[mapguide-commits] r9985 - in trunk/MgDev: . Oem
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Oct 13 02:17:25 PDT 2022
Author: jng
Date: 2022-10-13 02:17:25 -0700 (Thu, 13 Oct 2022)
New Revision: 9985
Removed:
   trunk/MgDev/Oem/Makefile.am
   trunk/MgDev/Oem/SWIGEx/
   trunk/MgDev/build_oem.sh
   trunk/MgDev/Oem/CMakeLists.txt
#2852: Remove Oem/SWIGEx. SWIG is now a tool that must be externally acquired.
#2853: Remove Oem/Makefile.am and build_oem.sh
Modified: trunk/MgDev/Oem/CMakeLists.txt
--- trunk/MgDev/Oem/CMakeLists.txt	2022-10-13 09:08:46 UTC (rev 9984)
+++ trunk/MgDev/Oem/CMakeLists.txt	2022-10-13 09:17:25 UTC (rev 9985)
@@ -32,6 +32,5 @@
 if (NOT MG_COMMON_SUBSET_ONLY)
     add_subdirectory(zlib_minizip)
-    add_subdirectory(SWIGEx)
     add_subdirectory(LinuxApt)
 endif (NOT MG_COMMON_SUBSET_ONLY)
\ No newline at end of file
Deleted: trunk/MgDev/Oem/Makefile.am
--- trunk/MgDev/Oem/Makefile.am	2022-10-13 09:08:46 UTC (rev 9984)
+++ trunk/MgDev/Oem/Makefile.am	2022-10-13 09:17:25 UTC (rev 9985)
@@ -1,21 +0,0 @@
-AUTOMAKE_OPTIONS = foreign
-prefix=@prefix@
-SUBDIRS = $(map_opt_oem_subdirs)
-DIST_SUBDIRS =
-EXTRA_DIST = ACE CsMap jsoncpp CppUnit-1.9.14 dbxml DWFTK FDO/ProviderList/ServerCommunity fusion fusionMG gd agg-2.4 geos-2.2.0 jsoncpp LinuxApt php SQLite SWIGEx oem.sln
-dist-hook:
-install-exec-am:
-	@mkdir -p ${prefix}/lib
-	@cp -fp ACE/ACE_wrappers/ace/*.so ${prefix}/lib
-	@cp -fp jsoncpp/lib/*.so ${prefix}/lib
-	@cp -fpd dbxml/install/lib/libxerces-c*.so* ${prefix}/lib
-	@cp -fpd dbxml/install/lib/libxqilla*.so* ${prefix}/lib
-	@cp -fpd dbxml/install/lib/libdb-*.so* ${prefix}/lib
-	@cp -fpd dbxml/install/lib/libdb_cxx*.so* ${prefix}/lib
-	@cp -fpd dbxml/install/lib/libdbxml*.so* ${prefix}/lib
-	@cp -fp  DWFTK/develop/global/src/dwfcore/.libs/libdwfcore-* ${prefix}/lib
-	@cp -fp  DWFTK/develop/global/src/dwf/.libs/libdwftk-* ${prefix}/lib
Deleted: trunk/MgDev/build_oem.sh
--- trunk/MgDev/build_oem.sh	2022-10-13 09:08:46 UTC (rev 9984)
+++ trunk/MgDev/build_oem.sh	2022-10-13 09:17:25 UTC (rev 9985)
@@ -1,700 +0,0 @@
-#! /bin/bash
-# MapGuide Open Source build script.
-# Initialization
-echo "MapGuide Open Source build script for OEM components"
-INSTALLDIR=/usr/local/mapguideopensource
-CLEAN_FLAG=0
-BUILD_CPU=32
-BUILD_CONFIG=release
-while [ $# -gt 0 ]; do    # Until you run out of parameters...
