[mapguide-commits] r10044 - trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts
svn_mapguide at osgeo.org
Mon Apr 3 05:37:43 PDT 2023
Author: jng
Date: 2023-04-03 05:37:42 -0700 (Mon, 03 Apr 2023)
New Revision: 10044
trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml
Remove Google Maps layers, street view widget and obsolete script references from our example "Commercial" flexible layout. Bing Maps support requires an API key, denoted by the ADD_BING_MAP_KEY_HERE placeholder that users must fill in if they want to see Bing Maps layers in this flexible layout
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml 2023-03-30 10:22:01 UTC (rev 10043)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml 2023-04-03 12:37:42 UTC (rev 10044)
@@ -1,4 +1,4 @@
-<?xml version="1.0" encoding="UTF-8"?>
+<?xml version="1.0" encoding="utf-8"?>
<ApplicationDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
<Title>Sample - Slate with Commerical Maps</Title>
<TemplateUrl>fusion/templates/mapguide/slate/index.html</TemplateUrl>
@@ -19,46 +19,6 @@
</Extension>
</Map>
<Map>
- <Type>Google</Type>
- <SingleTile>true</SingleTile>
- <Extension>
- <Options>
- <name>Google Hybrid</name>
- <type>G_HYBRID_MAP</type>
- </Options>
- </Extension>
- </Map>
- <Map>
- <Extension>
- <Options>
- <name>Google Satellite</name>
- <type>G_SATELLITE_MAP</type>
- </Options>
- </Extension>
- </Map>
- <Map>
- <Extension>
- <Options>
- <name>Google Streets</name>
- <type>G_NORMAL_MAP</type>
- </Options>
- </Extension>
- </Map>
- <Map>
- <Extension>
- <Options>
- <name>Google Physical</name>
- <type>G_PHYSICAL_MAP</type>
- </Options>
- </Extension>
- </Map>
- <Map>
<Type>VirtualEarth</Type>
<Extension>
@@ -84,7 +44,7 @@
<Extension>
<Options>
<name>Bing Maps Hybrid</name>
- <type>Hybrid</type>
+ <type>AerialsWithLabels</type>
</Options>
</Extension>
</Map>
@@ -125,7 +85,7 @@
<Name>Toolbar</Name>
<Type>Toolbar</Type>
<Position>top</Position>
- <Extension/>
+ <Extension />
<Item xsi:type="WidgetItemType">
<Function>Widget</Function>
<Widget>Print</Widget>
@@ -198,7 +158,7 @@
<Name>ToolbarSecondary</Name>
- <Extension/>
+ <Extension />
<Widget>Select</Widget>
@@ -240,7 +200,7 @@
<Name>ToolbarVertical</Name>
<Position>left</Position>
- <Extension/>
+ <Extension />
<Widget>vertSelect</Widget>
@@ -282,7 +242,7 @@
<Name>FileMenu</Name>
- <Extension/>
+ <Extension />
<Widget>MapMenu</Widget>
@@ -322,10 +282,6 @@
<Widget>CoordinateTracker</Widget>
</Item>
- <Item xsi:type="WidgetItemType">
- <Function>Widget</Function>
- <Widget>GoogleStreetViewer</Widget>
- </Item>
</Item>
</Container>
<Container xsi:type="UiItemContainerType">
@@ -332,7 +288,7 @@
<Name>Statusbar</Name>
<Type>Splitterbar</Type>
<Position>bottom</Position>
- <Extension/>
+ <Extension />
<Widget>statusCoordinates</Widget>
@@ -354,7 +310,7 @@
<Name>MapContextMenu</Name>
<Type>ContextMenu</Type>
- <Extension/>
+ <Extension />
<Widget>RefreshMap</Widget>
@@ -450,7 +406,7 @@
<Name>TaskMenu</Name>
- <Extension/>
+ <Extension />
<Widget>Measure</Widget>
@@ -487,7 +443,7 @@
<Widget xsi:type="UiWidgetType">
<Name>About</Name>
<Type>About</Type>
- <Location/>
+ <Location />
<Extension>
<AboutURL>widgets/About/About.html</AboutURL>
</Extension>
@@ -495,13 +451,13 @@
<ImageClass>about</ImageClass>
