echo "*** Warning: dynamic linker does not accept needed library $i."
- echo "*** shared version of the library, which I believe you do not have"
- echo "*** because a test_compile did reveal that the linker did not use it for"
- echo "*** its dynamic dependency list that programs get resolved with at runtime."
- fi
- else
- fi
- done
- else
- # Error occured in the first compile. Let's try to salvage
- # the situation: Compile a separate program for each library.
- $rm conftest
- $CC -o conftest conftest.c $i
- # Did it work?
- deplib_match=$2
- else
- droppeddeps=yes
- echo
- echo "*** because a test_compile did reveal that the linker did not use this one"
- echo "*** as a dynamic dependency that programs can get resolved with at runtime."
- fi
- else
- droppeddeps=yes
- echo
- echo "*** Warning! Library $i is needed by this library but I was not able to"
- echo "*** make it link in! You will probably need to install it or some"
- echo "*** library that it depends on before this library will be fully"
- echo "*** functional. Installing it before continuing would be even better."
- fi
- else
- fi
- done
- fi
- file_magic*)
- set dummy $deplibs_check_method
- file_magic_regex=`expr "$deplibs_check_method" : "$2 \(.*\)"`
- for a_deplib in $deplibs; do
- name="`expr $a_deplib : '-l\(.*\)'`"
- for i in $lib_search_path $sys_lib_search_path $shlib_search_path; do
- potential_libs=`ls $i/$libname[.-]* 2>/dev/null`
- for potent_lib in $potential_libs; do
- # Follow soft links.
- if ls -lLd "$potent_lib" 2>/dev/null \
- | grep " -> " >/dev/null; then
- continue
- fi
- # The statement above tries to avoid entering an
- # endless loop below, in case of cyclic links.
- # We might still enter an endless loop, since a link
- # loop can be closed while we follow links,
- # but so what?
- potlib="$potent_lib"
- while test -h "$potlib" 2>/dev/null; do
- potliblink=`ls -ld $potlib | ${SED} 's/.* -> //'`
- case $potliblink in
- [\\/]* | [A-Za-z]:[\\/]*) potlib="$potliblink";;
- *) potlib=`$echo "X$potlib" | $Xsed -e 's,[^/]*$,,'`"$potliblink";;
- esac
- done
- if eval $file_magic_cmd \"\$potlib\" 2>/dev/null \
- | ${SED} 10q \
- | egrep "$file_magic_regex" > /dev/null; then
- newdeplibs="$newdeplibs $a_deplib"
- a_deplib=""
- break 2
- fi
- done
- done
- if test -n "$a_deplib" ; then
- droppeddeps=yes
- echo
- echo "*** Warning: linker path does not have real file for library $a_deplib."
- echo "*** because I did check the linker path looking for a file starting"
- if test -z "$potlib" ; then
- echo "*** with $libname but no candidates were found. (...for file magic test)"
- else
- echo "*** with $libname and none of the candidates passed a file format test"
- echo "*** using a file magic. Last file checked: $potlib"
- fi
- fi
- else
- # Add a -L argument.
- fi
- done # Gone through all deplibs.
- match_pattern*)
- match_pattern_regex=`expr "$deplibs_check_method" : "$2 \(.*\)"`
- potlib="$potent_lib" # see symlink-check below in file_magic test
- if eval echo \"$potent_lib\" 2>/dev/null \
- | ${SED} 10q \
- | egrep "$match_pattern_regex" > /dev/null; then
- a_deplib=""
- break 2
- fi
- done
- done
- droppeddeps=yes
- echo
- echo "*** with $libname but no candidates were found. (...for regex pattern test)"
- else
- echo "*** using a regex pattern. Last file checked: $potlib"
- fi
- fi
- else
- fi
- none | unknown | *)
- newdeplibs=""
- if $echo "X $deplibs" | $Xsed -e 's/ -lc$//' \
- -e 's/ -[LR][^ ]*//g' -e 's/[ ]//g' |
- grep . >/dev/null; then
- echo
- if test "X$deplibs_check_method" = "Xnone"; then
- echo "*** Warning: inter-library dependencies are not supported in this platform."
- else
- echo "*** Warning: inter-library dependencies are not known to be supported."
- fi
- echo "*** All declared inter-library dependencies are being dropped."
- droppeddeps=yes
- fi
- esac
- versuffix=$versuffix_save
- major=$major_save
- release=$release_save
- libname=$libname_save
- name=$name_save
- case $host in
- # On Rhapsody replace the C library is the System framework
- newdeplibs=`$echo "X $newdeplibs" | $Xsed -e 's/ -lc / -framework System /'`
- esac
- if test "$droppeddeps" = yes; then
- echo
- echo "*** Warning: libtool could not satisfy all declared inter-library"
- echo "*** dependencies of module $libname. Therefore, libtool will create"
- echo "*** a static module, that should work as long as the dlopening"
- echo "*** application is linked with the -dlopen flag."
- echo
- fi
- oldlibs="$output_objdir/$libname.$libext"
- else
- fi
- else
- echo "*** The inter-library dependencies that have been dropped here will be"
- echo "*** automatically added whenever a program is linked with this library"
- echo "*** or is declared to -dlopen it."
- if test $allow_undefined = no; then
- echo
- echo "*** Since this library must not contain undefined symbols,"
- echo "*** because either the platform does not support them or"
- echo "*** it was explicitly requested with -no-undefined,"
- echo "*** libtool will only create a static version of it."
- else
- fi
- fi
- fi
- fi
- # Done checking deplibs!
- deplibs=$newdeplibs
- fi
- # All the library-specific variables (install_libdir is set above).
- library_names=
- old_library=
- dlname=
- # Test again, we may have decided not to build it any more
- if test $hardcode_into_libs = yes; then
- # Hardcode the library paths
- hardcode_libdirs=
- dep_rpath=
- rpath="$finalize_rpath"
- test "$mode" != relink && rpath="$compile_rpath$rpath"
- for libdir in $rpath; do
- if test -n "$hardcode_libdir_flag_spec"; then
- if test -n "$hardcode_libdir_separator"; then
- if test -z "$hardcode_libdirs"; then
- hardcode_libdirs="$libdir"
- else
- # Just accumulate the unique libdirs.
- case $hardcode_libdir_separator$hardcode_libdirs$hardcode_libdir_separator in
- *"$hardcode_libdir_separator$libdir$hardcode_libdir_separator"*)
- hardcode_libdirs="$hardcode_libdirs$hardcode_libdir_separator$libdir"
- esac
- fi
- else
- eval flag=\"$hardcode_libdir_flag_spec\"
- dep_rpath="$dep_rpath $flag"
- fi
- elif test -n "$runpath_var"; then
- case "$perm_rpath " in
- *" $libdir "*) ;;
- *) perm_rpath="$perm_rpath $libdir" ;;
- esac
- fi
- done
- # Substitute the hardcoded libdirs into the rpath.
- if test -n "$hardcode_libdir_separator" &&
- test -n "$hardcode_libdirs"; then
- libdir="$hardcode_libdirs"
- eval dep_rpath=\"$hardcode_libdir_flag_spec\"
- fi
- if test -n "$runpath_var" && test -n "$perm_rpath"; then
- # We should set the runpath_var.
- rpath=
- for dir in $perm_rpath; do
- rpath="$rpath$dir:"
- done
- eval "$runpath_var='$rpath\$$runpath_var'; export $runpath_var"
- fi
- test -n "$dep_rpath" && deplibs="$dep_rpath $deplibs"
- fi
- shlibpath="$finalize_shlibpath"
- test "$mode" != relink && shlibpath="$compile_shlibpath$shlibpath"
- if test -n "$shlibpath"; then
- eval "$shlibpath_var='$shlibpath\$$shlibpath_var'; export $shlibpath_var"
- fi
- # Get the real and link names of the library.
- eval library_names=\"$library_names_spec\"
- realname="$2"
- shift; shift
- if test -n "$soname_spec"; then
- else
- fi
- test -z "$dlname" && dlname=$soname
- lib="$output_objdir/$realname"
- for link
- do
- linknames="$linknames $link"
- done
- # Ensure that we have .o objects for linkers which dislike .lo
- # (e.g. aix) in case we are running --disable-static
- for obj in $libobjs; do
- xdir="."
- else
- xdir="$xdir"
- fi
- baseobj=`$echo "X$obj" | $Xsed -e 's%^.*/%%'`
- oldobj=`$echo "X$baseobj" | $Xsed -e "$lo2o"`
- if test ! -f $xdir/$oldobj; then
- $show "(cd $xdir && ${LN_S} $baseobj $oldobj)"
- $run eval '(cd $xdir && ${LN_S} $baseobj $oldobj)' || exit $?
- fi
- done
- # Use standard objects if they are pic
- test -z "$pic_flag" && libobjs=`$echo "X$libobjs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- # Prepare the list of exported symbols
- if test -z "$export_symbols"; then
- if test "$always_export_symbols" = yes || test -n "$export_symbols_regex"; then
- $show "generating symbol list for \`$libname.la'"
- export_symbols="$output_objdir/$libname.exp"
- $run $rm $export_symbols
- eval cmds=\"$export_symbols_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- if test -n "$export_symbols_regex"; then
- $show "egrep -e \"$export_symbols_regex\" \"$export_symbols\" > \"${export_symbols}T\""
- $run eval 'egrep -e "$export_symbols_regex" "$export_symbols" > "${export_symbols}T"'
- $show "$mv \"${export_symbols}T\" \"$export_symbols\""
- $run eval '$mv "${export_symbols}T" "$export_symbols"'
- fi
- fi
- fi
- if test -n "$export_symbols" && test -n "$include_expsyms"; then
- $run eval '$echo "X$include_expsyms" | $SP2NL >> "$export_symbols"'
- fi
- if test -n "$convenience"; then
- if test -n "$whole_archive_flag_spec"; then
- eval libobjs=\"\$libobjs $whole_archive_flag_spec\"
- else
- gentop="$output_objdir/${outputname}x"
- $show "${rm}r $gentop"
- $run ${rm}r "$gentop"
- $show "mkdir $gentop"
- $run mkdir "$gentop"
- status=$?
