[mapguide-commits] r9997 - trunk/MgDev/Bindings
svn_mapguide at osgeo.org
Wed Oct 26 08:34:44 PDT 2022
Author: jng
Date: 2022-10-26 08:34:44 -0700 (Wed, 26 Oct 2022)
New Revision: 9997
trunk/MgDev/Bindings/TODO.txt
#2852: TODO update
Modified: trunk/MgDev/Bindings/TODO.txt
--- trunk/MgDev/Bindings/TODO.txt 2022-10-26 15:31:03 UTC (rev 9996)
+++ trunk/MgDev/Bindings/TODO.txt 2022-10-26 15:34:44 UTC (rev 9997)
@@ -103,7 +103,7 @@
- [x] viewer samples (Java)
- [ ] viewer samples (.net)
- Give the .net viewer samples the same migration plan as mapviewernet
- - [ ] Include a web.config for all .net directories with the required settings to avoid needing to set this information with installer or MgInstantSetup:
+ - [x] Include a web.config for all .net directories with the required settings to avoid needing to set this information with installer or MgInstantSetup:
- Add assembly reference to netstandard
- Enable legacy request validation mode
- Target .net Framework 4.8
@@ -112,6 +112,7 @@
- GetDistance -> GetDistanceSimple
- GetAzimuth -> GetAzimuthSimple
- GetCoordinate -> GetCoordinateSimple
+ - [ ] See if later git master builds of SWIG address this issue, allowing us to revert these renames
- MgMap
- Create -> CreateStateless
- MgPropertyDefinition/MgClassDefinition/MgFeatureSchema
More information about the mapguide-commits
