[mapguide-commits] r10024 - in sandbox/jng/basic_label_justification: Common/MdfModel Common/MdfParser Common/Schema Common/Stylization Server/src/UnitTesting UnitTest/TestData/Symbology
svn_mapguide at osgeo.org
Sat Feb 4 05:50:49 PST 2023
Author: jng
Date: 2023-02-04 05:50:48 -0800 (Sat, 04 Feb 2023)
New Revision: 10024
Added:
sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyCenter.ldf
sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyCenter.mdf
sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyLeft.ldf
sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyLeft.mdf
sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyRight.ldf
sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyRight.mdf
sandbox/jng/basic_label_justification/Common/MdfModel/TextSymbol.cpp
sandbox/jng/basic_label_justification/Common/MdfModel/TextSymbol.h
sandbox/jng/basic_label_justification/Common/MdfParser/IOLabel.cpp
sandbox/jng/basic_label_justification/Common/Schema/LayerDefinition-4.0.0.xsd
sandbox/jng/basic_label_justification/Common/Stylization/GeometryAdapter.cpp
sandbox/jng/basic_label_justification/Common/Stylization/GeometryAdapter.h
sandbox/jng/basic_label_justification/Server/src/UnitTesting/TestRenderingService.cpp
sandbox/jng/basic_label_justification/Server/src/UnitTesting/TestServiceFactory.cpp
#772: Add basic stylization support for justification of labels. This support already existed in the rendering/stylization engine. The justification setting simply never surfaced to any supported element in the current Layer Definition XML schema, so it always defaulted to left justification. This setting will be most impactful when dealing with multi-line feature labels where such a setting becomes important.
New rendering service tests have been added to exercise the various label justification settings. Manually inspecting the rendered results verifies the new justification setting is being respected.
Since we're here, we are also cleaning up the current v4.0.0 schema by making the previously introduced IncludeBoundsForSelectedFeatures element optional.
Modified: sandbox/jng/basic_label_justification/Common/MdfModel/TextSymbol.cpp
--- sandbox/jng/basic_label_justification/Common/MdfModel/TextSymbol.cpp 2023-02-04 12:10:15 UTC (rev 10023)
+++ sandbox/jng/basic_label_justification/Common/MdfModel/TextSymbol.cpp 2023-02-04 13:50:48 UTC (rev 10024)
@@ -44,6 +44,7 @@
this->m_strBold = L"false"; // NOXLATE
this->m_strItalic = L"false"; // NOXLATE
this->m_strUnderlined = L"false"; // NOXLATE
+ this->m_strLabelJustification = L"'Left'"; //NOXLATE
#ifdef MG_ZERO_SCALELIMIT
this->m_dScaleLimit = 0.0;
#else
@@ -245,6 +246,33 @@
+// PURPOSE: Accessor method for the LabelJustification property in this
+// TextSymbol. LabelJustification is of type Expression:String,
+// which is an expression that evaluates to the text representation
+// of a member of the enum RS_Justify.
+// RETURNS: The string representation of the Expression:String. Default is
+// "Left".
+const MdfString& TextSymbol::GetLabelJustification() const
+ return this->m_strLabelJustification;
+// PARAMETERS:
+// strLabelJustification - The string representation of the
+// Expression:String.
+void TextSymbol::SetLabelJustification(const MdfString& strLabelJustification)
+ this->m_strLabelJustification = strLabelJustification;
// PURPOSE: Accessor method for the Bold property in this TextSymbol.
// The property is of type Expression:Boolean, which is an
// expression that evaluates to a bool for a given feature.
Modified: sandbox/jng/basic_label_justification/Common/MdfModel/TextSymbol.h
--- sandbox/jng/basic_label_justification/Common/MdfModel/TextSymbol.h 2023-02-04 12:10:15 UTC (rev 10023)
+++ sandbox/jng/basic_label_justification/Common/MdfModel/TextSymbol.h 2023-02-04 13:50:48 UTC (rev 10024)
@@ -94,6 +94,10 @@
const MdfString& GetVerticalAlignment() const;
void SetVerticalAlignment(const MdfString& strVrtAlignment);
+ // Property : LabelJustification
+ const MdfString& GetLabelJustification() const;
+ void SetLabelJustification(const MdfString& strLabelJustification);
// Property : Bold Type : Expression:Boolean
const MdfString& GetBold() const;
void SetBold(const MdfString& strBoldExpr);
@@ -144,6 +148,9 @@
// The Expression:enum string representation for the vertical orientation.
