[mapguide-commits] r10165 - in branches/4.0/MgDev/Portable: . Localization OSGeo.MapGuide.Viewer/Properties OSGeo.MapGuide.Viewer.Portable/Properties UnitTest
    svn_mapguide at osgeo.org
    Sat Aug  9 08:53:42 PDT 2025
Author: jng
Date: 2025-08-09 08:53:42 -0700 (Sat, 09 Aug 2025)
New Revision: 10165
Added:
   branches/4.0/MgDev/Portable/PortableUnmanagedApi/
   branches/4.0/MgDev/Portable/TestData/
Removed:
   branches/4.0/MgDev/Portable/DesktopTestData/
   branches/4.0/MgDev/Portable/DesktopUnmanagedApi/
   branches/4.0/MgDev/Portable/Localization/configuration.xml
   branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/Properties/AssemblyInfo.cs
   branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/Properties/AssemblyInfo.cs
   branches/4.0/MgDev/Portable/UnitTest/CMakeLists.txt
   branches/4.0/MgDev/Portable/UnitTest/UnitTest.vcxproj
More Desktop -> Portable renames
Modified: branches/4.0/MgDev/Portable/Localization/configuration.xml
--- branches/4.0/MgDev/Portable/Localization/configuration.xml	2025-08-09 15:40:38 UTC (rev 10164)
+++ branches/4.0/MgDev/Portable/Localization/configuration.xml	2025-08-09 15:53:42 UTC (rev 10165)
@@ -1,9 +1,9 @@
 <root>
 	<configuration name="MgAppLayout">
-		<assembly name="OSGeo.MapGuide.Viewer" folder="MapViewer" namespace="OSGeo.MapGuide.Viewer" />
-        <assembly name="OSGeo.MapGuide.Viewer.Desktop" folder="MapViewer.Desktop" namespace="OSGeo.MapGuide.Viewer.Desktop" />
+		<assembly name="OSGeo.MapGuide.Viewer" folder="OSGeo.MapGuide.Viewer" namespace="OSGeo.MapGuide.Viewer" />
+        <assembly name="OSGeo.MapGuide.Viewer.Portable" folder="OSGeo.MapGuide.Viewer.Portable" namespace="OSGeo.MapGuide.Viewer.Portable" />
-		<keyfile>..\DesktopUnmanagedApi\DotNet\MgPortable.snk</keyfile>
+		<keyfile>..\PortableUnmanagedApi\DotNet\MgPortable.snk</keyfile>
 		<versionassembly>..\bin\Release\MgAppLayout.exe</versionassembly>
 		<sourcefolder>..</sourcefolder>
 		<outputfolder>compiled</outputfolder>
Modified: branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/Properties/AssemblyInfo.cs
--- branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/Properties/AssemblyInfo.cs	2025-08-09 15:40:38 UTC (rev 10164)
+++ branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/Properties/AssemblyInfo.cs	2025-08-09 15:53:42 UTC (rev 10165)
@@ -35,4 +35,4 @@
 [assembly: AssemblyVersion("4.0.0.0")]
 [assembly: AssemblyFileVersion("4.0.0.0")]
-[assembly: AssemblyKeyFile("..\\DesktopUnmanagedApi\\DotNet\\MgPortable.snk")]
+[assembly: AssemblyKeyFile("..\\PortableUnmanagedApi\\DotNet\\MgPortable.snk")]
Modified: branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/Properties/AssemblyInfo.cs
--- branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/Properties/AssemblyInfo.cs	2025-08-09 15:40:38 UTC (rev 10164)
+++ branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/Properties/AssemblyInfo.cs	2025-08-09 15:53:42 UTC (rev 10165)
@@ -35,4 +35,4 @@
Modified: branches/4.0/MgDev/Portable/UnitTest/CMakeLists.txt
--- branches/4.0/MgDev/Portable/UnitTest/CMakeLists.txt	2025-08-09 15:40:38 UTC (rev 10164)
+++ branches/4.0/MgDev/Portable/UnitTest/CMakeLists.txt	2025-08-09 15:53:42 UTC (rev 10165)
@@ -63,5 +63,5 @@
 file(GLOB_RECURSE UNIT_TEST_FILES "${MG_UNIT_TEST_DATA_DIR}/*.*")
 file(COPY ${UNIT_TEST_FILES} DESTINATION ${CMAKE_CURRENT_BINARY_DIR}/../UnitTestFiles)
-file(GLOB_RECURSE PT_UNIT_TEST_FILES "${CMAKE_CURRENT_SOURCE_DIR}/../DesktopTestData/*.*")
+file(GLOB_RECURSE PT_UNIT_TEST_FILES "${CMAKE_CURRENT_SOURCE_DIR}/../TestData/*.*")
 file(COPY ${PT_UNIT_TEST_FILES} DESTINATION ${CMAKE_CURRENT_BINARY_DIR}/../UnitTestFiles)
\ No newline at end of file
Modified: branches/4.0/MgDev/Portable/UnitTest/UnitTest.vcxproj
--- branches/4.0/MgDev/Portable/UnitTest/UnitTest.vcxproj	2025-08-09 15:40:38 UTC (rev 10164)
+++ branches/4.0/MgDev/Portable/UnitTest/UnitTest.vcxproj	2025-08-09 15:53:42 UTC (rev 10165)
@@ -109,7 +109,7 @@
 xcopy /S /Y /I ..\..\UnitTest\TestData\ResourceService\*.* $(OutDir)..\UnitTestFiles\
 xcopy /S /Y /I ..\..\UnitTest\TestData\Symbology\*.* $(OutDir)..\UnitTestFiles\
 xcopy /S /Y /I ..\..\UnitTest\TestData\TileService\*.* $(OutDir)..\UnitTestFiles\
-xcopy /S /Y /I ..\DesktopTestData\*.* $(OutDir)..\UnitTestFiles\
+xcopy /S /Y /I ..\TestData\*.* $(OutDir)..\UnitTestFiles\
 copy /Y  $(OutDir)..\UnitTestFiles\UT_Parcels.sdf copy /Y  $(OutDir)..\UnitTestFiles\UT_Parcels_Writeable.sdf
 xcopy /S /Y /I ..\..\Oem\CsMap\CsMapDev\Dictionaries\*.csd $(OutDir)Dictionaries\
 xcopy /S /Y /I ..\..\Oem\CsMap\CsMapDev\Dictionaries\*.gdc $(OutDir)Dictionaries\
@@ -157,7 +157,7 @@
@@ -205,7 +205,7 @@
@@ -257,7 +257,7 @@
More information about the mapguide-commits
