[mapguide-commits] r10114 - branches/4.0/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jan 29 22:39:46 PST 2025
Author: jng
Date: 2025-01-29 22:39:45 -0800 (Wed, 29 Jan 2025)
New Revision: 10114
   branches/4.0/MgDev/cmake_linuxapt.sh
Add support for building httpd against static openssl
Modified: branches/4.0/MgDev/cmake_linuxapt.sh
--- branches/4.0/MgDev/cmake_linuxapt.sh	2025-01-05 11:18:01 UTC (rev 10113)
+++ branches/4.0/MgDev/cmake_linuxapt.sh	2025-01-30 06:39:45 UTC (rev 10114)
@@ -24,6 +24,7 @@
 OEM_WORK_DIR=~/mapguide_oem_build
 LINUXAPT_WORK_DIR=~/mapguide_linuxapt_build
 USE_CCACHE=0
+USE_STATIC_OPENSSL=0
 while [ $# -gt 0 ]; do    # Until you run out of parameters...
     case "$1" in
         --prefix)
@@ -38,6 +39,9 @@
             LINUXAPT_WORK_DIR="$2"
             shift
+        --with-static-openssl)
+            USE_STATIC_OPENSSL=1
         # "infecting" our ccache with root-elevated cached object files is probably a bad look
         # especially if we need to non-elevated ccache builds further down the road
         #--with-ccache)
@@ -176,8 +180,14 @@
         mv "${LA_WORKDIR}/apr-util-$APR_UTIL_VER" "${LA_WORKDIR}/httpd-$HTTPD_VER/srclib/apr-util"
     fi
     cd "${HTTPD_WORKDIR}" || exit
-    echo "Configuring HTTPD"
-    ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/apache2" --enable-mods-shared-all --with-included-apr --with-port=${HTTPD_PORT} 2>&1 | tee "$LINUXAPT_WORK_DIR/configure_httpd_fake.log"
+    if [ "$USE_STATIC_OPENSSL" = "1" ];
+    then
+        echo "Configuring HTTPD (with static openssl)"
+        ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/apache2" --with-ssl=/usr/local --enable-ssl --enable-ssl-staticlib-deps --enable-mods-static=ssl --with-included-apr --with-port=${HTTPD_PORT} 2>&1 | tee "$LINUXAPT_WORK_DIR/configure_httpd_fake.log"
+    else
+        echo "Configuring HTTPD"
+        ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/apache2" --enable-mods-shared-all --with-included-apr --with-port=${HTTPD_PORT} 2>&1 | tee "$LINUXAPT_WORK_DIR/configure_httpd_fake.log"
+    fi
     check_build
     echo "Building HTTPD. Please wait"
     make 2>&1 | tee "$LINUXAPT_WORK_DIR/make_httpd_fake.log"
More information about the mapguide-commits mailing list