MdfString m_strVrtAlignment;
+ // The Expression:enum string representation for the label justification.
+ MdfString m_strLabelJustification;
// The Expression:Boolean string representation for Bold style.
MdfString m_strBold;
Modified: sandbox/jng/basic_label_justification/Common/MdfParser/IOLabel.cpp
--- sandbox/jng/basic_label_justification/Common/MdfParser/IOLabel.cpp 2023-02-04 12:10:15 UTC (rev 10023)
+++ sandbox/jng/basic_label_justification/Common/MdfParser/IOLabel.cpp 2023-02-04 13:50:48 UTC (rev 10024)
@@ -48,7 +48,8 @@
ELEM_MAP_ENTRY(19, Underlined);
ELEM_MAP_ENTRY(20, AdvancedPlacement);
ELEM_MAP_ENTRY(21, ScaleLimit);
-ELEM_MAP_ENTRY(22, ExtendedData1);
+ELEM_MAP_ENTRY(22, LabelJustification);
+ELEM_MAP_ENTRY(23, ExtendedData1);
IOLabel::IOLabel(Version& version) : SAX2ElementHandler(version)
@@ -167,6 +168,10 @@
symbol->SetVerticalAlignment(ch);
break;
+ case eLabelJustification:
+ symbol->SetLabelJustification(ch);
+ break;
case eBold:
symbol->SetBold(ch);
break;
@@ -298,6 +303,14 @@
fd << endStr(sVerticalAlignment) << std::endl;
+ // Property: LabelJustification
+ if (symbol->GetLabelJustification() != L"'Left'") // NOXLATE
+ fd << tab.tab() << startStr(sLabelJustification);
+ fd << EncodeString(symbol->GetLabelJustification());
+ fd << endStr(sLabelJustification) << std::endl;
// Property: Bold
if (wstrToBool(symbol->GetBold().c_str()))
Modified: sandbox/jng/basic_label_justification/Common/Schema/LayerDefinition-4.0.0.xsd
--- sandbox/jng/basic_label_justification/Common/Schema/LayerDefinition-4.0.0.xsd 2023-02-04 12:10:15 UTC (rev 10023)
+++ sandbox/jng/basic_label_justification/Common/Schema/LayerDefinition-4.0.0.xsd 2023-02-04 13:50:48 UTC (rev 10024)
@@ -124,7 +124,7 @@
<xs:documentation>A boolean FDO expression that specifies which features to return. No filter means pass all features through.</xs:documentation>
</xs:annotation>
</xs:element>
- <xs:element name="IncludeBoundsForSelectedFeatures" type="xs:boolean" default="true">
+ <xs:element name="IncludeBoundsForSelectedFeatures" type="xs:boolean" default="true" minOccurs="0">
<xs:annotation>
<xs:documentation>Controls whether bounding box data is included with selected features when selecting from this layer</xs:documentation>
</xs:annotation>
@@ -601,6 +601,11 @@
</xs:sequence>
</xs:complexType>
</xs:element>
+ <xs:element name="LabelJustification" type="xs:string" default="'Left'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A string FDO expression for the label justification. Must evaluate to one of the 'Left', 'Right', ''.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
<xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0"/>
</xs:sequence>
</xs:extension>
Modified: sandbox/jng/basic_label_justification/Common/Stylization/GeometryAdapter.cpp
--- sandbox/jng/basic_label_justification/Common/Stylization/GeometryAdapter.cpp 2023-02-04 12:10:15 UTC (rev 10023)
+++ sandbox/jng/basic_label_justification/Common/Stylization/GeometryAdapter.cpp 2023-02-04 13:50:48 UTC (rev 10024)
@@ -486,6 +486,58 @@
+bool GeometryAdapter::ConvertLabelJustification(const MdfModel::MdfString& justify, RS_Justify& rsjustify)
+ // first check if the expression is a constant - in that case it can be cached
+ if (justify == L"'Center'")
+ rsjustify = RS_Justify_Center;
+ return true;
+ else if (justify == L"'Justify'")
+ rsjustify = RS_Justify_Justify;
+ return true;
+ else if (justify == L"'Left'")
+ rsjustify = RS_Justify_Left;
+ return true;
+ else if (justify == L"'Right'")
+ rsjustify = RS_Justify_Right;
+ return true;
+ // Otherwise we need to evaluate as expression. If it is an expression,
+ // the value will come back without quotes.