-    case "$1" in
-        -prefix|--prefix)
-            INSTALLDIR="$2"
-            shift
-        -clean|--clean)
-            CLEAN_FLAG=1
-            shift
-        -build|--build)
-            BUILD_CPU=$2
-            shift
-        -config|--config)
-            BUILD_CONFIG=$2
-            shift
-        -help|--help)
-            echo "Usage: $0 (options)"
-            echo "Options:"
-            echo "  --prefix [installation directory]"
-            echo "  --clean [clean all objects and binaries in Oem]"
-            echo "  --build [32(default)|64]"
-            echo "  --config [release(default)|debug]"
-            echo "  --help [Display usage]"
-            exit
-    esac
-    shift   # Check next set of parameters.
-done
-echo "OEM Build Initialization ............................"
-echo "Oem Libraries will be installed at: ${INSTALLDIR}"
-LIB_NAME=""
-# Generic Functions
-check_build()
-    error=$?
-    if [ $error -ne 0 ]; then
-        echo "$LIB_NAME: Error build failed ($error)................."
-        exit $error
-    fi
-check_clean()
-    error=$?
-        echo "$LIB_NAME: Error clean failed ($error)................."
-        exit $error
-    fi
-# Build Apache/PHP
-# Notes: none
-init_linuxapt()
-    LIB_NAME="Apache/PHP/Tomcat"
-build_linuxapt()
-    pushd LinuxApt
-    ./build_apt.sh --prefix "${INSTALLDIR}" --with-tomcat
-    check_build
-    popd
-clean_linuxapt()
-    echo "Nothing to clean for LinuxApt"
-# Build ACE 6.2.6
-# Notes: none
-init_ace()
-    LIB_NAME="ACE 6.2.6"
-    ace_buildbits=32
-    ace_debug=0
-    ace_optimize=1
-    if [ $BUILD_CONFIG = "debug" ]; then
-        ace_debug=1
-        ace_optimize=0
-    chmod +x bin/*.sh
-    fi
-    if [ $BUILD_CPU -eq 64 ]; then
-        ace_buildbits=64
-    fi
-build_ace()
-    pushd ACE/ACE_wrappers
-    ACE_PATH="${PWD}"
-    pushd ace
-    env ACE_ROOT="${ACE_PATH}" make buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
-    check_build
-    popd
-    popd
-clean_ace()
-    ACE_PATH="${PWD}"
-    pushd ace
-    env ACE_ROOT="${ACE_PATH}" make clean buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
-    check_clean
-    popd
-    popd
-# Build DWFCORE 1.0
-# Notes: none
-init_dwfcore()
-    LIB_NAME="DWFCORE 1.0"
-    pushd DWFTK/develop/global/build/gnu/dwfcore
-    if [ $CLEAN_FLAG -eq 0 ]; then
-    	sh ./build_setup.sh
-    fi
-    popd
-build_dwfcore()
-    pushd DWFTK/develop/global/src/dwfcore
-    aclocal
-    libtoolize --copy --force
-    automake --add-missing --copy
-    autoconf
-        sh ./configure --disable-optimized --enable-silent-rules --prefix="${INSTALLDIR}"
-    else
-        sh ./configure --enable-optimized --enable-silent-rules --prefix="${INSTALLDIR}"
-    fi
-    make
-    check_build
-    popd
-clean_dwfcore()
-    make clean
-    check_clean
-    popd
-# Build DWFTOOLKIT 7.7
-# Notes: none
-init_dwftk()
-    LIB_NAME="DWFTK 7.7"
-    pushd DWFTK/develop/global/build/gnu/dwftoolkit
-    fi
-    popd
-build_dwftk()
-    aclocal
-    autoconf
-    else
-    fi
-    make
-    check_build
-    popd
-clean_dwftk()
-    make clean
