[mapguide-commits] r10180 - in branches/4.0/MgDev/Oem/php: . include/Zend include/ext/hash include/ext/standard include/main include/main/streams include/win32 lib script
svn_mapguide at osgeo.org
Fri Aug 29 02:27:36 PDT 2025
Author: jng
Date: 2025-08-29 02:27:35 -0700 (Fri, 29 Aug 2025)
New Revision: 10180
branches/4.0/MgDev/Oem/php/PROVENANCE.TXT
branches/4.0/MgDev/Oem/php/include/Zend/zend.h
branches/4.0/MgDev/Oem/php/include/Zend/zend_cpuinfo.h
branches/4.0/MgDev/Oem/php/include/Zend/zend_multiply.h
branches/4.0/MgDev/Oem/php/include/Zend/zend_portability.h
branches/4.0/MgDev/Oem/php/include/Zend/zend_types.h
branches/4.0/MgDev/Oem/php/include/Zend/zend_vm_def.h
branches/4.0/MgDev/Oem/php/include/Zend/zend_vm_execute.h
branches/4.0/MgDev/Oem/php/include/ext/hash/php_hash_xxhash.h
branches/4.0/MgDev/Oem/php/include/ext/standard/basic_functions_arginfo.h
branches/4.0/MgDev/Oem/php/include/main/config.w32.h
branches/4.0/MgDev/Oem/php/include/main/php_streams.h
branches/4.0/MgDev/Oem/php/include/main/php_version.h
branches/4.0/MgDev/Oem/php/include/main/streams/php_stream_context.h
branches/4.0/MgDev/Oem/php/include/win32/signal.h
branches/4.0/MgDev/Oem/php/lib/php8.lib
branches/4.0/MgDev/Oem/php/script/phpize.js
Update PHP devel package
Modified: branches/4.0/MgDev/Oem/php/PROVENANCE.TXT
--- branches/4.0/MgDev/Oem/php/PROVENANCE.TXT 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/PROVENANCE.TXT 2025-08-29 09:27:35 UTC (rev 10180)
@@ -1,6 +1,6 @@
The contents of this directory originate from the PHP 8.3.20 development package SDK with key headers patched for ACE compatbility.
-https://windows.php.net/downloads/releases/php-devel-pack-8.3.20-nts-Win32-vs16-x64.zip
-sha256: db1ed03b76c5f7e7a2f08ca7904e3184a9f278813f510fa9869e68e2453c40e3
+https://windows.php.net/downloads/releases/php-devel-pack-8.3.25-nts-Win32-vs16-x64.zip
+sha256: 3af2f9661d0995d8adf4d9fb906929ca01aeaea3db2efc5e56fa618a7f98af6d
Refer to CHANGES.TXT for details on what was patched
\ No newline at end of file
Modified: branches/4.0/MgDev/Oem/php/include/Zend/zend.h
--- branches/4.0/MgDev/Oem/php/include/Zend/zend.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/Zend/zend.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -20,7 +20,7 @@
#ifndef ZEND_H
#define ZEND_H
-#define ZEND_VERSION "4.3.20"
+#define ZEND_VERSION "4.3.25"
#define ZEND_ENGINE_3
Modified: branches/4.0/MgDev/Oem/php/include/Zend/zend_cpuinfo.h
--- branches/4.0/MgDev/Oem/php/include/Zend/zend_cpuinfo.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/Zend/zend_cpuinfo.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -126,58 +126,86 @@
* functions */
ZEND_NO_SANITIZE_ADDRESS
static inline int zend_cpu_supports_sse2(void) {
+#ifdef __aarch64__
+ return 0;
+#else
#if PHP_HAVE_BUILTIN_CPU_INIT
__builtin_cpu_init();
#endif
return __builtin_cpu_supports("sse2");
+#endif
static inline int zend_cpu_supports_sse3(void) {
+#ifdef __aarch64__
+ return 0;
+#else
#endif
return __builtin_cpu_supports("sse3");
+#endif
static inline int zend_cpu_supports_ssse3(void) {
+#ifdef __aarch64__
+ return 0;
+#else
#endif
return __builtin_cpu_supports("ssse3");
+#endif
static inline int zend_cpu_supports_sse41(void) {
+#ifdef __aarch64__
+ return 0;
+#else
#endif
return __builtin_cpu_supports("sse4.1");
+#endif
static inline int zend_cpu_supports_sse42(void) {
+#ifdef __aarch64__
+ return 0;
+#else
#endif
return __builtin_cpu_supports("sse4.2");