+ RS_String str;
+ /*bool dummy =*/ EvalString(justify, str);
+ if (str == L"'Center'")
+ else if (str == L"'Justify'")
+ else if (str == L"'Left'")
+ else if (str == L"'Right'")
+ // not cacheable
+ return false;
bool GeometryAdapter::ConvertSymbol(MdfModel::Symbol* symbol, RS_MarkerDef& mdef)
SymbolVisitor::eSymbolType type = SymbolVisitor::DetermineSymbolType(symbol);
@@ -671,6 +723,9 @@
cacheable = ConvertTextHAlign(text->GetHorizontalAlignment(), tdef.halign()) && cacheable;
cacheable = ConvertTextVAlign(text->GetVerticalAlignment(), tdef.valign()) && cacheable;
+ // justification
+ cacheable = ConvertLabelJustification(text->GetLabelJustification(), tdef.justify()) && cacheable;
return cacheable;
Modified: sandbox/jng/basic_label_justification/Common/Stylization/GeometryAdapter.h
--- sandbox/jng/basic_label_justification/Common/Stylization/GeometryAdapter.h 2023-02-04 12:10:15 UTC (rev 10023)
+++ sandbox/jng/basic_label_justification/Common/Stylization/GeometryAdapter.h 2023-02-04 13:50:48 UTC (rev 10024)
@@ -54,6 +54,7 @@
STYLIZATION_API bool ConvertFill (MdfModel::AreaSymbolization2D* fill, RS_FillStyle& rsfill);
STYLIZATION_API bool ConvertTextHAlign(const MdfModel::MdfString& halign, RS_HAlignment& rshalign);
STYLIZATION_API bool ConvertTextVAlign(const MdfModel::MdfString& valign, RS_VAlignment& rsvalign);
+ STYLIZATION_API bool ConvertLabelJustification(const MdfModel::MdfString& justify, RS_Justify& rsjustify);
STYLIZATION_API bool ConvertSymbol (MdfModel::Symbol* symbol, RS_MarkerDef& mdef);
STYLIZATION_API bool ConvertTextDef (MdfModel::TextSymbol* text, RS_TextDef& tdef);
Modified: sandbox/jng/basic_label_justification/Server/src/UnitTesting/TestRenderingService.cpp
--- sandbox/jng/basic_label_justification/Server/src/UnitTesting/TestRenderingService.cpp 2023-02-04 12:10:15 UTC (rev 10023)
+++ sandbox/jng/basic_label_justification/Server/src/UnitTesting/TestRenderingService.cpp 2023-02-04 13:50:48 UTC (rev 10024)
@@ -114,6 +114,28 @@
return map;
+static MgMap* CreateLabelJustifyMap(CREFSTRING justify)
+ Ptr<MgServerSiteService> svcSite = TestServiceFactory::CreateSiteService();
+ Ptr<MgSiteConnection> m_siteConnection = TestServiceFactory::CreateSiteConnection(svcSite);
+ STRING sMdfId = L"Library://UnitTests/Maps/LabelJustify" + justify + L".MapDefinition";
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(sMdfId);
+ MgMap* map = new MgMap(m_siteConnection);
+ map->Create(mdfres, mdfres->GetName());
+ Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.733253, 43.746199);
+ Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
+ map->SetViewCenter(ptNewCenter);
+ map->SetViewScale(75000.0);
+ map->SetDisplayDpi(96);
+ map->SetDisplayWidth(1024);
+ map->SetDisplayHeight(1024);
+ return map;
static MgMap* CreateTestTiledMap()
@@ -1229,6 +1251,60 @@
+static void TestCase_LabelJustifyLeft(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgRenderingService> svcRendering = TestServiceFactory::CreateRenderingService();
+ Ptr<MgMap> map = CreateLabelJustifyMap(L"Left");
+ Ptr<MgByteReader> image = svcRendering->RenderMap(map, nullptr, imageFormat);
+ image->ToFile(GetPath(L"../UnitTestFiles/LabelJustifyLeft", imageFormat, extension));
+ catch (MgException* e)
+ STRING message = e->GetDetails(TestServiceFactory::TEST_LOCALE);
+ SAFE_RELEASE(e);
+ FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+static void TestCase_LabelJustifyRight(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgMap> map = CreateLabelJustifyMap(L"Right");
