[mapguide-commits] r10022 - trunk/MgDev/Server/src/PostBuild
    svn_mapguide at osgeo.org
    Sat Feb  4 03:56:39 PST 2023
Author: jng
Date: 2023-02-04 03:56:38 -0800 (Sat, 04 Feb 2023)
New Revision: 10022
   trunk/MgDev/Server/src/PostBuild/PostBuild.mak
Simplify the test data preparation step by having a single CopyTestDataFiles target that does wildcard-based xcopy of the required source test data directories to its target destination. It's not a recursive GLOB like the Linux (CMake) build, but it is close enough in that new test files added in the future should no longer require modifications to PostBuild.mak. It should be caught by the new wildcard-based xcopy.
Fixes #2860
Modified: trunk/MgDev/Server/src/PostBuild/PostBuild.mak
--- trunk/MgDev/Server/src/PostBuild/PostBuild.mak	2022-12-13 09:05:54 UTC (rev 10021)
+++ trunk/MgDev/Server/src/PostBuild/PostBuild.mak	2023-02-04 11:56:38 UTC (rev 10022)
@@ -157,121 +157,7 @@
         ..\..\bin\debug\xerces-c_3_1mgD.dll \
         ..\..\bin\debug\xerces-c_3_1mgD.pdb \
         ..\..\bin\debug\serverconfig.ini \
-        ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml \
-        ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml \
-        ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml \
-        ..\..\bin\UnitTestFiles\TEST.LayerDefinition \
-        ..\..\bin\UnitTestFiles\TEST.FeatureSource \
-        ..\..\bin\UnitTestFiles\TEST.sdf \
-        ..\..\bin\UnitTestFiles\UT_BaseMap.mdf \
-        ..\..\bin\UnitTestFiles\UT_BaseMap.tsd \
-        ..\..\bin\UnitTestFiles\UT_XYZ.tsd \
-        ..\..\bin\UnitTestFiles\UT_BaseMap_OrigSize.tsd \
-        ..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd \
-        ..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd \
-        ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf \
-        ..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf \
-        ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf \
-        ..\..\bin\UnitTestFiles\UT_Parcels.fs \
-        ..\..\bin\UnitTestFiles\UT_Parcels.ldf \
-        ..\..\bin\UnitTestFiles\UT_Parcels.sdf \
-        ..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs \
-        ..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf \
-        ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf \
-        ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs \
-        ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf \
-        ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf \
-        ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf \
-        ..\..\bin\UnitTestFiles\UT_AllElements.pl \
-        ..\..\bin\UnitTestFiles\PlotHole.mgp \
-        ..\..\bin\UnitTestFiles\UT_NoLegend.pl \
-        ..\..\bin\UnitTestFiles\UT_SymbolMart.sl \
-        ..\..\bin\UnitTestFiles\UT_Symbols.dwf \
-        ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf \
-        ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf \
-        ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf \
-        ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf \
-        ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf \
-        ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs \
-        ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf \
-        ..\..\bin\UnitTestFiles\UT_Rail.sdf \
-        ..\..\bin\UnitTestFiles\UT_Rail.fs \
-        ..\..\bin\UnitTestFiles\UT_Rail.ldf \
-        ..\..\bin\UnitTestFiles\UT_Rail.wdf \
-        ..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf \
-        ..\..\bin\UnitTestFiles\UT_MultiCTS.ldf \
-        ..\..\bin\UnitTestFiles\UT_MultiCTSWithTheme.ldf \
-        ..\..\bin\UnitTestFiles\UT_MultiFTS.ldf \
-        ..\..\bin\UnitTestFiles\UT_MultiFTSSingleCTS.ldf \
-        ..\..\bin\UnitTestFiles\UT_MultiFTSWithTheme.ldf \
-        ..\..\bin\UnitTestFiles\UT_SingleFTSMultiCTS.ldf \
-        ..\..\bin\UnitTestFiles\UT_RotatedPointStyles.ldf \
-        ..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource \
-        ..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf \
-        ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource \
-        ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf \
-        ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource \
-        ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf \
-        ..\..\bin\UnitTestFiles\Empty.FeatureSource \
-        ..\..\bin\UnitTestFiles\Empty.sdf \
-        ..\..\bin\UnitTestFiles\World.mgp \
-        ..\..\bin\UnitTestFiles\World_Countries.sdf \
-        ..\..\bin\UnitTestFiles\Shuttle.zip \
-        ..\..\bin\UnitTestFiles\test.dwf \
-        ..\..\bin\UnitTestFiles\SpaceShip.dwf \
-        ..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml \
-        ..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.shp \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.dbf \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.shx \
-        ..\..\bin\UnitTestFiles\1.1.1.mgd \
-        ..\..\bin\UnitTestFiles\epsgcodes.txt \
-        ..\..\bin\UnitTestFiles\ogcwkts.txt \
-        ..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt \
-        ..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt \
-        ..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt \
-        ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource \
-        ..\..\bin\UnitTestFiles\MdfTestMap.mdf \
-        ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf \
-        ..\..\bin\UnitTestFiles\MdfTestDisabledBounds.ldf \
-        ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd \
-        ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd \
-        ..\..\bin\UnitTestFiles\areasymbol.sd \
-        ..\..\bin\UnitTestFiles\linesymbol.sd \
-        ..\..\bin\UnitTestFiles\symbol.sd \
-        ..\..\bin\UnitTestFiles\symbolp.sd \