- if test $status -ne 0 && test ! -d "$gentop"; then
- exit $status
- fi
- generated="$generated $gentop"
- for xlib in $convenience; do
- # Extract the objects.
- case $xlib in
- [\\/]* | [A-Za-z]:[\\/]*) xabs="$xlib" ;;
- *) xabs=`pwd`"/$xlib" ;;
- esac
- xlib=`$echo "X$xlib" | $Xsed -e 's%^.*/%%'`
- xdir="$gentop/$xlib"
- $show "${rm}r $xdir"
- $run ${rm}r "$xdir"
- $show "mkdir $xdir"
- $run mkdir "$xdir"
- status=$?
- if test $status -ne 0 && test ! -d "$xdir"; then
- exit $status
- fi
- $show "(cd $xdir && $AR x $xabs)"
- $run eval "(cd \$xdir && $AR x \$xabs)" || exit $?
- libobjs="$libobjs "`find $xdir -name \*.o -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- fi
- if test "$thread_safe" = yes && test -n "$thread_safe_flag_spec"; then
- eval flag=\"$thread_safe_flag_spec\"
- fi
- # Make a backup of the uninstalled library when relinking
- if test "$mode" = relink; then
- $run eval '(cd $output_objdir && $rm ${realname}U && $mv $realname ${realname}U)' || exit $?
- fi
- # Do each of the archive commands.
- if test -n "$export_symbols" && test -n "$archive_expsym_cmds"; then
- eval cmds=\"$archive_expsym_cmds\"
- else
- for conv in $convenience; do
- tmp_deplibs=
- for test_deplib in $deplibs; do
- if test "$test_deplib" != "$conv"; then
- tmp_deplibs="$tmp_deplibs $test_deplib"
- fi
- done
- deplibs="$tmp_deplibs"
- done
- eval cmds=\"$archive_cmds\"
- deplibs="$save_deplibs"
- fi
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- # Restore the uninstalled library and exit
- $run eval '(cd $output_objdir && $rm ${realname}T && $mv $realname ${realname}T && $mv "$realname"U $realname)' || exit $?
- exit 0
- fi
- # Create links to the real library.
- for linkname in $linknames; do
- if test "$realname" != "$linkname"; then
- $show "(cd $output_objdir && $rm $linkname && $LN_S $realname $linkname)"
- $run eval '(cd $output_objdir && $rm $linkname && $LN_S $realname $linkname)' || exit $?
- fi
- done
- # If -module or -export-dynamic was specified, set the dlname.
- if test "$module" = yes || test "$export_dynamic" = yes; then
- # On all known operating systems, these are identical.
- dlname="$soname"
- fi
- fi
- obj)
- if test -n "$deplibs"; then
- $echo "$modename: warning: \`-l' and \`-L' are ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-dlopen' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-rpath' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-R' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-version-info' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for objects" 1>&2
- fi
- case $output in
- *.lo)
- if test -n "$objs$old_deplibs"; then
- $echo "$modename: cannot build library object \`$output' from non-libtool objects" 1>&2
- exit 1
- fi
- libobj="$output"
- obj=`$echo "X$output" | $Xsed -e "$lo2o"`
- libobj=
- obj="$output"
- esac
- # Delete the old objects.
- $run $rm $obj $libobj
- # Objects from convenience libraries. This assumes
- # single-version convenience libraries. Whenever we create
- # different ones for PIC/non-PIC, this we'll have to duplicate
- # the extraction.
- reload_conv_objs=
- gentop=
- # reload_cmds runs $LD directly, so let us get rid of
- # -Wl from whole_archive_flag_spec
- wl=
- eval reload_conv_objs=\"\$reload_objs $whole_archive_flag_spec\"
- else
- gentop="$output_objdir/${obj}x"
- status=$?
- exit $status
- fi
- case $xlib in
- esac
- status=$?
- exit $status
- fi
- reload_conv_objs="$reload_objs "`find $xdir -name \*.o -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- fi
- # Create the old-style object.
- reload_objs="$objs$old_deplibs "`$echo "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}$'/d' -e '/\.lib$/d' -e "$lo2o" | $NL2SP`" $reload_conv_objs" ### testsuite: skip nested quoting test
- output="$obj"
- eval cmds=\"$reload_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- # Exit if we aren't doing a library object file.
- if test -z "$libobj"; then
- if test -n "$gentop"; then
- $run ${rm}r $gentop
- fi
- exit 0
- fi
- fi
- # Create an invalid libtool object if no PIC, so that we don't
- $run eval "echo timestamp > $libobj" || exit $?
- exit 0
- fi
- if test -n "$pic_flag" || test "$pic_mode" != default; then
- # Only do commands if we really have different PIC objects.
- reload_objs="$libobjs $reload_conv_objs"
- output="$libobj"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- else
- # Just create a symlink.
- $show $rm $libobj
- $run $rm $libobj
- xdir=`$echo "X$libobj" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$xdir" = "X$libobj"; then
- xdir="."
- else
- xdir="$xdir"
- fi
- baseobj=`$echo "X$libobj" | $Xsed -e 's%^.*/%%'`
- $show "(cd $xdir && $LN_S $oldobj $baseobj)"
- $run eval '(cd $xdir && $LN_S $oldobj $baseobj)' || exit $?
- fi
- fi
- exit 0
- prog)
- case $host in
- *cygwin*) output=`echo $output | ${SED} -e 's,.exe$,,;s,$,.exe,'` ;;
- esac
- $echo "$modename: warning: \`-version-info' is ignored for programs" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for programs" 1>&2
- fi
- if test "$preload" = yes; then
- if test "$dlopen_support" = unknown && test "$dlopen_self" = unknown &&
- test "$dlopen_self_static" = unknown; then
- $echo "$modename: warning: \`AC_LIBTOOL_DLOPEN' not used. Assuming no dlopen support."
- fi
- fi
- case $host in
- compile_deplibs=`$echo "X $compile_deplibs" | $Xsed -e 's/ -lc / -framework System /'`
- finalize_deplibs=`$echo "X $finalize_deplibs" | $Xsed -e 's/ -lc / -framework System /'`
- case $host in
- *darwin*)
- # Don't allow lazy linking, it breaks C++ global constructors
- compile_command="$compile_command ${wl}-bind_at_load"
- finalize_command="$finalize_command ${wl}-bind_at_load"
- esac
- esac
- compile_command="$compile_command $compile_deplibs"
- finalize_command="$finalize_command $finalize_deplibs"
- if test -n "$rpath$xrpath"; then
- for libdir in $rpath $xrpath; do
- # This is the magic to use -rpath.
- *" $libdir "*) ;;
- esac
- done
- fi
- # Now hardcode the library paths
- rpath=
- hardcode_libdirs=
- for libdir in $compile_rpath $finalize_rpath; do
- else
- esac
- fi
- else
- rpath="$rpath $flag"
- fi
- *" $libdir "*) ;;
- esac
- fi
- case $host in
- *":$libdir:"*) ;;
- *) dllsearchpath="$dllsearchpath:$libdir";;
- esac
- esac
- done
- eval rpath=\" $hardcode_libdir_flag_spec\"
- fi
- compile_rpath="$rpath"
- rpath=
- hardcode_libdirs=
- for libdir in $finalize_rpath; do
- else
- esac
- fi
- else
- fi
- case "$finalize_perm_rpath " in
- *" $libdir "*) ;;
- *) finalize_perm_rpath="$finalize_perm_rpath $libdir" ;;
- esac
- fi
- done
- fi
- finalize_rpath="$rpath"
- if test -n "$libobjs" && test "$build_old_libs" = yes; then
- # Transform all the library objects into standard objects.
- compile_command=`$echo "X$compile_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- finalize_command=`$echo "X$finalize_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- fi
- dlsyms=
- if test -n "$NM" && test -n "$global_symbol_pipe"; then
- dlsyms="${outputname}S.c"
- else
- $echo "$modename: not configured to extract global symbols from dlpreopened files" 1>&2
- fi
- fi
- if test -n "$dlsyms"; then
- case $dlsyms in
- *.c)
- # Discover the nlist of each of the dlfiles.
- nlist="$output_objdir/${outputname}.nm"
- $show "$rm $nlist ${nlist}S ${nlist}T"
- $run $rm "$nlist" "${nlist}S" "${nlist}T"
- # Parse the name list into a source file.
- $show "creating $output_objdir/$dlsyms"
- test -z "$run" && $echo > "$output_objdir/$dlsyms" "\
-/* $dlsyms - symbol resolution table for \`$outputname' dlsym emulation. */
-/* Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP */
-#ifdef __cplusplus
-extern \"C\" {
-#endif
-/* Prevent the only kind of declaration conflicts we can make. */
-#define lt_preloaded_symbols some_other_symbol
-/* External symbol declarations for the compiler. */\
- if test "$dlself" = yes; then
- $show "generating symbol list for \`$output'"
- test -z "$run" && $echo ': @PROGRAM@ ' > "$nlist"
- # Add our own program objects to the symbol list.