+#endif
static inline int zend_cpu_supports_avx(void) {
+#ifdef __aarch64__
+ return 0;
+#else
#endif
return __builtin_cpu_supports("avx");
+#endif
static inline int zend_cpu_supports_avx2(void) {
+#ifdef __aarch64__
+ return 0;
+#else
#endif
return __builtin_cpu_supports("avx2");
+#endif
#if PHP_HAVE_AVX512_SUPPORTS
Modified: branches/4.0/MgDev/Oem/php/include/Zend/zend_multiply.h
--- branches/4.0/MgDev/Oem/php/include/Zend/zend_multiply.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/Zend/zend_multiply.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -176,13 +176,15 @@
__asm__ ("mull %3\n\tadcl $0,%1"
: "=&a"(res), "=&d" (m_overflow)
: "%0"(res),
- "rm"(size));
+ "rm"(size)
+ : "cc");
} else {
__asm__ ("mull %3\n\taddl %4,%0\n\tadcl $0,%1"
: "%0"(res),
"rm"(size),
- "rm"(offset));
+ "rm"(offset)
+ : "cc");
if (UNEXPECTED(m_overflow)) {
@@ -211,7 +213,8 @@
"adc $0,%1"
: "%0"(res),
- "rm"(size));
+ "rm"(size)
+ : "cc");
} else {
__asm__ ("mul" LP_SUFF " %3\n\t"
"add %4,%0\n\t"
@@ -219,7 +222,8 @@
: "%0"(res),
"rm"(size),
- "rm"(offset));
+ "rm"(offset)
+ : "cc");
#undef LP_SUFF
Modified: branches/4.0/MgDev/Oem/php/include/Zend/zend_portability.h
--- branches/4.0/MgDev/Oem/php/include/Zend/zend_portability.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/Zend/zend_portability.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -761,7 +761,9 @@
/** @deprecated */
#define ZEND_CGG_DIAGNOSTIC_IGNORED_END ZEND_DIAGNOSTIC_IGNORED_END
-#if defined(__STDC_VERSION__) && (__STDC_VERSION__ >= 201112L) /* C11 */
+#if defined(__cplusplus)
+# define ZEND_STATIC_ASSERT(c, m) static_assert((c), m)
+#elif defined(__STDC_VERSION__) && (__STDC_VERSION__ >= 201112L) /* C11 */
# define ZEND_STATIC_ASSERT(c, m) _Static_assert((c), m)
#else
Modified: branches/4.0/MgDev/Oem/php/include/Zend/zend_types.h
--- branches/4.0/MgDev/Oem/php/include/Zend/zend_types.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/Zend/zend_types.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -731,6 +731,18 @@
} while (0)
+#define GC_TRY_DTOR_NO_REF(p) \
+ do { \
+ zend_refcounted_h *_p = &(p)->gc; \
+ if (!(_p->u.type_info & GC_IMMUTABLE)) { \
+ if (zend_gc_delref(_p) == 0) { \
+ rc_dtor_func((zend_refcounted *)_p); \
+ } else { \
+ gc_check_possible_root_no_ref((zend_refcounted *)_p); \
+ } while (0)
#define GC_TYPE_MASK 0x0000000f
#define GC_FLAGS_MASK 0x000003f0
#define GC_INFO_MASK 0xfffffc00
Modified: branches/4.0/MgDev/Oem/php/include/Zend/zend_vm_def.h
--- branches/4.0/MgDev/Oem/php/include/Zend/zend_vm_def.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/Zend/zend_vm_def.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -5236,6 +5236,11 @@
name = Z_STR_P(&key);
+ zend_ulong tmp;
+ if (ZEND_HANDLE_NUMERIC(name, tmp)) {
+ name = NULL;
@@ -6157,17 +6162,22 @@
zval *val;
if (HT_IS_PACKED(ht) && (zend_hash_num_elements(result_ht) == 0 || HT_IS_PACKED(result_ht))) {
- zend_hash_extend(result_ht, result_ht->nNumUsed + zend_hash_num_elements(ht), 1);
- ZEND_HASH_FILL_PACKED(result_ht) {
- ZEND_HASH_PACKED_FOREACH_VAL(ht, val) {
- if (UNEXPECTED(Z_ISREF_P(val)) &&
- UNEXPECTED(Z_REFCOUNT_P(val) == 1)) {
- val = Z_REFVAL_P(val);
- Z_TRY_ADDREF_P(val);
- ZEND_HASH_FILL_ADD(val);
- } ZEND_HASH_FOREACH_END();
- } ZEND_HASH_FILL_END();
+ /* zend_hash_extend() skips initialization when the number of elements is 0,
+ * but the code below expects that result_ht is initialized as packed.