-        ..\..\bin\UnitTestFiles\MTYP1500a.sd \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.fs \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf \
-        ..\..\bin\UnitTestFiles\UT_Annotation1.ldf \
-        ..\..\bin\UnitTestFiles\UT_Annotation1.mdf \
-        ..\..\bin\UnitTestFiles\UT_Annotation2.ldf \
-        ..\..\bin\UnitTestFiles\UT_Annotation2.mdf \
-        ..\..\bin\UnitTestFiles\UT_Annotation3.ldf \
-        ..\..\bin\UnitTestFiles\UT_Annotation3.mdf \
-        ..\..\bin\UnitTestFiles\SavePointTest.sqlite \
-        ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource \
-        ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource \
-        ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource \
-        ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite \
-        ..\..\bin\UnitTestFiles\JoinTest.sqlite \
+        CopyTestDataFiles \
         CopyFdoComponentsDebug \
         CopyFdoProvidersDebug \
         CopySchemaDebug \
@@ -439,121 +325,7 @@
         ..\..\bin\debug64\xerces-c_3_1mgD.dll \
         ..\..\bin\debug64\xerces-c_3_1mgD.pdb \
         ..\..\bin\debug64\serverconfig.ini \
         CopyFdoComponentsDebug64 \
         CopyFdoProvidersDebug64 \
         CopySchemaDebug64 \
@@ -721,121 +493,7 @@
           ..\..\bin\release\xerces-c_3_1mg.dll \
           ..\..\bin\release\xerces-c_3_1mg.pdb \
           ..\..\bin\release\serverconfig.ini \
           CopyFdoComponentsRelease \
           CopyFdoProvidersRelease \
           CopySchemaRelease \
@@ -1003,121 +661,7 @@
           ..\..\bin\release64\xerces-c_3_1mg.dll \
           ..\..\bin\release64\xerces-c_3_1mg.pdb \
           ..\..\bin\release64\serverconfig.ini \
           CopyFdoComponentsRelease64 \
           CopyFdoProvidersRelease64 \
           CopySchemaRelease64 \
@@ -1127,152 +671,38 @@
 cleandebug:
-    if EXIST ..\..\bin\debug\MgFoundationd.dll               del /F ..\..\bin\debug\MgFoundationd.dll
-    if EXIST ..\..\bin\debug\MgFoundationd.pdb               del /F ..\..\bin\debug\MgFoundationd.pdb
-    if EXIST ..\..\bin\debug\MgGeometryd.dll                 del /F ..\..\bin\debug\MgGeometryd.dll
-    if EXIST ..\..\bin\debug\MgGeometryd.pdb                 del /F ..\..\bin\debug\MgGeometryd.pdb
-    if EXIST ..\..\bin\debug\MgPlatformBased.dll             del /F ..\..\bin\debug\MgPlatformBased.dll
-    if EXIST ..\..\bin\debug\MgPlatformBased.pdb             del /F ..\..\bin\debug\MgPlatformBased.pdb
-    if EXIST ..\..\bin\debug\MgMapGuideCommond.dll           del /F ..\..\bin\debug\MgMapGuideCommond.dll
-    if EXIST ..\..\bin\debug\MgMapGuideCommond.pdb           del /F ..\..\bin\debug\MgMapGuideCommond.pdb
-    if EXIST ..\..\bin\debug\MgMdfModeld.dll                 del /F ..\..\bin\debug\MgMdfModeld.dll
-    if EXIST ..\..\bin\debug\MgMdfModeld.pdb                 del /F ..\..\bin\debug\MgMdfModeld.pdb
-    if EXIST ..\..\bin\debug\MgMdfParserd.dll                del /F ..\..\bin\debug\MgMdfParserd.dll
-    if EXIST ..\..\bin\debug\MgMdfParserd.pdb                del /F ..\..\bin\debug\MgMdfParserd.pdb
-    if EXIST ..\..\bin\debug\MgStylizationd.dll              del /F ..\..\bin\debug\MgStylizationd.dll
-    if EXIST ..\..\bin\debug\MgStylizationd.pdb              del /F ..\..\bin\debug\MgStylizationd.pdb
-    if EXIST ..\..\bin\debug\MgRenderersd.dll                del /F ..\..\bin\debug\MgRenderersd.dll
-    if EXIST ..\..\bin\debug\MgRenderersd.pdb                del /F ..\..\bin\debug\MgRenderersd.pdb
-    if EXIST ..\..\bin\debug\ACEd.dll                        del /F ..\..\bin\debug\ACEd.dll
-    if EXIST ..\..\bin\debug\ACEd.pdb                        del /F ..\..\bin\debug\ACEd.pdb
-    if EXIST ..\..\bin\debug\gd.dll                          del /F ..\..\bin\debug\gd.dll
-    if EXIST ..\..\bin\debug\gd.pdb                          del /F ..\..\bin\debug\gd.pdb
-    if EXIST ..\..\bin\debug\GEOSd.dll                       del /F ..\..\bin\debug\GEOSd.dll
-    if EXIST ..\..\bin\debug\GEOSd.pdb                       del /F ..\..\bin\debug\GEOSd.pdb
-    if EXIST ..\..\bin\debug\libdb48d.dll                    del /F ..\..\bin\debug\libdb48d.dll
-    if EXIST ..\..\bin\debug\libdb48d.pdb                    del /F ..\..\bin\debug\libdb48d.pdb
-    if EXIST ..\..\bin\debug\libdbxml25d.dll                 del /F ..\..\bin\debug\libdbxml25d.dll
-    if EXIST ..\..\bin\debug\libdbxml25d.pdb                 del /F ..\..\bin\debug\libdbxml25d.pdb
-    if EXIST ..\..\bin\debug\xqilla24d.dll                   del /F ..\..\bin\debug\xqilla24d.dll
-    if EXIST ..\..\bin\debug\xqilla24d.pdb                   del /F ..\..\bin\debug\xqilla24d.pdb
-    if EXIST ..\..\bin\debug\xerces-c_3_1mgD.dll             del /F ..\..\bin\debug\xerces-c_3_1mgD.dll
-    if EXIST ..\..\bin\debug\xerces-c_3_1mgD.pdb             del /F ..\..\bin\debug\xerces-c_3_1mgD.pdb
-    if EXIST ..\..\bin\debug\serverconfig.ini                del /F ..\..\bin\debug\serverconfig.ini
-    if EXIST ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml   del /F ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml
-    if EXIST ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml     del /F ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml
-    if EXIST ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml    del /F ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml
-    if EXIST ..\..\bin\UnitTestFiles\TEST.LayerDefinition           del /F ..\..\bin\UnitTestFiles\TEST.LayerDefinition
-    if EXIST ..\..\bin\UnitTestFiles\TEST.FeatureSource             del /F ..\..\bin\UnitTestFiles\TEST.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\TEST.sdf                       del /F ..\..\bin\UnitTestFiles\TEST.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.mdf                 del /F ..\..\bin\UnitTestFiles\UT_BaseMap.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.tsd                 del /F ..\..\bin\UnitTestFiles\UT_BaseMap.tsd