- progfiles=`$echo "X$objs$old_deplibs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- for arg in $progfiles; do
- $show "extracting global C symbols from \`$arg'"
- $run eval "$NM $arg | $global_symbol_pipe >> '$nlist'"
- done
- if test -n "$exclude_expsyms"; then
- $run eval 'egrep -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T'
- $run eval '$mv "$nlist"T "$nlist"'
- fi
- $run eval 'egrep -e "$export_symbols_regex" "$nlist" > "$nlist"T'
- fi
- export_symbols="$output_objdir/$output.exp"
- $run eval "${SED} -n -e '/^: @PROGRAM@$/d' -e 's/^.* \(.*\)$/\1/p' "'< "$nlist" > "$export_symbols"'
- else
- $run eval "${SED} -e 's/\([][.*^$]\)/\\\1/g' -e 's/^/ /' -e 's/$/$/'"' < "$export_symbols" > "$output_objdir/$output.exp"'
- $run eval 'grep -f "$output_objdir/$output.exp" < "$nlist" > "$nlist"T'
- $run eval 'mv "$nlist"T "$nlist"'
- fi
- fi
- for arg in $dlprefiles; do
- name=`echo "$arg" | ${SED} -e 's%^.*/%%'`
- $run eval 'echo ": $name " >> "$nlist"'
- done
- if test -z "$run"; then
- # Make sure we have at least an empty file.
- test -f "$nlist" || : > "$nlist"
- egrep -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T
- $mv "$nlist"T "$nlist"
- fi
- # Try sorting and uniquifying the output.
- if grep -v "^: " < "$nlist" |
- if sort -k 3 </dev/null >/dev/null 2>&1; then
- sort -k 3
- else
- sort +2
- fi |
- uniq > "$nlist"S; then
- else
- grep -v "^: " < "$nlist" > "$nlist"S
- fi
- if test -f "$nlist"S; then
- eval "$global_symbol_to_cdecl"' < "$nlist"S >> "$output_objdir/$dlsyms"'
- else
- echo '/* NONE */' >> "$output_objdir/$dlsyms"
- fi
- $echo >> "$output_objdir/$dlsyms" "\
-#undef lt_preloaded_symbols
-#if defined (__STDC__) && __STDC__
-# define lt_ptr void *
-#else
-# define lt_ptr char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr address;
-lt_preloaded_symbols[] =
- eval "$global_symbol_to_c_name_address" < "$nlist" >> "$output_objdir/$dlsyms"
- {0, (lt_ptr) 0}
-/* This works around a problem in FreeBSD linker */
-#ifdef FREEBSD_WORKAROUND
-static const void *lt_preloaded_setup() {
- return lt_preloaded_symbols;
-#endif
-#ifdef __cplusplus
-#endif\
- fi
- pic_flag_for_symtable=
- case $host in
- # compiling the symbol table file with pic_flag works around
- # a FreeBSD bug that causes programs to crash when -lm is
- # linked before any other PIC object. But we must not use
- # pic_flag when linking with -static. The problem exists in
- # FreeBSD 2.2.6 and is fixed in FreeBSD 3.1.
- *-*-freebsd2*|*-*-freebsd3.0*|*-*-freebsdelf3.0*)
- case "$compile_command " in
- *" -static "*) ;;
- *) pic_flag_for_symtable=" $pic_flag -DPIC -DFREEBSD_WORKAROUND";;
- esac;;
- *-*-hpux*)
- *" -static "*) ;;
- *) pic_flag_for_symtable=" $pic_flag -DPIC";;
- esac
- esac
- # Now compile the dynamic symbol file.
- $show "(cd $output_objdir && $CC -c$no_builtin_flag$pic_flag_for_symtable \"$dlsyms\")"
- $run eval '(cd $output_objdir && $CC -c$no_builtin_flag$pic_flag_for_symtable "$dlsyms")' || exit $?
- # Clean up the generated files.
- $show "$rm $output_objdir/$dlsyms $nlist ${nlist}S ${nlist}T"
- $run $rm "$output_objdir/$dlsyms" "$nlist" "${nlist}S" "${nlist}T"
- # Transform the symbol file into the correct name.
- compile_command=`$echo "X$compile_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/${outputname}S.${objext}%"`
- finalize_command=`$echo "X$finalize_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/${outputname}S.${objext}%"`
- $echo "$modename: unknown suffix for \`$dlsyms'" 1>&2
- exit 1
- esac
- else
- # We keep going just in case the user didn't refer to
- # lt_preloaded_symbols. The linker will fail if global_symbol_pipe
- # really was required.
- # Nullify the symbol file.
- compile_command=`$echo "X$compile_command" | $Xsed -e "s% @SYMFILE@%%"`
- finalize_command=`$echo "X$finalize_command" | $Xsed -e "s% @SYMFILE@%%"`
- fi
- if test $need_relink = no || test "$build_libtool_libs" != yes; then
- # Replace the output file specification.
- compile_command=`$echo "X$compile_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
- link_command="$compile_command$compile_rpath"
- # We have no uninstalled library dependencies, so finalize right now.
- $show "$link_command"
- $run eval "$link_command"
- status=$?
- # Delete the generated files.
- $show "$rm $output_objdir/${outputname}S.${objext}"
- $run $rm "$output_objdir/${outputname}S.${objext}"
- fi
- exit $status
- fi
- # We should set the shlibpath_var
- rpath=
- for dir in $temp_rpath; do
- case $dir in
- # Absolute path.
- # Relative path: add a thisdir entry.
- rpath="$rpath\$thisdir/$dir:"
- esac
- done
- temp_rpath="$rpath"
- fi
- if test -n "$compile_shlibpath$finalize_shlibpath"; then
- compile_command="$shlibpath_var=\"$compile_shlibpath$finalize_shlibpath\$$shlibpath_var\" $compile_command"
- fi
- if test -n "$finalize_shlibpath"; then
- finalize_command="$shlibpath_var=\"$finalize_shlibpath\$$shlibpath_var\" $finalize_command"
- fi
- compile_var=
- finalize_var=
- if test -n "$runpath_var"; then
- if test -n "$perm_rpath"; then
- rpath=
- done
- compile_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- if test -n "$finalize_perm_rpath"; then
- rpath=
- for dir in $finalize_perm_rpath; do
- done
- finalize_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- fi
- if test "$no_install" = yes; then
- # We don't need to create a wrapper script.
- link_command="$compile_var$compile_command$compile_rpath"
- link_command=`$echo "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
- # Delete the old output file.
- $run $rm $output
- # Link the executable and exit
- $run eval "$link_command" || exit $?
- exit 0
- fi
- if test "$hardcode_action" = relink; then
- # Fast installation is not supported
- relink_command="$finalize_var$finalize_command$finalize_rpath"
- $echo "$modename: warning: this platform does not like uninstalled shared libraries" 1>&2
- $echo "$modename: \`$output' will be relinked during installation" 1>&2
- else
- if test "$fast_install" != no; then
- link_command="$finalize_var$compile_command$finalize_rpath"
- if test "$fast_install" = yes; then
- relink_command=`$echo "X$compile_var$compile_command$compile_rpath" | $Xsed -e 's%@OUTPUT@%\$progdir/\$file%g'`
- else
- # fast_install is set to needless
- relink_command=
- fi
- else
- fi
- fi
- link_command=`$echo "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output_objdir/$outputname"'%g'`
- # Delete the old output files.
- $run $rm $output $output_objdir/$outputname $output_objdir/lt-$outputname
- # Now create the wrapper script.
- $show "creating $output"
- # Quote the relink command for shipping.
- if test -n "$relink_command"; then
- # Preserve any variables that may affect compiler behavior
- for var in $variables_saved_for_relink; do
- if eval test -z \"\${$var+set}\"; then
- relink_command="{ test -z \"\${$var+set}\" || unset $var || { $var=; export $var; }; }; $relink_command"
- elif eval var_value=\$$var; test -z "$var_value"; then
- relink_command="$var=; export $var; $relink_command"
- else
- var_value=`$echo "X$var_value" | $Xsed -e "$sed_quote_subst"`
- relink_command="$var=\"$var_value\"; export $var; $relink_command"
- fi
- done
- relink_command="(cd `pwd`; $relink_command)"
- relink_command=`$echo "X$relink_command" | $Xsed -e "$sed_quote_subst"`
- fi
- # Quote $echo for shipping.
- if test "X$echo" = "X$SHELL $0 --fallback-echo"; then
- case $0 in
- [\\/]* | [A-Za-z]:[\\/]*) qecho="$SHELL $0 --fallback-echo";;
- *) qecho="$SHELL `pwd`/$0 --fallback-echo";;
- esac
- qecho=`$echo "X$qecho" | $Xsed -e "$sed_quote_subst"`
- else
- qecho=`$echo "X$echo" | $Xsed -e "$sed_quote_subst"`
- fi
- # Only actually do things if our run command is non-null.
- # win32 will think the script is a binary if it has
- # a .exe suffix, so we strip it off here.
- case $output in
- *.exe) output=`echo $output|${SED} 's,.exe$,,'` ;;
- esac
- # test for cygwin because mv fails w/o .exe extensions
- case $host in
- *cygwin*) exeext=.exe ;;
- *) exeext= ;;
- esac
- $rm $output
- trap "$rm $output; exit 1" 1 2 15
- $echo > $output "\
-#! $SHELL
-# $output - temporary wrapper script for $objdir/$outputname
-# Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP
-# The $output program cannot be directly executed until all the libtool
-# libraries that it depends on are installed.
