[mapguide-commits] r10034 - in trunk/MgDev: . Bindings/src/Bindings/DotNet Bindings/src/Bindings/DotNet/Foundation Bindings/src/Bindings/DotNet/Geometry Bindings/src/Bindings/DotNet/MapGuideCommon Bindings/src/Bindings/DotNet/PlatformBase Bindings/src/Bindings/DotNet/Portable Bindings/src/Bindings/DotNet/Web
svn_mapguide at osgeo.org
Mon Mar 20 07:51:05 PDT 2023
Author: jng
Date: 2023-03-20 07:51:04 -0700 (Mon, 20 Mar 2023)
New Revision: 10034
trunk/MgDev/Bindings/src/Bindings/DotNet/DotNetUnmanagedApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/Portable/PortableApi.vcxproj
trunk/MgDev/Bindings/src/Bindings/DotNet/Web/WebApi.vcxproj
trunk/MgDev/setenvironment64.bat
Now that SWIG 4.1 is actually released, standardize our environment around requiring an installed copy of SWIG 4.1.1
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/DotNetUnmanagedApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/DotNetUnmanagedApi.vcxproj 2023-03-20 12:54:05 UTC (rev 10033)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/DotNetUnmanagedApi.vcxproj 2023-03-20 14:51:04 UTC (rev 10034)
@@ -60,7 +60,7 @@
"..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)..\MapGuideApi\Constants.xml" -l C# -o "$(ProjectDir)..\..\Managed\DotNet\MapGuideDotNetApi\Constants.cs" -t
copy "$(ProjectDir)dotnetcore.i" "$(ProjectDir)language.i"
"..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)..\MapGuideApi\MapGuideApiGen.xml" -l C#
-"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module MapGuideDotNetUnmanagedApi -o "$(ProjectDir)MgApi_wrap.cpp" -outdir "$(ProjectDir)..\..\Managed\DotNet\MapGuideDotNetApi" MapGuideApi.i
+"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -DSWIG_CSHARP_NO_WSTRING_EXCEPTION_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module MapGuideDotNetUnmanagedApi -o "$(ProjectDir)MgApi_wrap.cpp" -outdir "$(ProjectDir)..\..\Managed\DotNet\MapGuideDotNetApi" MapGuideApi.i
del /Q ..\..\Managed\DotNet\MapGuideDotNetApi\MapGuideDotNetUnmanagedApi.cs
</Command>
</PreBuildEvent>
@@ -97,7 +97,7 @@
</Command>
</PreBuildEvent>
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApi.vcxproj 2023-03-20 12:54:05 UTC (rev 10033)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/Foundation/FoundationApi.vcxproj 2023-03-20 14:51:04 UTC (rev 10034)
@@ -61,7 +61,7 @@
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)FoundationConstants.xml" -l C# -o "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Foundation\Constants.cs" -t
copy "$(ProjectDir)..\dotnetcore_split.i" "$(ProjectDir)language.i"
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)FoundationApiGen.xml" -l C# -x "FoundationApi"
-"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module FoundationUnmanagedApi -o "$(ProjectDir)FoundationUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Foundation" FoundationApi.i
+"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -DSWIG_CSHARP_NO_WSTRING_EXCEPTION_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module FoundationUnmanagedApi -o "$(ProjectDir)FoundationUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Foundation" FoundationApi.i
del /Q ..\..\..\Managed\DotNet\OSGeo.MapGuide.Foundation\FoundationUnmanagedApi.cs
copy /Y "$(ProjectDir)..\..\..\..\..\Web\bin\$(Configuration)64\ACE*.*" "$(TargetDir)\native\"
copy /Y "$(ProjectDir)..\..\..\..\..\Web\bin\$(Configuration)64\xerces-c*.*" "$(TargetDir)\native\"
@@ -102,7 +102,7 @@
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApi.vcxproj 2023-03-20 12:54:05 UTC (rev 10033)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/Geometry/GeometryApi.vcxproj 2023-03-20 14:51:04 UTC (rev 10034)