-    if EXIST ..\..\bin\UnitTestFiles\UT_XYZ.tsd                     del /F ..\..\bin\UnitTestFiles\UT_XYZ.tsd
-    if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap_OrigSize.tsd        del /F ..\..\bin\UnitTestFiles\UT_BaseMap_OrigSize.tsd
-    if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd       del /F ..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd
-    if EXIST ..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd           del /F ..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd
-    if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf           del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf        del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf        del /F ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.fs                  del /F ..\..\bin\UnitTestFiles\UT_Parcels.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.ldf                 del /F ..\..\bin\UnitTestFiles\UT_Parcels.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.sdf                 del /F ..\..\bin\UnitTestFiles\UT_Parcels.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs          del /F ..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf         del /F ..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf         del /F ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs          del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf         del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf del /F ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf         del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_AllElements.pl              del /F ..\..\bin\UnitTestFiles\UT_AllElements.pl
-    if EXIST ..\..\bin\UnitTestFiles\PlotHole.mgp                   del /F ..\..\bin\UnitTestFiles\PlotHole.mgp
-    if EXIST ..\..\bin\UnitTestFiles\UT_NoLegend.pl                 del /F ..\..\bin\UnitTestFiles\UT_NoLegend.pl
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbolMart.sl               del /F ..\..\bin\UnitTestFiles\UT_SymbolMart.sl
-    if EXIST ..\..\bin\UnitTestFiles\UT_Symbols.dwf                 del /F ..\..\bin\UnitTestFiles\UT_Symbols.dwf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf  del /F ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf       del /F ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf               del /F ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf           del /F ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf    del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs     del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf    del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.sdf                    del /F ..\..\bin\UnitTestFiles\UT_Rail.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.fs                     del /F ..\..\bin\UnitTestFiles\UT_Rail.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.ldf                    del /F ..\..\bin\UnitTestFiles\UT_Rail.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.wdf                    del /F ..\..\bin\UnitTestFiles\UT_Rail.wdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf          del /F ..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_MultiCTS.ldf                del /F ..\..\bin\UnitTestFiles\UT_MultiCTS.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_MultiCTSWithTheme.ldf       del /F ..\..\bin\UnitTestFiles\UT_MultiCTSWithTheme.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_MultiFTS.ldf                del /F ..\..\bin\UnitTestFiles\UT_MultiFTS.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_MultiFTSSingleCTS.ldf       del /F ..\..\bin\UnitTestFiles\UT_MultiFTSSingleCTS.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_MultiFTSWithTheme.ldf       del /F ..\..\bin\UnitTestFiles\UT_MultiFTSWithTheme.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SingleFTSMultiCTS.ldf  del /F ..\..\bin\UnitTestFiles\UT_SingleFTSMultiCTS.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_RotatedPointStyles.ldf      del /F ..\..\bin\UnitTestFiles\UT_RotatedPointStyles.ldf
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource del /F ..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf          del /F ..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource del /F ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf del /F ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource del /F ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf  del /F ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Empty.FeatureSource            del /F ..\..\bin\UnitTestFiles\Empty.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Empty.sdf                      del /F ..\..\bin\UnitTestFiles\Empty.sdf
-    if EXIST ..\..\bin\UnitTestFiles\World.mgp                      del /F ..\..\bin\UnitTestFiles\World.mgp
-    if EXIST ..\..\bin\UnitTestFiles\World_Countries.sdf            del /F ..\..\bin\UnitTestFiles\World_Countries.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Shuttle.zip                    del /F ..\..\bin\UnitTestFiles\Shuttle.zip
-    if EXIST ..\..\bin\UnitTestFiles\test.dwf                       del /F ..\..\bin\UnitTestFiles\test.dwf
-    if EXIST ..\..\bin\UnitTestFiles\SpaceShip.dwf                  del /F ..\..\bin\UnitTestFiles\SpaceShip.dwf
-    if EXIST ..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml      del /F ..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml
-    if EXIST ..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml     del /F ..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource  del /F ..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.shp            del /F ..\..\bin\UnitTestFiles\Redding_Parcels.shp
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.dbf            del /F ..\..\bin\UnitTestFiles\Redding_Parcels.dbf
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.shx            del /F ..\..\bin\UnitTestFiles\Redding_Parcels.shx