-# This wrapper script should never be moved out of the build directory.
-# If it is, it will not operate correctly.
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed="${SED}"' -e 1s/^X//'
-sed_quote_subst='$sed_quote_subst'
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test \"\${CDPATH+set}\" = set; then CDPATH=:; export CDPATH; fi
-relink_command=\"$relink_command\"
-# This environment variable determines our operation mode.
-if test \"\$libtool_install_magic\" = \"$magic\"; then
- # install mode needs the following variable:
- notinst_deplibs='$notinst_deplibs'
-else
- # When we are sourced in execute mode, \$file and \$echo are already set.
- if test \"\$libtool_execute_magic\" != \"$magic\"; then
- echo=\"$qecho\"
- file=\"\$0\"
- # Make sure echo works.
- if test \"X\$1\" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
- elif test \"X\`(\$echo '\t') 2>/dev/null\`\" = 'X\t'; then
- # Yippee, \$echo works!
- else
- # Restart under the correct shell, and then maybe \$echo will work.
- exec $SHELL \"\$0\" --no-reexec \${1+\"\$@\"}
- fi
- fi\
- $echo >> $output "\
- # Find the directory that this script lives in.
- thisdir=\`\$echo \"X\$file\" | \$Xsed -e 's%/[^/]*$%%'\`
- test \"x\$thisdir\" = \"x\$file\" && thisdir=.
- # Follow symbolic links until we get to the real thisdir.
- file=\`ls -ld \"\$file\" | ${SED} -n 's/.*-> //p'\`
- while test -n \"\$file\"; do
- destdir=\`\$echo \"X\$file\" | \$Xsed -e 's%/[^/]*\$%%'\`
- # If there was a directory component, then change thisdir.
- if test \"x\$destdir\" != \"x\$file\"; then
- case \"\$destdir\" in
- [\\\\/]* | [A-Za-z]:[\\\\/]*) thisdir=\"\$destdir\" ;;
- *) thisdir=\"\$thisdir/\$destdir\" ;;
- esac
- fi
- file=\`\$echo \"X\$file\" | \$Xsed -e 's%^.*/%%'\`
- file=\`ls -ld \"\$thisdir/\$file\" | ${SED} -n 's/.*-> //p'\`
- done
- # Try to get the absolute directory name.
- absdir=\`cd \"\$thisdir\" && pwd\`
- test -n \"\$absdir\" && thisdir=\"\$absdir\"
- echo >> $output "\
- program=lt-'$outputname'$exeext
- progdir=\"\$thisdir/$objdir\"
- if test ! -f \"\$progdir/\$program\" || \\
- { file=\`ls -1dt \"\$progdir/\$program\" \"\$progdir/../\$program\" 2>/dev/null | ${SED} 1q\`; \\
- test \"X\$file\" != \"X\$progdir/\$program\"; }; then
- file=\"\$\$-\$program\"
- if test ! -d \"\$progdir\"; then
- $mkdir \"\$progdir\"
- else
- $rm \"\$progdir/\$file\"
- fi"
- # relink executable if necessary
- if test -n \"\$relink_command\"; then
- if relink_command_output=\`eval \$relink_command 2>&1\`; then :
- else
- $echo \"\$relink_command_output\" >&2
- exit 1
- fi
- fi
- $mv \"\$progdir/\$file\" \"\$progdir/\$program\" 2>/dev/null ||
- { $rm \"\$progdir/\$program\";
- $mv \"\$progdir/\$file\" \"\$progdir/\$program\"; }
- fi"
- else
- program='$outputname'
- fi
- if test -f \"\$progdir/\$program\"; then"
- # Export our shlibpath_var if we have one.
- if test "$shlibpath_overrides_runpath" = yes && test -n "$shlibpath_var" && test -n "$temp_rpath"; then
- # Add our own library path to $shlibpath_var
- $shlibpath_var=\"$temp_rpath\$$shlibpath_var\"
- # Some systems cannot cope with colon-terminated $shlibpath_var
- # The second colon is a workaround for a bug in BeOS R4 ${SED}
- $shlibpath_var=\`\$echo \"X\$$shlibpath_var\" | \$Xsed -e 's/::*\$//'\`
- export $shlibpath_var
- fi
- # fixup the dll searchpath if we need to.
- if test -n "$dllsearchpath"; then
- # Add the dll search path components to the executable PATH
- PATH=$dllsearchpath:\$PATH
- fi
- # Run the actual program with our arguments.
- case $host in
- # win32 systems need to use the prog path for dll
- # lookup to work
- *-*-cygwin* | *-*-pw32*)
- exec \$progdir/\$program \${1+\"\$@\"}
- # Backslashes separate directories on plain windows
- *-*-mingw | *-*-os2*)
- exec \$progdir\\\\\$program \${1+\"\$@\"}
- # Export the path to the program.
- PATH=\"\$progdir:\$PATH\"
- export PATH
- exec \$program \${1+\"\$@\"}
- esac
- \$echo \"\$0: cannot exec \$program \${1+\"\$@\"}\"
- exit 1
- fi
- else
- # The program doesn't exist.
- \$echo \"\$0: error: \$progdir/\$program does not exist\" 1>&2
- \$echo \"This script is just a wrapper for \$program.\" 1>&2
- echo \"See the $PACKAGE documentation for more information.\" 1>&2
- exit 1
- fi
-fi\
- chmod +x $output
- fi
- exit 0
- esac
- # See if we need to build an old-fashioned archive.
- for oldlib in $oldlibs; do
- if test "$build_libtool_libs" = convenience; then
- oldobjs="$libobjs_save"
- addlibs="$convenience"
- build_libtool_libs=no
- else
- if test "$build_libtool_libs" = module; then
- else
- oldobjs="$objs$old_deplibs "`$echo "X$libobjs_save" | $SP2NL | $Xsed -e '/\.'${libext}'$/d' -e '/\.lib$/d' -e "$lo2o" | $NL2SP`
- fi
- addlibs="$old_convenience"
- fi
- if test -n "$addlibs"; then
- status=$?
- exit $status
- fi
- # Add in members from convenience archives.
- for xlib in $addlibs; do
- case $xlib in
- esac
- status=$?
- exit $status
- fi
- oldobjs="$oldobjs "`find $xdir -name \*.${objext} -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- # Do each command in the archive commands.
- if test -n "$old_archive_from_new_cmds" && test "$build_libtool_libs" = yes; then
- eval cmds=\"$old_archive_from_new_cmds\"
- else
- # Ensure that we have .o objects in place in case we decided
- # not to build a shared library, and have fallen back to building
- # static libs even though --disable-static was passed!
- for oldobj in $oldobjs; do
- if test ! -f $oldobj; then
- xdir=`$echo "X$oldobj" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$xdir" = "X$oldobj"; then
- xdir="."
- else
- xdir="$xdir"
- fi
- baseobj=`$echo "X$oldobj" | $Xsed -e 's%^.*/%%'`
- obj=`$echo "X$baseobj" | $Xsed -e "$o2lo"`
- $show "(cd $xdir && ${LN_S} $obj $baseobj)"
- $run eval '(cd $xdir && ${LN_S} $obj $baseobj)' || exit $?
- fi
- done
- eval cmds=\"$old_archive_cmds\"
- fi
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- done
- if test -n "$generated"; then
- $show "${rm}r$generated"
- $run ${rm}r$generated
- fi
- # Now create the libtool archive.
- case $output in
- *.la)
- old_library=
- test "$build_old_libs" = yes && old_library="$libname.$libext"
- else
- fi
- done
- # Quote the link command for shipping.
- relink_command="(cd `pwd`; $SHELL $0 --mode=relink $libtool_args @inst_prefix_dir@)"
- # Only create the output if not a dry run.
- for installed in no yes; do
- if test "$installed" = yes; then
- if test -z "$install_libdir"; then
- break
- fi
- output="$output_objdir/$outputname"i
- # Replace all uninstalled libtool libraries with the installed ones
- case $deplib in
- *.la)
- name=`$echo "X$deplib" | $Xsed -e 's%^.*/%%'`
- exit 1
- fi
- newdependency_libs="$newdependency_libs $libdir/$name"
- *) newdependency_libs="$newdependency_libs $deplib" ;;
- esac
- done
- dependency_libs="$newdependency_libs"
- newdlfiles=
- for lib in $dlfiles; do
- name=`$echo "X$lib" | $Xsed -e 's%^.*/%%'`
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $lib`
- exit 1
- fi
- newdlfiles="$newdlfiles $libdir/$name"
- done
- newdlprefiles=
- for lib in $dlprefiles; do
- exit 1
- fi
- newdlprefiles="$newdlprefiles $libdir/$name"
- done
- fi
- $rm $output
- # place dlname in correct position for cygwin
- tdlname=$dlname
- case $host,$output,$installed,$module,$dlname in
- *cygwin*,*lai,yes,no,*.dll) tdlname=../bin/$dlname ;;
- esac
-# $outputname - a libtool library file
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# The name that we can dlopen(3).
-dlname='$tdlname'
-# Names of this library.
-library_names='$library_names'
-# The name of the static archive.
-old_library='$old_library'
-# Libraries that this one depends upon.
-dependency_libs='$dependency_libs'
-# Version information for $libname.
-current=$current
-age=$age
-revision=$revision
-# Is this an already installed library?
-installed=$installed
-# Files to dlopen/dlpreopen
-dlopen='$dlfiles'
-dlpreopen='$dlprefiles'
-# Directory that this library needs to be installed in:
-libdir='$install_libdir'"
- if test "$installed" = no && test $need_relink = yes; then
-relink_command=\"$relink_command\""
- fi
- done
- fi
- # Do a symbolic link so that the libtool archive can be found in
- # LD_LIBRARY_PATH before the program is installed.