<Label>About</Label>
<Tooltip>Click to show information about this application</Tooltip>
- <StatusText/>
+ <StatusText />
<Disabled>false</Disabled>
</Widget>
<Widget>
<Name>ActivityIndicator</Name>
<Type>ActivityIndicator</Type>
- <Location/>
+ <Location />
<Extension>
<ElementId>
</ElementId>
@@ -510,19 +466,19 @@
<Name>BasemapSwitcher</Name>
<Type>BasemapSwitcher</Type>
- <Location/>
- <Extension/>
+ <Location />
+ <Extension />
<ImageUrl>images/icons.png</ImageUrl>
<ImageClass>options</ImageClass>
<Label>External Providers</Label>
<Tooltip>Click to change the basemap</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>BufferPanel</Name>
<Type>BufferPanel</Type>
- <Location/>
+ <Location />
<Extension>
<Target>TaskPane</Target>
</Extension>
@@ -530,52 +486,52 @@
<ImageClass>buffer</ImageClass>
<Label>Buffer</Label>
<Tooltip>Click to create a buffer</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>CenterSelection</Name>
<Type>CenterSelection</Type>
- <Location/>
- <Extension/>
+ <Location />
+ <Extension />
<ImageClass>select-centre</ImageClass>
<Label>Center selection</Label>
<Tooltip>Click to center the map on the current selection</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>ClearSelection</Name>
<Type>ClearSelection</Type>
- <Location/>
- <Extension/>
+ <Location />
+ <Extension />
<ImageClass>select-clear</ImageClass>
<Label>Clear Selection</Label>
<Tooltip>Click to clear the current selection</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>ColorPicker</Name>
<Type>ColorPicker</Type>
- <Location/>
+ <Location />
<Extension>
<ColorInputId>
</ColorInputId>
</Extension>
- <ImageUrl/>
- <ImageClass/>
+ <ImageUrl />
+ <ImageClass />
<Label>Color picker</Label>
<Tooltip>Use this tool to select a color</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>CoordinateTracker</Name>
<Type>CoordinateTracker</Type>
- <Location/>
+ <Location />
<Extension>
<Projection>EPSG:4326</Projection>
@@ -585,13 +541,13 @@
<ImageClass>coordinate-tracker</ImageClass>
<Label>Coordinate Tracker</Label>
<Tooltip>Click to view mouse coordinates in various projections</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Widget>
<Name>EditableScale</Name>
<Type>EditableScale</Type>
- <Location/>
+ <Location />
<Extension>
<Precision>4</Precision>
</Extension>
@@ -599,7 +555,7 @@
<Name>FeatureInfo</Name>
<Type>FeatureInfo</Type>
- <Location/>
+ <Location />
<Extension>
</Extension>
@@ -607,13 +563,13 @@
<ImageClass>feature-info</ImageClass>
<Label>Feature Info</Label>
<Tooltip>Click to display selected feature info</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>Geolocation</Name>
<Type>Geolocation</Type>
- <Location/>
+ <Location />
<Extension>
<ZoomLevel>
</ZoomLevel>
@@ -625,32 +581,13 @@
<ImageClass>geolocation</ImageClass>
<Label>My Location</Label>
<Tooltip>Click to zoom to your current geographic location</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
- <Name>GoogleStreetViewer</Name>
- <Type>GoogleStreetViewer</Type>
- <Location/>
- <Extension>
- <Target>TaskPane</Target>
- <SymbolLayerName>GoogleStreetViewerSymbolLayer</SymbolLayerName>
- <ShowDirection>true</ShowDirection>
- <DirectionLength>22</DirectionLength>
- <AdditionalParameter>
- </AdditionalParameter>