-    if EXIST ..\..\bin\UnitTestFiles\1.1.1.mgd                      del /F ..\..\bin\UnitTestFiles\1.1.1.mgd
-    if EXIST ..\..\bin\UnitTestFiles\epsgcodes.txt                  del /F ..\..\bin\UnitTestFiles\epsgcodes.txt
-    if EXIST ..\..\bin\UnitTestFiles\ogcwkts.txt                    del /F ..\..\bin\UnitTestFiles\ogcwkts.txt
-    if EXIST ..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt         del /F ..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt
-    if EXIST ..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt       del /F ..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt
-    if EXIST ..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt    del /F ..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt
-    if EXIST ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource del /F ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestMap.mdf                 del /F ..\..\bin\UnitTestFiles\MdfTestMap.mdf
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf          del /F ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestDisabledBounds.ldf      del /F ..\..\bin\UnitTestFiles\MdfTestDisabledBounds.ldf
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd       del /F ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd         del /F ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\areasymbol.sd                  del /F ..\..\bin\UnitTestFiles\areasymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\linesymbol.sd                  del /F ..\..\bin\UnitTestFiles\linesymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\symbol.sd                      del /F ..\..\bin\UnitTestFiles\symbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\symbolp.sd                     del /F ..\..\bin\UnitTestFiles\symbolp.sd
-    if EXIST ..\..\bin\UnitTestFiles\MTYP1500a.sd                   del /F ..\..\bin\UnitTestFiles\MTYP1500a.sd
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.fs           del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf del /F ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf del /F ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs          del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf         del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf         del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf         del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf    del /F ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf    del /F ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs           del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf        del /F ..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf       del /F ..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation1.ldf             del /F ..\..\bin\UnitTestFiles\UT_Annotation1.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation1.mdf             del /F ..\..\bin\UnitTestFiles\UT_Annotation1.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation2.ldf             del /F ..\..\bin\UnitTestFiles\UT_Annotation2.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation2.mdf             del /F ..\..\bin\UnitTestFiles\UT_Annotation2.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation3.ldf             del /F ..\..\bin\UnitTestFiles\UT_Annotation3.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation3.mdf             del /F ..\..\bin\UnitTestFiles\UT_Annotation3.mdf
-    if EXIST ..\..\bin\UnitTestFiles\SavePointTest.sqlite           del /F ..\..\bin\UnitTestFiles\SavePointTest.sqlite
-    if EXIST ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource    del /F ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource    del /F ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource        del /F ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite         del /F ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite
-    if EXIST ..\..\bin\UnitTestFiles\JoinTest.sqlite                del /F ..\..\bin\UnitTestFiles\JoinTest.FeatureSource
+    if EXIST ..\..\bin\debug\MgFoundationd.dll                 del /F ..\..\bin\debug\MgFoundationd.dll
+    if EXIST ..\..\bin\debug\MgFoundationd.pdb                 del /F ..\..\bin\debug\MgFoundationd.pdb
+    if EXIST ..\..\bin\debug\MgGeometryd.dll                   del /F ..\..\bin\debug\MgGeometryd.dll
+    if EXIST ..\..\bin\debug\MgGeometryd.pdb                   del /F ..\..\bin\debug\MgGeometryd.pdb
+    if EXIST ..\..\bin\debug\MgPlatformBased.dll               del /F ..\..\bin\debug\MgPlatformBased.dll
+    if EXIST ..\..\bin\debug\MgPlatformBased.pdb               del /F ..\..\bin\debug\MgPlatformBased.pdb
+    if EXIST ..\..\bin\debug\MgMapGuideCommond.dll             del /F ..\..\bin\debug\MgMapGuideCommond.dll
+    if EXIST ..\..\bin\debug\MgMapGuideCommond.pdb             del /F ..\..\bin\debug\MgMapGuideCommond.pdb
+    if EXIST ..\..\bin\debug\MgMdfModeld.dll                   del /F ..\..\bin\debug\MgMdfModeld.dll
+    if EXIST ..\..\bin\debug\MgMdfModeld.pdb                   del /F ..\..\bin\debug\MgMdfModeld.pdb
+    if EXIST ..\..\bin\debug\MgMdfParserd.dll                  del /F ..\..\bin\debug\MgMdfParserd.dll
+    if EXIST ..\..\bin\debug\MgMdfParserd.pdb                  del /F ..\..\bin\debug\MgMdfParserd.pdb
+    if EXIST ..\..\bin\debug\MgStylizationd.dll                del /F ..\..\bin\debug\MgStylizationd.dll
+    if EXIST ..\..\bin\debug\MgStylizationd.pdb                del /F ..\..\bin\debug\MgStylizationd.pdb
+    if EXIST ..\..\bin\debug\MgRenderersd.dll                  del /F ..\..\bin\debug\MgRenderersd.dll
+    if EXIST ..\..\bin\debug\MgRenderersd.pdb                  del /F ..\..\bin\debug\MgRenderersd.pdb
+    if EXIST ..\..\bin\debug\ACEd.dll                          del /F ..\..\bin\debug\ACEd.dll