+ image->ToFile(GetPath(L"../UnitTestFiles/LabelJustifyRight", imageFormat, extension));
+ SAFE_RELEASE(e);
+static void TestCase_LabelJustifyCenter(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgMap> map = CreateLabelJustifyMap(L"Center");
+ image->ToFile(GetPath(L"../UnitTestFiles/LabelJustifyCenter", imageFormat, extension));
+ SAFE_RELEASE(e);
static void TestCase_RenderMetatile(CREFSTRING imageFormat, CREFSTRING extension)
try
@@ -1665,6 +1741,21 @@
TEST_CASE("RenderXYZMetatileJPG_4x", "[RenderingService]") { TestCase_RenderXYZMetatile(L"JPG", L"jpg", 4); }
TEST_CASE("RenderXYZMetatileGIF_4x", "[RenderingService]") { TestCase_RenderXYZMetatile(L"GIF", L"gif", 4); }
+TEST_CASE("RenderLabelJustifyLeftPNG", "[RenderingService]") { TestCase_LabelJustifyLeft(L"PNG", L"png"); }
+TEST_CASE("RenderLabelJustifyLeftPNG8", "[RenderingService]") { TestCase_LabelJustifyLeft(L"PNG8", L"png"); }
+TEST_CASE("RenderLabelJustifyLeftJPG", "[RenderingService]") { TestCase_LabelJustifyLeft(L"JPG", L"jpg"); }
+TEST_CASE("RenderLabelJustifyLeftGIF", "[RenderingService]") { TestCase_LabelJustifyLeft(L"GIF", L"gif"); }
+TEST_CASE("RenderLabelJustifyRightPNG", "[RenderingService]") { TestCase_LabelJustifyRight(L"PNG", L"png"); }
+TEST_CASE("RenderLabelJustifyRightPNG8", "[RenderingService]") { TestCase_LabelJustifyRight(L"PNG8", L"png"); }
+TEST_CASE("RenderLabelJustifyRightJPG", "[RenderingService]") { TestCase_LabelJustifyRight(L"JPG", L"jpg"); }
+TEST_CASE("RenderLabelJustifyRightGIF", "[RenderingService]") { TestCase_LabelJustifyRight(L"GIF", L"gif"); }
+TEST_CASE("RenderLabelJustifyCenterPNG", "[RenderingService]") { TestCase_LabelJustifyCenter(L"PNG", L"png"); }
+TEST_CASE("RenderLabelJustifyCenterPNG8", "[RenderingService]") { TestCase_LabelJustifyCenter(L"PNG8", L"png"); }
+TEST_CASE("RenderLabelJustifyCenterJPG", "[RenderingService]") { TestCase_LabelJustifyCenter(L"JPG", L"jpg"); }
+TEST_CASE("RenderLabelJustifyCenterGIF", "[RenderingService]") { TestCase_LabelJustifyCenter(L"GIF", L"gif"); }
TEST_CASE("RenderMapBigPNG", "[RenderingService_Stress]")
try
Modified: sandbox/jng/basic_label_justification/Server/src/UnitTesting/TestServiceFactory.cpp
--- sandbox/jng/basic_label_justification/Server/src/UnitTesting/TestServiceFactory.cpp 2023-02-04 12:10:15 UTC (rev 10023)
+++ sandbox/jng/basic_label_justification/Server/src/UnitTesting/TestServiceFactory.cpp 2023-02-04 13:50:48 UTC (rev 10024)
@@ -654,6 +654,21 @@
Ptr<MgByteReader> mdfrdr1 = mdfsrc1->GetReader();
svcResource->SetResource(mapres1, mdfrdr1, nullptr);
+ Ptr<MgResourceIdentifier> mapres22 = new MgResourceIdentifier(L"Library://UnitTests/Maps/LabelJustifyLeft.MapDefinition");
+ Ptr<MgByteSource> mdfsrc22 = new MgByteSource(L"../UnitTestFiles/UT_LabelJustifyLeft.mdf", false);
+ Ptr<MgByteReader> mdfrdr22 = mdfsrc22->GetReader();
+ svcResource->SetResource(mapres22, mdfrdr22, nullptr);
+ Ptr<MgResourceIdentifier> mapres23 = new MgResourceIdentifier(L"Library://UnitTests/Maps/LabelJustifyRight.MapDefinition");
+ Ptr<MgByteSource> mdfsrc23 = new MgByteSource(L"../UnitTestFiles/UT_LabelJustifyRight.mdf", false);
+ Ptr<MgByteReader> mdfrdr23 = mdfsrc23->GetReader();
+ svcResource->SetResource(mapres23, mdfrdr23, nullptr);
+ Ptr<MgResourceIdentifier> mapres24 = new MgResourceIdentifier(L"Library://UnitTests/Maps/LabelJustifyCenter.MapDefinition");
+ Ptr<MgByteSource> mdfsrc24 = new MgByteSource(L"../UnitTestFiles/UT_LabelJustifyCenter.mdf", false);