- </Extension>
- <ImageUrl>../../../widgets/GoogleStreetViewer/GoogleStreetView.png</ImageUrl>
- <ImageClass/>
- <Label>Google StreetView</Label>
- <Tooltip>Click to show Google StreetView</Tooltip>
- <StatusText/>
- <Disabled>false</Disabled>
- </Widget>
- <Widget xsi:type="UiWidgetType">
<Name>Help</Name>
<Type>Help</Type>
- <Location/>
+ <Location />
<Extension>
<Target>HelpWindow</Target>
<Url>widgets/Help/Help.html</Url>
@@ -659,13 +596,13 @@
<ImageClass>help</ImageClass>
<Label>Help</Label>
<Tooltip>Click to get help</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>InitialMapView</Name>
<Type>InitialMapView</Type>
- <Location/>
+ <Location />
<Extension>
<ViewType>initial</ViewType>
</Extension>
@@ -673,13 +610,13 @@
<ImageClass>zoom-full</ImageClass>
<Label>Zoom Extents</Label>
<Tooltip>Click to zoom to the full map extents</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Widget>
<Name>Legend</Name>
<Type>Legend</Type>
- <Location/>
+ <Location />
<Extension>
<HideInvisibleLayers>true</HideInvisibleLayers>
<ShowRootFolder>false</ShowRootFolder>
@@ -696,13 +633,13 @@
<Widget>
<Name>LinkToView</Name>
<Type>LinkToView</Type>
- <Location/>
- <Extension/>
+ <Location />
+ <Extension />
</Widget>
<Name>MapMenu</Name>
<Type>MapMenu</Type>
- <Location/>
+ <Location />
<Extension>
<Folder>
</Folder>
@@ -711,13 +648,13 @@
<ImageClass>legend-map</ImageClass>
<Label>Maps</Label>
<Tooltip>Choose a map theme</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>Maptip</Name>
<Type>Maptip</Type>
- <Location/>
+ <Location />
<Extension>
<Delay>350</Delay>
<Layer>
@@ -730,19 +667,19 @@
<ImageClass>maptip</ImageClass>
<Label>Maptip</Label>
<Tooltip>Click to Enable/Disable get information about features from Server</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Widget>
<Name>Navigator</Name>
<Type>Navigator</Type>
- <Location/>
- <Extension/>
+ <Location />
+ <Extension />
</Widget>
<Widget>
<Name>OverviewMap</Name>
<Type>OverviewMap</Type>
- <Location/>
+ <Location />
<Extension>
<MapId>
</MapId>
@@ -753,34 +690,34 @@
<Name>Pan</Name>
<Type>Pan</Type>
- <Location/>
- <Extension/>
+ <Location />
+ <Extension />
<ImageClass>pan</ImageClass>
<Label>Pan</Label>
<Tooltip>Click and drag to pan the map</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>PanOnClick</Name>
<Type>PanOnClick</Type>
- <Location/>
+ <Location />
<Extension>
<Percentage>75</Percentage>
<Direction>none</Direction>
</Extension>
- <ImageUrl/>
- <ImageClass/>
- <Label/>
- <Tooltip/>
- <StatusText/>
+ <ImageUrl />
+ <ImageClass />
+ <Label />
+ <Tooltip />
+ <StatusText />
</Widget>
<Name>PanQuery</Name>
<Type>PanQuery</Type>
- <Location/>
+ <Location />
<Extension>
<SelectionType>INTERSECTS</SelectionType>
<Tolerance>3</Tolerance>
@@ -790,13 +727,13 @@
<Label>Pan query</Label>
<Tooltip>Drag the mouse to pan, click to query</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>Print</Name>
<Type>Print</Type>
- <Location/>
+ <Location />
<Extension>
<ShowPrintUI>true</ShowPrintUI>
<ShowTitle>false</ShowTitle>
@@ -811,13 +748,13 @@
<ImageClass>file-print</ImageClass>
<Label>Print</Label>
<Tooltip>Print the current map view</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>Query</Name>
<Type>Query</Type>
- <Location/>