- $show "(cd $output_objdir && $rm $outputname && $LN_S ../$outputname $outputname)"
- $run eval '(cd $output_objdir && $rm $outputname && $LN_S ../$outputname $outputname)' || exit $?
- esac
- exit 0
- # libtool install mode
- install)
- modename="$modename: install"
- # There may be an optional sh(1) argument at the beginning of
- # install_prog (especially on Windows NT).
- if test "$nonopt" = "$SHELL" || test "$nonopt" = /bin/sh ||
- # Allow the use of GNU shtool's install command.
- $echo "X$nonopt" | $Xsed | grep shtool > /dev/null; then
- # Aesthetically quote it.
- arg=`$echo "X$nonopt" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$arg "
- arg="$1"
- shift
- else
- install_prog=
- arg="$nonopt"
- fi
- # The real first argument should be the name of the installation program.
- arg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$install_prog$arg"
- # We need to accept at least all the BSD install flags.
- dest=
- files=
- opts=
- prev=
- install_type=
- isdir=no
- stripme=
- for arg
- do
- if test -n "$dest"; then
- files="$files $dest"
- dest="$arg"
- continue
- fi
- case $arg in
- -d) isdir=yes ;;
- -f) prev="-f" ;;
- -g) prev="-g" ;;
- -m) prev="-m" ;;
- -o) prev="-o" ;;
- -s)
- stripme=" -s"
- continue
- # If the previous option needed an argument, then skip it.
- if test -n "$prev"; then
- prev=
- else
- dest="$arg"
- continue
- fi
- esac
- # Aesthetically quote the argument.
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$install_prog $arg"
- done
- if test -z "$install_prog"; then
- $echo "$modename: you must specify an install program" 1>&2
- $echo "$help" 1>&2
- exit 1
- fi
- $echo "$modename: the \`$prev' option requires an argument" 1>&2
- exit 1
- fi
- if test -z "$files"; then
- if test -z "$dest"; then
- $echo "$modename: no file or destination specified" 1>&2
- else
- $echo "$modename: you must specify a destination" 1>&2
- fi
- exit 1
- fi
- # Strip any trailing slash from the destination.
- dest=`$echo "X$dest" | $Xsed -e 's%/$%%'`
- # Check to see that the destination is a directory.
- test -d "$dest" && isdir=yes
- if test "$isdir" = yes; then
- destdir="$dest"
- destname=
- else
- destdir=`$echo "X$dest" | $Xsed -e 's%/[^/]*$%%'`
- test "X$destdir" = "X$dest" && destdir=.
- destname=`$echo "X$dest" | $Xsed -e 's%^.*/%%'`
- # Not a directory, so check to see that there is only one file specified.
- set dummy $files
- $echo "$modename: \`$dest' is not a directory" 1>&2
- exit 1
- fi
- fi
- case $destdir in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- for file in $files; do
- case $file in
- *.lo) ;;
- $echo "$modename: \`$destdir' must be an absolute directory name" 1>&2
- exit 1
- esac
- done
- esac
- # This variable tells wrapper scripts just to set variables rather
- # than running their programs.
- libtool_install_magic="$magic"
- staticlibs=
- future_libdirs=
- current_libdirs=
- # Do each installation.
- case $file in
- *.$libext)
- # Do the static libraries later.
- staticlibs="$staticlibs $file"
- *.la)
- # Check to see that this really is a libtool archive.
- if (${SED} -e '2q' $file | egrep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then :
- else
- $echo "$modename: \`$file' is not a valid libtool archive" 1>&2
- exit 1
- fi
- library_names=
- old_library=
- relink_command=
- # If there is no directory component, then add one.
- case $file in
- */* | *\\*) . $file ;;
- *) . ./$file ;;
- esac
- # Add the libdir to current_libdirs if it is the destination.
- if test "X$destdir" = "X$libdir"; then
- case "$current_libdirs " in
- *" $libdir "*) ;;
- *) current_libdirs="$current_libdirs $libdir" ;;
- esac
- else
- # Note the libdir as a future libdir.
- case "$future_libdirs " in
- *" $libdir "*) ;;
- *) future_libdirs="$future_libdirs $libdir" ;;
- esac
- fi
- dir=`$echo "X$file" | $Xsed -e 's%/[^/]*$%%'`/
- test "X$dir" = "X$file/" && dir=
- dir="$dir$objdir"
- # Determine the prefix the user has applied to our future dir.
- inst_prefix_dir=`$echo "$destdir" | sed "s%$libdir\$%%"`
- # Don't allow the user to place us outside of our expected
- # location b/c this prevents finding dependent libraries that
- # are installed to the same prefix.
- if test "$inst_prefix_dir" = "$destdir"; then
- $echo "$modename: error: cannot install \`$file' to a directory not ending in $libdir" 1>&2
- exit 1
- fi
- # Stick the inst_prefix_dir data into the link command.
- relink_command=`$echo "$relink_command" | sed "s%@inst_prefix_dir@%-inst-prefix-dir $inst_prefix_dir%"`
- else
- relink_command=`$echo "$relink_command" | sed "s%@inst_prefix_dir@%%"`
- fi
- $echo "$modename: warning: relinking \`$file'" 1>&2
- $show "$relink_command"
- if $run eval "$relink_command"; then :
- else
- $echo "$modename: error: relink \`$file' with the above command before installing it" 1>&2
- exit 1
- fi
- fi
- # See the names of the shared library.
- if test -n "$2"; then
- realname="$2"
- shift
- shift
- srcname="$realname"
- test -n "$relink_command" && srcname="$realname"T
- # Install the shared library and build the symlinks.
- $show "$install_prog $dir/$srcname $destdir/$realname"
- $run eval "$install_prog $dir/$srcname $destdir/$realname" || exit $?
- if test -n "$stripme" && test -n "$striplib"; then
- $show "$striplib $destdir/$realname"
- $run eval "$striplib $destdir/$realname" || exit $?
- fi
- if test $# -gt 0; then
- # Delete the old symlinks, and create new ones.
- for linkname
- do
- if test "$linkname" != "$realname"; then
- $show "(cd $destdir && $rm $linkname && $LN_S $realname $linkname)"
- $run eval "(cd $destdir && $rm $linkname && $LN_S $realname $linkname)"
- fi
- done
- fi
- # Do each command in the postinstall commands.
- lib="$destdir/$realname"
- eval cmds=\"$postinstall_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- fi
- # Install the pseudo-library for information purposes.
- name=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
- instname="$dir/$name"i
- $show "$install_prog $instname $destdir/$name"
- $run eval "$install_prog $instname $destdir/$name" || exit $?
- # Maybe install the static library, too.
- test -n "$old_library" && staticlibs="$staticlibs $dir/$old_library"
- *.lo)
- # Install (i.e. copy) a libtool object.
- # Figure out destination file name, if it wasn't already specified.
- if test -n "$destname"; then
- destfile="$destdir/$destname"
- else
- destfile=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
- destfile="$destdir/$destfile"
- fi
- # Deduce the name of the destination old-style object file.
- case $destfile in
- *.lo)
- staticdest=`$echo "X$destfile" | $Xsed -e "$lo2o"`
- *.$objext)
- staticdest="$destfile"
- destfile=
- $echo "$modename: cannot copy a libtool object to \`$destfile'" 1>&2
- exit 1
- esac
- # Install the libtool object if requested.
- if test -n "$destfile"; then
- $show "$install_prog $file $destfile"
- $run eval "$install_prog $file $destfile" || exit $?
- fi
- # Install the old object if enabled.
- if test "$build_old_libs" = yes; then
- # Deduce the name of the old-style object file.
- staticobj=`$echo "X$file" | $Xsed -e "$lo2o"`
- $show "$install_prog $staticobj $staticdest"
- $run eval "$install_prog \$staticobj \$staticdest" || exit $?
- fi
- exit 0
- else
- fi
- # Do a test to see if this is really a libtool program.
- case $host in
- *cygwin*|*mingw*)
- wrapper=`echo $file | ${SED} -e 's,.exe$,,'`
- wrapper=$file
- esac
- if (${SED} -e '4q' $wrapper | egrep "^# Generated by .*$PACKAGE")>/dev/null 2>&1; then
- notinst_deplibs=
- relink_command=
- case $file in
- */* | *\\*) . $wrapper ;;
- *) . ./$wrapper ;;
- esac
- # Check the variables that should have been set.
- if test -z "$notinst_deplibs"; then
- $echo "$modename: invalid libtool wrapper script \`$wrapper'" 1>&2
- exit 1
- fi
- finalize=yes
- for lib in $notinst_deplibs; do
- # Check to see that each library is installed.
