[mapguide-commits] r10028 - trunk/MgDev/Oem/agg-2.4/include
svn_mapguide at osgeo.org
Mon Feb 13 02:07:25 PST 2023
Author: jng
Date: 2023-02-13 02:07:24 -0800 (Mon, 13 Feb 2023)
New Revision: 10028
trunk/MgDev/Oem/agg-2.4/include/agg_font_cache_manager.h
A commentary update on the saga of #2570
No actual code changes.
Modified: trunk/MgDev/Oem/agg-2.4/include/agg_font_cache_manager.h
--- trunk/MgDev/Oem/agg-2.4/include/agg_font_cache_manager.h 2023-02-09 11:58:27 UTC (rev 10027)
+++ trunk/MgDev/Oem/agg-2.4/include/agg_font_cache_manager.h 2023-02-13 10:07:24 UTC (rev 10028)
@@ -172,6 +172,37 @@
if(m_num_fonts >= m_max_fonts)
obj_allocator<font_cache>::deallocate(m_fonts[0]);
+ UPDATE 13/02/2023:
+ Way back in r8844 (30/11/2015) we changed this call from memcpy to memmove
+ without a real explanation as to why (other than: So this code no longer segfaults
+ on Ubuntu 14.04 at the time)
+ With this update, we now have a proper explanation.
+ In glibc 2.14, an optimization was added to memcpy that makes it faster, but will
+ no longer work with overlapping memory ranges.
+ Our previous Ubuntu target before discovery of this issue and applying the subsequent
+ fix in r8844 was 12.04 LTS which shipped with glibc 2.13 (that pre-dates this
+ behavior change)
+ Ubuntu 14.04 shipped with glibc 2.19 (that has this memcpy behavior change), causing
+ this new segfaulting behavior due to the default linking policy of always choosing the latest
+ version of any given libc symbol.
+ The change to memmove was because at that time we didn't know of a possible alternative
+ solution: To explictly use the version of memcpy introduced in glibc 2.2.5 (ie. memcpy at GLIBC_2.2.5)
+ through the use of .symver asm directive
+ However, what's done is done and there's no point changing back because things work just
+ fine with memmove. This big wall of text is just to explain why the change from memcpy
+ to memmove was made.
+ Ref that sparked this commentary:
+ https://blog.gibson.sh/2017/11/26/creating-portable-linux-binaries/#example-glibc-s-memcpy
memmove(m_fonts,
m_fonts + 1,
(m_max_fonts - 1) * sizeof(font_cache*));
More information about the mapguide-commits