+ * We can just skip the work in that case. */
+ if (result_ht->nNumUsed + zend_hash_num_elements(ht) > 0) {
+ zend_hash_extend(result_ht, result_ht->nNumUsed + zend_hash_num_elements(ht), 1);
+ ZEND_HASH_FILL_PACKED(result_ht) {
+ ZEND_HASH_PACKED_FOREACH_VAL(ht, val) {
+ if (UNEXPECTED(Z_ISREF_P(val)) &&
+ UNEXPECTED(Z_REFCOUNT_P(val) == 1)) {
+ val = Z_REFVAL_P(val);
+ Z_TRY_ADDREF_P(val);
+ ZEND_HASH_FILL_ADD(val);
+ } ZEND_HASH_FOREACH_END();
+ } ZEND_HASH_FILL_END();
} else {
zend_string *key;
@@ -6281,6 +6291,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
array = EX_VAR(opline->result.var);
if (OP1_TYPE != IS_UNUSED) {
size = opline->extended_value >> ZEND_ARRAY_SIZE_SHIFT;
@@ -8980,7 +8991,6 @@
value = (zval*)((char*)ht->arData + (opline->extended_value & ~(ZEND_BIND_REF|ZEND_BIND_IMPLICIT|ZEND_BIND_EXPLICIT)));
if (opline->extended_value & ZEND_BIND_REF) {
- i_zval_ptr_dtor(variable_ptr);
if (UNEXPECTED(!Z_ISREF_P(value))) {
zend_reference *ref = (zend_reference*)emalloc(sizeof(zend_reference));
GC_SET_REFCOUNT(ref, 2);
@@ -8995,9 +9005,11 @@
ref->sources.ptr = NULL;
Z_REF_P(value) = ref;
Z_TYPE_INFO_P(value) = IS_REFERENCE_EX;
+ i_zval_ptr_dtor(variable_ptr);
ZVAL_REF(variable_ptr, ref);
} else {
Z_ADDREF_P(value);
ZVAL_REF(variable_ptr, Z_REF_P(value));
if (OP2_TYPE != IS_UNUSED) {
FREE_OP2();
Modified: branches/4.0/MgDev/Oem/php/include/Zend/zend_vm_execute.h
--- branches/4.0/MgDev/Oem/php/include/Zend/zend_vm_execute.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/Zend/zend_vm_execute.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -2355,6 +2355,11 @@
+ zend_ulong tmp;
+ name = NULL;
@@ -2652,17 +2657,22 @@
zval *val;
} else {
zend_string *key;
@@ -7424,6 +7434,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
if (IS_CONST != IS_UNUSED) {
@@ -9765,6 +9776,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -10695,6 +10707,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -12161,6 +12174,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -20189,6 +20203,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
if (IS_TMP_VAR != IS_UNUSED) {
@@ -20633,6 +20648,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -21094,6 +21110,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -21498,6 +21515,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -25327,6 +25345,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
if (IS_VAR != IS_UNUSED) {
@@ -27777,6 +27796,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -29855,6 +29875,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -32165,6 +32186,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -34399,6 +34421,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
if (IS_UNUSED != IS_UNUSED) {
@@ -36281,6 +36304,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -36918,6 +36942,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -38776,6 +38801,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -40548,7 +40574,6 @@
@@ -40563,9 +40588,11 @@
} else {
Z_ADDREF_P(value);
if (opline->op2_type != IS_UNUSED) {
FREE_OP(opline->op2_type, opline->op2.var);
@@ -43871,6 +43898,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
if (IS_CV != IS_UNUSED) {
@@ -47511,6 +47539,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -49480,6 +49509,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
@@ -52998,6 +53028,7 @@
uint32_t size;
USE_OPLINE
+ SAVE_OPLINE();
Modified: branches/4.0/MgDev/Oem/php/include/ext/hash/php_hash_xxhash.h
--- branches/4.0/MgDev/Oem/php/include/ext/hash/php_hash_xxhash.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/ext/hash/php_hash_xxhash.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -18,7 +18,7 @@
#define PHP_HASH_XXHASH_H
#define XXH_INLINE_ALL 1
-#include "xxhash.h"
+#include "xxhash/xxhash.h"
typedef struct {
XXH32_state_t s;
Modified: branches/4.0/MgDev/Oem/php/include/ext/standard/basic_functions_arginfo.h
--- branches/4.0/MgDev/Oem/php/include/ext/standard/basic_functions_arginfo.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/ext/standard/basic_functions_arginfo.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -1,5 +1,5 @@
/* This is a generated file, edit the .stub.php file instead.