- libdir=
- if test -f "$lib"; then
- case $lib in
- */* | *\\*) . $lib ;;
- *) . ./$lib ;;
- esac
- fi
- libfile="$libdir/"`$echo "X$lib" | $Xsed -e 's%^.*/%%g'` ### testsuite: skip nested quoting test
- if test -n "$libdir" && test ! -f "$libfile"; then
- $echo "$modename: warning: \`$lib' has not been installed in \`$libdir'" 1>&2
- finalize=no
- fi
- done
- relink_command=
- case $file in
- esac
- outputname=
- if test "$fast_install" = no && test -n "$relink_command"; then
- if test "$finalize" = yes && test -z "$run"; then
- tmpdir="/tmp"
- test -n "$TMPDIR" && tmpdir="$TMPDIR"
- tmpdir_mktemp=`mktemp -d $tmpdir/libtool-XXXXXX 2> /dev/null`
- if test $? = 0 ; then
- tmpdir="$tmpdir_mktemp"
- unset tmpdir_mktemp
- else
- tmpdir="$tmpdir/libtool-$$"
- fi
- if $mkdir -p "$tmpdir" && chmod 700 "$tmpdir"; then :
- else
- $echo "$modename: error: cannot create temporary directory \`$tmpdir'" 1>&2
- continue
- fi
- file=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
- outputname="$tmpdir/$file"
- relink_command=`$echo "X$relink_command" | $Xsed -e 's%@OUTPUT@%'"$outputname"'%g'`
- else
- ${rm}r "$tmpdir"
- continue
- fi
- file="$outputname"
- else
- $echo "$modename: warning: cannot relink \`$file'" 1>&2
- fi
- else
- # Install the binary that we compiled earlier.
- file=`$echo "X$file" | $Xsed -e "s%\([^/]*\)$%$objdir/\1%"`
- fi
- fi
- # remove .exe since cygwin /usr/bin/install will append another
- # one anyways
- case $install_prog,$host in
- /usr/bin/install*,*cygwin*)
- case $file:$destfile in
- *.exe:*.exe)
- # this is ok
- *.exe:*)
- destfile=$destfile.exe
- *:*.exe)
- destfile=`echo $destfile | ${SED} -e 's,.exe$,,'`
- esac
- esac
- $show "$install_prog$stripme $file $destfile"
- $run eval "$install_prog\$stripme \$file \$destfile" || exit $?
- test -n "$outputname" && ${rm}r "$tmpdir"
- esac
- done
- for file in $staticlibs; do
- # Set up the ranlib parameters.
- oldlib="$destdir/$name"
- $show "$install_prog $file $oldlib"
- $run eval "$install_prog \$file \$oldlib" || exit $?
- $show "$old_striplib $oldlib"
- $run eval "$old_striplib $oldlib" || exit $?
- fi
- eval cmds=\"$old_postinstall_cmds\"
- save_ifs="$IFS"; IFS='~'
- for cmd in $cmds; do
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd" || exit $?
- done
- IFS="$save_ifs"
- done
- if test -n "$future_libdirs"; then
- $echo "$modename: warning: remember to run \`$progname --finish$future_libdirs'" 1>&2
- fi
- if test -n "$current_libdirs"; then
- # Maybe just do a dry run.
- test -n "$run" && current_libdirs=" -n$current_libdirs"
- exec_cmd='$SHELL $0 --finish$current_libdirs'
- else
- exit 0
- fi
- # libtool finish mode
- finish)
- modename="$modename: finish"
- libdirs="$nonopt"
- admincmds=
- if test -n "$finish_cmds$finish_eval" && test -n "$libdirs"; then
- for dir
- do
- libdirs="$libdirs $dir"
- done
- for libdir in $libdirs; do
- if test -n "$finish_cmds"; then
- # Do each command in the finish commands.
- eval cmds=\"$finish_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd" || admincmds="$admincmds
- $cmd"
- done
- IFS="$save_ifs"
- fi
- if test -n "$finish_eval"; then
- # Do the single finish_eval.
- eval cmds=\"$finish_eval\"
- $run eval "$cmds" || admincmds="$admincmds
- $cmds"
- fi
- done
- fi
- # Exit here if they wanted silent mode.
- test "$show" = ":" && exit 0
- echo "----------------------------------------------------------------------"
- echo "Libraries have been installed in:"
- echo " $libdir"
- done
- echo
- echo "If you ever happen to want to link against installed libraries"
- echo "in a given directory, LIBDIR, you must either use libtool, and"
- echo "specify the full pathname of the library, or use the \`-LLIBDIR'"
- echo "flag during linking and do at least one of the following:"
- if test -n "$shlibpath_var"; then
- echo " - add LIBDIR to the \`$shlibpath_var' environment variable"
- echo " during execution"
- fi
- echo " - add LIBDIR to the \`$runpath_var' environment variable"
- echo " during linking"
- fi
- libdir=LIBDIR
- echo " - use the \`$flag' linker flag"
- fi
- if test -n "$admincmds"; then
- echo " - have your system administrator run these commands:$admincmds"
- fi
- if test -f /etc/ld.so.conf; then
- echo " - have your system administrator add LIBDIR to \`/etc/ld.so.conf'"
- fi
- echo
- echo "See any operating system documentation about shared libraries for"
- echo "more information, such as the ld(1) and ld.so(8) manual pages."
- exit 0
- # libtool execute mode
- execute)
- modename="$modename: execute"
- # The first argument is the command name.
- cmd="$nonopt"
- if test -z "$cmd"; then
- $echo "$modename: you must specify a COMMAND" 1>&2
- $echo "$help"
- exit 1
- fi
- # Handle -dlopen flags immediately.
- for file in $execute_dlfiles; do
- if test ! -f "$file"; then
- $echo "$modename: \`$file' is not a file" 1>&2
- exit 1
- fi
- dir=
- case $file in
- *.la)
- else
- $echo "$modename: \`$lib' is not a valid libtool archive" 1>&2
- exit 1
- fi
- # Read the libtool library.
- dlname=
- library_names=
- case $file in
- *) . ./$file ;;
- esac
- # Skip this library if it cannot be dlopened.
- if test -z "$dlname"; then
- # Warn if it was a shared library.
- test -n "$library_names" && $echo "$modename: warning: \`$file' was not linked with \`-export-dynamic'"
- continue
- fi
- test "X$dir" = "X$file" && dir=.
- if test -f "$dir/$objdir/$dlname"; then
- dir="$dir/$objdir"
- else
- $echo "$modename: cannot find \`$dlname' in \`$dir' or \`$dir/$objdir'" 1>&2
- exit 1
- fi
- *.lo)
- # Just add the directory containing the .lo file.
- $echo "$modename: warning \`-dlopen' is ignored for non-libtool libraries and objects" 1>&2
- continue
- esac
- # Get the absolute pathname.
- absdir=`cd "$dir" && pwd`
- test -n "$absdir" && dir="$absdir"
- # Now add the directory to shlibpath_var.
- if eval "test -z \"\$$shlibpath_var\""; then
- eval "$shlibpath_var=\"\$dir\""
- else
- eval "$shlibpath_var=\"\$dir:\$$shlibpath_var\""
- fi
- done
- # This variable tells wrapper scripts just to set shlibpath_var
- # rather than running their programs.
- libtool_execute_magic="$magic"
- # Check if any of the arguments is a wrapper script.
- args=
- for file
- do
- case $file in
- if (${SED} -e '4q' $file | egrep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
- case $file in
- *) . ./$file ;;
- esac
- # Transform arg to wrapped name.
- file="$progdir/$program"
- fi
- esac
- # Quote arguments (to preserve shell metacharacters).
- file=`$echo "X$file" | $Xsed -e "$sed_quote_subst"`
- args="$args \"$file\""
- done
- # Export the shlibpath_var.
- eval "export $shlibpath_var"
- fi
- # Restore saved enviroment variables
- if test "${save_LC_ALL+set}" = set; then
- LC_ALL="$save_LC_ALL"; export LC_ALL
- fi
- if test "${save_LANG+set}" = set; then
- LANG="$save_LANG"; export LANG
- fi
- # Now prepare to actually exec the command.
- exec_cmd="\$cmd$args"
- else
- # Display what would be done.
- eval "\$echo \"\$shlibpath_var=\$$shlibpath_var\""
- $echo "export $shlibpath_var"
- fi
- $echo "$cmd$args"
- exit 0
- fi
- # libtool clean and uninstall mode
- clean | uninstall)
- modename="$modename: $mode"
- rm="$nonopt"
- files=
- rmforce=
- exit_status=0
- for arg
- do
- case $arg in
- -f) rm="$rm $arg"; rmforce=yes ;;
- -*) rm="$rm $arg" ;;
- *) files="$files $arg" ;;
- esac
- done
- if test -z "$rm"; then
- $echo "$modename: you must specify an RM program" 1>&2
- exit 1
- fi
- rmdirs=
- if test "X$dir" = "X$file"; then
- dir=.
- objdir="$objdir"
- else
- objdir="$dir/$objdir"
- fi
- test $mode = uninstall && objdir="$dir"
- # Remember objdir for removal later, being careful to avoid duplicates
- if test $mode = clean; then
- case " $rmdirs " in
- *" $objdir "*) ;;
- *) rmdirs="$rmdirs $objdir" ;;
- esac
- fi
- # Don't error if the file doesn't exist and rm -f was used.
- if (test -L "$file") >/dev/null 2>&1 \
- || (test -h "$file") >/dev/null 2>&1 \
- || test -f "$file"; then
- elif test -d "$file"; then
- exit_status=1
- continue
- elif test "$rmforce" = yes; then
- continue
- fi
- rmfiles="$file"
- case $name in
- *.la)
- # Possibly a libtool archive, so verify it.
- . $dir/$name
- # Delete the libtool libraries and symlinks.
- for n in $library_names; do
- rmfiles="$rmfiles $objdir/$n"
- done
- test -n "$old_library" && rmfiles="$rmfiles $objdir/$old_library"
- test $mode = clean && rmfiles="$rmfiles $objdir/$name $objdir/${name}i"
- if test $mode = uninstall; then
- if test -n "$library_names"; then
- # Do each command in the postuninstall commands.