+ <Location />
<Extension>
</Extension>
@@ -825,13 +762,13 @@
<ImageClass>query</ImageClass>
<Label>Query</Label>
<Tooltip>Click to execute a custom query</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>QuickPlot</Name>
<Type>QuickPlot</Type>
- <Location/>
+ <Location />
<Extension>
<RememberPlotOptions>false</RememberPlotOptions>
@@ -852,16 +789,16 @@
<ShowLegalDisclaimer>true</ShowLegalDisclaimer>
</Extension>
<ImageUrl>images/icons/print.png</ImageUrl>
- <ImageClass/>
+ <ImageClass />
<Label>Quick Plot</Label>
<Tooltip>Click to create a plot quickly</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>Redline</Name>
<Type>Redline</Type>
- <Location/>
+ <Location />
<Extension>
<AutogenerateLayerNames>true</AutogenerateLayerNames>
@@ -876,25 +813,25 @@
<ImageClass>redline</ImageClass>
<Label>Redline</Label>
<Tooltip>Click to draw redline features</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>RefreshMap</Name>
<Type>RefreshMap</Type>
- <Location/>
- <Extension/>
+ <Location />
+ <Extension />
<ImageClass>view-refresh</ImageClass>
<Label>Refresh</Label>
<Tooltip>Click to redraw the map</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>SaveMap</Name>
<Type>SaveMap</Type>
- <Location/>
+ <Location />
<Extension>
<Format>png</Format>
<Scale>
@@ -906,13 +843,13 @@
<ImageClass>file-save</ImageClass>
<Label>Save map</Label>
<Tooltip>Click to save the map as an image</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Widget>
<Name>Scalebar</Name>
<Type>Scalebar</Type>
- <Location/>
+ <Location />
<Extension>
<Style>thin</Style>
<DisplaySystem>metric</DisplaySystem>
@@ -928,7 +865,7 @@
<Widget>
<Name>ScalebarDual</Name>
<Type>ScalebarDual</Type>
- <Location/>
+ <Location />
<Extension>
<MaxWidth>300</MaxWidth>
<TopInUnits>ft</TopInUnits>
@@ -940,7 +877,7 @@
<Name>Select</Name>
<Type>Select</Type>
- <Location/>
+ <Location />
<Extension>
@@ -950,13 +887,13 @@
<ImageClass>select</ImageClass>
<Label>Select</Label>
<Tooltip>Click to select features</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Widget>
<Name>SelectionPanel</Name>
<Type>SelectionPanel</Type>
- <Location/>
+ <Location />
<Extension>
<PreviousImageUrl>
</PreviousImageUrl>
@@ -969,7 +906,7 @@
<Name>SelectPolygon</Name>
<Type>SelectPolygon</Type>
- <Location/>
+ <Location />
<Extension>
@@ -978,13 +915,13 @@
<ImageClass>select-polygon</ImageClass>
<Label>Select Polygon</Label>
<Tooltip>Draw a polygon to perform a selection</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>SelectRadius</Name>
<Type>SelectRadius</Type>
- <Location/>
+ <Location />
<Extension>
@@ -997,13 +934,13 @@
<ImageClass>select-radius</ImageClass>
<Label>Select Radius</Label>
<Tooltip>Click to select within a radius</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>SelectRadiusValue</Name>
<Type>SelectRadiusValue</Type>
- <Location/>
+ <Location />
<Extension>
<RadiusName>SelectRadius</RadiusName>
<Label>
@@ -1011,17 +948,17 @@
<ClassName>
</ClassName>
</Extension>
- <ImageUrl/>
- <ImageClass/>
+ <ImageUrl />
+ <ImageClass />
<Label>Select radius value</Label>
<Tooltip>enter the radius for the Select by Radius tool</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>SelectWithin</Name>
<Type>SelectWithin</Type>
- <Location/>
+ <Location />