+    if EXIST ..\..\bin\debug\ACEd.pdb                          del /F ..\..\bin\debug\ACEd.pdb
+    if EXIST ..\..\bin\debug\gd.dll                            del /F ..\..\bin\debug\gd.dll
+    if EXIST ..\..\bin\debug\gd.pdb                            del /F ..\..\bin\debug\gd.pdb
+    if EXIST ..\..\bin\debug\GEOSd.dll                         del /F ..\..\bin\debug\GEOSd.dll
+    if EXIST ..\..\bin\debug\GEOSd.pdb                         del /F ..\..\bin\debug\GEOSd.pdb
+    if EXIST ..\..\bin\debug\libdb48d.dll                      del /F ..\..\bin\debug\libdb48d.dll
+    if EXIST ..\..\bin\debug\libdb48d.pdb                      del /F ..\..\bin\debug\libdb48d.pdb
+    if EXIST ..\..\bin\debug\libdbxml25d.dll                   del /F ..\..\bin\debug\libdbxml25d.dll
+    if EXIST ..\..\bin\debug\libdbxml25d.pdb                   del /F ..\..\bin\debug\libdbxml25d.pdb
+    if EXIST ..\..\bin\debug\xqilla24d.dll                     del /F ..\..\bin\debug\xqilla24d.dll
+    if EXIST ..\..\bin\debug\xqilla24d.pdb                     del /F ..\..\bin\debug\xqilla24d.pdb
+    if EXIST ..\..\bin\debug\xerces-c_3_1mgD.dll               del /F ..\..\bin\debug\xerces-c_3_1mgD.dll
+    if EXIST ..\..\bin\debug\xerces-c_3_1mgD.pdb               del /F ..\..\bin\debug\xerces-c_3_1mgD.pdb
+    if EXIST ..\..\bin\debug\serverconfig.ini                  del /F ..\..\bin\debug\serverconfig.ini
+    if EXIST ..\..\bin\UnitTestFiles\*.*                       del /F /Q ..\..\bin\UnitTestFiles\*.*
     del /F   ..\..\bin\debug\*.ilk
@@ -1308,121 +738,7 @@
     if EXIST ..\..\bin\debug64\xerces-c_3_1mgD.dll             del /F ..\..\bin\debug64\xerces-c_3_1mgD.dll
     if EXIST ..\..\bin\debug64\xerces-c_3_1mgD.pdb             del /F ..\..\bin\debug64\xerces-c_3_1mgD.pdb
     if EXIST ..\..\bin\debug64\serverconfig.ini                del /F ..\..\bin\debug64\serverconfig.ini
     del /F   ..\..\bin\debug64\*.ilk
@@ -1458,121 +774,7 @@
     if EXIST ..\..\bin\release\xerces-c_3_1mg.dll            del /F ..\..\bin\release\xerces-c_3_1mg.dll
     if EXIST ..\..\bin\release\xerces-c_3_1mg.pdb            del /F ..\..\bin\release\xerces-c_3_1mg.pdb
     if EXIST ..\..\bin\release\serverconfig.ini              del /F ..\..\bin\release\serverconfig.ini
 cleanrelease64:
     if EXIST ..\..\bin\release64\MgFoundation.dll              del /F ..\..\bin\release64\MgFoundation.dll
@@ -1606,691 +808,20 @@
     if EXIST ..\..\bin\release64\xerces-c_3_1mg.dll            del /F ..\..\bin\release64\xerces-c_3_1mg.dll
     if EXIST ..\..\bin\release64\xerces-c_3_1mg.pdb            del /F ..\..\bin\release64\xerces-c_3_1mg.pdb
     if EXIST ..\..\bin\release64\serverconfig.ini              del /F ..\..\bin\release64\serverconfig.ini
-"..\..\..\UnitTest\TestData\ResourceService\LibraryRepositoryContent.xml" :
-"..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryHeader.xml" :
-"..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryContent.xml" :
-"..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" :
-"..\..\..\UnitTest\TestData\DrawingService\test.dwf" :
-"..\..\..\UnitTest\TestData\DrawingService\SpaceShip.dwf" :
-"..\..\..\UnitTest\TestData\DrawingService\MapGuideDrawingSource.xml" :
-"..\..\..\UnitTest\TestData\DrawingService\SpaceShipDrawingSource.xml" :
-"..\..\..\UnitTest\TestData\ResourceService\World_Countries.sdf" :
-"..\..\..\UnitTest\TestData\ResourceService\TEST.LayerDefinition" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.sdf" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.sdf" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.sdf" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.sdf" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\TESTChainedInner1ToManyJoin.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shp" :
-"..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.dbf" :
-"..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shx" :
-"..\..\..\UnitTest\TestData\MappingService\UT_AllElements.pl" :
-"..\..\..\UnitTest\TestData\MappingService\PlotHole.mgp" :
-"..\..\..\UnitTest\TestData\MappingService\UT_NoLegend.pl" :
-"..\..\..\UnitTest\TestData\MappingService\UT_SymbolMart.sl" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Symbols.dwf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs" :
-"..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Rail.sdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Rail.wdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Rail_Watermark.ldf" :
-"..\..\..\UnitTestFiles\UT_MultiCTS.ldf" :
-"..\..\..\UnitTestFiles\UT_MultiCTSWithTheme.ldf" :
-"..\..\..\UnitTestFiles\UT_MultiFTS.ldf" :
-"..\..\..\UnitTestFiles\UT_MultiFTSSingleCTS.ldf" :
-"..\..\..\UnitTestFiles\UT_MultiFTSWithTheme.ldf" :
-"..\..\..\UnitTestFiles\UT_SingleFTSMultiCTS.ldf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf" :
-"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" :
-"..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" :
-"..\..\..\UnitTest\TestData\TileService\UT_BaseMap_OrigSize.tsd" :
-"..\..\..\UnitTest\TestData\TileService\UT_BaseMap_Metatiled.tsd" :
-"..\..\..\UnitTest\TestData\TileService\UT_XYZ_Metatiled.tsd" :
-"..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" :
-"..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" :
-"..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.fs" :
-"..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.ldf" :
-"..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs" :
-"..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" :
-"..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" :
-"..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" :
-"..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd" :
-"..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt" :
-"..\..\..\UnitTest\TestData\CoordinateSystems\ogcwkts.txt" :
-"..\..\..\UnitTest\TestData\KmlService\UT_GetMapKmlResult.txt" :
-"..\..\..\UnitTest\TestData\KmlService\UT_GetLayerKmlResult.txt" :