-    check_clean
-    popd
-# Build GEOS 3.4.2
-# Notes: none
-init_geos()
-    LIB_NAME="GEOS 3.4.2"
-build_geos()
-    pushd geos
-    # For this version of GEOS, don't run the aclocal/libtoolize/automake/autoconf quartet as we normally do, as it
-    # may produce an unusable configure script. Just run autoreconf to regenerate the configure script from configure.in
-    autoreconf
-    # Fix for error:
-    # virtual void geos::geom::GeometryComponentFilter::filter_ro(const geos::geom::Geometry*): Assertion `0' failed
-    # Based on this GEOS ticket: https://trac.osgeo.org/geos/ticket/469
-    # The fix to to set the appropriate CFLAGS/CPPFLAGS/CXXFLAGS/LDFLAGS/FFLAGS before calling the configure script
-    # If we upgrade our internal copy of GEOS in the future, this should be reviewed
-    chmod +x configure
-        CFLAGS="-m64" CPPFLAGS="-m64" CXXFLAGS="-m64" LDFLAGS="-m64" FFLAGS="-m64" LDFLAGS="-L/usr/lib64" ./configure --with-pic --enable-silent-rules --prefix="${INSTALLDIR}"
-    else
-        CFLAGS="-m32" CPPFLAGS="-m32" CXXFLAGS="-m32" LDFLAGS="-m32" FFLAGS="-m32" LDFLAGS="-L/usr/lib" ./configure --enable-silent-rules --prefix="${INSTALLDIR}"
-    fi
-    make
-    # The check build is disabled as the build will fail with automake version < 2.59
-    check_build
-    popd
-clean_geos()
-    pushd geos
-    make clean
-    check_clean
-    popd
-# Build SWIGEx 1.0
-# Notes: none
-init_swigex()
-    LIB_NAME="SWIGEx 1.0"
-build_swigex()
-    pushd SWIGEx
-    mkdir -p Linux/obj/release
-    make
-    check_build
-    popd
-clean_swigex()
-    pushd SWIGEx
-    # Note: the qmake system is required to regenerate the Makefile.
-    #       This is disabled.
-    # make clean
-    # check_clean
-    popd
-# Build BDBXML
-# Notes: none
-init_bdbxml()
-    LIB_NAME="BDBXML"
-build_bdbxml()
-    # Need to force regen of the correct xerces config header before building dbxml proper
-    pushd dbxml/xerces-c-src
-    sh ./configure
-    popd
-    # Also need to check and set executable flag for s_paths
-    pushd dbxml/dbxml/dist
-    chmod +x s_paths
-    popd
-    pushd dbxml
-        sh ./buildall.sh --enable-debug
-    else
-        sh ./buildall.sh
-    fi
-    check_build
-    popd
-clean_bdbxml()
-    pushd dbxml
-    sh ./buildall.sh --clean
-    check_clean
-    popd
-# Build CPPUNIT 1.9.14
-# Notes: none
-init_cppunit()
-    LIB_NAME="CPPUNIT 1.9.14"
-build_cppunit()
-    pushd CppUnit-1.9.14
-    # Force regen of configure to cover our bases
-    aclocal -I config
-    autoconf
-    automake --add-missing --copy --force-missing
-    # -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
-    sh ./configure --enable-silent-rules --prefix="${INSTALLDIR}" LDFLAGS="-ldl"
-    make
-    check_build
-    popd
-clean_cppunit()
-    make clean
-    check_clean
-    popd
-# Build IMake 1.0
-# Notes: none
-init_imake()
-    LIB_NAME="IMake 1.0"
-build_imake()
-    pushd ../BuildTools/WebTools/IMake
-    mkdir -p Linux/obj/debug
-    make
-    check_build
-    popd
-clean_imake()
-    # Note: does not support clean as qmake is needed to regenerate the Makefile.