<Extension>
<DisableIfSelectionEmpty>true</DisableIfSelectionEmpty>
@@ -1030,13 +967,13 @@
<ImageClass>select-features</ImageClass>
<Label>Select within</Label>
<Tooltip>Click to select features within this selection</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Widget>
<Name>TaskPane</Name>
<Type>TaskPane</Type>
- <Location/>
+ <Location />
<Extension>
<InitialTask>
</InitialTask>
@@ -1046,7 +983,7 @@
<Name>Theme</Name>
<Type>Theme</Type>
- <Location/>
+ <Location />
<Extension>
</Extension>
@@ -1054,13 +991,13 @@
<ImageClass>theme</ImageClass>
<Label>Theme</Label>
<Tooltip>Click to create a themed layer</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>ViewOptions</Name>
<Type>ViewOptions</Type>
- <Location/>
+ <Location />
<Extension>
<DisplayUnits>
</DisplayUnits>
@@ -1069,13 +1006,13 @@
<Label>Options</Label>
<Tooltip>Click to change the units displayed</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>Zoom</Name>
<Type>Zoom</Type>
- <Location/>
+ <Location />
<Extension>
<Tolerance>5</Tolerance>
<Factor>2</Factor>
@@ -1091,7 +1028,7 @@
<Name>ZoomToSelection</Name>
<Type>ZoomToSelection</Type>
- <Location/>
+ <Location />
<Extension>
<MaximumZoomDimension>-1</MaximumZoomDimension>
<ZoomFactor>2</ZoomFactor>
@@ -1100,13 +1037,13 @@
<ImageClass>select-zoom</ImageClass>
<Label>Zoom Selection</Label>
<Tooltip>Click to zoom to the selection</Tooltip>
- <StatusText/>
+ <StatusText />
</Widget>
<Name>ZoomIn</Name>
<Type>ZoomOnClick</Type>
- <Location/>
+ <Location />
<Extension>
<Factor>2</Factor>
</Extension>
@@ -1120,7 +1057,7 @@
<Name>ZoomOut</Name>
- <Location/>
+ <Location />
<Extension>
<Factor>0.5</Factor>
</Extension>
@@ -1134,7 +1071,7 @@
<Name>PreviousView</Name>
<Type>ExtentHistory</Type>
- <Location/>
+ <Location />
<Extension>
<Direction>previous</Direction>
</Extension>
@@ -1148,7 +1085,7 @@
<Name>NextView</Name>
- <Location/>
+ <Location />
<Extension>
<Direction>next</Direction>
</Extension>
@@ -1162,7 +1099,7 @@
<Name>tbBuffer</Name>
- <Location/>
+ <Location />
<Extension>
</Extension>
@@ -1176,7 +1113,7 @@
<Name>Measure</Name>
<Type>Measure</Type>
- <Location/>
+ <Location />
<Extension>
<Type>both</Type>
<MeasureTooltipContainer>MeasureResult</MeasureTooltipContainer>
@@ -1196,63 +1133,63 @@
<Name>showOverview</Name>
<Type>InvokeScript</Type>
- <Location/>
+ <Location />
<Extension>
<Script>showOverviewMap()</Script>
</Extension>
- <ImageUrl/>
- <ImageClass/>
+ <ImageUrl />
+ <ImageClass />
<Label>Show Overview</Label>
- <Tooltip/>
- <StatusText/>
+ <Tooltip />
+ <StatusText />
</Widget>
<Name>showTaskPane</Name>
- <Location/>
+ <Location />
<Extension>
<Script>showTaskPane()</Script>
</Extension>
- <ImageUrl/>
- <ImageClass/>
+ <ImageUrl />
+ <ImageClass />
<Label>Show Task Pane</Label>
- <Tooltip/>
- <StatusText/>
+ <Tooltip />
+ <StatusText />
</Widget>
<Name>showLegend</Name>
- <Location/>
+ <Location />
<Extension>
<Script>showLegend()</Script>
</Extension>
- <ImageUrl/>
- <ImageClass/>
+ <ImageUrl />
+ <ImageClass />
<Label>Show Legend</Label>
- <Tooltip/>
- <StatusText/>
+ <Tooltip />
+ <StatusText />
</Widget>
<Name>showSelectionPanel</Name>
- <Location/>
+ <Location />
<Extension>
<Script>showSelectionPanel()</Script>
</Extension>
- <ImageUrl/>
- <ImageClass/>
