[mapguide-commits] r10176 - in branches/4.0/MgDev: Bindings/src/Managed/DotNet/OSGeo.MapGuide.Portable Portable/OSGeo.MapGuide.Viewer Portable/OSGeo.MapGuide.Viewer/Properties Portable/OSGeo.MapGuide.Viewer.Portable Portable/OSGeo.MapGuide.Viewer.Portable/Properties
svn_mapguide at osgeo.org
Thu Aug 21 09:07:02 PDT 2025
Author: jng
Date: 2025-08-21 09:07:01 -0700 (Thu, 21 Aug 2025)
New Revision: 10176
Added:
branches/4.0/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Portable/README.md
branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/README.md
branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/README.md
branches/4.0/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Portable/OSGeo.MapGuide.Portable.csproj
branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/OSGeo.MapGuide.Viewer.Portable.csproj
branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/Properties/AssemblyInfo.cs
branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/OSGeo.MapGuide.Viewer.csproj
branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/Properties/AssemblyInfo.cs
Add README.md files for MgPortable and viewer packages. Also remove strong naming on viewer assemblies
Modified: branches/4.0/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Portable/OSGeo.MapGuide.Portable.csproj
--- branches/4.0/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Portable/OSGeo.MapGuide.Portable.csproj 2025-08-21 13:39:07 UTC (rev 10175)
+++ branches/4.0/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Portable/OSGeo.MapGuide.Portable.csproj 2025-08-21 16:07:01 UTC (rev 10176)
@@ -16,6 +16,8 @@
<PackageLicenseExpression></PackageLicenseExpression>
<PackageLicenseFile>License.txt</PackageLicenseFile>
<Description>A portable implementation of the MapGuide platform and APIs for use in console/desktop applications.</Description>
+ <Title>MapGuide Portable</Title>
+ <PackageReadmeFile>README.md</PackageReadmeFile>
</PropertyGroup>
<PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|AnyCPU'">
@@ -41,37 +43,28 @@
Visual Studio
<ItemGroup>
- <None Update="contentFiles\Platform.ini"
- Pack="true"
- PackagePath="contentFiles\any\any\Platform.ini">
+ <None Update="contentFiles\Platform.ini" Pack="true" PackagePath="contentFiles\any\any\Platform.ini">
<PackageCopyToOutput>true</PackageCopyToOutput>
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
<CopyToPublishDirectory>Always</CopyToPublishDirectory>
</None>
- <None Update="Dictionaries\*"
- Pack="true"
- PackagePath="contentFiles\any\any">
+ <None Include="README.md" Pack="true" PackagePath="" />
+ <None Update="Dictionaries\*" Pack="true" PackagePath="contentFiles\any\any">
</None>
- <None Update="FDO\**\*"
- Pack="true"
+ <None Update="FDO\**\*" Pack="true" PackagePath="contentFiles\any\any">
</None>
- <None Update="Resources\*"
- Pack="true"
+ <None Update="Resources\*" Pack="true" PackagePath="contentFiles\any\any">
</None>
- <None Update="Schema\*"
- Pack="true"
+ <None Update="Schema\*" Pack="true" PackagePath="contentFiles\any\any">
Added: branches/4.0/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Portable/README.md
--- branches/4.0/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Portable/README.md (rev 0)
+++ branches/4.0/MgDev/Bindings/src/Managed/DotNet/OSGeo.MapGuide.Portable/README.md 2025-08-21 16:07:01 UTC (rev 10176)
@@ -0,0 +1,17 @@
+# MapGuide Portable
+MapGuide Portable (formerly known as `mg-desktop`) is a portable implementation of the MapGuide Platform that has no dependencies on a MapGuide Server or Web Tier.
+All the necessary components and services for building geospatial applications such as feature data access and map rendering/stylization are contained in the MapGuide Portable library itself.
+As such, MapGuide Portable is geared for building self-contained console/desktop geospatial applications.
+## Migrating your application from `mg-desktop`
+After removing `mg-desktop` and replacing it with this nuget package, the code migration process is simply renaming a bunch of classes and namespaces.
+ * The namespace is now `OSGeo.MapGuide.Portable` instead of `OSGeo.MapGuide.Desktop`
+ * Classes starting with `Mgd` now start with `MgPortable`
+ * eg. `MgPortableMap` instead of `MgdMap`
+After doing these code changes, your application should now build and run as before.