-"..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt" :
-"..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf" :
-"..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" :
-"..\..\..\UnitTest\TestData\MdfModel\MdfTestDisabledBounds.ldf" :
-"..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" :
-"..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd" :
-"..\..\..\UnitTest\TestData\Symbology\areasymbol.sd" :
-"..\..\..\UnitTest\TestData\Symbology\linesymbol.sd" :
-"..\..\..\UnitTest\TestData\Symbology\symbol.sd" :
-"..\..\..\UnitTest\TestData\Symbology\symbolp.sd" :
-"..\..\..\UnitTest\TestData\Symbology\MTYP1500a.sd" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.fs" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.sdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.fs" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.sdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.fs" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.sdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyParcels.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPolygons.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Parcels_SQLite_Join.FeatureSource" :
-"..\..\..\UnitTest\TestData\Symbology\UT_FdoJoin.FeatureSource" :
-"..\..\..\UnitTest\TestData\Symbology\ParcelsJoinTest.sqlite" :
-"..\..\..\UnitTest\TestData\Symbology\JoinTest.sqlite" :
-..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml : "..\..\..\UnitTest\TestData\ResourceService\LibraryRepositoryContent.xml"
+CopyTestDataFiles:
     if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\LibraryRepositoryContent.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\LibraryRepositoryContent.xml" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml : "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryHeader.xml"
-    if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryHeader.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryHeader.xml" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SampleRepositoryContent.xml : "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryContent.xml"
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryContent.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryContent.xml" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Shuttle.zip : "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip"
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\test.dwf : "..\..\..\UnitTest\TestData\DrawingService\test.dwf"
-    if EXIST "..\..\..\UnitTest\TestData\DrawingService\test.dwf" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\test.dwf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SpaceShip.dwf : "..\..\..\UnitTest\TestData\DrawingService\SpaceShip.dwf"
-    if EXIST "..\..\..\UnitTest\TestData\DrawingService\SpaceShip.dwf" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\SpaceShip.dwf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml : "..\..\..\UnitTest\TestData\DrawingService\MapGuideDrawingSource.xml"
-    if EXIST "..\..\..\UnitTest\TestData\DrawingService\MapGuideDrawingSource.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\MapGuideDrawingSource.xml" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml : "..\..\..\UnitTest\TestData\DrawingService\SpaceShipDrawingSource.xml"
-    if EXIST "..\..\..\UnitTest\TestData\DrawingService\SpaceShipDrawingSource.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\SpaceShipDrawingSource.xml" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\World.mgp : "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip"
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" copy /y "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" ..\..\bin\UnitTestFiles\World.mgp
-..\..\bin\UnitTestFiles\World_Countries.sdf : "..\..\..\UnitTest\TestData\ResourceService\World_Countries.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\World_Countries.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\World_Countries.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\TEST.LayerDefinition : "..\..\..\UnitTest\TestData\ResourceService\TEST.LayerDefinition"
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\TEST.LayerDefinition" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\TEST.LayerDefinition" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\TEST.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\TEST.sdf : "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\TESTChainedInner1ToManyJoin.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\TESTChainedInner1ToManyJoin.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\TESTChainedInner1ToManyJoin.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Empty.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Empty.sdf : "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Redding_Parcels.shp : "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shp"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shp" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shp" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Redding_Parcels.dbf : "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.dbf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.dbf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.dbf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Redding_Parcels.shx : "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shx"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shx" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shx" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_AllElements.pl : "..\..\..\UnitTest\TestData\MappingService\UT_AllElements.pl"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_AllElements.pl" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_AllElements.pl" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\PlotHole.mgp : "..\..\..