[mapguide-commits] r10163 - branches/4.0/MgDev
    svn_mapguide at osgeo.org
    Wed Aug  6 06:36:30 PDT 2025
Author: jng
Date: 2025-08-06 06:36:29 -0700 (Wed, 06 Aug 2025)
New Revision: 10163
   branches/4.0/MgDev/cmake_build.sh
Enable parallelism on CMake build
Modified: branches/4.0/MgDev/cmake_build.sh
--- branches/4.0/MgDev/cmake_build.sh	2025-08-02 17:58:36 UTC (rev 10162)
+++ branches/4.0/MgDev/cmake_build.sh	2025-08-06 13:36:29 UTC (rev 10163)
@@ -129,5 +129,5 @@
     cmake "$SOURCE_DIR" -DMG_VERSION_MAJOR=$MG_VERSION_MAJOR -DMG_VERSION_MINOR=$MG_VERSION_MINOR -DMG_VERSION_RELEASE=$MG_VERSION_RELEASE -DMG_VERSION_REV=$MG_REV -DMG_INSTALL_PREFIX=$MG_INST_PREFIX -DMG_CPU=$BUILD_CPU -DWITH_JAVA=TRUE -DUSE_LD_GOLD=$USE_LD_GOLD -DSANITIZE_ADDRESS=$USE_ASAN -DPHP_VER=$PHP_VER -DHTTPD_VER=$HTTPD_VER -DCMAKE_BUILD_TYPE=$BUILD_CONFIG -DMG_OEM_WORK_DIR=$OEM_WORK_DIR -DMG_LINUXAPT_WORK_DIR=$LINUXAPT_WORK_DIR -DINTERNAL_XERCES=$INTERNAL_XERCES -DINTERNAL_ACE=$INTERNAL_ACE -DINTERNAL_ZLIB=$INTERNAL_ZLIB -DINTERNAL_JPEG=$INTERNAL_JPEG -DINTERNAL_PNG=$INTERNAL_PNG -DINTERNAL_FREETYPE=$INTERNAL_FREETYPE -DINTERNAL_GD=$INTERNAL_GD -DINTERNAL_JSON=$INTERNAL_JSON -DINTERNAL_GEOS=$INTERNAL_GEOS -DCOMMON_SUBSET_ONLY=$COMMON_SUBSET_ONLY -DWITH_PORTABLE=$ENABLE_MG_PORTABLE -DWITH_PHP_MBSTRING_SHARED=$WITH_PHP_MBSTRING_SHARED
     check_build
 fi
-cmake --build .
+cmake --build . --parallel $(($(nproc --all) - 1))
 check_build
\ No newline at end of file
More information about the mapguide-commits