+ Ptr<MgByteReader> mdfrdr24 = mdfsrc24->GetReader();
+ svcResource->SetResource(mapres24, mdfrdr24, nullptr);
// publish tile set
Ptr<MgResourceIdentifier> tilesetres1 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ.TileSetDefinition");
Ptr<MgByteSource> tsdsrc1 = new MgByteSource(L"../UnitTestFiles/UT_XYZ.tsd", false);
@@ -676,6 +691,21 @@
Ptr<MgByteReader> ldfrdr3 = ldfsrc3->GetReader();
svcResource->SetResource(ldfres3, ldfrdr3, nullptr);
+ Ptr<MgResourceIdentifier> ldfres24 = new MgResourceIdentifier(L"Library://UnitTests/Layers/LabelJustifyLeft.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc24 = new MgByteSource(L"../UnitTestFiles/UT_LabelJustifyLeft.ldf", false);
+ Ptr<MgByteReader> ldfrdr24 = ldfsrc24->GetReader();
+ svcResource->SetResource(ldfres24, ldfrdr24, nullptr);
+ Ptr<MgResourceIdentifier> ldfres25 = new MgResourceIdentifier(L"Library://UnitTests/Layers/LabelJustifyRight.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc25 = new MgByteSource(L"../UnitTestFiles/UT_LabelJustifyRight.ldf", false);
+ Ptr<MgByteReader> ldfrdr25 = ldfsrc25->GetReader();
+ svcResource->SetResource(ldfres25, ldfrdr25, nullptr);
+ Ptr<MgResourceIdentifier> ldfres26 = new MgResourceIdentifier(L"Library://UnitTests/Layers/LabelJustifyCenter.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc26 = new MgByteSource(L"../UnitTestFiles/UT_LabelJustifyCenter.ldf", false);
+ Ptr<MgByteReader> ldfrdr26 = ldfsrc26->GetReader();
+ svcResource->SetResource(ldfres26, ldfrdr26, nullptr);
// publish the feature sources
Ptr<MgResourceIdentifier> fsres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/HydrographicPolygons.FeatureSource");
Ptr<MgByteSource> fssrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.fs", false);
@@ -1936,6 +1966,15 @@
Ptr<MgResourceIdentifier> mapres1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
svcResource->DeleteResource(mapres1);
+ svcResource->DeleteResource(mapres22);
+ svcResource->DeleteResource(mapres23);
+ svcResource->DeleteResource(mapres24);
// delete tile set
svcResource->DeleteResource(tilesetres1);
@@ -1950,6 +1989,15 @@
Ptr<MgResourceIdentifier> ldfres3 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
svcResource->DeleteResource(ldfres3);
+ svcResource->DeleteResource(ldfres24);
+ svcResource->DeleteResource(ldfres25);
+ svcResource->DeleteResource(ldfres26);
// delete the feature sources
svcResource->DeleteResource(fsres1);
Added: sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyCenter.ldf
--- sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyCenter.ldf (rev 0)
+++ sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyCenter.ldf 2023-02-04 13:50:48 UTC (rev 10024)
@@ -0,0 +1,43 @@
+<?xml version="1.0" encoding="utf-8"?>
+<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="4.0.0" xsi:noNamespaceSchemaLocation="LayerDefinition-4.0.0.xsd">
+ <VectorLayerDefinition>
+ <ResourceId>Library://UnitTests/Data/VotingDistricts.FeatureSource</ResourceId>
+ <FeatureName>Default:VotingDistricts</FeatureName>
+ <FeatureNameType>FeatureClass</FeatureNameType>
+ <Geometry>Geometry</Geometry>
+ <VectorScaleRange>
+ <MinScale>10000</MinScale>
+ <AreaTypeStyle>
+ <AreaRule>
+ <LegendLabel />
+ <Label>
+ <Unit>Points</Unit>
+ <SizeContext>DeviceUnits</SizeContext>
+ <SizeX>0</SizeX>
+ <SizeY>10</SizeY>
+ <Text>concat('District\n', ID)</Text>
+ <FontName>Verdana</FontName>
+ <ForegroundColor>FF625231</ForegroundColor>
+ <BackgroundColor>FFFFFFFF</BackgroundColor>
+ <BackgroundStyle>Transparent</BackgroundStyle>