- eval cmds=\"$postuninstall_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd"
- if test $? != 0 && test "$rmforce" != yes; then
- exit_status=1
- fi
- done
- IFS="$save_ifs"
- fi
- if test -n "$old_library"; then
- # Do each command in the old_postuninstall commands.
- eval cmds=\"$old_postuninstall_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd"
- exit_status=1
- fi
- done
- IFS="$save_ifs"
- fi
- # FIXME: should reinstall the best remaining shared library.
- fi
- fi
- *.lo)
- oldobj=`$echo "X$name" | $Xsed -e "$lo2o"`
- rmfiles="$rmfiles $dir/$oldobj"
- fi
- # Do a test to see if this is a libtool program.
- if test $mode = clean &&
- (${SED} -e '4q' $file | egrep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
- relink_command=
- . $dir/$file
- rmfiles="$rmfiles $objdir/$name $objdir/${name}S.${objext}"
- if test "$fast_install" = yes && test -n "$relink_command"; then
- rmfiles="$rmfiles $objdir/lt-$name"
- fi
- fi
- esac
- $show "$rm $rmfiles"
- $run $rm $rmfiles || exit_status=1
- done
- # Try to remove the ${objdir}s in the directories where we deleted files
- for dir in $rmdirs; do
- if test -d "$dir"; then
- $show "rmdir $dir"
- $run rmdir $dir >/dev/null 2>&1
- fi
- done
- exit $exit_status
- $echo "$modename: you must specify a MODE" 1>&2
- $echo "$generic_help" 1>&2
- exit 1
- esac
- if test -z "$exec_cmd"; then
- $echo "$modename: invalid operation mode \`$mode'" 1>&2
- exit 1
- fi
-fi # test -z "$show_help"
-if test -n "$exec_cmd"; then
- eval exec $exec_cmd
- exit 1
-fi
-# We need to display help for each of the modes.
-case $mode in
-"") $echo \
-"Usage: $modename [OPTION]... [MODE-ARG]...
-Provide generalized library-building support services.
- --config show all configuration variables
- --debug enable verbose shell tracing
--n, --dry-run display commands without modifying any files
- --features display basic configuration information and exit
- --finish same as \`--mode=finish'
- --help display this help message and exit
- --mode=MODE use operation mode MODE [default=inferred from MODE-ARGS]
- --quiet same as \`--silent'
- --silent don't print informational messages
- --version print version information
-MODE must be one of the following:
- clean remove files from the build directory
- compile compile a source file into a libtool object
- execute automatically set library path, then run a program
- finish complete the installation of libtool libraries
- install install libraries or executables
- link create a library or an executable
- uninstall remove libraries from an installed directory
-MODE-ARGS vary depending on the MODE. Try \`$modename --help --mode=MODE' for
-a more detailed description of MODE."
- exit 0
-clean)
- $echo \
-"Usage: $modename [OPTION]... --mode=clean RM [RM-OPTION]... FILE...
-Remove files from the build directory.
-RM is the name of the program to use to delete files associated with each FILE
-(typically \`/bin/rm'). RM-OPTIONS are options (such as \`-f') to be passed
-to RM.
-If FILE is a libtool library, object or program, all the files associated
-with it are deleted. Otherwise, only FILE itself is deleted using RM."
-compile)
- $echo \
-"Usage: $modename [OPTION]... --mode=compile COMPILE-COMMAND... SOURCEFILE
-Compile a source file into a libtool library object.
-This mode accepts the following additional options:
- -o OUTPUT-FILE set the output file name to OUTPUT-FILE
- -prefer-pic try to building PIC objects only
- -prefer-non-pic try to building non-PIC objects only
- -static always build a \`.o' file suitable for static linking
-COMPILE-COMMAND is a command to be used in creating a \`standard' object file
-from the given SOURCEFILE.
-The output file name is determined by removing the directory component from
-SOURCEFILE, then substituting the C source code suffix \`.c' with the
-library object suffix, \`.lo'."
-execute)
- $echo \
-"Usage: $modename [OPTION]... --mode=execute COMMAND [ARGS]...
-Automatically set library path, then run a program.
- -dlopen FILE add the directory containing FILE to the library path
-This mode sets the library path environment variable according to \`-dlopen'
-flags.
-If any of the ARGS are libtool executable wrappers, then they are translated
-into their corresponding uninstalled binary, and any of their required library
-directories are added to the library path.
-Then, COMMAND is executed, with ARGS as arguments."
-finish)
- $echo \
-"Usage: $modename [OPTION]... --mode=finish [LIBDIR]...
-Complete the installation of libtool libraries.
-Each LIBDIR is a directory that contains libtool libraries.
-The commands that this mode executes may require superuser privileges. Use
-the \`--dry-run' option if you just want to see what would be executed."
-install)
- $echo \
-"Usage: $modename [OPTION]... --mode=install INSTALL-COMMAND...
-Install executables or libraries.
-INSTALL-COMMAND is the installation command. The first component should be
-either the \`install' or \`cp' program.
-The rest of the components are interpreted as arguments to that command (only
-BSD-compatible install options are recognized)."
-link)
- $echo \
-"Usage: $modename [OPTION]... --mode=link LINK-COMMAND...
-Link object files or libraries together to form another library, or to
-create an executable program.
-LINK-COMMAND is a command using the C compiler that you would use to create
-a program from several object files.
-The following components of LINK-COMMAND are treated specially:
- -all-static do not do any dynamic linking at all
- -avoid-version do not add a version suffix if possible
- -dlopen FILE \`-dlpreopen' FILE if it cannot be dlopened at runtime
- -dlpreopen FILE link in FILE and add its symbols to lt_preloaded_symbols
- -export-dynamic allow symbols from OUTPUT-FILE to be resolved with dlsym(3)
- -export-symbols SYMFILE
- try to export only the symbols listed in SYMFILE
- -export-symbols-regex REGEX
- try to export only the symbols matching REGEX
- -LLIBDIR search LIBDIR for required installed libraries
- -lNAME OUTPUT-FILE requires the installed library libNAME
- -module build a library that can dlopened
- -no-fast-install disable the fast-install mode
- -no-install link a not-installable executable
- -no-undefined declare that a library does not refer to external symbols
- -o OUTPUT-FILE create OUTPUT-FILE from the specified objects
- -release RELEASE specify package release information
- -rpath LIBDIR the created library will eventually be installed in LIBDIR
- -R[ ]LIBDIR add LIBDIR to the runtime path of programs and libraries
- -static do not do any dynamic linking of libtool libraries
- -version-info CURRENT[:REVISION[:AGE]]
- specify library version info [each variable defaults to 0]
-All other options (arguments beginning with \`-') are ignored.
-Every other argument is treated as a filename. Files ending in \`.la' are
-treated as uninstalled libtool libraries, other files are standard or library
-object files.
-If the OUTPUT-FILE ends in \`.la', then a libtool library is created,
-only library objects (\`.lo' files) may be specified, and \`-rpath' is
-required, except when creating a convenience library.
-If OUTPUT-FILE ends in \`.a' or \`.lib', then a standard library is created
-using \`ar' and \`ranlib', or on Windows using \`lib'.
-If OUTPUT-FILE ends in \`.lo' or \`.${objext}', then a reloadable object file
-is created, otherwise an executable program is created."
-uninstall)
- $echo \
-"Usage: $modename [OPTION]... --mode=uninstall RM [RM-OPTION]... FILE...
-Remove libraries from an installation directory.
-to RM.
-If FILE is a libtool library, all the files associated with it are deleted.
-Otherwise, only FILE itself is deleted using RM."
- exit 1
-esac
-echo
-$echo "Try \`$modename --help' for more information about other modes."
-exit 0
-# Local Variables:
-# mode:shell-script
-# sh-indentation:2
-# End:
Deleted: trunk/MgDev/missing
--- trunk/MgDev/missing 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/missing 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,336 +0,0 @@
-#! /bin/sh
-# Common stub for a few missing GNU programs while installing.
-# Copyright (C) 1996, 1997, 1999, 2000, 2002 Free Software Foundation, Inc.
-# Originally by Fran,cois Pinard <pinard at iro.umontreal.ca>, 1996.
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
-# 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-if test $# -eq 0; then
- echo 1>&2 "Try \`$0 --help' for more information"
- exit 1
-fi
-run=:
-# In the cases where this matters, `missing' is being run in the
-# srcdir already.
-if test -f configure.ac; then
- configure_ac=configure.ac
-else
- configure_ac=configure.in
-fi
-case "$1" in
---run)
- # Try to run requested program, and just exit if it succeeds.
- run=
- shift
- "$@" && exit 0
-esac
-# If it does not exist, or fails to run (possibly an outdated version),
-# try to emulate it.
-case "$1" in
- -h|--h|--he|--hel|--help)
- echo "\
-$0 [OPTION]... PROGRAM [ARGUMENT]...
-Handle \`PROGRAM [ARGUMENT]...' for when PROGRAM is missing, or return an
-error status if there is no known handling for PROGRAM.
-Options:
- -h, --help display this help and exit
- -v, --version output version information and exit
- --run try to run the given command, and emulate it if it fails
-Supported PROGRAM values:
- aclocal touch file \`aclocal.m4'
- autoconf touch file \`configure'
- autoheader touch file \`config.h.in'
- automake touch all \`Makefile.in' files
- bison create \`y.tab.[ch]', if possible, from existing .[ch]
- flex create \`lex.yy.c', if possible, from existing .c
- help2man touch the output file
- lex create \`lex.yy.c', if possible, from existing .c
- makeinfo touch the output file
- tar try tar, gnutar, gtar, then tar without non-portable flags
- yacc create \`y.tab.[ch]', if possible, from existing .[ch]"
- -v|--v|--ve|--ver|--vers|--versi|--versio|--version)
- echo "missing 0.4 - GNU automake"
- echo 1>&2 "$0: Unknown \`$1' option"
- exit 1
- aclocal*)
- if test -z "$run" && ($1 --version) > /dev/null 2>&1; then
- # We have it, but it failed.
