[mapguide-commits] r10086 - sandbox/adsk/trunk/Common/MdfParser
svn_mapguide at osgeo.org
Sun Jul 28 19:43:26 PDT 2024
Author: christinebao
Date: 2024-07-28 19:43:25 -0700 (Sun, 28 Jul 2024)
New Revision: 10086
sandbox/adsk/trunk/Common/MdfParser/IOSupplementalSpatialContextInfo.cpp
Add Vertical CS in SupplementalSpatialContextInfo into XML.
Modified: sandbox/adsk/trunk/Common/MdfParser/IOSupplementalSpatialContextInfo.cpp
--- sandbox/adsk/trunk/Common/MdfParser/IOSupplementalSpatialContextInfo.cpp 2024-07-23 12:55:36 UTC (rev 10085)
+++ sandbox/adsk/trunk/Common/MdfParser/IOSupplementalSpatialContextInfo.cpp 2024-07-29 02:43:25 UTC (rev 10086)
@@ -27,7 +27,8 @@
ELEM_MAP_ENTRY(1, SupplementalSpatialContextInfo);
ELEM_MAP_ENTRY(2, Name);
ELEM_MAP_ENTRY(3, CoordinateSystem);
-ELEM_MAP_ENTRY(4, ExtendedData1);
+ELEM_MAP_ENTRY(4, VerticalCoordinateSystem);
+ELEM_MAP_ENTRY(5, ExtendedData1);
IOSupplementalSpatialContextInfo::IOSupplementalSpatialContextInfo(Version& version) : SAX2ElementHandler(version)
@@ -86,6 +87,10 @@
case eCoordinateSystem:
this->m_ssContextInfo->SetCoordinateSystem(ch);
break;
+ case eVerticalCoordinateSystem:
+ this->m_ssContextInfo->SetVerticalCoordinateSystem(ch);
+ break;
@@ -126,6 +131,11 @@
fd << EncodeString(ssContextInfo->GetCoordinateSystem());
fd << endStr(sCoordinateSystem) << std::endl;
+ // Property: VerticalCoordinateSystem
+ fd << tab.tab() << startStr(sVerticalCoordinateSystem);
+ fd << EncodeString(ssContextInfo->GetVerticalCoordinateSystem());
+ fd << endStr(sVerticalCoordinateSystem) << std::endl;
// Write any unknown XML / extended data
IOUnknown::Write(fd, ssContextInfo->GetUnknownXml(), version, tab);
More information about the mapguide-commits