\UnitTest\TestData\MappingService\PlotHole.mgp"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\PlotHole.mgp" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\PlotHole.mgp" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_NoLegend.pl : "..\..\..\UnitTest\TestData\MappingService\UT_NoLegend.pl"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_NoLegend.pl" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_NoLegend.pl" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbolMart.sl : "..\..\..\UnitTest\TestData\MappingService\UT_SymbolMart.sl"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_SymbolMart.sl" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_SymbolMart.sl" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Symbols.dwf : "..\..\..\UnitTest\TestData\MappingService\UT_Symbols.dwf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Symbols.dwf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Symbols.dwf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf : "..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf : "..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Sheboygan.mdf : "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf : "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf : "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs : "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Rail.sdf : "..\..\..\UnitTest\TestData\MappingService\UT_Rail.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Rail.fs : "..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Rail.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Rail.wdf : "..\..\..\UnitTest\TestData\MappingService\UT_Rail.wdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.wdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.wdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_Rail_Watermark.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail_Watermark.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail_Watermark.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_MultiCTS.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTS.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTS.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_MultiCTSWithTheme.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTSWithTheme.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTSWithTheme.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTSWithTheme.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_MultiFTS.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTS.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTS.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_MultiFTSSingleCTS.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSSingleCTS.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSSingleCTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSSingleCTS.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_MultiFTSWithTheme.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSWithTheme.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSWithTheme.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSWithTheme.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SingleFTSMultiCTS.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_SingleFTSMultiCTS.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_SingleFTSMultiCTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_SingleFTSMultiCTS.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_RotatedPointStyles.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_BaseMap.mdf : "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_BaseMap.tsd : "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_XYZ.tsd : "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_BaseMap_OrigSize.tsd : "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_OrigSize.tsd"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_OrigSize.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_OrigSize.tsd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd : "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_Metatiled.tsd"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_Metatiled.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_Metatiled.tsd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd : "..\..\..\UnitTest\TestData\TileService\UT_XYZ_Metatiled.tsd"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_XYZ_Metatiled.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_XYZ_Metatiled.tsd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf : "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf : "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf : "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Parcels.fs : "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Parcels.ldf : "..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Parcels.sdf : "..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs : "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.fs"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf : "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf : "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_VotingDistricts.fs : "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf : "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf : "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf : "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\1.1.1.mgd : "..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd"
-    if EXIST "..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd" xcopy /r /d /y "..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\epsgcodes.txt : "..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt"
-    if EXIST "..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\ogcwkts.txt : "..\..\..\UnitTest\TestData\CoordinateSystems\ogcwkts.txt"