\ No newline at end of file
Modified: branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/OSGeo.MapGuide.Viewer.csproj
--- branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/OSGeo.MapGuide.Viewer.csproj 2025-08-21 13:39:07 UTC (rev 10175)
+++ branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/OSGeo.MapGuide.Viewer.csproj 2025-08-21 16:07:01 UTC (rev 10176)
@@ -16,6 +16,7 @@
<Description>Base WinForms viewer component package for MapGuide</Description>
</PropertyGroup>
<PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|AnyCPU'">
@@ -41,6 +42,7 @@
</ItemGroup>
<ItemGroup>
<None Include="..\..\License.txt">
<Pack>True</Pack>
<PackagePath></PackagePath>
@@ -53,4 +55,11 @@
<ProjectReference Include="..\..\Bindings\src\Managed\DotNet\OSGeo.MapGuide.PlatformBase\OSGeo.MapGuide.PlatformBase.csproj" />
</ItemGroup>
+ <ItemGroup>
+ <None Update="README.md">
+ <Pack>True</Pack>
+ <PackagePath>\</PackagePath>
+ </None>
+ </ItemGroup>
</Project>
Modified: branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/Properties/AssemblyInfo.cs
--- branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/Properties/AssemblyInfo.cs 2025-08-21 13:39:07 UTC (rev 10175)
+++ branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/Properties/AssemblyInfo.cs 2025-08-21 16:07:01 UTC (rev 10176)
@@ -33,6 +33,4 @@
// by using the '*' as shown below:
// [assembly: AssemblyVersion("4.0.0.0")]
-[assembly: AssemblyFileVersion("4.0.0.0")]
-[assembly: AssemblyKeyFile("..\\PortableUnmanagedApi\\DotNet\\MgPortable.snk")]
+[assembly: AssemblyFileVersion("4.0.0.0")]
Added: branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/README.md
--- branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/README.md (rev 0)
+++ branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer/README.md 2025-08-21 16:07:01 UTC (rev 10176)
@@ -0,0 +1,15 @@
+# MapGuide Viewer Component Library
+This library provides the base Windows Forms viewer components
+for building an interactive desktop map viewer application on the
+MapGuide Platform.
+By itself this library does nothing without a platform provider. You
+require a platform provider package in addition to this package that
+connects your map viewer components to the underlying MapGuide Platform
+that will provide the necessary services for rendering, feature querying, etc.
+Currently, there is only one platform provider package:
+ * `OSGeo.MapGuide.Viewer.Portable`
+ * Connects these map viewer components to the MapGuide Portable implementation of the MapGuide Platform.
Modified: branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/OSGeo.MapGuide.Viewer.Portable.csproj
--- branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/OSGeo.MapGuide.Viewer.Portable.csproj 2025-08-21 13:39:07 UTC (rev 10175)
+++ branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/OSGeo.MapGuide.Viewer.Portable.csproj 2025-08-21 16:07:01 UTC (rev 10176)
@@ -15,9 +15,11 @@
<Description>Integrates the WinForms viewer package with MapGuide Portable</Description>
</PropertyGroup>
<ItemGroup>
<Pack>True</Pack>
@@ -37,5 +39,12 @@
<ProjectReference Include="..\..\Bindings\src\Managed\DotNet\OSGeo.MapGuide.Portable\OSGeo.MapGuide.Portable.csproj" />
<ProjectReference Include="..\OSGeo.MapGuide.Viewer\OSGeo.MapGuide.Viewer.csproj" />
</ItemGroup>
+ <ItemGroup>
+ <Pack>True</Pack>
+ </None>
+ </ItemGroup>
</Project>
Modified: branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/Properties/AssemblyInfo.cs
--- branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/Properties/AssemblyInfo.cs 2025-08-21 13:39:07 UTC (rev 10175)
+++ branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/Properties/AssemblyInfo.cs 2025-08-21 16:07:01 UTC (rev 10176)
@@ -34,5 +34,3 @@
Added: branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/README.md
--- branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/README.md (rev 0)
+++ branches/4.0/MgDev/Portable/OSGeo.MapGuide.Viewer.Portable/README.md 2025-08-21 16:07:01 UTC (rev 10176)
@@ -0,0 +1,4 @@
+# MapGuide Portable Platform Provider for the MapGuide Viewer Component Library
+This package is the platform provider for the MapGuide Viewer Component Library
+that connects it to the services provided by MapGuide Portable.
More information about the mapguide-commits