@@ -61,7 +61,7 @@
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)GeometryConstants.xml" -l C# -o "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Geometry\Constants.cs" -t
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)GeometryApiGen.xml" -l C# -x "GeometryApi"
-"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module GeometryUnmanagedApi -o "$(ProjectDir)GeometryUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Geometry" GeometryApi.i
+"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -DSWIG_CSHARP_NO_WSTRING_EXCEPTION_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module GeometryUnmanagedApi -o "$(ProjectDir)GeometryUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Geometry" GeometryApi.i
del /Q ..\..\..\Managed\DotNet\OSGeo.MapGuide.Geometry\GeometryUnmanagedApi.cs
</Command>
</PreBuildEvent>
@@ -98,7 +98,7 @@
copy /Y "$(ProjectDir)..\..\..\..\..\Web\bin\$(Configuration)64\GEOS*.*" "$(TargetDir)\native\"
copy /Y "$(ProjectDir)..\..\..\..\..\Common\bin\$(Configuration)64\MgGeometry*.*" "$(TargetDir)\native\"
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApi.vcxproj 2023-03-20 12:54:05 UTC (rev 10033)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/MapGuideCommon/MapGuideCommonApi.vcxproj 2023-03-20 14:51:04 UTC (rev 10034)
@@ -61,7 +61,7 @@
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)MapGuideCommonConstants.xml" -l C# -o "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon\Constants.cs" -t
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)MapGuideCommonApiGen.xml" -l C# -x "MapGuideCommonApi"
-"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module MapGuideCommonUnmanagedApi -o "$(ProjectDir)MapGuideCommonUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon" MapGuideCommonApi.i
+"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -DSWIG_CSHARP_NO_WSTRING_EXCEPTION_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module MapGuideCommonUnmanagedApi -o "$(ProjectDir)MapGuideCommonUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon" MapGuideCommonApi.i
del /Q ..\..\..\Managed\DotNet\OSGeo.MapGuide.MapGuideCommon\MapGuideCommonUnmanagedApi.cs
copy /Y "$(ProjectDir)..\..\..\..\..\Common\bin\$(Configuration)64\MgMapGuideCommon*.*" "$(TargetDir)\native\"
</Command>
@@ -99,7 +99,7 @@
</Command>
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj 2023-03-20 12:54:05 UTC (rev 10033)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/PlatformBase/PlatformBaseApi.vcxproj 2023-03-20 14:51:04 UTC (rev 10034)
@@ -61,7 +61,7 @@
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)PlatformBaseConstants.xml" -l C# -o "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.PlatformBase\Constants.cs" -t
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)PlatformBaseApiGen.xml" -l C# -x "PlatformBaseApi"
-"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module PlatformBaseUnmanagedApi -o "$(ProjectDir)PlatformBaseUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.PlatformBase" PlatformBaseApi.i
+"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -DSWIG_CSHARP_NO_WSTRING_EXCEPTION_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module PlatformBaseUnmanagedApi -o "$(ProjectDir)PlatformBaseUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.PlatformBase" PlatformBaseApi.i
del /Q ..\..\..\Managed\DotNet\OSGeo.MapGuide.PlatformBase\PlatformBaseUnmanagedApi.cs