- * Stub hash: 7389d094a842a2289cd32cb37386e5e40ea7e031 */
+ * Stub hash: 60960e59f6310521a958b6fb0917650854d19612 */
ZEND_BEGIN_ARG_WITH_RETURN_TYPE_INFO_EX(arginfo_set_time_limit, 0, 1, _IS_BOOL, 0)
ZEND_ARG_TYPE_INFO(0, seconds, IS_LONG, 0)
Modified: branches/4.0/MgDev/Oem/php/include/main/config.w32.h
--- branches/4.0/MgDev/Oem/php/include/main/config.w32.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/main/config.w32.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -145,7 +145,7 @@
/* values determined by configure.js */
/* Windows build system version */
-#define PHP_BUILD_SYSTEM "Microsoft Windows Server 2019 Datacenter [10.0.17763]"
+#define PHP_BUILD_SYSTEM "Microsoft Windows Server 2022 Datacenter [10.0.20348]"
/* Configure line */
#define CONFIGURE_COMMAND "cscript /nologo /e:jscript configure.js \"--enable-snapshot-build\"" " \"--enable-debug-pack\" \"--disable-zts\" \"--with-pdo-oci=..\\..\\..\\..\\instantclient\\sdk,shared\"" " \"--with-oci8-19=..\\..\\..\\..\\instantclient\\sdk,shared\" \"--enable-object-out-dir=../obj/\"" " \"--enable-com-dotnet=shared\" \"--without-analyzer\" \"--with-pgo\""
Modified: branches/4.0/MgDev/Oem/php/include/main/php_streams.h
--- branches/4.0/MgDev/Oem/php/include/main/php_streams.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/main/php_streams.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -223,6 +223,9 @@
/* whether stdio cast flushing is in progress */
uint16_t fclose_stdiocast_flush_in_progress:1;
+ /* whether fatal error happened and all operations should terminates as soon as possible */
+ uint16_t fatal_error:1;
char mode[16]; /* "rwb" etc. ala stdio */
uint32_t flags; /* PHP_STREAM_FLAG_XXX */
Modified: branches/4.0/MgDev/Oem/php/include/main/php_version.h
--- branches/4.0/MgDev/Oem/php/include/main/php_version.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/main/php_version.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -2,7 +2,7 @@
/* edit configure.ac to change version number */
#define PHP_MAJOR_VERSION 8
#define PHP_MINOR_VERSION 3
-#define PHP_RELEASE_VERSION 20
+#define PHP_RELEASE_VERSION 25
#define PHP_EXTRA_VERSION ""
-#define PHP_VERSION "8.3.20"
-#define PHP_VERSION_ID 80320
+#define PHP_VERSION "8.3.25"
+#define PHP_VERSION_ID 80325
Modified: branches/4.0/MgDev/Oem/php/include/main/streams/php_stream_context.h
--- branches/4.0/MgDev/Oem/php/include/main/streams/php_stream_context.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/main/streams/php_stream_context.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -59,7 +59,8 @@
const char *wrappername, const char *optionname);
PHPAPI void php_stream_context_set_option(php_stream_context *context,
const char *wrappername, const char *optionname, zval *optionvalue);
+void php_stream_context_unset_option(php_stream_context *context,
+ const char *wrappername, const char *optionname);
PHPAPI php_stream_notifier *php_stream_notification_alloc(void);
PHPAPI void php_stream_notification_free(php_stream_notifier *notifier);
END_EXTERN_C()
Modified: branches/4.0/MgDev/Oem/php/include/win32/signal.h
--- branches/4.0/MgDev/Oem/php/include/win32/signal.h 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/include/win32/signal.h 2025-08-29 09:27:35 UTC (rev 10180)
@@ -10,6 +10,7 @@
#define SIGPROF 27 /* profiling time alarm */
PHP_WINUTIL_API void php_win32_signal_ctrl_handler_init(void);
+PHP_WINUTIL_API void php_win32_signal_ctrl_handler_request_shutdown(void);
PHP_WINUTIL_API void php_win32_signal_ctrl_handler_shutdown(void);
#endif /* PHP_WIN32_SIGNAL_H */
Modified: branches/4.0/MgDev/Oem/php/lib/php8.lib
(Binary files differ)
Modified: branches/4.0/MgDev/Oem/php/script/phpize.js
--- branches/4.0/MgDev/Oem/php/script/phpize.js 2025-08-29 09:18:24 UTC (rev 10179)
+++ branches/4.0/MgDev/Oem/php/script/phpize.js 2025-08-29 09:27:35 UTC (rev 10180)
@@ -3,9 +3,9 @@
var VC_VERSION=1929
var PHP_VERSION=8
var PHP_MINOR_VERSION=3
-var PHP_RELEASE_VERSION=20
+var PHP_RELEASE_VERSION=25
var PHP_EXTRA_VERSION=""
-var PHP_VERSION_STRING="8.3.20"
+var PHP_VERSION_STRING="8.3.25"
/* Generated extensions list with mode (static/shared) */
PHP_BCMATH_SHARED=false;
More information about the mapguide-commits