-    if EXIST "..\..\..\UnitTest\TestData\CoordinateSystems\ogcwkts.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\CoordinateSystems\ogcwkts.txt" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt : "..\..\..\UnitTest\TestData\KmlService\UT_GetMapKmlResult.txt"
-    if EXIST "..\..\..\UnitTest\TestData\KmlService\UT_GetMapKmlResult.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\KmlService\UT_GetMapKmlResult.txt" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt : "..\..\..\UnitTest\TestData\KmlService\UT_GetLayerKmlResult.txt"
-    if EXIST "..\..\..\UnitTest\TestData\KmlService\UT_GetLayerKmlResult.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\KmlService\UT_GetLayerKmlResult.txt" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt : "..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt"
-    if EXIST "..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MdfTestMap.mdf : "..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf : "..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MdfTestDisabledBounds.ldf : "..\..\..\UnitTest\TestData\MdfModel\MdfTestDisabledBounds.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestDisabledBounds.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestDisabledBounds.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd : "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd"
-    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd : "..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd"
-    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\areasymbol.sd : "..\..\..\UnitTest\TestData\Symbology\areasymbol.sd"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\areasymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\areasymbol.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\linesymbol.sd : "..\..\..\UnitTest\TestData\Symbology\linesymbol.sd"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\linesymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\linesymbol.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\symbol.sd : "..\..\..\UnitTest\TestData\Symbology\symbol.sd"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\symbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\symbol.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\symbolp.sd : "..\..\..\UnitTest\TestData\Symbology\symbolp.sd"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\symbolp.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\symbolp.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MTYP1500a.sd : "..\..\..\UnitTest\TestData\Symbology\MTYP1500a.sd"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\MTYP1500a.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\MTYP1500a.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLines.fs : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.fs"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.fs"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.fs"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyParcels.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyParcels.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyParcels.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPolygons.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPolygons.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPolygons.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation1.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation1.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation2.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation2.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation3.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation3.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SavePointTest.sqlite : "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.sqlite"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.sqlite" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.sqlite" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SavePointTest.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_Parcels_SQLite_Join.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_Parcels_SQLite_Join.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_Parcels_SQLite_Join.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_FdoJoin.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_FdoJoin.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_FdoJoin.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite : "..\..\..\UnitTest\TestData\FeatureService\SQLite\ParcelsJoinTest.sqlite"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\ParcelsJoinTest.sqlite" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\ParcelsJoinTest.sqlite" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\JoinTest.sqlite : "..\..\..\UnitTest\TestData\FeatureService\SQLite\JoinTest.sqlite"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\JoinTest.sqlite" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\JoinTest.sqlite" ..\..\bin\UnitTestFiles\
+    if EXIST "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" copy /y "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" "..\..\bin\UnitTestFiles\World.mgp"
+    if EXIST "..\..\..\UnitTest\TestData\CoordinateSystems\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\CoordinateSystems\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\DrawingService\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\KmlService\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\KmlService\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MdfModel\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\ResourceService\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\ServerAdmin\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\ServerAdmin\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\*.*" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\*.*" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\*.*" "..\..\bin\UnitTestFiles\"
More information about the mapguide-commits