- exit 1
- fi
- echo 1>&2 "\
-WARNING: \`$1' is missing on your system. You should only need it if
- you modified \`acinclude.m4' or \`${configure_ac}'. You might want
- to install the \`Automake' and \`Perl' packages. Grab them from
- any GNU archive site."
- touch aclocal.m4
- autoconf)
- exit 1
- fi
- echo 1>&2 "\
- you modified \`${configure_ac}'. You might want to install the
- \`Autoconf' and \`GNU m4' packages. Grab them from any GNU
- archive site."
- touch configure
- autoheader)
- exit 1
- fi
- echo 1>&2 "\
- you modified \`acconfig.h' or \`${configure_ac}'. You might want
- to install the \`Autoconf' and \`GNU m4' packages. Grab them
- from any GNU archive site."
- files=`sed -n 's/^[ ]*A[CM]_CONFIG_HEADER(\([^)]*\)).*/\1/p' ${configure_ac}`
- test -z "$files" && files="config.h"
- touch_files=
- for f in $files; do
- case "$f" in
- *:*) touch_files="$touch_files "`echo "$f" |
- sed -e 's/^[^:]*://' -e 's/:.*//'`;;
- *) touch_files="$touch_files $f.in";;
- esac
- done
- touch $touch_files
- automake*)
- exit 1
- fi
- echo 1>&2 "\
- you modified \`Makefile.am', \`acinclude.m4' or \`${configure_ac}'.
- You might want to install the \`Automake' and \`Perl' packages.
- Grab them from any GNU archive site."
- find . -type f -name Makefile.am -print |
- sed 's/\.am$/.in/' |
- while read f; do touch "$f"; done
- autom4te)
- exit 1
- fi
- echo 1>&2 "\
-WARNING: \`$1' is needed, and you do not seem to have it handy on your
- system. You might have modified some files without having the
- proper tools for further handling them.
- You can get \`$1Help2man' as part of \`Autoconf' from any GNU
- archive site."
- file=`echo "$*" | sed -n 's/.*--output[ =]*\([^ ]*\).*/\1/p'`
- test -z "$file" && file=`echo "$*" | sed -n 's/.*-o[ ]*\([^ ]*\).*/\1/p'`
- if test -f "$file"; then
- touch $file
- else
- test -z "$file" || exec >$file
- echo "#! /bin/sh"
- echo "# Created by GNU Automake missing as a replacement of"
- echo "# $ $@"
- echo "exit 0"
- chmod +x $file
- exit 1
- fi
- bison|yacc)
- echo 1>&2 "\
- you modified a \`.y' file. You may need the \`Bison' package
- in order for those modifications to take effect. You can get
- \`Bison' from any GNU archive site."
- rm -f y.tab.c y.tab.h
- if [ $# -ne 1 ]; then
- eval LASTARG="\${$#}"
- case "$LASTARG" in
- *.y)
- SRCFILE=`echo "$LASTARG" | sed 's/y$/c/'`
- if [ -f "$SRCFILE" ]; then
- cp "$SRCFILE" y.tab.c
- fi
- SRCFILE=`echo "$LASTARG" | sed 's/y$/h/'`
- cp "$SRCFILE" y.tab.h
- fi
- esac
- fi
- if [ ! -f y.tab.h ]; then
- echo >y.tab.h
- fi
- if [ ! -f y.tab.c ]; then
- echo 'main() { return 0; }' >y.tab.c
- fi
- lex|flex)
- echo 1>&2 "\
- you modified a \`.l' file. You may need the \`Flex' package
- \`Flex' from any GNU archive site."
- rm -f lex.yy.c
- *.l)
- SRCFILE=`echo "$LASTARG" | sed 's/l$/c/'`
- cp "$SRCFILE" lex.yy.c
- fi
- esac
- fi
- if [ ! -f lex.yy.c ]; then
- echo 'main() { return 0; }' >lex.yy.c
- fi
- help2man)
- exit 1
- fi
- echo 1>&2 "\
- you modified a dependency of a manual page. You may need the
- \`Help2man' package in order for those modifications to take
- effect. You can get \`Help2man' from any GNU archive site."
- file=`echo "$*" | sed -n 's/.*-o \([^ ]*\).*/\1/p'`
- if test -z "$file"; then
- file=`echo "$*" | sed -n 's/.*--output=\([^ ]*\).*/\1/p'`
- fi
- if [ -f "$file" ]; then
- touch $file
- else
- echo ".ab help2man is required to generate this page"
- exit 1
- fi
- makeinfo)
- if test -z "$run" && (makeinfo --version) > /dev/null 2>&1; then
- # We have makeinfo, but it failed.
- exit 1
- fi
- echo 1>&2 "\
- you modified a \`.texi' or \`.texinfo' file, or any other file
- indirectly affecting the aspect of the manual. The spurious
- call might also be the consequence of using a buggy \`make' (AIX,
- DU, IRIX). You might want to install the \`Texinfo' package or
- the \`GNU make' package. Grab either from any GNU archive site."
- file=`echo "$*" | sed 's/.* \([^ ]*\) *$/\1/'`
- file=`sed -n '/^@setfilename/ { s/.* \([^ ]*\) *$/\1/; p; q; }' $file`
- fi
- touch $file
- tar)
- shift
- if test -n "$run"; then
- echo 1>&2 "ERROR: \`tar' requires --run"
- exit 1
- fi
- # We have already tried tar in the generic part.
- # Look for gnutar/gtar before invocation to avoid ugly error
- # messages.
- if (gnutar --version > /dev/null 2>&1); then
- gnutar "$@" && exit 0
- fi
- if (gtar --version > /dev/null 2>&1); then
- gtar "$@" && exit 0
- fi
- firstarg="$1"
- if shift; then
- case "$firstarg" in
- *o*)
- firstarg=`echo "$firstarg" | sed s/o//`
- tar "$firstarg" "$@" && exit 0
- esac
- *h*)
- firstarg=`echo "$firstarg" | sed s/h//`
- esac
- fi
- echo 1>&2 "\
-WARNING: I can't seem to be able to run \`tar' with the given arguments.
- You may want to install GNU tar or Free paxutils, or check the
- command line arguments."
- exit 1
- echo 1>&2 "\
- proper tools for further handling them. Check the \`README' file,
- it often tells you about the needed prerequirements for installing
- this package. You may also peek at any GNU archive site, in case
- some other package would contain this missing \`$1' program."
- exit 1
-esac
-exit 0
Deleted: trunk/MgDev/mkinstalldirs
--- trunk/MgDev/mkinstalldirs 2022-10-10 13:41:35 UTC (rev 9981)
+++ trunk/MgDev/mkinstalldirs 2022-10-10 14:07:45 UTC (rev 9982)
@@ -1,99 +0,0 @@
-#! /bin/sh
-# mkinstalldirs --- make directory hierarchy
-# Author: Noah Friedman <friedman at prep.ai.mit.edu>
-# Created: 1993-05-16
-# Public domain
-errstatus=0
-dirmode=""
-usage="\
-Usage: mkinstalldirs [-h] [--help] [-m mode] dir ..."
-# process command line arguments
-while test $# -gt 0 ; do
- case "${1}" in
- -h | --help | --h* ) # -h for help
- echo "${usage}" 1>&2; exit 0 ;;
- -m ) # -m PERM arg
- shift
- test $# -eq 0 && { echo "${usage}" 1>&2; exit 1; }
- dirmode="${1}"
- shift ;;
- -- ) shift; break ;; # stop option processing
- -* ) echo "${usage}" 1>&2; exit 1 ;; # unknown option
- * ) break ;; # first non-opt arg
- esac
-done
-for file
-do
- if test -d "$file"; then
- shift
- else
- break
- fi
-done
-case $# in
-0) exit 0 ;;
-esac
-case $dirmode in
- if mkdir -p -- . 2>/dev/null; then
- echo "mkdir -p -- $*"
- exec mkdir -p -- "$@"
- fi ;;
- if mkdir -m "$dirmode" -p -- . 2>/dev/null; then
- echo "mkdir -m $dirmode -p -- $*"
- exec mkdir -m "$dirmode" -p -- "$@"
- fi ;;
-esac
-for file
-do
- set fnord `echo ":$file" | sed -ne 's/^:\//#/;s/^://;s/\// /g;s/^#/\//;p'`
- shift
- pathcomp=
- for d
- do
- pathcomp="$pathcomp$d"
- case "$pathcomp" in
- -* ) pathcomp=./$pathcomp ;;
- esac
- if test ! -d "$pathcomp"; then
- echo "mkdir $pathcomp"
- mkdir "$pathcomp" || lasterr=$?
- errstatus=$lasterr
- else
- if test ! -z "$dirmode"; then
- echo "chmod $dirmode $pathcomp"
- lasterr=""
- chmod "$dirmode" "$pathcomp" || lasterr=$?
- if test ! -z "$lasterr"; then
- fi
- fi
- fi
- fi
- pathcomp="$pathcomp/"
- done
-done
-exit $errstatus
-# Local Variables:
-# mode: shell-script
-# sh-indentation: 3
-# End:
-# mkinstalldirs ends here
More information about the mapguide-commits