-    # make clean
-    # check_clean
-    popd
-# Build ZLIB 1.2.3
-# Notes: none
-init_zlib()
-    LIB_NAME="ZLIB 1.2.3"
-build_zlib()
-    pushd gd/zlib
-    sh ./configure
-    make
-    check_build
-    popd
-clean_zlib()
-    pushd gd/zlib
-    make clean
-    check_clean
-    popd
-# Build LIBPNG 1.2.8
-# Notes: none
-init_libpng()
-    LIB_NAME="LIBPNG 1.2.8"
-build_libpng()
-    pushd gd/lpng
-    cp scripts/makefile.std makefile
-        #Inject -fPIC to CFLAGS for 64-bit
-        sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' makefile > makefile64
-        make -fmakefile64
-    else
-        make
-    fi
-    check_build
-    popd
-clean_libpng()
-    pushd gd/lpng
-    make clean
-    check_clean
-    popd
-# Build JPEG 6b
-# Notes: none
-init_jpeg()
-    LIB_NAME="JPEG 6b"
-build_jpeg()
-    pushd gd/jpeg
-    # A jconfig.h that is not modifed by ./configure will trip up make, so nuke it first
-    rm -f jconfig.h
-        sh ./configure --enable-static --disable-shared
-        #--with-pic does nothing (probably ancient configure script), so do some sed trickery
-        #to inject this flag. Know a better way? Enlighten us :)
-        sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' Makefile > Makefile64
-        make -fMakefile64
-    else
-        make
-    fi
-    check_build
-    popd
-clean_jpeg()
-    pushd gd/jpeg
-    make clean
-    check_clean
-    popd
-# Build FREETYPE 2.1.10
-# Notes: none
-init_freetype()
-    LIB_NAME="FREETYPE 2.1.10"
-build_freetype()
-    pushd gd/freetype
-        sh ./configure --enable-static --disable-shared --with-pic
-    else
-    fi
-    make
-    check_build
-    popd
-clean_freetype()
-    pushd gd/freetype
-    make clean
-    check_clean
-    popd
-# Build GD 2.0.33
-# Notes: none
-init_gd()
-    LIB_NAME="GD 2.0.33"
-build_gd()
-    pushd gd/gd
-        sh ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-pic
-    else
-    fi
-    make
-    check_build
-    popd
-clean_gd()
-    pushd gd/gd
-    make clean
-    check_clean
-    popd
-# Build AGG 2.4
-# Notes: none
-init_agg()
-    LIB_NAME="AGG 2.4"
-build_agg()
-    pushd agg-2.4
-        make EXTRACXXFLAGS="-fPIC -m64"
-    else
-        make
-    fi
-    check_build
-    popd
-clean_agg()
-    pushd agg-2.4
-    make clean
-    check_clean
-    popd
-# Build JSON
-# Notes: none
-init_json()
-    LIB_NAME="JSON"
-build_json()
-    pushd jsoncpp
-    # Use system scons
-    scons platform=linux-gcc
-    popd
-clean_json()
-    pushd jsoncpp
-    rm -rf lib buildscons dist
-    popd
-# Build CSMAP
-# Notes: none
-init_csmap()
-    LIB_NAME="CSMAP"
-build_csmap()
-    pushd CsMap/CsMapDev
-    mkdir -p .libs
-    pushd Source
-        make -fLibrary.mak PROCESSOR=x64
-    else
-        make -fLibrary.mak PROCESSOR=x86
-    fi
-    cp ../lib47/Linux$BUILD_CPU/CsMap.a ../.libs/libCsmap.a
-    popd
-    pushd Dictionaries
-        make -fCompiler.mak PROCESSOR=x64
-    else
-        make -fCompiler.mak PROCESSOR=x86
-    fi
-    popd
-    check_build
-    popd
-clean_csmap()
-    pushd CsMap/CsMapDev/Source
-        make clean -fLibrary.mak PROCESSOR=x64
-    else
-        make clean -fLibrary.mak PROCESSOR=x86
-    fi
-    check_clean
-    popd
-# Build Fusion
-# Notes: requires Apache Ant
-init_fusion()
-    LIB_NAME="Fusion"
-build_fusion()
-    pushd fusion
-    ant prepare
-    ant compress
-    popd
-clean_fusion()
-    pushd fusion
-    ant clean
-    popd
-# Script loop
-pushd Oem
-for lib in linuxapt fusion ace dwfcore dwftk bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap geos;
-do
-    echo "$lib: Initialization..........................."
-    init_"$lib"
-    if test "$CLEAN_FLAG" = "1"; then
-        echo "$lib: Clean ....................................."
-        clean_"$lib"
-        echo "$lib: Clean Successful .........................."
-    else
-        echo "$lib: Configure/Build ..........................."
-        build_"$lib"
-        echo "$lib: Build Successful .........................."
-    fi
-done
-popd
More information about the mapguide-commits mailing list