+ <LabelJustification>'Center'</LabelJustification>
+ </Label>
+ <AreaSymbolization2D>
+ <Fill>
+ <FillPattern>None</FillPattern>
+ <ForegroundColor>00FFFFFF</ForegroundColor>
+ <BackgroundColor>FF000000</BackgroundColor>
+ </Fill>
+ <Stroke>
+ <LineStyle>Solid</LineStyle>
+ <Thickness>0</Thickness>
+ <Color>FFA68B53</Color>
+ <Unit>Inches</Unit>
+ </Stroke>
+ </AreaSymbolization2D>
+ </AreaRule>
+ </AreaTypeStyle>
+ </VectorScaleRange>
+ </VectorLayerDefinition>
+</LayerDefinition>
\ No newline at end of file
Added: sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyCenter.mdf
--- sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyCenter.mdf (rev 0)
+++ sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyCenter.mdf 2023-02-04 13:50:48 UTC (rev 10024)
@@ -0,0 +1,22 @@
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
+ <Name>New Map</Name>
+ <CoordinateSystem>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</CoordinateSystem>
+ <Extents>
+ <MinX>-87.76498623679663</MinX>
+ <MaxX>-87.69551753753811</MaxX>
+ <MinY>43.691398447253356</MinY>
+ <MaxY>43.7975198255836</MaxY>
+ </Extents>
+ <BackgroundColor>ffffffff</BackgroundColor>
+ <MapLayer>
+ <Name>Districts</Name>
+ <ResourceId>Library://UnitTests/Layers/LabelJustifyCenter.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <ShowInLegend>true</ShowInLegend>
+ <LegendLabel>Districts</LegendLabel>
+ <ExpandInLegend>true</ExpandInLegend>
+ <Visible>true</Visible>
+ <Group />
+ </MapLayer>
+</MapDefinition>
Added: sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyLeft.ldf
--- sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyLeft.ldf (rev 0)
+++ sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyLeft.ldf 2023-02-04 13:50:48 UTC (rev 10024)
@@ -0,0 +1,43 @@
+ <AreaTypeStyle>
+ <AreaRule>
+ <LegendLabel />
+ <Label>
+ <SizeX>0</SizeX>
+ <SizeY>10</SizeY>
+ <LabelJustification>'Left'</LabelJustification>
+ </Label>
+ <Fill>
+ </Fill>
+ <Stroke>
+ </Stroke>
+ </AreaRule>
+ </AreaTypeStyle>
+</LayerDefinition>
Added: sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyLeft.mdf
--- sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyLeft.mdf (rev 0)
+++ sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyLeft.mdf 2023-02-04 13:50:48 UTC (rev 10024)
@@ -0,0 +1,22 @@
+ <Extents>
+ </Extents>
+ <MapLayer>
+ <ResourceId>Library://UnitTests/Layers/LabelJustifyLeft.LayerDefinition</ResourceId>
+ <Group />
+ </MapLayer>
+</MapDefinition>
Added: sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyRight.ldf
--- sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyRight.ldf (rev 0)
+++ sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyRight.ldf 2023-02-04 13:50:48 UTC (rev 10024)
@@ -0,0 +1,43 @@
+ <AreaTypeStyle>
+ <AreaRule>
+ <LegendLabel />
+ <Label>
+ <SizeX>0</SizeX>
+ <SizeY>10</SizeY>
+ <LabelJustification>'Right'</LabelJustification>
+ </Label>
+ <Fill>
+ </Fill>
+ <Stroke>
+ </Stroke>
+ </AreaRule>
+ </AreaTypeStyle>
+</LayerDefinition>
Added: sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyRight.mdf
--- sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyRight.mdf (rev 0)
+++ sandbox/jng/basic_label_justification/UnitTest/TestData/Symbology/UT_LabelJustifyRight.mdf 2023-02-04 13:50:48 UTC (rev 10024)
@@ -0,0 +1,22 @@
+ <Extents>
+ </Extents>
+ <MapLayer>
+ <ResourceId>Library://UnitTests/Layers/LabelJustifyRight.LayerDefinition</ResourceId>
+ <Group />
+ </MapLayer>
+</MapDefinition>
More information about the mapguide-commits