+ <ImageUrl />
+ <ImageClass />
<Label>Show Selection Panel</Label>
- <Tooltip/>
- <StatusText/>
+ <Tooltip />
+ <StatusText />
</Widget>
<Widget>
<Name>statusCoordinates</Name>
<Type>CursorPosition</Type>
- <Location/>
+ <Location />
<Extension>
<Template>X: {x} {units}, Y: {y} {units}</Template>
@@ -1265,7 +1202,7 @@
<Widget>
<Name>statusSelection</Name>
<Type>SelectionInfo</Type>
- <Location/>
+ <Location />
<Extension>
<Template>{0} feature(s) selected on {1} layer(s)</Template>
<EmptyText>No selection</EmptyText>
@@ -1274,7 +1211,7 @@
<Widget>
<Name>statusViewSize</Name>
<Type>ViewSize</Type>
- <Location/>
+ <Location />
<Extension>
<Units>Meters</Units>
<Precision>2</Precision>
@@ -1284,13 +1221,13 @@
<Name>vertZoomIn</Name>
- <Location/>
+ <Location />
<Extension>
<Factor>2</Factor>
</Extension>
<ImageClass>zoom-in-fixed</ImageClass>
- <Label/>
+ <Label />
<Tooltip>Zoom in by a preset increment</Tooltip>
<StatusText>Zoom in by a preset increment</StatusText>
@@ -1298,13 +1235,13 @@
<Name>vertZoomOut</Name>
- <Location/>
+ <Location />
<Extension>
</Extension>
<ImageClass>zoom-out-fixed</ImageClass>
- <Label/>
+ <Label />
<Tooltip>Zoom out by a preset increment</Tooltip>
<StatusText>Zoom out by a preset increment</StatusText>
@@ -1312,13 +1249,13 @@
<Name>vertPreviousView</Name>
- <Location/>
+ <Location />
<Extension>
</Extension>
<ImageClass>view-back</ImageClass>
- <Label/>
+ <Label />
<Tooltip>Go to previous view</Tooltip>
<StatusText>Go to previous view</StatusText>
@@ -1326,13 +1263,13 @@
<Name>vertNextView</Name>
- <Location/>
+ <Location />
<Extension>
</Extension>
<ImageClass>view-forward</ImageClass>
- <Label/>
+ <Label />
<Tooltip>Go to next view</Tooltip>
<StatusText>Go to next view</StatusText>
@@ -1340,7 +1277,7 @@
<Name>vertSelect</Name>
<Type>Select</Type>
- <Location/>
+ <Location />
<Extension>
@@ -1348,27 +1285,27 @@
</Extension>
- <Label/>
+ <Label />
- <StatusText/>
+ <StatusText />
</Widget>
<Name>vertPan</Name>
<Type>Pan</Type>
- <Location/>
- <Extension/>
+ <Location />
+ <Extension />
- <Label/>
+ <Label />
- <StatusText/>
+ <StatusText />
</Widget>
<Name>vertZoom</Name>
<Type>Zoom</Type>
- <Location/>
+ <Location />
<Extension>
<Factor>2</Factor>
@@ -1376,7 +1313,7 @@
</Extension>
<ImageClass>zoom-in</ImageClass>
- <Label/>
+ <Label />
<Tooltip>Click or click and drag on the map to zoom in</Tooltip>
<StatusText>Click or click and drag on the map to zoom in</StatusText>
@@ -1384,21 +1321,21 @@
<Name>vertInitialMapView</Name>
- <Location/>
+ <Location />
<Extension>
</Extension>
- <Label/>
+ <Label />
- <StatusText/>
+ <StatusText />
</Widget>
<Name>vertZoomToSelection</Name>
- <Location/>
+ <Location />
<Extension>
@@ -1405,15 +1342,14 @@
</Extension>
- <Label/>
+ <Label />
- <StatusText/>
+ <StatusText />
</Widget>
</WidgetSet>
<Extension>
- <VirtualEarthScript>http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.2</VirtualEarthScript>
- <GoogleScript>http://maps.google.com/maps/api/js?sensor=false</GoogleScript>
<OpenStreetMapScript>http://www.openstreetmap.org/openlayers/OpenStreetMap.js</OpenStreetMapScript>
+ <BingMapKey>ADD_BING_MAP_KEY_HERE</BingMapKey>
</Extension>
</ApplicationDefinition>
\ No newline at end of file
More information about the mapguide-commits