copy /Y "$(ProjectDir)..\..\..\..\..\Common\bin\$(Configuration)64\MgMdfParser*.*" "$(TargetDir)\native\"
copy /Y "$(ProjectDir)..\..\..\..\..\Common\bin\$(Configuration)64\MgPlatformBase*.*" "$(TargetDir)\native\"
@@ -100,7 +100,7 @@
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/Portable/PortableApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/Portable/PortableApi.vcxproj 2023-03-20 12:54:05 UTC (rev 10033)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/Portable/PortableApi.vcxproj 2023-03-20 14:51:04 UTC (rev 10034)
@@ -61,7 +61,7 @@
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)PortableConstants.xml" -l C# -o "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Portable\Constants.cs" -t
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)PortableApiGen.xml" -l C# -x "PortableApi"
-"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module PortableUnmanagedApi -o "$(ProjectDir)PortableUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Portable" PortableApi.i
+"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -DSWIG_CSHARP_NO_WSTRING_EXCEPTION_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module PortableUnmanagedApi -o "$(ProjectDir)PortableUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Portable" PortableApi.i
del /Q ..\..\..\Managed\DotNet\OSGeo.MapGuide.Portable\PortableUnmanagedApi.cs
copy /Y "$(ProjectDir)..\..\..\..\..\Portable\bin\$(Configuration)64\MgPortable*.*" "$(TargetDir)\native\"
</Command>
@@ -99,7 +99,7 @@
</Command>
Modified: trunk/MgDev/Bindings/src/Bindings/DotNet/Web/WebApi.vcxproj
--- trunk/MgDev/Bindings/src/Bindings/DotNet/Web/WebApi.vcxproj 2023-03-20 12:54:05 UTC (rev 10033)
+++ trunk/MgDev/Bindings/src/Bindings/DotNet/Web/WebApi.vcxproj 2023-03-20 14:51:04 UTC (rev 10034)
@@ -61,7 +61,7 @@
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)WebConstants.xml" -l C# -o "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Web\Constants.cs" -t
"..\..\..\IMake\$(Platform)\$(Configuration)\bin\IMake.exe" -p "$(ProjectDir)WebApiGen.xml" -l C# -x "WebApi"
-"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module WebUnmanagedApi -o "$(ProjectDir)WebUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Web" WebApi.i
+"$(SWIG_DIR)\swig.exe" -c++ -csharp -DDOTNETCORE -DWIN32 -DSWIG_CSHARP_NO_EXCEPTION_HELPER -DSWIG_CSHARP_NO_STRING_HELPER -DSWIG_CSHARP_NO_WSTRING_HELPER -DSWIG_CSHARP_NO_WSTRING_EXCEPTION_HELPER -namespace OSGeo.MapGuide -nodefaultctor -nodefaultdtor -module WebUnmanagedApi -o "$(ProjectDir)WebUnmanagedApi_wrap.cpp" -outdir "$(ProjectDir)..\..\..\Managed\DotNet\OSGeo.MapGuide.Web" WebApi.i
del /Q ..\..\..\Managed\DotNet\OSGeo.MapGuide.Web\WebUnmanagedApi.cs
copy /Y "$(ProjectDir)..\..\..\..\..\Web\bin\$(Configuration)64\MgHttpHandler*.*" "$(TargetDir)\native\"
copy /Y "$(ProjectDir)..\..\..\..\..\Web\bin\$(Configuration)64\MgWebApp*.*" "$(TargetDir)\native\"
@@ -102,7 +102,7 @@
Modified: trunk/MgDev/setenvironment64.bat
--- trunk/MgDev/setenvironment64.bat 2023-03-20 12:54:05 UTC (rev 10033)
+++ trunk/MgDev/setenvironment64.bat 2023-03-20 14:51:04 UTC (rev 10034)
@@ -93,7 +93,7 @@
IF "%GNUWIN32%" == "" SET GNUWIN32=C:\Program Files (x86)\GnuWin32\bin
IF "%SEVENZ%" == "" SET SEVENZ=%MG_DEV%\BuildTools\WebTools\7-Zip
IF "%ANT_HOME%" == "" SET ANT_HOME=C:\apache-ant
-IF "%SWIG_DIR%" == "" SET SWIG_DIR=C:\swig\bin
+IF "%SWIG_DIR%" == "" SET SWIG_DIR=C:\swigwin-4.1.1
SET PATH=%PATH%;%DOXYGEN%;%GNUWIN32%;%SEVENZ%;%ANT_HOME%\bin
rem ==================================================
More information about the mapguide-commits
